12-可靠性命令参考
01-以太网OAM命令
本章节下载 01-以太网OAM命令  (272.11 KB)
01-以太网OAM命令
  录
1 以太网OAM
1.1 以太网OAM配置命令
1.1.1 display oam
1.1.2 display oam configuration
1.1.3 display oam critical-event
1.1.4 display oam link-event
1.1.5 oam enable
1.1.6 oam errored-frame threshold
1.1.7 oam errored-frame window
1.1.8 oam errored-frame-period threshold
1.1.9 oam errored-frame-period window
1.1.10 oam errored-frame-seconds threshold
1.1.11 oam errored-frame-seconds window
1.1.12 oam errored-symbol-period threshold
1.1.13 oam errored-symbol-period window
1.1.14 oam global errored-frame threshold
1.1.15 oam global errored-frame window
1.1.16 oam global errored-frame-period threshold
1.1.17 oam global errored-frame-period window
1.1.18 oam global errored-frame-seconds threshold
1.1.19 oam global errored-frame-seconds window
1.1.20 oam global errored-symbol-period threshold
1.1.21 oam global errored-symbol-period window
1.1.22 oam global timer hello
1.1.23 oam global timer keepalive
1.1.24 oam mode
1.1.25 oam remote-failure action
1.1.26 oam remote-loopback
1.1.27 oam remote-loopback interface
1.1.28 oam remote-loopback reject-request
1.1.29 oam timer hello
1.1.30 oam timer keepalive
1.1.31 reset oam
1 以太网OAM
1.1  以太网OAM配置命令
1.1.1  display oam
display oam命令用来显示以太网OAM连接的信息。
display oam { local | remote } [ interface interface-type interface-number ]
local:显示本端信息。
remote:显示远端信息。
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的信息。
# 显示所有接口上以太网OAM连接的本端信息。
<Sysname> display oam local
----------- [Ten-GigabitEthernet1/0/1] -----------
 Enable status     : Enable
 Loopback status   : No loopback
 Link status       : UP
 OAM mode          : Active
 PDU               : ANY
 Mux action        : FWD
 Par action        : FWD
# 显示接口Ten-GigabitEthernet1/0/1上以太网OAM连接的本端信息。
<Sysname> display oam local interface ten-gigabitethernet 1/0/1
 Link status       : UP
 OAM mode          : Active
 PDU               : ANY
 Mux action        : FWD
 Par action        : FWD
 Flags
   Link fault        : Not occurred
   Dying gasp        : Not occurred
   Critical event    : Not occurred
   Local evaluating  : COMPLETE
   Remote evaluating : COMPLETE
 Packets statistics
   Packet type                      Sent                   Received
   OAMPDU                           100                    80
   OAMInformation                   64                     60
   OAMEventNotification             36                     20
   OAMUniqueEventNotification       36                     10
   OAMDuplicateEventNotification    0 10
表1-1 display oam local命令显示信息描述表
接口Ten-GigabitEthernet1/0/1上的信息
Enable status
本端的以太网OAM状态:
·     Enable:表示已开启
·     Disable:表示未开启
Loopback status
以太网OAM远端环回状态:
·     No loopback:表示尚未建立远端环回
·     Remote loopback:表示远端环回的主控端
·     Local loopback:表示远端环回的被控端
Link status
链路物理状态:
·     UP:表示链路up
·     DOWN:表示链路down
OAM mode
本端以太网OAM的连接模式:
·     Active:表示主动模式
·     Passive:表示被动模式
PDU
本端对OAMPDU的处理方式:
·     RX_INFO:表示只接收Information OAMPDU,不允许发送任何OAMPDU
·     LF_INFO:表示只发送不带Information TLV且链路错误标志位已被置位的Information OAMPDU
·     INFO:表示只收发Information OAMPDU
·     ANY:表示可收发所有OAMPDU
Mux action
本端发送器的工作方式:
·     FWD:表示发送方向为FORWARDING,允许发送任何报文
·     DISCARD:表示发送方向为DISCARDING,只允许发送OAMPDU
Par action
本端接收器的工作方式:
·     FWD:表示接收方向为FORWARDING,允许接收任何报文
·     DISCARD:表示接收方向为DISCARDING,只允许接收OAMPDU
·     LB:表示接收方向处于环回状态,收到的所有非OAMPDU都将按原路返回
