H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
33-SSH Commands
33-SSH Commands 150 KB
Table of Contents
Chapter 1 SSH Configuration Commands. 1-1
1.1 SSH Configuration Commands. 1-1
1.1.1 display public-key local 1-1
1.1.2 display public-key peer 1-3
1.1.3 display sftp client source. 1-4
1.1.4 display ssh client source. 1-5
1.1.5 display ssh server 1-5
1.1.6 display ssh server-info. 1-7
1.1.7 display ssh user-information. 1-8
1.1.8 peer-public-key end. 1-8
1.1.9 public-key-code begin. 1-9
1.1.10 public-key-code end. 1-10
1.1.11 public-key local create. 1-11
1.1.12 public-key local destroy. 1-12
1.1.13 public-key local export rsa. 1-13
1.1.14 public-key local export dsa. 1-14
1.1.15 public-key peer 1-15
1.1.16 public-key peer import sshkey. 1-16
1.1.17 sftp. 1-17
1.1.18 sftp client ipv6 source. 1-18
1.1.19 sftp client source. 1-18
1.1.20 sftp ipv6. 1-19
1.1.21 sftp server enable. 1-20
1.1.22 sftp server idle-timeout 1-21
1.1.23 ssh client authentication server 1-21
1.1.24 ssh client first-time enable. 1-22
1.1.25 ssh client ipv6 source. 1-23
1.1.26 ssh client source. 1-24
1.1.27 ssh server authentication-retries. 1-24
1.1.28 ssh server authentication-timeout 1-25
1.1.29 ssh server compatible-ssh1x enable. 1-26
1.1.30 ssh server enable. 1-26
1.1.31 ssh server rekey-interval 1-27
1.1.32 ssh user 1-28
1.1.33 ssh2. 1-29
1.1.34 ssh2 ipv6. 1-31
1.2 SFTP Configuration Commands. 1-32
1.2.1 bye. 1-32
1.2.2 cd. 1-33
1.2.3 cdup. 1-33
1.2.4 delete. 1-34
1.2.5 dir 1-34
1.2.6 exit 1-35
1.2.7 get 1-36
1.2.8 help. 1-36
1.2.9 ls. 1-37
1.2.10 mkdir 1-38
1.2.11 put 1-38
1.2.12 pwd. 1-39
1.2.13 quit 1-39
1.2.14 remove. 1-40
1.2.15 rename. 1-41
1.2.16 rmdir 1-41
display public-key local { dsa | rsa } public
View
dsa: Displays the public key(s) of DSA local key pair(s).
rsa: Displays the public key(s) of RSA local key pair(s).
Use the display public-key local command to display the information about the public key(s) of the local key pair(s).
Related commands: public-key local create.
# Display the public key information of RSA local key pair(s).
<Sysname> display public-key local rsa public
Time of Key pair created: 19:59:16  2006/10/25
Key name: HOST_KEY
Key type: RSA Encryption Key
Key code:
30819F300D06092A864886F70D010101050003818D0030818902818100BC4C392A97734A633BA0F1DB01F84EB51228EC86ADE1DBA597E0D9066FDC4F04776CEA3610D2578341F5D049143656F1287502C06D39D39F28F0F5CBA630DA8CD1C16ECE8A7A65282F2407E8757E7937DCCDB5DB620CD1F471401B7117139702348444A2D8900497A87B8D5F13D61C4DEFA3D14A7DC07624791FC1D226F62DF3020301
0001
Time of Key pair created: 19:59:17  2006/10/25
Key name: SERVER_KEY
Key code:
307C300D06092A864886F70D0101010500036B003068026100C51AF7CA926962284A4654B2AACC7B2AE12B2B1EABFAC1CDA97E42C3C10D7A70D1012BF23ADE5AC4E7AAB132CFB6453B27E054BFAA0A85E113FBDE751EE0ECEF659529E857CF8C211E2A03FD8F10C5BEC162B2989ABB5D299D1E4E27A13C7DD10203010001
# Display the public key information of DSA local key pair(s).
<Sysname> display public-key local dsa public
Time of Key pair created: 20:00:16  2006/10/25
Key name: HOST_KEY
Key type: DSA Encryption Key
Key code:
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
A4C79054
Table 1-1 Description on fields of the display public-key local command
Time when the key pair is created
Key name
Name of the key
Key type
Type of the key
Key code
Code of the key
display public-key peer [ brief | name publickey-name ]
View
brief: Displays brief information about all public keys of remote ends.
name publickey-name: Specifies a public key by its name, which is a string of 1 to 64 characters.
