H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesS5500 SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
02-VLAN Commands
02-VLAN Commands 178 KB
Table of Contents
Chapter 1 VLAN Configuration Commands. 1-1
1.1 VLAN Configuration Commands. 1-1
1.1.1 description. 1-1
1.1.2 display interface Vlan-interface. 1-2
1.1.3 display vlan. 1-3
1.1.4 interface Vlan-interface. 1-4
1.1.5 ip address. 1-5
1.1.6 shutdown. 1-6
1.1.7 vlan. 1-7
1.2 Port-Based VLAN Configuration Commands. 1-8
1.2.1 port 1-8
1.2.2 port access vlan. 1-9
1.2.3 port hybrid pvid vlan. 1-10
1.2.4 port hybrid vlan. 1-11
1.2.5 port link-type. 1-12
1.2.6 port trunk permit vlan. 1-13
1.2.7 port trunk pvid vlan. 1-14
1.3 MAC Address-Based VLAN Configuration Commands. 1-15
1.3.1 display mac-vlan interface. 1-15
1.3.2 display mac-vlan. 1-15
1.3.3 mac-vlan mac-address. 1-17
1.3.4 mac-vlan enable. 1-18
1.3.5 vlan precedence. 1-19
1.4 Protocol-Based VLAN Configuration Commands. 1-19
1.4.1 display protocol-vlan interface. 1-19
1.4.2 display protocol-vlan vlan. 1-20
1.4.3 port hybrid protocol-vlan. 1-21
1.4.4 protocol-vlan. 1-22
1.5 IP-Subnet-Based VLAN Configuration Commands. 1-25
1.5.1 display ip-subnet-vlan interface. 1-25
1.5.2 display ip-subnet-vlan vlan. 1-26
1.5.3 ip-subnet-vlan. 1-27
1.5.4 port hybrid ip-subnet-vlan vlan. 1-28
Chapter 2 Voice VLAN Configuration Commands. 2-1
2.1 Voice VLAN Configuration Commands. 2-1
2.1.1 display voice vlan oui 2-1
2.1.2 display voice vlan state. 2-2
2.1.3 voice vlan. 2-3
2.1.4 voice vlan aging. 2-4
2.1.5 voice vlan enable. 2-4
2.1.6 voice vlan mac-address. 2-5
2.1.7 voice vlan mode auto. 2-7
2.1.8 voice vlan security enable. 2-8
Chapter 3 GARP/GVRP Configuration Commands. 3-1
3.1 GARP Configuration Commands. 3-1
3.1.1 display garp statistics. 3-1
3.1.2 display garp timer 3-2
3.1.3 garp timer 3-2
3.1.4 garp timer leaveall 3-4
3.1.5 reset garp statistics. 3-5
3.2 GVRP Configuration Commands. 3-5
3.2.1 display gvrp local-vlan interface. 3-5
3.2.2 display gvrp state. 3-6
3.2.3 display gvrp statistics. 3-6
3.2.4 display gvrp status. 3-8
3.2.5 display gvrp vlan-operation interface. 3-8
3.2.6 gvrp. 3-9
3.2.7 gvrp registration. 3-10
1.1.1  description
View
VLAN view, VLAN interface view
text: String that describes the current VLAN or VLAN interface (Space can be included), case sensitive.
l           For VLAN, this is a string of 1 to 32 characters.
l           For VLAN interface, this is a string of 1 to 80 characters.
Use the description command to configure the descriptive string of the current VLAN or VLAN interface.
Use the undo description command to restore the default.
By default, the descriptive string for a VLAN is the VLAN ID, for example, “VLAN 0001"; for a VLAN interface is name of the current VLAN interface, for example, “Vlan-interface 1 Interface”
# Assign a descriptive string RESEARCH for VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] description RESEARCH
# Assign a descriptive string VLAN-INTERFACE-2 for VLAN-interface 2
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description VLAN-INTERFACE-2
display interface vlan-interface [ vlan-interface-id ]
View
vlan-interface-id: VLAN interface ID.
Use the display interface Vlan-interface command to display the relevant information of a VLAN interface.
Execution of the command with vlan-interface-id specified will display the information of the specified VLAN interface; otherwise, information on all created VLAN interfaces will be displayed.
Related commands: interface Vlan-interface.
# Display the information of VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2 current state: DOWN
Line protocol current state: DOWN
Description: Vlan-interface2 Interface
The Maximum Transmit Unit is 1500
Internet protocol processing : disabled
IP Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e200-3904
IPv6 Packet Frame Type: PKTFMT_ETHNT_2,  Hardware Address: 000f-e200-3904
Table 1-1 Description on the fields of  the display interface Vlan-interface command
 The physical state of a VLAN interface
The link layer protocol state of a VLAN interface
The description string of a VLAN interface
The MTU of a VLAN interface
IP packets processing ability
IPv4 outgoing frame format
Hardware address
MAC address corresponding to a VLAN interface
IPv6 outgoing frame format
1.1.3  display vlan
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
View
vlan-id1: Displays the information of a VLAN specified by VLAN ID in the range of 1 to 4,094.
vlan-id1 to vlan-id2: Displays the information of a range of VLANs specified by a VLAN ID range.
all: Displays all current VLAN information except for the reserved VLANs.
dynamic: Displays the information of dynamic VLANs
reserved: Displays information of the reserved VLANs. Protocol modules determine reserved VLANs according to function implementation, and reserved VLANs serve protocol modules. You cannot do any operation on reserved VLANs.
static: Displays static VLAN information.
Use the display vlan command to display VLAN information.
Related commands: vlan.
