H3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
HomeSupportSwitchesS9500 SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release2132[V2.03]-01 IP Access Volume
01-Ethernet Interface Commands
01-Ethernet Interface Commands 142.89 KB
Chapter 1  Ethernet Interface Configuration Commands
1.1  Ethernet Interface Configuration Commands
1.1.1  broadcast-suppression
broadcast-suppression { ratio | pps max-pps }
undo broadcast-suppression
View
Ethernet interface view, port group view
Default Level
2: System level
ratio: Specifies a percentage of the total interface bandwidth for broadcasts on the interface, in the range 1 to 100. The smaller the ratio is, the less the broadcast traffic is allowed through the interface.
pps max-pps:  Specifies the maximum number of broadcast packets allowed to pass through the interface every second, in the range 1 to 1488100 (in pps, packets per second).
Use the broadcast-suppression command to configure broadcast suppression by setting a broadcast traffic threshold.
Use the undo broadcast-suppression command to restore the default.
By default, all broadcast traffic is allowed to go through an Ethernet interface, that is, broadcast traffic is not suppressed.
Configured in Ethernet interface view, the command takes effect only on the current interface; configured in port group view, the command takes effect on all interfaces in the port group.
l           With broadcast suppression enabled, the switch discards all broadcasts that cross the predefined broadcast threshold to ensure the operation of network services.
l           The broadcast suppression setting you configured will overwrite the previous broadcast suppression setting, if any.
l           With multicast suppression enabled, broadcast suppression is enabled automatically. However, with broadcast suppression enabled, multicast suppression can not be enabled.
l           You cannot enable broadcast suppression and multicast suppression on a board at the same time. If you have enabled broadcast suppression on some ports of a board, you cannot enable multicast suppression on the other ports, and vice versa.
# Set the broadcast threshold to 20 for Ethernet 1/1/1.
[Sysname] interface ethernet 1/1/1
[Sysname-Ethernet1/1/1] broadcast-suppression 20
# Set the broadcast threshold to 20 for all the interfaces in port group 1.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member ethernet 2/1/1
[Sysname-port-group manual group1] group-member ethernet 2/1/2
[Sysname-port-group manual group1] broadcast-suppression 20
1.1.2  debugging ethernet packet
debugging ethernet packet [ interface interface-type interface-number ]
undo debugging ethernet packet
View
Default Level
1: Monitor level
Use the debugging ethernet packet command to enable Ethernet packet debugging for a specified interface or globally if no interface is specified.
Use the undo debugging ethernet packet command to disable Ethernet packet debugging.
By default, Ethernet packet debugging is disabled.
# Enable Ethernet packet debugging.
<Sysname> debugging ethernet packet
1.1.3  description
View
Ethernet interface view, POS interface view
Default Level
2: System level
text: Interface description information, a string of 1 to 80 characters.
Use the description command to set the description of a specific interface.
Use the undo description command to restore the default.
By default, the description of an interface is interface index + interface.
# Set the description to lanswitch-interface for Ethernet 1//1/1.
[Sysname-Ethernet1/1/1] description lanswitch-interface
1.1.4  display brief interface
display brief interface [ interface-type [ interface-number ] ] [ | { begin | include | exclude } text ]
View
Default Level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
|: Uses a regular expression to filter output information.
begin: Displays the configuration information from the line that contains the string specified by the text argument.
include: Displays only the lines that contain the string specified by the text argument.
exclude: Displays all the lines that do not contain the string specified by the text argument.
text: Regular expression, a string of 1 to 256 characters. This argument is case-sensitive and allows spaces.
Table 1-1 Special characters used in regular expressions
Character
Meaning
Notes on Use
Boundary matcher for the beginning of a line. This character specifies a string with which a line begins.
The regular expression “^user” matches lines that begin with the string “user”. Lines that don t begin with the string “user”, for example, “Auser”, are not matched.
Boundary matcher for the end of a line. This character specifies a string with which a line ends.
The regular expression “user$” matches lines that end with the string “user”. Lines that do not end with the string, for example, “userA”, are not matched.
Full stop, used as the wildcard character, which matches any single character, including space.
None
Star, which matches the occurrences of the character to the left for zero or multiple times
 zo* matches z and zoo.
Plus, which  matches one or multiple occurrences of the character to the left
zo+ matches zo and zoo, but not z.
Hyphen, which is used to connect two numbers or characters. Note that the number to the left of this character needs to be larger than the one to the right. When used in a “[“ and “]” pair, it represents a range.
