H3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
06-RPR Commands
06-RPR Commands 128.77 KB
Chapter 1  RPR Configuration Commands
1.1  RPR Configuration Commands
1.1.1  debugging rpr
debugging rpr { all | function }
undo debugging rpr { all | function }
View
Default Level
2: System level
all: All types of RPR debugging.
function: Debugging for RPR function information.
Use the debugging rpr command to enable the specified type of RPR debugging.
Use the undo debugging rpr command to disable the specified type of RPR debugging.
By default, all types of RPR debugging are disabled.
# Enable debugging for RPR.
<Sysname> debugging rpr all
1.1.2  debugging rpr interface
debugging rpr interface interface-type interface-number
undo debugging rpr interface [ interface-type interface-number ]
View
Default Level
2: System level
interface-type: Type of the RPR interface.
interface-number: Number of the RPR interface.
Use the debugging rpr interface command to enable debugging for the RPR interface.
Use the undo debugging rpr interface command to disable the debugging.
By default, debugging for the RPR interface is disabled.
# Enable debugging for the RPR logical interface Ten-GigabitEthernet 1/1/1.
<Sysname> debugging rpr interface Ten-GigabitEthernet 1/1/1
1.1.3  debugging rpr packet
debugging rpr packet { all | { atd | echo } { rx | tx } | { tc | tp } { rx | tx | burst } }
undo debugging rpr packet { all | { atd | echo } { rx | tx } | { tc | tp } { rx | tx | burst } }
View
Default Level
2: System level
all: Debugging for all RPR packets.
atd: Debugging for RPR ATD packets.
echo: Debugging for RPR Echo packets.
tc: Debugging for RPR TC packets.
tp: Debugging for RPR TP packets.
rx: Debugging for the received packets.
tx: Debugging for the sent packets.
burst: Debugging for all sub-modules.
Use the debugging rpr packet command to enable debugging for RPR packets of a specific type or all types.
Use the undo debugging rpr packet command to disable the debugging.
By default, debugging for RPR packets is disabled.
# Enable debugging for all RPR packets.
<sysname> debugging rpr packet all
1.1.4  debugging rpr sub-module
debugging rpr { error | event } sub-module { all | common | echo | fairness | if | ip | link | mac-table | protect | ring-select | timer | topology | vlan-tunnel | vrrp }
undo debugging rpr { error | event } sub-module { all | common | echo | fairness | if | ip | link | mac-table | protect | ring-select | timer | topology | vlan-tunnel | vrrp }
View
Default Level
2: System level
error: Debugging for RPR error information .
event: Debugging for RPR event information
sub-module: Debugging for a specific sub-module.
all: Debugging for all sub-modules.
common: Debugging for common modules.
echo: Debugging for echo sub-modules.
fairness: Debugging for fairness sub-modules.
if: Debugging for interface sub-modules.
ip: Debugging for IP sub-modules.
link: Debugging for link layer sub-modules.
mac-table: Debugging for MAC address table sub-modules.
protect: Debugging for protection sub-modules.
ring-select: Debugging for ring selection sub-modules.
timer: Debugging for timer sub-modules.
topology: Debugging for topology sub-modules.
vlan-tunnel: Debugging for sub-module of VLAN tunnel.
vrrp: Debugging for sub-module of VRRP.
Use the debugging rpr command to enable debugging for RPR error/event information for a sub-module or all modules.
Use the undo debugging rpr sub-module command to disable the debugging.
By default, the debugging is disabled.
# Enable debugging for RPR errors of all the sub-modules.
<Sysname> debugging rpr error sub-module all
1.1.5  display interface
display interface { RPRXGE | RPRPOS } interface-number
View
Default Level
1: Monitor level
RPRXGE: Displays RPRXGE port information.
RPRPOS: Displays RPRPOS port information.
interface-number: Port number.
Use the display interface command to display information about the specified RPR physical port.
# Display information about RPRPOS 4/1/2.
<Sysname> display interface rprpos 4/1/2
RPRPOS4/1/2 current state: UP
Description: RPRPOS4/1/2 Interface
The Maximum Transmit Unit is 1552
Optical module  state: RPR_PHYPOS_CONNECTOR
     SDH alarm:
        section layer:
        line    layer:
        path    layer:
     SDH Overhead  C2           J0       J1
        Rx         0x16
        Tx         0x16
     SDH Threshold:  sdber:  10e-5        sfber:  10e-3
     SDH error:
        section layer:  B1   7
        line    layer:  B2   1520
                        M1   31132
        path    layer:  B3   5
                        G1   2
 Host receive             Packets                Bytes
   unicast                      0                    0
   multicast                  172                11352
 Line receive             Packets                Bytes
   unicast                      0                    0
   multicast                  173                12110
 Host send                Packets                Bytes
   unicast                      0                    0
   multicast                    0                    0
 Line send                Packets                Bytes
   unicast                      0                    0
   multicast                    0                    0
Input Errors
   parity 0  short 0 crc 0 ringiderr 0
Output Errors
   parity 0  short 0 giant 0 fifo 0
Control Frame                   In                  Out
          Oam                    0                    0
          Atd                  851                  845
           Tc                 8518                 8456
           Tp                    4                 8524
         Mode              Packets                Bytes
      TtlDrop                 8521                   --
      TxFlood                    0                    0
      RxFlood                  173                12110
Last 300 second Host input:  0 packets/sec  104 bits/sec  0%
Last 300 second Line input:  0 packets/sec  112 bits/sec  0%
Last 300 second Host output:  0 packets/sec   0 bits/sec  0%
Last 300 second Line output:  0 packets/sec   0 bits/sec  0%
1.1.6  display rpr defect
display rpr defect [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an RPR logical interface by its type and number.