# Display VLAN 2 information.
<Sysname> display vlan 2
VLAN ID: 2
 VLAN Type: static
 Route interface: not configured
 Description: VLAN 0002
 Tagged   Ports: none
 Untagged Ports:
    GigabitEthernet1/0/1       GigabitEthernet1/0/3            GigabitEthernet1/0/4
# Display VLAN 3 information.
<Sysname> display vlan 3
 VLAN ID: 3
 VLAN Type: static
 Route Interface: configured
 IP Address: 1.1.1.1
 Subnet Mask: 255.255.255.0
 Description: VLAN 0003
 Tagged   Ports: none
 Untagged Ports: none
Table 1-2 Description on the fields of the display vlan command
VLAN ID
VLAN ID
VLAN Type
VLAN type (static or dynamic)
Route interface
Whether the VLAN interface is configured for the VLAN: not configured or configured
VLAN descriptive string
IP Address
IP address of the VLAN interface (not display if the VLAN interface has no IP address configured)
Subnet Mask
Subnet mask of the IP address (not display if the VLAN interface has no IP address configured)
Tagged Ports
Ports through which packets of the VLAN are sent with the VLAN tag kept
Untagged Ports
Ports through which packets of the VLAN are sent with the VLAN tag stripped off
interface Vlan-interface vlan-interface-id
undo interface Vlan-interface vlan-interface-id
View
vlan-interface-id: VLAN interface ID, in the range of 1 to 4,094.
Use the interface Vlan-interface command to enter the specified VLAN interface view. If the specified VLAN interface does not exist, this command creates the VLAN interface and then enters its view. Before creating a VLAN interface, make sure the corresponding VLAN has been created; otherwise, the VLAN interface cannot be created.
Use the undo interface Vlan-interface command to delete the specified VLAN interface.
Related commands: display interface Vlan-interface.
# Create VLAN-interface 2.
[Sysname] vlan 2
1.1.5  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
VLAN interface view
ip-address: IP address of a VLAN interface, in dotted decimal format.
mask: Subnet mask that corresponds to the IP address of a VLAN interface, in dotted decimal format.
mask-length: Length of a sub-net mask, indicated by the number of “1”s. This argument ranges from 0 to 32.
sub: Indicates the address is a sub-IP address of the VLAN interface.
Use the ip address command to specify the IP address and subnet mask for a VLAN interface.
Use the undo ip address command to remove the IP address and sub-net mask for a VLAN interface.
By default, no IP address is configured.
An interface normally has one IP address. To enable a VLAN of a device to connect to multiple subnets, a maximum of 20 IP addresses can be configured on the VLAN interface, in which only one is the main IP address and all the rest are sub-IP addresses. At most five IP addresses can be configured on a VLAN interface on an S5500-EI series switch. Their relationship is illustrated as follows:
l           A newly configured main IP address will replace the original one, if there is one.
l           Using the undo ip address command without any parameter indicates that all IP addresses will be deleted from the VLAN interface.
l           Use the undo ip address ip-address { mask | mask-length } command to delete the main IP address.
l           Use the undo ip address ip-address { mask | mask-length } sub command to delete a sub-IP address.
l           Note that before deletion of the main IP address you must first delete the sub-IP addresses.
# Specify the IP address as 1.1.0.1, the sub-net mask as 255.255.255.0 for the VLAN-interface 1.
[Sysname-Vlan-interface1] ip address 1.1.0.1 255.255.255.0
1.1.6  shutdown
shutdown
View
VLAN interface view
 None
Use the shutdown command to shut down a VLAN interface.
Use the undo shutdown command to bring up a VLAN interface.
By default, the VLAN interface is down if all ports in the VLAN are down, as long as one port in the VLAN is up, the VLAN interface is up
You can use the undo shutdown command to bring up a VLAN interface after related parameters and protocols are configured for the VLAN interface. When there is a fault in a VLAN interface, you can use the shutdown command to shut down the interface and then bring it up using the undo shutdown command. In this way, the interface may resume.
Shutting down/bringing up a VLAN interface does not affect any Ethernet ports in the VLAN. The state of an Ethernet port does not change with the VLAN interface state.
# Shut down the VLAN interface and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
1.1.7  vlan
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
View
vlan-id : VLAN ID, in the range of 1 to 4,094.
vlan-id1 to vlan-id2: Specifies a VLAN range. VLAN ID is in the range 1 to 4094.
all: Creates or deletes all VLANs except reserved VLANs.
Use the vlan vlan-id command to create the specified VLAN. If the specified VLAN exits, the command brings you to its view.
Use the vlan vlan-id1 to vlan-id2 command to create a range of VLANs specified by vlan-id1 and vlan-id2.
Use the undo vlan command to delete specified VLAN(s).
&  Note:
l      As the default VLAN, VLAN 1 cannot be created, or removed.
l      You cannot create/remove reserved VLANs that are reserved for specific function implementation.
l      Dynamic VLANs cannot be removed using the undo vlan command.
l      A VLAN configured with QoS policies cannot be removed.
l      If a VLAN is configured as a remote-probe VLAN for remote port mirroring, it cannot be removed using the undo vlan command unless its remote-probe VLAN configuration is removed.
Related commands: display vlan.
# Enter VLAN 2 view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 4 through VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
1.2.1  port
port interface-list
undo port interface-list
View
VLAN interface view
interface interface-list: Ethernet interface list, in the format of interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> indicates that you can specify up to 10 ports or port ranges.
Use the port command to add one Access port or a group of Access ports to a VLAN.
Use the undo port command to remove one Access port or a group of Access ports from a VLAN.
Note:
l           This command is only applicable to Access ports.
l           All ports have their default link type configured as Access, however, users can manually configure the port type. For more information, refer to port link-type.
# Add the ports from GigabitEthernet 1/0/1 to GigabitEthernet 1/0/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/3
port access vlan vlan-id
undo port access vlan
View
 Ethernet port view, port group view
Use the port access vlan command to add the current Access port to the specified VLAN.
Use the undo port access vlan command to add the current Access port to the default VLAN.
By default, all Access ports are added to VLAN 1.
Execution of the above command in Ethernet port view will apply the configurations to the current port only whereas in port group view will apply the configurations to all ports in the port group.
Ensure the VLAN specified by the vlan-id argument exists before issuing the above commands.
# Add GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
port hybrid pvid vlan vlan-id
undo port hybrid pvid
View
Use the port hybrid pvid vlan command to configure the default VLAN ID of the Hybrid port.
Use the undo port hybrid pvid command to restore the default, that is, VLAN 1.
For a Hybrid port, after you execute the undo vlan command to remove the default VLAN of the Hybrid port, the default VLAN of the Hybrid port does not change. That is to say, the Hybrid port can use the non-existing VLAN as the default VLAN.
