01-以太网OAM命令
本章节下载 (276.93 KB)
1.1.2 display oam configuration
1.1.3 display oam critical-event
1.1.6 oam errored-frame threshold
1.1.7 oam errored-frame window
1.1.8 oam errored-frame-period threshold
1.1.9 oam errored-frame-period window
1.1.10 oam errored-frame-seconds threshold
1.1.11 oam errored-frame-seconds window
1.1.12 oam errored-symbol-period threshold
1.1.13 oam errored-symbol-period window
1.1.14 oam global errored-frame threshold
1.1.15 oam global errored-frame window
1.1.16 oam global errored-frame-period threshold
1.1.17 oam global errored-frame-period window
1.1.18 oam global errored-frame-seconds threshold
1.1.19 oam global errored-frame-seconds window
1.1.20 oam global errored-symbol-period threshold
1.1.21 oam global errored-symbol-period window
1.1.23 oam global timer keepalive
1.1.25 oam remote-failure action
仅运行在独立运行模式下的S7506X-G交换机支持MDC。
display oam命令用来显示以太网OAM连接的信息。
display oam { local | remote } [ interface interface-type interface-number ]
local:显示本端信息。
remote:显示远端信息。
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的信息。
# 显示所有接口上以太网OAM连接的本端信息。
<Sysname> display oam local
----------- [Ten-GigabitEthernet1/0/25] -----------
Enable status : Enable
Loopback status : No loopback
Link status : UP
OAM mode : Active
PDU : ANY
Mux action : FWD
Par action : FWD
# 显示接口Ten-GigabitEthernet1/0/25上以太网OAM连接的本端信息。
<Sysname> display oam local interface ten-gigabitethernet 1/0/25
Link status : UP
OAM mode : Active
PDU : ANY
Mux action : FWD
Par action : FWD
Flags
Link fault : Not occurred
Dying gasp : Not occurred
Critical event : Not occurred
Local evaluating : COMPLETE
Remote evaluating : COMPLETE
Packets statistics
Packet type Sent Received
OAMPDU 100 80
OAMInformation 64 60
OAMEventNotification 36 20
OAMUniqueEventNotification 36 10
OAMDuplicateEventNotification 0 10
表1-1 display oam local命令显示信息描述表
Ten-GigabitEthernet1/0/25 |
接口Ten-GigabitEthernet1/0/25上的信息 |
Enable status |
本端的以太网OAM状态: · Enable:表示已开启 · Disable:表示未开启 |
Loopback status |
(暂不支持)以太网OAM远端环回状态: · No loopback:表示尚未建立远端环回 · Remote loopback:表示远端环回的主控端 · Local loopback:表示远端环回的被控端 |
Link status |
链路物理状态: · UP:表示链路up · DOWN:表示链路down |
OAM mode |
本端以太网OAM的连接模式: · Active:表示主动模式 · Passive:表示被动模式 |
PDU |
本端对OAMPDU的处理方式: · RX_INFO:表示只接收Information OAMPDU,不允许发送任何OAMPDU · LF_INFO:表示只发送不带Information TLV且链路错误标志位已被置位的Information OAMPDU · INFO:表示只收发Information OAMPDU · ANY:表示可收发所有OAMPDU |
Mux action |
本端发送器的工作方式: · FWD:表示发送方向为FORWARDING,允许发送任何报文 · DISCARD:表示发送方向为DISCARDING,只允许发送OAMPDU |
Par action |
本端接收器的工作方式: · FWD:表示接收方向为FORWARDING,允许接收任何报文 · DISCARD:表示接收方向为DISCARDING,只允许接收OAMPDU · LB:表示接收方向处于环回状态,收到的所有非OAMPDU都将按原路返回(暂不支持) |
Flags |
以太网OAM报文中的本端标识域 |
Link fault |
是否发生链路故障: · Occurred:表示已发生 · Not occurred:表示未发生 |
Dying gasp |
是否发生致命故障: · Occurred:表示已发生 · Not occurred:表示未发生 |
Critical event |
是否发生紧急事件: · Occurred:表示已发生 · Not occurred:表示未发生 |
Local evaluating |
本端对远端配置的协商过程: · COMPLETE:表示协商已完成 · NOTCOMPLETE:表示协商未完成 |
Remote evaluating |