Use the display rpr defect command to display RPR error information.
If an RPR interface is specified, only the RPR defect information of the RPR station corresponding to the specified interface is displayed. If no interface is specified, the RPR defect information of the corresponding stations of all the RPR logical interfaces on your device is displayed.
# Display the ring defect information for interface Ten-GigabitEthernet 1/1/1.
<Sysname> display rpr defect Ten-GigabitEthernet 1/1/1
Rpr defects of the interface: Ten-GigabitEthernet 1/1/1
Amount of reserved bandwidth exceeded defect: ringlet0: 0, ringlet1: 0
Jumbo configuration defect:1
Maximum number of stations exceeded defect:0
Miscabling defect: ringlet0: 0, ringlet1: 0
Protection mode configuration defect:0
Inconsistent topology defect:0
Topology instability defect:0
IP address duplicate defect:0
Table 1-1 Description on the fields of the display rpr defect command
Defect information of the RPR station corresponding to the specified interface
Reserved bandwidth exceeded defect on Ringlet 0 and Ringlet 1: 0 means no defect; 1 means such defect is present.
The number 0 means no such defect; 1 means that such defect is present.
Miscabling defect
Fiber-optic miscabling defect on Ringlet 0 and Ringlet 1: 0 means no such defect; 1 means that such defect is present.
1.1.7  display rpr fairness
display rpr fairness [ interface-type interface-number ]
View
Default Level
1: Monitor level
interface-type interface-number: Specifies an interface by its type and number. It must be an RPR logical interface.
Use the display rpr fairness command to display information about RPR fairness parameters.
If no RPR logical interface specified, the RPR fairness parameters information of the RPR stations corresponding to all the RPR logical interfaces on your device is displayed. If an RPR logical interface is specified, only the RPR fairness parameters information of its corresponding RPR station is displayed.
# Display the RPR fairness parameters information for interface Ten-GigabitEthernet 1/1/1.
<Sysname> display rpr fairness Ten-GigabitEthernet 1/1/1
Rpr fairness parameters of the interface: Ten-GigabitEthernet1/1/1
  Station's fairness weight on ringlet0: 1
  Station's fairness weight on ringlet1: 1
  Local Reserved bandwidth for class A0 on ringlet0: 0Mbps
  Local Reserved bandwidth for class A0 on ringlet1: 0Mbps
  Local Rate-limiter bandwidth for high priority on ringlet0: 20Mbps
  Local Rate-limiter bandwidth for high priority on ringlet1: 20Mbps
  Local Rate-limiter bandwidth for medium priority on ringlet0: 0Mbps
  Local Rate-limiter bandwidth for medium priority on ringlet1: 0Mbps
  Local Rate-limiter bandwidth for low priority on ringlet0: 10000Mbps
  Local Rate-limiter bandwidth for low priority on ringlet1: 10000Mbps
  Total Reserved bandwidth for class A0 on ringlet0: 0Mbps
  Total Reserved bandwidth for class A0 on ringlet1: 0Mbps
Table 1-2 Description on the fields of the display rpr fairness command
RPR fairness parameters information of the station corresponding to the specified interface
The fairness weight of the current station on Ringlet 0
The fairness weight of the current station on Ringlet 1
Bandwidth reserved by the current station for the subclass A0 service on Ringlet 0
Bandwidth reserved by the current station  for the subclass A0 service on Ringlet 1
Rate limit setting of the station for the class A1 service on Ringlet 0
Rate limit setting of the station for the class A1 service on Ringlet 1
Rate limit setting of the station for the class B CIR service on Ringlet 0
Rate limit setting of the station for the class B CIR service on Ringlet 1
Rate limit setting of the station for the class B EIR and class C services on Ringlet 0
Rate limit setting of the station for the class B EIR and class C services on Ringlet 1
Total bandwidth reserved by all the stations on the ring for the class A0 service on Ringlet 0
Total bandwidth reserved by all the stations on the ring for the class A0 service on Ringlet 1
1.1.8  display rpr protection
display rpr protection [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display rpr protection command to display RPR protection information.
If an interface is specified, only the RPR protection information of its corresponding RPR station is displayed. If no interface is specified, the RPR protection information of all the RPR stations on your device is displayed.
  Caution:
The protection mode comes with configured protection mode and effective protection mode. Configured protection mode is administratively configured but does not necessarily take effect. RPR automatically checks the protection modes of all the stations to ensure consistency of effective protection mode on the ring.