Execution of the above commands in Ethernet interface view will apply to the current port only whereas in port group view will apply to all ports in the port group.
The default VLAN ID of local Hybrid port must be consistent with that of the peer; otherwise, packets cannot be forwarded properly.
Related commands: port link-type.
# Configure the default VLAN ID for the Hybrid port GigabitEthernet 1/0/1 to be 100.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
undo port hybrid vlan vlan-id-list
View
vlan-id-list: The range of VLANs that the Hybrid ports will be added to, vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4,094 and &<1-10> indicates that the you can specify up to 10 VLAN IDs or VLAN ID ranges.
tagged: Specifies to send the packets of the specified VLAN (s) with the tags kept.
untagged: Specifies to send the packets of the specified VLAN(s) with the tags stripped off.
Use the port hybrid vlan command to add the current Hybrid port to the specified VLAN(s).
Use the undo port hybrid vlan command to remove the current Hybrid port from the specified VLAN(s).
The Hybrid port can allow multiple VLANs to pass. If you execute the port hybrid vlan command for multiple times, the VLANs allowed on the Hybrid port are the set of VLANs specified by vlan-id-list in each execution.
# Add the Hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and the range of VLANs from VLAN 50 to VLAN 100, and configure the port to send packets of all these VLANs with tags kept.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
# Add Hybrid ports of port group 2 to VLAN 2. Packets are untagged when sent by the ports.
[Sysname] vlan 2
[Sysname] port-group manual 2
[Sysname-port-group-manual-2] group-member GigabitEthernet 1/0/1 to GigabitEthernet 1/0/6
[Sysname-port-group-manual-2] port link-type hybrid
[Sysname-port-group-manual-2] port hybrid vlan 2 untagged
 Configuring GigabitEthernet1/0/1... Done.
 Configuring GigabitEthernet1/0/2... Done.
 Configuring GigabitEthernet1/0/3... Done.
 Configuring GigabitEthernet1/0/4... Done.
 Configuring GigabitEthernet1/0/5... Done.
 Configuring GigabitEthernet1/0/6... Done.
undo port link-type
View
access: Configures the link type of a port as Access.
hybrid: Configures the link type of a port as Hybrid.
trunk: Configures the link type of a port as Trunk.
Use the port link-type command to configure the link type of a port.
Use the undo port link-type command to restore the default link type of a port, which is Access by default.
&  Note:
The Trunk and Hybrid ports cannot be converted to each other directly. You can convert either to the Access port, and then to the other type. For example, convert a Trunk port to an Access port, and then to a Hybrid port.
# Configure GigabitEthernet 1/0/1 to be a Trunk port.
# Configure all the ports in the manual port group group1 as Hybrid ports.
[Sysname] port-group manual group1
[Sysname-port-group manual group1] group-member GigabitEthernet 1/0/1
[Sysname-port-group manual group1] group-member GigabitEthernet 1/0/2
[Sysname-port-group manual group1] port link-type hybrid
undo port trunk permit vlan { vlan-id-list | all }
View
vlan-id-list: The range of VLANs that the Hybrid ports will be added to, in the format of vlan-id-list = [ vlan-id1 [ to vlan-id2 ] ]&<1-10>, where vlan-id ranges from 1 to 4,094 and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges.
all: Adds the Trunk port to all VLANs.
Use the port trunk permit vlan command to add a Trunk port to a specified VLAN, a selection of VLANs, or all VLANs.
Use the undo port trunk permit vlan command to remove the Trunk port from a specified VLAN, a selection of VLANs, or all VLANs.
The Trunk port can allow multiple VLANs to pass. If you execute the port trunk permit vlan command for multiple times, the VLANs allowed on the Trunk port are the set of VLANs specified by vlan-id-list in each execution.
# Add the Trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and the range of VLANs from VLAN 50 to VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
port trunk pvid vlan vlan-id
undo port trunk pvid
View
Use the port trunk pvid vlan command to configure the default VLAN ID for the Trunk port.
Use the undo port trunk pvid command to restore the default.
By default, the default VLAN on a Trunk port is VLAN 1.
For a Trunk port, after you execute the undo vlan command to remove the default VLAN of the Trunk port, the default VLAN of the Trunk port does not change. That is to say, the Trunk port can use the non-existing VLAN as the default VLAN.
You must configure the same default VLAN ID for the Trunk ports on both the local and peer devices. Otherwise, the packets cannot be transmitted properly.
# Configure the default VLAN ID for the Trunk port GigabitEthernet 1/0/1 as 100.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
View
None
Use the display mac-vlan interface command to display all the ports with MAC address-based VLAN enabled.
Related commands: mac-vlan enable.
# Display all the interfaces with MAC VLAN enabled.
<Sysname> display  mac-vlan interface
  MAC VLAN is enabled on following ports:
    GigabitEthernet1/0/1  GigabitEthernet1/0/2  GigabitEthernet1/0/3
display mac-vlan { all | dynamic | mac-address mac-addr [ mask mac-mask ] | static | vlan vlan-id }
View
all: Displays all the MAC address-to-VLAN entries.
dynamic: Displays dynamically configured MAC address-to-VLAN entries.
mac-address mac-addr: Displays the MAC address-to-VLAN entry containing the specified MAC address.
mask mac-mask: Displays the MAC address-to-VLAN entries with their MAC addresses in the specified range.
static: Displays the statically configured MAC address-to-VLAN entries.
vlan vlan-id: Displays the MAC address-to-VLAN entries associated with the specified VLAN.
Use the display mac-vlan command to display the information about specific MAC address-to-VLAN entries.
If the mac-address mac-addr keyword-argument combination is specified while the mask keyword is not specified, only the information about the MAC address-to-VLAN entry containing the specified MAC address is displayed.
# Display the information about all the MAC address-to-VLAN entries.
<Sysname> display mac-vlan all
  The following MAC VLAN addresses exist:
  S: Static   D: Dynamic
  MAC ADDR           MASK                    VLAN ID   PRIO    STATE
  0008-0001-0000     ffff-ff00-0000          5         3       S
  0002-0001-0000     ffff-ffff-ffff          5         3       S&D
  Total MAC VLAN address count:2
Table 1-3 Description on the fields of the display mac-vlan command
The following MAC-VLAN address exist:
The information about the existing MAC address-to-VLAN entries is listed.
