06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release758X-6W10006-Layer 3 - IP Routing Command Reference
07-Policy-based routing commands
07-Policy-based routing commands 100.19 KB
apply default-next-hop
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No default next hop is set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
ip-address: Specifies the IP address of the default next hop. If you do not specify the vpn-instance vpn-instance-name option, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that you can specify up to two default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No next hop is set.
Policy node view
ip-address: Specifies the IP address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
&<1-2>: Indicates that you can specify up to two next hops, each of which can be associated with a track entry.
You can specify multiple next hops for backup in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply output-interface
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }
undo apply output-interface [ { interface-type interface-number } ]
No output interface is set.
Policy node view
You can specify only a null interface as the output interface.
# Specify Null 0 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface NULL 0
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
apply service-chain
Use apply service-chain to set the service chain information.
Use undo apply service-chain to restore the default.
apply service-chain path-id service-path-id [ path-index service-path-index ]
No service chain information is set.
Policy node view
path-id service-path-id: Specifies a service chain by its path ID in the range of 1 to 16777215. The path ID uniquely identifies a service chain.
path-index service-path-index: Specifies the path index of the node to which you are sending the matching packets. The value range for path indexes is 1 to 255. Specify this option if the destination node might receive packets from different nodes in the service chain. If the destination node receives packets only from the device, you do not need to specify this option.
# Set service chain path ID 1 and node index 10.
[Sysname] policy-based-route aa permit node 5
[Sysname-pbr-aa-5] apply service-chain path-id 1 path-index 10
description
Use description to configure a description for a policy node.
No description is configured for a policy node.
Policy node view
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as Officeuse for policy node 1.
[Sysname] policy-based-route 1 permit node 1
[Sysname-pbr-1-1] description Officeuse
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device.
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply output-interface Vlan-interface3 track 1
    apply output-interface Vlan-interface4 track 2
  Matched: 0
Total matched: 0
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Policy based routing information for interface XXXX(failed)
PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·          For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·          For a physical interface, specify its slot number.
node 0 deny(not support)
node 2 permit(no resource)
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·          not support—The device does not support the match criteria configured on the node.
·          no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
Matched: 0 (no statistics resource)
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matched
Total number of successful matches on all nodes.
reset ip policy-based-route statistics
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matched: 0
Total matched
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy name              Type     Interface
pr01                     Forward  Vlan-interface2
aaa                      Egress   Tunnel1
aaa                      Local    N/A
Table 5 Command output
Type of the PBR:
·          Forward—Interface PBR.
·          Egress—Outbound PBR.
·          Local—Local PBR.
Interface where the policy is applied.
This field displays N/A for local PBR.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
if-match service-chain
Use if-match service-chain to set a service chain match criterion.
Use undo if-match service-chain to restore the default.
if-match service-chain { path-id service-path-id [ path-index service-path-index ] }
undo if-match service-chain [ path-id service-path-id ] ]
No service chain match criteria are set.
Policy node view
path-index service-path-index: Specifies a node in the service chain by its index to match packets sent from that node. The value range for path indexes is 1 to 255. Specify this option if the device might receive packets from different nodes in the service chain. If only one node in the service chain sends packets to the device, you do not need to specify this option.
# Set a service chain match criterion to match packets with service chain path ID 1 and node index 10.
[Sysname-pbr-aa-5] if-match service-chain path-id 1 path-index 10
ip local policy-based-route
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
ip policy-based-route apply
policy-based-route
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
You cannot use this command on both a Layer 3 aggregate interface and its member ports.
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority. The value range for the node-number argument is 0 to 255.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
·           If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·           If a match mode is specified, the command deletes all nodes configured with the match mode.
·           If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