”1-9” represent a range from 1 to 9 (“1” and “9” included), and a-h represent a range from “a” to “h” (“a” and “h” included).
Specifies a range.
[1-36A] matches a character, which can be a number in the range 1 to 36 or character A.
Specifies a group of characters. Usually used with “+” and “*”.
 (123A) specifies the string “123A”. 408(12)+ matchers “40812” or “408121212” (but not “408”). That is, “12” can appear for multiple times.
Use the display brief interface command to display interface information in brief.
l           If neither interface type nor interface number is specified, all interface information will be displayed;
l           If only interface type is specified, then only information of this particular type of interface will be displayed.
l           If both interface type and interface number are specified, then only information of the specified interface will be displayed.
Related commands: interface.
# Display the information about all the interfaces in brief.
<Sysname> display brief interface
The brief information of interface(s) under route mode:
Interface            Link      Protocol-link  Protocol type    Main IP
Loop0                UP        UP(spoofing)   LOOP             10.2.2.2
M-E0/0/0             UP        UP             ETHERNET         192.168.0.54
NULL0                UP        UP(spoofing)   NULL             --
Pos4/1/1             DOWN      DOWN           PPP              --
Pos4/1/2             DOWN      DOWN           PPP              --
Pos4/1/3             DOWN      DOWN           PPP              --
Pos4/1/4             DOWN      DOWN           PPP              --
Vlan1000             DOWN      DOWN           ETHERNET         10.110.10.1
The brief information of interface(s) under bridge mode:
Interface            Link      Speed     Duplex   Link-type  PVID
GE4/2/1              DOWN      auto      auto     access     1000
GE4/2/2              DOWN      auto      auto     access     1
GE4/2/4              DOWN      auto      auto     access     1
GE4/3/1              DOWN      auto      auto     access     1
GE4/3/2              DOWN      auto      auto     access     1
GE4/3/3              DOWN      auto      auto     access     1
GE4/3/4              DOWN      auto      auto     access     1
Table 1-2 Description on the fields of the display brief interface command.
Brief information of interface(s) in route mode
Abbreviated interface name
Link
 Interface physical link state, which can be up or down
Protocol-link
Interface protocol link state, which can be up or down
Protocol type
Interface protocol type
Main IP
Main IP
Brief information of interface(s) in bridge mode
Speed
 Interface rate, in bps
Duplex
Duplex mode, which can be half (half duplex), full (full duplex), or auto (auto-negotiation).
PVID
Default VLAN ID
Table 1-3 Acronyms for different types of Interface
Interface name
Acronyms
Ethernet
Eth
GigabitEthernet
GE
Ten-GigabitEthernet
XGE
1.1.5  display counters
display counters { inbound | outbound } interface [ interface-type ]
View
Default Level
1: Monitor level
inbound: Displays statistics on inbound packets.
outbound: Displays statistics on outbound packets.
Use the display counters command to display the statistics on specific packets.
l           If you provide the interface-type argument, this command displays the statistics on the packets passing through all the interfaces that are of the specified type.
l           If you do not provide the argument, this command displays the statistics on the packets passing through all the interfaces that support this command.
# Display the statistics on the inbound packets passing through all the GigabitEthernet interfaces.
<Sysname> display counters inbound interface GigabitEthernet
Interface            Total(pkts)    Broadcast(pkts)    Multicast(pkts) Err(pkts)
GE5/1/1                    100               100                 0         0
GE5/1/2               Overflow                  0          Overflow         0
GE5/1/3                        0                  0                  0         0
GE5/1/4                        0                  0                  0         0
GE5/2/1                        0                  0                  0         0
GE5/2/2                        0                  0                  0         0
GE5/2/3                        0                  0                  0         0
GE5/2/4                        0                  0                  0         0
GE5/3/1                        0                  0                  0         0
GE5/3/2                        0                  0                  0         0
GE5/3/3                        0                  0                  0         0
GE5/3/4                        0                  0                  0         0
Overflow: more than 14 decimal digits(7 digits for column "Err").
       --: not supported.
Table 1-4 Description on the fields of the display counters command
Total(pkts)
Total number of the packets received/sent through the interface. (You can specify the direction of the packets using the inbound and outbound keyword.)
Broadcast(pkts)
Total number of the broadcast packets received/sent through the interface. (You can specify the direction of the packets using the inbound and outbound keyword.)
Multicast(pkts)
Total number of the multicast packets received/sent through the interface. (You can specify the direction of the packets using the inbound and outbound keyword.)
