H3C SecPath系列防火墙 Probe命令参考(V7)(R9514 R9323)-6W203
01-Probe命令
本章节下载: 01-Probe命令  (1009.64 KB)
01-Probe命令
1 Probe命令
1.1 C
1.1.1 crypto-engine accelerator disable
1.2 D
1.2.1 debugging ha
1.2.2 debugging lipc
1.2.3 debugging lipc mtcp
1.2.4 debugging lipc stcp
1.2.5 debugging system internal adj4
1.2.6 debugging system internal adj6
1.2.7 debugging system internal httpd
1.2.8 debugging system internal ike detail
1.2.9 debugging system internal ikev2 detail
1.2.10 debugging system internal ipsec packet detail
1.2.11 debugging system internal stg
1.2.12 debugging system internal stp
1.2.13 debugging system internal vlan
1.2.14 debugging transceiver
1.2.15 display fastforward session table
1.2.16 display hardware internal cpld reboot
1.2.17 display hardware internal gm-engine statistics
1.2.18 display hardware internal irf statistics
1.2.19 display hardware internal transceiver register interface
1.2.20 display hardware internal xlp txlane info
1.2.21 display system internal acl
1.2.22 display system internal adj4 entry
1.2.23 display system internal adj4 statistics
1.2.24 display system internal adj6 entry
1.2.25 display system internal adj6 statistics
1.2.26 display system internal adjacent-table
1.2.27 display system internal aft
1.2.28 display system internal aspf statistics
1.2.29 display system internal attack-defense scan stat-nodes ip
1.2.30 display system internal attack-defense scan stat-nodes ipv6(for security zone)
1.2.31 display system internal bgp address-family statistics
1.2.32 display system internal bgp graceful-restart statistics
1.2.33 display system internal bgp interface
1.2.34 display system internal bgp link-state
1.2.35 display system internal bgp log
1.2.36 display system internal bgp nib
1.2.37 display system internal bgp nib log
1.2.38 display system internal bgp peer standby
1.2.39 display system internal bgp peer statistics
1.2.40 display system internal bgp protocol statistics
1.2.41 display system internal bgp routing-table advertise-info
1.2.42 display system internal bgp routing-table ipv4 unicast outlabel standby
1.2.43 display system internal bgp routing-table ipv4 unicast standby
1.2.44 display system internal bgp routing-table ipv6 unicast outlabel standby
1.2.45 display system internal bgp routing-table ipv6 unicast standby
1.2.46 display system internal bgp routing-table verbose
1.2.47 display system internal bgpm log
1.2.48 display system internal bridge cache ip verbose
1.2.49 display system internal bridge cache ipv6 verbose
1.2.50 display system internal client-verify http redirect-node
1.2.51 display system internal context block-information
1.2.52 display system internal context configuration-status
1.2.53 display system internal context running-status
1.2.54 display system internal customlog host
1.2.55 display system internal customlog mbuf dump
1.2.56 display system internal customlog mbuf usage
1.2.57 display system internal customlog test
1.2.58 display system internal data-filter match
1.2.59 display system internal data-filter policy
1.2.60 display system internal data-filter rule
1.2.61 display system internal dbm
1.2.62 display system internal dropstats registered-modules
1.2.63 display system internal ethernet character
1.2.64 display system internal ethernet controlblock
1.2.65 display system internal ha service
1.2.66 display system internal ha service-group
1.2.67 display system internal ha statistics
1.2.68 display system internal hot-backup broadcast node
1.2.69 display system internal hot-backup peer
1.2.70 display system internal ifmgr brief
1.2.71 display system internal ifmgr down
1.2.72 display system internal ifmgr entry
1.2.73 display system internal ifmgr event
1.2.74 display system internal ifmgr hotplug
1.2.75 display system internal ifmgr index
1.2.76 display system internal ifmgr list
1.2.77 display system internal ifmgr name
1.2.78 display system internal ifmgr type
1.2.79 display system internal ike phase2-sa count
1.2.80 display system internal ike phase2-sa verbose
1.2.81 display system internal ike received-message count
1.2.82 display system internal ike sent-message count
1.2.83 display system internal ikev2 child-sa count
1.2.84 display system internal inspect dim-rule
1.2.85 display system internal inspect hit-statistics
1.2.86 display system internal inspect http
1.2.87 display system internal inspect memory engine ac
1.2.88 display system internal inspect memory engine mn
1.2.89 display system internal inspect memory rule
1.2.90 display system internal inspect session table
1.2.91 display system internal inspect statistic packet
1.2.92 display system internal ip packet-drop statistics
1.2.93 display system internal ip routing-table
1.2.94 display system internal ip routing-table acl
1.2.95 display system internal ip routing-table ip-address
1.2.96 display system internal ip routing-table prefix-list
1.2.97 display system internal ip routing-table protocol
1.2.98 display system internal ip routing-table statistics
1.2.99 display system internal ip source binding
1.2.100 display system internal ipsec block-flow
1.2.101 display system internal ipsec received-message
1.2.102 display system internal ipsec sent-message
1.2.103 display system internal ipsec sp
1.2.104 display system internal ipv6 adjacent-table
1.2.105 display system internal ipv6 fast-forwarding cache verbose
1.2.106 display system internal ipv6 fast-forwarding statistics
1.2.107 display system internal ipv6 packet-drop statistics
1.2.108 display system internal ipv6 pbr fib
1.2.109 display system internal ipv6 pbr kernel policy
1.2.110 display system internal ipv6 pbr policy
1.2.111 display system internal ipv6 rib event attribute
1.2.112 display system internal ipv6 rib event policy
1.2.113 display system internal ipv6 rib event prefix
1.2.114 display system internal ipv6 rib event protocol
1.2.115 display system internal ipv6 rib event statistics
1.2.116 display system internal ipv6 rib instance
1.2.117 display system internal ipv6 rib log
1.2.118 display system internal ipv6 rib memory
1.2.119 display system internal ipv6 rib nib
1.2.120 display system internal ipv6 rib nib log
1.2.121 display system internal ipv6 rib prefix
1.2.122 display system internal ipv6 rib summary
1.2.123 display system internal ipv6 route-direct interface
1.2.124 display system internal ipv6 route-direct log
1.2.125 display system internal ipv6 route-static nib log
1.2.126 display system internal ipv6 routing-table
1.2.127 display system internal ipv6 routing-table acl
1.2.128 display system internal ipv6 routing-table ipv6-address
1.2.129 display system internal ipv6 routing-table prefix-list
1.2.130 display system internal ipv6 routing-table protocol
1.2.131 display system internal ipv6 routing-table statistics
1.2.132 display system internal ipv6 source binding
1.2.133 display system internal irf global
1.2.134 display system internal irf msg
1.2.135 display system internal irf roledb
1.2.136 display system internal irf topodb
1.2.137 display system internal isis import-route
1.2.138 display system internal isis import-route ipv6
1.2.139 display system internal isis interface
1.2.140 display system internal isis interface ipv6
1.2.141 display system internal isis interface standby
1.2.142 display system internal isis keychain
1.2.143 display system internal isis lsdb standby
1.2.144 display system internal isis nib
1.2.145 display system internal isis nib ipv6
1.2.146 display system internal isis nib log
1.2.147 display system internal isis peer standby
1.2.148 display system internal isis prefix
1.2.149 display system internal isis prefix ipv6
1.2.150 display system internal isis standby
1.2.151 display system internal isis status
1.2.152 display system internal kernel memory dump
1.2.153 display system internal kernel memory pool
1.2.154 display system internal license buffer-data
1.2.155 display system internal license feature-set
1.2.156 display system internal license fifo
1.2.157 display system internal license lipc
1.2.158 display system internal license lipc hash
1.2.159 display system internal license lmi-paa
1.2.160 display system internal link-aggregation global
1.2.161 display system internal link-aggregation interface
1.2.162 display system internal lipc dump
1.2.163 display system internal lipc dump configuration
1.2.164 display system internal lipc history
1.2.165 display system internal lipc lcmp statistics
1.2.166 display system internal lipc lgmp group
1.2.167 display system internal lipc lgmp group-list
1.2.168 display system internal lipc lgmp physical-group
1.2.169 display system internal lipc lgmp physical-group-list
1.2.170 display system internal lipc lgmp statistics
1.2.171 display system internal lipc lip statistics
1.2.172 display system internal lipc loop statistics
1.2.173 display system internal lipc mtcp group
1.2.174 display system internal lipc mtcp group all
1.2.175 display system internal lipc mtcp performance
1.2.176 display system internal lipc mtcp statistics
1.2.177 display system internal lipc pcb mbuf statistics
1.2.178 display system internal lipc pcb statistics
1.2.179 display system internal lipc physical
1.2.180 display system internal lipc publish global-cb
1.2.181 display system internal lipc publish statistics
1.2.182 display system internal lipc stcp event
1.2.183 display system internal lipc stcp global-server
1.2.184 display system internal lipc stcp links
1.2.185 display system internal lipc stcp performance
1.2.186 display system internal lipc stcp port
1.2.187 display system internal lipc stcp statistics
1.2.188 display system internal lipc stcp status
1.2.189 display system internal lipc stream
1.2.190 display system internal lipc sudp pcb-info
1.2.191 display system internal lipc sudp statistics
1.2.192 display system internal lipc sudp { global-port | local-port }
1.2.193 display system internal lipc topology history
1.2.194 display system internal lipc topology link
1.2.195 display system internal lipc topology node
1.2.196 display system internal lipc topology process-time
1.2.197 display system internal lipc topology statistics
1.2.198 display system internal lipc topology status
1.2.199 display system internal loadbalance connections
1.2.200 display system internal loadbalance connections count
1.2.201 display system internal loadbalance fdb-info
1.2.202 display system internal loadbalance local-dns-server statistics error
1.2.203 display system internal loadbalance local-dns-server statistics predictor-times
1.2.204 display system internal loadbalance local-dns-server statistics selected-times
1.2.205 display system internal loadbalance statistics alg
1.2.206 display system internal loadbalance statistics configuration
1.2.207 display system internal loadbalance statistics error
1.2.208 display system internal loadbalance statistics http
1.2.209 display system internal loadbalance statistics probe
1.2.210 display system internal loadbalance statistics proximity
1.2.211 display system internal local-dns-server abnormal request
1.2.212 display system internal local-dns-server statistics
1.2.213 display system internal mac-address configuration
1.2.214 display system internal mac-address learned
1.2.215 display system internal mac-address protocol
1.2.216 display system internal mac-address statistics
1.2.217 display system internal mac-forwarding cache ip verbose
1.2.218 display system internal mac-forwarding cache ipv6 verbose
1.2.219 display system internal mac-forwarding controlblock
1.2.220 display system internal mac-forwarding packet-drop statistics
1.2.221 display system internal mbuf relay statistics
1.2.222 display system internal mbuf socket statistics
1.2.223 display system internal mrib interface statistics
1.2.224 display system internal mrib mbr
1.2.225 display system internal mrib mbr interface standby
1.2.226 display system internal multicast  fast-forwarding cache verbose
1.2.227 display system internal multicast boundary standby
1.2.228 display system internal multicast capability
1.2.229 display system internal multicast forwarding-table dummy
1.2.230 display system internal multicast forwarding-table verbose
1.2.231 display system internal multicast record
1.2.232 display system internal nat
1.2.233 display system internal nat aging-queue
1.2.234 display system internal nat hot-backup statistics
1.2.235 display system internal nat statistics
1.2.236 display system internal object-group
1.2.237 display system internal object-policy
1.2.238 display system internal ospf event-log
1.2.239 display system internal ospf flood-list
1.2.240 display system internal ospf interface
1.2.241 display system internal ospf interface standby
1.2.242 display system internal ospf keychain
1.2.243 display system internal ospf lsdb
1.2.244 display system internal ospf lsdb standby
1.2.245 display system internal ospf nib
1.2.246 display system internal ospf peer standby
1.2.247 display system internal ospf peer statistics standby
1.2.248 display system internal ospf prefix
1.2.249 display system internal ospf router
1.2.250 display system internal ospf statistics
1.2.251 display system internal ospf status
1.2.252 display system internal ospf vlink standby
1.2.253 display system internal ospfv3 event-log
1.2.254 display system internal ospfv3 flood-list
1.2.255 display system internal ospfv3 interface
1.2.256 display system internal ospfv3 interface standby
1.2.257 display system internal ospfv3 lsdb
1.2.258 display system internal ospfv3 lsdb standby
1.2.259 display system internal ospfv3 nib
1.2.260 display system internal ospfv3 peer standby
1.2.261 display system internal ospfv3 prefix
1.2.262 display system internal ospfv3 router
1.2.263 display system internal ospfv3 standby
1.2.264 display system internal ospfv3 statistics
1.2.265 display system internal ospfv3 status
1.2.266 display system internal ospfv3 vlink standby
1.2.267 display system internal packet-capture statistics
1.2.268 display system internal pbr fib
1.2.269 display system internal pbr kernel policy
1.2.270 display system internal pbr policy
1.2.271 display system internal pim bsr-info standby
1.2.272 display system internal pim c-rp standby
1.2.273 display system internal pim interface
1.2.274 display system internal pim neighbor standby
1.2.275 display system internal pim routing-table standby
1.2.276 display system internal pim rp
1.2.277 display system internal pim rp-info standby
1.2.278 display system internal pim thread
1.2.279 display system internal pim thread main standby
1.2.280 display system internal ppp statistics
1.2.281 display system internal process state
1.2.282 display system internal rib event attribute
1.2.283 display system internal rib event policy
1.2.284 display system internal rib event prefix
1.2.285 display system internal rib event protocol
1.2.286 display system internal rib event statistics
1.2.287 display system internal rib instance
1.2.288 display system internal rib log
1.2.289 display system internal rib memory
1.2.290 display system internal rib nib
1.2.291 display system internal rib nib log
1.2.292 display system internal rib prefix
1.2.293 display system internal rib summary
1.2.294 display system internal rip database standby
1.2.295 display system internal rip graceful-restart event-log
1.2.296 display system internal rip interface
1.2.297 display system internal rip interface standby
1.2.298 display system internal rip neighbor standby
1.2.299 display system internal rip nib
1.2.300 display system internal rip nib log
1.2.301 display system internal rip non-stop-routing event-log
1.2.302 display system internal rip route standby
1.2.303 display system internal rip status
1.2.304 display system internal ripng database standby
1.2.305 display system internal ripng graceful-restart event-log
1.2.306 display system internal ripng interface
1.2.307 display system internal ripng interface standby
1.2.308 display system internal ripng neighbor standby
1.2.309 display system internal ripng nib
1.2.310 display system internal ripng nib log
1.2.311 display system internal ripng non-stop-routing event-log
1.2.312 display system internal ripng route standby
1.2.313 display system internal ripng status
1.2.314 display system internal route-direct interface
1.2.315 display system internal route-direct log
1.2.316 display system internal route-static nib log
1.2.317 display system internal security-policy
1.2.318 display system internal security-policy dbm
1.2.319 display system internal security-policy kernel
1.2.320 display system internal session
1.2.321 display system internal session aging-queue
1.2.322 display system internal session alg-exception
1.2.323 display system internal session hot-backup statistics
1.2.324 display system internal session relation hot-backup statistics
