10-安全命令参考
08-攻击检测与防范命令
本章节下载 08-攻击检测与防范命令  (495.47 KB)
08-攻击检测与防范命令
  录
1 攻击检测与防范
1.1 攻击检测与防范配置命令
1.1.1 ack-flood action
1.1.2 ack-flood detect
1.1.3 ack-flood detect non-specific
1.1.4 ack-flood threshold
1.1.5 attack-defense local apply policy
1.1.6 attack-defense login reauthentication-delay
1.1.7 attack-defense policy
1.1.8 attack-defense signature log non-aggregate
1.1.9 attack-defense tcp fragment enable
1.1.10 display attack-defense flood statistics ip
1.1.11 display attack-defense flood statistics ipv6
1.1.12 display attack-defense policy
1.1.13 display attack-defense policy ip
1.1.14 display attack-defense policy ipv6
1.1.15 display attack-defense scan attacker ip
1.1.16 display attack-defense scan attacker ipv6
1.1.17 display attack-defense scan victim ip
1.1.18 display attack-defense scan victim ipv6
1.1.19 display attack-defense statistics local
1.1.20 dns-flood action
1.1.21 dns-flood detect
1.1.22 dns-flood detect non-specific
1.1.23 dns-flood port
1.1.24 dns-flood threshold
1.1.25 exempt acl
1.1.26 fin-flood action
1.1.27 fin-flood detect
1.1.28 fin-flood detect non-specific
1.1.29 fin-flood threshold
1.1.30 http-flood action
1.1.31 http-flood detect
1.1.32 http-flood detect non-specific
1.1.33 http-flood port
1.1.34 http-flood threshold
1.1.35 icmp-flood action
1.1.36 icmp-flood detect ip
1.1.37 icmp-flood detect non-specific
1.1.38 icmp-flood threshold
1.1.39 icmpv6-flood action
1.1.40 icmpv6-flood detect ipv6
1.1.41 icmpv6-flood detect non-specific
1.1.42 icmpv6-flood threshold
1.1.43 reset attack-defense policy flood
1.1.44 reset attack-defense statistics local
1.1.45 rst-flood action
1.1.46 rst-flood detect
1.1.47 rst-flood detect non-specific
1.1.48 rst-flood threshold
1.1.49 scan detect
1.1.50 signature { large-icmp | large-icmpv6 } max-length
1.1.51 signature detect
1.1.52 signature level action
1.1.53 signature level detect
1.1.54 syn-ack-flood action
1.1.55 syn-ack-flood detect
1.1.56 syn-ack-flood detect non-specific
1.1.57 syn-ack-flood threshold
1.1.58 syn-flood action
1.1.59 syn-flood detect
1.1.60 syn-flood detect non-specific
1.1.61 syn-flood threshold
1.1.62 udp-flood action
1.1.63 udp-flood detect
1.1.64 udp-flood detect non-specific
1.1.65 udp-flood threshold
1 攻击检测与防范
1.1  攻击检测与防范配置命令
ack-flood action命令用来配置ACK flood攻击防范的全局处理行为。
undo ack-flood action命令用来恢复缺省情况。
ack-flood action { drop | logging } *
不对检测到的ACK flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ACK报文都会被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] ack-flood action drop
·     ack-flood threshold
·     ack-flood detect
·     ack-flood detect non-specific
ack-flood detect命令用来开启对指定IP地址的ACK flood攻击防范检测,并配置ACK flood攻击防范的触发阈值和对ACK flood攻击的处理行为。
undo ack-flood detect命令用来关闭对指定IP地址的ACK flood攻击防范检测。
ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为全1地址或全0地址。
ipv6 ipv6-address:指定要保护的IPv6地址。
vpn-instance vpn-instance-name:受保护IP地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该保护IP地址属于公网。
threshold threshold-value:指定ACK flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ACK报文数目,取值范围为1~1000000。
action:设置对ACK flood攻击的处理行为。若未指定本参数,则表示采用ACK flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置ACK flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ACK报文数持续达到或超过2000时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect ip 192.168.1.2 threshold 2000
·     ack-flood action
ack-flood detect non-specific命令用来对所有非受保护IP地址开启ACK flood攻击防范检测。
undo ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的ACK flood攻击防范检测。
未对任何非受保护IP地址开启ACK flood攻击防范检测。
攻击防范策略视图
对所有未配置具体攻击防范策略的IP地址开启ACK flood攻击防范检测后,设备将采用全局的阈值设置(由ack-flood threshold命令设置)和处理行为(由ack-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启ACK flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood detect non-specific
·     ack-flood action
·     ack-flood detect
ack-flood threshold命令用来配置ACK flood攻击防范的全局触发阈值。
undo ack-flood threshold命令用来恢复缺省情况。
ack-flood threshold threshold-value
ACK flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ACK报文数目,取值范围为1~1000000。
使能ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ACK报文数持续达到或超过100时,启动ACK flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] ack-flood threshold 100
·     ack-flood action
·     ack-flood detect
attack-defense local apply policy命令用来在本机应用安全攻击防范策略。
undo attack-defense local apply policy命令用来恢复缺省情况。
attack-defense local apply policy policy-name
本机未应用任何攻击防范策略。
policy-name:攻击防范策略名称,为1~31个字符的字符串,不区分大小写。合法取值包括大写字母、小写字母、数字、特殊字符“_”和“-”。
通过在本机应用攻击防范策略,使已配置的攻击防范策略对目的地址为本机的报文生效。
缺省情况下设备将需要转发的报文下发给硬件转发,只有目的地址是本机的报文才会由软件处理,但软件没有攻击防范功能。为处理针对本机的攻击,需要通过在本机上应用攻击防范策略来实现。
本机只能应用一个攻击防范策略(可多次配置,最后一次配置的有效)。
# 在本机应用攻击防范策略atk-policy-1。
[Sysname] attack-defense local apply policy atk-policy-1
·     attack-defense policy
·     display attack-defense policy
attack-defense login reauthentication-delay命令用来配置Login用户登录失败后重新进行认证的等待时长。
undo attack-defense login reauthentication-delay命令用来恢复缺省情况。
attack-defense login reauthentication-delay seconds
Login用户登录失败后重新进行认证不需要等待。
seconds:设备管理用户登录失败后重新进行认证的等待时长,取值范围为4~60,单位为秒。
Login用户登录失败后,若设备上配置了重新进行认证的等待时长,则系统将会延迟一定的时长之后再允许用户进行认证,可以避免设备受到字典式攻击。
# 配置Login用户登录失败后重新进行认证的等待时长为5秒钟。
[Sysname] attack-defense login reauthentication-delay 5
attack-defense policy命令用来创建一个攻击防范策略,并进入攻击防范策略视图。如果指定的攻击防范策略已经存在,则直接进入攻击防范策略视图。
undo attack-defense policy命令用来删除指定的攻击防范策略。
attack-defense policy policy-name
undo attack-defense policy policy-name
不存在任何攻击防范策略。
# 创建攻击防范策略atk-policy-1,并进入攻击防范策略视图。
attack-defense signature log non-aggregate命令用来指定对单包攻击防范日志非聚合输出。
undo attack-defense signature log non-aggregate命令用来恢复缺省情况。
单包攻击防范的日志信息经系统聚合后再输出。
对日志进行聚合输出是指,在一定时间内,对在本机上检测到的相同攻击类型、相同攻击防范动作、相同的源/目的地址以及属于相同VPN的单包攻击的所有日志聚合成一条日志输出。通常不建议开启单包攻击防范的日志非聚合输出功能,因为在单包攻击较为频繁的情况下,它会导致大量日志信息输出,占用控制台的显示资源。
# 开启对单包攻击防范日志的非聚合输出功能。
[Sysname] attack-defense signature log non-aggregate
·     signature detect
attack-defense tcp fragment enable命令用来开启TCP分片攻击防范功能。
undo attack-defense tcp fragment enable命令用来关闭TCP分片攻击防范功能。
TCP分片攻击防范功能处于开启状态。
设备的包过滤功能一般是通过判断TCP首个分片中的五元组(源IP地址、源端口号、目的IP地址、目的端口号、传输层协议号)信息来决定后续TCP分片是否允许通过。RFC 1858对TCP分片报文进行了规定,认为TCP分片报文中,首片报文中TCP报文长度小于20字节,或后续分片报文中分片偏移量等于8字节的报文为TCP分片攻击报文。这类报文可以成功绕过上述包过滤功能,对设备造成攻击。为防止这类攻击,可以在设备上开启TCP分片攻击防范功能,对TCP分片攻击报文进行丢弃。
如果设备上开启了TCP分片攻击防范功能,并应用了单包攻击防范策略,则TCP分片攻击防范功能会先于单包攻击防范策略检测并处理入方向的TCP报文。
# 开启TCP分片攻击防范功能。
[Sysname] attack-defense tcp fragment enable
display attack-defense flood statistics ip命令用来显示IPv4 flood攻击防范统计信息。
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } statistics ip [ ip-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
ack-flood:显示ACK flood攻击防范统计信息。
dns-flood:显示DNS flood攻击防范统计信息。
fin-flood:显示FIN flood攻击防范统计信息。
flood:显示所有类型的IPv4 flood攻击防范统计信息。
http-flood:显示HTTP flood攻击防范统计信息。
icmp-flood:显示ICMP flood攻击防范统计信息。
rst-flood:显示RST flood攻击防范统计信息。
syn-ack-flood:显示SYN-ACK flood攻击防范统计信息。
syn-flood:显示SYN flood攻击防范统计信息。
udp-flood:显示UDP flood攻击防范统计信息。
ip-address:显示指定目的IPv4地址的flood攻击防范统计信息。若未指定本参数,则显示所有目的IPv4地址的flood攻击防范统计信息。
vpn-instance vpn-instance-name:指定IPv4地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该IPv4地址属于公网。
interface interface-type interface-number:显示指定接口的flood攻击防范统计信息,interface-type interface-number表示接口类型和接口编号。
local:显示本机上进行检测的flood攻击防范统计信息。
slot slot-number:显示指定成员设备上的flood攻击防范统计信息,slot-number表示设备在IRF中的成员编号。该参数仅在指定本机或指定全局接口(例如VLAN接口、Tunnel接口)时可见。若未指定本参数,则表示显示所有成员设备上的flood攻击防范统计信息。
count:显示符合指定条件的被进行flood攻击检测的IPv4地址数目。
由于flood攻击不关心源地址,因此本命令显示的是对指定目的IPv4地址的攻击防范统计信息。
若未指定interfacelocal参数,则显示本机上的flood攻击防范统计信息。
# 显示所有类型的IPv4 flood攻击防范统计信息。
<Sysname> display attack-defense flood statistics ip
slot 1:
IP address      VPN         Detected on  Detect type   State    PPS    Dropped
201.55.7.44     --          Local        DNS-FLOOD     Normal   1000   111111111
192.168.11.4    --          Local        ACK-FLOOD     Normal   1000   22222222
slot 2:
192.168.100.66  --          Local        SYN-ACK-FLOOD Normal   1000   165467998
# 显示所有类型的flood攻击检测的IPv4地址数目。
<Sysname> display attack-defense flood statistics ip count
Slot 1:
Totally 2 flood entries.
