20-Command
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release758X-6W10020-Command
20-Command
Title Size Downloads
20-Command-book.rar 6.36 MB
Table of Contents
Related Documents
book
book 6.36 MB
Index
A B C D E F G H I J K L M N O P Q R S T U V W X Y
A
aaa authorization
aaa authorization
aaa connection-recording policy
aaa device-id
aaa nas-id profile
aaa session-limit
abr-summary (OSPF area view)
abr-summary (OSPFv3 area view)
ac interface
ac statistics enable (VLAN view)
accept-label
accept-lifetime utc
accept-tolerance
access-limit
accounting
accounting command
accounting default
accounting dual-stack
accounting hwtacacs-scheme
accounting lan-access
accounting login
accounting portal
accounting quota-out
accounting start-fail
accounting update-fail
accounting-on enable
accounting-on extended
ack-flood action
ack-flood detect
ack-flood detect non-specific
ack-flood threshold
acl
acl copy
acl logging interval
acl trap interval
action cli
action reboot
action switchover
action syslog
activation-key
active instance
active region-configuration
additional-paths select-best
address
address range
address range
address-alloc-mode eui-64
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4
address-family ipv4 (public instance view)
address-family ipv4 (VPN instance view)
address-family ipv4 mdt
address-family ipv6
address-family ipv6
address-family ipv6
address-family ipv6 (public instance view)
address-family ipv6 (VPN instance view)
address-family l2vpn
address-family l2vpn evpn
address-family link-state
address-family vpnv4
address-family vpnv6
advantage-factor
advertise evpn route
advertise l2vpn evpn
advertise l3vpn route
advertise-label
advertise-rib-active
affinity location-set
affinity location-type
affinity program
affinity self
aggregate
aging-time
ah authentication-algorithm
alias
allowed-domain-id
anycast-rp (IPv6 PIM view)
anycast-rp (PIM view)
append
apply as-path
apply comm-list delete
apply community
apply cost
apply cost-type
apply default-next-hop
apply extcommunity rt
apply extcommunity soo
apply fast-reroute
apply ip-address next-hop
apply ip-precedence
apply ipv6 fast-reroute
apply ipv6 next-hop
apply isis
apply l3-vni
apply local-preference
apply mpls-label
apply next-hop
apply next-hop
apply origin
apply output-interface
apply precedence
apply precedence
apply preference
apply preferred-value
apply prefix-priority
apply qos-local-id
apply service-chain
apply tag
apply traffic-index
archive configuration
archive configuration interval
archive configuration location
archive configuration max
archive configuration server
archive configuration server password
archive configuration server user
area
area (OSPF view)
area-authentication send-only
area-authentication-mode
arp active-ack enable
arp authorized enable
arp check enable
arp check log enable
arp detection enable
arp detection log enable
arp detection port-match-ignore
arp detection rule
arp detection trust
arp detection validate
arp distributed-gateway dynamic-entry synchronize
arp fast-reply enable
arp filter binding
arp filter source
arp fixup
arp ip-conflict log prompt
arp mac-interface-consistency check enable
arp mac-learning disable
arp max-learning-num
arp max-learning-number
arp mode uni
arp multiport
arp rate-limit
arp rate-limit log enable
arp rate-limit log interval
arp resolving-route enable
arp resolving-route probe-count
arp resolving-route probe-interval
arp route-direct advertise
arp scan
arp sender-ip-range
arp send-gratuitous-arp
arp send-rate
arp smooth
arp snooping enable
arp source-mac
arp source-mac aging-time
arp source-mac exclude-mac
arp source-mac log enable
arp source-mac threshold
arp source-suppression enable
arp source-suppression limit
arp static
arp suppression enable
arp timer aging
arp timer aging probe-count
arp timer aging probe-interval
arp user-ip-conflict record enable
arp user-move record enable
arp valid-check enable
arp-advertising disable
asbr-summary (OSPF view)
asbr-summary (OSPFv3 view)
ascii
attack-defense apply policy (interface view)
attack-defense local apply policy
attack-defense login block-timeout
attack-defense login enable
attack-defense login max-attempt
attack-defense login reauthentication-delay
attack-defense policy
attack-defense signature log non-aggregate
attack-defense tcp fragment enable
attribute
attribute 15 check-mode
attribute 25 car
attribute 31 mac-format
attribute convert (RADIUS DAS view)
attribute convert (RADIUS scheme view)
attribute reject (RADIUS DAS view)
attribute reject (RADIUS scheme view)
attribute remanent-volume
attribute translate
attribute-map
authentication challenge
authentication default
authentication key
authentication lan-access
authentication lifetime
authentication login
authentication portal
authentication super
authentication window-size
authentication-method
authentication-mode
authentication-mode
authentication-mode
authentication-server
authentication-timeout
authorization command
authorization default
authorization lan-access
authorization login
authorization portal
authorization-attribute (ISP domain view)
authorization-attribute (local user view/user group view)
authorization-server
auto-cost enable
auto-cost enable
auto-discovery
auto-discovery
auto-execute command
auto-report
auto-rp enable (PIM view)
auto-tunnel backup
B
backoff
backup startup-configuration
backup-peer
backup-peer
balance
balance as-path-neglect
balance as-path-relax
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth
bandwidth queue
bandwidth-reference
bandwidth-reference (OSPF view)
bandwidth-reference (OSPFv3 view)
bestroute as-path-neglect
bestroute compare-med
bestroute igp-metric-ignore
bestroute med-confederation
bestroute origin-as-validation
bestroute router-id-ignore
bfd authentication-mode
bfd dampening
bfd demand enable
bfd detect-interface
bfd detect-interface first-fail-timer
bfd detect-interface special-processing
bfd detect-multiplier
bfd echo enable
bfd echo-source-ip
bfd echo-source-ipv6
bfd ip-router-alert
bfd min-echo-receive-interval
bfd min-receive-interval
bfd min-transmit-interval
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
bfd session init-mode
bgp
bgp apply-policy on-startup duration
bgp policy on-startup med
bgp update-delay on-startup
bgp update-delay on-startup ipv6-prefix-list
bgp update-delay on-startup prefix-list
bidir-pim enable (IPv6 PIM view)
bidir-pim enable (PIM view)
bidir-rp-limit (IPv6 PIM view)
bidir-rp-limit (PIM view)
bims-server
binary
bind interface
bind-attribute
binding-retry
blacklist global enable
blacklist ip
blacklist ipv6
blacklist logging enable
bmp server
bootfile-name
boot-loader
boot-loader file
boot-loader pex file (IRF3.1)
boot-loader update
bootrom update
border enable
bpdu-drop any
broadcast-suppression
bsm-fragment enable (IPv6 PIM view)
bsm-fragment enable (PIM view)
bsm-reflection enable (IPv6 PIM view)
bsm-reflection enable (PIM view)
bsr-policy (IPv6 PIM view)
bsr-policy (PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
burst-mode enable
bye
bye
C
ca identifier
cache-sa-enable
ca-file
capability default-exclusion
captive-bypass enable
car
car name
c-bsr (IPv6 PIM view)
c-bsr (PIM view)
ccc
cd
cd
cd
cdp voice-vlan
cdup
cdup
certificate domain
certificate domain
certificate request entity
certificate request from
certificate request mode
certificate request polling
certificate request url
certificate-chain-sending enable
cfd ais enable
cfd ais level
cfd ais period
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
cfd cc enable
cfd cc interval
cfd dm one-way
cfd dm two-way
cfd enable
cfd linktrace
cfd linktrace auto-detection
cfd loopback
cfd md
cfd mep
cfd meplist
cfd mip-rule
cfd service-instance
cfd slm
cfd tst
check region-configuration
check-origin-validation
checkzero
checkzero
ciphersuite
circuit-cost
class ip-pool
class option-group
class pool
class range
classification
classifier behavior
cli
client
client-authentication
client-verify
clock datetime
clock protocol
clock summer-time
clock timezone
close
codec-type
command
command accounting
command authorization
commit
common-name
community read
company
compare-different-as-med
confederation id
confederation nonstandard
confederation peer-as
confidentiality-offset
config-exchange
configuration commit
configuration commit delay
configuration encrypt
configuration replace file
connection
connection remote-site-id
continue
controller address
controller auxiliary
controller connect interval
controller echo-request interval
controller mode
control-plane
control-vlan
control-vlan
control-word enable
control-word enable
copy
copyright-info enable
cost-style
country
create batch-file
crl check enable
crl url
c-rp (IPv6 PIM view)
c-rp (PIM view)
crp-policy (IPv6 PIM view)
crp-policy (PIM view)
cwmp
cwmp acs default password
cwmp acs default url
cwmp acs default username
cwmp acs password
cwmp acs url
cwmp acs username
cwmp cpe connect interface
cwmp cpe connect retry
cwmp cpe inform interval
cwmp cpe inform interval enable
cwmp cpe inform time
cwmp cpe password
cwmp cpe provision-code
cwmp cpe stun enable
cwmp cpe username
cwmp cpe wait timeout
cwmp enable
D
dampening
dampening
database-filter peer (OSPF view)
databits
data-delay
data-fill
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
data-group
datapath-id
data-plane enable
data-size
dcbx version
dci enable
dcn
ddns apply policy
ddns dscp
ddns policy
debug
debugging
default
default
default
default
default
default
default
default
default (OSPF view)
default cost
default cost
default ip-pool
default local-preference
default med
default pool
default table-miss permit
default tag
default-cost (OSPF area view)
default-cost (OSPFv3 area view)
default-group
default-logon-page
default-pw-id
default-route
default-route imported
default-route update-first
default-route-advertise
default-route-advertise (OSPF view)
default-route-advertise (OSPFv3 view)
default-send-key
delay
delete
delete
delete
delete ip rpf-route-static
delete ipv6 static-routes all
delete ssh client server-public-key
delete static-routes all
delete zone database all
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description
description (OSPF/OSPF area view)
description (VPN instance view)
destination
destination host
destination ip
destination ipv6
destination port
device-role
dh
dh
dhcp apply-policy
dhcp class
dhcp client dad enable
dhcp client dscp
dhcp client identifier
dhcp client-detect
dhcp dscp
dhcp enable
dhcp flood-protection aging-time
dhcp flood-protection enable
dhcp flood-protection threshold
dhcp option-group
dhcp policy
dhcp relay check mac-address
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay dhcp-server timeout
dhcp relay gateway
dhcp relay information circuit-id
dhcp relay information enable
dhcp relay information remote-id
dhcp relay information strategy
dhcp relay mac-forward enable
dhcp relay master-server switch-delay
dhcp relay pool
dhcp relay release ip
dhcp relay request-from-tunnel discard
dhcp relay server-address algorithm
dhcp relay source-address
dhcp select
dhcp server always-broadcast
dhcp server apply ip-pool
dhcp server bootp ignore
dhcp server bootp reply-rfc-1048
dhcp server check mac-address
dhcp server database update interval
dhcp server database update now
dhcp server database update stop
dhcp server forbidden-ip
dhcp server ip-pool
dhcp server ping packets
dhcp server ping timeout
dhcp server relay information enable
dhcp server request-ip-address check
dhcp smart-relay enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping binding record
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping deny
dhcp snooping disable
dhcp snooping enable
dhcp snooping enable vlan
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping information vendor-specific
dhcp snooping log enable
dhcp snooping max-learning-num
dhcp snooping rate-limit
dhcp snooping trust
dhcp snooping trust interface
dhcp snooping trust tunnel
dhcp-server timeout
diagnostic event-log size
diagnostic monitor enable
diagnostic monitor interval
diagnostic simulation
diagnostic-logfile save
dir
dir
dir
