08-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (602.26 KB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 description
1.1.2 display traffic classifier
1.1.3 if-match
1.1.4 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 redirect
1.2.7 remark customer-vlan-id
1.2.8 remark dot1p
1.2.9 remark dscp
1.2.10 remark local-precedence
1.2.11 remark service-vlan-id
1.2.12 remark source-mac
1.2.13 traffic behavior
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 display qos policy
1.3.3 display qos policy global
1.3.4 display qos policy interface
1.3.5 display qos vlan-policy
1.3.6 qos apply policy (interface view)
1.3.7 qos apply policy (user profile view)
1.3.8 qos apply policy global
1.3.9 qos policy
1.3.10 qos vlan-policy
1.3.11 reset qos policy global
1.3.12 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 qos map-table
2.2 端口优先级信任模式配置命令
2.2.1 display qos trust interface
2.2.2 qos trust
2.3 端口优先级配置命令
2.3.1 qos priority
3 流量监管、流量整形和限速
3.1 流量监管配置命令
3.1.1 qos car any
3.2 流量整形配置命令
3.2.1 display qos gts interface
3.2.2 qos gts
3.3 限速配置命令
3.3.1 display qos lr interface
3.3.2 qos lr
4 拥塞管理
4.1 拥塞管理公共配置命令
4.1.1 display qos queue interface
4.2 严格优先级队列配置命令
4.2.1 display qos queue sp interface
4.2.2 qos sp
4.3 加权轮询队列配置命令
4.3.1 display qos queue wrr interface
4.3.2 qos wrr
4.3.3 qos wrr { byte-count | weight }
4.3.4 qos wrr group sp
4.4 加权公平队列配置命令
4.4.1 display qos queue wfq interface
4.4.2 qos bandwidth queue
4.4.3 qos wfq
4.4.4 qos wfq { byte-count | weight }
4.4.5 qos wfq group sp
4.5 队列调度策略配置命令
4.5.1 bandwidth queue
4.5.2 display qos qmprofile configuration
4.5.3 display qos qmprofile interface
4.5.4 qos apply qmprofile
4.5.5 qos qmprofile
4.5.6 queue
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue table
5.1.5 queue
5.1.6 queue weighting-constant
6 聚合CAR
6.1 聚合CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car
6.1.4 reset qos car name
7 端口队列统计
7.1 端口队列统计配置命令
7.1.1 display qos queue-statistics interface outbound
1 QoS策略
1.1  定义类的命令
1.1.1  description
description命令用来配置类的描述信息。
undo description命令用来恢复缺省情况。
未配置类的描述信息。
类视图
text:表示类的描述信息,为1~127个字符的字符串,区分大小写。
多次执行本命令,最后一次执行的命令生效。
# 为类class1配置描述信息。
[Sysname-classifier-class1] description classifier
display traffic classifier命令用来显示类的配置信息。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定成员设备的流分类的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示主用设备的类的配置信息。
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.3  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
表1-2 类的匹配规则取值
取值
acl [ ipv6 | mac ] { acl-number | name acl-name }
定义匹配ACL的规则
·     acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999
·     acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
ACL规则中未指定VPN实例时,表示该规则对非VPN报文和VPN报文均有效
any
定义匹配所有数据包的规则
customer-dot1p dot1p-value&<1-8>
定义匹配内层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-id、vlan-id1、vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
Nest场景下,若报文只携带单层VLAN Tag,请用内层VLAN Tag VLAN ID规则来匹配
destination-mac mac-address
定义匹配目的MAC地址的规则,仅对以太网接口生效
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-4所示
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
protocol protocol-name
定义匹配协议的规则,protocol-name取值为ipipv6
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag 802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
通常情况下(Nest场景除外),若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配
source-mac mac-address
定义匹配源MAC地址的规则,仅对以太网接口生效
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在定义匹配规则(DSCP、VLAN ID、802.1p优先级和IP优先级)时,请注意:
·     一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,类中引用的ACL必须已经存在。
if-match中引用的ACL规则的动作为deny时,则直接忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
在定义匹配类的规则时,如果匹配类的规则之间既有逻辑与,又有逻辑或的关系,请使用以下方式配置。例如,需要定义classA,满足以下关系:规则1 & 规则2 | 规则3,可以这样定义:
·     traffic classifier classB operator and
¡     if-match规则1
¡     if-match规则2
·     traffic classifier classA operator or
¡     if-match规则3
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配QoS本地ID值为3的报文。
[Sysname-classifier-class1] if-match qos-local-id 3
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
未配置类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting { byte | packet }
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为16~160000000。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     不指定cbs参数时,其缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
·     指定cbs参数时,取值范围为128~256000000。
ebs excess-burst-size:超出突发尺寸,单位为byte。
·     配置pir参数后:
¡     如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
¡     如果指定ebs,取值范围0~256000000且必须为512的整数倍。
