H3C Comware 7 NETCONF API Developers Guide-6W100
HomeSupportResource CenterTechnical DocumentsConfigure & DeployConfiguration GuidesH3C Comware 7 NETCONF API Developers Guide-6W100
Download Book
Table of Contents
Related Documents
Developers Guide
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
This document provides generic technical information, some of which might not be applicable to your products.
Preface
This guide is intended for network administrators and operators to configure and manage Comware-based devices from a NETCONF client.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners that have knowledge of XML and NETCONF.
·     Network administrators that manage Comware-based devices from a NETCONF client.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Represents an access point.
We appreciate your comments.
About NETCONF· 1
NETCONF protocol stack· 1
Basic NETCONF architecture· 1
NETCONF message formats· 2
NETCONF· 2
NETCONF over SOAP· 4
Additional NETCONF message format conventions· 5
Protocols and standards· 6
Supported capability sets· 7
Supported protocol operations· 8
Using NETCONF to configure and manage the device· 9
Summary procedure· 9
Choosing a NETCONF client and session type· 10
NETCONF-based configuration methods· 10
NETCONF access methods· 11
Assigning access permissions to a NETCONF user on the device· 11
About NETCONF user access permissions· 11
Configuring user role rules for the NETCONF client 13
Configuring a user account for the NETCONF client 14
Configuring NETCONF session establishment settings· 15
Configuring settings for NETCONF over SSH· 15
Configuring NETCONF over SOAP over HTTP (or HTTPS) service· 16
Constructing XML NETCONF requests· 16
About NETCONF API references· 16
Using NETCONF API references to construct NETCONF requests· 18
Using XSD schema files to construct NETCONF requests· 19
Using YANG module files to construct NETCONF requests· 19
Connecting the NETCONF client to the target device· 19
Selecting a NETCONF access method· 19
Establishing a NETCONF over SOAP over HTTP (or HTTPS) session to the target device· 20
Establishing a NETCONF over SSH session to the target device· 24
Establishing a NETCONF over Telnet, SSH, or console to access the CLI of the target device· 24
Verifying that the NETCONF session has been established· 24
Testing the connectivity between the NETCONF client and the target device· 25
Exchanging capability sets· 25
Disconnecting a NETCONFsession· 26
Validating a NETCONF XML request file· 26
Integrating the validated XML request into the NETCONF client script or program·· 27
Best practices· 27
Fault tolerance· 27
Massive data retrieval 27
Session concurrency· 28
Termination of NETCONF over SOAP over HTTP or HTTPS sessions· 28
Event notification suppression· 28
Mixed use of HTTP and HTTPS· 28
FAQ·· 29
What should I do when no response is received to a NETCONF XML request in CLI?· 29
What should I do when I receive a request timeout error message on a SOAP-based NETCONF client such as SoapUI?  29
Device-supplied test commands· 29
About Comware NETCONF sessions· 30
Lifecycle of NETCONF sessions· 30
Lifecycle of NETCONF over SOAP sessions· 30
Lifecycle of NETCONF over console, Telnet or SSH sessions· 31
Request concurrency over one session· 31
RBAC-based access control 31
Configuration lock· 32
Maximum number of NETCONF sessions· 32
Executing Comware NETCONF requests· 32
Supported NETCONF operations· 32
Standard NETCONF operations· 34
get-config· 34
edit-config· 35
lock· 41
unlock· 42
get 43
close-session· 44
kill-session· 45
create-subscription· 46
validate· 52
get-schema· 52
netconf-state· 53
commit (immediate commit) 58
commit (confirmed commit) 58
commit (confirming commit) 59
cancel-commit 60
copy-config· 60
delete-config· 61
discard-changes· 61
Comware-extended protocol operations· 61
get-bulk· 61
get-bulk-config· 63
action· 64
load· 65
save· 66
rollback· 68
CLI 68
get-sessions· 73
save-point 75
Name-to-index conversion· 80
edit-config:incremental 81
cancel-subscription· 82
createDot1qFlow· 83
deleteDot1qFlow· 84
sortByName (for data retrieval operations) 85
xml2cli 86
Summary of NETCONF data operations· 96
About responses to data retrieval requests· 102
Returning data in tables, rows, or columns· 102
Returning empty data to a data retrieval request 104
Impact of RBAC on data retrieval results· 104
Impact of module-specific filters on data retrieval 104
Comware NETCONF data filtering· 105
Data filtering methods· 105
Exact match· 105
Regular expression match· 106
About regular expressions· 106
Example: Using a regular expression to filter data· 108
Conditional match· 110
About conditional match· 110
Example: Performing conditional match to filter data· 112
Filtering instances of a column· 113
Filtering instances of a group (data structure) 113
Example: Using ncclient for NETCONF-based device configuration and management 1
Setting up ncclient 1
About ncclient 1
Setting up the environment 1
Installing ncclient 1
Executing the script 2
Establishing a NETCONF session· 2
Configuring the target device for NETCONF session establishment 2
Running a script to establish a NETCONF session· 2
Basic device management with ncclient 4
Constructing an <edit-config> request 5
Constructing a <get> or <get-config> request for data retrieval 8
Constructing a <get-bulk> or <get-bulk-config> request for configuration and state data retrieval 10
Constructing an <action> request to perform a non-configuration operation· 13
Constructing a subscription request 14
Constructing an <xml2cli> request for XML-to-CLI conversion· 16
Appendixes· 1
Appendix A  Comware NETCONF operation error messages· 1
Error handling mechanism·· 1
Common schema errors· 1
Common NETCONF operation errors· 10
Appendix B  Comware schema built-in data types· 25
Appendix C  Treatment of Boolean or boolean values in Comware· 26
Appendix D  Common issues and recommendations· 26
Scenario-dependent columns· 26
IP and mask as indexes· 26
Order of same-level elements in a request 27
About NETCONF
Network Configuration Protocol (NETCONF) is an XML-based network management protocol. It provides a programmable mechanism to manage and configure network devices. Network administrators can use NETCONF to configure network devices and retrieve their configuration and operational data. On a network that has devices from different vendors, you can develop a NETCONF-based management system to configure and manage devices in a simple and effective way.
The NETCONF protocol stack contains a content layer, operations layer, remote procedure call (RPC) layer, and transport protocol layer.
Table 1 NETCONF layer and XML layer mappings
NETCONF layer
XML layer
Content
Configuration data, operational state data, and statistics
Contains a set of managed objects, which can be configuration data, operational state data, and statistics.
For information about permission of access to the data nodes, see the NETCONF XML API references for the device.
Operations
<get>, <get-config>, <edit-config>…
Defines a set of base operations invoked as RPC methods with XML-encoded parameters.
NETCONF base operations include data retrieval operations, configuration operations, lock operations, and session operations. For information about operations supported on the device, see "Supported protocol operations."
RPC
<rpc> and <rpc-reply>
Provides a simple, transport-independent framing mechanism for encoding RPCs. NETCONF uses <rpc> and <rpc-reply> elements to enclose requests and responses (data at the operations layer and the content layer).
Transport protocol
In non-FIPS mode:
Console, Telnet, SSH, HTTP, HTTPS, and TLS
In FIPS mode:
Console, SSH, HTTPS, and TLS
Provides reliable, connection-oriented, serial data links.
The following transport layer sessions are supported in non-FIPS mode:
·     CLI sessions, including NETCONF over Telnet, NETCONF over SSH, and NETCONF over console sessions.
·     NETCONF over HTTP and NETCONF over HTTPS sessions.
·     NETCONF over SOAP sessions, including NETCONF over SOAP over HTTP and NETCONF over SOAP over HTTPS sessions.
The following transport layer sessions are supported in FIPS mode:
·     CLI sessions, including NETCONF over SSH and NETCONF over console sessions.
·     NETCONF over HTTPS sessions.
·     NETCONF over SOAP over HTTPS sessions.
As shown in Figure 1, NETCONF architecture is based on the client-server model.
·     A NETCONF client can be a script or application typically running as part of a network manager to manage or configure NETCONF servers. It can be NETCONF software such as ncclient or NetConf Browser or a script or program based on SOAP requests. The client invokes protocol operations on the servers for the following purposes:
¡     Configures or manages the network devices that act as NETCONF servers.
¡     Retrieves the state data from the network devices.
¡     Subscribes to notifications about events and alarms from the network devices.
·     A managed network device acts as a NETCONF server to execute protocol operations invoked by the client and sends event notifications to the client.
Figure 1 Basic NETCONF architecture
NETCONF
All NETCONF messages are XML-encoded and comply with the formats defined in RFC 4741.
NETCONF requests and replies use different message formats.
The server checks every request against the XML schema before it processes them. If a request passes XML schema check, the server continues to process the request. If a request fails XML schema check, the server sends an error message to the client.
Request format (Base 1.0 capability set)
Comware supports the following generic NETCONF request message format:
<rpc message-id =”101” xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0”>
  <operation>
</rpc>
The <operation> argument represents any operation elements listed in "Supported protocol operations."
·     A get request contains H3C-defined module information elements in the <top> subelement under the <filter> element. The following information takes the <get-config> request format for example:
<rpc message-id=”101” xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0”>
  <get-config>
    <source>
      <running/>
    </source>
    <filter type=”subtree”>
      <top xmlns=”http://www.h3c.com/netconf/config:1.0”>
        Module information
      </top>
    </filter>
  </get-config>
</rpc>
·     An edit-config request contains H3C-defined module information elements in the <top> subelement under the <config> element, as shown below:
  <edit-config>
    <target>
      <running/>
    </target>
    <config xmlns:xc=”urn:ietf:params:xml:ns:netconf:base:1.0”>
        Module information
      </top>
    </config>
  </edit-config>
</rpc>
For more information about the XML structures defined by H3C for the accessible data items, see the H3C Comware 7 NETCONF XML API reference for the module of interest.
The following example shows a NETCONF request that retrieves all data from all interfaces on the target device:
<?xml version="1.0" encoding="utf-8"?>
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
             <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
IMPORTANT
IMPORTANT:
In the XML view of the device, you must add the ]]>]]> end delimiter string at the end of every NETCONF message for the device to identify the messages. For simplicity, this document omits the ]]>]]> end delimiter string in all sample NETCONF messages except the previous one.
Response format (Base 1.0 capability set)
The response format is compliant with the <rpc-reply> message defined in RFC 4741. The following example shows the response to a successful NETCONF operation:
<rpc-reply xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0” message-id=”101”>
  <ok/>
</rpc-reply>
NETCONF over SOAP
All NETCONF over SOAP messages are contained in the <Body> element of SOAP messages. NETCONF over SOAP messages also comply with the following rules:
·     The SOAP messages must be XML encoded.
·     SOAP messages must use the SOAP Envelope namespaces and SOAP Encoding namespaces.
·     The SOAP messages cannot contain the following information:
¡     DTD references.
¡     XML processing instructions.
NETCONF over SOAP requests and replies use different message formats.
NETCONF over SOAP request format
The following example shows a NETCONF over SOAP request that retrieves all data from all interfaces on the target device:
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
  <env:Header>
    <auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
      <auth:AuthInfo>100002ea7bd8f3bbb727c5eff9b246d85be6</auth:AuthInfo>
    </auth:Authentication>
  </env:Header>
  <env:Body>
      <get>
            <Ifmgr>
              <Interfaces>
                <Interface/>
              </Interfaces>
            </Ifmgr>
          </top>
        </filter>
      </get>
    </rpc>
  </env:Body>
</env:Envelope>
NETCONF over SOAP reply format
<env:Envelope xmlns:env=”http://schemas.xmlsoap.org/soap/envelope/”>
  <env:Header>
    <auth:Authentication env:mustUnderstand=”true” xmlns:auth=”http://www.h3c.com/netconf/base:1.0”>
      <auth:AuthInfo>10027c2abebdb482633f847102fbc890d22a</auth:AuthInfo>
  </env:Header>
  <env:Body>
    <rpc-reply message-id=”101” xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0”>
      <data>
          <Syslog>
            <LogBuffer>
              <BufferSize>527</BufferSize>
            </LogBuffer>
            <LogHosts>
              <Host>
                <Address>1.1.1.1</Address>
                <VRF/>
                <Port>123</Port>
                <Facility>152</Facility>
              </Host>
              <Host>
                <VRF>a</VRF>
                <Port>123</Port>
              </Host>
              <Host>
                <VRF>b</VRF>
                <Port>123</Port>
              </Host>
              <Host>
                <VRF>c</VRF>
                <Port>123</Port>
              </Host>
            </LogHosts>
          </Syslog>
        </top>
      </data>
    </rpc-reply>
  </env:Body>
</env:Envelope>
CDATA nodes
The NETCONF server in Comware encloses the raw data output from CLI commands in CDATA tags to prevent misinterpretation of some data as XML markups. When the NETCONF client receives the response to a CLI operation, the NETCONF client must extract data from the CDATA tag.
Comments
You can add any valid XML comments in the NETCONF requests sent to a Comware-based device. The XML-encoded responses do not contain XML comments.
Spaces
To retain the leading or trailing spaces of a string in a request, you must escape the first leading space or the last trailing space, respectively. The escape rules are in compliance with the W3C XML specification. The NETCONF server will ignore the space sequences at the two ends of a string if they are not escaped.
In responses sent by the NETCONF server in Comware, the leading and trailing spaces in a string are automatically escaped.
Escaping XML data
Escape special characters or characters not available in the used encoding, in compliance with the W3C XML specification. For example, use the &#x09; string to escape the Tab character.
XML encoding
The Comware NETCONF server supports GB2312, GB18030, UTF-8, UTF-16, UTF-16BE, UTF-16LE, UTF-32, UTF-32BE, and UTF-32LE for XML data encoding. If a request does not specify an encoding format, UTF-8 encoding applies. The server uses the question mark (?) to replace any characters that are not convertible during character set conversion.
Table 2 shows the support of the Comware NETCONF implementation for NETCONF protocols and standards.
Table 2 Support of Comware for NETCONF protocols and standards
Protocol number
Protocol title
Support status
RFC 4741
NETCONF Configuration Protocol
Supported
RFC 4742
Using the NETCONF Configuration Protocol over Secure Shell (SSH)
Supported
RFC 4743
Using NETCONF over the Simple Object Access Protocol (SOAP)
Supported
RFC 4744
Using the NETCONF Protocol over the Blocks Extensible Exchange Protocol (BEEP)
Not supported
RFC 5277
NETCONF Event Notifications
Supported
RFC 5381
Experience of Implementing NETCONF over SOAP
Supported
RFC 5539
NETCONF over Transport Layer Security (TLS)
Not supported
RFC 5717
Partial Lock Remote Procedure Call (RPC) for NETCONF
Not supported
RFC 6020
YANG - A Data Modeling Language for the Network Configuration Protocol (NETCONF)
Supported
RFC 6021
Common YANG Data Types
Supported
RFC 6022
YANG Module for NETCONF Monitoring
Supported
RFC 6087
Guidelines for Authors and Reviewers of YANG Data Model Documents
Supported
RFC 6241
Supported
RFC 6242
Using the NETCONF Protocol over Secure Shell (SSH)
Supported
RFC 6243
With-defaults Capability for NETCONF
Not supported
RFC 7950
The YANG 1.1 Data Modeling Language
Supported
Table 3 presents the availability of standard and vendor-defined private capability sets with Comware at the time of this writing. The Protocol column displays a hyphen (‑) for private capability sets.
Table 3 NETCONF capability set implementation of Comware
RFC
Capability set
Status
RFC 4741
Base 1.0
urn:ietf:params:netconf:base:1.0
Supported
RFC 4741
Writable-Running
urn:ietf:params:netconf:capability:writable-running:1.0
Supported
RFC 4741
Candidate Configuration
urn:ietf:params:netconf:capability:candidate:1.0
Supported
RFC 4741
Confirmed Commit 1.0
urn:ietf:params:netconf:capability:confirmed-commit:1.0
Supported
RFC 4741
Rollback on Error
urn:ietf:params:netconf:capability:rollback-on-error:1.0
Supported
RFC 4741
Validate 1.0
urn:ietf:params:netconf:capability:validate:1.0
Supported
RFC 4741
Distinct Startup
urn:ietf:params:netconf:capability:startup:1.0
Not supported
RFC 4741
URL
urn:ietf:params:netconf:capability:url:1.0?scheme={name,...}
Not supported
RFC 4741
XPATH
urn:ietf:params:netconf:capability:xpath:1.0
Not supported
RFC 5277
Interleave
urn:ietf:params:netconf:capability:interleave:1.0
Supported
RFC 6022
Yang
urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring
Supported
RFC 6241
Validate 1.1
urn:ietf:params:netconf:capability:validate:1.1
Supported
RFC 6241
Confirmed Commit 1.1
urn:ietf:params:netconf:capability:confirmed-commit:1.1
Supported
RFC 6242
Base 1.1
urn:ietf:params:netconf:base:1.1
Supported
h3c-netconf-ext:1.0
urn:h3c:params:netconf:capability:h3c-netconf-ext:1.0
Supported
h3c-save-point:1.0
urn:h3c:params:netconf:capability:h3c-save-point:1.0
Supported
h3c-name2index:1.1
urn:h3c:params:netconf:capability:h3c-name2index:1.1
Supported
not-need-top:1.0
urn:h3c:params:netconf:capability:not-need-top:1.0
Supported
module-specified-namespace:1.0
urn:h3c:params:netconf:capability:module-specified-namespace:1.0
Supported
h3c-lightrollback:1.0
urn:h3c:params:netconf:capability:h3c-lightrollback:1.0
Supported
full-replace:1.0
urn:h3c:params:netconf:capability:full-replace:1.0
Supported
save-safely:1.0
urn:h3c:params:netconf:capability:h3c-save-safely:1.0
Supported
xml2cli:1.0
urn:h3c:params:netconf:capability:h3c-xml2cli:1.0
Supported
Table 4 lists the availability of NETCONF operations with Comware.
Table 4 NETCONF operations available with Comware
RPC operation
Status
action
Executes a non-configuration action, for example, an action to clear or obtain operational statistics.
Supported
CLI
Executes CLI commands that are not available in NETCONF API form.
Supported
commit
Commits the configuration in the candidate datastore to the running datastore.
Supported
cancel-commit
Cancels an ongoing confirmed commit and rolls back the running configuration to the previously committed configuration.
Supported
close-session
Closes the current NETCONF session.
Supported
copy-config
Creates or replaces an entire configuration datastore with the content of another complete configuration datastore.
Supported
create-subscription
Subscribes to events.
Supported
delete-config
Deletes configuration data.
Supported
discard-changes
Discards uncommitted changes.
Supported
edit-config
Edits the configuration in a datastore.
Supported
get
Retrieves running configuration and state data.
Supported
get/filter/netconf
Retrieves the event streams supported by the target device.
Supported
get/filter/netconf-state
Retrieves NETCONF state data.
Supported
get-bulk
Retrieves device data in bulk.
Supported
get-bulk-config
Retrieves configuration data in bulk.
Supported
get-config
Retrieves configuration data from a datastore.
Supported
get-sessions
Retrieves NETCONF session information.
Supported
kill-session
Forces termination of any other NETCONF sessions than the current one.
Supported
load
Loads the configuration from a file.
Supported
lock
Locks a configuration datastore.
Supported
rollback
Rolls back configuration.
Supported
save
Saves configuration.
Supported
unlock
Unlocks a locked configuration datastore.
Supported
validate
Examines NETCONF requests for XML syntax errors.
Supported
get-schema
Retrieves YANG/Schema model files.
Partial support.
YANG files are available only for some of the feature modules.
cancel-subscription
Unsubscribes from events.
Supported
The action, CLI, get-bulk, get-bulk-config, get-sessions, load, save, rollback and cancel-subscription operations are Comware specific. Comware also adds the count attribute to the <get> and <get-config> operations. For more information about these operations, see "Executing Comware NETCONF requests."
Summary procedure
To configure and manage the device:
1.     Choosing a NETCONF client and session type
Comware supports the following NETCONF access methods:
¡     NETCONF over Telnet
¡     NETCONF over Console
¡     NETCONF over SSH
¡     NETCONF over SOAP over HTTP
¡     NETCONF over SOAP over HTTPS
Select a method depending on the network environment.
2.     Assigning access permissions to a NETCONF user on the device
Authorizes the NETCONF client to use the required network service:
¡     To establish NETCONF over SOAP over HTTP sessions, authorize the client to use the HTTP service.
¡     To establish NETCONF over SOAP over HTTPS sessions, authorize the client to use the HTTPS service.
¡     To establish NETCONF over SSH sessions, authorize the client to use the SSH service.
3.     Configuring NETCONF session establishment settings
Configure parameters for NETCONF session establishment.
4.     Constructing XML NETCONF requests
Use the API documents for the modules of interest to construct NETCONF XML requests.
5.     Setting up the NETCONF client
Set up the NETCONF client. Verify that it can send hello and close-session messages to the target device successfully. The client can be an RFC 4741-compliant network management software or SOAP-based scripting tool or utility. For more information about NETCONF client setup, see the documentation for the client.
6.     Connecting the NETCONF client to the target device
Establish a NETCONF session from the NETCONF client to the target device.
7.     Testing the connectivity between the NETCONF client and the target device
Verify that the client can establish a session to the target device and close the session by sending a hello and close-session message, respectively.
8.     Validating a NETCONF XML request file
Use a validation tool or access the XML view of the target device to verify that the NETCONF XML request files are valid and correct.
9.     Integrating the validated XML request into the NETCONF client script or program
Build the request files into the client software.
10.     (Optional.) Best practices
Use the best practices to optimize the NETCONF configuration and client setup. The best practices provide recommendations regarding fault tolerance, massive data processing, concurrency, and other important issues.
11.     (Optional.) FAQ
Access the target device from the NETCONF client to operate and manage the device. For more information about the operations supported in Comware, see "Executing Comware NETCONF requests."
To configure and manage the device from a NETCONF client, use one of the following methods:
·     Access the CLI of the device through a Telnet, SSH, or console session. In XML view, copy and paste NETCONF messages to operate and configure the device. For more information about NETCONF message formats, see “NETCONF.” Typically, you use this method for development or test purposes.
·     Use a configuration tool to issue NETCONF RPC messages to operate or configure the device. The configuration tool can use SSH or SOAP as the transport protocol for NETCONF.
¡     NETCONF over SSH—The configuration tool establishes an SSH connection with the device and then transport NETCONF RPC messages over the connection. For more information about NETCONF message formats, see "NETCONF."
¡     NETCONF over SOAP—Establishes an HTTP or HTTPS connection with the device and then transport SOAP-encapsulated NETCONF RPC messages over the connection. For more information about NETCONF over SOAP message formats, see "NETCONF over SOAP." To use this method, you must enable NETCONF over SOAP on the device.
You can develop custom NETCONF-based configuration applications or use a third-party configuration tool depending on the choice of transport protocol. For example, to run NETCONF over SSH, choose NetConf Browser. To run NETCONF over SOAP, choose SoupUI.
For more information about a configuration tool, see its documentation.
H3C devices support different NETCONF access methods in non-FIPS mode and FIPS mode.
·     In non-FIPS mode:
¡     NETCONF over SSH.
¡     NETCONF over Telnet.
¡     NETCONF over console.
¡     NETCONF over SOAP over HTTP.
¡     NETCONF over SOAP over HTTPS.
·     In FIPS mode:
¡     NETCONF over SSH.
Select an access method depending on the configuration method, as shown in Table 5.
Table 5 Configuration methods and NETCONF access methods matrix
Login method
CLI in XML view
Telnet
NETCONF over Telnet
Console port
SSH
NETCONF over SSH
SSH-based configuration tool (for example, NETCONF Browser)
SSH
NETCONF over SSH
SOAP-based configuration tool
HTTP or HTTPS
NETCONF over SOAP over HTTP/HTTPS
To have a NETCONF client establish a NETCONF session with the target device, make sure the user account used by the NETCONF client has the required access permissions.
Comware uses the role-based access control (RBAC) model to control access to the system by user role. A user role is assigned access permissions based on user role rules and resource access policies.
·     A user role rule controls access to a system functionality or feature. For example, you can define a user role rule to permit or deny access to feature A.
·     A resource access policy controls access to system resources. For example, you can define a resource access policy to permit access to VLAN 10.
User role rules for a NETCONF user role must include the following access permissions:
·     Access to the <rpc> element and the elements required for the NETCONF operations to be performed. Table 7 shows the NETCONF operations and their required access permissions.
·     Access to the XML elements for the feature modules and tables in the modules, at their XPaths. For example, to assign the NETCONF client read, write, and execute access to the XML elements for the interface module, execute the rule number permit read write execute xml-element ifmgr/ command.
Every user role has one interface policy, VLAN policy, VPN instance policy, and security zone policy. By default, these policies permit a user role to access any system resources.