disable (explicit path view)
disable-dn-bit-check
disable-dn-bit-set
discard-route
disconnect
display [ | [ by-linenum ] { begin | exclude | include } ]
display >
display >>
display aaa connection-recording policy
display acl
display adjacent-table
display alias
display archive configuration
display arp
display arp detection
display arp detection statistics attack-source
display arp detection statistics packet-drop
display arp entry-limit
display arp ip-address
display arp openflow count
display arp snooping
display arp source-mac
display arp source-suppression
display arp suppression vsi
display arp timer aging
display arp user-ip-conflict record
display arp user-move record
display arp vpn-instance
display attack-defense flood statistics ip
display attack-defense flood statistics ipv6
display attack-defense policy
display attack-defense policy ip
display attack-defense policy ipv6
display attack-defense scan attacker ip
display attack-defense scan attacker ipv6
display attack-defense scan victim ip
display attack-defense scan victim ipv6
display attack-defense statistics local
display bfd session
display bgp bmp server
display bgp dampening parameter
display bgp group
display bgp instance-info
display bgp l2vpn auto-discovery
display bgp l2vpn evpn
display bgp l2vpn signaling
display bgp link-state
display bgp network
display bgp non-stop-routing status
display bgp paths
display bgp peer
display bgp peer received prefix-list
display bgp routing-table dampened
display bgp routing-table flap-info
display bgp routing-table ipv4 mdt
display bgp routing-table ipv4 multicast
display bgp routing-table ipv4 rtfilter
display bgp routing-table ipv4 unicast
display bgp routing-table ipv4 unicast inlabel
display bgp routing-table ipv4 unicast outlabel
display bgp routing-table ipv6 multicast
display bgp routing-table ipv6 unicast
display bgp routing-table ipv6 unicast inlabel
display bgp routing-table ipv6 unicast outlabel
display bgp routing-table vpnv4
display bgp routing-table vpnv4 inlabel
display bgp routing-table vpnv4 outlabel
display bgp routing-table vpnv6
display bgp routing-table vpnv6 inlabel
display bgp routing-table vpnv6 outlabel
display bgp rpki server
display bgp rpki table
display bgp update-group
display blacklist ip
display blacklist ipv6
display boot-loader
display bootp client
display cfd ais
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply
display cfd linktrace-reply auto-detection
display cfd md
display cfd mep
display cfd meplist
display cfd mp
display cfd remote-mep
display cfd service-instance
display cfd status
display cfd tst
display clock
display copyright
display counters
display counters rate
display cpu-usage
display cpu-usage configuration
display cpu-usage history
display crypto version
display current-configuration
display current-configuration diff
display cwmp configuration
display cwmp status
display dcn
display dcn ne-info
display ddns policy
display debugging
display default-configuration
display device
display device manuinfo
display device manuinfo fan
display device manuinfo power
display device uptime
display dhcp client
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp relay statistics
display dhcp server conflict
display dhcp server database
display dhcp server expired
display dhcp server free-ip
display dhcp server ip-in-use
display dhcp server pool
display dhcp server statistics
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display dhcp snooping trust
display diagnostic content
display diagnostic event-log
display diagnostic result
display diagnostic simulation
display diagnostic-information
display diagnostic-logfile summary
display diff
display dldp
display dldp statistics
display dns domain
display dns host
display dns server
display domain
display dot1x
display dot1x connection
display dot1x mac-address
display dot1x supplicant
display drni consistency
display drni drcp statistics
display drni keepalive
display drni mad verbose
display drni role
display drni summary
display drni system
display drni verbose
display environment
display erps
display erps detail
display erps statistics
display ethernet statistics
display evb cdcp
display evb evb-tlv
display evb s-channel
display evb summary
display evb vsi
display evi arp-suppression
display evi isis brief
display evi isis graceful-restart status
display evi isis local-mac
display evi isis lsdb
display evi isis peer
display evi isis remote-mac
display evi isis tunnel
display evi link
display evi mac-address
display evi neighbor-discovery client member
display evi neighbor-discovery client statistics
display evi neighbor-discovery client summary
display evi neighbor-discovery server member
display evi neighbor-discovery server statistics
display evi neighbor-discovery server summary
display evpn auto-discovery
display evpn route arp
display evpn route arp suppression
display evpn route mac
display evpn route nd
display evpn routing-table
display exception context
display exception filepath
display explicit-path
display fan
display fc domain
display fc domain-list
display fc ess
display fc exchange
display fc fib
display fc login
display fc name-service database
display fc routing-table
display fc scr-table
display fc switch-wwn
display fc timer
display fcid allocation
display fcid persistent
display fcoe
display fcoe-mode
display fcs database
display fcs discovery status
display fcs ie
display fcs port
display fdmi database
display fib
display fips status
display fip-snooping enode
display fip-snooping fcf
display fip-snooping flushing-rules
display fip-snooping rules
display fip-snooping sessions
display fspf graceful-restart
display fspf lsdb
display fspf neighbor
display fspf statistics
display ftp client source
display ftp-server
display ftp-user
display ha service-group
display history-command
display history-command all
display hotkey
display hwtacacs scheme
display icmp statistics
display igmp group
display igmp host group
display igmp interface
display igmp proxy group
display igmp proxy routing-table
display igmp ssm-mapping
display igmp-snooping
display igmp-snooping group
display igmp-snooping host-tracking
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display ike proposal
display ike sa
display ike statistics
display ikev2 policy
display ikev2 profile
display ikev2 proposal
display ikev2 sa
display ikev2 statistics
display info-center
display info-center filter
display install active
display install backup
display install committed
display install inactive
display install ipe-info
display install job
display install log
display install package
display install which
display interface
display interface
display interface { s-channel | schannel-aggregation }
display interface evi-link
display interface inloopback
display interface link-info
display interface loopback
display interface main
display interface null
display interface range
display interface register-tunnel
display interface tunnel
display interface vfc
display interface vlan-interface
display interface vsi-interface
display ip as-path
display ip community-list
display ip extcommunity-list
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
display ip http
display ip https
display ip interface
display ip interface brief
display ip load-sharing mode
display ip policy-based-route
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip prefix-list
display ip routing-table
display ip routing-table acl
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ip routing-table summary
display ip source binding
display ip statistics
display ip urpf
display ip verify source excluded
display ip vpn-instance
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ipsec profile
display ipsec sa
display ipsec statistics
display ipsec transform-set
display ipsec tunnel
display ip-subnet-vlan interface
display ip-subnet-vlan vlan
display ipv6 adjacent-table
display ipv6 dhcp client
display ipv6 dhcp client statistics
display ipv6 dhcp duid
display ipv6 dhcp guard policy
display ipv6 dhcp option-group
display ipv6 dhcp pool
display ipv6 dhcp prefix-pool
display ipv6 dhcp relay client-information address
display ipv6 dhcp relay client-information pd
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server
display ipv6 dhcp server conflict
display ipv6 dhcp server database
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping pd binding
display ipv6 dhcp snooping trust
display ipv6 dns server
display ipv6 fast-forwarding aging-time
display ipv6 fast-forwarding cache
display ipv6 fib
display ipv6 icmp statistics
display ipv6 interface
display ipv6 interface prefix
display ipv6 l2-multicast fast-forwarding cache
display ipv6 l2-multicast ip
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac
display ipv6 l2-multicast mac forwarding
display ipv6 mrib interface
display ipv6 multicast boundary
display ipv6 multicast fast-forwarding cache
display ipv6 multicast forwarding df-info
display ipv6 multicast forwarding event
display ipv6 multicast forwarding-table
display ipv6 multicast forwarding-table df-list
display ipv6 multicast routing-table
display ipv6 multicast rpf-info
display ipv6 multicast-vlan
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd raguard policy
display ipv6 nd raguard statistics
display ipv6 nd snooping count vlan
display ipv6 nd snooping count vsi
display ipv6 nd snooping vlan
display ipv6 nd snooping vsi
display ipv6 nd suppression vsi
display ipv6 nd user-ip-conflict record
display ipv6 nd user-move record
display ipv6 neighbors
display ipv6 neighbors count
display ipv6 neighbors entry-limit
display ipv6 neighbors vpn-instance
display ipv6 pathmtu
display ipv6 pim bsr-info
display ipv6 pim claimed-route
display ipv6 pim c-rp
display ipv6 pim df-info
display ipv6 pim interface
display ipv6 pim neighbor
display ipv6 pim routing-table
display ipv6 pim rp-info
display ipv6 pim statistics
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route apply
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 prefix
display ipv6 prefix-list
display ipv6 rawip
display ipv6 rawip verbose
display ipv6 rib attribute
display ipv6 rib nib
display ipv6 route-direct nib
display ipv6 route-static nib
display ipv6 route-static routing-table
display ipv6 routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display ipv6 routing-table summary
display ipv6 source binding
display ipv6 source binding pd
display ipv6 statistics
display ipv6 tcp
display ipv6 tcp verbose
display ipv6 udp
display ipv6 udp verbose
display ipv6 urpf
display irf
display irf configuration
display irf link
display irf topology
display irf-port load-sharing mode
display isis
display isis event-log graceful-restart
display isis event-log lsp
display isis event-log non-stop-routing
display isis event-log spf
display isis graceful-restart status
display isis interface
display isis lsdb
display isis lsdb statistics
display isis mesh-group
display isis mpls te advertisement
display isis mpls te network
display isis mpls te tunnel
display isis name-table
display isis non-stop-routing status
display isis packet
display isis peer
display isis redistribute
display isis route
display isis spf-tree
display isis statistics
display issu state
display kernel deadloop
display kernel deadloop configuration
display kernel exception
display kernel reboot
display kernel starvation
display kernel starvation configuration
display keychain
display l2-multicast fast-forwarding cache
display l2-multicast ip
display l2-multicast ip forwarding
display l2-multicast mac
display l2-multicast mac forwarding
display l2protocol statistics
display l2vpn auto-discovery
display l2vpn bgp
display l2vpn bgp
display l2vpn forwarding
display l2vpn ldp
display l2vpn ldp
display l2vpn mac-address
display l2vpn pw
display l2vpn pw
display l2vpn pw-class
display l2vpn service-instance
display l2vpn vsi
display l2vpn vsi
display l2vpn xconnect-group
display lacp system-id
display ldap scheme
display license
display license device-id
display license feature
display line
display link-aggregation load-sharing mode