Slot 2:
Totally 1 flood entries.
表1-1 display attack-defense flood statistics ip命令显示信息描述表
IP address
被检测的目的IPv4地址
VPN
目的IPv4地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
进行攻击检测的位置,即本机(Local)
Detect type
检测的flood攻击类型
本机是否处于攻击状态,可包括以下取值:
·     Attacked:受攻击状态
·     Normal:正常状态(当前并未受到攻击)
PPS
指定的目的IPv4地址收到flood攻击报文的速率(单位为报文每秒)
Dropped
本机丢弃的flood攻击报文数目
被检测的IPv4地址数目
display attack-defense flood statistics ipv6命令用来显示IPv6 flood攻击防范统计信息。
display attack-defense { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-flood | syn-ack-flood | udp-flood } statistics ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
ack-flood:显示指定ACK flood类型统计信息。
dns-flood:显示指定DNS flood类型统计信息。
fin-flood:显示指定FIN flood类型统计信息。
flood:显示所有类型的IPv6 flood攻击防范统计信息。
icmpv6-flood:显示指定ICMPv6 flood类型统计信息。
rst-flood:显示指定RST flood类型统计信息。
syn-flood:显示指定SYN flood类型统计信息。
udp-flood:显示指定UDP flood类型统计信息。
ipv6-address:显示指定目的IPv6地址的flood攻击防范统计信息。若未指定本参数,则显示所有目的IPv6地址的flood攻击防范统计信息。
vpn vpn-instance-name:指定IPv6地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该IPv6地址属于公网。
count:仅显示符合指定条件的被进行flood攻击检测的IPv6地址数目。
由于flood攻击不关心源地址,因此本命令显示的是对指定目的IPv6地址的攻击防范统计信息。
# 显示所有类型的IPv6 flood攻击防范统计信息。
<Sysname> display attack-defense flood statistics ipv6
Slot 1:
IPv6 address    VPN         Detected on  Detect type   State    PPS    Dropped
1::4            --          Local        ACK-FLOOD     Normal   1000   111111111
1::5            --          Local        SYN-FLOOD     Normal   1000   22222222
Slot 2:
1::6            --          Local        DNS-FLOOD     Normal   1000   12569985
# 显示所有类型的flood攻击检测的IPv6地址数目。
<Sysname> display attack-defense flood statistics ipv6 count
Slot 1:
Totally 4 flood entries.
Slot 2:
Totally 3 flood entries.
表1-2 display attack-defense flood statistics ipv6命令显示信息描述表
IPv6 address
被检测的目的IPv6地址
VPN
目的IPv6地址所属的MPLS L3VPN实例名称,属于公网时显示为“--”
Detected on
Detect type
检测的flood攻击类型
本机是否处于攻击状态,可包括以下取值:
·     Attacked:受攻击状态
PPS
指定的目的IPv6地址收到报文的速率(单位为报文每秒)
Dropped
本机丢弃的flood攻击报文数目
被检测的IPv6地址数目
display attack-defense policy用来显示攻击防范策略的配置信息。
display attack-defense policy [ policy-name ]
policy-name:攻击防范策略名称,为1~31个字符的字符串,包括英文大/小写字母、数字、下划线和连字符,不区分大小写。若未指定本参数,则表示显示所有攻击防范策略的摘要信息。
本命令显示的内容主要包括各类型攻击防范的使能情况、对攻击报文的处理方式和相关的阈值参数。
# 显示指定攻击防范策略abc的配置信息。
<Sysname> display attack-defense policy abc
          Attack-defense Policy Information
Policy name                        : abc
Applied list                       : Local
Exempt IPv4 ACL:                  : Not configured
Exempt IPv6 ACL:                  : vip
  Actions: CV-Client verify  BS-Block source  L-Logging  D-Drop  N-None
Signature attack defense configuration:
Signature name                     Defense      Level             Actions
Fragment                           Enabled      Info              L
Impossible                         Enabled      Info              L
Teardrop                           Disabled     Info              L
Tiny fragment                      Disabled     Info              L
IP option abnormal                 Disabled     Info              L
Smurf                              Disabled     Info              N
Traceroute                         Disabled     Medium            L,D
Ping of death                      Disabled     Low               L
Large ICMP                         Disabled     Medium            L,D
  Max length                       4000 bytes
Large ICMPv6                       Disabled     Low               L
TCP invalid flags                  Disabled     medium            L,D
TCP null flag                      Disabled     Low               L
TCP all flags                      Enabled      Info              L
TCP SYN-FIN flags                  Disabled     Info              L
TCP FIN only flag                  Enabled      Info              L
TCP Land                           Disabled     Info              L
Winnuke                            Disabled     Info              L
UDP Bomb                           Disabled     Info              L
UDP Snork                          Disabled     Info              L
UDP Fraggle                        Enabled      Info              L
IP option record route             Disabled     Info              L
IP option internet timestamp       Enabled      Info              L
IP option security                 Disabled     Info              L
IP option loose source routing     Enabled      Info              L
IP option stream ID                Disabled     Info              L
IP option strict source routing    Disabled     Info              L
IP option route alert              Disabled     Info              L
ICMP echo request                  Disabled     Info              L
ICMP echo reply                    Disabled     Info              L
ICMP source quench                 Disabled     Info              L
ICMP destination unreachable       Enabled      Info              L
ICMP redirect                      Enabled      Info              L
ICMP time exceeded                 Enabled      Info              L
ICMP parameter problem             Disabled     Info              L
ICMP timestamp request             Disabled     Info              L
ICMP timestamp reply               Disabled     Info              L
ICMP information request           Disabled     Info              L
ICMP information reply             Disabled     Medium            L,D
ICMP address mask request          Disabled     Medium            L,D
ICMP address mask reply            Disabled     Medium            L,D
ICMPv6 echo request                Enabled      Medium            L,D
ICMPv6 echo reply                  Disabled     Medium            L,D
ICMPv6 group membership query      Disabled     Medium            L,D
ICMPv6 group membership report     Disabled     Medium            L,D
ICMPv6 group membership reduction  Disabled     Medium            L,D
ICMPv6 destination unreachable     Enabled      Medium            L,D
ICMPv6 time exceeded               Enabled      Medium            L,D
ICMPv6 parameter problem           Disabled     Medium            L,D
ICMPv6 packet too big              Disabled     Medium            L,D
Scan attack defense configuration:
 Defense: Disabled
 Level: Medium
 Actions: L
Flood attack defense configuration:
Flood type      Global thres(pps)  Global actions  Service ports   Non-specific
SYN flood       1000(default)      -               -               Disabled
ACK flood       1000(default)      -               -               Enabled
SYN-ACK flood   1000(default)      -               -               Disabled
RST flood       200                -               -               Enabled
FIN flood       1000(default)      L,D             -               Disabled
UDP flood       1000(default)      -               -               Disabled
ICMP flood      1000(default)      -               -               Disabled
ICMPv6 flood    1000(default)      CV              -               Disabled
DNS flood       10000              -               30,61 to 62     Enabled
HTTP flood      10000              -               80,8080         Enabled
Flood attack defense for protected IP addresses:
 Address                 VPN instance Flood type    Thres(pps)  Actions Ports
 1::1                    --           FIN-FLOOD     10          L,D     -
 192.168.1.1             --           SYN-ACK-FLOOD 10          -       -
 1::1                    --           FIN-FLOOD     -           L       -
 2013:2013:2013:2013:    --           DNS-FLOOD     100         L,CV    53
 2013:2013:2013:2013
表1-3 display attack-defense policy命令显示信息描述表
Policy name
攻击防范策略名称
Applied list
攻击防范策略应用的对象列表,包括本机(Local)
Exempt IPv4 ACL
IPv4例外列表
Exempt IPv6 ACL
IPv6例外列表
Actions
攻击防范的处理行为,包括以下取值:
·     L:输出告警日志
·     D:丢弃报文
·     N:不采用任何处理行为
