01-Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release758X-6W10001-Fundamentals Command Reference
13-License management commands
13-License management commands 65.90 KB
display license
Use display license to display detailed license information.
display license [ activation-file ] [ slot slot-number ]
activation-file: Displays license information about activation files. The device supports license installation only through activation files, so this command always displays license information about activation files whether you specify this keyword or not.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices.
The display license command displays detailed information about all licenses if it is used without the activation-file keyword.
# Display detailed information about all licenses.
<Sysname> display license
Slot 1:
flash:/license/13.ak
Feature: EVB evi mdc TRILL FCoE
Product Description: H3C S7500E Advanced Data Center License
Registered at: 2016-03-08 14:35:47
License Type: Permanent
Current State: In use
Slot n
Member ID of the IRF member device.
Activation file path.
13.ak represents the activation file name.
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·          NA—The system cannot obtain the license type.
·          Permanent—Purchased license that never expires and is always valid.
·          Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·          Trial (days restricted)—Free trial license that is valid for a period of days.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Trial Time Left (days)
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·          In use—The license is being used.
·          Usable—The license is available for use. If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
·          Expired—The license has expired.
·          Uninstalled—The license has been uninstalled.
·          Unusable—The license cannot be used.
·          Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
When you uninstall an activation file, an Uninstall file that contains an Uninstall key is created.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
The DID can be generated as a string. Enter the string when you register the license with the license center.
# Display the SN and DID for the specified slot.
<Sysname> display license device-id slot 1
SN: 210231S12500XSUPSUPC
Device ID: jFvq-zRGA-DpJy-VK@d-$Zz+-QjA7-$pLP-xvzR
display license feature
Use display license feature to display brief license information for features.
# Display brief feature license information.
<Sysname> display license feature
Slot 1:
Total: 8  Usage: 0
Feature                         Licensed        State
APMGR                           N               -
EVB                             N               -
FCoE                            N               -
TRILL                           N               -
evi                             N               -
mdc                             N               -
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
The device does not support MDC in the current software version.
Licensed
Licensing state of the feature:
·          N—Not licensed.
·          Y—Licensed.
License type by purchasing state:
·          Formal—Purchased license.
·          Trial—Trial license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
license activation-file install
Use license activation-file install to install an activation file.
license activation-file install file-name slot slot-number
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on the device.
To install a license activation file successfully, make sure the SN and DID used for registering the feature license matches the current SN and DID of the device.
Activation files are device locked rather than MPU locked. A licensed feature can run on the entire system even after an MPU replacement.
# Install activation file 20130811.ak to the specified slot.
[Sysname] license activation-file install flash:/license/20130811.ak slot 1
This operation might take some time. Do not perform any other operations until the operation is completed or a failure message is displayed. Please wait...
display license activation-file
license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
license activation-file uninstall file-name slot slot-number
Use this command to revoke an unexpired license if you want to transfer the license from one device to another.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
A feature cannot run after you uninstall all of its activation files.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# Uninstall activation file flash:/license/20130811.ak from the specified slot.
[Sysname] license activation-file uninstall flash:/license/20130811.ak slot 1
Uninstall file: flash:/license/20130811.uak
license compress
Use license compress to compress the license storage.
license compress slot slot-number
Use this command if the free license storage (see the display license feature command) is not sufficient.
This command clears expired licenses and uninstalled licenses. If uninstalled licenses or expired licenses exist on the device, the compression operation will make the DID change. Before performing a compression, make sure all licenses registered with the old DID have been installed. You will be unable to install such licenses after the compression.
This command clears invalid licenses (expired licenses and uninstalled licenses) and Uninstall keys from the license storage area. Back up the Uninstall keys before you compress the license storage.
# Compress the license storage on the specified slot.
[Sysname] license compress slot 1
This command will delete all data relevant to uninstalled and expired keys/licenses, including Uninstall keys, and create a new device ID for activation keys/files. Make sure you have saved the Uninstall keys so you can apply for a new activation key/file for the unexpired licenses that were covered by the uninstalled activation keys/files.
Are you sure you want to continue? [Y/N]: Y