display link-aggregation load-sharing path
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display link-flap protection
display lldp local-information
display lldp neighbor-information
display lldp statistics
display lldp status
display lldp tlv-config
display local-proxy-arp
display local-user
display logbuffer
display logbuffer summary
display logfile buffer
display logfile summary
display loopback-detection
display mac-address
display mac-address [ multicast ]
display mac-address aging-time
display mac-address mac-learning
display mac-address mac-move
display mac-address statistics
display mac-authentication
display mac-authentication connection
display mac-authentication mac-address
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display mac-list
display macsec
display mac-vlan
display mac-vlan interface
display mad
display max-ecmp-num
display mdns relay
display mdns relay statistics
display memory
display memory-threshold
display mirroring-group
display mka policy
display mka session
display mka statistics
display mld group
display mld interface
display mld proxy group
display mld proxy routing-table
display mld ssm-mapping
display mld-snooping
display mld-snooping group
display mld-snooping host-tracking
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display monitor-link group
display mpls forwarding ilm
display mpls forwarding nhlfe
display mpls interface
display mpls label
display mpls ldp discovery
display mpls ldp fec
display mpls ldp igp sync
display mpls ldp interface
display mpls ldp lsp
display mpls ldp parameter
display mpls ldp peer
display mpls ldp summary
display mpls lsp
display mpls lsp statistics
display mpls nib
display mpls nid
display mpls static-cr-lsp
display mpls static-lsp
display mpls summary
display mpls te link-management bandwidth-allocation
display mpls te pce discovery
display mpls te pce peer
display mpls te pce statistics
display mpls te tedb
display mpls te tunnel-interface
display mpls tunnel
display mrib interface
display msdp brief
display msdp non-stop-routing status
display msdp peer-status
display msdp sa-cache
display msdp sa-count
display multicast boundary
display multicast fast-forwarding cache
display multicast forwarding df-info
display multicast forwarding event
display multicast forwarding-table
display multicast forwarding-table df-list
display multicast routing-table
display multicast routing-table static
display multicast rpf-info
display multicast-vlan
display multicast-vlan forwarding-table
display multicast-vlan group
display multicast-vpn data-group receive
display multicast-vpn data-group send
display multicast-vpn default-group
display mvrp running-status
display mvrp state
display mvrp statistics
display npv login
display npv status
display npv traffic-map
display nqa history
display nqa reaction counters
display nqa result
display nqa server
display nqa statistics
display ntp-service ipv6 sessions
display ntp-service sessions
display ntp-service status
display ntp-service trace
display oam
display oam configuration
display oam critical-event
display oam link-event
display object-group
display openflow
display openflow auxiliary
display openflow flow-table
display openflow group
display openflow instance
display openflow meter
display openflow summary
display osi
display osi statistics
display ospf
display ospf abr-asbr
display ospf abr-summary
display ospf asbr-summary
display ospf event-log
display ospf fast-reroute lfa-candidate
display ospf graceful-restart
display ospf interface
display ospf lsdb
display ospf mpls te advertisement
display ospf mpls te network
display ospf mpls te pce
display ospf mpls te tunnel
display ospf nexthop
display ospf non-stop-routing status
display ospf peer
display ospf peer statistics
display ospf request-queue
display ospf retrans-queue
display ospf routing
display ospf sham-link
display ospf spf-tree
display ospf statistics
display ospf vlink
display ospfv3
display ospfv3 abr-asbr
display ospfv3 abr-summary
display ospfv3 asbr-summary
display ospfv3 event-log
display ospfv3 graceful-restart
display ospfv3 interface
display ospfv3 lsdb
display ospfv3 nexthop
display ospfv3 non-stop-routing
display ospfv3 peer
display ospfv3 request-queue
display ospfv3 retrans-queue
display ospfv3 routing
display ospfv3 sham-link
display ospfv3 spf-tree
display ospfv3 statistics
display ospfv3 vlink
display packet-capture status
display packet-drop
display packet-filter
display packet-filter statistics
display packet-filter statistics sum
display packet-filter verbose
display password-control
display password-control blacklist
display pex interface
display pex topology
display pim bsr-info
display pim claimed-route
display pim c-rp
display pim df-info
display pim interface
display pim neighbor
display pim routing-table
display pim rp-info
display pim statistics
display pim-snooping neighbor
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate request-status
display pki crl domain
display placement location
display placement policy
display placement program
display placement reoptimize
display port
display portal
display portal mac-trigger-server
display portal packet statistics
display portal rule
display portal server
display portal user
display portal web-server
display port-isolate group
display port-security
display port-security mac-address block
display port-security mac-address security
display power
display priority-flow-control
display private-vlan
display process
display process cpu
display process log
display process memory
display process memory heap
display process memory heap address
display process memory heap size
display protocol-vlan interface
display protocol-vlan vlan
display provision failed-config
display proxy-arp
display public-key local public
display public-key peer
display qinq
display qos car name
display qos gts interface
display qos lr interface
display qos map-table
display qos policy
display qos policy control-plane
display qos policy control-plane pre-defined
display qos policy global
display qos policy interface
display qos qmprofile configuration
display qos qmprofile interface
display qos queue interface
display qos queue sp interface
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display qos trust interface
display qos vlan-policy
display qos wred interface
display qos wred table
display qos-acl resource
display radius scheme
display radius server-load statistics
display radius statistics
display radius-server active-client
display radius-server active-user
display rawip
display rawip verbose
display rdp database
display rdp request-polling-interval
display resource-monitor
display rib attribute
display rib graceful-restart
display rib nib
display rip
display rip database
display rip graceful-restart
display rip interface
display rip neighbor
display rip non-stop-routing
display rip route
display ripng
display ripng database
display ripng graceful-restart
display ripng interface
display ripng neighbor
display ripng non-stop-routing
display ripng route
display rmon alarm
display rmon event
display rmon eventlog
display rmon history
display rmon prialarm
display rmon statistics
display role
display role feature
display role feature-group
display route-direct nib
display route-policy
display router id
display route-static nib
display route-static routing-table
display rrpp brief
display rrpp ring-group
display rrpp statistics
display rrpp verbose
display rsvp
display rsvp authentication
display rsvp lsp
display rsvp peer
display rsvp request
display rsvp reservation
display rsvp sender
display rsvp statistics
display rtm environment
display rtm policy
display saved-configuration
display scheduler job
display scheduler logfile
display scheduler reboot
display scheduler schedule
display scp client source
display security-logfile buffer
display security-logfile summary
display service-loopback group
display sflow
display sftp client source
display smart-link flush
display smart-link group
display smartmc backup configuration status
display smartmc batch-file status
display smartmc configuration
display smartmc device-link
display smartmc group
display smartmc replace status
display smartmc resource-monitor
display smartmc resource-monitor configuration
display smartmc tc
display smartmc tc log buffer
display smartmc tc log restart
display smartmc upgrade status
display smartmc vlan
display smartsan status
display snmp-agent community
display snmp-agent context
display snmp-agent group
display snmp-agent local-engineid
display snmp-agent mib-node
display snmp-agent mib-view
display snmp-agent remote
display snmp-agent statistics
display snmp-agent sys-info
display snmp-agent trap queue
display snmp-agent trap-list
display snmp-agent usm-user
display sntp ipv6 sessions
display sntp sessions
display ssh client server-public-key
display ssh client source
display ssh server
display ssh user-information
display ssh2 algorithm
display ssl client-policy
display ssl server-policy
display startup
display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer (for RADIUS)
display storm-constrain
display stp
display stp abnormal-port
display stp bpdu-statistics
display stp down-port
display stp history
display stp region-configuration
display stp root
display stp tc
display supervlan
display switch-mode status
display system health
display system health history
display system stable state
display system-working-mode
display tcp
display tcp statistics
display tcp verbose
display telnet client
display this
display time-range
display track
display traffic behavior
display traffic classifier
display transceiver alarm
display transceiver diagnosis
display transceiver interface
display transceiver manuinfo
display trill adjacent-table
display trill brief
display trill fib
display trill graceful-restart status
display trill ingress-route
display trill interface
display trill lsdb
display trill mfib ingress
display trill mfib transit
display trill multicast-route
display trill neighbor-table
display trill peer
display trill rpf-table
display trill topology
display trill unicast-route
display tunnel-policy
display udp
display udp statistics
display udp verbose
display udp-helper interface
display user-group
display user-interface
display users
display vcf-fabric role
display vcf-fabric topology
display vcf-fabric underlay autoconfigure
display vcf-fabric underlay template-version
display version
display version comp-matrix file
display version-update-record
display vlan
display vlan brief
display vlan mapping
display vlan statistics
display vlan-group
display voice-vlan mac-address
display voice-vlan state
display vrrp
display vrrp binding
display vrrp ipv6
display vrrp ipv6 binding
display vrrp ipv6 statistics
display vrrp statistics
display vsan port-member
display vxlan tunnel
display web menu
display web users
display web-auth
display web-auth free-ip
display web-auth server
display web-auth user
display web-redirect rule
display zone
display zone member
display zone statistics
display zone status
display zone-alias
display zoneset
display zoneset active
distribute bgp-ls
distribute bgp-ls
distributed-gateway local
dldp authentication-mode
dldp authentication-password
dldp delaydown-timer
dldp enable
dldp global enable
dldp interval
dldp port unidirectional-shutdown
dldp unidirectional-shutdown
dns domain
dns dscp
dns proxy enable
dns server
dns source-interface
dns trust-interface
dns-flood action
dns-flood detect
dns-flood detect non-specific
dns-flood port
dns-flood threshold
dns-list
dns-server
domain
domain auto-reconfigure enable
domain configure enable
domain default enable
domain if-unknown
domain restart
domain ring
domain-authentication send-only
domain-authentication-mode
domain-distinguisher
domain-id
domain-id (OSPF view)
domain-id (OSPFv3 view)
domain-name
domain-name
dot1p-priority (IGMP-snooping view)
dot1p-priority (MLD-snooping view)
dot1x
dot1x access-user log enable
dot1x after-mac-auth max-attempt
dot1x authentication-method
dot1x auth-fail eapol
dot1x auth-fail vlan
dot1x auth-fail vsi
dot1x critical eapol
