05-二层技术-广域网接入命令参考
07-3G Modem和4G Modem管理命令
本章节下载  (430.20 KB)
1 3G/4G Modem管理
1.1  3G/4G Modem管理公共配置命令
1.1.1  controller cellular
controller cellular命令用来进入Cellular接口视图。
controller cellular cellular-number
cellular-number:Cellular接口的编号。
# 进入接口Cellular2/4/0的视图。
[Sysname] controller cellular 2/4/0
[Sysname-Cellular 2/4/0]
1.1.2  description
description命令用来设置当前接口的描述信息。
undo description命令用来恢复缺省情况。
接口的描述信息为“该接口的接口名 Interface”,比如:Cellular2/4/0 Interface。
Cellular接口视图
text:接口描述信息,为1~255个字符的字符串,区分大小写。
# 设置接口Cellular2/4/0的描述信息为“Cellular-intf”。
[Sysname-Cellular2/4/0] description Cellular-intf
1.1.3  display cellular
display cellular命令用来显示3G/4G Modem的呼叫连接信息。
display cellular [ interface-number ]
interface-number:显示指定Cellular接口的3G/4G Modem呼叫连接信息。如果不指定本参数,则显示所有在位Modem对应Cellular接口的3G/4G Modem呼叫连接信息。
对于不同厂家生产的3G/4G Modem,此命令显示的内容和格式可能略有区别。
# 显示3G Modem的呼叫连接信息(WCDMA网络)。
<Sysname> display cellular 2/4/0
Cellular2/4/0:
  Hardware Information:
    Model: E176G
    Modem Firmware Version: 11.604.09.00.00
    Hardware Version: CD25TCPU
    International Mobile Subscriber Identity (IMSI): 460029010431055
    International Mobile Equipment Identity (IMEI): 353871020138548
    Factory Serial Number (FSN):  DK9RAA1871500602
    Modem Status: Online
  Profile Information:
    Profile 1: Active
      PDP Type: IPv4, Header Compression: Off
      Data Compression: Off
      Access Point Name (APN): 001
      Packet Session Status: Inactive
  Modem Setup Information:
    Diagnostics Monitor: Close
  Network Information:
    Current Service Status: Service available
    Current Service: Combined
    Packet Service: Attached
    Current Roaming Status: Roaming
    Network Selection Mode: Manual
    Network Connection Mode: WCDMA precedence
    Current Network Connection: HSDPA and HSUPA
    Mobile Country Code (MCC): 460
    Mobile Network Code (MNC): 00
    Location Area Code (LAC): 4318
    Cell ID: 25381
  Radio Information:
    Current Band: ANY
    Current RSSI: -51 dBm
  Modem Security Information:
    PIN Verification: Disabled
    PIN Status: Ready
    Number of Retries remaining: 3
    SIM Status: OK
表1-1 display cellular命令显示信息描述表(WCDMA网络)
硬件信息
Model
3G Modem名称
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
SIM卡的IMSI号码串
3G Modem的IMEI串号
3G Modem的产品序列号
Modem Status
3G Modem的状态:
·     Online:3G Modem处于上电状态
·     Offline:3G Modem处于下电状态或省电模式,cellular接口功能不可用
Profile Information
3G Modem的参数模板信息
Profile 1
3G Modem的PDP设置状态:
·     Active:已经配置参数模板
·     Undefined:还未配置参数模板
PDP Type
PDP类型,只有Profile 1: Active时,才显示该信息:
·     IPv4:PDP协议类型为IPv4
·     IPv6:PDP协议类型为IPv6
·     PPP:PDP协议类型为PPP透传
Header Compression
PDP头压缩模式:
·     On:使能PDP头压缩
·     Off:禁止PDP头压缩
Data Compression
PDP数据压缩模式:
·     On:使能PDP数据压缩
·     Off:禁止PDP数据压缩
接入点名称
PDP的激活状态:
·     Active:处于激活状态,3G Modem正在进行PPP传输
·     Inactive:处于非激活状态,3G Modem接口的物理状态为Down
Modem安装状态
Diagnostics Monitor
诊断口监控状态
·     Open:诊断监控打开
·     Close:诊断监控关闭
Network Information
网络信息
3G Modem的服务状态:
·     Service available:提供有效服务
·     Emergency:提供有限制服务,Cellular接口功能不可用
·     No service:无法提供服务,Cellular接口功能不可用
·     Low power:处于省电模式,Cellular接口功能不可用
Current Service
当前服务类型:
·     Circuit-switched:仅CS域服务
·     Packet-switched:仅PS域服务
·     Combined:CS和PS域服务都有效
·     Invalid:服务无效
Packet Service
3G Modem PS域附着状态:
·     Detached:分离状态,Cellular接口功能不可用
·     Attached:连接状态
漫游状态:
·     Roaming:漫游状态
·     Home:本地状态
网络选择模式:
·     Manual:手动选择
·     Automatic:自动选择
网络连接模式:
·     WCDMA only:仅连接WCDMA网络
·     WCDMA precedence:优先连接WCDMA网络
·     GSM only:仅连接GSM网络
·     GSM precedence:优先连接GSM网络
当前网络连接:
·     No Service:无服务
·     GSM:GSM网络
·     GPRS:GPRS网络
·     EDGE:EDGE网络
·     WCDMA:WCDMA网络
·     HSDPA:HSDPA网络
·     HSUPA:HSUPA网络
·     HSDPA and HSUPA:HSDPA和HSUPA网络
·     HSPA+:HSPA+网络
·     Unknown:未知网络
移动国家码,搜索到网络后才能显示该信息。
运营商网络代码,成功注册到网络后才能显示该信息。
位置码信息,成功注册到网络后才能显示该信息
Cell ID
小区信息,成功注册到网络后才能显示该信息
Current Band
当前频带选择模式:
·     GSM:选择GSM网络频带
·     WCDMA:选择WCDMA网络频带
·     ANY:选择任意频带
·     AUTO:自动选择频带
Current RSSI
当前信号质量:
·     信号质量的取值范围为-110dBm ~ -51dBm
·     Unknown:无信号,Cellular接口功能不可用
Modem安全信息
PIN Verification
PIN认证状态:
·     Disabled:未使能PIN认证
·     Enabled:使能了PIN认证
PIN Status
·     Ready:SIM卡状态正常
·     PIN Requirement:SIM卡有PIN认证请求,需要用户配置pin verify命令
·     PUK Requirement:SIM卡有PUK认证请求,需要用户配置pin unlock命令
PIN或PUK剩余尝试次数
SIM Status
SIM卡状态:
·     OK:SIM卡状态正常
·     Network Reject:SIM卡被拒绝接入网络,Cellular接口功能不可用
·     Not Insert:未插入SIM卡,Cellular接口功能不可用
# 显示3G Modem的呼叫连接信息(TD-SCDMA网络)。
Cellular2/4/0:
    Model: ET128
    Modem Firmware Version: 11.101.01.08.00
    Hardware Version:  CS31TCPU
    International Mobile Subscriber Identity (IMSI): 460079011105842
    International Mobile Equipment Identity (IMEI): 860039002369111
    Factory Serial Number (FSN):  GQ4CAB1942911350
    Profile 1: Active
      PDP Type: IPv4
      Access Point Name (APN): cmnet
      Packet Session Status: Active
    Network Selection Mode: Automatic
    Network Connection Mode: TD-SCDMA precedence
    Mobile Network Name: CHINA MOBILE
    Downstream Bandwidth: 2800000 bps
  Radio Information:
    Current RSSI: -75 dBm
    PIN Status: Ready
    SIM Status: OK
表1-2 display cellular命令显示信息描述表(TD-SCDMA网络)
硬件信息
Model
3G Modem名称
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
SIM卡的IMSI号码串
3G Modem的IMEI串号
3G Modem的产品序列号
Modem Status
3G Modem的状态:
Profile Information
3G Modem的参数模板信息
Profile 1
3G Modem的PDP设置状态:
·     Active:已经配置参数模板
PDP Type
·     IPv4:PDP协议类型为IPv4
·     IPv6:PDP协议类型为IPv6
·     PPP:PDP协议类型为PPP透传
Header Compression
PDP头压缩模式:
·     On:使能PDP头压缩
·     Off:禁止PDP头压缩
Data Compression
PDP数据压缩模式:
·     On:使能PDP数据压缩
·     Off:禁止PDP数据压缩
接入点名称
PDP的激活状态:
Network Information
网络信息
3G Modem的服务状态:
网络选择模式:
·     Manual:手动选择
·     Automatic:自动选择
网络连接模式:
·     TD-SCDMA only:仅连接TD-SCDMA网络
·     TD-SCDMA precedence:优先连接TD-SCDMA网络
·     GSM only:仅连接GSM网络
当前网络连接:
·     No Service:无服务
·     GSM:GSM网络
·     GPRS:GPRS网络
·     EDGE:EDGE网络
·     TD-SCDMA:TD-SCDMA网络
·     HSDPA:HSDPA网络
·     Unknown:未知网络
Mobile Network Name
移动网络名称
下行理论带宽,单位为bps
Radio Information
无线电通信信息
Current RSSI
当前信号质量:
Modem安全信息
PIN Verification
PIN认证状态:
·     Disabled:未使能PIN认证
·     Enabled:使能了PIN认证
PIN Status
PIN状态:
·     Ready:SIM卡状态正常
PIN或PUK剩余尝试次数
SIM Status
SIM卡状态:
·     OK:SIM卡状态正常
# 显示3G Modem的呼叫连接信息(CDMA网络)。
Cellular2/4/0:
    Model: EC169
    Manufacturer: HUAWEI TECHNOLOGIES CO.
    Modem Firmware Version: 11.002.03.01.45
    Hardware Version:  CE62TCPUVer A
    Electronic Serial Number (ESN): c1836f2d
    Preferred Roaming List (PRL) Version: 0
    International Mobile Subscriber Identity (IMSI): 460036101433925
    Current Roaming Status: Home
    Network Connection Mode: Manual
    Current Network Connection: 1xRTT/EVDO HYBRID
    Downstream Bandwidth: 3100000 bps
  Radio Information:
    Current RSSI(1xRTT): -93 dBm
    Current RSSI(EVDO): -75 dBm
    Current Voltage: 3336 mV
    PIN Status: Ready
    UIM Status: OK
表1-3 display cellular命令显示信息描述表(CDMA网络)
硬件信息
Model
3G Modem名称
Manufacturer
设备生产商
3G Modem的软件版本号
Hardware Version
3G Modem的硬件版本号
3G Modem的产品序列号
首选漫游列表版本
UIM卡的IMSI号码串
Modem Status
3G Modem的状态:
Network Information
网络信息
3G Modem的服务状态:
漫游状态:
·     Roaming:漫游状态
·     Home:本地状态
网络选择模式:
·     Manual:手动选择
·     Automatic:自动选择
当前网络连接:
·     No Service:无服务
·     1xRTT/EVDO HYBRID:1xRTT和EVDO网络
·     EVDO:EVDO网络
·     1xRTT:1xRTT网络
·     Unknown:未知网络
下行理论带宽,单位为bps
Radio Information
无线电通信信息
Current RSSI (1xRTT)
当前1xRTT网络信号质量:
·     信号质量的取值范围为-125dBm ~ -75dBm
·     Unknown:无信号
Current RSSI (EVDO)
当前EVDO网络信号质量:
·     信号质量的取值范围为-120dBm ~ -60dBm
·     Unknown:无信号
Current Voltage
UIM卡电压值,单位为mV
Modem安全信息
PIN Verification
PIN认证状态:
·     Disabled:未使能PIN认证
·     Enabled:使能了PIN认证
PIN Status
·     Ready:UIM卡状态正常
·     PIN Requirement:UIM卡有PIN认证请求,需要用户配置pin verify命令
·     PUK Requirement:UIM卡有PUK认证请求,需要用户配置pin unlock命令
PIN或PUK剩余尝试次数
UIM Status
UIM卡状态:
·     OK:SIM卡状态正常
# 显示4G Modem的呼叫连接信息(LTE网络)。
<Sysname> display cellular 0/0
Cellular0/0:
    Model: MC7750
    Manufacturer: Sierra Wireless, Incorporated
    Modem Firmware Version: SWI9600M_03.05.10.06
    Hardware Version: 10
    International Mobile Equipment Identity (IMEI): 990000560327506
    Profile index: 1
      PDP Type: IPv4
      Access Point Name (APN): vzwinternet
    Current Data Bearer Technology: Unknown
    Cell ID: 25381
  Radio Information:
    Technology Preference: LTE only
    Technology Selected: LTE
  LTE related info:
    Current RSSI: -79 dBm
    Current RSRQ: -9 dB
    Current RSRP: -106 dBm
    Current SNR: 5 dB
    Tx Power: -3276 dBm
    PIN Status: Ready
SIM Status: OK
  ICCID: 89860113811003195000
表1-4 display cellular命令显示信息描述表(LTE网络)
硬件信息
Model
Modem名称
Manufacturer
设备生产商
Modem的软件版本号
Hardware Version
Modem的硬件版本号
Modem的IMEI串号
Modem Status
Modem的状态:
·     Online:Modem处于上电状态
·     Offline:Modem处于下电状态或省电模式,Cellular接口功能不可用
Profile Information
Modem的参数模板信息
Profile index
Modem的参数模板索引
PDP Type
PDP类型,只有Profile 1 = Active时,才显示该信息:
·     IPv4:PDP协议类型为IPv4
·     IPv6:PDP协议类型为IPv6
·     PPP:PDP协议类型为PPP透传
Header Compression
PDP头压缩模式:
·     On:使能PDP头压缩
·     Off:禁止PDP头压缩
Data Compression
PDP数据压缩模式:
·     On:使能PDP数据压缩
·     Off:禁止PDP数据压缩
Access Point Name
接入点名称
Network Information
网络信息
Modem的服务状态:
·     Limited:服务受限,Cellular接口功能不可用
漫游状态:
·     Roaming:漫游状态
·     Home:本地状态
当前载波制式,包括:
·     CDMA2000 1X
·     CDMA2000 HRPD (1xEV-DO)
·     GSM
·     UMTS
·     CDMA2000 HRPD (1xEV-DO RevA)
·     EDGE
·     HSDPA and WCDMA
·     WCDMA and HSUPA
·     HSDPA and HSUPA
·     LTE
·     CDMA2000 EHRPD
·     HSDPA+ and WCDMA
·     HSDPA+ and HSUPA
·     DC_HSDPA+ and WCDMA
·     DC_HSDPA+ and HSUPA
·     HSDPA+ and 64QAM
·     HSDPA+, 64QAM and HSUPA
·     TDSCDMA
·     TDSCDMA and HSDPA
·     Unknown
网络选择模式:
·     Manual:手动选择
·     Automatic:自动选择
Mobile Country Code
Mobile Network Code
Location Area Code
Cell ID
Radio Information
无线电通信信息
网络优先连接选择:
·     AUTO:自动选择连接网络
·     GSM only:仅连接GSM网络
·     EVDO:仅连接CDMA-EVDO网络
·     1x RTT:仅连接CDMA-1x RTT网络
·     1xRTT/EVDO HYBRID:同时连接CDMA-EVDO和CDMA-1x RTT网络
·     LTE only:仅连接LTE网络
Technology Selected
当前选择的网络:
·     GSM:连接GSM网络
·     WCDMA:连接WCDMA网络
·     TD-SCDMA:连接TD-SCDMA网络
·     EVDO:连接CDMA-EVDO网络
·     1x RTT:连接CDMA-1x RTT网络
·     LTE:连接LTE网络
LTE related info
LTE网络相关信息
Current RSSI
当前信号质量:
·     信号质量的取值范围为-110dBm~-51dBm
Current RSRQ
当前参考信号接收质量
Current RSRP
当前参考信号接收功率
Current SNR
当前信噪比
Tx Power
发送功率
Modem安全信息
PIN Verification
PIN认证状态:
·     Disabled:未使能PIN认证
·     Enabled:使能了PIN认证
·     Unknown:当前PIN码状态未知
PIN Status
·     Ready:SIM卡状态正常
·     PUK Requirement:SIM卡有PUK认真请求,需要用户配置pin unlock命令
SIM Status
SIM卡状态:
·     OK:SIM卡状态正常
·     Not Inserted:未插入SIM卡,Cellular接口功能不可用
·     Not Initialized:当前SIM卡状态未知
ICCID
SIM卡ID号,仅当SIM卡状态为正常时显示
·     mode cdma
·     mode td-scdma
·     mode wcdma
·     pin modify
·     pin unlock
·     pin verification enable
·     pin verify
·     plmn select
·     profile create
1.1.4  display controller cellular
display controller cellular命令用来显示Cellular接口的相关信息。
display controller [ cellular [ interface-number ] ]
interface-number:Cellular接口的编号。
如果不指定cellular参数,将显示设备支持的所有接口的相关信息;
如果指定cellular参数,不指定interface-number参数,将显示所有已创建的Cellular接口的相关信息。
USB 3G/4G Modem模块热插拔后,相关统计信息会被清零。
# 显示接口Cellular2/4/0的相关信息。
<Sysname> display controller cellular 2/4/0
Cellular2/4/0
Current state: UP
Description: Cellular2/4/0 Interface
Modem status: Present
DM port status: Disabled
Capability:
  1 Control channel, 1 PPP channel
Control channel 0 traffic statistics:
  TX: 0 packets, 0 errors
  RX: 0 packets, 0 errors
PPP channel 0 traffic statistics:
表1-5 display controller cellular命令显示信息描述表
Cellular2/4/0
Current state
接口当前的物理状态和管理状态,可能的取值及含义如下:
·     DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障)
·     UP:该接口的管理状态和物理状态均为开启
Cellular接口的描述信息
Modem status
USB 3G/4G Modem模块的在位状态:
·     Present:表示在位
·     Absent:表示不在位
DM port status
DM功能的状态:
·     Enabled:表示DM功能处于打开状态
·     Disabled:表示DM功能处于关闭状态
Capability:
Cellular接口支持的通道类型及数量:
·     1 Control channel:支持1个控制通道
·     1 PPP channel:支持1个异步串口子通道
·     1 ETH channel:支持1个以太网子通道
Control channel的报文收发统计信息:
·     发送完成的报文数量,发送错误的报文数量
·     接收的报文数量,接收错误的报文数量
PPP channel的报文收发统计信息:
·     接收的报文数量,接收错误的报文数量
ETH channel 0 traffic statistics
ETH channel的报文收发统计信息:
·     接收的报文数量,接收错误的报文数量
·     reset counters controller cellular
1.1.5  dm-port open
dm-port open命令用来开启3G/4G Modem的DM功能。
undo dm-port open命令用来关闭3G/4G Modem的DM功能。
dm-port open
undo dm-port open
本命令的缺省情况与3G/4G Modem设备的型号有关,请以设备的实际情况为准。
Cellular接口视图
本命令用于在3G/4G Modem上打开或关闭DM功能。
DM(Diagnostic and Monitoring,诊断和监控),指某些类型的3G/4G Modem支持通过3G/4G Modem上的调试信息输出接口输出调试信息功能,用于连接第三方的调试工具(如高通QXDM软件)进行诊断和监控。
不同型号的3G/4G Modem对于DM功能的支持情况不同,具体使用请参考相应的3G/4G Modem用户手册。
# 打开3G/4G Modem的DM功能。
[Sysname-Cellular2/4/0] dm-port open
1.1.6  mode
mode命令用来选择网络连接方式。
mode { 1xrtt | auto | evdo | gsm | gsm-precedence | hybrid | lte | td | td-precedence | wcdma | wcdma-precedence }
Cellular接口视图
1xrtt:设置3G/4G Modem只选择CDMA-1x RTT网络。
auto:设置3G/4G Modem自动选择网络。
evdo:设置3G/4G Modem只选择CDMA-EVDO网络。
gsm:设置3G/4G Modem只选择GSM网络。
gsm-preference:设置3G/4G Modem优先选择GSM网络。
hybrid:设置3G/4G Modem同时选择CDMA-EVDO和CDMA-1x RTT网络。
lte:设置3G/4G Modem只选择LTE网络。
td:设置3G/4G Modem只选择TD-SCDMA网络。
td-preference:设置3G/4G Modem优先选择TD-SCDMA网络。
wcdma:设置3G/4G Modem只选择WCDMA网络。
wcdma-preference:设置3G/4G Modem优先选择WCDMA网络。
本命令用于在3G/4G Modem上选择网络连接方式。
本命令中各参数的支持情况与3G/4G Modem设备的型号有关,请以设备的实际情况为准。