Err(pkts)
Total number of the error packets received/sent through the interface. (You can specify the direction of the packets using the inbound and outbound keyword.)
Overflow: more than 14 decimal digits (7 digits for column "Err")
The value of the statistics item is larger than the maximum number a 14-digit decimal number can represent. For an Err item, Overflow means the value of the statistics item is larger than the maximum number a 7-digit decimal number can represent.
--: not supported
The statistics item is not supported.
1.1.6  display counters rate
display counters rate { inbound | outbound } interface [ interface-type ]
View
Default Level
1: Monitor level
inbound: Displays the statistics on the rate of inbound packets.
outbound: Displays the statistics on the rate of outbound packets.
Use the display counters rate command to display the statistics on the rate of the packets passing the interfaces that are in up state in the latest sampling interval.
l           If you provide the interface-type argument, this command displays the statistics on the rate of the packets passing through all the interfaces that are in up state and are of the specified type.
l           If you do not provide the argument, this command displays the statistics on the rate of the packets passing through all the interfaces that support this command.
Sampling intervals can be set using the flow-interval command.
By default, the sampling interval is 300 seconds.
Related commands: flow-interval.
# Display the statistics on the rate of the inbound packets passing through all the GigabitEthernet interfaces.
<Sysname> display counters rate inbound interface GigabitEthernet
Interface           Total(pkts/sec)   Broadcast(pkts/sec)   Multicast(pkts/sec)
GE6/1/1                      200                  100                  100
GE6/1/2                      300                  200                  100
GE6/1/3                      300                  200                  100
Overflow: more than 14 decimal digits.
       --: not supported.
Table 1-5 Description on the fields of the display counters rate command
Total(pkts/sec)
Average rate (in packets per second) of receiving/sending packets during the sampling interval. You can specify the direction of the packets using the inbound and outbound keyword.
Broadcast(pkts/sec)
Average rate (packets per second) of receiving/sending broadcast packets during the sampling interval. You can specify the direction of the packets using the inbound and outbound keyword.
Multicast(pkts/sec)
Average rate (packets per second) of receiving/sending multicast packets during the sampling interval. You can specify the direction of the packets using the inbound and outbound keyword.
--: not supported
&  Note:
The display counters and display counters rate commands only count the statistics on the packets passing through RPR logical ports.
1.1.7  display interface
display interface [ interface-type [ interface-number ] ]
View
Default Level
1: Monitor level
Use the display interface command to display the current state of an interface and related information.
# Display the current state of the interface Ten-GigabitEthernet 5/1/2 and related information.
<Sysname> display interface Ten-GigabitEthernet5/1/2
 Ten-GigabitEthernet5/1/2 current state: DOWN
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-e23f-32ce
 Description: Ten-GigabitEthernet5/1/2 Interface
 Loopback is not set
 Media type is not sure, Port hardware type is No Connector
Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled
 The Maximum Frame Length is 1552
 Broadcast MAX-ratio: 100%
 PVID: 1
 Link delay is 1(sec)
 Ethernet port mode: WAN
        J0(Rx):""
        00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     *................*
        J0(Tx):""
        J1(Rx):""
        J1(Tx):""
     SDH error:
        section layer:  B1  0
        line    layer:  B2  0  M1  0
        path    layer:  B3  0  G1  0
 Port link-type: access
  Tagged   VLAN ID : none
  Untagged VLAN ID : 1
 Port priority: 0
 Last 300 seconds input:  0 packets/sec 0 bytes/sec
 Last 300 seconds output:  0 packets/sec 0 bytes/sec
 Input (total):  0 packets, 0 bytes
          0 broadcasts, 0 multicasts
 Input (normal):  0 packets, 0 bytes
          - broadcasts, - multicasts
          0 ignored, - parity errors
          0 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 0 packets, 0 bytes
          - broadcasts, - multicasts, 0 pauses
          0 aborts, 0 deferred, - collisions, 0 late collisions
          - lost carrier, - no carrier
Table 1-6 Description on the fields of the display interface command
Ethernet interface physical state
Ethernet frame type
Hardware address
Hardware address
Loopback is not set
Loopback is not set.
Media type, Port hardware type
Cable type, Port hardware type
Unknown-speed mode
Unknown-speed mode, in which mode speed is negotiated between the current host and the peer
unknown-duplex mode
unknown-duplex mode, in which mode speed is negotiated between the current host and the peer.
Link speed type is autonegotiation.
Link duplex type is autonegotiation.
