H3C S3100-52P Command Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Command Manual-Release 1602(V1.01)
07-GVRP Command
07-GVRP Command 80.41 KB
Chapter 1  GVRP Configuration Commands
1.1  GARP Configuration Commands
1.1.1  display garp statistics
display garp statistics [ interface interface-list ]
View
interface-list: Specifies a list of Ethernet ports for which the statistics about GARP are to be displayed. In this list, you can specify individual ports and port ranges. An individual port takes the form of interface-type interface-number and a port range takes the form of interface-type interface-number1 to interface-type interface-number2, with interface-number2 taking a value greater than interface-number1. The total number of individual ports and port ranges defined in the list must not exceed 10.
Use the display garp statistics command to display the GARP statistics of the specified or all ports. If the interface interface-list keyword-argument combination is not specified, this command displays the GARP statistics on all the ports.
The switch automatically collects statistics about GVRP packets sent, received and dropped on GVRP-enabled ports. Upon system reboot or the execution of the reset garp statistics command, the system automatically deletes the statistics and starts collecting statistics again. You can check whether GVRP is running normally on a port by checking the GVRP statistics on it:
l           If the number of received GVRP packets and the number of sent GVRP packets are the same as those on the remote port, it indicates that the ports are transmitting and receiving GVRP packets normally and no registration information is lost.
l           If the number of dropped GVRP packets is not 0, it indicates that the registration mode on the port may be fixed or forbidden. As in either mode dynamic VLANs cannot be registered, GVRP packet drop may occur on the port.
# Display the GARP statistics on Ethernet1/0/1 and Ethernet 1/0/2.
<Sysname> display garp statistics interface Ethernet 1/0/1 to Ethernet 1/0/2
        GARP statistics on port Ethernet1/0/1
        Number Of GVRP Frames Received          : 0
        Number Of GVRP Frames Transmitted       : 0
        Number Of Frames Discarded              : 0
        GARP statistics on port Ethernet1/0/2
Table 1-1 Description on the fields of the display garp statistics command
Number of GVRP Frames Received
Number of the GVRP frames received on the port
Number of GVRP Frames Transmitted
Number of the GVRP frames transmitted through the port
Number of Frames Discarded
Number of GVRP frames discarded by the port
1.1.2  display garp timer
display garp timer [ interface interface-list ]
View
interface-list: Specifies a list of Ethernet ports of which the GARP timer settings are to be displayed. In this list, you can specify individual ports and port ranges. An individual port takes the form of interface-type interface-number and a port range takes the form of interface-type interface-number1 to interface-type interface-number2, with interface-number2 taking a value greater than interface-number1. The total number of individual ports and port ranges defined in the list must not exceed 10.
Use the display garp timer command to display the settings of the GARP timers on specified ports or all ports.
If the interface interface-list keyword-argument combination is not specified, this command displays the GARP timer settings of all ports.
This command displays the settings of the following timers:
l           Join timer
l           Leave timer
l           LeaveAll timer
l           Hold timer
Related commands: garp timer, garp timer leaveall.
# Display the settings of the GARP timers on port Ethernet1/0/1.
<Sysname> display garp timer interface Ethernet 1/0/1
                Garp Join Time          : 20 centiseconds
                Garp Leave Time         : 60 centiseconds
                Garp LeaveAll Time      : 1000 centiseconds
                Garp Hold Time          : 10 centiseconds
1.1.3  garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
Ethernet port view
hold: Sets the GARP Hold timer.
join: Sets the GARP Join timer.
leave: Sets the GARP Leave timer.
timer-value: Timeout time (in centiseconds) of the GARP timer (Hold, Join or Leave) to be set.
Use the garp timer command to set a GARP timer (that is, the Hold timer, the Join timer, or the Leaver timer) for an Ethernet port.
Use the undo garp timer command to restore the default setting of a GARP timer.
By default, the Hold, Join, and Leave timers are set to 10, 20, and 60 centiseconds.
Note that:
l           The setting of each timer must be a multiple of 5 (in centiseconds).
l           The timeout ranges of the timers vary depending on the timeout values you set for other timers. If you want to set the timeout time of a timer to a value out of the current range, you can set the timeout time of the associated timer to another value to change the timeout range of this timer.
The following table describes the relations between the timers:
Table 1-2 Relations between the timers
Timer
Lower threshold
Upper threshold
Hold
10 centiseconds
This upper threshold is less than or equal to one-half of the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
Join
This lower threshold is greater than or equal to twice the timeout time of the Hold timer. You can change the threshold by changing the timeout time of the Hold timer.
This upper threshold is less than one-half of the timeout time of the Leave timer. You can change the threshold by changing the timeout time of the Leave timer.
Leave
This lower threshold is greater than twice the timeout time of the Join timer. You can change the threshold by changing the timeout time of the Join timer.
This upper threshold is less than the timeout time of the LeaveAll timer. You can change the threshold by changing the timeout time of the LeaveAll timer.
LeaveAll
This lower threshold is greater than the timeout time of the Leave timer. You can change threshold by changing the timeout time of the Leave timer.
32,765 centiseconds
&  Note:
In networking, the following GARP timer settings are recommended:
l      GARP hold timer: 100 centiseconds (1 second)
l      GARP Join timer: 600 centiseconds (6 seconds)
l      GARP Leave timer: 3000 centiseconds (30 seconds)
Related commands: display garp timer.
