09-LLDP命令
本章节下载: 09-LLDP命令 (377.64 KB)
1.1.1 display lldp local-information
1.1.2 display lldp neighbor-information
1.1.7 lldp check-change-interval
1.1.12 lldp global tlv-enable basic-tlv management-address-tlv
1.1.14 lldp ignore-pvid-inconsistency
1.1.15 lldp management-address
1.1.16 lldp management-address-format string
1.1.19 lldp notification med-topology-change enable
1.1.20 lldp notification remote-change enable
1.1.22 lldp timer fast-interval
1.1.23 lldp timer notification-interval
1.1.24 lldp timer reinit-delay
display lldp local-information命令用来显示LLDP本地信息。
global:显示全局LLDP本地信息。
interface interface-type interface-number:显示指定接口上的LLDP本地信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示所有LLDP本地信息,包括全局LLDP信息以及所有开启了LLDP功能且状态为up的接口上的LLDP信息。
<Sysname> display lldp local-information
Chassis ID : 0000-fc00-6ae4
System name : Sysname
System description :
H3C Comware Platform Software, Software Version 7.1.070, Alpha 772101
H3C S5560-54C-EI-G
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. All rights reserved.
System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
System capabilities enabled : Bridge, Router, Customer Bridge
MED information:
Device class : Connectivity device
MED inventory information of master board:
HardwareRev : VER.A
FirmwareRev : 016
SoftwareRev : 7.1.0707721
SerialNum : Unknown
Manufacturer name : H3C
Model name : H3CS5560-54C-EI-G
Asset tracking identifier : Unknown
LLDP local-information of port 641[M-GigabitEthernet0/0/0]:
Port ID type : Interface name
Port ID : M-GigabitEthernet0/0/0
Port description : M-GigabitEthernet0/0/0 Interface
LLDP agent nearest-bridge management address:
Management address type : IPv4
Management address : 192.168.2.220
Management address interface ID : 641
Management address OID : 0
LLDP agent nearest-nontpmr management address:
LLDP agent nearest-customer management address:
Link aggregation supported : No
Link aggregation enabled : No
Aggregation port ID : 0
Auto-negotiation enabled : Yes
OperMau : Speed(100)/Duplex(Full)
Power port class : PSE
PSE power supported : No
PSE power enabled : No
PSE pairs control ability : No
Power pairs : Signal
Port power classification : Class 0
Power type : Type 2 PSE
Power source : Primary
Power priority : Unknown
PD requested power value : 0.0 w
PSE allocated power value : 0.0 w
Maximum frame size : 0
Transmit Tw : 0 us
Receive Tw : 0 us
Fallback Tw : 0 us
Echo Transmit Tw : 0 us
Echo Receive Tw : 0 us
PoE PSE power source : Primary
Port PSE priority : Critical
Port available power value : 0.0 w
表1-1 display lldp local-information命令显示信息描述表
Global LLDP local-information |
本设备的全局LLDP本地信息 |
Chassis ID |
Chassis ID值,为本设备的桥MAC地址 |
System name |
系统名称 |
System description |
系统描述 |
System capabilities supported |
系统所支持的功能: · Bridge:表示支持交换功能 · Router:表示支持路由功能 · WlanAccessPoint:表示支持无线接入点功能 · Repeater:表示支持信号中继功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
System capabilities enabled |
系统已开启的功能: · Bridge:表示交换功能已开启 · Router:表示路由功能已开启 · WlanAccessPoint:表示无线接入点功能已开启 · Repeater:表示支持信号中继功能 · Telephone:表示电话功能已开启 · DocsisCableDevice:表示电缆设备功能已开启 · StationOnly:表示只作站点功能已开启 · Customer Bridge:表示客户桥功能已开启 · Service Bridge:表示服务桥功能已开启 · TPMR:表示双端口MAC中继功能已开启 · Other:表示不在上述列表的其它功能已开启 |
MED information |
MED设备相关信息 |
Device class |
MED设备类型: · Connectivity device:表示网络设备 · Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备 · Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流 · Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用 |
MED inventory information of master board |
主控板MED资产信息 |
HardwareRev |
产品的硬件版本 |
FirmwareRev |
产品的固件版本 |
SoftwareRev |
产品的软件版本 |
SerialNum |
序列号 |
Manufacturer name |
制造厂商 |
Model name |
模块名称 |
Asset tracking identifier |
资产跟踪ID |
LLDP local-information of port 1 |
端口1上LLDP本地信息 |
Port ID type |
端口ID类型: · MAC address:表示MAC地址 · Interface name:表示接口名称 |
Port ID |
端口ID值,根据本设备的Port ID type取相应类型的值 |
Port description |
端口描述 |
LLDP agent nearest-bridge management address |
LLDP最近桥代理的管理地址 |
LLDP agent nearest-customer management address |
LLDP最近客户桥代理的管理地址 |