单包攻击防范配置信息
Signature name
单包的类型
Defense
攻击防范的开启状态,包括以下取值:
Enabled:开启
Disabled:关闭
Level
单包攻击的级别,包括以下取值:
·     Info: 提示级别
·     low:低级别
·     medium:中级别
·     high:高级别(目前暂无实例)
IP 选项record route攻击
IP option security
IP 选项security攻击
IP option stream ID
IP 选项stream identifier攻击
IP 选项 internet timestamp攻击
IP 选项loose source routing攻击
IP 选项strict source routing攻击
IP option abnormal
IP 选项异常攻击
IP 选项route alert攻击
Fragment
IP分片异常攻击
IP impossible
IP impossible攻击
Tiny fragment
IP tiny fragment攻击
Teardrop
IP teardrop攻击,又称IP overlapping fragments
Large ICMP
Large ICMP攻击
Max length
ICMP报文所允许的最大长度
Smurf
Smurf攻击
Traceroute
Traceroute攻击
Ping of death
Ping of death攻击
ICMP echo request
ICMP echo request攻击
ICMP echo reply
ICMP echo reply攻击
ICMP source quench
ICMP source quench攻击
ICMP redirect
ICMP redirect攻击
ICMP parameter problem攻击
ICMP timestamp request攻击
ICMP timestamp reply攻击
ICMP information request攻击
ICMP information reply攻击
ICMP address mask request攻击
ICMP address mask reply攻击
ICMP destination  unreachable攻击
ICMP time exceeded
ICMP time exceeded攻击
Large ICMPv6
Large ICMPv6攻击
ICMPv6 echo request
ICMPv6 echo request攻击
ICMPv6 echo reply
ICMPv6 echo reply攻击
ICMPv6 group membership query攻击
ICMPv6 group membership report攻击
ICMPv6 group membership reduction攻击
ICMPv6 destination unreachable攻击
ICMPv6 time exceeded攻击
ICMPv6 parameter problem攻击
ICMPv6 packet too big攻击
Winnuke
Winnuke攻击
TCP Land
Land攻击
TCP NULL flag
TCP NULL flag攻击
TCP invalid flags
TCP invalid flags攻击
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击
TCP FIN only flag
TCP 只有FIN被置位的攻击
Fraggle
Fraggle攻击,又称UDP chargen DoS attack
UDP Bomb
UDP Bomb攻击
Snork
Snork攻击
扫描攻击防范配置信息
Level
扫描攻击的级别,包括以下取值:
·     low:低级别
·     medium:中级别
·     high:高级别
flood攻击防范配置信息
Flood type
flood攻击类型,包括以下取值:
·     ACK flood
·     DNS flood
·     FIN flood
·     ICMP flood
·     ICMPv6 flood
·     SYN flood
·     SYN-ACK flood
·     UDP flood
·     RST flood
·     HTTP flood
Global thres(pps)
flood攻击防范的全局触发阈值,单位为每秒报文数,默认值为1000pps
Global actions
flood攻击防范的全局处理行为,包括以下取值:
·     D:丢弃报文
·     L:输出告警日志,
·     -:未配置
Service ports
flood攻击防范的全局检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其它flood攻击防范,显示为“-”
Non-specific
对非受保护IP地址开启SYN flood攻击防范检测的状态
对受保护IP地址的flood攻击防范配置
Address
指定的IP地址
VPN instance
所属的VPN实例名称,未配置时显示为“--”
Thres(pps)
攻击防范检测的触发阈值,单位为报文每秒,未配置时显示为“-”
Ports
Flood攻击防范的检测端口号。该字段只对DNS flood攻击防范和HTTP flood攻击防范生效,对于其他攻击防范,显示为“-”
# 显示所有攻击防范策略的概要配置信息。
           Attack-defense Policy Brief Information
Policy Name                        Applied list
P2                                 None
p1                                 Local
p12                                Local
表1-4 display attack-defense policy命令显示信息描述表
Policy Name
攻击防范策略名称
Applied list
display attack-defense policy ip命令用来显示flood攻击防范的IPv4类型的受保护IP表项。
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmp-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ip [ ip-address [ vpn vpn-instance-name ] ] [ slot slot-number ] [ count ]
ack-flood:显示ACK flood攻击防范受保护IP表项。
dns-flood:显示DNS flood攻击防范受保护IP表项。
fin-flood:显示FIN flood攻击防范受保护IP表项。
flood:显示所有类型的flood攻击防范受保护IP表项。
http-flood:显示HTTP flood攻击防范受保护IP表项。
icmp-flood:显示ICMP flood攻击防范受保护IP表项。
rst-flood:显示RST flood攻击防范受保护IP表项。
syn-ack-flood:显示SYN-ACK flood攻击防范受保护IP表项。
syn-flood:显示SYN flood攻击防范受保护IP表项。
udp-flood:显示UDP flood攻击防范受保护IP表项。
ip ip-address:显示指定IPv4地址的受保护IP表项。若未指定ip-address参数,则表示显示所有IPv4类型的受保护IP表项。
vpn-instance vpn-instance-name:显示指定VPN实例的受保护IP表项。其中vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示显示指公网的受保护IP表项。
slot slot-number:显示指定成员设备上的受保护IP表项,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的受保护IP表项。
count:显示符合指定条件的flood受保护IP表项的数目。
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv4类型受保护IP表项的信息。
<Sysname> display attack-defense policy abc flood ip
Slot 1:
IP address      VPN instance     Type Rate threshold(PPS) Dropped
123.123.123.123 --               SYN-ACK-FLOOD 100                 4294967295
201.55.7.45     --               ICMP-FLOOD    100                 10
192.168.11.5    --               DNS-FLOOD 23                  100
Slot 2:
# 显示指定攻击防范策略abc中所有IPv4类型flood受保护IP表项的个数。
<Sysname> display attack-defense policy abc flood ip count
Slot 1:
Totally 3 flood protected IP addresses.
Slot 2:
Totally 0 flood protected IP addresses.
表1-5 display attack-defense flood ip命令显示信息描述表
IPv4类型受保护IP表项数目
IP address
受保护的IPv4地址
VPN instance
受保护的IPv4地址所属的MPLS L3VPN实例名称,未指定时显示为“--”
flood攻击类型
Rate threshold(PPS)
配置的flood攻击防范触发阈值(单位为报文每秒),未配置时显示“-”
Dropped
检测到flood攻击后的丢包数,若只输出日志该项显示为0
display attack-defense policy ipv6命令用来显示flood攻击防范的IPv6类型的受保护IP表项。
display attack-defense policy policy-name { ack-flood | dns-flood | fin-flood | flood | http-flood | icmpv6-flood | rst-flood | syn-ack-flood | syn-flood | udp-flood } ipv6 [ ipv6-address [ vpn vpn-instance-name ] ] [ slot slot-number ] ] [ count ]
icmpv6-flood:显示ICMPv6 flood攻击防范受保护IP表项。
ipv6 ipv6-address:显示指定IPv6地址的受保护IP表项。若未指定ipv6-address参数,则表示所有IPv6类型的受保护IP表项。
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项。
<Sysname> display attack-defense policy abc flood ipv6
Slot 1:
IPv6 address    VPN instance     Type Rate threshold(PPS) Dropped
2013::127f      --               SYN-ACK-FLOOD 100                 4294967295
2::5            --               ACK-FLOOD 100                 10
1::5            --               ACK-FLOOD 100                 23
Slot 2:
# 显示指定攻击防范策略abc中所有flood攻击防范的IPv6类型受保护IP表项的个数。
<Sysname> display attack-defense policy abc flood ipv6 count
Slot 1:
Slot 2:
表1-6 display flood ipv6命令显示信息描述表
IPv6类型受保护IP表项数目
IPv6 address
受保护的IPv6地址
VPN instance
受保护的IPv6地址所属的MPLS L3VPN实例名称,未指定时显示为“--”
flood攻击类型
Rate threshold(PPS)
Dropped
display attack-defense scan attacker ip命令用来显示扫描攻击者的IPv4地址表项。
display attack-defense scan attacker ip [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
interface interface-type interface-number:显示指定接口上检测到的扫描攻击者的IPv4地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv4地址表项。
slot slot-number:显示指定成员设备上的扫描攻击者的IPv4地址表项,slot-number表示设备在IRF中的成员编号。该参数仅在指定本机或指定全局接口(例如VLAN接口、Tunnel接口)时可见。如果不指定该参数,则表示显示所有成员设备上的扫描攻击者的IPv4地址表项。
count:显示符合指定条件的当前扫描攻击者的IPv4地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv4地址表项。
# 显示所有扫描攻击者的IPv4地址表项。
<Sysname> display attack-defense scan attacker ip
Slot 1:
IP address      VPN instance     DS-Lite tunnel peer  Detected on  Duration(min)
192.68.11.2     --               --                   Local        782
# 显示所有扫描攻击者的IPv4地址表项的个数。
<Sysname> display attack-defense scan attacker ip count
Slot 1:
Totally 3 attackers.
Slot 2:
Totally 2 attackers.
表1-7 display attack-defense scan attacker ip命令显示信息描述表
Totally 3 attackers
扫描攻击者的数目
IP address
发起攻击的IPv4地址
VPN instance
DS-Lite tunnel peer
DS-Lite隧道对端地址。DS-Lite组网下,若本设备为AFTR,此列表示报文来自具体的哪个B4,如果不在DS-Lite组网或本设备不为AFTR,则该字段无意义,显示为“--”
Detected on
Duration(min)
检测到攻击持续的时间,单位为分钟
·     display attack-defense scan victim ip
·     scan detect
display attack-defense scan attacker ipv6命令用来显示扫描攻击者的IPv6地址表项。
display attack-defense scan attacker ipv6 [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
interface interface-type interface-number:显示指定接口的扫描攻击者的IPv6地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的扫描攻击者IPv6地址表项。
slot slot-number:显示指定成员设备上的扫描攻击者的IPv6地址表项,slot-number表示设备在IRF中的成员编号。该参数仅在指定本机或指定全局接口(例如VLAN接口、Tunnel接口)时可见。如果不指定该参数,则表示显示所有成员设备上的扫描攻击者的IPv6地址表项。
count:显示符合指定条件的当前扫描攻击者的IPv6地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击者的IPv6地址表项。
# 显示扫描攻击者的IPv6地址表项。
<Sysname> display attack-defense scan attacker ipv6
Slot 1:
IPv6 address             VPN instance     Detected on              Duration(min)
1002::20                --               Local                    782
Slot 2:
# 显示扫描攻击者的IPv6地址表项的个数。
<Sysname> display attack-defense scan attacker ipv6 count
Slot 1:
Slot 2:
Totally 0 attackers.
