06-IP组播命令参考
14-IPv6 PIM命令
本章节下载 14-IPv6 PIM命令  (354.93 KB)
14-IPv6 PIM命令
  录
1 IPv6 PIM配置命令
1.1 IPv6 PIM配置命令
1.1.1 bidir-pim enable (IPv6 PIM view)
1.1.2 bsm-fragment enable (IPv6 PIM view)
1.1.3 bsr-policy (IPv6 PIM view)
1.1.4 c-bsr (IPv6 PIM view)
1.1.5 c-bsr admin-scope (IPv6 PIM view)
1.1.6 c-bsr hash-length (IPv6 PIM view)
1.1.7 c-bsr holdtime (IPv6 PIM view)
1.1.8 c-bsr interval (IPv6 PIM view)
1.1.9 c-bsr priority (IPv6 PIM view)
1.1.10 c-bsr scope
1.1.11 c-rp (IPv6 PIM view)
1.1.12 c-rp advertisement-interval (IPv6 PIM view)
1.1.13 c-rp holdtime (IPv6 PIM view)
1.1.14 crp-policy (IPv6 PIM view)
1.1.15 display pim ipv6 bsr-info
1.1.16 display pim ipv6 claimed-route
1.1.17 display pim ipv6 control-message counters
1.1.18 display pim ipv6 df-info
1.1.19 display pim ipv6 grafts
1.1.20 display pim ipv6 interface
1.1.21 display pim ipv6 join-prune
1.1.22 display pim ipv6 neighbor
1.1.23 display pim ipv6 routing-table
1.1.24 display pim ipv6 rp-info
1.1.25 embedded-rp
1.1.26 hello-option dr-priority (IPv6 PIM view)
1.1.27 hello-option holdtime (IPv6 PIM view)
1.1.28 hello-option lan-delay (IPv6 PIM view)
1.1.29 hello-option neighbor-tracking (IPv6 PIM view)
1.1.30 hello-option override-interval (IPv6 PIM view)
1.1.31 holdtime assert (IPv6 PIM view)
1.1.32 holdtime join-prune (IPv6 PIM view)
1.1.33 jp-pkt-size (IPv6 PIM view)
1.1.34 jp-queue-size (IPv6 PIM view)
1.1.35 pim ipv6
1.1.36 pim ipv6 bfd enable
1.1.37 pim ipv6 bsr-boundary
1.1.38 pim ipv6 dm
1.1.39 pim ipv6 hello-option dr-priority
1.1.40 pim ipv6 hello-option holdtime
1.1.41 pim ipv6 hello-option lan-delay
1.1.42 pim ipv6 hello-option neighbor-tracking
1.1.43 pim ipv6 hello-option override-interval
1.1.44 pim ipv6 holdtime assert
1.1.45 pim ipv6 holdtime join-prune
1.1.46 pim ipv6 neighbor-policy
1.1.47 pim ipv6 require-genid
1.1.48 pim ipv6 sm
1.1.49 pim ipv6 state-refresh-capable
1.1.50 pim ipv6 timer graft-retry
1.1.51 pim ipv6 timer hello
1.1.52 pim ipv6 timer join-prune
1.1.53 pim ipv6 triggered-hello-delay
1.1.54 probe-interval (IPv6 PIM view)
1.1.55 prune delay (IPv6 PIM view)
1.1.56 register-policy (IPv6 PIM view)
1.1.57 register-suppression-timeout (IPv6 PIM view)
1.1.58 register-whole-checksum (IPv6 PIM view)
1.1.59 reset pim ipv6 control-message counters
1.1.60 source-lifetime (IPv6 PIM view)
1.1.61 source-policy (IPv6 PIM view)
1.1.62 spt-switch-threshold infinity (IPv6 PIM view)
1.1.63 ssm-policy (IPv6 PIM view)
1.1.64 state-refresh-hoplimit
1.1.65 state-refresh-interval (IPv6 PIM view)
1.1.66 state-refresh-rate-limit (IPv6 PIM view)
1.1.67 static-rp (IPv6 PIM view)
1.1.68 timer hello (IPv6 PIM view)
1.1.69 timer join-prune (IPv6 PIM view)
1 IPv6 PIM配置命令
l          本文所指的路由器代表运行了路由协议的三层设备。
l          IPv6 PIM功能中所指的“接口”为三层口,包括VLAN接口、三层以太网端口等。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
1.1  IPv6 PIM配置命令
bidir-pim enable
undo bidir-pim enable
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
bidir-pim enable命令用来使能IPv6双向PIM。undo bidir-pim enable命令用来关闭IPv6双向PIM。
缺省情况下,IPv6双向PIM处于关闭状态。
需要注意的是,只有在设备上先使能了IPv6组播路由,本命令才能生效。
相关配置可参考命令pim ipv6,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable
# 使能IPv6组播路由,进入IPv6 PIM视图。
[Sysname] multicast ipv6 routing-enable
[Sysname] pim ipv6
[Sysname-pim6] bidir-pim enable
bsm-fragment enable
undo bsm-fragment enable
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
bsm-fragment enable命令用来使能自举报文语义分片功能。undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
缺省情况下,自举报文语义分片功能处于使能状态。
需要注意的是,当IPv6 PIM-SM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
相关配置可参考命令c-bsr admin-scope
# 关闭自举报文语义分片功能。
[Sysname] pim ipv6
[Sysname-pim6] undo bsm-fragment enable
bsr-policy acl6-number
undo bsr-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定合法BSR的源IPv6地址范围。
【描述】
bsr-policy命令用来配置合法的BSR地址范围,以防止BSR欺骗。undo bsr-policy命令用来取消BSR地址范围的限制。
缺省情况下,BSR的地址范围不受任何限制,即认为来自任意源的自举报文都是合法的。
# 配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001::2 64
[Sysname-acl6-basic-2000] quit
[Sysname] pim ipv6
[Sysname-pim6] bsr-policy 2000
c-bsr ipv6-address [ hash-length [ priority ] ]
undo c-bsr
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-address:指定接口的IPv6地址,将该接口配置为C-BSR。
hash-length:指定哈希掩码长度,取值范围为0~128。如果未指定本参数,则取相应的全局值。
priority:指定该C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr命令用来配置某接口为C-BSR。undo c-bsr命令用来删除C-BSR的相关配置。
缺省情况下,没有配置C-BSR。
需要注意的是,充当C-BSR的接口上必须使能IPv6 PIM-SM。
相关配置可参考命令pim ipv6 smc-bsr hash-lengthc-bsr priorityc-rp
# 配置IPv6地址1101::1为C-BSR。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr 1101::1
c-bsr admin-scope
undo c-bsr admin-scope
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
c-bsr admin-scope命令用来使能IPv6管理域机制。undo c-bsr admin-scope命令用来关闭IPv6管理域机制。
缺省情况下,IPv6管理域机制处于关闭状态,即每个IPv6 PIM-SM域中只能有一个BSR。
相关配置可参考命令c-bsrc-bsr scope
# 使能IPv6管理域机制。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr admin-scope
c-bsr hash-length hash-length
undo c-bsr hash-length
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
c-bsr hash-length命令用来配置哈希掩码长度的全局值。undo c-bsr hash-length命令用来恢复缺省情况。
缺省情况下,哈希掩码长度为126。
相关配置可参考命令c-bsr
# 配置哈希掩码长度的全局值为16。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr hash-length 16
c-bsr holdtime interval
undo c-bsr holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定自举超时时间,取值范围为1~2147483647,单位为秒。
【描述】