远端对本端配置的协商过程: · COMPLETE:表示协商已完成 · NOTCOMPLETE:表示协商未完成 · RESERVED:表示此字段为保留值,协商未完成 · UNSATISFIED:表示远端对本端的配置不满意,协商未完成 |
Packets statistics |
各种以太网OAM报文的发送和接收数量 |
Packet type |
报文类型 |
Sent |
发送的报文数量 |
Received |
收到的报文数量 |
OAMPDU |
以太网OAM报文 |
OAMInformation |
以太网OAM信息报文 |
OAMEventNotification |
以太网OAM事件通知报文 |
OAMUniqueEventNotification |
以太网OAM一次性发送或接收的事件报文 |
OAMDuplicateEventNotification |
以太网OAM重复发送或接收的事件报文 |
# 显示所有接口上以太网OAM连接的远端信息。
<Sysname> display oam remote
OAM mode : Active
MAC address : 3822-d6a2-a800
MTU size : 1500
Mux action : FWD
Par action : FWD
# 显示接口Ten-GigabitEthernet1/0/25上以太网OAM连接的远端信息。
<Sysname> display oam remote interface ten-gigabitethernet 1/0/25
OAM mode : Active
MTU size : 1500
Mux action : FWD
Par action : FWD
Configuration
Unidirectional : Not supported
Remote loopback : Supported
Link events : Supported
MIB retrieval : Not supported
Flags
表1-2 display oam remote命令显示信息描述表
OAM mode |
远端的以太网OAM连接模式: · Active:表示主动模式 · Passive:表示被动模式 |
MAC address |
远端的MAC地址 |
MTU size |
以太网OAM实体间传送的报文最大长度,单位为字节 |
Mux action |
远端发送器的工作方式 · FWD:表示发送方向为FORWARDING,允许发送任何报文 · DISCARD:表示发送方向为DISCARDING,只允许发送OAMPDU |
Par action |
远端接收器的工作方式: · FWD:表示接收方向为FORWARDING,允许接收任何报文 · DISCARD:表示接收方向为DISCARDING,只允许接收OAMPDU · LB:表示接收方向处于环回状态,收到的所有非OAMPDU都将按原路返回(暂不支持) |
Configuration |
远端以太网OAM实体的配置信息 |
Unidirectional |
是否支持单向传输: · Supported:表示支持 · Not supported:表示不支持 |
Remote loopback |
(暂不支持)是否支持远端环回: · Supported:表示支持 · Not supported:表示不支持 |
Link events |
是否支持一般链路事件: · Supported:表示支持 · Not supported:表示不支持 |
MIB retrieval |
是否支持获取MIB变量: · Supported:表示支持 · Not supported:表示不支持 |
Flags |
以太网OAM报文中的远端标识域 |
Link fault |
Dying gasp |
Critical event |
Local evaluating |
本端对远端配置的协商过程: · COMPLETE:表示协商已完成 · NOTCOMPLETE:表示协商未完成 · RESERVED:表示此字段为保留值,协商未完成 · UNSATISFIED:表示本端对远端的配置不满意,协商未完成 |
Remote evaluating |
远端对本端配置的协商过程: · COMPLETE:表示协商已完成 · NOTCOMPLETE:表示协商未完成 · UNSATISFIED:表示本端对远端的配置不满意,协商未完成 |
· reset oam
display oam configuration命令用来显示以太网OAM的配置信息。
display oam configuration [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示全局以及未采用缺省配置的接口上的信息。
# 显示全局以及未采用缺省配置的接口上的以太网OAM配置信息。
<Sysname> display oam configuration
---------------- [Global] ----------------
OAM timers
Hello timer : 1000 milliseconds
Keepalive timer : 5000 milliseconds
Link monitoring
Errored symbol period
Window : 100 x 1000000 symbols
Threshold : 1 error symbols
Errored frame
Window : 10 x 100 milliseconds
Threshold : 1 error frames
Errored frame period
Window : 1000 x 10000 frames
Errored frame seconds
Window : 600 x 100 milliseconds
Threshold : 1 error seconds
OAM timers
Hello timer : 500 milliseconds
Link monitoring
Errored frame
表1-3 display oam configuration命令显示信息描述表
Global |
全局信息 |
OAM timers |
以太网OAM连接检测定时器 |
Hello timer |
以太网OAM握手报文的发送间隔 |
Keepalive timer |
以太网OAM连接的超时时间 |
Link monitoring |
一般链路事件的检测窗口和检测阈值 |
Errored symbol period |
错误信号事件 |
Errored frame |
错误帧事件 |
Errored frame period |
错误帧周期事件 |
Errored frame seconds |
错误帧秒事件 |
Window |
检测窗口 |
Threshold |
检测阈值 |
