27-WLAN命令参考(FAT AP)
03-WLAN接入命令
本章节下载  (432.99 KB)
03-WLAN接入命令
  录
1 WLAN接入
1.1 WLAN接入配置命令
1.1.1 access-control acl
1.1.2 beacon ssid-advertise
1.1.3 beacon ssid-hide
1.1.4 client max-count
1.1.5 client smart-access enable
1.1.6 customlog format wlan
1.1.7 description
1.1.8 display interface wlan-radio
1.1.9 display wlan ap all client-number
1.1.10 display wlan ap all radio client-number
1.1.11 display wlan blacklist
1.1.12 display wlan bss
1.1.13 display wlan client
1.1.14 display wlan client ipv6
1.1.15 display wlan client online-duration
1.1.16 display wlan client status
1.1.17 display wlan service-template
1.1.18 display wlan statistics client
1.1.19 display wlan statistics connect-history
1.1.20 display wlan statistics service-template
1.1.21 display wlan whitelist
1.1.22 interface wlan-radio
1.1.23 nas-id
1.1.24 nas-port-type
1.1.25 quick-association enable
1.1.26 reset wlan client
1.1.27 reset wlan dynamic-blacklist
1.1.28 reset wlan statistics client
1.1.29 reset wlan statistics service-template
1.1.30 service-template
1.1.31 service-template enable
1.1.32 snmp-agent trap enable wlan client
1.1.33 snmp-agent trap enable wlan client-audit
1.1.34 ssid
1.1.35 unknown-client
1.1.36 vlan
1.1.37 wlan association optimization
1.1.38 wlan broadcast-probe reply
1.1.39 wlan client idle-timeout
1.1.40 wlan client keep-alive
1.1.41 wlan client keep-alive interval
1.1.42 wlan client reauthentication-period
1.1.43 wlan dynamic-blacklist lifetime
1.1.44 wlan led-mode
1.1.45 wlan link-test
1.1.46 wlan nas-port-id format
1.1.47 wlan service-template
1.1.48 wlan static-blacklist mac-address
1.1.49 wlan web-server api-path
1.1.50 wlan web-server host
1.1.51 wlan web-server max-client-entry
1.1.52 wlan whitelist mac-address
1 WLAN接入
·     设备对无线接入功能的支持情况请参见“WLAN特性与硬件适配关系(FAT AP)”。
·     不同设备的接口编号对应的射频模式不同,本文中仅以WLAN-Radio0/0举例。具体接口编号对应的射频模式,请以设备实际情况为准。
1.1  WLAN接入配置命令
access-control acl命令用来配置基于ACL的接入控制。
undo access-control acl命令用来恢复缺省情况。
access-control acl acl-number
未配置基于ACL的接入控制。
无线服务模板视图
acl-number:二层ACL的编号,取值范围为4000~4999。
基于ACL的接入控制是指设备根据指定ACL中配置的规则对新接入的无线客户端进行接入控制。
当无线客户端接入无线网络时,设备会判断无线客户端的MAC地址是否在ACL访问控制列表的规则中,具体的过滤机制如下:
·     如果在permit规则中,则允许无线客户端接入无线网络;
·     如果在deny规则中,则拒绝无线客户端接入无线网络;
·     如果未匹配任何已配置的规则,则拒绝其接入。
设备支持MAC地址匹配和OUI匹配。当ACL访问控制列表中存在OUI匹配时,只要客户端与OUI匹配,就可以接入网络。
需要注意的是,当在ACL中配置deny规则来拒绝指定客户端接入时,请在deny规则之后配置允许所有客户端接入的permit规则,否则会导致所有客户端无法接入。
基于ACL的接入控制的优先级高于基于名单的接入控制的优先级。当设备上没有配置无线客户端访问控制规则时,按照基于名单的接入控制规则对无线客户端进行访问控制。
多次执行本命令,最后一次执行的命令生效。
# 在无线服务模板下,配置基于ACL的接入控制为4000,仅允许MAC地址为000e-35b2-000e以及匹配OUI值为000e-35的无线客户端接入。
[Syname] acl mac 4000
[Syname-acl-mac-4000] rule 0 permit source-mac 000e-35b2-000e ffff-ffff-ffff
[Syname-acl-mac-4000] rule 1 permit source-mac 000e-35b2-000f ffff-ff00-0000
[Syname-acl-mac-4000] rule 2 deny
[Syname-acl-mac-4000] quit
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] access-control acl 4000
beacon ssid-advertise命令用来配置在信标帧中通告SSID。
undo beacon ssid-advertise命令用来恢复缺省情况。
信标帧不强制通告SSID。
无线服务模板视图
当射频或无线服务模板下关联的客户端数目达到最大值时,AP会在Beacon帧中隐藏SSID信息,导致客户端无法发现并关联AP,配置本命令可以强制AP在Beacon帧中通告SSID信息,使客户端可以发现AP,但无法进行关联。
# 配置在信标帧中通告SSID。
[Sysname-wlan-st-s1] beacon ssid-advertise
·     client max-count
beacon ssid-hide命令用来配置在信标帧中隐藏SSID,即不通告SSID。
undo beacon ssid-hide命令用来恢复缺省情况。
beacon ssid-hide
信标帧不隐藏SSID。
无线服务模板视图
服务模板配置SSID隐藏,即将无线服务模板绑定到某个射频后,该射频发送的Beacon帧将不携带SSID信息,而且不回复广播Probe Request帧。
# 配置在信标帧中隐藏SSID。
[Sysname-wlan-st-service1] beacon ssid-hide
client max-count命令用来配置无线服务模板允许关联的最大客户端数目。
undo client max-count命令用来恢复缺省情况。
client max-count max-number
不限制无线服务模板允许关联的最大客户端数目。
无线服务模板视图
max-number:无线服务模板所允许关联的最大客户端数目,取值范围为1~512。
无线服务模板上关联的客户端数达到允许关联的最大客户端数目后,将不再接受新的客户端接入且SSID会自动隐藏。
# 配置无线服务模板允许关联的最大客户端数目为38。
[Sysname-wlan-st-service1] client max-count 38
·     beacon ssid-hide
client smart-access enable命令用来开启无线客户端智能接入功能。
undo client smart-access enable命令用来恢复缺省情况。
无线客户端智能接入功能处于关闭状态。
无线服务模板视图
对于某些物联网应用场景,用户希望我司配套的无线客户端产品能自动发现并连接当前网络中的缺省SSID。开启本功能后,可以在仅创建无线服务模板或身份认证与密钥管理模式配置为PSK的情况下,自动将我司配套的无线客户端接入到无线网络。
# 在无线服务模板视图下,开启无线客户端智能接入功能。
[Sysname-wlan-st-service1] client smart-access enable
customlog format wlan命令用来配置客户端上线日志的格式。
undo customlog format wlan命令用来恢复缺省情况。
customlog format wlan { normal | sangfor }
输出H3C格式的客户端上线日志。
normal:指定日志格式为normal格式。
sangfor:指定日志格式为sangfor格式。
配置本功能后,设备支持同时输出H3C格式和指定格式的客户端上线日志信息。
·     H3C格式的日志内容主要包含客户端上线的AP名称、Radio ID、客户端MAC地址、关联的SSID、BSSID及客户端的上线状态变化。
·     指定格式的日志有两种类型。
¡     normal格式:日志内容为客户端上线的AP的MAC地址、AP名称、客户端IP地址、客户端MAC地址、关联的SSID及BSSID。
¡     sangfor格式:日志内容为客户端上线的AP的MAC地址、客户端IP地址和客户端MAC地址。
# 配置客户端上线日志的格式为sangfor格式。
[Sysname] customlog format wlan sangfor
1.1.7  description
description命令用来配置无线服务模板的描述信息。
undo description命令用来恢复缺省情况。
未配置无线服务模板的描述信息。
无线服务模板视图
text:无线服务模板的描述信息,为1~64个字符的字符串,区分大小写。
# 配置无线服务模板service1的描述信息为wlanst。
[Sysname-wlan-st-service1] description wlanst
display interface wlan-radio命令用来显示WLAN射频接口信息。
display interface wlan-radio [ interface-number ] [ brief ]
interface-number:WLAN射频接口编号,显示指定WLAN射频接口的详细信息。不指定该参数时,将显示所有WLAN射频接口的信息。
# 显示WLAN射频接口1的详细信息。
<Sysname> display interface wlan-radio 0/0
WLAN-Radio0/0
Current state: UP
Description: WLAN-Radio0/0 Interface
IP Packet Frame Type: PKTFMT_IEEE_802.11, Hardware Address: d461-fe59-4d20
current mode: 802.11ac, current channel: 36
Last link flapping: 0 hours 31 minutes 6 seconds
Current system time:2016-01-01 00:31:19
Last time when physical state changed to up:2016-01-01 00:00:13
Last time when physical state changed to down:2016-01-01 00:00:13