# Display RPR protection information.
<Sysname> display rpr protection
Protection information of the interface: Ten-GigabitEthernet1/1/1
Protection mode configured: steer
Protection mode effective: steer
Protection reversion mode: revertive
Context containment active:0
MAC address of the last east neighbour:0000-0000-0000
-0000-0000
MAC address of the last west neighbour:0000-0000-0000
-0000-0000
Protection State of the east span:sf
Protection State of the west span:sf
Edge status of the east span: true
 the east span: true
st span: true
: true
Edge status of the west span: true
The number of protections on the east span:1
The number of protections on the west span:1
Last protection time on the east span:
Last protection time on the west span:
Protection start time on the east span:2007.07.25 04:51:13
04:51:13
Protection start time on the west span:2007.07.25 04:51:13
Table 1-3 Description on the fields of the display rpr protection command
RPR protection information of the station corresponding to the specified interface.
Protection mode configured administratively.
Protection mode that is taking effect.
Protection reversion mode.
Indicates whether the CC mechanism is taking effect: 0 for active, 1 for inactive.
MAC address of the adjacent station on the east.
MAC address of the adjacent station on the west.
Protection state of the east span.
Protection state of the west span.
Indicates whether the east span is an edge. If it is, true is displayed; if not, false is displayed.
Indicates whether the west span is an edge. If it is, true is displayed; if not, false is displayed.
Number of protection reversions on the east span.
Number of protection reversions on the west span.
Time when the last protection reversion occurred on the east span.
Time when the last protection reversion occurred on the west span.
Starting time of the protection reversion occurring on the east span.
Starting time of the protection reversion occurring on the west span.
1.1.9  display rpr rs-table
display rpr rs-table { default | dynamic | ipv6 | overall | static | vrrp } [ interface-type interface-number ]
View
Default Level
1: Monitor level
default: Displays information about the default ringlet selection table.
dynamic: Displays information about the dynamic ringlet selection table.
ipv6: Displays information about the IPv6 ringlet selection table.
overall: Displays information about the overall ringlet selection table.
static: Displays information about the static ringlet selection table.
vrrp: Displays information about the VRRP ringlet selection table.
Use the display rpr rs-table command to display information about RPR ringlet selection table.
If an RPR interface is specified, only the RPR ringlet selection table information of its corresponding RPR station is displayed. If no interface is specified, the ringlet selection table information of all the RPR stations on your device is displayed.
# Display information about the dynamic ringlet selection tables of all RPR stations on your device.
<Sysname> display rpr rs-table dynamic
Dynamic ringlet selection table of interface: Ten-GigabitEthernet 1/1/1
MAC-Address       Ringlet    TTL    IP-Address         Station-Name
00e0-fc57-3640       0         1       0.0.0.0
---   Total entries: 1   ---
# Display information about the static ringlet selection tables of all RPR stations on your device.
<Sysname> display rpr rs-table static
Static ringlet selection table of interface: Ten-GigabitEthernet1/1/1
MAC-Address      Ringlet   Valid
0003-0002-0002      0        0
Table 1-4 Description on the fields of the display rpr rs-table command
Dynamic ringlet selection table of the station corresponding to the specified interface
Static ringlet selection table of the station corresponding to the specified interface
MAC-Address
Destination MAC address
Ringlet
Sending ringlet: 0 for Ringlet 0, 1 for Ringlet 1.
TTL
Time to live. Number of hops for reaching the destination.
IP-Address
IP address of the destination
Station-Name
Name of the destination station
Valid
Indicates whether the entry is valid: 1 for valid, 0 for invalid.
1.1.10  display rpr statistics
display rpr statistics { dmac | smac } [ mac-address ] [ interface-type interface-number ]
View
Default Level
1: Monitor level
dmac: Displays traffic statistics by destination MAC address.
smac: Displays traffic statistics by source MAC address.
mac-address: Source or destination MAC address, in the format of H-H-H.
Use the display rpr statistics command to display the statistics about traffic on RPR rings for specified or all RPR stations on the device.
l           If the dmac is specified, the statistics of traffic destined to the destination is displayed; if the smac is specified, the statistics of traffic received by the source is displayed
l           If the mac-address is not specified, the statistics of all the traffic destined to or received by the stations on the ringlet is displayed.
l           If the interface-type interface-number argument is not specified, the traffic statistics of all the RPR stations on your device is displayed.
l           If the interface-type interface-number argument is specified, only the traffic statistics of the RPR station corresponding to the specified interface is displayed.
# Display traffic statistics sent out from the stations whose MAC address is 00E0-FC00-1A01 on the ring.
<Sysname> display rpr statistics smac 00e0-fc00-1a01
Source statistics of interface: Ten-GigabitEthernet 1/1/1
Mac address: 00e0-fc00-1a01 Packets: 0 Bytes: 0
Table 1-5 Description on the fields of the display rpr statistics command
Traffic statistics (based on source MAC address) of the station corresponding to the specified interface
Destination statistics of interface
Traffic statistics (based on destination MAC address) of the station corresponding to the specified interface
Mac address
MAC address of the source or destination
Packets
Number of packets sent or received
Bytes
Number of bytes sent or received
1.1.11  display rpr timers
display rpr timers [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display rpr timer command to display RPR timers.