1.2.325 display system internal session relation-table ipv4
1.2.326 display system internal session relation-table ipv6
1.2.327 display system internal session statistics
1.2.328 display system internal session table ipv4
1.2.329 display system internal session table ipv6
1.2.330 display system internal sslvpn statistics
1.2.331 display system internal startup cache
1.2.332 display system internal stp bridge-info
1.2.333 display system internal stp port-info
1.2.334 display system internal tunnel data
1.2.335 display system internal userlog mbuf dump
1.2.336 display system internal userlog statistic
1.2.337 display system internal userlog test
1.2.338 display system internal virtual-crypto-engine
1.2.339 display system internal virtual-crypto-engine statistics
1.2.340 display system internal vlan
1.2.341 display system internal vrrp ipv6 kernel
1.2.342 display system internal vrrp kernel
1.2.343 display transceiver information
1.2.344 display transceiver moduleinfo
1.2.345 display transceiver register
1.3 F
1.3.1 follow
1.4 L
1.4.1 license check-timer
1.4.2 license file-timer
1.4.3 lipc connection detect
1.4.4 lipc dump
1.4.5 lipc dump buffer
1.4.6 lipc dump enable
1.4.7 lipc dump offset
1.4.8 lipc dump-port
1.4.9 lipc performance
1.4.10 lipc ping
1.4.11 lipc timeout
1.5 M
1.5.1 memory boundary-check enable
1.5.2 memory boundary-check scan
1.5.3 monitor lipc
1.5.4 multicast record limit
1.6 R
1.6.1 reset hardware internal gm-engine statistics
1.6.2 reset hardware internal irf statistics
1.6.3 reset system internal adj4 statistics
1.6.4 reset system internal adj6 statistics
1.6.5 reset system internal aspf statistics
1.6.6 reset system internal bgp link-state
1.6.7 reset system internal bgp log
1.6.8 reset system internal bgpm log
1.6.9 reset system internal data-filter match statistics
1.6.10 reset system internal data-filter rule statistics
1.6.11 reset system internal inspect hit-statistics
1.6.12 reset system internal inspect http
1.6.13 reset system internal ip packet-drop statistics
1.6.14 reset system internal ip routing-table statistics protocol
1.6.15 reset system internal ipv6 fast-forwarding statistics
1.6.16 reset system internal ipv6 packet-drop statistics
1.6.17 reset system internal ipv6 rib log
1.6.18 reset system internal ipv6 rib nib log
1.6.19 reset system internal ipv6 rib summary
1.6.20 reset system internal ipv6 route-direct log
1.6.21 reset system internal ipv6 route-static nib log
1.6.22 reset system internal ipv6 routing-table statistics protocol
1.6.23 reset system internal irf msg
1.6.24 reset system internal lipc dump buffer
1.6.25 reset system internal loadbalance local-dns-server statistics
1.6.26 reset system internal loadbalance statistics
1.6.27 reset system internal local-dns-server statistics
1.6.28 reset system internal mac-address statistics
1.6.29 reset system internal mac-forwarding packet-drop statistics
1.6.30 reset system internal mbuf relay statistics
1.6.31 reset system internal multicast forwarding-table dummy
1.6.32 reset system internal multicast record
1.6.33 reset system internal nat statistics
1.6.34 reset system internal ospf event-log
1.6.35 reset system internal packet-capture statistics
1.6.36 reset system internal ppp statistics
1.6.37 reset system internal rib log
1.6.38 reset system internal rib nib log
1.6.39 reset system internal rib summary
1.6.40 reset system internal rip graceful-restart event-log
1.6.41 reset system internal rip non-stop-routing event-log
1.6.42 reset system internal ripng graceful-restart event-log
1.6.43 reset system internal ripng non-stop-routing event-log
1.6.44 reset system internal route-direct log
1.6.45 reset system internal route-static nib log
1.6.46 reset system internal session alg statistics
1.6.47 reset system internal session statistics
1.6.48 reset system internal sslvpn statistics
1.6.49 reset system internal virtual-crypto-engine statistics
1.7 S
1.7.1 set xlp txlane
1.7.2 switch flow
1.7.3 switch show-flow
1.7.4 system internal relation hot-backup force-delete enable
1.7.5 system internal relation hot-backup update enable
1.7.6 system internal relation synchronization enable
1.7.7 system internal session alg statistics
1.7.8 system internal session hot-backup aging-request enable
1.7.9 system internal session hot-backup aging-response enable
1.7.10 system internal session hot-backup broadcast enable
1.7.11 system internal session hot-backup force-delete enable
1 Probe命令
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
1.1  C
crypto-engine accelerator disable命令用来关闭硬件加密引擎。
undo crypto-engine accelerator disable命令用来开启硬件加密引擎。
硬件加密引擎处于开启状态。
Probe视图
context-admin
无
开启硬件加密引擎加密功能,是指开启硬件加密引擎来加速加密过程。
硬件加密引擎的开启或关闭状态的改变对业务模块的影响由业务模块决定,例如,对于IPsec业务来说,硬件加密引擎状态的改变只对新建立的IPsec SA有影响,已建的IPsec SA仍旧使用之前选择的加密引擎来处理。因此,建议在开启或关闭硬件加密引擎之后,使用reset ipsec sa命令将当前已有的IPsec SA删除,使得所有新建立的IPsec SA都将使用新选择的加密引擎处理流程来处理。
硬件加密引擎加密功能仅允许在测试、调试或故障排除的环境下关闭,正常情况下不建议关闭该功能。
1.2  D
1.2.1  debugging ha
debugging ha命令用来打开HA各子模块的调试信息开关。
undo debugging ha命令用来关闭HA各子模块的调试信息开关。
debugging ha { all | config | fsm | policy | standby | sync }
undo debugging ha { all | config | fsm | policy | standby | sync }
HA各子模块的调试信息开关处于关闭状态。
context-admin
all:HA所有模块的信息。
config:config子模块的信息。
fsm:FSM子模块的信息。
policy:policy子模块的信息。
standby:备份HA模块的信息。
sync:sync子模块的信息。
# 打开HA FSM子模块的调试开关。
<Sysname> debugging ha fsm
debugging lipc命令用来打开LIPC的debug开关。
undo debugging lipc命令用来恢复缺省情况。
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
LIPC的debug开关处于关闭状态。
context-admin
detail:用来打开LIPC的报文详细内容的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
mtcp:用来打开LIPC的MTCP模块调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示主设备所在节点。
debugging lipc mtcp命令用来打开LIPC组播传输控制协议的调试信息开关。
undo debugging lipc mtcp命令用来恢复缺省情况。
debugging lipc mtcp [ group group-id ] [ lip lip ]
undo debugging lipc mtcp [ group group-id ] [ lip lip ]
LIPC组播传输控制协议调试信息开关处于关闭状态。
Probe视图
context-admin
group group-id:要调试的组播端口号,取值范围为0~65535。不指定该参数时,表示所有组播组。
debugging lipc stcp命令用来打开LIPC单播的调试信息开关。
undo debugging lipc stcp命令用来恢复缺省情况。
debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
undo debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
LIPC单播调试信息开关处于关闭状态。
Probe视图
context-admin
port port1 [ port port2 ]:port1和port2分别为连接的本地和对端端口号,取值范围为0~65535,缺省值为0。
debugging system internal adj4命令用来打开IPv4邻接表调试开关。
undo debugging system internal adj4命令用来关闭IPv4邻接表调试开关。
debugging system internal adj4 { bind | entry | hardware | notify }
undo debugging system internal adj4 { bind | entry | hardware | notify }
IPv4邻接表调试开关处于关闭状态。
Probe视图
context-admin
bind:打开VN/NHLFE表项绑定IPv4邻接表调试功能。
entry:打开IPv4邻接表项更新时调试功能。
hardware:打开IPv4邻接表下驱动调试功能。
notify:打开IPv4邻接表项变化时,反刷VN和NHLFE表项调试功能。
debugging system internal adj6命令用来打开IPv6邻接表调试开关。
undo debugging system internal adj6命令用来关闭IPv6邻接表调试开关。
debugging system internal adj6 { bind | entry | hardware | notify }
undo debugging system internal adj6 { bind | entry | hardware | notify }
IPv6邻接表调试开关处于关闭状态。
Probe视图
context-admin
bind:打开VN/NHLFE表项绑定IPv6邻接表调试功能。
entry:打开IPv6邻接表项更新时调试功能。
hardware:打开IPv6邻接表下驱动调试功能。
notify:打开IPv6邻接表项变化时,反刷VN和NHLFE表项调试功能。
debugging system internal httpd命令用来打开HTTPD的调试信息开关。
undo debugging system internal httpd命令用来关闭HTTPD的调试信息开关。
debugging system internal httpd { all | event | process | error }
undo debugging system internal httpd { all | event | process | error }
Probe视图
context-admin
all:打开HTTPD模块全部调试信息开关。
event:打开HTTPD模块的事件调试信息开关。
process:打开HTTPD模块的处理调试信息开关。
error:打开HTTPD模块的错误调试信息开关。
debugging system internal ike detail { event | packet [ remote-address { ipv4-address | ipv6 ipv6-address } [ local-address { ipv4-address | ipv6 ipv6-address } | remote-port port-number | vpn-instance vpn-instance-name ] * ] }
undo debugging system internal ike detail { event | packet }
Probe视图
context-admin
event:表示事件调试信息开关。
packet:表示报文调试信息开关。
remote-address:根据对端地址过滤调试信息。
local-address:根据本端地址过滤调试信息。
ipv4-address:表示IPv4地址。
ipv6 ipv6-address:表示IPv6地址。
remote-port remote-port:根据对端端口过滤调试信息。port-number表示对端端口号,取值范围为0~65535。
vpn-instance vpn-instance-name:根据对端地址所属的VPN实例过滤调试信息。vpn-instance-name为VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则表示根据对端地址所属公网过滤调试信息。
【描述】
debugging system internal ike detail命令用来打开IKE详细调试开关。undo debugging system internal ike detail命令用来关闭IKE详细调试开关。
缺省情况下,IKE详细调试开关处于关闭状态。
debugging system internal ikev2 detail命令用来打开IKEv2的详细调试开关。
debugging system internal ikev2 detail [ { event | packet | remote-address } { { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name | remote-port port-number | local-address { ipv4-address | ipv6 ipv6-address } ]* ]
undo debugging system interval ikev2 detail [ packet | event ]
Probe视图
context-admin
event:表示事件调试信息开关。
packet:表示报文调试信息开关。
【描述】
debugging system internal ikev2 detail命令用来打开IKEv2详细调试开关。undo debugging system internal ikev2 detail命令用来关闭IKEv2详细调试开关。
缺省情况下,IKEv2详细调试开关处于关闭状态。
debugging system internal ipsec packet detail命令用来打开IPsec转发过程的调试信息开关。
undo debugging system internal ipsec packet detail命令用来关闭IPsec转发过程的调试信息开关。
debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
undo debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
Probe视图
context-admin
acl [ ipv6 ] acl-number:显示符合指定高级ACL的调试信息。ipv6表示IPv6类型的高级ACL,若不指定,则表示IPv4类型的高级ACL。acl-number是高级ACL的变化,取值范围为3000~3999。
{ ipv6-policy | policy } policy-name [ policy-sequence-number ]:显示指定IPv4或IPv6 IPsec安全策略的调试信息。
·            ipv6-policy:IPv6 IPsec安全策略。
·            policy:IPv4 IPsec安全策略。
·            policy-name:IPsec安全策略的名称,为1~63个字符的字符串,不区分大小写。
·            policy-sequence-number:IPsec安全策略的顺序号,取值范围为1~65535,若不指定此参数,则表示显示指定名称IPsec安全策略中所有IPsec安全策略表项的调试信息。
profile profile-name:显示指定IPsec安全框架的调试信息。profile-name是IPsec安全框架的名称,为1~63个字符的字符串,不区分大小写。
remote { ipv4-address | ipv6 ipv6-address }:显示符合指定IPsec隧道对端IPv4/IPv6地址的过滤信息。
·            ipv4-address:IPsec隧道的对端IPv4地址。
·            ipv6 ipv6-address:IPsec隧道的对端IPv6地址。
spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number:显示符合SA的三元组信息(对端IP地址、安全协议、安全参数索引)的过滤信息。
·            ipv4-address:对端的IPv4地址。
·            ipv6 ipv6-address:对端的IPv6地址。
·            ah:AH协议。
·            esp:ESP协议。
·            spi-number:安全参数索引,取值范围为256~4294967295。
命令用于在Probe视图下查看IPsec转发过程中报文详细信息,包括加密前报文信息、加密后报文详细信息、解密前报文详细信息、解密后报文详细信息。
debugging system internal stg命令用来开启STG调试信息开关。
undo debugging system internal stg命令用来关闭STG调试信息开关。
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
STG调试信息开关处于关闭状态。
Probe视图
context-admin
all:表示STG所有调试信息开关。
bind:表示STG与VLAN绑定调试信息开关。
error:表示STG错误调试信息开关。
map:表示STG与STI映射事件调试信息开关。
state:表示STG状态设置调试信息开关。
tc:表示TC事件调试信息开关。
debugging system internal stp命令用来开启生成树进程间通信调试开关。
undo debugging system internal stp命令用来关闭生成树进程间通信调试开关。
debugging system internal stp ipc
undo debugging system internal stp ipc
生成树进程间通信调试开关处于关闭状态。
Probe视图
context-admin
ipc:表示生成树进程间通信调试信息开关。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
context-admin
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
debugging transceiver命令用来调试光模块的相关功能。
debugging transceiver { mibcache | moduleinfo | read_write_retry } { disable | enable } interface [ interface-type interface-number ]
光模块的调试开关处于关闭状态。
Probe视图
context-admin
moduleinfo:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块在需要使用光模块的信息时,必须直接从光模块中获取。关闭调试开关后,设备第一次识别光模块时,会在软件内部保存光模块的信息,以便上层模块可直接从软件中获取光模块的信息。
mibcache:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块需要使用MIB节点的值时,必须通过硬件中的数据立即构建光模块MIB节点的值。关闭调试开关后,系统后台会定期从硬件获取数据来构建光模块MIB节点的值,并将该值保存在内存中供上层模块使用。
read_write_retry:该参数用来控制读写错误的光模块信息时采取的措施。打开调试开关后,即便系统读写的光模块基本信息存在校验和错误,软件也不会重新读写。关闭调试开关后,当系统读写的光模块基本信息存在校验和错误时,软件会重新读写。
disable:关闭调试开关。
enable:打开调试开关。
interface [ interface-type interface-number ]:表示接口类型和接口编号。不指定该参数时,表示所有接口。需要注意的,配置该参数后,会开启/关闭接口所在单板的光模块的相关功能。
display fastforward session table命令用来显示未经过安全业务处理的会话表项。
display fastforward session table { ipv4 | ipv6 } [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ verbose ]
Probe视图
context-admin
ipv4:显示IPv4会话表项。
ipv6:显示IPv6会话表项。
slot slot-number:显示指定成员设备上的会话表项,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的会话表项。
source-ip source-ip:显示指定源IP地址的会话表项。其中,source-ip表示发起方到响应方会话的源IP地址。
destination-ip destination-ip:显示指定目的IP地址的会话表项。其中,destination-ip表示发起方到响应方会话的目的IP地址。
verbose:显示详细的会话表项。不指定该参数表示显示会话表项的概要信息。
如果除ipv4、ipv6外不指定任何参数,则显示所有未经过安全业务处理的IPv4或IPv6会话表项。
display hardware internal cpld reboot命令用来显示设备最近一次重启的原因。
display hardware internal cpld reboot slot slot-number
Probe
context-admin
slot slot-number:显示指定成员设备上最近一次重启的原因,slot-number表示设备在IRF中的成员编号。
display hardware internal gm-engine statistics命令用来显示国密硬件加密引擎的加解密统计信息。
display hardware internal gm-engine statistics slot-number subslot-number
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号
特性
F1000-E-G2/F1000-A-G2/F1000-S-G2/F1000-C-G2
支持
F100-E-G2/F100-A-G2/F100-M-G2/F100-S-G2/F100-C-G2
·         F100-E-G2/F100-A-G2:支持
·         F100-M-G2/F100-S-G2/F100-C-G2:不支持
F1000-C-EI/F100-E-EI/F100-A-EI/F100-C-EI/F100-A-SI
·         F1000-C-EI/F100-E-EI/F100-A-EI/F100-A-SI:支持
·         F100-C-EI:不支持
F100-C-HI/F100-S-HI/F100-A-HI/F1000-C-HI
·         F100-A-HI/F1000-C-HI:支持
·         F100-C-HI/F100-S-HI:不支持
F1000-C8180/F1000-C8170/F1000-C8160/F1000-C8150/F1000-C8130/F1000-C8120
·         F1000-C8180/F1000-C8170/F1000-C8160:支持
·         F1000-C8150/F1000-C8130/F1000-C8120:不支持
F100-C80-WiNet/F100-C60-WiNet
不支持
Probe视图
slot-number:表示单板所在槽位号。
subslot-number:表示单板所在子槽位号。
只有指定的国密硬件加密引擎在位时才会输出显示信息,否则不会输出显示信息。
display hardware internal irf statistics命令用来显示不同堆叠通道收发报文统计。
Probe视图
context-admin
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe视图
context-admin
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
display hardware internal xlp txlane info命令用来显示不同报文发送通道配置信息。
display hardware internal xlp txlane info slot slot-number
型号
特性
支持
·         F100-C-EI:不支持
不支持
Probe视图
context-admin
slot slot-number:显示指定成员设备上报文发送通道配置信息,slot-number表示设备在IRF中的成员编号。
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name } slot slot-number
Probe视图
context-admin
ipv6:指定ACL类型为IPv6 ACL。
mac:指定ACL类型为二层ACL。若未指定以上两种类型,则表示IPv4 ACL。
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
·            2000~2999:表示基本ACL。
·            3000~3999:表示高级ACL。
·            4000~4999:表示二层ACL。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
slot slot-number:显示指定成员设备上ACL的配置和运行情况,slot-number表示设备在IRF中的成员编号。
display system internal adj4 entry 命令用来显示指定IPv4邻接表项的详细信息。
display system internal adj4 entry ip-address interface interface-type interface-number slot slot-number
Probe视图
context-admin
ip-address:IPv4邻接表项中的IP地址。
interface interface-type interface-number:IPv4邻接表项所对应的三层接口类型和接口号。
slot slot-number:显示指定成员设备的IPv4邻接表项的信息。slot-number表示设备在IRF中的成员编号。
display system internal adj4 statistics命令用来显示IPv4邻接表项的统计信息。
display system internal adj4 statistics slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPv4邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。
display system internal adj6 entry 命令用来显示指定IPv6邻接表项的详细信息。
display system internal adj6 entry ipv6-address interface interface-type interface-number slot slot-number
Probe视图
context-admin
ipv6-address:IPv6邻接表项中的IPv6地址。
interface interface-type interface-number:IPv6邻接表项所对应的三层接口类型和接口号。
slot slot-number:显示指定成员设备的IPv6邻接表项的信息。slot-number表示设备在IRF中的成员编号。
display system internal adj6 statistics 命令用来显示IPv6邻接表项的统计信息。
display system internal adj6 statistics slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPv6邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。
display system internal adjacent-table命令用来显示IPv4邻接表的信息。
display system internal adjacent-table slot slot-number [ count | verbose ]
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPv4邻接表信息。slot-number表示设备在IRF中的成员编号。
count:显示IPv4邻接表项的数目。
verbose:显示IPv4邻接表项的详细信息。不指定该参数时显示IPv4邻接表项的摘要信息。
display system internal aft命令用来显示AFT内核配置信息。
display system internal aft [ slot slot-number ]
型号
支持
·         F100-C-EI:不支持
不支持
Probe视图
context-admin
slot slot-number:显示指定成员设备上的AFT内核配置信息,slot-number表示设备在IRF中的成员编号。
display system internal aspf statistics命令用来查看ASPF、报文过滤以及对象策略模块的丢包统计信息。
display system internal aspf statistics { interface | zone-pair } { ipv4 | ipv6 } [ slot slot-number ]
Probe视图
context-admin
interface:查看接口上的ASPF丢包统计信息。
zone-pair:查看域间实例上的ASPF丢包统计信息。
ipv4: 查看IPv4报文的丢包统计信息。
ipv6: 查看IPv6报文的丢包统计信息。
slot slot-number:显示指定成员设备上的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的丢包统计信息。
display system internal attack-defense scan stat-nodes ip命令用来显示扫描攻击防范的IPv4统计节点信息。
display system internal attack-defense scan stat-nodes ip [ security-zone zone-name ] [ { source | destination } [ ipv4-address [ vpn-instance vpn-instance-name ] ] ] [ slot slot-number ] [ count ]
Probe视图
context-admin
security-zone zone-name:显示指定安全域的扫描攻击统计节点,zone-name表示安全域名称,为1~31个字符的字符串,不区分大小写,不能包含字符“-”。
source:显示基于源IP地址进行统计的扫描攻击统计节点。
destination:显示基于目的IP地址进行统计的扫描攻击统计节点。
ipv4-address:表示指定的源IPv4地址或目的IPv4地址,不能为广播地址、127.0.0.0/8网段地址、D类地址或E类地址。