Input (total): 0 packets, 0 bytes
Input (normal): 0packets, 0bytes
                0 management, 0 control, 0 data
Input (error): 0 total, 0 CRC, 0 decrypt errors
               0 mic failures, 0 phy errors, 0 other errors
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets
                 Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes
Output (bcn&probe): 0 packets, 0 bytes
Output (error): 0 total, 0 discard, 0 buffer failures
                0 ack failures, 0 rts successed, 0 rts failures
# 显示WLAN射频接口1的概要信息。
<Sysname> display interface wlan-radio 0/0 brief
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
WLAN-Radio0/0        UP   --        --     --   --
表1-1 display interface wlan-radio命令显示信息描述表
WLAN-Radio0/0
接口WLAN-Radio0/0的相关信息
Current state
接口物理连接状态:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
接口描述信息
802.11帧格式,取值为PKTFMT_IEEE_802.11表示报文以802.11型帧格式封装
Hardware Address
接口的MAC地址
current mode
接口当前的射频类型
current channel
接口当前所在信道
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never)
Current system time
当前系统时间,时间显示格式为YYYY/MM/DD HH:MM:SS
如果配置了时区,时间显示格式为YYYY/MM/DD HH:MM:SS UTC±HH:MM:SS
最近一次接口物理状态变为UP的时刻“-”表示接口物理状态没有发生过变化
最近一次接口物理状态变为DOWN的时刻“-”表示接口物理状态没有发生过变化
Input(total): 0 packets, 0 bytes
接口接收报文的统计值,包括正常报文和异常报文的报文数、字节数
Input (normal): 0packets, 0bytes 0 management, 0 control, 0 data
接口接收的正常报文的统计值,包括正常报文的报文数、字节数
接口接收的正常管理报文、控制报文和数据报文的数量
Input (error)
接口接收的错误报文的统计值
接口发送报文的统计值,包括正常报文和异常报文的报文数、字节数
Output (normal): Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 packets Q[0]:0, Q[1]:0, Q[2]:0, Q[3]:0 bytes 0 management, 0 control, 0 data
接口发送的正常报文的统计值,Q[]表示AC队列
接口发送的正常管理报文、控制报文和数据报文的数量
Output (bcn&probe)
接口发送Beacon帧和Probe帧的报文数、字节数
Output (error)
接口发送的错误报文的统计值
二层模式下(bridge)接口的概要信息,即二层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
Speed: (a) - auto
如果该接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
当接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
接口名称缩写
Link
接口物理连接状态
Speed
显示为“--”,对于WLANRadio接口无意义
Duplex
PVID
·     interface wlan-radio
display wlan ap all client-number命令用来显示AP上2.4GHz及5GHz频段的在线客户端数量。
# 显示AP上2.4GHz及5GHz频段的在线客户端数量。
<System> display wlan ap all client-number
AP name           Clients           2.4GHz            5GHz
fatap             2                 2                 0
表1-2 display wlan ap clients-number命令显示信息描述表
AP name
AP名称
Clients
AP上所有在线客户端数量
2.4GHz
AP上2.4GHz频段的在线客户端数量
5GHz
AP上5GHz频段的在线客户端数量
display wlan ap all radio client-number命令用来显示AP的所有Radio接口下在线客户端数量和信道信息。
# 显示AP的所有Radio接口下在线客户端数量和信道信息。
<Sysname> display wlan ap all radio client-number
AP name                    RID     Channel     Clients
fatap                      1       44 12
fatap                      2       11          4
表1-3 display wlan ap all radio client-number命令显示信息描述表
AP name
AP名称
RID
射频ID
Channel
射频工作信道
Clients
在线客户端数量
display wlan blacklist命令用来显示黑名单。
display wlan blacklist { dynamic | static }
dynamic:显示动态黑名单。
static:显示静态黑名单。
# 显示静态黑名单。
<Sysname> display wlan blacklist static
Total number of clients: 3
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
表1-4 display wlan blacklist static命令显示信息描述表
静态黑名单中的客户端数量
MAC addresses
黑名单列表中的客户端MAC地址
# 显示动态黑名单。
<Sysname> display wlan blacklist dynamic
MAC address     APID  Lifetime (s)  Duration (hh:mm:ss)
000f-e2cc-0001  1     300           00:02:11
000f-e2cc-0002  2     300           00:01:17
000f-e2cc-0003  3     300           00:02:08
表1-5 display wlan blacklist dynamic命令显示信息描述表
动态黑名单中的客户端数量
MAC address
客户端MAC地址
APID
检测到非法客户端的AP的序列号
Lifetime (s)
动态黑名单表项的老化时间,单位为秒
Duration (hh:mm:ss)
动态黑名单表项的存活时间
display wlan bss命令用来显示BSS(Basic Service Set,基本服务集)信息。
display wlan bss { all | bssid bssid } [ verbose ]
all:显示所有BSS信息。
bssid bssid:显示指定BSSID(Basic Service Set ID,基本服务集标识)的BSS信息,bssid为48位的16进制数,格式为H-H-H。
verbose:显示BSS的详细信息。如果不指定本参数,则显示BSS的简要信息。
# 显示所有BSS的简要信息。
<Sysname> display wlan bss all
Total number of BSSs: 4
AP name                   RID  SSID                            BSSID
fatap                     1    SSID1                           001c-f08f-f804
fatap                     2    SSID1                           001c-f08f-f806
表1-6 display wlan bss all命令显示信息描述表
AP name
AP名称
RID
AP的Radio ID
SSID
无线服务模板的SSID
BSSID
基本服务集标识
# 显示BSSID为001c-f08f-f804的BSS的详细信息。
<Sysname> display wlan bss bssid 001c-f08f-f804 verbose
AP name                       : fatap
BSSID                         : 001c-f08f-f804
Radio ID                      : 1
Service template name         : servcie1
SSID                          : SSID1
VLAN ID                       : 1
AKM mode                      : Not configured
User authentication mode      : Bypass
表1-7 display wlan bss bssid verbose命令显示信息描述表
AP name
AP名称
BSSID
基本服务集标识
Radio ID
AP的Radio ID
无线服务模板的名称
SSID
无线服务模板的SSID
VLAN ID
无线客户端的接入VLAN
AKM mode
身份认证与密钥管理模式:
·     802.1X:表示用户认证与密钥管理模式是802.1X方式
·     PSK:表示身份认证与密钥管理模式是PSK方式
·     Not configured:未配置身份认证与密钥管理模式
用户认证模式:
·     Bypass:不做用户认证
·     MAC:MAC地址认证
·     802.1X:802.1X认证
·     OUI:OUI认证
display wlan client命令用来查看客户端的信息。
display wlan client [ interface wlan-radio interface-number | mac-address mac-address | service-template service-template-name | vlan vlan-id ] [ verbose ]
interface wlan-radio interface-number:显示连接到指定射频接口的客户端信息。
mac-address mac-address:显示指定MAC地址的客户端信息。
service-template service-template-name:显示连接到指定无线服务模板的客户端信息,为1~63个字符的字符串,不区分大小写。
verbose:显示客户端的详细信息。如果未指定本参数,表示显示客户端的简要信息。
vlan vlan-id:显示连接到指定VLAN的客户端信息。vlan-id为VLAN的编号,取值范围1~4094。