·     未配置pir参数时,ebs的取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为16~160000000。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 为流行为配置流量监管。报文正常流速为256kbps,承诺突发尺寸为51200bytes,速率大于256kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 256 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定成员设备的流行为的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的流行为的配置信息。
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      -none-
表1-3 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名称及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
Accounting enable
流量统计动作
Filter enable
流量过滤动作
Redirecting
流量重定向相关信息
Mirroring
流量镜像相关信息
none
表示未配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃命中规则的数据包。
permit:允许命中规则的数据包通过,如果本QoS策略中还有其他流分类,则这类数据包可以被继续处理。
# 为流行为database配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加报文的外层VLAN Tag动作。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未配置添加报文外层VLAN Tag动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
slot slot-number:重定向到指定成员设备,slot-number表示设备在IRF中的成员编号。
# 为流行为配置流量重定向动作,重定向到接口GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet 1/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重新标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文CVLAN的动作。
流行为视图
vlan-id:表示重新标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
仅基于接口应用QoS策略时,QoS策略中配置的重新标记报文的CVLAN才会生效。
# 在流行为b1上配置重新标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.8  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级。
undo remark dot1p命令用来恢复缺省情况。
remark dot1p dot1p-value
undo remark dot1p
未配置重新标记报文802.1p优先级。
流行为视图
dot1p-value:802.1p优先级,取值范围为0~7。
仅基于接口、VLAN和全局应用QoS策略时,QoS策略中配置的重新标记报文的802.1p优先级才会生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
1.2.9  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来恢复缺省情况。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文DSCP值的动作。
流行为视图
green:对绿色报文进行重新标记。
red:对红色报文进行重新标记。
yellow:对黄色报文进行重新标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-4所示。
表1-4 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
仅基于接口、VLAN和全局应用QoS策略时,QoS策略中配置的重新标记报文的DSCP值才会生效。
# 重新标记报文的DSCP值为6。
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来恢复缺省情况。
remark local-precedence local-precedence-value
未配置重新标记报文本地优先级的动作。
流行为视图
local-precedence-value:本地优先级,取值范围为0~7。
仅基于仅基于接口入方向、VLAN入方向和全局入方向应用QoS策略时,QoS策略中配置的重新标记报文的本地优先级才会生效。
应用QoS策略重新标记报文到某个本地优先级时,需保证dot1p-lp映射表存在该本地优先级的映射关系,并且避免在应用该QoS策略后修改dot1p-lp映射表中该本地优先级的映射关系。
# 重新标记报文的本地优先级值为2。
remark service-vlan-id命令用来重新标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重新标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
仅基于接口应用QoS策略时,QoS策略中配置的重新标记报文的SVLAN才会生效。
# 在流行为b1上配置重新标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
remark source-mac命令用来配置重新标记报文的源MAC地址。
undo remark source-mac命令用来恢复缺省情况。
remark source-mac mac-address
未配置重新标记报文的源MAC地址。
流行为视图
mac-address:源MAC地址,形式为H-H-H。
# 在流行为behavior1中配置重新标记报文的源MAC地址为600b-038a-a395。
[Sysname-behavior-behavior1] remark source-mac 600b-038a-a395
·     traffic behavior
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
·     display traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [  insert-before before-classifier-name ]
没有为类指定流行为。
QoS策略视图
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
display qos policy命令用来显示QoS策略的配置信息。
user-defined:用户定义QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定成员设备的QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的QoS策略的配置信息。
# 显示用户定义QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
     Behavior: 2
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
表1-5 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
其它显示信息解释请参见表1-1表1-3
display qos policy global命令用来显示基于全局应用QoS策略的配置信息和运行情况。
display qos  policy global [ slot slot-number ] [ inbound | outbound ]
inbound:显示入方向QoS策略的配置信息和运行情况。
outbound:显示出方向QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向QoS策略的配置信息和运行情况。
# 显示基于全局应用通用类型QoS策略的信息。
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-6 display qos policy global命令显示信息描述表
Direction
QoS策略应用的方向
Policy
用户定义的QoS策略名
其它显示信息解释请参见表1-1表1-3
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos policy interface [ interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
slot slot-number:显示指定成员设备指定逻辑接口的QoS策略的配置信息和运行情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备逻辑接口QoS策略的配置信息和运行情况。
# 显示对接口GigabitEthernet1/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示所有接口上QoS策略的配置信息和运行情况。
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/2
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
Interface: GigabitEthernet1/0/4
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: GigabitEthernet1/0/5
        Green action  : pass