dot1x critical vlan
dot1x critical vsi
dot1x critical-voice-vlan
dot1x domain-delimiter
dot1x ead-assistant enable
dot1x ead-assistant free-ip
dot1x ead-assistant url
dot1x eapol untag
dot1x eap-tls-fragment to-server
dot1x guest-vlan
dot1x guest-vlan-delay
dot1x guest-vsi
dot1x guest-vsi-delay
dot1x handshake
dot1x handshake reply enable
dot1x handshake secure
dot1x mac-binding
dot1x mac-binding enable
dot1x mandatory-domain
dot1x max-user
dot1x multicast-trigger
dot1x offline-detect enable
dot1x port-control
dot1x port-method
dot1x quiet-period
dot1x re-authenticate
dot1x re-authenticate manual
dot1x re-authenticate server-unreachable keep-online
dot1x retry
dot1x server-recovery online-user-sync
dot1x supplicant anonymous identify
dot1x supplicant eap-method
dot1x supplicant enable
dot1x supplicant mac-address
dot1x supplicant password
dot1x supplicant ssl-client-policy
dot1x supplicant transmit-mode
dot1x supplicant username
dot1x timer
dot1x timer reauth-period
dot1x unauthenticated-user aging enable
dot1x unicast-trigger
dot1x user-ip freeze
downlink up-delay
dpd
dpd
drni auto-recovery reload-delay
drni consistency-check disable
drni drcp period short
drni keepalive { ip | ipv6 }
drni keepalive hold-time
drni keepalive interval
drni mad exclude interface
drni restore-delay
drni role priority
drni system-mac
drni system-number
drni system-priority
drop-unknown (IGMP-snooping view)
drop-unknown (MLD-snooping view)
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
dscp
duplex
E
eap-profile
easy-irf
ebgp-interface-sensitive
eee enable
email
embedded-rp
enable (IGMP-snooping view)
enable (MLD-snooping view)
enable ipsec-profile
enable link-local-signaling
enable log updown
enable out-of-band-resynchronization
enable snmp trap updown
encap-data-enable
encapsulation
encapsulation
encapsulation
encapsulation-mode
encryption
encryption-algorithm
entry-limit (IGMP-snooping view)
entry-limit (MLD-snooping view)
erps clear
erps enable
erps ring
erps switch
erps tcn-propagation
escape-key
esn enable
esp authentication-algorithm
esp encryption-algorithm
evb default-manager
evb enable
evb mac-learning forbidden
evb reflective-relay
evb s-channel
evb vdp timer keepalive exponent
evb vdp timer resource-wait-delay exponent
evb vsi
evb vsi active
evb vsi filter
event cli
event hotplug
event interface
event process
event snmp oid
event snmp-notification
event syslog
event track
event-log
event-log
evi arp-suppression enable
evi enable
evi extend-vlan
evi flooding enable
evi isis ded-priority
evi isis timer csnp
evi isis timer hello
evi isis timer holding-multiplier
evi isis timer lsp
evi isis track
evi neighbor-discovery authentication
evi neighbor-discovery client enable
evi neighbor-discovery client register-interval
evi neighbor-discovery server enable
evi network-id
evi selective-flooding mac-address
evi site-id
evi-isis
evpn edge group
evpn encapsulation
evpn route arp-mobility suppression
exception filepath
exchange-mode
exclude
execute
exempt acl
exit
exit()
expect data
expect ip
expect ipv6
expect status
expired
explicit-path
export route-policy
export route-policy
export route-policy
ext-community-type (OSPF view)
ext-community-type (OSPFv3 view)
F
fabric-name
fail-open mode
fan prefer-direction
fast-leave (IGMP-snooping view)
fast-leave (MLD-snooping view)
fast-reroute
fast-reroute
fast-reroute
fast-reroute (OSPF view)
fast-reroute (OSPFv3 view)
fast-reroute route-policy
fast-reroute timer
fc domain rcf-reject
fc login-limit
fc mode
fc name-service auto-discovery
fc route-static
fc timer distributed-services
fc timer error-detect
fc timer resource-allocation
fc wwn default-fc4-type
fcid persistent enable
fcoe enable
fcoe fcf-priority
fcoe fcmap
fcoe fka-adv-period
fcoe global fcf-priority
fcoe-mode
fcping
fcs discovery start
fcs discovery stop
fctracert
fdisk
feature
fib lifetime
file prompt
filename
filter
filter (OSPF area view)
filter (OSPFv3 area view)
filter-policy
filter-policy export
filter-policy export (OSPF view)
filter-policy export (OSPFv3 view)
filter-policy import
filter-policy import (OSPF view)
filter-policy import (OSPFv3 view)
fin-flood action
fin-flood detect
fin-flood detect non-specific
fin-flood threshold
fips mode enable
fips self-test
fip-snooping enable
fip-snooping fc-map
fip-snooping port-mode
fixdisk
flash-flood
flash-flood
flooding disable
flow-control
flow-control
flow-control receive enable
flow-entry max-limit
flow-interval
flow-log disable
flow-table
flush enable
flush route-attribute
flush suboptimal-route
flush-policy difference
forbidden packet-in arp controller
forbidden port
forbidden-ip
format
fqdn
free ftp user
free ftp user-ip
free ftp user-ip ipv6
free line
free ssh
free user-interface
free web users
free-traffic threshold
frequency
fspf cost
fspf dead-interval
fspf enable
fspf graceful-restart helper
fspf graceful-restart interval
fspf hello-interval
fspf min-ls-arrival
fspf min-ls-interval
fspf retransmit-interval
fspf silent
fspf spf-hold-time
ftp
ftp client ipv6 source
ftp client source
ftp ipv6
ftp server acl
ftp server acl-deny-log enable
ftp server dscp
ftp server enable
ftp server ipv6 dscp
ftp server ssl-server-policy
ftp timeout
full-name
G
gateway ip
gateway subnet
gateway vsi-interface
gateway-list
gateway-list
gateway-list
get
get
global-enable (IGMP-snooping view)
global-enable (MLD-snooping view)
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart
graceful-restart (OSPF view)
graceful-restart enable
graceful-restart helper enable
graceful-restart helper strict-lsa-checking
graceful-restart interval (OSPF view)
graceful-restart suppress-sa
graceful-restart t1
graceful-restart t2
graceful-restart t3
graceful-restart timer
graceful-restart timer purge-time
graceful-restart timer restart
graceful-restart timer wait-for-rib
gratuitous-arp mac-change retransmit
gratuitous-arp-learning enable
gratuitous-arp-sending enable
gre key vlan-id
group
group
group-policy (IGMP-snooping view)
group-policy (MLD-snooping view)
gunzip
gzip
H
header
hello interval
hello lost
hello-option dr-priority (IPv6 PIM view)
hello-option dr-priority (PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option holdtime (PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option lan-delay (PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option neighbor-tracking (PIM view)
hello-option override-interval (IPv6 PIM view)
hello-option override-interval (PIM view)
help
help
history-command max-size
history-record enable
history-record keep-time
history-record number
holdtime join-prune (IPv6 PIM view)
holdtime join-prune (PIM view)
host-advertise
host-aging-time (IGMP-snooping view)
host-aging-time (MLD-snooping view)
hostname
host-route
host-tracking (IGMP-snooping view)
host-tracking (MLD-snooping view)
hotkey
http-flood action
http-flood detect
http-flood detect non-specific
http-flood port
http-flood threshold
http-redirect https-port
http-redirect ssl-server-policy
hwtacacs nas-ip
hwtacacs scheme
I
icmp-flood action
icmp-flood detect ip
icmp-flood detect non-specific
icmp-flood threshold
icmpv6-flood action
icmpv6-flood detect ipv6
icmpv6-flood detect non-specific
icmpv6-flood threshold
identity
identity local
idle-timeout
if-match
if-match
if-match
if-match
if-match acl
if-match acl
if-match acl
if-match as-path
if-match autoconfig managed-address-flag
if-match autoconfig other-flag
if-match community
if-match cost
if-match extcommunity
if-match hop-limit
if-match interface
if-match ip
if-match ipv6
if-match l3-vni
if-match local-preference
if-match mac-list
if-match mpls-label
if-match prefix
if-match reply acl
if-match router-preference
if-match route-type
if-match rpki
if-match server acl
if-match service-chain
if-match tag
if-match vlan
igmp
igmp enable
igmp fast-leave
igmp group-policy
igmp host enable
igmp last-member-query-count
igmp last-member-query-interval
igmp max-response-time
igmp non-stop-routing
igmp other-querier-present-interval
igmp proxy enable
igmp proxy forwarding
igmp query-interval
igmp robust-count
igmp startup-query-count
igmp startup-query-interval
igmp static-group
igmp version
igmp-snooping
igmp-snooping { disable | enable }
igmp-snooping dot1p-priority
igmp-snooping drop-unknown
igmp-snooping fast-leave
igmp-snooping general-query source-ip
igmp-snooping group-limit
igmp-snooping group-policy
igmp-snooping host-aging-time
igmp-snooping host-join
igmp-snooping last-member-query-interval
igmp-snooping leave source-ip
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping proxy enable
igmp-snooping querier
igmp-snooping querier-election
igmp-snooping query-interval
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping source-deny
igmp-snooping special-query source-ip
igmp-snooping version
ignore all-peers
ignore-att
ignore-first-as
igp sync delay
igp sync delay on-restart
ike address-group
ike dpd
ike identity
ike invalid-spi-recovery enable
ike keepalive interval
ike keepalive timeout
ike keychain
ike limit
ike nat-keepalive
ike profile
ike proposal
ike signature-identity from-certificate
ike-profile
ikev2 address-group
ikev2 cookie-challenge
ikev2 dpd
ikev2 ipv6-address-group
ikev2 keychain
ikev2 nat-keepalive
ikev2 policy
ikev2 profile
ikev2 proposal
ikev2-profile
import
import bgp
import evpn mac-ip
import route-policy
import route-policy
import route-policy
import-route
import-route
import-route
import-route
import-route (OSPF view)
import-route (OSPFv3 view)
import-route isis level-1 into level-2
import-route isis level-2 into level-1
import-route isisv6 level-1 into level-2
import-route isisv6 level-2 into level-1
import-route limit
import-source
in-band management vlan
include
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center enable
info-center filter
info-center format
info-center logbuffer
info-center logbuffer size
info-center logfile directory
info-center logfile enable
info-center logfile frequency
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center logging suppress module
info-center loghost
info-center loghost source
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center source
info-center synchronous
info-center syslog min-age
info-center syslog trap buffersize
info-center timestamp
info-center timestamp loghost
info-center trace-logfile quota
ingress assign-delay
ingress assign-rule load-balancing
init-ttl
inside-vpn
inside-vrf
install abort
install activate
install activate pex patch
install add
install commit
install deactivate
install deactivate pex patch
install remove
install verify
instance
instance
instance enable
integrity
interface
interface
interface bridge-aggregation
interface loopback
interface null
interface policy deny
interface range
interface range name
interface route-aggregation
interface tunnel
interface vfc
inter-protocol fast-reroute
interval
ip
ip
ip
ip (MAC binding server view)
ip (portal authentication server view)
ip address
ip address bootp-alloc
ip address dhcp-alloc
ip address unnumbered
ip as-path
ip binding vpn-instance
ip community-list
ip fast-forwarding load-sharing
ip forward-broadcast
ip forwarding-conversational-learning
ip host
ip http acl
ip http enable
ip http port
ip https acl
ip https certificate access-control-policy
ip https enable
ip https port
ip https ssl-server-policy
ip icmp error-interval
ip icmp fragment discarding
ip icmp source
ip irdp
ip irdp address
ip irdp interval
ip irdp lifetime
ip irdp multicast
ip irdp preference
ip load-sharing local-first enable
ip local policy-based-route
ip mtu
ip prefix-list
ip public-instance
ip reassemble local enable
ip redirects enable
ip route fast-switchover enable
ip route-static
ip route-static arp-request
ip route-static default-preference
ip route-static fast-reroute auto
ip route-static primary-path-detect bfd echo
ip route-static-group
ip rpf-route-static
ip source binding (interface view)
ip source binding (system view)
ip ttl-expires enable
ip unreachables enable
ip urpf
ip verify source
ip vpn-instance (BGP instance view)
ip vpn-instance (system view)
ip-in-use threshold
ip-prefix-route generate disable
