H3C S3100-52P Command Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Command Manual-Release 1602(V1.01)
09-Link Aggregation Command
09-Link Aggregation Command 46.83 KB
Chapter 1  Link Aggregation Configuration Commands
1.1  Link Aggregation Configuration Commands
1.1.1  display link-aggregation interface
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
interface-type: Port type.
interface-number: Port number.
to: Specifies a port index range, with the two interface-type interface-number argument pairs around it as the two ends.
Use the display link-aggregation interface command to display the link aggregation details about a specified port or port range.
Note that as ports in a manual link aggregation groups do not acquire the information about their peers automatically, so the entries in the information about the peer ports displayed are all 0 instead of the actual values.
# Display the link aggregation details on Ethernet 1/0/1.
<Sysname> display link-aggregation interface Ethernet1/0/1
 Ethernet1/0/1:
   Selected AggID: 1
   Local:
     Port-Priority: 32768, Oper key: 2, Flag: 0x45
   Remote:
     System ID: 0x8000, 0000-0000-0000
     Port Number: 0, Port-Priority: 32768 , Oper-key: 0, Flag: 0x38
   Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
   Sent LACP Packets: 0 packet(s)
Table 1-1 Description on the fields of the display link-aggregation interface command
Selected AggID
ID of the aggregation group to which the specified port belongs
Local
Information about the local end
Port-Priority
Port priority
Oper key
Operation key
Flag
Protocol status flag
Remote
Information about the remote end
System ID
Remote device ID
Port number
Port number
Statistics about received, invalid, and sent LACP packets
1.1.2  display link-aggregation summary
View
None
Use the display link-aggregation summary command to display summary information of all aggregation groups.
# Display summary information of all aggregation groups.
<Sysname> display link-aggregation summary
Aggregation Group Type:D -- Dynamic, S -- Static , M -- Manual
Actor ID: 0x8000, 000f-e20f-5104
  AL  AL   Partner ID            Select Unselect Share Master
  ID  Type                         Ports  Ports     Type  Port
  1   S    0x8000,0000-0000-0000 0      1        NonS  Ethernet1/0/2
  2   M    none                     0      1        NonS  Ethernet1/0/3
Table 1-2 Description on the fields of the display link-aggregation summary command
Aggregation group type: D for dynamic, S for static, and M for manual
Loadsharing Type
Load sharing type: Shar for load sharing and NonS for non-load sharing
Actor ID
Local device ID
AL ID
Aggregation group ID
AL Type
Aggregation group type: D (dynamic), S (static), or M (manual)
Partner ID
ID of the remote device, including the system priority and system MAC address of the remote device
For a device belonging to an dynamic aggregation group or static aggregation group, if no LACP packet is received, the partner ID is displayed as 0x8000, 0000-0000-0000.
Select Ports
Number of the selected ports
Unselect Ports
Number of the unselected ports
Share Type
Load sharing type: Shar (load-sharing), or NonS (non-load-sharing)
Master Port
the smallest port number in an aggregation group
1.1.3  display link-aggregation verbose
display link-aggregation verbose [ agg-id ]
View
agg-id: Aggregation group ID to be displayed, which ranges from 1 to 416 and must be the ID of an existing aggregation group.
Use the display link-aggregation verbose command to display the details about a specified aggregation group or all aggregation groups.
# Display the details about aggregation group 1.
<Sysname> display link-aggregation verbose 1
Flags:  A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregation ID: 1,  AggregationType: Manual,   Loadsharing Type: NonS
Aggregation Description:
System ID: 0x8000, 000f-e214-000a
Port Status: S -- Selected,  U -- Unselected
Local:
Port                     Status  Priority  Key    Flag
Ethernet1/0/2            S       32768     1      {}
Ethernet1/0/3            U       32768     1      {}
Remote:
Actor                    Partner Priority Key   SystemID                 Flag
Ethernet1/0/2          0         0         0      0x0000,0000-0000-0000 {}
Ethernet1/0/3          0         0         0      0x0000,0000-0000-0000 {}
Table 1-3 Description on the fields of the display link-aggregation verbose command
Loadsharing Type
Loadsharing type, including Loadsharing and Non-Loadsharing
Flags
Flag types of LACP
Aggregation ID
Aggregation group description string
AggregationType
System ID
Device ID
Port Status
Port status, including selected and unselected
1.1.4  display lacp system-id
View
None
Use the display lacp system-id command to display the device ID of the local system, including the system priority and the MAC address.
# Display the device ID of the local system.
<Sysname> display lacp system-id
 Actor System ID: 0x8000, 000f-e20f-0100
The Actor System ID field is the device ID (consisting of the system priority and the system MAC address) of the local system.
1.1.5  lacp enable
lacp enable
undo lacp enable
View
Ethernet port view
None
Use the lacp enable command to enable LACP on the current port.
Use the undo lacp enable command to disable LACP.
By default, LACP is disabled on a port.
# Enable the LACP protocol on Ethernet 1/0/1.
[Sysname] interface Ethernet1/0/1
[Sysname-Ethernet1/0/1] lacp enable
1.1.6  lacp port-priority
lacp port-priority port-priority
undo lacp port-priority
View
Ethernet port view
port-priority: Port priority, ranging from 0 to 65,535.
Use the lacp port-priority command to set the priority of the current port.
Use the undo lacp port-priority command to restore the default port priority.
By default, the port priority is 32,768.
You can use the display link-aggregation verbose command or the display link-aggregation interface command to check the configuration result.
# Set the priority of Ethernet 1/0/1 to 64.
[Sysname-Ethernet1/0/1] lacp port-priority 64
1.1.7  lacp system-priority
lacp system-priority system-priority
undo lacp system-priority
View
system-priority: System priority, ranging from 0 to 65,535.
Use the lacp system-priority command to set the system priority.
Use the undo lacp system-priority command to restore the default system priority.
By default, the system priority is 32,768.
# Set the system priority to 64.
[Sysname] lacp system-priority 64
1.1.8  link-aggregation group description
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
agg-id: Aggregation group ID, in the range of 1 to 416.
agg-name: Aggregation group description, a string of 1 to 32 characters.
Use the link-aggregation group description command to set a description for an aggregation group.
Use the undo link-aggregation group description command to remove the description of an aggregation group.
&  Note:
If you have saved the current configuration with the save command, after system reboot, the configuration concerning manual and static aggregation groups and their descriptions still exists, but that of the dynamic aggregation groups and their descriptions gets lost.
You can use the display link-aggregation verbose command to check the configuration result.
# Set the description abc for aggregation group 1.
[Sysname] link-aggregation group 1 description abc
1.1.9  link-aggregation group mode
link-aggregation group agg-id mode { manual | static }
View
manual: Creates a manual aggregation group.
static: Creates a static aggregation group.
Use the link-aggregation group mode command to create a manual or static aggregation group.
Use the undo link-aggregation group command to remove the specified aggregation group.
Related commands: display link-aggregation summary.
# Create manual aggregation group 22
[Sysname] link-aggregation group 22 mode manual
1.1.10  port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
Use the port link-aggregation group command to add the current Ethernet port to a manual or static aggregation group.
Use the undo port link-aggregation group command to remove the current Ethernet port from the aggregation group.
Related commands: display link-aggregation verbose.
# Add Ethernet 1/0/1 to aggregation group 22.
[Sysname-Ethernet1/0/1] port link-aggregation group 22
1.1.11  reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Use the reset lacp statistics command to clear LACP statistics on specified port(s), or on all ports if no port is specified.
Related commands: display link-aggregation interface.
# Clear LACP statistics on all Ethernet ports.
<Sysname> reset lacp statistics