c-bsr holdtime命令用来配置自举超时时间,即C-BSR等待接收来自BSR的自举报文的超时时间。undo c-bsr holdtime命令用来恢复缺省情况。
缺省情况下,自举超时时间由如下公式决定:自举超时时间=自举时间间隔×2+10。
缺省情况下,自举时间间隔为60秒,则自举超时时间的缺省值=60×2+10=130(秒)。
相关配置可参考命令c-bsrc-bsr interval
# 配置自举超时时间为150秒。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr holdtime 150
c-bsr interval interval
undo c-bsr interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定自举时间间隔,取值范围为10~2147483647,单位为秒。
【描述】
c-bsr interval命令用来配置自举时间间隔,即BSR发送自举报文的时间间隔。undo c-bsr interval命令用来恢复缺省情况。
缺省情况下,自举时间间隔由如下公式决定:自举时间间隔=(自举超时时间-10)÷2。
缺省情况下,自举超时时间为130秒,则自举时间间隔的缺省值=(130-10)÷2=60(秒)。
相关配置可参考命令c-bsrc-bsr holdtime
# 配置自举时间间隔为30秒。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr interval 30
c-bsr priority priority
undo c-bsr priority
IPv6 PIM视图
【缺省级别】
2:系统级
priority:指定C-BSR的优先级,取值范围为0~255。该数值越大,优先级越高。
【描述】
c-bsr priority命令用来配置C-BSR优先级的全局值。undo c-bsr priority命令用来恢复缺省情况。
缺省情况下,C-BSR的优先级为64。
相关配置可参考命令c-bsr
# 配置C-BSR优先级的全局值为5。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr priority 5
1.1.10  c-bsr scope
c-bsr scope { scope-id | admin-local | global | organization-local | site-local } [ hash-length hash-length | priority priority ] *
undo c-bsr scope { scope-id | admin-local | global | organization-local | site-local }
IPv6 PIM视图
【缺省级别】
2:系统级
scope-id:指定Scope字段的值,取值范围为3~15。
admin-local:指定Scope字段为管理本地范围,对应的Scope值为4。
global:指定Scope字段为全球范围,对应的Scope值为14。
organization-local:指定Scope字段为机构本地范围,对应的Scope值为8。
site-local:指定Scope字段为站点本地范围,对应的Scope值为5。
hash-length:指定某Scope值所对应IPv6管理域中的哈希掩码长度,取值范围为0~128。如果未指定本参数,则取相应的全局值。
priority:指定某Scope值所对应IPv6管理域中C-BSR的优先级,取值范围为0~255。数值越大,优先级越高。如果未指定本参数,则取相应的全局值。
【描述】
c-bsr scope命令用来配置IPv6管理域的C-BSR。undo c-bsr scope命令用来删除IPv6管理域C-BSR的配置。
缺省情况下,没有配置IPv6管理域的C-BSR。
相关配置可参考命令c-bsr admin-scopec-bsr hash-lengthc-bsr priority
# 配置本设备为Scope值为全球范围时所对应IPv6管理域的C-BSR,其优先级为10。
[Sysname] pim ipv6
[Sysname-pim6] c-bsr scope global priority 10
c-rp ipv6-address [ { group-policy acl6-number | scope scope-id } | priority priority | holdtime hold-interval | advertisement-interval adv-interval ] * [ bidir ]
undo c-rp ipv6-address
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-address:指定接口的IPv6地址,将该接口配置为C-RP。
acl6-number:指定基本IPv6访问控制列表号,取值范围为2000~2999。该IPv6 ACL规则并不用来进行匹配过滤,而是定义了该C-RP所服务的IPv6组播组范围,只要是permit的IPv6组播组都会作为RP的服务组范围通告出去,其它诸如deny等的配置不起作用。
priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
hold-interval:指定C-RP的超时时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒。如果未指定本参数,则取相应的全局值。
bidir:指定该C-RP服务于IPv6双向PIM。如果未指定本参数,该C-RP将服务于IPv6 PIM-SM。
【描述】
c-rp命令用来配置某接口为C-RP。undo c-rp命令用来删除C-RP的相关配置。
缺省情况下,没有配置C-RP。
l              充当C-RP的接口上必须使能IPv6 PIM-SM。
l              若没有为C-RP指定其所服务的IPv6组播组范围,在IPv6非管理域机制下,该C-RP将为所有IPv6组播组服务;而在IPv6管理域机制下,该C-RP将为IPv6 Global域服务。
l              如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的IPv6 ACL时将多个组范围用多个rule规则表示出来。
l              如果对于同一接口多次执行本命令,则最新配置将覆盖旧配置。
相关配置可参考命令c-bsr
# 配置IPv6地址为2001::1的接口为组播组FF0E:0:1391::/96的C-RP,C-RP的优先级为10。
[Sysname-acl6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] pim ipv6
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
c-rp advertisement-interval interval
undo c-rp advertisement-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送宣告报文的时间间隔,取值范围为1~65535,单位为秒。
【描述】
c-rp advertisement-interval命令用来配置发送宣告报文时间间隔的全局值。undo c-rp advertisement-interval命令用来恢复缺省情况。
缺省情况下,发送宣告报文的时间间隔为60秒。
相关配置可参考命令c-rp
# 配置发送宣告报文时间间隔的全局值为30秒。
[Sysname] pim ipv6
[Sysname-pim6] c-rp advertisement-interval 30
c-rp holdtime interval
undo c-rp holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
c-rp holdtime命令用来配置C-RP超时时间的全局值,即BSR等待接收来自C-RP的宣告报文的超时时间。undo c-rp holdtime命令用来恢复缺省情况。
缺省情况下,C-RP的超时时间为150秒。
需要注意的是,由于非BSR通过BSR自举报文来更新C-RP的超时时间,所以在配置时,C-RP的超时时间不要小于BSR发送自举报文的时间间隔,且最好为该间隔的2.5倍以上,以防止BSR自举报文中的C-RP信息丢失。
相关配置可参考命令c-rpc-bsr interval
# 配置C-RP超时时间的全局值为200秒。
[Sysname] pim ipv6
[Sysname-pim6] c-rp holdtime 200
crp-policy acl6-number
undo crp-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定高级IPv6访问控制列表编号,取值范围为3000~3999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定C-RP的IPv6地址,destination参数来指定该C-RP所服务的IPv6组播组地址范围。
【描述】
crp-policy命令用来配置合法的C-RP地址范围及其所服务的IPv6组播组范围,以防止C-RP欺骗。undo crp-policy命令用来取消C-RP地址范围及其所服务的IPv6组播组范围的限制。
缺省情况下,C-RP地址范围及其所服务的IPv6组播组范围不受任何限制,即认为所有收到的C-RP报文都是合法的。
需要注意的是,本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只依据其组前缀进行过滤。譬如,当C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,crp-policy命令所规定的合法IPv6组播组范围为FF0E:0:1::/120时,最终通过过滤的IPv6组播组范围为FF0E:0:1::/96。
相关配置可参考命令c-rp
# 配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl6-adv-3000] quit
[Sysname] pim ipv6
[Sysname-pim6] crp-policy 3000
display pim ipv6 bsr-info [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display pim ipv6 bsr-info命令用来查看IPv6 PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
相关配置可参考命令c-bsrc-rp
# 查看IPv6 PIM-SM域中的BSR信息,以及本地配置并生效的C-RP信息。
<Sysname> display pim ipv6 bsr-info
 Elected BSR Address: 2004::2
     Priority: 64
     Hash mask length: 126
     State: Elected
     Scope: 14
     Uptime: 00:01:10
     Next BSR message scheduled at: 00:00:48
 Candidate BSR Address: 2004::2
     Priority: 64
     State: Elected
     Scope: 14
 Candidate RP: 2001::1(LoopBack1)
     Priority: 192
     HoldTime: 130
     Advertisement Interval: 60
     Next advertisement scheduled at: 00:00:48
 Candidate RP: 2002::1(Vlan-interface1)
     Priority: 200
     HoldTime: 90