# 显示所有客户端的简要信息。
<Sysname> display wlan client
MAC address    Username             AP name               R IP address      VLAN
000f-e265-6400 N/A                  fatap                 1 1.1.1.1         100
000f-e265-6401 user                 fatap                 1 3.0.0.3         200
84db-ac14-dd08 N/A                  fatap                 1 5.5.5.3         1
表1-8 display wlan client命令显示信息描述表
MAC address
客户端的MAC地址
Username
客户端的用户名,若客户端采用802.1X认证或MAC地址认证,则显示认证使用的用户名,若客户端不进行802.1X认证或MAC地址认证,则显示为N/A
需要注意的是,如果客户端采用Portal认证方式,Username字段不会显示客户端的Portal用户名,显示为N/A
AP name
客户端关联AP的名称
R
客户端关联的Radio ID
IP address
客户端的IPv4地址
VLAN ID
客户端所属VLAN
# 显示指定客户端的详细信息。
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address                        : 000f-e265-6400
IPv4 address                       : 10.1.1.114
IPv6 address                       : 2001::1234:5678:0102:0304
Username                           : N/A
AID                                : 1
Radio ID                           : 1
SSID                               : office
BSSID                              : 0026-3e08-1150
VLAN ID                            : 3
Sleep count                        :3
Wireless mode                      : 802.11gn
Channel bandwidth                  : 20MHz
SM power save                      : Enabled
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set                 : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
Supported rates                    : 1, 2, 5.5, 6, 9, 11,
                                     12, 18, 24, 36, 48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/195 Mbps
Speed                              :N/A
Authentication method              : Open system
Security mode                      : PRE-RSNA
Cipher suite                       : N/A
WPA3 status                        : Disabled
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Authorization CAR                  :
  Average input rate               : 102400 bps
  Average output rate              : 102400 bps
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forwarding policy name             : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
表1-9 display wlan client verbose命令显示信息描述表
MAC address
客户端的MAC地址
IPv4 address
客户端的IPv4地址
IPv6 address
客户端的IPv6地址
Username
AID
关联标识符
Radio ID
客户端关联的Radio ID
SSID
客户端关联的SSID
BSSID
基本服务集识别码
VLAN ID
客户端所属的VLAN
Sleep count
客户端睡眠次数
Wireless mode
客户端工作的模式:
·     802.11a:工作模式为 802.11a
·     802.11b:工作模式为 802.11b
·     802.11g:工作模式为 802.11g
·     802.11gn:工作模式为 802.11gn
·     802.11an:工作模式为 802.11an
·     802.11ac:工作模式为802.11ac
·     802.11gac:工作模式为802.11gac
Channel bandwidth
客户端的工作带宽模式:
·     20MHz:工作带宽为20MHz
·     40MHz:工作带宽为40MHz
·     80MHz:工作带宽为80MHz
·     160MHz:工作带宽为160MHz
20/40 BSS Coexistence Management
客户端是否支持20M和40M带宽共存管理
SM Power Save
省电模式状态:
·     Enabled:省电模式处于开启状态,省电模式开启后客户端上只有一个天线处于工作状态,其余天线均处于休眠状态,从而达到节电的目的
·     Disabled:省电模式处于关闭状态
Short GI for 20MHz
客户端工作带宽为20MHz时,对于Short GI的支持情况:
·     Supported:客户端支持Short GI
·     Not supported:客户端不支持Short GI
Short GI for 40MHz
客户端工作带宽为40MHz时,对于Short GI的支持情况:
Short GI for 80MHz
客户端工作带宽为80MHz时,对于Short GI的支持情况:
客户端工作带宽为160或80+80MHz时,对于Short GI的支持情况:
STBC RX capability
客户端STBC接收能力情况:
·     Supported:客户端支持STBC接收
·     Not supported:客户端不支持STBC接收
STBC Tx capability
客户端STBC发送能力情况:
·     Supported:客户端支持STBC发送
·     Not supported:客户端不支持STBC发送
LDPC Rx capability
客户端LDPC接收能力情况:
·     Supported:客户端支持LDPC接收
·     Not supported:客户端不支持LDPC接收
客户端单用户波束成形能力情况:
·     Supported:客户端支持单用户波束成形
·     Not supported:客户端不支持单用户波束成形
客户端多用户波束成形能力情况:
·     Supported:客户端支持多用户波束成形
·     Not supported:客户端不支持多用户波束成形
客户端作为波束成形接收者,支持的空间流数:
·     N/A:表示客户端不支持作为波束成形接收者
·     0~7:波束成形空间流最大值减1
Number of Sounding Dimensions
客户端作为波束成形发送者,支持的空间流数:
·     N/A:表示客户端不支持作为波束成形发送者
·     0~7:波束成形空间流最大值减1
Block Ack
QoS TID的Block Ack协商结果:
·     TID 0 In:表示上行数据报文支持Block Ack
·     TID 0 Out:表示下行数据报文支持Block Ack
·     TID 0 Both:表示上行和下行数据报文都支持Block Ack
·     N/A:表示上行和下行数据报文都不支持Block Ack
客户端支持VHT-MCS
客户端支持MCS
Supported rates
客户端支持的速率
QoS mode
QoS模式:
·     N/A:不支持WMM协议
·     WMM:支持WMM协议
对于WMM的支持情况,AP和客户端会进行协商。只有AP和客户端同时支持WMM时,才能协商成功
Listen interval
处于睡眠模式的客户端定期醒来,接收缓存在AP中的数据帧的时间间隔,间隔时间单位为信标发送时间间隔
RSSI
客户端信号强度指示,该值表明了AP检测到客户端的信号强度
Rx/Tx rate
客户端发送/接收报文的速率(包括数据、管理和控制报文)
Speed
最近2分钟内客户端发送/接收报文的速率(以Kbps为单位显示,保留小数点后三位),当显示N/A时,表示设备获取到的客户端发送/接收报文的速率为0
链路层认证方法:
·     Open system:开放系统认证
·     Shared key:共享密钥认证
·     SAE:SAE密钥认证
Security mode
安全模式:
·     RSN:信标和探查响应帧携带RSN IE
·     WPA:信标和探查响应帧携带WPA IE
·     PRE-RSNA:信标和探查响应帧不携带RSN IE或WPA IE
AKM mode
身份认证与密钥管理模式:
·     802.1X:表示身份认证与密钥管理模式是802.1X方式
·     OWE:表示身份证与密钥管理模式是机会性无线机密方式
Cipher suite
加密套件:
·     N/A:明文方式,不加密
·     WEP40:使用WEP40加密套件
·     WEP104:使用WEP104加密套件
·     WEP128:使用WEP128加密套件
·     CCMP:使用AES-CCMP加密套件
·     TKIP:使用TKIP加密套件
用户认证模式:
·     Bypass:不做用户认证
·     MAC:MAC认证
·     802.1X:802.1X认证
·     OUI :OUI认证
WPA3 status
(暂不支持)WPA3安全模式状态:
·     Disabled:关闭状态
·     Enabled:开启状态
·     N/A:不涉及WPA3安全模式
授权ACL对应的ACL编号:
·     授权ACL生效,则显示ACL编号
·     授权ACL未生效,则显示ACL编号 + Not effective
·     不配置授权ACL,显示N/A
授权User profile名称:
·     如果下发授权User Profile生效,显示Authorization User Profile名称
·     如果下发授权User Profile未生效,显示Authorization User Profile名称+Not effective
·     不配置授权User profile,显示N/A
Authorization CAR
当服务器未授权用户CAR属性时,该字段显示为N/A
当服务器授权用户CAR属性,将分为以下两个字段:
·     Average input rate :上行平均速率,单位为bps
·     Average output rate:下行平均速率,单位为bps
Roam status
(暂不支持)漫游状态:
·     Roaming in progress:漫游切换中
·     Inter-AC roam:AC间漫游
