H3C S3100-52P Command Manual-Release 1602(V1.01)
HomeSupportSwitchesS3100 SeriesReference GuidesCommand ReferencesH3C S3100-52P Command Manual-Release 1602(V1.01)
38-Smart Link-Monitor Link Command
38-Smart Link-Monitor Link Command 64.2 KB
Chapter 1  Smart Link Configuration Commands
1.1  Smart Link Configuration Commands
1.1.1  display smart-link flush
View
None
Use the display smart-link flush command to view the information about how the Smart Link device processes flush messages.
# Display the information about how the Smart Link device processes flush messages.
<Sysname> display smart-link flush
Flush interface :Ethernet1/0/1
 Count of flush packets received               : 1
 Time of last flush packet received            : 22:52:23 2006/04/01
 Source MAC of last flush packet received      : 000f-e20f-5566
 Device ID of last flush packet received       : 000f-e20f-5566
 Control VLAN ID of last flush packet received : 1
Table 1-1 Description on the fields of the display smart-link flush command
Flush interface
Interface that receives the latest legal flush message
Total number of flush messages received
Time when the last legal flush message is received
Source MAC address in the last legal flush message received
Bridge MAC address of the device from which the last legal flush message was received
Control VLAN ID in the last legal flush message received
&  Note:
A legal flush message refers to the message whose control VLAN ID is consistent with the receiving control VLAN ID configured on the receiving port.
1.1.2  display smart-link group
display smart-link group { group-id | all }
View
group-id: Smart link group ID, in the range of 1 to 24.
all: Displays the information about all Smart Link groups.
Use the display smart-link group command to display the information about the specific Smart Link group or all the Smart Link groups.
# Display the information about Smart Link group 1.
<Sysname> display smart-link group 1
 Smart Link Group 1 information:
 Device ID: 000f-e212-3456              Control-VLAN ID: 1
 Member                    Role    State    Flush-count Last-flush-time
 Ethernet1/0/1             MASTER  ACTVIE   1           16:37:20 2006/04/21
 AGG-1                     SLAVE   STANDBY  2           17:45:20 2006/04/21
Table 1-2 Description on the fields of the display smart-link group command
Member
Member of the Smart Link group
Role
Port role of a Smart Link group member: master or slave.
Status
Port status of a Smart Link group member when the link of this member port is up: active or standby.
Flush-count
Number of sent flush messages
Last-flush-time
Time when the last flush message is sent. If no flush message is sent, “NA” will be displayed.
1.1.3  flush enable control-vlan
flush enable control-vlan vlan-id
undo flush enable
View
Smart Link group view
vlan-id: Control VLAN ID, in the range of 1 to 4,094.
Use the flush enable control-vlan command to enable the function of sending flush messages in the specified control VLAN.
Use the undo flush enable control-vlan command to disable the function of sending flush messages to the specified control VLAN.
By default, no control VLAN is specified.
# Configure to send flush messages within control VLAN 1.
[Sysname] smart-link group 1
[Sysname-smlk-group1] flush enable control-vlan 1
1.1.4  link-aggregation group
link-aggregation group group-id { master | slave }
undo link-aggregation group group-id
View
group-id: Link aggregation group ID, in the range of 1 to 416. Note that the specified link aggregation group can only be a static or manual one.
master: Specifies the specified link aggregation group as the master port of the Smart Link group.
slave: Specifies the specified link aggregation group as the slave port of the Smart Link group.
Use the link-aggregation group command to assign a link aggregation group to a member of the Smart Link group.
Use the undo link-aggregation group command to remove the specified link aggregation group from the current Smart Link group.
&  Note:
Because Smart Link and STP cannot be enabled on an Ethernet port at the same time, you must make sure that STP is disabled on the port before assigning the port to a smart link group.
# Configure link aggregation group 8 as the slave port of Smart Link group 1.
[Sysname-smlk-group1] link-aggregation group 8 slave
1.1.5  port
port interface-type interface-number { master | slave }
undo port interface-type interface-number
View
interface-type: Port type.
interface-number: Port number.
master: Specifies the specified port as the master port of the Smart Link group.
slave: Specifies the specified port as the slave port of the Smart Link group.
Use the port command to assign the specified port to a member of the Smart Link group.
Use the undo port command to remove the specified port from the Smart Link group.