LLDP agent nearest-nontpmr management address |
LLDP最近非TPMR桥代理的管理地址 |
Management address type |
管理地址类型 |
Management address |
管理地址 |
Management address interface type |
管理地址所在接口的编码方式 |
Management address interface ID |
管理地址接口索引 |
Management address OID |
管理地址对象标识符 |
Port VLAN ID(PVID) |
端口VLAN ID |
Port and protocol VLAN ID(PPVID) |
端口协议VLAN ID |
Port and protocol VLAN supported |
是否支持端口协议VLAN |
Port and protocol VLAN enabled |
是否已开启端口协议VLAN |
VLAN name of VLAN 12 |
VLAN 12的名称 |
Management VLAN ID |
管理VLAN ID |
Link aggregation supported |
端口是否支持链路聚合 |
Link aggregation enabled |
端口是否已开启链路聚合 |
Aggregation port ID |
聚合组中该成员端口的编号,未开启链路聚合功能时为0 |
Auto-negotiation supported |
端口是否支持自协商 |
Auto-negotiation enabled |
端口是否已开启自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE(Power Sourcing Equipment,供电设备) · PD(Powered Device,受电设备) |
PSE power supported |
是否支持PSE供电 |
PSE power enabled |
是否已开启PSE供电 |
PSE pairs control ability |
供电方式是否可控 |
Power pairs |
PoE端口的远程供电模式: · Signal:表示信号线供电模式 · Spare:表示空闲线供电模式 |
Port power classification |
PD的端口控制级别: · Class 0:表示级别0 · Class 1:表示级别1 · Class 2:表示级别2 · Class 3:表示级别3 · Class 4:表示级别4 |
Power type |
供电类型: · Type 1 PD:表示类型1 PD · Type 2 PD:表示类型2 PD · Type 1 PSE:表示类型1 PSE · Type 2 PSE:表示类型2 PSE |
Power source |
功率来源(功率来源根据供电类型为PD类型或PSE类型,取值不同): PSE · Unknown:表示采用的电源类型未知 · Primary:表示采用主用电源作为电源 · Backup:表示采用备用电源作为电源 · Reserved:保留 PD · Unknown:表示采用的电源类型未知 · PSE:表示采用PSE作为电源 · Local:表示采用本地电源作为电源 · PSE and local:表示采用PSE和本地电源作为电源 |
Power priority |
功率优先级: · Unknown:表示优先级未知 · Critical:表示优先级为1级 · High:表示优先级为2级 · Low:表示优先级为3级 |
PD requested power value |
PD请求功率值,单位为瓦特 |
PSE allocated power value |
PSE分配功率值,单位为瓦特 |
Congestion notification TLV info |
拥塞通知TLV信息 |
Dot1p |
802.1p优先级 |
CNPV |
802.1p优先级是否被配置为CNPV(Congestion Notification Priority Value,拥塞通知优先级值),表明是否加入了对应CNPV域: · Yes:表示802.1p优先级被配置为CNPV · No:表示802.1p优先级未被配置为CNPV |
Ready |
表明设备接口是否已经关闭了802.1p优先级与隔离优先级的映射: · Yes:表示关闭优先级映射 · No:表示未关闭优先级映射 |
Maximum frame size |
端口支持的最大帧长度 |
Media policy type |
媒体策略类型: · Unknown:表示类型未知 · Voice:表示语音 · VoiceSignaling:表示语音信号 · GuestVoice:表示访客语音 · GuestVoiceSignaling:表示访客语音信号 · SoftPhoneVoice:表示软体电话语音 · Videoconferencing:表示视频会议 · StreamingVideo:表示流视频 · VideoSignaling:表示视频信号 |
Unknown policy |
媒体策略类型是否未知: · Yes:表示策略类型未知 · No:表示策略类型已知 |
VLAN tagged |
媒体VLAN是否带Tag |
Media policy VLANID |
媒体VLAN的VLAN ID |
Media policy L2 priority |
二层优先级 |
Media policy DSCP |
DSCP的值 |
Location format |
位置信息格式: · Invalid:表示无效位置数据类型 · Coordinate-based LCI:表示基于坐标的位置信息 · Civic Address LCI:表示普通地址信息 · ECS ELIN:表示紧急电话号码 |
Location information |
位置信息 |
PoE PSE power source |
PSE所采用的电源类型: · Unknown:表示采用的电源类型未知 · Primary:表示采用主用电源作为电源 · Backup:表示采用备用电源作为电源 |
PoE PD power source |
PD所采用的电源类型: · Unknown:表示采用的电源类型未知 · PSE:表示采用PSE作为电源 · Local:表示采用本地电源作为电源 · PSE and local:表示采用PSE和本地电源作为电源 |
Port PSE priority |
PSE上端口的供电优先级: · Unknown:表示优先级未知 · Critical:表示优先级为1级 · High:表示优先级为2级 · Low:表示优先级为3级 |
Port PD priority |
PD上端口的受电优先级: · Unknown:表示优先级未知 · Critical:表示优先级为1级 · High:表示优先级为2级 · Low:表示优先级为3级 |
Port available power value |
PSE上端口可提供的功率,或PD上端口所需的功率,单位为瓦特 |
Transmit Tw |
本端发送的等待时间,单位为微秒 |
Receive Tw |
本端向对端请求的等待时间,单位为微秒 |
Fallback Tw |
本端向对端请求的候选等待时间,单位为微秒 |
Echo Transmit Tw |
收到的对端发送的等待时间,单位为微秒 |
Echo Receive Tw |
收到的对端请求的等待时间,单位为微秒 |
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息。
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
agent:显示指定类型LLDP代理收到的由邻居设备发来的LLDP信息。如果未指定该参数,将显示所有类型LLDP代理收到的由邻居设备发来的LLDP信息。
nearest-bridge:表示最近桥代理。
nearest-customer:表示最近客户桥代理。
nearest-nontpmr:表示最近非TPMR桥代理。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口最近桥代理收到的由邻居设备发来的LLDP详细信息。
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[Ten-GigabitEthernet1/0/25]:
LLDP agent nearest-bridge:
LLDP Neighbor index : 1
Update time : 0 days, 0 hours, 1 minutes, 1 seconds
Chassis type : MAC address
Chassis ID : 000f-0055-0002
Port ID : Ten-GigabitEthernet1/0/25
Time to live : 121
Port description : Ten-GigabitEthernet1/0/25 Interface
System description : H3C Comware Platform Software, Software Version 7.1.070,
Alpha 7170
H3C Simware32
l rights reserved.