·     Inter-MA roam:MA间漫游
·     Intra-AC roam:AC内漫游
·     Intra-MA roam:MA内漫游
·     N/A:客户端正常上线
Key derivation
密钥衍生类型,包括以下几种:
·     SHA1:SHA1 Key Derivation
·     SHA256:SHA256 Key Derivation
·     N/A:不涉及密钥衍生算法
PMF status
保护管理帧状态,包括以下几种:
·     Enabled:保护管理帧功能开启
·     Disabled:保护管理帧功能关闭
·     N/A:不涉及保护管理帧功能
无线转发策略:
·     Not configured:未配置无线转发策略
·     policy-name:无线转发策略名称
Online time
客户端在线的时间
FT status
(暂不支持)快速BSS切换功能状态:
·     Active:开启状态
·     Inactive:关闭状态
display wlan client ipv6命令用来显示客户端的IPv6地址信息。
# 显示客户端的IPv6地址信息。
<Sysname> display wlan client ipv6
MAC address    AP name              IPv6 address                            VLAN
84db-ac14-dd08 fatap                1::2:0:0:3 300
表1-10 display wlan client ipv6命令显示信息描述表
MAC address
客户端的MAC地址
AP name
客户端关联AP的名称
IPv6 address
客户端的IPv6地址
VLAN
客户端所属VLAN
display wlan client online-duration命令用来显示客户端在线时长。
display wlan client online-duration [ verbose ]
# 显示客户端在线时长。
<Sysname> display wlan client online-duration
Total number of online clients: 2
MAC address            IPv4 address    Online duration
a4c1-5b79-fa5b-1d62    192.168.11.123 0days 0hours 2minutes 23seconds
22d3-c5b7-a4b5-96fa    192.168.11.234 0days 0hours 5minutes 34seconds
表1-11 display wlan client online-duration命令显示信息描述表
MAC address
客户端MAC地址
IPv4 address
客户端IP地址
Online duration
客户端在线时长
display wlan client status命令用来显示客户端状态信息。
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address:显示指定客户端的状态信息,mac-address表示客户端的MAC地址格式为H-H-H。如果未指定本参数,则显示所有客户端的状态信息。
verbose:显示客户端的详细状态信息。如果未指定本参数,则显示客户端的简要状态信息。
# 显示指定客户端的简要状态信息。
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address     RSSI  Rx/Tx rate(bps)   Speed(bps)   Discard  AP name          RID
001c-f08f-f804  0     39/117Mbps        N/A          0.00     fatap            2
# 显示所有客户端的简要状态信息。
Total number of clients: 2
000b-c002-9d09  65    39/117Mbps        N/A          0.00%    fatap            2
000f-e265-6401  62    130/195Mbps       N/A          0.00%    fatap            1
表1-12 display wlan client status命令显示信息描述表
MAC address
客户端的MAC地址
RSSI
客户端发送关联请求报文时,AP检测到的客户端的信号强度
Rx/Tx rate(bps)
Speed(bps)
最近2分钟内客户端发送/接收报文的速率。
·     当报文速率小于1M时,以Kbps为单位显示,并保留一位小数
·     当报文速率大于等于1M时,以Mbps为单位显示,保留一位小数
·     当显示N/A时,表示设备获取到的客户端发送/接收报文的速率为0
Discard
客户端丢弃报文百分比
AP name
客户端关联的AP名称
RID
客户端关联的Radio ID
# 显示指定客户端的详细状态信息。
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address                       : 001c-f08f-f804
Radio ID                          : 2
RSSI                              : 0
Rx/Tx rate                        : 39/117 Mbps
Speed                             :N/A
Received:
 Retransmitted packets            : 84
 Retransmitted packet ratio       : 64.12%
Sent:
 Retransmitted packets            : 0
 Retransmitted packet ratio       : 0.00%
Discarded:
 Discarded packets                : 0
 Discarded packet ratio           : 0.00%
表1-13 display wlan client status命令显示信息描述表
MAC address
客户端的MAC地址
AP name
客户端的关联AP名称
Radio ID
客户端的关联的Radio ID
RSSI
Rx/Tx rate
Speed
Received
AP接收报文统计:
·     Retransmitted packets:重传报文数
·     Retransmitted packet ratio:重传报文占接收报文的百分比
Sent
AP发送报文统计:
·     Retransmitted packet ratio:重传报文占发送报文的百分比
Discarded
客户端丢弃报文统计:
·     Discarded packets:丢弃报文数
·     Discarded packet ratio:丢弃报文占所有接收和发送报文百分比
display wlan service-template命令用来显示无线服务模板信息。
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name:无线服务模板名称,为1~63个字符的字符串。不区分大小写。如果未指定本参数,则显示所有无线服务模板的信息。
verbose:显示无线服务模板的详细信息。如果未指定本参数,则显示无线服务模板的概要信息。
# 显示无线服务模板的概要信息。
[Sysname] display wlan service-template
Total number of service templates: 2
Service template name           SSID                                    Status
1                               2333                                    Enabled
2                               3222                                    Enabled
表1-14 display wlan service-template命令显示信息描述表
无线服务模板名称
SSID
无线服务模板的SSID
Status
无线服务模板状态:
·     Disabled:关闭状态
·     Enabled:开启状态
# 显示无线服务模板详细信息。
<Sysname> display wlan service-template verbose
Service template name                            : service1
Description                                      : Not configured
SSID                                             : wuxianfuwu
SSID-hide                                        : Disabled
User-isolation                                   : Disabled
Service template status                          : Disabled
Maximum clients per BSS                          : 64
Frame format                                     : Dot3
Seamless roam status                             : Disabled
Seamless roam RSSI threshold                     : 50
Seamless roam RSSI gap                           : 20
VLAN ID                                          : 1
AKM mode                                         : PSK
Security IE                                      : RSN
Cipher suite                                     : CCMP
WEP key ID                                       : 1
TKIP countermeasure time                         : 100 sec
PTK lifetime                                     : 43200 sec
PTK rekey                                        : Enabled
GTK rekey                                        : Enabled
GTK rekey method                                 : Time-based
GTK rekey time                                   : 86400 sec
GTK rekey client-offline                         : Enabled
PPSK                                             : Disabled
PPSK Fail Permit                                 : Disabled
