05-用户命令
本章节下载: 05-用户命令 (602.64 KB)
1.1.10 clear user-wechat white-list
1.1.18 display user-recognition
1.2.5 user-policy proxy all-url
1.2.6 user-policy https-portal-no-waring
1.2.7 user-policy https-auth-no-waring
1.2.8 user-policy portal-cache-cert
1.3.11 record-user bind { ip | mac }
1.3.12 record-user bind preiod
1.3.15 user-policy user-whitelist
1.3.17 user-sms without-awareness
1.3.18 user-webauth without-awareness
1.3.19 user-webauth force-timeout
1.3.21 user-webauth keepalive-timeout
1.3.22 user-webauth login-multi
1.3.23 user-webauth login-single
1.3.24 user-webauth traffic-alive
1.3.27 user-wechat official-acct-name
1.3.32 user-wechat without-awareness
1.3.34 user-wechat flow-pass-time
1.3.35 user-qrcode without-awareness
1.3.36 user-qrcode qrcode-timeout
1.3.37 user-qrcode keepalive-timeout
1.3.38 user-qrcode jump-access-web
1.3.39 user-qrcode jump-auth-web
1.3.40 user-qrcode jump-redirect-web
1.3.44 user-ic-card local-check
1.3.45 clear user-ic-card info
1.3.47 user-app without-awareness
1.3.53 user-pop3 qrcode-timeout
1.3.54 user-pop3 without-awareness
1.3.55 user-pop3 { jump-access-web | jump-auth-web | user-pop3 jump-redirect-web URL }
1.3.56 user-pop3 { auth-server | auth-group }
1.3.59 user-dingtalk { jump-access-web | jump-auth-web | user-pop3 jump-redirect-web URL }
1.3.60 user-dingtalk callbackaddr
1.3.62 user-dingtalk appsecret
1.3.63 user-dingtalk enterpriseid
1.3.64 user-dingtalk sync-group
1.3.65 user-dingtalk group-path
1.3.67 user-mini-program timeout
1.3.71 user-wxwork jump-access-web
1.3.72 user-wxwork callbackaddr
1.4.19 display running-config db-server
1.6.9 ldap-auth easy-name-match
1.7 nameldapserverdescriptionnameldapserverdescription第三方用户同步
1.7.1 imc-server1 (imc-server2)
1.9.2 user-policy listen authentication
1.11.1 user-db-recognition server
1.11.2 user-db-recognition enable|disable
1.11.3 user-db-recognition address
1.11.4 user-db-recognition cmd
1.11.5 user-db-recognition priority
1.11.6 user-db-recognition interval
1.11.7 display running-config user-db-recognition
1.12.1 user-self-reg {NAME} type {account | terminal}
1.12.2 approval { enable | disable }
alias命令用来配置用户别称,改别称可以在命令行查看。
alias name 命令用来创建用户的别名。
no alias 命令用来删除该用户的别名。
用户配置视图
alias name是指用户的别名,在实际使用中可以设置为用户的实际姓名或者职位等。
HOST# system-view
HOST(config)# user user10
HOST(config-user)# alias nickname
HOST(config-user)# exit
HOST(config)# display user user10
Alias: nickname
Description: 你好
Reference count: 0
User Status: authenticate-need
Authenticate Mode: NONLOCAL
NONLOACAL
display user
bind exclude ip命令用来创建绑定地址的排除地址。
no bind exclude ip 命令用来删除绑定地址的排除地址。
bind exclude ip { address ip-address | range start_ip end_ip | net IPNET }
no bind exclude ip { address ip-address | range start_ip end_ip | net IPNET }
用户配置视图
ip-address:要排除的地址。
start-ip:排除地址范围的起始地址。
end-ip:排除地址范围的结束地址。
IPNET:排除地址为一个网段,例如:1.1.1.1/24或者1.1.1.1/255.255.255.0。
排除IP地址可以配置多条,但是条目之间不能有冲突现象。一个用户最多绑定256个IP地址。
# 将用户user1绑定到地址范围1.1.1.1-1.1.1.5,并且排除地址1.1.1.4。
host# system-view
host(config)# user user1
host(config)#enable bind
host(config-user)# bind ip range 1.1.1.1 1.1.1.5
host(config-user)# bind exclude ip address 1.1.1.4
· display user
bind ip命令用来绑定地址或地址范围。
no bind ip命令用来删除地址或地址范围绑定。
bind ip { address ip-address | range start_ip end_ip | net IPNET }
no bind ip { address ip-address | range start_ip end_ip | net IPNET }
用户配置视图
ip-address:要绑定的地址(IPv4/IPv6)。
start-ip:绑定地址范围的起始地址。
end-ip:绑定地址范围的结束地址。
绑定IP地址可以配置多条,但是条目之间不能有冲突现象。一个用户最多绑定256个IP地址。
绑定IP地址支持IPv4以及IPv6地址,绑定范围仅支持IPv4地址。
# 将用户user1绑定到地址范围1.1.1.1-1.1.1.5。
host# system-view
# 将用户user1绑定IPv6地址2020::2。
Host# configure terminal
Host(config)# user user1
Host(config-user)# enable bind
Host(config-user)# bind ip address 2020::2
· display user
bind mac address命令用来绑定MAC地址。
no bind mac address命令用来删除绑定的MAC地址。
bind mac address HH:HH:HH:HH:HH:HH
no bind mac address HH:HH:HH:HH:HH:HH
用户配置视图
HH:HH:HH:HH:HH:HH:绑定的mac地址。
绑定MAC地址可以配置多条,但是条目之间不能有冲突现象。
# 将用户user1绑定mac地址00:01:0a:0b:0c:11
host# system-view
host(config-user)# bind mac address 00:01:0a:0b:0c:11
· display user
bind-group 命令用于将用户绑定到指定用户组中。
bind-group group-name
用户配置视图
group-name:用户组路径,格式如:/organization/产品部/资料组。
该命令用于将用户绑定到指定的用户组中。没有重名用户组的情况下,可以只填写用户组名称,有重名用户组的情况下,必须填写完整路径。
HOST# system-view
HOST(config-user)# bind-group /organization/产品部/资料组
user-group
clear user 命令用于清除某一个在线用户。
clear user name address A.B.C.D time YYYY-MM-DD HH:MM
全局视图
A.B.C.D:用户的ip地址。
YYYY-MM-DD HH:MM:用户的上线时间。
该命令用户清除某一个在线用户。
HOST# clear user 192.168.200.36 address 192.168.200.36 time 2019-03-31 12:00
display user
clear user-policy命令用于清除用户认证策略白名单。
clear user-policy { user-whitelist | whitelist}
全局视图
user-whitelist:清除用户白名单。
whitelist:清除域名白名单。
该命令用于清除用户白名单,清除白名单后,所有在用户认证范围内的用户都要经过认证才能正常使用网络。
#清除用户认证策略用户白名单
HOST# clear user-policy user-whitelist
HOST#
user-policy whitelist
clear user-recognition命令用来清除所有或者某个动态识别出的在线用户信息。
clear user-recognition [ name | ip A.B.C.D ]
A.B.C.D:要清除在线用户的信息的IP地址。
# 清除所有动态识别出的在线用户信息。
host# clear user-recognition
clear user-waa命令用于清除所有无感知上线的用户。
clear user-waa {local-waa | qrcode-waa | sms-waa | wechat-waa} [usermac MAC]
全局配置视图
local-waa:清除本地无感知认证上线的用户。
qrcode-waa:清除二维码无感知认证上线的用户。
sms-waa:清除短信无感知认证上线的用户。
wechat-waa:清除微信无感知认证上线的用户。
MAC:清除指定MAC地址对应的用户。
清除无感知上线用户后,通过无感知方式上线的用户将被强制下线。
HOST# clear user-waa local-waa
%Clear the local-waa list success
HOST#
display user
clear user-wechat white-list命令用于清除微信认证白名单用户。
全局配置视图
无
使用该命令可以将微信认证白名单清除。
HOST# system-view
HOST(config)# clear user-wechat white-list
HOST(config)#
user-wechat whitelist
description命令用来设置本地用户描述。
no description命令用来清除本地用户描述
no description
缺省情况下,没有配置本地用户描述。
用户配置视图
用户组配置视图
text:用户描述信息,为0~127个字符的字符串,特殊字符只能包含“@._-()[]| ”。
# 创建用户名为user1的用户,添加描述first user。
host# system-view
host(config-user)# description firstuser
disable命令用来禁用本地用户。
disable
缺省情况下,用户创建后是启用状态。
用户配置视图
# 禁用用户名为user1的用户。
host# system-view
host(config-user)# disable
· display user
· enable
disable bind mac命令用于将取消用户绑定mac的信息。
disable bind mac
用户配置视图
无
使用该命令来取消用户绑定的MAC地址。
HOST# system-view
HOST(config-user)# disable bind mac
enable bind mac
display 命令用于查看用户信息。
display { user-am | user-sols | user-srun} switch 查看第三方认证服务器同步的开关的状态
display user-authed [ usermac MAC | username name ] 查看认证用户的信息
display user-policy user-whitelist 查看用户认证白名单
display user-policy whitelist 查看用户认证白名单
display user-portal-escape info 查看portal逃生配置信息和功能状态。
display user-portal-server dhcp mac查看CMCC认证信息
display user-radius-ap-mac查看ap-mac学习状态
display user-radius-listen查看radius监听状态
display user-waa { local-waa | qrcode-waa | sms-waa | wechat-waa }查看无感知认证用户
全局配置视图
无
该命令主要用于快速查询用户的信息。
#查看用户组信息
HOST# display user-group
Flags: g--Group
Name Ref Members
anonymous 0
organization 0 default(g), 产品部(g), 研发部(g), 财务部(g), 销售部(g), ...
authen-method 0 wechat(g), portal-server(g), sso(g), imc(g), Radius-user(g), ...