Management address : 192.168.1.55
Management address interface ID : Unknown
Port VLAN ID(PVID): 1
Port and protocol VLAN ID(PPVID) : 12
Port and protocol VLAN supported : Yes
Port and protocol VLAN enabled : Yes
VLAN name of VLAN 12: VLAN 0012
Link aggregation enabled : Yes
Aggregation port ID : 52
Management VLAN ID : 5
OperMau : Speed(1000)/Duplex(Full)
Power port class : PD
PSE power supported : Yes
PSE power enabled : Yes
PSE pairs control ability : Yes
Power type : Type 2 PD
Power source : PSE and local
Power priority : High
PD requested power value : 21.1 w
PSE allocated power value : 15.3 w
Congestion notification TLV info:
Dot1p CNPV Ready
0 Yes Yes
1 No No
2 No No
3 No No
4 Yes No
5 Yes Yes
6 No No
7 No No
Maximum frame size : 10000
Transmit Tw : 100 us
Receive Tw : 90 us
Fallback Tw : 90 us
MED information:
Media policy type : Unknown
Unknown policy : No
VLAN tagged : No
Media policy VLAN ID : 1000
Media policy L2 priority : 6
Media policy DSCP : 10
Location format : Civic Address LCI
Location information :
What(1) Country(CN)
CA type CA value
0 Chinese
1 Zhejiang
2 Hangzhou
MED port information:
Unknown policy : No
VLAN tagged : No
Media policy VLANID : 1000
Port PSE priority : Low
Port available power value : 2.2 w
Unknown basic TLV:
TLV type : 23
TLV information : 0x00140014
Unknown organizationally-defined TLV:
TLV OUI : 00-12-bb
TLV subtype : 21
Index : 1
TLV information : 0x556e6b6e 6f776e
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP概要信息。
LLDP neighbor-information of port 52[Ten-GigabitEthernet1/0/27]:
LLDP neighbor index : 3
ChassisID/subtype : 0011-2233-4400/MAC address
PortID/subtype : 000c-29f5-c71f/MAC address
Capabilities : Bridge, Router, Customer Bridge
LLDP neighbor index : 6
PortID/subtype : 000c-29f5-c715/MAC address
Capabilities : None
CDP neighbor-information of port 52[Ten-GigabitEthernet1/0/27]:
CDP neighbor index : 4
Chassis ID : SEP00260B5C0548
Port ID : Port 1
CDP neighbor index : 5
Chassis ID : 0011-2233-4400
Port ID : Ten-GigabitEthernet1/0/28
LLDP agent nearest-nontpmr:
Capabilities : None
# 按列表显示类型LLDP代理所有邻居设备发来的LLDP信息。
Chassis ID : * -- --Nearest nontpmr bridge neighbor
# -- --Nearest customer bridge neighbor
Default -- -- Nearest bridge neighbor
Local Interface Chassis ID Port ID System Name
XGE1/0/25 000f-e25d-ee91 Ten-GigabitEthernet1/0/25 System1
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP agent nearest-bridge |
LLDP缺省代理,即最近桥代理 |
LLDP agent nearest-customer |
LLDP最近客户桥代理 |
LLDP agent nearest-nontpmr |
LLDP最近非TPMR桥代理 |
LLDP neighbor-information of port 1 |
端口1上收到的LLDP邻居信息 |
LLDP Neighbor index |
邻居索引 |
Update time |
邻居信息最新更新时间 |
Chassis type |
Chassis ID类型: · Chassis component:表示底架组件 · Interface alias:表示接口别名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Locally assigned:表示邻居自定义 |
Chassis ID |
Chassis ID值,根据邻居设备的Chassis type取相应类型的值 |
Port ID type |
端口ID类型: · Interface alias:表示接口别名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network Address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Agent circuit ID:表示代理巡回标识 · Locally assigned:表示邻居自定义 |
Port ID |
端口ID值,根据邻居设备的Port ID type取相应类型的值 |
Time to live |
邻居信息在本地的存活时间 |
Port description |
端口描述 |
System name |
系统名称 |
系统描述 |
系统所支持的功能: · Repeater:表示支持信号中继功能 · Bridge:表示支持交换功能 · WlanAccessPoint:表示支持无线接入点功能 · Router:表示支持路由功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
系统已开启的功能: · Repeater:表示信号中继功能已开启 · Bridge:表示交换功能已开启 · WlanAccessPoint:表示无线接入点功能已开启 · Router:表示路由功能已开启 · Telephone:表示电话功能已开启 · DocsisCableDevice:表示电缆设备功能已开启 · StationOnly:表示只作站点功能已开启 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示不在上述列表的其它功能已开启 |
管理地址类型 |
管理地址 |
管理地址接口类型 |
管理地址接口索引 |
管理地址对象标识符 |
Port VLAN ID |
端口VLAN ID |
端口协议VLAN ID |
是否支持端口协议VLAN |
是否开启端口协议VLAN |
VLAN 12的名称 |
端口是否支持链路聚合 |
端口是否已开启链路聚合 |
管理VLAN ID |
端口是否支持自协商 |
端口是否已开启自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE:表示供电设备 · PD:表示受电设备 |
是否支持PSE供电 |
PSE power enabled |
是否已开启PSE供电 |
供电方式是否可控 |
Power pairs |
Power type |
Power source |
Power priority |
PD请求功率值,单位为瓦特 |
PSE分配功率值,单位为瓦特 |
拥塞通知TLV信息 |
Dot1p |
802.1p优先级 |
CNPV |