The maximum frame length allowed on an interface
Broadcast MAX-ratio
Broadcast storm suppression ratio (the maximum broadcast traffic allowed to overall traffic through an interface)
PVID
Default VLAN ID
Link delay
Link suppression time
Ethernet port mode
Ethernet port mode
SDH error
SDH error information
Port link-type
Interface link type, which could be access, trunk, and hybrid.
Tagged   VLAN ID
Identify the VLANs that need Tag markers
Untagged VLAN ID
Identify the VLANs that do not need Tag markers
Port priority
Port priority
Average input rate within the latest 300 seconds
Average output rate within the latest 300 seconds
Input
Input packets
Output
Output packets
1.1.8  display port
View
Default Level
1: Monitor level
hybrid: Displays the existing Hybrid ports.
trunk: Displays the existing Trunk ports.
Use the display port command to display the information about the existing ports that are of a specified type, including port name, default VLAN ID, and the VLAN ID of VLANs that the ports can pass through.
# Display the existing hybrid ports.
<Sysname> display port hybrid
Interface            PVID  VLAN passing
GE4/2/2              100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                                    2555-2558, 3000, 4000
                           Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                                    150-160, 200, 255, 286, 300-302
# Display the existing trunk ports.
<Sysname> display port trunk
GE4/3/2              2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
                           555, 600-611, 1000, 2006-2008
Table 1-7 Description on the fields of the display port command.
Interface name
PVID
Default VLAN ID of a port
VLAN passing
ID of the VLANs permitted by the port
1.1.9  display port-group manual
display port-group manual [ all | name port-group-name ]
View
Default Level
1: Monitor level
all: Specifies all the manual port groups.
name port-group-name: Specifies the name of a manual port group, a string of 1 to 32 characters.
Use the display port-group manual command to display the information about a manual port group.
l           If you provide the port-group-name argument, this command displays the information about the manual port group identified by the argument, including port group name and the Ethernet interface ports contained in the port group.
l           If you provide the all keyword, this command displays the information about all the manual port groups, including their names and the Ethernet interface ports included.
l           If you provide no keyword/argument, this command displays the names of all the manual port groups.
# Display the names of all manual port groups.
<Sysname> display port-group manual
The following manual port group exist(s):
group1                                    group2
# Display the information about the manual port group named “group1”.
<Sysname> display port-group manual group1
Member of group1:
    Ethernet1/1/1            Ethernet1/1/2            Ethernet1/1/3
    Ethernet1/1/4            Ethernet1/1/5            Ethernet1/1/6
    Ethernet2/1/1            Ethernet2/1/2            Ethernet2/1/3
    Ethernet2/1/4
1.1.10  display transceiver alarm interface
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and number.
Use the display transceiver alarm interface command to display the alarm information of pluggable optical modules.
If an interface is specified, the system displays alarm information only for the pluggable optical module of the interface. If no interface is specified, the system displays alarm information for all pluggable optical modules.
If no alarm has occurred, None displays.
The following table lists the alarms that may occur on a pluggable optical module.
Table 1-8 Alarms that may occur on a pluggable optical module
Alarm
Number
GBIC/SFP modules
RX loss of signal
TX fault
TX
020
RX power high
Numeric
100
RX power low
Numeric
101
TX power high
Numeric
120
TX power low
Numeric
121
TX bias high
Numeric
122
TX bias low
Numeric
123
Temp high
Numeric
140
Temp low
Numeric
141
Voltage high
Numeric
142
Voltage low
Numeric
143
Transceiver info I/O error
Transceiver info checksum error
Transceiver type and port configuration mismatch
Transceiver type not supported by port hardware
XFP modules
RX loss of signal
RX not ready
RX
000
RX CDR loss of lock
RX
001
TX fault
TX
020
TX not ready
TX
021
TX CDR loss of lock
TX
022
Module not ready
Other
040
APD supply fault
Other
041
TEC fault
Other
042
Wavelength unlocked
Other
043
RX power high
Numeric
100
RX power low
Numeric
101
TX power high
Numeric
120
TX power low
Numeric
121
TX bias high
Numeric
122
TX bias low
Numeric
123
Temp high
Numeric
140
Temp low
Numeric
141
Voltage high
Numeric
142
Voltage low
Numeric
143
XENPAK modules
Receive optical power fault
RX
002
PMA/PMD receiver local fault
RX
003
PCS receive local fault
RX
004
PHY XS receive local fault
RX
005
TX fault
TX
020
Laser bias current fault
TX
023
Laser output power fault
TX
024
PMA/PMD transmitter local fault
TX
025
PCS transmit local fault
TX
026
PHY XS transmit local fault
TX
027
WIS local fault
Other
044
Laser temperature fault
Other
045
RX power high
Numeric
100
RX power low
Numeric
101
TX power high
Numeric
120
TX power low
Numeric
121
TX bias high
Numeric
122
TX bias low
Numeric
123
Temp high
Numeric
140
Temp low
Numeric
141
# Display the alarm information of the pluggable optical module of GigabitEthernet 1/1/1.
<H3C> display transceiver alarm interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver current alarm information:
  TX fault
1.1.11  display transceiver diagnosis interface
View
Default Level
1: Monitor level
interface-type interface-number: Interface type and interface number.