If an interface is specified, only the RPR timers for its corresponding RPR station are displayed. If no interface is specified, the RPR timers for all the RPR stations on your device are displayed.
# Display the settings of all RPR timers.
<Sysname> display rpr timers
All the timers' value of interface: Ten-GigabitEthernet1/1/1
TP fast timer: 10ms
TP slow timer: 100ms
TC fast timer: 5ms
TC slow timer: 10ms
ATD timer: 1s
WTR timer: 10s
Holdoff timer: 0ms
Keepalive timer: 10ms
Topology stability timer: 40ms
Table 1-6 Description on the fields of the display rpr timers command
All the timers’ value of interface
All RPR timers for the station corresponding to the specified interface
TP fast timer
Value of the TP fast timer
TP slow timer
Value of the TP slow timer
TC fast timer
Value of the TC fast timer
TC slow timer
Value of the TC slow timer
ATD timer
Value of the ATD timer
WTR timer
Value of the WTR timer
Holdoff timer
Value of the hold-off timer
Keepalive timer
Value of the keepalive timer
Value of the topology stability timer
1.1.12  display rpr topology
display rpr topology { all | local | ring | stations } [ summary ] [ interface-type interface-number ]
View
Default Level
1: Monitor level
all: Displays all topology information.
local: Displays the topology information of the local station.
ring: Displays the ring topology information.
stations: Displays the topology information of all the stations on the ring.
summary: Displays the RPR topology summary.
Use the display rpr topology command to display RPR topology information.
If an RPR logical interface is specified, only the topology information of its corresponding RPR station is displayed. If no interface is specified, the topology information of all the RPR stations on your device is displayed.
# Display all topology information.
<Sysname> display rpr topology all
Ring topology information on interface:Ten-GigabitEthernet1/1/1
  Stations on ringlet0:1
  Stations on ringlet1:1
  Total stations on ring:2
  Jumbo preference:regular
  Ring topology type:closed ring
Local station topology information on interface:Ten-GigabitEthernet1/1/1
  Mac address:00e0-fc00-1801
  Station name:
  Ip address: 0.0.0.0  Jumbo preference:regular
  Current protection mode:steer
  Protection state on west:idle
  Protection state on east:idle
  Edge status on west: false
  Edge status on east: false
  Sequence number:1
  Last known neighbour on west:00e0-fc00-1c01
  Last known neighbour on east:00e0-fc00-1c01
  Local topology state:topology is valid
Station topology information on interface:Ten-GigabitEthernet1/1/1
Station entry on ringlet0
  Mac address:00e0-fc00-1c01
  Station name:
  Ip address: 0.0.0.0  Hops:1
  Protection mode:steer
  Sequence number:1
  Reachability:reachable
  Valid:1
Station entry on ringlet1
  Station name:
  Sequence number:1
  Valid:1
Table 1-7 Description of the fields of the display rpr topology all command
Ring topology information of the station corresponding to the specified interface
Number of stations on Ringlet 0
Number of stations on Ringlet 1.
Total number of stations on the ring.
Jumbo preference
Whether Jumbo frames are supported. Regular means not supported, jumbo means supported.
Ring topology type
Ring status, either open ring or closed ring.
Local topology information of the station corresponding to the specified interface.
Mac address
MAC address of the station.
Station name
Station name.
Ip address
IP address of the station.
Protection mode of the station.
Edge status on west
Edge status on east
Sequence number
Sequence number of TP frame.
Learned neighbour MAC address on west.
Learned neighbour MAC address on east.
It could be start (for topology initializing), stable, unstable, valid, or invalid.
Topology information of other stations on the same ring to which the specified interface belongs.
Topology information of neighbour on the west span.
Topology information of neighbour on the east span.
MAC-Address
IP address
Hops
Number of hops from the specified station to the local station.
Protection mode
Edge status on west
Edge status on east
Reachability
Indicates whether the station is reachable.
Valid
Indicates whether the entries are valid or not: 1 for valid, 0 for invalid.
# Display the topology summary.
<Sysname> display rpr topology all summary
Topology information items
Pse:protection state, east       Psw:protection state, west
Ese:edge state, east             Esw:edge state, west
Wc:wrap protection configured    Jp:jumbo frame preferred
Ringlet0 Ringlet1 Ring Jumbo-Prefer Topology-Type
 1         1      2    regular      closed ring
MAC-Address     Pse  Psw  Ese Esw   Wc  Jp IP-Address        Station-Name
00e0-fc00-1801  idle idle  0   0    0   0  0.0.0.0
00e0-fc00-1c01  idle idle  0   0  0   0  0.0.0.0
Table 1-8 Description on the fields of the display rpr topology summary command
Items of topology information
Edge state of the east span. 1 means that edge occurs; 0 means that edge does not occur
Edge state of the west span. 1 means that edge occurs; 0 means that edge does not occur
Wrap protection mode: 0 means no Wrap protection is set; 1 means the Wrap protection is set
Whether Jumbo frames are supported. 1 means supported, 0 means not supported
Topology information of ring specified by the interface
Ringlet0
Number of stations on the west span
Ringlet1
Number of stations on the east span
Ring
Total stations on the ring
Jumbo-Prefer
Topology-Type
Summary of local topology information of the station that corresponds to the specified interface
MAC-Address
IP-Address
Station-Name
Station name
Summary of topology information of other stations on the same ring to which the specified interface belongs
