14-三层技术-IP路由命令参考
01-IP路由基础命令
本章节下载: 01-IP路由基础命令  (363.71 KB)
01-IP路由基础命令
1 IP路由基础
1.1 IP路由基础配置命令
1.1.1 address-family ipv4
1.1.2 address-family ipv6
1.1.3 display ip routing-table
1.1.4 display ip routing-table acl
1.1.5 display ip routing-table ip-address
1.1.6 display ip routing-table prefix-list
1.1.7 display ip routing-table protocol
1.1.8 display ip routing-table statistics
1.1.9 display ip routing-table summary
1.1.10 display ipv6 rib attribute
1.1.11 display ipv6 rib graceful-restart
1.1.12 display ipv6 rib nib
1.1.13 display ipv6 route-direct nib
1.1.14 display ipv6 routing-table
1.1.15 display ipv6 routing-table acl
1.1.16 display ipv6 routing-table ipv6-address
1.1.17 display ipv6 routing-table prefix-list
1.1.18 display ipv6 routing-table protocol
1.1.19 display ipv6 routing-table statistics
1.1.20 display ipv6 routing-table summary
1.1.21 display rib attribute
1.1.22 display rib graceful-restart
1.1.23 display rib nib
1.1.24 display route-direct nib
1.1.25 fib lifetime
1.1.26 inter-protocol fast-reroute
1.1.27 non-stop-routing
1.1.28 protocol lifetime
1.1.29 reset ip routing-table statistics protocol
1.1.30 reset ipv6 routing-table statistics protocol
1.1.31 rib
1 IP路由基础
1.1  IP路由基础配置命令
address-family ipv4命令用来创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
undo address-family ipv4命令用来删除RIB IPv4地址族和RIB IPv4地址族视图下的所有配置。
address-family ipv4
不存在RIB IPv4地址族。
RIB视图
context-admin
# 创建RIB IPv4地址族,并进入RIB IPv4地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv4
[Sysname-rib-ipv4]
address-family ipv6命令用来创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
undo address-family命令用来删除RIB IPv6地址族和RIB IPv6地址族视图下的所有配置。
address-family ipv6
undo address-family ipv6
不存在RIB IPv6地址族。
RIB视图
context-admin
# 创建RIB IPv6地址族,并进入RIB IPv6地址族视图。
[Sysname] rib
[Sysname-rib] address-family ipv6
[Sysname-rib-ipv6]
display ip routing-table命令用来显示路由表的信息。
display ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ]
context-admin
context-operator
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
如果不指定任何参数时,则显示公网的信息。
# 显示路由表中当前激活路由的概要信息。
<Sysname> display ip routing-table
Destinations : 10        Routes : 10
0.0.0.0/32          Direct 0    0            127.0.0.1       InLoop0
1.1.1.0/24          Static 60   0            192.168.47.4    GE1/0/1
192.168.1.40/32     Direct 0    0            127.0.0.1       InLoop0
224.0.0.0/4         Direct 0    0            0.0.0.0         NULL0
224.0.0.0/24        Direct 0    0            0.0.0.0         NULL0
255.255.255.255/32  Direct 0    0            127.0.0.1       InLoop0
表1-1 display ip routing-table命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination/Mask
目的地址/掩码长度
Proto
发现该路由的路由协议类型
Pre
路由的优先级
Cost
路由的度量值
NextHop
此路由的下一跳地址
出接口,即到该目的网段的数据包将从此接口发出
Summary count
路由数目
# 显示路由表的全部详细信息。
<Sysname> display ip routing-table verbose
Destinations : 2        Routes : 2
Destination: 0.0.0.0/32
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h34m37s
       Cost: 0               Preference: 0
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active NoAdv
  OrigTblID: 0x0                OrigVrf: default-vrf
    TableID: 0x2                 OrigAs: 0
      NibID: 0x10000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: 0.0.0.0
      Flags: 0x1000c        OrigNextHop: 127.0.0.1
      Label: NULL           RealNextHop: 127.0.0.1
    BkLabel: NULL             BkNextHop: N/A
    SRLabel: NULL             BkSRLabel: NULL
  Tunnel ID: Invalid          Interface: InLoopBack0
BkTunnel ID: Invalid        BkInterface: N/A
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A              VpnPeerId: N/A
       Dscp: N/A                    Exp: N/A
Destination: 1.1.1.0/24
   Protocol: Static
 Process ID: 0
  SubProtID: 0x0                    Age: 04h20m37s
       Cost: 0               Preference: 60
        Tag: 0                    State: Active Adv
      NibID: 0x10000003          LastAs: 0
      Flags: 0x1008c        OrigNextHop: 192.168.47.4
      Label: NULL           RealNextHop: 192.168.47.4
  Tunnel ID: Invalid          Interface: GigabitEthernet1/0/1
       Dscp: N/A                    Exp: N/A
表1-2 display ip routing-table verbose命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination
目的地址/掩码
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
OrigTblID
原始路由表ID
OrigVrf
路由所属的原始VPN,显示为default-vrf表示公网
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
(暂不支持)SR(Segment Routing)标签
BkSRLabel
(暂不支持)SR(Segment Routing)备份标签
Tunnel ID
隧道ID
BkTunnel ID
备份隧道ID
BkInterface
备份出接口
FtnIndex
FTN表项索引
TrafficIndex
流量统计索引值,取值范围为1~64,N/A表示无效值
Connector
