H3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
10-QinQ Commands
10-QinQ Commands 45.79 KB
Chapter 1  QinQ Configuration Commands
1.1  QinQ Configuration Commands
1.1.1  qinq enable
qinq enable
undo qinq enable
View
Ethernet interface view, port group view
Default Level
2: System level
None
Use the qinq enable command to enable the basic QinQ function.
Use the undo qinq enable command to disable the basic QinQ function.
By default, the basic QinQ function is disabled.
With the basic QinQ function enabled on a port, the port tags each received frame with the VLAN tag of the default VLAN of the port.
When executed in Ethernet interface view, these two commands apply to the current port; when executed in port group view, these two commands apply to all the ports in the port group.
  Caution:
As basic QinQ function affects layer-3 packet forwarding and MPLS switching, do not enable layer-3 packet forwarding or MPLS switching on ports with basic QinQ function enabled.
# Enable basic QinQ function on Ethernet 1/1/1.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] qinq enable
1.1.2  qing ethernet-type
qinq ethernet-type hex-value
undo qinq ethernet-type
View
Default Level
2: System level
hex-value: QinQ tag protocol identifier (TPID) to be set, a hexadecimal number. Note that this argument cannot be set to any of the values listed in Table 1-1.
Table 1-1 Commonly used TPIDs
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86DD
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
802.1x
0x888E
Cluster
0x88A7
Reserved
0xFFFD/0xFFFE/0xFFFF
Use the qing ethernet-type command to set the TPID in the outer VLAN tag of QinQ frames.
Use the undo ethernet-type command to restore the default.
The default TPID in the outer VLAN tag of QinQ frames is 0x8100.
Note that:
l           A board supports only one TPID except the default TPID.
l           Currently, the ports of LSB1XP4B and LSB1XP4CA boards do not support setting TPID.
l           When executed in Ethernet interface view, these two commands apply to the current port; when executed in port group view, these two commands apply to all the ports in the port group.
l           If you execute the qinq ethernet-type command repeatedly, the latest TPID set takes effect.
# Set the TPID in the outer VLAN tag of QinQ frames to 0x9100 on Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] qinq ethernet-type 9100