表1-7 display qos policy interface命令显示信息描述表
Direction
QoS策略应用的方向
其它显示信息解释请参见表1-1表1-3
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的配置信息和运行情况。
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于VLAN应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方QoS策略的配置信息和运行情况。
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-8 display qos vlan-policy命令显示信息描述表
Direction
QoS策略应用的方向
其它显示信息解释请参见表1-1表1-3
qos apply policy命令用来在接口上应用QoS策略。
undo qos apply policy命令用来取消接口上应用的QoS策略。
undo qos apply policy policy-name { inbound | outbound }
未应用QoS策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:入方向应用QoS策略。
outbound:出方向应用QoS策略。
# 将QoS策略TEST1应用到接口GigabitEthernet1/0/1的出方向上。
[Sysname-GigabitEthernet1/0/1] qos apply policy TEST1 outbound
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
未在User Profile下应用QoS策略。
User Profile视图
inbound:入方向应用QoS策略。
policy-name:策略名,为1~31个字符的字符串。
User Profile被删除将导致其下引用的QoS策略被删除。
User Profile视图下应用的QoS策略不能为空,因为应用空策略的User Profile不能被激活,且QoS策略中的流行为只支持caraccounting动作。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:入方向应用QoS策略。
全局应用的QoS策略对全部流量生效。
# 将QoS策略user1应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.9  qos policy
qos policy命令用来创建一个QoS策略,并进入QoS策略视图。如果指定的QoS策略已经存在,则直接进入QoS策略视图。
undo qos policy命令用来删除一个QoS策略。
qos policy policy-name
undo qos policy policy-name
不存在QoS策略。
如果QoS策略已经被应用,则不允许删除,需要先在应用的位置上取消对QoS策略的应用,然后再使用undo qos policy命令删除。
# 定义一个名为user1的QoS策略。
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:入方向应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除入方向QoS策略的统计信息。
outbound:清除出方向QoS策略的统计信息。
如果未指定清除方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
如果未指定方向,则同时清除出入两个方向QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示优先级映射表的配置情况。
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp ]
表2-1 优先级映射表
优先级映射
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.2  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
2.1.3  qos map-table
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
其它参数请参见表2-1
# 进入802.1p优先级到本地优先级映射表视图。
·     import
2.2  端口优先级信任模式配置命令
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface gigabitethernet 1/0/1
 Port priority information
  Port priority: 4
  Port dscp priority: -
  Port priority trust type: dscp
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
端口优先级信任信息
Port priority
端口优先级
Port dscp priority
改写报文的DSCP优先级的值,-表示未配置修改报文的DSCP优先级的值
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
·     none:不信任任何优先级
2.2.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备不信任报文携带的优先级,会使用端口优先级作为报文的802.1p优先级进行优先级映射。
# 在接口GigabitEthernet1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
·     display qos trust interface
2.3  端口优先级配置命令
2.3.1  qos priority
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority [ dscp ] priority-value
undo qos priority [ dscp ]
端口优先级的缺省值为0;无端口DSCP优先级的缺省值。
priority-value:端口优先级值。不指定dscp时,取值范围为0~7;指定dscp时,取值范围如表2-4所示。
表2-4 端口DSCP优先级取值范围
端口优先级类型
priority-value取值范围
dscp(DSCP优先级)
0~63
# 配置接口GigabitEthernet1/0/1的端口优先级为2。
[Sysname-GigabitEthernet1/0/1] qos priority 2
# 配置接口GigabitEthernet1/0/1的DSCP优先级为20。
[Sysname-GigabitEthernet1/0/1] qos priority dscp 20
3 流量监管、流量整形和限速
3.1  流量监管配置命令
3.1.1  qos car any
qos car any命令用来在User Profile下对所有IP数据包配置流量监管。
undo qos car命令用来取消User Profile下流量监管的配置。
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound }
未配置流量监管。
User Profile视图
inbound:入方向流量监管。
outbound:出方向流量监管。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为16~160000000。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。取值范围为128~256000000。
ebs excess-burst-size:过度突发尺寸,单位为byte,缺省值为0byte。取值范围为0~256000000。
数据流量符合承诺速率时,允许数据包通过;数据流量不符合承诺速率时,丢弃数据包。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 对上线用户user接收的报文进行流量监管。报文正常流速为256kbps,允许51200byte的突发流量通过,速率小于等于256kbps时正常发送,大于256kbps时,报文被丢弃。
[Sysname-user-profile-user] qos car outbound any cir 256 cbs 51200
3.2  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
 Rule: If-match queue 1
  CIR 512 (kbps), CBS 51200 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
3.2.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
未配置流量整形。
queue queue-id:对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为16~16777200。
cbs committed-burst-size:承诺突发尺寸,单位为byte。取值范围1536~65535且必须为512的整数倍。不指定cbs参数时,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍。
# 在接口GigabitEthernet1/0/1上对队列0的报文进行流量整形。正常流速为200kbps,突发流量为51200bytes。
[Sysname-GigabitEthernet1/0/1] qos gts queue 0 cir 200 cbs 51200
3.3  限速配置命令
display qos lr interface命令用来显示接口上的限速配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况。
# 显示所有接口的接口限速配置情况。
 Direction: outbound