表1-8 display attack-defense scan attacker ipv6命令显示信息描述表
Totally 3 attackers
攻击者的数目
IPv6 address
发起攻击的IPv6地址
VPN instance
Detected on
Duration(min)
检测到攻击持续的时间,单位为分钟
·     display attack-defense scan victim ipv6
·     scan detect
display attack-defense scan victim ip命令用来显示扫描攻击被攻击者的IPv4地址表项。
display attack-defense scan victim ip [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
interface interface-type interface-number:显示指定接口的被攻击者的IPv4地址表项,interface-type interface-number表示接口类型和接口编号。
local:显示本机检测到的被攻击者的IPv4地址表项。
slot slot-number:显示指定成员设备上的被攻击者的IPv4地址表项,slot-number表示设备在IRF中的成员编号。该参数仅在指定本机或指定全局接口(例如VLAN接口、Tunnel接口)时可见。如果不指定该参数,则表示显示所有成员设备上的被攻击者的IPv4地址表项。
count:显示符合指定条件的被攻击者的IPv4地址表项数目。
若未指定任何参数,则表示显示所有扫描攻击的被攻击者的IPv4地址表项。
# 显示扫描攻击的被攻击者的IPv4地址表项。
<Sysname> display attack-defense scan victim ip
Slot 1:
IP address      VPN instance                    Detected on        Duration(min)
192.168.24.82   --                              Local              782
Slot 2:
# 显示扫描攻击的被攻击者的IPv4地址表项的个数。
<Sysname> display attack-defense scan victim ip count
Slot 1:
Totally 3 victim IP addresses.
Slot 2:
Totally 0 victim IP addresses.
表1-9 display attack-defense scan victim ip命令显示信息描述表
被攻击者的数目
IP address
被攻击的IPv4地址
VPN instance
Detected on
Duration(min)
检测到被攻击的持续时间,单位为分钟
·     display attack-defense scan attacker ip
·     scan detect
display attack-defense scan victim ipv6命令用来显示扫描攻击被攻击者IPv6表项。
display attack-defense scan victim ipv6 [ [ interface interface-type interface-number | local ] [ slot slot-number ] ] [ count ]
interface interface-type interface-number:显示指定接口的被攻击者的IPv6地址表项,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定成员设备上的被攻击者的IPv6地址表项,slot-number表示设备在IRF中的成员编号。该参数仅在指定本机或指定全局接口(例如VLAN接口、Tunnel接口)时可见。如果不指定该参数,则表示显示所有成员设备上的被攻击者的IPv6地址表项。
local:显示本机检测到的被攻击者的IPv6地址表项。
count:仅显示符合指定条件的当前被攻击者的数目。
若未指定任何参数,则表示显示所有扫描攻击的被攻击者的IPv6地址表项。
# 显示扫描攻击的被攻击者的IPv6地址表项。
<Sysname> display attack-defense scan victim ipv6
Slot 1:
1002::20                 --               Local                    28
Slot 2:
# 显示扫描攻击的被攻击者的IPv6地址表项的个数。
<Sysname> display attack-defense scan victim ipv6 count
Slot 1:
Slot 2:
表1-10 display attack-defense scan victim ipv6命令显示信息描述表
被攻击者的数目
IPv6 address
被攻击的IPv6地址
VPN instance
Detected on
Duration(min)
检测到被攻击的持续时间,单位为分钟
·     display attack-defense scan attacker ipv6
·     scan detect
display attack-defense statistics local命令用来显示本机攻击防范的统计信息。
display attack-defense statistics local [ slot slot-number ]
slot slot-number:显示本机攻击防范在指定成员设备上的统计信息,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上检测到的本机攻击防范统计信息。
# 显示本机攻击防范统计信息。
<Sysname> display attack-defense statistics local
Attack policy name: abc
Slot 1:
Scan attack defense statistics:
 AttackType                          AttackTimes Dropped
 Port scan                           2           23
 IP sweep                            3           33
 Distribute port scan                1           10
Flood attack defense statistics:
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       3           5000
 RST flood                           2           0
 FIN flood                           2           0
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
Signature attack defense statistics:
 IP option record route              1           100
 IP option security                  2           0
 IP option stream ID                 3           0
 IP option internet timestamp        4           1
 IP option loose source routing      5           0
 IP option strict source routing     6           0
 IP option route alert               3           0
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 IP options abnormal                 3           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP SYN-FIN flags                   1           0
 TCP FIN only flag                   1           0
 TCP invalid flag                    1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo request                   1           0
 ICMP echo reply                     1           0
 ICMP source quench                  1           0
 ICMP destination unreachable        1           0
 ICMP redirect                       2           0
 ICMP time exceeded                  3           0
 ICMP parameter problem              4           0
 ICMP timestamp request              5           0
 ICMP timestamp reply                6           0
 ICMP information request            7           0
 ICMP information reply              4           0
 ICMP address mask request           2           0
 ICMP address mask reply             1           0
 ICMPv6 echo request                 1           1
 ICMPv6 echo reply                   1           1
 ICMPv6 group membership query       1           0
 ICMPv6 group membership report      1           0
 ICMPv6 group membership reduction   1           0
 ICMPv6 destination unreachable      1           0
 ICMPv6 time exceeded                1           0
 ICMPv6 parameter problem            1           0
 ICMPv6 packet too big               1           0
Slot 2:
 Port scan                           4           46
 IP sweep                            2           28
 SYN flood                           1           0
 ACK flood                           1           0
 SYN-ACK flood                       2           4200
 RST flood                           2           0
 FIN flood                           2           20
 UDP flood                           1           0
 ICMP flood                          1           0
 ICMPv6 flood                        1           0
 DNS flood                           1           0
 HTTP flood                          1           0
 IP option record route              2           230
 IP option strict source routing     2           0
 IP option route alert               3           12
 Fragment                            1           0
 Impossible                          1           1
 Teardrop                            1           1
 Tiny fragment                       1           0
 Smurf                               1           0
 Ping of death                       1           0
 Traceroute                          1           0
 Large ICMP                          1           0
 TCP NULL flag                       1           0
 TCP all flags                       1           0
 TCP Land                            1           0
 Winnuke                             1           0
 UDP Bomb                            1           0
 Snork                               1           0
 Fraggle                             1           0
 Large ICMPv6                        1           0
 ICMP echo reply                     1           0
 ICMP redirect                       2           3
表1-11 display attack-defense statistics local命令显示信息描述表
AttackType
攻击类型
AttackTimes
受到攻击的次数
Dropped
丢弃报文的数目
Port scan
端口扫描攻击,当AttackTimes为0时,该列不显示
IP Sweep
IP扫描攻击,当AttackTimes为0时,该列不显示
分布式端口扫描攻击,当AttackTimes为0时,该列不显示
SYN flood
SYN flood攻击,当AttackTimes 为0时,该列不显示
ACK flood
ACK flood攻击,当AttackTimes 为0时,该列不显示
SYN-ACK flood
SYN-ACK flood攻击,当AttackTimes为0时,该列不显示
RST flood
RST flood攻击,当AttackTimes为0时,该列不显示
FIN flood
FIN flood攻击,当AttackTimes为0时,该列不显示
UDP flood
UDP flood 攻击,当AttackTimes为0时,该列不显示
ICMP flood
ICMP flood攻击,当AttackTimes为0时,该列不显示
ICMPv6 flood
ICMPv6 flood攻击,当AttackTimes为0时,该列不显示
DNS flood
DNS flood攻击,当AttackTimes为0时,该列不显示
HTTP flood
HTTP flood攻击,当AttackTimes为0时,该列不显示
IP 选项record route攻击,当AttackTimes为0时,该列不显示
IP option security
IP 选项security攻击,当AttackTimes为0时,该列不显示
IP option stream ID
IP 选项stream identifier攻击,当AttackTimes为0时,该列不显示
IP 选项 internet timestamp攻击,当AttackTimes为0时,该列不显示
IP 选项loose source routing攻击,当AttackTimes为0时,该列不显示
IP 选项strict source routing攻击,当AttackTimes为0时,该列不显示
Fragment
IP分片异常攻击,当AttackTimes为0时,该列不显示
Impossible
IP impossible攻击,当AttackTimes为0时,该列不显示
Teardrop
IP teardrop攻击,又称IP overlapping fragments,当AttackTimes为0时,该列不显示
Tiny fragment
IP tiny fragment攻击
IP option abnormal
IP 选项异常攻击,当AttackTimes为0时,该列不显示
Smurf
Smurf攻击,当AttackTimes为0时,该列不显示
Ping of death
Ping of death攻击,当AttackTimes为0时,该列不显示
Traceroute
Traceroute攻击,当AttackTimes为0时,该列不显示
Large ICMP
Large ICMP攻击,当AttackTimes为0时,该列不显示
TCP NULL flag
TCP NULL flag攻击,当AttackTimes为0时,该列不显示
TCP all flags
TCP所有标志位均被置位攻击,又称圣诞树攻击,当AttackTimes为0时,该列不显示
TCP SYN-FIN flags
TCP SYN和FIN被同时置位攻击,当AttackTimes为0时,该列不显示
TCP FIN only flag
TCP只有FIN被置位的攻击,当AttackTimes为0时,该列不显示
TCP invalid flag
TCP非法标志位攻击,当AttackTimes为0时,该列不显示
TCP Land
TCP Land攻击,当AttackTimes为0时,该列不显示
Winnuke
Winnuke攻击,当AttackTimes为0时,该列不显示
