Title | Size | Downloads |
00-About the S5560-EI Command References-book.pdf | 24.55 KB |
About the H3C S5560-EI command references
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the switch. This command reference includes: · Basic CLI · Login management · RBAC · FTP and TFTP · File system management · Configuration file management · Software upgrade · ISSU · Device management · Tcl · Python |
IRF Command Reference |
Covers the commands for configuring the H3C proprietary Intelligent Resilient Framework (IRF) technology features. It covers planning the switch roles in the IRF fabric, connecting the IRF links, and detecting and maintaining the IRF fabric. |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface · Loopback, null, and inloopback interfaces · Bulk interface configuration · MAC address table and MAC Information · Ethernet link aggregation · Port isolation · Spanning tree · Loop detection · VLAN (including VLAN, super VLAN, private VLAN, and voice VLAN) · MVRP · QinQ · VLAN mapping · LLDP · Service loopback group |
Layer 3—IP Services Command Reference |
Covers the commands for configuring IP addressing, IP performance optimization, ARP, IP forwarding basic, DHCP, DNS, UDP helper, IPv6 basics, DHCPv6 server, tunneling, and GRE. This command reference includes: · ARP (including gratuitous ARP, proxy ARP, and ARP snooping) · IP addressing · DNS (including DDNS) · IP forwarding basics (including basic IP forwarding and load sharing) · Fast forwarding · IDRP · IP performance optimization · UDP helper · IPv6 fast forwarding |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes. This command reference includes: · Basic IP routing · Static routing · RIP · OSPF · IS-IS · BGP · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 IS-IS · IPv6 policy-based routing · Routing policy |
IP Multicast Command Reference |
Covers the commands for Layer 3 IPv4 multicast protocols (including IGMP, PIM, and MSDP), Layer 3 IPv6 multicast protocols (including MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (including IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (including MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This command reference includes: · IGMP snooping · PIM snooping · Multicast VLAN · Multicast routing and forwarding · IGMP · PIM · MSDP · MLD snooping · IPv6 multicast routing and forwarding · MLD · IPv6 PIM |
MPLS Command Reference |
Covers the commands for configuring basic MPLS and extended MPLS functions. This command reference includes: · Basic MPLS · LDP · MPLS TE · Static CRLSP · RSVP · Tunnel policy · MPLS L3VPN and IPv6 MPLS L3VPN · MPLS L2VPN · VPLS · MPLS OAM · MCE and IPv6 MCE |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL · QoS (including QoS policy, priority mapping, GTS and rate limit, queue-based accounting, congestion management, per-port queue-based accounting, congestion avoidance, and aggregate CAR) · Data buffer · Time range · QCN |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication, secure management, and attack protection. This command reference includes: · AAA · 802.1X · MAC authentication · Portal · Port security · Password control · PKI · IPsec and IKE · SSH · SSL · IP source guard · ARP attack protection · ND attack defense · MFF · uRPF · FIPS · User profile · Attack detection and prevention · MACsec (available in Release 1121 and later) |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM · CFD · DLDP · RRPP · Smart Link · Monitor Link · VRRP · BFD · Track |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, and test network connectivity. This command reference includes: · System maintenance and debugging (ping, tracert, and system debugging) · NTP (including SNTP) · Information center · NQA · Mirroring (including both port and flow mirroring) · Process monitoring and maintenance · CWMP · PoE · Packet capture · NETCONF |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