Flags
以太网OAM报文中的本端标识域
Link fault
是否发生链路故障:
·     Occurred:表示已发生
·     Not occurred:表示未发生
Dying gasp
是否发生致命故障:
·     Occurred:表示已发生
Critical event
是否发生紧急事件:
·     Occurred:表示已发生
Local evaluating
本端对远端配置的协商过程:
·     COMPLETE:表示协商已完成
·     NOTCOMPLETE:表示协商未完成
Remote evaluating
远端对本端配置的协商过程:
·     COMPLETE:表示协商已完成
·     RESERVED:表示此字段为保留值,协商未完成
·     UNSATISFIED:表示远端对本端的配置不满意,协商未完成
Packets statistics
各种以太网OAM报文的发送和接收数量
Packet type
报文类型
Sent
发送的报文数量
Received
收到的报文数量
OAMPDU
以太网OAM报文
OAMInformation
以太网OAM信息报文
以太网OAM事件通知报文
以太网OAM一次性发送或接收的事件报文
以太网OAM重复发送或接收的事件报文
# 显示所有接口上以太网OAM连接的远端信息。
<Sysname> display oam remote
 OAM mode          : Active
 MAC address       : 3822-d6a2-a800
 MTU size          : 1500
 Mux action        : FWD
 Par action        : FWD
# 显示接口Ten-GigabitEthernet1/0/1上以太网OAM连接的远端信息。
<Sysname> display oam remote interface ten-gigabitethernet 1/0/1
 OAM mode          : Active
 MTU size          : 1500
 Mux action        : FWD
 Par action        : FWD
 Configuration
   Unidirectional    : Not supported
   Remote loopback   : Not supported
   Link events       : Supported
   MIB retrieval     : Not supported
 Flags
表1-2 display oam remote命令显示信息描述表
OAM mode
远端的以太网OAM连接模式:
·     Active:表示主动模式
·     Passive:表示被动模式
MAC address
远端的MAC地址
MTU size
以太网OAM实体间传送的报文最大长度,单位为字节
Mux action
远端发送器的工作方式
Par action
远端接收器的工作方式:
Configuration
远端以太网OAM实体的配置信息
Unidirectional
是否支持单向传输:
·     Supported:表示支持
·     Not supported:表示不支持
Remote loopback
是否支持远端环回:
·     Supported:表示支持
Link events
是否支持一般链路事件:
·     Supported:表示支持
MIB retrieval
是否支持获取MIB变量:
·     Supported:表示支持
Flags
以太网OAM报文中的远端标识域
Link fault
是否发生链路故障:
·     Occurred:表示已发生
Dying gasp
是否发生致命故障:
·     Occurred:表示已发生
Critical event
是否发生紧急事件:
·     Occurred:表示已发生
Local evaluating
本端对远端配置的协商过程:
·     COMPLETE:表示协商已完成
·     UNSATISFIED:表示本端对远端的配置不满意,协商未完成
Remote evaluating
远端对本端配置的协商过程:
·     COMPLETE:表示协商已完成
·     reset oam
display oam configuration命令用来显示以太网OAM的配置信息。
display oam configuration [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示全局以及未采用缺省配置的接口上的信息。
# 显示全局以及未采用缺省配置的接口上的以太网OAM配置信息。
<Sysname> display oam configuration
---------------- [Global] ----------------
 OAM timers
   Hello timer        : 1000 milliseconds
   Keepalive timer    : 5000 milliseconds
 Link monitoring
   Errored symbol period
     Window           : 100 x 1000000 symbols
     Threshold        : 1 error symbols
   Errored frame
     Window           : 10 x 100 milliseconds
     Threshold        : 1 error frames
   Errored frame period
     Window           : 1000 x 10000 frames
   Errored frame seconds
     Window           : 600 x 100 milliseconds
     Threshold        : 1 error seconds
 OAM timers
   Hello timer        : 500 milliseconds
 Link monitoring
   Errored frame
表1-3 display oam configuration命令显示信息描述表
Global
全局信息
OAM timers
以太网OAM连接检测定时器
Hello timer
以太网OAM握手报文的发送间隔
Keepalive timer
以太网OAM连接的超时时间
Link monitoring
一般链路事件的检测窗口和检测阈值
错误信号事件
Errored frame
错误帧事件
错误帧周期事件
错误帧秒事件
Window
检测窗口
Threshold
检测阈值
display oam critical-event命令用来显示以太网OAM的紧急链路事件统计信息。
display oam critical-event [ interface interface-type interface-number ]
# 显示所有接口上以太网OAM紧急链路事件的统计信息。
<Sysname> display oam critical-event
 Local link status   : UP
 Event statistics
表1-4 display oam critical-event命令显示信息描述表
Local link status
本端的链路状态:
·     UP:表示链路up
·     DOWN:表示链路down