Use the display public-key peer command to display information about specified or all public keys.
With neither the brief keyword nor the name publickey-name combination specified, the command displays detailed information about all public keys.
Related commands: public-key peer.
# Display detailed information about the public key named idrsa.
<Sysname> display public-key peer name idrsa
  Key name  : idrsa
  Key type  : RSA
  Key module: 1024
Key Code:
30819D300D06092A864886F70D010101050003818B00308187028181009C46A8710216CEC0C01C7CE136BA76C79AA6040E79F9E305E453998C7ADE8276069410803D5974F708496947AB39B3F39C5CE56C95B6AB7442D56393BF241F99A639DD02D9E29B1F5C1FD05CC1C44FBD6CFFB58BE6F035FAA2C596B27D1231D159846B7CB9A7757C5800FADA9FD72F65672F4A549EE99F63095E11BD37789955020123
Table 1-2 Description on fields of the display public-key peer name command
Key name
Name of the key
Key type
Type of the key
Key module
Module of the key
Key code
Code of the key
# Display brief information about all public keys.
<Sysname> display public-key peer brief
Type  Module  Name
RSA   1024    idrsa
DSA   1024    10.1.1.1
Table 1-3 Description on the fields of the display public-key peer brief command
Type of the key
Module
Number of bits in the key
Name
Name of the peer public key
View
None
Use the display sftp client source command to display the source IP address or source interface currently set for the SFTP client.
If neither source IP address nor source interface is specified for the SFTP client, “You didn’t specify the source” will be displayed.
Related commands: sftp client source.
# Display the source IP address of the SFTP client.
<Syaname> display sftp client source
The source IP address you specified is 192.168.0.1
View
None
Use the display ssh client source command to display the source IP address or source interface currently set for the SSH client.
If neither source IP address nor source interface is specified for the SSH client, “You didn't specify the source” will be displayed.
Related commands: ssh client source.
# Display the source IP address of the SSH client.
<Sysname> display ssh client source
display ssh server { status | session }
View
status: Displays the status information of the SSH server.
session: Displays the session information of the SSH server.
Use the display ssh server command to display the status information or session information of an SSH server.
Related commands: ssh server authentication-retries, ssh server rekey-interval, ssh server authentication-timeout, ssh server enable, ssh server compatible-ssh1x enable.
# Display the status information of the SSH server.
<Sysname> display ssh server status
 SSH Server: Disable
 SSH version : 1.99
 SSH authentication-timeout : 60 second(s)
 SSH server key generating interval : 0 hour(s)
 SSH Authentication retries : 3 time(s)
 SFTP Server: Disable
 SFTP Server Idle-Timeout: 10 minute(s)
Table 1-4 Description on fields of the display ssh server status command
SSH Server
Whether the SSH server function is enabled
SSH version
SSH protocol version
When the SSH supports SSH1, the protocol version is 1.99. Otherwise, the protocol version is 2.0.
Authentication timeout period
SSH server key pair update interval
Maximum number of SSH authentication attempts
SFTP Server
Whether the SFTP server function is enabled
SFTP connection idle timeout period
# Display the session information of the SSH server.
<Sysname> display ssh server session
 Conn   Ver   Encry    State         Retry    SerType  Username
 VTY 0  2.0   DES      Established   0        SFTP     client001
Table 1-5 Description on fields of the display ssh server session command
Conn
Connected VTY channel
Ver
SSH server protocol version
Encry
Encryption algorithm
Status of the session, including: Init, Ver-exchange, Keys-exchange, Auth-request, Serv-request, Established, Disconnected
Retry
Number of authentication attempts
SerType
Service type (SFTP, Stelnet)
Username
Name of a user during login
View
None
Use the display ssh server-info command to display the mappings between host public keys and SSH servers saved on a client.
# Display the mappings between host public keys and SSH servers saved on the client.
<Sysname> display ssh server-info
Server Name(IP)                 Server public key name
______________________________________________________
192.168.0.1                      abc_key01
192.168.0.2                      abc_key02
Table 1-6 Descriptions on fields of the display ssh server-info command
Server Name(IP)
Name or IP address of the server
Name of the host public key of the server
View
username: SSH username, a string of 1 to 80 characters.
Use the display ssh user-information command to display information about a specified or all SSH users.