vpn-instance vpn-instance-name:指定IPv4地址所属的VPN实例。其中,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示该IPv4地址属于公网。
slot slot-number:显示指定成员设备上的扫描攻击统计节点,slot-number表示设备在IRF中的成员编号。该参数仅在指定显示全局接口(例如VLAN接口、Tunnel接口)时可见。如果不指定该参数,则表示显示所有成员设备上的扫描攻击统计节点。
count:显示符合指定条件的统计节点的个数。
display system internal attack-defense scan stat-nodes ipv6命令用来显示扫描攻击防范的IPv6统计节点信息。
display system internal attack-defense scan stat-nodes ipv6 [ security-zone zone-name ] [ { source | destination } [ ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ slot slot-number ] [ count ]
Probe视图
context-admin
source:显示基于源IPv6地址进行统计的扫描攻击统计节点。
destination:显示基于目的IPv6地址进行统计的扫描攻击统计节点。
ipv6-address:表示指定的源IPv6地址或目的IPv6地址。
vpn-instance vpn-instance-name:指定IPv6地址所属的VPN实例。其中,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示该IPv6地址属于公网。
display system internal bgp address-family statistics命令用来显示BGP实例统计信息。
display system internal bgp [ instance instance-name ] address-family { ipv4 | ipv6 } [ vpn-instance vpn-instance-name ] [ rib | send ] statistics [ standby slot slot-number ]
display system internal bgp [ instance instance-name ] address-family link-state [ rib | send ] statistics [ standby slot slot-number ]
Probe视图
context-admin
instance instance-name:显示指定BGP实例的信息。instance-name为BGP实例的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示default实例的信息。
ipv4:显示IPv4地址族的BGP实例统计信息。
ipv6:显示IPv6地址族的BGP实例统计信息。
mdt:显示MDT地址族的BGP实例统计信息。
link-state:显示LS地址族的BGP实例统计信息。
vpn-instance vpn-instance-name:显示指定VPN的BGP实例统计信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP实例的统计信息。
rib:显示BGP实例路由模块的统计信息。
send:显示BGP实例发送模块的统计信息。
standby:显示指定BGP备进程的信息。如果不指定本参数,则显示BGP主进程的信息。
slot slot-number:指定备进程所在的成员设备。slot-number为设备在IRF中的成员编号。
执行本命令时,如果没有指定rib和send参数,则显示BGP协议的地址族实例统计信息。
开启BGP NSR功能后,BGP主进程将BGP邻居和路由等信息备份到备进程。执行本命令时,如果指定了standby参数,则显示备份到指定备进程的信息。如果没有开启BGP NSR功能,则指定standby参数时,不会显示任何信息。通过standby参数指定的单板不能是BGP主进程所在的单板。
display system internal bgp graceful-restart statistics命令用来显示BGP GR统计信息。
display system internal bgp [ instance instance-name ] graceful-restart statistics
Probe视图
context-admin
display system internal bgp interface命令用来显示BGP接口信息。
display system internal bgp [ instance instance-name ] interface ipv4 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv4-address { mask | mask-length } ]
display system internal bgp [ instance instance-name ] interface ipv6 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
ipv4:显示IPv4地址族的BGP接口信息。
ipv6:显示IPv6地址族的BGP接口信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP接口信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP接口信息。
interface-type interface-number:显示指定BGP接口的信息。interface-type interface-number为接口类型和接口编号。
ipv4-address { mask | mask-length }:显示IPv4地址为指定值的BGP接口的信息。ipv4-address为接口的IPv4地址;mask为接口IPv4地址的网络掩码;mask-length为接口IPv4地址的网络掩码长度,取值范围为0~32。
ipv6-address prefix-length:显示IPv6地址为指定值的BGP接口的信息。ipv6-address为接口的IPv6地址;prefix-length为接口IPv6地址的前缀长度,取值范围为0~128。
执行本命令时,如果没有指定interface-type interface-number和ipv4-address { mask | mask-length }、ipv6-address prefix-length参数,则显示所有BGP接口的信息。
display system internal bgp link-state命令用来显示BGP和IGP的进程间通信状态信息、IGP发布到BGP的链路状态信息。
display system internal bgp [ instance instance-name ] link-state ipc
display system internal bgp [ instance instance-name ] link-state log
display system internal bgp [ instance instance-name ] link-state [ link | node | prefix | statistics ]
Probe视图
context-admin
ipc:显示BGP和IGP的进程间通信状态信息。
log:显示BGP和IGP进程间通信的日志信息。
link:显示IGP发布到BGP的链路状态的链路信息。
node:显示IGP发布到BGP的链路状态的节点信息。
prefix:显示IGP发布到BGP的链路状态的前缀信息。
statistics:显示IGP发布到BGP的链路状态的统计信息。
如果未指定link、node和prefix参数,则显示IGP发布到BGP的链路状态信息,包括链路信息、节点信息和前缀信息。
display system internal bgp log命令用来显示BGP进程的日志信息。
display system internal bgp [ instance instance-name ] log [ reverse ] [ standby slot slot-number ]
Probe视图
context-admin
reverse:按时间新旧的顺序显示日志信息。
display system internal bgp nib命令用来显示BGP路由下一跳信息。
display system internal bgp [ instance instance-name ] nib { ipv4 | ipv6 } [ nib-id ] [ verbose ]
Probe视图
context-admin
ipv4:显示IPv4地址族的BGP路由下一跳信息。
ipv6:显示IPv6地址族的BGP路由下一跳信息。
nib-id:下一跳ID,取值范围为1~FFFFFFFF。如果不指定本参数,则显示所有下一跳信息。
verbose:显示下一跳的详细信息。如果不指定本参数,则显示下一跳的简要信息。
display system internal bgp nib log命令用来显示BGP路由下一跳的日志信息。
display system internal bgp [ instance instance-name ] nib log
Probe视图
context-admin
display system internal bgp peer standby命令用来显示BGP备进程上BGP对等体的信息。
display system internal bgp [ instance instance-name ] peer ipv6 [ unicast ] [ [ ipv4-address ] verbose ] standby slot slot-number
display system internal bgp [ instance instance-name ] peer link-state [ verbose ] standby slot slot-number
Probe视图
context-admin
ipv6:显示BGP IPv6对等体的信息。
link-state:显示LS地址族的BGP对等体统计信息。
unicast:显示BGP单播对等体的信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP对等体的信息。
ipv4-address:显示指定对等体的信息。ipv4-address为对等体的IPv4地址。如果不指定本参数,则显示所有BGP对等体的信息。
ipv6-address:显示指定对等体的信息。ipv6-address为对等体的IPv6地址。如果不指定本参数,则显示所有BGP对等体的信息。
verbose:显示对等体的详细信息。如果不指定本参数,则显示BGP对等体的简要信息。
执行本命令时,缺省为unicast。
开启BGP NSR功能后,BGP主进程将BGP邻居和路由等信息备份到备进程,通过本命令可以显示备份到备进程的信息。如果没有开启BGP NSR功能,则不会显示任何信息。
display system internal bgp peer statistics命令用来显示BGP对等体的统计信息。
display system internal bgp [ instance instance-name ] peer { ipv4 } [ vpn-instance vpn-instance-name ] ipv4-address [ rib | send | session ] statistics [ standby slot slot-number ]
display system internal bgp [ instance instance-name ] peer ipv6 { ipv4-address | [ vpn-instance vpn-instance-name ] ipv6-address } [ rib | send | session ] statistics [ standby slot slot-number ]
display system internal bgp [ instance instance-name ] peer link-state { ipv4-address | ipv6-address } [ rib | send | session ] statistics [ standby slot slot-number ]
Probe视图
context-admin
ipv4:显示IPv4地址族的BGP对等体统计信息。
ipv6:显示IPv6地址族的BGP对等体统计信息。
mdt:显示MDT地址族的BGP对等体统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体统计信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP对等体统计信息。
rib:显示BGP路由模块相关信息。
send:显示BGP发送模块相关信息。
session:显示BGP会话模块相关信息。
指定本命令时,如果不指定rib、send和session参数,则显示BGP协议的对等体统计信息。
display system internal bgp protocol statistics命令用来显示BGP协议的统计信息。
display system internal bgp [ instance instance-name ] protocol [ calc | rib | send | session ] statistics [ standby slot slot-number ]
Probe视图
context-admin
calc:显示BGP路由优选模块的统计信息。
rib:显示BGP路由模块的统计信息。
send:显示BGP发送模块的统计信息。
session:显示BGP会话模块的统计信息。
执行本命令时,如果没有指定任何参数,则显示BGP协议的统计信息。
display system internal bgp routing-table advertise-info命令用来显示BGP路由的通告信息。
display system internal bgp [ instance instance-name ] routing-table ipv4 [ vpn-instance vpn-instance-name ] ipv4-address { mask | mask-length } advertise-info [ standby slot slot-number ]
display system internal bgp [ instance instance-name ] routing-table ipv6 [ vpn-instance vpn-instance-name ] ipv6-address prefix-length advertise-info [ standby slot slot-number ]
Probe视图
context-admin
ipv4:显示IPv4地址族的BGP路由通告信息。
ipv6:显示IPv6地址族的BGP路由通告信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由通告信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由通告信息。
ipv4-address:目的网络的IPv4地址。
mask:目的网络的掩码,点分十进制格式。
mask-length:目的网络的掩码长度,取值范围为0~32。
ipv6-address:目的网络的IPv6地址。
prefix-length:目的网络的前缀长度,取值范围为0~128。
display system internal bgp routing-table ipv4 unicast outlabel standby命令用来显示BGP备进程上BGP IPv4单播路由的出标签信息。
display system internal bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] outlabel standby slot slot-number
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例内BGP IPv4单播路由的出标签信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv4单播路由的出标签信息。
·            开启BGP NSR功能后,BGP主进程将BGP邻居和路由等信息备份到备进程,通过本命令可以显示备份到备进程的信息。如果没有开启BGP NSR功能,则不会显示任何信息。
·            通过standby参数指定的单板不能是BGP主进程所在的单板。
·            执行本命令时指定unicast参数和不指定unicast参数的效果相同。
display system internal bgp routing-table ipv4 unicast standby命令用来显示BGP备进程上BGP IPv4单播路由信息。
display system internal bgp [ instance instance-name ] routing-table ipv4 [ unicast ] [ vpn-instance vpn-instance-name ] [ ip-address [ { mask | mask-length } [ longest-match ] ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ip-address { advertised-routes | received-routes } [ ip-address [ mask | mask-length ] | statistics ] | statistics ] standby slot slot-number
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例的BGP IPv4单播路由信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv4单播路由信息。
ip-address:目的网络的IP地址。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
longest-match:指定根据如下方法判断显示哪条BGP IPv4单播路由信息:
(1)       将用户输入的网络地址和路由的掩码进行与操作;
(2)       计算结果与路由的网段地址相同,且掩码小于等于用户输入子网掩码的路由中,子网掩码最长的路由将被显示出来。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv4单播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
community-list:显示匹配指定BGP团体列表的BGP IPv4单播路由信息。
basic-community-list-number:基本团体列表号,取值范围为1~99。
comm-list-name:团体属性列表名,为1~63个字符的字符串,区分大小写。
whole-match:精确匹配。如果指定了本参数,则只有路由的团体属性列表与指定的团体属性列表完全相同时,才显示该路由的信息;如果未指定本参数,则只要路由的团体属性列表中包含指定的团体属性列表,就显示该路由的信息。
adv-community-list-number:高级团体列表号,取值范围为100~199。
peer ip-address:显示向指定对等体发布或者从指定对等体收到的BGP IPv4单播路由信息。ip-address为对等体的地址。
advertised-routes:显示向指定的对等体发布的路由信息。
received-routes:显示从指定的对等体接收到的路由信息。
statistics:显示路由的统计信息。
·            如果没有指定任何参数,则显示指定BGP备进程上所有BGP IPv4单播路由的简要信息。
·            如果只指定了ip-address参数,则将指定的网络地址和路由的掩码进行与操作,若计算结果与路由的网段地址相同,则显示该路由的信息。
·            如果指定了ip-address mask或ip-address mask-length参数,没有指定longest-match参数,则显示与指定目的网络IP地址和网络掩码(或掩码长度)精确匹配的BGP IPv4单播路由的信息。
display system internal bgp routing-table ipv6 unicast outlabel standby命令用来显示BGP备进程上BGP IPv6单播路由的出标签信息。
display system internal bgp [ instance instance-name ] routing-table ipv6 [ unicast ] outlabel standby slot slot-number
Probe视图
context-admin
display system internal bgp routing-table ipv6 unicast standby命令用来显示BGP备进程上BGP IPv6单播路由信息。
display system internal bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ] standby slot slot-number
display system internal bgp [ instance instance-name ] routing-table ipv6 [ unicast ] peer ipv4-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] standby slot slot-number
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例的BGP IPv6单播路由信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP IPv6单播路由信息。
ipv6-address prefix-length:显示与指定的目的网络地址和前缀长度精确匹配的BGP IPv6单播路由信息。prefix-length为目的网络地址的前缀长度,取值范围为0~128。如果没有指定本参数,则显示所有BGP IPv6单播路由的简要信息。
as-path-acl as-path-acl-number:显示匹配指定AS路径过滤列表的BGP IPv6单播路由信息。as-path-acl-number为AS路径过滤列表号,取值范围为1~256。
community-list:显示匹配指定BGP团体列表的BGP IPv6单播路由信息。
peer:显示向指定的对等体发布或者从指定的对等体收到的BGP IPv6单播路由信息。
ip-address:对等体的IPv4地址。
ipv6-address:对等体的IPv6地址。
display system internal bgp routing-table verbose命令用来显示BGP路由的详细信息。
display system internal bgp [ instance instance-name ] routing-table ipv4 [ vpn-instance vpn-instance-name ] ipv4-address { mask | mask-length } verbose [ standby slot slot-number ]
display system internal bgp [ instance instance-name ] routing-table ipv6 [ vpn-instance vpn-instance-name ] ipv6-address prefix-length verbose [ standby slot slot-number ]
Probe视图
context-admin
ipv4:显示IPv4地址族的BGP路由详细信息。
ipv6:显示IPv6地址族的BGP路由详细信息。
mdt:显示MDT地址族的BGP MDT详细信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由详细信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由详细信息。
display system internal bgpm log命令用来显示BGP管理进程的日志信息。
display system internal bgpm log [ reverse ] [ standby slot slot-number ]
Probe视图
context-admin
display system internal bridge cache ip verbose命令用来显示Bridge转发创建的IP快速转发表的详细内容。
display system internal bridge cache ip { inline | inter-vlan } [ ip-address ] verbose [ slot slot-number ]
probe视图
context-admin
inline:显示Inline转发的快速转发表信息。
inter-vlan:显示跨VLAN转发的快速转发表信息。
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
slot slot-number:显示指定成员设备的快速转发表信息。slot-number表示设备在IRF中的成员编号。如果不指定slot slot-number,将显示所有成员设备的快速转发表信息。
display system internal bridge cache ipv6 verbose命令用来显示Bridge转发创建的IPv6快速转发表的详细内容。
display system internal bridge cache ipv6 { inline | inter-vlan } [ ipv6-address ] verbose [ slot slot-number ]
probe视图
context-admin
inline:显示Inline转发的IPv6快速转发表信息。
inter-vlan:显示跨VLAN转发的IPv6快速转发表信息。
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
slot slot-number:显示指定成员设备的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有成员设备的IPv6快速转发表信息。slot-number表示设备在IRF中的成员编号。
display system internal client-verify http redirect-node命令用来显示HTTP客户端验证重定向节点信息。
display system internal client-verify http redirect-node { ip [ ipv4-address [ vpn-instance ipv4-vpn-instance-name ] ] | ipv6 [ ipv6-address [ vpn-instance ipv6-vpn-instance-name ] ] } [ slot slot-number ] ] [ count ]
Probe视图
context-admin
ip ipv4-address:显示指定IPv4地址的重定向节点。
ipv6 ipv6-address:显示指定IPv6地址的重定向节点。
vpn-instance ipv4-vpn-instance-name:显示指定VPN实例的重定向节点。其中ipv4-vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示信任IPv4地址位于公网。
vpn-instance ipv6-vpn-instance-name:显示指定VPN实例的重定向节点。其中ipv6-vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示信任IPv6地址位于公网。
slot slot-number:显示指定成员设备上的重定向节点,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的重定向节点。
count:显示统计数据的个数。
display system internal context block-information命令用来显示Context的阻塞信息。
display system internal context id context-id block-information [ slot slot-number ]
Probe视图
context-admin
id context-id:Context的编号。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。
该命令用于确认Context阻塞的原因。可根据阻塞信息找到对应模块定位。
display system internal context configuration-status命令用来查询各单板上Context相关配置的执行情况。
Probe视图
context-admin
当设备重启或者单板插入时,设备或单板会运行Context进程,并运行Context的相关配置。使用本命令可以查看各单板Context相关配置的执行情况,如果执行过程中出现错误,可以定位到出错的单板。
display system internal context running-status命令用来显示Context在各单板上的运行状态。
display system internal context id context-id running-status
Probe视图
context-admin
该命令用于确定哪些单板上的Context存在问题,分别阻塞在哪个阶段。
display system internal customlog host命令用来显示指定日志主机当前运行状态下的内核数据信息。
display system internal customlog host index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number ]
Probe视图
context-admin
index:表示指定日志主机的索引号。index取值范围为0~3。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的内核数据信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的内核数据信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的内核数据信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的内核数据信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的内核数据信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的内核数据信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的内核数据信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的内核数据信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的内核数据信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的内核数据信息。
slot slot-number:显示指定成员设备上的内核数据信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示在Master设备运行状态下的内核数据信息。
display system internal customlog mbuf dump命令用来显示指定个数的CUSTOMLOG报文的详细信息。
display system internal customlog mbuf dump count number [ slot slot-number ]
Probe视图
context-admin
number:指定需要显示的日志个数。number取值范围为1~100。
slot slot-number:显示指定成员设备上CUSTOMLOG报文的详细信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上日志报文的详细信息。
display system internal customlog mbuf usage命令用来显示指定日志主机上每个CPU内MBUF池的使用情况信息。
display system internal customlog mbuf usage index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number ]
Probe视图
context-admin
index:指定需要查看数据的日志主机索引号。index取值范围为0~3。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的MBUF池使用情况信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的MBUF池使用情况信息。
slot slot-number:显示指定成员设备上的CPU内MBUF池的使用情况信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的CPU内MBUF使用情况。
display system internal customlog test命令用来发送指定数目CUSTOMLOG测试的报文,并显示日志发送结果信息。
display system internal customlog test count number { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number ]
Probe视图
context-admin
number:指定需要参与测试的CUSTOMLOG数目。number取值范围为1~100。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的测试日志发送结果信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的测试日志发送结果信息。
slot slot-number:显示指定成员设备上的日志发送结果信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上日志报文的发送结果信息。
display system internal data-filter match命令用来显示数据过滤匹配表项信息。
display system internal data-filter match [ match-id match-id ] slot slot-number
Probe视图
context-admin
match-id match-id:显示指定数据匹配表项信息,match-id为match表项的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上所有的匹配信息。
slot slot-number:显示指定成员设备上的数据过滤匹配表项信息,slot-number表示设备在IRF中的成员编号。
display system internal data-filter policy命令用来显示数据过滤策略信息。
display system internal data-filter policy [ policy-id policy-id ] slot slot-number
Probe视图
context-admin
policy-id policy-id:显示指定数据过滤策略的信息。policy-id为数据过滤策略的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上的所有数据过滤策略信息。
slot slot-number:显示指定成员设备上的数据过滤策略信息。slot-number表示设备在IRF中的成员编号。
display system internal data-filter rule命令用来显示数据过滤规则信息。
display system internal data-filter rule [ policy-id policy-id [ rule-id rule-id ] ] slot slot-number
Probe视图
context-admin
policy-id policy-id:显示指定数据过滤策略中的数据过滤规则的信息。policy-id为数据过滤策略的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上的所有数据过滤策略中的规则信息。
rule-id rule-id:显示指定数据过滤规则的信息。rule-id为数据过滤规则的ID,取值范围为0~4294967294。若不指定该参数,则显示指定数据过滤策略中的所有规则信息。