# Set the GARP Join timer to 30 centiseconds for Ethernet1/0/1.
[Sysname-Ethernet1/0/1] garp timer join 30
1.1.4  garp timer leaveall
garp timer leaveall timer-value
undo garp timer leaveall
View
timer-value: Setting (in centiseconds) of the GARP LeaveAll timer. You need to set this argument with the Leave timer settings of other Ethernet ports as references. That is, this argument needs to be larger than the Leave timer settings of any Ethernet ports. Also note that this argument needs to be a multiple of 5 and cannot be larger than 32,765.
Use the garp timer leaveall command to set the GARP LeaveAll timer.
Use the undo garp timer leaveall command to restore the default setting of the GARP LeaveAll timer.
By default, the LeaveAll timer is set to 1,000 centiseconds, that is, 10 seconds.
&  Note:
In networking, you are recommended to set the GARP LeaveAll timer to 12000 centiseconds (2 minutes).
# Set the GARP LeaveAll timer to 100 centiseconds.
[Sysname] garp timer leaveall 100
1.1.5  reset garp statistics
reset garp statistics [ interface interface-list ]
View
interface-list: Specifies a list of Ethernet ports. In this list, you can specify individual ports and port ranges. An individual port takes the form of interface-type interface-number and a port range takes the form of interface-type interface-number1 to interface-type interface-number2, with interface-number2 taking a value greater than interface-number1. The total number of individual ports and port ranges defined in the list must not exceed 10.
Use the reset garp statistics command to clear the GARP statistics (including statistics about packets received/sent/discarded by GVRP) on the specified or all ports. You can use the display garp statistics command to view the NDP statistics before and after the execution of the reset garp statistics command to verify the execution result.
Executing the reset garp statistics command without any parameter clears the GARP statistics of all ports.
Related commands: display garp statistics.
# Clear GARP statistics of all ports.
<Sysname> reset garp statistics
1.2  GVRP Configuration Commands
1.2.1  display gvrp statistics
display gvrp statistics [ interface interface-list ]
View
interface interface-list: Specifies an Ethernet port list. By providing a value for this argument, you can display the GVRP statistics on the specified ports. You need to provide the interface-list argument in the format of { interface-type interface-number [ to interface-type interface-number ] } &<1-10>, where the interface-type argument represents the port type, the interface-number argument represents the port number, and & <1-10> means that you can provide up to 10 port indexes/port index ranges for this argument.
Note that, this command displays GVRP statistics only on the trunk ports included in the list. Statistics on non-trunk ports will not be displayed.
Use the display gvrp statistics command to display the GVRP statistics of trunk ports.
This command displays the following information:
l           GVRP status
l           Number of the GVRP entries that fail to be registered
l           Source MAC address of the previous GVRP PDU
l           GVRP registration type of a port
# Display the GVRP statistics of Ethernet1/0/1, assuming that the port is a trunk port.
<Sysname> display gvrp statistics interface Ethernet 1/0/1
        GVRP statistics on port Ethernet1/0/1
                GVRP Status                     : Enabled
                GVRP Failed Registrations       : 0
                GVRP Last Pdu Origin            : 0000-0000-0000
                GVRP Registration Type          : Normal
1.2.2  display gvrp status
display gvrp status
View
None
Use the display gvrp status command to display the global GVRP status (enabled or disabled).
# Display the global GVRP status.
<Sysname> display gvrp status
GVRP is enabled
The above information indicates that GVRP is enabled globally.
1.2.3  gvrp
gvrp
undo gvrp
View
System view, Ethernet port view
None
Use the gvrp command to enable GVRP globally (in system view) or for a port (in Ethernet port view).
Use the undo gvrp command to disable GVRP globally (in system view) or on a port (in Ethernet port view).
By default, GVRP is disabled both globally and on ports.
Note that:
l           To enable GVRP for a port, you need to enable GVRP globally first. GVRP does not take effect automatically on ports upon being enabled globally.
l           You can enable/disable GVRP only on trunk ports.
l           After you enable GVRP on a trunk port, you cannot change the port to other types.
Related commands: display gvrp status.
# Enable GVRP globally.
[Sysname] gvrp
# Enable GVRP on Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] gvrp
GVRP is enabled on port Ethernet1/0/5.
1.2.4  gvrp registration
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
Ethernet port view
fixed: Specifies the fixed GVRP registration mode. A port operating in this mode cannot register or deregister VLAN information dynamically. It only propagates static VLAN information. Besides, the port permits only static VLANs, that is, it propagates only static VLAN information to the other GARP members.
forbidden: Specifies the forbidden GVRP registration mode. A port operating in this mode cannot register or deregister VLAN information dynamically. It permits only VLAN 1, that is, it propagates only the information about VLAN 1 to the other GARP members.
normal: Specifies the normal mode. A port operating in this mode can dynamically register or deregister VLAN information and can propagate both dynamic and static VLAN information.
Use the gvrp registration command to configure the GVRP registration mode on a port.
Use the undo gvrp registration command to restore the default GVRP registration mode on a port.
By default, the GVRP registration mode is normal.
Note that these commands only apply to trunk ports.
Related commands: display gvrp statistics
# Configure Ethernet1/0/1 to operate in fixed GVRP registration mode.
[Sysname] interface Ethernet1/0/1
[Sysname-Ethernet1/0/1] gvrp registration fixed