S: Static
The character S stands for the MAC address-to-VLAN entries that are configured statically.
D: Dynamic
The character D stands for the MAC address-to-VLAN entries that are configured dynamically.
MAC ADDR
MAC address of a MAC address-to-VLAN entry
MASK
Mask of the MAC address of a MAC address-to-VLAN entry
VLAN ID
VLAN ID of a MAC address-to-VLAN entry
PRIO
802.1p priority corresponding to the MAC address of a MAC address-to-VLAN entry
STATE
The state of a MAC address-to-VLAN entry, which can be:
S, indicating that the MAC address-to-VLAN entry is configured statically.
D, indicating that the MAC address-to-VLAN entry is configured automatically through the authentication server
S&D, indicating that the MAC address-to-VLAN entry is configured both statically and dynamically
mac-vlan mac-address mac-addr [ mask mac-mask ] vlan vlan-id  [ priority priority ]
undo mac-vlan { all | mac-address mac-addr  [ mask mac-mask ] | vlan vlan-id }
View
mac-address mac-addr: Specifies a MAC address.
mask mac-mask: Specifies the mask for the MAC address in the format of H-H-H. The mac-mask argument comprises two parts: the high-order part (all the binary bits of which are 1s) and the low-order part (all the binary bits of which are 0s). By default, the hexadecimal digits of this argument are all Fs.
vlan vlan-id: Specifies a VLAN ID, in the range of 1 to 4094.
priority priority: Specifies the 802.1p priority value corresponding to the specified MAC address. This argument is in the range of 0 to 7.
all: Removes all the static MAC address-to-VLAN entries.
Use the mac-vlan mac-address command to set the VLAN and priority value corresponding to a specific MAC address.
Use the undo mac-vlan command to remove the association between MAC addresses and VLANs.
Two MAC address-to-VLAN entry tables exist in a device. One table contains the MAC address-to-VLAN entries configured with the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a group of MAC addresses and a VLAN, and the priority. Another table contains the MAC address-to-VLAN entries configured with the mask keyword not specified. A MAC address-to-VLAN entry of this type describes the relationship between a single MAC address and a VLAN, and priority. The system adds/removes MAC address-to-VLAN entries to/from the two tables according to your configuration.
# Associate a single MAC address 000f-e201-1111 with VLAN 100 and set the priority to 7.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 priority 7
# Associate the MAC addresses with the high-order six hexadecimal digits being 111122 .with VLAN 100 and set the priority to 4.
[Sysname] mac-vlan mac-address 1111-2222-3333 mask ffff-ff00-0000 vlan 100 priority 4
mac-vlan enable
undo mac-vlan enable
View
Ethernet port view
None
Use the mac-vlan enable command to enable MAC address-based VLAN on a port.
Use the undo mac-vlan enable command to disable MAC address-based VLAN on a port.
By default, MAC address-based VLAN is disabled on a port.
# Enable MAC address-based VLAN on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] mac-vlan enable
vlan precedence { mac-vlan | ip-subnet-vlan }
undo vlan precedence
View
Ethernet port view
mac-vlan: Specifies to match VLANs based on MAC addresses preferentially.
ip-subnet-vlan: Specifies to match VLANs based on IP subnet settings preferentially.
Use the vlan precedence command to set the order of VLAN matching.
Use the undo vlan precedence command to restore the default.
By default, VLANs are matched based on MAC addresses preferentially.
Note that these two commands only apply to VLANs based on a single MAC address and IP subnet-based VLANs. If both MAC address-based VLANs and IP subnet-based VLANs are enabled on a port, MAC address-to-VLAN entries configured with the mask keyword specified are matched preferentially, and the left VLAN entries are matched as configured by the vlan precedence command.
# Configure to match VLANs based on MAC addresses preferentially on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] vlan precedence mac-vlan
display protocol-vlan interface { interface-listtype interface-number1 [ to interface-type interface-number2 ] | all }
View
interface-type interface-number1: Specifies a port by its type and number.
interface-type interface-number1 to interface-type interface-number2: Specifies a port range.
all: Displays protocol information and protocol indexes of all ports.
Use the display protocol-vlan interface command to display protocol-based VLAN information on the specified port(s).
# Display protocol based VLAN information on GigabitEthernet 1/0/1.
<Sysname> display protocol-vlan interface GigabitEthernet 1/0/1
   VLAN ID   Protocol Index      Protocol Type
       2          0               ipv4
       2          3               ipx ethernetii
Table 1-4 Description on the fields of the display protocol-vlan interface command
Interface of which you want to view the information
VLAN ID
VLAN ID
Protocol Index
Protocol index
Protocol Type
Protocol type
display protocol-vlan vlan { vlan-id [ to vlan-id ] | all }
View
vlan-id: VLAN ID, in the range of 1 to 4,094.
to: Specifies a VLAN range, the value after this keyword must be greater than or equal to that before it.
all: All VLANs.
Use the display protocol-vlan vlan command to display the protocol information and protocol index configured on the specified VLAN(s).
# Display the protocol information and protocol index configured on all protocol-based-VLANs.
<Sysname> display protocol-vlan vlan all
 VLAN ID:2
          0              ipv4
          3              ipx ethernetii
 VLAN ID:3
          0              ipv4
          1              ipx snap
Refer to Table 1-4 for description of the output.
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo port hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
View
vlan vlan-id: Specifies a VLAN ID, in the range 1 to 4094.
protocol-index: Beginning protocol index, in the range 0 to 15, automatically numbered according to the order in which protocols are associated with the VLAN if not manually specified. You can use the display protocol-vlan vlan all command to display the protocol indexes.
to protocol-end: Specifies the end protocol index, in the range 0 to 15. The protocol-end argument must be greater than or equal to the beginning protocol index.
all: All protocols.
Use the port hybrid protocol-vlan vlan command to associate the port(s) with a protocol-based VLAN.
Use the undo port hybrid protocol-vlan command to delete the association between the port(s) and the protocol-based VLAN.