表示BGP为MD VPN特性所携带的Connector属性,具体取值为BGP对等体在交换VPN-IPv4路由时携带源PE的地址,N/A表示没有该属性
VpnPeerId
路由所属的VPN peer ID值,取值范围为1~134217727,N/A表示无效值
Dscp
路由的DSCP优先级,取值范围为0~63,N/A表示无效值
Exp
路由的EXP优先级(仅BGP支持),N/A表示无效值
Summary count
路由数目
display ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ]
context-admin
context-operator
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
如果用户指定的ACL不存在或者ACL中没有任何规则,将显示所有的路由信息。
# 配置ACL 2000,并设置路由过滤规则。
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule permit source 192.168.1.0 0.0.0.255
[Sysname-acl-ipv4-basic-2000] rule deny source any
# 显示通过ACL 2000过滤的激活路由的概要信息。
[Sysname-acl-ipv4-basic-2000] display ip routing-table acl 2000
Summary count : 4
192.168.1.0/24      Direct 0    0            192.168.1.111   GE1/0/1
192.168.1.0/32      Direct 0    0            192.168.1.111   GE1/0/1
192.168.1.111/32    Direct 0    0            127.0.0.1       InLoop0
192.168.1.255/32    Direct 0    0            192.168.1.111   GE1/0/1
以上显示信息解释请参见表1-1。
# 显示通过ACL 2000过滤的所有路由的详细信息。
<Sysname> display ip routing-table acl 2000 verbose
Summary count : 4
Destination: 192.168.1.0/24
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x1                    Age: 04h20m37s
      Flags: 0x10080        OrigNextHop: 192.168.1.111
      Label: NULL           RealNextHop: 192.168.1.111
       Dscp: N/A                    Exp: N/A
Destination: 192.168.1.0/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 192.168.1.111
       Dscp: N/A                    Exp: N/A
Destination: 192.168.1.111/32
   Protocol: Direct
 Process ID: 0
      Flags: 0x10004        OrigNextHop: 127.0.0.1
       Dscp: N/A                    Exp: N/A
Destination: 192.168.1.255/32
   Protocol: Direct
 Process ID: 0
       Dscp: N/A                    Exp: N/A
以上显示信息解释请参见表1-2。
display ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ]
context-admin
context-operator
ip-address:目的IP地址,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
mask:网络掩码,点分十进制格式。
longer-match:匹配掩码更长的路由。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
使用不同的可选参数,命令的输出也不相同,以下是对该命令不同形式的输出说明:
·     display ip routing-table ip-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同路由表中各条路由的子网掩码值进行与运算;
¡     路由表中各条路由的目的IP地址同其自身子网掩码值进行与运算;
¡     两次运算结果相同的路由条目将被显示出来。
·     display ip routing-table ip-address mask
显示满足如下条件的所有激活路由:
¡     用户输入的目的IP地址同用户输入的子网掩码值进行与运算;
¡     路由表中各条路由的目的IP地址同用户输入的子网掩码值进行与运算;
¡     两次运算结果相同,并且掩码小于等于用户输入的子网掩码的路由条目将被显示出来。
·     display ip routing-table ip-address longer-match
显示满足如下条件的所有激活路由:
¡     两次运算结果相同,并且子网掩码最长匹配的路由条目将被显示出来。
·     display ip routing-table ip-address mask longer-match
显示满足如下条件的所有激活路由:
¡     两次运算结果相同,掩码小于等于用户输入的子网掩码,同时子网掩码最长匹配的路由条目将被显示出来。
·     display ip routing-table ip-address1 to ip-address2
显示ip-address1/32到ip-address2/32之间的激活路由,目的地址与掩码(32位)同时在指定范围内才会显示。
# 显示目的地址为11.0.0.1的路由信息。
<Sysname> display ip routing-table 11.0.0.1
Summary count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# 显示目的地址/掩码为11.0.0.1/20的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20
Summary count : 2
# 显示目的地址为11.0.0.1并且掩码最长匹配的路由信息。
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
# 显示目的地址/掩码为11.0.0.1/20并且掩码最长匹配的路由信息。
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary count : 1
# 显示目的地址从1.1.1.0到5.5.5.0范围内的路由信息。
<Sysname> display ip routing-table 1.1.1.0 to 5.5.5.0
Summary count : 5
1.1.1.1/32          Direct 0    0            127.0.0.1       InLoop0
3.3.3.0/24          Direct 0    0            3.3.3.1         GE1/0/2
3.3.3.1/32          Direct 0    0            127.0.0.1       InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1         GE1/0/1
4.4.4.1/32          Direct 0    0            127.0.0.1       InLoop0
# 显示目的地址为1.2.3.4的路由的详细信息。
<Sysname> display ip routing-table 1.2.3.4 verbose
Summary count : 1
Destination: 1.2.3.4/32
   Protocol: O_INTRA
 Process ID: 0
  SubProtID: 0x1                    Age: 00h00m37s
       Cost: 0               Preference: 255
    TableID: 0x2                 OrigAs: 200
      NibID: 0x15000000          LastAs: 200
     AttrID: 0x0               Neighbor: 192.168.47.2
      Flags: 0x10060        OrigNextHop: 192.168.47.2
      Label: NULL           RealNextHop: 192.168.47.2
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-1。
display ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
context-admin
context-operator
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
如果指定的前缀列表不存在,将显示所有的路由信息。
# 配置地址前缀列表test允许前缀为1.1.1.0,掩码长度为24的路由通过。
[Sysname] ip prefix-list test permit 1.1.1.0 24
# 显示通过前缀列表test过滤的激活路由的概要信息。
[Sysname] display ip routing-table prefix-list test
Summary count : 1