Summary of topology information of the neighbour stations on the west span
Summary of topology information of the neighbour stations on the east span
# Display the topology information of the local station.
<Sysname>display rpr topology local
  Station name:
  Sequence number:1
Table 1-9 Description on the fields of the display rpr topology local command
Topology information of the local stations mapping to the logical interfaces of the device
Mac address
Station name
Station name
Ip address
Jumbo preference
Edge status on west
Edge status on east
Sequence number
Sequence number of TP frames
Last learned neighbour MAC address on west
Last learned neighbour MAC address on east
Start means topology is initiating; stable means topology is stable; unstable means topology is not stable; valid means topology is valid; invalid means topology is not valid.
# Display the ring topology information.
<Sysname>display rpr topology ring
Table 1-10 Description on the fields of the display rpr topology ring command
Ring topology information of the station that corresponds to the specified interface
Jumbo preference
Ring topology type
# Display all the station topology information on the ring.
<Sysname> display rpr topology stations
  Station name:
  Sequence number:1
  Valid:1
  Station name:
  Sequence number:1
  Valid:1
Table 1-11 Description on the fields of display rpr topology stations
Topology information of the neighbour on the west span
Topology information of the neighbour on the east span
MAC-Address
Station name
Station name
IP address
Hops
Jumbo preference
Protection mode
Edge status on west
Edge status of west span. True means that edge occurs; false means that edge does not occur
Edge status on east
Edge status of east span. True means that edge occurs; false means that edge does not occur
Sequence number
Reachability
Whether the station is reachable
Valid
Whether the entries are valid or not. 1 means valid, 0 means not valid.
1.1.13  display rpr tunnel vlan
display rpr tunnel vlan { vlan-id1 [ to vlan-id2 ] | all } [ valid | invalid ] [ interface-type interface-number ]
View
Default Level
1: Monitor level
vlan-id1 [ to vlan-id2 ]: Specifies a VLAN or a VLAN range to display their RPR VLAN tunnel information. Both the vlan-id1 argument and the vlan-id2 argument take a value in the range 1 to 4094.
all: Displays all RPR VLAN tunnels.
valid: Displays valid entries.
invalid: Displays invalid entries.
Use the display rpr tunnel vlan command to view the tunnel information about the currently configured RPR VLANS.
# Display the tunnel information about VLAN 5 to 7.
<Sysname> display rpr tunnel vlan 5 to 7
Vlan tunnel table of interface:Ten-GigabitEthernet5/1/1
VLAN-ID  MAC-Address          Cfg-Ringlet    Eft-Ringlet    TTL    Valid
5        00e0-fc00-8582       0              0              2       valid
6        00e0-fc00-8583       1              0              1       valid
7        00e0-fc00-8584       1              N/A            N/A     invalid
---   Total entries: 3, Valid entries: 2, Invalid entries: 1    ---
Table 1-12 Description on the fields of the display rpr tunnel command
Tunnel information about RPR VLANs of the specified interface.
VLAN-ID
ID of the VLAN
MAC-Address
MAC address of the specified station
Cfg-Ringlet
Ringlet ID configured to reach the destination on the ring
Eft-Ringlet
Actually effective ringlet ID to reach the destination on the ring; N/A means an invalid entry.
TTL
Time to Live: number of hops involved to reach the destination through the specified ringlet; N/A means an invalid entry
Valid
Total entries:, Valid entries:, Invalid entries
Number of total entries, valid entries and invalid entries
1.1.14  display rpr vrrp-info
display rpr vrrp-info [ interface-type interface-number ]
View
Default Level
1: Monitor level
Use the display rpr vrrp-info command to display RPR VRRP standby group information.
If an RPR interface is specified, only the VRRP standby group information of its corresponding RPR station is displayed. If no interface is specified, the VRRP standby group information of all the RPR stations on your device is displayed.
&  Note:
For details about VRRP, refer to VRRP Configuration in the System Volume.
# Display VRRP standby group information of RPR.
<Sysname> display rpr vrrp
Ten-GigabitEthernet1/1/1 VRRP info:
 Index   Virtual-Group   Status      MAC-Address
 0        -                 -            -
 1        -                 -            -
Table 1-13 Description on the fields of the display rpr vrrp interface command
VRRP standby group information of the specified RPR interface
Index
Index
Virtual-Group
Name of virtual group
Status
Status of the VRRP standby group: master and backup
MAC-Address
MAC address
1.1.15  rpr admin-request
rpr admin-request { fs | idle | ms } { ringlet0 | ringlet1 }
View
RPR logical interface view
Default Level
2: System level
fs: Sends a forced switch (FS) protection request.
idle: Sends an idle protection request.
ms: Sends a manual switch (MS) protection request.
ringlet0: Sends a protection request on Ringlet 0.
ringlet1: Sends a protection request on Ringlet 1.
