09-ACL and QoS Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release758X-6W10009-ACL and QoS Command Reference
04-Data buffer commands
04-Data buffer commands 39.16 KB
burst-mode enable
Use burst-mode enable to enable the Burst feature.
Use undo burst-mode enable to disable the Burst feature.
burst-mode enable
The Burst feature is disabled.
The Burst feature is especially useful for reducing packet losses under the following circumstances:
·           Broadcast or multicast traffic is intensive, resulting in bursts of traffic.
·           Traffic enters a device from a high-speed interface and goes out of a low-speed interface.
·           Traffic enters a device from multiple same-rate interfaces and goes out of an interface with the same rate.
# Enable the Burst feature.
[Sysname] burst-mode enable