Use the display transceiver diagnosis interface command to display the diagnostic results of pluggable optical modules.
If an interface is specified, the system displays diagnostic results only for the pluggable optical module of the interface. If no interface is specified, the system displays diagnostic results for all pluggable optical modules.
&  Note:
This command is applicable only to the pluggable optical modules that have passed H3C authentication.
# Display the diagnostic results of the pluggable optical module of GigabitEthernet 1/1/1.
<H3C> display transceiver diagnosis interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver diagnostic information:
Temp.(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
40         3.3         1.1          20.0              -30.0
Table 1-9 Description on the fields of the display transceiver diagnosis interface command
Temp.(°C)
Digital diagnostic monitoring – temperature
Voltage(V)
Digital diagnostic monitoring – voltage with a precision of 1 digit after the decimal point
Bias(mA)
Digital diagnostic monitoring – bias current with a precision of 1 digit after the decimal point
RX power(dBM)
Digital diagnostic monitoring – RX power with a precision of 1 digit after the decimal point
TX power(dBM)
Digital diagnostic monitoring – TX power with a precision of 1 digit after the decimal point
&  Note:
N/A displays for parameters not supported by the device.
1.1.12  display transceiver interface
View
Default Level
1: Monitor level
interface-type interface-number: Interface and interface number.
Use the display transceiver interface command to display the major parameters of the pluggable optical module of an interface or all pluggable optical modules.
# Display the major parameters of the pluggable optical module of GigabitEthernet 1/1/1.
<H3C> display transceiver interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver information:
  Transceiver Type                    : 1000_BASE_LX_SFP
  Connector Type                   : LC
  Wavelength(nm)                   : 1310
  Transfer Distance                : 10km(9um)
  Digital Diagnostic Monitoring    : YES
  Vendor Name                      : H3C
  Ordering Name                    : SFP-GE-LX10-SM1310
Table 1-10 Description on the fields of the display transceiver interface command
Transceiver Type
Physical type of the transceiver
Connector Type
Connector type, which could be:
l      SC, LC (for fiber connection)
l      RJ-45, CX4, and so on (for other types of connection)
Wavelength(nm)
Transmit laser wavelength in nm
For a module that supports multiple wavelength values, the wavelength values are separated by commas (,).
Transfer Distance(xx)
Transmission distance in m or km
If multiple distances are supported, they are separated by commas (,).
The media type is bracketed, which can be one of the following:
l      9/125um signle-mode optical fiber: 9um
l      50/125um multi-mode optical fiber: 50um
l      62.5/125um multi-mode optical fiber: 62.5um
l      Twisted pair: TP
l      CX4 cable: CX4
l      Stack cable: STACK
The support for digital diagnostic monitoring, which could be YES or NO.
Vendor Name
l      For latest H3C modules, the vendor name in the RFID1 of the module displays.
l      For other modules, the Original Equipment Manufacturer name displays.
Ordering Name
l      For H3C devices, the external model displays.
l      For OEM devices, N/A displays.
Note: RFID = radio frequency identification (also called e-tag)
1.1.13  display transceiver manuinfo interface
View
Default Level
1: Monitor level
Use the display transceiver manuinfo interface command to display the radio frequency identification (RFID) information of pluggable optical modules.
If an interface is specified, the system only displays the RFID information of the pluggable optical module of the interface. If no interface is specified, the system displays the RFID information of all pluggable optical modules.
# Display the RFID information of the pluggable optical module of GigabitEthernet 1/1/1.
<H3C> display transceiver manuinfo interface GigabitEthernet 1/1/1
GigabitEthernet1/1/1 transceiver manufacture information:
  Manu. Serial Number     : 213410A0000054000251
  Manufacturing Date      : 2007-04-01
  Vendor Name             : H3C
Table 1-11 Description on the fields of the display transceiver manuinfo interface command
Manu. Serial Number
Serial number generated during module test. The information is stored in the RFID.