default 0 ser10
wechat 0
mobile 0
portal-server 0
sso 0
imc 0
Radius-user 0
sols 0
srun 0
telecom 0
Ldap-user 0
sms_authentication 0
app 0
free 0
qrcode_authentication 0
user
display user命令用来显示系统中配置的本地用户。
display user [ username ]
username:要显示的用户名,为1~63个字符的字符串,且不能包含“%!"#$&`*+,/:;<=>?\^'{}!”。
# 显示系统中配置的所有本地用户。
host# display user
Flags: E--Enabled, F--Frozen-Enabled, A--Authenticate-Need, B--Bind-Address
Name Ref Status Frozen-EndTime Account Bind-Address
any 0 E---
123 0 E-A- [SERVER group]
A 0 E-A- [LOCAL]
user1 1 E---
user2 0 E--B 1.1.1.1-1.1.1.5, 1.1.1.4(e)
user3 0 E---
表1-1 display user命令显示信息描述表
Name |
本地用户名 |
Ref |
用户引用计数 |
Status |
用户状态 |
E |
用户启用 |
F |
用户被冻结 |
A |
是认证用户 |
B |
是绑定用户 |
Frozen-EndTime |
冻结结束时间 |
Account |
用户认证类型 |
[LOCAL] |
用户是本地认证 |
[RADIUS] |
用户是RADIUS认证 |
[LDAP] |
用户是LDAP认证 |
[SERVER group] |
用户是RADIUS或者LDAP组认证 |
Bind-Address |
绑定用户的绑定地址 |
(e) |
表示前边的地址是绑定地址中排除的部分 |
# 显示用户名为user1的用户信息。
host# display user user1
Alias:
Description: first user
Reference count: 1
User Status: enabled
表1-2 display user命令显示信息描述表
Name |
本地用户命 |
Alias |
用户别名 |
用户描述 |
Reference count |
引用计数 |
User Status |
用户启用状态 |
display user-group命令用来显示用户组。
display user-group [ group-name ]
group-name:用户组名,为1~63个字符的字符串,且不能包含“%!"#$&`*+,/:;<=>?\^'{}!”。
# 显示系统所有用户组。
host# display user-group
Flags: g--Group
Name Ref Members
anonymous 0
mobile 0
group1 0 user1
表1-3 display user-group命令显示信息描述表
Name |
用户组名 |
Ref Members |
引用计数 |
Members |
用户组内用户成员 |
# 显示用户组group1。
host# display user-group group1
Description:
Reference count: 0
Member count: 1
Entry Members:
user1
表1-4 display user-group group-name命令显示信息描述表
Name |
用户组名 |
用户组描述 |
Reference count |
引用计数 |
Member count |
用户组内成员个数 |
Entry Members |
用户组内成员条目 |
display user-param命令用来显示用户识别属性。
display user-param
# 显示用户识别属性。
host# display user-param
Address Scope: private[Strict Mode]
Recognition threshold: 60000
Recognition minimum ttl: 120 seconds
Recognition maximum ttl: 1200 seconds
表1-5 display user-param命令显示信息描述表
Address Scope |
用户识别范围的地址对象名 |
[ mode ] |
用户识别的方式 |
Recognition threshold |
可识别用户的个数 |
Recognition minimum ttl |
识别老化时间的最小值 |
Recognition maximum ttl |
识别老化时间的最大值 |
display user-recognition命令用来显示本地已识别用户。
display user-recognition [address {host A.B.C.D | name name | range A.B.C.D A.B.C.D} | authenticated | user name name [address { host A.B.C.D | name name | range A.B.C.D A.B.C.D }]]
全局配置视图
user name:只显示某个用户名的用户。
address:只显示地址为某种条件的用户。
host:只显示用户地址是某个地址的用户。
host-ip:用户地址。
range:只显示用户地址在某个地址范围内的用户。
start-ip:地址范围开始地址。
end-ip:地址范围结束地址。
address-name:地址对象名。
# 显示本地已识别用户。
host# display user-recognition
Address Scope: private[Heuristic Mode]
Recognitions: 32
Name Identity IP MAC Status Online-StartTime Frozen-EndTime
192.168.1.56 anonymous 192.168.1.56 28:d2:44:38:43:0 2014/07/04 11:03
192.168.1.239 anonymous 192.168.1.239 00:23:ff:4b:6c:d1 2014/07/04 10:59
169.254.67.28 anonymous 169.254.67.28 c8:1f:66:f2:53:e6 2014/07/04 10:57
192.168.1.157 anonymous 192.168.1.157 7c:e9:d3:f5:13:d1 2014/07/04 10:50
表1-6 display user-recognition命令显示信息描述表
Address Scope |
用户识别范围的地址对象名 |
[ mode ] |
用户识别的方式 |
Recognitions |
已识别用户个数 |
Name |
识别的用户名 |
Identity |
识别用户类型 |
anonymous |
匿名用户 |
static |
本地认证/静态绑定用户 |
mobile |
移动用户 |
IP |
用户登录地址 |
MAC |
用户登录mac地址 |
Status |
用户状态,是否被冻结 |
Online-StartTime |
用户登录的时间 |
Frozen-EndTime |
冻结结束时间 |
enable命令用来启用本地用户。
disbale命令用来禁用本地用户。
enable
disable
缺省情况下,用户创建后是启用状态。
用户配置视图
# 禁用用户名为user1的用户。
host# system-view
· display user
enable bind命令用来配置用户为绑定用户
no enable bind命令用配置用户为非绑定用户。
enable bind
no enable bind
用户配置视图
# 创建用户名为user1的用户并且设置为绑定用户。
host# system-view
host(config-user)# enable bind
· display user
enable命令用来启用静态绑定mac用户。
disable命令用来禁用静态绑定mac用户。
enable bind mac
disable bind mac
用户配置视图
# 创建用户名为user1的用户并且设置为静态绑定mac用户。
host# system-view
host(config-user)# enable bind mac
· display user
expire-set 命令用于设置账户过期时间。
expire-set {YYYY-MM-DD | never-expire }
用户配置视图
YYYY-MM-DD:用户到期时间,超过此时间后,该用户即过期。
never-expire :该用户永不过期
默认永不过期
#配置用户user10的过期时间为2019年4月1日。
HOST# system-view
HOST(config-user)# expire-set 2019-04-01
user
match user命令用来测试一个用户是否属于一个用户组。
match user username
用户组配置视图
username:要测试的用户名,为1~63个字符的字符串。
某种情况下,可能用户组会套嵌多层用户组,这样不太好判断一个用户是否属于这个用户组。这个命令可以用来测试使用户是否属于这个用户组。
# 测试用user1是否属于用户组group1。
host# system-view
host(config)# user-group group1
host(config-user-group)# match user user1
Hit user user1
· user-group
· member
· display user-group
user命令用来创建本地用户。
no user命令用来删除本地用户。
user username
no user username
缺省情况下,存在一个any用户。
username:用户名,为1~63个字符的字符串,且不能包含“%!"#$&`*+,/:;<=>?\^'{}!”。
该命令执行完后进入用户配置节点。
# 创建用户名为user1的用户。
host# system-view
host(config-user)#
· display user
· display running-config user
user-group命令用来创建本地用户组。
no user-group命令用来删除本地用户组。
user-group groupname
no user-group groupname
缺省情况下,存在一个anonymous用户组。
groupname:用户组名,为1~63个字符的字符串,且不能包含“%!"#$&`*+,/:;<=>?\^'{}!”。
该命令执行完后进入用户组配置节点。
# 创建用户名为group1的用户。
host# system-view
· member
· match user
· display running-config user-group
portal_pages_edit disable命令用来隐藏portal自定义页面按钮。
portal_pages_edit enable 命令用来显示portal自定义页面按钮。
portal_pages_edit { enable | disable }
默认为隐藏portal自定义页面按钮。
配置视图
disable:隐藏portal自定义页面按钮。
enable:显示portal自定义页面按钮。
该命令默认为隐藏portal自定义页面按钮,开启后显示portal自定义页面按钮,该命令为隐藏命令,需要手动输入完整命令才能生效,没有自动填充和联想功能。
将portal自定义页面按钮显示再隐藏(默认隐藏)
Host:WD-D# system-view
Host:WD-D(config)# portal_pages_edit enable
Host:WD-D(config)# portal_pages_edit disable
无
user-param auth命令用来启用和配置第三方认证。
no user-param auth命令用来禁用第三方认证。
user-param auth { radius | ldap } name
user-param auth { radius | ldap } group name
no user-param auth
缺省情况下,第三方认证未开启,且未配置第三方认证服务器。
用户配置视图
radius:第三方认证服务器为Radius服务器。
ldap:第三方认证服务器为Ldap服务器。
第三方认证配置前,需要先在认证服务器配置中配置好Radius或Ldap认证服务器,或服务器组。然后在启用配置第三方认证时选择相应的认证服务器。
# 配置第三方认证为Radius认证。
host# system-view
host(config)# radius-server test 192.168.1.103 test
host(config)# user-param auth radius test
· display running-config user-param
user-param recognition命令用来修改用户识别属性。
no user-param recognition命令用来恢复用户识别属性。
user-param recognition scope address-object { heuristic | strict }
no user-param recognition scope address-object
user-param threshold count
缺省情况下,用户识别的范围是地址对象private,方式是强制模式的,识别用户的个数是因设备内存大小不同会有差异。
(1)内存大于等于8G 的规格为60000;
(2)内存大于等于4G而小于8G的规格为40000;
(3)内存小于4G的规格为10000
用户配置视图
address-object:设置的用户识别的地址对象或者地址组对象名称,为1~31个字符的字符串。
heuristic:启发式识别。
strict:强制识别。
count:识别用户上限,范围是5000~10000000。
识别模式分为“启发模式”和“强制模式”两种。
· “启发模式”指的是,优先将属于识别范围的IP地址识别为用户,识别顺序是先识别会话中的源IP,再识别目的IP,如果源目IP都不属于识别范围会将源IP识别为用户。
· “强制模式”指的是,只有源IP或目的IP地址属于识别范围时,才会被识别为用户;否则不识别,该IP地址不进后续用户策略流程,不受用户策略限制,不会出现在在线用户当中。
# 将所有私有地址private识别模式改为强制模式。
host# system-view
host(config)# user-param recognition scope private strict
· display user
user-param threshold命令用来配置用户识别规格。
user-param threshold <5000-10000000>
缺省情况下,设备已根据内存大小做了用户识别规格适配,不需要修改此配置。
(3)内存小于4G的规格为10000
用户配置视图
<5000-10000000>:规格最小为5000,最大为10000000。
设备已根据内存大小做了用户识别规格适配,建议不要修改此配置。
# 修改用户识别规格为10000。
host# system-view
host(config)# user-param threshold 10000
· display user-param
user-policy proxy all-url disable命令用来关闭所有url消除告警。
user-policy proxy all-url enable 命令用来开启所有url消除告警。
user-policy proxy all-url { enable | disable }
用户配置视图
disable:关闭命令功能。
enable:开启命令功能。