With the username argument not specified, the command displays information about all SSH users.
Related commands: ssh user.
# Display information about all SSH users.
<Sysname> display ssh user-information
 Total ssh users : 2
 Username    Authentication-type   User-public-key-name     Service-type
 yemx        password              null                    stelnet|sftp
 test        publickey             pubkey                     sftp
Table 1-7 Description on fields of the display ssh user-information command
Username
Name of the user
Authentication-type
Authentication type
Public key of the user
Service-type
Service type
peer-public-key end
View
Public key view
None
Use the peer-public-key end command to return from public key view to system view.
# Exit public key view.
[Sysname] public-key peer key1
[Sysname-pkey-public-key] peer-public-key end
[Sysname]
View
Public key view
None
Use the public-key-code begin command to enter RSA key code view.
After entering public key code view, you can input the key data. It must be a hexadecimal string that is generated randomly by the SSH-supported client software and coded compliant to PKCS.
Related commands: public-key peer, public-key-code end.
# Enter public key code view to input the key.
[Sysname-pkey-public-key] public-key-code begin
[Sysname-pkey-key-code]30819F300D06092A864886F70D010101050003818D0030818902818100C0EC8014F82515F6335A0A
[Sysname-pkey-key-code]EF8F999C01EC94E5760A079BD73E4F4D97F3500EDB308C29481B77E719D1643135877E13B1C531B4
[Sysname-pkey-key-code]FF1877A5E2E7B1FA4710DB0744F66F6600EEFE166F1B854E2371D5B952ADF6B80EB5F52698FCF3D6
[Sysname-pkey-key-code]1F0C2EAAD9813ECB16C5C7DC09812D4EE3E9A0B074276FFD4AF2050BD4A9B1DDE675AC30CB020301
[Sysname-pkey-key-code]0001
public-key-code end
View
RSA key code view
None
Use the public-key-code end command to return from public key code view to public key view and to save the configured public key.
The system verifies the key before saving it. If the key contains illegal characters, the system displays an error message and discards the key. If the key is legal, the system saves it.
Related commands: public-key peer, public-key-code begin.
# Exit RSA key code view save the configured public key.
[Sysname-pkey-key-code] public-key-code end
public-key local create { dsa | rsa }
View
dsa: DSA key pair.
rsa: RSA key pair.
Use the public-key local create command to create the local key pair(s).
Note that:
l           After entering this command, you will be prompted to provide the length of the key pair. The length of a server/host key must be in the range 512 to 2048 bits and defaults to 1024. If the key pair already exists, the system will ask you whether you want to overwrite it.
l           The configuration of this command can survive a reboot. You only need to configure it once.
Related commands: public-key local destroy, display public-key local.
# Create RSA local key pair.
[Sysname] public-key local create rsa
NOTES: If the key modulus is greater than 512,
       It may take a few minutes.
Press CTRL+C to abort.
Input the bits in the modulus [default = 1024]:
Generating keys...
# Create DSA local key pair.
[Sysname] public-key local create dsa
       It will take a few minutes.
Input the bits in the modulus[default = 1024]:
Generating keys...
public-key local destroy { dsa | rsa }
View
dsa: DSA key pair.
rsa: RSA key pair.
Use the public-key local destroy command to destroy the local key pair(s).
# Destroy RSA local key pair.
[Sysname] public-key local destroy rsa
Warning: Confirm to destroy these keys? [Y/N]:y
# Destroy DSA local key pair.
[Sysname] public-key local destroy dsa
Warning: Confirm to destroy these keys? [Y/N] : y
public-key local export rsa { openssh | ssh1 | ssh2 } [ filename ]
View
openssh: Uses the format of OpenSSH.
ssh1: Uses the format of SSH1.
ssh2: Uses the format of SSH2.
filename: Name of the file for storing public key.
Use the public-key local export rsa command to display the RSA local public key on the screen or export it to a specified file.
If you do not specify the filename argument, the command displays the RSA local public key on the screen; otherwise, the command exports the RSA local public key to the specified file and saves the file.
SSH1, SSH2 and OpenSSH are three different public key file formats for different requirements.
Related commands: public-key local create, public-key local destroy.