Enhance-open status                              : Enabled
Enhanced-open transition-mode service-template   : N/A
Intrusion protection                             : Disabled
Intrusion protection mode                        : Temporary-block
Temporary block time                             : 180 sec
Temporary service stop time                      : 20 sec
Fail VLAN ID                                     : 1
802.1X handshake                                 : Enabled
802.1X handshake secure                          : Disabled
802.1X domain                                    : my-domain
MAC-auth domain                                  : Not configured
Max 802.1X users per BSS                         : 4096
Max MAC-auth users per BSS                       : 4096
802.1X re-authenticate                           : Enabled
Authorization fail mode                          : Online
Accounting fail mode                             : Online
Authorization                                    : Permitted
PMF status                                       : Optional
Hotspot policy number                            : Not configured
Forwarding policy status                         : Disabled
Forwarder                                        : AP
FT status                                        : Disabled
QoS trust                                        : Port
QoS priority                                     : 0
表1-15 display wlan service-template verbose命令显示信息描述表
无线服务模板名称
无线服务模板的描述信息
SSID
无线服务模板的SSID
SSID-hide
SSID隐藏:
·     Disabled:启用SSID通告
·     Enabled:禁用SSID通告
User-isolation
(暂不支持)用户隔离功能状态:
·     Disabled:关闭状态
·     Enabled:开启状态
无线服务模板状态:
·     Disabled:关闭状态
·     Enabled:开启状态
一个BSS中能够连接的最大客户端数
Frame format
客户端数据报文封装格式:
·     Dot3:802.3格式
·     Dot11:802.11格式
Seamless-roam
(暂不支持)零漫游功能:
·     Disabled:关闭状态
·     Enabled:开启状态
Seamless-roam RSSI threshold
(暂不支持)零漫游RSSI门限
Seamless-roam RSSI gap
(暂不支持)零漫游RSSI差值门限
VLAN ID
无线客户端从指定无线服务模板上线后所属的VLAN
AKM mode
身份认证与密钥管理模式:
·     802.1X:以802.1X作为身份认证与密钥管理模式
·     PSK:以PSK作为身份认证与密钥管理模式
Security IE
安全IE类型:
·     RSN:RSN类型
·     WPA:WPA类型
Cipher suite
加密套件:
·     WEP40:使用WEP40作为加密套件
·     WEP104:使用WEP104作为加密套件
·     WEP128:使用WEP128作为加密套件
·     TKIP:使用TKIP作为加密套件
·     CCMP:使用CCMP作为加密套件
·     GCMP:使用GCMP作为加密套件
WEP key ID
WEP密钥ID
TKIP反制策略的时间,0表示不启动反制策略
PTK life time
PTK的生存时间
PTK rekey
PTK更新功能状态:
·     Enabled:开启状态
·     Disabled:关闭状态
GTK rekey
GTK更新功能状态:
·     Enabled:开启状态
·     Disabled:关闭状态
GTK rekey method
GTK更新方法:
·     Time-based:基于时间更新
·     Packet-based:基于报文数更新
GTK rekey time
GTK更新的时间间隔
GTK rekey packets
触发GTK更新的最大报文数量
客户端离线更新功能状态:
·     Enabled:开启状态
·     Disabled:关闭状态
WPA3 status
(暂不支持)WPA3安全模式状态:
·     Disabled:关闭状态
·     Mandatory:强制模式
·     Optional:可选模式
PPSK
PPSK功能状态:
·     Disabled:关闭状态
·     Enabled:开启状态
PPSK Fail Permit
PPSK无线用户逃生功能状态:
·     Disabled:关闭状态
·     Enabled:开启状态
Enhance-open status
Enhanced-open功能状态:
·     Disabled:关闭状态
·     Enabled:开启状态
过渡模式下推荐的无线服务模板。未配置,则显示N/A
认证模式,包括以下几种:
·     Bypass:不认证模式
·     MAC:只进行MAC地址认证
·     MAC-or-802.1X:先进行MAC地址认证,如果失败在进行802.1X认证
·     802.1X:只进行802.1X认证
·     802.1X-or-MAC:先进行802.1X认证,如果失败,再进行MAC地址认证
·     OUI-or-802.1X:先进行OUI认证,如果失败,再进行802.1X认证
入侵检测功能状态:
·     Enabled:开启状态
·     Disabled:关闭状态
入侵检测特性模式,包括以下三种:
·     Temporary-block:表示临时将用户MAC加入阻止MAC列表中
·     Service-stop:表示直接关闭对应BSS上的所有服务,直到重启该BSS
·     Temporary-service-stop:表示临时关闭收到非法报文的BSS所提供的接入服务
临时阻塞非法入侵用户的时长,单位为秒
临时关闭BSS服务时长,单位为秒
Fail VLAN ID
认证失败的VLAN ID。未配置,则显示“Not configured”
802.1X handshake
802.1X握手功能状态
·     Enabled:开启状态
·     Disabled:关闭状态
802.1X安全握手功能状态
·     Enabled:开启状态
·     Disabled:关闭状态
802.1X domain
802.1X认证域的域名。未配置,则显示“Not configured”
MAC-auth domain
MAC地址认证域的域名。未配置,则显示“Not configured”
一个BSS中能够进行802.1X认证的最大用户数
一个BSS中能够进行MAC地址认证的最大用户数
802.1X重认证功能状态:
·     Enabled:开启状态
·     Disabled:关闭状态
授权失败处理模式包括以下两种模式:
·     Offline:强制下线模式
·     Online:非强制下线模式
计费请求失败处理模式包括以下两种模式:
·     Offline:下线模式
·     Online:非下线模式
Authorization
服务器的授权信息:
·     Permitted:应用RADIUS服务器或本地设备下发的授权信息
·     Ignored:忽略RADIUS服务器或本地设备下发的授权信息
Key derivation
密钥衍生类型,包括以下几种:
·     SHA1:表示使用SHA1算法衍生密钥
·     SHA256:表示使用SHA256算法衍生密钥
·     SHA1-AND-SHA256:表示使用SHA1 and SHA256算法衍生密钥
PMF status
保护管理帧状态,包括以下几种:
·     Optional:保护管理帧功能可选
·     Mandatory:保护管理帧功能强制
(暂不支持)Hotspot 2.0策略号
无线转发策略状态:
·     Disabled:关闭状态
·     Enabled:开启状态
Forward policy name
无线转发策略名称:
Forwarder
客户端数据报文的转发位置:
·     AP:转发位置在AP上
FT status
(暂不支持)FT功能状态:
·     Disabled:关闭状态
·     Enabled:开启状态
FT method
(暂不支持)快速BSS切换的方式:
·     over-the-air:Over-the-Air方式
·     over-the-ds:Over-the-DS方式
FT reassociation deadline
(暂不支持)重关联超时时间,单位为秒
QoS trust
QoS信任模式:
·     Port:信任端口优先级
·     Dot11e:信任报文的802.11e优先级
QoS priority
端口优先级,取值范围为0~7
display wlan statistics client命令用来查看无线客户端的统计信息。
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address:显示指定MAC地址的客户端统计信息。如果未指定本参数,则显示所有客户端统计信息。
# 显示所有无线客户端的统计信息。
<Sysname> display wlan statistics client
MAC address                : 0014-6c8a-43ff
AP name                    : fatap
Radio ID                   : 1
SSID                       : office
BSSID                      : 000f-e2ff-7700
RSSI                       : 31
Sent frames:
  Back ground              : 0/0 (frames/bytes)
  Best effort              : 9/1230 (frames/bytes)
  Video                    : 0/0 (frames/bytes)
  Voice                    : 2/76 (frames/bytes)
Received frames:
  Best effort              : 18/2437 (frames/bytes)
  Voice                    : 7/468 (frames/bytes)