该命令默认关闭,开启后将所有访问的URL都进行告警消除。
# 将全部URL消除告警功能开启再关闭(默认关闭)
Host# system-view
Host(config)# user-policy proxy all-url enable
Host(config)# user-policy proxy all-url disable
display running-config user-policy
user-policy https-portal-no-waring disable命令用来关闭https弹portal告警消除。
user-policy https-portal-no-waring enable 命令用来开启https弹portal告警消除。
user-policy https-portal-no-waring { enable | disable }
用户配置视图
disable:关闭命令功能。
enable:开启命令功能。
该命令默认关闭,开启后将https弹的portal告警进行消除。
# 将https弹portal告警消除功能开启再关闭(默认关闭)
Host# system-view
Host(config)# user-policy https-portal-no-waring enable
Host(config)# user-policy https-portal-no-waring disable
user-policy https-auth-no-waring disable命令用来关闭加密认证告警消除。
user-policy https-auth-no-waring enable 命令用来开启加密认证告警消除。
user-policy https-auth-no-waring { enable | disable }
用户配置视图
disable:关闭命令功能。
enable:开启命令功能。
该命令默认关闭,开启后将加密认证后弹出的告警进行消除。
# 将加密认证告警消除功能开启再关闭(默认关闭)
Host# system-view
Host(config)# user-policy https-auth-no-waring enable
Host(config)# user-policy https-auth-no-waring disable
user-policy portal-cache-cert disable命令用来关闭证书缓存。
user-policy portal-cache-cert enable 命令用来开启证书缓存。
user-policy portal-cache-cert {enable | disable}
用户配置视图
disable:关闭命令功能。
enable:开启命令功能。
该命令默认开启,关闭后将取消证书缓存功能,消除告警改为通过ssl解密代理。
# 将证书缓存功能关闭 再开启(默认开启)
Host# system-view
Host(config)# user-policy portal-cache-cert disable
Host(config)# user-policy portal-cache-cert enable
authenticate命令用来配置用户的认证方式。
authenticate local password change-password {enable | disable}
缺省情况下,没有配置用户认证。
用户配置视图
local:启用本地认证。
password:本地认证的密码,为6~31个字符的字符串。
change-password:是否允许用户修改密码
enable:允许用户修改密码
disable:不允许用户修改密码
认证方式要用no authenticate命令删除。
# 配置用户user1使用本地认证,密码是123456,不允许修改密码。
host# system-view
host(config-user)# authenticate local 123456 change-password disable
· display user
display user-policy命令用来显示用户策略。
display user-policy查看用户认证策略。
display user-policy user-whitelist 查看用户认证白名单。
display user-policy whitelist 查看用户认证白名单。
# 显示用户策略。
host(config)# display user-policy
ID In-interface Out-interface Source-address Dest-address Schedul Action
1 any any any any always local-webauth
表1-7 display user-policy命令显示信息描述表
ID |
用户策略的ID号 |
In-interface |
匹配流量入接口 |
Out-interface |
匹配流量出接口 |
Source-address |
匹配流量源地址 |
Dest-address |
匹配流量目的地址 |
Schedule |
匹配流量时间组 |
Action |
匹配的流量的执行动作 |
permit |
匹配用户的流量直接放行 |
local-webauth |
用户必须通过WEB认证后,流量才可以通过 |
portal-server-webauth |
用户必须通过portal认证后,流量才可以通过 |
move命令用于移动用户认证策略的先后顺序。
move {before <1-65535>| after <1-65535> | head | tail}
用户认证策略视图。
before:将目标策略移动至某一个策略ID之前。
after:将目标策略移动至某一个策略ID之后。
head:将目标策略移动至所有策略之前。
tail:将目标策略移动至所有策略之后。
用户认证策略是顺序匹配的,如果某用户同时符合2个认证策略,那么该用户会优先匹配ID比较靠前的策略。
#将策略1移动到最前面
HOST(config)# user-policy 1
HOST(config-user-policy)# move head
display user-policy
user-free timeout命令用来配置免认证方式用户超时老化时间。
no user-free timeout命令用来取消超时时间。
user- free timeout timeout
缺省情况下,用户老化超时时间为15分钟。
timeout:范围10-144000,单位分钟,缺省15分钟
# 配置免认证用户超时老化时间为10分钟。
host# system-view
host(config)# user-free timeout 10
user-imc imc-web-auth命令用于配置IMC认证对接。
user-imc imc-web-auth log-name name1 real-name name2 ip A.B.C.D [group-name name3]
name1:用户登录名
name2:用户实际名称
A.B.C.D:IMC服务器的IP地址
name3:团体名。
默认无该配置
设备上的配置需要和IMC服务器的配置一致。
HOST(config)# user-imc imc-web-auth log-name AAA real-name BBB ip 1.1.1.1 group-name CCC
HOST(config)#
user-imc port
user-imc port 用于配置IMC上的对接端口。
user-imc port <1-65535>
<1-65535>:IMC服务器上配置的端口号。
缺省情况没有配置。
HOST# system-view
HOST(config)# user-imc port 2001
user-imc timeout
user-imc timeout命令用于修改IMC用户的超时时间。
user-imc timeout {< 10-144000 > | infinite }
系统视图。
< 10-144000 >:超时时间。
infinite:设置为不超时。
缺省情况下为30。
HOST# system-view
HOST(config)# user-imc timeout infinite
HOST(config)#
user-imc port
user-mix命令用于配置混合认证用户跳转方式。
user-mix { jump-access-web | jump-auth-web | hello-url {enable | disable} URL }
jump-access-web:跳转到之前访问的网页
jump-auth-web:跳转到认证成功网页
hello-url:跳转到指定URL页面
默认跳转到认证成功页面。
HOST(config)# user-mix hello-url enable http://www.baidu.com
HOST(config)#
user-policy命令用来创建用户策略。
no user-policy命令用来删除用户策略。
user-policy { if_in | any } { if_out | any } { sip | any } { dip | any } { schedule | always } {free-webauth|sms-webauth|mix-webauth|local-webauth|portal-server-webauth|wechat-webauth|sso-no-authen-ip|sso-match-other | sam-webauth | qrcode-webauth | iccd-webauth | mini-program-webauth | wxwork-webauth } {enable | disable } name {group | no-record} { PERIOD | forever | once } [.DESCRIPTION]
no user-policy id
缺省情况下,没有启用用户策略。
if_in:流量入接口。
any:任何接口。
if_out:流量出接口。
any:任何接口:
sip:源地址匹配的地址对象或对象组。
any:任何源地址。
dip :目的地址匹配的地址对象或对象组。
any:任何目的地址。
schedule :配的时间对象。
always:任何时间。
free-webauth :用户通过免认证方式后,流量才可以放通。
sms-webauth :用户通过短信认证方式后,流量才可以放通。
mix-webauth :通过混合认证方式后,流量才可以放通。
local-webauth:用户必须通过WEB认证后,流量才可以放通。
portal-server-webauth:用户必须通过portal认证后,流量才可以放通。
wechat-webauth:用户必须通过微信认证后,流量才可以放通。
sso-no-authen-ip:用户必须通过单点登录认证后,流量才可以放通,若认证失败直接以IP上线。
sso-match-other:用户必须通过单点登录认证后,流量才可以放通,若认证失败继续匹配策略。
sam-webauth :用户必须通过SAM认证后,流量才可以放通。
qrcode-webauth:用户必须通过二维码认证后,流量才可以放通。
iccd-webauth:用户必须通过IC卡认证后,流量才可以放通。
mini-program-webauth:用户必须通过第三方小程序认证后,流量才可以放通。
wxwork-webauth:用户必须通过企业微信认证后,流量才可以放通。
enable:启用该策略。
disable:不启用该策略。
group:选择用户录入组,格式:group1/group2/。
PERIOD:用户录入有效时间节点,格式:YYYY-MM-DD。
forever:用户录入永久有效。
once:用户临时录入。
no-record:不录入用户。
[.DESCRIPTION]:描述信息。
用户在策略匹配时有顺序要求,一般按照显示的顺序从上到下匹配。
# 创建配置所有通过设备的流量必须通过WEB认证。
host# system-view
host(config)# user-policy any any any any always local-webauth enable test-web no-record forever
· display user-policy
bind ipmac 命令用来开启认证策略的ip-mac绑定。
no bind ipmac命令用来关闭认证策略的ip-mac绑定。
认证策略配置视图
无
开启/关闭认证策略的ip-mac绑定。
# 开启/关闭认证策略的ip-mac绑定
Host# system-view
Host(config)# user-policy id 1
Host(config)# bind ipmac
Host(config)# no bind ipmac
无
record-user bind { ip | mac } 开启认证策略录入用户mac或者ip。
no record-user bind { ip | mac } 关闭认证策略录入用户mac或者ip。
认证策略配置视图
无
开启或者关闭认证策略录入用户mac或者ip
Host# system-view
Host(config)# record-user bind ip
Host(config)# no record-user bind ip
Host(config)# record-user bind mac
Host(config)# no record-user bind mac
无
record-user bind preiod TIME 命令用来设置录入用户绑定ip、mac期限。
no record-user bind preiod命令用来不设置录入用户绑定ip、mac期限。
认证策略配置视图
TIME:录入用户绑定ip、mac期限,单位为天,范围为1-30天。
设置录入用户绑定ip、mac期限为10天
Host# system-view
Host(config)# record-user bind preiod 10
Host(config)# no record-user bind preiod
无
user-policy move命令用来调整用户策略的匹配顺序。
user-policy move id { head | tail | { before | after } compare-id }
head:将用户策略的匹配顺序到放到最前面。
tail:将用户策略的匹配顺序到放到最后面。
before:将用户策略的匹配顺序发到某条策略之前。
after:将用户策略的匹配顺序发到某条策略之后。
compare-id:before和after使用时的基准策略id,范围是1~65535。
用户策略的匹配时有顺序的,一般按照显示的顺序从上到下匹配。
# 将用户策略100调整到用户策略2之后。
host# system-view
host(config)# user-policy move 100 after 2
user-policy whitelist 命令用来域名白名单。
no user- policy whitelist 命令用来删除域名白名单。
user-policy whitelist {exclude{host HOST}|host Host}
缺省情况下, 没有配置域名白名单。
exclude:白名单排除地址,可以设置为IP或域名。
host:白名单地址,可以设置为IP或域名。
域名白名单对所有认证方式都生效,用户在未认证前即可访问白名单地址。
# 将192.168.1.0/24加入域名白名单,排除IP为192.168.1.50。
# 将qq.com加入域名白名单,排除域名为news.qq.com。
host# system-view
host(config)# user-policy whitelist host 192.168.1.0/24
host(config)# user-policy whitelist exclude host 192.168.1.50
host(config)#user-policy whitelist host qq.com
host(config)#user-policy whitelist exclude host news.qq.com