# Export the RSA local public key in OpenSSH format.
[Sysname] public-key local export rsa openssh key.pub
# Display the RSA local public key in SSH2 format.
[Sysname] public-key local export rsa ssh2
---- BEGIN SSH2 PUBLIC KEY ----
Comment: "rsa-key-20061105"
AAAAB3NzaC1yc2EAAAADAQABAAAAgKRkxFoZ+T72Srs9c60+j2yrkd0AHBsXBh0Uq+iNvE12PaYR1On4
x+aNlwe9fjW1PYgzH+DRkTpiMrn3j2pIs7gaJXvefTW94rbVWJ94uiSDk1NLX1JcoTtWnQcVhft3mUZ+
J0jBEhAcw4bROe7/qr6l7VTCo9FBZ0XgKuHroovX
---- END SSH2 PUBLIC KEY ----
# Display the RSA local public key in OpenSSH format.
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgLxMOSqXc0pjO6Dx2wH4TrUSKOyGreHbpZfg2QZv3E8Ed2zqNhDSV4NB9dBJFDZW8Sh1AsBtOdOfKPD1y6Yw2ozRwW7OinplKC8kB+h1fnk33M2122IM0fRxQBtxFxOXAjSERKLYkASXqHuNXxPWHE3vo9FKfcB2JHkfwdIm9i3z rsa-key
public-key local export dsa { openssh | ssh2 } [ filename ]
View
Use the public-key local export dsa command to display the DSA local public key on the screen or export it to a specified file.
If you do not specify the filename argument, the command displays the DSA local public key on the screen; otherwise, the command exports the DSA local public key to the specified file and saves the file.
SSH2 and OpenSSH are two different public key file formats for different requirements.
# Export the DSA local public key in OpenSSH format.
[Sysname] public-key local export dsa openssh key.pub
# Display the DSA local public key in SSH2 format.
[Sysname] public-key local export dsa ssh2
Comment: "dsa-key-20061025"
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
# Display the DSA local public key in OpenSSH format.
ssh-dss AAAAB3NzaC1kc3MAAACA11cmLEWExEwhHxi9luXwYcTwpCP3/mtrhbNM73LOFKDTpSIv4Izs5lvmwmWFSIncHtvRPsiydNqfdbomzLmHcjYCeH6SK6hEIfIsPInLmwb9YP4BlB3dd/5rEok9p27rwdEo2X8GeNdyK1NByFBvNYIUsWovrEs2iVA4eBHH2jMAAAAUx3MhjHN+yO6ZO08t7TD0jtrOkV8AAACAgiaQCeFOxHS68pMuadOx8YUXrZWUGEzN/OrpbsTV75MTPoS0cJPFKyDNNdAkkrOVnsZJliW8T6UILiLFs3ThbdABMs5xsCAhcJGscXthI5HHbB+y6IMXwb2BcdQey4PiEMA8ybMugQVhwhYhxz1tqsAo9LFYXaf0JRlxjMmwnu8AAACAzPH3jghgvpN/08oH0vKhtm505dHhZpPrN01nenphJOur1Z/kh5bFbz/5GfmZrrl9HyuD2bmKwJvB9y6A2+M3yymYmiM3jrIcOO4IPxHtbcjU2+ABuoVFDOoHHCpHHIN2HkzzLBdLQYYSzdWXtEHwyqBdwBy5Ogq7JHwG+6THkFQ= dsa-key
public-key peer keyname
undo public-key peer keyname
View
keyname: Public key name, a string of 1 to 64 characters.
Use the public-key peer command to enter public key view.
Use the undo public-key peer command to delete the configuration of peer public key.
After entering public key view, you can configure the peer public key with the public-key-code begin and public-key-code end commands. This requires that you obtain the hexadecimal public key from the peer beforehand.
Related commands: public-key-code begin, public-key-code end.
# Enter public key view, specifying a public key name of key1.
public-key peer keyname import sshkey filename
View
filename: Public key file name.
Use the public-key peer import sshkey command to import a peer public key from the public key file.
Use the undo public-key peer import sshkey command to remove the setting.
After execution of this command, the system automatically transforms the public key file in SSH1, SSH2 or OpenSSH format to PKCS format, and imports the peer public key. This requires that you get a copy of the public key file from the peer through FTP/TFTP.