UDP Bomb
UDP Bomb攻击,当AttackTimes为0时,该列不显示
Snork
Snork攻击,当AttackTimes为0时,该列不显示
Fraggle
Fraggle攻击,又称UDP chargen DoS attack,当AttackTimes为0时,该列不显示
Large ICMPv6
Large ICMPv6攻击,当AttackTimes为0时,该列不显示
ICMP echo request
ICMP echo request攻击,当AttackTimes 为0时,该列不显示
ICMP echo reply
ICMP echo reply攻击,当AttackTimes为0时,该列不显示
ICMP source quench
ICMP source quench攻击,当AttackTimes为0时,该列不显示
ICMP destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMP redirect
ICMP redirect攻击,当AttackTimes为0时,该列不显示
ICMP time exceeded
ICMP time exceeded攻击,当AttackTimes为0时,该列不显示
ICMP parameter problem攻击,当AttackTimes为0时,该列不显示
ICMP timestamp request攻击,当AttackTimes为0时,该列不显示
ICMP timestamp reply攻击,当AttackTimes为0时,该列不显示
ICMP information request攻击,当AttackTimes为0时,该列不显示
ICMP information reply攻击,当AttackTimes为0时,该列不显示
ICMP address mask request攻击,当AttackTimes为0时,该列不显示
ICMP address mask reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 echo request
ICMPv6 echo request攻击,当AttackTimes 为0时,该列不显示
ICMPv6 echo reply
ICMPv6 echo reply攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership query攻击,当AttackTimes 为0时,该列不显示
ICMPv6 group membership report攻击,当AttackTimes为0时,该列不显示
ICMPv6 group membership reduction攻击,当AttackTimes为0时,该列不显示
ICMPv6 destination unreachable攻击,当AttackTimes为0时,该列不显示
ICMPv6 time exceeded攻击,当AttackTimes为0时,该列不显示
ICMPv6 parameter problem攻击,当AttackTimes为0时,该列不显示
ICMPv6 packet too big攻击,当AttackTimes为0时,该列不显示
·     reset attack-defense statistics local
dns-flood action命令用来配置对DNS flood攻击防范的全局处理行为。
undo dns-flood action命令用来恢复缺省情况。
dns-flood action { drop | logging } *
不对检测到的DNS flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有DNS报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对DNS flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood action drop
·     dns-flood detect
·     dns-flood detect non-specific
·     dns-flood threshold
dns-flood detect命令用来开启对指定IP地址的攻击防范检测,并配置DNS flood攻击防范检测的触发阈值和对DNS flood攻击的处理行为。
undo dns-flood detect命令用来关闭对指定IP地址的DNS flood攻击防范检测。
dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo dns-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置DNS flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启DNS flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-65535>&<1-65535>表示前面的参数最多可以输入65535次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定DNS flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的DNS报文数目,取值范围为1~1000000。
action:设置对DNS flood攻击的处理行为。若未指定本参数,则表示采用DNS flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送DNS报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置DNS flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的DNS flood攻击防范检测,并指定检测端口为53、触发阈值为2000。当设备监测到向该IP地址的53端口每秒发送的DNS报文数持续达到或超过2000时,启动DNS flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect ip 192.168.1.2 port 53 threshold 2000
·     dns-flood action
·     dns-flood port
dns-flood detect non-specific命令用来对所有非受保护IP地址开启DNS flood攻击防范检测。
undo dns-flood detect non-specific命令用来关闭对所有非受保护IP地址的DNS flood攻击防范检测。
未对任何非受保护IP地址开启DNS flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启DNS flood攻击防范检测后,设备将采用全局的阈值设置(由dns-flood threshold命令设置)和处理行为(由dns-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启DNS flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood detect non-specific
·     dns-flood action
·     dns-flood detect
dns-flood port命令用来配置DNS flood攻击防范的全局检测端口号。
undo dns-flood port命令用来恢复缺省情况。
dns-flood port port-list
undo dns-flood port
DNS flood攻击防范的全局检测端口号为53。
攻击防范策略视图
设备只对指定检测端口上收到的报文进行DNS flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行DNS flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行DNS flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为53与61000,当设备检测到访问53端口或61000端口的DNS flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood port 53 61000
·     dns-flood action
·     dns-flood detect
dns-flood threshold命令用来配置DNS flood攻击防范的全局触发阈值。
undo dns-flood threshold命令用来恢复缺省情况。
dns-flood threshold threshold-value
DNS flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的DNS报文数目,取值范围为1~1000000。
使能DNS flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送DNS报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了DNS flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置DNS flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(DNS服务器)的DNS报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的DNS报文数持续达到或超过100时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] dns-flood threshold 100
·     dns-flood action
·     dns-flood detect ip
1.1.25  exempt acl
exempt acl命令用来配置攻击防范例外列表。
undo exempt acl命令用来恢复缺省情况。
exempt acl [ ipv6 ] { acl-number | name acl-name }
undo exempt acl [ ipv6 ]
未配置攻击防范例外列表。
攻击防范策略视图
ipv6:指定IPv6 ACL。如果未指定本参数,则表示IPv4 ACL。
acl-number:表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示基本ACL。
·     3000~3999:表示高级ACL。
name acl-name:指定ACL的名称。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。为避免混淆,ACL的名称不允许使用英文单词all。
通过配置例外列表,使用ACL过滤不需要进行攻击防范检测的主机报文。当本机上收到的报文与攻击防范例外列表引用的ACL中的permit规则匹配时,设备不对其进行攻击防范检测。该配置用于过滤某些被信任的安全主机发送的报文,可以有效的减小误报率,并提高服务器处理效率。
例外列表引用的ACL的permit规则中仅源地址、目的地址、源端口、目的端口、协议号、L3VPN和非首片分片标记参数用于匹配报文。
如果配置的攻击防范例外列表中引用的ACL不存在,或引用的ACL中未定义任何规则,例外列表不会生效。
# 在攻击防范策略atk-policy-1中配置例外列表ACL 2001,过滤来自主机1.1.1.1的报文,不对其进行攻击防范检测。
[Sysname] acl basic 2001
[attack-defense-policy-atk-policy-1] exempt acl 2001
fin-flood action命令用来配置对FIN flood攻击防范的全局处理行为。
undo fin-flood action命令用来恢复缺省情况。
fin-flood action { drop | logging } *
不对检测到的FIN flood攻击采取任何处理行为。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有FIN报文都会被丢弃。
#在攻击防范策略atk-policy-1配置对FIN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood action drop
·     fin-flood detect
·     fin-flood detect non-specific
·     fin-flood threshold
fin-flood detect命令用来开启对指定IP地址的FIN flood攻击防范检测,并配置FIN flood攻击防范检测的触发阈值和对FIN flood攻击的处理行为。
undo fin-flood detect命令用来关闭对指定IP地址的FIN flood攻击防范检测。
fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo fin-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置FIN flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的FIN报文数目,取值范围为1~1000000。
action:设置对FIN flood攻击的处理行为。若未指定本参数,则表示采用FIN flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送FIN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置FIN flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的FIN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的FIN报文数持续达到或超过2000时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect ip 192.168.1.2 threshold 2000
·     fin-flood action
fin-flood detect non-specific命令用来对所有非受保护IP地址开启FIN flood攻击防范检测。
undo fin-flood detect non-specific命令用来关闭对所有非受保护IP地址的FIN flood攻击防范检测。
未对任何非受保护IP地址开启FIN flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启FIN flood攻击防范检测后,设备将采用全局的阈值设置(由fin-flood threshold命令设置)和处理行为(由fin-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启FIN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood detect non-specific
·     fin-flood action
·     fin-flood detect
fin-flood threshold命令用来配置FIN flood攻击防范的全局触发阈值。
undo fin-flood threshold命令用来恢复缺省情况。
fin-flood threshold threshold-value
FIN flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的FIN报文数目,取值范围为1~1000000。
使能FIN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送FIN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了FIN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置FIN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的FIN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置FIN flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的FIN报文数持续达到或超过100时,启动FIN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] fin-flood threshold 100
·     fin-flood action
·     fin-flood detect
http-flood action命令用来配置对HTTP flood攻击防范的全局处理行为。
undo http-flood action命令用来恢复缺省情况。
http-flood action { drop | logging } *
不对检测到的HTTP flood攻击采取任何处理行为。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有HTTP报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对HTTP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] http-flood action drop
·     http-flood detect non-specific
·     http-flood detect
·     http-flood threshold
http-flood detect命令用来开启对指定IP地址的HTTP flood攻击防范检测,并配置HTTP flood攻击防范的触发阈值和对HTTP flood攻击的处理行为。
undo http-flood detect命令用来关闭对指定IP地址的HTTP flood攻击防范检测。
http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ port port-list ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo http-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置HTTP flood攻击防范检测。
攻击防范策略视图
port port-list:指定开启HTTP flood攻击防范检测的端口列表,表示方式为{ start-port-number [ to end-port-number ] } &<1-65535>&<1-65535>表示前面的参数最多可以输入65535次。end-port-number必须大于或等于start-port-number。若未指定本参数,则表示使用全局配置的检测端口列表。
