Title | Size | Downloads |
H3C S5800-60C-PWR Ethernet Switch Hot Swappable Power Module Ordering Guide-6W101-book.pdf | 67.57 KB |
1 Power Module Overview
Adopting advanced power module design, the H3C S5800-60C-PWR Ethernet switch features the following:
l Adopting hot swappable power module design, each switch providing two hot swappable power module slots, as shown in Figure 1-1.
l Supporting different models of hot swappable power modules. For details, see Table 1-1.
l Supporting combination of different hot swappable power modules. Users can select them as needed. For details, see Table 2-1.
Figure 1-1 Location of power modules on an S5800-60C-PWR switch (rear panel)
(1) Hot swappable power module 1 |
(2) Filler module (Remove the module when hot swappable power module 1 is a 750 W power module.) |
(3) Hot swappable power module 2 |
(4) Filler module (Remove the module when hot swappable power module 2 is a 750 W power module.) |
The S5800-60C-PWR provides two power module slots on its rear panel. Hot swappable power module slot 1 is empty when the switch is shipped, and hot swappable power module slot 2 is installed with a filler panel. Figure 1-1 illustrates a switch with two PSR300-12A AC power modules.
Table 1-1 Power module models supported by the S5800-60C-PWR
Model |
Power supply mode |
PSR300-12A |
AC input (Rated voltage range: 100 VAC to 240 VAC; 50 Hz or 60 Hz) |
PSR300-12D1 |
–48 VDC equipment-room power supply (Rated voltage range: –48 VDC to –60 VDC) RPS 1000 DC power supply (Rated voltage range: –52 VDC to –55 VDC) |
PSR750-A |
PSR750-D |
Table 2-1 Hot swappable power module configuration of the S5800-60C-PWR
Model (Slot 1) |
Model (Slot 2) |
30 W PoE |
15.4 W PoE |
Remarks |
PSR300-12A |
Not supported |
Not supported |
PSR300-12D1 |
Not supported |
Not supported |
PSR300-12A |
PSR300-12A |
Not supported |
Not supported |
Power module backup |
PSR300-12D1 |
PSR300-12D1 |
Not supported |
Not supported |
PSR300-12A |
PSR300-12D1 |
Not supported |
Not supported |
PSR750-A |
12-port middle power PoE (30 W) |
24-port standard PoE (15.4 W) |
Maximum PoE power: 425 W |
PSR750-D |
48-port middle power PoE (30 W) |
48-port standard PoE (15.4 W) |
Maximum PoE power: 1500 W |
PSR750-A |
PSR750-A |
24-port middle power PoE (30 W) |
Maximum PoE power: 740 W |
PSR750-D |
PSR750-D |
l Do not plug a PSR750-A and PSR750-D on one S5800-60C-PWR switch.
l Do not plug a 300 W power module (PSR300-12A or PSR300-12D1) and a 750 W power module (PSR750-A or PSR750-D) on one S5800-60C-PWR switch.
l Purchasing a power module according to whether PoE is needed and the power of powered devices (PDs), thus ensuring normal PoE power supply. Refer to the corresponding power module manual or H3C S5800 Series Ethernet Switches Installation Manual for the introduction and installation of hot swappable power modules.