802.1p优先级是否被配置为CNPV,即是否匹配该优先级的报文具有QCN功能: · Yes:表示802.1p优先级被配置为CNPV · No:表示802.1p优先级未被配置为CNPV |
Ready |
端口支持的最大帧长度 |
MED information |
MED设备相关信息 |
Device class |
Media policy type |
Unknown policy |
VLAN tagged |
媒体VLAN是否带Tag |
Media policy VLAN ID |
媒体VLAN的VLAN ID |
二层优先级 |
Media policy DSCP |
DSCP的值 |
Location format |
位置信息 |
PoE service type |
PoE服务类型 |
Port PSE priority |
Port PD priority |
HardwareRev |
产品的硬件版本 |
FirmwareRev |
产品的固件版本 |
SoftwareRev |
产品的软件版本 |
SerialNum |
序列号 |
Manufacturer name |
制造厂商 |
Model name |
模块名称 |
资产跟踪ID |
Unknown basic TLV |
未知的基本TLV |
TLV type |
未知的基本TLV类型 |
TLV information |
未知的基本TLV的具体信息 |
Unknown organizationally-defined TLV |
未知组织定义TLV |
TLV OUI |
未知组织定义TLV的对象唯一标识 |
TLV subtype |
未知的组织定义TLV类型 |
Index |
未知组织的索引 |
CDP neighbor-information of port 1 |
(暂不支持)端口1的CDP邻居信息 |
CDP neighbor index |
(暂不支持)CDP邻居索引 |
Chassis ID/subtype |
Chassis ID值及Chassis ID类型 |
Port ID/subtype |
Port ID值及PortID类型 |
Software version |
邻居软件版本 |
Platform version |
邻居平台版本 |
Duplex |
双工状态 |
Capabilities |
系统已开启的功能: · Repeater:表示开启信号中继功能 · Bridge:表示开启交换功能 · WlanAccessPoint:表示开启无线接入点功能 · Router:表示开启路由功能 · Telephone:表示开启电话功能 · DocsisCableDevice:表示开启电缆设备功能 · StationOnly:表示开启只作站点功能,与其他功能不能同时出现 · Other:表示开启不在上述列表的其他功能 · None:表示该邻居未发布该TLV |
Local Interface |
接收LLDP信息的本端端口 |
Chassis ID : * -- -- Nearest nontpmr bridge neighbor #-- -- Nearest customer bridge neighbor |
*符号:表示该邻居是最近非TPMR桥代理类型邻居 #符号:表示该邻居是最近客户桥代理类型邻居 |
Transmit Tw |
本端发送的等待时间,单位为微秒 |
Receive Tw |
Fallback Tw |
Echo Transmit Tw |
Echo Receive Tw |
display lldp statistics命令用来显示LLDP的统计信息。
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
agent:显示指定类型LLDP代理的统计信息。如果未指定该参数,将显示所有类型LLDP代理的统计信息。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted : 1
The number of LLDP neighbor information dropped : 0
LLDP statistics information of port 1 [Ten-GigabitEthernet1/0/25]:
The number of LLDP frames transmitted : 0
The number of LLDP frames received : 0
The number of LLDP frames discarded : 0
The number of LLDP error frames : 0
The number of LLDP TLVs discarded : 0
The number of LLDP TLVs unrecognized : 0
The number of CDP frames transmitted : 0
The number of CDP frames received : 0
The number of CDP frames discarded : 0
The number of CDP error frames : 0
LLDP agent nearest-customer:
# 显示接口Ten-GigabitEthernet1/0/25的最近客户桥代理上的LLDP统计信息。
<Sysname> display lldp statistics interface ten-gigabitethernet 1/0/25 agent nearest-customer
表1-3 display lldp statistics命令显示信息描述表
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
LLDP statistics global information |
全局LLDP统计信息 |
LLDP neighbor information last change time |
邻居信息的最后更新时间 |
The number of LLDP neighbor information inserted |
邻居信息的增加次数 |
The number of LLDP neighbor information deleted |
邻居信息的删除次数 |
The number of LLDP neighbor information dropped |
由于空间不足而导致丢弃邻居信息的次数 |
The number of LLDP neighbor information aged out |
邻居信息的老化数量 |
LLDP statistics Information of port 1 |
端口1上的LLDP统计信息 |
The number of LLDP frames transmitted |
发送的LLDP帧总数 |
The number of LLDP frames received |
收到的LLDP帧总数 |
The number of LLDP frames discarded |
丢弃的LLDP帧总数 |
The number of LLDP error frames |
收到的错误LLDP帧总数 |
The number of LLDP TLVs discarded |
丢弃的LLDP TLV总数 |
The number of LLDP TLVs unrecognized |
不可识别的LLDP TLV总数 |
老化的LLDP邻居信息总数 |
The number of CDP frames transmitted |
(暂不支持)发送的CDP帧总数 |
The number of CDP frames received |
(暂不支持)收到的CDP帧总数 |
The number of CDP frames discarded |
(暂不支持)丢弃的CDP帧总数 |
The number of CDP error frames |
(暂不支持)收到的错误CDP帧总数 |
display lldp status命令用来显示LLDP的状态信息。
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有开启了LLDP功能的接口上的LLDP状态信息。
agent:显示指定类型LLDP代理的状态信息。如果未指定该参数,将显示所有类型LLDP代理的状态信息。
# 显示全局和所有接口上的LLDP状态信息。
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 5
Transmit interval : 30s
Fast transmit interval : 1s
Transmit max credit : 5
Hold multiplier : 4
Reinit delay : 2s
Trap interval : 5s
Fast start times : 3
LLDP status information of port 1 [Ten-GigabitEthernet1/0/25]:
Port status of LLDP : Enable
Admin status : TX_RX
Trap flag : No
MED trap flag : No
Polling interval : 0s
Number of LLDP neighbors : 5
Number of MED neighbors : 2
Number of CDP neighbors : 0