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec anti-replay check
ipsec anti-replay window
ipsec apply
ipsec decrypt-check enable
ipsec df-bit
ipsec fragmentation
ipsec global-df-bit
ipsec limit max-tunnel
ipsec logging packet enable
ipsec profile
ipsec redundancy enable
ipsec sa global-duration
ipsec sa idle-time
ipsec transform-set
ip-subnet-vlan
ipv6
ipv6
ipv6 accept-label
ipv6 address
ipv6 address anycast
ipv6 address auto
ipv6 address auto link-local
ipv6 address dhcp-alloc
ipv6 address eui-64
ipv6 address link-local
ipv6 address prefix-number
ipv6 advertise-label
ipv6 dhcp advertise address-route
ipv6 dhcp advertise pd-route
ipv6 dhcp apply-policy
ipv6 dhcp class
ipv6 dhcp client dscp
ipv6 dhcp client duid
ipv6 dhcp client pd
ipv6 dhcp client stateful
ipv6 dhcp client stateless enable
ipv6 dhcp client-detect
ipv6 dhcp dscp
ipv6 dhcp flood-protection aging-time
ipv6 dhcp flood-protection enable
ipv6 dhcp flood-protection threshold
ipv6 dhcp guard apply policy
ipv6 dhcp log enable
ipv6 dhcp policy
ipv6 dhcp pool
ipv6 dhcp relay client-information record
ipv6 dhcp relay client-link-address enable
ipv6 dhcp relay gateway
ipv6 dhcp relay interface-id
ipv6 dhcp relay release-agent
ipv6 dhcp relay request-from-tunnel discard
ipv6 dhcp relay source-address
ipv6 dhcp select
ipv6 dhcp server
ipv6 dhcp server apply pool
ipv6 dhcp server database filename
ipv6 dhcp server database update interval
ipv6 dhcp server database update now
ipv6 dhcp server database update stop
ipv6 dhcp server entry-convert enable
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping deny
ipv6 dhcp snooping disable
ipv6 dhcp snooping enable
ipv6 dhcp snooping enable vlan
ipv6 dhcp snooping log enable
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 dhcp snooping pd binding record
ipv6 dhcp snooping rate-limit
ipv6 dhcp snooping trust interface
ipv6 dhcp snooping trust tunnel
ipv6 dns dscp
ipv6 dns server
ipv6 extension-header drop enable
ipv6 fast-forwarding load-sharing
ipv6 forwarding-conversational-learning
ipv6 hop-limit
ipv6 hoplimit-expires enable
ipv6 host
ipv6 icmpv6 error-interval
ipv6 icmpv6 source
ipv6 import bgp
ipv6 local policy-based-route
ipv6 lsp-trigger
ipv6 mtrace-service port
ipv6 mtu
ipv6 multicast forwarding supervlan community
ipv6 multicast forwarding-table cache-unknown per-entry
ipv6 multicast forwarding-table cache-unknown total
ipv6 multicast-vlan
ipv6 multicast-vlan entry-limit
ipv6 nd autoconfig other-flag
ipv6 nd check log enable
ipv6 nd dad attempts
ipv6 nd detection enable
ipv6 nd detection log enable
ipv6 nd detection trust
ipv6 nd distributed-gateway dynamic-entry synchronize
ipv6 nd mac-check enable
ipv6 nd mode uni
ipv6 nd ns retrans-timer
ipv6 nd nud reachable-time
ipv6 nd online-offline-log enable
ipv6 nd ra boot-file-url
ipv6 nd ra dns search-list
ipv6 nd ra dns search-list suppress
ipv6 nd ra dns server
ipv6 nd ra dns server suppress
ipv6 nd ra halt
ipv6 nd ra hop-limit unspecified
ipv6 nd ra interval
ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix default
ipv6 nd ra router-lifetime
ipv6 nd raguard apply policy
ipv6 nd raguard log enable
ipv6 nd raguard role
ipv6 nd route-direct advertise
ipv6 nd route-direct prefix convert-length
ipv6 nd router-preference
ipv6 nd snooping dad retrans-timer
ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
ipv6 nd snooping glean source
ipv6 nd snooping lifetime
ipv6 nd snooping max-learning-num
ipv6 nd snooping uplink
ipv6 nd suppression enable
ipv6 nd user-ip-conflict record enable
ipv6 nd user-move record enable
ipv6 neighbor
ipv6 neighbor aging probe-count
ipv6 neighbor aging probe-interval
ipv6 neighbor stale-aging
ipv6 neighbor timer stale-aging
ipv6 neighbors max-learning-num
ipv6 pathmtu
ipv6 pathmtu age
ipv6 pim
ipv6 pim bfd enable
ipv6 pim bsr-boundary
ipv6 pim dm
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim holdtime join-prune
ipv6 pim neighbor-policy
ipv6 pim non-stop-routing
ipv6 pim passive
ipv6 pim require-genid
ipv6 pim sm
ipv6 pim state-refresh-capable
ipv6 pim timer graft-retry
ipv6 pim timer hello
ipv6 pim timer join-prune
ipv6 pim triggered-hello-delay
ipv6 pim-snooping enable
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
ipv6 port multicast-vlan
ipv6 prefer temporary-address
ipv6 prefix
ipv6 prefix-list
ipv6 reassemble local enable
ipv6 redirects enable
ipv6 route fast-switchover enable
ipv6 route-static
ipv6 route-static default-preference
ipv6 source binding (interface view)
ipv6 source binding (system view)
ipv6 temporary-address
ipv6 unreachables enable
ipv6 urpf
ipv6 verify source
irf auto-update enable
irf domain
irf link-delay
irf mac-address
irf mac-address persistent
irf member description
irf member priority
irf member renumber
irf-port
irf-port global load-sharing mode
irf-port-configuration active
isis
isis authentication send-only
isis authentication-mode
isis bfd enable
isis circuit-level
isis circuit-type p2p
isis cost
isis dis-name
isis dis-priority
isis enable
isis fast-reroute lfa-backup exclude
isis ipv6 bfd enable
isis ipv6 cost
isis ipv6 enable
isis ipv6 fast-reroute lfa-backup exclude
isis ipv6 prefix-suppression
isis ipv6 primary-path-detect bfd
isis ipv6 tag
isis mesh-group
isis mib-binding
isis prefix-suppression
isis primary-path-detect bfd
isis silent
isis small-hello
isis tag
isis timer csnp
isis timer hello
isis timer lsp
isis timer retransmit
is-level
is-name
is-name map
ispf enable
ispf enable (OSPF view)
issu accept
issu commit
issu load
issu quit
issu rollback-timer
issu run switchover
J
job
jp-pkt-size (IPv6 PIM view)
jp-pkt-size (PIM view)
jumboframe enable
jumboframe enable
K
keepalive
keepalive
keep-multiplier
key
key
key (HWTACACS scheme view)
key (RADIUS scheme view)
keychain
keychain
keychain
key-string
L
l2agent enable
l2protocol tunnel dot1q
l2protocol tunnel-dmac
l2vpn enable
l2vpn enable
l2vpn enable
l2vpn mac-address software-learning enable
l2vpn switchover
l2vpn switchover
l3agent enable
l3-vni
label-allocation-mode
label-distribution
labeled-route ignore-no-tunnel
lacp default-selected-port disable
lacp edge-port
lacp mode
lacp period short
lacp select speed
lacp system-mac
lacp system-number
lacp system-priority
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
last-listener-query-interval (MLD-snooping view)
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
last-member-query-interval (IGMP-snooping view)
lcd
ldap attribute-map
ldap scheme
ldap server
ldap-server
license activation-file install
license activation-file uninstall
license compress
line
line class
link-aggregation auto-aggregation enable
link-aggregation bfd ipv4
link-aggregation global load-sharing mode
link-aggregation group load-sharing mode local-first
link-aggregation ignore vlan
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation mode
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
link-delay
link-delay
link-flap protect enable
link-management periodic-flooding timer
linkup-delay-timer
listening port
lldp admin-status
lldp check-change-interval
lldp compliance admin-status cdp
lldp compliance cdp
lldp enable
lldp encapsulation snap
lldp fast-count
lldp global enable
lldp global tlv-enable basic-tlv management-address-tlv
lldp hold-multiplier
lldp ignore-pvid-inconsistency
lldp management-address
lldp management-address-format string
lldp max-credit
lldp mode
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp source-mac vlan
lldp timer fast-interval
lldp timer notification-interval
lldp timer reinit-delay
lldp timer tx-interval
lldp tlv-enable
load-splitting (IPv6 MRIB view)
load-splitting (MRIB view)
local-address
local-guest email format
local-guest email sender
local-guest email smtp-server
local-guest generate
local-guest send-email
local-identity
locality
local-proxy-arp enable
local-proxy-nd enable
local-user
local-user auto-delete enable
local-user-export
local-user-import
locator blink
lock
lock reauthentication
lock-key
log data-group-reuse
logfile save
login-dn
login-password
log-peer-change
log-peer-change
log-peer-change
log-peer-change
log-peer-change enable
log-route-flap
longest-match (IPv6 MRIB view)
longest-match (MRIB view)
loopback
loopback-detection action
loopback-detection enable
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
loop-detect
loop-protection enable
ls
ls
lsa-arrival-interval
lsa-generation-interval
lsdb-overflow-interval
lsdb-overflow-limit
lsp-fragments-extend
lsp-length originate
lsp-length receive
lsp-length receive
lsp-trigger
lsr-id
lsr-path
M
mac-address (interface view)
mac-address (system view)
mac-address forwarding-conversational-learning
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information mode
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-learning priority
mac-address mac-move fast-update
mac-address mac-roaming enable
mac-address max-mac-count (interface view)
mac-address max-mac-count (VLAN view)
mac-address max-mac-count enable-forwarding (interface view)
mac-address max-mac-count enable-forwarding (VLAN view)
mac-address multicast
mac-address notification mac-move
mac-address notification mac-move suppression (interface view)
mac-address notification mac-move suppression (system view)
mac-address static source-check enable
mac-address static vsi
mac-advertising disable
mac-authentication
mac-authentication access-user log enable
mac-authentication authentication-method
mac-authentication carry user-ip
mac-authentication critical vlan
mac-authentication critical vsi
mac-authentication critical-voice-vlan
mac-authentication domain
mac-authentication guest-vlan
mac-authentication guest-vlan auth-period
mac-authentication guest-vsi
mac-authentication guest-vsi auth-period
mac-authentication host-mode multi-vlan
mac-authentication max-user
mac-authentication offline-detect enable
mac-authentication offline-detect mac-address
mac-authentication parallel-with-dot1x
mac-authentication re-authenticate
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication server-recovery online-user-sync
mac-authentication timer (interface view)
mac-authentication timer (system view)
mac-authentication unauthenticated-user aging enable
mac-authentication user-name-format
mac-based ac
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
mac-forced-forwarding server
mac-ip dynamic-mac aware
mac-learning enable
mac-list
macsec confidentiality-offset
macsec desire
macsec mka-session log enable
macsec replay-protection enable
macsec replay-protection window-size
macsec validation mode
mac-vlan enable
mac-vlan mac-address
mac-vlan trigger enable
mad arp enable
mad bfd enable
mad enable
mad ip address
mad nd enable
mad restore
map
map export
mapping vni
match
match local (IKEv2 profile view)
match local address (IKE keychain view)
match local address (IKE profile view)
match local address (IKEv2 policy view)
match remote
match remote
match vrf (IKEv2 policy view)
match vrf (IKEv2 profile view)
max-ecmp-num
max-failure
maxhops
maximum load-balancing
maximum load-balancing (OSPF view)
maximum load-balancing (OSPFv3 view)
max-response-time (IGMP view)
max-response-time (IGMP-snooping view)
max-response-time (MLD view)
max-response-time (MLD-snooping view)
max-unicast-load-balancing
md5-authentication
md5sum
mdix-mode
mdns relay enable
mdns relay gateway ip
mdns relay probe interval
mdns relay source ip
member (zone alias view)
member (zone set view)
member (zone view)
memory-threshold
memory-threshold usage
method
method
mirroring-group
mirroring-group mirroring-cpu
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mirror-to cpu
mirror-to interface
mka apply policy
mka enable
mka policy
mka priority
mka psk
mka timer mka-life
mkdir
mkdir
mkdir
mld
mld enable
mld fast-leave
mld group-policy
mld last-listener-query-count
mld last-listener-query-interval
mld max-response-time
mld non-stop-routing
mld other-querier-present-timeout
mld proxy enable
mld proxy forwarding
mld query-interval
mld robust-count
mld startup-query-count
mld startup-query-interval
mld static-group
mld version
mld-snooping
mld-snooping { disable | enable }
mld-snooping done source-ip