Use the rpr admin-request command to send an RPR protection request on the specified ringlet.
By default, idle protection applies.
Six types of protection requests, FS, signal fail (SF), signal degrade (SD), MS, wait to restore (WTR), and idle, are available with decreased priorities. Among them, FS and MS requests are sent manually, whereas SF, SD, and WTR requests are sent automatically.
Note that:
l           Use the rpr admin-request fs command to send an FS protection request. As the FS request takes priority over all other requests, you can remove it from the RPR ring only with the rpr admin-request idle command.
l           Use the rpr admin-request ms command to send an MS protection request. As the priority of the MS request is the lowest, RPR ring does not perform MS switching if any other type of protection request is present. On the contrary, the FS, SF, or SD request can override the MS request.
l           Use the rpr admin-request idle command to clear the FS or MS protection request.
# Send an FS protection request on Ringlet 0.
[Sysname] interface Ten-GigabitEthernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] rpr admin-request fs ringlet0
1.1.16  rpr default-rs
rpr default-rs { ringlet0 | ringlet1 }
undo rpr default-rs
View
Default Level
2: System level
ringlet0: Specifies Ringlet 0 as the default ringlet.
ringlet1: Specifies Ringlet 1 as the default ringlet.
Use the rpr default-rs command to configure the default RPR ringlet for sending data frames.
Use the undo rpr default-rs command to restore the default.
By default, the default ringlet is Ringlet 0.
  Caution:
The default ringlet you configured is not necessarily the one in use. This happens when a span is faulty and unable to forward data.
# Specify Ringlet 1 as the default ringlet.
[Sysname-Ten-GigabitEthernet1/1/1] rpr default-rs ringlet1
1.1.17  rpr echo mac
rpr echo mac mac-address [ -c value | -r { ringlet0 | ringlet1 | reverse } | -s { ringlet0 | ringlet1 } | -t value ] *
View
Default Level
2: System level
mac-address: MAC address of a station in the format of H-H-H. Specify it to test the connectivity to the station.
-c value: Specifies the number of echo requests to be sent for testing connectivity, in the range 1 to 1000. If the number is not specified, five requests are to be sent.
-r: Specifies the ringlet for the destination to send Echo Responses. It could be ringlet0, ringlet1, or reverse. If the reverse keyword is specified, the destination station is expected to send Echo Reponses from the ringlet different from the one from which it receives Echo Requests. For example, if the destination station receives Echo Requests from Ringlet 0, it should send out Echo Responses onto Ringlet 1.
-s: Specifies the ringlet for sending Echo Requests, either ringlet0 or ringlet1.
-t value: Specifies the echo response timeout in the range 10 to 65535 milliseconds. If it is not specified, the default of 10 milliseconds applies.
If transmitting ringlet or receiving ringlet is not specified, the source station will send the Echo Request packet from the default ringlet actually taking effect. The destination station will send the Echo Response packet from the default ringlet actually taking effect.
Use the rpr echo mac command to test the connectivity of the current station to the destination station. The connectivity between the current station and the destination station is considered to be normal if the connection between the two stations is normal on both the specific sending ringlet and the specific receiving ringlet. In this case, the destination station can receive the Echo Request packets that the current node sends on the specific ringlet and the current station can receive the Echo Response packets that the destination station sends on the specific ringlet. Otherwise, the connectivity between the current station and the destination station is considered to fail.
If neither the sending ringlet nor the receiving ringlet is specified, the default ringlet currently in use will be used for transmitting Echo Request packets and Echo Response packets.
# Test the connectivity to the station with MAC address 0012-3F83-A1E3, specify ringlet 0 as the sending ringlet and ringlet 1 as the receiving ringlet.
[Sysname-Ten-GigabitEthernet1/1/1] rpr echo mac 0012-3F83-A1E3 -s ringlet0 -r ringlet1
PING 0012-3F83-A1E3: press CTRL+C to break
    Reply from  0012-3F83-A1E3:  ringlet=1 hops=1 seq=2 time=1 ms
    Reply from  0012-3F83-A1E3:  ringlet=1 hops=1 seq=3 time=1 ms
    Reply from  0012-3F83-A1E3:  ringlet=1 hops=1 seq=4 time=1 ms
    Reply from  0012-3F83-A1E3:  ringlet=1 hops=1 seq=5 time=1 ms
    Reply from  0012-3F83-A1E3:  ringlet=1 hops=1 seq=6 time=1 ms
--- echo 0012-3F83-A1E3 statistics ---
    100 packet(s) transmitted
    100 packet(s) received
    0.0%  packet loss
    round-trip min/avg/max = 1/1/16 ms
1.1.18  rpr port-type
rpr port-type { 10gpos | 10ge }
View
Default Level
2: System level
10gpos: Sets the type of RPR physical ports to 10 Gbps POS.