Comware 7 predefines a set of user roles. The following are the most commonly used predefined user roles:
Table 6 Predefined user roles in most common use and their access permissions
Permissions
Remarks
network-admin, mdc-admin, and context-admin
Have full access to all features and resources on the device, administered MDC, and administered context, respectively, except for the following commands for security log file management:
·     display security-logfile summary
·     info-center security-logfile directory
·     security-logfile save
You assign the network-admin, mdc-admin, or context-admin user role to an administrator without having to do additional configuration.
network-operator, context-operator and mdc-operator
Have only read access to all features and execute access to some of the features on the device, administered MDC, and administered context, respectively.
N/A
You can also use other predefined user roles and configure custom user roles for granular functionality and resource access control. For more information about RBAC, see the fundamentals configuration guide for the target device.
When you assign access permissions to NETCONF users, use Table 7.
Table 7 NETCONF operations and required access permissions
NETCONF operation
XML element path
Required access to the path
N/A
Execute access to the xml command is required for NETCONF over Telnet or NETCONF over Console access to the CLI in XML view.
Subscribe to events
rpc/create-subscription
execute
Lock a configuration datastore
rpc/lock
execute
Unlock a configuration datastore
rpc/unlock
execute
Perform the <get> operation to retrieve device configuration and state data
rpc/get
read
Perform the <get> operation to retrieve NETCONF state data
rpc/get/filter/netconf-state
read
Perform the <get-bulk> operation to retrieve device configuration and state data
rpc/get-bulk
read
Perform the <get-config> operation to retrieve configuration data
rpc/get-config
read
Perform the <get-bulk-config> operation to retrieve configuration data
rpc/get-bulk-config
read
Perform the <get-schema> operation to retrieve YANG file information
rpc/get-schema
read
Perform the <edit-config> operation to edit the configuration for a module
rpc/edit-config
write
Perform an <action> operation to execute a non-configuration instruction
rpc/action
execute
Save the configuration
rpc/save
write
Roll back the configuration
rpc/rollback
write
Load the configuration
rpc/load
write
Execute CLI commands
rpc/CLI
write
Retrieve session information
rpc/get-sessions
read
Force termination of a session other than the current one
rpc/kill-session
execute
Validate the NETCONF message
rpc/validate
read
Create a rollback point
rpc/save-point
write
Commit the configuration in the candidate configuration datastore to the running configuration datastore
rpc/commit
execute
Cancel the committed configuration
rpc/cancel-commit
execute
Copy a configuration datastore
rpc/copy-config
execute
Delete a configuration datastore
rpc/delete-config
execute
Revert the candidate configuration to the current running configuration
rpc/discard-changes
execute
Enable preprovisioning
rpc/config-provisioned
execute
Quit XML view
N/A
Execute access to the xml command.
Unsubscribe from events
rpc/cancel-subscription
execute
2.     Create a user role and enter its user role view.
role name role-name
3.     Configure user role rules:
¡     Enable access to specified <rpc> elements in XML.
rule number permit { execute | read | write } * xml-element rpc/
To view the list of supported RPC operations, execute the rule number permit { execute | read | write } * xml-element rpc/? command. If you do not specify an operation, the rule permits all RPC operations.
¡     Configure access to a module or table in XML elements.
rule number { deny | permit } { execute | read | write } * xml-element [ module-xpath ]
To view the list of modules, execute the rule number { deny | permit } { execute | read | write } * xml-element ? command. To view the list of tables in a module, execute the rule number { deny | permit } { execute | read | write } * xml-element module-name/? command. If you do not specify a module or table, the rule applies to all modules or tables in a module, respectively.
In the user account for a NETCONF client, configure the following settings:
·     Enable network services for the user account depending on the NETCONF access method.
¡     To run NETCONF over SSH, enable SSH service.
¡     To run NETCONF over SOAP over HTTP, enable HTTP service.
¡     To run NETCONF over SOAP over HTTPS, enable HTTPS service.
·     Assign the user role or user roles to the NETCONF client.
The following information uses local authentication for example to describe the configuration procedure. For information about the configuration procedure for remote authentication, see AAA configuration in the set of configuration guides for the software release running on the device.
2.     Create a local device management user account and enter its view.
local-user user-name class manage
3.     Set a password for the user.
In non-FIPS mode:
password [ { hash | simple } string ]
In FIPS mode:
password
In non-FIPS mode, the password setting is optional.
In FIPS mode, you must set a password in interactive mode for a device management user. The device management user must provide the password to pass local authentication.
4.     Assign services to the user. Choose one of the following options depending on the NETCONF session type:
¡     NETCONF over SSH:
service-type ssh
¡     NETCONF over SOAP over HTTP or NETCONF over SOAP over HTTPS:
In non-FIPS mode:
service-type { http | https } *
In FIPS mode:
service-type https
By default, none of the services are available for a local user.
5.     Assign a user role to the user.
authorization-attribute user-role role-name
Configuring SSH service
The following information uses password-based SSH client authentication for example to describe the SSH server configuration procedure. For more information about configuring SSH and publickey authentication, see the security configuration guide for the device.
2.     Create local key pairs.
In non-FIPS mode:
public-key local create { dsa | ecdsa [ secp192r1 | secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
In FIPS mode:
public-key local create { dsa | ecdsa [ secp256r1 | secp384r1 | secp521r1 ] | rsa } [ name key-name ]
3.     (Optional.) Create an SSH user, authorize the user to use NETCONF service, and set the authentication method to password.
ssh user username service-type netconf authentication-type password
4.     Enter VTY line view or class view.
¡     Enter VTY line view.
line vty first-number [ last-number ]
¡     Enter VTY line class view.
line class vty
5.     Enable scheme authentication.
In non-FIPS mode:
authentication-mode scheme
By default, password authentication is enabled for VTY lines.
In FIPS mode:
By default, scheme authentication is enabled for VTY lines.
Configuring NETCONF over SSH service
2.     Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
3.     Specify the listening port for NETCONF over SSH packets.
netconf ssh server port port-number
By default, the listening port for NETCONF over SSH packets is 830.
4.     (Optional.) Enable NETCONF logging.
netconf log source { all | { agent | soap | web } * } { protocol-operation { all | { action | config | get | set | session | syntax | others } * } | row-operation | verbose }
By default, NETCONF logging is disabled.
5.     Establish a NETCONF over SSH session with the device from the configuration tool. For more information about the configuration tool, see its documentation.
This task allows a NETCONF client (the network manager or controller) to establish a NETCONF over SOAP over HTTP/HTTPS session with the device.
This task provides only the basic configuration procedure. For information about advanced features such as marking the DSCP value of SOAP packets, controlling NETCONF access, and configuring a NETCONF user authentication domain, see the NETCONF configuration guide and command reference for the device.
Enabling NETCONF over SOAP service
2.     Enable NETCONF over SOAP.
In non-FIPS mode:
netconf soap { http | https } enable
In FIPS mode:
netconf soap https enable
By default, NETCONF over SOAP is disabled.
3.     (Optional.) Enable NETCONF logging.
4.     Establish a NETCONF over SOAP session with the device from the configuration tool. For more information about the configuration tool, see its documentation.
Comware NETCONF API references describe all capabilities available in Comware. Some of the capabilities might be unavailable for some devices. As a best practice, use the XSD schema files for the managed device to identify its support for capabilities.
Types of NETCONF API references
Every NETCONF-capable feature has a set of API references, one for each of the following namespaces:
·     Data namespace—Contains read-only operational state and configuration data and supports <get> and <get-bulk> operations.
·     Config namespace—Contains configuration data that is read and write accessible. A NETCONF client can perform operations such as <get-config>, <get-bulk-config> and <edit-config> to retrieve or edit this data.
·     Action namespace—Contains data that support execute access. A NETCONF client can use the <action> element to perform non-configuration operations such as ping and reset on this data.
·     Event namespace—Contains system event data to which a NETCONF client can subscribe by performing a <create-subscription> operation.
Every NETCONF-capable feature has a set of NETCONF API references to describe their capabilities in the data, config, action, and event namespaces. These API references use the following file naming conventions:
·     API namespace: Comware Module_name NETCONF XML API Data Reference
·     Config namespace: Comware Module_name NETCONF XML API Configuration Reference
·     Action namespace: Comware Module_name NETCONF XML API Action Reference
·     Event namespace: Comware Module_name NETCONF XML API Event Reference
A NETCONF module might also have an error message reference to describe the error messages that a NETCONF client might encounter when it performs NETCONF operations.
Organization of a NETCONF API reference
Every NETCONF API reference describes the objects in the tables for a feature (for example, APR or DHCP) in a namespace. A table contains rows and columns.
·     Each row represents one instance of an object.
·     Each column contains a parameter for the instance.
For example, each row in the ARP table is an ARP entry. Each ARP entry contains several parameters, including the IP address, MAC address, and VLAN.
In a NETCONF API reference, information for a table contains the following parts:
·     Table name—Presented in the table-path/table-name format, for example, ACL/Base. The table path starts with the feature module name.
·     XML structure—The XML structure for the table, starting from the module name element. In the API references, values in the XML structure are omitted. The following example shows the XML structure for a request:
·     Table description—Provides information about the feature module name, table name, table type, row name, and constraints. The table type indicates whether the table is a multi-instance table or a single-instance table.
¡     Multi-instance table—Contains one or more rows.
¡     Single-instance table—Contains only one row.
·     Columns—Provides information about each column in the table, including their column name, column description, column type, data type, and constraints (or restrictions). The column type indicates whether the column is an index column.
¡     Index—The column is an index column for the table.
¡     N/A—The column is not an index column.
·     XML structure for the response—This structure starts with the feature module name element. In the API references, values in the XML structure for the response are omitted. The NETCONF client uses the response to identify the operation result. This structure is available only for tables in the action namespace that are designed to return operation results. The following example shows the XML structure for a response:
·     Columns in the response—Describes the columns in a response.
NETCONF API references describe the syntax of the H3C-defined sections in the messages for feature modules. For more information about NETCONF message formats, see "NETCONF message formats." To construct a request message, identify the API reference that contains the applicable XML structure based on the operation type and feature module, as shown in Table 8.
Table 8 Matrix of operations and API references
Operations
Applicable API references
<get>
<get-bulk>
For example, use Comware Ifmgr NETCONF XML API Data Reference when you construct NETCONF request messages for retrieving interface management data.
<get-config>
<get-bulk-config>
<edit-config>
For example, use Comware Ifmgr NETCONF XML API Configuration Reference when you construct NETCONF request messages for retrieving or editing interface settings.
<action>
For example, use Comware Ifmgr NETCONF XML API Action Reference when you construct NETCONF request messages to perform non-configuration operations.
For example, use Comware Ifmgr NETCONF XML API Event Reference when you construct NETCONF request messages to subscribe to interface management events.
After you obtain the applicable NETCONF API reference, verify that the capability of interest is available on the target device. If the capability is available, construct messages as needed. The following information describes the generic procedure to construct a NETCONF request message in XML format:
1.     Construct the protocol-defined section, the part outside the <top> and </top> tag pair.
The following example shows the generic RPC message format for the <get> operation, with the protocol-defined section highlighted:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get>
    <filter>
        XML structure (module, submodule, table, and columns)
      </top>
    </filter>
  </get>
</rpc>
For information about the protocol-defined sections for all operations, see "Executing Comware NETCONF requests."
2.     Construct the <top> element.
The <top> element contains the xmlns attribute to specify an H3C proprietary namespace. For example, the <top xmlns="http://www.h3c.com/netconf/data:1.0"> tag specifies the H3C data namespace at http://www.h3c.com/netconf/data:1.0. To specify the config or action namespace, replace data:1.0 with config:1.0 or action:1.0, respectively.
3.     Construct the operation section.
Copy the applicable XML structure from the NETCONF API reference, and paste the XML structure in the <top> element. Then, delete unused columns and enter values in the remaining columns as required.
H3C releases XSD schema files along with software version releases. You can use XSD schema files to construct NETCONF requests in the same way as you do with NETCONF API references.
In compliance with NETCONF standards, Comware supports the <get-schema> and <netconf-state> operations for a NETCONF client to retrieve the content of a YANG module file and obtain the list of YANG module files on the target device, respectively. For more information about these operations, see "get-schema" and "netconf-state."
You can use YANG module files to construct NETCONF requests in the same way as you do with NETCONF API references.
Select an access method depending on the configuration method, as shown in Table 9.
Table 9 Configuration methods and NETCONF access methods matrix
Login method
CLI in XML view
Telnet
NETCONF over Telnet
Console port
SSH
NETCONF over SSH
SSH
NETCONF over SSH
HTTP or HTTPS
Before the NETCONF client can establish a NETCONF session with the target device, you must configure the target device with settings for NETCONF session establishment.
To establish a NETCONF over SOAP over HTTP (or HTTPS) session with the target device, configure the client to send SOAP-encapsulated request messages over HTTP or HTTPS to the URL in http://deviceIP:[portNum]/soap/netconf/ or https://deviceIP:portNum/soap/netconf/ format.
·     The deviceIP argument represents the IP address of the target device.
·     The portNum argument represents the service port for NETCONF over SOAP over HTTP (or HTTPS). The service port number must be the one configured on the target device. By default, the service port is 80 and 832 for NETCONF over SOAP over HTTP and NETCONF over SOAP over HTTPS, respectively.
For example, the device IP address is 192.168.1.1 and the default service ports are used. The NETCONF client must send requests to either of the following URLs:
·     In HTTP:
http://192.168.1.1/soap/netconf/
·     In HTTPS:
https://192.168.1.1:832/soap/netconf/
IMPORTANT
IMPORTANT:
·     Whe you specify the HTTP or HTTPS URL, you must retain the ending forward slash (/).
·     The service ports for NETCONF over SOAP over HTTP and NETCONF over SOAP over HTTPS are configurable. Make sure the NETCONF client sends the requests to the correct service port.
SOAP-encapsulated message format
As shown in Figure 2, a NETCONF over SOAP message format contains the following layers:
·     Outer layer—HTTP header.
·     Middle layer—HTTP content wrapped in a SOAP envelope.
·     SOAP inner layer (body)—NETCONF RPC message.
Figure 2 NETCONF over SOAP over HTTP (or HTTPS) message format
Delivering the username and password for NETCONF access
As shown in Figure 2, enclose the username and password for authentication in the \Envelope\Header\Authentication\UserName and \Envelope\Header\Authentication\Password elements, respectively.
The Authentication element must comply with the following rules:
·     Its xmlns attribute must be set to http://www.h3c.com/netconf/base:1.0.
·     It must contain the mustUnderstand attribute in the http://www.w3.org/2003/05/soap-envelope namespace, and the attribute value must be set to 1 or true.
Obtaining the authentication token returned for a login success
If the NETCONF client successfully connects to the device, the device returns an authentication token in the \Envelope\Header\Authentication\AuthInfo element, as shown in Figure 3. The client must retain this token and include it in the subsequent requests.
Figure 3 Obtaining the authentication token returned for a login success
Sending requests with the authentication token after a successful login
After the NETCONF client receives an authentication token in a hello message from the device, the client must send every subsequent request with the token included in the \Envelope\Header\Authentication\AuthInfo element.
Figure 4 Sending requests with an authentication token after a successful login
Changing the language preference for error messages
Comware NETCONF server can return error messages in Chinese (zh-cn) or English (en). The NETCONF client can specify the expected language when it sends a request message. As shown in Figure 4, set the language preference in the \Envelope\Header\Authentication\Language element. Options are zh-cn for Chinese, and en for English. If the request does not specify the language preference, English applies by default.
IMPORTANT
IMPORTANT:
You must put the Language element behind the AuthInfo element.
Not all NETCONF response messages support error messages in Chinese. If an error message is not available in Chinese, the device sets the xml:lang attribute to "en".
Figure 5 Actual language used in a sample response message
Differences of NETCONF over SOAP requests with other types of NETCONF requests
NETCONF over SOAP has the following characteristics:
·     Authentication starts along with the first hello message.
·     The connection is not persistent across requests. The client closes the connection established for a request when it receives a response from the server. Consequently, NETCONF over SOAP does not support event subscription.
·     All requests and normal responses are encoded in a SOAP envelope, with the RPC request in the SOAP body.
·     NETCONF over SOAP supports multithreading for concurrent requests. A NETCONF over SOAP session supports a maximum of four concurrent requests. If the server receives a request after this limit has been reached, the server rejects the request and returns a resource inadequate error message.
A NETCONF client can establish a NETCONF over SSH session to operate and configure the target device after you configure the device with settings for NETCONF over SSH access. The access process complies with RFC 4742.
Typically, the client must provide the server’s IP address, the username and password for SSH access, the subsystem to access, and the service port.
The device might send banner, greeting, and legal statement information to the NETCONF client before this information is sent over the NETCONF over SSH session. The NETCONF client should ignore this information.
After the NETCONF client accesses the CLI of the target device through a Telnet, SSH, or console session, execute the xml command to enter XML view.  In XML view, copy and paste NETCONF messages to operate and configure the device.
The NETCONF client can determine that a NETCONF over Telnet, SSH, or console session is established when it receives a hello message in the following format from the device:
<?xml version=”1.0” encoding=”UTF-8”?><hello xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0”><capabilities><capability>urn:ietf:params:netconf:base:1.0</capability><capability>urn:ietf:params:netconf:capability:writable-running:1.0</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.0</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:h3c:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>
The NETCONF client can determine that a NETCONF over SOAP over HTTP or HTTPS session is established when it receives a hello message in the following format from the device:
<env:Envelope xmlns:env=”http://www.w3.org/2003/05/soap-envelope”>
  <env:Header>
      <auth:AuthInfo>1001e17d1916e60ef0068f3c6387d4410a1b</auth:AuthInfo>
  </env:Header>
  <env:Body>
      <capabilities>
      </capabilities>
    </hello>
  </env:Body>
</env:Envelope>
The device and the NETCONF client exchange their capability sets in a hello message immediately after they are connected. Only after the capability set exchange is complete will they continue with subsequent operations.
Capability set exchange message from the device to the client
The device notifies a NETCONF client of its NETCONF capabilities in a hello message in the following format:
<?xml version=”1.0” encoding=”UTF-8”?><hello xmlns=”urn:ietf:params:xml:ns:netconf:base:1.0”><capabilities><capability>urn:ietf:params:netconf:base:1.0</capability><capability>urn:ietf:params:netconf:writable-running</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.0</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:h3c:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>
Where:
·     The <capabilities> element contains the capabilities supported by the device. The supported capabilities vary by device model.
·     The <session-id> element contains a session ID that uniquely identifies the current NETCONF session.
Capability set exchange message from the client to the device
In response to the capability set hello message from the device, the NETCONF client must send a hello message to notify the device of its supported capability sets.
The NETCONF client must send the hello message for capability negotiation in the following format:
  <capabilities>
    <capability>
      capability-set
    </capability>
  </capabilities>
</hello>
Enclose a capability set in a <capability> element. Client-side capability sets depend on the client model. If the client supports multiple capability sets, enclose each of them in one pair of <capability> and </capability> element tags.
Tuning the client-side NETCONF access protocol settings
If NETCONF over SSH is used when both the server and client support Base 1.1 capabilities, the server and client must use the NETCONF over SSH access method specified in Base 1.1 for communication. The NETCONF client must examine the capabilities received from the server and make sure it runs the same transport protocol settings as the server.
Sending a close-session message from the client to the device
A NETCONF client sends a message in the following format to terminate the current session:
  <close-session/>
</rpc>
If you are in XML view, you must return to user view before you can execute commands in CLI to configure the device. To return from XML view to user view, copy and paste this message to the client.
Verifying the result
If the device closes the session, the client should receive the following message from the device:
<?xml version=”1.0” encoding=”UTF-8” ?>
  <ok/>
</rpc-reply>
Before you integrate an XML request file into a NETCONF client, use a test tool (for example, SoapUI Open Source) to validate the XML request file. Alternatively, access the CLI of the target device and then copy and paste the request file in XML view for validation.
When you validate NETCONF XML request files from the CLI, use the following guidelines:
·     Run NETCONF over Telnet or SSH instead of console as long as possible. The console port has rate limiting, and the device does not generate prompts or warning in XML view. Validation of NETCONF requests over console is error prone.
·     To avoid typing errors, copy and paste the XML file.
·     For the device to correctly identify a NETCONF request, you must add the ]]>]]> end delimiter string to the end of its XML file in XML view.
Figure 6 shows a sample request message and its response on SoapUI Open Source.
Figure 6 Sample NETCONF XML request and response on SoapUI Open Source
After you verify that an XML request file is correct, integrate that file into the NETCONF client. If the client is an unattended program, design mechanisms to handle anomalies such as timeout and loss of connectivity so the program can operate correctly unattended for a long time.
Best practices
Fault tolerance
Client developers must provide mechanisms for recovery from response exceptions in situations such as loss of connectivity, malformed XML responses, and server unresponsiveness.
It might be difficult or inefficient to retrieve all data from an oversized table in one request. As a best practice to retrieve all data from an oversized table, perform multiple <get-bulk> operations with the count attribute.
The count attribute specifies the number of data entries to retrieve. After the first <get-bulk> operation retrieves the specified number of entries, the client sends the second <get-bulk> operation request to retrieve the specified number of data entries next to the last entry in the previous <get-bulk> operation. The last entry in the previous <get-bulk> operation is identified by its index. This process continues until the client retrieves all data from the table.
When you design the massive data retrieval mechanism, set the TCP session timeout timer to a value that is high enough to prevent TCP session timeout from causing undesired NETCONF session disconnection. As a best practice, test and tune the setting before you deploy the NETCONF client in the production environment.
Session concurrency
Comware supports concurrent requests over multiple sessions. To make sure the device is configured as expected, lock the running configuration datastore before issuing an <edit-config> operation request.
The following issues might occur if you do not lock the datastore:
·     The system might not operate with the expected configuration if concurrent <edit-config> operations have been performed.
·     An <edit-config> operation with the error-option element set to rollback-on-error might roll back the settings made by other users. For more information about rollback-on-error, see Table 20.
After a configuration datastore is locked by a NETCONF client, only that client can change the configuration in that datastore. None of other users can configure the device through NETCONF, CLI or SNMP.
You do not necessarily get linear growth in overall request processing performance as the number of concurrent <get> or <edit-config> operations increases. This is because the response time for individual requests gradually grows as the number of requests increases to consume more resources.
For more information about the <lock> operation, see "lock."
As a best practice, send a <close-session> request to close a NETCONF over SOAP over HTTP or HTTPS session when it becomes idle.
The client might be unable to receive a response to a <close-session> request.
As a best practice, do not receive debugging log messages through NETCONF.
The device might generate a large number of log messages when a debugging switch is turned on. Receiving debugging log messages through NETCONF might cause slow responses to NETCONF requests.
SOAP can run over both HTTP and HTTPS. Use either protocol for one session, not both. For example, do not configure the client to log in to the device through HTTP and then send subsequent requests with the returned authentication token (in the AuthInfo element) over HTTPS.
FAQ
This issue might occur because the entered XML script is incomplete.
To resolve this issue:
1.     Manually enter the ]]>]]> string.
If the NETCONF server is operating correctly, it typically responds with an XML input error message.
2.     Verify that the XML file correct, and then copy and paste the script in the file to the CLI in XML view.
As a best practice to avoid mistyping, do not enter the script manually.
To avoid this issue, use the following guidelines:
·     Run NETCONF over Telnet or SSH to access the CLI. Console ports are slow in data transmission. Loss of characters and response issues might occur on a NETCONF over console session, even if the request script is copied and pasted. If you need to manually enter XML-encoded commands at the CLI over a console session, make sure you are familiar with Comware.
·     After you enter XML-encoded commands at the CLI, enter the ]]>]]> end delimiter string, copy and paste a <close-session> message, and wait for the system to quit XML view. For more information about the <close-session> message, see "Disconnecting a NETCONFsession."
This issue occurs if the client has failed to receive a response to a request in SOAP before the response timeout timer expires. This issue typically occurs when the client attempts to retrieve massive data. When a response timeout occurs, the client automatically returns a failure.
To avoid undesired response timeout, use the following guidelines:
·     Tune the response timeout timer for the socket to an appropriate value on the client.
·     Avoid retrieving all data from the device as long as possible. Use filters in requests to retrieve only data of interest. For more information about data filtering, see "Comware NETCONF data filtering."
Table 10 and Table 11 list the commands that you can use when you test NETCONF functionality and connectivity.
Table 10 SOAP related commands
Purposes
display tcp
This command displays TCP connections.
Use this command to verify that a TCP connection can be set up correctly for NETCONF over SOAP over HTTP (or HTTPS) service at the specified service port.
Table 11 NETCONF over SSH service related commands
Purposes
display tcp
Use this command to verify that a TCP connection can be set up correctly for NETCONF over SSH service at the specified service port.
display ssh server session
This command displays active SSH sessions.
Use this command to verify that NETCONF over SSH sessions can be correctly established.
netconf log
This command enable the device to log information about NETCONF requests and request processing results.