Execution of the above commands in Ethernet interface view  will apply the configurations to the current port only whereas in port group view will apply the configurations to all ports in the port group.
Note that only the Hybrid ports support the above feature at the moment. Before issuing this command, ensure that the port has been added to the VLAN to be associated with and that the VLAN has been assigned with a protocol.
Related commands: display protocol-vlan interface.
# Associate Hybrid port GigabitEthernet 1/0/1 with protocol 0 in VLAN 2.
[Sysname] vlan 2
[Sysname-Vlan2] protocol-vlan ipx ethernetii
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 untagged
 Please wait... Done
[Sysname-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 2 0
1.4.4  protocol-vlan
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
View
VLAN view
at: Specifies the AppleTalk based VLAN.
ipv4: Specifies the IPv4 based VLAN.
ipv6: Specifies the IPv6 based VLAN.
ipx: Specifies the IPX based VLAN. The keywords ethernetii, llc, raw, and snap are encapsulation formats.
mode: Configures self-defined protocol template for the VLAN, which could also have four encapsulation formats, namely,  ethernetii, llc, raw, and snap.
ethernetii etype etype-id: Specifies to match Ethernet II encapsulation format and the corresponding protocol type values. The etype-id argument is the Ethernet type of inbound packets, in the range 0x0600 to 0xffff (excluding 0x0800, 0x809b, 0x8137, and 0x86dd).
llc: Specifies to match the llc encapsulation format.
dsap dsap-id: Specifies the destination service access point, in the rang 00 to ff.
ssap ssap-id: Specifies the source service access point, in the rang 00 to ff.
snap etype etype-id: Specifies to match SNAP encapsulation format and the corresponding protocol type values. The etype-id argument is the Ethernet type of inbound packets, in the range 0x0600 to 0xffff (excluding ipx snap under the snap encapsulation format).
protocol-index: Beginning protocol index, in the range 0 to 15. System will automatically assign an index if this parameter is not specified.
to protocol-end: Specifies the end protocol index, in the range 0 to 15, and must be greater than or equal to the protocol-index argument.
all: Specifies all the protocol indexes.
  Caution:
l      At present, the AppleTalk-based protocol template cannot be associated with a port on an S5500-EI series Ethernet switch.
l      Do not configure both the dsap-id and ssap-id arguments in the protocol-vlan command as 0xe0 or 0xff when configuring the user-defined template for llc encapsulation. Otherwise, the encapsulation format of the matching packets will be the same as that of the ipx llc or ipx raw packets respectively. When either of the dsap-id and ssap-id arguments is configured, the system assigns aa to the other argument.
l      When you use the mode keyword to configure a user-defined protocol template, do not set etype-id in ethernetii etype etype-id to 0x0800, 0x8137,  0x809b, or 0x86dd. Otherwise, the encapsulation format of the matching packets will be the same as that of the IPv4, IPX, AppleTalk, and IPv6 packets respectively.
Use the protocol-vlan command to configure the VLAN as a protocol based VLAN and configure the protocol template for the VLAN.
Use the undo protocol-vlan command to remove the configured protocol template.
Related commands: display protocol-vlan vlan.
&  Note:
To ensure proper data transmission, do not configure a VLAN as both a protocol-based VLAN and a voice VLAN.
# Specify VLAN 3 as the IPv4 based VLAN to make the VLAN transmit IPv4 packets.
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan ipv4
  Caution:
Because the IP protocol is closely associated with the ARP protocol, when configuring IPv4 protocol for a VLAN, you are recommended to configure the ARP protocol for the same VLAN as well, and associate the two protocols with the same port to avoid that ARP packets and IP packets are not assigned to the same VLAN, which will cause IP address resolution failure, affecting normal communications.
# Configure ARP protocol template for VLAN3 (ARP code is 0x0806) to make VLAN 3 transmit ARP packets.
l           To use Ethernet encapsulation, use the command:
[Sysname-vlan3] protocol-vlan mode ethernetii etype 0806
l           To use 802.3 encapsulation, use the command:
[Sysname-vlan3] protocol-vlan mode snap etype 0806
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 | all }
View
interface-type interface-number1: Port type and port number.
interface-type interface-number1 to interface-type interface-number2: Specify a port range.
all: Displays the IP-subnet-based VLAN information about all the ports with IP-subnet-based VLAN configured.
Use the display ip-subnet-vlan interface command to display the IP-subnet-based VLAN information and IP subnet index on the specified port(s).
# Display the IP-subnet-based VLAN information and IP subnet index on GigabitEthernet 1/0/1.
<Sysname> display ip-subnet-vlan interface 1/0/1
  VLAN ID   Subnet-Index    IP ADDRESS        NET MASK
     3           0             192.168.1.0    255.255.255.0
Table 1-5 Description on the fields of the display ip-subnet-vlan interface command
VLAN ID
VLAN ID
Subnet-Index
Index of the IP subnet
IP ADDRESS
IP address of the subnet (can be either an IP address or a network address)
NET MASK
Mask of the IP subnet
display ip-subnet-vlan vlan { vlan-id [ to vlan-id ] | all }
View
vlan-id: VLAN ID, in the range 1 to 4094.
to: Specifies a VLAN ID range, the argument to the right of this keyword must be greater than or equal to that to the left of this keyword.
all: Specifies all the VLANs.
Use the display ip-subnet-vlan vlan command to display the IP subnet information and IP subnet index on the specified VLAN(s).
# Display the IP subnet information of all VLANs.
<Sysname> display ip-subnet-vlan vlan all
VLAN ID:  3
 Subnet Index      IP Address      Subnet Mask
Table 1-6 Description on the fields of the display ip-subnet-vlan vlan command
VLAN ID
VLAN ID
Subnet Index
IP subnet Index
IP Address
IP address of the subnet (can be an IP address or a network address)
Subnet Mask
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
View
VLAN view
ip-subnet-index: IP subnet Index, in the range of 0 to 11. This value can be configured by users, or automatically numbered by system based on the order in which the IP subnets or IP addresses are associated with the VLAN.
ip ip-address [mask]: Specifies the source IP address or network address based on which the subnet-based VLANs are classified, in dotted decimal notation. The mask argument is the subnet mask of the source IP address or network address, in dotted decimal notation with a default value of 255.255.255.0.
to: Specifies an IP subnet Index range.
ip-subnet-end: The last index value of the IP subnet, in the range of 0 to 11, must be greater than or equal to the ip-subnet-index value.
all: Removes all the associations between the VLAN and specified IP subnets or IP addresses.