1.1.1.0/24          Direct 0    0            1.1.1.2         GE1/0/2
以上显示信息的解释请参见表1-1。
# 显示通过前缀列表test过滤的所有路由的详细信息。
[Sysname] display ip routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
      Flags: 0x1008c        OrigNextHop: 1.1.1.2
      Label: NULL           RealNextHop: 1.1.1.2
  Tunnel ID: Invalid          Interface: GigabitEthernet1/0/2
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-2。
display ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
context-admin
context-operator
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有直连路由的概要信息。
<Sysname> display ip routing-table protocol direct
Summary count : 9
Direct Routing table status : <Active>
Summary count : 9
192.168.80.0/24     Direct 0    0            192.168.80.10   GE1/0/1
192.168.80.0/32     Direct 0    0            192.168.80.10   GE1/0/1
192.168.80.10/32    Direct 0    0            127.0.0.1       InLoop0
192.168.80.255/32   Direct 0    0            192.168.80.10   GE1/0/1
Direct Routing table status : <Inactive>
Summary count : 0
# 显示静态路由表。
<Sysname> display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 0
Static Routing table status : <Inactive>
Summary count : 1
3.0.0.0/8           Static 60   0            2.2.2.2        GE1/0/1
# 显示所有OSPF路由的详细信息。
<Sysname> display ip routing-table protocol ospf verbose
Summary count : 1
Destination: 1.1.1.2/32
   Protocol: O_INTRA
 Process ID: 0
  SubProtID: 0x6                    Age: 00h03m54s
      NibID: 0x16000000          LastAs: 200
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-1。
display ip routing-table statistics命令用来显示路由表中的综合路由统计信息。综合路由统计信息包括路由总数目、路由协议添加/删除路由数目、激活路由数目。
display ip routing-table [ vpn-instance vpn-instance-name ] statistics
context-admin
context-operator
# 显示路由表中的综合路由统计信息。
<Sysname> display ip routing-table statistics
Total prefixes: 15        Active prefixes: 15
Proto      route       active      added       deleted
DIRECT     12          12          30          18
STATIC     3           3           5           2
RIP        0           0           0           0
OSPF       0           0           0           0
IS-IS      0           0           0           0
BGP        0           0           0           0
Total      15          15          35          20
表1-3 display ip routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
route
总的路由数目
active
活跃的、正在使用的路由数目
added
路由器启动后或在上一次清除路由表后,路由表中添加的路由数目
deleted
标记为删除的路由数目(此类路由在等待一段时间后会被释放)
Total
各种类型路由数目的总和
display ip routing-table summary命令用来显示路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ip routing-table [ vpn-instance vpn-instance-name ] summary
context-admin
context-operator
# 显示公网的路由表概要信息。
<Sysname> display ip routing-table summary
Max ECMP: 32
Max Active Route: 262144
Remain Active Route: 262126
# 显示vpn1实例的路由表概要信息。
<Sysname> display ip routing-table vpn-instance vpn1 summary
Max ECMP: 32
Remain Active Route: 262134
Threshold value percentage of max active routes: 100%
表1-4 display ip routing-table summary命令显示信息描述表
Max ECMP
最大等价路由数
Max Active Route
最多支持激活路由前缀数
Remain Active Route
剩余可激活路由前缀数
Threshold value of active routes alert
显示最多支持激活路由前缀数的告警门限:
·     如果在VPN实例中配置了routing-table limit number simply-alert命令,则显示信息字段为Threshold value of active routes alert,取值表示产生告警的门限值。当VPN实例的激活路由前缀数超过该取值时,可以继续激活新的路由前缀,但会产生Trap告警和日志信息
·     若在VPN实例中未配置routing-table limit命令或配置了routing-table limit number warn-threshold命令,则显示信息字段为Threshold value percentage of max active routes,取值表示当(VPN实例中的激活路由前缀数/最多支持激活路由前缀数×100)达到warn-threshold时,产生Trap告警和日志信息,但仍然允许增加激活路由前缀。当VPN实例中的激活路由前缀由数达到最多支持激活路由前缀数目时,不再激活新的路由前缀
display ipv6 rib attribute命令用来显示IPv6 RIB的路由属性信息。
context-admin
context-operator
attribute-id:路由属性ID值,取值范围为十六进制数0~ffffffff。
# 显示IPv6 RIB的路由属性信息。
<Sysname> display ipv6 rib attribute
Total number of attribute(s): 1
Detailed information of attribute 0x9:
                  Flag: 0x0
              Protocol: BGP4+ instance default
        Address family: IPv6
       Reference count: 0
      Local preference: 0
Ext-communities number: 0
 Ext-communities value: N/A
    Communities number: 0
     Communities value: N/A
        AS-path number: 0
         AS-path value: N/A
以上显示信息的解释请参见表1-8。
display ipv6 rib graceful-restart命令用来显示IPv6 RIB的GR状态信息。
context-admin
context-operator
# 显示IPv6 RIB的GR状态信息。
<Sysname> display ipv6 rib graceful-restart
RIB GR state     : Phase2-calculation end
RCOM GR state    : Flush end
Protocol GR state:
 No.  Protocol   Lifetime FD   State    Start/End
 1    DIRECT6    480      29   End      No/No
 2    STATIC6    480      32   End      No/No
 3    ISISV6     480      30   End      No/No