Use this command to verify that the NETCONF requests are valid and can be correctly processed.
A NETCONF client starts to establish a NETCONF over SOAP session with the device when it sends the first <hello> message. The NETCONF over SOAP session closes when one of the following events occurs:
·     The NETCONF client sends a <close-session> request to close the session.
·     Another user forces the session to close by sending a <kill-session> request.
·     The idle timeout timer for the session expires.
During the lifetime of a session, one TCP connection is open for every request sent over the session. The NETCONF server closes the TCP connection for a request after it sends a response for that request.
The server sends its first <hello> message with an authentication token in the AuthInfo element. After the client receives this authentication token, the client must send every request with this authentication token set in the AuthInfo element for authentication.
The server maintains a session idle timeout timer for every NETCONF session. If no messages have been sent over a NETCONF session before the timer expires, the session closes automatically.
The NETCONF session idle timeout timer is configurable with the netconf idle-timeout command. By default, the timer is set to 10 minutes.
To maintain a session, configure the NETCONF client to regularly send a <hello> message to the NETCONF server, with the authentication token set in the AuthInfo element. The server will return a <hello> message that is the same as the first <hello> message sent over the session.
A NETCONF client starts to establish a NETCONF over console, Telnet, or SSH session with the device when the underlying connection is established. The session closes when one of the following events occurs:
·     The underlying connection disconnects.
·     The idle timeout timer for the session expires. By default, the session idle timeout timer never expires for NETCONF over SSH, NETCONF over Telnet, and NETCONF over console sessions. These types of sessions persist until they are closed for other reasons. To set the NETCONF session idle timeout timer, use the netconf idle-timeout command.
Comware supports concurrent requests on one NETCONF over SOAP session.
A NETCONF client can use multiple threads to send requests with the same token in the AuthInfo element concurrently over one NETCONF over SOAP session. Despite this, do not design a NETCONF client to send concurrent requests over one NETCONF over SOAP session unless necessary.
Comware does not support concurrent requests on any types of NETCONF sessions other than NETCONF over SOAP.
Comware NETCONF manages access at the protocol, module, and instance levels.
·     Protocol-level permission controls access to RPC operations.
·     Module-level permission controls access to modules and their tables, rows, groups, and columns.
·     Instance-level permission controls access to instances of an object, such as a VPN instance, interface, VLAN, or security zone.
For the device to execute a NETCONF request, make sure the client has sufficient access permissions at the protocol, module, and instance levels.
Look at the following <edit-config> request. For the device to process this request, you must make sure the client has the following access permissions:
·     Protocol level—Write access to the rpc/edit-config/config/top path.
·     Module level—Write access to the Ifmgr/Interfaces/Interface table.
·     Instance level—Write access to the interface with an interface index of 3.
  <edit-config>
    <target>
      <running/>
    </target>
    <default-operation> merge</default-operation>
    <test-option>set</test-option>
    <error-option>continue-on-error</error-option>
        <Ifmgr xc:operation=”delete”>
          <Interfaces>
            <Interface>
              <IfIndex>3</IfIndex>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
To assign these access permissions to the NETCONF client, configure the following settings on the device:
role name netconf
 rule 1 permit write xml-element rpc/edit-config/config/top
 rule 2 permit write xml-element ifmgr/interfaces/interface
 interface policy deny
  permit interface GigabitEthernet2/0/1
Configuration lock
Comware NETCONF implements the configuration lock mechanism in compliant with RFC 4741. If a configuration datastore is locked, only the client that holds the lock can change the configuration in the datastore. Other NETCONF clients, non-NETCONF clients, and CLI users will be unable to change the configuration until after the lock is released or the NETCONF session closes.
The maximum number of sessions supported for a type of NETCONF session (NETCONF over console, Telnet, SSH, SOAP over HTTP, or SOAP over HTTPS) depends on the session limit configured with the AAA module.
Table 12 lists the NETCONF operations available with Comware.
Table 12 NETCONF operations available with Comware
Category
Operation
Purpose
Data retrieval
get
Retrieves configuration and state data.
get-bulk
Retrieves the specified number of data entries.
get-config
Retrieves configuration data.
get-bulk-config
Retrieves the specified number of configuration data entries.
Configuration actions
edit-config
Edits the configuration on the managed device.
Non-configuration actions
action
Executes a non-configuration action, for example, an action to clear or retrieve operational statistics.
Event operations
get/filter/netconf
create-subscription
cancel-subscription
Session management
close-session
kill-session
Forces another NETCONF session to close.
get-sessions
Retrieves information about established sessions.
lock
unlock
Unlocks a configuration datastore.
Executes a non-interactive CLI commands.
CLI
Configuration management
rollback
Rolls back the configuration.
save
Saves the configuration.
load
Loads the configuration.
save-point
Performs configuration rollback related operations, including creation of rollback points.
Request validation
validate
Examines a NETCONF request for XML syntax errors.
YANG module operations
get/filter/netconf-state/capabilities
Retrieves the capability sets of the device.
get/filter/netconf-state/datastores
Retrieves the configuration datastores on the device.
get/filter/netconf-state/schemas
Retrieves the list of YANG module file names on the device.
get/filter/netconf-state/sessions
Retrieves information about sessions on the device.
get/filter/netconf-state/statistics
Retrieves NETCONF statistics.
get-schema
Retrieves the contents of a YANG module file.
Configuration datastore operations
commit
Commits the configuration from the candidate configuration datastore to the running configuration datastore.
cancel-commit
Cancels the committed configuration.
discard-changes
Reverts the candidate configuration to the current running configuration.
copy-config
Copies the configuration in the source configuration datastore to the target configuration datastore.
delete-config
Deletes a configuration datastore, which can only be the candidate configuration datastore.
Preprovisioning
config-provisioned
Enables preprovisioning.
To prevent misconfiguration from causing undesirable issues, use the candidate configuration datastore to store or edit configuration data to be applied without impacting the running configuration. The candidate configuration applies to the device only after you perform a <commit> operation to commit the candidate configuration to the running configuration datastore. The system creates a configuration rollback point for every successful commit operation.
Standard NETCONF operations
The following information describes the most commonly used standard operations defined in NETCONF protocols.
Standard base operations include the <get>, <get-config>, and <edit-config> operations.
·     To retrieve state and configuration data from the target device, perform the <get> operation.
·     To retrieve only configuration data, perform the <get-config> operation.
·     To edit the configuration, perform the <edit-config> operation.
For more information about configuring and managing a module through NETCONF, see the NETCONF XML API references for that module.
get-config
The <get-config> operation retrieves only non-default configuration data, regardless of whether the data is configured from the CLI or Web interface or through MIB operations. To retrieve only configuration data of interest, use a <filter> subelement in the <get-config> operation element to filter data.
Request format
The following is the XML format for the <get-config> request:
<?xml version="1.0"?>
  <get-config>
    <source>
      <datastore/>
    </source>
    <filter>
      <top xmlns="http://www.h3c.com/netconf/config:1.0">
      </top>
    </filter>
  </get-config>
</rpc>
The value for datastore can be one of the following:
Value
running
Specifies the running configuration datastore.
candidate
Specifies the candidate configuration datastore.
Verification
The request is successful if the client receives a response that contains the requested configuration data. The following is the response format:
<rpc-reply message-id="100"   xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <data>
    Data matching the filter
  </data>
</rpc-reply>
edit-config
About the <edit-config> operation
By default, the device rejects an <edit-config> request while it is rolling back the configuration. To have the device accept an <edit-config> request while it is rolling back the configuration, use the <action> operation. For more information about this operation, see "action."
The standard <edit-config> operation supports the merge, create, replace, remove, delete, default-operation, error-option, and test-option options. For more information about these options, see Table 20.
If a data table has substructures, the system processes all substructures as one column.
Request format
  <edit-config>
    <target>
      <datastore/>
    </target>
    <error-option>
      Action to take when error occurs during the operation
    </error-option>
    <config>
      </top>
    </config>
  </edit-config>
</rpc>
Value
running
candidate
Verification
If the <edit-config> operation succeeds, the device returns the following response:
<?xml version="1.0">
  <ok/>
</rpc-reply>
To verify that the running configuration on the server has been changed as expected, perform a <get> operation.
Example: Retrieving all configuration data for all modules
Retrieve all configuration data for all modules.
# Enter XML view.
<Sysname> xml
# Exchange capability sets. Copy and paste the following request message to the client:
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve all configuration data for all modules. Copy and paste the following request message to the client:
  <get-config>
    <source>
      <running/>
    </source>
  </get-config>
</rpc>
Verification
If the requested operation succeeds, the server responds with the configuration for all modules. The following is a sample response:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <IfIndex>1307</IfIndex>
            <Shutdown>1</Shutdown>
          </Interface>
          <Interface>
            <IfIndex>1308</IfIndex>
          </Interface>
          <Interface>
            <IfIndex>1309</IfIndex>
          </Interface>
          <Interface>
            <IfIndex>1311</IfIndex>
            <VlanType>2</VlanType>
          </Interface>
          <Interface>
            <IfIndex>1313</IfIndex>
          </Interface>
        </Interfaces>
      </Ifmgr>
      <Syslog>
        <LogBuffer>
          <BufferSize>120</BufferSize>
        </LogBuffer>
      </Syslog>
      <System>
        <Device>
          <SysName>H3C</SysName>
          <TimeZone>
            <Zone>+11:44</Zone>
            <ZoneName>beijing</ZoneName>
          </TimeZone>
        </Device>
      </System>
      <Fundamentals>
        <WebUI>
          <SessionAgingTime>98</SessionAgingTime>
        </WebUI>
      </Fundamentals>
    </top>
  </data>
</rpc-reply>
Example: Retrieving all configuration data for the Syslog module
Retrieve all configuration data for the Syslog module.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve all configuration data for the Syslog module. Copy and paste the following request message to the client:
  <get-config>
    <source>
      <running/>
    </source>
        <Syslog/>
      </top>
    </filter>
  </get-config>
</rpc>
Verification
If the requested operation succeeds, the server responds with the configuration for the Syslog module. The following is a sample response:
<?xml version="1.0" encoding="UTF-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
  <data>
      <Syslog>
        <LogBuffer>
        </LogBuffer>
      </Syslog>
    </top>
  </data>
</rpc-reply>
Example: Retrieving one data entry from the interface table
Retrieve one data entry from the interface table.
# Enter XML view.
<Sysname> xml
  <capabilities>
  </capabilities>
</hello>
# Retrieve one data entry from the interface table. Copy and paste the following request message to the client:
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:web="http://www.h3c.com/netconf/base:1.0">
        <Ifmgr>
          <Interfaces web:count="1">
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
Verification
If the requested operation succeeds, the server responds with the specified data entry from the interface table. The following is a sample response:
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <Name>GigabitEthernet1/0/2</Name>
            <AbbreviatedName>GE1/0/2</AbbreviatedName>
            <PortIndex>3</PortIndex>
            <ifTypeExt>22</ifTypeExt>
            <ifType>6</ifType>
            <Description>GigabitEthernet 1/0/2 Interface</Description>
            <AdminStatus>2</AdminStatus>
            <OperStatus>2</OperStatus>
            <ConfigSpeed>0</ConfigSpeed>
            <ActualSpeed>100000</ActualSpeed>
            <ConfigDuplex>3</ConfigDuplex>
            <ActualDuplex>1</ActualDuplex>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
Example: Edit the setting for a parameter
Configure the Syslog module (for the information center) to set the size of the general log buffer to 512. This setting enables the log buffer to store a maximum of 512 log entries.
# Enter XML view.
<Sysname> xml
  <capabilities>
  </capabilities>
</hello>
# Set the BufferSize column in the LogBuffer table of the Syslog module to 512. Copy and paste the following request message to the client:
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
      <top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
        <Syslog>
          <LogBuffer>
            <BufferSize>512</BufferSize>
          </LogBuffer>
        </Syslog>
      </top>
    </config>
  </edit-config>
</rpc>
Verification
If the requested operation succeeds, the device returns an operation succeeded response. The following is a sample response:
<?xml version="1.0" encoding="UTF-8" ?>
  <ok/>
</rpc-reply>
lock
The device supports a maximum of 32 concurrent NETCONF sessions for device management. In addition to NETCONF, users can configure and manage the device by using methods such as CLI and SNMP.
Before you configure, manage, or troubleshoot the device over a NETCONF session, you can lock the configuration to prevent other users from changing the device configuration.
After you lock the configuration, only you can perform <edit-config> operations to change or unlock the configuration as the lock holder. Other users can only read the configuration, and they will be unable to change or lock the configuration until after the configuration is unlocked.
 The system unlocks the configuration when the lock holder releases the lock or when its NETCONF session closes.
Request format
At the time of this writing, Comware NETCONF supports the <lock> operation only on the running configuration datastore. You cannot lock the configuration on a per-module basis.
  <rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
    <lock>
      <target>
        <datastore/>
      </target>
    </lock>
  </rpc>
Value
running
candidate
Verification
If the <lock> operation succeeds, the device returns the following response:
<rpc-reply message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <ok/>
</rpc-reply>
Example: Locking the running configuration datastore
Lock the running configuration datastore to prevent other users from changing the running configuration.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Lock the running configuration datastore. Copy and paste the following request message to the client:
    <lock>
      <target>
        <running/>
      </target>
    </lock>
  </rpc>
Verification
  <ok/>
</rpc-reply>
If the server receives a <lock> request from another NETCONF client after the running configuration datastore is locked, the device returns the following lock failed response:
<rpc-error>
  <error-type>protocol</error-type>
  <error-tag>lock-denied</error-tag>
  <error-severity>error</error-severity>
  <error-message xml:lang="en">Lock failed, lock is already held.</error-message>
  <error-info>
  </error-info>
  </rpc-error>
</rpc-reply>
The message shows that the lock operation failed because the client with a session-id of 1 held the lock.
unlock
Only the NETCONF client that holds the configuration lock can perform the <unlock> operation to release the lock.
Request format
Copy and paste the following unlock request message to the client:
    <unlock>
      <target>
        <datastore/>
      </target>
    </unlock>
  </rpc>
Value
running
candidate
Verification
If the <unlock> operation succeeds, the device returns the following response:
  <ok/>
</rpc-reply>
get
The <get> operation retrieves configuration and state date.
This operation retrieves all device configuration and state data that matches the specified filter in one request. As a best practice to retrieve massive data in multiple requests, use the Comware-extended <get-bulk> operation.
The <get-bulk> operation allows you to retrieve a specific number of data entries next to a particular data entry. For more information about using the <get-bulk> operation, see "get-bulk."
Request format
The following is the XML format for the <get> request:
  <get>
    <filter>
      </top>
    </filter>
  </get>
</rpc>
The <filter> element specifies the filtering conditions. For more information about filters and filtering results, see "Comware NETCONF data filtering." The filtering conditions can include the module name, submodule name, table name, and column name.
In a <get> request, you can use the Comware-extended count attribute to specify the number of data entries to retrieve, as shown in the following request message:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get >
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:base="http://www.h3c.com/netconf/base:1.0">
        <Syslog>
          <Logs xc:count="5">
            <Log>
              <Index></Index>
           </Log>
          </Logs>
        </Syslog>
      </top>
    </filter>
  </get >
</rpc>
Use the count attribute in compliance with the following rules:
·     You can use the count attribute only in module and table elements within the <top> element. In this sample request, you can use the count attribute in the <Syslog> module element or in the <Logs> table element. In other types of elements, it cannot be resolved.
·     The table subelements in a module element inherit the count attribute (if any) specified in the module element, if they do not contain the count attribute.
·     If a table contains a subtable, only the count attribute in the table element takes effect. If you specify the count attribute in a subtable element, you must specify the index columns for all its ancestor elements.
·     If you do not specify the count attribute, the operation retrieves all data entries, starting from the specified index.
Verification
If the requested operation succeeds, the server responds with all matching configuration and state data. The following is the response format:
  <data>
    All matching configuration and state data
  </data>
</rpc-reply>
close-session
The <close-session> operation closes the current session.
Request format
To close the current session, copy and paste the following request message to the client:
  <close-session/>
</rpc>
Verification
If the <close-session> operation succeeds, the device returns the following response:
  <ok/>
</rpc-reply>
kill-session
The <kill-session> operation forces a NETCONF session other than the current session to close. If the client that established the session is at the CLI, this operation places the client in user view.
Request format
To force a session other than the current one to close, copy and paste the following message to the client, and then specify the session ID of that session:
  <kill-session>
    <session-id>
      Specify the session ID of the session to close
    </session-id>
  </kill-session>
</rpc>
Verification
If the <kill-session> operation succeeds, the device returns the following response:
  <ok/>
</rpc-reply>
Example: Forcing a session to close
The target device has two NETCONF sessions, one with session ID 1 and the other with session ID 2. Force NETCONF session 2 to close from the NETCONF client connected to session 1.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Force NETCONF session 2 to close. Copy and paste the following request message to the client:
  <kill-session>
    <session-id>2</session-id>
  </kill-session>
</rpc>
Verification
If the server forces NETCONF session 2 to close successful, the device returns the following response. The NETCONF client connected to session 2 returns from XML view to user view.
  <ok/>
</rpc-reply>
create-subscription
A NETCONF client can subscribe to Syslog events, events monitored by NETCONF, and events reported by modules. The device will then push subscribed events to the subscribers as configured. Event subscription is available only for NETCONF over Telnet and NETCONF over SSH.
Subscribing to Syslog events
The Syslog events available for subscription are system log messages. If a NETCONF client has subscribed to a system log message, the server pushes the log message to the client when it occurs. The event notification includes the mnemonic symbol of the log message, its source module, severity level, time of occurrence, and event description.
For information about the log messages to which you can subscribe, see the system log messages reference for the device.
When you subscribe to Syslog events, use the following guidelines:
·     A subscription takes effect on a session for the lifetime of that session. It is canceled when the session closes.
·     You can subscribe to multiple events by specifying multiple <filter> elements, one for each event.
·     At the time of this writing, Comware does not support event playback.
·     You can unsubscribe from an event. However, you cannot renew or edit a subscription.
The following is the XML format for the Syslog event subscription request:
  <create-subscription  xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
    <stream>NETCONF</stream>
    <filter>
      <event xmlns="http://www.h3c.com/netconf/event:1.0">
        <Code>code</Code>
        <Group>group</Group>
        <Severity>severity</Severity>
      </event>
    </filter>
    <startTime>start-time</startTime>
    <stopTime>stop-time</stopTime>
  </create-subscription>
</rpc>
A Syslog event subscription request contains the following elements:
·     stream: Specifies an event stream. The name for the syslog event stream is NETCONF.
·     event: Specifies an event.
·     code: Specifies the mnemonic symbol of the log message.
·     group: Specifies the module name of the log message.
·     severity: Specifies the severity level of the log message.
·     start-time: Specifies the start date and time of the subscription.
·     stop-time: Specifies the end date and time of the subscription.
If the subscription is successful, the device returns the following response:
<rpc-reply message-id="101" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
  <ok/>
</rpc-reply >
If a subscription error occurs, the device returns an error response, in the following format:
  <rpc-error>
    <error-type>error-type</error-type>
    <error-tag>error-tag</error-tag>
    <error-severity>error-severity</error-severity>
    <error-message xml:lang="en">error-message</error-message>
  </rpc-error>
</rpc-reply>
For more information about the elements in an error response, see RFC 4741.
Subscribing to events monitored by NETCONF
After a NETCONF client subscribes to an event monitored by NETCONF, the server regularly pushes the matching event instances to the NETCONF client.
The following is the XML format for the NETCONF monitored-event subscription request:
  <create-subscription xmlns='urn:ietf:params:xml:ns:netconf:notification:1.0'>
    <stream>NETCONF_MONITOR_EXTENSION</stream>
    <filter>
      <NetconfMonitor xmlns='http://www.h3c.com/netconf/monitor:1.0'>
        <XPath>XPath</XPath>
        <Interval>interval</Interval>
        <ColumnConditions>
          <ColumnCondition>
            <ColumnName>ColumnName</ColumnName>
            <ColumnValue>ColumnValue</ColumnValue>
            <ColumnCondition>ColumnCondition</ColumnCondition>
          </ColumnCondition>
        </ColumnConditions>
        <MustIncludeResultColumns>
          <ColumnName>columnName</ColumnName>
        </MustIncludeResultColumns>
      </NetconfMonitor>
    </filter>
</rpc>
Table 13 Elements in a monitored-event subscription request
Element
stream
Specifies an event stream. The name for the monitored-event stream is NETCONF_MONITOR_EXTENSION.
NetconfMonitor
Specifies information that identifies the event of interest.
XPath
Specifies the XPath of the monitored event in the format of ModuleName[/SubmoduleName]/TableName.
Interval
Specifies the interval for the server to retrieve and push events that match the subscription condition. The value range is 1 to 4294967 seconds. The default value is 300 seconds.
ColumnName
Specifies the name of a column in the monitored table, in [GroupName.]ColumnName format.
ColumnValue
Specifies the column value on which the filter operates.
ColumnCondition
Specifies an operator:
·     more—Greater than the specified value.
·     less—Less than the specified value.
·     notLess—Equal to or greater than the specified value.
·     notMore—Equal to or less than the specified value.
·     equal—Equal to the specified value.
·     notEqual—Greater than or less than the specified value.
·     include—Include the specified value.
·     exclude—Not include the specified value.
·     startWith—Start with the specified value.
·     endWith—End with the specified value.
The operators you can use depend on the data type of the specified value.
start-time
Start date and time of the subscription.
stop-time
End date and time of the subscription.
IMPORTANT
IMPORTANT:
The order of the elements in a NETCONF monitored-event subscription request must be in strict compliance with the XML format provided in this document.
If the subscription succeeds, the device returns a response in the following format:
<rpc-reply message-id="100" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
  <ok/>
</rpc-reply>
Subscribing to events reported by modules
A NETCONF client can subscribe to a module to receive events of interest. On receipt of a subscribed event from the module, the NETCONF server pushes the event to the client.
The following is the XML format for the module-reported event subscription request:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xs="http://www.h3c.com/netconf/base:1.0">
    <stream>XXX_STREAM</stream>
      <event xmlns="http://www.h3c.com/netconf/event:1.0/xxx-features-list-name:1.0">
        <ColumnName xs:condition="Condition">value</ColumnName>
      </event>
    </filter>
</rpc>
Table 14 Elements in requests that subscribe to events reported by modules
Element
stream
Specifies an event stream. Supported module-reported event streams vary by device model.
event
Specifies an event name. An event stream includes multiple events. The events use the same namespace as the event stream.
ColumnName
Specifies the name of a column.
Condition
value
Specifies a column value.
start-time
stop-time
  <ok/>
</rpc-reply>
Example: Subscribing to events
Subscribe to all events without a time limit. The server pushes all events to the client until the NETCONF session closes.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Send the subscription message.
·     Subscribe to Syslog events:
# Subscribe to all Syslog events without a time limit. Copy and paste the following request message to the client:
  <create-subscription xmlns ="urn:ietf:params:xml:ns:netconf:notification:1.0">
</rpc>
If the subscription succeeds, the device returns the following response:
  <ok/>
</rpc-reply>
The following is a sample event notification that the device sent when an airflow issue was detected on fan tray 1:
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
  <eventTime>2011-01-04T12:30:46</eventTime>
    <Group>DEV</Group>
    <Code>FAN_DIRECTION_NOT_PREFERRED</Code>
    <Slot>6</Slot>
    <Severity>Alert</Severity>
    <context>Fan 1 airflow direction is not preferred on slot 6, please check it.</context>
  </event>
</notification>
The following is a sample event notification that the device sent when a user logged in to the device from 192.168.100.130:
  <eventTime>2011-01-04T12:30:52</eventTime>
    <Group>SHELL</Group>
    <Code>SHELL_LOGIN</Code>
    <Slot>6</Slot>
    <Severity>Notification</Severity>
    <context>VTY logged in from 192.168.100.130.</context>
  </event>
</notification>
·     Subscribe to events monitored by NETCONF.
# Subscribe to receive Device/Base table events at 1-second intervals. Copy and paste the following request message to the client:
  <filter>
    <NetconfMonitor xmlns="http://www.h3c.com/netconf/monitor:1.0">
      <XPath>Device/Base</XPath>
      <Interval>1</Interval>
      <ColumnConditions>
        <ColumnCondition>
          <ColumnName>HostName</ColumnName>
          <ColumnValue>H3C</ColumnValue>
          <ColumnCondition>include</ColumnCondition>
        </ColumnCondition>
      </ColumnConditions>
    </NetconfMonitor>
  </filter>
</rpc>
  <ok/>
</rpc-reply>
Then, the device sends Device/Base table events to the client at 1-second intervals. The following is a sample event notification:
  <eventTime>2020-02-22T09:28:14</eventTime>
    <Device xmlns="http://www.h3c.com/netconf/data:1.0">
      <Base>
        <HostName>H3C</HostName>
      </Base>
    </Device>
  </NetconfMonitor>
</notification>
·     Subscribe to events reported by modules.