slot slot-number:显示指定成员设备上的数据过滤规则信息。slot-number表示设备在IRF中的成员编号。
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] } [ slot slot-number ]
Probe视图
context-admin
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。
display system internal dropstats registered-modules命令用来显示丢包统计模块中注册成功的业务模块。
display system internal dropstats registered-modules [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上丢包统计模块中注册成功的业务模块,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上丢包统计模块中注册成功的业务模块。
仅业务模块在丢包统计模块注册成功后,丢包统计模块才会对业务模块的丢包原因进行统计。可通过此命令来查看丢包统计模块中已有哪些业务模块注册成功。
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number } slot slot-number
Probe视图
context-admin
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface { interface-type interface-number } slot slot-number
Probe视图
context-admin
display system internal ha service命令用来显示某个业务进程的HA统计信息,包括业务注册的基本信息、各控制消息接收处理统计、各数据的发送统计和接收统计等。
display system internal ha service socket
Probe视图
context-admin
socket:所要查询的业务进程的socket ID,socket ID可通过display system internal ha service-group sg-name命令显示信息中Socket字段的值获取。
display system internal ha service-group命令用来显示当前到HA模块注册的所有SG信息,包括SG的名称、SG的状态、SU的个数等信息。
display system internal ha service-group [ name [ instance ] ]
Probe视图
context-admin
instance:SG实例的名称(如果有实例)。
display system internal ha statistics命令用来显示HA各子模块的统计信息。
display system internal ha statistics { submodule { fsm | service } | summary }
Probe视图
context-admin
submodule:HA子模块的信息。
fsm:FSM子模块的信息。
service:service子模块的信息。
summary:全局统计信息。
display system internal hot-backup broadcast node命令用来显示广播会话热备份的节点信息。
display system internal hot-backup broadcast node [ slot slot-number ]
无
Probe视图
context-admin
slot slot-number:显示指定成员设备上广播会话热备份的节点信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备广播会话热备份的节点信息。
display system internal hot-backup peer命令用来显示热备份的对端信息。
Probe视图
context-admin
display system internal ifmgr brief命令用来显示接口基本信息同步的信息。
display system internal ifmgr brief { para slot slot-number | help }
Probe视图
context-admin
para:指定显示时的参数,为接口索引值。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr down命令用来显示已注册的down类型。
display system internal ifmgr down [ slot slot-number ]
Probe视图
context-admin
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para [ slot slot-number ] | help }
Probe视图
context-admin
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para [ slot slot-number ] | help }
Probe视图
context-admin
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type。
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ [ para ] [ slot slot-number ] | help ]
Probe视图
context-admin
para:指定显示时的参数。para为槽位号或者槽位号和子槽位号(格式为slot-number*subslot-number),用于显示该板或子卡的热插拔信息。不指定该参数以及help参数时,显示所有板的热插拔信息;
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。用于显示slot-number成员设备上记录的热插拔信息。
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para [ slot slot-number ] | help }
Probe视图
context-admin
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ [ para ] [ slot slot-number ] | help ]
Probe视图
context-admin
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定para和help参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para [ slot slot-number ] | help }
Probe视图
context-admin
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para [ slot slot-number ] | help }
Probe视图
context-admin
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal ike phase2-sa count命令用来显示IKE第二阶段SA的个数。
display system internal ike phase2-sa count [ phase1-connection-id connection-id ]
Probe视图
context-admin
phase1-connection-id connection-id:指定IKE第一阶段的连接标识,可以根据此表示显示第二阶段SA的个数,取值范围为1~2000000000。
通过display ike sa可以查看IKE第一阶段的连接标识。
display system internal ike phase2-sa verbose命令用来显示IKE第二阶段SA的详细信息。
Probe视图
context-admin
display system internal ike received-message count命令用来显示IKE接收消息的个数。
display system internal ike received-message count [ verbose ipsec-doi ]
Probe视图
context-admin
verbose:显示IKE收到消息个数的详细信息。
ipsec-doi:显示接收IPsec-DOI消息个数的详细信息。
display system internal ike sent-message count命令用来显示IKE发送消息的个数。
display system internal ike sent-message count [ verbose ipsec-doi ]
Probe视图
context-admin
verbose:显示IKE发送消息个数的详细信息。
ipsec-doi:显示发送给IPsec-DOI消息个数的详细信息。
display system internal ikev2 child-sa count命令用来显示Child SA的个数。
display system internal ikev2 child-sa count [ tunnel-id tunnel-id ]
Probe视图
context-admin
tunnel-id tunnel-id:指定IKEv2 SA的Tunnel ID,用来显示Child SA的个数,取值范围为1~2000000000。
通过display ikev2 sa可以查看Tunnel ID。
display system internal inspect dim-rule命令用来显示各个DPI相关业务模块内检测规则的统计信息。
display system internal inspect dim-rule [ module-id ] [ rule-id ] [ slot slot-number ]
Probe视图
context-admin
module-id:显示指定DPI相关业务模块检测规则的统计信息。若不指定该参数,则表示所有DPI相关业务模块,取值范围为0~10,其取值含义如下所示:
·            0:表示NBAR业务。
·            1:表示内容过滤业务。(暂不支持)
·            2:表示IPS业务。
·            3:表示带宽管理业务。
·            4:表示URL过滤业务。
·            5:表示数据过滤业务。
·            6:表示防病毒业务。
·            7:表示文件过滤业务。
·            8:表示应用识别信息统计业务。(暂不支持)
·            9:表示Netstream流量统计业务。(暂不支持)
·            10:表示应用审计业务。
rule-id:显示各个DPI业务模块内指定检测规则的统计信息。若不指定该参数,则表示所有检测规则。
slot slot-number:显示指定成员设备上的各个DPI相关业务模块内检测规则ID的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。
display system internal inspect hit-statistics命令用来显示应用层检测引擎中的检测规则被命中的统计信息。
display system internal inspect hit-statistics [ module-id ] [ rule-id ] [ slot slot-number ]
Probe视图
context-admin
module-id:显示指定DPI相关业务模块检测规则被命中的统计信息。若不指定该参数,则表示所有DPI相关业务模块,取值范围为0~9,其取值含义如下所示:
·            0:表示NBAR业务。
·            1:表示内容过滤业务。(暂不支持)
·            2:表示IPS业务。
·            3:表示带宽管理业务。
·            4:表示URL过滤业务。
·            5:表示数据过滤业务。
·            6:表示防病毒业务。
·            7:表示文件过滤业务。
·            10:表示应用审计业务。
rule-id:显示各个DPI业务模块内指定检测规则被命中的统计信息。若不指定该参数,则表示所有检测规则。
slot slot-number:显示指定成员设备上的应用层检测引擎中的检测规则被命中的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上规则被命中的统计信息。
display system internal inspect http命令用来显示应用层检测引擎对HTTP协议解析的统计信息。
display system internal inspect http [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎对HTTP协议解析的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上HTTP协议解析的统计信息。
该命令可以显示应用层检测引擎对HTTP协议解析的统计信息,一定程度上可以用来观察HTTP协议解析对设备的性能、内存等运行情况的影响。
1.2.87  display system internal inspect memory engine ac
display system internal inspect memory engine ac命令用来显示应用层检测引擎中AC关键字检测模块占用内存的统计信息。
display system internal inspect memory engine ac [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎中AC关键字检测模块占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。
该命令可以显示应用层检测引擎中AC关键字检测模块占用的内存数值,一定程度上可以用来观察应用层检测引擎对设备运行情况的影响。
1.2.88  display system internal inspect memory engine mn
display system internal inspect memory engine mn命令用来显示应用层检测引擎锚定AC关键字检测模块占用内存的统计信息。
display system internal inspect memory engine mn [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎中锚定AC关键字检测模块占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。
该命令可以显示应用层检测引擎中锚定AC关键字检测模块占用的内存数值,一定程度上可以用来观察引擎对设备内存运行情况的影响。锚定的意思是要求目标关键字的第一个字符在报文中出现的位置是预先固定的。
1.2.89  display system internal inspect memory rule
display system internal inspect memory rule命令用来显示应用层检测引擎中的检测规则占用内存的统计信息。
display system internal inspect memory rule [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎中的检测规则占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。
该命令可以显示应用层检测引擎中的检测规则占用的内存数值,一定程度上可以用来观察引擎对设备内存运行情况的影响。
1.2.90  display system internal inspect session table
display system internal inspect session table命令用来显示应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。
display system internal inspect session table [ slot slot-number ] [ source-ip start-ip-address [ end-ip-address ] ] [ destination-ip start-ip-address [ end-ip-address ] ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port port-number ] [ destination-port port-number ] [ verbose ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息,slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。
source-ip start-source-ip [ end-source-ip ]:显示指定源IP地址的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。其中,start-source-ip表示发起方到响应方会话的起始源IP地址,end-source-ip表示发起方到响应方会话的结束源IP地址。
destination-ip start-destination-ip [ end-destination-ip ]:显示指定目的IP地址的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。其中,start-destination-ip表示发起方到响应方会话的起始目的IP地址,end-destination-ip表示发起方到响应方会话的结束目的IP地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。其中,IP传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
verbose:显示应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息的详细信息。不指定该参数时,显示应用层检测引擎处理过的会话信息的概要信息。
如果不指定任何参数,则显示应用层检测引擎处理过的会话信息及其应用层检测引擎相关的会话扩展信息。
1.2.91  display system internal inspect statistic packet
display system internal inspect statistic packet命令用来显示应用层检测引擎处理异常情况时的报文统计信息。
display system internal inspect statistic packet [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的应用层检测引擎处理异常情况的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。
1.2.92  display system internal ip packet-drop statistics
display system internal ip packet-drop statistics命令用来查看IPv4转发的丢包统计信息。
display system internal ip packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上IPv4转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上IPv4转发的丢包统计信息。
1.2.93  display system internal ip routing-table
display system internal ip routing-table命令用来显示路由表的信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby slot slot-number
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的路由表信息,slot-number表示设备在IRF中的成员编号。
1.2.94  display system internal ip routing-table acl
display system internal ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ] standby slot slot-number
Probe视图
context-admin
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的通过指定ACL过滤的路由信息,slot-number表示设备在IRF中的成员编号。
1.2.95  display system internal ip routing-table ip-address
display system internal ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display system internal ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] standby slot slot-number
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ] standby slot slot-number
Probe视图
context-admin
ip-address:目的IP地址,点分十进制格式。
mask/mask-length:IP地址掩码,点分十进制格式或以整数形式表示的长度,当用整数时,取值范围为0~32。
longer-match:匹配掩码更长的路由。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
standby slot slot-number:显示备份的指定成员设备的指定目的地址的路由信息,slot-number表示设备在IRF中的成员编号。
1.2.96  display system internal ip routing-table prefix-list
display system internal ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby slot slot-number
Probe视图
context-admin
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的指定前缀列表过滤的路由信息,slot-number表示设备在IRF中的成员编号。
1.2.97  display system internal ip routing-table protocol
display system internal ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby slot slot-number
Probe视图
context-admin
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的路由表中的指定路由协议的信息,slot-number表示设备在IRF中的成员编号。
1.2.98  display system internal ip routing-table statistics
display system internal ip routing-table statistics命令用来显示路由表中的综合路由统计信息。综合路由统计信息包括路由总数目、路由协议添加/删除路由数目、激活路由数目。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] statistics standby slot slot-number
Probe视图
context-admin
standby slot slot-number:显示备份的指定成员设备的路由表中的综合路由统计信息,slot-number表示设备在IRF中的成员编号。
1.2.99  display system internal ip source binding
display system internal ip source binding命令用来显示详细的IPv4绑定表项信息。
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
Probe视图
context-admin
static:显示配置的静态绑定表项。
vpn-instance vpn-instance-name:显示指定VPN的动态绑定表项,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示公网的动态绑定表项。
dhcp-relay:显示DHCP中继模块生成的动态绑定表项。
dhcp-server:显示DHCP服务器模块生成的动态绑定表项。
ip-address ip-address:显示指定IPv4地址的绑定表项,ip-address表示绑定的IPv4地址。
mac-address mac-address:显示指定MAC地址的绑定表项,mac-address表示绑定的MAC地址,格式为H-H-H。
vlan vlan-id:显示指定VLAN的绑定表项,vlan-id表示绑定的VLAN ID,取值范围为1~4094。
interface interface-type interface-number:显示指定接口的绑定表项,interface-type interface-number表示绑定的接口类型和接口编号。
slot slot-number:显示存储在指定成员设备上的绑定表项,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的绑定表项。
1.2.100  display system internal ipsec block-flow
display system internal ipsec block-flow命令用来显示IPsec阻流表信息。
display system internal ipsec block-flow slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPsec阻流表信息。slot-number表示设备在IRF中的成员编号。
阻流表是为了阻止相同流量重复触发IPsec协商,以节省系统资源。阻流表默认协商成功或者失败后就会删除。
1.2.101  display system internal ipsec received-message
display system internal ipsec received-message count命令用来显示IPsec接收自IKE的消息个数。
Probe视图
context-admin
1.2.102  display system internal ipsec sent-message
display system internal ipsec sent-message count命令用来显示IPsec发送给IKE的消息个数。
Probe视图
context-admin
1.2.103  display system internal ipsec sp
display system internal ipsec sp命令用来显示IPsec的SP信息。
display system internal ipsec sp { brief | sp-id sp-id slot slot-number }
Probe视图
context-admin
brief:表示显示IPsec SP的摘要信息。
sp-id sp-id:表示显示指定IPsec SP的详细信息。sp-id是IPsec SP的ID号,取值范围为0~4294967295。
slot slot-number:显示指定成员设备的IPsec的SP信息。slot-number表示设备在IRF中的成员编号。
SP是IPsec Security Policy生成的动态数据,有可能每个板都会有SP信息,查看时需要区分板号。
1.2.104  display system internal ipv6 adjacent-table
display system internal ipv6 adjacent-table命令用来显示IPv6邻接表的信息。
display system internal ipv6 adjacent-table slot slot-number [ count | verbose ]
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPv6邻接表信息。slot-number表示设备在IRF中的成员编号。
1.2.105  display system internal ipv6 fast-forwarding cache verbose
display system internal ipv6 fast-forwarding cache verbose命令用来显示指定IPv6地址的IPv6快转表项的详细内容。
display system internal ipv6 fast-forwarding cache [ ipv6-address ] verbose [ slot slot-number ]
Probe视图
context-admin
ipv6-address:显示指定IPv6地址的IPv6快转表详细信息。
slot slot-number:显示指定成员设备的IPv6快转表详细信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的IPv6快转表详细信息。
1.2.106  display system internal ipv6 fast-forwarding statistics
display system internal ipv6 fast-forwarding statistics 命令用来显示IPv6快转的报文统计信息。
display system internal ipv6 fast-forwarding statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备的IPv6快转的报文统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的快转的报文统计信息。
1.2.107  display system internal ipv6 packet-drop statistics
display system internal ipv6 packet-drop statistics命令用来查看IPv6转发的丢包统计信息。
display system internal ipv6 packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上IPv6转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上IPv6转发的丢包统计信息。
1.2.108  display system internal ipv6 pbr fib
display system internal ipv6 pbr fib命令用来显示用户态下IPv6下一跳的配置信息。
display system internal ipv6 pbr slot slot-number fib [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示用户态下指定私网内IPv6下一跳的配置信息,如果未指定本参数,则显示用户态下公网内下一跳的配置信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定成员设备的指定私网内IPv6下一跳的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.109  display system internal ipv6 pbr kernel policy
display system internal ipv6 pbr kernel policy用于显示内核态下指定单板上的IPv6策略路由信息。
display system internal ipv6 pbr slot slot-number kernel policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示内核态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息
slot slot-number:显示内核态下指定成员设备的IPv6策略路由信息。slot-number表示设备在IRF中的成员编号。
1.2.110  display system internal ipv6 pbr policy
display system internal ipv6 pbr policy用于显示用户态下的IPv6策略路由信息。
display system internal ipv6 pbr slot slot-number policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示用户态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定成员设备的IPv6策略路由信息。slot-number表示设备在IRF中的成员编号。
1.2.111  display system internal ipv6 rib event attribute
display system internal ipv6 rib event attribute 命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
context-admin
1.2.112  display system internal ipv6 rib event policy
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
context-admin
1.2.113  display system internal ipv6 rib event prefix
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
context-admin
1.2.114  display system internal ipv6 rib event protocol
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
display system internal ipv6 rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
1.2.115  display system internal ipv6 rib event statistics
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
display system internal ipv6 rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
1.2.116  display system internal ipv6 rib instance
display system internal ipv6 rib instance命令用来显示IPv6 RIB的协议进程信息。
Probe视图
context-admin
1.2.117  display system internal ipv6 rib log
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ] [ standby slot slot-number ]
display system internal ipv6 rib event log [ standby slot slot-number ]
Probe视图
context-admin
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定成员设备的RIB的日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB的日志信息。
1.2.118  display system internal ipv6 rib memory
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
context-admin
1.2.119  display system internal ipv6 rib nib
display system internal ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
display system internal ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number