display oam critical-event命令用来显示以太网OAM的紧急链路事件统计信息。
display oam critical-event [ interface interface-type interface-number ]
# 显示所有接口上以太网OAM紧急链路事件的统计信息。
<Sysname> display oam critical-event
Local link status : UP
Event statistics
表1-4 display oam critical-event命令显示信息描述表
Local link status |
本端的链路状态: · UP:表示链路up · DOWN:表示链路down |
Event statistics |
紧急链路事件的统计信息 |
Link fault |
Dying gasp |
Critical event |
display oam link-event命令用来显示以太网OAM的一般链路事件统计信息。
display oam link-event { local | remote } [ interface interface-type interface-number ]
local:显示本端统计信息。
remote:显示远端统计信息。
以太网OAM的一般链路事件包括错误信号事件、错误帧事件、错误帧周期事件和错误帧秒事件。
# 显示所有接口上以太网OAM一般链路事件的本端统计信息。
<Sysname> display oam link-event local
Link status: UP
OAM local errored symbol event
Event time stamp : 35498 x 100 milliseconds
Errored symbol window : 100000000 symbols
Errored symbol threshold : 1 error symbols
Errored symbol : 1 error symbols
Error running total : 4 error symbols
Event running total : 4 events
OAM local errored frame event
Event time stamp : 49582 x 100 milliseconds
Errored frame window : 10 x 100 milliseconds
Errored frame threshold : 1 error frames
Errored frame : 1 error frames
Error running total : 6 error frames
Event running total : 6 events
OAM local errored frame period event
Event time stamp : 16382 x 100 milliseconds
Errored frame period window : 10000000 frames
Errored frame period threshold : 1 error frames
Errored frame period : 1 error frames
Error running total : 5 error frames
Event running total : 5 events
OAM local errored frame seconds summary event
Event time stamp : 50022 x 100 milliseconds
Errored frame seconds window : 600 x 100 milliseconds
Errored frame seconds threshold : 1 error seconds
Errored frame seconds : 1 error seconds
Error running total : 1 error seconds
Event running total : 1 events
# 显示所有接口上以太网OAM一般链路事件的远端统计信息。
<Sysname> display oam link-event remote
Link status: UP
OAM remote errored symbol event
OAM remote errored frame event
OAM remote errored frame period event
OAM remote errored frame seconds summary event
表1-5 display oam link-event命令显示信息描述表
Link status |
OAM local/remote errored symbol event |
本端/远端产生的错误信号事件信息(只有产生了错误信号事件才会显示): · Event time stamp:表示错误信号事件的发生时间 · Errored symbol window:表示错误信号事件的检测窗口 · Errored symbol threshold:表示错误信号事件的检测阈值 · Errored symbol:表示最近一次错误信号事件中错误信号的数量 · Error running total:表示错误信号的总数量 · Event running total:表示错误信号事件的总数量 |
OAM local/remote errored frame event |
本端/远端产生的错误帧事件信息(只有产生了错误帧事件才会显示): · Event time stamp:表示错误帧事件的发生时间 · Errored frame window:表示错误帧事件的检测窗口 · Errored frame threshold:表示错误帧事件的检测阈值 · Errored frame:表示最近一次错误帧事件中错误帧的数量 · Error running total:表示错误帧的总数量 · Event running total:表示错误帧事件的总数量 |
OAM local/remote errored frame period event |
本端/远端产生的错误帧周期事件信息(只有产生了错误帧周期事件才会显示): · Event time stamp:表示错误帧周期事件的发生时间 · Errored frame period window:表示错误帧周期事件的检测窗口 · Errored frame period threshold:表示错误帧周期事件的检测阈值 · Errored frame period:表示最近一次错误帧周期事件中错误帧的数量 · Error running total:表示错误帧周期的总数量 · Event running total:表示错误帧周期事件的总数量 |