Manufacturing Date
H3C module test date. The information is stored in the RFID.
Vendor Name
The specified vendor name for the module. The information is stored in the RFID.
1.1.14  duplex
duplex { auto | full | half }
undo duplex
View
Default Level
2: System level
auto: Specifies the auto-negotiation mode.
full: Specifies the full-duplex mode.
half: Specifies the half-duplex mode. This keyword is not available for GigabitEthernet interfaces.
Use the duplex command to set the duplex mode of the Ethernet interface.
Use the undo duplex command to restore the default duplex mode.
By default, the duplex mode of an Ethernet interface is determined through auto-negotiation.
Related commands: speed.
&  Note:
This command is not available on Ten-GigabitEthernet interfaces.
# Configure interface Ethernet 1/1/1 to operate in the full-duplex mode.
[Sysname-Ethernet1/1/1] duplex full
1.1.15  flag sdh
flag { j0 | j1 } sdh value
undo flag { j0 | j1 } sdh
View
Ten-GigabitEthernet interface view
Default Level
2: System level
j0: Sets the regenerator section trace byte.
j1: Sets the path trace byte.
value: Value for the J0 or J1 byte, a string of 1 to 15 characters.
Use the flag sdh command to set the overhead byte (J0 or J1) of SDH frames when the Ten-GigabitEthernet interface is working in WAN mode.
Use the undo flag command to restore the default.
By default, both J0 and J1 bytes are all zeros.
Related commands: port-mode.
&  Note:
This command can take effect only when the Ten-GigabitEthernet interface is operating in WAN mode.
#  Set the J0 byte in SDH frames to Sysname on ten-GigabitEthernet 1/1/1.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] port-mode wan
[Sysname-Ten-GigabitEthernet1/1/1] flag j0 sdh Sysname
1.1.16  flow-control
flow-control
undo flow-control
View
Default Level
2: System level
None
Use the flow-control command to enable flow control on an Ethernet interface.
 Use the undo flow-control command to disable flow control on an Ethernet interface.
By default, flow control is disabled.
&  Note:
Flow control takes effect only when it is enabled on both local and remote sides.
# Enable flow control on interface Ethernet1/1/1.
[Sysname-Ethernet1/1/1] flow-control
1.1.17  flow-interval
flow-interval interval
undo flow-interval
View
Default Level
2: System level
interval: Interval for generating interface statistics, in the range of 5 to 300 (in seconds) in steps of 5.
Use the flow-interval command to set the interval for generating interface statistics.
Use the undo flow-interval command to restore the default.
By default, the interval for generating interface statistics is 300 seconds.
# Set the time interval for generating interface statistics to 100 seconds for interface Ethernet1/1/1.
[Sysname-Ethernet1/1/1] flow-interval 100
1.1.18  group-member
group-member interface-list
undo group-member interface-list
View
Manual port group view
Default Level
2: System level
interface-list: Ethernet interface list, in the format of {interface-type interface-number [ to interface-type interface-number ] } &<1-10>, where interface-type interface-number is Ethernet interface type and number, and &<1-10> means that you can specify up to 10 interfaces/interface ranges for this argument.
Use the group-member command to add Ethernet interfaces to a manual port group.
Use the undo group-member command to remove Ethernet interfaces from a manual port group.
By default, a manual port group contains no Ethernet interface.
# Add interfaces Ethernet1/1/1 and Ethernet1/1/5 to the manual port group named group1.
[Sysname-port-group-manual-group1] group-member Ethernet 1/1/1 to Ethernet 1/1/5
1.1.19  interface
View
Default Level
2: System level
&  Note:
l      Interface is numbered using slot number, daughter card number, and interface number. For example, the interface number of Ethernet 1/1/1 is 1/1/1.
l      For ease of user input, interface type can be abbreviated so long as it does not cause any confusion, for example, interface Ethernet 1/1/1 can be abbreviated as e1/1/1.
Use the interface command to enter interface view.
# Enter Ethernet1/1/1 interface view.
1.1.20  jumboframe enable
jumboframe enable [ jumboframe-value ] slot slot-id
undo jumboframe enable slot slot-id
View
Default Level
2: System level
jumboframe-value: Size (in bytes) of the jumbo frames allowed to pass through an Ethernet interface, in the range 1552 to 10240. This range can be subdivided into three ranges with one valid value in each: 9022 in the range 1553 to 9022, 9192 in the range 9023 to 9192 and 10240 in the range 9193 to 10240. By default, the size of the jumbo frames allowed is 1,552 bytes.
slot slot-id: Specifies a board by its slot ID. The command applies to all the Ethernet interfaces on the specified board.