 4    BGP4+ instance default
                 480      31   End      No/No
 5    BGP4+ instance ebcdefg
                 480      32   End      No/No
以上显示信息的解释请参见表1-9。
display ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
context-admin
context-operator
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围为十六进制数1~ffffffff。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
# 显示IPv6 RIB的下一跳信息。
<Sysname> display ipv6 rib nib
Total number of nexthop(s): 151
      NibID: 0x20000000        Sequence: 0
       Type: 0x1                Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: ::
    IFIndex: 0x111            LocalAddr: ::
   TopoNthp: Invalid
      NibID: 0x20000001        Sequence: 1
   UserKey1: 0x0                Nexthop: ::1
    IFIndex: 0x112            LocalAddr: ::1
   TopoNthp: Invalid
# 显示IPv6 RIB下一跳的详细信息。
<Sysname> display ipv6 rib nib verbose
   TopoNthp: Invalid
     RefCnt: 4              FlushRefCnt: 1
       Flag: 0x84               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::
  RelyDepth: 0              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0
   TopoNthp: Invalid
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: ::1
  RelyDepth: 0              RealNexthop: ::1
  Interface: InLoop0          LocalAddr: ::1
     Weight: 0
      NibID: 0x26000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 121::2
   TopoNthp: Invalid
   Instance: default
      NibID: 0x26000002        Sequence: 1
   UserKey1: 0x0                Nexthop: 122::2
   TopoNthp: Invalid
   Instance: abc
以上显示信息的解释请参见表1-10和表1-11。
display ipv6 route-direct nib命令用来显示IPv6直连路由下一跳信息。
context-admin
context-operator
nib-id:路由邻居ID值,取值范围为十六进制数1~ffffffff。
# 显示IPv6直连路由下一跳信息。
<Sysname> display ipv6 route-direct nib
Total number of nexthop(s): 115
   TopoNthp: Invalid
   TopoNthp: Invalid
# 显示IPv6直连路由下一跳详细信息。
<Sysname> display ipv6 route-direct nib verbose
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x2                Version: 1
 1 nexthop(s):
     Weight: 0
 1 nexthop(s):
     Weight: 0
以上显示信息的解释请参见表1-12和表1-13。
display ipv6 routing-table命令用来显示IPv6路由表的信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ]
context-admin
context-operator
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
# 显示当前路由表的概要信息。
<Sysname> display ipv6 routing-table
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Interface  : InLoop0                                     Cost      : 0
Destination: FE80::/10                                   Protocol  : Direct
NextHop    : ::                                          Preference: 0
表1-5 display ipv6 routing-table命令显示信息描述表
Destinations
目的地址个数
Routes
路由条数
Destination
目的网络/主机的IPv6地址和前缀
NextHop
下一跳地址
Preference
路由优先级
出接口,即到该目的地址的数据包将从此接口发出
Protocol
发现该路由的路由协议类型
Cost
路由的开销值
Summary count
路由数目
# 显示路由表的详细路由信息。
<Sysname> display ipv6 routing-table verbose
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h23m02s
    TableID: 0xa                 OrigAs: 0
      NibID: 0x20000000          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10004        OrigNextHop: ::1
      Label: NULL           RealNextHop: ::1
       Dscp: N/A                    Exp: N/A
Destination: 12::/96
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h01m47s
      NibID: 0x20000003          LastAs: 0
      Flags: 0x10080        OrigNextHop: ::
       Dscp: N/A                    Exp: N/A
表1-6 display ipv6 routing-table verbose命令显示信息描述表
Destination
目的网络/主机的IPv6地址和前缀
Protocol
发现该路由的路由协议类型
Process ID
进程号
SubProtID
路由子协议ID
Age
此路由在路由表中存在的时间
Cost
路由的度量值
Preference
路由的优先级
IpPre
IP优先级值
QosLocalID
QoS本地ID
Tag
路由标记
路由状态描述:
·     Active:有效的单播路由
·     Adv:允许对外发送的路由
·     Inactive:非激活路由标志
·     NoAdv:不允许发布的路由
·     Nat:NAT产生的路由
·     TunE:Tunnel隧道的标志
OrigTblID
原始路由表ID
OrigVrf
TableID
路由所在路由表的ID
OrigAs
初始AS号
NibID
下一跳ID
LastAs
最后AS号
AttrID
路由属性ID号
Neighbor
路由协议的邻居地址
Flags
路由标志位
OrigNextHop
此路由的下一跳地址
Label
标签
RealNextHop
路由真实下一跳
BkLabel
备份标签
BkNexthop
备份下一跳地址
SRLabel
BkSRLabel
Tunnel ID
隧道ID
BkTunnel ID
备份隧道ID
BkInterface
备份出接口
FtnIndex
FTN表项索引
TrafficIndex
Connector
VpnPeerId
Dscp
Exp
Summary count
路由数目
display ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ]
context-admin
context-operator
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
如果指定的IPv6 ACL不存在或者IPv6 ACL中没有任何规则,将显示所有的IPv6路由信息。
# 显示通过IPv6 ACL 2000过滤的激活路由的概要信息。
<Sysname> display ipv6 routing-table acl 2000
Summary count : 6
Destination : ::1/128                                    Protocol  : Direct
Destination: 12::/96                                     Protocol  : Direct
