Title | Size | Downloads |
03-Layer 2 - LAN Switching Command Reference-book.pdf | 959.07 KB |
Preface
This command reference describes configuration commands for Layer 2 LAN switching features, including:
· Flow control and load sharing.
· Isolating users in the same VLAN and configuring VLANs.
· Eliminating Layer 2 loops.
· Transmitting packets of the customer network over the service provider network.
· Modifying VLAN tags.
· Audience
Audience
· Network planners.
· Network administrators working with the S5560-EI switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