· display user-policy whitelist
· display running-config user-policy
user-policy user-whitelist命令用来配置认证全局白名单。
no user-policy user-whitelist 命令用来删除认证全局白名单。
user-policy user-whitelist{A.B.C.D|A.B.C.D/M}
no user-policy user-whitelist{A.B.C.D|A.B.C.D/M}
缺省情况下, 没有配置认证全局白名单。
A.B.C.D:全局白名单IP。
A.B.C.D/M:全局白名单IP地址段。
全局认证白名单针对所有认证方式都生效,配置为全局白名单的用户不需要认证即可访问网络。
# 将192.168.2.128和192.168.1.0/24加入认证全局白名单。
host# system-view
host(config)# user-policy user-whitelist 192.168.2.128
host(config)# user-policy user-whitelist 192.168.1.0/24
user-sms timeout命令用来配置短信认证方式用户超时老化时间。
no user-sms timeout命令用来取消超时时间。
user- sms timeout timeout
缺省情况下,用户超时老化时间为15分钟。
# 配置短信认证用户超时老化时间为10分钟。
host# system-view
host(config)# user-sms timeout 10
user-sms without-awareness enable 命令用来开启短信认证无感知功能。
user-sms without-awareness disable命令用来关闭短信认证无感知功能。
user-sms without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
timeout:无感知功能超时时间,范围是10~144000,单位是分钟,缺省为10080分钟。
当用户认证登录以后,设备会记录用户的MAC地址,加入无感知表,在超时时间范围内,用户下次再次上线设备先查询无感知表,查询到已记录的MAC后直接认证自动完成认证上线,实现无感知功能。
# 开启短信认证无感知功能,并设置无感知功能超时时间为7200分钟。
host# system-view
host(config)# user-sms without-awareness enable
host(config)# user-sms without-awareness timeout 7200
user-webauth without-awareness enable 命令用来开启本地WEB认证无感知功能。
user-webauth without-awareness disable命令用来关闭本地WEB认证无感知功能。
user-webauth without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
# 开启本地WEB认证无感知功能,并设置无感知功能超时时间为7200分钟。
host# system-view
host(config)# user-webauth without-awareness enable
host(config)# user-webauth without-awareness timeout 7200
user-webauth force-timeout命令用来配置WEB强制重新认证时间。
no user-webauth force-timeout命令用来关闭WEB强制重新认证时间。
user-webauth force-timeout timeout
no no user-webauth force-timeout
缺省情况下,不启用WEB强制重新认证。
timeout:WEB强制重新认证时间,范围是10~144000,单位是分钟,缺省不启用。
当用户登录以后,即使用户一直在线,在设定的时间长度之后,也必须重新登录。
# 设置WEB强制重新认证时间为60分钟。
host# system-view
host(config)# user-webauth force-timeout 60
user-webauth hello-url 命令用来配置WEB认证重定向URL。
no user-webauth hello-url命令用来关闭WEB认证重定向。
user-webauth hello-url { enable | disable } url
缺省情况下,不启用WEB认证重定向。
url:WEB认证重定向的URL地址,为1~127个字符的字符串。
# 设置WEB认证重定向到www.example.com。
host# system-view
host(config)# user-webauth hello-url enable http://www.example.com
user-webauth keepalive-timeout命令用来配置WEB心跳间隔时间。
no user-webauth keepalive-timeout命令用来恢复心跳间隔时间的默认配置。
user-webauth keepalive-timeout timeout
缺省情况下,心跳间隔时间是10分钟。
timeout:WEB心跳间隔时间,范围是10到144000,单位是分钟,缺省是10分钟。
# 设置心跳间隔时间为30分钟。
host# system-view
host(config)# user-webauth keepalive-timeout 30
user-webauth login-multi命令用来允许同一个用户名登录同时登录多次。
user-webauth login-multi number [ count ]
缺省情况下,不允许同一个用户同时登录多次。
count:允许同一个用户同时登录的次数,范围是2到1000次,如果不输入数字,缺省是无限制。
# 设置WEB认证允许同一用户名在同时无限次登录。
host# system-view
host(config)# user-webauth login-multi number
user-webauth login-single命令用来限制用户同时只能登录一次。
user-webauth login-single mode { kick-old | forbid-new }
缺省情况下,用户同时只能登录一次,缺省策略是踢出老用户。
kick-old:新用户会踢出老用户。
forbid-new:禁止老用户登录。
# 配置用户同时只能登录一次,新用户登录会踢出老用户。
host# system-view
host(config)# user-webauth login-single mode kick-old
user-webauth traffic-alive命令用来配置用户老化方式为流量超时老化。
缺省情况下,用户老化方式为心跳超时老化。
无
# 配置用户老化方式为流量超时老化,超时时间为15分钟。
host# system-view
host(config)# user-webauth traffic-alive
host(config)#
user-wechat timeout命令用来配置用户超时时间。
no user-wechat timeout命令用来取消用户超时时间。
user-wechat timeout timeout
缺省情况下,用户超时时间默认为15分钟。
timeout:在线用户超时时间,范围是10~144000,单位是分钟,缺省15分钟。
# 配置用户超时时间为20分钟。
host# system-view
host(config)# user-wechat timeout 20
user-wechat name-type命令用来配置用户名类型。
user-wechat name-type { ip | openid | phone_number }
缺省情况下,用户名类型默认为IP地址。
ip:用户名为用户的IP地址。
openid:为加密后的微信号,每个用户对每个公众号的OpenID是唯一的。对于不同公众号,同一用户的OpenID不同。
phone_number:为用户注册微信的手机号码。
# 配置用户名为openid。
host# system-view
host(config)# user-wechat name-type openid
user-wechat official-acct-name 命令用来配置微信公众号名称。
user-wechat official-acct-name STRING
缺省情况下,未配置微信公众号名称。
STRING:微信公众号名称,从公众平台申请微信公众号。
# 配置公众号名称为testname。
host# system-view
host(config)# user-wechat official-acct-name testname
user-wechat appid命令用来微信公众号应用id。
user-wechat appid STRING
缺省情况下,未配置微信公众号appid。
STRING:应用id,从公众平台获取。
# 配置微信应用id为wxa921dcce3f9ea198。
host# system-view
host(config)# user-wechat appid wxa921dcce3f9ea198
user-wechat appsecret命令用来配置微信公众号应用密钥。
user-wechat appsecret STRING
缺省情况下,未配置微信公众号appsecret。
STRING:应用密钥,从公众平台获取。
# 配置微信应用密钥为86691be59b208d489111429f75f7f678。
host# system-view
host(config)# user-wechat appsecret 86691be59b208d489111429f75f7f678
user-wechat user-wechat auth-step 命令用来配置认证步骤说明。
user-wechat auth-step STRING
缺省情况下,默认认证步骤说明是“请点击认证菜单进行微信认证”。
STRING:认证步骤说明,默认认证步骤说明是“请点击认证菜单进行微信认证”,用户可以根据自己公众号的配置进行自定义配置。
# 配置微信认证步骤说明为:请点击“微信认证”菜单进行认证。
host# system-view
host(config)# user-wechat auth-step 请点击“微信认证”菜单进行认证
user-wechat auth-url命令用来配置微信认证URL。
user-wechat auth-url URL
缺省情况下,未配置认证URL。
URL:不能配置为已经存在的URL,只能配置为无法访问的URL,不支持https。
# 设置auth-url地址为:http://www.example.com/test
host# system-view
host(config)# user-wechat auth-url http://www.example.com/test
user-wechat without-awareness enable 命令用来开启本地WEB认证无感知功能。
user- wechat without-awareness disable命令用来关闭本地WEB认证无感知功能。
user- wechat without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
host# system-view
host(config)# user-wechat without-awareness enable
host(config)# user-wechat without-awareness timeout 7200
user-wechat white-list 命令用来配置微信认证白名单。
no user-wechat white-list 命令用来删除微信认证白名单。
user-wechat white-list {A.B.C.D|A.B.C.D/M}
缺省情况下, 没有配置微信认证白名单。
A.B.C.D:白名单IP。
A.B.C.D/M:白名单IP地址段。
微信认证白名单只针对微信认证方式生效,其它认证方式白名单可通过配置全局白名单实现。
微信认证白名单对混合认证中的微信认证不生效。
# 将192.168.2.128和192.168.1.0/24加入微信认证白名单。
host# system-view
host(config)# user-wechat white-list 192.168.2.128
host(config)# user-wechat white-list 192.168.1.0/24
user-wechat flow-pass-time 命令用来配置流量放通时间。
user-wechat flow-pass-time <20-180>
缺省情况下,流量放通时间为60秒。
<20-180>:流量放通时间,范围是20~180,单位是秒,缺省为60秒。
微信认证流量放通时间是指弹出微信认证页面后点击打开微信,流量开始放通,默认流量放通时间为60秒,用户可以通过命令调整放通时间为20~180s。
# 将流量放通时间调整为90s。
host# system-view
host(config)# user-wechat flow-pass-time 90
user-qrcode without-awareness enable 命令用来开启本地二维码认证无感知功能。
user-qrcode without-awareness disable命令用来关闭本地二维码认证无感知功能。
user-qrcode without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
# 开启本地二维码认证无感知功能,并设置无感知功能超时时间为7200分钟。
host# system-view
host(config)# user-qrcode without-awareness enable
host(config)# user-qrcode without-awareness timeout 7200
user-qrcode qrcode-timeout命令用来配置二维码失效时间。
no user-qrcode qrcode-timeout命令用来恢复心跳间隔时间的默认配置。
user-qrcode qrcode-timeout timeout
缺省情况下,二维码失效时间是2分钟。
timeout:二维码超时时间,范围是2~10,单位是分钟。
# 设置二维码失效时间为3分钟。
host# system-view
host(config)# user-qrcode qrcode-timeout 3
user-qrcode keepalive-timeout 命令用来配置二维码认证流量超时时间。
no user-qrcode keepalive-timeout命令用来恢复二维码认证流量超时时间的默认配置。
user-qrcode keepalive-timeout timeout
缺省情况下,流量超时时间是10分钟。
timeout:二维码认证超时时间,范围是10~144000,单位是分钟。
# 设置二维码认证流量超时时间为17分钟。
host# system-view
host(config)# user-qrcode keepalive-timeout 17
user-qrcode jump-access-web 命令用来配置二维码认证成功后跳转回之前访问的页面。
缺省情况下,二维码认证成功后回跳转回之前访问的页面。
#二维码认证成功后回跳转回之前访问的页面。
host# system-view
host(config)# user-qrcode jump-access-web
user-qrcode jump-auth-web命令用来配置二维码认证成功后转到认证成功页面。
# 设置二维码认证成功后转到认证成功页面。
host# system-view
host(config)# user-qrcode jump-auth-web