OAM local/remote errored frame seconds summary event |
本端/远端产生的错误帧秒事件信息(只有产生了错误帧秒事件才会显示): · Event time stamp:表示错误帧秒事件的发生时间 · Errored frame seconds window:表示错误帧秒事件的检测窗口 · Errored frame seconds threshold:表示错误帧秒事件的检测阈值 · Errored frame seconds:表示最近一次错误帧秒事件中错误帧的数量 · Error running total:表示错误帧秒的总数量 · Event running total:表示错误帧秒事件的总数量 |
· reset oam
oam enable命令用来开启以太网OAM功能。
undo oam enable命令用来关闭以太网OAM功能。
oam enable
undo oam enable
以太网OAM功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/25上开启以太网OAM功能。
[Sysname] interface ten-gigabitethernet 1/0/25
[Sysname-Ten-GigabitEthernet1/0/25] oam enable
oam errored-frame threshold命令用来在接口上配置错误帧事件的检测阈值。
undo oam errored-frame threshold命令用来恢复缺省情况。
oam errored-frame threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧事件的检测阈值,取值范围为0~4294967295,单位为次。
接口值只对当前接口有效,但配置优先级高于全局值。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame threshold 100
· display oam configuration
· display oam link-event
· oam global errored-frame threshold
oam errored-frame window命令用来在接口上配置错误帧事件的检测窗口。
undo oam errored-frame window命令用来恢复缺省情况。
oam errored-frame window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧事件的检测窗口,取值范围为10~600,步长为10,单位为100毫秒。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧事件的检测窗口为2000毫秒。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame window 20
· oam global errored-frame window
oam errored-frame-period threshold命令用来在接口上配置错误帧周期事件的检测阈值。
undo oam errored-frame-period threshold命令用来恢复缺省情况。
oam errored-frame-period threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧周期事件的检测阈值,取值范围为0~4294967295,单位为次。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧周期事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame-period threshold 100
· oam global errored-frame-period threshold
oam errored-frame-period window命令用来在接口上配置错误帧周期事件的检测窗口。
undo oam errored-frame-period window命令用来恢复缺省情况。
oam errored-frame-period window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧周期事件的检测窗口,取值范围为1~65535,单位为10000次。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧周期事件的检测窗口为20000000次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame-period window 2000
· oam global errored-frame-period window
oam errored-frame-seconds threshold命令用来在接口上配置错误帧秒事件的检测阈值。
undo oam errored-frame-seconds threshold命令用来恢复缺省情况。
oam errored-frame-seconds threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误帧秒事件的检测阈值,取值范围为0~900,单位为次。
在数量上,错误帧秒事件的检测阈值不应大于其检测窗口值(换算成秒),否则将不会产生错误帧秒事件。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧秒事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame-seconds threshold 100
· oam errored-frame-seconds window
· oam global errored-frame-seconds threshold
oam errored-frame-seconds window命令用来在接口上配置错误帧秒事件的检测窗口。
undo oam errored-frame-seconds window命令用来恢复缺省情况。
oam errored-frame-seconds window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误帧秒事件的检测窗口,取值范围为100~9000,步长为10,单位为100毫秒。