# 设置4G Modem只选择LTE网络。
[Sysname-Cellular2/4/0] mode lte
1.1.7  modem reboot
modem reboot命令用来手动重启3G/4G Modem。
modem reboot
Cellular接口视图
3G/4G Modem在运行过程中能够自动检测异常,并实施自动重启。如果无法自动重启,用户可以通过本命令手动重启3G/4G Modem。
# 手动重启3G/4G Modem。
[Sysname-Cellular2/4/0] modem reboot
1.1.8  modem response
modem response命令用来配置系统向3G/4G Modem下发配置指令后,等待其回复的时间间隔,以及3G/4G Modem连续不响应系统配置指令(配置指令失败或配置指令响应超时)次数的阈值,达到系统配置的阈值后,自动重启3G/4G Modem。
undo modem response命令用来恢复缺省情况。
modem response timer time auto-recovery threshold
undo modem response
系统等待3G/4G Modem回复的时间间隔为10秒,3G/4G Modem连续不响应系统配置指令次数的阈值为3次。
Cellular接口视图
timer time:系统向3G/4G Modem下发配置指令后,等待其回复的时间间隔。若在该时间内系统没收到3G/4G Modem的回复,则认为3G/4G Modem不响应系统配置指令。time的取值范围为1~300,单位为秒。
auto-recovery threshold:3G/4G Modem连续不响应系统配置指令次数的阈值,达到阈值后系统自动重启3G/4G Modem。取值范围为0~10。当threshold配置为0时,关闭自动重启功能。
3G/4G无线网络的不稳定运行或应用环境变化可能导致3G/4G Modem功能故障,无法自动拨号并连接网络。设备提供自动重启3G/4G Modem功能,尽可能减少需要用户手工重启3G/4G Modem的情况。
开启自动重启3G/4G Modem功能后,如果连续多次下发配置指令失败或配置指令响应超时,系统将自动重启3G/4G Modem。为避免因配置错误引起的多次拨号失败,而导致的反复自动重启3G/4G Modem的情况,系统仅在上次自动重启3G/4G Modem后有过至少一次拨号成功记录,并且多次发配置指令失败或配置指令响应超时的情况下才会自动重启3G/4G Modem。
# 配置系统向3G/4G Modem下发配置指令时,等待其回复的时间间隔为20秒,配置3G/4G Modem模块连续4次不响应系统配置指令,则自动重启。
[Sysname-Cellular2/4/0] modem response timer 20 auto-recovery 4
1.1.9  pin modify
pin modify命令用来修改SIM/UIM卡的PIN码,修改后的PIN码保存在SIM/UIM卡上。
pin modify current-pin new-pin
Cellular接口视图
current-pin:插在3G/4G Modem上的SIM/UIM卡的PIN码,由4~8位数字组成。
new-pin:用户重新设置的PIN码,由4~8位数字组成。
本命令用于在3G/4G Modem上修改SIM/UIM卡的PIN码。
如果开启了3G/4G Modem的PIN码认证功能,修改PIN码后,需要配置pin verify命令以保持和修改后的PIN码一致。
如果连续多次修改PIN码失败,会导致SIM/UIM卡被锁。
如果SIM/UIM卡被锁,必须先通过pin unlock命令来解锁。
部分3G/4G Modem必须在启用PIN码认证,并且PIN码认证通过后才可以修改PIN码。
# 修改SIM/UIM卡的PIN码。
[Sysname-Cellular2/4/0] pin modify 1234 4321
PIN will be changed to “4321”. Continue? [Y/N]:y
PIN has been changed successfully.
·     pin unlock
·     pin verify
1.1.10  pin unlock
pin unlock命令用来对3G/4G Modem上的SIM/UIM卡进行PIN码解锁。
pin unlock puk new-pin
Cellular接口视图
puk:插在3G/4G Modem上的SIM/UIM卡的PUK码,由网络提供商提供,由4~8位数字组成。
new-pin:用户重新设置的PIN码,由4~8位数字组成。重新设置的PIN码保存在SIM/UIM卡上。
下列情况可能导致SIM/UIM卡PIN码被锁住:
·     连续多次修改PIN码失败。
·     连续多次开启或关闭3G/4G Modem的PIN码认证功能失败。
·     连续多次PIN码认证失败。
如果PIN码被锁住,需要用户使用PUK码将PIN码解锁,否则3G/4G Modem的数据通信功能不可用。
如果开启了3G/4G Modem的PIN码认证功能,解锁PIN码后,需要配置pin verify命令以保持和重新设置的PIN码一致。
如果连续多次解锁失败,可能会导致SIM/UIM卡被永久锁定,无法使用。
如果SIM/UIM卡被永久锁定,请联系SIM/UIM卡的运营商为SIM/UIM卡解锁。
# 使用PUK码解锁PIN码。
[Sysname-Cellular2/4/0] pin unlock 87654321 1234
PIN will be unlocked and changed to “1234”. Continue? [Y/N]:y
PIN has been unlocked and changed successfully.
·     pin modify
1.1.11  pin verification enable
pin verification enable命令用来开启3G/4G Modem的PIN码认证功能。
undo pin verification enable命令用来关闭3G/4G Modem的PIN码认证功能。
pin verification enable [ pin ]
undo pin verification enable [ pin ]
Cellular接口视图
本命令用于在3G/4G Modem上开启或关闭PIN码认证功能。
·     如果开启了3G/4G Modem的PIN码认证功能,当3G/4G Modem插入或3G/4G Modem重启时,会使用pin verify命令配置的PIN码进行认证,否则3G/4G Modem的数据通信功能不可用。重启3G/4G Modem的途径包括:重启设备、使用modem reboot命令重启3G/4G Modem、热拔插USB 3G/4G Modem。对于SIC-3G/4G-CDMA模块,只有设备冷启动后,才需要重新进行PIN码认证。
·     如果关闭了3G/4G Modem的PIN码认证功能,不需要进行PIN码认证就可以进行3G/4G Modem数据通信。
如果开启了3G/4G Modem的PIN码认证功能,需要通过pin verify命令将PIN码保存在设备上,在需要认证时,自动完成PIN码认证。
开启或关闭3G/4G Modem的PIN码认证功能时,可能要求输入当前的PIN码。如果连续多次开启或关闭3G/4G Modem的PIN码认证功能失败,可能会导致SIM/UIM卡被锁。如果SIM/UIM卡被锁,可以通过pin unlock命令来解锁。
部分3G/4G Modem在启用PIN码认证功能后,必须PIN码认证通过后才可以关闭PIN码认证功能。
# 开启PIN码认证功能。
[Sysname-Cellular2/4/0] pin verification enable 1234
·     pin unlock
·     pin verify
1.1.12  pin verify
pin verify命令用来配置3G/4G Modem进行认证的PIN码,即插在3G/4G Modem上的SIM/UIM卡的PIN码。
undo pin verify命令用来恢复缺省情况。
pin verify { cipher | simple } string
undo pin verify
未配置3G/4G Modem进行认证的PIN码。
Cellular接口视图
cipher:以密文方式设置PIN码。
simple:以明文方式设置PIN码,该PIN码将以密文形式存储。
string:插在3G/4G Modem上的SIM/UIM卡的PIN码。明文PIN码为4~8位的数字,密文PIN码为37~41个字符的字符串。
开启了3G/4G Modem的PIN码认证功能后,当3G/4G Modem插入或重启时,需要通过pin verify命令输入PIN码进行认证,如果输入的PIN码正确,则PIN码认证通过,否则,PIN码认证失败。如果连续多次PIN码认证失败,可能会导致SIM/UIM卡被锁。如果SIM/UIM卡被锁,可以通过pin unlock命令来解锁。
用户可以在需要PIN码认证时配置pin verify命令,也可以提前配置pin verify命令,只要配置一次pin verify命令,PIN码就会保存在设备上,在需要认证时,自动完成PIN码认证。
#  配置3G/4G Modem进行认证的PIN码为明文的1234。
[Sysname-Cellular2/4/0] pin verify simple 1234
·     pin unlock
1.1.13  plmn search
plmn search命令用来搜索移动网络。
plmn search
Cellular接口视图
本命令用于触发3G/4G Modem搜索移动网络。
搜索移动网络需要等待几分钟,完成搜索后,命令行会给出提示,显示搜索到的移动网络。
3G/4G Modem使用时,需要在PLMN(Public Land Mobile Network,公共地带移动网络)进行选择接入的移动网络。如果用户需要手工指定接入的移动网络,则需要先搜索移动网络,获取当前区域内有信号的移动网络列表。
# 搜索移动网络。
[Sysname-Cellular2/4/0] plmn search
PLMN search done.