Discarded frames:
  Best effort              : 0/0 (frames/bytes)
  Voice                    : 5/389 (frames/bytes)
表1-16 display wlan statistics client命令显示信息描述表
AP name
接入点名称
RadioID
射频ID号
SSID
无线客户端关联的SSID
BSSID
基本服务集识别码
MAC address
无线客户端的MAC地址
RSSI
接收信号强度指示,该值表明AP检测到Client的信号强度
Sent frames
发送帧的数目
Back ground
以帧或字节为单位对背景流优先级队列进行统计
Best effort
以帧或字节为单位对尽力而为流优先级队列进行统计
Video
以帧或字节为单位对视频流优先级队列进行统计
Voice
以帧或字节为单位对语音流优先级队列进行统计
Sent frames
发送的帧的数目
Received frames
收到的帧的数目
Discarded frames
丢弃的帧的数目
display wlan statistics connect-history命令用来查看客户端连接历史信息。
display wlan statistics connect-history service-template service-template-name
service-template service-template-name:显示无线服务模板的客户端连接历史信息。
# 显示服务模板1的AP的客户端连接历史信息。
<Sysname> display wlan statistics  connect-history service-template 1
AP name                     : fatap
Radio ID                    : 1
Associations                : 132
Association failures        : 3
Reassociations              : 30
Rejections                  : 12
Abnormal disassociations    : 2
Current associations        : 57
表1-17 display wlan statistics connect-history service-template 1 命令显示信息描述
AP name
AP名称
Radio ID
射频ID号
Associations
累计关联次数
累计关联失败次数
Reassociations
累计重关联次数
Rejections
累计拒绝客户端连接次数
累计异常中断关联次数
当前关联次数
display wlan statistics service-template命令用来查看无线服务模板的统计信息。
display wlan statistics service-template service-template-name
service-template-name:显示指定无线服务模板的统计信息。
# 显示服务模板1的统计信息。
<Sysname> display wlan statistics service-template 1
AP name                       : fatap
Radio ID                      : 1
Received:
  Frame count                 : 1713
  Frame bytes                 : 487061
  Data frame count            : 1683
  Data frame bytes            : 485761
  Association request count   : 2
Sent:
  Frame count                 : 62113
  Frame bytes                 : 25142076
  Data frame count            : 55978
  Data frame bytes            : 22626600
  Association response count  : 2
表1-18 display wlan statistics service-template命令显示信息描述
AP name
AP名称
Radio ID
射频ID号
Received
接收统计:
·     Frame count:接收帧数
·     Frame bytes:接收帧字节数
·     Data frame count:接收数据帧数
·     Data frame bytes:接收数据帧字节数
·     Association request count:接收连接请求帧数
Sent
发送统计:
·     Frame count:发送帧数
·     Frame bytes:发送帧字节数
·     Data frame count:发送数据帧数
·     Data frame bytes:发送数据帧字节数
·     Association response count:发送连接响应帧数
display wlan whitelist命令用来显示白名单。
# 显示白名单。
<Sysname> display wlan whitelist
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
表1-19 display wlan whitelist命令显示信息描述表
白名单中的客户端数量
MAC addresses
白名单列表中的客户端MAC地址
interface wlan-radio命令用来进入WLAN射频接口视图。
interface-number:WLAN射频接口编号。
# 进入WLAN射频接口1视图。
[Sysname] interface wlan-radio 0/0
[Sysname-WLAN-Radio0/0]
·     display interface wlan-radio
1.1.23  nas-id
nas-id命令用来配置网络接入服务器标识。
undo nas-id命令用来恢复缺省情况。
nas-id nas-id
undo nas-id
未配置网络接入服务器标识。
全局配置视图
nas-id:指定网络接入服务器标识,为1~63个字符的字符串,区分大小写。
无线客户端上线时,会通过发送给RADIUS服务器的RADIUS请求报文中携带的NAS-ID(Network Access Server Identifier,网络接入服务器标识)属性,标识客户端的接入位置。
# 配置网络接入服务器标识为abc123。
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] nas-id abc123
nas-port-type命令用来配置设备发送的RADUIS请求报文中的NAS-Port-Type属性值。
undo nas-port-type命令用来恢复缺省情况。
nas-port-type value
undo nas-port-type
设备发送的RADIUS请求报文中的NAS-Port-Type属性值为19。
无线服务模板视图
value:NAS-Port-Type属性值,取值范围为0~255。
对于要使用RADIUS服务器进行802.1X或者MAC地址认证的用户,需要通过本命令将RADIUS请求报文的NAT-Port-Type类型配置为RADIUS服务器支持的类型。
本命令只能在无线服务模板状态关闭的状态下配置。
NAS-Port-Type常用属性值如下:Async(0)、Sync(1)、ISDN Sync(2)、ISDN Async V.120(3)、ISDN Async V.110(4)、Virtual(5)、PIAFS(6)、HDLC Clear Channel(7)、X.25(8)、X.75(9)、G.3 Fax(10)、SDSL(11)、ADSL-CAP(12)、ADSL-DMT(13)、IDSL(14)、Ethernet(15)、xDSL(16)、Cable(17)、Wireless-Other(18)、Wireless-IEEE 802.11(19)。
# 配置设备发送的RADIUS请求报文中的NAS-Port-Type的属性值为15。
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] nas-port-type 15
quick-association enable命令用来开启快速关联功能。
undo quick-association enable命令用来关闭快速关联功能。
快速关联处于关闭状态。
无线服务模板视图
服务模板上开启快速关联功能后,设备不会对关联到此服务模板的客户端进行频谱导航和负载均衡计算,从而让客户端可以快速地关联到AP上。
# 开启服务模板1的快速关联功能。
[Sysname-wlan-st-service1] quick-association enable
reset wlan client命令用来断开与客户端的连接。
reset wlan client { all | mac-address mac-address }
all:断开与所有客户端的连接。
mac-address mac-address:断开与指定客户端的连接。
# 断开与所有客户端的连接。
<Sysname> reset wlan client all
·     display wlan client
reset wlan dynamic-blacklist命令用来清除动态黑名单表项。
reset wlan dynamic-blacklist [ mac-address mac-address ]
mac-address mac-address:清除动态黑名单中指定客户端的MAC地址。如果未指定本参数,则表示清除所有动态黑名单中的客户端。
# 清除动态黑名单表项。
<Sysname> reset wlan dynamic-blacklist
# 清除指定的动态黑名单表项。
<Sysname> reset wlan dynamic-blacklist mac-address b8ca-32a2-df69
·     display wlan blacklist
reset wlan statistics client命令用来清除无线客户端的统计信息。
reset wlan statistics client { all | mac-address mac-address }
all:清除所有无线客户端的统计信息。
mac-address mac-address:清除指定无线客户端的统计信息。
#  清除所有无线客户端的统计信息。
<Sysname> reset wlan statistics client all
·     display wlan statistics
reset wlan statistics service-template命令用来清除无线服务模板的统计信息。
reset wlan statistics service-template service-template-name
配置该功能后,无线服务模板的最新统计信息和历史统计信息将被清除。
# 清除无线服务模板service1的统计信息。
<Sysname> reset wlan statistics service-template service1
service-template命令用来将无线服务模板绑定到当前WLAN射频接口上。
undo service-template命令用来解除当前WLAN射频接口上与无线服务模板的绑定关系。
undo service-template service-template-name
未绑定无线服务模板。
Radio接口视图
service-template-name:无线服务模板名称,为1~63个字符的字符串,不区分大小写。
当只指定无线服务模板名称时,该无线服务模板须先被创建才可完成绑定。
# 将无线服务模板service1绑定到WLAN射频接口上。
[Sysname-WLAN-Radio0/0] service-template service1
service-template enable命令用来开启无线服务模板。