Event statistics
紧急链路事件的统计信息
Link fault
是否发生链路故障:
·     Occurred:表示已发生
Dying gasp
是否发生致命故障:
·     Occurred:表示已发生
Critical event
是否发生紧急事件:
·     Occurred:表示已发生
display oam link-event命令用来显示以太网OAM的一般链路事件统计信息。
display oam link-event { local | remote } [ interface interface-type interface-number ]
local:显示本端统计信息。
remote:显示远端统计信息。
以太网OAM的一般链路事件包括错误信号事件、错误帧事件、错误帧周期事件和错误帧秒事件。
# 显示所有接口上以太网OAM一般链路事件的本端统计信息。
<Sysname> display oam link-event local
 Link status: UP
 OAM local errored symbol event
   Event time stamp         : 35498 x 100 milliseconds
   Errored symbol window    : 100000000 symbols
   Errored symbol threshold : 1 error symbols
   Errored symbol           : 1 error symbols
   Error running total      : 4 error symbols
   Event running total      : 4 events
 OAM local errored frame event
   Event time stamp        : 49582 x 100 milliseconds
   Errored frame window    : 10 x 100 milliseconds
   Errored frame threshold : 1 error frames
   Errored frame           : 1 error frames
   Error running total     : 6 error frames
   Event running total     : 6 events
 OAM local errored frame period event
   Event time stamp                : 16382 x 100 milliseconds
   Errored frame period window     : 10000000 frames
   Errored frame period threshold  : 1 error frames
   Errored frame period            : 1 error frames
   Error running total             : 5 error frames
   Event running total             : 5 events
 OAM local errored frame seconds summary event
   Event time stamp                : 50022 x 100 milliseconds
   Errored frame seconds window    : 600 x 100 milliseconds
   Errored frame seconds threshold : 1 error seconds
   Errored frame seconds           : 1 error seconds
   Error running total             : 1 error seconds
   Event running total             : 1 events
# 显示所有接口上以太网OAM一般链路事件的远端统计信息。
<Sysname> display oam link-event remote
 Link status: UP
 OAM remote errored symbol event
 OAM remote errored frame event
 OAM remote errored frame period event
 OAM remote errored frame seconds summary event
表1-5 display oam link-event命令显示信息描述表
Link status
链路状态:
·     UP:表示链路up
·     DOWN:表示链路down
OAM local/remote errored symbol event
本端/远端产生的错误信号事件信息(只有产生了错误信号事件才会显示):
·     Event time stamp:表示错误信号事件的发生时间
·     Errored symbol window:表示错误信号事件的检测窗口
·     Errored symbol threshold:表示错误信号事件的检测阈值
·     Errored symbol:表示最近一次错误信号事件中错误信号的数量
·     Error running total:表示错误信号的总数量
·     Event running total:表示错误信号事件的总数量
OAM local/remote errored frame event
本端/远端产生的错误帧事件信息(只有产生了错误帧事件才会显示):
·     Event time stamp:表示错误帧事件的发生时间
·     Errored frame window:表示错误帧事件的检测窗口
·     Errored frame threshold:表示错误帧事件的检测阈值
·     Errored frame:表示最近一次错误帧事件中错误帧的数量
·     Error running total:表示错误帧的总数量
·     Event running total:表示错误帧事件的总数量
OAM local/remote errored frame period event
本端/远端产生的错误帧周期事件信息(只有产生了错误帧周期事件才会显示):
·     Event time stamp:表示错误帧周期事件的发生时间
·     Errored frame period window:表示错误帧周期事件的检测窗口
·     Errored frame period threshold:表示错误帧周期事件的检测阈值
·     Errored frame period:表示最近一次错误帧周期事件中错误帧的数量
·     Error running total:表示错误帧周期的总数量
·     Event running total:表示错误帧周期事件的总数量
OAM local/remote errored frame seconds summary event
本端/远端产生的错误帧秒事件信息(只有产生了错误帧秒事件才会显示):
·     Event time stamp:表示错误帧秒事件的发生时间
·     Errored frame seconds window:表示错误帧秒事件的检测窗口
·     Errored frame seconds threshold:表示错误帧秒事件的检测阈值