display system internal ipv6 rib nib protocol protocol [ verbose ] standby slot slot-number
Probe视图
context-admin
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围1~FFFFFFFF。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
standby slot slot-number:显示备份的指定成员设备的IPv6 RIB下一跳信息,slot-number表示设备在IRF中的成员编号。
1.2.120  display system internal ipv6 rib nib log
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ] [ standby slot slot-number ]
Probe视图
context-admin
nib:显示IPv6 NIB子模块的运行状态。
standby slot slot-number:显示备份的指定成员设备的NIB子模块的运行状态日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示NIB子模块的运行状态日志。
1.2.121  display system internal ipv6 rib prefix
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length [ vpn-instance vpn-instance-name ] [ standby slot slot-number ]
Probe视图
context-admin
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定成员设备的IPv6路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv6路由表前缀信息。
1.2.122  display system internal ipv6 rib summary
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
display system internal ipv6 rib summary [ standby slot slot-number ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定成员设备的RIB统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB统计信息。
1.2.123  display system internal ipv6 route-direct interface
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
ipv6-address:IPv6地址。
1.2.124  display system internal ipv6 route-direct log
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
1.2.125  display system internal ipv6 route-static nib log
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
context-admin
1.2.126  display system internal ipv6 routing-table
display system internal ipv6 routing-table命令用来显示IPv6路由表的信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby slot slot-number
Probe视图
context-admin
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
slot slot-number:显示备份的指定成员设备的IPv6路由表信息,slot-number表示设备在IRF中的成员编号。
1.2.127  display system internal ipv6 routing-table acl
display system internal ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ] standby slot slot-number
Probe视图
context-admin
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的通过指定ACL过滤的IPv6路由信息,slot-number表示设备在IRF中的成员编号。
1.2.128  display system internal ipv6 routing-table ipv6-address
display system internal ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display system internal ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] standby slot slot-number
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ] standby slot slot-number
Probe视图
context-admin
ipv6-address:IPv6目的地址。
longer-match:匹配并显示前缀最长的路由条目。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的指定目的地址的IPv6路由信息,slot-number表示设备在IRF中的成员编号。
1.2.129  display system internal ipv6 routing-table prefix-list
display system internal ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby slot slot-number
Probe视图
context-admin
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的指定前缀列表过滤的IPv6路由信息,slot-number表示设备在IRF中的成员编号。
1.2.130  display system internal ipv6 routing-table protocol
display system internal ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby slot slot-number
Probe视图
context-admin
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
standby slot slot-number:显示备份的指定成员设备的指定IPv6路由协议的信息,slot-number表示设备在IRF中的成员编号。
1.2.131  display system internal ipv6 routing-table statistics
display system internal ipv6 routing-table statistics命令用来显示IPv6路由表中的综合路由统计信息。综合路由统计信息包括路由总数、增加的路由数、删除的路由数等。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics standby slot slot-number
Probe视图
context-admin
standby slot slot-number:显示备份的指定成员设备的IPv6路由表中的综合路由统计信息,slot-number表示设备在IRF中的成员编号。
1.2.132  display system internal ipv6 source binding
display system internal ipv6 source binding命令用来显示详细的IPv6绑定表项信息。
display system internal ipv6 source binding static [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number ]
Probe视图
context-admin
static:显示配置的静态绑定表项。
ip-address ipv6-address:显示指定IPv6地址的绑定表项,ipv6-address表示绑定的IPv6地址。
1.2.133  display system internal irf global
display system internal irf global命令用来显示IRF的部分全局信息。
display system internal irf global [ slot slot-number ]
Probe视图
1.2.134  display system internal irf msg
display system internal irf msg命令用来显示IRF的日志信息。
display system internal irf msg [ reverse ] [ slot slot-number ]
Probe视图
reverse:表示反向显示信息,先显示时间新的日志,再显示时间旧的日志。不指定该参数时,表示按时间先后顺序显示信息。
1.2.135  display system internal irf roledb
display system internal irf roledb命令用来显示IRF的角色数据库信息。
display system internal irf roledb [ slot slot-number ]
Probe视图
1.2.136  display system internal irf topodb
display system internal irf topodb命令用来显示IRF的拓扑数据库信息。
display system internal irf topodb [ slot slot-number ]
Probe视图
1.2.137  display system internal isis import-route
display system internal isis import-route命令用来显示IS-IS的IPv4引入路由表。
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby slot slot-number
Probe视图
context-admin
ipv4:显示IS-IS的IPv4引入路由表。如果不指定该参数,显示IPv4引入路由表。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程引入路由表。 如果未指定IS-IS进程号,将显示所有IS-IS进程引入路由表。
standby slot slot-number:显示备份的指定成员设备的IS-IS引入路由表信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS引入路由表信息。
1.2.138  display system internal isis import-route ipv6
display system internal isis import-route ipv6命令用来显示IS-IS的IPv6引入路由表。
display system internal isis import-route ipv6 [ process-id ] [ standby slot slot-number ]
Probe视图
context-admin
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程引入路由表。如果未指定IS-IS进程号,将显示所有IS-IS进程引入路由表。
1.2.139  display system internal isis interface
display system internal isis interface命令用来显示接口的IPv4信息。
display system internal isis interface [ ipv4 ] [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
ipv4:显示接口的IPv4信息。如果未指定该参数,显示接口的IPv4信息。
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
1.2.140  display system internal isis interface ipv6
display system internal isis interface ipv6命令用来显示接口的IPv6信息。
display system internal isis interface ipv6 [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
1.2.141  display system internal isis interface standby
display system internal isis interface standby命令用来显示接口的备份信息。
display system internal isis interface [ interface-type interface-number ] [ verbose ] [ process-id ] standby slot slot-number
Probe视图
context-admin
interface-type interface-number:显示指定接口的信息。如果未指定本参数,将显示所有接口的信息。
verbose:显示接口的详细信息。如果未指定该参数,将显示接口的概要信息。
process-id:IS-IS进程号,取值范围为1~65535,显示与指定IS-IS进程相关联接口的信息。如果未指定本参数,将显示所有IS-IS进程的接口信息。
standby slot slot-number:显示备份的指定成员设备的IS-IS接口信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的接口信息。
1.2.142  display system internal isis keychain
display system internal isis keychain命令用来查看IS-IS进程的keychain信息。
display system internal isis keychain [ name keychain-name [ key key-id ] ]
Probe视图
context-admin
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则显示所有keychain的信息。
key-id:key的标识符,取值范围为0~281474976710655。如果不指定本参数,则显示指定keychain的所有key的信息。
1.2.143  display system internal isis lsdb standby
display system internal isis lsdb standby命令用来显示IS-IS的备份链路状态数据库信息。
display system internal isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose ] * [ process-id ] standby slot slot-number
Probe视图
context-admin
level-1:显示Level-1链路状态数据库。
level-2:显示Level-2链路状态数据库。
local:显示当前路由器产生的LSP的信息。
lsp-id lspid:LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的节点或伪节点的SystemID,Pseudonode ID是伪节点ID,fragment num是该LSP的分片号。
lsp-name lspname:LSP名称,形式为Symbolic name.[Pseudo ID]-fragment num。
verbose:显示链路状态数据库中的LSP的详细信息。如果未指定该参数,将显示链路状态数据库中的LSP的概要信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的链路状态数据库信息。如果未指定本参数,将显示所有IS-IS进程的链路状态数据库信息。
standby slot slot-number:显示备份的指定成员设备的IS-IS链路状态数据库信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的链路状态数据库信息。
1.2.144  display system internal isis nib
display system internal isis nib命令用来显示IS-IS的IPv4路由下一跳信息。
display system internal isis nib [ ipv4 ] [ nib-id ] [ verbose ]
Probe视图
context-admin
ipv4:显示IS-IS的IPv4下一跳信息。如果不指定该参数,显示IPv4下一跳信息。
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
1.2.145  display system internal isis nib ipv6
display system internal isis nib ipv6命令用来显示IS-IS的IPv6路由下一跳信息。
display system internal isis nib ipv6 [ nib-id ] [ verbose ]
Probe视图
context-admin
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果未指定本参数,则显示所有下一跳信息。
verbose:显示下一跳详细信息。如果未指定本参数,则显示概要信息。
1.2.146  display system internal isis nib log
display system internal isis nib log命令用来显示IS-IS路由下一跳日志信息。
Probe视图
context-admin
1.2.147  display system internal isis peer standby
display system internal isis peer standby命令用来显示IS-IS的备份邻居信息。
display system internal isis peer [ statistics | verbose ] [ process-id ] standby slot slot-number
Probe视图
context-admin
statistics:显示IS-IS邻居的统计信息。
verbose:显示IS-IS邻居的详细信息。如果未指定该参数,将显示IS-IS邻居的概要信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的邻居信息。如果未指定本参数,将显示所有IS-IS进程的邻居信息。
standby slot slot-number:显示备份的指定成员设备的IS-IS邻居信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的邻居信息。
1.2.148  display system internal isis prefix
display system internal isis prefix命令用来显示IS-IS的IPv4前缀信息。
display system internal isis prefix [ ipv4 ] [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby slot slot-number
Probe视图
context-admin
ipv4:显示IS-IS的IPv4前缀信息。如果不指定该参数,显示IPv4前缀信息。
level-1:显示IS-IS的Level-1前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
level-2:显示IS-IS的Level-2前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
prefix mask-length:显示指定前缀和掩码长度的前缀信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的前缀信息。如果未指定IS-IS进程号,将显示所有IS-IS进程的前缀信息。
standby slot slot-number:显示备份的指定成员设备的IPv4前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv4前缀信息。
1.2.149  display system internal isis prefix ipv6
display system internal isis prefix ipv6命令用来显示IS-IS的IPv6前缀信息。
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ prefix prefix-length ] ] * [ process-id ] [ standby slot slot-number ]
Probe视图
context-admin
prefix prefix-length:显示指定前缀和掩码长度的前缀信息。
standby slot slot-number:显示备份的指定成员设备的IS-IS前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS前缀信息。
1.2.150  display system internal isis standby
display system internal isis standby命令用来显示IS-IS的进程备份信息。
display system internal isis [ process-id ] standby slot slot-number
Probe视图
context-admin
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的进程信息。如果未指定本参数,将显示所有IS-IS进程的进程信息。
standby slot slot-number:显示备份的指定成员设备的IS-IS进程信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的进程信息。
1.2.151  display system internal isis status
display system internal isis status命令用来显示IS-IS的协议全局状态信息。
Probe视图
context-admin
1.2.152  display system internal kernel memory dump
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number ]
Probe视图
context-admin
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。
1.2.153  display system internal kernel memory pool
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ] [ slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number ]
Probe视图
context-admin
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
1.2.154  display system internal license buffer-data
display system internal license buffer-data命令用来显示内存中缓存的License数据。
display system internal license buffer-data slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的内存缓存的License数据。slot-number为设备在IRF中的成员编号。
1.2.155  display system internal license feature-set
display system internal license feature-set命令用来显示设备支持的特性集的相关信息。
display system internal license feature-set slot slot-number
Probe视图
context-admin
feature-set:显示设备中的特性集相关信息。
slot slot-number:显示指定成员设备的设备中的特性集相关信息。slot-number为设备在IRF中的成员编号。
1.2.156  display system internal license fifo
display system internal license fifo命令用来显示License使用的FIFO管道信息。
display system internal license fifo slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的FIFO管道信息。slot-number为设备在IRF中的成员编号。
1.2.157  display system internal license lipc
display system internal license lipc命令用来显示License LIPC通道信息。License LIPC用于特性模块和License模块的内部通信。
display system internal license lipc slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的License LIPC通道信息。slot-number为设备在IRF中的成员编号。
1.2.158  display system internal license lipc hash
display system internal license lipc hash命令用来显示hash链表中存储的License LIPC通道信息。
display system internal license lipc hash slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的hash链表中存储的LIPC信息。slot-number为设备在IRF中的成员编号。
1.2.159  display system internal license lmi-paa
display system internal license lmi-paa命令用来显示LMI(License Manage Item,License管理项)信息和PAA(Product Ability Aggregate,产品能力集)信息。
display system internal license lmi-paa slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的LMI信息和PAA能力信息。slot-number为设备在IRF中的成员编号。
1.2.160  display system internal link-aggregation global
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
display system internal link-aggregation slot slot-number global
Probe视图
slot slot-number:表示设备所在IRF中的成员编号。
1.2.161  display system internal link-aggregation interface
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
display system internal link-aggregation slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
route-aggregation:显示三层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
ipv4:IPv4报文统计值。
ipv6:IPv6报文统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
·            如果未指定kernel、lacp、lacppdu和statistics参数,则显示LAGG主线程中接口的基本数据。
·            如果未指定ipv4、ipv6参数,则显示所有报文统计值。
·            部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
1.2.162  display system internal lipc dump
display system internal lipc dump命令用来显示LIPC抓包记录。
display system internal lipc dump [ lip lip ]
Probe视图
context-admin
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示主设备所在节点。
1.2.163  display system internal lipc dump configuration
display system internal lipc dump configuration命令用来显示配置的LIPC抓包规则。
display system internal lipc dump configuration [ lip lip ]
Probe视图
context-admin
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
1.2.164  display system internal lipc history
display system internal lipc history命令用来以图表方式显示LIPC各协议的历史流量信息。
display system internal lipc history [ mtcp | publish | stcp ] { recv | send } { by-min | by-sec } [ lip lip ]
Probe视图
context-admin
mtcp:显示组播传输控制协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
publish:显示可靠发布协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
stcp:显示单播传输控制协议的历史流量信息。不指定mtcp、publish和stcp参数时,表示显示三种协议报文流量总和的历史信息。
recv:显示当前协议的历史接收流量。
send:显示当前协议的历史发送流量。
by-min:以分钟为单位显示最近30分钟内的历史流量。
by-sec:以秒为单位显示最近30秒内的历史流量。
1.2.165  display system internal lipc lcmp statistics
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
Probe视图
context-admin
1.2.166  display system internal lipc lgmp group
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group groupID [ lip lip ]
Probe视图
context-admin
groupID:表示组播组号,取值范围为0~4294967295。
1.2.167  display system internal lipc lgmp group-list
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
Probe视图
context-admin
1.2.168  display system internal lipc lgmp physical-group
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phyID [ lip lip ]
Probe视图
context-admin
physical-group phyID:表示硬件组播组ID,取值范围为0~4294967295。
1.2.169  display system internal lipc lgmp physical-group-list
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
Probe视图
context-admin
1.2.170  display system internal lipc lgmp statistics
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
Probe视图
context-admin
1.2.171  display system internal lipc lip statistics
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
Probe视图
context-admin
1.2.172  display system internal lipc loop statistics
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
Probe视图
context-admin
1.2.173  display system internal lipc mtcp group
display system internal lipc mtcp group命令用来显示LIPC显示某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
Probe视图
context-admin
portID:组播组的端口号,一个端口号标识一个组播组,取值范围为0~4294967295。
history:显示该组播组状态机的历史变迁轨迹。
member:显示该组播组的成员信息。
statistics:显示该组播组的统计信息。
1.2.174  display system internal lipc mtcp group all
display system internal lipc mtcp group all命令用来显示所有包含本节点的组播组的统计信息。
display system internal lipc mtcp group all [ lip lip ]
Probe视图
context-admin
1.2.175  display system internal lipc mtcp performance
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
Probe视图
context-admin
必须打开相应得性能统计开关后,该命令才能输出性能信息。
·            lipc performance
1.2.176  display system internal lipc mtcp statistics
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
Probe视图
context-admin
1.2.177  display system internal lipc pcb mbuf statistics
display system internal lipc pcb mbuf statistics命令用来显示LIPC各个PCB下的MBUF使用情况。
display system internal lipc pcb mbuf statistics [ lip lip ]
Probe视图
context-admin
1.2.178  display system internal lipc pcb statistics
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
Probe视图
context-admin
1.2.179  display system internal lipc physical