     Advertisement Interval: 50
     Next advertisement scheduled at: 00:00:28
 Candidate RP: 2003::1(Vlan-interface2)
     Priority: 192
     HoldTime: 80
表1-1 display pim ipv6 bsr-info命令显示信息描述表
Elected BSR Address
当选BSR的IPv6地址
候选BSR的地址
Priority
BSR的优先级
Hash mask length
哈希掩码长度
BSR的状态
Scope
BSR所服务的IPv6管理域
Uptime
BSR已经存在的时间
BSR超时剩余时间
Candidate RP
候选RP的地址
Priority
候选RP的优先级
HoldTime
候选RP的超时时间
候选RP发送宣告报文时间间隔
候选RP发送下一个宣告报文的剩余时间
display pim ipv6 claimed-route [ ipv6-source-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-source-address:组播源的IPv6地址,查看到达指定组播源的IPv6单播路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有IPv6单播路由信息。
【描述】
display pim ipv6 claimed-route命令用来查看IPv6 PIM所使用的IPv6单播路由信息。
如果某(S,G)表项的标志是SPT,则该(S,G)表项会使用IPv6单播路由。
# 查看IPv6 PIM使用的所有IPv6单播路由信息。
<Sysname> display pim ipv6 claimed-route
 RPF information about: 2001::2
     RPF interface: Vlan-interface1, RPF neighbor: FE80::A01:100:1
     Referenced prefix/prefix length: 2001::/64
     Referenced route type: igp
     RPF-route selecting rule: preference-preferred
     The (S, G) or (*, G) list dependent on this route entry
     (2001::2, FF03::101)
表1-2 display pim ipv6 claimed-route命令显示信息描述表
到IPv6组播源2001::2的RPF路由信息
RPF interface
RPF接口的名称和编号
RPF neighbor
RPF邻居的IPv6地址
所用的路由项
所引用的路由类型,可以是下列类型之一:
l      igp:IPv6单播路由(内部网关协议)
l      egp:IPv6单播路由(外部网关协议)
l      unicast (direct):IPv6单播路由(直连)
l      unicast:其它IPv6单播路由(如IPv6单播静态路由等)
l      mbgpIPv6 MBGP路由
RPF路由的选择规则
The (S,G) or (*,G) list dependent on this route entry
基于此RPF路由的(S,G)或(*,G)列表
display pim ipv6 control-message counters [ message-type { probe | register | register-stop } | [ interface interface-type interface-number | message-type { assert | bsr | crp | graft | graft-ack | hello | join-prune | state-refresh } ] * ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
probe:查看空注册报文的数量。
register:查看注册报文的数量。
register-stop:查看注册停止报文的数量。
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM控制报文数量。
assert:查看断言报文的数量。
bsr:查看自举报文的数量。
crp:查看宣告报文的数量。
graft:查看嫁接报文的数量。
graft-ack:查看嫁接应答报文的数量。
hello:查看Hello报文的数量。
join-prune:查看加入/剪枝报文的数量。
state-refresh:查看状态刷新报文的数量。
【描述】
display pim ipv6 control-message counters命令用来查看IPv6 PIM控制报文的数量。
# 查看所有接口上所有类型的IPv6 PIM控制报文数量。
<Sysname> display pim ipv6 control-message counters
 PIM global control-message counters:
                  Received         Sent             Invalid
 Register         20               37               2
 Register-Stop    25               20               1
 Probe            10               5                0
 PIM control-message counters for interface: Vlan-interface1
 Assert           10               5                0
 Graft            20               37               2
 Graft-Ack        25               20               1
 Hello            1232             453              0
 Join/Prune       15               30               21
 State-Refresh    8                7                1
 BSR              3243             589              1
 C-RP             53               32               0
表1-3 display pim ipv6 control-message counters命令显示信息描述表
统计IPv6 PIM全局控制报文
统计IPv6 PIM控制报文的接口
Received
收到的报文数量
Sent
发送的报文数量
Invalid
无效报文的数量
Register
注册报文
Register-Stop
注册停止报文
Probe
空注册报文
Assert
断言报文
Graft
嫁接报文
Graft-Ack
嫁接应答报文
Hello
Hello报文
Join/Prune
加入/剪枝报文
State Refresh
状态刷新报文
BSR
自举报文
C-RP
宣告报文
display pim ipv6 df-info [ rp-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
rp-address:指定IPv6双向PIM的RP地址。
【描述】
display pim ipv6 df-info命令用来查看IPv6双向PIM的DF信息。
# 查看IPv6双向PIM的DF信息。
<Sysname> display pim ipv6 df-info
 RP Address: 2010::1
  Interface           State   DF-Pref    DF-Metric  DF-Uptime DF-Address
  Vlan1               Win     100        1          01:24:09  FE80::20F:E2FF:
                                                              FE38:4E01 (local)
  Vlan2               Win     100        1          01:24:09  FE80::200:5EFF:
                                                              FE71:2801 (local)
  Vlan3               Lose    0          0          01:23:12  FE80::20F:E2FF:
                                                              FE15:5601
表1-4 display pim ipv6 df-info命令显示信息描述表
RP Address
IPv6双向PIM的RP地址
接口名称
DF的选举状态:
l      Win:表示获选
l      Lose:表示落选
DF-Pref
DF通告的路由优先级
DF-Metric
DF通告的路由度量值
DF-Uptime
DF的存在时间
DF-Address
DF的IPv6地址,local表示为本地地址
display pim ipv6 grafts [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display pim ipv6 grafts命令用来查看尚未确认的IPv6 PIM-DM嫁接信息。
# 查看尚未确认的IPv6 PIM-DM嫁接信息。
<Sysname> display pim ipv6 grafts
 Source             Group             Age           RetransmitIn
 1004::2            ff03::101         00:00:24      00:00:02
表1-5 display pim ipv6 grafts命令显示信息描述表
Source
嫁接报文中的IPv6组播源地址
Group
嫁接报文中的IPv6组播组地址
Age
嫁接报文的老化剩余时间
RetransmitIn
重发嫁接报文的剩余时间
display pim ipv6 interface [ interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM信息。
verbose:查看IPv6 PIM接口的详细信息。
【描述】
display pim ipv6 interface命令用来查看接口上的IPv6 PIM信息。
# 查看接口Vlan-interface1上的IPv6 PIM详细信息。
<Sysname> display pim ipv6 interface vlan-interface 1 verbose
 InterfaceVlan-interface1, FE80::200:5EFF:FE04:8700
     PIM version: 2
     PIM mode: Sparse
     PIM DR: FE80::200:AFF:FE01:101
     PIM DR Priority (configured): 1
     PIM neighbor count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
表1-6 display pim ipv6 interface命令显示信息描述表
接口名称与IPv6地址
PIM version