Use the jumboframe enable command to set the maximum size of the jumbo Ethernet frames allowed to pass through the specified Ethernet interfaces.
Use the undo jumboframe enable command to prevent Ethernet frames longer than 1522 bytes from passing through the specified Ethernet interfaces.
By default, the maximum length of Ethernet frames allowed is 1522 bytes.
&  Note:
l      The jumboframe-value argument is in the range 1,552 to 10,236 for the boards LSB1XP4B, LSB1XP4CA, LSB1XP4DB, LSB1GV48DA, LSB2GV48DA, and LSB1GV48DB.
l      By default, the boards LSB1VPNB0, LSB1NAMB0 and LSB1NATB0 allow jumbo frames with their size being 8,192 bytes. If you execute the jumboframe enable command for a board of this type, an error occurs.
l      For FE interfaces, the maximum size of allowed jumbo frames is 1552 bytes.
# Allow Ethernet frames smaller than 9022 bytes to pass through all the Ethernet interfaces on the board in slot 4.
[Sysname] jumboframe enable 9022 slot 4
1.1.21  link-delay
link-delay delay-time
undo link-delay
View
Default Level
2: System level
delay-time: Up/Down suppression time for the physical connection of an Ethernet interface, in the range 0 to 10 (in seconds).
Use the link-delay command to set the suppression time of physical-link-state changes on an Ethernet Interface.
Use the undo link-delay command to restore the default.
By default, the suppression time of physical-link-state changes on an Ethernet Interface is 1 second.
# Set the up/down suppression time of the physical connection of Ethernet 1/1/1 interface to 2 seconds.
[Sysname-Ethernet1/1/1] link-delay 2
1.1.22  loopback
undo loopback
View
Default Level
2: System level
external: Enables external loopback testing.
internal: Enables internal loopback testing.
Use the loopback command to enable Ethernet interface loopback testing.
Use the undo loopback command to disable Ethernet interface loopback testing.
By default, Ethernet interface loopback testing is disabled.
&  Note:
l      Currently, the S9500 series do not support external loopback testing.
l      Loopback testing is required when you test certain functions, such as locating problems in an Ethernet.
l      After you enable loopback testing on an Ethernet interface, the interface operates in full-duplex mode at the highest speed. The interface will return to its original state when loopback testing is disabled.
# Enable internal loopback testing on Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] loopback internal
1.1.23  mdi
mdi { across | auto | normal }
undo mdi
View
Default Level
2: System level
across: Specifies the MDI mode as across.
auto: Specifies the MDI mode as auto.
normal: Specifies the MDI mode as normal.
Use the mdi command to configure the MDI mode of an Ethernet interface.
Use the undo mdi command to restore the default.
By default, the MDI mode of an Ethernet interface is auto. That is, an Ethernet interface decides the role of the pins (to send packets or receive packets) through auto negotiation.
# Configure the MDI mode of interface Ethernet1/1/1 as across.
[Sysname-Ethernet1/1/1] mdi across
1.1.24  multicast-suppression
multicast-suppression { ratio | pps max-pps }
undo multicast-suppression
View
Default Level
2: System level
ratio: Specifies a percentage of the total interface bandwidth for multicasts on the interface, in the range 1 to 100. The smaller the ratio is, the less the multicast traffic is allowed through the interface.
pps max-pps:  Specifies the maximum number of multicast packets allowed to pass through the interface every second, in the range 1 to 1488100 (in pps, packets per second).
Use the multicast-suppression command to configure multicast suppression by setting a multicast traffic threshold.
Use the undo multicast-suppression command to restore the default.
By default, all multicast traffic is allowed to go through an Ethernet interface, that is, multicast traffic is not suppressed.
Configured in Ethernet interface view, this command takes effect only on the current interface; configured in port group view, this command takes effect on all interfaces in the port group.
Note that:
l           With multicast suppression enabled, the switch discards all multicast packets that cross the predefined multicast threshold to ensure the operation of network services.
l           The multicast suppression setting you configured will overwrite the previous multicast suppression setting, if any.
l           With multicast suppression enabled, broadcast suppression is enabled automatically. However, with broadcast suppression enabled, multicast suppression cannot be enabled.
l           Multicast suppression does not differentiate unknown multicasts from known multicasts.