  CIR 2000 (kbps), CBS 20480 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction
接口限速应用的方向
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
3.3.2  qos lr
qos lr命令用来配置接口限速。
undo qos lr命令用来取消接口配置的限速。
undo qos lr { inbound | outbound }
未配置限速。
inbound:入方向限速。
outbound:出方向限速。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为16~1048576。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。取值范围为512~134217728。
在接口出方向应用qos lr进行限速时,若该接口同时应用了队列调度策略,且配置了队列调度策略下队列的最小带宽保证,可能会导致实际限速速率小于配置限速速率。
# 对接口GigabitEthernet1/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
4 拥塞管理
4.1  拥塞管理公共配置命令
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
.....(省略部分显示信息)
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列的相关信息
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算
4.2  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示GigabitEthernet1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface gigabitethernet 1/0/1
 Output queue: Strict Priority queuing
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
4.2.2  qos sp
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
接口上缺省的队列调度方式为WRR。
# 在接口GigabitEthernet1/0/1上应用SP模式的队列调度。
[Sysname-GigabitEthernet1/0/1] qos sp
·     display qos queue sp interface
4.3  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口GigabitEthernet1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface gigabitethernet 1/0/1
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         9
 6            cs6            1         13
 7            cs7            1         15
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Weight
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法
4.3.2  qos wrr
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
undo qos wrr { byte-count | weight }
接口上缺省的队列调度方式为WRR,按照每次轮询可发送的报文个数进行计算。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wrr weight
# 在接口GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
·     display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复指定队列的缺省情况。
qos wrr queue-id group 1 { byte-count | weight } schedule-value
undo qos wrr queue-id
所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、9、13、15。
queue-id:队列序号。取值范围为0~7或表4-4中的关键字。
表4-4 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group 1:表示该队列属于WRR优先组,目前仅支持1个WRR调度组。
schedule-value:配置队列的调度权重,取值范围为1~15。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口GigabitEthernet1/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
所有队列均处于WRR调度组1中。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
4.4  加权公平队列配置命令
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口GigabitEthernet1/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
分组号,说明队列属于哪一个分组
Byte-count
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法
Min-Bandwidth
队列的最小保证带宽值
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
各队列的最小带宽保证均为0kbps。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为16~1000000。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口GigabitEthernet1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
·     qos wfq
4.4.3  qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
undo qos wfq { byte-count | weight }
接口上缺省的队列调度方式为WRR。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
·     display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复指定队列的缺省情况。
qos wfq queue-id group 1 { byte-count | weight } schedule-value
undo qos wfq queue-id
所有队列都处于WFQ调度组1中,各队列的调度权重均为1,按照每次轮询可发送的报文个数进行计算。
group 1:表示该队列属于WFQ优先组,目前仅支持1个WFQ调度组。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     qos bandwidth queue
·     qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
所有队列均处于WFQ调度组1中。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口GigabitEthernet1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
4.5  队列调度策略配置命令
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
队列的最小带宽保证为0kbps。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为16~100000000。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列0使用WFQ队列算法,使用报文个数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定成员设备的队列调度策略的配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的队列调度策略的配置情况。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1) Basic
 Queue ID    Type    Group    Schedule  Schedule  Min           Max
                              unit      value     bandwidth     bandwidth
 be          SP      N/A      N/A        N/A      64            10000
 af1         WFQ     1        byte-count N/A      100           10000
 af2         WRR     1        weight     100      100           10000
 af3         WRR     1        weight     100      100           10000