# Import a peer public key named key2 from public key file key.pub.
[Sysname] public-key peer key2 import sshkey key.pub
1.1.17  sftp
sftp server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
server: IPv4 address or name of the server, a string of 1 to 20 characters.
port-number: Port number of the server, in the range 0 to 65535. The default is 22.
identity-key: Specifies the algorithm for publickey authentication, either dsa or rsa. The default is dsa.
prefer-ctos-cipher: Preferred encryption algorithm from client to server, defaulted to aes128.
l           aes128: Encryption algorithm aes128-cbc.
l           des: Encryption algorithm des-cbc.
prefer-ctos-hmac: Preferred HMAC algorithm from client to server, defaulted to sha1.
l           md5: HMAC algorithm hmac-md5.
l           md5-96: HMAC algorithm hmac-md5-96.
l           sha1: HMAC algorithm hmac-sha1.
l           sha1-96: HMAC algorithm hmac-sha1-96.
prefer-kex: Preferred key exchange algorithm, defaulted to dh-group-exchange.
l           dh-group-exchange: Key exchange algorithm diffie-hellman-group-exchange-sha1.
l           dh-group1: Key exchange algorithm diffie-hellman-group1-sha1.
l           dh-group14: Key exchange algorithm diffie-hellman-group14-sha1.
prefer-stoc-cipher: Preferred algorithm from server to client, defaulted to aes128.
prefer-stoc-hmac: Preferred HMAC algorithm from server to client, defaulted to sha1.
Use the sftp command to establish a connection to a remote IPv4 SFTP server and enter SFTP client view.
Note that when the client’s authentication method is publickey, the client needs to get the local private key for validation. As the publickey authentication includes RSA and DSA algorithms, you must specify an algorithm (by using the identity-key keyword) in order to get the correct data for the local private key.
# Connect to SFTP server 10.1.1.2.
<Sysname> sftp 10.1.1.2
Input Username:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
undo sftp client ipv6 source
View
ipv6 ipv6-address: Specifies a source IPv6 address.
interface interface-type interface-number: Specifies a source interface by its type and number.
Use the sftp client ipv6 source command to specify the source IPv6 address or source interface for an SFTP client.
Use the undo sftp client ipv6 source command to remove the configuration.
By default, the client uses the interface address specified by the route of the device to access the SFTP server.
# Specify the source IPv6 address of the SFTP client as 2:2::2:2.
[Sysname] sftp client ipv6 source ipv6 2:2::2:2
sftp client source { ip ip-address | interface interface-type interface-number }
undo sftp client source
View
ip ip-address: Specifies a source IPv4 address.
Use the sftp client source command to specify the source IPv4 address or interface of an SFTP client.
Use the undo sftp source-interface command to remove the configuration.
By default, a client uses the IP address or interface specified by the route to access the SFTP server.
Related commands: display sftp client source.
# Specify the source IP address of the SFTP client as 192.168.0.1.
[Sysname] sftp client source ip 192.168.0.1
1.1.20  sftp ipv6
sftp ipv6 server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
server: IPv6 address or name of the server, a string of 1 to 46 characters.
prefer-stoc-cipher: Preferred encryption algorithm from server to client, defaulted to aes128.
Use the sftp ipv6 command to establish a connection to a remote IPv6 SFTP server and enter SFTP client view.
# Connect to server 2:5::8:9.
<Sysname> sftp ipv6 2:5::8:9
Input Username:
sftp server enable
undo sftp server enable
View
None
Use the sftp server enable command to enable SFTP server.
Use the undo sftp server enable command to disable SFTP server.
By default, SFTP server is disabled.
Related commands: display ssh server.
# Enable SFTP server.
[Sysname] sftp server enable
undo sftp server idle-timeout
View
time-out-value: Timeout period in minutes. It ranges from 1 to 35,791.
Use the sftp server idle-timeout command to set the idle timeout period for SFTP user connections.
Use the undo sftp server idle-timeout command to restore the default.
By default, the idle timeout period is 10 minutes.
# Set the idle timeout period for SFTP user connections to 500 minutes.
[Sysname] sftp server idle-timeout 500
ssh client authentication server server assign publickey keyname
undo ssh client authentication server server assign publickey
View
server: IP address or name of the server, a string of 1 to 80 characters.
keyname: Name of the host public key of the server, a string of 1 to 64 characters.
Use the ssh client authentication server command to configure the host public key of the server so that the client can determine whether the server is trustworthy.
Use the undo ssh authentication server command to remove the configuration.
By default, the host public key of the server is not configured, and when logging into the server, the client uses the IP address or host name used for login as the public key name.
# Configure the public key of the server with the IP address of 192.168.0.1 to be key1.
[Sysname] ssh client authentication server 192.168.0.1 assign rsa-key key1
undo ssh client first-time
View
None
Use the ssh client first-time enable command to enable the first authentication function.