Available PLMNs:
PLMN No.     MCC    MNC    Status     Type
01           460    00     Current    GSM
02           460    00     Available  UTRAN
03           460    01     Forbidden  GSM
表1-6 plmn search命令显示信息描述表
PLMN No
序号
MCC
移动国家编码
MNC
移动网络编码,表示运营商,比如:
·     00、02、07:表示移动
·     01:表示联通
·     03:表示电信
Status
移动网络的状态,其取值及含义如下:
·     Current:表示当前正在使用的网络
·     Available:表示网络可达
·     Forbidden:表示网络被禁止使用
搜索到的移动网络类型
·     display cellular
·     plmn select
1.1.14  plmn select
plmn select命令用来配置选择移动网络的方式。
plmn select { auto | manual mcc mnc }
Cellular接口视图
auto:表示自动选择PLMN(Public Land Mobile Network,公共地带移动网络)。
manual:表示人工指定PLMN。
mcc:MCC(Mobile Country Code,移动国家编码),取值范围为0~65535。
mnc:MNC(Mobile Network Code,移动网络编码),取值范围为0~65535。
本命令用于在3G/4G Modem上配置选择移动网络的方式。
当配置选择移动网络的方式为人工指定时,需要先通过plmn search命令搜索移动网络。
# 配置选择移动网络的方式为人工指定。
[Sysname-Cellular2/4/0] plmn select manual 65524 65524
·     display cellular
·     plmn search
1.1.15  reset counters controller cellular
reset counters controller cellular命令用来清除Cellular接口的统计信息。
reset counters controller cellular [ interface-number ]
cellular [ interface-number ]:Cellular接口的编号。如果不指定interface-number,则清除所有Cellular接口的统计信息;如果指定interface-number,则清除指定Cellular接口的统计信息。
# 清除接口Cellular2/4/0的统计信息。
<Sysname> reset counters controller cellular 2/4/0
·     display controller cellular
1.1.16  rssi
rssi命令用来配置3G/4G网络RSSI监控阈值。
undo rssi命令用来恢复缺省情况。
rssi { 1xrtt | evdo | gsm | lte } { low lowthreshold | medium mediumthreshold } *
undo rssi { 1xrtt | evdo | gsm | lte } [ low | medium ]
3G/4G网络RSSI监控下限阈值为-150dBm、上限阈值为0dBm。
Cellular接口视图
1xrtt:1xRTT网络制式。
evdo:EVDO网络制式。
gsm:GSM网络制式。
lte:LTE网络制式。
low lowthreshold配置RSSI监控的下限阀值,lowthreshold表示下限阈值的相反数,取值范围为0~150,代表阈值范围为-150dBm~0dBm。
medium mediumthreshold:配置RSSI监控的上限阀值,mediumthreshold表示上限阈值的相反数,取值范围为0~150,代表阈值范围为-150dBm~0dBm。
3G/4G网络通过RSSI表示当前信号的强度,用户可以通过display cellular命令查看当前网络的RSSI值来了解信号强弱的变化。
配置RSSI的监控的下限阀值必须小于等于上限阀值,但是由于lowthreshold参数和mediumthreshold参数表示的是RSSI值的相反数,所以lowthreshold参数的值必须大于等于mediumthreshold参数的值。当RSSI值大于配置的上限阀值时,发送一次显示信号强的trap信息;当RSSI值在配置的阈值范围内时,发送一次显示信号正常的trap信息;当RSSI值小于等于配置的下限阀值时,发送一次显示信号弱的trap信息,如果RSSI值一直小于等于配置的下限阀值时,每10分钟发送一次显示信号弱的trap信息。
# 配置GSM网络制式RSSI监控的下限阀值为-110dBm。
[Sysname] controller cellular 0/0
[Sysname-Cellular0/0] rssi gsm low 110
1.1.17  sendat
sendat命令用来手工向3G/4G Modem发送配置指令。
sendat at-string
Cellular接口视图
at-string:配置指令字符串,为1~300个字符的字符串。该字符串的内容格式不同产品有所区别,可能是AT指令(“+++”和“A/”以及任意以AT开头的字符串,AT指令的详细解释请参见“二层技术-广域网接入命令参考/Modem管理”中的命令sendat),也可能是CNS格式的报文(样例请参见表1-7)。
表1-7 CNS格式报文举例
指令
CNSn
控制CNS心跳检测开关
·     n = 00000500000000000000,打开CNS心跳检测开关
·     n = 00000800000000000000,关闭CNS心跳检测开关
sendat命令不检查配置指令的合法性,直接将用户输入的字符串送至3G/4G Modem(遇到小写字母自动转化为大写字母)。
sendat命令一次只能配置一条配置指令。
通过配置指令配置3G/4G Modem后,3G/4G Modem的工作状态会被改变,有可能导致3G/4G Modem的状态混乱从而影响到拨号等基本功能。请在专业人员的指导下慎重使用此功能。
# 向3G/4G Modem发送拨号指令,呼叫号码169。
[Sysname-Cellular2/4/0] sendat ATD169
# 向3G/4G Modem发送打开CNS心跳检测开关的指令。
[Sysname-Cellular2/4/0] sendat cns00000500000000000000
1.1.18  shutdown
shutdown命令用来关闭Cellular接口。
undo shutdown命令用来打开Cellular接口。
shutdown
Cellular接口处于打开状态。
Cellular接口视图
# 关闭接口Cellular2/4/0。
[Sysname] interface cellular 2/4/0
[Sysname-Cellular2/4/0] shutdown
1.1.19  trust-imsi
trust-imsi命令用来配置本地信任的IMSI。
undo trust-imsi命令用来删除本地信任的IMSI。
trust-imsi string-imsi
undo trust-imsi [ string-imsi ]
未配置本地信任的IMSI。
Cellular接口视图
string-imsi:表示本地信任的IMSI,为1~31个字符的字符串,不区分大小写。
配置了本地信任的IMSI后,只有安装的SIM卡的IMSI与配置的本地信任的IMSI一致时,才可以进行拨号。重复执行本命令,最多可以配置16个本地信任的IMSI。
# 在Cellular0/0接口配置本地信任的IMSI为hccc123456789。
[Sysname-Cellular0/0] trust-imsi hccc123456789
1.2  3G Modem管理专用配置命令
1.2.1  gsm band
说明: 说明
此命令目前只有Sierra的4G模块MC7354的ATT版本和MC7304支持。
gsm band命令用来配置3G/4G Modem接入GSM网络的工作频段。
undo gsm band命令用来恢复缺省情况。
gsm band { egsm900 | gsm450 | gsm480 | gsm750 | gsm850 | gsm1800 | gsm1900 | pgsm900 | rsgm900 }
undo gsm band
未配置3G/4G Modem接入GSM网络的工作频段。
Cellular接口视图
egsm900:使用E-GSM 900MHz频段。
gsm450:使用GSM 450MHz频段。
gsm480使用GSM 480MHz频段。
gsm750:使用GSM 750MHz频段。
gsm850:使用GSM 850MHz频段。
gsm1800:使用GSM 1800MHz频段。
gsm1900:使用GSM 1900MHz频段。
pgsm900:使用P-GSM 900MHz频段。
rgsm900:使用GSM-R 900MHz频段。