Interface  : GE1/0/2                                     Cost      : 0
Destination: 12::1/128                                   Protocol  : Direct
Destination: FF::11/128                                  Protocol  : O_INTER
NextHop    : 12::2                                       Preference: 255
Destination: FF00::/8                                    Protocol  : Direct
Interface  : NULL0                                       Cost      : 0
以上显示信息的解释请参见表1-5。
# 显示通过IPv6 ACL 2000过滤的所有路由的详细信息。
<Sysname> display ipv6 routing-table acl 2000 verbose
Summary count : 6
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 19h29m12s
       Dscp: N/A                    Exp: N/A
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m57s
       Dscp: N/A                    Exp: N/A
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 00h07m55s
       Dscp: N/A                    Exp: N/A
   Protocol: O_INTER
 Process ID: 0
  SubProtID: 0x6                    Age: 00h06m43s
    TableID: 0xa                 OrigAs: 200
      NibID: 0x26000000          LastAs: 200
     AttrID: 0x1               Neighbor: 12::2
      Flags: 0x10060        OrigNextHop: 12::2
      Label: NULL           RealNextHop: 12::2
       Dscp: N/A                    Exp: N/A
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000002          LastAs: 0
      Flags: 0x10084        OrigNextHop: ::
       Dscp: N/A                    Exp: N/A
   Protocol: Direct
 Process ID: 0
      NibID: 0x20000001          LastAs: 0
      Flags: 0x10014        OrigNextHop: ::
  Tunnel ID: Invalid          Interface: NULL0
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-6。
display ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ]
display ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ]
context-admin
context-operator
ipv6-address:IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
longer-match:匹配并显示前缀最长的路由条目。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
·     display ipv6 routing-table ipv6-address
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同路由表中各条路由的前缀长度值进行与运算;
¡     路由表中各条路由的目的IPv6地址同其自身前缀长度值进行与运算;
·     display ipv6 routing-table ipv6-address prefix-length
显示满足如下条件的所有激活路由:
¡     用户输入的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡     路由表中各条路由的目的IPv6地址同用户输入的前缀长度值进行与运算;
¡     两次运算结果相同,并且路由表中前缀长度小于等于用户输入的前缀长度的路由条目将被显示出来。
·     display ipv6 routing-table ipv6-address longer-match
显示满足如下条件的所有激活路由:
¡     两次运算结果相同,同时前缀长度最长匹配的路由条目将被显示出来。
·     display ipv6 routing-table ipv6-address prefix-length longer-match
显示满足如下条件的所有激活路由:
¡     两次运算结果相同,路由表中前缀长度小于等于用户输入的前缀长度,同时前缀长度最长匹配的路由条目将被显示出来。
·     display ipv6 routing-table ipv6-address1 to ipv6-address2
显示ipv6-address1/128到ipv6-address2/128之间的路由,目的IPv6地址与前缀长度(128位)同时在指定范围内才会显示。
# 显示目的IPv6地址/前缀为10::1/127的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127
Summary count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# 显示目的IPv6地址/前缀为10::1/127并且掩码最长匹配的IPv6路由信息。
<Sysname> display ipv6 routing-table 10::1 127 longer-match
Summary count : 1
# 显示目的IPv6地址从100::到300::范围内的IPv6路由信息。
<Sysname> display ipv6 routing-table 100:: to 300::
Summary count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
# 显示目的IPv6地址/前缀为1:2::3:4/128的IPv6路由的详细信息。
<Sysname> display ipv6 routing-table 1:2::3:4 128 verbose
Summary count : 1
Destination: 1:2::3:4/128
   Protocol: O_INTER
 Process ID: 0
  SubProtID: 0x1                    Age: 00h01m14s
    TableID: 0x1                 OrigAs: 200
     AttrID: 0x0               Neighbor: 2:2::3:4
      Flags: 0x10060        OrigNextHop: 2:2::3:4
      Label: NULL           RealNextHop: 2:2::3:4
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-5。
display ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ]
context-admin
context-operator
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
# 配置地址前缀列表test允许前缀为::1,前缀长度为128的IPv6路由通过。
[Sysname] ipv6 prefix-list test permit ::1 128
# 显示通过前缀列表test过滤的IPv6激活路由的概要信息。
[Sysname] display ipv6 routing-table prefix-list test
Summary count : 1
以上显示信息的解释请参见表1-5。
# 显示通过前缀列表test过滤的所有IPv6路由的详细信息。
[Sysname] display ipv6 routing-table prefix-list test verbose
Summary count : 1
   Protocol: Direct
 Process ID: 0
  SubProtID: 0x0                    Age: 08h57m19s
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-6。
display ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ]
context-admin
context-operator
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
# 显示所有IPv6直连路由的概要信息。
<Sysname> display ipv6 routing-table protocol direct
Summary count : 3
Summary count : 3
Summary count : 0