Use the undo ssh client first-time command to disable the function.
By default, the function is enabled.
When an SSH client tries to access a server whose public host key it does not know for the first time, the first authentication function enables it to access the server and obtain and save the public host key of the server. When the client accesses the server later, it can use the locally saved public host key of the server to authenticate the server.
With the first authentication function disabled, an SSH client cannot access any server whose public host key it does not know. In this case, you must configure the public host key of the server to be accessed and specify the public key name on the client at first.
# Enable the first authentication function.
[Sysname] ssh client first-time enable
ssh client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
undo ssh client ipv6 source
View
Use the ssh client ipv6 source command to specify the source IPv6 address or source interface for the SSH client.
Use the undo ssh client ipv6 source command to remove the configuration.
By default, the client uses the source address specified by the route of the device to access the SSH server.
# Specify the source IPv6 address as 2:2::2:2 for the SSH client.
[Sysname] ssh client ipv6 source ipv6 2:2::2:2
ssh client source { ip ip-address | interface interface-type interface-number }
undo ssh client source
View
Use the ssh client source command to specify the source IPv4 address or source interface of the SSH client.
Use the undo ssh client source command to remove the configuration.
By default, an SSH client uses the IP address or interface specified by the route to access the SSH server.
Related commands: display ssh client source.
# Specify the source IPv4 address of the SSH client as 192.168.0.1.
[Sysname] ssh client source ip 192.168.0.1
ssh server authentication-retries times
undo ssh server authentication-retries
View
times: Maximum number of authentication attempts, in the range 1 to 5.
Use the ssh server authentication-retries command to set the maximum number of SSH connection authentication attempts, which takes effect at next login.
Use the undo ssh server authentication-retries command to restore the default.
By default, the maximum number of SSH connection authentication attempts is 3.
Note that the threshold specified by using the ssh server authentication-retries command takes into account both publickey authentication attempts and password authentication attempts.
# Set the maximum number of SSH connection authentication attempts to four.
[Sysname] ssh server authentication-retries 4
undo ssh server authentication-timeout
View
time-out-value: Authentication timeout period in seconds, in the range 1 to120.
Use the ssh server authentication-timeout command to set the SSH user authentication timeout period on the SSH server.
Use the undo ssh server authentication-timeout command to restore the default.
By default, the authentication timeout period is 60 seconds.
# Set the SSH user authentication timeout period to 10 seconds.
[Sysname] ssh server authentication-timeout 10
undo ssh server compatible-ssh1x
View
None
Use the ssh server compatible-ssh1x command to enable the SSH server to work with SSH1.x clients.
Use the undo ssh server compatible-ssh1x command to disable the SSH server from working with SSH1.x clients.
By default, the SSH server can work with SSH1.x clients.
This configuration takes effect at next login.
# Enable the SSH server to work with SSH1.x clients.
[Sysname] ssh server compatible-ssh1x enable
ssh server enable
undo ssh server enable
View
None
Use the ssh server enable command to enable SSH server.
Use the undo ssh server enable command to disable SSH server.
By default, SSH server is disabled.
# Enable SSH server.
[Sysname] ssh server enable
ssh server rekey-interval hours
undo ssh server rekey-interval
View
hours: Server key pair update interval in hours, in the range 1 to 24.
Use the ssh server rekey-interval command to set the interval for updating the RSA server key.
Use the undo ssh server rekey-interval command to remove the configuration.
By default, the update interval of the RSA server key is 0, that is, the RSA server key is not updated.
  Caution:
This command is only available to SSH users using SSH1 client software.
# Set the RSA server key pair update interval to three hours.
[Sysname] ssh server rekey-interval 3
1.1.32  ssh user
ssh user username service-type stelnet authentication-type { password | { any | password-publickey | publickey } assign publickey keyname }
ssh user username service-type { all | sftp } authentication-type { password | { any | password-publickey | publickey } assign publickey keyname work-directory directory-name }
undo ssh user username
View
service-type: Specifies the service type of an SSH user, which can be one of the following:
l           all: Specifies both secure Telnet and secure FTP.
l           sftp: Specifies the service type as secure FTP.
l           stelnet: Specifies the service type of secure Telnet.
authentication-type: Specifies the authentication method of an SSH user, which can be one the following:
l           password: Performs password authentication.
l           any: Performs either password authentication or publickey authentication. The server performs publickey authentication first.
l           password-publickey: Performs both password authentication and publickey authentication. A client running SSH1 client only needs to pass either type of authentication while a client running SSH2 client must pass both types of authentication to log in.
l           publickey: Performs publickey authentication.
assign publickey keyname: Assigns an existing public key for an SSH user. keyname indicates the name of the client public key and is a string of 1 to 64 characters.
work-directory directory-name: Specifies the working folder for an SFTP user. directory-name indicates the name of the working folder and is a string of 1 to 135 characters.