# Subscribe to all events reported by the Ifmgr module. Copy and paste the following request message to the client:
  <create-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0" xmlns:xs="http://www.h3c.com/netconf/base:1.0">
    <stream>Ifmgr</stream>
</rpc>
  <ok/>
</rpc-reply>
The following is a sample notification that the device sent when an interface went down:
  <eventTime>2020-02-22T09:32:10</eventTime>
  <InterfaceEvent xmlns="Ifmgr:1.0">
    <Interface>
      <Name>GigabitEthernet2/0/2</Name>
      <Status>IF_DEACTIVE</Status>
      <IfIndex>286</IfIndex>
      <AdminStatus>ADMIN_UP</AdminStatus>
      <OperStatus>OPER_DOWN</OperStatus>
      <Description>The Interface GigabitEthernet2/0/2 occurred IF_DEACTIVE event,the administration status is ADMIN_UP,operation status is OPER_DOWN.</Description>
    </Interface>
  </InterfaceEvent>
</notification>
The following is a sample notification that the device sent when an interface came up:
    <Interface>
      <Status>IF_ACTIVE</Status>
      <Description>The Interface GigabitEthernet2/0/2 occurred IF_ACTIVE event,the administration status is ADMIN_UP,operation status is OPER_DOWN.</Description>
    </Interface>
  </InterfaceEvent>
</notification>
validate
The <validate> operation examines the NETCONF XML request for syntax errors and violation of constraints. The Comware NETCONF server only examines a request for syntax errors and does not check for violation of additional constraints. A request might still fail even if it has been validated to be syntactically correct.
You can send a request without using the <validate> operation for prior validation, because the NETCONF server always examines a request for syntax errors.
get-schema
The <get-schema> operation retrieves the content of a data model file. At the time of this writing, you can only retrieve the content of YANG module files.
Request format
The following is the XML format for the <get-schema> request message:
  <get-schema xmlns='urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring'>
    <identifier>syslog-data</identifier>
    <version>2015-05-07</version>
    <format>yang</format>
  </get-schema>
</rpc>
For information about the <identifier>, <version>, and <format> elements, see "netconf-state."
Verification
If the requested operation succeeds, the device responds with the requested content of the YANG module file. The following is the response format:
  <data>
    Content of the specified YANG module file
  </data>
</rpc-reply>
netconf-state
To retrieve the following types of data, use the following subtrees in a get operation:
·     To retrieve the list of capability sets on the device, use the <netconf-state><capabilities/></netconf-state> subtree.
·     To retrieve the list of NETCONF configuration datastores on the device, use the <netconf-state><datastores/></netconf-state> subtree.
·     To retrieve the list of schema files on the device, use the <netconf-state><schemas/></netconf-state> subtree.
·     To retrieve the list of active NETCONF sessions on the device, use the <netconf-state><sessions/></netconf-state> subtree.
·     To retrieve the global statistics for the NETCONF server, use the <netconf-state><statistics/></netconf-state> subtree.
The following is the XML format for the <get> request message with the <netconf-state> subtree:
  <get>
    <filter type='subtree'>
      <netconf-state xmlns='urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring'>
        <getType/>
      </netconf-state>
    </filter>
  </get>
</rpc>
·     Replace the getType argument with capabilities, datastores, schemas, sessions, or statistics, depending on the data you are retrieving. To retrieve all types of netconf-state data, send the request without the <getType/> element.
·     At the time of this writing, data filtering is not available for netconf-state data retrieval.
Example: Retrieving the NETCONF capability sets on the device
Request format
  <get>
        <capabilities/>
      </netconf-state>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the device responds with its NETCONF capability sets. The following is a sample response:
  <data>
    <netconf-state xmlns="urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring">
      <capabilities>
     </capabilities>
    </netconf-state>
  <data>
</rpc-reply>
The capability set in this sample response is for illustration only.
Example: Retrieving the NETCONF datastores on the device
Request format
  <get>
      <datastores/>
      </netconf-state>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the device responds with the requested NETCONF configuration datastore. The following is a sample response:
  <data>
      <datastores>
        <datastore>
          <name>running</name>
          <locks>
            <global-lock>
            <locked-by-session>1</locked-by-session>
            <locked-time>2015-07-30T12:54:45</locked-time>
            </global-lock>
          </locks>
       </datastore>
      </datastores>
    </netconf-state>
  <data>
</rpc-reply>
At the time of this writing, Comware supports only the running configuration datastore.
The <locks> element indicates whether the NETCONF client holds the lock and provides information about the lock.
Example: Retrieving the list of schema files on the device
Request format
  <get>
        <schemas/>
      </netconf-state>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the server responds with the list of schema files on the device. The following is a sample response:
  <data>
<schemas>
        <schema>
          <namespace>http://www.h3c.com/netconf/data:1.0</namespace>
          <location>NETCONF</location>
        </schema>
      </schemas>
    </netconf-state>
  <data>
</rpc-reply>
·     To retrieve the content of a schema file, use its identifier, version, and format information to construct a <get-schema> request.
·     The value for the <format> element can only be yang (YANG module files).
·     The <namespace> element contains the namespace of the file.
·     The <location> element contains the file storage location. At the time of this writing, the value is fixed at NETCONF. The file is stored on a disk on the device.
Example: Retrieving the list of active NETCONF sessions on the device
Request format
  <get>
        <sessions/>
      </netconf-state>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the server responds with the list of active NETCONF sessions on the device. The following is a sample response:
  <data>
      <sessions>
        <session>
          <transport>netconf-soap-over-http</transport>
          <username>test</username>
          <source-host>192.168.100.68</source-host>
          <login-time>2015-07-30T09:44:03</login-time>
          <in-rpcs>0</in-rpcs>
          <in-bad-rpcs>0</in-bad-rpcs>
          <out-rpc-errors>0</out-rpc-errors>
          <out-notifications>0</out-notifications>
        </session>
      </sessions>
    </netconf-state>
  <data>
</rpc-reply>
The response contains the following information:
Element
session-id
Identifier that uniquely identifies the NETCONF session.
transport
The transport protocol for the session.
username
Username with which the NETCONF client logged in to the device.
source-host
The IP address with which the NETCONF client initiated the session.
login-time
The login date and time.
in-rpcs
Number of valid RPCs received by the device over the session.
in-bad-rpcs
Number of invalid RPCs received by the device over the session.
out-rpc-errors
Number of RPC errors sent by the device over the session.
out-notifications
Number of event notifications sent by the device over the session.
Example: Retrieving NETCONF global statistics
Request format
  <get>
        <statistics/>
      </netconf-state>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the device responds with the NETCONF global statistics on it. The following is a sample response:
  <data>
      <statistics>
        <netconf-start-time>2015-07-30T09:44:01</netconf-start-time>
        <in-bad-hellos>0</in-bad-hellos>
        <in-sessions>2</in-sessions>
        <dropped-sessions>0</dropped-sessions>
        <in-rpcs>1</in-rpcs>
      </statistics>
    </netconf-state>
  <data>
</rpc-reply>
Element
netconf-start-time
Date and time when the NETCONF service started.
in-bad-hellos
Number of invalid <hello> messages received by the device.
in-sessions
Number of sessions established.
dropped-sessions
Number of NETCONF sessions dropped because of session timeout.
in-rpcs
Number of valid RPC requests received by the device.
in-bad-rpcs
Number of invalid RPC requests received by the device.
out-rpc-errors
Number of RPC errors sent by the device.
out-notifications
Number of event notifications sent by the device.
commit (immediate commit)
The immediate <commit> operation commits the candidate configuration to the running configuration datastore immediately.
Request format
The following is the XML format for the immediate <commit> request:
  <commit/>
</rpc>
Verification
If the requested operation succeeds, the device returns the following response:
  <ok/>
</rpc-reply>
commit (confirmed commit)
The confirmed <commit> operation requires a confirming <commit> operation to be performed within the confirmation timeout period to commit the candidate configuration to the running configuration datastore. If you fail to do a confirming <commit> within the timeout period, the device automatically rolls back the running configuration to the previously committed configuration.
When you perform a confirmed <commit> operation, you must specify the <confirmed> node and can optionally specify the following columns:
·     <confirm-timeout>—Sets the confirmation timeout timer, in seconds. The default is 600 seconds.
·     <persist>—Specifies an identifier to identify the target candidate configuration to be committed. This element ensures that a follow-up commit or other operations can be performed on the target candidate configuration on any sessions after the NETCONF session terminates. If you do not include the <persist> element in this commit operation, you can perform a follow-up commit operation or other operations on the specified candidate configuration only on the same session that issued the confirmed <commit> operation.
Request format
The following sample request shows the XML format for the confirmed <commit> request. This sample request sets the confirmation timeout timer to 600 seconds and sets the candidate configuration identifier to test.
  <commit>
    <confirmed/>
    <confirm-timeout>600</confirm-timeout>
    <persist>test</persist>
  </commit>
</rpc>
Verification
  <ok/>
</rpc-reply>
commit (confirming commit)
The confirming <commit> operation commits the candidate configuration issued by a confirmed <commit> operation to the running configuration.
When you use this operation, follow these guidelines:
·     The confirming <commit> operation takes effect only if you execute it before the confirmation timeout timer sets in the confirmed <commit> operation expires.
·     If the <persist> element is included in the confirmed <commit> operation, you must also include the <persist-id> element in the confirming <commit> operation. Make sure the value for the <persist-id> element is the same as that specified in the <persist> element set in the confirmed <commit> operation.
·     If the <persist> element is not included in the confirmed operation, the confirming <commit> operation uses the same XML structure as the immediate <commit> operation.
Request format
The following sample request shows the XML format for the confirming <commit> request with the <persist-id> element included. In this example, the candidate configuration identifier is test.
  <commit>
    <persist-id>test</persist-id>
  </commit>
</rpc>
Verification
  <ok/>
</rpc-reply>
cancel-commit
The <cancel-commit> operation cancels an ongoing confirmed <commit> operation and rolls back the running configuration to the state before the confirmed <commit> operation was performed.
Perform this task before the confirmation timeout timer expires.
Request format
The following is the XML format for the <cancel-commit> operation that cancels the confirmed <commit> operation on the same session that issued the confirmed <commit> operation:
  <cancel-commit/>
</rpc>
Verification
  <ok/>
</rpc-reply>
copy-config
The <copy-config> operation copies the running configuration to a target configuration datastore. If the target configuration datastore does not exist, this operation creates the datastore.
At the time of this writing, this operation can only copy the running configuration to the candidate configuration store.
Request format
The following is the XML format for the <copy-config> request to copy the running configuration to the candidate configuration datastore:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <copy-config>
    <source>
      <running/>
    </source>
    <target>
     <candidate/>
    </target>
  </copy-config>
</rpc>
Verification
  <ok/>
</rpc-reply>
delete-config
The <delete-config> operation deletes a configuration datastore.
At the time of this writing, this operation can delete only the candidate configuration store.
Request format
The following is the XML format for the request to delete the candidate configuration datastore:
  <delete-config>
    <target>
      <candidate/>
    </target>
  <delete-config/>
</rpc>
Verification
  <ok/>
</rpc-reply>
discard-changes
The <discard-changes> operation revert the candidate configuration to the current running configuration.
Request format
The following is the XML format for the <discard-changes> request:
  <discard-changes/>
</rpc>
Verification
  <ok/>
</rpc-reply>
Comware-extended protocol operations
get-bulk
The <get-bulk> operation retrieves a specific number of data entries starting from the data entry next to the one with the specified index. Use the <Index> element to specify an index and use the count attribute to specify the number of entries to retrieve.
If you do not specify an index, the retrieval starts from the first data entry.
This operation retrieves all remaining data entries starting from the data entry next to the one with the specified index if either of the following conditions occurs:
·     You do not specify the count attribute.
·     The number of matching data entries is less than the value in the count attribute.
The <get> operation retrieves all configuration and state data that matches the specified filter in one request. This might cause performance issues when a client retrieves massive data and is not efficient when the client only needs to retrieve some of the data entries.
For efficient retrieval of massive data, use the <get-bulk> operation to retrieve data in multiple requests. In addition, you can use the <get-bulk> operation to retrieve only the data entries of interest.
Request format
The following is the XML format for the <get-bulk> request:
  <get-bulk>
    <filter>
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        XML structure (module, submodule, table, and columns)
      </top>
    </filter>
  </get-bulk>
</rpc>
The following is a sample <get-bulk> request that contains the count attribute and the <Index> element:
  <get-bulk>
        <Syslog>
          <Logs xc:count="5">
            <Log>
              <Index>10</Index>
            </Log>
          </Logs>
        </Syslog>
      </top>
    </filter>
  </get-bulk>
</rpc>
·     You can use the count attribute only in module and table elements. In this sample request, you can use the count attribute in the <Syslog> module element or in the <Logs> table element. In other types of elements, it cannot be resolved.
Verification
If the requested operation succeeds, the server responds with all matching data entries. The following is the response format:
  <data>
  </data>
</rpc-reply>
get-bulk-config
The <get-bulk-config> operation retrieves a specific number of non-default configuration data entries, starting from the data entry next to the one with the specified index.
The <get-bulk-config> operation uses the same XML request format as the <get-config> operation, except that the <get-bulk-config> operation introduces the <Index> and the count attribute for efficient retrieval of massive data.
In the <get-bulk-config> request, you can use the <Index> element to specify an index and use the count attribute to specify the number of entries to retrieve.
The guidelines for the <get-bulk> operation also apply to this operation.
Request format
The following is the XML format for the <get-config> and <get-bulk-config> requests:
  <get-config>
    <source>
      <datastore/>
    </source>
    <filter>
      </top>
    </filter>
  </get-config>
</rpc>
Value
running
candidate
Verification
If the requested operation succeeds, the server responds with the matching configuration data entries. The following is the response format:
  <data>
  </data>
</rpc-reply>
action
The <action> operation instructs the device to execute a non-configuration operation, for example, to ping an address or to clear the statistics on an interface.
If the operation succeeds, the device returns </ok> or information about the result. If the operation fails, the device returns an error message.
Request format
The following is the XML format for the <action> request:
  <action>
    <top xmlns="http://www.h3c.com/netconf/action:1.0">
    </top>
  </action>
</rpc>
Verification
If the operation succeeds, the device returns </ok> or the operation results.
The following is the XML format for the success response without operation results:
  <ok/>
</rpc-reply>
The following is the XML format for the success response that contains operation results:
  <action-result>
    Operation results
  </action-result>
</rpc-reply>
Example: Permitting the NETCONF client to send <edit-config> requests during configuration rollback on the current session
Permit the NETCONF client to send <edit-config> requests during configuration rollback on the current session.
# Enter XML view.
<Sysname> xml
  <capabilities>
  </capabilities>
</hello>
# Request the device to permit the NETCONF client to send <edit-config> requests during configuration rollback on the current session. Copy and paste the following request message to the client:
  <action>
    <error-option>stop-on-error</error-option>
      <Fundamentals>
        <CurrentSessionOpt>
          <DisableEditConfigWhenRollback>false</DisableEditConfigWhenRollback>
        </CurrentSessionOpt>
      </Fundamentals>
    </top>
  </action>
</rpc>
Verification
If the requested operation succeeds, the device responds with a success response without operation results.
  <ok/>
</rpc-reply>
# To prevent the NETCONF client from editing the configuration during configuration rollback on the current session, set the <DisableEditConfigWhenRollback> element to true.
load
The <load> operation adds the configuration in a configuration file into the running configuration datastore. If the running configuration already contains a setting for a parameter, the system replaces that setting with the setting in the configuration file.
IMPORTANT
IMPORTANT:
The <load> operation will fail for a parameter if the system requires that you must delete its setting before you can reconfigure it.
Request format
The following is the XML format for the <load> request:
  <load>
    <file>Path of the configuration file to load</file>
  </load>
</rpc>
The configuration file must use the .cfg extension. The extension is case insensitive.
Verification
If the configuration file is loaded successfully, the device returns the following response:
  <ok/>
</rpc-reply>
save
The <save> operation saves the running configuration to a configuration file.
Request format
The following is the XML format for the <save> request:
  <save OverWrite=”false” VsysName=”vsys-name” Safely=”false”>
    <file>destination configuration file name</file>
  </save>
</rpc>
Element or attribute
<file>
In the <file> element, specify the name of the .cfg configuration file to which the running configuration is to be saved. The name must start with the storage media name and end with the .cfg extension. The extension is case insensitive.
The <file> element is optional. If you include the element in the request, you must specify a file name. If the request does not include the element, the configuration is automatically saved to the default main next-startup configuration file.
OverWrite
The OverWriteattribute attribute determines whether to overwrite the specified file if the file already exists. The following values are available:
·     true—Overwrites the file.
·     false—Prevents the device from saving the running configuration to the specified file. In this situation, the device returns an error message.
The default value is true.
VsysName
The VsysName attribute takes effect only when the target device supports vSystems.
·     If the NETCONF client is connected to a non-default vSystem, you cannot specify the VsysName attribute in the request or include the <file> element in the request to specify a destination file.
·     If the NETCONF client is connected to the default vSystem, you can include the VsysName attribute and <file> element in the request to save the running configuration to the specified file for the specified vSystem.
You can use the VsysName attribute together with the OverWrite attribute, but not with the Binary-only attribute.
Safely
Determines whether to save the configuration file in safe mode or fast mode.  Available values:
·     true—Saves the configuration in safe mode. In this mode, the system saves the configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a disruptive event such as a reboot or power failure occurs during the save operation, the device can still start up with the original next-startup configuration file.
·     false—Saves the configuration in fast mode. In this mode, the system directly overwrites the target next-startup configuration file. If a disruptive event such as a reboot, power failure, out-of-memory, out-of-storage event occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots.
By default, the Safely attribute is set to false if you do not specify a value for it.
Safe mode is slower than fast mode, but more secure. As a best practice, use the safe mode if the power source is not reliable or you are remotely configuring the device.
Verification
If the running configuration is saved successfully, the device returns the following response:
  <ok/>
</rpc-reply>
Example: Saving the running configuration to a configuration file
Save the running configuration to the my_config.cfg configuration file.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
      urn:ietf:params:netconf:base:1.0
    </capability>
  </capabilities>
</hello>
# Save the running configuration to the my_config.cfg configuration file. Copy and paste the following request message to the client:
  <save>
    <file>my_config.cfg</file>
  </save>
</rpc>
Verification
If the requested operation succeeds, the server responds with a success response without operation results.
  <ok/>
</rpc-reply>
rollback
The <rollback> operation replaces the running configuration with the configuration from a configuration file.
Request format
The following is the XML format for a <rollback> request:
  <rollback>
    <file>Replacement configuration file name</file>
  </rollback>
</rpc>
Verification
If the configuration rolls back successfully, the device returns the following response:
  <ok/>
</rpc-reply>
CLI
The <CLI> operation executes CLI commands encoded in XML format.
The <CLI> operation includes the Open-channel, Close-channel, Execution, and Configuration options.
·     Open-channel—Opens a persistent channel for the current session.
·     Close-channel—Closes the persistent channel for the current session.
·     Execution—Executes commands in user view. The system cannot execute the system command to enter system view for command execution.
·     Configuration—Executes commands in system view by default. From system view, you can enter lower-level views. To change between views, use the system and quit commands to change between views. If you issue CLI commands over a persistent or temporary channel, you cannot use the quit command to exit user view. The system executes each of the specified commands in the view that the CLI stays upon execution of the previous command, except that the system always executes the first command in system view.
Table 15 Elements and attributes in the <CLI> operation tag
Operation
Example
<Open-channel>
Opens a persistent channel to access the CLI in system view. If a persistent channel already exists, the device returns a failure message.
Open a persistent channel to access the CLI in system view:
  <CLI>
    <Open-channel/>
  </CLI>
</rpc>
<Close-channel>
Closes the persistent channel. If the operation fails, the device returns an error message.
Close the persistent channel:
  <CLI>
    <Close-channel/>
  </CLI>
</rpc>
<Configuration>
You must include the exec-use-channel attribute in the <configuration> element to indicate the method to issue CLI commands. Options for the exec-use-channel attribute:
·     false—Issues commands without using a channel.
·     true—Issues commands over a temporary channel. The channel automatically closes after the commands are executed.
·     persist—Issues commands over a persistent channel for the session. A session can have only one persistent channel.
Execute the display this command in system over the persistent channel:
  <CLI>
    <Configuration exec-use-channel=”persist”>
      display this
    </Configuration>
  </CLI>
</rpc>
<Execution>
Execute the display this command in user view:
  <CLI>
    <Execution>
      display this
    </Execution>
  </CLI>
</rpc>
Table 16 describes the value options for the exec-use-channel attribute in the <Configuration> element.
Table 16 Value options for the exec-use-channel attribute in the <Configuration> element
Attribute value
Example
false
Uses the exec comsh command to open the CLI. This method is slow because the system must start the comsh process to open the CLI.
Execute the display this command in system view:
  <CLI>
    <Configuration exec-use-channel=”false”>
      display this
    </Configuration>
  </CLI>
</rpc>
true
Issues commands over a temporary channel. This method is faster than the exec comsh method. However, the improvement is slight, because the system must execute the commands in CLI.
  <CLI>
    <Configuration exec-use-channel=”true”>
      display this
    </Configuration>
  </CLI>
</rpc>
persist
Issues commands over the persistent channel.
If the channel has not been created, the system creates it first.
If the channel already exists, the system executes commands in the view that the CLI stays for the channel.
  <CLI>
      display this
    </Configuration>
  </CLI>
</rpc>
·     As a best practice, do not use the <CLI> operation to execute interactive CLI commands. The operation is very likely to fail, because user interaction is required.
·     Before you issue a configuration command over a channel, make sure the returned data will not exceed 4000 lines. The channel will hang up if this limit is exceeded and you cannot execute the quit command to quit.
Request format
Use one of the following XML formats to construct a <CLI> request:
·     Issue commands without using a channel:
Method 1:
  <CLI>
    <Execution>
      Series of commands, one on a line
    </Execution>
  </CLI>
</rpc>
Method 2:
  <CLI>
    <Configuration exec-use-channel="false">
    </ Configuration>
  </CLI>
</rpc>
·     Issue commands over a temporary channel:
  <CLI>
    <Configuration exec-use-channel="true">
    </ Configuration>
  </CLI>
</rpc>
·     Issue commands over the persistent channel:
  <CLI>
    <Configuration exec-use-channel="persist">
    </ Configuration>
  </CLI>
</rpc>
·     Open a persistent channel:
  <CLI>
    <Open-channel/>
  </CLI>
</rpc>
·     Close the persistent channel:
  <CLI>
    <Close-channel/>
  </CLI>
</rpc>
You can enclose a series of commands in one <Execution> or <Configuration> element, with one command on a line.
Verification
If the requested operation succeeds, the device returns a response in the following format, with data enclosed in a CDATA tag:
  <CLI>
    <Execution>
      <![CDATA[returned data]]>
    </Execution>
  </CLI>
</rpc-reply>
If the <Open-channel> or <Close-channel> operation succeeds, the device returns the following message:
<rpc-reply message-id="101235" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <ok/>
</rpc-reply>
If the <Open-channel>, <Close-channel>, <Configuration exec-use-channel="true">, or <Configuration exec-use-channel="persist"> operation fails, the device returns an error response in the following format:
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <error-type>application</error-type>
  <error-tag>data-missing</error-tag>
  <error-message xml:lang="en">error message</error-message>
</rpc-error>
Example: Executing CLI commands from a NETCONF client
Retrieve the running configuration by issuing the display current-configuration  command from a NETCONF client.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Issue the command that displays the running configuration from the NETCONF client. Copy and paste the following request message to the client:
  <CLI>
    <Execution>
    </Execution>
  </CLI>
</rpc>
Verification
If the requested operation succeeds, the device responds with the running configuration on the device.
  <CLI>
    <Execution><![CDATA[
 version 7.1.052, Demo 2501005
 sysname ab
 ftp server enable
 ftp update fast
 ftp timeout 2000
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
vlan 1
vlan 1000
radius scheme system
 primary authentication 127.0.0.1 1645
   </Execution>
  </CLI>
</rpc-reply>
get-sessions
The <get-sessions> operation retrieves all active NETCONF sessions on the device.
Request format
The following is the XML format for the <get-sessions> request:
  <get-sessions/>
</rpc>
Verification
If the requested operation succeeds, the device returns a response in the following format:
  <get-sessions>
    <Session>
      <SessionID>session ID</SessionID>
      <Line>user line</Line>
      <UserName>login username</UserName>
      <Since>date and time of login</Since>
      <LockHeld>whether the user holds the lock</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
Table 17 Elements in the <get-sessions> response
Element
SessionID
ID of the session. The return value is 1 or a higher number.