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的HTTP报文数目,取值范围为1~1000000。
action:设置对HTTP flood攻击的处理行为。若未指定本参数,则表示采用HTTP flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送HTTP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置HTTP flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的HTTP flood攻击防范检测,并指定检测端口为80与8080、触发阈值为2000。当设备监测到向该IP地址的80或8080端口每秒发送的HTTP报文数持续达到或超过2000时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect ip 192.168.1.2 port 80 8080 threshold 2000
·     http-flood action
·     http-flood port
http-flood detect non-specific命令用来对所有非受保护IPv4地址开启HTTP flood攻击防范检测。
undo http-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的HTTP flood攻击防范检测。
未对任何非受保护IP地址开启HTTP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启HTTP flood攻击防范检测后,设备将采用全局的阈值设置(由http-flood threshold命令设置)和处理行为(由http-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启HTTP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] http-flood detect non-specific
·     http-flood action
·     http-flood detect
http-flood port命令用来配置HTTP flood攻击防范的全局检测端口号。
undo http-flood port命令用来恢复缺省情况。
http-flood port port-list
HTTP flood攻击防范的全局检测端口号为80。
攻击防范策略视图
设备只对指定检测端口上收到的报文进行HTTP flood攻击检测。
对于所有非受保护IP地址,或未指定检测端口的受保护IP地址,设备采用全局的检测端口进行HTTP flood攻击检测。对于所有指定检测端口的受保护IP地址,设备针对为每个受保护IP地址指定的端口进行HTTP flood攻击检测。
# 在攻击防范策略atk-policy-1中配置DNS flood攻击防范的全局检测端口为80与8080,当设备检测到访问80端口或8080端口的HTTP flood攻击时,启动攻击防范措施。
[Sysname-attack-defense-policy-atk-policy-1] http-flood port 80 8080
·     http-flood action
·     http-flood detect
http-flood threshold命令用来配置HTTP flood攻击防范的全局触发阈值。
undo http-flood threshold命令用来恢复缺省情况。
http-flood threshold threshold-value
缺省情况下,HTTP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的HTTP报文数目,取值范围为1~1000000。
使能HTTP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送HTTP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了HTTP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置HTTP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器)的HTTP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置HTTP flood攻击防范的全局触发阈值为100, 即当设备监测到向某IP地址每秒发送的HTTP报文数持续达到或超过100时,启动HTTP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] http-flood threshold 100
·     http-flood action
·     http-flood detect
icmp-flood action命令用来配置对ICMP flood攻击防范的全局处理行为。
undo icmp-flood action命令用来恢复缺省情况。
icmp-flood action { drop | logging } *
不对检测到的ICMP flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMP报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对ICMP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood action drop
·     icmp-flood detect non-specific
·     icmp-flood detect ip
·     icmp-flood threshold
icmp-flood detect ip命令用来开启对指定IP地址的ICMP flood攻击防范检测,并配置ICMP flood攻击防范检测的触发阈值和对ICMP flood攻击的处理行为。
undo icmp-flood detect ip命令用来关闭对指定IP地址的ICMP flood攻击防范检测。
icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmp-flood detect ip ip-address [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置ICMP flood 攻击防范触发阈值。
攻击防范策略视图
ip ip-address:指定要保护的IP地址。该IP地址不能为全1地址或全0地址。
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMP报文数目,取值范围为1~1000000。
action:设置对ICMP flood攻击的处理行为。若未指定本参数,则表示采用ICMP flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置ICMP flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的ICMP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect ip 192.168.1.2 threshold 2000
·     icmp-flood action
icmp-flood detect non-specific命令用来对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
undo icmp-flood detect non-specific命令用来关闭对所有非受保护IPv4地址的ICMP flood攻击防范检测。
未对任何非受保护IPv4地址开启ICMP flood攻击防范检测。
攻击防范策略视图
对任何非受保护IPv4地址开启ICMP flood攻击防范检测后,设备将采用全局的阈值设置(由icmp-flood threshold命令设置)和处理行为(由icmp-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv4地址开启ICMP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood detect non-specific
·     icmp-flood action
icmp-flood threshold命令用来配置ICMP flood攻击防范的全局触发阈值。
undo icmp-flood threshold命令用来恢复缺省情况。
icmp-flood threshold threshold-value
ICMP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ICMP报文数目,取值范围为1~1000000。
使能ICMP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ICMP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ICMP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ICMP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMP flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMP报文数持续达到或超过100时,启动ICMP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmp-flood threshold 100
·     icmp-flood action
·     icmp-flood detect
icmpv6-flood action命令用来配置对ICMPv6 flood攻击防范的全局处理行为。
undo icmpv6-flood action命令用来恢复缺省情况。
icmpv6-flood action { drop | logging } *
不对检测到的ICMPv6 flood攻击采取任何防范措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有ICMPv6报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对ICMPv6 flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood action drop
·     icmpv6-flood detect ipv6
·     icmpv6-flood detect non-specific
·     icmpv6-flood threshold
icmpv6-flood detect ipv6命令用来开启对指定IPv6地址的ICMPv6 flood攻击防范检测,并配置ICMPv6 flood攻击防范检测的触发阈值和对ICMPv6 flood攻击的处理行为。
undo icmpv6-flood detect ipv6命令用来关闭对指定IPv6地址的ICMPv6 flood攻击防范检测。
icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo icmpv6-flood detect ipv6 ipv6-address [ vpn-instance vpn-instance-name ]
未对任何指定IPv6地址配置ICMPv6 flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的ICMPv6报文数目,取值范围为1~1000000。
action:设置对ICMPv6 flood攻击的处理行为。若未指定本参数,则表示采用ICMPv6 flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送ICMPv6报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IPv6地址配置ICMPv6 flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址2012::12的ICMPv6 flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的ICMP报文数持续达到或超过2000时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect ipv6 2012::12 threshold 2000
·     icmpv6-flood action
icmpv6-flood detect non-specific命令用来对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
undo icmpv6-flood detect non-specific命令用来关闭对所有非受保护IPv6地址的ICMPv6 flood攻击防范检测。
未对任何非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
攻击防范策略视图
对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测后,设备将采用全局的阈值设置(由icmpv6-flood threshold命令设置)和处理行为(由icmpv6-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IPv6地址开启ICMPv6 flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood detect non-specific
icmpv6-flood threshold命令用来配置ICMPv6 flood攻击防范的全局触发阈值。
undo icmpv6-flood threshold命令用来恢复缺省情况。
icmpv6-flood threshold threshold-value
ICMPv6 flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的ICMPv6报文数目,取值范围为1~1000000。
使能ICMPv6 flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送ICMPv6报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了ICMPv6 flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置ICMPv6 flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的ICMPv6报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置ICMPv6 flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的ICMPv6报文数持续达到或超过100时,启动ICMPv6 flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] icmpv6-flood threshold 100
reset attack-defense policy flood命令用来清除flood攻击防范受保护IP表项的统计信息。
reset attack-defense policy policy-name flood protected { ip | ipv6 } statistics
ip:指定IPv4类型的flood受保护IP表项。
ipv6:指定IPv6类型的flood受保护IP表项。
statistics:清除指定类型的flood受保护IP表项的统计信息。
# 清除攻击防范策略abc中所有IPv4类型的flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ip statistics
# 清除攻击防范策略abc中所有IPv6类型的Flood保护IP表项的统计信息
<Sysname> reset attack-defense policy abc flood protected ipv6 statistics
·     display attack-defense policy ip
·     display attack-defense policy ipv6
reset attack-defense statistics local命令用来清除本机攻击防范的统计信息。
# 清除本机上所有攻击防范的统计信息。
<Sysname> reset attack-defense statistics local
·     display attack-defense statistics local
rst-flood action命令用来配置对RST flood攻击防范的全局处理行为。
undo rst-flood action命令用来恢复缺省情况。
rst-flood action { drop | logging } *
不对检测到的RST flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有RST报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对RST flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood action drop
·     rst-flood detect
·     rst-flood detect non-specific
·     rst-flood threshold
rst-flood detect命令用来开启对指定IP地址的RST flood攻击防范检测,并配置RST flood攻击防范的触发阈值和对RST flood攻击的处理行为。
undo rst-flood命令用来关闭对指定IP地址的RST flood攻击防范检测。
rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo rst-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置RST flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的RST报文数目,取值范围为1~1000000。