Use the ip-subnet-vlan command to associate the current VLAN with a specified IP subnet or IP address.
Use the undo ip-subnet-vlan command to delete the association.
Note that the IP subnet or IP address cannot be a multicast network segment or a multicast address.
Related commands: display ip-subnet-vlan vlan.
# Configure VLAN 3 to be an IP-subnet-based VLAN. Associate it with the 192.168.1.0/24 network segment.
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
View
all: All VLANs.
Use the port hybrid ip-subnet-vlan vlan command to associate the current Ethernet port with the specified IP-subnet-based VLAN.
Use the undo port hybrid ip-subnet-vlan vlan command to remove the association between the current Ethernet port and the IP-subnet-based VLAN(s).
Note that only the Hybrid ports support the above feature at the moment. Before issuing this command, ensure that the port has been added to the IP-subnet-based VLAN to be associated with. Otherwise, the port cannot be associated with the VLAN.
Related commands: display ip-subnet-vlan interface.
# Associate GigabitEthernet 1/0/1 with the IP-subnet-based VLAN 3.
[Sysname] vlan 3
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 3 untagged
 Please wait... Done.
[Sysname-GigabitEthernet1/0/1] port hybrid ip-subnet-vlan vlan 3
View
None
Use the display voice vlan oui command to display the currently supported organizationally unique identifier (OUI) address(es), the OUI address mask, and the descriptive string.
Related commands: voice vlan, voice vlan enable.
&  Note:
As the first 24 bits of a MAC address (in binary format), an OUI address is a globally unique identifier assigned to a vendor by IEEE.
# Display the OUI address of the voice VLAN.
<Sysname> display voice vlan oui
Oui Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3com phone
Table 2-1 Description on the fields of the display voice vlan oui command
Oui Address
OUI addresses that are allowed to pass
Mask
Masks of the OUI addresses that are allowed to pass
Description of the OUI addresses that are allowed to pass
View
None
Use the display voice vlan state command to display the voice VLAN configuration.
Related commands: voice vlan vlan-id enable, voice vlan enable.
# Display the voice VLAN configurations.
<Sysname> display voice vlan state
 Voice VLAN status: ENABLE
 Voice VLAN ID: 2
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled port and its mode:
 PORT                        MODE
 GigabitEthernet1/0/2        MANUAL
 GigabitEthernet1/0/3        MANUAL
 GigabitEthernet1/0/4        MANUAL
 GigabitEthernet1/0/5        AUTO
Table 2-2 Description on the fields of  the display voice vlan state command
Voice VLAN status
The current voice VLAN status: ENABLE or DISABLE.
Voice VLAN ID
ID of the voice VLAN
Security mode for the voice VLAN
Aging time of the voice VLAN
Current voice vlan enabled port and its mode
The port that is currently enabled with the voice VLAN feature and its voice VLAN mode
PORT
port ID
MODE
Voice VLAN mode of the port: manual or automatic.
2.1.3  voice vlan
undo voice vlan enable
View
vlan-id: ID of the VLAN to be enabled with the voice VLAN feature, in the range of 2 to 4,094.
Use the voice vlan command to enable the voice VLAN feature globally.
Use the undo voice vlan enable command to disable the voice VLAN feature globally.
l           Only one VLAN of a device can have the voice VLAN function enabled at a time, and the VLAN must be an exsiting static VLAN.
l           To configure a VLAN as a voice VLAN, the specified VLAN must exist and cannot be VLAN 1. Otherwise, the configurations will fail.
l           To delete a VLAN with voice VLAN enabled, you need to disable the voice VLAN feature before deleting the VLAN.
Related commands: display voice vlan state.
# Enable the voice VLAN feature on VLAN 2(assuming that VLAN 2 already exists).
[Sysname] voice vlan 2 enable
voice vlan aging minutes
undo voice vlan aging
View
minutes: Aging time of a voice VLAN, in the range 5 to 43,200 minutes.
Use the voice vlan aging command to configure the aging time of a voice VLAN.
Use the undo voice vlan aging command to restore the default aging time of a voice VLAN.
By default, the aging time of a voice VLAN is 1440 minutes.
When a port in automatic voice VLAN mode receives voice packets, the system will decide whether to add the port to the voice VLAN based on the source MAC address contained in the inbound voice packets. When adding the port to the voice VLAN, the system starts the aging timer at the same time. If within the aging time, no voice packets are received on the port, the system automatically removes the port from the voice VLAN when the aging time expires.
# Configure the aging time of the voice VLAN as 100 minutes.
[Sysname] voice vlan aging 100
voice vlan enable
View
Ethernet port view
None
Use the voice vlan enable command to enable the voice VLAN feature on an Ethernet port.
Use the undo voice vlan enable command to disable the voice VLAN feature on an Ethernet port.
No voice VLAN is enabled on a port by default.
l           For a port configured to work in automatic voice VLAN mode, the port must be a Trunk or Hybrid port. An Access port configured in automatic mode cannot be enabled with the voice VLAN feature.
l           Enable the voice VLAN feature globally before enabling the feature on a port
l           The voice VLAN functions properly only after the voice VLAN feature is enabled both globally and on a port.
# Enable the voice VLAN feature on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] voice vlan enable
voice vlan mac-address mac-addr mask oui-mask [ description text ]
undo voice vlan mac-address oui
View
mac-addr: MAC address, in the format of H-H-H, such as 1234-1234-1234.
mask oui-mask: Specifies the valid length of the OUI address, represented in mask, in the format of H-H-H, with the higher bits being consecutive fs and the lower bits 0s, for example, ffff-f000-0000.
description text: Specifies a string that describes the OUI address. The string is of 1 to 30 characters and is case sensitive.
oui: Specifies the OUI address to be removed, in the format H-H-H, such as 1234-1200-0000, which is the logic AND result of mac-addr and oui-mask. Using the display voice vlan oui command can display OUI address information. The OUI address cannot be a broadcast, multicast or address of all 0s or all fs.