undo service-template enable命令用来关闭无线服务模板。
无线服务模板处于关闭状态。
无线服务模板视图
若设备上所能创建的BSS已达上限,则不能打开其它处于关闭状态的无线服务模板。
# 开启无线服务模板开关。
[Sysname-wlan-st-service1] service-template enable
snmp-agent trap enable wlan client命令用来开启客户端的告警功能。
undo snmp-agent trap enable wlan client命令用来关闭客户端的告警功能。
客户端的告警功能处于关闭状态。
开启了告警功能之后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。(有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。)
# 开启客户端的告警功能。
[Sysname] snmp-agent trap enable wlan client
snmp-agent trap enable wlan client-audit命令用来开启客户端审计的告警功能。
undo snmp-agent trap enable wlan client-audit命令用来关闭客户端审计的告警功能。
客户端审计的告警功能处于关闭状态。
开启客户端审计告警功能之后,设备会生成告警信息,用于报告有关客户端审计的重要事件。这些告警信息可用于对客户端进行审计、监控和统计等操作。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启客户端审计的告警功能。
[Sysname] snmp-agent trap enable wlan client-audit
1.1.34  ssid
ssid命令用来在无线服务模板视图下配置SSID。
undo ssid命令用来恢复缺省情况。
ssid ssid-name
undo ssid
未配置SSID。
无线服务模板视图
ssid-name:指定无线服务模板的SSID,为1~32个字符的字符串,区分大小写。
本命令只能在无线服务模板处于关闭状态时配置。
# 设置无线服务模版service1的SSID为lynn。
[Sysname-wlan-st-service1] ssid lynn
unknown-client命令用来配置对未知客户端数据报文处理方式。
undo unknown-client命令用来恢复缺省情况。
unknown-client { deauthenticate | drop }
undo unknown-client
丢弃未知客户端发送的数据报文并向客户端发送解除认证报文。
无线服务模板视图
deauthenticate:丢弃未知客户端发送的数据报文并向客户端发送解除认证报文。
drop:仅丢弃未知客户端发送的数据报文。
# 仅丢弃未知客户端发送的数据报文。
[Sysname] wlan service-template example
[Sysname-wlan-st-example] unknown-client drop
1.1.36  vlan
vlan命令用来配置无线客户端从指定无线服务模板上线后所属的VLAN。
undo vlan命令用来恢复缺省情况。
vlan vlan-id
undo vlan
无线客户端从指定无线服务模板上线后将被加入到VLAN 1。
无线服务模板视图
vlan-id:指定无线客户端从指定无线服务模板上线后将被加入的VLAN ID,取值范围为1~4094。
本命令只能在无线服务模板处于关闭状态下配置。
配置无线客户端从指定无线服务模板上线后将被加入的VLAN后,如果指定的VLAN已经存在,则客户端在该服务模板上线后会被加入此VLAN;如果指定的VLAN不存在,则客户端上线时会自动创建指定的VLAN,并将客户端加入此VLAN。
# 无线客户端从无线服务模板service1上线后将被加入到VLAN 2。
[Sysname-wlan-st-service1] vlan 2
wlan association optimization命令用来配置客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值。
undo wlan association optimization命令用来恢复缺省情况。
wlan association optimization value
客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值为0,即不对客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率进行优化,采用实际值。
value:客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值,取值范围为900~1000。该数值配置越小,客户端关联AP的关联成功率越小、关联拥塞率越大、终端异常下线率越大。
关联成功率是指客户端关联AP成功的次数占客户端关联AP的总次数的百分比。关联拥塞率是指在AP满载的情况下,客户端在关联AP过程中被拒绝的次数占关联AP的总次数的百分比。终端异常下线率是指终端异常断开连接的总次数占终端关联成功的总次数与当前在线用户总数之和的百分比。
配置本命令后,设备会重新对客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率进行优化计算。
# 配置客户端关联AP的关联成功率、关联拥塞率以及终端异常下线率的优化参数值为950。
[Sysname] wlan association optimization 950
wlan broadcast-probe reply命令用来开启AP回复广播Probe request报文功能。
undo wlan broadcast-probe reply命令用来关闭AP回复广播Probe request报文功能。
AP回复广播Probe request报文功能处于开启状态。
# 关闭AP回复广播Probe request报文功能。
[Sysname] undo wlan broadcast-probe reply
wlan client idle-timeout命令用来配置AP和客户端之间连接允许的最大空闲的时间间隔。
undo wlan client idle-timeout命令用来恢复缺省情况。
wlan client idle-timeout timeout
AP和客户端之间连接允许的最大空闲的时间间隔为3600秒。
timeout:AP和客户端之间连接允许的最大空闲的时间间隔,取值范围为60~86400,单位为秒。
当客户端处于空闲状态,即客户端与AP无任何报文交互,当达到最大空闲的时间间隔时,AP会自动与客户端断开连接。
# 设置AP和客户端之间连接允许的最大空闲的时间间隔为2000秒。
[Sysname] wlan client idle-timeout 2000
wlan client keep-alive enable命令用来开启客户端保活功能。
undo wlan client keep-alive命令用来关闭客户端保活功能。
客户端保活功能处于关闭状态。
保活机制通常用来检测客户端是否在线。导致客户端异常离线原因有电源故障、系统崩溃等。
AP会定期给客户端发送保活报文,以确认其是否在线。如果在保活时间内未收到客户端回应的应答报文,则断开与客户端的连接。
# 开启客户端保活功能。
[Sysname] client keep-alive enable
·     wlan client keep-alive interval
wlan client keep-alive interval命令用来配置客户端保活时间。
undo wlan client keep-alive interval命令用来恢复缺省情况。
wlan client keep-alive interval interval
客户端保活时间为300秒。
interval:向客户端发送保活报文的时间间隔,取值范围为3~1800,单位为秒。
AP会定期给客户端发送空数据报文,以确认其是否在线。如果在保活时间内未收到客户端回应的ACK报文,则断开客户端与AP的连接。
配置本命令前,必须先开启客户端保活功能。
# 配置客户端保活时间为1000秒。
[Sysname] wlan client keep-alive interval 1000
wlan client reauthentication-period命令用来配置客户端二次接入认证的时间间隔。
undo wlan client reauthentication-period命令用来恢复缺省情况。
wlan client reauthentication-period [ period-value ]
客户端二次接入认证的时间间隔为10秒。
period-value:客户端二次接入认证的时间间隔,取值范围为1~3600,单位为秒,缺省值为10。
在客户端进行二次接入认证并切换VLAN的组网环境中,建议配置客户端二次接入认证的时间间隔。
客户端二次接入认证的时间间隔是指客户端通过802.1X认证或MAC地址认证(包括通过URL重定向功能完成MAC地址认证)后,RADIUS服务器强制客户端下线到再次对其进行认证的时间间隔。
配置了客户端二次接入认证的时间间隔之后,设备将已通过认证的客户端的MAC地址加入到动态黑名单中,并在指定的时间间隔内禁止客户端接入。通过此方式加入动态黑名单的MAC地址不受动态黑名单老化时间的影响。
# 配置客户端二次接入认证的时间间隔为100秒。
[Sysname] wlan client reauthentication-period 100
wlan dynamic-blacklist lifetime命令用来配置动态黑名单表项的老化时间。
undo wlan dynamic-blacklist lifetime命令用来恢复缺省情况。
wlan dynamic-blacklist lifetime lifetime
动态黑名单表项的老化时间为300秒。
lifetime:动态黑名单表项的老化时间,取值范围为1~3600,单位为秒。
若更新动态黑名单表项老化时间,新配置的时间只对新加入动态黑名单的客户端生效。
# 配置动态黑名单表项的老化时间为3600秒。
[Sysname] wlan dynamic-blacklist lifetime 3600
wlan led-mode命令用来配置AP的LED闪烁模式。
undo wlan led-mode命令用来恢复缺省情况。
wlan led-mode { always-on | awake | normal | quiet }
undo wlan led-mode
LED闪烁模式为normal模式。
always-on:指定LED闪烁模式为always-on模式,表示所有LED常亮。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
awake:指定LED闪烁模式为awake模式,表示所有LED每分钟闪烁一次。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
normal:指定LED闪烁模式为normal模式,normal模式的LED闪烁情况与设备型号有关,请以设备的实际情况为准。
quiet:指定LED闪烁模式为quiet模式,表示所有LED常灭。
# 配置LED闪烁模式为awake。
[Sysname] wlan led-mode awake
wlan link-test命令用来对客户端进行无线链路质量检测。
wlan link-test mac-address
mac-address:客户端MAC地址,格式为H-H-H。
无线链路质量检测,即AP根据客户端上线时协商的速率集,以每个速率发送5个空数据报文进行链路质量检测。AP根据客户端的响应报文可以获取AP客户端之间的无线链路质量信息,如信号强度、报文重传次数、RTT(Round-Trip Time,往返时间)等。
无线链路质量检测的超时时间为10秒,如果AP在超时时间内没有完成链路质量检测,将无法得到链路质量检测结果。
# 对MAC地址为60a4-4cda-eff0的客户端进行无线链路质量检测。
<Sysname> wlan link-test 60a4-4cda-eff0
Testing link to 60a4-4cda-eff0. Press CTRL + C to break.