# 显示IPv6静态路由表。
<Sysname> display ipv6 routing-table protocol static
Summary count : 3
Summary count : 3
Destination: 2::2/128                                    Protocol  : Static
NextHop    : fe80::2                                     Preference: 60
NextHop    : fe80::3                                     Preference: 60
Destination: 3::3/128                                    Protocol  : Static
NextHop    : 2::2                                        Preference: 60
Summary count : 0
# 显示所有OSPFv3路由的详细信息。
<Sysname> display ipv6 routing-table protocol ospfv3 verbose
Summary count : 1
Destination: 22::22/128
   Protocol: O_INTER
 Process ID: 0
  SubProtID: 0x6                    Age: 00h04m15s
      NibID: 0x25000001          LastAs: 200
     AttrID: 0x3               Neighbor: 121::2
      Flags: 0x10060        OrigNextHop: 121::2
      Label: NULL           RealNextHop: 121::2
       Dscp: N/A                    Exp: N/A
以上显示信息的解释请参见表1-5。
display ipv6 routing-table statistics命令用来显示IPv6路由表中的综合路由统计信息。综合路由统计信息包括路由总数、路由协议添加/删除路由数目、激活路由数目。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics
context-admin
context-operator
# 显示综合路由统计信息。
<Sysname> display ipv6 routing-table statistics
Total prefixes: 8        Active prefixes: 8
DIRECT     5           5           5           0
STATIC     3           3           3           0
RIPng      0           0           0           0
OSPFv3     0           0           0           0
IS-ISv6    0           0           0           0
BGP4+      0           0           0           0
Total      8           8           8           0
表1-7 display ipv6 routing-table statistics命令显示信息描述表
Total prefixes
总的前缀数目
Active prefixes
总的激活前缀数目
Proto
路由协议
route
总的路由数目
active
激活的、正在使用的路由数目
added
deleted
Total
各种类型路由数目的总和
display ipv6 routing-table summary命令用来显示IPv6路由表的概要信息,包括最大等价路由数、最大可激活路由前缀数、剩余可激活路由前缀数等。
display ipv6 routing-table [ vpn-instance vpn-instance-name ] summary
context-admin
context-operator
# 显示公网的路由表概要信息。
<Sysname> display ipv6 routing-table summary
Max ECMP: 32
# 显示实例vpn1的路由表概要信息。
<Sysname> display ipv6 routing-table vpn-instance vpn1 summary
Max ECMP: 32
Threshold value of active routes alert: 65100
以上显示信息的解释请参见表1-4。
display rib attribute命令用来显示RIB的路由属性信息。
context-admin
context-operator
# 显示RIB的路由属性信息。
<Sysname> display rib attribute
Total number of attribute(s): 10
Detailed information of attribute 0x0:
                  Flag: 0x0
              Protocol: BGP instance default
        Address family: IPv4
       Reference count: 0
      Local preference: 0
Ext-communities number: 26
 Ext-communities value: <RT: 1:1> <RT: 2:2> <RT: 3:3> <RT: 123.123.123.123:65535
                        > <RT: 1234567890:65535> <RT: 123.123.123.123:65534> <RT
                        : 4:4> <RT: 5:5> <RT: 6:6> <RT: 7:7> <RT: 8:8> <RT: 9:9>
                         <RT: 10:10> <RT: 10:1> <RT: 10:11> <RT: 10:12> <RT: 10:
                        13> <RT: 10:14> <RT: 10:15> <RT: 10:16> ...
        AS-path number: 0
         AS-path value: N/A
Detailed information of attribute 0x1:
                  Flag: 0x0
              Protocol: BGP
       Reference count: 0
       Local prefrence: 0
Ext-communities number: 1
 Ext-communities value: <RT: 1:2>
        AS-path number: 0
         AS-path value: N/A
表1-8 display rib attribute命令显示信息描述表
attribute的总个数
Flag
标志位
Protocol
产生该属性的协议
Address family
地址族类型
Reference count
引用计数
Local prefrence
本地优先级
扩展团体属性个数
扩展团体属性值(个数为0显示N/A,最多显示20个,超出部分用…表示)
Communities number
团体属性个数
Communities value
AS-path number
AS-path个数(AS-path个数为所有AS号之和)
AS-path value
AS-path值(AS-path值不区分AS-set、AS-sequence、联盟AS-set、联盟AS-sequence;个数为0显示N/A,最多显示20个,超出部分用…表示)
display rib graceful-restart命令用来显示RIB的GR状态信息。
context-admin
context-operator
# 显示RIB的GR状态信息。
<Sysname> display rib graceful-restart
Protocol GR state:
 1    DIRECT     100      30   End      No/No
 2    STATIC     480      34   End      No/No
 3    OSPF       480      36   End      No/No
 4    ISIS       480      32   End      No/No
表1-9 display rib graceful-restart命令显示信息描述表
RIB GR state
RIB GR状态:
·     Start:协议GR开始
·     IGP end:所有IGP协议GR结束
·     VPN-triggering end:VPN路由触发优选结束
·     VPN-calculation end:VPN路由优选结束
·     Routing protocol end:所有路由协议GR结束
·     NSR-calculation unfinished:NSR优选未完成状态
·     Triggering start:所有路由触发优选开始
·     Triggering end:所有路由触发优选结束
·     Phase1-calculation end:第一阶段优选结束
·     All end:所有协议GR结束
·     Phase2-calculation end:第二阶段优选结束
RCOM GR state
RCOM GR状态:
·     Start:协议GR开始
·     VPN-notification end:VPN路由上报结束
·     Notification end:所有路由上报结束
·     Flush start:开始下刷FIB
·     Flush end:下刷FIB结束
Protocol GR state
协议GR状态
No.