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc physical [ lip lip ]
Probe视图
context-admin
1.2.180  display system internal lipc publish global-cb
display system internal lipc publish global-cb命令用来显示LIPC PUBLISH模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
Probe视图
context-admin
一般用于诊断Pub模块在某个节点上是否乱序。
1.2.181  display system internal lipc publish statistics
display system internal lipc publish statistics命令用来显示LIPC  PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
Probe视图
context-admin
1.2.182  display system internal lipc stcp event
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
Probe视图
context-admin
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
1.2.183  display system internal lipc stcp global-server
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
Probe视图
context-admin
1.2.184  display system internal lipc stcp links
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
Probe视图
context-admin
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0~65535。
global gport:表示全局知名端口号,取值范围为100~8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100~65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0~65535。
1.2.185  display system internal lipc stcp performance
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
Probe视图
context-admin
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
·            lipc performance
1.2.186  display system internal lipc stcp port
display system internal lipc stcp port命令用来显示单播支持的知名端口的指定操作的统计信息。
display system internal lipc stcp port { close | connect | get-port | half-close| recv-get-port | resend | send } [ lip lip ]
Probe视图
context-admin
close:显示当前节点各端口的连接关闭次数。
connect:显示当前节点各端口的连接请求次数。
get-port:显示当前节点各全局知名端口的目的节点请求次数。
half-close:显示各端口的连接半关闭次数。
recv-get-port:显示当前节点收到的全局知名端口目的节点请求次数。
resend:显示各端口的重传次数。
send:显示各端口的发送次数。
1.2.187  display system internal lipc stcp statistics
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息,用于分析单播的全局工作情况。
display system internal lipc stcp statistics [ lip lip ]
Probe视图
context-admin
1.2.188  display system internal lipc stcp status
display system internal lipc stcp status命令用来显示单播的传输状态。主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。该命令通常用于分析单播的数据可靠传输问题。
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe视图
context-admin
recv:显示接收端的单播传输状态。
send:显示发送端的单播传输状态。
1.2.189  display system internal lipc stream
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
Probe视图
context-admin
ack:表示查看指定端口号的收到ACK的记录。
reass:表示查看指定端口号的接收重组队列信息。
send:表示查看指定端口号的发送报文分片记录。
port portID:表示端口号,为0~65535的整数。
1.2.190  display system internal lipc sudp pcb-info
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
Probe视图
context-admin
all-port:显示所有PCB信息。
global-port:显示全局知名端口的PCB信息。
local-port:显示本地知名端口的PCB信息。
specific-port portID:表示指定端口号,取值范围为0~65535。
1.2.191  display system internal lipc sudp statistics
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
Probe视图
context-admin
1.2.192  display system internal lipc sudp { global-port | local-port }
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
Probe视图
context-admin
global-port:表示查看所有SUDP全局知名端口号的信息。
local-port:表示查看所有SUDP本地端口号的信息。
1.2.193  display system internal lipc topology history
display system internal lipc topology history命令用来查看拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
Probe视图
context-admin
1.2.194  display system internal lipc topology link
display system internal lipc topology link命令用来显示LIPC 的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
Probe视图
context-admin
1.2.195  display system internal lipc topology node
display system internal lipc topology node命令用来查看拓扑节点相关的统计信息。
display system internal lipc topology node nodeID [ lip lip ]
Probe视图
context-admin
nodeID:表示节点号,取值范围为0~65535。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
1.2.196  display system internal lipc topology process-time
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
Probe视图
context-admin
1.2.197  display system internal lipc topology statistics
display system internal lipc topology statistics命令用来查看拓扑相关的全局统计。记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology statistics [ lip lip ]
Probe视图
context-admin
1.2.198  display system internal lipc topology status
display system internal lipc topology status命令用来显示节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
Probe视图
context-admin
1.2.199  display system internal loadbalance connections
display system internal loadbalance connections命令用来显示负载均衡连接信息。
display system internal loadbalance connections [ client-side { ipv4 | ipv6 } [ cs-client-ip ip-address [ cs-client-port port-number ] ] [ cs-server-ip ip-address [ cs-server-port port-number ] ] ] [ server-side { ipv4 | ipv6 } [ ss-client-ip ip-address [ ss-client-port port-number ] ] [ ss-server-ip ip-address [ ss-server-port port-number ] ] ] [ verbose ] [ slot slot-number ]
Probe视图
context-admin
client-side:显示客户端的负载均衡连接信息。
server-side:显示服务器端的负载均衡连接信息。
ipv4:IPv4连接。
ipv6:IPv6连接。
cs-client-ip ip-address:显示指定客户端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
cs-client-port port-number:显示指定客户端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
ss-client-ip ip-address:显示指定客户端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的客户端IP地址。
ss-client-port port-number:显示指定客户端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的客户端端口号,取值范围为0~65535,0表示通配。
cs-server-ip ip-address:显示指定服务器端IP地址的客户端侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
cs-server-port port-number:显示指定服务器端端口号的客户端侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
ss-server-ip ip-address:显示指定服务器端IP地址的服务器侧负载均衡连接信息。其中,ip-address表示负载均衡连接的服务器端IP地址。
ss-server-port port-number:显示指定服务器端端口号的服务器侧负载均衡连接信息。其中,port-number表示负载均衡连接的服务器端端口号,取值范围为0~65535,0表示通配。
verbose:显示负载均衡连接的详细信息。不指定该参数时,显示负载均衡连接的概要信息。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的信息。
本命令显示的负载均衡连接信息不包含空闲连接信息。
如果不指定任何参数,则显示所有负载均衡连接的概要信息。
1.2.200  display system internal loadbalance connections count
display system internal loadbalance connections count命令用来显示负载均衡连接总数。
display system internal loadbalance connections count [ slot slot-number ]
Probe视图
context-admin
本命令显示的负载均衡连接总数不包含空闲连接数。
1.2.201  display system internal loadbalance fdb-info
display system internal loadbalance fdb-info命令用来显示实服务器/链路/DNS服务器对逻辑转发的支持情况。
display system internal loadbalance fdb-info [ dns-proxy dns-proxy-name | virtual-server virtual-server-name ]
Probe视图
context-admin
dns-proxy-name:显示指定DNS透明代理下的DNS服务器/链路对逻辑转发的支持情况。dns-proxy-name为DNS透明代理的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有DNS透明代理下的链路和DNS服务器对逻辑转发的支持情况。
virtual-server-name:显示指定虚服务器下的实服务器/链路对逻辑转发的支持情况。virtual-server-name为虚服务器的名称,为1~63个字符的字符串,不区分大小写。如果未指定本参数,将显示所有虚服务器下的实服务器和链路对逻辑转发的支持情况。
1.2.202  display system internal loadbalance local-dns-server statistics error
display system internal loadbalance local-dns-server statistics error命令用来显示入方向链路负载均衡的内核错误统计信息。
display system internal loadbalance local-dns-server statistics error [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的错误统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的错误统计信息。
1.2.203  display system internal loadbalance local-dns-server statistics predictor-times
display system internal loadbalance local-dns-server statistics predictor-times命令用来显示入方向链路负载均衡调度算法执行次数的统计信息。
display system internal loadbalance local-dns-server statistics predictor-times [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上调度算法执行次数的统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的错误统计信息。
1.2.204  display system internal loadbalance local-dns-server statistics selected-times
display system internal loadbalance local-dns-server statistics selected-times命令用来显示入方向链路负载均衡虚服务选中次数的统计信息。
display system internal loadbalance local-dns-server statistics selected-times [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上虚服务选中次数的统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上虚服务选中次数的统计信息。
1.2.205  display system internal loadbalance statistics alg
display system internal loadbalance statistics alg命令用来显示负载均衡 ALG相关处理的统计信息。
display system internal loadbalance statistics alg [ slot slot-number ] { all | ftp | h323 | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
Probe视图
context-admin
all:显示所有协议的ALG统计信息。
ftp:显示ftp协议的ALG统计信息。
h323:显示h323协议的ALG统计信息。
ils:显示ils协议的ALG统计信息。
mgcp:显示mgcp协议的ALG统计信息。
nbt:显示nbt协议的ALG统计信息。
pptp:显示pptp协议的ALG统计信息。
rsh:显示rsh协议的ALG统计信息。
rtsp:显示rtsp协议的ALG统计信息。
sccp:显示sccp协议的ALG统计信息。
sip:显示sip协议的ALG统计信息。
sqlnet:显示sqlnet协议的ALG统计信息。
tftp:显示tftp协议的ALG统计信息。
xdmcp:显示xdmcp协议的ALG统计信息。
slot slot-number:显示指定成员设备上的ALG统计信息,slot-number表示设备在IRF中的成员编号。若未指定本参数,将显示所有设备上ALG统计信息。
1.2.206  display system internal loadbalance statistics configuration
display system internal loadbalance statistics configuration命令用来显示负载均衡配置处理出错的统计信息。
display system internal loadbalance statistics configuration [ slot slot-number ]
Probe视图
context-admin
1.2.207  display system internal loadbalance statistics error
display system internal loadbalance statistics error命令用来显示负载均衡内核转发流程的错误统计信息。
display system internal loadbalance statistics error [ slot slot-number ]
Probe视图
context-admin
error:显示错误统计信息。
1.2.208  display system internal loadbalance statistics http
display system internal loadbalance statistics http命令用来显示负载均衡中解析HTTP报文的统计信息。
display system internal loadbalance statistics http [ slot slot-number ]
Probe视图
context-admin
1.2.209  display system internal loadbalance statistics probe
display system internal loadbalance statistics probe命令用来显示负载均衡触发探测的统计信息。
Probe视图
context-admin
1.2.210  display system internal loadbalance statistics proximity
display system internal loadbalance statistics proximity命令用来显示就近性表项的统计信息。
display system internal loadbalance statistics proximity [ vpn-instance vpn-instance-name ] [ slot slot-number ]
显示公网实例下就近性表项统计信息。
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例中的信息。vpn-instance-name为VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例中的信息。
slot slot-number:显示指定成员设备上的就进性表项统计信息,slot-number表示设备在IRF中的成员编号。
1.2.211  display system internal local-dns-server abnormal request
display system internal local-dns-server abnormal request命令用来显示接收到的异常DNS请求报文。
display system internal local-dns-server abnormal request [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上异常DNS请求报文信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的信息。
当DNS服务器错误调试信息开关打开时,执行本操作命令,将显示接收到的每个异常DNS请求最大报文为1024个字节,超过的部分不会显示。每个CPU最多记录10个报文,如果超过10个,新接收的报文会替换已有报文。
当DNS服务器错误调试信息开关关闭时,不再记录新收到的异常DNS请求报文,也不会删除已经记录的报文。
1.2.212  display system internal local-dns-server statistics
display system internal local-dns-server statistics命令用来显示入方向链路负载均衡的KDNS内核统计信息。
display system internal local-dns-server statistics { error | packet } [ slot slot-number ]
Probe视图
context-admin
error:显示入方向链路负载均衡的错误统计信息。
packet:显示入方向链路负载均衡的报文统计信息。
slot slot-number:显示指定成员设备上DNS服务器的统计的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的信息。
1.2.213  display system internal mac-address configuration
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | multiport | multicast | static } [ count ] slot slot-number
Probe视图
context-admin
blackhole:显示黑洞MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
slot slot-number:显示指定成员设备的MAC地址信息。slot-number表示设备在IRF中的成员编号。
1.2.214  display system internal mac-address learned
display system internal mac-address learned命令用来显示动态MAC地址表项。
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ] slot slot-number
Probe视图
context-admin
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
slot slot-number:显示指定成员设备的动态MAC地址表项。slot-number表示设备在IRF中的成员编号。
1.2.215  display system internal mac-address protocol
display system internal mac-address protocol命令用来显示指定协议或特性生成的MAC地址或VLAN接口的MAC地址。
display system internal mac-address protocol [ security | vlan-interface ] [ count ] slot slot-number
Probe视图
context-admin
security:显示端口安全特性中学习到的MAC地址表项。
vlan-interface:显示VLAN接口的MAC地址表项。
count:显示MAC地址表项的数量。如果指定了本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果未指定本参数,则显示符合条件的MAC地址表项的具体内容。
slot slot-number:显示指定成员设备的MAC地址表项。slot-number表示设备在IRF中的成员编号。
1.2.216  display system internal mac-address statistics
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
display system internal mac-address statistics slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的MAC地址表统计信息。slot-number表示设备在IRF中的成员编号。
1.2.217  display system internal mac-forwarding cache ip verbose
display system internal mac-forwarding cache ip verbose命令用来显示IP快转表项的详细内容。
display system internal mac-forwarding cache ip [ ip-address ] verbose [ slot slot-number ]
probe视图
context-admin
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
slot slot-number:显示指定成员设备的快速转发表信息。slot-number表示设备在IRF中的成员编号。如果不指定slot slot-number,将显示所有成员设备的快速转发表信息。
1.2.218  display system internal mac-forwarding cache ipv6 verbose
display system internal mac-forwarding cache ipv6 verbose命令用来显示IPv6快转表项的详细内容。
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose [ slot slot-number ]
probe视图
context-admin
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
slot slot-number:显示指定成员设备的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有成员设备的IPv6快速转发表信息。slot-number表示设备在IRF中的成员编号。
1.2.219  display system internal mac-forwarding controlblock
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number slot slot-number
Probe视图
context-admin
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
slot slot-number:显示指定成员设备的二层转发控制信息。slot-number表示设备在IRF中的成员编号。
1.2.220  display system internal mac-forwarding packet-drop statistics
display system internal mac-forwarding packet-drop statistics命令用来显示二层转发的丢包统计信息。
display system internal mac-forwarding packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上二层转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上二层转发的丢包统计信息。
1.2.221  display system internal mbuf relay statistics
display system internal mbuf relay statistics命令用来显示MBUF中继模块的统计信息。
display system internal mbuf relay statistics slot slot-number [ vcpu vcpu-number ] [ rcv receiver-id ]
Probe视图
context-admin
slot slot-number:显示指定成员设备的MBUF中继模块的统计信息。slot-number表示设备在IRF中的成员编号。
vcpu vcpu-number:MBUF中继使用的VCPU的编号。不指定该参数时,表示当前单板上的所有VCPU。
rcv received-id:MBUF中继接收者的编号。不指定该参数时,表示当前VCPU上的所有接收者。
1.2.222  display system internal mbuf socket statistics
display system internal mbuf socket statistics命令用来显示Socket申请的MBUF数据块的数量。
display system internal mbuf socket statistics slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备上Socket申请的MBUF数据块数量。slot-number表示设备在IRF中的成员编号。
1.2.223  display system internal mrib interface statistics
display system internal mrib interface statistics命令用来显示MRIB所维护接口的统计信息,这些接口包括配置了PIM等组播协议的接口以及注册接口、InLoopBack0接口、Null0接口等内部接口。
display system internal mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
1.2.224  display system internal mrib mbr
display system internal mrib mbr命令用来显示MRIB进程中MBR模块维护的组加入信息。
display system internal mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number [ source source-address group group-address ]
Probe视图
interface interface-type interface-number:显示指定接口上的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将不显示MBR表项信息。
group group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将不显示MBR表项信息。
1.2.225  display system internal mrib mbr interface standby
display system internal mrib mbr interface standby命令用来显示备份的MBR接口信息。
display system internal mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number standby slot slot-number
Probe视图
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,表示公网实例。
interface-type interface-number:显示指定接口上的信息。如果未指定本参数,将显示所有接口上的信息。
slot slot-number:输出指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将输出主设备上的信息。
1.2.226  display system internal multicast  fast-forwarding cache verbose
display system internal multicast fast-forwarding cache verbose命令用来显示IPv4 ip 组播快转表详细信息。
display system internal multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache verbose [ source address | group address  ] * [ slot slot-number ]
Probe视图
source-address:组播源地址,显示包含指定组播源的组播快转发项。
group-address:组播组地址,显示指定组播组的组播快转发项,取值范围为224.0.1.0~239.255.255.255。
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示主设备上的信息。
1.2.227  display system internal multicast boundary standby
display system internal multicast boundary standby命令用来显示备份的组播边界信息。
display system internal multicast [ vpn-instance vpn-instance-name ] boundary [ group-address [ mask-length | mask ] ] [ interface interface-type interface-number ] standby slot slot-number
Probe视图
group-address:显示指定组播组的组播边界信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的组播边界信息。
mask-length:指定组播组地址的掩码长度,取值范围为4~32,缺省值为32。
mask:指定组播组地址的掩码,缺省值为255.255.255.255。
interface interface-type interface-number:显示指定接口上的组播边界信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的组播边界信息。
1.2.228  display system internal multicast capability
display system internal multicast capability命令用来显示组播能力的信息。
display system internal multicast capability [ slot slot-number ]
Probe视图
slot slot-number:显示指定成员设备上的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上的信息。