GSM网络可以提供多种频段供用户接入。3G/4G Modem通过Cellular接口接入GSM网络后,当GSM网络频段发生变化时,3G/4G Modem会自动调整工作频段来适应网络环境的变化,从而影响3G链路的稳定性。为了避免因网络频段变化引起的3G链路不稳定,用户可以手动配置3G/4G Modem接入的GSM网络的工作频段。
# 配置3G/4G Modem接入GSM网络的工作频段为gsm1800。
[Sysname-Cellular0/0] gsm band gsm1800
·     lte band
·     wcdma band
1.2.2  profile create
profile create命令用来创建3G Modem的参数模板。
profile create profile-number { dynamic | static apn } authentication-mode { none | { chap | pap } user username [ password password ] }
本命令的缺省情况与3G Modem设备的型号有关,请以设备的实际情况为准。
Cellular接口视图
profile-number:3G Modem的参数模板编号。不同型号的3G Modem设备支持的取值范围不同,请以设备的实际情况为准。
dynamic:由运营商根据接入用户动态分配接入点。
static apn:指定的由运营商提供的接入点名称,为1~100个字符的字符串,是否大小写敏感和运营商有关。
authentication-mode:认证方式。
none:不认证。
chap:认证方式为CHAP。
pap:认证方式为PAP。
user username:认证用户名,由运营商提供。为1~32个字符的字符串,区分大小写。
password password:认证密码,由运营商提供。为1~32个字符的字符串,区分大小写。
本命令用于在3G Modem上创建参数模板。
参数模板可以配置接入点和认证方式,3G Modem会根据配置的接入点和认证方式,来和对应的服务商进行认证:
·     当选用None方式时,不需要输入用户名和密码。
·     当选用CHAP或PAP方式时,需要根据运营商的要求,选择配置用户名和密码,其中username字段是必选的,而password字段是可选的。
# 创建3G Modem的参数模板1,指定的接入点名称为cmnet,认证方式采用PAP。
[Sysname-Cellular2/4/0] profile create 1 static cmnet authentication-mode pap user abc password abc
·     display cellular
·     profile delete
1.2.3  profile delete
profile delete命令用来删除3G Modem的参数模板。
profile delete profile-number
Cellular接口视图
# 删除3G Modem的参数模板1。
[Sysname-Cellular2/4/0] profile delete 1
·     display cellular
·     profile create
1.2.4  profile main
profile main命令用来配置3G Modem拨号使用的主备参数模板。
undo profile main命令用来恢复缺省情况。
profile main main-profile-number backup backup-profile-number
undo profile main
3G Modem使用参数模板1进行拨号。
Cellular接口视图
main-profile-numbe:主参数模板索引。不同型号的3G Modem设备支持的取值范围不同,请以设备的实际情况为准。
backup backup-profile-number:备份参数模板索引。不同型号的3G Modem设备支持的取值范围不同,请以设备的实际情况为准。
配置profile main命令后,3G Modem每次拨号都优先选择主参数模板,如果主参数模板拨号失败,将使用备份参数模板进行拨号。无论备份参数模板拨号是否成功,下次拨号时都使用主参数模板拨号。
使用的主备参数模板的用户名和密码必须配成一样的。
本命令的配置会在下次拨号时生效,不会影响当前的拨号结果。
# 配置3G Modem拨号使用主参数模板1,备份参数模板2。
[Sysname-Cellular2/4/0] profile main 1 backup 2
1.2.5  serial-set
serial-set命令用来将Cellular接口通道化出同/异步串口。
undo serial-set命令用来将Cellular接口通道化出的同/异步串口删除。
serial-set set-number
undo serial-set set-number
Cellular接口视图
set-number:通道化出的串口的编号。
Cellular接口在配置该命令后通道化出一个Serial接口,接口名是serial cellular-number:set-number
# 将接口Cellular2/4/0通道化出一个Serial接口。
[Sysname-Cellular2/4/0] serial-set 0
1.2.6  wcdma band
说明: 说明
wcdma band命令用来配置3G/4G Modem接入WCDMA网络的工作频段。
undo wcdma band命令用来恢复缺省情况。
wcdma band { wcdma800 | wcdma850 | wcdma900 | wcdma1700ip | wcdma1700us | wcdma1800 | wcdma1900 | wcdma2100 | wcdma2600 }
undo wcdma band
未配置3G/4G Modem接入WCDMA网络的工作频段。
Cellular接口视图
wcdma800使用WCDMA 800MHz频段。
wcdma850:使用WCDMA 850MHz频段。
wcdma900:使用WCDMA 900MHz频段。
wcdma1700jp:使用日本WCDMA 1700MHz频段。
wcdma1700us:使用美国WCDMA 1700MHz频段。
wcdma1800:使用WCDMA 1800MHz频段。
wcdma1900:使用WCDMA 1900MHz频段。
wcdma2100:使用WCDMA 2100MHz频段。
wcdma2600:使用WCDMA 2600MHz频段。
WCMDA网络可以提供多种频段供用户接入。3G/4G Modem通过Cellular接口接入WCDMA网络后,当WCDMA网络频段发生变化时,3G/4G Modem会自动调整工作频段来适应网络环境的变化,从而影响3G链路的稳定性。了避免因网络频段变化引起的3G链路不稳定,用户可以手动配置3G/4G Modem接入的WCDMA网络的工作频段。
# 配置3G/4G Modem接入WCDMA网络的工作频段为wcdma1700。
[Sysname-Cellular0/0] wcdma band wcdma1700
·     gsm band
·     lte band
1.3  4G Modem管理专用配置命令
1.3.1  apn
apn命令用来配置接入4G网络时的接入点。
undo apn命令用来删除接入4G网络时的接入点。
apn { dynamic | static apn }
undo apn
未配置接入4G网络时的接入点。
4G Modem参数模板视图
dynamic:动态接入点,接入点名称在拨号协商时由运营商分配。
# 为4G Modem参数模板test配置静态接入点apn1。
[Sysname] apn-profile test
[Sysname-apn-profile-test] apn static apn1
·     apn-profile
1.3.2  apn-profile
apn-profile命令用来创建4G Modem参数模版。
undo apn-profile命令用来删除4G Modem参数模版。
apn-profile profile-name
undo apn-profile profile-name
未配置4G Modem参数模版。
profile-name:参数模版的名称。
当4G Modem参数模版关联了4G接口时,参数模版的配置才会起作用。当需要删除4G参数模版时,必须先删除所有与4G接口的关联。
# 创建4G Modem参数模版test。
·     apn-profile apply
1.3.3  apn-profile apply
apn-profile apply命令用来指定接口使用的4G Modem参数模板。
undo apn-profile apply命令用来恢复缺省情况。
apn-profile apply profile-name [ backup profile-name ]
未指定接口使用的4G Modem参数模板。
以太网通道接口视图
profile-name:参数模板的名称。
backup profile-name:指定备份的4G Modem参数模板。
配置apn-profile apply命令后, 4G Modem将使用4G Modem参数模板中配置的拨号参数与运营商核心网设备进行协商。
当配置了备份4G Modem参数模版时, 4G Modem使用主参数模板拨号失败,将使用备份参数模板进行拨号。无论备份参数模板拨号是否成功,下次拨号时仍使用主参数模板进行拨号。
本命令的配置会在下一次拨号时生效,不影响当前的拨号结果。