IPv6 PIM协议的版本号
PIM mode
IPv6 PIM协议的模式,是密集模式还是稀疏模式
PIM DR
DR的IPv6地址
竞选DR的优先级
PIM neighbor count
IPv6 PIM邻居的总数
PIM hello interval
发送IPv6 PIM Hello报文的时间间隔
发送剪枝报文延迟时间的协商值
发送剪枝报文延迟时间的配置值
剪枝否决时间的协商值
剪枝否决时间的配置值
邻居跟踪使能与否的协商情况
邻居跟踪使能与否的配置情况
PIM generation ID
Generation_ID参数值
是否使能不接受无Generation ID的Hello报文
保持IPv6 PIM邻居的可达状态的时间
保持断言状态的时间
发送Hello报文的最大延迟时间
PIM J/P interval
发送加入/剪枝报文的时间间隔
保持加入/剪枝状态的时间
该接口是否配置了BSR的服务边界
该接口所在网段上没有使用DR优先级字段的路由器数量
该接口所在网段上未使用LAN-delay字段的路由器数量
该接口所在网段上未使能邻居跟踪的路由器数量
display pim ipv6 join-prune mode { sm [ flags flag-value ] | ssm } [ interface interface-type interface-number | neighbor ipv6-neighbor-address ] * [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
mode:查看指定IPv6 PIM模式下待发送的加入/剪枝报文信息。IPv6 PIM模式包括smssm,分别表示IPv6 PIM-SM和IPv6 PIM-SSM类型的路由项。
flags flag-value:查看含有指定标志的IPv6 PIM路由表项。flag-value的取值及含义如下
l              rpt:表示共享树上的路由表项;
l              spt:表示最短路径树上的路由表项;
l              wc:表示带WC通配符的路由表项。
interface-type interface-number:接口类型和接口编号,查看指定接口上待发送的加入/剪枝报文信息。
ipv6-neighbor-address:PIM邻居的IPv6地址,查看待发送给指定IPv6 PIM邻居的加入/剪枝报文信息。
verbose:查看待发送的加入/剪枝报文的详细信息。
【描述】
display pim join-prune命令用来查看待发送的加入/剪枝报文信息。
# 查看IPv6 PIM-SM模式下待发送的加入/剪枝报文信息。
<Sysname> display pim ipv6 join-prune mode sm
 Expiry Time: 50 sec
 Upstream nbr: FE80::2E0:FCFF:FE03:1004 (Vlan-interface1)
 1 (*, G) join(s), 0 (S, G) join(s), 1 (S, G, rpt) prune(s)
 Total (*, G) join(s): 1, (S, G) join(s): 0, (S, G, rpt) prune(s): 1
表1-7 display pim join-prune命令显示信息描述表
Expiry Time:
发送加入/剪枝报文的剩余时间
Upstream nbr:
上游IPv6 PIM邻居的IPv6地址和所在接口
(*, G) join(s)
待发送的(*,G)加入项数量
(S, G) join(s)
待发送的(S,G)加入项数量
待发送的(S,G,rpt)剪枝项数量
display pim ipv6 neighbor [ interface interface-type interface-number | ipv6-neighbor-address | verbose ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,查看指定接口上的IPv6 PIM邻居信息。
ipv6-neighbor-address:PIM邻居的IPv6地址,查看指定IPv6 PIM邻居的信息。
verbose:查看IPv6 PIM邻居的详细信息。
【描述】
display pim ipv6 neighbor命令用来查看IPv6 PIM邻居信息。
# 查看所有IPv6 PIM邻居的信息。
<Sysname> display pim ipv6 neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  Dr-Priority  Mode
 FE80::A01:101:1 Vlan1               02:50:49 00:01:31 1            B
 FE80::A01:102:1 Vlan2               02:49:39 00:01:42 1            B
# 查看IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display pim ipv6 neighbor fe80::a01:101:1 verbose
Neighbor: FE80::A01:101:1
     Interface: Vlan-interface3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     Bidirectional PIM: Enabled
     Neighbor Secondary Address(es):
     1::1
表1-8 display pim ipv6 neighbor命令显示信息描述表
IPv6 PIM邻居的总数
Neighbor
IPv6 PIM邻居的IPv6主地址(链路本地地址)
IPv6 PIM邻居所在接口的名称
Uptime
IPv6 PIM邻居已存在的时间
Expires/Expiry time
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达
Dr-Priority/DR Priority
IPv6 PIM邻居的优先级
Mode
IPv6 PIM邻居的模式,B表示IPv6双向PIM模式,显示为空则表示非IPv6双向PIM模式
Generation ID
IPv6 PIM邻居的Generation ID(状态随机数)
Holdtime
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达
LAN delay
发送剪枝报文的延迟时间
Override interval
剪枝否决的时间间隔
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段
Neighbor tracking
邻居跟踪功能是否已使能
Bidirectional PIM
IPv6双向PIM是否已使能
IPv6 PIM邻居的IPv6从地址(非链路本地地址)
display pim ipv6 routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | incoming-interface [ interface-type interface-number | register ] | outgoing-interface { include | exclude | match } { interface-type interface-number | register } | mode mode-type | flags flag-value | fsm ] * [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-group-address:IPv6组播组地址,查看指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。
ipv6-source-address:IPv6组播源地址,查看包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
incoming-interface:查看指定入接口的IPv6 PIM路由项。
interface-type interface-number:查看指定接口类型和接口编号的入接口的IPv6 PIM路由项。
register:查看入接口为IPv6 PIM-SM注册接口的IPv6 PIM路由项。本参数只有在未指定mode-type,或mode-typesm时才有效。
outgoing-interface:查看指定出接口的IPv6 PIM路由项。
include:查看出接口列表中包含指定接口的IPv6 PIM路由项。
exclude:查看出接口列表中不包含指定接口的IPv6 PIM路由项。
match:查看出接口列表中包含且仅包含指定接口的IPv6 PIM路由项。
mode mode-type:IPv6 PIM模式,查看指定模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
l              dm:表示IPv6 PIM-DM模式;
l              sm:表示IPv6 PIM-SM模式;
l              ssm:表示IPv6 PIM-SSM模式。
flags flag-value:IPv6 PIM标志,查看包含指定标志的IPv6 PIM路由项。flag-value的取值及含义如下
l              act:表示已经有实际数据到达的IPv6 PIM路由项;
l              bidir:表示由IPv6双向PIM创建的IPv6 PIM路由项;
l              del:表示计划删除的IPv6 PIM路由项;
l              exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
l              ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
l              loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
l              niif:表示未确定入接口的IPv6 PIM路由项;
l              nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
l              rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
l              spt:表示SPT上的IPv6 PIM路由项;
l              swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
l              wc:表示带WC通配符的IPv6 PIM路由项。
fsm:查看状态机信息。
【描述】
display pim ipv6 routing-table命令用来查看IPv6 PIM路由表的内容。
相关配置可参考“IP组播命令参考/IPv6组播路由与转发”中的命令display ipv6 multicast routing-table
# 查看IPv6 PIM路由表的内容。
<Sysname> display pim ipv6 routing-table
 (2001::2, FFE3::101)
     RP: FE80::A01:100:1
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 查看IPv6 PIM路由表的状态机信息。
<Sysname> display pim ipv6 routing-table fsm
 Abbreviations for FSM states:
     NI - no info, J - joined, NJ - not joined, P - pruned,
     NP - not pruned, PP - prune pending, W - winner, L - loser,
     F - forwarding, AP - ack pending, DR - designated router,
     NDR - non-designated router, RCV - downstream receivers
     RP: FE80::A01:100:1
     UpTime: 02:54:43
         Join/Prune FSM: [SPT: J] [RPT: NP]
         1: Vlan-interface2
             DR state: [DR]
             Join/Prune FSM: [NI]
             Assert FSM: [NI]
     FSM information for non-downstream interfaces: None
表1-9 display pim ipv6 routing-table命令显示信息描述表
IPv6 PIM路由表中(S,G)与(*,G)表项的总数
NI - no info, J - joined, NJ - not joined, P – pruned
NP - not pruned, PP - prune pending, W - winner, L – loser
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者
IPv6 PIM路由表中的(S,G)表项
RP
RP的地址
Protocol
IPv6 PIM的模式
Flag
IPv6 PIM路由表中(S,G)或(*,G)表项的标志:
l      ACT:表示已有实际数据到达
l      BIDIR:表示由IPv6双向PIM创建
l      DEL:表示计划要删除
l      EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝
l      EXT:表示包含了由它IPv6组播路由协议提供的出接口
l      LOC:表示与IPv6组播源处于同一网段
l      NIIF:表示未确定入接口
l      NONBR:表示IPv6 PIM邻居查找失败
l      RPT:表示向RP方向发送过(S,G)RPT位剪枝
l      SPT:表示在SPT上
l      SWT:表示正在向SPT切换
l      WC:表示带WC通配符
Uptime
(S,G)或(*,G)表项已存在的时间
Upstream interface
(S,G)或(*,G)表项的上游接口名称
Upstream neighbor
(S,G)或(*,G)表项的上游邻居
RPF prime neighbor
(S,G)或(*,G)表项的RPF邻居:
l      对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL
l      对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL
DR state
DR的状态
Join/Prune FSM
加入/剪枝状态机
Assert FSM
断言状态机
下游接口的信息,包括:
l      下游接口的总数
l      下游接口的名称
l      下游接口使用的协议类型
l      下游接口的存在时间
l      下游接口的超时时间
非下游接口的状态机信息
display pim ipv6 rp-info [ ipv6-group-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ipv6-group-address:IPv6组播组地址,查看指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
【描述】
display pim ipv6 rp-info命令用来查看RP的信息。
需要注意的是,RP信息包括通过BSR机制动态发现的RP信息和静态RP的信息。
# 查看IPv6组播组FF0E::101所对应的RP信息。
<Sysname> display pim ipv6 rp-info ff0e::101
 PIM-SM BSR RP information:
 prefix/prefix length: FF0E::101/64 [B]
     RP: 2004::2
     Priority: 192
     HoldTime: 130
     Uptime: 00:05:19
     Expires: 00:02:11
表1-10 display pim ipv6 rp-info命令显示信息描述表
RP所服务的IPv6组播组
[B]
表示RP服务于IPv6双向PIM,不显示本字段则表示RP服务于IPv6 PIM-SM
RP
RP的IPv6地址
Priority
RP的优先级
HoldTime
RP的超时时间
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
1.1.25  embedded-rp
embedded-rp [ acl6-number ]
undo embedded-rp [ acl6-number ]
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
embedded-rp命令用来使能嵌入式RP功能。undo embedded-rp命令用来关闭嵌入式RP功能或者恢复缺省情况。
缺省情况下,默认嵌入式RP地址范围内的IPv6组播组均可以使用嵌入式RP功能。
默认的嵌入式RP地址范围为FF7x::/12和FFFx::/12,其中x表示任意合法的scope。有关scope字段的详细介绍,请参见“IP组播配置指导”中的“组播概述”。
l              使用embedded-rp命令时,如果未指定acl6-number参数,则默认嵌入式RP地址范围内的所有IPv6组播组均可以使用嵌入式RP功能;如果指定了acl6-number参数,则只有在默认嵌入式RP地址范围内且通过了IPv6 ACL检查的IPv6组播组才能使用嵌入式RP功能。
l              使用undo embedded-rp命令时,如果未指定acl6-number参数,则关闭所有IPv6组播组的嵌入式RP功能;如果指定了acl6-number参数,则恢复缺省情况。
# 通过配置,使只有在FF7E:140:20::101/64范围内的IPv6组播组才能使用嵌入式RP功能。
[Sysname-acl6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] pim ipv6
[Sysname-pim6] embedded-rp 2000
undo hello-option dr-priority
IPv6 PIM视图
【缺省级别】
2:系统级
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
【描述】
hello-option dr-priority命令用来全局配置竞选DR的优先级。undo hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令pim ipv6 hello-option dr-priority
# 全局配置竞选DR的优先级为3。
[Sysname] pim ipv6
[Sysname-pim6] hello-option dr-priority 3
hello-option holdtime interval
undo hello-option holdtime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。undo hello-option holdtime命令用来恢复缺省情况。
缺省情况下,保持IPv6 PIM邻居可达状态的时间为105秒。
相关配置可参考命令pim ipv6 hello-option holdtime
# 全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option holdtime 120
hello-option lan-delay interval
undo hello-option lan-delay
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送剪枝报文的延迟时间,取值范围为1~32767,单位为毫秒。
【描述】
hello-option lan-delay命令用来全局配置发送剪枝报文的延迟时间。undo hello-option lan-delay命令用来恢复缺省情况。
缺省情况下,发送剪枝报文的延迟时间为500毫秒。
相关配置可参考命令hello-option override-intervalpim ipv6 hello-option override-intervalpim ipv6 hello-option lan-delay
# 全局配置发送剪枝报文的延迟时间为200毫秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option lan-delay 200
undo hello-option neighbor-tracking
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
hello-option neighbor-tracking命令用来全局禁止加入报文抑制能力,即使能邻居跟踪。undo hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入消息抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令pim ipv6 hello-option neighbor-tracking
# 全局禁止加入报文抑制能力。
[Sysname] pim ipv6
[Sysname-pim6] hello-option neighbor-tracking
undo hello-option override-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定剪枝否决时间,取值范围为1~65535,单位为毫秒。
【描述】
hello-option override-interval命令用来全局配置剪枝否决时间。undo hello-option override-interval命令用来恢复缺省情况。
缺省情况下,剪枝否决时间为2500毫秒。
相关配置可参考命令hello-option lan-delaypim ipv6 hello-option lan-delaypim ipv6 hello-option override-interval
# 全局配置剪枝否决时间为2000毫秒。
[Sysname] pim ipv6
[Sysname-pim6] hello-option override-interval 2000
holdtime assert interval
undo holdtime assert
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持断言状态的时间,取值范围为7~2147483647,单位为秒。
【描述】
holdtime assert命令用来全局配置保持断言状态的时间。undo holdtime assert命令用来恢复缺省情况。
缺省情况下,保持断言状态的时间为180秒。
相关配置可参考命令holdtime join-prunepim ipv6 holdtime join-prunepim ipv6 holdtime assert
# 全局配置保持断言状态的时间为100秒。
[Sysname] pim ipv6
[Sysname-pim6] holdtime assert 100