1.2.229  display system internal multicast forwarding-table dummy
display system internal multicast forwarding-table dummy命令用来显示组播临时转发表的信息。
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | statistics | slot slot-number ] *
Probe视图
group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
statistics:显示统计信息。
1.2.230  display system internal multicast forwarding-table verbose
display system internal multicast forwarding-table verbose命令用来显示组播转发表的详细信息。
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number ] *
Probe视图
incoming-interface:显示指定入接口的信息。如果未指定本参数,将显示所有入接口的信息。
outgoing-interface:显示指定出接口的信息。如果未指定本参数,将显示所有出接口的信息。
exclude:显示不包含指定接口的信息。
include:显示包含指定接口的信息。
match:显示包含且仅包含指定接口的信息。
1.2.231  display system internal multicast record
display system internal multicast record命令用来显示组播表项的操作记录。
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-data-group | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ slot slot-number ]
Probe视图
statistics:显示组播表项操作记录的统计信息。
all:显示组播表项的所有操作记录。
fail:显示组播表项的失败操作记录。
group-address:组播组地址,显示指定组播组的记录。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的记录。
source-address:组播源地址,显示包含指定组播源的记录。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的记录。
item item-list:记录列表,表示一条或多条记录。表示方式为item-list = start-item [ to end-item ]。其中,start-item和end-item的取值范围均为1~500000。
filter:显示指定模式下的组播表项操作记录。
exclude:显示排除满足指定条件的组播表项操作记录。
include:显示包含满足指定条件的组播表项操作记录。
add-l2-ip:表示添加二层IP表项的操作记录。
add-l2-ip-port:表示添加二层IP表项端口的操作记录。
add-l2-ip-slot:表示添加二层IP表项板信息的操作记录。
add-l2-mac:表示添加二层MAC表项的操作记录。
add-l2-mac-port:表示添加二层MAC表项端口的操作记录。
add-l2-mac-slot:表示添加二层MAC表项板信息的操作记录。
add-l3-ipm:表示添加三层组播表项的操作记录。
add-l3-oif:表示添加三层表项出接口的操作记录。
add-l3-port:表示添加三层表项出端口的操作记录。
add-l3-slot:表示添加三层表项分布式转发的出接口板信息的操作记录。
del-l2-ip:表示删除二层IP表项的操作记录。
del-l2-ip-port:表示删除二层IP表项端口的操作记录。
del-l2-ip-slot:表示删除二层IP表项板信息的操作记录。
del-l2-mac:表示删除二层MAC表项的操作记录。
del-l2-mac-port:表示删除二层MAC表项端口的操作记录。
del-l2-mac-slot:表示删除二层MAC表项板信息的操作记录。
del-l3-ipm:表示删除三层组播表项的操作记录。
del-l3-oif:表示删除三层表项出接口的操作记录。
del-l3-port:表示删除三层表项出端口的操作记录。
del-l3-slot:表示删除三层表项分布式转发的出接口板信息的操作记录。
set-l3-data-group:表示设置三层表项对应的Data-Group地址。
set-l3-iif:表示设置三层表项入接口的操作记录。
ipmc-type-all:表示全部类型。
verbose:显示详细信息。如果记录的出接口和出端口显示不全时,需要指定本参数。
1.2.232  display system internal nat
display system internal nat命令用来显示内核的NAT配置信息。
display system internal nat slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的内核的NAT配置信息,slot-number表示设备在IRF中的成员编号。
1.2.233  display system internal nat aging-queue
display system internal nat aging-queue命令用来显示NAT模块老化队列的统计信息。
display system internal nat aging-queue { no-pat | port-block } [ slot slot-number [ core core-number ] ] [ verbose ]
Probe视图
context-admin
no-pat:显示NO-PAT表项老化队列的统计信息。
port-block:显示端口块表项所需要的配置信息不存在时,已备份的端口块表项暂存老化队列的统计信息。
slot slot-number:显示指定单板上的NAT老化队列统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有单板上的NAT老化队列统计信息。
core core-number:显示指定内核上的NAT老化队列统计信息,core-number表示多核CPU的内核编号。
verbose:显示NAT老化队列的详细统计信息。若不指定该参数,则只显示NAT老化队列上NAT表项的个数统计信息。
1.2.234  display system internal nat hot-backup statistics
display system internal nat hot-backup statistics命令用来显示NAT热备份的统计信息。
display system internal nat hot-backup statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上NAT热备份的统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上NAT热备份的统计信息。
1.2.235  display system internal nat statistics
display system internal nat statistics命令用来显示NAT统计信息。
display system internal nat statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的NAT统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的NAT统计信息。
当配置有NAT业务的组网环境中,出现网络丢包时,可以通过该命令查看NAT统计信息,确定丢包是否与NAT业务有关。
1.2.236  display system internal object-group
display system internal object-group命令用来显示对象组的配置和运行情况。
display system internal object-group [ { { ip | ipv6 } address | port | service } [ default ] [ name object-group-name ] | name object-group-name ] slot slot-number
Probe视图
context-admin
ip address:指定对象组类型为IP地址对象组。
ipv6 address:指定对象组类型为IPv6地址对象组。
port:指定对象组类型为端口对象组。
service:指定对象组类型为服务对象组。
default:指定默认对象组。
name object-group-name:指定对象组名称。object-group-name表示对象组的名称,为1~31个字符的字符串,不区分大小写。
slot slot-number:显示指定成员设备上对象组的配置和运行情况,slot-number表示设备在IRF中的成员编号。
1.2.237  display system internal object-policy
display system internal object-policy命令用来显示指定对象策略的配置信息。
display system internal object-policy { ip | ipv6 } object-policy-name [ kernel ] slot slot-number
Probe视图
context-admin
ip:表示IPv4对象策略。
ipv6:表示IPv6对象策略。
object-policy-name表示对象策略的名称,为1~63个字符的字符串,不区分大小写。
kernel:表示显示对象策略的内核信息。
slot slot-number:显示指定成员设备上指定对象策略的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.238  display system internal ospf event-log
display system internal ospf event-log命令用来显示OSPF的日志信息。
display system internal ospf event-log { gr | igp-ls { control | data } | interface | nib | notify | { ha | upgrade } [ standby slot slot-number ] }
Probe视图
context-admin
gr:显示GR日志。
ha:显示HA事件处理日志信息。
igp-ls:显示链路状态的日志信息。
control:显示链路状态控制类日志信息。
data:显示链路状态数据类日志信息。
interface:显示接口事件日志。
nib:显示NIB日志。
notify:显示接口通知日志。
upgrade:显示升级平滑日志信息。
standby slot slot-number:显示备份的指定成员设备的OSPF日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的日志信息。
1.2.239  display system internal ospf flood-list
display system internal ospf flood-list命令用来显示OSPF的flooding信息。
display system internal ospf [ process-id ] flood-list [ interface-type interface-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的flooding信息。
interface-type interface-number:显示指定接口的flooding信息。如果未指定本参数,将显示所有接口的flooding信息。
1.2.240  display system internal ospf interface
display system internal ospf interface命令用来显示接口相关信息。
display system internal ospf interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例下接口相关信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的信息。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
1.2.241  display system internal ospf interface standby
display system internal ospf interface standby命令用来显示备份的OSPF接口信息。
display system internal ospf [ process-id ] interface [ interface-type interface-number | verbose ] standby slot slot-number
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的接口信息。
interface-type interface-number:接口类型和编号。显示指定接口的OSPF详细信息。
verbose:显示所有接口的OSPF详细信息。
standby slot slot-number:显示备份的指定成员设备的OSPF接口信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的接口信息。
1.2.242  display system internal ospf keychain
display system internal ospf keychain命令用来查看OSPF进程下的keychain信息。
display system internal ospf keychain [ name keychain-name [ key key-id ] ]
Probe视图
context-admin
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则显示OSPF进程下所有keychain的信息。
1.2.243  display system internal ospf lsdb
display system internal ospf lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospf [ process-id ] lsdb { asbr | ase | nssa | summary }
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的LSA map信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的map信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的map信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的map信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的map信息。
1.2.244  display system internal ospf lsdb standby
display system internal ospf lsdb standby命令用来显示备份的OSPF链路状态数据库信息。
display system internal ospf [ process-id ] lsdb [ area area-id | brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] standby slot slot-number
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的链路状态数据库信息。
area area-id:显示数据库中指定区域的LSA信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的信息。
brief:显示数据库的概要信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的信息。
network:显示数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的信息。
opaque-area:显示数据库中Type-10 LSA (Opaque-area LSA)的信息。
opaque-as:显示数据库中Type-11 LSA (Opaque-AS LSA)的信息。
opaque-link:显示数据库中Type-9 LSA(Opaque-link LSA)的信息。
router:显示数据库中Type-1 LSA(Router LSA)的信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的信息。
link-state-id:链路状态ID,IP地址格式。
originate-router advertising-router-id:发布LSA报文的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的数据库信息。
standby slot slot-number:显示备份的指定成员设备的OSPF链路状态数据库信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的链路状态数据库信息。
1.2.245  display system internal ospf nib
display system internal ospf nib命令用来显示NIB分配的下一跳信息。
display system internal ospf nib [ nib-id ] [ verbose ]
Probe视图
context-admin
nib-id:路由下一跳信息的ID值,取值范围1~FFFFFFFF。
verbose:显示NIB详细信息。
1.2.246  display system internal ospf peer standby
display system internal ospf peer standby命令用来显示备份的OSPF邻居信息。
display system internal ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ] standby slot slot-number
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的各区域邻居的信息。
verbose:显示OSPF各区域邻居的详细信息。如果未指定本参数,将显示OSPF进程各区域邻居的概要信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的OSPF邻居的信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的OSPF邻居的信息。
standby slot slot-number:显示备份的指定成员设备的OSPF各区域邻居的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF各区域邻居的信息。
1.2.247  display system internal ospf peer statistics standby
display system internal ospf peer statistics standby命令用来显示备份的本地路由器所有OSPF邻居的统计信息,即处于各种状态的邻居数目。
display system internal ospf [ process-id ] peer statistics standby slot slot-number
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的邻居统计信息。
standby slot slot-number:显示备份的指定成员设备的OSPF邻居统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的邻居统计信息。
1.2.248  display system internal ospf prefix
display system internal ospf prefix命令用来显示OSPF中前缀对应的LSA信息。
display system internal ospf [ process-id ] prefix [ ip-address { mask | mask-length } ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的前缀信息。
ip-address:路由的目的IP地址。如果未指定本参数,将显示所有前缀的信息。
mask:网络掩码,点分十进制格式。
1.2.249  display system internal ospf router
display system internal ospf router命令用来显示OSPF中到路由器节点的路由信息。
display system internal ospf [ process-id ] router
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的信息。
1.2.250  display system internal ospf statistics
display system internal ospf statistics命令用来显示OSPF的统计信息。
display system internal ospf [ process-id ] statistics { confusion-log | { request-queue | retrans-queue } [ interface-type interface-number ] [ neighbor-id ] }
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的统计信息。
confusion-log:显示Router ID冲突和IP地址冲突的统计信息。
request-queue:邻居请求链计数。
retrans-queue:邻居重传链计数。
interface-type interface-number:接口类型和编号,显示指定接口的统计信息。
neighbor-id:显示指定邻居的统计信息。
1.2.251  display system internal ospf status
display system internal ospf status命令用来显示OSPF协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
context-admin
1.2.252  display system internal ospf vlink standby
display system internal ospf vlink standby命令用来显示备份的OSPF虚连接信息。
display system internal ospf [ process-id ] vlink standby slot slot-number
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的虚连接信息。
standby slot slot-number:显示备份的指定成员设备的OSPF虚连接信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的虚连接信息。
1.2.253  display system internal ospfv3 event-log
display system internal ospfv3 event-log命令用来显示OSPFv3的各种日志信息。
display system internal ospfv3 event-log { gr | nib | rib }
Probe视图
context-admin
gr:显示GR状态机变迁记录。
nib:显示路由管理上报给OSPFv3的NIB信息。
rib:显示路由管理上报给OSPFv3的RIB信息。
1.2.254  display system internal ospfv3 flood-list
display system internal ospfv3 flood-list命令用来显示OSPFv3的flooding信息。
display system internal ospfv3 [ process-id ] flood-list [ interface-type interface-number ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的flooding信息。
1.2.255  display system internal ospfv3 interface
display system internal ospfv3 interface命令用来显示OSPFv3的接口相关信息。
display system internal ospfv3 interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。
ipv6-address:IPv6地址前缀。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
1.2.256  display system internal ospfv3 interface standby
display system internal ospfv3 interface standby命令用来显示备份的OSPFv3接口信息。
display system internal ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ] standby slot slot-number
Probe视图
context-admin
interface-type interface-number:接口类型和接口编号。显示指定接口的详细信息。
verbose:显示所有接口的详细信息。
standby slot slot-number:显示备份的指定成员设备的OSPFv3接口信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的接口信息。
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的接口信息。
如果未指定接口或参数verbose,将显示所有接口的概要信息。
1.2.257  display system internal ospfv3 lsdb
display system internal ospfv3 lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospfv3 [ process-id ] lsdb { inter-prefix | inter-router | intra-prefix { reference type-1 | reference type-2 } | router }
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下的map信息。
inter-prefix:显示Inter-area-prefix LSA的map信息。
inter-router:显示Inter-area-router LSA的map信息。
intra-prefix:显示Intra-area-prefix LSA的map信息。
reference type-1:显示引用Router-LSA的Intra-area-prefix LSA map信息。
reference type-2:显示引用Network-LSA的Intra-area-prefix LSA map信息。
router:显示Router-LSA的map信息。
1.2.258  display system internal ospfv3 lsdb standby
display system internal ospfv3 lsdb standby命令用来显示备份的LSA信息。
display system internal ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ] standby slot slot-number
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的链路状态数据库信息。
external:显示链路状态数据库中Type-5 LSA(AS External LSA)的信息。
grace:显示链路状态数据库中Type-11 LSA(Grace LSA)的信息。
inter-prefix:显示链路状态数据库中Type-3 LSA(Inter-Area-Prefix LSA)的信息。
inter-router:显示链路状态数据库中Type-4 LSA(Inter-Area-Router LSA)的信息。
intra-prefix:显示链路状态数据库中Type-9 LSA(Intra-Area-Prefix LSA)的信息。
link:显示链路状态数据库中Type-8 LSA(Link LSA)的信息。
network:显示链路状态数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示链路状态数据库中Type-7 LSA(NSSA LSA)的信息。
router:显示链路状态数据库中Type-1 LSA(Router LSA)的信息。
unknown:显示链路状态数据库中未知类型LSA的信息。
type:LSA类型,取值范围十六进制0~FFFF。如果未指定本参数,将显示所有未知类型LSA的信息。
link-state-id:链路状态ID,IPv4地址形式。
originate-router router-id:发布该LSA的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的链路状态数据库信息。
statistics:显示链路状态数据库中LSA的统计信息。
total:显示链路状态数据库中各种LSA的总数。
standby slot slot-number:显示备份的指定成员设备的OSPFv3链路状态数据库信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的链路状态数据库信息。
1.2.259  display system internal ospfv3 nib
display system internal ospfv3 nib命令用来显示OSPFv3的下一跳NIB信息。
display system internal ospfv3 nib [ nib-id ] [ verbose ]
Probe视图
context-admin
verbose:显示NIB详细信息。
1.2.260  display system internal ospfv3 peer standby
display system internal ospfv3 peer standby命令用来显示备份的OSPFv3邻居信息。
display system internal ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ] standby slot slot-number
Probe视图
context-admin
area area-id:显示位于指定区域的邻居信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
verbose:显示邻居的详细信息。
peer-router-id:显示指定邻居的信息。
statistics:显示OSPFv3邻居的统计信息。
standby slot slot-number:显示备份的指定成员设备的OSPFv3邻居的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3邻居的信息。
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的邻居信息。
如果未指定区域,将显示所有区域的邻居信息。
如果接口参数、邻居Router ID参数都不输入,则显示所有接口的邻居信息。
1.2.261  display system internal ospfv3 prefix
display system internal ospfv3 prefix命令用来显示OSPFv3的前缀对应的LSA信息。
display system internal ospfv3 [ process-id ] prefix { inter | intra } [ ipv6-address prefix-length ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的前缀对应的LSA信息。
inter:显示InterAs前缀对应的LSA信息。
intra:显示IntraAs前缀对应的LSA信息。
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3前缀对应的LSA信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有的前缀对应的LSA信息。
1.2.262  display system internal ospfv3 router
display system internal ospfv3 router命令用来显示OSPFv3中到路由器节点的路由信息。
display system internal ospfv3 [ process-id ] router
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的信息。
1.2.263  display system internal ospfv3 standby
display system internal ospfv3 standby命令用来显示备份的OSPFv3进程的信息。
display system internal ospfv3 [ process-id ] [ verbose ] standby slot slot-number
Probe视图
context-admin
verbose:显示OSPFv3进程的详细信息。如果未指定本参数,将显示OSPFv3进程的概要信息。
standby slot slot-number:显示备份的指定成员设备的OSPFv3进程信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的进程信息。
1.2.264  display system internal ospfv3 statistics
display system internal ospfv3 statistics命令用来显示OSPFv3的统计信息。
display system internal ospfv3 [ process-id ] statistics { request-queue | retrans-queue } [ interface-type interface-number ] [ neighbor-id ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的统计信息。
interface-type interface-number:接口类型和编号,显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
neighbor-id:显示指定邻居的统计信息。如果未指定本参数,将显示所有邻居的统计信息。
1.2.265  display system internal ospfv3 status
display system internal ospfv3 status命令用来显示OSPFv3协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
context-admin
1.2.266  display system internal ospfv3 vlink standby
display system internal ospfv3 vlink standby命令用来显示备份的OSPFv3虚连接信息。
display system internal ospfv3 [ process-id ] vlink standby slot slot-number
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的虚连接信息。
standby slot slot-number:显示备份的指定单板的OSPFv3的虚连接信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的虚连接信息。
standby slot slot-number:显示备份的指定成员设备的OSPFv3的虚连接信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的虚连接信息。