Number of sent optional TLV : 12
Neighbor protection status : Port not protected
Trap flag : No
MED trap flag : No
Trap flag : No
MED trap flag : No
表1-4 display lldp status命令显示信息描述表
Bridge mode of LLDP |
LLDP桥模式: · service-bridge:表示服务桥模式 · customer-bridge:表示客户桥模式 |
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
Global status of LLDP |
LLDP功能是否已全局开启 |
The current number of LLDP neighbors |
当前设备的LLDP邻居总数 |
The current number of CDP neighbors |
(暂不支持)当前设备的CDP邻居总数 |
LLDP neighbor information last changed time |
邻居信息的最后更新时间 |
Transmit interval |
LLDP报文的发送间隔 |
Hold multiplier |
TTL乘数 |
Reinit delay |
端口初始化延迟时间 |
Transmit max credit |
LLDP报文发包限速令牌桶的最大值 |
Trap interval |
Trap信息的发送间隔 |
Fast start times |
快速发送LLDP报文的个数 |
LLDP status infomation of port 1 |
端口1上的LLDP状态信息 |
Port status of LLDP |
LLDP功能是否已在端口上开启 |
Admin status |
端口LLDP工作模式: · TX_RX:表示既发送也接收LLDP报文 · Rx_Only:表示只接收不发送LLDP报文 · Tx_Only:表示只发送不接收LLDP报文 · Disable:表示既不发送也不接收LLDP报文 |
Trap Flag |
LLDP Trap功能是否已开启 |
MED trap flag |
LLDP-MED Trap功能是否已开启 |
Polling interval |
轮询间隔,0表示轮询功能处于关闭状态 |
Number of neighbors |
端口LLDP邻居数量 |
Number of MED neighbors |
端口MED邻居设备的数量 |
Number of CDP neighbors |
(暂不支持)端口CDP邻居设备的数量 |
Number of sent optional TLV |
端口在一个LLDP报文中发送的可选TLV总数 |
Number of received unknown TLV |
端口在所有LLDP报文中收到的不能识别的TLV总数 |
Neighbor protection status |
端口邻居保护状态: · Port blocked (validation):表示端口阻塞,阻塞原因是邻居识别信息不一致 · Port blocked (aging):表示端口阻塞,阻塞原因是邻居老化超时 · Port shutdown (aging):表示端口关闭,关闭原因是邻居老化超时 · Port not protected:表示端口未保护 |
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
agent:显示指定类型LLDP代理的可选TLV信息。如果未指定该参数,将显示所有类型LLDP代理的可选TLV信息。
# 显示接口Ten-GigabitEthernet1/0/25上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface ten-gigabitethernet 1/0/25
LLDP tlv-config of port 1[Ten-GigabitEthernet1/0/25]:
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES YES
System Name TLV YES YES
System Description TLV YES YES
System Capabilities TLV YES YES
Management Address TLV YES YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV YES YES
Port And Protocol VLAN ID TLV NO NO
VLAN Name TLV NO NO
DCBX TLV NO NO
Link Aggregation TLV YES YES
Management VID TLV NO NO
IEEE 802.3 extend TLV:
MAC-Physic TLV YES YES
Power via MDI TLV YES YES
Maximum Frame Size TLV YES YES
LLDP-MED extend TLV:
Location Identification TLV NO NO
Extended Power via MDI TLV YES YES
Inventory TLV YES YES
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV NO NO
System Name TLV NO NO
System Description TLV NO NO
System Capabilities TLV NO NO
Management Address TLV NO NO
Port VLAN ID TLV NO NO
VLAN Name TLV NO NO
DCBX TLV NO NO
Link Aggregation TLV NO NO
MAC-Physic TLV NO NO
Power via MDI TLV NO NO
Maximum Frame Size TLV NO NO
Extended Power via MDI TLV NO NO
Inventory TLV NO NO
NAME STATUS DEFAULT
Basic optional TLV:
VLAN Name TLV NO NO
DCBX TLV NO NO
Inventory TLV NO NO
表1-5 display lldp tlv-config命令显示信息描述表
LLDP 缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
LLDP tlv-config of port 1 |
端口1上可发送的可选TLV类型 |
NAME |
TLV类型 |
STATUS |
端口是否配置发布指定类型TLV |
DEFAULT |
端口发布指定类型TLV的缺省情况 |
Basic optional TLV |
端口可以发送的基本TLV类型 |
Port Description TLV |
端口描述TLV |
System Name TLV |
系统名称TLV |
System Description TLV |
系统描述TLV |
System Capabilities TLV |
系统能力集TLV |
Management Address TLV |
管理地址TLV |
Congestion notification TLV |
拥塞通知TLV |
IEEE 802.1 extended TLV |
端口可发送的IEEE 802.1组织定义的TLV类型 |
Port VLAN ID TLV |
端口VLAN ID TLV |
Port And Protocol VLAN ID TLV |
协议VLAN ID TLV |
VLAN Name TLV |
VLAN名称TLV |
DCBX TLV |
DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV |
EVB TLV |
EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV |
Management VID TLV |
管理VLAN TLV |
IEEE 802.3 extended TLV |
端口可发送的IEEE 802.3组织定义的TLV类型 |
MAC-Physic TLV |
端口物理属性TLV |
Power via MDI TLV |
供电能力TLV |
Link Aggregation TLV |
链路聚合TLV |
Maximum Frame Size TLV |
最大帧长度TLV |
LLDP-MED extend TLV |
LLDP-MED TLV |
Capabilities TLV |
MED能力集TLV |
Network Policy TLV |
网络策略TLV |
Location Identification TLV |
位置标识TLV |
Extended Power via MDI TLV |
扩展供电能力TLV |
Inventory TLV |