编号
Protocol
协议名称
Lifetime
倒换过程中协议的路由信息/标签信息在RIB中的存活时间,单位为秒
FD
协议进程与RIB连接的句柄
协议GR状态:
·     Init:协议GR初始化状态
·     Listen:协议GR监听状态
·     Idle:协议GR空闲状态
·     Active:协议GR激活状态
·     Start:协议GR开始状态
·     End:协议GR结束状态
Start/End
·     No:表示该消息未发送
·     Yes:表示该消息已发送
display rib nib命令用来显示RIB的下一跳信息。
context-admin
context-operator
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围为十六进制数1~ffffffff。
protocol protocol:显示指定路由协议生成的下一跳信息。
# 显示RIB的下一跳信息。
<Sysname> display rib nib
Total number of nexthop(s): 176
      NibID: 0x10000000        Sequence: 0
   UserKey1: 0x0                Nexthop: 0.0.0.0
    IFIndex: 0x111            LocalAddr: 0.0.0.0
   TopoNthp: 0
      NibID: 0x10000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 127.0.0.1
    IFIndex: 0x112            LocalAddr: 127.0.0.1
   TopoNthp: 0
      NibID: 0x10000002        Sequence: 2
       Type: 0x5                Flushed: Yes
   TopoNthp: 0
      NibID: 0x16000000        Sequence: 3
       Type: 0x21               Flushed: No
   UserKey1: 0x0                Nexthop: 12.1.1.2
    IFIndex: 0x0              LocalAddr: 0.0.0.0
   TopoNthp: 0
   Instance: abc
表1-10 display rib nib命令显示信息描述表
Total number of Nexthop(s)
总的下一跳个数
NibID
下一跳ID
Sequence
下一跳序列号
下一跳类型
Flushed
是否下刷
UserKey0
第一个协议保留数据
UserKey1
第二个协议保留数据
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳地址
IFIndex
接口索引
LocalAddr
本地接口地址
TopoNthp
(暂不支持)下一跳所在拓扑索引,显示为0表示公网拓扑(目前IPv6不支持子拓扑,显示为Invalid)
Instance
BGP实例名称
SubNibID
子下一跳的ID
SubSeq
子下一跳的序列号
NthpCnt
子下一跳的下一跳计数
Samed
子下一跳中相同下一跳计数
NthpType
子下一跳类型:
·     IP:下一跳是IP转发类型
# 显示RIB下一跳详细信息。
<Sysname> display rib nib verbose
   TopoNthp: 0
     RefCnt: 6              FlushRefCnt: 2
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 0.0.0.0
  RelyDepth: 0              RealNexthop: 0.0.0.0
  Interface: NULL0            LocalAddr: 0.0.0.0
   TunnelID: N/A               Topology: base
     Weight: 0
   TopoNthp: 0
     RefCnt: 13             FlushRefCnt: 5
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 127.0.0.1
  RelyDepth: 0              RealNexthop: 127.0.0.1
  Interface: InLoop0          LocalAddr: 127.0.0.1
     Weight: 0
      NibID: 0x15000003        Sequence: 3
       Type: 0x43               Flushed: Yes
   UserKey0: 0x100010000        VrfNthp: 0
   UserKey1: 0x0                Nexthop: 22.22.22.22
   TopoNthp: 0
   Instance: default
     RefCnt: 9              FlushRefCnt: 3
     Policy: tnl-policy1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 22.22.22.22
  RelyDepth: 1              RealNexthop: 13.1.1.2
  Interface: GE1/0/3          LocalAddr: 13.1.1.1
  TunnelCnt: 1                      Vrf: default-vrf
   TunnelID: 1025              Topology: base
     Weight: 0
表1-11 display rib nib verbose命令显示信息描述表
Policy
隧道策略名
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
Vrf
VPN实例名,显示为default-vrf表示公网
OrigNexthop
原始下一跳
RealNexthop
真实下一跳
出接口
LocalAddr
本地接口地址
RelyDepth
迭代深度
TunnelCnt
迭代到隧道的个数
TunnelID
迭代到隧道的ID
Topology
(暂不支持)拓扑名称,显示为base表示公网拓扑(目前IPv6不支持子拓扑,显示为空)
Weight
等价路由各路由的权重,取值为0表示不是等价路由
Instance
BGP实例名称
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
display route-direct nib命令用来显示直连路由下一跳信息。
context-admin
context-operator
# 显示直连路由下一跳信息。
<Sysname> display route-direct nib
Total number of nexthop(s): 116
   TopoNthp: 0