user-qrcode jump-redirect-web命令用来重定向二维码认证成功后的网页。
user-qrcode jump-redirect-web url
缺省情况下,没有配置重定向url。
url:可输入1-127字符http/https前缀的url,且只能设置一条url。
# 配置二维码认证后重定向url到http://www.example.com。
host# system-view
host(config)# user-qrcode jump-redirect-web http://www.example.com
user-qrcode auditor命令用来配置二维码认证审核人。
user-qrcode auditor name
缺省情况下,审核人为any。
# 配置二维码认证审核人为用户组Sale。
host# system-view
host(config)# user-qrcode auditor Sale
# 配置二维码认证审核人为用户Sale-wangxin。
host# system-view
host(config)# user-qrcode auditor Sale-wangxin
user-qrcode audit-type命令用来配置二维码认证的审核方式。
user-qrcode audit-type{indirectly|directly | selfdefine }
缺省情况下,为indirectly方式。
Indirectly:弹出审核页面,审核人备注并授权。
directly:不弹审核页面,以审核人身份登录。
selfdefine:访客填写用户信息,审核人扫吗,授权访客上线。
# 配置二维码认证审核方式为indirectly。
host# system-view
host(config)# user-qrcode audit-type indirectly
# 配置二维码认证审核方式为directly。
host# system-view
host(config)# user-qrcode audit-type directly
#配置二维码认证审核方式为Selfdefine
host# system-view
host(config)# user-qrcode audit-type Selfdefine
user-ic-card timeout命令用来配置IC卡认证用户超时下线时间。
no user- ic-card timeout命令用来恢复IC卡认证用户超时下线时间的默认配置。
user-ic-card timeout timeout
no user-ic-card timeout
缺省情况下,IC卡认证用户超时下线时间是15分钟。
timeout:IC卡认证用户超时下线时间,范围是10-144000分钟,单位是分钟。
# 设置IC卡认证用户超时下线时间为30分钟。
host# system-view
host(config)# user-ic-card timeout 30
user-ic-card local-check disable 命令用来关闭IC卡本地校验。
user-ic-card local-check enable 命令用来开启IC卡本地校验。
user-ic-card local-check { enable | disable }
disable关闭命令功能。
enable开启命令功能。
该命令默认关闭,开启后将执行IC卡本地校验功能。
# 将IC卡本地校验功能开启再关闭(默认关闭)
Host:WD-D(config)# user-ic-card local-check enable
Host:WD-D(config)# user-ic-card local-check disable
无
clear user-ic-card info命令用来清除本地IC卡卡号信息。
无
该命令用来清除本地IC卡卡号信息。
# 将IC卡卡号信息清除
Host:WD-D(config)# clear user-ic-card info
无
user-app timeout命令用来配置APP认证用户超时下线时间。
no user-app timeout命令用来配置APP认证用户超时下线时间为默认值。
user-app timeout timeout
no user-app timeout
缺省情况下,APP认证失效时间是15分钟。
timeout:APP认证用户超时下线时间,范围是10-144000,单位是分钟。
# 设置APP认证用户超时下线时间为10分钟。
host# system-view
host(config)# user-app timeout 10
user-app without-awareness enable 命令用来开启APP认证无感知功能。
user-app without-awareness disable命令用来关闭APP认证无感知功能。
user-app without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
# 开启APP认证无感知功能,并设置无感知功能超时时间为7200分钟。
host# system-view
host(config)# user-app without-awareness enable
host(config)# user-app without-awareness timeout 7200
user-app { enable | disable }命令用来开启/关闭APP认证识别。
缺省情况下关闭。
enable:开启APP认证识别功能。
disable:关闭APP认证识别功能。
# 开启APP认证识别。
host# system-view
host(config)# user-app enable
user-app server ip A.B.C.D命令用来设置放通APP服务器的IP地址。
no user-app server ip A.B.C.D命令用来删除已设置的放通APP服务器的IP地址。
A.B.C.D:服务器的IP地址。
user-app server host命令用来设置放通APP服务器的域名。
no user-app server host命令用来删除已设置的放通APP服务器的域名。
user-app server host HOST
no user-app server host HOST
HOST:服务器的域名。
user-app name-rule { first | second } name-start STRING name-end STRING 命令设置APP用户名提取特征。
no app name-rule { first | second }命令用来删除APP用户名提取特征。
first:配置用户名特征提取规则一
second:配置用户名特征提取规则二
name-start:用户名起始特征
name-end:用户名结束特征
user-app download { android | ios | pc } URL 命令设置APP下载地址。
no user-app download { android | ios | pc } 命令用来删除APP下载地址。
android:安卓下载。
ios:苹果下载。
pc:电脑下载。
URL:下载地址。
user-pop3 timeout命令用来配置pop3认证用户超时下线时间。
no user-pop3 timeout命令用来配置pop3认证用户超时下线时间为默认值。
user-pop3 timeout timeout
缺省情况下,pop3认证失效时间是15分钟。
timeout:pop3认证用户超时下线时间,范围是10-144000,单位是分钟。
# 设置pop3认证用户超时下线时间为10分钟。
host# system-view
host(config)# user-pop3 timeout 10
user-pop3 without-awareness enable 命令用来开启pop3认证无感知功能。
user-pop3 without-awareness disable命令用来关闭pop3认证无感知功能。
user-pop3 without-awareness {enable|disable|timeout}
缺省情况下, 无感知功能关闭。
enable:开启无感知功能。
disable:关闭无感知功能。
# 开启pop3认证无感知功能,并设置无感知功能超时时间为7200分钟。
host# system-view
host(config)# user-pop3 without-awareness enable
host(config)# user-pop3 without-awareness timeout 7200
命令用来配置POP3认证成功后跳转页面。
jump-access-web
配置视图
jump-access-web:跳转到认证之前访问页面。
jump-auth-web:停留在认证页面。
jump-redirect-web:跳转到指定页面.
URL:跳转到指定页面的URL地址。
#设置停留在认证页面
Host(config)# user-pop3 jump-auth-web
user-pop3 { auth-server | auth-group } 命令用来配置POP3认证服务器。
user-pop3 { auth-server | auth-group }NAME
auth-server:认证服务器为指定POP3服务器。
auth-group:认证服务器为指定POP3服务器组。
user-dingtalk { enable | disable }命令用来启用、禁用钉钉配置。
缺省情况下关闭。
enable:启用。
disable:禁用。
# 启用钉钉认证。
host# system-view
host(config)# user-dingtalk enable
display user-dingtalk config
user-dingtalk命令用来配置钉钉认证用户超时下线时间。
no user-dingtalk timeout命令用来配置钉钉认证用户超时下线时间为默认值。
user-dingtalk timeout timeout
缺省情况下,钉钉认证失效时间是15分钟。
timeout:钉钉认证用户超时下线时间,范围是10-144000,单位是分钟。
# 设置钉钉认证用户超时下线时间为10分钟。
host# system-view
host(config)# user-dingtalk timeout 10
命令用来配置钉钉认证成功后跳转页面。
jump-access-web
配置视图
URL:跳转到指定页面的URL地址。
#设置停留在认证页面
Host(config)# user-dingtalk jump-auth-web
user-dingtalk callbackaddr STRING命令用来设置钉钉认证的回调地址。
no user-dingtalk callbackaddr STRING命令用来删除钉钉认证的回调地址。
STRING:回调地址字符串。
user-dingtalk appid STRING命令用来设置钉钉认证的appid。
STRING:从认证服务器获取的appid字符串。
user-dingtalk appsecret STRING命令用来设置钉钉认证的appsecret。
STRING:从认证服务器获取的appsecret字符串。
user-dingtalk enterpriseid STRING命令用来设置钉钉认证的enterpriseid(企业id)。
STRING:从认证服务器获取的enterpriseid(企业id)字符串。
user-dingtalk sync-group { enable | disable }命令用来配置是否获取用户所属组。
enable:获取。
disable:不获取。
user-dingtalk group-path STRING命令用来设置钉钉认证获取用户所属组时用户组在本地所创建的路径。
STRING:本地创建用户组的路径信息字符串。
user-dingtalk appkey STRING命令用来设置钉钉认证获取用户所属组时的appkey。
STRING:从认证服务器获取的appkey字符串。
user-mini-program timeout命令用来 配置第三方小程序认证无流量时的超时下线时间。
user-mini-program timeout <10-144000>
缺省值为15分钟。
config视图
【参数说明】
<10-14400>:配置范围为10-14400 单位为分钟。
#配置认证用户无流量时的超时下线时间。
Host(config)# user-mini-program timeout 10
user-mini-program key 命令用来配置第三方小程序认证加密密钥。
user-mini-program key STRING
config视图
【参数解释】
STRING:加密密钥的字符串。
#配置认证加密密钥。
Host(config)# user-mini-program key TFYZA0JYB2FKMJAYMDEYMTEJZ9YZ
user-wxwork enable命令用来启用企业微信认证服务。
user-wxwork disable 命令用来禁用企业微信认证服务。
user-wxwork { enable|disable }
system-view;
disable:禁用命令功能。
enable:启用命令功能。
该命令默认关闭,开启后企业微信认证配置生效。
将企业微信认证功能开启再关闭(默认关闭)
HOST# system-view
HOST(config)#
HOST(config)# user-wxwork enable
HOST(config)#
HOST(config)# user-wxwork disable
无
user-wxwork timeout <10-144000> 命令用来配置用户超时时间。
no user-wxwork timeout 命令用来恢复用户默认超时时间。
【参数解释】
<10-144000>:用户超时时间。
配置用户超时时间和恢复用户超时时间。
#配置用户超时时间,恢复用户超时时间。
HOST# system-view
HOST(config)#
HOST(config)# user-wxwork timeout 300
HOST(config)# no user-wxwork timeout
user-wxwork jump-access-web 命令用来配置认证成功后跳转到之前访问的页面。
user-wxwork jump-auth-web 命令用来配置认证成功后认证成功的页面。
user-wxwork jump-redirect-web URL 命令用来配置认证成功后跳转到指定页面。
【参数解释】
无。
配置认证成功后的跳转页面。
#配置认证成功后的跳转页面,跳转到之前访问的页面,认证成功页面,之前访问的页面。
HOST# system-view
HOST(config)# user-wxwork jump-access-web
HOST(config)# user-wxwork jump-auth-web
HOST(config)# user-wxwork jump-redirect-web https://www.qq.com/
user-wxwork callbackaddr STRING 命令用来配置回调地址。
user-wxwork appid STRING 命令用来配置appid。
user-wxwork appsecret STRING 命令用来配置appsecret。
user-wxwork agentid STRING 命令用来配置企业ID。
【参数解释】
无。
配置接口参数。
#配置回调地址、appid、appsecret 、企业ID。
HOST# system-view
HOST(config)# user-wxwork callbackaddr http://example.com:8000
HOST(config)# user-wxwork appid ww2086a22148c83532
HOST(config)# user-wxwork appsecret 2_7P7UXz5rHPAuDTS4aiI7ahNyD2ftPNWXHJd0spwGY
HOST(config)# user-wxwork agentid 1000