mld-snooping dot1p-priority
mld-snooping drop-unknown
mld-snooping fast-leave
mld-snooping general-query source-ip
mld-snooping group-limit
mld-snooping group-policy
mld-snooping host-aging-time
mld-snooping host-join
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping overflow-replace
mld-snooping proxy enable
mld-snooping querier
mld-snooping querier-election
mld-snooping query-interval
mld-snooping report source-ip
mld-snooping router-aging-time
mld-snooping router-port-deny
mld-snooping source-deny
mld-snooping special-query source-ip
mld-snooping version
mode
monitor cpu-usage enable
monitor cpu-usage interval
monitor cpu-usage threshold
monitor kernel deadloop action
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel deadloop time
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
monitor process
monitor resend cpu-usage
monitor resend memory-threshold
monitor thread
monitor-link disable
monitor-link group
more
mount
move
mpls enable
mpls label advertise
mpls ldp
mpls ldp enable
mpls ldp igp sync disable
mpls ldp ipv6 enable
mpls ldp sync (IS-IS view)
mpls ldp sync (OSPF view/OSPF area view)
mpls ldp timer
mpls ldp transport-address
mpls lsr-id
mpls mtu
mpls statistics
mpls statistics interval
mpls te
mpls te affinity-attribute
mpls te auto-tunnel backup disable
mpls te backup
mpls te backup bandwidth
mpls te backup-path
mpls te bandwidth
mpls te bandwidth change thresholds
mpls te bidirectional
mpls te enable (interface view)
mpls te enable (IS-IS view)
mpls te enable (OSPF area view)
mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te igp advertise
mpls te igp metric
mpls te igp shortcut
mpls te link-attribute
mpls te loop-detection
mpls te max-link-bandwidth
mpls te metric
mpls te path
mpls te path-metric-type
mpls te priority
mpls te record-route
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
mpls te resv-style
mpls te retry
mpls te route-pinning
mpls te signaling
mpls te static-cr-lsp
mpls te timer retry
mpls ttl expiration enable
mpls ttl propagate
mrp timer join
mrp timer leave
mrp timer leaveall
mrp timer periodic
msdp
mtrace v1
mtrace v2
mtrace v2 ipv6
mtrace-service port
mtu
mtu
mtu
mtu
mtu
mtu
mtu
multicast boundary
multicast multi-thread enable
multicast routing
multicast rpf-proxy-vector compatible
multicast-ecmp enable
multicast-suppression
multicast-vlan
multicast-vpn
multi-topology
mvrp enable
mvrp global enable
mvrp gvrp-compliance enable
mvrp registration
N
name
nas-id bind vlan
nas-ip (HWTACACS scheme view)
nas-ip (RADIUS scheme view)
nas-port-type
nat-keepalive
nbns-list
nd mac-learning disable
ne-id
ne-ip
nest top-most
netbios-type
netconf capability specific-namespace
netconf idle-timeout
netconf log
netconf soap acl
netconf soap domain
netconf soap dscp
netconf soap enable
netconf ssh server enable
netconf ssh server port
network
network
network
network
network
network
network (OSPF area view)
network short-cut
network-entity
network-type
neutron
newer
nexthop
next-hop ip
next-hop ipv6
next-server
nhop-only
nickname
node-role
no-fragment enable
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
non-stop-routing
npv auto-load-balance enable
npv auto-load-balance-interval
npv load-balance disruptive
npv traffic-map
nqa
nqa agent enable
nqa schedule
nqa server enable
nqa server tcp-connect
nqa server udp-echo
nqa template
nssa (OSPF area view)
nssa (OSPFv3 area view)
ntp-service acl
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service broadcast-client
ntp-service broadcast-server
ntp-service dscp
ntp-service enable
ntp-service inbound enable
ntp-service ipv6 acl
ntp-service ipv6 dscp
ntp-service ipv6 inbound enable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 source
ntp-service ipv6 unicast-peer
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service multicast-client
ntp-service multicast-server
ntp-service refclock-master
ntp-service reliable authentication-keyid
ntp-service source
ntp-service time-offset-threshold
ntp-service unicast-peer
ntp-service unicast-server
O
oam enable
oam errored-frame threshold
oam errored-frame window
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam global timer hello
oam global timer keepalive
oam mode
oam remote-failure action
oam remote-loopback
oam remote-loopback interface
oam remote-loopback reject-request
oam timer hello
oam timer keepalive
object
object-group
opaque-capability enable
open
openflow instance
openflow shutdown
operation (FTP operation view)
operation (HTTP/HTTPS operation view)
option
option
option-group
organization
organization-unit
originating-rp
ospf
ospf area
ospf authentication-mode
ospf bfd enable
ospf cost (interface view)
ospf database-filter
ospf dr-priority
ospf fast-reroute lfa-backup
ospf lsu-flood-control
ospf mib-binding
ospf mtu-enable
ospf network-type
ospf packet-size
ospf prefix-suppression
ospf primary-path-detect bfd
ospf timer dead
ospf timer hello
ospf timer poll
ospf timer retransmit
ospf trans-delay
ospf ttl-security
ospfv3
ospfv3 area
ospfv3 authentication-mode
ospfv3 bfd enable
ospfv3 cost
ospfv3 dr-priority
ospfv3 fast-reroute lfa-backup exclude
ospfv3 ipsec-profile
ospfv3 mib-binding
ospfv3 mtu-ignore
ospfv3 network-type
ospfv3 peer
ospfv3 prefix-suppression
ospfv3 primary-path-detect bfd
ospfv3 timer dead
ospfv3 timer hello
ospfv3 timer poll
ospfv3 timer retransmit
ospfv3 trans-delay
other-querier-present-interval (IGMP view)
other-querier-present-timeout (MLD view)
out interface
output-delay
output-delay
overflow-replace (IGMP-snooping view)
overflow-replace (MLD-snooping view)
ovsdb server bootstrap ca-certificate
ovsdb server enable
ovsdb server pki domain
ovsdb server pssl
ovsdb server ptcp
ovsdb server ssl
ovsdb server tcp
P
packet-capture interface
packet-capture local interface
packet-capture read
packet-capture remote interface
packet-capture stop
packet-filter
packet-filter default deny
packet-filter filter
packet-filter global
pairwise-zoning enable
parity
passive
password
password
password (device management user view)
password (network access user view)
password-control { aging | composition | history | length } enable
password-control aging
password-control alert-before-expire
password-control authentication-timeout
password-control change-password first-login enable
password-control complexity
password-control composition
password-control enable
password-control expired-user-login
password-control history
password-control length
password-control login idle-time
password-control login-attempt
password-control super aging
password-control super composition
password-control super length
password-control update-interval
password-recovery enable
passwords
path-metric-type
pce address
pce deadtimer
pce keepalive
pce request-timeout
pce static
pce tolerance
peer
peer
peer
peer
peer
peer
peer (OSPF view)
peer additional-paths
peer advertise additional-paths best
peer advertise evpn-route suppress
peer advertise origin-as-validation
peer advertise-community
peer advertise-ext-community
peer advertise-policy exist-policy
peer advertise-policy non-exist-policy
peer allow-as-loop
peer as-number (for a BGP peer group)
peer as-number (for a BGP peer)
peer as-path-acl
peer auto-discovery
peer bfd
peer bmp server
peer capability-advertise conventional
peer capability-advertise orf non-standard
peer capability-advertise orf prefix-list
peer capability-advertise route-refresh
peer capability-advertise suppress-4-byte-as
peer connect-interface
peer default-gateway no-advertise
peer default-route-advertise
peer description
peer description
peer dscp
peer ebgp-max-hop
peer enable
peer fake-as
peer filter-policy
peer group
peer ignore
peer ignore-first-as
peer ignore-originatorid
peer ipsec-profile
peer keep-all-routes
peer keychain
peer label-route-capability
peer log-change
peer low-memory-exempt
peer mesh-group
peer minimum-ttl
peer next-hop-invariable
peer next-hop-local
peer nexthop-recursive-policy disable
peer next-hop-vpn
peer password
peer password
peer preferred-value
peer prefix-list
peer public-as-only
peer reflect-client
peer re-originated
peer request-sa-enable
peer route-limit
peer route-policy
peer router-mac-local
peer route-update-interval
peer sa-cache-maximum
peer sa-policy
peer sa-request-policy
peer signaling
peer signaling
peer soo
peer source-address
peer substitute-as
peer timer
peer timer connect-retry
peer ttl-security
peer-public-key end
permit interface
permit vlan
permit vpn-instance
permit-port-type member-port
pex associate
pex auto-config enable
pex group
pex idle-cascade delete
pex local-forwarding
pex persistent-forwarding
pex-capability enable
pfs
phone
pic
pic
pic (OSPF view)
pim
pim bfd enable
pim bsr-boundary
pim dm
pim neighbor-policy
pim passive
pim require-genid
pim sm
pim timer hello
pim-snooping enable
ping
ping ipv6
ping mpls ipv4
ping mpls pw
ping mpls te
pki abort-certificate-request
pki delete-certificate
pki domain
pki entity
pki export
pki import
pki request-certificate
pki retrieve-certificate
pki retrieve-crl
pki storage
pki validate-certificate
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
placement program
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy vpn-target
policy-based-route
port
port
port
port
port
port (IPv6 multicast VLAN view)
port (MAC binding server view)
port (multicast-VLAN view)
port (portal authentication server view)
port access vlan
port bridge enable
port drni group
port drni intra-portal-port
port erps track
port group interface
port hybrid ip-subnet-vlan
port hybrid protocol-vlan
port hybrid pvid
port hybrid vlan
port link-aggregation group
port link-flap protect enable
port link-mode
port link-type
port monitor-link group
port multicast-vlan
port private-vlan host
port private-vlan promiscuous
port private-vlan trunk promiscuous
port private-vlan trunk secondary
port pvid forbidden
port service-loopback group
port smart-link group
port smart-link group track
port s-mlag group
port trunk permit vlan
port trunk pvid
port trunk vsan
port up-mode
port0
port1
portal { bas-ip | bas-ipv6 } (interface view)
portal { ipv4-max-user | ipv6-max-user } (interface view)
portal apply mac-trigger-server
portal apply web-server (interface view)
portal authorization strict-checking
portal delete-user
portal device-id
portal domain (interface view)
portal enable (interface view)
portal fail-permit server
portal free-all except destination
portal free-rule
portal free-rule destination
portal free-rule source
portal ipv6 free-all except destination
portal ipv6 layer3 source
portal ipv6 user-detect
portal layer3 source
portal local-web-server
portal log enable
portal max-user
portal nas-id-profile
portal nas-port-id format
portal nas-port-type
portal pre-auth domain
portal pre-auth ip-pool
portal refresh enable
portal roaming enable
portal server
portal user-detect
portal user-dhcp-only (interface view)
portal user-rule assign-check enable
portal web-proxy port
portal web-server
port-isolate enable
port-isolate group
port-security access-user log enable
port-security authentication open
port-security authentication open global
port-security authorization ignore
port-security authorization-fail offline
port-security enable
port-security escape critical-vsi
port-security free-vlan
port-security global escape critical-vsi
port-security intrusion-mode
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security mac-limit
port-security mac-move permit
port-security max-mac-count
port-security nas-id-profile
port-security ntk-mode
port-security oui
port-security port-mode
port-security timer autolearn aging
port-security timer blockmac
port-security timer disableport
precedence dynamic arp
preemption delay
preemption mode
prefer-cipher
preference
preference
preference
preference
preference
preference
preference (OSPF view)
preferred-path
prefix
prefix-pool
prefix-priority
prefix-priority (OSPF view)
prefix-suppression
prefix-suppression
pre-shared-key
pre-shared-key
prf
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
primary authorization
priority
priority (IKE keychain view)
priority (IKE profile view)