Line
User line over which the session is established. For a NETCONF over SOAP session, this element contains an empty value.
UserName
Since
Date and time when the client logged in. The return value is schema-defined standard DateTime data type.
LockHeld
Whether the client holds the lock. The return value is true or false.
Retrieve the list of active NETCONF sessions on the device.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve the list of active NETCONF sessions on the device. Copy and paste the following request message to the client:
  <get-sessions/>
</rpc>
Verification
  <get-sessions>
    <Session>
      <SessionID>1</SessionID>
      <Line>vty0</Line>
      <UserName></UserName>
      <Since>2011-01-05T00:24:57</Since>
      <LockHeld>false</LockHeld>
    </Session>
  </get-sessions>
</rpc-reply>
The response shows that the device has one NETCONF session with a session ID of 1. The NETCONF client connected to the VTY 0 user line on January 5, 2011 at 00:24:57 and it does not hold the configuration lock.
save-point
The <save-point> operation enables you to set configuration rollback points for automatic or manual configuration rollback to a rollback point.
The system rolls back the configuration based on a rollback point when one of the following events occurs:
·     The NETCONF client sends a rollback request.
·     The NETCONF client has not issued any instruction before the rollback idle timeout timer expires.
·     The NETCONF client unexpectedly disconnects from the device.
Configuration rollback procedure
IMPORTANT
IMPORTANT:
In a multisession environment, lock the running configuration datastore to prevent other users from editing the configuration when you use the configuration rollback feature. This action ensures that you can roll back the configuration to the expected state.
1.     Lock the running configuration datastore.
2.     Send a <save-point>/<begin> request to create the initial rollback point and set the rollback idle timeout timer.
3.     Send one or multiple <edit-config> requests to configure the device before the timer expires.
4.     Send a <save-point>/<commit> request to commit the configuration. You can perform multiple commit operations, one for a set of <edit-config> operations. The system creates a rollback point for every commit operation.
5.     If the settings made after a rollback point are not desirable, send a <save-point>/<rollback> request to roll back the configuration to that rollback point. If the NETCONF client has not issued any instruction before the rollback idle timeout timer expires, the system automatically rolls back the configuration to the rollback point created for the most recent commit operation.
6.     Send the <save-point>/<end> request to end the configuration rollback.
7.     Unlock the running configuration datastore.
Enabling the configuration rollback feature and creating the initial rollback point
Request format
The following is the XML format for the <save-point>/<begin> request:
  <save-point>
    <begin>
      <confirm-timeout>100</confirm-timeout>
    </begin>
  </save-point>
</rpc>
The <confirm-timeout> element specifies the idle timeout timer for rollback. The value range for the timer is 1 to 65535. This element is optional. If you do not send the request with this element, the timer is set to 600 seconds by default.
Verification
If the rollback point is created successfully, the device returns a response in the following format:
  <data>
    <save-point>
      <commit>
        <commit-id>1</commit-id>
      </commit>
    </save-point>
  </data>
</rpc-reply>
Rolling back the configuration to a rollback point
Request format
The following is the XML format for the <save-point>/<rollback> request:
  <save-point>
    <rollback>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </rollback>
  </save-point>
</rpc>
To roll back to a rollback point other than the most recent one, you must send the request with the <commit-id/>, <commit-index/>, or <commit-label/> element to specify the commit operation upon which the rollback point was created.
To roll back to the most recent rollback point, send the request with one of those elements or none of the elements.
Table 18 Elements in a configuration rollback request
Element
commit-id
The identifier uniquely identifies a commit operation.
commit-index
The index of a commit operation. The system supports a maximum of 50 commit operations (or rollback points) for a NETCONF session. A value of 49 represents the stored earliest rollback points. A value of 0 represents the most recent rollback point.
commit-label
Label that identifies the commit operation.
Verification
  <ok></ok>
</rpc-reply>
Committing the configuration
Send the <save-point>/<commit> request to commit the changes you have made to the running configuration. The system supports a maximum of 50 commit operations (or rollback points) for a NETCONF session. If you do a commit operation after the limit is reached, include the force attribute in the <commit> element to overwrite the earliest rollback point.
Request format
  <save-point>
    <commit>
      <label>SUPPORT VLAN<label>
      <comment>vlan 1 to 100 and interfaces. Each vlan used for different custom as follows: ……</comment>
    </commit>
  </save-point>
</rpc>
The <label/> and <comment/> elements are optional.
Verification
If the configuration is committed successfully, the device returns a response in the following format:
  <data>
    <save-point>
      <commit>
        <commit-id>2</commit-id>
      </commit>
    </save-point>
  </data>
</rpc-reply>
Disabling configuration rollback
Send the <save-point>/<end> request to disable configuration rollback for the current NETCONF session.
Request format
The following is the XML format for a <save-point>/<rollback> request:
  <save-point>
    <end/>
  </save-point>
</rpc>
Verification
If configuration rollback is disabled successfully, the device returns the following response:
  <ok/>
</rpc-reply>
Retrieving records of rollback points
The <save-point>/<get-commits> operation retrieves records of rollback points.
  <save-point>
    <get-commits>
      <commit-id/>
      <commit-index/>
      <commit-label/>
    </get-commits>
  </save-point>
</rpc>
To retrieve the record of a specific rollback point, send the request with the <commit-id>, <commit-index>, or <commit-label> element to specify the commit operation upon which the rollback point was created. To retrieve the records of all rollback points, send the request without any of those elements.
Request format
The following is the XML format for the rollback point retrieval request:
  <save-point>
    <get-commits>
      <commit-label>SUPPORT VLAN</commit-label>
    </get-commits>
  </save-point>
</rpc>
Verification
If the retrieval operation succeeds, the device returns a response in the following format:
  <data>
    <save-point>
      <commit-information>
        <CommitID>2</CommitID>
        <TimeStamp>Thu Oct 30 11:30:28 1980</TimeStamp>
        <UserName>test</UserName>
        <Label>SUPPORT VLAN</Label>
      </commit-information>
        <CommitID>1</CommitID>
        <TimeStamp>Wed Nov  8 18:26:28 1972</TimeStamp>
    </save-point>
  </data>
</rpc-reply>
Retrieving the configuration data at a rollback point
The <save-point>/<get-commits> operation retrieves the configuration data recorded at a rollback point.
  <save-point>
    <get-commit-information>
        <commit-id/>
        <commit-index/>
        <commit-label/>
      <compare-information>
        <commit-id/>
        <commit-index/>
        <commit-label/>
      </compare-information>
    </get-commit-information>
  </save-point>
</rpc>
To retrieve the configuration data recorded at a specific rollback point, specify that point by using the <commit-id/>, <commit-index/>, or <commit-label/> element. The <compare-information> element is optional. If the <commit-information> does not contain the <commit-id/>, <commit-index/>, or <commit-label/> element, the server responds the configuration data recorded at the most recent rollback point.
Request format
The following is the XML format for a request to retrieve the configuration data recorded at a rollback point:
  <save-point>
  </save-point>
</rpc>
Verification
If the configuration data retrieval succeeds, the device returns a response in the following format:
  <data>
    <save-point>
        <content>
          interface vlan 1
        </content>
    </save-point>
  </data>
</rpc-reply>
Name-to-index conversion
About name-to-index conversion
Name-to-index conversion (h3c-name2index) capability allows you to use a name type value in place of an index-type value in index elements when you perform the <get>, <get-config>, <edit-config>, or <action> operations. For example, interface Ethernet 1/0/1 is indexed at 1. In a request to operate on that interface, you can set the <IfIndex> element to Ethernet1/0/1 instead of 1. Support for h3c-name2index capability differs by table. To identify the support of a table for name-to-index conversion, see the NETCONF API reference that contains the table.
For example, GigabitEthernet 1/0/1 is a trunk port. To permit VLANs 2 and 3 to pass through the port, use the following message:
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
      <top xmlns="http://www.h3c.com/netconf/config:1.0"> xmlns:base=”http://www.h3c.com/netconf/base:1.0”
        <VLAN>
          <TrunkInterfaces>
            <Interface>
              <IfIndex>GigabitEthernet1/0/1</IfIndex>
              <PermitVlanList>2-3</PermitVlanList>
            </Interface>
          </TrunkInterfaces>
        </VLAN>
      </top>
    </config>
  </edit-config>
</rpc>
As of the h3c-name2index1.1 version, you can use the valuetype attribute in the <IfIndex> element to explicitly identify the element value as a name or index. You can retrieve the capability sets on the target device to obtain its supported h3c-name2index version. For more information about exchange of capability sets, see "Testing the connectivity between the NETCONF client and the target device."
Options for the valuetype attribute:
·     Name—The value is a name.
·     index—The value is an index.
·     auto—The system looks up the value in the name column first. If no match is found, the system looks up the value in the index column.
If you do not specify the valuetype attribute, the auto option applies.
For example, the following message contains an index of 1 in the <IfIndex> element:
  <getoperation>
    <filter>
      <top xmlns="http://www.h3c.com/netconf/config:1.0" xmlns:base=”http://www.h3c.com/netconf/base:1.0”>
        <VLAN>
          <TrunkInterfaces>
            <Interface>
              <IfIndex base:valuetype="index">1</IfIndex>
            </Interface>
          </TrunkInterfaces>
        </VLAN>
      </top>
    </filter >
  </getoperation>
</rpc>
Constraints
·     In a <get-bulk> or <get-bulk-config> operation, you cannot specify multiple names in an index element if all of the following conditions are met:
¡     The index values are table indexes.
¡     The index element acts as the start delimiter for the retrieval operation.
·     Name-to-index conversion is not supported for match filtering.
·     One-to-many conversion is not available for the non-index columns in an <edit-config> operation.
·     Conversion syntax differs by data type. For example, the interface management module (Ifmgr) allows you to specify a range of interfaces (for example, GigabitEthernet1/0/1 to GigabitEthernet1/0/24) in the <IfIndex> element. However, you can only specify one VPN instance in one VPN element.
edit-config:incremental
The <edit-config> operation with the incremental element adds configuration data to lists in a list column without impact on the original data in the lists.
An example of list columns is the <PermitVlanList> element in the <VLAN>/<TrunkIntefaces>/<Interface> subtree. The <PermitVlanList> element specifies a list of VLANs (for example, 2,3,5-8,9,10-100) permitted to pass through on a trunk interface.
To perform an incremental data operation on a list column, you must add incremental=”true” to the element in the request for that column.
For example, the list of permitted VLANs on interface indexed at 100 contains VLAN 10. To add or delete VLANs 2 and 3 to or from that VLAN list, send the following request message to perform an incremental data operation on that list:
  <edit-config>
    <target>
      <running/>
    </target>
        <VLAN xc:operation="operXXX">
          <TrunkInterfaces>
            <Interface>
              <IfIndex>100</IfIndex>
              <PermitVlanList base:incremental=”true”>2-3</PermitVlanList>
            </Interface>
          </TrunkInterfaces>
        </VLAN>
      </top>
    </config>
  </edit-config>
</rpc>
The result of the incremental <edit-config> operation differs depending on the operation type, as shown in Table 19.
Table 19 Results of incremental VLAN operations on the VLAN list
Operation (OperXXX)
Incremental operation on the VLAN list
Remarks
create
VLANs 2 and 3 are added to the PermitVlanList column. If you retrieve values from this column, the device returns 2,3,10.
If any specified values already exist, the server replies that the values already exist. If none of them exist, the device returns a success message.
delete
Operation fails. The device returns an error message to indicate that the operation failed because VLAN 2 does not exist.
The delete operation deletes all specified values from the column if they are all contained in the column. If any one of the specified values does not exist, the delete operation fails, whether or not the incremental attribute is specified.
merge
N/A
replace
You cannot use the incremental attribute with a replace operation.
N/A
remove
Operation succeeds. The VLAN list stays unchanged, because the VLAN list does not contain VLANs 2 and 3.
Use caution when you perform a remove operation. This operation removes all data in the column if you do not specify the incremental attribute.
cancel-subscription
The <cancel-subscription> operation unsubscribes from an event stream.
Request format
The following is the XML format for the NETCONF event unsubscription request:
  <cancel-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
  </cancel-subscription>
</rpc>
Element
stream
Name of the subscribed event stream.
Verification
If the subscription is unsubscribed, the device returns a success response in the following format:
<?xml version="1.0" encoding="UTF-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
  <ok/>
</rpc-reply>
If the subscribed event stream does not exist, the device returns the following error message:
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <rpc-error>
    <error-tag>operation-failed</error-tag>
    <error-message xml:lang="en">The subscription stream to be canceled doesn't exist: Stream name=XXX_STREAM.</error-message>
  </rpc-error>
</rpc-reply>
createDot1qFlow
The <createDot1qFlow> operation enables Dot1q termination on a subinterface and specifies a range of outermost VLAN IDs to terminate.
In the request for this operation, use the <ifName> element to specify the target subinterface name.
Use the <vlanIdBgn> and <vlanldEnd> elements to specify the start and end VLAN IDs, respectively, in the range of outermost VLAN IDs to terminate. To terminate only one VLAN, set the ID of that VLAN in both the <vlanIdBgn> and <vlanldEnd> elements.
The <groupId> element takes a value in the range of 1 to 16. For interoperability of the target device with a third-party device, make sure the two devices use the same group ID. If there is no interoperability issue, you can set the group ID to any value in the valid value range.
Request format
The following is a sample <createDot1qFlow> request that enables subinterface GigabitEthernet 1/0/1.1 to terminate VLAN-tagged packets with the outermost VLAN IDs in the range of 1 to 100:
  <createDot1qFlow xmlns="http://www.gsta.com/netconf/gsta-ethernet">
    <ifName>GigabitEthernet1/0/1.1</ifName>
    <vlanIdBgn>1</vlanIdBgn>
    <vlanIdEnd>100</vlanIdEnd>
    <groupId>1</groupId>
  </createDot1qFlow>
</rpc>
Element
ifName
Subinterface name.
vlanIdBgn
Start VLAN ID of the VLAN range.
vlanIdEnd
End VLAN ID of the VLAN range.
groupId
Group ID.
Verification
If the 802.1q termination settings are configured successfully, the device returns a success response in the following format:
  <ok/>
</rpc-reply>
If the target subinterface does not exist, the device returns the following error message:
<env:Body>
      <env:Fault>
         <env:Code>
            <env:Value>env:Receiver</env:Value>
         </env:Code>
         <env:Reason>
            <env:Text xml:lang="en">invalid-value</env:Text>
         </env:Reason>
         <env:Detail>
               <error-tag>invalid-value</error-tag>
               <error-message xml:lang="en">Configuration target does not exist.</error-message>
            </rpc-error>
         </env:Detail>
      </env:Fault>>
deleteDot1qFlow
The <deleteDot1qFlow> operation deletes the Dot1q settings on a subinterface. This operation is supported only in the B75 version train.
Use the <vlanIdBgn> and <vlanldEnd> elements to specify the start and VLAN IDs, respectively, in the range of outermost VLAN IDs to terminate. To terminate only one VLAN, set the ID of that VLAN in both the <vlanIdBgn> and <vlanldEnd> elements.
Request format
The following is a sample <deleteDot1qFlow> request that disables subinterface GigabitEthernet 1/0/1.1 from terminating VLAN-tagged packets with the outermost VLAN IDs in the range of 1 to 100:
  <deleteDot1qFlow xmlns="http://www.gsta.com/netconf/gsta-ethernet">
  </deleteDot1qFlow>
</rpc>
Element
ifName
Subinterface name.
vlanIdBgn
vlanIdEnd
groupId
Group ID.
Verification
If the 802.1q termination settings are deleted successfully, the device returns a success response in the following format:
  <ok/>
</rpc-reply>
sortByName (for data retrieval operations)
The sortByName attribute enables the device to sort returned data by name in response to a data retrieval operation.
This attribute is useful for data retrieval from multi-instance tables that meet the following conditions:
·     The tables have an index value and a name value for each instance.
·     The index and name values are in one-to-one mappings.
For example, the Interfaces table has one IfIndex value and one Name value for each interface. By default, the device sorts the interface data returned in response to an interface data retrieval request by interface index.
To have the device sort the returned interface data by interface name, set the sortByName attribute to true on the Interfaces table.
Request format
The following sample request enables the device sort returned data by name:
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc=”http://www.h3c.com/netconf/base:1.0”>
  <get>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:data="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces xc:sortByName="true">
            <Interface>
              <IfIndex></IfIndex>
              <Name></Name>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the device returns the following response, with data sorted by name:
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <data>
      <Ifmgr>
        <Interfaces>
          Other row instances
          <Interface>
            <IfIndex>1413</IfIndex>
            <Name>Route-Aggregation1</Name>
          </Interface>
          <Interface>
            <IfIndex>1412</IfIndex>
            <Name>Route-Aggregation10</Name>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
xml2cli
About XML-to-CLI conversion
The Comware extended xml2cli:1.0 capability enables the device to convert the XML configuration in a request into their command line forms and send back to the client.
With this capability, a client can also request conversion of configuration data in XML format into command lines by using an xml2cli RPC.
The following is the URL for the xml2cli capability:
urn:$oem:params:netconf:capability:$oem-xml2cli:1.0
The $oem parameter represents the vendor name of the device.
If the client includes the xml2cli capability in its hello message for capability exchange on a session, the device enables xml2cli capability for that session.
When the device handles requests sent over the xml2cli-capable session, the device performs the following operations:
·     When the device handles an <edit-config> or <action> request, the device perform the following operations:
¡     Executes the requested configuration operation or action.
¡     Converts the XML configuration in the request to their command line forms and returns the command lines in <rpc-reply> to the client.
·     When the device handles the xml2cli RPC from the client, the device converts the XML configuration in the <xml2cli> element to their command line forms and returns the commands to the client.
Dependencies and constraints
The client must make sure the correctness of the XML configuration and verification of returned command lines. The device is only responsible for changing correct and valid XML configuration to their command line forms. It does not guarantee the correctness of the returned command lines.
xml2cli RPC
About the xml2cli RPC
The xml2cli method enables the client to obtain the command line forms of XML configuration data.
When the device handles the xml2cli RPC from the client, the device converts the XML configuration in the <xml2cli> element to their command line forms and returns the command lines to the client.
You can use the xml2cli RPC in the auditing module for a network controller to present the configuration differences detected between the controller and the device in their command line forms.
Request format
The following is the request format for the XML2CLI RPC:
<rpc message-id="100" xmlns=" urn:ietf:params:xml:ns:netconf:base:1.0">
  <xml2cli>
    XML configuration
  </xml2cli>
</rpc>
Response format
The following is the response returned by the device:
<rpc-reply message-id="100" xmlns=" urn:ietf:params:xml:ns:netconf:base:1.0">
  <xml2cli>
    <cli>
      command lines for the XML configuration
    </cli>
  </xml2cli>
<rpc-reply/>
If the XML-to-CLI conversion succeeds, the device returns the commands for the configuration data in the <rpc-reply> element.
If the XML-to-CLI conversion fails, the device includes the <rpc-error> element in the <rpc-reply> element to indicate the failure.
Specification limitations for the xml2cli capability
Item
Support status
Remarks
Example
valueType
Supported
As of the h3c-name2index1.1 version, you can use the valuetype attribute to explicitly identify an element value as a name or index. You can retrieve the capability sets on the target device to obtain its supported h3c-name2index version. Options for the valuetype attribute:
·     name—The value is a name.
·     auto—The system looks up the value in the name column first. If no match is found, the system looks up the value in the index column. If you do not specify the valuetype attribute, the auto option applies.
<xml2cli xmlns=” urn:ietf:params:xml:ns:netconf:base:1.0”>
  <VLAN>
    <TrunkInterfaces>
      <Interface>
        <IfIndex valuetype="index">1</IfIndex>
      </Interface>
    </TrunkInterfaces>
  </VLAN>
</xml2cli>
Per-row command conversion
Supported
By default, the device performs XML-to-CLI conversion by row and encloses the command lines in their respective row tags.
If the conversion is performed for a subtable in a table, the device encloses the command lines in the <cli> row elements in the table element. This is because the subtables of a table are row nodes of the table.
  <xml2cli>
    <Ifmgr>
      <Interfaces>
        <Interface>  //row node
          <cli>
              Interface gigabitethernet2/0/1
              port link-type trunk
              port trunk pvid vlan 1
          </cli>
          <IfIndex>1647</IfIndex>
          <LinkType>2</LinkType>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc-reply>
operation
Not supported
The <xml2cli> element does not support the operation attribute that is available for the <edit-config> operation. This is because XML-to-CLI conversion is primarily in configuration auditing and does not configure the device.
N/A
<error-option>
Not supported
The xml2cli RPC does not support the <error-option> parameter. The <error-option> parameter in an <edit-config> operation does not take effect on XML-to-CLI conversion. The device always applies the continue-on-error policy to XML-to-CLI conversion.
N/A
·     Example: XML-to-CLI conversion for one row of data
The client sends the following request to do XML-to-CLI conversion for one row of data:
  <xml2cli>
    <Ifmgr>
      <Interfaces>
        <Interface>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc>
The device returns the following response:
  <xml2cli>
    <Ifmgr>
      <Interfaces>
        <Interface>
          <cli>
          </cli>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc-reply>
·     Example: XML-to-CLI conversion for multiple rows of data
The client sends the following request to do XML-to-CLI conversion for multiple rows of data:
  <xml2cli>
    <Ifmgr>
      <Interfaces>
        <Interface>
          <PVID>1</PVID>
        </Interface>
        <Interface>
          <IfIndex>1648</IfIndex>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc>
  <xml2cli>
    <Ifmgr >
      <Interfaces>
        <Interface>
          <cli>
          </cli>
          <PVID>1</PVID>
        </Interface>
      <Interface>
          <cli>
              Interface gigabitethernet2/0/2
          </cli>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc-reply>
·     Example: XML-to-CLI conversion for a multilevel table
The client sends the following request to do XML-to-CLI conversion for a multilevel table:
  <xml2cli>
    <GRPC>
      <SensorGroups>
        <SensorGroup>
          <GroupName>1</GroupName>
          <SensorPaths>
            <SensorPath>
              <Path>device/base</Path>
              <SelectionNodes>
                <SelectionNode>
                  <NodeName>uptime</NodeName>
                </SelectionNode>
              </SelectionNodes>
            </SensorPath>
          </SensorPaths>
        </SensorGroup>
      </SensorGroups>
    </GRPC>
  </xml2cli>
</rpc>
  <ok/>
  <xml2cli>
    <GRPC>
      <SensorGroups>
        <SensorGroup>
          <cli>
            telemetry
              sensor group 1
                sensor path device/base selection-nodes uptime
          </cli>
          <SensorPaths>
            <SensorPath>
              <SelectionNodes>
                <SelectionNode>
                </SelectionNode>
              </SelectionNodes>
            </SensorPath>
          </SensorPaths>
        </SensorGroup>
      </SensorGroups>
    </GRPC>
  </xml2cli>
</rpc-reply>
xml2cli for <edit-config>
About XML-to-CLI conversion for <edit-config>
The xml2cli capability extends the <rpc-reply> response to the <edit-config> request. It adds the <xml2cli> element in the <rpc-rely> element to return the command lines for the XML configuration in the request.
The device returns the conversion results, regardless of whether the <edit-config> RPC has been executed successfully or not.
Example: An <edit-config> operation successfully executed on an xml2cli-capable session
The client sends the following <edit-config> request over an xml2cli-capable session:
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
      <top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
        <Ifmgr>
          <Interfaces>
            <Interface>
              <PVID>1</PVID>
            </Interface>
            <Interface>
              <PVID>1</PVID>
            </Interface>
          </Interfaces>
        </Ifmgr>
      <top/>
    <config/>
  <edit-config/>
<rpc/>
Upon a successful execution of the requested operation, the device returns the following response, with the command lines for the requested XML configuration:
  <ok/>
  <xml2cli>
    <Ifmgr >
      <Interfaces>
        <Interface>
          <cli>
          </cli>
          <PVID>1</PVID>
        </Interface>
        <Interface>
          <cli>
          </cli>
          <PVID>1</PVID>
        </Interface>
      </Interfaces>
    </Ifmgr>
  </xml2cli>
</rpc-reply>
Example: A failed <edit-config> operation on an xml2cli-capable session
The client sends the following request:
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
        <Device xc:operation="create">
          <Base>
            <HostName>xml2cli</HostName>
          </Base>
        </Device>
      <top/>
    <config/>
  <edit-config/>
<rpc/>
Upon a failed execution of the requested operation, the device returns the following response, with the command lines for the requested XML configuration:
  <rpc-error>
    <error-severity>error</error-severity>
    <error-path>/rpc/edit-config[1]/config[1]/Device[1]/Base[1]</error-path>
    <error-message xml:lang="en">When the create, merge, or replace operation is issued, empty data cannot be assigned to columns.</error-message>
  </rpc-error>
  <xml2cli>
    <Device >
      <Base>
        <CLI>
           hostname xml2cli
        </CLI>
      </Base>
    </Device>
  </xml2cli>
</rpc-reply>
xml2cli for <action>
About XML-to-CLI conversion for <action>
The xml2cli capability extends the <rpc-reply> response to the <action> request. It adds the <xml2cli> element in the <rpc-rely> element to return the command lines for the XML configuration in the request.
