H3C S3100-52P Command Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Command Manual-Release 1602(V1.01)
10-Port Isolation Command
10-Port Isolation Command 14.21 KB
Chapter 1  Port Isolation Configuration Commands
1.1  Port Isolation Configuration Commands
1.1.1  display isolate port
View
None
Use the display isolate port command to display the Ethernet ports assigned to the isolation group.
# Display information about the Ethernet ports added to the isolation group.
<Sysname> display isolate port
 Isolated port(s) on UNIT 1:
 Ethernet1/0/2, Ethernet1/0/3, Ethernet1/0/4
The information above shows that Ethernet1/0/2, Ethernet1/0/3, and Ethernet1/04 are in the isolation group. Neither Layer-2 nor Layer-3 packets can be exchanged between these ports.
1.1.2  port isolate
port isolate
undo port isolate
View
Ethernet port view
None
Use the port isolate command to add an Ethernet port to the isolation group.
Use the undo port isolate command to remove an Ethernet port from the isolation group.
By default, the isolation group contains no port.
# Add Ethernet1/0/1 to the isolation group.
[Sysname] interface ethernet1/0/1
[Sysname-Ethernet1/0/1] port isolate
[Sysname-Ethernet1/0/1] quit
[Sysname] interface ethernet1/0/2
[Sysname-Ethernet1/0/2] port isolate
After the configuration, packets cannot be exchanged between Ethernet 1/0/1 and Ethernet 1/0/2.
# Remove Ethernet1/0/2 from the isolation group.
[Sysname-Ethernet1/0/2] undo port isolate
