H3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
12-Port Isolation Commands
12-Port Isolation Commands 27.81 KB
Chapter 1  Port Isolation Commands
1.1  Port Isolation Commands
1.1.1  display port-isolate group
display port-isolate group [ group-number ]
View
Default Level
1: Monitor level
group-number: Specifies an isolation group number.
Use the display port-isolate group command to display information about the specified isolation group or all isolation groups if no isolation group is specified.
# Display the information of isolation group 2.
<Sysname> display port-isolate group 2
 Port-isolate group information:
 Uplink port support: YES
 Group ID: 2
 Uplink port: GigabitEthernet4/3/2
    GigabitEthernet4/3/1
1.1.2  port-isolate enable
port-isolate enable group group-number
undo port-isolate enable
View
Ethernet interface view, port group view
Default Level
2: System level
group-number: Number of the isolation group to which the current port or ports are to be assigned.
Use the port-isolate enable command to assign a port in Ethernet interface view or a group of ports in port group view to the specified isolation group as isolated ports.
Use the undo port-isolate enable command to remove the current port or ports from the isolation group.
Before you can assign a port to an isolation group, you must create the isolation group first.
&  Note:
You can assign a port to an isolation group as either an uplink port or isolated port, but not the both. In addition, A port that has been assigned to an isolation group as an isolated or uplink port cannot be configured as the uplink port for another isolation group.
# Assign port Ethernet 1/1/1 to isolation group 2 as an isolated port.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] port-isolate enable group 2
1.1.3  port-isolate group
port-isolate group group-number
undo port-isolate group { group-number | all }
View
Default Level
2: System level
all: All isolation groups.
Use the port-isolate group command to create an isolation group.
Use the undo port isolate command to remove isolation groups. If the group-number argument is specified, the specified isolation group and its configurations are removed; if the all keyword is specified, all isolation groups and their configurations are removed.
# Create isolation group 2.
[Sysname] port-isolate group 2
1.1.4  port-isolate uplink-port
port-isolate uplink-port group group-number
undo port-isolate uplink-port
View
Default Level
2: System level
Use the port-isolate uplink-port command to configure the current port as the uplink port of the specified isolation group. Before you can do this, you must ensure that the isolation group has been created.
Use the undo port-isolate uplink-port command to remove the current port from the isolation group to which it has been assigned as an uplink port.
&  Note:
You can assign a port to an isolation group as either an uplink port or isolated port, but not the both. In addition, a port that has been assigned to an isolation group as an isolated or uplink port cannot be configured as the uplink port for another isolation group.
# Configure Ethernet1/1/1 as the uplink port of isolation group 2.
[Sysname] interface Ethernet 1/1/1
[Sysname-Ethernet1/1/1] port-isolate uplink-port group 2