·     Errored frame seconds:表示最近一次错误帧秒事件中错误帧的数量
·     Error running total:表示错误帧秒的总数量
·     Event running total:表示错误帧秒事件的总数量
·     reset oam
1.1.5  oam enable
oam enable命令用来开启以太网OAM功能。
undo oam enable命令用来关闭以太网OAM功能。
oam enable
undo oam enable
以太网OAM功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上开启以太网OAM功能。
[Sysname-Ten-GigabitEthernet1/0/1] oam enable
oam errored-frame threshold命令用来在接口上配置错误帧事件的检测阈值。
undo oam errored-frame threshold命令用来恢复缺省情况。
oam errored-frame threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧事件的检测阈值,取值范围为0~4294967295,单位为次。
接口值只对当前接口有效,但配置优先级高于全局值。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame threshold 100
·     display oam configuration
·     display oam link-event
·     oam global errored-frame threshold
oam errored-frame window命令用来在接口上配置错误帧事件的检测窗口。
undo oam errored-frame window命令用来恢复缺省情况。
oam errored-frame window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧事件的检测窗口,取值范围为10~600,步长为10,单位为100毫秒。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧事件的检测窗口为2000毫秒。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame window 20
·     oam global errored-frame window
oam errored-frame-period threshold命令用来在接口上配置错误帧周期事件的检测阈值。
undo oam errored-frame-period threshold命令用来恢复缺省情况。
oam errored-frame-period threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧周期事件的检测阈值,取值范围为0~4294967295,单位为次。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧周期事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame-period threshold 100
·     oam global errored-frame-period threshold
oam errored-frame-period window命令用来在接口上配置错误帧周期事件的检测窗口。
undo oam errored-frame-period window命令用来恢复缺省情况。
oam errored-frame-period window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧周期事件的检测窗口,取值范围为1~65535,单位为10000次。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧周期事件的检测窗口为20000000次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame-period window 2000
·     oam global errored-frame-period window
oam errored-frame-seconds threshold命令用来在接口上配置错误帧秒事件的检测阈值。
undo oam errored-frame-seconds threshold命令用来恢复缺省情况。
oam errored-frame-seconds threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧秒事件的检测阈值,取值范围为0~900,单位为次。
在数量上,错误帧秒事件的检测阈值不应大于其检测窗口值(换算成秒),否则将不会产生错误帧秒事件。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧秒事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame-seconds threshold 100
·     oam errored-frame-seconds window
·     oam global errored-frame-seconds threshold
oam errored-frame-seconds window命令用来在接口上配置错误帧秒事件的检测窗口。
undo oam errored-frame-seconds window命令用来恢复缺省情况。
oam errored-frame-seconds window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧秒事件的检测窗口,取值范围为100~9000,步长为10,单位为100毫秒。
# 在接口Ten-GigabitEthernet1/0/1上配置错误帧秒事件的检测窗口为10000毫秒。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-frame-seconds window 100
·     oam errored-frame-seconds threshold
·     oam global errored-frame-seconds window
oam errored-symbol-period threshold命令用来在接口上配置错误信号事件的检测阈值。
undo oam errored-symbol-period threshold命令用来恢复缺省情况。
oam errored-symbol-period threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误信号事件的检测阈值,取值范围为0~4294967295,单位为次。
# 在接口Ten-GigabitEthernet1/0/1上配置错误信号事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-symbol-period threshold 100
·     oam global errored-symbol-period threshold
oam errored-symbol-period window命令用来在接口上配置错误信号事件的检测窗口。