priority (IKEv2 policy view)
priority (IKEv2 profile view)
priority-flow-control (Ethernet interface view)
priority-flow-control (system view)
priority-flow-control no-drop dot1p (Ethernet interface view)
priority-flow-control no-drop dot1p (system view)
private-vlan (VLAN interface view)
private-vlan (VLAN view)
private-vlan community
private-vlan isolated
private-vlan primary
probe count
probe packet-interval
probe packet-number
probe packet-timeout
probe timeout
process core
proposal
proposal
protected-vlan
protected-vlan
protected-vlan
protocol
protocol inbound
protocol lifetime
protocol nexthop recursive-lookup
protocol-packet filter slow
protocol-version
protocol-vlan
provision
proxy multipath (IGMP view)
proxy multipath (MLD view)
proxy-arp enable
proxy-arp enable
proxy-nd enable
public-key dsa
public-key ecdsa
public-key local create
public-key local destroy
public-key local export dsa
public-key local export ecdsa
public-key local export rsa
public-key peer
public-key peer import sshkey
public-key rsa
purge-time
put
put
pv-limit
pw-class (auto-discovery cross-connect group view)
pw-class (auto-discovery VSI view)
pw-class (system view)
pwd
pwd
pwd
pw-redundancy
pw-redundancy
pwsignaling
pw-type
pw-type
python
python filename
Q
qinq enable
qinq ethernet-type (interface view)
qinq ethernet-type (system view)
qinq transparent-vlan
qos apply policy
qos apply policy global
qos apply qmprofile
qos bandwidth queue
qos car
qos gts
qos lr
qos map-table
qos policy
qos pre-classify
qos priority
qos qmprofile
qos sp
qos trust
qos vlan-policy
qos wfq
qos wfq { byte-count | weight }
qos wfq group sp
qos wred apply
qos wred queue table
qos wrr
qos wrr { byte-count | weight }
qos wrr group sp
queue
queue
queue ecn
queue weighting-constant
R
rabbit durable-queue enable
rabbit host
rabbit password
rabbit source-ip
rabbit user
rabbit virtual-host
radius attribute extended
radius attribute-test-group
radius dscp
radius dynamic-author server
radius enable
radius nas-ip
radius scheme
radius session-control client
radius session-control enable
radius trap-version
radius-server activate
radius-server client
radius-server test-profile
r-aps level
r-aps ring-mac
raw-request
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element mos
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
reaction checked-element rtt
reaction trap
reaction trigger per-probe
reaction trigger probe-fail
reaction trigger probe-pass
reauthentication server-select
reboot
redirect
redirect-wait-time
redundancy replay-interval
reflect between-clients
reflector cluster-id
refresh bgp
refresh interval
refresh ip-flow
refresh-time
reget
region-name
register-policy (IPv6 PIM view)
register-policy (PIM view)
register-suppression-timeout (IPv6 PIM view)
register-suppression-timeout (PIM view)
register-whole-checksum (IPv6 PIM view)
register-whole-checksum (PIM view)
remark customer-vlan-id
remark dot1p
remark drop-precedence
remark dscp
remark ip-precedence
remark local-precedence
remark qos-local-id
remark service-vlan-id
remote-address
remote-server
remote-server
remote-server algorithm
remove
rename
rename
rename
repeat
report-aggregation (IGMP-snooping view)
report-aggregation (MLD-snooping view)
reserved vxlan
reset
reset acl counter
reset arp
reset arp detection statistics attack-source
reset arp detection statistics packet-drop
reset arp snooping
reset arp suppression vsi
reset attack-defense policy flood
reset attack-defense statistics local
reset bfd session statistics
reset bgp
reset bgp all
reset bgp bmp server statistics
reset bgp dampening
reset bgp flap-info
reset bgp rpki server
reset blacklist ip
reset blacklist ipv6
reset blacklist statistics
reset cfd dm one-way history
reset cfd tst
reset counters interface
reset counters interface { s-channel | schannel-aggregation }
reset counters interface loopback
reset counters interface null
reset counters interface tunnel
reset counters interface vfc
reset counters interface vlan-interface
reset dhcp relay client-information
reset dhcp relay statistics
reset dhcp server conflict
reset dhcp server expired
reset dhcp server ip-in-use
reset dhcp server statistics
reset dhcp snooping binding
reset dhcp snooping packet statistics
reset diagnostic event-log
reset diagnostic result
reset dldp statistics
reset dns host
reset dot1x access-user
reset dot1x guest-vlan
reset dot1x guest-vsi
reset dot1x statistics
reset drni drcp statistics
reset erps statistics
reset ethernet statistics
reset evi arp-suppression
reset evi isis all
reset evi neighbor-discovery client statistics
reset evi neighbor-discovery server statistics
reset exception context
reset fcid persistent
reset fspf counters
reset hwtacacs statistics
reset igmp group
reset igmp-snooping group
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ike sa
reset ike statistics
reset ikev2 sa
reset ikev2 statistics
reset install log-history oldest
reset ip fast-forwarding cache
reset ip policy-based-route statistics
reset ip prefix-list
reset ip routing-table statistics protocol
reset ip statistics
reset ipsec sa
reset ipsec statistics
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay client-information address
reset ipv6 dhcp relay client-information pd
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 dhcp snooping pd binding
reset ipv6 fast-forwarding cache
reset ipv6 l2-multicast fast-forwarding cache
reset ipv6 multicast fast-forwarding cache
reset ipv6 multicast forwarding event
reset ipv6 multicast forwarding-table
reset ipv6 multicast routing-table
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 nd raguard statistics
reset ipv6 nd snooping vlan
reset ipv6 nd snooping vsi
reset ipv6 nd suppression vsi
reset ipv6 neighbors
reset ipv6 pathmtu
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 prefix-list
reset ipv6 routing-table statistics protocol
reset ipv6 statistics
reset isis all
reset isis event-log graceful-restart
reset isis event-log lsp
reset isis event-log non-stop-routing
reset isis event-log spf
reset isis packet
reset isis peer
reset kernel deadloop
reset kernel exception
reset kernel reboot
reset kernel starvation
reset l2-multicast fast-forwarding cache
reset l2protocol statistics
reset l2vpn mac-address
reset l2vpn statistics ac
reset l2vpn statistics vsi
reset lacp statistics
reset lldp statistics
reset logbuffer
reset mac-authentication access-user
reset mac-authentication critical vlan
reset mac-authentication critical vsi
reset mac-authentication critical-voice-vlan
reset mac-authentication guest-vlan
reset mac-authentication guest-vsi
reset mac-authentication statistics
reset mac-list
reset mdns relay statistics
reset mka session
reset mka statistics
reset mld group
reset mld-snooping group
reset mld-snooping router-port
reset mld-snooping statistics
reset mpls ldp
reset mpls statistics
reset mpls te pce statistics
reset msdp peer
reset msdp sa-cache
reset msdp statistics
reset multicast fast-forwarding cache
reset multicast forwarding event
reset multicast forwarding-table
reset multicast routing-table
reset multicast-vlan group
reset mvrp statistics
reset oam
reset openflow instance statistics
reset osi statistics
reset ospf event-log
reset ospf process
reset ospf redistribution
reset ospf statistics
reset ospfv3 event-log
reset ospfv3 process
reset ospfv3 redistribution
reset ospfv3 statistics
reset packet-drop interface
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset pim-snooping statistics
reset portal packet statistics
reset provision failed-config
reset qos car name
reset qos policy control-plane
reset qos policy global
reset qos vlan-policy
reset radius server-load statistics
reset radius statistics
reset recycle-bin
reset rip process
reset rip statistics
reset ripng process
reset ripng statistics
reset rrpp statistics
reset rsvp authentication
reset rsvp statistics
reset saved-configuration
reset scheduler logfile
reset smart-link statistics
reset stop-accounting-buffer (for HWTACACS)
reset stop-accounting-buffer (for RADIUS)
reset stp
reset tcp statistics
reset trill
reset udp statistics
reset udp-helper statistics
reset version-update-record
reset vlan statistics
reset vrrp ipv6 statistics
reset vrrp statistics
reset zone statistics
resolve-target
resolve-type
resource-monitor minor resend enable
resource-monitor output
resource-monitor resource
response-time
restart
restful http enable
restful https enable
restful user
restore factory-default
restore startup-configuration
retain local-label
retry
retry realtime-accounting
retry stop-accounting (HWTACACS scheme view)
retry stop-accounting (RADIUS scheme view)
return
reverse-route dynamic
reverse-route preference
reverse-route tag
revertive
revertive
revertive-operation
revision-level
rewrite inbound tag
rewrite outbound tag
rfc1583 compatible
rhelp
rib
ring
ring enable
ring-type sub-ring
rip
rip authentication-mode
rip bfd enable
rip bfd enable destination
rip default-route
rip enable
rip input
rip max-packet-length
rip metricin
rip metricout
rip mib-binding
rip output
rip output-delay
rip poison-reverse
rip primary-path-detect bfd echo
rip split-horizon
rip summary-address
rip version
ripng
ripng default-route
ripng enable
ripng ipsec-profile
ripng metricin
ripng metricout
ripng output-delay
ripng poison-reverse
ripng primary-path-detect bfd echo
ripng split-horizon
ripng summary-address
rmdir
rmdir
rmdir
rmon alarm
rmon event
rmon history
rmon prialarm
rmon statistics
robust-count (IGMP view)
robust-count (MLD view)
role
role default-role enable
role feature-group
root-certificate fingerprint
route-distinguisher
route-distinguisher
route-distinguisher (EVPN instance view)
route-distinguisher (public instance view)
route-distinguisher (VPN instance view)
route-mode adj-rib-out
route-mode loc-rib
route-option bypass-route
route-policy
route-policy-change delay-time
router id
router id
router-aging-time (IGMP-snooping view)
router-aging-time (MLD-snooping view)
route-rate-limit
route-replicate
router-id
router-id (BGP instance view)
router-id (BGP-VPN instance view)
route-select delay
route-tag (OSPF view)
route-tag (OSPFv3 view)
route-tag-check enable
route-update-interval withdrawn enable
routing-table limit
routing-table limit
routing-table limit
rpf proxy vector
rpki
rr-filter
rr-filter
rr-filter
rr-filter (BGP VPNv4 address family view)
rr-filter (BGP VPNv6 address family view)
rrpp domain
rrpp enable
rrpp ring-group
rscn aggregation enable
rscn aggregation timer
rstatus
rst-flood action
rst-flood detect
rst-flood detect non-specific
rst-flood threshold
rsvp
rsvp authentication challenge
rsvp authentication key
rsvp authentication lifetime
rsvp authentication window-size
rsvp bfd enable
rsvp enable
rsvp hello enable
rsvp reduction retransmit increment
rsvp reduction retransmit interval
rsvp reduction srefresh
rtm cli-policy
rtm environment
rtm event syslog buffer-size
rtm scheduler suspend
rtm tcl-policy
rule
rule
rule (IPv4 advanced ACL view)
rule (IPv4 basic ACL view)
rule (IPv6 advanced ACL view)
rule (IPv6 basic ACL view)
rule (Layer 2 ACL view)
rule (user-defined ACL view)
rule comment
running-time
S
sa duration
sa duration
sa duration
sa hex-key authentication
sa hex-key encryption
sa idle-time
sa spi
sa string-key
save
save pex-configuration
scan detect
scheduler job
scheduler logfile size
scheduler reboot at
scheduler reboot delay
scheduler schedule
scp
scp client ipv6 source
scp client source
scp ipv6
scp ipv6 suite-b
scp server enable
scp suite-b
screen-length
screen-length disable
search-base-dn
search-scope
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
secondary authorization
security acl
security-logfile save
select-seq load-balance-number
send
send-lifetime utc
send-query enable
send-query enable
server
server connect-interface
server tcp
server vpn-instance
server-detect (portal authentication server view)
server-detect (portal Web server view)
server-load-sharing enable
server-timeout
server-type (MAC binding server view)
server-type (portal authentication/Web server view)
server-verify enable
service
service