资产信息TLV,包括以下几种: · Hardware Revision TLV:终端设备硬件版本 · Firmware Revision TLV:终端设备固件版本 · Software Revision TLV:终端设备软件版本 · Serial Number TLV:终端设备序列号 · Manufacturer Name TLV:终端设备的制造厂商名称 · Model name TLV:终端设备的模块名称 · Asset ID TLV:终端设备的资产标识符,以便目录管理和资产跟踪 |
Energy-Efficient Ethernet TLV |
节能以太网TLV |
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
在二层以太网接口视图/管理以太网接口视图下:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
LLDP最近桥代理的工作模式为TxRx,既发送也接收LLDP报文。其他类型的LLDP代理的工作模式为Disable,即不发送也不接收LLDP报文。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:配置指定类型LLDP代理的工作模式。在以太网接口视图/管理以太网接口视图下,未指定时表示配置最近桥代理的工作模式。
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口Ten-GigabitEthernet1/0/25上最近客户桥代理LLDP的工作模式为Rx。
[Sysname] interface ten-gigabitethernet 1/0/25
[Sysname-Ten-GigabitEthernet1/0/25] lldp agent nearest-customer admin-status rx
lldp check-change-interval命令用来开启轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
轮询功能处于关闭状态。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:配置指定类型LLDP代理的轮询功能。在以太网接口视图/管理以太网接口视图下,未指定时表示配置最近桥代理的轮询功能。
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口Ten-GigabitEthernet1/0/25的最近客户桥代理上开启轮询功能,并配置轮询间隔为30秒。
[Sysname-Ten-GigabitEthernet1/0/25] lldp agent nearest-customer check-change-interval 30
lldp enable命令用来在接口上开启LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
lldp enable
undo lldp enable
接口上的LLDP功能处于开启状态。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
只有当全局和接口上都开启了LLDP功能后,该功能才会生效。
# 在接口Ten-GigabitEthernet1/0/25上关闭LLDP功能。
[Sysname-Ten-GigabitEthernet1/0/25] undo lldp enable
· lldp global enable
lldp encapsulation snap命令用来配置LLDP报文的封装格式为SNAP格式。
undo lldp encapsulation命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
LLDP报文的封装格式为Ethernet II格式。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:配置指定类型LLDP代理的封装格式。在以太网接口视图/管理以太网接口视图下,未指定时表示配置最近桥代理的封装格式。
携带EVB模块TLV的LLDP报文不能通过SNAP格式封装和发送。
# 配置接口Ten-GigabitEthernet1/0/25上发送的LLDP报文的封装格式为SNAP格式。
[Sysname-Ten-GigabitEthernet1/0/25] lldp encapsulation snap
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
lldp fast-count count
快速发送LLDP报文的个数为4个。
count:表示快速发送LLDP报文的个数,取值范围为1~8。
# 配置快速发送LLDP报文的个数为5个。
[Sysname] lldp fast-count 5
lldp global enable命令用来全局开启LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
lldp global enable
LLDP功能的全局状态为关闭。
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
· lldp enable
lldp global tlv-enable basic-tlv management-address-tlv命令用来配置全局允许在LLDP报文中发布管理地址并配置所发布的管理地址。
undo lldp global tlv-enable basic-tlv management-address-tlv命令用来恢复缺省情况。
lldp [ agent { nearest-customer | nearest-nontpmr } ] global tlv-enable basic-tlv management-address-tlv [ ipv6 ] { ip-address | interface loopback interface-number | interface m-gigabitethernet interface-number | interface vlan-interface interface-number }
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] global tlv-enable basic-tlv management-address-tlv
全局不允许在LLDP报文中发布管理地址TLV。
agent:配置指定类型LLDP代理允许发布的TLV类型。未指定本参数时,表示配置最近桥代理允许发布的TLV类型。
ipv6:表示LLDP报文中所要发布的管理地址为IPv6格式的地址,当未指定本参数时,表示LLDP报文中所要发布的管理地址为IPv4格式的地址。
ip-address:表示在LLDP报文中发布的管理地址为指定的IP地址。
interface loopback interface-number:表示在LLDP报文中发布的管理地址为指定的LoopBack接口的IP地址。interface-number表示LoopBack接口的编号。interface-number的取值范围为0~1023。
interface m-gigabitethernet interface-number:表示在LLDP报文中发布的管理地址为指定的M-GigabitEthernet接口的IP地址。interface-number表示M-GigabitEthernet接口的编号。
interface vlan-interface interface-number:表示在LLDP报文中发布的管理地址为指定的VLAN接口的IP地址。interface-number表示VLAN接口的编号,取值范围为1~4094。
多次执行本命令,最后一次执行的命令生效。
允许发布的管理地址TLV支持全局配置或在接口上配置两种方式:全局的配置对所有接口都有效,而接口上的配置只对当前接口有效。对于一个接口来说,优先采用该接口上的配置,只有该接口上未进行配置时,才采用全局的配置。当全局和接口下都未配置时,会采用接口下的缺省配置。
在满足如下条件的情况下,系统会将当前发送LLDP报文接口的IPv4/IPv6地址发布为管理地址:
· ip-address参数未指定。
· 指定的LoopBack、M-GigabitEthernet接口或VLAN接口不存在或接口未配置IPv4/IPv6地址。
此时,如果当前发送LLDP报文的接口未配置IPv4/IPv6地址,则发布的管理地址为固定MAC地址000f-e207-f2e0。
如果指定了ipv6参数,则发布的管理地址为IPv6地址。如果未指定ipv6参数,则发布的管理地址为IPv4地址。
# 配置全局最近客户桥代理允许发布的Management Address TLV。
[Sysname] lldp agent nearest-customer global tlv-enable basic-tlv management-address-tlv 192.168.1.1
· lldp tlv-enable
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
lldp hold-multiplier value
TTL乘数为4。
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔+1)),即取65535与(TTL乘数×LLDP报文的发送间隔+1)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