user-wxwork sync-group { enable | disable } 命令用来配置自动获取所属组。
user-wxwork sync-group enable 配置开启自动获取所属组。
user-wxwork sync-group disable 配置关闭自动获取所属组。
【参数解释】
无。
配置自动获取所属组。
#配置开启、关闭自动获取所属组。
HOST# system-view
HOST(config)# user-wxwork sync-group enable
HOST(config)# user-wxwork sync-group disable
bindtype命令用来配置LDAP服务器绑定类型及用户、密码。
bindtype { simple user name passwd password }
LDAP配置视图
simple:绑定类型为简单。
user:配置用户名。
passwd:配置密码。
password:密码,为1~16个字符的字符串。
# 配置LDAP服务器server2的用户名为ldap1,密码为123456。
host# system-view
host(config)# ldap server2
host(config-ldap)# bindtype simple user ldap1 passwd 123456
· ldap
· cnid
· dn
· filter
cnid命令用来配置通用名称。
cnid cnid
LDAP配置视图
cnid:通用标识名,为1~4个字符的字符串。
# 配置LDAP服务器server2的通用标识名为cn。
host# system-view
host(config-ldap)# cnid cn
· ldap
· bindtype
· dn
· filter
display radius-server命令用来显示系统中配置的服务器。
display radius-server [ servername ]
servername:要显示的服务器名字,为1~256个字符的字符串。
host# display radius-server
# 显示系统内所有的RADIUS服务器。
Radius-Server Name Secret IP Address Port Reference Count
aaa ****** 1.1.1.1 1812 1
12312 ***** 2.2.2.2 1812 0
server1 ****** 1.1.1.1 1812 0
Total radius-servers : 3
表1-8 display radius-server命令显示信息描述表
Radius-Server Name |
RADIUS服务器名称 |
Secret |
服务器密码,已经加密 |
IP Address |
服务器地址 |
Port |
服务器端口 |
Reference Count |
引用计数 |
Total radius-servers |
系统内RADIUS服务器个数 |
display server-group命令用来显示配置的服务器组。
display server-group [ groupname ]
groupname:要显示的服务组名称,为1-256个字符的字符串。
# 显示系统所有的服务器组。
host(config)# display server-group
Group Name Type Mode Imprint_Clean Access_Security Rule Refer_Count
bbbb firewall 1
dddd firewall 0
group2 firewall 0
Total groups : 3
表1-9 display server-group命令显示信息描述表
Group Name |
服务器组名称 |
Type |
服务器组类型 |
Refer_Count |
引用计数 |
Total groups |
系统内服务器组的个数 |
# 显示RADIUS服务器组bbbb和LDAP服务器组group2。
host(config)# display server-group bbbb
Group Name Type Mode Imprint_Clean Access_Security Rule Refer_Count User List
bbbb firewall 1 123
1 user in group (bbbb)
Group Name Type Mode Refer_Count Radius-server List
bbbb firewall 1 aaa
radius-server in group (bbbb)
host(config)# display server-group group2
group2 firewall 0
0 user in group (group2)
Group Name Type Mode Refer_Count Ldap-server List
group2 firewall 0 server2
1 ldap-server in group (group2
表1-10 display server-group groupname 命令显示信息描述表
Group Name |
服务器组名称 |
Type |
服务器组类型 |
Refer_Count |
引用计数 |
Total groups |
服务器组的个数 |
User List |
使用此服务器组认证的用户列表 |
Radius-server List |
服务器组内RADIUS服务器列表 |
Ldap-server |
服务器组内LDAP服务器列表 |
dn命令用来配置LDAP服务器区别名。
dn dn
LDAP配置视图
dn:区别名,为1~128个字符的字符串。
# 配置LDAP服务器server2的区别名为OU=users,OU=test, DC=com。
host# system-view
host(config-ldap)# dn OU=users,OU=test,DC=com
· ldap
· bindtype
· cnid
· filter
ldap命令用来配置LDAP服务器地址。
ldap server-ip port
LDAP配置视图
server-ip:LDAP服务器地址。
port:LDAP服务器端口,范围是1~65535,缺省389。
# 配置LDAP服务器server2的地址为2.2.2.2。
host# system-view
host(config-ldap)# ldap 2.2.2.2 389
· ldap
· bindtype
· cnid
· dn
ldap命令用来创建和管理LDAP服务器。
no ldap命令用来删除和管理LDAP服务器。
ldap name [ group groupname ]
no ldap name [ group groupname ]
缺省情况下,没有配置LDAP服务器。
group将服务器加入到LDAP组中。
groupname:LDAP服务器要加入的服务器组名称,为1~19个字符的字符串。
创建LDAP服务器后,会进入LDAP配置视图。
# 创建名字为server2的LDAP服务器。
host# system-view
host(config-ldap)#
· ldap
· bindtype
· cnid
· dn
radius-server命令用来配置或管理RADIUS服务器。
no radius-server命令用来管理或删除RADIUS服务器。
radius-server name { server-ip secret [ port ] | group group-name }
no radius-server name [ group group-name ]
缺省情况下,没有配置RADIUS服务器。
用视图
server-ip:服务器IP地址。
secret:服务器密码,为1~256个字符的字符串。
port:服务器的端口号,范围是1~65535,缺省是1812。
group:将服务器加入或删除RADIUS服务器组中。
group-name:服务器组名称,为1~256个字符的字符串。
# 创建RADIUS服务器server1,IP地址1.1.1.1,密码123456。
host# system-view
host(config)# radius-server server1 1.1.1.1 123456
· display radius-server
server-group命令用来创建服务器组。
no server-group命令用来删除服务器组。
server-group name { radius | ldap } firewall
no server-group name
缺省情况下,没有配置服务组。
radius:服务器组为RADIUS服务器组。
ldap:服务器组为LDAP服务器组。
# 创建名字为group2的LDAP服务器组。
host# system-view
host(config)# server-group group2 ldap firewall
· radius-server
· ldap
user-portal-server命令用来配置Portal认证的服务器IP地址。
no user-portal-server命令用来管理或删除Portal认证的服务器IP地址。
user-portal-server {server server-ip | radius server-name | timeout time-value}
no user-portal-server {server server-ip | radius server-name | timeout time-value| portal-url URL }
缺省情况下,没有配置Portal服务器。
server-ip:Portal服务器IP地址。
server-name:RADIUS服务器的名称。
time-out:Portal认证用户的超时时间,范围是1到144000,单位是分钟,缺省是15分钟。
Portal-url:格式如
http://serverip/portal?userip=<USERIP>&usermac=<USERMAC>&origurl=<ORIGURL>&nasip=nasip。
# 配置Portal服务器的IP地址是192.168.10.1,radius服务器的名称是rad-server。
host# system-view
host(config)# user-portal-server server 192.168.10.1
host(config)# user-portal-server radius rad-server
user-radius-ap-mac 命令用于启用AP-Mac学习功能。
user-radius-ap-mac {enable | disable}
enable:启用AP-Mac学习功能
disable:关闭AP-Mac学习功能
缺省情况下,此功能关闭。
可通过识别AP的mac地址来确认场所。
#开启AP-Mac学习
HOST# system-view
HOST(config)# user-radius-ap-mac enable
db-server 命令用于配置数据库服务器名称。
db-server NAME
缺省情况下,无数据库服务器。
创建数据库服务器后,会进入数据库服务器配置视图。
#创建数据库服务器dbtest
HOST:WD-D# system-view
HOST:WD-D(config)# db-server dbtest
HOST:WD-D(db-server-config)#
type 命令用于配置数据库服务器类型。
type postgresql
postgresql:PostgreSQL数据库
缺省情况下,为PostgreSQL,目前只支持PostgreSQL数据库服务器。
可支持与PostgreSQL数据库交互。
#创建数据库服务器dbtest,type配置为postgresql
HOST:WD-D(db-server-config)# type postgresql
server-ip命令用于配置数据库服务器IP和端口。
server-ip A.B.C.D port <1-65535>
A.B.C.D:数据库服务器IP地址
<1-65535>:数据库服务器端口,范围为1-65535
缺省情况下,无IP和port配置。
Postgresql服务器端口一般默认为5432,与数据库服务器安装时配置的端口保持一致即可。
#创建数据库服务器dbtest,配置ip和端口
HOST:WD-D(db-server-config)# server-ip 192.168.2.50 port 5432
character命令用于配置数据库编码。
character { utf-8 | big5 | gbk }
utf-8:数据库编码为utf-8
big5:数据库编码为big5
gbk:数据库编码为gbk
缺省情况下,为utf-8编码。
Postgresql数据库编码需要选择utf-8编码,该类型数据库默认使用utf-8,如果人为修改和使用其他编码会存在兼容性问题,需要经过繁琐的设置和操作才能对接成功。
#创建数据库服务器dbtest,配置编码类型为UTF-8
HOST:WD-D(db-server-config)# character utf8
user命令用于配置数据库服务器的登录用户名和密码。
user USERNAME password PASSWORD
USERNAME:数据库服务器登录用户名
PASSWORD:数据库服务器登录密码
缺省情况下,无用户名密码配置。
与数据库服务器设置的用户名密码保持一致,否则对接时无法通过验证。
#创建数据库服务器dbtest,配置数据库服务器登录的用户名密码
HOST:WD-D(db-server-config)# user postgres password 123456
database命令用于配置数据库服务器的名称。
database NAME
缺省情况下,无数据库名称配置。
数据库名称需要真实存在与服务器中的保持一致。
#创建数据库服务器dbtest,配置数据库名称postgres
HOST:WD-D(db-server-config)# database postgres
timeout命令用于配置数据库服务器的超时时间。
timeout <5-300>
<5-300>:超时时间范围5-300s
缺省情况下,超时时间为30s。
当与数据库对接发起连接请求时等待超过timeout的时间会认为连接超时,自动断开本次连接。
#创建数据库服务器dbtest,配置超时时间为60s
HOST:WD-D(db-server-config)# timeout 60
display running-config db-server命令用来显示系统中配置的所有数据库服务器。
无。
host# display running-config db-server
# 显示系统内所有的数据库服务器配置信息。
db-server test1
type postgresql
server-ip 10.1.200.2 port 5432
character utf8
user postgres secret OSS4E1ouB0s+dZbvVERi9ioYu/EFDtPtH8SFOe0s9+8rev+RQhGEnSzDPHRkqh+
database postgres
db-server test2
type postgresql
server-ip 10.1.163.62 port 5432
character utf8
database dbname
sso-match-other命令用来配置继续匹配后续策略。
user-policy {IF_IN | any} {IF_OUT | any} {SIP |any} {DIP | any} {SCHEDULE | always} sso-match-other { enable | disable } name {group | no-record} { PERIOD | forever | once }
缺省情况下,未开启单点登录。
Config视图
if_in:流量入接口。
any:任何接口。
if_out:流量出接口。
any:任何接口:
sip:源地址匹配的地址对象或对象组。
any:任何源地址。
any:任何目的地址。
schedule :配的时间对象。