holdtime join-prune interval
undo holdtime join-prune
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定保持加入/剪枝状态的时间,取值范围为1~65535,单位为秒。
【描述】
holdtime join-prune命令用来全局配置保持加入/剪枝状态的时间。undo holdtime join-prune命令用来恢复缺省情况。
缺省情况下,保持加入/剪枝状态的时间为210秒。
相关配置可参考命令holdtime assertpim ipv6 holdtime assertpim ipv6 holdtime join-prune
# 全局配置保持加入/剪枝状态的时间为280秒。
[Sysname] pim ipv6
[Sysname-pim6] holdtime join-prune 280
jp-pkt-size packet-size
undo jp-pkt-size
IPv6 PIM视图
【缺省级别】
2:系统级
packet-size:指定加入/剪枝报文的最大长度,取值范围为100~64000,单位为字节。
【描述】
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。undo jp-pkt-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文的最大长度为8100字节。
相关配置可参考命令jp-queue-size
# 配置加入/剪枝报文的最大长度为1500字节。
[Sysname] pim ipv6
[Sysname-pim6] jp-pkt-size 1500
jp-queue-size queue-size
undo jp-queue-size
IPv6 PIM视图
【缺省级别】
2:系统级
queue-size:指定加入/剪枝报文中(S,G)表项的最大数量,取值范围为1~4096。
【描述】
jp-queue-size命令用来配置加入/剪枝报文中(S,G)表项的最大数量。undo jp-queue-size命令用来恢复缺省情况。
缺省情况下,加入/剪枝报文中(S,G)表项的最大数量为1020个。
l              在使用jp-queue-size命令进行配置时,需要考虑产品转发表的实际规格。对于某些不支持分片的网络,当queue-size值配置得较大时,加入/剪枝报文中可能包含较多的组,使该报文的长度可能超过网络所规定的MTU(Maximum Transmission Unit,最大传输单元),某些不支持超过MTU报文传输的产品会将其丢弃。
l              在使用jp-queue-size命令进行配置时,还需要考虑上游设备(S,G)保持加入/剪枝状态的时间。当queue-size值配置得很小时,在队列中的最后一个加入/剪枝报文送达上游设备之前,上游设备相应表项的出接口有可能由于已超时而被剪枝。
相关配置可参考命令jp-pkt-sizeholdtime join-prunepim ipv6 holdtime join-prune
# 配置加入/剪枝报文中(S,G)表项的最大数量为2000。
[Sysname] pim ipv6
[Sysname-pim6] jp-queue-size 2000
1.1.35  pim ipv6
pim ipv6
undo pim ipv6
【缺省级别】
2:系统级
【描述】
pim ipv6命令用来进入IPv6 PIM视图。undo pim ipv6命令用来清除IPv6 PIM视图下的所有配置。
相关配置可参考“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable
[Sysname] pim ipv6
[Sysname-pim6]
pim ipv6 bfd enable
undo pim ipv6 bfd enable
【缺省级别】
2:系统级
【描述】
pim ipv6 bfd enable命令用来使能IPv6 PIM与BFD联动功能。undo pim ipv6 bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
缺省情况下,IPv6 PIM与BFD联动功能处于关闭状态。
需要注意的是,只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,pim ipv6 bfd enable命令才能生效。
相关配置可参考命令pim ipv6 dmpim ipv6 sm
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM,并使能IPv6 PIM与BFD联动功能。
[Sysname-Vlan-interface100] pim ipv6 sm
[Sysname-Vlan-interface100] pim ipv6 bfd enable
undo pim ipv6 bsr-boundary
【缺省级别】
2:系统级
【描述】
pim ipv6 bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。undo pim ipv6 bsr-boundary命令用来删除BSR的服务边界。
缺省情况下,没有配置BSR的服务边界。
相关配置可参考命令c-bsr,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 boundary
# 配置接口Vlan-interface100为BSR的服务边界。
[Sysname-Vlan-interface100] pim ipv6 bsr-boundary
1.1.38  pim ipv6 dm
pim ipv6 dm
undo pim ipv6 dm
【缺省级别】
2:系统级
【描述】
pim ipv6 dm命令用来使能IPv6 PIM-DM。undo pim ipv6 dm命令用来关闭IPv6 PIM-DM。
缺省情况下,IPv6 PIM-DM处于关闭状态。
l              只有在设备上先使能了IPv6组播路由,本命令才能生效。
l              在运行IPv6 PIM-DM时不能使用处于IPv6 SSM组地址范围内的IPv6组播组。
相关配置可参考命令pim ipv6 smssm-policy,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-DM。
[Sysname-Vlan-interface100] pim ipv6 dm
pim ipv6 hello-option dr-priority priority
undo pim ipv6 hello-option dr-priority
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option dr-priority命令用来在接口上配置竞选DR的优先级。undo pim ipv6 hello-option dr-priority命令用来恢复缺省情况。
缺省情况下,竞选DR的优先级为1。
相关配置可参考命令hello-option dr-priority
# 在接口Vlan-interface100上配置竞选DR的优先级为3。
[Sysname-Vlan-interface100] pim ipv6 hello-option dr-priority 3
pim ipv6 hello-option holdtime interval
undo pim ipv6 hello-option holdtime
【缺省级别】
2:系统级
interval:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
【描述】
pim ipv6 hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。undo pim ipv6 hello-option holdtime命令用来恢复缺省情况。
相关配置可参考命令hello-option holdtime
# 在接口Vlan-interface100上配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option holdtime 120
pim ipv6 hello-option lan-delay interval
undo pim ipv6 hello-option lan-delay
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option lan-delay命令用来在接口上配置发送剪枝报文的延迟时间。undo pim ipv6 hello-option lan-delay命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 hello-option override-intervalhello-option override-intervalhello-option lan-delay。
# 在接口Vlan-interface100上配置发送剪枝报文的延迟时间为200毫秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option lan-delay 200
undo pim ipv6 hello-option neighbor-tracking
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option neighbor-tracking命令用来在接口上禁止加入报文抑制能力,即使能邻居跟踪。undo pim ipv6 hello-option neighbor-tracking命令用来使能加入报文抑制能力。
缺省情况下,加入报文抑制能力处于使能状态,即禁止邻居跟踪。
相关配置可参考命令hello-option neighbor-tracking
# 在接口Vlan-interface100上禁止加入报文抑制能力。
[Sysname-Vlan-interface100] pim ipv6 hello-option neighbor-tracking
pim ipv6 hello-option override-interval interval
undo pim ipv6 hello-option override-interval
【缺省级别】
2:系统级
【描述】
pim ipv6 hello-option override-interval命令用来在接口上配置剪枝否决时间。undo pim ipv6 hello-option override-interval命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 hello-option lan-delayhello-option lan-delayhello-option override-interval
# 在接口Vlan-interface100上配置剪枝否决时间为2000毫秒。
[Sysname-Vlan-interface100] pim ipv6 hello-option override-interval 2000
pim ipv6 holdtime assert interval
undo pim ipv6 holdtime assert
【缺省级别】
2:系统级
【描述】
pim ipv6 holdtime assert命令用来在接口上配置保持断言状态的时间。undo pim ipv6 holdtime assert命令用来恢复缺省情况。
相关配置可参考命令holdtime join-prunepim ipv6 holdtime join-pruneholdtime assert
# 在接口Vlan-interface100上配置保持断言状态的时间为100秒。
[Sysname-Vlan-interface100] pim ipv6 holdtime assert 100
