Title | Size | Downloads |
04 Layer 3 - IP Services Command Reference-book.pdf | 1.2 MB |
Preface
The H3C S5500-HI documentation set includes 11 command references, which describe the commands and command syntax options available for the H3C S5500-HI Switch Series.
The Layer 3—IP Services Command Reference describes the commands for configuring IP addressing, DHCP, IP performance optimization, ARP, DNS, UDP helper, IRDP, IPv6 basics, DHCPv6 and IPv4-IPv6 transitional technologies.
This preface includes:
· Audience
· About the H3C S5500-HI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-HI series
Added and modified commands
This documentation set is for Release 52xx. The following describes the command changes between releases:
· Release 5206 has the following command changes over Release 5203:
Command reference |
Added and modified commands |
ARP |
N/A |
IP addressing |
Modified features: The description keyword was added to the display interface brief command. |
DHCP |
N/A |
DNS |
N/A |
IRDP |
N/A |
IP performance optimization |
N/A |
UDP Helper |
N/A |
IPv6 basics |
N/A |
DHCPv6 |
N/A |
IPv6 DNS |
N/A |
Tunneling |
N/A |
Release 5203 has the following command changes over Release 5101:
Command reference |
ARP |
· Added commands: arp ip-conflict prompt |
IP addressing |
· N/A |
DHCP |
Added commands: · dhcp dscp · dhcp server client-detect enable · dhcp client dscp · Modified commands: keywords cipher and simple were added to the bims-server command. |
DNS |
Added commands: · dns dscp dns source-interface |
IRDP |
N/A |
N/A |
UDP Helper |
Modified command: option vpn-instance vpn-instance-name was added to the udp-helper server command. |
IPv6 basics |
Modified commands: value range of the task-id argument in the display ipv6 socket command changed. |
DHCPv6 |
Added commands: · ipv6 dhcp dscp · ipv6 dhcp client dscp · ipv6 dhcp snooping option interface-id enable · ipv6 dhcp snooping option interface-id string · ipv6 dhcp snooping option remote-id enable ipv6 dhcp snooping option remote-id string |
IPv6 DNS |
Added command: dns ipv6 dscp. |
Tunneling |
N/A |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5500-HI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochure |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual CE DOCs |
Provide regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Guides you through initial installation and setup procedures to help you quickly set up your device. |
Installation guide |
Provides a complete guide to switch installation and specifications. |
LSPM1FAN and LSPM1FANB Installation Manual |
Describes the appearances, specifications, installation, and removal of the pluggable fan modules available for the products. |
User manuals for power modules |
Describe the specifications, installation, and replacement of hot swappable power modules. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Helps you order RPSs for switches that can work with an RPS. |
User manuals for RPSs |
Describe the specifications, installation, and replacement of RPSs. |
User manuals for interface cards |
Describe the specifications, installation, and replacement of expansion interface cards. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the specifications of pluggable transceiver modules. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