The port you specified in this command cannot be a link aggregation group member port.
Besides assigning single ports to a smart link group, you can assign a link aggregation group (static or manual, but not dynamic) to a smart link group with the link-aggregation group command in smart link group view.
&  Note:
# Configure Ethernet 1/0/6 as the slave port of Smart Link group 1.
[Sysname-smlk-group1] port Ethernet 1/0/6 slave
1.1.6  port smart-link group
port smart-link group group-id { master | slave }
undo port smart-link group group-id
View
Ethernet port view
master: Specifies the port as the master port of the Smart Link group.
slave: Specifies the port as the slave port of the Smart Link group.
Use the port smart-link group command to assign the current port to a member of the Smart Link group.
Use the undo port smart-link group command to remove the current port from the specified Smart Link group.
The port where you configure the command cannot be a link aggregation group member port.
&  Note:
# Configure Ethernet 1/0/3 as the master port of Smart Link group 1.
[Sysname] interface Ethernet 1/0/3
[Sysname-Ethernet1/0/3] port smart-link group 1 master
1.1.7  reset smart-link packets counter
View
None
Use the reset smart-link packets counter command to clear the flush message statistics of Smart Link.
# Clear the flush message statistics of Smart Link.
<Sysname> reset smart-link packets counter
1.1.8  smart-link flush enable
l           In Ethernet port view:
smart-link flush enable control-vlan vlan-id
undo smart-link flush enable
l           In system view:
smart-link flush enable control-vlan vlan-id port interface-type interface-number [ to interface-type interface-number ]
undo smart-link flush enable port interface-type interface-number [ to interface-type interface-number ]
View
Ethernet port view, system view
Use the smart-link flush enable control-vlan command to enable the current/specified port to process flush messages received on the specified control VLAN.
Use the undo smart-link flush enable command to disable the port from processing flush messages.
l           The command executed in Ethernet port view has effect on the current port only.
l           The command executed in system view has effect on the specified port only.
If you configure different control VLANs on the same port, only the last one takes effect.
&  Note:
The VLAN configured as a control VLAN for sending or receiving flush messages must exist. You cannot directly remove the control VLAN. When a dynamic VLAN is configured as a control VLAN for the Smart Link group, this VLAN will become a static VLAN, and related prompt information is displayed.
# Enable Ethernet 1/0/4 to process flush messages received from control VLAN 1.
[Sysname] interface Ethernet 1/0/4
[Sysname-Ethernet1/0/4] smart-link flush enable control-vlan 1
# Enable Ethernet 1/0/5 through Ethernet 1/0/10 to process flush messages received from control VLAN 1.
[Sysname] smart-link flush enable control-vlan 1 port Ethernet 1/0/5 to Ethernet 1/0/10
1.1.9  smart-link group
undo smart-link group group-id
View
Use the smart-link group command to create a Smart Link group and enter Smart Link group view. If the specified Smart Link group exists, this command leads you into Smart Link group view directly.
Use the undo smart-link group command to remove the specified Smart Link group.
After creating a Smart Link group, you must configure member ports for this Smart Link group.
Related commands: port smart-link group, link-aggregation group, port.
&  Note:
Make sure that the Smart Link group has no members before executing the undo smart-link group command.
# Create a Smart Link group.
New Smart Link Group has been created.
Chapter 2  Monitor Link Configuration Commands
2.1  Monitor Link Configuration Commands
2.1.1  display monitor-link group
display monitor-link group { group-id | all }
View
group-id: Monitor Link group ID, ranging 1 to 24.
all: Specifies all the Monitor Link groups.
Use the display monitor-link group command to display Monitor Link group information.
# Display the information about Monitor Link group 1.
<Sysname> display monitor-link group 1
Monitor link group 1 information:
Member  Role       Status     Last-up-time          Last-down-time
SMLK-2  UPLINK     UP         16:37:20 2006/4/21   16:37:20 2006/4/20
AGG-1   DOWNLINK   UP
Table 2-1 Description on the fields of the display monitor-link group command
Member
Member of the Monitor Link group
Role
Role of Monitor Link group member port: UPLINK or DOWNLINK
Status
Status of Monitor Link group member port: UP or DOWN
Last-up-time
Last time the port is up
Last-down-time
Last time the port is down
2.1.2  link-aggregation group
link-aggregation group group-id { uplink | downlink }
View
Monitor Link group view
group-id: Link aggregation group ID, ranging from 1 to 416 (A link aggregation group can be a manual or static link aggregation group only).
uplink: Configures the specified link aggregation group as the uplink port of the Monitor Link group
downlink: Configures the specified link aggregation group as the downlink port of the Monitor Link group
Use the link-aggregation group command to configure the specified link aggregation group as a Monitor Link group member.