service-instance
service-instance
service-instance
service-type (ISP domain view)
service-type (local user view)
session
session protection
session-time include-idle-time
set authentication password
set ingress-load-balancing
set overload
set-att
set-overload
sflow agent
sflow collector
sflow counter collector
sflow counter interval
sflow flow collector
sflow flow max-header
sflow sampling-mode
sflow sampling-rate
sflow source
sftp
sftp client ipv6 source
sftp client source
sftp ipv6
sftp ipv6 suite-b
sftp server enable
sftp server idle-timeout
sftp suite-b
sha256sum
sham-link (OSPF area view)
sham-link (OSPFv3 area view)
shell
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown (cross-connect group view)
shutdown (MSDP view)
shutdown-interval
signaling-protocol
signature { large-icmp | large-icmpv6 } max-length
signature detect
signature level action
signature level detect
silent-interface
silent-interface (OSPF view)
silent-interface(OSPFv3 view)
sip-server
site
site
slot
smart-link flush enable
smart-link group
smartmc auto-link-aggregation enable
smartmc backup configuration interval
smartmc backup configuration max-number
smartmc batch-file apply
smartmc batch-file deploy
smartmc enable
smartmc ftp-server
smartmc group
smartmc outbound
smartmc replace
smartmc resource-monitor interval
smartmc resource-monitor max-age
smartmc tc boot-loader
smartmc tc device-type
smartmc tc password
smartmc tc startup-configuration
smartmc topology-refresh
smartmc topology-refresh interval
smartmc topology-save
smartmc upgrade boot-loader
smartmc upgrade startup-configuration
smartmc vlan
smartsan enable
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp context-name
snmp trap rate-limit
snmp-agent
snmp-agent { inform | trap } source
snmp-agent calculate-password
snmp-agent community-map
snmp-agent context
snmp-agent group
snmp-agent log
snmp-agent mib-view
snmp-agent packet max-size
snmp-agent packet response dscp
snmp-agent port
snmp-agent remote
snmp-agent sys-info contact
snmp-agent sys-info location
snmp-agent sys-info version
snmp-agent target-host
snmp-agent trap enable
snmp-agent trap enable arp
snmp-agent trap enable bfd
snmp-agent trap enable bgp
snmp-agent trap enable evi-isis
snmp-agent trap enable fc-fabric
snmp-agent trap enable fc-name-service
snmp-agent trap enable fc-zone
snmp-agent trap enable ike
snmp-agent trap enable ipsec
snmp-agent trap enable isis
snmp-agent trap enable l2vpn
snmp-agent trap enable l3vpn
snmp-agent trap enable ldp
snmp-agent trap enable mac-address
snmp-agent trap enable mpls
snmp-agent trap enable ospf
snmp-agent trap enable ospfv3
snmp-agent trap enable pim
snmp-agent trap enable pim6
snmp-agent trap enable port-security
snmp-agent trap enable radius
snmp-agent trap enable rrpp
snmp-agent trap enable stp
snmp-agent trap enable syslog
snmp-agent trap enable te
snmp-agent trap enable trill
snmp-agent trap enable vrrp
snmp-agent trap if-mib link extended
snmp-agent trap life
snmp-agent trap log
snmp-agent trap periodical-interval
snmp-agent trap queue-size
snmp-agent usm-user { v1 | v2c }
snmp-agent usm-user v3
snmp-agent usm-user v3 user-role
sntp authentication enable
sntp authentication-keyid
sntp enable
sntp ipv6 unicast-server
sntp reliable authentication-keyid
sntp time-offset-threshold
sntp unicast-server
source
source
source
source interface (ICMP echo/UDP tracert operation view)
source ip
source ipv6
source port
source-deny (IGMP-snooping view)
source-deny (MLD-snooping view)
source-lifetime (IPv6 PIM view)
source-lifetime (PIM view)
source-policy (IPv6 PIM view)
source-policy (PIM view)
speed
speed
spf-schedule-interval
spf-schedule-interval (OSPF view)
sponsor-department
sponsor-email
sponsor-full-name
spt-switch-threshold (IPv6 PIM view)
spt-switch-threshold (PIM view)
ssh client ipv6 source
ssh client source
ssh server acl
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
ssh server dscp
ssh server enable
ssh server ipv6 acl
ssh server ipv6 dscp
ssh server key-re-exchange enable
ssh server pki-domain
ssh server port
ssh server rekey-interval
ssh user
ssh2
ssh2 algorithm cipher
ssh2 algorithm key-exchange
ssh2 algorithm mac
ssh2 algorithm public-key
ssh2 ipv6
ssh2 ipv6 suite-b
ssh2 suite-b
ssl client-policy
ssl client-policy
ssl renegotiation disable
ssl server-policy
ssl version disable
ssl-client-policy
ssl-client-policy
ssm-mapping (IGMP view)
ssm-mapping (MLD view)
ssm-policy (IPv6 PIM view)
ssm-policy (PIM view)
standby auto-update config
startup saved-configuration
startup-query-count (IGMP view)
startup-query-count (MLD view)
startup-query-interval (IGMP view)
startup-query-interval (MLD view)
state
state (ISP domain view)
state (local user view)
state primary
state secondary
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-interval (PIM view)
state-refresh-rate-limit (IPv6 PIM view)
state-refresh-rate-limit (PIM view)
state-refresh-ttl (PIM view)
static-bind
static-bind
static-cr-lsp egress
static-cr-lsp ingress
static-cr-lsp transit
static-lsp egress
static-lsp ingress
static-lsp transit
static-rp (IPv6 PIM view)
static-rp (PIM view)
static-rpf-peer
statistics enable
statistics enable (Ethernet service instance view)
statistics enable (VSI view)
statistics hold-time
statistics interval
statistics max-group
statistics-interval
status
step
stop-accounting-buffer enable (HWTACACS scheme view)
stop-accounting-buffer enable (RADIUS scheme view)
stop-accounting-packet send-force
stopbits
storm-constrain
storm-constrain control
storm-constrain enable log
storm-constrain enable trap
storm-constrain interval
stp bpdu-protection
stp bridge-diameter
stp compliance
stp config-digest-snooping
stp cost
stp dispute-protection
stp edged-port
stp enable
stp global config-digest-snooping
stp global enable
stp global mcheck
stp ignore-pvid-inconsistency
stp log enable tc
stp loop-protection
stp max-hops
stp mcheck
stp mode
stp no-agreement-check
stp pathcost-standard
stp point-to-point
stp port bpdu-protection
stp port priority
stp port shutdown permanent
stp priority
stp pvst-bpdu-protection
stp region-configuration
stp role-restriction
stp root primary
stp root secondary
stp root-protection
stp tc-protection
stp tc-protection threshold
stp tc-restriction
stp tc-snooping
stp timer forward-delay
stp timer hello
stp timer max-age
stp timer-factor
stp transmit-limit
stp vlan enable
stub (OSPF area view)
stub (OSPFv3 area view)
stub-router
stub-router (OSPF view)
sub-ring connect
subvlan
subvlan (IPv6 multicast VLAN view)
subvlan (multicast-VLAN view)
summary
summary
summary automatic
super
super authentication-mode
super default role
super password
super use-login-username
supervlan
switch-mode
switchto pex
syn-ack-flood action
syn-ack-flood detect
syn-ack-flood detect non-specific
syn-ack-flood threshold
syn-flood action
syn-flood detect
syn-flood detect non-specific
syn-flood threshold
sysname
system
system-id
system-working-mode
T
tar create
tar extract
tar list
targeted-peer
targeted-peer
target-only
tclquit
tclsh
tcp anti-naptha enable
tcp check-state interval
tcp dscp
tcp mss
tcp path-mtu-discovery
tcp state
tcp syn-cookie enable
tcp timer fin-timeout
tcp timer syn-timeout
tcp timestamps enable
tcp window
tcp-algorithm-id
tcp-connection backup
tcp-kind
tcp-port
telnet
telnet client source
telnet ipv6
telnet server acl
telnet server acl-deny-log enable
telnet server dscp
telnet server enable
telnet server ipv6 acl
telnet server ipv6 dscp
telnet server ipv6 port
telnet server port
temperature-limit
temporary address range
terminal debugging
terminal logging level
terminal monitor
terminal type
test-aaa
tfc enable
tftp
tftp client ipv6 source
tftp client source
tftp ipv6
tftp-server acl
tftp-server domain-name
tftp-server ip-address
tftp-server ipv6 acl
threshold percentage
threshold weight
time at
time once
time repeating
timer
timer
timer connect-retry
timer error-detect
timer guard
timer hello (IPv6 PIM view)
timer hello (PIM view)
timer hold-off
timer join-prune (IPv6 PIM view)
timer join-prune (PIM view)
timer keepalive
timer lsp-generation
timer lsp-max-age
timer lsp-max-age
timer lsp-max-age
timer lsp-refresh
timer lsp-refresh
timer lsp-refresh
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
timer retry
timer spf
timer spf
timer triggered
timer triggered
timer wtr
time-range
timers
timers
timers removal unused
tnl-policy
tos
tracert
tracert ipv6
tracert mpls ipv4
tracert mpls te
track bfd ctrl
track bfd echo
track cfd
track interface
track interface physical
track interface protocol
track ip route reachability
track list boolean
track list threshold percentage
track list threshold weight
track lldp neighbor
track nqa
traffic behavior
traffic classifier
transform-set
transmit-pacing
transmit-pacing
tree-root priority
trees calculate
trill
trill announcing-vlan
trill bypass-pseudonode enable
trill cost
trill designated-vlan
trill drb-priority
trill enable
trill link-type
trill timer avf-inhibited
trill timer csnp
trill timer hello
trill timer holding-multiplier
trill timer lsp
trill track
trust port
ttl
ttl-security
tunnel
tunnel bfd enable
tunnel dfbit enable
tunnel discard ipv4-compatible-packet
tunnel global source-address
tunnel tos
tunnel ttl
tunnel vpn-instance
tunnel-number
tunnel-policy (auto-discovery cross-connect view)
tunnel-policy (auto-discovery VSI view)
tunnel-policy (system view)
type
U
udp-flood action
udp-flood detect
udp-flood detect non-specific
udp-flood threshold
udp-helper broadcast-map
udp-helper enable
udp-helper port
udp-helper server
umount
undelete
unicast-suppression
update-first route-policy
uplink up-port-threshold
url
url
url
url
url-parameter
url-parameter
usage
user
user-group
user-interface
user-interface class
username
username
user-name-format (HWTACACS scheme view)
user-name-format (RADIUS scheme view)
user-parameters
user-role
user-role
user-role
user-sync
using fortygige
using tengige
V
valid class
validate-source-address
validation mode
validity-datetime
vccv cc
vcf-fabric role
vcf-fabric spine-role master
vcf-fabric topology enable
vcf-fabric underlay autoconfigure
vcf-fabric underlay pause
verbose
verify class
version
version
version
version
version (IGMP-snooping view)
version (MLD-snooping view)
virtual-system
virtual-system
vlan
vlan mapping
vlan mapping untagged
vlan policy deny
vlan precedence
vlan-group
vlan-list
vlan-mapping modulo
vlink-peer (OSPF area view)
vlink-peer (OSPFv3 area view)
voice-config
voice-vlan aging
voice-vlan enable
voice-vlan mac-address
voice-vlan mode auto
voice-vlan qos
voice-vlan qos trust
voice-vlan security enable
voice-vlan track lldp
vpls-id
vpn popgo
vpn-id
vpn-id
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance
vpn-instance (HWTACACS scheme view)
vpn-instance (RADIUS scheme view)
vpn-instance policy deny
vpn-instance-capability simple (OSPF view)
vpn-route cross multipath
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target
vpn-target export-extcommunity
vpn-target import-extcommunity
vrrp check-ttl enable
vrrp dscp
vrrp ipv6 dscp
vrrp ipv6 mode
vrrp ipv6 send-nd
vrrp ipv6 vrid
vrrp ipv6 vrid follow
vrrp ipv6 vrid name
vrrp ipv6 vrid preempt-mode
vrrp ipv6 vrid priority
vrrp ipv6 vrid shutdown
vrrp ipv6 vrid timer advertise
vrrp ipv6 vrid track
vrrp mode
vrrp send-gratuitous-arp
vrrp version
vrrp vrid
vrrp vrid authentication-mode
vrrp vrid follow
vrrp vrid name
vrrp vrid preempt-mode
vrrp vrid priority
vrrp vrid shutdown
vrrp vrid source-interface
vrrp vrid timer advertise
vrrp vrid track
vrrp vrid vrrpv3-send-packet
vsan
vsi
vsi-mac
vtep access port
vtep acl disable
vtep enable
vtep group member local
vtep group member remote
vxlan
vxlan invalid-vlan-tag discard
vxlan local-mac report
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
vxlan udp-port
vxlan vlan-based
vxlan vni
W
web captcha
web https-authorization mode
web idle-timeout
web-auth auth-fail vlan
web-auth domain
web-auth enable
web-auth free-ip
web-auth max-user
web-auth offline-detect
web-auth proxy port
web-auth server
web-redirect url
webui log enable
wwn fcid
X
xconnect vsi
xconnect vsi
xconnect-group
xml
Y