pim ipv6 holdtime join-prune interval
undo pim ipv6 holdtime join-prune
【缺省级别】
2:系统级
【描述】
pim ipv6 holdtime join-prune命令用来在接口上配置保持加入/剪枝状态的时间。undo pim ipv6 holdtime join-prune命令用来恢复缺省情况。
相关配置可参考命令holdtime assertpim ipv6 holdtime assertholdtime join-prune
# 在接口Vlan-interface100上配置保持加入/剪枝状态的时间为280秒。
[Sysname-Vlan-interface100] pim ipv6 holdtime join-prune 280
pim ipv6 neighbor-policy acl6-number
undo pim ipv6 neighbor-policy
【缺省级别】
2:系统级
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。在定义该IPv6 ACL时,使用rule命令中的source参数来指定合法Hello报文的源地址范围。
【描述】
pim ipv6 neighbor-policy命令用来配置合法Hello报文的源地址范围,以防止Hello报文欺骗。undo pim ipv6 neighbor-policy命令用来恢复缺省情况。
缺省情况下,Hello报文的源地址范围不受任何限制,即认为所有收到的Hello报文都是合法的。
# 在接口Vlan-interface100上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl6-basic-2000] rule permit source fe80:101::101 64
[Sysname-Vlan-interface100] pim ipv6 neighbor-policy 2000
undo pim ipv6 require-genid
【缺省级别】
2:系统级
【描述】
pim ipv6 require-genid命令用来配置不接受无Generation ID的Hello报文。undo pim ipv6 require-genid命令用来恢复缺省情况。
缺省情况下,接受无Generation ID的Hello报文。
# 配置接口Vlan-interface100不接受无Generation ID的Hello报文。
[Sysname-Vlan-interface100] pim ipv6 require-genid
1.1.48  pim ipv6 sm
pim ipv6 sm
undo pim ipv6 sm
【缺省级别】
2:系统级
【描述】
pim ipv6 sm命令用来使能IPv6 PIM-SM。undo pim ipv6 sm命令用来关闭IPv6 PIM-SM。
缺省情况下,IPv6 PIM-SM处于关闭状态。
相关配置可参考命令pim ipv6 dm,以及“IP组播命令参考/IPv6组播路由与转发”中的命令multicast ipv6 routing-enable
# 使能IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM。
undo pim ipv6 state-refresh-capable
【缺省级别】
2:系统级
【描述】
pim ipv6 state-refresh-capable命令用来使能状态刷新能力。undo pim ipv6 state-refresh-capable命令用来关闭状态刷新能力。
缺省情况下,状态刷新能力处于使能状态。
相关配置可参考命令state-refresh-intervalstate-refresh-rate-limitstate-refresh-hoplimit
# 在接口Vlan-interface100上关闭状态刷新能力。
[Sysname-Vlan-interface100] undo pim ipv6 state-refresh-capable
pim ipv6 timer graft-retry interval
undo pim ipv6 timer graft-retry
【缺省级别】
2:系统级
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
【描述】
pim ipv6 timer graft-retry命令用来配置嫁接报文的重传时间。undo pim ipv6 timer graft-retry命令用来恢复缺省情况。
缺省情况下,嫁接报文的重传时间为3秒。
# 在接口Vlan-interface100上配置嫁接报文的重传时间为80秒。
[Sysname-Vlan-interface100] pim ipv6 timer graft-retry 80
pim ipv6 timer hello interval
undo pim ipv6 timer hello
【缺省级别】
2:系统级
interval:指定发送Hello报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim ipv6 timer hello命令用来在接口上配置发送Hello报文的时间间隔。undo pim ipv6 timer hello命令用来恢复缺省情况。
缺省情况下,发送Hello报文的时间间隔为30秒。
相关配置可参考命令timer hello
# 在接口Vlan-interface100上配置发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface100] pim ipv6 timer hello 40
pim ipv6 timer join-prune interval
undo pim ipv6 timer join-prune
【缺省级别】
2:系统级
interval:指定发送加入/剪枝报文的时间间隔,取值范围为1~2147483647,单位为秒。
【描述】
pim ipv6 timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。undo pim ipv6 timer join-prune命令用来恢复缺省情况。
缺省情况下,发送加入/剪枝报文的时间间隔为60秒。
相关配置可参考命令timer join-prune
# 在接口Vlan-interface100上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-Vlan-interface100] pim ipv6 timer join-prune 80
pim ipv6 triggered-hello-delay interval
undo pim ipv6 triggered-hello-delay
【缺省级别】
2:系统级
interval:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
【描述】
pim ipv6 triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。undo pim ipv6 triggered-hello-delay命令用来恢复缺省情况。
缺省情况下,触发Hello报文的最大延迟时间为5秒。
# 在接口Vlan-interface100上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-Vlan-interface100] pim ipv6 triggered-hello-delay 3
probe-interval interval
undo probe-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定注册探测时间,取值范围为1~1799,单位为秒。
【描述】
probe-interval命令用来配置注册探测时间。undo probe-interval命令用来恢复缺省情况。
缺省情况下,注册探测时间为5秒。
相关配置可参考命令register-suppression-timeout
# 配置注册探测时间为6秒。
[Sysname] pim ipv6
[Sysname-pim6] probe-interval 6
prune delay interval
undo prune delay
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定剪枝延迟时间,取值范围1~128,单位为秒。
【描述】
prune delay命令用来配置剪枝延迟时间。undo prune delay命令用来恢复缺省情况。
缺省情况下,剪枝延迟时间等于剪枝未决时间(Prune Pending Timer,缺省为3秒)。
# 配置剪枝延迟时间为75秒。
[Sysname] pim ipv6
[Sysname-pim6] prune delay 75
register-policy acl6-number
undo register-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定高级IPv6访问控制列表编号,取值范围为3000~3999。只有与IPv6 ACL的permit语句匹配的注册报文才会被RP接受。
【描述】
register-policy命令用来配置注册报文的过滤规则。undo register-policy命令用来删除注册报文的过滤规则。
缺省情况下,没有配置注册报文的过滤规则。
# 配置RP上对注册报文的过滤规则,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] pim ipv6
[Sysname-pim6] register-policy 3000
undo register-suppression-timeout
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
【描述】
register-suppression-timeout命令用来配置注册抑制时间。undo register-suppression-timeout命令用来恢复缺省情况。
缺省情况下,注册抑制时间为60秒。
相关配置可参考命令probe-intervalregister-policy
# 配置注册抑制时间为70秒。
[Sysname] pim ipv6
[Sysname-pim6] register-suppression-timeout 70
undo register-whole-checksum
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。undo register-whole-checksum命令用来恢复缺省情况。
缺省情况下,仅根据注册报文头来计算校验和。
相关配置可参考命令register-policyregister-suppression-timeout
# 配置根据注册报文的全部内容来计算校验和。
[Sysname] pim ipv6
[Sysname-pim6] register-whole-checksum
reset pim ipv6 control-message counters [ interface interface-type interface-number ]
【缺省级别】
1:监控级
interface-type interface-number:接口类型和接口编号,重置指定接口的IPv6 PIM控制报文计数器。如果未指定本参数,将重置所有接口的IPv6 PIM控制报文数量。
【描述】
reset pim ipv6 control-message counters命令用来重置IPv6 PIM控制报文计数器。
# 重置IPv6 PIM控制报文计数器。
<Sysname> reset pim ipv6 control-message counters
source-lifetime interval