# 配置主4G Modem参数模板为test,备份4G Modem参数模板为bktest。
[Sysname] interface eth-channel 2/4/0:0
[Sysname-Eth-channel2/4/0:0] apn-profile apply test backup bktest
·     apn-profile
1.3.4  attach-format imsi-sn split
attach-format imsi-sn split命令用来配置IMSI/SN捆绑协商认证时发送用户名使用的分隔符。
undo attach-format imsi-sn split命令用来恢复缺省情况。
attach-format imsi-sn split splitchart
未配置协商认证时发送用户名使用的分隔符。
4G Modem参数模板视图
split splitchart:配置IMSI/SN捆绑协商认证时用户名发送使用的分隔符。splitchart表示分隔符,长度为1个字符,可以为字母、数值或%、#等符号。
如果设置splitchart参数为#,则发送用户名的格式为imsiinfo#sninfo#username。
# 配置协商认证时发送用户名使用的分隔符为为#。
[Sysname-apn-profile-test] attach-format imsi-sn split #
·     apn-profile
1.3.5  authentication-mode
authentication-mode命令用来配置接入4G网络时的认证方式。
undo authentication-mode命令用来删除接入4G网络时的认证方式。
authentication-mode { pap | chap | pap-chap } user user-name password { cipher | simple } string
认证方式为不认证。
4G Modem参数模板视图
chap:认证方式为CHAP。
pap:认证方式为PAP。
pap-chap认证方式为PAP或CHAP。
user-name:认证用户名,为1~80个字符的字符串,区分大小写。
cipher:以密文方式设置密码。
simple:以明文方式设置密码,该密码将以密文形式存储。
string:密码字符串,区分大小写。明文密码为1~32个字符的字符串,密文密码为1~73个字符的字符串。
# 为4G Modem参数模板指定认证方式为CHAP,认证用户名为user1,密码为123456。
[Sysname-apn-profile-test] authentication-mode chap user user1 password simple 123456
·     apn-profile
1.3.6  bandwidth
bandwidth命令用来配置接口的期望带宽。
undo bandwidth命令用来恢复缺省情况。
bandwidth bandwidth-value
undo bandwidth
接口的期望带宽=接口的波特率÷1000(kbit/s)。
以太网通道接口视图
bandwidth-value:表示接口的期望带宽,取值范围为1~400000000,单位为kbit/s。
接口的期望带宽会影响链路开销值,具体介绍请参见“三层技术-IP路由配置指导”中的“OSPF“OSPFv3”和“IS-IS”。
# 设置以太网通道接口Eth-channel2/4/0:0的期望带宽为1000 kbit/s。
[Sysname-Eth-channel2/4/0:0] bandwidth 1000
1.3.7  default
default命令用来恢复当前接口的缺省配置。
default
以太网通道接口视图
# 将以太网通道接口Eth-channel2/4/0:0恢复为缺省配置。
[Sysname-Eth-channel2/4/0:0] default
1.3.8  description
接口的描述信息为“该接口的接口名 Interface”,比如“Echannel2/4/0:0 Interface”。
以太网通道接口视图
可以根据需要修改接口的描述。
修改后的描述信息会在display interface显示的接口信息中体现。
# 设置以太网通道接口Eth-channel2/4/0:0的描述信息为“Echannel-interface”。
[Sysname-Eth-channel2/4/0:0] description Echannel-interface
1.3.9  display interface eth-channel
display interface eth-channel命令用来显示以太网通道接口的相关信息。
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
channel-id:以太网通道接口的编号。
如果不指定eth-channel参数,将显示设备支持的所有接口的相关信息;
如果指定eth-channel参数,不指定channel-id参数,将显示所有已通道化的以太网通道接口的相关信息。
#显示以太网通道接口Eth-channel2/4/0:0的详细信息。
<Sysname> display interface eth-channel 2/4/0:0
Echannel2/4/0:0
Current state: DOWN
Line protocol state: DOWN
Description: Echannel2/4/0:0 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
Last link flapping: Never
Last 300 seconds input rate 0.00 bytes/sec, 0.00 packets/sec
Last 300 seconds output rate 0.00 bytes/sec, 0.00 packets/sec
Input: 0 packets, 0 bytes, 0 buffers
Output:0 packets, 0 bytes
# 显示以太网通道接口Eth-channel2/4/0:0的概要信息。
<Sysname> display interface eth-channel 2/4/0:0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Echannel2/4/0:0      UP   UP(s)    192.168.80.239
# 显示当前物理状态为down的以太网通道接口的信息以及down的原因。
<Sysname> display interface eth-channel brief down
Echannel2/4/0:0      ADM  Administratively
表1-8 display interface eth-channel命令显示信息描述表
Current state
Line protocol state
接口的链路层协议状态,由链路层经过参数协商决定,取值为:
·     UP:表示数据链路层协议状态为开启
·     DOWN:表示数据链路层协议状态为关闭
·     UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性
接口的描述信息
Bandwidth
接口的期望带宽
接口允许通过的最大传输单元
接口IP地址。Type表示地址获取方式,取值如下:
·     Primary:手动配置的主地址
·     Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息
·     DHCP-Allocated:通过DHCP获取的IP地址,详细介绍请参见“三层技术-IP业务命令参考”中的“DHCP”
·     BOOTP-Allocated:通过BOOTP获取的IP地址,详细介绍请参见“三层技术-IP业务命令参考”中的“DHCP”
·     PPP-Negotiated:PPP协商过程中由Server端分配的IP地址,详细介绍请参见“二层技术-广域网接入命令参考”中的“PPP”
·     Unnumbered:借用其他接口的IP地址
·     Cellular-Allocated:通过Modem私有协议获取的IP地址,详细介绍请参见“二层技术-广域网接入命令参考”中的“3G Modem和4G Modem管理”
·     MAD:成员设备上配置的MAD IP地址,详细介绍请参见“虚拟化技术命令参考”中的“IRF”
·     SSLVPN:SSL VPN AC接口的IP地址,详细介绍请参见“安全命令参考”中的“SSL VPN”
·     MTunnel:组播隧道接口的IP地址,详细介绍请参见“IP组播命令参考”中的“组播VPN”
Type的取值情况与接口类型有关,请以实际情况为准
接口当前不能处理IP报文
Internet Address is 192.168.1.200/24 Primary
接口的主IP地址,此IP地址由运营商自动分配
IP Packet Frame Type,Hardware Address
IP报文发送帧格式,硬件地址
IPv6 Packet Frame Type,Hardware Address
IPv6报文发送帧格式,硬件地址
输出队列的紧急队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。