# Set the multicast threshold to 20 for Ethernet 1/1/1.
[Sysname-Ethernet1/1/1] multicast-suppression 20
# Set the multicast threshold to 20 for all the interfaces in port group 1.
[Sysname-port-group manual group1] multicast-suppression 20
1.1.25  port-group
port-group { manual port-group-name | aggregation agg-id }
undo port-group manual port-group-name
View
Default Level
2: System level
manual port-group-name: Specifies the name of a manual port group, a string of 1 to 32 characters.
aggregation agg-id: Specifies the ID of an existing aggregation port group.
Use the port-group manual command to create a manual port group. If the manual port group identified by the port-group-name argument already exists, this command leads you to manual port group view.
Use the port-group aggregation command to enter aggregation port group view.
Use the undo port-group manual command to remove a manual port group.
By default, no manual port group exists in the system.
# Create a manual port group named “group1”.
1.1.26  port-mode
port-mode { lan | wan }
undo port-mode
View
Default Level
2: System level
lan: Specifies LAN mode.
wan: Specifies WAN mode.
Use the port-mode command to configure a 10GE interface to operate in LAN or WAN mode.
Use the undo port-mode command to restore the default.
By default, a 10GE interface operates in LAN mode.
&  Note:
WAN mode is not supported on LSB1XP4CA, LSB1XK1DB, and LSB1XP4B boards.
Configure the Ten-GigabitEthernet 1/1/1 to operate in WAN mode.
1.1.27  reset counters interface
reset counters interface [ interface-type [ interface-number ] ]
View
Default Level
2: System level
Use the reset counters interface command to clear the statistics on specific interfaces.
To obtain interface statistics within specific period of time, you need to clear the existing interface statistics first.
l           If neither interface type nor interface number is specified, this command clears the statistics on all the interfaces.
l           If only interface type is specified, this command clears the statistics on the interfaces that are of specific type.
l           If both interface type and interface number are specified, this command clears the statistics on the specified interface.
# Clear the statistics on Ethernet1/1/1.
<Sysname> reset counters interface ethernet 1/1/1
1.1.28  shutdown
shutdown
View
Default Level
2: System level
None
Use the shutdown command to shut down an Ethernet interface.
Use the undo shutdown command to bring up an Ethernet interface.
By default, an Ethernet interface is up.
# Shut down interface Ethernet1/1/1.
[Sysname-Ethernet1/1/1] shutdown
# Bring up interface Ethernet1/1/1.
[Sysname-Ethernet1/1/1] undo shutdown
1.1.29  source-mac-tail
source-mac-tail last-byte
undo source-mac-tail
View
Default Level
2: System level
last-byte: Two-digit hexadecimal number to be used as the least octet of the source MAC address.
Use the source-mac-tail command to set the least octet of the source MAC address for an interface.
Use the undo source-mac-tail command to remove the source MAC address setting.
After you execute the source-mac-tail command, packets forwarded on Layer 3 through the interface uses the number set by this command as the least octet of their source MAC addresses.
By default, the source MAC address for an interface is that of the corresponding VLAN interface.
&  Note:
Currently, this command is not supported by the following boards: LSB1GV48DA, LSB1GV48DB, LSB2GV48DA, LSB1GP48DB, LSB1XP4B, LSB1XP4CA, and LSB1XP4DB.
# Set the least octet of the source MAC address to 0x12 for interface Ethernet 3/1/1.
[Sysname] interface ethernet 3/1/1
[Sysname-Ethernet3/1/1] source-mac-tail 12
# Remove the source MAC address setting for the interface Ethernet 3/1/1.
[Sysname-Ethernet3/1/1] undo source-mac-tail
1.1.30  speed
speed { 10 | 100 | 1000 | auto }
undo speed
View
Default Level
2: System level
10: Specifies the interface rate as 10 Mbps.
100: Specifies the interface rate as 100 Mbps.
1000: Specifies the interface rate as 1,000 Mbps.
auto: Specifies the interface rate is determined through auto-negotiation.
Use the speed command to set the operating rate for an Ethernet interface.
Use the undo speed command to restore the default operating rate.
By default, an Ethernet interface determines its operating rate through auto-negotiation.
Note that the speed 1000 command is only applicable to GigabitEthernet interface.
Related commands: duplex.
&  Note:
You cannot set the transmission rate of a ten-GigabitEthernet or 100 Mbps Ethernet optical interface. For a 1000 Mbps Ethernet optical interface, you can only set the transmission rate to 1000 Mbps or auto negotiation.
# Configure the operating rate of interface Ethernet1/1/1 as 100 Mbps.
[Sysname-Ethernet1/1/1] speed 100