undo source-lifetime
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定IPv6组播源的生存时间,取值范围为1~31536000,单位为秒。
【描述】
source-lifetime命令用来配置IPv6组播源的生存时间。undo source-lifetime命令用来恢复缺省情况。
缺省情况下,IPv6组播源的生存时间为210秒。
# 配置IPv6组播源的生存时间为200秒。
[Sysname] pim ipv6
[Sysname-pim6] source-lifetime 200
source-policy acl6-number
undo source-policy
IPv6 PIM视图
【缺省级别】
2:系统级
acl6-number:指定基本或高级IPv6访问控制列表编号,取值范围为2000~3999。
【描述】
source-policy命令用来配置IPv6组播数据过滤器。undo source-policy命令用来删除IPv6组播数据过滤器。
缺省情况下,没有配置IPv6组播数据过滤器。
l              如果指定的是基本访问控制列表,则对收到的IPv6组播数据报文匹配源地址,未通过匹配的报文将被丢弃。
l              如果指定的是高级访问控制列表,则对收到的IPv6组播数据报文匹配源地址和组地址,未通过匹配的报文将被丢弃。
l              重复执行本命令,新的配置会覆盖原有配置。
# 配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl6-basic-2000] rule permit source 3121::1 128
[Sysname-acl6-basic-2000] rule deny source 3121::2 128
[Sysname] pim ipv6
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold infinity [ group-policy acl6-number [ order order-value ] ]
undo spt-switch-threshold [ group-policy acl6-number ]
IPv6 PIM视图
【缺省级别】
2:系统级
group-policy acl6-number:表示IPv6组策略列表中的一项,与该IPv6组策略相匹配的IPv6组播组将应用本配置。acl6-number表示基本IPv6访问控制列表编号,取值范围为2000~2999。如果未指定本参数,本配置将应用于所有IPv6组播组。
order order-value:指定IPv6 ACL在组策略列表中的序号。order-value的取值范围为1~现有组策略列表中的最大序号+1,但取值范围中不包括该IPv6 ACL在组策略列表中的原有序号。如果已为某IPv6 ACL指定了order-value,则不允许为该IPv6 ACL指定相同的order-value,否则系统将报错;如果未指定本参数,则不改变该IPv6 ACL在组策略列表中的序号。
【描述】
spt-switch-threshold infinity命令用来配置发起SPT切换的条件。undo spt-switch-threshold命令用来恢复缺省情况。
缺省情况下,设备收到第一个IPv6组播数据包后便立即向SPT切换。
l              当需要调整组策略列表中已有IPv6 ACL的次序时,可以通过配置参数acl6-number指定该IPv6 ACL,并设置其order-value,将该IPv6 ACL插入到组策略列表的order-value位置。组策略列表中已有的其它IPv6 ACL保持先后排列次序不变。
l              当需要启用组策略列表中没有的IPv6 ACL时,可以通过配置参数acl6-number指定该IPv6 ACL,并设置其order-value,将该IPv6 ACL插入到组策略列表的order-value位置。如果未指定order-value,则将其插入组策略列表的尾部。
l              如果对同一IPv6组播组配置了多条该命令,则该IPv6组播组按顺序匹配到的第一个命令将生效。
l              对于本系列无线PoE注入器来说,一旦建立了IPv6组播转发表项,即使有注册出接口,后续的IPv6组播数据报文也不会被封装成注册报文进行转发。所以,在可能成为RP的无线PoE注入器(即静态RP或C-RP等)上,不要配置永不发起SPT切换,以免导致转发失败。
# 在不可能成为RP的无线PoE注入器上,配置RPT永不发起SPT切换。
[Sysname] pim ipv6
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy acl6-number
undo ssm-policy
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
ssm-policy命令用来配置IPv6 SSM组播组的范围。undo ssm-policy命令用来恢复缺省情况。
缺省情况下,IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] pim ipv6
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit hoplimit-value
undo state-refresh-hoplimit
IPv6 PIM视图
【缺省级别】
2:系统级
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
【描述】
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。undo state-refresh-hoplimit命令用来恢复缺省情况。
缺省情况下,状态刷新报文的Hop Limit值为255。
相关配置可参考命令pim ipv6 state-refresh-capablestate-refresh-intervalstate-refresh-rate-limit
# 配置状态刷新报文的Hop Limit值为45。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-hoplimit 45
undo state-refresh-interval
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
【描述】
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。undo state-refresh-interval命令用来恢复缺省情况。
缺省情况下,发送状态刷新报文的时间间隔为60秒。
相关配置可参考命令pim ipv6 state-refresh-capablestate-refresh-rate-limitstate-refresh-hoplimit
# 配置发送状态刷新报文的时间间隔为70秒。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit interval
undo state-refresh-rate-limit
IPv6 PIM视图
【缺省级别】
2:系统级
interval:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
【描述】
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。undo state-refresh-rate-limit命令用来恢复缺省情况。
缺省情况下,接收新状态刷新报文的等待时间为30秒。
相关配置可参考命令pim ipv6 state-refresh-capablestate-refresh-intervalstate-refresh-hoplimit
# 配置接收新状态刷新报文的等待时间为45秒。
[Sysname] pim ipv6
[Sysname-pim6] state-refresh-rate-limit 45
static-rp ipv6-rp-address [ acl6-number ] [ preferred ] [ bidir ]
undo static-rp ipv6-rp-address
IPv6 PIM视图
【缺省级别】
2:系统级
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是实际存在且有效的IPv6全球单播地址;但对于服务于IPv6双向PIM的静态RP来说,允许将其IPv6地址指定为一个实际不存在的IPv6地址。
acl6-number:指定基本IPv6访问控制列表编号,取值范围为2000~2999。如果指定了本参数,则配置的静态RP只为能够通过匹配的IPv6组播组服务;如果未指定本参数,则配置的静态RP将为所有IPv6组播组服务。
preferred:指定当静态RP与动态RP冲突时,优先选择静态RP。如果未指定本参数,则优先选择动态RP,如果网络中没有动态RP或动态RP失效,静态RP才能生效。
bidir:指定该静态RP服务于IPv6双向PIM。如果未指定本参数,该静态RP将服务于IPv6 PIM-SM。
【描述】
static-rp命令用来配置静态RP。undo static-rp命令用来删除静态RP。
缺省情况下,没有配置静态RP。
l              作为静态RP的接口不必使能IPv6 PIM-SM或IPv6 PIM-DM。
l              当某个静态RP引用的IPv6 ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
l              重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或IPv6 ACL规则相同,则新配置将覆盖旧配置;如果存在多个静态RP服务于同一IPv6组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
l              一台设备上最多可以配置50个不同的静态RP。
相关配置可参考命令display pim ipv6 rp-info
# 配置IPv6地址为2001::2的接口为静态RP,为IPv6 ACL 2001所定义的IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source ff03::101 64
[Sysname-acl6-basic-2001] quit
[Sysname] pim ipv6
[Sysname-pim6] static-rp 2001::2 2001 preferred
undo timer hello
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
timer hello命令用来全局配置发送Hello报文的时间间隔。undo timer hello命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 timer hello
# 全局配置发送Hello报文的时间间隔为40秒。
[Sysname] pim ipv6
[Sysname-pim6] timer hello 40
undo timer join-prune
IPv6 PIM视图
【缺省级别】
2:系统级
【描述】
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。undo timer join-prune命令用来恢复缺省情况。
相关配置可参考命令pim ipv6 timer join-prune
# 全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] pim ipv6
[Sysname-pim6] timer join-prune 80