10ge: Sets the type of RPR physical ports to 10GE.
Use the rpr port-type command to set the RPR physical port type for the station.
By default, the RPR physical port type detected at initialization applies by default.
  Caution:
l      After you change the RPR port type, the interface card will reboot to have the change take effect. The previous settings on the interface card will be lost as a result.
l      This command can only take effect on 10 Gbps POS and 10GE physical ports. It cannot take effect on 2.5 Gbps POS port.
# Configure the RPR physical port type as 10 GE.
[Sysname-Ten-GigabitEthernet1/1/1] rpr port-type 10ge
1.1.19  rpr protect-mode
rpr protect-mode { steer | wrap }
undo rpr protect-mode
View
Default Level
2: System level
steer: Sets the protection mode to steering where the source station directs protected frames to the ringlet that retains connectivity to their destinations.
wrap: Sets the protection mode to wrapping where protected traffic is directed at the point of failure to the opposing ringlet.
Use the rpr protect-mode command to set the RPR protection mode for the station. Use the undo rpr protect-mode command to restore the default.
By default, the steering mode applies.
  Caution:
All the stations on an RPR ring must adopt the same protection mode for the ring to operate normally.
# Adopt the wrapping protection mode on the station corresponding to the RPR logical interface Ten-GigabitEthernet 1/1/1.
[Sysnamey-Ten-GigabitEthernet1/1/1] rpr protect-mode wrap
1.1.20  rpr rate-limiter
rpr rate-limiter { high | low | medium | reserved } { ringlet0 | ringlet1 } value
undo rpr rate-limiter { high | low | medium | reserved } { ringlet0 | ringlet1 }
View
Default Level
2: System level
high: Configures the rate limit for the subclass A1 service.
low: Configures the rate limit for the class B EIR and class C services.
medium: Configures the rate limit for the class B CIR service.
reserved: Configures the reserved bandwidth for the subclass A0 service.
ringlet0: Configures the reserved bandwidth or rate limit for service classes on Ringlet 0.
ringlet1: Configures the reserved bandwidth or rate limit for service classes on Ringlet 1.
value: Permillage of the reserved bandwidth for subclass A0 to the total bandwidth or the rate limit in permillage for any other service. It ranges from 0 to 1000. The defaults in permillage for different services are as follows:
l           0 for subclass A0
l           2 for subclass A1
l           0 for class B CIR and class B EIR
l           1000 for class C
Use the rpr rate-limiter command to specify the reserved bandwidth for the subclass A0 service or rate limit for any other service on the specified ringlet.
Use the undo rpr rate-limiter command to restore the default.
  Caution:
l      The total bandwidth reserved for subclass A0 by the stations on a ringlet must be less than the ringlet bandwidth.
l      The ringlet0 and ringlet1 keywords in the command refer to sending ringlets.
# Set the reserved bandwidth in permillage for the subclass A0 service on Ringlet 0 to 5.
[Sysname-Ten-GigabitEthernet1/1/1] rpr rate-limiter reserved ringlet0 5
1.1.21  rpr reversion-mode
rpr reversion-mode { non-revertive | revertive }
undo rpr reversion-mode
View
Default Level
2: System level
non-revertive: Sets the protection reversion mode to non-revertive where the station remains in automatic protection state upon expiration of the WTR timer and does not resume the idle state until a higher protection request is present on the ring.
revertive: Sets the protection reversion mode to revertive where the station resumes the idle protection state once the WTR timer expires.
Use the rpr reversion-mode command to set the RPR protection reversion mode.
Use the undo rpr reversion-mode command to restore the default.
By default, revertive mode applies.
# Set the protection reversion mode to non-revertive.
[Sysname-Ten-GigabitEthernet1/1/1] rpr reversion-mode non-revertive
1.1.22  rpr static-rs
rpr static-rs mac-address { ringlet0 | ringlet1 }
undo rpr static-rs mac-address
View
Default Level
2: System level
ringlet0: Specifies Ringlet 0 as the sending ringlet for data frames destined to a specified MAC address.
ringlet1: Specifies Ringlet 1 as the sending ringlet for data frames destined to a specified MAC address.
mac-address: Destination MAC address, in the format of H-H-H.
Use the rpr static-rs command to add a static ringlet selection entry, specifying which ringlet is used for sending data frames destined to the specified MAC address.
Use the undo rpr static-rs command to remove the entry.
A static ring selection entry can take effect only when the configured ringlet is available.
# Send data frames with destination MAC 0001-0002-0003 on Ringlet 0 and data frames with destination MAC address 0001-0002-0004 on Ringlet 1.
[Sysname-Ten-GigabitEthernet1/1/1] rpr static-rs 0001-0002-0003 ringlet0
[Sysname-Ten-GigabitEthernet1/1/1] rpr static-rs 0001-0002-0004 ringlet1
1.1.23  rpr station-name
rpr station-name station-name
undo rpr station-name
View
Default Level
2: System level
station-name: Name of an RPR station, a string of 1 to 20 characters.