                              Link Status
MAC address: 60a4-4cda-eff0
VHT-MCS  Rate(Mbps)  Tx packets  Rx packets  RSSI   Retries RTT(ms)
NSS = 1
 0       32.5        5           5           54     0       0
 1       65          5           5           51     0       0
 2       97.5        5           5           49     0       0
 3       130         5           5           47     0       0
 4       195         5           5           45     0       0
 5       260         5           5           45     0       0
 6       292.5       5           5           44     0       0
 7       325         5           5           44     0       0
 8       390         5           5           44     0       0
 9       433.3       5           5           43     0       0
NSS = 2
0       65          5           5            44     0       0
1       130         5           5            44     0       0
2       195         5           5            44     0       0
3       260         5           5            44     0       0
 4       390         5           5           44     0       0
 5       520         5           5           44     0       0
 6       585         5           5           43     0       0
 7       650         5           5           43     0       0
 8       780         5           5           43     0       0
 9       866.7       5           5           43     0       0
<Sysname> wlan link-test 784f-43b6-077c
Testing link to 784f-43b6-077c. Press CTRL + C to break.
                              Link Status
MAC address: 784f-43b6-077c
0       6.5         5           5           54     0        0
1       13          5           5           51     0        0
2       19.5        5           5           49     0        0
3       26          5           5           47     0        0
4       39          5           5           45     0        0
5       52          5           5           45     0        0
6       58.5        5           5           44     0        0
7       72.2        5           5           44     0        0
8       13          5           5           44     0        0
9       26          5           5           43     0        0
10       39         5           5           44     0        0
11       52         5           5           44     0        0
12       78         5           5           44     0        0
13       104        5           5           44     0        0
14       117        5           5           44     0        0
15       144.4      5           5           44     11       0
表1-20 链路质量检测结果
No./MCS/VHT-MCS
·     No:对802.11a、802.11b或802.11g客户端进行链路质量检测的速率编号
·     MCS:对802.11n客户端进行链路质量检测的MCS索引值
·     VHT-MCS:对802.11ac客户端进行链路质量检测的VHT-MCS索引值
Rate(Mbps)
AP发送无线链路质量检测包的速率
Tx packets
AP发送无线链路质量检测包的个数
Rx packets
AP收到客户端响应报文的个数
RSSI
接收信号强度指示,表示AP检测到客户端的信号强度
Retries
AP重传无线链路质量检测包的次数
RTT(ms)
从AP发出无线链路质量检测包到收到客户端回应的平均往返时间
NSS
对802.11n或802.11ac客户端进行链路质量检测的空间流数
wlan nas-port-id format命令用来配置无线客户端的NAS-Port-ID属性的格式。
undo wlan nas-port-id format命令用来恢复缺省情况。
wlan nas-port-id format { 2 | 4 }
NAS-Port-ID的消息格式为格式2。
2:表示格式2,具体为SlotID00IfNOVlanID。
4:表示格式4,具体为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**。
不同厂商的RADIUS服务器对于NAS-Port-ID格式有不同的要求。可通过本命令修改无线802.1X或MAC地址认证用户发送的RADIUS报文中填充的NAS-Port-ID属性的格式。
1. 格式2
SlotID00IfNOVlanID
各项含义如下:
·     SlotID:用户接入的槽位号,为两个字符的字符串。
·     IfNO:用户接入的接口编号,为3个字符的字符串。
·     VlanID:用户接入的VLAN ID,为9个字符的字符串。
2. 格式4
对于在未终结VLAN的接口上接的用户:其格式为slot=**;subslot=**;port=**;vlanid=**。
对于在终结了外层VLAN的接口上接入的用户:其格式为slot=**;subslot=**;port=**;vlanid=**;vlanid2=**。
# 配置无线客户端的NAS-Port-ID属性的格式为格式4。
[Sysname] wlan nas-port-id format 4
·     nas-port-id
wlan service-template命令用来创建无线服务模板,并进入无线服务模板视图。如果指定的无线服务模板已经存在,则直接进入无线服务模板视图。
undo wlan service-template命令用来删除无线服务模板。
wlan service-template service-template-name
undo wlan service-template service-template-name
不存在无线服务模板。
删除无线服务模板时,如果指定的无线服务模板映射到射频,则在解除映射之前不能删除此无线服务模板。
# 创建无线服务模板service1,并进入无线服务模板视图。
wlan static-blacklist mac-address命令用来添加静态黑名单表项。
undo wlan static-blacklist命令用来删除静态黑名单。
wlan static-blacklist mac-address mac-address
undo wlan static-blacklist [ mac-address mac-address ]
不存在静态黑名单。
mac-address mac-address:将指定MAC地址的客户端添加到静态黑名单,mac-address
的格式为H-H-H。
配置静态黑名单后,名单中的客户端将不允许上线,如果静态黑名单中的客户端在线,设备会解除与该客户端的关联。undo wlan static-blacklist命令中,如果未指定本参数,则表示将静态黑名单中所有客户端从静态黑名单中删除。
同一个客户端不能同时存在静态黑名单和白名单中。
黑名单的MAC地址不能设置为组播或者广播地址。
# 添加静态黑名单表项001c-f0bf-9c92。
[Sysname] wlan static-blacklist mac-address 001c-f0bf-9c92
wlan web-server api-path命令用来指定接收客户端信息的Web服务器的路径。
undo wlan web-server api-path命令用来恢复缺省情况。
wlan web-server api-path path
未指定接收客户端信息的Web服务器的路径。
path:接收客户端信息的Web服务器的路径,为1~256个字符的字符串,区分大小写。
指定接收客户端信息的Web服务器的路径后,服务器才会接收并保存客户端信息。
# 指定接收客户端信息的Web服务器的路径为wlan/dev-cfg(Web服务器的URL为http://www.abc.com:668/wlan/dev-cfg)。
[Sysname] wlan web-server api-path /wlan/dev-cfg
·     wlan web-server host
·     wlan web-server max-client-entry
wlan web-server host命令用来配置接收客户端信息的Web服务器的域名和端口号。
undo wlan web-server host命令用来恢复缺省情况。
wlan web-server host host-name port port-number
未配置接收客户端信息的Web服务器的域名和端口号。
host host-name:指定Web服务器的域名,host-name为3~127个字符的字符串,不区分大小写,可以包含字母、数字、“-”、“_”和“.”
port port-number:指定Web服务器的端口号,port-number取值范围为1~65534
配置接收客户端信息的Web服务器的域名和端口号后,设备将与Web服务器建立连接并上报关联客户端的信息。
设备与Web服务器建立连接后,如果已关联客户端的信息发生变化或有新的客户端关联,设备会将变化和新增客户端的信息实时上报给Web服务器。
# 配置接收客户端信息的Web服务器的域名为www.abc.com,端口号为668。
[Sysname] wlan web-server host www.abc.com port 668
·     wlan web-server api-path
wlan web-server max-client-entry命令用来配置设备一次向Web服务器上报客户端信息的最大数目。
undo wlan web-server max-client-entry命令用来恢复缺省情况。
wlan web-server max-client-entry number
设备一次向Web服务器上报客户端信息的最大数目为10。
number:一次向Web服务器上报客户端信息的数目,取值范围为1~25。
# 配置设备一次向Web服务器上报客户端信息的最大数目为12。
[Sysname] wlan web-server max-client-entry 12
wlan whitelist mac-address命令用来添加白名单表项。
undo wlan whitelist命令用来删除白名单表项。
wlan whitelist mac-address mac-address
undo wlan whitelist [ mac-address mac-address ]
不存在白名单。
mac-address mac-address:白名单中的客户端的MAC地址,mac-address的格式为H-H-H。如果没有指定本参数,则表示所有白名单表项。
第一次配置白名单时,设备会先解除与当前在线的所有客户端的关联,并且只有在白名单内的客户端才允许上线。
删除某个白名单表项时,如果对应的客户端在线,则设备会解除与该客户端的关联;如果没有指定参数,则表示所有白名单表项。删除所有白名单时,不会解除与任何在线客户端的关联。至于是否允许客户端上线,还得看有没有黑名单。
白名单的MAC地址不能设置为组播或者广播地址。
# 添加白名单表项。
[Sysname] wlan whitelist mac-address 001c-f0bf-9c92
This command will disconnect all clients. Continue? [Y/N]:
·     display wlan whiteliest