undo oam errored-symbol-period window命令用来恢复缺省情况。
oam errored-symbol-period window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误信号事件的检测窗口,取值范围为1~65535,单位为1000000次。
# 在接口Ten-GigabitEthernet1/0/1上配置错误信号事件的检测值为200000000次。
[Sysname-Ten-GigabitEthernet1/0/1] oam errored-symbol-period window 200
·     oam global errored-symbol-period window
oam global errored-frame threshold命令用来全局配置错误帧事件的检测阈值。
undo oam global errored-frame threshold命令用来恢复缺省情况。
oam global errored-frame threshold threshold-value
错误帧事件检测阈值的全局值为1次。
全局值对所有接口都有效,但配置优先级低于接口值。
# 全局配置错误帧事件的检测阈值为100次。
[Sysname] oam global errored-frame threshold 100
·     oam errored-frame threshold
oam global errored-frame window命令用来全局配置错误帧事件的检测窗口。
undo oam global errored-frame window命令用来恢复缺省情况。
oam global errored-frame window window-value
错误帧事件检测窗口的全局值为1000毫秒。
# 全局配置错误帧事件的检测窗口配置为2000毫秒。
[Sysname] oam global errored-frame window 20
·     oam errored-frame window
oam global errored-frame-period threshold命令用来全局配置错误帧周期事件的检测阈值。
undo oam global errored-frame-period threshold命令用来恢复缺省情况。
oam global errored-frame-period threshold threshold-value
错误帧周期事件检测阈值的全局值为1次。
# 全局配置错误帧周期事件的检测阈值为100次。
[Sysname] oam global errored-frame-period threshold 100
·     oam errored-frame-period threshold
oam global errored-frame-period window命令用来全局配置错误帧周期事件的检测窗口。
undo oam global errored-frame-period window命令用来恢复缺省情况。
oam global errored-frame-period window window-value
错误帧周期事件检测窗口的全局值为10000000次。
# 全局配置错误帧周期事件的检测窗口为20000000次。
[Sysname] oam global errored-frame-period window 2000
·     oam errored-frame-period window
oam global errored-frame-seconds threshold命令用来全局配置错误帧秒事件的检测阈值。
undo oam global errored-frame-seconds threshold命令用来恢复缺省情况。
oam global errored-frame-seconds threshold threshold-value
错误帧秒事件检测阈值的全局值为1次。
# 全局配置错误帧秒事件的检测阈值配置为100次。
[Sysname] oam global errored-frame-seconds threshold 100
oam global errored-frame-seconds window命令用来全局配置错误帧秒事件的检测窗口。
undo oam global errored-frame-seconds window命令用来恢复缺省情况。
oam global errored-frame-seconds window window-value
错误帧秒事件检测窗口的全局值为60000毫秒。
# 全局配置错误帧秒事件的检测窗口为10000毫秒。
[Sysname] oam global errored-frame-seconds window 100
oam global errored-symbol-period threshold命令用来全局配置错误信号事件的检测阈值。
undo oam global errored-symbol-period threshold命令用来恢复缺省情况。
oam global errored-symbol-period threshold threshold-value
错误信号事件检测阈值的全局值为1次。
# 全局配置错误信号事件的检测阈值为100次。
[Sysname] oam global errored-symbol-period threshold 100
·     oam errored-symbol-period threshold
oam global errored-symbol-period window命令用来全局配置错误信号事件的检测窗口。
undo oam global errored-symbol-period window命令用来恢复缺省情况。
oam global errored-symbol-period window window-value
错误信号事件检测窗口的全局值为100000000次。
# 全局配置错误信号事件的检测窗口为200000000次。
[Sysname] oam global errored-symbol-period window 200
·     oam errored-symbol-period window
oam global timer hello命令用来全局配置以太网OAM握手报文的发送间隔。
undo oam global timer hello命令用来恢复缺省情况。
oam global timer hello interval
以太网OAM握手报文发送间隔的全局值为1000毫秒。
interval:表示以太网OAM握手报文的发送间隔,取值范围为500~5000,单位为毫秒,步长为100。
由于本端OAM实体在连接超时后将老化与远端OAM实体的连接关系,导致OAM连接中断,因此连接超时时间必须大于握手报文发送间隔(建议为五倍或以上),否则将导致以太网OAM连接不稳定。
# 全局配置以太网OAM握手报文的发送间隔为600毫秒。
[Sysname] oam global timer hello 600
·     oam timer hello
oam global timer keepalive命令用来全局配置以太网OAM连接的超时时间。
undo oam global timer keepalive命令用来恢复缺省情况。
oam global timer keepalive interval
以太网OAM连接超时时间的全局值为5000毫秒。
interval:表示以太网OAM连接的超时时间,取值范围为1000~25000,单位为毫秒,步长为100。