Use the ssh user command to create an SSH user and specify the service type and authentication method.
Use the undo ssh user username command to delete an SSH user.
Note that:
l           For a publickey authentication user, you must configure the username and the public key on the device. For a password authentication user, you can configure the account information on either the device or the remote authentication server such as a RADIUS server.
l           If you use the ssh user command to configure a public key for a user who has already had a public key, the new one overwrites the old one.
l           Authentication method and public key configuration for a user that has logged in takes effect when the user logs in next time.
l           If an SFTP user has been assigned a public key, it is necessary to set a working folder for the user.
l           The working folder of an SFTP user is subject to the user authentication method. For a user using only password authentication, the working folder is the AAA authorized one. For a user using only publickey authentication  or using both the publickey and password authentication methods, the working folder is the one set by using the ssh user command.
Related commands: display ssh user-information.
# Create an SSH user named user1, setting the service type as sftp, the authentication method as publickey, the work folder of the SFTP server as flash, and assigning a public key named key1 to the user.
[Sysname] ssh user user1 service-type sftp authentication-type publickey assign publickey key1 work-directory flash:
1.1.33  ssh2
ssh2 server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
Use the ssh2 command to establish a connection to an SSH server, and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms of the client and the server.
# Log in to remote SSH2 server 10.214.50.51, setting the algorithms as follows:
l           Preferred key exchange algorithm: DH-group1
l           Preferred encryption algorithm from server to client: AES128
l           Preferred HMAC algorithm from client to server: MD5
l           Preferred HMAC algorithm from server to client: SHA1-96.
<Sysname> ssh2 10.214.50.51 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
1.1.34  ssh2 ipv6
ssh2 ipv6 server [ port-number ] [ identity-key { dsa | rsa } | prefer-ctos-cipher { aes128 | des } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 } | prefer-kex { dh-group-exchange | dh-group1 | dh-group14 } | prefer-stoc-cipher { aes128 | des } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 } ] *
View
prefer-kex: Preferred key exchange algorithm, default to dh-group-exchange.
Use the ssh2 ipv6 command to establish a connection to an IPv6 SSH server and specify the preferred key exchange algorithm, encryption algorithms, and HMAC algorithms of the client and the server.
# Login to remote SSH2 server 2000::1, setting the algorithms as follows:
<Sysname> ssh2 ipv6 2000::1 prefer-kex dh-group1 prefer-stoc-cipher aes128 prefer-ctos-hmac md5 prefer-stoc-hmac sha1-96
1.2.1  bye
bye
View
SFTP client view
None
Use the bye command to terminate the connection with a remote SFTP server and return to system view.
This command functions as the exit and quit commands.
# Terminate the connection with the remote SFTP server.
sftp-client> bye
Bye
Connection closed.
<Sysname>
1.2.2  cd
cd [ remote-path ]
View
SFTP client view
remote-path: Name of a path on the server.
Use the cd command to change the working path on a remote SFTP server. With the argument not specified, the command displays the current working path.
&  Note:
l      You can use the cd .. command to return to the upper-level directory.
l      You can use the cd / command to return to the root directory of the system.
# Change the working path to new1.
sftp-client> cd new1
Current Directory is:
/new1
1.2.3  cdup
cdup
View
SFTP client view
None
Use the cdup command to return to the upper-level directory.
# From the current working directory /new1, return to the upper-level directory.
sftp-client> cdup
1.2.4  delete
delete remote-file&<1-10>
View
SFTP client view
remote-file&<1-10>: Name of a file on the server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the delete command to delete a specified file from a server.
This command functions as the remove command.
# Delete file temp.c from the server.
sftp-client> delete temp.c
The following files will be deleted:
/temp.c
Are you sure to delete it? [Y/N]:y
This operation may take a long time.Please wait...
File successfully Removed
1.2.5  dir
View
SFTP client view
-a: Displays the filenames or the folder names of the specified directory.