输出队列的协议队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。
输出队列的先进先出队列中当前的消息数/最大可容纳的消息数/已丢弃的消息数。该显示信息与用户的配置有关,当配置为CBQ、WFQ等队列时则显示为CBQ/WFQ等队列的消息数。
Last link flapping
接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过)
最近一次使用reset counters interface命令清除接口下的统计信息的时间。如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
输入报文:报文数,字节数,缓存单元的个数
输出报文:报文数,字节数
三层模式下(route)接口的概要信息,即三层接口的概要信息
·     如果某接口的Link属性值为“ADM”,则表示该接口被管理员手工关闭了,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果某接口的Link属性值为“Stby”,则表示该接口是一个备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
如果某接口的Protocol属性值中带有“(s)”,则表示该接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
接口名称缩写
Iink
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被手工关闭了,需要执行undo shutdown命令才能打开接口
·     Stby:表示该接口是一个备份接口
Protocol
接口数据链路层协议状态,取值可能为:
·     UP:表示接口的数据链路层是连通的
·     DOWN:表示接口的数据链路层不通
·     UP(s):表示接口的数据链路层协议状态显示为UP,但实际可能没有对应的链路,或者对应的链路不是永久存在而是按需建立的
Main IP
接口主IP地址
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息
Cause
接口物理连接状态为down的原因,取值为Administratively时表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
1.3.10  eth-channel
eth-channel命令用来将Cellular接口通道化出以太网通道接口。
undo eth-channel命令用来将Cellular接口通道化出的以太网通道接口删除。
eth-channel channel-number
undo eth-channel channel-number
Cellular接口视图
channel-number:通道化出的以太网通道接口编号。
Cellular接口在配置该命令后通道化出一个以太网通道接口,接口名是eth-channel cellular-number:channel-number
# 将接口Cellular2/4/0通道化出一个以太网通道接口。
[Sysname-Cellular2/4/0] eth-channel 0
1.3.11  interface eth-channel
interface eth-channel命令用来进入以太网通道接口视图。
interface eth-channel interface-number
interface-number:以太网通道接口的编号。
# 进入以太网通道接口Eth-channel2/4/0:0的视图。
1.3.12  ip address cellular-alloc
ip address cellular-alloc命令用来配置接口通过Modem私有协议获取IP地址。
undo ip address cellular-alloc命令用来恢复缺省情况。
接口不通过Modem私有协议获取IP地址。
以太网通道接口视图
ip address cellular-allocip address dhcp-alloc命令用于设置接口以何种方式从Modem获取接口IP地址,Modem的IP地址由运营商自动分配。
其中,ip address cellular-alloc命令是配置接口采用Modem私有协议获取IP地址,而ip address dhcp-alloc命令是配置接口采用标准DHCP协议获取IP地址。
# 为接口Cellular2/4/0创建以太网通道接口,并采用Modem私有协议获取运营商自动分配的IP地址。
[Sysname-Cellular2/4/0] quit
[Sysname-Eth-channel2/4/0:0] ip address cellular-alloc
1.3.13  ipv6 address cellular-alloc
ipv6 address cellular-alloc命令用来配置接口通过Modem私有协议获取IPv6地址。
undo ipv6 address cellular-alloc命令用来恢复缺省情况。
接口不通过Modem私有协议获取IPv6地址。
以太网通道接口视图
ipv6 address cellular-allocipv6 address dhcp-alloc命令用于设置接口以何种方式从Modem获取接口IPv6地址,Modem的IPv6地址由运营商自动分配。
其中,ipv6 address cellular-alloc命令是配置接口采用Modem私有协议获取IPv6地址,而ipv6 address dhcp-alloc命令是配置接口采用标准DHCP协议获取IPv6地址。
# 为接口Cellular2/4/0创建以太网通道接口,并采用Modem私有协议获取运营商自动分配的IPv6地址。
[Sysname-Eth-channel2/4/0:0] ipv6 address cellular-alloc
·     ip address cellular-alloc
1.3.14  lte band
此命令目前只有Sierra的MC7354和MC7304,龙尚的U8300C、U8300W和U8300,以及启基的DM11-2等4G模块支持。
lte band命令用来配置LTE模块工作的频段。
undo lte band命令用来恢复缺省情况。
lte band band-number
undo lte band
本命令的缺省情况与4G Modem设备的型号有关,请以设备的实际情况为准。
Cellular接口视图
band-number:LTE频段号。不同4G模块支持的频段号不同,请以设备的实际情况为准。
# 为接口Cellular2/4/0配置选择3频段。
[Sysname-Controller-Cellular2/4/0] lte band 3
·     gsm band
·     wcdma band
1.3.15  mtu
mtu命令用来配置接口的MTU(Maximum Transmission Unit,最大传输单元)值。
undo mtu命令用来恢复缺省情况。
mtu size
undo mtu
接口的MTU值为1500字节。
以太网通道接口视图
# 配置以太网通道接口Eth-channel2/4/0:0的MTU值为1430字节。
[Sysname-Eth-channel2/4/0:0] mtu 1430
1.3.16  pdp-type
pdp-type命令用来配置PDP协议的数据负载类型。
undo pdp-type命令用来恢复缺省情况。
pdp-type { ipv4 | ipv6 | ipv4v6 }
undo pdp-type
PDP协议的数据负载类型为IPv4和IPv6。
apn-profile视图
ipv4:PDP协议的数据负载类型为IPv4。
ipv6:PDP协议的数据负载类型为IPv6。
ipv4v6:PDP协议的数据负载类型为IPv4和IPv6。
# 配置PDP协议的数据负载类型为IPv4。
[Sysname] apn-profile 1
[Sysname-apn-profile-1] pdp-type ipv4
1.3.17  reset counters interface
reset counters interface命令用来清除以太网通道接口的统计信息。
reset counters interface [ eth-channel [ channel-id ] ]
eth-channel:清除以太网通道接口的统计信息。
·     如果不指定eth-channelchannel-id,则清除所有接口的统计信息;
·     如果指定eth-channel而不指定channel-id,则清除所有以太网通道接口的统计信息;
·     如果同时指定eth-channelchannel-id,则清除指定以太网通道接口的统计信息。
# 清除以太网通道接口Eth-channel2/4/0:0的统计信息。
<Sysname> reset counters interface eth-channel 2/4/0:0
1.3.18  shutdown
shutdown命令用来关闭以太网通道接口。
undo shutdown命令用来打开以太网通道接口。
shutdown
缺省情况下,以太网通道接口为开启状态
以太网通道接口视图
# 关闭以太网通道接口Eth-channel2/4/0:0。
[Sysname-Eth-channel2/4/0:0] shutdown