# 在接口Ten-GigabitEthernet1/0/25上配置错误帧秒事件的检测窗口为10000毫秒。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-frame-seconds window 100
· oam errored-frame-seconds threshold
· oam global errored-frame-seconds window
oam errored-symbol-period threshold命令用来在接口上配置错误信号事件的检测阈值。
undo oam errored-symbol-period threshold命令用来恢复缺省情况。
oam errored-symbol-period threshold threshold-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
threshold-value:表示错误信号事件的检测阈值,取值范围为0~4294967295,单位为次。
# 在接口Ten-GigabitEthernet1/0/25上配置错误信号事件的检测阈值为100次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-symbol-period threshold 100
· oam global errored-symbol-period threshold
oam errored-symbol-period window命令用来在接口上配置错误信号事件的检测窗口。
undo oam errored-symbol-period window命令用来恢复缺省情况。
oam errored-symbol-period window window-value
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
window-value:表示错误信号事件的检测窗口,取值范围为1~65535,单位为1000000次。
# 在接口Ten-GigabitEthernet1/0/25上配置错误信号事件的检测值为200000000次。
[Sysname-Ten-GigabitEthernet1/0/25] oam errored-symbol-period window 200
· oam global errored-symbol-period window
oam global errored-frame threshold命令用来全局配置错误帧事件的检测阈值。
undo oam global errored-frame threshold命令用来恢复缺省情况。
oam global errored-frame threshold threshold-value
错误帧事件检测阈值的全局值为1次。
全局值对所有接口都有效,但配置优先级低于接口值。
# 全局配置错误帧事件的检测阈值为100次。
[Sysname] oam global errored-frame threshold 100
· oam errored-frame threshold
oam global errored-frame window命令用来全局配置错误帧事件的检测窗口。
undo oam global errored-frame window命令用来恢复缺省情况。
oam global errored-frame window window-value
错误帧事件检测窗口的全局值为1000毫秒。
# 全局配置错误帧事件的检测窗口配置为2000毫秒。
[Sysname] oam global errored-frame window 20
· oam errored-frame window
oam global errored-frame-period threshold命令用来全局配置错误帧周期事件的检测阈值。
undo oam global errored-frame-period threshold命令用来恢复缺省情况。
oam global errored-frame-period threshold threshold-value
错误帧周期事件检测阈值的全局值为1次。
# 全局配置错误帧周期事件的检测阈值为100次。
[Sysname] oam global errored-frame-period threshold 100
· oam errored-frame-period threshold
oam global errored-frame-period window命令用来全局配置错误帧周期事件的检测窗口。
undo oam global errored-frame-period window命令用来恢复缺省情况。
oam global errored-frame-period window window-value
错误帧周期事件检测窗口的全局值为10000000次。
# 全局配置错误帧周期事件的检测窗口为20000000次。
[Sysname] oam global errored-frame-period window 2000
· oam errored-frame-period window
oam global errored-frame-seconds threshold命令用来全局配置错误帧秒事件的检测阈值。
undo oam global errored-frame-seconds threshold命令用来恢复缺省情况。
oam global errored-frame-seconds threshold threshold-value
错误帧秒事件检测阈值的全局值为1次。
# 全局配置错误帧秒事件的检测阈值配置为100次。
[Sysname] oam global errored-frame-seconds threshold 100
oam global errored-frame-seconds window命令用来全局配置错误帧秒事件的检测窗口。
undo oam global errored-frame-seconds window命令用来恢复缺省情况。
oam global errored-frame-seconds window window-value
错误帧秒事件检测窗口的全局值为60000毫秒。
# 全局配置错误帧秒事件的检测窗口为10000毫秒。
[Sysname] oam global errored-frame-seconds window 100
oam global errored-symbol-period threshold命令用来全局配置错误信号事件的检测阈值。
undo oam global errored-symbol-period threshold命令用来恢复缺省情况。
oam global errored-symbol-period threshold threshold-value
错误信号事件检测阈值的全局值为1次。