Use the voice vlan mac-address command to configure the specified OUI address to be identified by the voice VLAN.
Use the undo voice vlan mac-address command to remove an OUI address identified by the voice VLAN.
A maximum of 16 OUI addresses can be supported by the system.
By default, the system is configured with the default OUI addresses, which can be removed and then added, as illustrated in the following table.
Table 2-3 Default OUI addresses
Number
OUI
1
0001-e300-0000
Siemens phone
2
0003-6b00-0000
Cisco phone
3
0004-0d00-0000
Avaya phone
4
0060-b900-0000
Philips/NEC phone
5
00d0-1e00-0000
Pingtel phone
6
00e0-7500-0000
Polycom phone
7
00e0-bb00-0000
3com phone
Related commands: display voice vlan oui.
# Configure the OUI address as 1234-1234-1234, the mask as ffff-ff00-0000, and the descriptive string as phone A, that is, voice packets from Phone A with source MAC address being 1234-1234-1234 can pass through the voice VLAN.
[Sysname] voice vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
# Display information about the supported OUI address.
1234-1200-0000  ffff-ff00-0000  PhoneA
# Disable voice packets of Phone A from passing through the voice VLAN.
[Sysname] undo voice vlan mac-address 1234-1200-0000
undo voice vlan mode auto
View
Ethernet port view
None
Use the voice vlan mode auto command to configure the voice VLAN mode on the current port to be automatic.
Use the undo voice vlan mode auto command to configure the voice VLAN mode on the current port to be manual.
By default, the port voice VLAN mode is automatic.
Different voice VLAN modes can be configured on different ports, independent of one another.
Note that: if a port is enabled with voice VLAN and works in manual mode, you need to add the port to the voice VLAN manually to make the voice VLAN take effect on the port.
 # Configure the voice VLAN work mode on GigabitEthernet 1/0/1 as manual.
[Sysname-GigabitEthernet1/0/1] undo voice vlan mode auto
undo voice vlan security enable
View
None
Use the voice vlan security enable command to enable the security mode for the voice VLAN.
Use the undo voice vlan security enable command to disable the security mode for  the voice VLAN.
By default, the security mode for the voice VLAN is enabled.
# Disable the security mode for the voice VLAN.
[Sysname] undo voice vlan security enable
display garp statistics [ interface interface-list ]
View
interface interface-list: Specifies an Ethernet port list, in the format of { interface-type interface-number [ to interface-type interface-number ] }&<1-10>, where &<1-10> means that you can specify up to 10 port ranges. A port range defined without the to interface-type interface-number portion comprises only one port.
Use the display garp statistics command to display GARP statistics of specified or all the ports.
Note that:
l           If the interface interface-list keyword-argument combination is not specified, this command displays the GARP statistics of all the ports.
l           If the interface interface-list keyword-argument combination is specified, this command displays the GARP statistics of the specified ports.
# Display statistics about GARP for port GigabitEthernet 1/0/1.
<Sysname> display garp statistics interface GigabitEthernet1/0/1
        GARP statistics on port GigabitEthernet1/0/1
        Number of GVRP Frames Received          : 0
        Number of GVRP Frames Transmitted       : 0
        Number of Frames Discarded              : 0
display garp timer [ interface interface-list ]
View
Use the display garp timer command to display GARP timer settings of specific ports.
Note that:
l           If the interface interface-list keyword-argument combination is not specified, this command displays the GARP timer settings of all the ports.
l           If the interface interface-list keyword-argument combination is specified, this command displays the GARP timer settings of the specified ports.
Related commands: garp timer, garp timer leaveall.
# Display GARP timers on port GigabitEthernet 1/0/1.
<Sysname> display garp timer interface GigabitEthernet 1/0/1
        GARP timers on port GigabitEthernet1/0/1
                Garp Join Time          : 20 centiseconds
                Garp Leave Time         : 60 centiseconds
                Garp LeaveAll Time      : 1000 centiseconds
                Garp Hold Time          : 10 centiseconds
3.1.3  garp timer
garp timer { hold | join | leave } timer-value
undo garp timer { hold | join | leave }
View
hold: Sets the hold timer.
join: Sets the join timer.
leave: Sets the leave timer.
timer-value: Timer setting (in centiseconds), which must be a multiple of 5 centiseconds.
Use the garp timer command to set a GARP timer for an Ethernet port or all ports in a port group in compliance with the timer setting dependencies shown in Table 3-1.
Use the undo garp timer command to restore the default of a GARP timer. This may fail if the default does not satisfy the dependencies shown in Table 3-1.
By default, the hold timer, the join timer, and the leave timer are set to 10 centiseconds, 20 centiseconds, and 60 centiseconds.
Note that:
l           In Ethernet port view, these two commands apply to the current port only; in port group view, these two commands apply to all the ports in the port group.
l           When restoring the default GARP timers, you are recommended to do that on the timers in the order of hold, join, leave, and leaveall.
l           When configuring GARP timers, note that their values are dependent on each other and must be a multiplier of five centiseconds. If the value range for a timer is not desired, you may change it by tuning the value of another timer as shown in the following table:
Table 3-1 Dependencies of GARP timers
Timer
Lower limit
Upper limit
Hold
10 centiseconds
Not greater than half of the join timer setting
Join
Not less than two times the hold timer setting
Less than half of the leave timer setting
Leave
Greater than two times the join timer setting
Less than the leaveall timer setting
Leaveall
Greater than the leave timer setting
32765 centiseconds
Related commands: display garp timer.
# Set the GARP join timer on port GigabitEthernet 1/0/1 to 25 centiseconds, assuming that both the hold timer and the leave timer are using the default.
[Sysname-GigabitEthernet1/0/1] garp timer join 25
garp timer leaveall timer-value
undo garp timer leaveall
View
timer-value: Leaveall timer setting, in the range 65 to 32765 (in centiseconds), Note that the setting of the leaveall timer must be a multiple of 5 centiseconds and must be greater than the leave timer settings of all the ports.
Use the garp timer leaveall command to set the leaveall timer of GARP.