· lldp timer tx-interval
lldp ignore-pvid-inconsistency命令用来关闭LLDP的PVID不一致检查功能。
undo lldp ignore-pvid-inconsistency命令用来开启LLDP的PVID不一致检查功能。
LLDP的PVID不一致检查功能处于开启状态。
缺省情况下,LLDP会对接口接收报文中的PVID TLV进行检查,如果发现报文中PVID与本端不一致,LLDP会打印日志信息,提示用户。但在一些特殊情况下,可以允许链路两端的PVID配置不一致,此时可以关闭LLDP的PVID不一致性检查功能。
# 关闭LLDP的PVID不一致检查功能。
[Sysname] lldp ignore-pvid-inconsistency
lldp management-address命令用来配置接口收到携带Management Address TLV的LLDP报文后生成ARP表项或ND表项。
undo lldp management-address命令用来恢复缺省情况。
lldp management-address { arp-learning | nd-learning } vlan vlan-id
undo lldp management-address { arp-learning | nd-learning }
接口收到携带Management Address TLV的LLDP报文后不生成ARP表项和ND表项。
二层以太网接口视图
arp-learning:表示接口收到携带IPv4格式Management Address TLV的LLDP报文后,会生成该报文携带的管理地址与报文源MAC地址组成的ARP表项。
nd-learning:表示接口收到携带IPv6格式Management Address TLV的LLDP报文后,会生成该报文携带的管理地址与报文源MAC地址组成的ND表项。
vlan vlan-id:指定该接口所属VLAN的VLAN ID,且已创建该VLAN对应的VLAN接口,取值范围为1~4094。
ARP表项和ND表项的生成互不影响,可同时配置。
配置本命令时,需要同时配置lldp source-mac vlan命令,以保证设备发送报文的MAC为VLAN接口的MAC地址,而不是端口的MAC地址,确保对端学习到正确的ARP/ND表项。
# 配置接口Ten-GigabitEthernet1/0/25收到携带IPv4格式Management Address TLV的LLDP报文后,生成ARP表项。
[Sysname-Ten-GigabitEthernet1/0/25] lldp management-address arp-learning
· lldp source-mac vlan
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
管理地址在TLV中的封装格式为数字格式。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:配置指定LLDP代理类型管理地址在TLV中的封装格式。在以太网接口视图/管理以太网接口视图下,未指定时表示配置最近桥代理的管理地址在TLV中的封装格式。
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
对于LLDP报文中所要发布的IPv6格式的管理地址,仅支持数字格式的封装格式。
# 在接口Ten-GigabitEthernet1/0/25的最近客户桥代理上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-Ten-GigabitEthernet1/0/25] lldp agent nearest-customer management-address-format string
lldp max-credit命令用来配置限制发送报文速率的令牌桶大小。
undo lldp max-credit命令用来恢复缺省情况。
lldp max-credit credit-value
限制发送报文速率的令牌桶大小为5。
credit-value:表示LLDP发包限速的令牌桶大小,取值范围1~100。
# 配置LLDP发包限速的令牌桶大小为10。
[Sysname] lldp max-credit 10
lldp mode命令用来配置LLDP桥模式。
undo lldp mode命令用来恢复缺省情况。
lldp mode service-bridge
undo lldp mode
LLDP桥模式为客户桥模式。
service-bridge:表示服务桥模式。
LLDP桥模式命令用于控制设备支持不同的LLDP代理。
· 工作于服务桥模式时,设备可支持最近桥代理和最近非TPMR桥代理,即对上述类型的代理MAC的LLDP报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
· 工作于客户桥模式时,设备可支持最近桥代理、最近非TPMR桥代理及最近客户桥代理,即对上述类型的代理MAC的LLDP报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
桥模式配置只在LLDP全局开启后才能生效,LLDP全局关闭时,只能作为客户桥对三种类型代理MAC的LLDP报文进行拦截。
# 配置LLDP桥模式为服务桥模式。
[Sysname] lldp mode service-bridge
lldp notification med-topology-change enable命令用来开启LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图
管理以太网接口视图
# 在接口Ten-GigabitEthernet1/0/25上开启LLDP-MED Trap功能。
[Sysname-Ten-GigabitEthernet1/0/25] lldp notification med-topology-change enable
lldp notification remote-change enable命令用来开启LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP Trap功能处于关闭状态。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:开启指定类型LLDP代理的LLDP Trap功能。在以太网接口视图/管理以太网接口视图下,未指定时表示开启最近桥代理类型LLDP代理的LLDP Trap功能。
# 在接口Ten-GigabitEthernet1/0/25最近客户桥代理上开启LLDP Trap功能。
[Sysname-Ten-GigabitEthernet1/0/25] lldp agent nearest-customer notification remote-change enable
lldp source-mac vlan命令用来配置发送的LLDP报文源MAC地址为VLAN接口的MAC地址。
undo lldp source-mac vlan命令用来恢复缺省情况。
lldp source-mac vlan vlan-id
LLDP报文源MAC地址为主接口的MAC地址。
二层以太网接口视图
vlan-id:指定该接口所属的VLAN的VLAN ID,且已创建该VLAN对应的VLAN接口,取值范围为1~4094。
本命令用来配合lldp management-address arp-learning命令使用,以保证设备发送报文的MAC为VLAN接口的MAC地址,而不是端口的MAC地址,确保对端学习到正确的ARP/ND表项。
# 配置LLDP报文源MAC地址为指定二层以太网接口所属VLAN的VLAN接口的MAC地址。
[Sysname-Ten-GigabitEthernet1/0/25] lldp source-mac vlan 4094
· lldp management-address arp-learning
lldp timer fast-interval命令用来配置LLDP快速发送报文的时间间隔。
undo lldp timer fast-interval命令用来恢复缺省情况。
LLDP快速发送报文的时间间隔为1秒。
interval:表示LLDP快速发送报文的时间间隔,取值范围为1~3600,单位为秒。
# 配置LLDP快速发送报文的时间间隔为2秒。
[Sysname] lldp timer fast-interval 2
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为30秒。
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
lldp timer reinit-delay delay
接口初始化的延迟时间为2秒。
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
interval:表示LLDP报文的发送间隔,取值范围为1~32768,单位为秒。
# 配置LLDP报文的发送间隔为20秒。
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
在二层以太网接口视图下:
· 配置最近桥代理LLDP接口上允许发布的TLV类型
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
· 配置最近非TPMR代理LLDP接口上允许发布的TLV类型
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } | dot3-tlv { all | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } | dot3-tlv { all | link-aggregation } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
· 配置最近客户桥代理LLDP接口上允许发布的TLV类型
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } | dot3-tlv { all | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } | dot3-tlv { all | link-aggregation } }
在管理以太网接口视图下:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | link-aggregation } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | link-aggregation | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ipv6 ] [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | link-aggregation } }
在二层聚合接口视图下:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ipv6 ] [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
二层以太网接口上:
· 最近桥代理允许发布基本TLV、IEEE 802.1组织定义TLV(只支持Port VLAN ID TLV和Link Aggregation TLV)、IEEE 802.3组织定义TLV(不包括Link Aggregation TLV)、LLDP-MED TLV(不包括Location Identification TLV);
· 最近非TPMR桥代理不发布任何TLV;
· 最近客户桥代理允许发布基本TLV、Port VLAN ID TLV和Link Aggregation TLV。
管理以太网接口上:
· 最近桥代理允许发布基本TLV、IEEE 802.1组织定义TLV(只支持Link Aggregation TLV )、IEEE 802.3组织定义TLV(不包括Link Aggregation TLV)、LLDP-MED TLV(不包括Network Policy TLV和Location Identification TLV);
· 最近客户桥代理允许发布基本TLV和Link Aggregation TLV。
二层聚合接口上:
· 最近客户桥代理允许发布基本TLV和Port VLAN ID TLV。
二层以太网接口视图
管理以太网接口视图
二层聚合接口视图
agent:配置指定类型LLDP代理允许发布的TLV类型。在以太网接口视图/管理以太网接口视图下,未指定时表示配置最近桥代理允许发布的TLV类型。
all:发布指定类型的所有可选TLV:
¡ 如果为basic-tlv参数指定all,则允许发布所有基本TLV。
¡ 如果为dot1-tlv参数指定all,则允许发布所有802.1组织定义TLV。
¡ 如果为dot3-tlv参数指定all,则允许发布所有802.3组织定义TLV。
¡ 如果为med-tlv参数指定all,则允许发布除location-id以外所有的可选LLDP-MED TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ipv6 ] [ ip-address | interface loopback interface-number ]:表示Management Address TLV。其中,ipv6表示LLDP报文中所要发布的管理地址为IPv6格式的地址。ip-address表示在LLDP报文中发布的管理地址为指定的IP地址,interface loopback interface-number表示在LLDP报文中发布的管理地址为指定的LoopBack接口的IP地址。其缺省值如下:
· 执行lldp tlv-enable命令时:
¡ 在二层以太网接口视图下,如果ip-address参数未指定,或指定的LoopBack接口不存在或LoopBack接口没有配置IPv4/IPv6地址,则发布的管理地址为当前接口允许通过的、对应VLAN接口上配置有IPv4/IPv6地址且处于up状态的最小VLAN的IPv4/IPv6地址。
如果指定了ipv6参数,则发布的管理地址为IPv6地址。如果未指定ipv6参数,则发布的管理地址为对应VLAN接口的IP地址(包括IPv4地址和IPv6地址)。
如果当前接口允许通过的所有VLAN所对应的VLAN接口上都未配置IPv4/IPv6地址或均处于down状态,则发布固定MAC地址000f-e207-f2e0。
¡ 在二层聚合接口视图下,如果ip-address参数未指定,则发布的管理地址为当前接口允许通过的、对应VLAN接口上配置有IPv4/IPv6地址且处于up状态的最小VLAN的IPv4/IPv6地址。
¡ 管理以太网接口视图下,如果ip-address参数未指定,发布的管理地址为当前发送LLDP报文接口的IPv4/IPv6地址。
如果当前接口未配置IPv4/IPv6地址,则发布固定MAC地址000f-e207-f2e0。
· 执行undo lldp tlv-enable命令时:
如果不带ipv6、ip-address和interface loopback interface-number参数表示不发布该TLV;
如果带ipv6、ip-address和interface loopback interface-number参数表示按缺省值发布该TLV。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。如果未指定vlan-id,且端口未加入任何VLAN,所要发布的VLAN为该端口PVID。
management-vid [ mvlan-id ]:表示Management VLAN ID TLV。mvlan-id指定要发布管理VLAN的VLAN ID,取值范围为1~4094。如果未指定该参数,则表示发布0,表示当前LLDP agent未配置管理VLAN。
link-aggregation:表示Link Aggregation TLV。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Network device,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy [ vlan-id ]:表示Network Policy TLV,vlan-id为要发布的Voice VLAN ID,取值范围为1~4094。
power-over-ethernet:表示Extended Power-via-MDI TLV。
聚合接口不支持最近桥代理。
在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
IEEE 802.1组织定义的TLV的Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV只能基于最近桥代理配置,但是其配置会被最近非TPMR桥代理和最近客户桥代理继承。
# 配置接口Ten-GigabitEthernet1/0/25上最近客户桥代理允许发布IEEE 802.1组织定义的Link Aggregation可选TLV。
[Sysname-Ten-GigabitEthernet1/0/25] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
reset lldp statistics命令用来清除接口上的LLDP统计信息。
reset lldp statistics [ interface interface-type interface number ] [ agent { nearest-bridge | nearest-customer | nearest-nontpmr } ]
interface interface-type interface-number:清除指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,则清除所有接口的LLDP统计信息。
agent:清除指定类型LLDP代理的统计信息。如果未指定该参数,将清除所有类型LLDP代理的统计信息。
如果未指定任何参数,将清除所有接口上的LLDP统计信息,但不会清除全局LLDP统计信息。
# 清除所有接口上的LLDP统计信息。
<Sysname> reset lldp statistics
· display lldp statistics