Use the rpr station-name command to assign a name to the station.
Use the undo rpr station-name command to remove the station name.
By default, no station name is configured.
# Name the station as ABC.
[Sysname-Ten-GigabitEthernet1/1/1] rpr station-name Beijing
1.1.24  rpr timer
rpr timer { atd value | holdoff value | keepalive value | stability value | tc-fast value | tc-slow value | tp-fast value | tp-slow value | wtr value }
undo rpr timer { atd | holdoff | keepalive | stability | tc-fast | tc-slow | tp-fast | tp-slow | wtr }
View
Default Level
2: System level
atd value: Sets the ATD timer in the range 1 to 10 seconds. The default is 1 second.
holdoff value: Sets the hold-off timer in steps of 10 milliseconds in the range 0 to 200 milliseconds. The default is 0 milliseconds.
keepalive value: Sets the keepalive timer in the range 2 to 50 milliseconds. The default is 3 milliseconds.
stability value: Sets the topology stability timer in the range 10 to 100 milliseconds. The default is 40 milliseconds.
tc-fast value: Sets the TC fast timer in the range 1 to 20 milliseconds. The default is 10 milliseconds.
tc-slow value: Sets the TC slow timer in steps of 50 milliseconds in the range 50 to 10000 milliseconds. The default is 100 milliseconds.
tp-fast value: Sets the TP fast timer in the range 1 to 20 milliseconds. The default is 10 milliseconds.
tp-slow value: Sets the TP slow timer in the range 50 to 10000 milliseconds in steps of 50 milliseconds. The default is 100 milliseconds.
wtr value: Sets the WTR timer in the range 0 to 1440 seconds. The default is 10 seconds.
Use the rpr timer command to set RPR timers.
Use the undo rpr timer command to restore the defaults.
# Set the ATD timer to three seconds.
[Sysname-Ten-GigabitEthernet1/1/1] rpr timer atd 3
1.1.25  rpr tunnel vlan dest-mac
rpr tunnel vlan { vlan-list | all } dest-mac mac-address [ ringlet0 | ringlet1 ]
undo rpr tunnel vlan { vlan-id-list | all }
View
Default Level
2: System level
vlan-list: VLAN list specified in the format of { vlan-id [ to vlan-id ] }&<1-10>, where the vlan-id argument can take a value in the range 1 to 4094 and &<1-10> indicates that you can specify up to 10 VLAN range. A VLAN range defined without the to vlan-id portion includes only one VLAN.
all: Configures or removes all RPR VLAN tunnels.
mac-address: MAC address of frame copying station, in the format of H-H-H. It must be a MAC address on the ring.
ringlet0: Configures the RPR VLAN tunnel to reach the destination through Ringlet 0. By default, the setting is consistent with that of the overall ringlet selection table.
ringlet1: RPR VLAN tunnel reaches the destination through Ringlet 1. By default, the setting is consistent with that of the overall ringlet selection table.
Use the rpr tunnel vlan command to configure RPR VLAN tunnels.
Use the undo rpr tunnel vlan command to remove RPR VLAN tunnels.
Before configuring a VLAN tunnel on an RPR interface, first configure the interface to allow the VLAN to pass.
# Configure an RPR VLAN tunnel.
[Sysname-Ten-GigabitEthernet1/1/1] port link-type trunk
[Sysname-Ten-GigabitEthernet1/1/1] rpr tunnel vlan 5 dest-mac 00fc-0010-8582 ringlet0
# Remove the RPR tunnels for VLAN 5.
[Sysname-Ten-GigabitEthernet1/1/1] undo rpr tunnel vlan 5
1.1.26  rpr weight
rpr weight { ringlet0 | ringlet1 } value
undo rpr weight { ringlet0 | ringlet1 }
View
Default Level
2: System level
ringlet0: Sets the fairness weight of the station on Ringlet 0.
ringlet1: Sets the fairness weight of the station on Ringlet 1.
value: The number of the powers, in the range 0 to 7. The station weight is represented as a power of 2.
Use the rpr weight command to set the fairness weight of a station.
Use the undo rpr weight command to restore the default.
By default, the weight of a station is 0 on both Ringlet 0 and Ringlet 1, and the corresponding weight of fairness actually taking effect is 1. .
# Set the weight of the station on Ringlet 0 to 4 (that is, two power of 2).
[Sysname-Ten-GigabitEthernet1/1/1] rpr weight ringlet0 2
1.1.27  reset rpr protection statistics
reset rpr protection statistics [ interface-type interface-number ]
View
Default Level
2: System level
interface-type interface-number: Specifies an interface by its type and number. The interface must be an RPR logical interface.
Use the reset rpr protection statistics command to clear the statistics of the RPR station protection events.
&  Note:
If the interface-type interface-number argument is specified, only the information about the RPR ring to which the interface belongs is cleared. Otherwise, all the RPR ring information will be cleared.
# Clear the statistics of RPR station protection events.
<Sysname> reset rpr protection statistics