action:设置对RST flood攻击的处理行为。若未指定本参数,则表示采用RST flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送RST报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置RST flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的RST flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的RST报文数持续达到或超过2000时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect ip 192.168.1.2 threshold 2000
·     rst-flood action
rst-flood detect non-specific命令用来对所有非受保护IP地址开启RST flood攻击防范检测。
undo rst-flood detect non-specific命令用来关闭对所有非受保护IP地址的RST flood攻击防范检测。
未对任何非受保护IP地址开启RST flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启RST flood攻击防范检测后,设备将采用全局的阈值设置(由rst-flood threshold命令设置)和处理行为(由rst-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启RST flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood detect non-specific
·     rst-flood action
·     rst-flood detect
rst-flood threshold命令用来配置RST flood攻击防范的全局触发阈值。
undo rst-flood threshold命令用来恢复缺省情况。
rst-flood threshold threshold-value
RST flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的RST报文数目,取值范围为1~1000000。
使能RST flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送RST报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了RST flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置RST flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的RST报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置RST flood攻击防范检测的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的RST报文数持续达到或超过100时,启动RST flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] rst-flood threshold 100
·     rst-flood action
·     rst-flood detect
1.1.49  scan detect
scan detect命令用来配置开启指定级别的扫描攻击防范。
undo scan detect命令用来关闭指定级别的扫描攻击防范。
scan detect level { high | low | medium } action { drop | logging } *
undo scan detect
扫描攻击防范处于关闭状态。
攻击防范策略视图
level:指定攻击防范的检测级别。
low:表示低防范级别,该级别提供基本的扫描攻击检测,有很低的误报率,但对于一些扫描攻击类型不能检出。该级别的扫描攻击统计周期为60秒。
high:表示高防范级别,该级别能检测出大部分的扫描攻击,但对活跃主机误报率较高,即将可提供服务的主机的报文错误判断为攻击报文的概率比较高。该级别的扫描攻击统计周期为600秒。
medium:表示中防范级别,该级别有适中的攻击检出率与误报率,通常能够检测出Filtered Scan等攻击。该级别的扫描攻击统计周期为90秒。
action:设置对扫描攻击的处理行为。
drop:表示丢弃攻击报文,即设备检测到攻击发生后,由该攻击者发送的报文都将被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成记录告警信息。
# 在攻击防范策略atk-policy-1中配置扫描攻击的检测级别为低级别,处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] scan detect level low action drop
signature { large-icmp | large-icmpv6 } max-length命令用来配置启动Large ICMP攻击防范的ICMP报文长度的最大值。
undo signature { large-icmp | large-icmpv6 } max-length命令用来恢复缺省情况。
signature { large-icmp | large-icmpv6 } max-length length
启动Large ICMP攻击防范的ICMP报文和ICMPv6报文长度的最大值均为4000字节。
攻击防范策略视图
large-icmp:表示超大ICMP报文攻击防范。
large-icmpv6:表示超大ICMPv6报文攻击防范。
length:表示ICMP报文长度的最大值,ICMP报文取值范围为28~65534,ICMPv6报文取值范围为48~65534,单位为字节。
# 在攻击防范策略atk-policy-1中配置启动Large ICMP攻击防范的ICMP报文长度的最大值为50000字节。
[Sysname-attack-defense-policy-atk-policy-1] signature large-icmp max-length 50000
·     signature detect
signature detect命令用来开启指定类型单包攻击报文的特征检测,并设置攻击防范的处理行为。
undo signature detect命令用来关闭对指定类型的单包攻击报文的特征检测。
signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke } [ action { { drop | logging } * | none } ]
undo signature detect { fraggle | fragment | impossible | land | large-icmp | large-icmpv6 | smurf | snork | tcp-all-flags | tcp-fin-only | tcp-invalid-flags | tcp-null-flag | tcp-syn-fin | tiny-fragment | traceroute | udp-bomb | winnuke }
signature detect { ip-option-abnormal | ping-of-death | teardrop } action { drop | logging } *
undo signature detect { ip-option-abnormal | ping-of-death | teardrop }
signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request } [ action { { drop | logging } * | none } ]
undo signature detect icmp-type { icmp-type-value | address-mask-reply | address-mask-request | destination-unreachable | echo-reply | echo-request | information-reply | information-request | parameter-problem | redirect | source-quench | time-exceeded | timestamp-reply | timestamp-request }
signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded } [ action { { drop | logging } * | none } ]
undo signature detect icmpv6-type { icmpv6-type-value | destination-unreachable | echo-reply | echo-request | group-query | group-reduction | group-report | packet-too-big | parameter-problem | time-exceeded }
signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing } [ action { { drop | logging } * | none } ]
undo signature detect ip-option { option-code | internet-timestamp | loose-source-routing | record-route | route-alert | security | stream-id | strict-source-routing }
signature detect ipv6-ext-header ext-header-value [ action { { drop | logging } * | none } ]
undo signature detect ipv6-ext-header next-header-value
所有类型的单包攻击报文的特征检测均处于关闭状态。
攻击防范策略视图
fraggle:表示Fraggle类型的报文攻击。
fragment:表示IP分片报文攻击。
icmp-type:表示ICMP类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmp-type-value:表示ICMP报文类型的数值,取值范围为0~255。
·     address-mask-reply:表示ICMP address mask reply类型的报文攻击。
·     address-mask-request:表示ICMP address mask request类型的报文攻击。
·     destination-unreachable:表示ICMP destination unreachable类型的报文攻击。
·     echo-reply:表示ICMP echo reply类型的报文攻击。
·     echo-request:表示ICMP echo request类型的报文攻击。
·     information-reply:表示ICMP information reply类型的报文攻击。
·     information-request:表示ICMP information request类型的报文攻击。
·     parameter-problem:表示ICMP para problem类型的报文攻击。
·     redirect:表示ICMP redirect类型的报文攻击。
·     source-quench:表示ICMP source quench类型的报文攻击。
·     time-exceeded:表示ICMP time exceeded类型的报文攻击。
·     timestamp-reply:表示ICMP timestamp reply类型的报文攻击。
·     timestamp-request:表示ICMP timestamp request类型的报文攻击。
icmpv6-type:表示ICMPv6类型的报文攻击。可以指定报文的类型值,或者指定报文的类型关键字。
·     icmpv6-type-value:表示ICMPv6报文类型的数值,取值范围为0~255。
·     destination-unreachable:表示ICMPv6 destination unreachable类型的报文攻击。
·     echo-reply:表示ICMPv6 echo reply类型的报文攻击。
·     echo-request:表示ICMPv6 echo request类型的报文攻击。
·     group-query:表示ICMPv6 group query类型的报文攻击。
·     group-reduction:表示ICMPv6 group reduction类型的报文攻击。
·     group-report:表示ICMPv6 group report类型的报文攻击。
·     packet-too-big:表示ICMPv6 packet too big类型的报文攻击。
·     parameter-problem:表示ICMPv6 para problem类型的报文攻击。
·     time-exceeded:表示ICMPv6 time exceeded类型的报文攻击。
impossible:表示IP不可信报文的攻击。
ip-option:表示IP选项类型的报文攻击。可以指定IP选项代码值,或者指定IP选项关键字。
·     option-code:表示IP选项代码值,取值范围为0~255。
·     internet-timestamp:表示IP选项timestamp类型的报文攻击。
·     loose-source-routing:表示IP选项loose source route类型的报文攻击。
·     record-route:表示IP选项record packet route类型的报文攻击。
·     route-alert:表示IP选项route alert类型的报文攻击。
·     security:表示IP选项security类型的报文攻击。
·     stream-id:表示IP选项stream identifier类型的报文攻击。
·     strict-source-routing:表示IP选项strict source route类型的报文攻击。
ip-option-abnormal:表示IP选项异常类型的报文攻击。
ipv6-ext-header ext-header-value:表示IPv6扩展头参数值,取值范围在0~255。
land:表示Land类型的报文攻击。
large-icmp:表示超大ICMP报文的攻击。
large-icmpv6:表示超大ICMPv6报文的攻击。
ping-of-death:表示Ping-of-death类型的报文攻击。
smurf:表示Smurf类型的报文攻击。
snork:表示UDP Snork attack类型的报文攻击。
tcp-all-flags:表示TCP所有标志位均置位的报文攻击。
tcp-fin-only:表示TCP仅FIN标志被置位的报文攻击。
tcp-invalid-flags:表示TCP 标志位非法的报文攻击。
tcp-null-flag:表示TCP 标志位为零的报文攻击。
tcp-syn-fin:表示TCP SYN和FIN标志位被同时置位的报文攻击。
teardrop:表示teardrop类型的报文攻击。
tiny-fragment:表示IP分片报文的攻击。
traceroute:表示Trace route类型的报文攻击。
udp-bomb:表示UDP Bomb attack类型的报文攻击。
winnuke:表示WinNuke类型的报文攻击。
action:对指定报文攻击所采取的攻击防范处理行为。若未指定本参数,则采用该攻击报文所属的攻击防范级别所对应的默认处理行为。
·     drop:设置单包攻击的处理行为为丢弃报文。
·     logging:设置单包攻击的处理行为为发送日志。
·     none:不采取任何动作。
可以通过多次执行本命令开启多种类型的单包攻击报文的特征检测。
若通过数值指定了报文类型,则当指定的数值为标准的报文类型值时,在显示信息中将会显示该数值对应的报文类型字符串,否则显示为数值。
# 在攻击防范策略atk-policy-1中开启对IP分片攻击报文的特征检测,并指定攻击防范处理行为为为丢弃报文。
[Sysname-attack-defense-policy-atk-policy-1] signature detect fragment action drop
·     signature level action
signature level action命令用来配置指定级别单包攻击的处理行为。
undo signature level action命令用来恢复缺省情况。
signature level { high | info | low | medium } action { { drop | logging } * | none }
undo signature level { high | info | low | medium } action
对提示级别和低级别的单包攻击的处理行为是发送日志;对中级别的单包攻击的处理行为是发送日志并丢包;对高级别的单包攻击的处理行为是发送日志并丢包。
攻击防范策略视图
high:表示高级别的单包攻击,暂无实例。
info:表示提示级别的单包攻击,例如Large ICMP。
low:表示低级别的单包攻击,例如Traceroute。
medium:表示中级别的单包攻击,例如Winnuke。
none:不采取任何动作。
系统根据单包攻击结果的严重程度由低到高将其划分为四个攻击级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有类型的单包攻击报文的特征检测。
若同时通过signature detect命令开启了具体类型的单包攻击报文的特征检测,则以signature detect命令配置的参数为准。
# 在攻击防范策略atk-policy-1中配置对提示级别的单包攻击的处理行为是丢弃后续报文。
[Sysname] attack-defense policy 1
[Sysname-attack-defense-policy-1] signature level info action drop
·     signature detect
·     signature level detect
signature level detect命令用来开启指定级别单包攻击报文的特征检测。
undo signature level detect命令用来关闭对指定级别的单包攻击报文的特征检测。
signature level { high | info | low | medium } detect
undo signature level { high | info | low | medium } detect