The device returns the conversion results, regardless of whether the <action> RPC has been executed successfully or not.
Example: An <action> operation successfully executed on an xml2cli-capable session
The client sends the following request over an xml2cli-capable session:
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <action>
      <VLAN>
        <BatchVlans>
          <CreateVlanList>5-15</CreateVlanList>
          <DestroyVlanList>5-9</DestroyVlanList>
        </BatchVlans>
      </VLAN>
    </top>
  </action>
</rpc>
<rpc-reply message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <action-result xmlns="http://www.h3c.com/netconf/action:1.0">
    <request-path>/Envelope/Body[1]/rpc[1]/action[1]/top[1]/VLAN[1]/BatchVlans[1]</request-path>
    <result-data>
    </result-data>
  </action-result>
  <xml2cli>
    <VLAN>
      <BatchVlans>
        <cli>
          vlan 1 to 15
          undo vlan 5 to 10
        </cli>
        <CreateVlanList>1-15</CreateVlanList>
        <DestroyVlanList>5-10</DestroyVlanList>
      </BatchVlans>
    </VLAN>
  </xml2cli>
</rpc-reply>
Example: A failed <action> operation on an xml2cli-capable session
  <action>
      <VLAN>
        <BatchVlans>
        </BatchVlans>
      </VLAN>
    </top>
  </action>
</rpc>
The following is the sample response returned by the device:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
  <rpc-error>
    <error-type>rpc</error-type>
    <error-tag>unknown-element</error-tag>
    <error-message xml:lang="en">Unexpected element 'http://www.h3c.com/netconf/action:1.0':'BatchVlan'(index:0) under element '/rpc/action[1]/top[1]/VLAN[1]</error-message>
    <error-info>
      <bad-element>BatchVlan</bad-element>
    </error-info>
  </rpc-error>
  <xml2cli>
    <VLAN>
      <BatchVlans>
        <cli>
          vlan 1 to 15
          undo vlan 5 to 10
        </cli>
      </BatchVlans>
    </VLAN>
  </xml2cli>
</rpc-reply>
Summary of NETCONF data operations
Table 20 lists all NETCONF operations available with Comware at the time of this writing. These operations include <get>, <get-config>, <get-bulk>, <get-bulk-config>, <edit-config>, and <action>.
Table 20 Summary of NETCONF operations available with Comware
Operation
Sample request in XML format
get
Retrieves configuration and state data.
Retrieve all Syslog configuration and state data:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get>
      <top xmlns="http://www.h3c.com/netconf/data:1.0" >
        <Syslog>
        </Syslog>
      </top>
    </filter>
  </get>
</rpc>
get-config
Retrieves configuration data. This operation retrieves only non-default configuration data. If no non-default configuration data exists, the device returns a response without a value for the <data> element.
Retrieve all non-default configuration data from the Interfaces table:
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
           <Interfaces>
              <Interface/>
            </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
get-bulk
Retrieves a specific number of data entries starting from the data entry next to the one with the specified index, including the configuration and state data.
The <get> operation retrieves all configuration and state data that matches the specified filter in one request. In some situations, the <get-bulk> operation is a better choice than the <get> operation. For example, when you retrieve massive data, you can use the <get-bulk> operation to retrieve data in multiple requests to improve data retrieval performance.
Retrieve all interface data:
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
        <Ifmgr>
          <Interfaces xc:count=”5” xmlns:xc=” http://www.h3c.com/netconf/base:1.0”>
            <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
get-bulk-config
Retrieves a specific number of configuration data entries, starting from the data entry next to the one with the specified index. The <get-bulk> operation constraints also apply to this operation.
Retrieve all interface configuration data:
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" >
  <get-bulk-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk-config>
</rpc>
edit-config: merge
Merges target configuration data to the running configuration.
In a merge request, you must specify the target (or the row) on which the merge operation to be performed.
·     If the target already exists, the merge operation updates the setting for it.
·     If the target does not exist, but it can be created, the merge operation creates and then configures the target.
·     If the target does not exist and it cannot be created, the device returns a merge failure message.
Set the size of the log buffer to 120:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"  xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <config>
        <Syslog xmlns="http://www.h3c.com/netconf/config:1.0" xc:operation="merge">
           <LogBuffer>
             <BufferSize>120</BufferSize>
          </LogBuffer>
        </Syslog>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: create
Creates the specified target. In the <edit-config> request for a create operation, you must specify the target to create. The <edit-config> request for a create operation uses the same XML data format as the <edit-config> request for a merge operation, except that you must change the operation attribute value to create in the request.
·     If the target can be created, the device creates and then configures the target as requested.
·     If the specified target already exists, the device returns a data-exist error message.
See the XML format for the merge operation. Change the operation attribute value to create in the request.
edit-config: replace
·     Replaces the specified target.
If the specified target already exists, the operation replaces the configuration for the target with the configuration specified in the request.
·     If the target does not exist, but it can be created, the replace operation creates and then configures the target as requested.
·     If the specified target does not exist and cannot be created, the device does not perform the replace operation and it returns an invalid-value error message.
See the XML format for the merge operation. Change the operation attribute value to replace in the request.
edit-config: remove
Deletes the specified configuration target.
·     To delete a table and all configuration data in it, specify only the table index in the <target> element.
·     To delete the configuration for a parameter from a table, specify the index of the table and the configuration to delete in the <target> element.
·     If the specified target does not exist or if the request contains an empty <target> element, the device returns a success message.
See the XML format for the merge operation. Change the operation attribute value to remove in the request.
edit-config: delete
·     If the specified target does not exist, the device returns an error message.
See the XML format for the merge operation. Change the operation attribute value to delete in the request.
edit-config: default-operation
Modifies the running configuration of the device by using the default operation method.
NETCONF uses one of the following operation attributes to modify configuration: merge, create, delete, and replace.
If you do not specify an operation attribute in an <edit-config> request, NETCONF uses the specified default operation method.
The value specified for the <default-operation> element takes effect only once.
If you do not specify an operation attribute or the default operation method for an <edit-config> message, merge always applies.
The following are values available for the <default-operation> element:
·     merge—Requests the server to perform a merge operation if the request does not contain an operation attribute.  If an <edit-config> request does not contain an operation attribute or a default operation, the merge operation applies.
·     replace—Requests the server to perform a replace operation if the request does not contain an operation attribute.
·     none—Requests the server to verify the request for schema syntax errors if the request does not contain an operation attribute. This option does not change configuration data. If schema verification is passed, the device returns a success message. If schema verification fails, the device returns an error message.
Verify the request for schema syntax errors:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
    <default-operation>none</default-operation>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <IfIndex>262</IfIndex>
              <Description>222222</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: error-option
Specifies the action to take on a configuration error.
By default, the device returns an error message if a request fails. To take a different action, include the <error-option> parameter in an <edit-config> request.
The following are values available for the <error-option> element:
·     stop-on-error—Stops the operation on error and returns an error message. This is the default error-option value.
·     continue-on-error—Continues the operation on error and returns an error message.
·     rollback-on-error—Rolls back the configuration.
Configure two interfaces and take the continue-on-error action when an error occurs:
  <edit-config>
    <target>
      <running/>
    </target>   <error-option>continue-on-error</error-option>
        <Ifmgr xc:operation="merge">
          <Interfaces>
            <Interface>
              <Description>222</Description>
                <ConfigSpeed>1000000</ConfigSpeed>
                <ConfigDuplex>1</ConfigDuplex>
            </Interface>
            <Interface>
              <IfIndex>263</IfIndex>
              <Description>333</Description>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
edit-config: test-option
Determines whether to issue a configuration item in the <edit-config> operation.
The <test-option> element has one of the following values:
·     test-then-set—Performs a validation test before setting the configuration on the system. If the validation test fails, the <edit-config> operation is not performed. This is the default test-option value.
·     set—Performs the set operation without validation.
·     test-only—Performs validation without the set operation. If syntax verification is passed, the device returns a success message. If syntax verification fails, the device returns an error message.
Test the configuration for an interface:
  <edit-config>
    <target>
      <running/>
    </target>
    <test-option>test-only</test-option>
          <Interfaces>
            <Interface>
               </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </config>
  </edit-config>
</rpc>
action
Performs non-configuration actions, for example, the reset action.
Clear all interface statistics data:
  <action>
      <Ifmgr>
            <ClearAllIfStatistics>
                <Clear>
                </Clear>
        </ClearAllIfStatistics>
      </Ifmgr>
    </top>
  </action>
</rpc>
About responses to data retrieval requests
The following information describes the responses to data retrieval requests, including <get>, <get-bulk>, <get-config>, and <get-bulk-config> requests.
Returning data in tables, rows, or columns
General XML formats for data retrieval requests
The following is the general XML format for <get-> and <get-bulk> requests:
<?xml version="1.0" encoding="UTF-8" ?>
  <getoperation>
    <filter>
      </top>
    </filter>
  </getoperation>
</rpc>
The following is the general XML format for <get-config> and <get-bulk-config> requests:
  <getoperation>
    <source>
      <running/>
    </source>
    <filter>
      </top>
    </filter>
  </getoperation>
</rpc>
Replace the getoperation argument with get, get-bulk, get-config, or get-bulk-config.
Use the <filter> element to identify data of interest.
Usage of the <filter> element
The <filter> element can filter data by module, submodule, table, or column. Depending on the filter you use, the device returns data in tables, rows, or columns.
Retrieving data in tables
·     To retrieve data from all modules (submodules), do not specify any modules (or submodules) in the <filter> element. To retrieve data from only one module (submodule), specify that module (or submodule) in the <filter> element.
·     To retrieve data from all tables for the specified module, do not specify a table. To retrieve data from only one table for a module, specify that table.
Retrieving data in rows
·     To retrieve data from all rows of a table, do not specify any column names in that table.
·     To retrieve data in a row for all columns in a table, specify the row-specific index value in the index column for that table. If the table has multiple index columns, specify all of them in the request.
·     To retrieve data in a row for some of the columns in a table, specify the row-specific index column for that table and the columns of interest. If the table has multiple index columns, specify all of them in the request.
Retrieving data in columns
If a retrieval request does not specify all index columns in a multi-index table, the device returns data in all rows for all index columns.
If a <get-bulk> request specifies an incomplete set of discrete index column nodes for data retrieval from a multi-index table, the device processes the request as follows:
·     Uses the leading consecutive index column nodes as the start delimiters for the retrieval operation. The device retrieves data entries starting from the one next to the entry identified by the start delimiters.
·     Uses the remaining index column nodes as filtering criteria to identify data entries to retrieve.
For example, a multi-instance table has five index columns (A, B, C, D, and E). If the <get-bulk> request specifies all the index columns except column C, the device uses A and B as the start delimiters and uses D and E as filtering criteria to identify data of interest:
·     Searches the table starting from the entry next to the one identified by A and B.
·     Returns values in each index column that are in the same row as the values specified for columns D and E.
If a <get> request contains an incomplete set of indexes, the server uses all index columns as filtering criteria. The returned values in each index column will be those in rows that contain all the specified index column values.
Returning empty data to a data retrieval request
The device returns empty data to a data retrieval request in the following situations:
·     The target modules have not started.
·     The client has no access to the requested targets.
·     The filter excludes all data.
·     Non-format constraints are violated.
·     The target tables in configuration retrieval requests contain only default settings.
·     The target tables are not supported on the target device.
Impact of RBAC on data retrieval results
If the NETCONF client does not have read access to a table, the device does not return data in that table.
If the NETCONF client does not have read access to a column, do not include that column in the request. The device can return data from read-accessible columns if the request does not contain read-inaccessible column nodes. If the request contains an explicitly specified read-inaccessible column node, the device will not return data from the target table.
If the NETCONF client does not have read access to the object instance at the specified index, the device does not return the object instance when it performs a <get> or <get-config> operation. The device skips the row when it performs a <get-bulk> or <get-bulk-config> operation.
Impact of module-specific filters on data retrieval
Some modules provide module-specific filtering criteria for you to do more complicated filtering than with standard filtering criteria. You can set a filter as an attribute in row name elements for data retrieval from a multi-instance table or in the table name element for data retrieval from a single-instance table.
The following sample request includes a filter attribute in the row name element to retrieve data from the Ipv4Routes table of the Route module.
  <Route>
    <Ipv4Routes>
      <RouteEntry h3c:filter=' ip 1.1.1.1' xmlns:h3c='http://www.h3c.com/netconf/base:1.0' >
      </RouteEntry>
    </Ipv4Routes>
  </Route>
The device returns data that matches the criteria defined by all filters, including module-specific filters and standard filters.
For information about the availability of module-specific self-defined filters, see the NETCONF XML API references for that module.
Comware NETCONF data filtering
Data filtering methods
To retrieve only data of interest, use a filter when you perform a data retrieval operation (<get>, <get-bulk>, <get-config>, or <get-bulk-config>). You can filter data by doing an exact match, regular expression match, or conditional match.
If multiple types of filters apply to an element, only one of them takes effect. The device selects the filter to apply in order of exact match, regular expression match, and conditional match.
Exact match
When you define a filter in a request, specify an element value or an attribute for exact match. If both types of filtering criteria are present, the device preferentially uses the element value for exact match.
If multiple elements are set, the device returns data that match all of them. The device responds a success message only if it has found data that fully matches all the specified criteria.
The following is a sample request that retrieves the configuration and state data from all interfaces in up state. The request includes the <AdminStatus> element in the subtree filter and sets the element to 2.
  <get>
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
            <Interface>
              <AdminStatus>2</AdminStatus>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
Alternatively, you can include the AdminStatus="2" attribute name-value pair in the <Interface> row name element tag for the same purpose, as shown below:
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface data:AdminStatus="2" />
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
Regular expression match
About regular expressions
To do more sophisticated filtering on an element than with exact match, set a regExp attribute in the element tag. You can use regular expressions to match various types of data, including integers, date and time values, strings, IPv4 addresses, IPv4 masks, IPv6 addresses, MAC addresses, OIDs, and time zones.
Comware depends on libraries such as ucLibC and gLibC to handle regular expressions. Differences might exist between libraries. As a best practice to ensure successful regular expression parsing, avoid using overcomplicated regular expressions.
For example, the following request uses a regular expression to retrieve interface descriptions that contain only letters in uppercase:
<rpc message-id="1-0" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" >
  <get-config>
    <source>
      <running/>
    </source>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description h3c:regExp="^[A-Z]*$" />
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-config>
</rpc>
Table 21 shows the metacharacters that you can use to build a regular expression.
Table 21 Commonly used metacharacters for regular expressions
Metacharacter
Matches lines that begin with the character next to the caret sign (^).
The ^u pattern matches all lines that begin with the u character. The pattern does not match lines that begin with Au.
Matches lines that end with the character that precedes the dollar ($) sign.
The u$ pattern matches all lines that end with the u character. The pattern does not match lines that end with uA.
Matches any single character.
The .s matches as and bs.
Matches zero or more occurrences of the character that precedes the asterisk (*) sign.
·     The zo* pattern matches z and zoo.
·     The (zo)* pattern matches zo and zozo.
Matches one or more occurrences of the character or character string that precedes the plus (+) sign.
The zo+ pattern matches zo and zoo, but not z.
Matches the string on either side of the vertical bar (|).
The def|int pattern matches lines that contain def or int.
Matches the string in the parentheses, typically used together with the plus sign (+) or asterisk sign (*).
The (123A) pattern matches 123A. The 408(12)+ pattern matches 40812 and 408121212, but not 408.
\index
Matches the preceding strings and then the repetition of a particular string. You must enclose the preceding strings each in a pair of parentheses. The strings are each indexed with a number starting from 1, from left to right. To match one repetition of a string at a particular index, specify the index number for that string.
For example, the (string)\1 pattern matches stringstring. The (string1)(string2)\2 matches string1string2string2. The (string1)(string2)\1\2 pattern matches string1string2string1string2.
Matches any characters or characters in a hyphenated range in the brackets.
·     The [16A] pattern matches strings that contain 1, 6, or A.
·     The [1-36A] pattern matches strings that contain 1, 2, 3, 6, or A. The hyphen (-) represents a range.
To match the right bracket character (]), put it immediately after the [ metacharacter, in the []string] format. This constraint does not apply to the left bracket character ([).
Matches a string that contains characters not in the brackets. A matching string can contain characters in the brackets, as long as it contains a minimum of one character not in the brackets.
The [^16A] pattern matches strings that contain one or more characters except for 1, 6, or A. For example, the [^16A] pattern matches abc, m16, but not 1, 16, or 16A.
{n}
Matches the preceding character n times. The n argument represents a non-negative integer.
The o{2} pattern matches food, but not Bob.
{n,}
Matches the preceding character a minimum of n times. The n argument represents a non-negative integer.
The o{2,} pattern matches foooood, but not Bob.
{n,m}
Matches the preceding character n to m times or more. The n and m arguments represent non-negative integers and the value for n must be equal to or less than the value for m.
The o{1,3} pattern matches fod, food, and foooood, but not fd.
Matches strings that start with the pattern following \<.
A string that contains the pattern is also a match if the characters that precede the pattern are not digits, letters, or underscores.
The \<do pattern matches domain and doa.
Matches strings that end with the pattern preceding \>.
A string that contains the pattern is also a match if the characters that follow the pattern are not digits, letters, or underscores.
The do\> pattern matches undo and cdo.
\b
Matches words that start with the pattern following \b or end with the pattern preceding \b.
The er\b pattern matches never, but not verb.
The \ber pattern matches erase, but not verb.
\B
Matches a word that contains the pattern preceding \B but does not start or end with the pattern.
The er\B pattern matches verb, but not never.
\w
Matches a character that is a digit, letter, or underscore. It is identical to [A-Za-z0-9_].
The v\w pattern matches vlan and services.
\W
Matches a character that is not a digit, letter, or underscore. It is identical to [^A-Za-z0-9_].
The \Wa pattern matches -a, but not 2a or ba.
Escapes the character that follows the back slash(\). To have the device treat a special character listed in this table as a literal character, precede that character with a back slash.
·     The \\ pattern matches strings that contain \.
·      The \^ pattern matches strings that contain ^.
·     The \\b pattern matches strings that contains \b.
Example: Using a regular expression to filter data
Retrieve all data entries that contain a colon (:) in the Description column of the Interfaces table in the Ifmgr module.
# Enter XML view.
<Sysname> xml
# Exchange capability sets. Copy and paste the following request message to the client:
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <capabilities>
    <capability>
    </capability>
  </capabilities>
</hello>
# Retrieve all data entries that contain a colon (:) in the Description column of the Interfaces table in the Ifmgr module. Copy and paste the following request message to the client:
<?xml version="1.0"?>
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0">
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <Description  reg:regExp=":" />
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the server responds with the list of interface data entries that contain a colon in their interface descriptions.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0" message-id="100">
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <IfIndex>2681</IfIndex>
            <Description>Ten-GigabitEthernet1/0/49:1 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2682</IfIndex>
            <Description>Ten-GigabitEthernet1/0/49:2 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2683</IfIndex>
            <Description>Ten-GigabitEthernet1/0/49:3 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2684</IfIndex>
            <Description>Ten-GigabitEthernet1/0/49:4 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2685</IfIndex>
            <Description>Ten-GigabitEthernet1/0/50:1 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2686</IfIndex>
            <Description>Ten-GigabitEthernet1/0/50:2 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2687</IfIndex>
            <Description>Ten-GigabitEthernet1/0/50:3 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2688</IfIndex>
            <Description>Ten-GigabitEthernet1/0/50:4 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2689</IfIndex>
            <Description>Ten-GigabitEthernet1/0/51:1 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2690</IfIndex>
            <Description>Ten-GigabitEthernet1/0/51:2 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2691</IfIndex>
            <Description>Ten-GigabitEthernet1/0/51:3 Interface</Description>
          </Interface>
          <Interface>
            <IfIndex>2692</IfIndex>
            <Description>Ten-GigabitEthernet1/0/51:4 Interface</Description>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
Conditional match
About conditional match
Regular expressions are intended for character string matching. To filter data based on logical operations on numbers, use conditional match.
To do a conditional match on an element, add the match attribute in the element tag, and set the value for the attribute to be a filtering condition that operates on numbers or strings.
Table 22 Conditional match commands
Operator
Greater than
match=”more:value
Matches values higher than the specified value.
The specified value can be one of the following data types:
·     Any number type.
·     Any date and time type.
·     Any string type.
·     IPv4 address, IPv4 mask, IPv6 address, or MAC address.
·     Time zone.
Less than
match=”less:value
Matches values lower than the specified value.
·     Any number type.
·     Any string type.
·     Time zone.
Not less than
match=”notLess:value
Matches values equal to or higher than the specified value.
·     Any number type.
·     Any string type.
·     Time zone.
Not greater than
match=”notMore:value
Matches values equal to or less than the specified value.
·     Any number type.
·     Any string type.
·     Time zone.
Equal to
match=”equal:value
Matches values equal to the specified value, which can be any data type.
Not equal to
match=”notEqual:value
Matches values not equal to the specified value, which can be any data type.
Include
match=”include:string
Includes the specified string.
The specified string can be any one of the following data types:
·     Any string type.
·     IPv4 address or IPv4 mask.
Exclude
match=”exclude:string
Excludes the specified string.
·     Any string type.
Begin with
match=”startWith:string
Starts with the specified string.
·     Any string type.
·     OID.
End with
match=”endWith:string
Ends with the specified string.
·     Any string type.
For example, send the following NETCONF message to retrieve extension information about entities whose CPU usage is higher than 50%.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" >
  <get>
        <Device>
          <ExtPhysicalEntities>
            <Entity>
              <CpuUsage h3c:match="more:50"></CpuUsage>
            </Entity>
          </ExtPhysicalEntities>
        </Device>
      </top>
    </filter>
  </get>
</rpc>
Example: Performing conditional match to filter data
Retrieve names of the interfaces that have an interface index equal to or higher than 5000.
# Enter XML view.
<Sysname> xml
  <capabilities>
    <capability>
      urn:ietf:params:netconf:base:1.0
    </capability>
  </capabilities>
</hello>
# Retrieve interface names of the interfaces with an interface index equal to or higher than 5000 from the Name column of the Interfaces table in the Ifmgr module. Copy and paste the following request message to the client:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0">
  <get>
        <Ifmgr>
          <Interfaces>
            <Interface>
              <IfIndex nc:match="more:5000"/>
              <Name/>
            </Interface>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get>
</rpc>
Verification
If the requested operation succeeds, the server responds with interface names of the interfaces with an interface index of 5000 or higher.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0" message-id="100">
  <data>
      <Ifmgr>
        <Interfaces>
          <Interface>
            <IfIndex>7241</IfIndex>
            <Name>NULL0</Name>
          </Interface>
          <Interface>
            <IfIndex>7243</IfIndex>
            <Name>Register-Tunnel0</Name>
          </Interface>
        </Interfaces>
      </Ifmgr>
    </top>
  </data>
</rpc-reply>
Filtering instances of a column
Some columns allow you to specify multiple instances of them in one row element for data retrieval. If you apply a filter to such a column, the device returns only matching instances. If no matches are found, the device does not return the row.
Filtering instances of a group (data structure)
For the ease of management, Comware groups columns for the same purpose in data structures. Some of the groups allow you to specify multiple instances of them in one row element for data retrieval. If you apply a filter to such a group, the device returns an instance of the group only if all group members in the instance match the filtering criteria. If no matches are found, the device does not return the row.
Example: Using ncclient for NETCONF-based device configuration and management
The following information uses ncclient for example to describe the generic procedure to establish a NETCONF session with a Comware-based device.
Setting up ncclient
About ncclient
ncclient is a Python library for NETCONF clients. The ncclient library enables easy client-side scripting and application development by offering an intuitive API that maps the XML-encoded nature of NETCONF to Python constructs and idioms.
The following are some of the capabilities available with ncclient:
·     Support for all operations and capabilities defined in RFC 6241.
·     Request pipelining.
·     Asynchronous RPC requests.
·     Keeping XML out of the way unless really needed.
·     Extensible. New transport mappings, capabilities, and operations can be easily added.
Setting up the environment
To use ncclient, install the following software and libraries:
·     Python 2.7 or Python 3.5 (or later).
·     Libraries:
¡     setuptools 0.6 (or later)
¡     Paramiko 1.7 (or later)
¡     lxml 3.3.0 (or later)
¡     libxml2
¡     libxslt
If you are running ncclient in Debian or Ubuntu, you must also install the following libraries, for example, by using aptitude or apt-get:
·     libxml2-dev
·     libxslt1-dev
Installing ncclient
Use either of the following methods to install ncclient:
·     Download and then decompress an ncclient installation package.