always:任何时间。
enable:启用该策略。
disable:不启用该策略。
forever:用户录入永久有效。
once:用户临时录入。
no-record:不录入用户。
# 开启单点登录,源目ip默认、引用时间默认,配置单点登录认证失败后继续匹配后续策略。
host# system-view
host(config)# user-policy any any any any always sso-match-other enable test-sso1 no-record forever
sso-no-authen-ip命令用来配置认证失败后以地址作为用户名。
user-policy {IF_IN | any} {IF_OUT | any} {SIP |any}{DIP | any} {SCHEDULE | always} sso-no-authen-ip { enable | disable } name {group | no-record} { PERIOD | forever | once }
缺省情况下,默认是认证失败后以ip地址作为用户名
Config视图
if_in:流量入接口。
any:任何接口。
if_out:流量出接口。
any:任何接口:
sip:源地址匹配的地址对象或对象组。
any:任何源地址。
any:任何目的地址。
schedule :配的时间对象。
always:任何时间。
enable:启用该策略。
disable:不启用该策略。
forever:用户录入永久有效。
once:用户临时录入。
no-record:不录入用户。
配置认证失败后,允许以ip地址作为用户名
# 开启单点登录,源目ip默认、引用时间默认,配置单点登录认证失败后以ip地址作为用户名。
host# system-view
host(config)#user-policy any any any any always sso-no-authen-ip enable test-sso2 no-record forever
· display running-config user-sso
user-adsso key命令用来配置单点登录密码。
User-adsso key password
缺省情况下,未开启单点登录。
Config视图
配置单点登录使用的密码
# 配置单点登录密码为123456。
host# system-view
host(config)# user-adsso key 123456
· no user-adsso key
user-adsso timeouts命令用于配置单点登录超时时间
user-adsso timeouts <1-72>
配置视图
<1-72>:超时时间
命令用于配置单点登录超时时间,超过该时间后,无法实现单点登录。
#配置单点登录的超时时间为60s
HOST(config)# user-adsso timeouts 60
user-adsso key
bindtype ldap服务器的认证方式。
bindtype simple user name passwd PASSWORD
ldap配置视图
Ldap服务器的认证方式,当域服务器需要认证才能同步用户时必须使用simple认证方式。
# 配置ldap服务器拥有管理权限的域服务器管理员。
host# system-view
host(config)# ldap ad-ldap
host(config-ldap)#bindtype simple user cn=Manager,dc=sa,dc=com passwd 123456
· display ldapserver
cnid 通用名标示。通常情况下有两种类型一种cn,一种upn
1、cn 全称 common name :每个用户节点的识别属性标识
2、upn 用于用户登录名进行web认证时使用的标识
cnid
缺省情况下,cnid为空
ldap配置视图
1、cn 全称 common name :每个用户节点的识别属性标识,当使用标示名时使用cn。
2、upn 用于用户登录名进行web认证时使用的标识。
# 启用负载均衡组。
host# system-view
host(config)#cnid cn
dn也叫Base dn用于获取同步信息的服务器域名路径
Dn distinguish name
缺省情况下,DN为空
ldap配置视图
当配置dn时需保证dn路径正常,否则ldap服务器无法同步和认证
# 配置dn路径。
host# system-view
host(config)#dn ou=spl,ou=abt,dc=sa,dc=com
· display ldap
display sync-task 命令用来查看LDAP用户同步情况。
display sync-task
全局视图
该命令用于查看LDAP用户同步。
# 配置ldap服务器自动同步,并设置同步时间为0点
HOST# display sync-task
name DESC STATUS SYNC_TYPE SYNC_TIME RECORD_LOCAL LATEST_SYNC_STATUS
123 enable LDAP同步 0 enable
同步成功
· display ldap
ldap auto-syn命令用来配置ldap服务器
ldap auto-syn {enable | disable| <0-23>}
ldap配置视图
只有开启自动同步后才可以配置同步时间,默认23点同步。
host# system-view
host(config-ldap)# ldap auto-syn enable
host(config-ldap)# ldap auto-syn 0
ldap A.B.C.D 命令用来配置ldap服务器地址
ldap A.B.C.D
缺省情况下,没有ldap服务器地址,默认端口389
LDAP配置视图
# 配置LDAP服务器server2的地址为A.B.C.D。
host# system-view
host(config-ldap)# ldap A.B.C.D 389
· display ldap
ldap name命令用来ldap配置试图。
No ldap name命令删除ldap服务器。
Ldap name
No ldap name
缺省情况下,未配置ldap服务器
当需要使用ldap认证或者同步时需要配置ldap服务器
# 创建ldap服务器名称。
host# system-view
host(config-ldap)#
表1-11 LDAP服务器页面的详细说明
Ldap name名称 |
LDAP服务器名称 |
addr服务器IP |
LDAP服务器地址 |
port端口 |
LDAP服务器端口,默认389明文,暂不支持636加密同步 |
cnid通用名标示 |
1、cn 全称 common name :每个用户节点的识别属性标识 2、upn 用于用户登录名进行web认证时使用的标识 |
dn |
用于获取同步信息的服务器域名路径 |
bindtype绑定方式 |
1.匿名 2.简单 |
管理员 |
拥有管理权限的域服务器管理员 |
管理员密码 |
管理员对应密码 |
自动同步 |
开启关闭自动同步 |
时间 |
勾选自动同步后配置自动同步时间向AD服务器发送同步请求 |
ldap-auth easy-name-match命令用来配置ldap认证用户名称是否区分大小写。
ldap-auth easy-name-match{enable|disable}
(config)#视图
默认情况下设备认证过程中用户名称区分大小写,而LDAP服务器在检验用户名时不区分大小写,如在LDAP服务器上配置用户名为aaa,用户在认证时输入AAA,也可以认证通过,但在设备侧上线时记录的用户名是AAA,由于设备从LDAP服务器同步下来的用户名是aaa,其它策略在调用aaa做控制后,由于上线时的用户为AAA,导致策略无法匹配上,为了解决这一问题,设备侧开启认证用户名称不区分大小写,即使用户输入了AAA,上线时也会显示为aaa,与本地存的用户名一模一样,保证了后续用户对象正常匹配。
# 配置ldap认证用户名称大小写匹配
(config)# ldap-auth easy-name-match enable 开启后认证时对用户名不区分大小写匹配
(config)# ldap-auth easy-name-match disable 默认区分认证时对用户名区分大小写匹配
· display ldap-auth easy-name-match switch
imc-server1(imc-server2)命令用来配置第三方用户同步接口服务器1(服务器2)。
no imc-server1(imc-server2)命令用来删除第三方服务器1(服务器2)。
imc-server1(imc-server2) name A.B.C.D PASSWD
系统配置视图
A.B.C.D:第三方服务器地址。
PASSWD:与第三方服务器之间对接的密钥,需要与服务器保持一致。
原有命令格式为imc-server name A.B.C.D PASSWD,为了与UI上的服务器1、服务器2配置对应,修改命令格式为imc-server1 name A.B.C.D PASSWD,imc-server2 name A.B.C.D PASSWD,同时做了版本升级配置兼容性,版本升级后自动适配为新的命令格式,但不支持版本回退配置兼容。
#配置第三方用户同步接口名称为imc1,服务器地址为10.0.50.210,密钥为123456
HOST# system-view
HOST(config)# imc-server1 imc1 10.0.50.210 123456
· display imc-server
user-radius-listen accounting port <1-65535>命令用来配置Radius服务器上计费报文的接收端口。
user-radius-listen authentication port <1-65535>命令用来配置Radius服务器上认证报文的接收端口。
user-radius-listen { disable|enable [name]}命令用来禁用/开启radius用户同步功能,并设置将同步成功的radius账号加入本地已创建的用户组
user-radius-listen timeout <10-144000>命令用来配置通过同步上线的radius用户超时时间
系统配置视图
<1-65535>:Radius服务器上计费报文的接收端口,默认为1812。
<1-65535>:Radius服务器上认证报文的接收端口,默认 1813。
disable:禁用radius用户同步功能,默认为禁用状态。
enable:启用radius用户同步功能,同步成功的用户默认加入Radius用户组。
<10-144000>:配置通过Radius同步上线的用户超时时间,默认为15分钟。
Radius报文直接过设备或通过旁路方式镜像到设备的场景均支持。
#配置Radius用户同步
HOST# system-view
HOST(config)# user-radius-listen enable 开启Radius用户同步
HOST(config)# user-radius-listen authentication port 1812 配置radius认证端口为1812
HOST(config)# user-radius-listen accounting port 1813 配置Radius计费端口为1813
HOST(config)#user-radius-listen timeout 144000 配置超时时间为144000分钟
· display user-radius-listen
user-srun switch 命令用来配置与第三方深澜认证服务器对接。
user-srun switch {enable|disable}
系统配置视图
enable:启用与第三方深澜认证服务器对接功能。
disable:禁用与第三方深澜认证服务器对接功能。
深澜认证服务器报文直接通过旁路方式镜像到设备即可。
#配置与第三方深澜认证服务器对接
HOST# system-view
HOST(config)# user-srun switch enable 开启与第三方深澜认证服务器对接的用户同步
HOST(config)#
· display user-srun switch
user-sols switch 命令用来配置与第三方城市热点认证服务器对接。
user-sols switch {enable|disable}
系统配置视图
enable:启用与第三方城市热点认证服务器对接功能。
disable:禁用与第三方城市热点认证服务器对接功能。
城市热点认证服务器报文直接通过旁路方式镜像到设备即可。
#配置与第三方城市热点认证服务器对接
HOST# system-view
HOST(config)# user-sols switch enable 开启与第三方城市热点认证服务器对接的用户同步
HOST(config)#
· display user-sols switch
user-am switch 命令用来配置与第三方安美认证服务器对接。
user-am switch {enable|disable}
系统配置视图
enable:启用与第三方安美认证服务器对接功能。
disable:禁用与第三方安美认证服务器对接功能。
安美认证服务器报文直接通过旁路方式镜像到设备即可。
#配置与第三方安美认证服务器对接
HOST# system-view
HOST(config)# user-am switch enable 开启与第三方安美认证服务器对接的用户同步
HOST(config)#
· display user-am switch
pppoe user-snooper 命令用来配置与第三方pppoe认证服务器对接。
pppoe user-snooper {enable|disable}
系统配置视图
enable:启用与第三方pppoe认证服务器对接功能。
disable:禁用与第三方pppoe认证服务器对接功能。
pppoe认证报文直接过设备或通过旁路方式镜像到设备场景都支持。
#配置与第三方pppoe认证服务器对接
HOST# system-view
HOST(config)# pppoe user-snooper enable 开启与第三方安美认证服务器对接的用户同步
HOST(config)#
user mac-sensitive 命令用来配置用户识别是否对MAC变化保持敏感。
user mac-sensitive{enable|disable}
(config)#视图
enable:开启用户MAC敏感,用户MAC发生变化后会被踢下线重新识别。
disable:关闭用户MAC敏感。
用户MAC敏感命令是配合SNMP跨三层学习MAC功能一起使用的,默认情况下为disable状态,即用户MAC发生变化后用户不会被踢下线;在跨三层环境下由于通过SNMP获取到真实MAC后在线用户的MAC会发生变化,开启MAC敏感以将用户踢下线,重新进行识别,以便重新关联用户。
说明:跨三层环境下,用户上线时MAC识别为匿名用户,MAC 地址为下联三层设备的接口MAC1,用户静态绑定条目为(user2 MAC2),当开启跨三层学习后,正常获取到用户的真实MAC2,如果用户MAC敏感为关闭状态,用户不会重新识别会导致无法关联上静态绑定用户,在线用户仍然会显示匿名用户,就会导致所有引用了账号user2的策略均不生效。
# 配置用户MAC敏感
(config)# user mac-sensitive enable 开启用户MAC敏感
(config)# user mac-sensitive disable 关闭用户MAC敏感
无
旁路认证是指设备旁路部署,为用户提供安全认证服务,如本地web认证、portal认证,不改变客户原有网络架构。
deploy-mode listen enable命令用于接口启用旁路部署。
deploy-mode listen disable命令用于关闭接口旁路部署。
deploy-mode listen {enable| disable}
缺省情况下, 旁路认证未开启。
enable:开启旁路监听功能。
disable:关闭旁路监听功能。
· 旁路模式并不替换用户的路由器,也不提供任何NAT,DHCP或者DNS服务。它通常 放在交换机旁边,通过镜像的方式,仅仅提供认证的功能。旁路模式不修改网络结构, 甚至不关心网络细节,关机也不掉线。