# 全局配置以太网OAM连接的超时时间为6000毫秒。
[Sysname] oam global timer keepalive 6000
·     oam timer keepalive
1.1.24  oam mode
oam mode命令用来配置以太网OAM的连接模式。
undo oam mode命令用来恢复缺省情况。
oam mode { active | passive }
undo oam mode
以太网OAM连接模式为主动模式。
二层以太网接口视图
三层以太网接口视图
active:表示主动模式。
passive:表示被动模式。
不允许在已开启以太网OAM功能的接口上更改以太网OAM的连接模式。如需更改,请先关闭该接口上的以太网OAM功能。
# 在接口Ten-GigabitEthernet1/0/1上先关闭以太网OAM功能,再配置以太网OAM的连接模式为被动模式。
[Sysname-Ten-GigabitEthernet1/0/1] undo oam enable
[Sysname-Ten-GigabitEthernet1/0/1] oam mode passive
·     oam enable
oam remote-failure action命令用来配置接口收到远端以太网OAM事件时的响应动作。
undo oam remote-failure action命令用来取消接口收到远端以太网OAM事件时的响应动作的配置。
oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
undo oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
接口收到远端以太网OAM事件时仅记录日志。
二层以太网接口视图
三层以太网接口视图
connection-expired:表示以太网OAM连接超时。
critical-event:表示紧急事件。
dying-gasp:表示致命故障。
link-fault:表示链路故障。
error-link-down:表示断开OAM连接,并设置接口的链路层状态为down。
对于Link fault功能,需要注意的是:
·     仅光接口支持Link fault功能。
·     当光接口接入的光模块为QSFP-40G-BIDI-SR-MM850时,不支持Link fault功能。
# 配置接口Ten-GigabitEthernet1/0/1收到紧急事件时的响应动作为断开OAM连接,并设置该接口的链路层状态为down。
[Sysname-Ten-GigabitEthernet1/0/1] oam remote-failure critical-event action error-link-down
oam remote-loopback start命令用来开启接口的以太网OAM远端环回功能。
oam remote-loopback stop命令用来关闭接口的以太网OAM远端环回功能。
以太网OAM远端环回功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
只有当接口上的以太网OAM连接已建立完成,且以太网OAM的连接模式为主动模式时,才允许在该接口上开启以太网OAM远端环回功能。
用户既可在用户视图或系统视图下开启指定接口的以太网OAM远端环回功能,也可在接口视图下开启当前接口的以太网OAM远端环回功能,三者的配置效果相同。
# 配置接口Ten-GigabitEthernet1/0/1的以太网OAM的连接模式为主动模式并开启其以太网OAM功能,然后在该接口视图下开启其以太网OAM远端环回功能。
[Sysname-Ten-GigabitEthernet1/0/1] oam mode active
[Sysname-Ten-GigabitEthernet1/0/1] oam remote-loopback start
·     oam enable
·     oam mode
·     oam remote-loopback interface
oam remote-loopback start interface命令用来开启接口的以太网OAM远端环回功能。
oam remote-loopback stop interface命令用来关闭接口的以太网OAM远端环回功能。
oam remote-loopback start interface interface-type interface-number
oam remote-loopback stop interface interface-type interface-number
以太网OAM远端环回功能处于关闭状态。
# 配置接口Ten-GigabitEthernet1/0/1的以太网OAM的连接模式为主动模式并开启其以太网OAM功能,然后在系统视图下开启该接口的以太网OAM远端环回功能。
[Sysname] oam remote-loopback start interface ten-gigabitethernet 1/0/1
·     oam enable
·     oam mode
oam remote-loopback reject-request命令用来配置接口拒绝远端发起的以太网OAM远端环回。
undo oam remote-loopback reject-request命令用来恢复缺省情况。
接口不拒绝远端发起的以太网OAM远端环回。
二层以太网接口视图
三层以太网接口视图
在执行oam remote-loopback reject-request命令时若接口已处于环回状态,则该配置将从下次环回开始时生效。
# 配置接口Ten-GigabitEthernet1/0/1拒绝远端发起的以太网OAM远端环回。
[Sysname-Ten-GigabitEthernet1/0/1] oam remote-loopback reject-request
oam timer hello命令用来在接口上配置以太网OAM握手报文的发送间隔。
undo oam timer hello命令用来恢复缺省情况。
oam timer hello interval
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上配置以太网OAM握手报文的发送间隔为600毫秒。
[Sysname-Ten-GigabitEthernet1/0/1] oam timer hello 600
·     oam global timer hello
oam timer keepalive命令用来在接口上配置以太网OAM连接的超时时间。
undo oam timer keepalive命令用来恢复缺省情况。
oam timer keepalive interval
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/1上配置以太网OAM连接的超时时间为6000毫秒。
[Sysname-Ten-GigabitEthernet1/0/1] oam timer keepalive 6000
·     oam global timer keepalive
1.1.31  reset oam
reset oam命令用来清除以太网OAM的报文和一般链路事件统计信息。
reset oam [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的信息。
# 清除所有接口上以太网OAM的报文和一般链路事件统计信息。
<Sysname> reset oam
·     display oam