 af4         WRR     1        weight     50       100           10000
 ef          WRR     1        weight     50       100           10000
 cs6         WRR     1        weight     100      100           10000
 cs7         WRR     1        weight     50       100           10000
表4-6 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列)
Group
优先组,N/A表示无效
Schedule unit
队列调度单位,包括weight和byte-count,N/A表示无效
Schedule vlaue
·     队列调度单位为weight时,表示报文个数
·     队列调度单位为byte-count时,表示字节个数
·     N/A表示无效
Min Bandwidth
最小保证带宽,N/A表示无效
Max bandwidth
最大带宽值,N/A表示无效
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 1/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称
Direction
队列调度策略应用的方向
队列调度策略名称
qos apply qmprofile命令用来在接口出方向上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
每个接口出方向上只能应用一个队列调度策略。
# 在接口GigabitEthernet1/0/1出方向上应用队列调度策略myprofile。
[Sysname-GigabitEthernet1/0/1] qos apply qmprofile myprofile
·     display qos qmprofile interface
4.5.5  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
·     queue
4.5.6  queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value } *
undo queue queue-id
队列调度策略的内容是所有队列均采用SP方式调度。
队列调度策略视图
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。取值只能为1。
schedule-value:配置队列的调度权重。取值范围为1~15。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,分组为1,权重为10。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
5 拥塞避免
5.1  WRED配置命令
display qos wred interface命令用来显示接口上WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口下应用的WRED表配置情况和统计信息。
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
表5-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成
当前WRED的配置情况
当前应用的WRED表的名称
display qos wred table命令用来显示WRED表的配置情况。
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定成员设备的WRED表配置情况。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主用设备的WRED表配置情况。
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     100   1000  10     100   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gprob
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
yprob
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rprob
红色报文的丢弃概率
exponent
计算平均队列长度指数
ECN
(暂不支持)是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口GigabitEthernet1/0/1上应用WRED表。
[Sysname-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred queue table
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id [ drop-level drop-level ] | all }
WRED表在创建之后,有缺省的一套参数,low-limit的取值为100,high-limit的取值为1000,discard-prob的取值为10。
WRED表视图
all:表示所有队列。
queue-id:队列编号。取值范围为0~7。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限。取值范围为0~5840。
high-limit high-limit:队列平均长度的上限。取值范围为0~5840。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越大。取值范围为0~100。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue weighting-constant命令用来配置计算平均队列长度的指数。
undo queue weighting-constant命令用来恢复缺省情况。
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
计算平均队列长度的指数为9。
WRED表视图
weighting-constant exponent:计算平均队列长度的指数。取值范围为0~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
6 聚合CAR
6.1  聚合CAR配置命令
6.1.1  car name
car name命令用来配置聚合CAR动作。
undo car用来恢复缺省情况。
car name car-name
undo car
未配置聚合CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
·     display qos car name
·     display traffic behavior user-defined
display qos car name命令用来显示聚合CAR的配置和统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定聚合CAR的配置和统计信息。如果未指定本参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR的配置和统计信息。
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
表6-1 display qos car name命令显示信息描述表
Name
聚合CAR的名称
Mode
聚合CAR的类型,取值为aggregative(聚合CAR)
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Green action
对绿色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Yellow action
对黄色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
6.1.3  qos car
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte。
配置pir参数后:
·     如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
·     如果指定ebs,取值范围0~256000000且必须为512的整数倍。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name命令用来清除聚合CAR的统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定聚合CAR的统计信息。如果未指定本参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 端口队列统计
7.1  端口队列统计配置命令
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
# 显示接口GigabitEthernet1/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface gigabitethernet 1/0/1 outbound
Direction: outbound
 Queue 0
  Forwarded: 0 packets, 0 pps
  Dropped: 0 packets
…省略…
 Queue 7
  Dropped: 0 packets
表7-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目和速率
Dropped
丢弃的数据包数目
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7
某端口队列统计信息
·     reset counters interface(接口管理命令参考/以太网接口)