Use the undo garp timer leaveall command to restore the default. This may fail if the default is less than the setting of the current leave timer.
By default, the setting of the leaveall timer is 1000 centiseconds (that is, 10 seconds).
A leaveall timer starts upon the start of a GARP application entity. When this timer expires, the entity sends a LeaveAll message so that other entities can re-register its attribute information and starts another leaveall timer at the same time.
Each time a device on the network receives a LeaveAll message, it resets its leaveall timer. Therefore, a GARP application entity may send LeaveAll messages at the interval set by its leaveall timer or the leaveall timer on another device on the network, whichever is smaller.
# Set the leaveall timer to 100 centiseconds, assuming that the leave timer is 60 centiseconds.
[Sysname] garp timer leaveall 100
reset garp statistics [ interface interface-list ]
View
Use the reset garp statistics command to clear GARP statistics of specific or all the ports.
Note that:
l           If the interface interface-list keyword-argument combination is not specified, this command clears the GARP statistics of all the ports.
l           If the interface interface-list keyword-argument combination is specified, this command clears the GARP statistics of the specified ports.
Related commands: display gvrp statistics.
# Clear statistics about GARP on all ports.
<Sysname> reset garp statistics
display gvrp local-vlan interface interface-type interface-number
View
Use the display gvrp local-vlan interface command to display the local VLAN information maintained by GVRP on a port.
# Display the local VLAN information maintained by GVRP on GigabitEthernet 1/0/1.
<Sysname> display gvrp local-vlan interface GigabitEthernet 1/0/1
 Following VLANs exist in GVRP local database:
  1(default),2-500
// The information above shows that GVRP maintains the information about VLAN 1, VLAN 2 through VLAN 500, which GigabitEthernet 1/0/1 belongs to.
display gvrp state interface interface-type interface-number vlan vlan-id
View
Use the display gvrp state command to display the current GVRP state.
# Display the GVRP state of VLAN 1, which GigabitEthernet 1/0/1 belongs to.
<Sysname> display gvrp state interface GigabitEthernet 1/0/1 vlan 1
          GVRP state of VLAN 1 on port GigabitEthernet1/0/1
                  Applicant state machine           : VP
                  Registrar state machine           : MTR
display gvrp statistics [ interface interface-list ]
View
Use the display gvrp statistics command to display the GVRP statistics of specified or all trunk ports.
Note that if the interface interface-list is not provided, the GVRP statistics of all trunk ports will be displayed. Otherwise, only the GVRP statistics of all the specified trunk port will be displayed.
# Display statistics about GVRP for trunk port GigabitEthernet 1/0/1.
<Sysname> display gvrp statistics interface GigabitEthernet 1/0/1
          GVRP statistics on port GigabitEthernet1/0/1
                  GVRP Status                     : Enabled
                  GVRP Running                    : YES
                  GVRP Failed Registrations       : 0
                  GVRP Last Pdu Origin            : 0000-0000-0000
                  GVRP Registration Type          : Normal
Table 3-2 Description on the fields of the display gvrp statistics command
GVRP Status
Indicates whether GVRP is enabled or disabled.
GVRP Running
Indicates whether GVRP is running.
Indicates the number of GVRP registration failures.
Indicates the source MAC address in the last GVRP PDU.
Indicates the GVRP registration type on the port.
display gvrp status
View
None
Use the display gvrp status command to display the global enable/disable state of GVRP.
# Display the global GVRP enable/disable state.
<Sysname> display gvrp status
                      GVRP is enabled
//The above output information indicates that GVRP is enabled globally.
display gvrp vlan-operation interface interface-type interface-number
View
Use the display gvrp vlan-operation interface command to display the information about dynamic VLAN operations performed on a port.
# Display information about dynamic VLAN operations performed on GigabitEthernet 1/0/1.
<Sysname> display gvrp vlan-operation interface GigabitEthernet 1/0/1
        Dynamic VLAN operations on port GigabitEthernet1/0/1
                  Operations of creating VLAN              : 2-100
                  Operations of deleting VLAN              : none
                  Operations of adding VLAN to TRUNK       : 2-100
                  Operations of deleting VLAN from TRUNK   : none
3.2.6  gvrp
gvrp
undo gvrp
View
System view, Ethernet port view, port group view
None
Use the gvrp command to enable GVRP globally, on a port, or on all ports in a port group depending on the view you entered.
Use the undo gvrp command to disable GVRP globally, on a port, or on all ports in a port group depending on the view you entered.
By default, GVRP is disabled.
Executed in system view, the command takes effect globally. Executed in Ethernet port view, the command takes effect on the current port. Executed in port group view, the command takes effect on all the ports in the port group.
&  Note:
l      To enable GVRP on a port, you need to enable it globally.
l      The port where you enable/disable GVRP must be a Trunk port.
l      BPDU Tunnel is incompatible with GVRP. Before enabling GVRP, disable BPDU Tunnel.
Related commands: display gvrp status.
# Enable GVRP globally.
[Sysname] gvrp
gvrp registration { fixed | forbidden | normal }
undo gvrp registration
View
fixed: Sets the registration type to fixed.
forbidden: Sets the registration type to forbidden.
normal: Sets the registration type to normal.
Use the gvrp registration command to configure the GVRP registration type on a port or all ports in a port group.
Use the undo gvrp registration command to restore the default.
The default GVRP registration type is normal.
GVRP provides the following three registration types on a port:
l           Normal –– Enables the port to dynamically register/deregister VLANs, and to propagate both dynamic and static VLAN information.
l           Fixed –– Disables the port from dynamically registering/deregistering VLANs or propagating information about dynamic VLANs, but allows the port to propagate information about static VLANs. A trunk port with fixed registration type thus allows only manually configured VLANs to pass through even though it is configured to carry all VLANs.
l           Forbidden –– Disables the port from dynamically registering/deregistering VLANs or propagating VLAN information except information about VLAN 1. A trunk port with forbidden registration type thus allows only VLAN 1 to pass through even though it is configured to carry all VLANs.
Note that this command is only available on trunk ports.
Related commands: display garp statistics.
# Set the GVRP registration type to fixed on port GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] gvrp registration fixed