Take installing the ncclient-0.6.10.tar.gz installation package in Windows for example.
a.     Decompress the installation package.
b.     Run the cmd command. In the command shell that opens, access the directory that contains the setup.py file.
c.     Execute the python setup.py build command.
d.     Execute the python setup.py install command.
·     Execute the pip install ncclient command to install ncclient by using pip. When you use this method, make sure you have access to the target library source if you are using the default library source or a source on the public network.
Verify that ncclient has been installed:
1.     Execute the cmd command. In the command shell, access the python view.
2.     Execute the import ncclient command.
3.     If you do not receive error messages, you can determine that the installation is successful.
To run a different version of ncclient than the current one, first execute the pip uninstall ncclient command to uninstall the current version of ncclient.
Executing the script
When you use the python command to execute the python script, you must specify the path of the script file. For example, the *.py script files are stored in the C/desktop/examples directory. To execute the script, execute the following command in the C/desktop directory:
[ncclient] $ python examples/*.py
Establishing a NETCONF session
The following information provides an example that uses a Python script to establish a NETCONF session. In this example, a NETCONF over SSH session is established. To establish a NETCONF session:
1.     Configure the target device (the server side) with settings for NETCONF session establishment.
2.     Create a *.py script  and import the dependent libraries.
3.     Call the connection method to establish a NETCONF session over SSH.
Configuring the target device for NETCONF session establishment
To establish a NETCONF over SSH session, configure an SSH user account and enable NETCONF over SSH service on the target device. For more information about the configuration procedure, see "Configuring settings for NETCONF over SSH."
This example sets the username to ssh and sets the password to 00password00connect.
Running a script to establish a NETCONF session
Verify that the NETCONF client (ncclient) can ping the NETCONF server (the target device).
On ncclient, create an SSH connection to the device. Configure the SSH user account to use the username and password set on the target device. In this example, set the username to ssh and set the password to 00password00connect. When you execute the script that calls the connect function, the client connects to the target device to establish a NETCONF session.
If you receive a "No module named XXX" message while the script is running, use the pip install module command to install the missing module.
You can specify connection parameters when you execute the script or in the script file.
To specify connection parameters when executing the script
1.     Create a .py file (for example, demo1.py), and then copy the following code section to the file.
# -*- coding:utf-8 -*-
import sys
from ncclient import manager
from ncclient import operations
def h3c_connection(host, port, user, password):
    return manager.connect(host=host,
                           port=port,
                           username=user,
                           password=password,
                           hostkey_verify = False,
                           device_params={'name':"h3c"},
                           allow_agent = False,
                           look_for_keys = False)
def test_connect(host, port, user, password):
    with h3c_connection(host,port=port,user=user,password=password) as m:
        n = m._session.id
        print("This session id is %s."%(n))
if __name__ == '__main__':
    # test_connect("192.168.56.120", 830, "ssh", "00password00connect ")
    test_connect(sys.argv[1],sys.argv[2],sys.argv[3],sys.argv[4])
Parameter
host
IP address of the target device that acts as the NETCONF server. As a best practice, use the IP address of the management port on the device. In this example, the IP address of the target device is 192.168.56.120.
port
Service port number for the SSH connection. By default, the port number is 830.
username
SSH username. This example sets the username to ssh.
password
SSH password for the user. This example sets the password to 00password00connect.
2.     Execute the cmd command. In the command shell that opens, access the directory that contains the demo1.py file, and then connect to the target device to run the script file:
>python demo1.py 192.168.56.120 830 ssh 00password00connect
Figure 7 shows a successful script execution result.
Figure 7 Successful script execution result
To provide connection parameters in the script file
1.     Create a .py file (for example, demo2.py), and then copy the following code section to the file:
import sys
                           port=port,
                           username=user,
                           password=password,
        n = m._session.id
2.     Execute the cmd command. In the command shell that opens, access the directory that contains the demo2.py file, and then run the script file:
>python demo2.py
Basic device management with ncclient
The following information describes how to use ncclient to perform basic NETCONF operations for device configuration, data retrieval, and event subscription.
To perform a NETCONF operation on a target device from ncclient:
1.     Construct an RPC request for configuration, delete, retrieval, or subscription.
2.     Execute the Python script to send the request.
Constructing an <edit-config> request
Basic procedure
1.     Construct an RPC request. For example, construct an RPC request to create a VLAN. For information about the XML structures for RPC requests, see H3C Comware 7 NETCONF XML API references.
VLAN_RPC = """<config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
                  <VLAN xc:operation="create">
                     <VLANs>
                        <VLANID>
                           <ID>3</ID>
                           <Name>3</Name>
                           <Description>2</Description>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
2.     Configure the operation to perform depending on the purpose:
¡     To have the configuration take effect immediately, request the device to execute the <edit-config> operation on the running configuration datastore, and verify the response message.
rpc_obj = m.edit_config(target='running', config=VLAN_RPC)
_check_response(rpc_obj,'VLAN_MERGE')
¡     To preconfigure the device and then commit the configuration when certain conditions are met, request the device to execute the <edit-config> operation on the candidate configuration datastore, and verify the response message.
rpc_obj = m.edit_config(target=' candidate ', config=VLAN_RPC)
To commit the issued configuration to the running configuration, execute the following line of code:
m.commit()
¡     To run the specified configuration on a trial basis, request the server to execute the <edit-config> operation on the candidate configuration datastore, and verify the response message.
Execute the following line of code to run the configuration for a period of time set by using the timeout timer:
m.commit(confirmed=True, timeout=' 300 ')
To discard changes to the target configuration that have not yet been committed, execute the following line of code:
m.discard_changes()
In this sample script, m is defined as h3c_connection(host,port=port,user=user,password=password).
Sample Python code
Example: Sample Python code for sending an <edit-config> request to create a VLAN
import sys
import logging
log = logging.getLogger(__name__)
# RPC message for VLAN creation.
                     <VLANs>
                        <VLANID>
                           <ID>3</ID>
                           <Name>3</Name>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
# Connect to the target device.
                           port=port,
                           username=user,
                           password=password,
# Examine the RPC response.
def _check_response(rpc_obj, snippet_name):
    print("RPC reply for %s is  %s" % (snippet_name, rpc_obj.xml))
    xml_str = rpc_obj.xml
    if "<ok/>" in xml_str:
        print("%s successful"%snippet_name)
    else:
        print("Cannot successfully execute: %s" % snippet_name)
def test_edit_config_running(host, port, user, password):
    # Create a NETCONF session.
        # Send the RPC request and examine the RPC response.
    test_edit_config_running("192.168.56.120", 830, "ssh", "00password00connect ")
Example: Sample Python code for sending an <edit-config> request to delete VLANs
import sys
import logging
# RPC message for VLAN deletion.
VLAN_RPC_DELETE = """<config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
                  <VLAN xc:operation="delete">
                     <VLANs>
                        <VLANID>
                           <ID>4</ID>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
                           port=port,
                           username=user,
                           password=password,
                           device_params={'name':"h3c"})
        print("%s successful" % snippet_name)
    else:
    with h3c_connection(host, port=port, user=user, password=password) as m:
        rpc_obj = m.edit_config(target='running', config=VLAN_RPC_DELETE)
        _check_response(rpc_obj, 'VLAN_DELETE')
    test_edit_config_running("192.168.56.120", 830, "ssh", "00password00connect")
Constructing a <get> or <get-config> request for data retrieval
Basic procedure
1.     Construct an RPC request and include a filter as needed.
¡     In a <get> request, set the xmlns attribute to http://www.h3c.com/netconf/data:1.0. For example, to retrieve all interface data, use the following RPC request:
IF_GET_RPC = """
                  <Ifmgr>
                     <Interfaces>
                        <Interface></Interface>
                     </Interfaces>
                  </Ifmgr>
               </top>
¡     In a <get-config> request, set the xmlns attribute to http://www.h3c.com/netconf/config:1.0. For example, to retrieve all interface configuration data, use the following RPC request:
IF_GET_CONFIG_RPC = """
                  <Ifmgr>
                     <Interfaces>
                     </Interfaces>
                  </Ifmgr>
               </top>
2.     Send the <get> or <get-config> request to the server for data retrieval.
¡     Call the get API to send the RPC request for the <get> operation and write the response to the specified XML file.
get_reply = m.get(("subtree", IF_GET_RPC)).data_xml
print(get_reply)
with open("%s_get.xml" % host, 'w') as f:
f.write(get_reply)
¡     Call the get or get-config API to send the RPC request for the <get-config> operation and write the response to the specified XML file.
You can call the get or get-config API to perform a <get-config> operation. The device can automatically determine the retrieval operation to perform based on the namespace specified in the request.
To call the get API for interface configuration data retrieval, use the following section of code:
get_reply2 = m.get(("subtree", IF_GET_CONFIG_RPC)).data_xml
print(get_reply2)
with open("%s_getconfig.xml" % host, 'w') as f:
f.write(get_reply2)
To call the get-config API for interface configuration data retrieval, use the following section of code:
c = m.get_config(source='running',filter=('subtree',IF_GET_CONFIG_RPC)).data_xml
with open("%s_getconfig2.xml" % host, 'w') as f:
f.write(c)
Sample Python code
The following is the sample code that sends a < get> or <get-config> request for interface data retrieval:
import sys
import logging
# RPC message for interface configuration and state data retrieval.
IF_GET_RPC = """
                  <Ifmgr>
                     <Interfaces>
                     </Interfaces>
                  </Ifmgr>
               </top>
              <top xmlns="http://www.h3c.com/netconf/config:1.0">
                  <Ifmgr>
                     <Interfaces>
                     </Interfaces>
                  </Ifmgr>
               </top>
                           port=port,
                           username=user,
                           password=password,
def test_get(host, port, user, password):
        n = m._session.id
        # Send the RPC request for the <get> operation and write the response to the specified XML file.
        print(get_reply)
            f.write(get_reply)
        # Call the get API to send the RPC request for the <get-config> operation and write the response to the specified XML file.
        print(get_reply2)
            f.write(get_reply2)
        # Call the get-config API to send the RPC request for the <get-config> operation and write the response to the specified XML file.
            f.write(c)
    test_get("192.168.56.120", 830, "ssh", "00password00connect ")
Constructing a <get-bulk> or <get-bulk-config> request for configuration and state data retrieval
The <get-bulk> and <get-bulk-config> operations are Comware-extended operations. With ncclient, you use the get-bulk and get-bulk-config APIs in the same way as you use the get API.
Basic procedure
For example, the following RPC message sends a <get-bulk> request to retrieve configuration and state data on all interfaces with an index higher than 1536:
RPC_GET_BULK = """
                  <Ifmgr>
                     <Interfaces>
                        <Interface>
                            <IfIndex>1536</IfIndex>
                        </Interface>
                     </Interfaces>
                  </Ifmgr>
               </top>
To perform a <get-bulk-config> operation to retrieve configuration data on all interfaces, use the following RPC request:
RPC_GET_BULK_CONFIG = """
                  <Ifmgr>
                  </Ifmgr>
                  <GRPC>
                  </GRPC>
               </top>
2.     Send the <get-bulk> or <get-bulk-config> request to the server for data retrieval.
¡     To call the get-bulk API to send the <get-bulk> request:
reply = m.get_bulk(filter=('subtree',RPC_GET_BULK))
print(reply)
¡     To call the get-bulk-config API to send the <get-bulk-config> request:
reply = m.get_bulk_config(source= "running", filter=('subtree', RPC_GET_BULK_CONFIG))
print(reply)
Sample Python code
The following is the sample code that sends a < get-bulk> or <get-bulk-config> request for interface data retrieval:
import sys
import logging
# RPC message that requests a <get-bulk> operation to retrieve the interface configuration and state data of interest.
RPC_GET_BULK = """
                  <Ifmgr>
                     <Interfaces>
                        <Interface>
                        </Interface>
                     </Interfaces>
                  </Ifmgr>
               </top>
# RPC message that requests a <get-bulk-config> operation to retrieve the interface configuration data of interest.
                  <Ifmgr>
                  </Ifmgr>
                  <GRPC>
                  </GRPC>
               </top>
                           port=port,
                           username=user,
                           password=password,
def test_get_bulk(host, port, user, password):
        # Send the <get-bulk> request.
        print(reply)
        # Send the <get-bulk-config> request.
        print(reply)
    test_get_bulk("192.168.56.120", 830, "ssh", "00password00connect ")
Constructing an <action> request to perform a non-configuration operation
Basic procedure
1.     Construct an RPC request to perform an <action> operation.
For example, to clear all interface statistics, use the following RPC request:
ACTION_RPC = """
              <rpc message-id="{}" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
                <action>
                    <top xmlns="http://www.h3c.com/netconf/action:1.0">
                        <Ifmgr>
                                <Clear>
                                </Clear>
                          </Ifmgr>
                        </top>
                </action>
              </rpc>
2.     Send the <action> request.
msgid = 100
rpc = ACTION_RPC.format(msgid)
m._session.send(rpc)
time.sleep(2)
Sample Python code
The following is the sample code that sends an <action> request to clear all interface statistics:
import sys
import logging
import  time
# RPC message that clears all interface statistics.
ACTION_RPC = """
                <action>
                        <Ifmgr>
                                <Clear>
                                </Clear>
                          </Ifmgr>
                        </top>
                </action>
              </rpc>
                           port=port,
                           username=user,
                           password=password,
def test_action(host, port, user, password):
        n = m._session.id
        # Send the <action> request.
        msgid = 100
        time.sleep(2)
    test_action("192.168.56.120", 830, "ssh", "00password00connect ")
Constructing a subscription request
Basic procedure
1.     Construct an RPC request to subscribe to an event stream.
# Create a NETCONF subscription.
Rpc4Subscription = """<rpc message-id="{}" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
                <create-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
                    <stream>NETCONF</stream>
                </create-subscription>
            </rpc>
# Subscribe to the Ifmgr event stream.
RPC4Ifmgr = """
    <rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xs="http://www.h3c.com/netconf/base:1.0">
            <stream>Ifmgr</stream>
    </rpc>
2.     Send the subscription request:
# Assign a message ID to the RPC request.
msgid = 100
rpc = Rpc4Subscription.format(msgid)
# Send the subscription request.
m._session.send(RPC4Ifmgr))
3.     Monitor for notifications of the subscribed events.
m.take_notification(block=True,timeout=100)
Sample Python code
The following is the sample code that subscribes to the Ifmgr module for interface events:
import sys
import logging
import time
from ncclient.operations import CreateSubscription
# RPC message that creates a NETCONF subscription.
            </rpc>
# RPC message that subscribes to the Ifmgr event stream.
RPC4Ifmgr = """
    </rpc>
                           port=port,
                           username=user,
                           password=password,
def test_notification(host, port, user, password):
        n = m._session.id
        msgid = 100
        # Monitor for notifications of the subscribed events.
    logging.basicConfig(level=logging.DEBUG)
    test_notification("192.168.56.120", 830, "ssh", "00password00connect ")
Constructing an <xml2cli> request for XML-to-CLI conversion
Basic procedure
1.     Add the xml2cli capability set to the ncclient package.
Edit the file at package_installation_directory\ncclient\devices\h3c.py. Replace the package_installation_directory argument with the ncclient package installation directory. The following is a sample directory:
C:\Users\c23406\AppData\Local\Programs\Python\Python37\Lib\site-packages\ncclient\devices\h3c.py
# Add the xml2cli capability set to the get_capabilities method for the H3cDeviceHandler class.
class H3cDeviceHandler(DefaultDeviceHandler):
    def get_capabilities(self):
        # Just need to replace a single value in the default capabilities
        c = super(H3cDeviceHandler, self).get_capabilities()
        c.append("urn:h3c:params:netconf:capability:h3c-xml2cli:1.0")
        return c
2.     Construct <edit-config> RPC messages:
# Construct an RPC for VLAN creation.
VLAN_MERGE_RPC = """<config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
                  <VLAN xc:operation="merge">
                     <VLANs>
                        <VLANID>
                           <ID>4</ID>
                           <Name>4</Name>
                           <Description>helloword</Description>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
# Construct an RPC for VLAN deletion.
VLAN_DEL_RPC = """<config xmlns:xc="urn:ietf:params:xml:ns:netconf:base:1.0">
                     <VLANs>
                        <VLANID>
                           <ID>4</ID>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
# Construct an RPC for gRPC subscription creation.
GRPC_MERGE_1 = """
               <top xc:operation="merge" xmlns="http://www.h3c.com/netconf/config:1.0">
                  <GRPC xc:operation="merge">
                     <Subscriptions>
                        <Subscription>
                           <SubscriptionName>1</SubscriptionName>
                           <SourceAddress>1.1.1.1</SourceAddress>
                           <SensorProfiles>
                              <SensorProfile>
                                 <SampleInterval>10</SampleInterval>
                              </SensorProfile>
                              <SensorProfile>
                                 <GroupName>2</GroupName>
                                 <SampleInterval>20</SampleInterval>
                              </SensorProfile>
                           </SensorProfiles>
                           <DestinationProfiles>
                              <DestinationProfile>
                              </DestinationProfile>
                                 <GroupName>3</GroupName>
                           </DestinationProfiles>
                        </Subscription>
                     </Subscriptions>
                  </GRPC>
               </top>
            </config>
3.     Establish a NETCONF connection to the device.
                           port=port,
                           username=user,
                           password=password,
4.     Issue the message and export the results to a file.
    i = 1
    if(os.path.exists("%s_xml2cli.xml" % host)):
        os.remove("%s_xml2cli.xml" % host)
    fd = open("%s_xml2cli.xml" % host, 'a')
    fd.write("<root>\n")
    # Establish a NETCONF connection.
        # 2. Send the RPC request and examine the RPC response.
        while True:
            if (i == 1):
                rpc_obj = m.edit_config(target='running', config=VLAN_MERGE_RPC)
                # print(rpc_obj.xml)
            if (i == 2):
                rpc_obj = m.edit_config(target='running', config=VLAN_DEL_RPC)
            if (i == 3):
                rpc_obj = m.edit_config(target='running', config=GRPC_MERGE_1)
            if ((i != 1) and (i != 2) and (i != 3)):
                break
            i = i+1
            # Export to the destination file.
            parseXmlString2File(fd, rpc_obj.xml)
    fd.write("</root>\n")
    fd.close()
Sample Python code
The following is the sample Python code for this example:
import sys
import logging
import xml.etree.ElementTree as ET
from xml.dom import minidom
import time
import os
# Create a vlan.
                     <VLANs>
                        <VLANID>
                           <ID>4</ID>
                           <Name>4</Name>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
# Delete a vlan.
                     <VLANs>
                        <VLANID>
                           <ID>4</ID>
                        </VLANID>
                     </VLANs>
                  </VLAN>
               </top>
            </config>
# merge GRPC
GRPC_MERGE_1 = """
                     <Subscriptions>
                        <Subscription>
                           <SensorProfiles>
                              <SensorProfile>
                              </SensorProfile>
                              <SensorProfile>
                              </SensorProfile>
                           </SensorProfiles>
                        </Subscription>
                     </Subscriptions>
                  </GRPC>
               </top>
            </config>
# Estalbish a connection to the device.
                           port=port,
                           username=user,
                           password=password,
    else:
def parseXmlString2File(fd, xmlstring):
    localtime = time.asctime(time.localtime((time.time())))
    str = "<!--" + time.strftime("%Y-%m-%d %H:%M:%S", time.localtime()) + "--> \n"
    fd.write(str)
    dom = minidom.parseString(xmlstring)
    dom.writexml(fd, "","  ", "\n", "utf-8")
    i = 1
        while True:
            if (i == 1):
            if (i == 2):
            if (i == 3):
                break
            i = i+1
            # Output to the destination file.
    fd.close()
Appendixes
Appendix A  Comware NETCONF operation error messages
Error handling mechanism
·     The NETCONF server stops processing a NETCONF request and returns an error message when it detects that its XML file contains a schema error. Some of the schema checks might be performed against multiple types of constraints. The returned error message differs depending on the violated constraint. For more information about the constraints for a data module, see its XSD schema file.
·     This appendix describes only some of the typical error messages that you might receive.  Some modules might return more data in the error messages.
·     If the value for an element exceeds the limit, the device returns the error message with that value truncated. For example, the 2014-13-18T17:03: string in the error message returned in response to the following request is truncated. To identify the element or attribute that contains the error, use the XPath information.
    <filter>
      <event xmlns="http://www.h3c.com/netconf/event:1.0">
        <Code>SHELL_LOGIN</Code>
      </event>
    </filter>
    <startTime>2014-07-13T17:00:59</startTime>
    <stopTime>2014-13-18T17:03:05</stopTime>
</rpc>
  The value of element '/rpc/create-su
  bscription[1]/stopTime[1]' is invalid. 2014-13-18T17:03: is an invalid value of
  datetime type value.
</error-message>
Common schema errors
Comware performs basic schema checks on XML-encoded NETCONF requests to make sure they are free of syntax errors in most situations.
Table 23 Common schema error messages
Error message
Explanation
Sample error response
Expecting element 'path'.
The mandatory element at the displayed XPath is missing. To resolve the issue, edit the request to include the element.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<error-tag>missing-element</error-tag>
<error-message xml:lang="en">Expecting element '/Envelope/Body[1]/rpc[1]/copy-config[1]/target'.</error-message>
<error-info>
<bad-element>target</bad-element>
</error-info>
</rpc-error>
The element 'a' should have an attribute 'b'.
Attribute b is mandatory for element a. To resolve the issue, edit the request to include the b attribute in the tag of element a.
<error-tag>missing-attribute</error-tag>
<error-message xml:lang="en">The element '/Envelope/Body[1]/rpc[1]' should have an attribute 'message-id'.</error-message>
<error-info>
<bad-element>rpc</bad-element>
<bad-attribute>message-id</bad-attribute>
</error-info>
</rpc-error>
The value of element 'a' is invalid. reason
Value for the element is invalid. To resolve the issue, review the reason and troubleshoot the issue.
Table 24 lists the possible reasons for this issue.
<error-type>application</error-type>
<error-tag>bad-element</error-tag>
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/SNMP[1]/System[1]/AgentStatus[1]' is invalid. The value does not match the enumeration.</error-message>
<error-info>
<bad-element>AgentStatus</bad-element>
</error-info>
</rpc-error>
The value of attribute 'a' for element 'b' is invalid. reason
When you receive this message, review the provided reason and take action to resolve the issue.
<error-tag>bad-attribute</error-tag>
<error-message xml:lang="en">The value of attribute 'count' for element '/Envelope/Body[1]/rpc[1]/get-bulk[1]/filter[1]/top[1]' is invalid. aa is an invalid value of unsignedInt type value.</error-message>
<error-info>
<bad-element>top</bad-element>
<bad-attribute>count</bad-attribute>
</error-info>
</rpc-error>
The number of occurrences of element '%s/%s' is invalid.
The number of occurrences of the displayed element is incorrect.
<error-message xml:lang="en">The number of occurrences of element '/Envelope/Body[1]/rpc[1]/get-config[1]/filter[1]/top[1]/SecurityZone[1]/Interfaces[1]/Interface[1]/ZoneName' is invalid.</error-message>
<error-info>
<bad-element>ZoneName</bad-element>
</error-info>
</rpc-error>
Unexpected element '%s'.
The element is placed incorrectly. To resolve the issue, examine the applicable XML structure and move the element to the correct location.
<error-message xml:lang="en">Unexpected element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/Device[1]/SummerTime[1]'.</error-message>
 <error-info>
<bad-element>SummerTime</bad-element>
</error-info>
</rpc-error>
Unexpected attribute '%s' of element '%s'.
The element must not contain the attribute. To resolve the issue, remove the attribute from the element tag.
<error-tag>unknown-attribute</error-tag>
<error-message xml:lang="en">Unexpected attribute 'match' of element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/SNMP[1]/System[1]/AgentStatus[1]'.</error-message>
<error-info>
<bad-attribute>match</bad-attribute>
</error-info>
</rpc-error>
The child elements of '%s' are invalid.
The element contains invalid child elements.
<error-message xml:lang="en">The child elements of '/Envelope/Body[1]' are invalid.</error-message>
<error-info>
<bad-element>Body</bad-element>
</error-info>
</rpc-error>
Element '%s' can not have a textual child element.
The element cannot contain textual child elements. To resolve this issue, remove textual child elements.
<?xml version="1.0" encoding="UTF-8"?><rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101"><rpc-error><error-type>rpc</error-type><error-tag>bad-element</error-tag><error-severity>error</error-severity><error-message xml:lang="en">Element '/rpc' can not have a textual child element.</error-message><error-info><bad-element>rpc</bad-element></error-info></rpc-error></rpc-reply>
Element '%s' can not have a child element.
The element cannot contain child elements. To resolve the issue, remove all child elements from the element.