# 全局配置错误信号事件的检测阈值为100次。
[Sysname] oam global errored-symbol-period threshold 100
· oam errored-symbol-period threshold
oam global errored-symbol-period window命令用来全局配置错误信号事件的检测窗口。
undo oam global errored-symbol-period window命令用来恢复缺省情况。
oam global errored-symbol-period window window-value
错误信号事件检测窗口的全局值为100000000次。
# 全局配置错误信号事件的检测窗口为200000000次。
[Sysname] oam global errored-symbol-period window 200
· oam errored-symbol-period window
oam global timer hello命令用来全局配置以太网OAM握手报文的发送间隔。
undo oam global timer hello命令用来恢复缺省情况。
oam global timer hello interval
以太网OAM握手报文发送间隔的全局值为1000毫秒。
interval:表示以太网OAM握手报文的发送间隔,单位为毫秒,步长为100,取值范围为500~5000。
由于本端OAM实体在连接超时后将老化与远端OAM实体的连接关系,导致OAM连接中断,因此连接超时时间必须大于握手报文发送间隔(建议为五倍或以上),否则将导致以太网OAM连接不稳定。
# 全局配置以太网OAM握手报文的发送间隔为600毫秒。
[Sysname] oam global timer hello 600
· oam timer hello
oam global timer keepalive命令用来全局配置以太网OAM连接的超时时间。
undo oam global timer keepalive命令用来恢复缺省情况。
oam global timer keepalive interval
以太网OAM连接超时时间的全局值为5000毫秒。
interval:表示以太网OAM连接的超时时间,单位为毫秒,步长为100,取值范围为1000~25000。
# 全局配置以太网OAM连接的超时时间为6000毫秒。
[Sysname] oam global timer keepalive 6000
· oam timer keepalive
oam mode命令用来配置以太网OAM的连接模式。
undo oam mode命令用来恢复缺省情况。
oam mode { active | passive }
undo oam mode
以太网OAM连接模式为主动模式。
二层以太网接口视图
三层以太网接口视图
active:表示主动模式。
passive:表示被动模式。
不允许在已开启以太网OAM功能的接口上更改以太网OAM的连接模式。如需更改,请先关闭该接口上的以太网OAM功能。
# 在接口Ten-GigabitEthernet1/0/25上先关闭以太网OAM功能,再配置以太网OAM的连接模式为被动模式。
[Sysname-Ten-GigabitEthernet1/0/25] undo oam enable
[Sysname-Ten-GigabitEthernet1/0/25] oam mode passive
· oam enable
oam remote-failure action命令用来配置接口收到远端以太网OAM事件时的响应动作。
undo oam remote-failure action命令用来取消接口收到远端以太网OAM事件时的响应动作的配置。
oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
undo oam remote-failure { connection-expired | critical-event | dying-gasp | link-fault } action error-link-down
接口收到远端以太网OAM事件时仅记录日志。
二层以太网接口视图
三层以太网接口视图
connection-expired:表示以太网OAM连接超时。
critical-event:表示紧急事件。
dying-gasp:表示致命故障。
link-fault:表示链路故障。
error-link-down:表示断开OAM连接,并设置接口的链路层状态为down。
# 配置接口Ten-GigabitEthernet1/0/25收到紧急事件时的响应动作为断开OAM连接,并设置该接口的链路层状态为down。
[Sysname-Ten-GigabitEthernet1/0/25] oam remote-failure critical-event action error-link-down
oam timer hello命令用来在接口上配置以太网OAM握手报文的发送间隔。
undo oam timer hello命令用来恢复缺省情况。
oam timer hello interval
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/25上配置以太网OAM握手报文的发送间隔为600毫秒。
[Sysname-Ten-GigabitEthernet1/0/25] oam timer hello 600
· oam global timer hello
oam timer keepalive命令用来在接口上配置以太网OAM连接的超时时间。
undo oam timer keepalive命令用来恢复缺省情况。
oam timer keepalive interval
接口采用全局值。
二层以太网接口视图
三层以太网接口视图
# 在接口Ten-GigabitEthernet1/0/25上配置以太网OAM连接的超时时间为6000毫秒。
[Sysname-Ten-GigabitEthernet1/0/25] oam timer keepalive 6000
· oam global timer keepalive
reset oam命令用来清除以太网OAM的报文和一般链路事件统计信息。
reset oam [ interface interface-type interface-number ]
interface interface-type interface-number:清除指定接口上的信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将清除所有接口上的信息。
# 清除所有接口上以太网OAM的报文和一般链路事件统计信息。
<Sysname> reset oam
· display oam