   TopoNthp: 0
表1-12 display route-direct nib命令显示信息描述表
总的下一跳个数
NibID
NIB ID号
Sequence
NIB序列号
NIB类型
Flushed
是否下刷FIB
UserKey0
NIB协议保留数据1
UserKey1
NIB协议保留数据2
VrfNthp
下一跳所在VPN索引,显示为0表示公网
Nexthop
下一跳信息
IFIndex
接口索引
LocalAddr
本地接口地址
TopoNthp
# 显示直连路由下一跳详细信息。
<Sysname> display route-direct nib verbose
     RefCnt: 2              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
     RefCnt: 5              FlushRefCnt: 0
 1 nexthop(s):
     Weight: 0
表1-13 display route-direct nib verbose命令显示信息描述表
x nexthop (s)
下一跳具体值(前面数值表示下一跳个数)
PrefixIndex
等价时下一跳序号
Vrf
OrigNexthop
原始下一跳
RealNexthop
真实下一跳
出接口
localAddr
本地接口地址
RelyDepth
迭代深度
TunnelCnt
迭代到隧道的个数
TunnelID
迭代到隧道的ID
Topology
Weight
RefCnt
下一跳信息的引用计数
FlushRefCnt
下一跳信息的下刷引用计数
Flag
下一跳信息的标志位
Version
下一跳信息的版本号
1.1.25  fib lifetime
fib lifetime命令用来配置IPv4/IPv6路由在FIB中的最大存活时间。
undo fib lifetime命令用来恢复缺省情况。
fib lifetime seconds
undo fib lifetime
IPv4/IPv6路由在FIB中的最大存活时间为600秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
context-admin
seconds:路由在FIB中的最大存活时间,取值范围为0~6000,单位为秒。取值为0时表示,协议或RIB进程倒换并重新恢复后,会立即通知FIB老化表项。
配置本命令后,协议在未配置GR或NSR的情况下,协议或RIB倒换重新恢复后,会延迟配置的seconds,再通知FIB老化表项。
# 配置IPv4路由在FIB中的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] fib lifetime 60
inter-protocol fast-reroute命令用来开启RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
undo inter-protocol fast-reroute命令用来关闭RIB IPv4/IPv6地址族的不同协议间快速重路由功能。
inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
undo inter-protocol fast-reroute [ vpn-instance vpn-instance-name ]
不同协议间快速重路由功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
context-admin
vpn-instance vpn-instance-name:开启指定VPN实例的不同协议间快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则开启RIB IPv4/IPv6地址族中公网的不同协议间快速重路由功能。
通过配置不同协议间快速重路由功能,可将不同协议的下一跳作为备份下一跳。当路由器检测到网络故障时,将使用备份下一跳替换失效下一跳,通过备份下一跳来指导报文的转发,从而大大缩短了流量中断的时间。
如果RIB表中去往同一目的地的不同路由的下一跳和出接口均相同,使用该命令不会生成备份下一跳。
使用不同协议间的快速重路由功能生成备份下一跳时可能会造成环路。
# 开启RIB IPv4地址族中公网的不同协议间快速重路由功能。
[Sysname] rib
[Sysname-rib-ipv4] inter-protocol fast-reroute
non-stop-routing命令用来使能路由的NSR功能。
undo non-stop-routing命令用来关闭路由的NSR功能。
non-stop-routing
路由的NSR功能处于关闭状态。
RIB IPv4地址族视图
RIB IPv6地址族视图
context-admin
# 使能IPv4路由的NSR功能。
[Sysname] rib
[Sysname-rib-ipv4] non-stop-routing
protocol lifetime命令用来配置IPv4/IPv6路由和标签在RIB中的最大存活时间。
undo protocol lifetime命令用来恢复缺省情况。
undo protocol protocol [ instance instance-name ] lifetime
IPv4/IPv6路由和标签在RIB中的最大存活时间为480秒。
RIB IPv4地址族视图
RIB IPv6地址族视图
context-admin
protocol:路由协议。
instance instance-name:BGP实例名称,instance-name为1~31个字符的字符串,区分大小写。如果未指定本参数,将配置所有BGP实例的最大存活时间。只有当protocol是bgp时该参数可选。
seconds:最大存活时间,取值范围为1~6000,单位为秒。
如果配置了该命令,且协议配置GR的情况下,需要注意该时间不要与GR时间冲突,即必须要保证协议能够在该时间内完成GR并将全部表项下发RIB,否则会导致GR失败并断流。
# 配置RIB中RIP路由和标签的最大存活时间为60秒。
[Sysname] rib
[Sysname-rib-ipv4] protocol rip lifetime 60
reset ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
context-admin
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
执行本命令只能清除路由统计信息中路由协议添加/删除路由的数目信息。
# 清除路由表中的路由统计信息。
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all }
context-admin
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
# 清除IPv6路由表中所有路由协议的综合路由统计信息。
<Sysname> reset ipv6 routing-table statistics protocol all
1.1.31  rib
rib命令用来进入RIB视图。
undo rib命令用来删除RIB视图下的所有配置。
rib
undo rib
context-admin
# 进入RIB视图。
[Sysname] rib
[Sysname-rib]