<error-message xml:lang="en">Element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/License[1]/Systems[1]/System[1]/Max[1]' can not have a child element.</error-message>
<error-info>
<bad-element>Max</bad-element>
</error-info>
</rpc-error>
Table 24 Common reasons for schema errors
Reason
Explanation/action
value is an invalid value of type type value.
The value for the element or attribute is not valid for the XSD data type.
·     value—Represents the value specified in the request for the element or attribute. The device would return the error message with the value truncated if it exceeds the length limit.
·     type—Data type required for the element or attribute.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/action[1]/top[1]/License[1]/Operations[1]/Operation[1]/DeviceNode[1]/Chassis[1]' is invalid. 12345678901234565 is an invalid value of unsignedShort type value.</error-message>
<error-info>
<bad-element>Chassis</bad-element>
</error-info>
</rpc-error>
%s cannot be empty.
You must specify a value for the element in the request.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/action[1]/top[1]/License[1]/Operations[1]/Operation[1]/OpType[1]' is invalid. unsignedInt cannot be empty.</error-message>
<error-info>
<bad-element>OpType</bad-element>
</error-info>
</rpc-error>
The value does not match the regular expression.
The value does not match the regular expression defined in the XSD schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/action[1]/top[1]/License[1]/Operations[1]/Operation[1]/OpTarget[1]/ActivationKey[1]' is invalid. The value does not match the regular expression.</error-message>
<error-info>
<bad-element>ActivationKey</bad-element>
</error-info>
</rpc-error>
The element value does not match any one of the enumeration options defined in the XSD schema file.
<error-info>
</error-info>
</rpc-error>
The length must be equal to %s.
Examine the element value and make sure its length is equal to the length defined in the XSD schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Syslog[1]/LogHosts[1]/Host[1]/VRF[1]' is invalid. The length must be equal to 2.</error-message>
<error-info>
<bad-element>VRF</bad-element>
</error-info>
</rpc-error>
The total digit length must be equal to %s.
Examine the element value and make sure the number of digits in the value is compliant with the XSD scheme file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Syslog[1]/LogHosts[1]/Host[1]/VRF[1]' is invalid. The total digit length must be equal to 2.</error-message>
<error-info>
</error-info>
</rpc-error>
The length must be less than or equal to %s.
The length of the element value exceeds the maximum length defined in the XSD schema file for maxLength.
To resolve the issue, change the value to be shorter.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/action[1]/top[1]/License[1]/Operations[1]/Operation[1]/OpTarget[1]/ActivationFile[1]' is invalid. The length must be less than or equal to 255.</error-message>
<error-info>
<bad-element>ActivationFile</bad-element>
</error-info>
</rpc-error>
The length must be greater than or equal to %s.
The element value is shorter than the minimum length defined in the XSD schema file for minLength.
To resolve the issue, change the value to be equal to or longer than the required minimum length.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/action[1]/top[1]/License[1]/Operations[1]/Operation[1]/OpTarget[1]/ActivationKey[1]' is invalid. The length must be greater than or equal to 1.</error-message>
<error-info>
</error-info>
</rpc-error>
The value must be less than %s.
The element value is equal to or exceeds the maximum value defined in the XSD schema file for maxExclusive.
To resolve the issue, change the value to be less than that defined in the schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Syslog[1]/LogHosts[1]/Host[1]/Port[1]' is invalid. The value must be less than 5.</error-message>
<error-info>
<bad-element>Port</bad-element>
</error-info>
</rpc-error>
The value must be greater than %s.
The element value is equal to or less than the minimum value defined in the XSD schema file for minExclusive.
To resolve the issue, change the value to be greater than the minimum value defined in the schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Syslog[1]/LogHosts[1]/Host[1]/Port[1]' is invalid. The value must be greater than 2.</error-message>
<error-info>
</error-info>
</rpc-error>
The value must be less than or equal to %s.
The element value is greater than the maximum value defined in the XSD schema file for maxInclusive.
To resolve the issue, change the value to be equal to or less than that defined in the schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/ACL[1]/Groups[1]/Group[1]/GroupID[1]' is invalid. The value must be less than or equal to 5999.</error-message>
<error-info>
<bad-element>GroupID</bad-element>
</error-info>
</rpc-error>
The value must be greater than or equal to %s.
The element value is less than the minimum value defined in the XSD schema file for minInclusive.
To resolve the issue, change the value to be equal to or greater than the minimum value defined in the schema file.
<error-message xml:lang="en">The value of element '/Envelope/Body[1]/rpc[1]/get[1]/filter[1]/top[1]/ACL[1]/Groups[1]/Group[1]/GroupID[1]' is invalid. The value must be greater than or equal to 2000.</error-message>
<error-info>
</error-info>
</rpc-error>
Common NETCONF operation errors
Table 25 Common NETCONF operation errors
Error message
Explanation
Invalid value.
The value to set is invalid.
To resolve the issue, correct the value to be compliant with the requirements of the target module for the column.
<error-tag>invalid-value</error-tag>
<error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Syslog[1]/LogHosts[1]/Host[1]</error-path>
<error-message xml:lang="en">Invalid value.</error-message>
<error-info>
<Syslog>
<LogHosts>
<Host>
<Address>1.#.1.1</Address>
<VRF>aa</VRF>
</Host>
</LogHosts>
</Syslog>
</top>
</error-info>
</rpc-error>
Can't issue the configuration because of configuration conflict.
The configuration to set conflicts with the existing configuration in the system.
The message differs by module.
Configuration already exists.
This message occurs if the non-default configuration you are creating already exists.
<error-tag>data-exists</error-tag>
<error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/SNMP[1]/Communities[1]/Community[1]</error-path>
<error-message xml:lang="en">Configuration already exists.</error-message>
<error-info>
<SNMP>
<Communities>
<Community>
<Name>123</Name>
<Type>1</Type>
</Community>
</Communities>
</SNMP>
</top>
</error-info>
</rpc-error>
Configuration target does not exist.
The configuration target to set does not exist.
<error-message xml:lang="en">Configuration target does not exist.</error-message>
<error-info>
<SNMP>
<Communities>
<Community>
<Name>12311</Name>
<Type>1</Type>
</Community>
</Communities>
</SNMP>
</top>
</error-info>
</rpc-error>
Configuration does not exist.
This message occurs if the non-default configuration you are deleting does not exist.
<error-tag>data-missing</error-tag>
<error-message xml:lang="en">Configuration does not exist.</error-message>
<error-info>
<SNMP>
<Communities>
<Community>
<Name>1231</Name>
<Type/>
</Community>
</Communities>
</SNMP>
</top>
</error-info>
</rpc-error>
Current session has held the lock.
This message occurs when a NETCONF client attempts to lock the running configuration datastore on which it has locked over the current session.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>protocol</error-type>               <error-tag>lock-denied</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">Current session has held the lock.</error-message>               <error-info>                  <session-id>1</session-id>               </error-info>
</rpc-error>
Unlock failed because no NETCONF lock exists.
This message occurs when the NETCONF client attempts to unlock the running configuration datastore on which it does not have the lock.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>protocol</error-type>               <error-tag>operation-failed</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">Unlock failed because no NETCONF lock exists.</error-message>            </rpc-error>
Unlock Failed because the lock is not held by current session.
This message occurs when a NETCONF client attempts to release the configuration lock held by another client.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>protocol</error-type>               <error-tag>operation-failed</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">Unlock Failed because the lock is not held by current session.</error-message>            </rpc-error>
Lock failed because the NETCONF lock is held by another session.
This message occurs when one NETCONF client attempts to release the configuration lock held by another client.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>protocol</error-type>               <error-tag>lock-denied</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">Lock failed because the NETCONF lock is held by another session.</error-message>               <error-info>                  <session-id>1</session-id>               </error-info>
</rpc-error>
Can not edit tables with only table names.
This message occurs if a delete request specifies only the table name.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>invalid-value</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Device[1]/Base[1]</error-path>
<error-message xml:lang="en">Can not edit tables with only table names.</error-message>            </rpc-error>
When the delete or remove operation is issued, data cannot be assigned to non-index columns.
Do not specify values for non-index columns in a delete or remove request.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>invalid-value</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Device[1]/Base[1]/HostName[1]</error-path>
<error-message xml:lang="en">When the delete or remove operation is issued, data cannot be assigned to non-index columns.</error-message>            </rpc-error>
To delete or remove data, you must specify a value in the index column element.
               <error-path>/Envelope/Body/rpc/edit-config/config/openconfig-acl:acl/acl-sets/acl-set[name=''][type='ACL_IPV4']/config/description</error-path>
            </rpc-error>
When the create, merge, or replace operation is issued, empty data cannot be assigned to columns.
To create, merge, or replace data, you must specify values in the target column elements.
               <error-message xml:lang="en"> When the create, merge, or replace operation is issued, empty data cannot be assigned to columns.</error-message>
            </rpc-error>
For a <get-bulk> or <get-bulk-config> operation request, a table can't contain both non-index columns and subtables, and it can contain only one subtable.
In a <get-bulk> or <get-bulk-config> request, do not specify both non-index columns and subtables in a table element. In addition, you can include only one subtable in a table element.
<error-tag>operation-not-supported</error-tag><error-severity>error</error-severity>
<error-path>/Envelope/Body[1]/rpc[1]/get-bulk[1]/filter[1]/top[1]/GRPC[1]/Subscriptions[1]/Subscription[1]/SourceAddress[1]</error-path>
<error-message xml:lang="en">For a <get-bulk> or <get-bulk-config> operation request, a table can't contain both non-index columns and subtables, and it can contain only one subtable.</error-message>
</rpc-error>
In a create, merge, or replace request, you must specify values for non-index columns.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>invalid-value</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Fundamentals[1]/WebUI[1]</error-path>
<error-message xml:lang="en">When the create, merge, or replace operation is issued, empty data cannot be assigned to columns.</error-message>            </rpc-error>
The configuration not supported on the specified target.
The target does not support the configuration.
You would also receive this message if you specified a Layer 3 interface when you operated on a table that supports only Layer 2 interfaces.
<error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Ifmgr[1]/Interfaces[1]/Interface[1]/Loopback[1]</error-path>
<error-message xml:lang="en">The configuration not supported on the specified target.</error-message>
<error-info>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>449</IfIndex>
<Loopback>1</Loopback>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</error-info>
</rpc-error>
The session does not have the privilege to process the request.
The NETCONF client does not have sufficient privilege to perform the operation.
<error-tag>resource-denied</error-tag>
<error-severity>error</error-severity><error-path>/rpc/edit-config[1]/config[1]/top[1]/Device[1]/Base[1]/TimeZone[1]/ZoneName[1]</error-path>
<error-message xml:lang="en">The session does not have the privilege to process the request.</error-message>
<error-info>
<Device>
<Base>
<TimeZone>
<ZoneName>1</ZoneName>
</TimeZone>
</Base>
</Device>
</top>
</error-info>
</rpc-error>
Resources are insufficient for processing the request.
The system does not have sufficient resources for the requested operation.
For example, you might receive this message when you add a data instance to a column after the limit on the number of instances in that column has reached.
<error-message xml:lang="en"> Resources are insufficient for processing the request..</error-message>
<error-info>
<Device>
<Base>
<TimeZone>
</TimeZone>
</Base>
</Device>
</top>
</error-info>
</rpc-error>
The system does not support this operation.
The server does not support the requested operation.
Operation failed.
Any error other than those explicitly stated.
<error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/SNMP[1]/System[1]</error-path>
<error-message xml:lang="en">Operation failed.</error-message>
<error-info>
<SNMP>
<System>
<AgentStatus>disable</AgentStatus>
</System>
</SNMP>
</top>
</error-info>
</rpc-error>
The session cannot kill itself.
You cannot force the session you are using to close.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>invalid-value</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">The session cannot kill itself.</error-message>            </rpc-error>
Hello is required before any other operation.
You must send a <hello> message before you create a subscription.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xs="http://www.h3c.com/netconf/base:1.0" message-id="100">
<error-message xml:lang="en">Hello is required before any other operation.</error-message>
</rpc-error>
</rpc-reply>]]>]
Event subscription already exists.
The NETCONF client has subscribed to the event stream.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="100">
<error-message xml:lang="en">Event subscription already exists.</error-message>
</rpc-error>
</rpc-reply>
The event stream name can't be empty.
Edit the subscription request to specify the name of the target event stream in the <stream> element.
<error-message xml:lang="en">The event stream name can't be empty.</error-message>
</rpc-error>
</rpc-reply>
You don't have the privilege to perform this NETCONF operation.
The NETCONF client does not have sufficient privilege to create a subscription.
To resolve the issue, you must configure the target device to assign the required access permission to the user account used by the client.
<error-tag>access-denied</error-tag>
<error-message xml:lang="en">You don't have the privilege to perform this NETCONF operation.</error-message>
</rpc-error>
</rpc-reply>
You don't have the privilege to subscribe the event-name event.
The NETCONF client does not have sufficient privilege to subscribe to the event.
To resolve the issue, you must configure the target device to assign the required event access permission to the user account used by the client.
<error-message xml:lang="en">You don't have the privilege to subscribe the InterfaceEvent event.</error-message>
</rpc-error>
</rpc-reply>
The element stopTime is required.
Add the <stopTime> element in the subscription request to specify the end time of the subscribed period.
<error-message xml:lang="en">The element stopTime is required.</error-message>
<error-info><bad-element>stopTime</bad-element>
</error-info>
</rpc-error>
</rpc-reply>
The startTime should be earlier than the current system time.
Examine the start time of the subscribed period in the <startTime> element of the subscription request. Make sure it is later than the current time.
<error-message xml:lang="en">The startTime should be earlier than the current system time.</error-message>
<error-info>
<bad-element>startTime</bad-element>
</error-info>
</rpc-error>
</rpc-reply>]]>]
The startTime should be earlier than the stopTime.
Examine the start time of the subscribed period in the <startTime> element of the subscription request. Make sure it is later than the end time in the <stopTime> element.
<error-message xml:lang="en">The startTime should be earlier than the stopTime.</error-message>
<error-info>
</error-info>
</rpc-error>
</rpc-reply>
The stopTime should be later than the current system time.
Examine the end time of the subscribed period in the <stopTime> element of the subscription request. Make sure it is later than the current time.
<error-message xml:lang="en">The stopTime should be later than the current system time.</
error-message>
<error-info>
</error-info>
</rpc-error>
</rpc-reply>]]>]
Maximum number of NETCONF sessions exceeded.
The maximum number of NETCONF sessions has exceeded. To establish a new NETCONF session, you must force a session to close or wait for an existing session to close.
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
<env:Body>
<env:Fault>
<env:Code>            <env:Value>env:Receiver</env:Value>         </env:Code>
<env:Reason>
<env:Text xml:lang="en"> Maximum number of NETCONF sessions exceeded.</env:Text>         </env:Reason>
</env:Fault>
</env:Body>
</env:Envelope>
Operation failed. flash:/startup.cfg can't be overwritten because the OverWrite flag is false.
The <save> operation failed because the OverWrite flag of the target file is false.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>operation-failed</error-tag>               <error-severity>error</error-severity>               <error-message xml:lang="en">Operation failed. flash:/startup.cfg can't be overwritten because the OverWrite flag is false.</error-message>            </rpc-error>
Failed to set HTTPS server status because the specified SSL server policy doesn't exist.
N/A
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>operation-failed</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/Fundamentals[1]/WebUI[1]/HTTPS[1]/SSLPolicyName[1]</error-path>               <error-message xml:lang="en">Failed to set HTTPS server status because the specified SSL server policy doesn't exist.</error-message>               <error-info>
<top xmlns="http://www.h3c.com/netconf/config:1.0">                     <Fundamentals>                        <WebUI>                           <HTTPS>                              <SSLPolicyName>hjhkjhkj</SSLPolicyName>                           </HTTPS>
</WebUI>                     </Fundamentals>
</top>
</error-info>
</rpc-error>
The replace operation does not support incremental-edit.
You cannot use the incremental attribute in the <edit-config> request for a replace operation.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>operation-not-supported</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/VLAN[1]/TrunkInterfaces[1]/Interface[1]</error-path>               <error-message xml:lang="en">The replace operation does not support incremental-edit.</error-message>            </rpc-error>
The incremental column must have value.
You must specify a value for a column if you need to perform an incremental edit operation on it.
<rpc-error xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">               <error-type>application</error-type>               <error-tag>invalid-value</error-tag>               <error-severity>error</error-severity>               <error-path>/Envelope/Body[1]/rpc[1]/edit-config[1]/config[1]/top[1]/VLAN[1]/TrunkInterfaces[1]/Interface[1]/PermitVlanList[1]</error-path>               <error-message xml:lang="en">The incremental column must have value.</error-message>            </rpc-error>
The value of attribute 'count' is invalid. Ancestor node index is incomplete.
If you specify the count attribute in a subtable node element in a <get> or <get-bulk> request, you must specify the index columns for all its ancestor nodes.
   <error-path>/Envelope/Body[1]/rpc[1]/get-bulk[1]/filter[1]/top[1]/GRPC[1]/Subscriptions[1]/Subscription[1]/DestinationProfiles[1]</error-path>
   <error-message xml:lang="en">The value of attribute 'count' is invalid. Ancestor node index is incomplete.</error-message>
</rpc-error>
The NETCONF_MONITOR_EXTENSION stream must include filter information.
Edit the subscription request to include filter information.
<error-message xml:lang="en">The NETCONF_MONITOR_EXTENSION stream must include filter information.</error-message>
</rpc-error>
</rpc-reply>
The NETCONF_MONITOR_EXTENSION stream must have NetconfMonitor information.
Edit the subscription request to include NetconfMonitor information.
<error-message xml:lang="en">The NETCONF_MONITOR_EXTENSION stream must have NetconfMonitor information.</error-message>
</rpc-error>
</rpc-reply>]]>]
Incorrect name for Stream NETCONF_MONITOR_EXTENSIO.
Examine the event stream name for an error.
<error-tag>operation-not-supported</error-tag><error-severity>error</error-severity><error-message xml:lang="en">Incorrect name for Stream NETCONF_MONITOR_EXTENSIO.</error-message>
</rpc-error>
</rpc-reply>
The subscribing to event time must be in the range of 1970 to 2035.
Examine the start or end time of the subscribed period and make sure they are in the valid time period.
<error-message xml:lang="en">The subscribing to event time must be in the range of 1970 to 2035.</error-message>
<error-info>
</error-info>
</rpc-error>
</rpc-reply>
The value %s of attribute 'match' is invalid.
The value for the match attribute is invalid. For more information about setting the match attribute, see “Conditional match.”
               <error-path>/Envelope/Body/rpc/get/filter/top/Device/ExtPhysicalEntities/Entity[PhysicalIndex='']/MAC</error-path>
               <error-message xml:lang="en">The value 50 of attribute 'match' is invalid.</error-message>
            </rpc-error>
The value of the ColumnValue parameter for column HostName can't be empty.
When you send a subscription request, you must make sure all columns in it have a value.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="16">
  <rpc-error>
    <error-message xml:lang="en">The value of the ColumnValue parameter for column HostName can't be empty.</error-message>
  </rpc-error>
</rpc-reply>
Unexpected element:
The element is misplaced. This issue might occur because the element has not been defined or its parent element is missing.
               <error-tag>unknown-element</error-tag>
               <error-path>/Envelope/Body/rpc/edit-config/config/openconfig-acl:acl/acl-sets/acl-set[name='test01'][type='ACL_IPV4']/config/hello</error-path>
               <error-message xml:lang="en">Unexpected element 'http://openconfig.net/yang/acl':'hello' under element "/Envelope/Body/rpc/edit-config/config/openconfig-acl:acl/acl-sets/acl-set[name='test01'][type='ACL_IPV4']/config"</error-message>
               <error-info>
                  <bad-element>hello</bad-element>
               </error-info>
            </rpc-error>
Incorrect column name for column %s of XPath %s.
This issue occurs if the column name specified for the <ColumName> element in a NetconfMonitor subscription request cannot be found at the specified XPath.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="33">
  <rpc-error>
    <error-message xml:lang="en">Incorrect column name for column 1 of XPath Device/Base.</error-message>
  </rpc-error>
</rpc-reply>
XPath %s is wrong. Valid format is ModuleName[/SubmoduleName]/TableName.
The subscription request specifies an incorrect XPath.
<?xml version="1.0" encoding="utf-8"?>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="34">
  <rpc-error>
    <error-message xml:lang="en">XPath Base is wrong. Valid format is ModuleName[/SubmoduleName]/TableName.</error-message>
  </rpc-error>
</rpc-reply>
Appendix B  Comware schema built-in data types
Some data cannot be described in simple schema data types. For the ease of validation, Comware uses built-in data types to describe these data. Values of these data types are still strings on the client end. However, when the server validates them, the server will treat them as values of built-in data types. The built-in data types are defined in basetype.xsd. Table 26 lists the Comware built-in schema data.
Table 26 Comware schema built-in data types
Name
OID
32-bit integer in dotted notation. The maximum length is 128 bytes.
_Ipv6Address
IPv6 address format conventions apply.
IPV6_ADDR_PREFIX
IPv6 prefix format conventions apply.
_PortRange
A comma-separated list of items in a string. An item can be a single number or a range of number, for example, 1,3-9,11,12. The string cannot contain spaces in the middle or at its two ends, or any other characters than numbers, commas (,), and hyphens (-). The numbers must be presented in ascending order. The value range for numbers is 0 to 65535.
_VlanRange
A comma-separated list of items in a string. An item can be a single number or a range of numbers, for example, 1,3-9,11,12. The string cannot contain spaces in the middle or at its two ends, or any other characters than numbers, commas (,), and hyphens (-). The numbers must be presented in ascending order. The value range for numbers is 1 to 4094.
_Ipv4Mask
IPv4 mask format conventions apply.
_IfIndexRange
A comma-separated list of items in a string. An item can be a single number or a range of number, for example, 1,3-9,11,12. The string cannot contain spaces in the middle or at its two ends, or any other characters than numbers, commas (,), and hyphens (-). The numbers must be presented in ascending order. The value range for numbers is 1 to 0xBFFFFFFF.
Appendix C  Treatment of Boolean or boolean values in Comware
The implementation of boolean differs by system. Some systems accept only true and false as boolean values while some others also accept 1 and 0 in addition to true and false. To be compatible with different NETCONF clients, Comware accepts true, false, 1, and 2 as valid Boolean (or boolean) values. Value 1 is identical to true and value 0 is identical to false.
Comware NETCONF API references list only true and false as Boolean (or boolean) values. In practice, you can use 1 and 0 instead.
Appendix D  Common issues and recommendations
Scenario-dependent columns
Some tables might contain columns that are supported only in some scenarios. When the server performs a delete or remove operation on these columns, the server always returns a success, whether they are supported or not. This mechanism helps suppress error messages that would otherwise be returned when the request contains only the index column.
IP and mask as indexes
Be careful when you operate on a table that uses the IP address and mask as table indexes.
When the server receives a request to operate on such a table, the server operates on the IP address and mask to identify the target data entry. This operation might evaluate to an IP address different from the one specified in the request.
For example, send a request with the IP address and mask set to 192.168.1.1 and 255.255.0.0, respectively. Operation on the IP address and mask will evaluate to 192.168.0.0.
Order of same-level elements in a request
You can sort same-level elements in a <get>, <get-config>, <get-bulk>, <get-bulk-config>, <edit-config>, or <action> request in any order if they are not in repeatable group elements. If they are in repeatable group elements, you must sort their order in strict compliance with the XML structure for the target table.
As a best practice to ensure a successful request, always sort the elements in the request in compliance with the XML structure for the target table.
For example, the XML structure for the IRF/IRFPorts table contains a repeatable group node called <Interface>, as shown below:
<IRF>
  <IRFPorts>
    <IRFPort>
      <MemberID></MemberID>
      <Port></Port>
      <Interface>
        <IfName></IfName>
        <MDCName></MDCName>
        <Mode></Mode>
      </Interface>
    </IRFPort>
  </IRFPorts>
</IRF>
In this structure, the <Interface> group element contains the <IfName>, <MDCName>, and <Mode> elements. When you construct a request, you must order these group member elements in compliance with the XML structure for the table:
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <edit-config>
    <target>
      <running/>
    </target>
        <IRF>
          <IRFPorts xc:operation="merge">
            <IRFPort>
              <MemberID>1</MemberID>
              <Port>2</Port>
              <Interface>
                <IfName>Ten-GigabitEthernet1/0/48</IfName>
                <Mode>1</Mode>
              </Interface>
              <Interface>
                <IfName>Ten-GigabitEthernet1/0/49</IfName>
                <Mode>1</Mode>
              </Interface>
            </IRFPort>
          </IRFPorts>
        </IRF>
      </top>
    </config>
  </edit-config>
</rpc>
  • Become a Partner
  • Partner Resources