Use the undo link-aggregation group command to remove the specified link aggregation group from the current Monitor Link group.
In Monitor Link, a Monitor Link group member can be a single port, a manual or static link aggregation group, but not a dynamic link aggregation group. Uplink port can also be a Smart Link group.
Use this command only on the link aggregation groups that are not Smart Link group members.
&  Note:
A port or a link aggregation group cannot serve as a member port for two Smart Link groups. On the other hand, a port or a link aggregation group cannot serve as a member of a Smart Link group and a Monitor Link group at the same time. However, a Smart Link group can serve as the uplink member port of a Monitor Link group.
# Configure link aggregation group 8 as the downlink port of the Monitor Link group.
[Sysname] monitor-link group 1
[Sysname-mtlk-group1] link-aggregation group 8 downlink
2.1.3  monitor-link group
monitor-link group group-id
undo monitor-link group group-id
View
group-id: Monitor Link group ID, ranging from 1 to 24.
Use the monitor-link group command to create a Monitor Link group and enter Monitor Link group view.
Use the undo monitor-link group command to remove a Monitor Link group.
After the Monitor Link group is configured, member ports of the Monitor Link group need to be configured.
Related commands: port monitor-link group, link-aggregation group, smart-link group, port.
&  Note:
Make sure that the Monitor Link group has no members before executing the undo monitor-link group command.
# Create a Monitor Link group.
 New Monitor Link Group has been created.
2.1.4  port
port interface-type interface-number { uplink | downlink }
View
uplink: Configures the specified port as the uplink port of the Monitor Link group
downlink: Configures the specified port as the downlink port of the Monitor Link group
Use the port command to configure the specified port as a member of the Monitor Link group.
Use the undo port command to remove the specified port from the current Monitor Link group.
In Monitor Link, a Monitor Link group member can be a single port, a static link aggregation group, but not a dynamic link aggregation group. The uplink port of a Monitor Link group can also be a Smart Link group.
Do not use this command on member ports of a link aggregation group or a Smart Link group.
&  Note:
A port or a link aggregation group cannot serve as a member port for two Smart Link groups. On the other hand, a port or a link aggregation group cannot serve as a member for a Smart Link group and a Monitor Link group at the same time. However, a Smart Link group can serve as the uplink member port of a Monitor Link group.
# Configure Ethernet 1/0/7 as a downlink port of the Monitor Link group
[Sysname-mtlk-group1] port Ethernet 1/0/7 downlink
2.1.5  port monitor-link group
port monitor-link group group-id{ uplink | downlink }
undo port monitor-link group group-id
View
Ethernet port view
uplink: Configures the port as the uplink port of the specified Monitor Link group
downlink: Configures the port as the downlink port of the specified Monitor Link group
Use the port monitor-link group command to configure the current port as a member of the specified Monitor Link group.
Use the undo port monitor-link group command to remove the current port from the specified Monitor Link group.
In Monitor Link, a Monitor Link group member can be a single port, a static link aggregation group, but not a dynamic link aggregation group. Uplink port can also be a Smart Link group.
&  Note:
# Configure Ethernet 1/0/8 as a downlink port of Monitor Link group 1.
[Sysname] interface Ethernet 1/0/8
[Sysname-Ethernet1/0/8] port monitor-link group 1 downlink
2.1.6  smart-link group
smart-link group group-id uplink
View
group-id: Smart Link group ID, ranging 1 to 24.
uplink: Configures the specified Smart Link group as the uplink port of the Monitor Link group
Use the smart-link group command to configure the specified Smart Link group as the uplink port of the Monitor Link group.
Use the undo smart-link group command to remove the configuration.
A Smart Link group can belong to only one Monitor Link group and can be configured only as an uplink port of the Monitor Link group.
# Configure Smart Link group 1 as the uplink port of Monitor Link group 1.
[Sysname-mtlk-group1] smart-link group 1 uplink