-l: Displays in list form detailed information of the files and folder of the specified directory
remote-path: Name of the directory to be queried.
Use the dir command to display file and folder information under a specified directory.
With the –a and –l keyword not specified, the command displays detailed information of files and folder under the specified directory in a list form.
With the remote-path not specified, the command displays the file and folder information of the current working directory.
This command functions as the ls command.
# Display in a list form detailed file and folder information under the current working directory.
sftp-client> dir
-rwxrwxrwx   1 noone    nogroup      1759 Aug 23 06:52 config.cfg
-rwxrwxrwx   1 noone    nogroup       225 Aug 24 08:01 pubkey2
-rwxrwxrwx   1 noone    nogroup       283 Aug 24 07:39 pubkey1
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:28 pub1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:24 new1
drwxrwxrwx   1 noone    nogroup         0 Sep 28 08:18 new2
-rwxrwxrwx   1 noone    nogroup       225 Sep 28 08:30 pub2
1.2.6  exit
exit
View
SFTP client view
None
Use the exit command to terminate the connection with a remote SFTP server and return to system view.
This command functions as the bye and quit commands.
sftp-client> exit
Bye
Connection closed.
<Sysname>
1.2.7  get
View
SFTP client view
remote-file: Name of a file on the remote SFTP server.
local-file: Name for the local file.
Use the get command to download a file from a remote SFTP server and save it locally.
If you do not specify the local-file argument, the file will be saved locally with the same name as that on the remote SFTP server.
# Download file temp1.c and save it as temp.c locally.
sftp-client> get temp1.c temp.c
Remote  file:/temp1.c --->  Local file: temp.c
Downloading file successfully ended
1.2.8  help
help [ all | command-name ]
View
SFTP client view
all: Displays a list of all commands.
command-name: Name of a command.
Use the help command to display a list of all commands or the help information of an SFTP client command.
With neither the argument nor the keyword specified, the command displays a list of all commands.
# Display the help information of the get command.
sftp-client> help get
get remote-path [local-path]  Download file.Default local-path is the same
                              with remote-path
1.2.9  ls
View
SFTP client view
Use the ls command to display file and folder information under a specified directory.
This command functions as the dir command.
sftp-client> ls
1.2.10  mkdir
mkdir remote-path
View
SFTP client view
remote-path: Name for the directory on a remote SFTP server.
Use the mkdir command to create a directory on a remote SFTP server.
# Create a directory named test on the remote SFTP server.
sftp-client> mkdir test
New directory created
1.2.11  put
View
SFTP client view
local-file: Name of a local file.
remote-file: Name for the file on a remote SFTP server.
Use the put command to upload a local file to a remote SFTP server.
If you do not specify the remote-file argument, the file will be saved remotely with the same name as the local one.
# Upload local file temp.c to the remote SFTP server and save it as temp1.c.
sftp-client> put temp.c temp1.c
Local file:temp.c --->  Remote file: /temp1.c
Uploading file successfully ended
1.2.12  pwd
pwd
View
SFTP client view
None
Use the pwd command to display the current working directory of a remote SFTP server.
# Display the current working directory of the remote SFTP server.
sftp-client> pwd
1.2.13  quit
View
SFTP client view
None
Use the quit command to terminate the connection with a remote SFTP server and return to system view.
This command functions as the bye and exit commands.
sftp-client> quit
Bye
Connection closed.
<Sysname>
1.2.14  remove
remove remote-file&<1-10>
View
SFTP client view
remote-file&<1-10>: Name of a file on an SFTP server. &<1-10> means that you can provide up to 10 filenames, which are separated by space.
Use the remove command to delete a specified file from a remote server.
This command functions as the delete command.
sftp-client> remove temp.c
/temp.c
1.2.15  rename
rename oldname newname
View
SFTP client view
oldname: Original file name or directory name.
newname: New file name or directory name.
Use the rename command to change the name of a specified file or directory on an SFTP server.
# Change the name of a file on the SFTP server from temp1.c to temp2.c.
sftp-client> rename temp1.c temp2.c
File successfully renamed
1.2.16  rmdir
rmdir remote-path&<1-10>
View
SFTP client view
remote-path&<1-10>: Name of the directory on the remote SFTP server. &<1-10> means that you can provide up to 10 filenames that are separated by space.
Use the rmdir command to delete a specified directory from an SFTP server.
# On the SFTP server, delete directory temp1 in the current directory.
sftp-client> rmdir temp1
Directory successfully removed