未开启任何级别的单包攻击报文的特征检测。
攻击防范策略视图
info:表示提示级别的单包攻击,例如Large ICMP报文攻击。
low:表示低级别的单包攻击,例如Traceroute报文攻击。
medium:表示中级别的单包攻击,例如Winnuke报文攻击。
系统根据单包攻击结果的严重程度将其划分为四个级别:提示、低级、中级、高级。开启某一个级别的单包攻击报文的特征检测,相当于批量开启了属于该级别的所有单包攻击报文的特征检测。针对某一级别的单包攻击的处理行为由signature level action命令指定。若通过signature detect命令开启了具体的单包攻击报文的特征检测,则对该类攻击报文的处理行为以signature detect命令配置的参数为准。
可通过display attack-defense policy命令查看各类型单包攻击所属的级别。
# 在攻击防范策略atk-policy-1中开启提示级别的单包攻击报文的特征检测。
[Sysname-attack-defense-policy-1] signature level info detect
·     signature detect
syn-ack-flood action命令用来配置对SYN-ACK flood攻击防范的全局处理行为。
undo syn-ack-flood action命令用来恢复缺省情况。
syn-ack-flood action { drop | logging }*
不对检测到的 SYN-ACK flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN-ACK报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对SYN-ACK flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood action drop
·     syn-ack-flood detect
·     syn-ack-flood detect non-specific
·     syn-ack-flood threshold
syn-ack-flood detect命令用来对指定IP地址的SYN-ACK flood攻击防范检测,并配置SYN-ACK flood攻击防范检测触发阈值和防范行为。
undo syn-ack-flood detect命令用来关闭对指定IP地址的SYN-ACK flood攻击防范检测。
syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo syn-ack-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置SYN-ACK flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定SYN-ACK flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN-ACK报文数目,取值范围为1~1000000。
action:设置对SYN-ACK flood攻击的处理行为。若未指定本参数,则表示采用SYN-ACK flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN-ACK报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置SYN-ACK flood攻击防范检测。
# 开启对IP地址192.168.1.2的SYN-ACK flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN-ACK报文数持续达到或超过2000时,启动SYN-ACK攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect ip 192.168.1.2 threshold 2000
·     syn-ack-flood action
syn-ack-flood detect non-specific命令用来对所有非受保护IP地址开启SYN-ACK flood攻击防范检测。
undo syn-ack-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN-ACK flood攻击防范检测。
未对任何非受保护IP地址开启SYN-ACK flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN-ACK flood攻击防范检测后,设备将采用全局的阈值设置(由syn-ack-flood threshold命令设置)和处理行为(由syn-ack-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启UDP flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood detect non-specific
·     syn-ack flood action
1.1.57  syn-ack-flood threshold
syn-ack-flood threshold命令用来配置SYN-ACK flood攻击防范的全局触发阈值。
undo syn-ack-flood threshold命令用来恢复缺省情况。
syn-ack-flood threshold threshold-value
SYN-ACK flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN-ACK报文数目,取值范围为1~1000000。
使能SYN-ACK flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN-ACK报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN-ACK flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置SYN-ACK flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN-ACK报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN-ACK flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN-ACK报文数持续达到或超过100时,启动SYN-ACK flood攻击防范。
[Sysname] attack-defense policy atk-policy-1
[Sysname-attack-defense-policy-atk-policy-1] syn-ack-flood threshold 100
1.1.58  syn-flood action
syn-flood action命令用来配置对SYN flood攻击防范的全局处理行为。
undo syn-flood action命令用来恢复缺省情况。
syn-flood action { drop | logging } *
不对检测到的SYN flood攻击采取任何措施。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有SYN报文都会被丢弃。
logging:表示输出告警日志,即设备检测到攻击发生时,生成告警信息。
# 在攻击防范策略atk-policy-1中配置对SYN flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood action drop
·     syn-flood detect non-specific
·     syn-flood detect
·     syn-flood threshold
1.1.59  syn-flood detect
syn-flood detect命令用来开启对指定IP地址的SYN flood攻击防范检测,并配置SYN flood攻击防范检测的触发阈值和对SYN flood攻击的处理行为。
undo syn-flood detect命令用来关闭对指定IP地址的SYN flood攻击防范检测。
syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo syn-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置SYN flood攻击防范检测。
攻击防范策略视图
ip ipv4-address:指定要保护的IPv4地址。该IPv4地址不能为全1地址或全0地址。
ipv6 ipv6-address:指定要保护的IPv6地址。
vpn-instance vpn-instance-name:受保护IP地址所属的VPN实例。其中,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若未指定本参数,则表示该保护IP地址属于公网。
threshold threshold-value:指定SYN flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的SYN报文数目,取值范围为1~1000000。
action:设置对SYN flood攻击的处理行为。若未指定本参数,则表示采用SYN flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送SYN报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置SYN flood攻击防范检测。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的SYN flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的SYN报文数持续达到或超过2000时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect ip 192.168.1.2 threshold 2000
·     syn-flood action
1.1.60  syn-flood detect non-specific
syn-flood detect non-specific命令用来对所有非受保护IP地址开启SYN flood攻击防范检测。
undo syn-flood detect non-specific命令用来关闭对所有非受保护IP地址的SYN flood攻击防范检测。
未对任何非受保护IP地址开启SYN flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启SYN flood攻击防范检测后,设备将采用全局的阈值设置(由syn-flood threshold命令设置)和处理行为(由syn-flood action命令配置)对这些IP地址进行保护。
# 在攻击防范策略atk-policy-1中,对所有非受保护IP地址开启SYN flood攻击防范检测。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood detect non-specific
·     syn-flood action
·     syn-flood detect
1.1.61  syn-flood threshold
syn-flood threshold命令用来配置SYN flood攻击防范的全局触发阈值。
undo syn-flood threshold命令用来恢复缺省情况。
syn-flood threshold threshold-value
SYN flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的SYN报文数目,取值范围为1~1000000。
使能SYN flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送SYN报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了SYN flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置SYN flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的SYN报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置SYN flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的SYN报文数持续达到或超过100时,启动SYN flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] syn-flood threshold 100
·     syn-flood action
·     syn-flood detect
1.1.62  udp-flood action
udp-flood action命令用来配置对UDP flood攻击防范的全局处理行为。
undo udp-flood action命令用来恢复缺省情况。
udp-flood action { drop | logging } *
不对检测到的UDP flood攻击进行任何处理。
攻击防范策略视图
drop:表示丢弃攻击报文,即设备检测到攻击发生后,向被攻击者发送的后续所有UDP报文都会被丢弃。
# 在攻击防范策略atk-policy-1中配置对UDP flood攻击防范的全局处理行为是丢弃后续报文。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood action drop
·     udp-flood detect
·     udp-flood detect non-specific
·     udp-flood threshold
1.1.63  udp-flood detect
udp-flood detect命令用来开启对指定IP地址的UDP flood攻击防范检测,并配置UDP flood攻击防范检测的触发阈值和对UDP flood攻击的处理行为。
undo udp-flood detect命令用来关闭对指定IP地址的UDP flood攻击防范检测。
udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] [ threshold threshold-value ] [ action { { drop | logging } * | none } ]
undo udp-flood detect { ip ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
未对任何指定IP地址配置UDP flood攻击防范检测。
攻击防范策略视图
threshold threshold-value:指定UDP flood攻击防范的触发阈值。其中,threshold-value为向指定IP地址每秒发送的UDP报文数目,取值范围为1~1000000。
action:设置对UDP flood攻击的处理行为。若未指定本参数,则表示采用UDP flood攻击防范的全局处理行为。
none:表示不采取任何动作。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向指定IP地址发送UDP报文的速率持续达到或超过了触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
每个攻击防范策略下可以同时对多个IP地址配置UDP flood攻击防范参数。
# 在攻击防范策略atk-policy-1中开启对IP地址192.168.1.2的UDP flood攻击防范检测,并指定触发阈值为2000。当设备监测到向该IP地址每秒发送的UDP报文数持续达到或超过2000时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect ip 192.168.1.2 threshold 2000
·     udp-flood action
1.1.64  udp-flood detect non-specific
udp-flood detect non-specific命令用来对所有非受保护IP地址开启UDP flood攻击防范检测。
undo udp-flood detect non-specific命令用来关闭对所有非受保护IP地址的UDP flood攻击防范检测。
未对任何非受保护IP地址开启UDP flood攻击防范检测。
攻击防范策略视图
对所有非受保护IP地址开启UDP flood攻击防范检测后,设备将采用全局的阈值设置(由udp-flood threshold命令设置)和处理行为(由udp-flood action命令配置)对这些IP地址进行保护。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood detect non-specific
·     udp-flood action
·     udp-flood detect
1.1.65  udp-flood threshold
udp-flood threshold命令用来配置UDP flood攻击防范的全局触发阈值。
undo udp-flood threshold命令用来恢复缺省情况。
udp-flood threshold threshold-value
UDP flood攻击防范的全局触发阈值为1000。
攻击防范策略视图
threshold-value:指定向某IP地址每秒发送的UDP报文数目,取值范围为1~1000000。
使能UDP flood攻击防范后,设备处于攻击检测状态,当它监测到向某IP地址发送UDP报文的速率持续达到或超过了该触发阈值时,即认为该IP地址受到了UDP flood攻击,则进入攻击防范状态,并根据配置启动相应的防范措施。此后,当设备检测到向该服务器发送报文的速率低于恢复阈值(触发阈值的3/4)时,即认为攻击结束,则由攻击防范状态恢复为攻击检测状态,并停止执行防范措施。
对于未专门配置UDP flood攻击防范检测的IP地址,设备采用全局的阈值设置来进行保护。阈值的取值需要根据实际网络应用场景进行调整,对于正常情况下到被保护对象(HTTP服务器或者FTP服务器)的UDP报文流量较大的应用场景,建议调大触发阈值,以免阈值太小对正常的业务流量造成影响;对于网络状况较差,且对攻击流量比较敏感的场景,可以适当调小触发阈值。
# 在攻击防范策略atk-policy-1中配置UDP flood攻击防范的全局触发阈值为100,即当设备监测到向某IP地址每秒发送的UDP报文数持续达到或超过100时,启动UDP flood攻击防范。
[Sysname-attack-defense-policy-atk-policy-1] udp-flood threshold 100
·     udp-flood action
·     udp-flood detect