· 核心交换机将所有流量镜像给Device,Device需另外配置一个管理口与内网pc路由可达,开启旁路认证功能,配置认证策略进行认证。
# 开启旁路认证功能,配置认证策略为本地web认证。
HOST# system-view
HOST(config)# interface ge8
HOST(config-ge8)# deploy-mode listen enable
HOST(config)# user-policy listen authentication enable
HOST(config)# user-policy ge8 ge8 any any always local-webauth enable test no-record forever
user-policy listen authentication 命令打开或关闭旁路认证。
user-policy listen authentication {enable| disable}
缺省情况下, 旁路认证未开启。
enable:开启旁路认证功能。
disable:关闭旁路认证功能。
Ø 旁路模式并不替换用户的路由器,也不提供任何NAT,DHCP或者DNS服务。它通常 放在交换机旁边,通过镜像的方式,仅仅提供认证的功能。旁路模式不修改网络结构, 甚至不关心网络细节,关机也不掉线。
Ø 核心交换机将所有流量镜像给Device,Device需另外配置一个管理口与内网pc路由可达,开启旁路认证功能,配置认证策略进行认证。
Ø 旁路认证功能必须与用户策略配合使用才能生效,具体用户策略配置请参考用户认证章节。
HOST# system-view
HOST(config)# int ge8
policy listen block enable 命令用来开启旁路阻断功能。
policy listen block disable 命令用来关闭旁路阻断功能。
policy listen block{enable | disable}
缺省情况下,旁路阻断功能是关闭。
enable:开启旁路阻断功能。
disable:关闭旁路阻断功能。
旁路阻断是针对用户发送TCP rst报文进行阻挡,通过匹配IPV4安全策略阻断相应的上网行为,旁路模式下不修改网络结构,不关心网络细节,甚至设备故障下线也不会影响用户上网。
# 将设备开启旁路阻断功能。
HOST# system-view
HOST(config)# policy listen block enable
· display running-config policy
arp-task命令用来创建arp同步任务。
arp-task { enable | disable } namename A.B.C.D/M { <10-36000> | once } groupgroup [ description ]
配置视图
enable|disable:启用/禁用。
namename:ARP同步任务名称。
A.B.C.D/M:扫描网段。
<2-36000>|once:同步周期,once为单次同步。
groupgroup:用户加入组。
.description:描述信息。
# 创建扫描网段为192.168.200.0/24的arp扫描任务,开启周期同步,同步周期为24小时,加入用户组abc。
Host(config)# arp-task enable sss 192.168.200.0/24 1440 abc
snmp-task命令用来创建snmp同步任务。
snmp-task { enable | disable } name A.B.C.D HH:HH:HH:HH:HH:HH community {v1 | v2 } (<2-36000> | once) group [description]
配置视图
A.B.C.D:SNMP服务器的IP地址。
HH:HH:HH:HH:HH:HH:SNMP服务器的MAC地址。
community:团体名。
v1 | v2:snmp版本号。
<2-36000>:同步周期,单位为秒。
once:单次同步。
group:用户加入组。
description:描述,支持0-127个字符。
# 创建SNMP同步任务,开启周期同步,同步周期为24小时,加入用户组abc,SNMP服务器的IP地址为192.168.203.1,MAC地址为38:22:d6:30:38:7f,服务器支持版本v1。
Host(config)# snmp-task enable snmp 192.168.203.1 38:22:d6:30:38:7f zzz v1 1440 abc
snmp-task record name { default | IP | MAC }命令用于设置snmp自动录入方式。
配置视图
default:录入方式,以默认方式录入。
IP:录入方式,以IP方式。MAC:录入方式,以MAC方式录入。
# 设置SNMP同步任务的录入方式
Host(config)# snmp-task aaa record IP
ldap-task 命令用于从ldap服务器同步用户到设备。
ldap-task { enable | disable } NAEM LDAPSVERVER (ou | sg) enable <0-23> <30-86400> [ GROUP ] [.DESCRIPTION]
config视图
enable|disable:启用|禁用同步任务。
NAEM:同步任务名称。
LDAPSVERVER:LDAP服务器名称。
ou | sg:同步模式,可以选择 ou或 sg(安全组)。
<0-23>:同步时间0-23点。
<30-86400>:间隔多久同步一次,范围30-86400秒,默认为3600秒。
GROUP:用户组名称,将用户加入组。
DESCRIPTION:描述信息,非必填项。
配置此命令前,需要先配置LDAP服务器。
HOST(config)# ldap-task enable 123 ldap1 ou enable 0 86400
display ldap-task
no sync-task命令用来删除同步任务。
no sync-task name
# 删除ldapsyn同步任务。
Host(config)# no sync-task ldapsyn
数据库用户同步是指设备与数据库服务器对接,获取数据库表中用户名和IP,当响应IP的用户产生流量过设备是,会自动加入在线用户,不需要再受其他认证策略限制。
user-db-recognition server命令用于选择配置的数据库服务器。
user-db-recognition server NAME
缺省情况下, 无此配置。
· 当存在多个数据库服务器时,通过名称来区分,配置正确的数据库服务器名称即可。
# 配置数据库用户同步对接的服务器为dbtest。
HOST# system-view
HOST(config-ge8)# user-db-recognition server dbtest
user-db-recognition enable命令用于启用数据库用户同步功能。
user-db-recognition disable命令用于禁用数据库用户同步功能。
user-db-recognition {enable|disable}
缺省情况下, 为禁用状态。
enable:启用。
disable:禁用。
· 当启用数据库用户同步功能后会定期与数据服务器交互获取指定表中的IP和用户名信息。
# 启用数据库用户同步功能。
HOST# system-view
HOST(config-ge8)# user-db-recognition enable
user-db-recognition address 命令用于配置用户同步IP地址范围。
user-db-recognition address ADDRESS
缺省情况下, 无此配置。
ADDRESS:IPv4地址范围,支持配置单个IP、IP范围、IP/MASK三种格式
· 只支持IPV4地址范围的配置,最大支持16组IP配置。
· 只会从数据库服务器中同步满足IP地址范围的用户信息。
# 启用数据库用户同步功能。
HOST# system-view
user-db-recognition cmd 命令用于配置获取已认证用户列表的SQL语句。
user-db-recognition cmd LINE
缺省情况下, 无此配置。
LINE:合法的SQL语句。
需要配置正确合法的SQL语句,从表中获取用户名和IP关键信息。
# 配置获取数据库已认证用户的SQL语句。
HOST# system-view
HOST(config-ge8)# user-db-recognition cmd select username,ip from usertable;
user-db-recognition priority 命令用于配置用户同步功能和认证策略的匹配优先级。
user-db-recognition priority { low | high}
缺省情况下,low。用户流量优先匹配认证策略,匹配不上认证策略的情况下再匹配数据库用户同步的信息
low:优先匹配认证策略,匹配不上认证策略才会匹配数据库用户同步信息
high:优先匹配数据库用户同步信息,匹配不上数据库用户同步信息才会匹配认证策略
· 此命令作用主要用于认证策略地址范围和数据库用户同步的地址范围存在重叠的情况来控制使用那种方式进行匹配处理。以满足不同的用户使用场景。
· 一般情况下认证策略地址对象和数据库用户同步IP范围不存在重叠,使用缺省配置即可。
# 配置数据库用户同步优先级高。
HOST# system-view
HOST(config-ge8)# user-db-recognition priority high
user-db-recognition interval 命令用于配置用户同步间隔。
user-db-recognition interval <10-3600>
缺省情况下, 为60s。
<10-3600>:同步间隔为10-3600s,默认为60s
· 设备会基于数据库用户同步间隔时间定期向数据库发起获取已认证用户的连接请求。当用户信息获取完成后等待下个同步间隔再次进行同步。
· 如果用户量大很大,建议时间间隔配置大一些,避免频繁进行用户同步。
# 配置数据库用户同步间隔为600s。
HOST# system-view
HOST(config-ge8)# user-db-recognition interval 600
display running-config user-db-recognition命令用来显示系统中数据库用户同步配置。
无。
host# display running-config user-db-recognition
# 显示系统内数据库用户同步配置信息。
user-db-recognition address 172.16.0.0/16
user-self-reg NAME type命令用来创建自注册对象,如果指定的自注册对象已经存在,则直接进入相应的自注册对象视图。
no user-self-reg { NAME }命令用来删除已创建的自注册对象。
user-self-reg NAME type { account | terminal }
用户配置视图
NAME 对象名称
account:账号注册
terminal:终端注册
创建新自注册对象,在认证策略中启用自注册时进行引用。根据选择的用户自注册对象,在用户认证页面给用户提供自注册账号的功能。
# 创建新自注册对象或者进入自注册对象视图。
Host# system-view
Host(config)# user-self-reg 123 type account
Host(user-self-reg)# quit
无
approval disable命令用来关闭审批。
approval enable 命令用来开启审批。
approval {enable | disable}
自注册对象视图
disable:关闭命令功能
enable;开启命令功能
命令行配置的自注册对象默认免审批,不开启审批。
在选择审批管理员之前需要先开启审批功能。
将审批功能开启再关闭(默认关闭)
Host# system-view
Host(config)# user-self-reg zh type account
Host(user-self-reg)# approval enable
Host(user-self-reg)# approval disable
auditor
auditor [ NAME ]
自注册对象视图
用来选择审批注册信息的管理员
# 选择管理员
Host# system-view
Host(user-self-reg)# auditor admin
approval
bind { ip | mac }
自注册对象视图
ip:绑定方式为绑定ip。
mac:绑定方式为绑定mac。
只有终端注册有绑定方式的选项,通过绑定信息用来为终端进行注册。
# 选择绑定方式为绑定mac
Host# system-view
Host(config)# user-self-reg zd type terminal
Host(user-self-reg)# bind ip
Host(user-self-reg)# bind mac
expire-set { EXPIRE-DATE | never-expire }
自注册对象视图
EXPIRE-DATE:自定义账号失效时间。
never-expire:永久有效。
命令用来设置账号有效期,设置时间应不早于设备系统当前时间,默认永久有效
# 自定义账号失效时间
Host# system-view
Host(user-self-reg)# expire-set 2021-12-25
group-record命令用来配置用户录入组的方式。
group-record { optional | policy | specific }
自注册对象视图
record:用户录入组的方式,更改注册用户所属组。
specific:指定。
optional:自选。
policy:根据认证策略。
#更改用户录入组的方式
Host# system-view
Host(user-self-reg)# group-record specific
group-path PATH
group-path命令用来指定用户组的路径。
no group-path 命令用来删除指定的用户组路径。
group-path PATH
[no] group-path PATH
自注册对象视图
PATH:指定的用户组路径。
# 更改用户录入组的路径为yonghuzu1
Host# system-view
Host(user-self-reg)# group-path yonghuzu1
item命令用来设置邮箱、手机是否为必填项。
item { mail | phone } { enable | disable }
自注册对象视图
mail:邮件。
phone:手机。
enable:启用必填。
disable:非必填。
#设置邮箱和手机为必填项
Host# system-view
Host(user-self-reg)# item mail enable
Host(user-self-reg)# item phone enable
user-notify mail
mail-limit DOMAIN
user-notify mail命令用来设置邮箱通知审批结果是否开启。
user-notify mail { enable | disable }
自注册对象视图
enable:启用。
disable:禁用。
#设置开启邮箱通知审批结果
Host# system-view
Host(user-self-reg)# user-notify mail enable
mail-limit DOMAIN
mail-limit命令用来设置邮箱填写项的域名限制。
no mail-limit命令用来删除邮箱填写项的域名限制。
mail-limit DOMAIN
no mail-limit DOMAIN
自注册对象视图
DOMAIN:限制允许的域名
设置邮箱填写项的域名限制后,认证注册时则只能填写指定域名的邮箱地址。
比如域名限制设置为qq.com ,则只能填写QQ邮箱地址。
设置邮箱域名限制
Host# system-view
Host(user-self-reg)# mail-limit 163.com