1.2.267  display system internal packet-capture statistics
display system internal packet-capture statistics命令用来显示报文捕获的统计信息。
display system internal packet-capture statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备的报文捕获的统计信息,slot-number表示设备在IRF中的成员编号。若未指定本参数,则显示所有成员设备上的报文捕获的统计信息。
1.2.268  display system internal pbr fib
display system internal pbr fib命令用来显示用户态下下一跳的配置信息。
display system internal pbr slot slot-number fib [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示用户态下指定私网内下一跳的配置信息,如果未指定本参数,则显示用户态下公网内下一跳的配置信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定成员设备的指定私网内下一跳的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.269  display system internal pbr kernel policy
display system internal pbr kernel policy用于显示内核态下的策略路由信息。
display system internal pbr slot slot-number kernel policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示内核态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息。
slot slot-number:显示内核态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。
1.2.270  display system internal pbr policy
display system internal pbr policy用于显示用户态下的策略路由信息。
display system internal pbr slot slot-number policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示用户态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。
1.2.271  display system internal pim bsr-info standby
display system internal pim bsr-info standby命令用来显示备份的BSR信息。
display system internal pim [ vpn-instance vpn-instance-name ] bsr-info standby slot slot-number
Probe视图
1.2.272  display system internal pim c-rp standby
display system internal pim c-rp standby命令用来显示备份的RP信息。
display system internal pim [ vpn-instance vpn-instance-name ] c-rp standby slot slot-number
Probe视图
1.2.273  display system internal pim interface
display system internal pim interface命令用来显示PIM进程中路由管理LIB所维护的接口信息。
display system internal pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number | ip-address { mask-length | mask } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
ip-address:显示指定IP地址的信息。如果未指定本参数,将显示所有IP地址的信息。0.0.0.0为保留地址,用户不感知。
mask-length:表示掩码长度,取值范围为0~32。
mask:表示掩码。
1.2.274  display system internal pim neighbor standby
display system internal pim neighbor standby命令用来显示备份的PIM邻居信息。
display system internal pim [ vpn-instance vpn-instance-name ] neighbor [ interface interface-type interface-number [ neighbor-addres ] ] standby slot slot-number
Probe视图
neighbor-address:PIM邻居的IP地址,显示指定PIM邻居的信息。如果未指定本参数,将显示所有PIM邻居的信息。
1.2.275  display system internal pim routing-table standby
display system internal pim routing-table standby命令用来显示备份的PIM表项信息。
display system internal pim [ vpn-instance vpn-instance-name ] routing-table [ group-address | source-address ] * standby slot slot-number
Probe视图
group-address:组播组地址,显示指定组播组的PIM路由项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的PIM路由项。
source-address:组播源地址,显示包含指定组播源的PIM路由项。
1.2.276  display system internal pim rp
display system internal pim rp命令用来显示PIM的RP统计信息。
display system internal pim [ vpn-instance vpn-instance-name ] rp
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网实例的信息。
1.2.277  display system internal pim rp-info standby
display system internal pim rp-info standby命令用来显示备份的RP信息。
display system internal pim [ vpn-instance vpn-instance-name ] rp-info standby slot slot-number
Probe视图
1.2.278  display system internal pim thread
display system internal pim thread命令用来显示PIM线程的统计信息。
display system internal pim thread { event | main | route }
Probe视图
event:显示PIM事件线程的统计信息。
main:显示PIM主线程的统计信息。
route:显示PIM路由线程的统计信息。
1.2.279  display system internal pim thread main standby
display system internal pim thread main standby命令用来显示PIM备进程的主线程统计信息。
display system internal pim thread main standby slot slot-number
Probe视图
1.2.280  display system internal ppp statistics
display system internal ppp statistics命令用来显示PPP的统计信息。
display system internal ppp statistics { aggregation | all | interface-event } [ slot slot-number ]
Probe视图
context-admin
aggregation:显示PPP的聚合处理统计信息。
all:显示PPP的所有统计信息。
interface-event:显示PPP的接口处理统计信息。
slot slot-number:显示指定成员设备的PPP统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示所有成员设备上的PPP统计信息。
在主用设备和备用设备上都可以查询PPP的统计信息。
1.2.281  display system internal process state
display system internal process state命令用来显示服务的运行状态。
display system internal process state [ slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上服务的运行状态,slot-number表示设备在IRF中的成员编号。不指定该参数时,表示主设备。
cpu cpu-number:显示指定CPU上服务的运行状态,cpu-number表示CPU的编号。
1.2.282  display system internal rib event attribute
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
context-admin
1.2.283  display system internal rib event policy
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
context-admin
1.2.284  display system internal rib event prefix
display system internal rib notificaion prefix命令用来显示IPv4 RIB的路由前缀事件信息。
Probe视图
context-admin
1.2.285  display system internal rib event protocol
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
display system internal rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
1.2.286  display system internal rib event statistics
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
display system internal rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
1.2.287  display system internal rib instance
display system internal rib instance命令用来显示RIB的协议进程信息。
Probe视图
context-admin
1.2.288  display system internal rib log
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ] [ standby slot slot-number ]
display system internal rib event log [ standby slot slot-number ]
Probe视图
context-admin
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定成员设备的RIB的日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB的日志信息。
1.2.289  display system internal rib memory
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
context-admin
1.2.290  display system internal rib nib
display system internal rib nib命令用来显示RIB的下一跳信息。
display system internal rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number
display system internal rib nib protocol protocol [ verbose ] standby slot slot-number
Probe视图
context-admin
self-originated:路由管理自己生成的下一跳信息。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议生成的下一跳信息。
standby slot slot-number:显示备份的指定成员设备的RIB下一跳信息,slot-number表示设备在IRF中的成员编号。
1.2.291  display system internal rib nib log
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ] [ standby slot slot-number ]
Probe视图
context-admin
nib:显示NIB子模块的运行状态。
standby slot slot-number:显示备份的指定成员设备的NIB子模块的运行状态日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示NIB子模块的运行状态日志。
1.2.292  display system internal rib prefix
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length [ vpn-instance vpn-instance-name ] [ standby slot slot-number ]
Probe视图
context-admin
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
standby slot slot-number:显示备份的指定成员设备的IPv4路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv4路由表前缀信息。
1.2.293  display system internal rib summary
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
display system internal rib summary [ standby slot slot-number ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定成员设备的RIB统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB统计信息。
1.2.294  display system internal rip database standby
display system internal rip database standby命令用来显示备份的RIP数据库的激活路由。
display system internal rip process-id database standby [ ip-address { mask-length | mask } ] slot slot-number
Probe视图
context-admin
process-id:RIP进程号,取值范围为1~65535。
ip-address:目的IP地址,点分十进制格式。
mask-length/mask:IP地址掩码,点分十进制格式或以整数形式表示的长度,当用整数时,取值范围为0~32。
standby slot slot-number:显示备份的指定成员设备的RIP数据库的激活路由,slot-number表示设备在IRF中的成员编号。
1.2.295  display system internal rip graceful-restart event-log
display system internal rip graceful-restart event-log命令用来显示RIP GR日志信息。
display system internal rip graceful-restart event-log slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的RIP GR日志信息,slot-number表示设备在IRF中的成员编号。
1.2.296  display system internal rip interface
display system internal rip interface命令用来显示RIP的接口信息。
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
1.2.297  display system internal rip interface standby
display system internal rip interface standby命令用来显示备份的RIP接口信息。
display system internal rip process-id interface standby [ interface-type interface-number ] slot slot-number
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有接口信息。
standby slot slot-number:显示备份的指定成员设备的RIP接口信息,slot-number表示设备在IRF中的成员编号。
1.2.298  display system internal rip neighbor standby
display system internal rip neighbor standby命令用来显示备份的RIP邻居信息。
display system internal rip process-id neighbor standby [ interface-type interface-number ] slot slot-number
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有邻居信息。
standby slot slot-number:显示备份的指定成员设备的RIP邻居信息,slot-number表示设备在IRF中的成员编号。
1.2.299  display system internal rip nib
display system internal rip nib命令用来显示RIP路由下一跳信息。
display system internal rip nib [ nib-id ] [ verbose ]
Probe视图
context-admin
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
1.2.300  display system internal rip nib log
display system internal rip nib log命令用来显示RIP路由下一跳日志信息。
Probe视图
context-admin
1.2.301  display system internal rip non-stop-routing event-log
display system internal rip non-stop-routing event-log命令用来显示RIP NSR日志信息。
display system internal rip non-stop-routing event-log slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备的RIP NSR日志信息,slot-number表示设备在IRF中的成员编号。
1.2.302  display system internal rip route standby
display system internal rip route standby命令用来显示备份的RIP路由信息。
display system internal rip process-id route standby [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ] slot slot-number
Probe视图
context-admin
verbose:显示当前RIP路由表中指定目的地址和掩码的所有路由信息。如果未指定本参数,则只显示指定目的地址和掩码的最优RIP路由。
peer ip-address:显示从指定邻居学到的所有路由信息。
statistics:显示路由的统计信息。路由的统计信息包括路由总数目,各个邻居的路由数目。
standby slot slot-number:显示备份的指定成员设备的RIP路由信息,slot-number表示设备在IRF中的成员编号。
1.2.303  display system internal rip status
display system internal rip status命令用来显示RIP协议全局状态信息。
Probe视图
context-admin
1.2.304  display system internal ripng database standby
display system internal ripng database standby命令用来显示备份的RIPng数据库的激活路由。
display system internal ripng process-id database standby [ ipv6-address prefix-length ] slot slot-number
Probe视图
context-admin
process-id:RIPng进程号,取值范围为1~65535。
ipv6-address prefix-length:显示指定IPv6地址的激活路由信息。ipv6-address表示IPv6地址;prefix-length表示IPv6地址前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定成员设备的RIPng数据库的激活路由,slot-number表示设备在IRF中的成员编号。
1.2.305  display system internal ripng graceful-restart event-log
display system internal ripng graceful-restart event-log命令用来显示RIPng GR日志信息。
display system internal ripng graceful-restart event-log slot slot-number
Probe视图
context-admin
standby slot slot-number:显示指定成员设备的RIPng GR日志信息,slot-number表示设备在IRF中的成员编号。
1.2.306  display system internal ripng interface
display system internal ripng interface命令用来显示RIPng的接口信息。
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128。
1.2.307  display system internal ripng interface standby
display system internal ripng interface standby命令用来显示备份的RIPng接口信息。
display system internal ripng process-id interface standby [ interface-type interface-number ] slot slot-number
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng指定进程的所有接口信息。
standby slot slot-number:显示备份的指定成员设备的RIPng接口信息,slot-number表示设备在IRF中的成员编号。
1.2.308  display system internal ripng neighbor standby
display system internal ripng neighbor standby命令用来显示备份的RIPng邻居信息。
display system internal ripng process-id neighbor standby [ interface-type interface-number ] slot slot-number
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng的所有接口信息。
standby slot slot-number:显示备份的指定成员设备的RIPng邻居信息,slot-number表示设备在IRF中的成员编号。
1.2.309  display system internal ripng nib
display system internal ripng nib命令用来显示RIPng路由下一跳信息。
display system internal ripng nib [ nib-id ] [ verbose ]
Probe视图
context-admin
verbose:显示下一跳详细信息。
1.2.310  display system internal ripng nib log
display system internal ripng nib log命令用来显示RIPng路由下一跳日志信息。
Probe视图
context-admin
1.2.311  display system internal ripng non-stop-routing event-log
display system internal ripng non-stop-routing event-log命令用来显示RIPng NSR日志信息。
display system internal ripng non-stop-routing event-log slot slot-number
Probe视图
context-admin
standby slot slot-number:显示指定成员设备的RIPng NSR日志信息,slot-number表示设备在IRF中的成员编号。
1.2.312  display system internal ripng route standby
display system internal ripng route standby命令用来显示备份的RIPng路由信息。
display system internal ripng process-id route standby [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ] slot slot-number
Probe视图
context-admin
standby slot slot-number:显示备份的指定成员设备的RIPng路由信息,slot-number表示设备在IRF中的成员编号。
1.2.313  display system internal ripng status
display system internal ripng status命令用来显示RIPng协议全局状态信息。
Probe视图
context-admin
1.2.314  display system internal route-direct interface
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
1.2.315  display system internal route-direct log
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
1.2.316  display system internal route-static nib log
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
context-admin
1.2.317  display system internal security-policy
display system internal security-policy命令用来显示安全策略的配置信息。
display system internal security-policy { ip | ipv6 } slot slot-number
Probe视图
context-admin
ip:表示IPv4安全策略。
ipv6:表示IPv6安全策略。
slot slot-number:显示指定成员设备上安全策略的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.318  display system internal security-policy dbm
display system internal security-policy dbm命令用来显示DBM中安全策略的配置信息。
display system internal security-policy { ip | ipv6 } dbm slot slot-number
Probe视图
context-admin
ip:表示显示DBM中IPv4安全策略的配置信息。
ipv6:表示显示DBM中IPv6安全策略的配置信息。
slot slot-number:显示指定成员设备上DBM中安全策略的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.319  display system internal security-policy kernel
display system internal security-policy kernel命令用来显示内核中安全策略的配置信息。
display system internal security-policy { ip | ipv6 } kernel slot slot-number
Probe视图
context-admin
ip:表示IPv4安全策略。
ipv6:表示IPv6安全策略。
slot slot-number:显示指定成员设备上内核中安全策略的配置信息。slot-number表示设备在IRF中的成员编号。
1.2.320  display system internal session
display system internal session命令用来显示会话的配置信息。
display system internal session [ slot slot-number ] [ verbose | interface [ interface-type interface-number ] ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的会话配置信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的会话配置信息。
verbose:显示会话配置的详细信息。不指定该参数时,显示会话配置的概要信息。
interface interface-type interface-number:表示使用指定接口的会话配置信息。interface-type interface-number表示接口类型和接口编号。
1.2.321  display system internal session aging-queue
display system internal session aging-queue命令用来显示会话管理模块老化队列的统计信息。
display system internal session aging-queue [ { ipv4 | ipv6 } hot-backup-relation | relation ] [ slot slot-number [ core core-number ] ] [ verbose ]
Probe视图
context-admin
ipv4:显示IPv4热备份关联表项老化队列的统计信息。
ipv6:显示IPv6热备份关联表项老化队列的统计信息。
hotback-relation:显示热备份关联表项老化队列的统计信息。
relation:显示关联表项老化队列的统计信息。
slot slot-number:显示指定单板上的会话老化队列统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有单板上的会话老化队列统计信息。
core core-number:显示指定内核上的会话老化队列统计信息,core-number表示多核CPU的内核编号。
verbose:显示会话模块老化队列的详细统计信息。若不指定该参数,则只显示会话管理模块老化队列上关联表项的个数统计信息。
如果不指定任何参数,则显示会话表项老化队列的统计信息。
1.2.322  display system internal session alg-exception
display system internal session alg-exception命令用来显示ALG异常统计信息。
display system internal session alg-exception [ slot slot-number ] [ acl acl-number ] [ application { ftp | gtp | h225 | h245 | ils | mgcp | nbdgm | nbns | nbss | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的ALG异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的ALG异常报文统计信息。
acl acl-number:显示匹配指定ACL的ALG异常统计信息,取值范围为2000~3999。
ftp:表示FTP的ALG异常统计信息。
gtp:表示GTP的ALG异常统计信息。
h225:表示H.225的ALG异常统计信息。
h245:表示H.245的ALG异常统计信息。
ils:表示ILS的ALG异常统计信息。
mgcp:表示MGCP的ALG异常统计信息。
nbns:表示NBNS的ALG异常统计信息。
nbss:表示NBSS的ALG异常统计信息。
ngdgm:表示NGDGM的ALG异常统计信息。
pptp:表示PPTP的ALG异常统计信息。
rsh:表示RSH的ALG异常统计信息。
ras:表示RAS的ALG异常统计信息。
rtsp:表示RTSP的ALG异常统计信息。
sccp:表示SCCP的ALG异常统计信息。
sip:表示SIP的ALG异常统计信息。
sqlnet:表示SQLNET的ALG异常统计信息。
tftp:表示TFTP的ALG异常统计信息。
xdmcp:表示XDMCP的ALG异常统计信息。
1.2.323  display system internal session hot-backup statistics
display system internal session hot-backup statistics命令用来显示会话热备份的统计信息。
display system internal session hot-backup statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上会话热备份的统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上会话热备份的统计信息。
1.2.324  display system internal session relation hot-backup statistics
display system internal session relation hot-backup statistics命令用来显示会话关联表的热备统计信息。
display system internal session relation hot-backup statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上会话关联表的热备份统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上会话关联表的热备份统计信息。
1.2.325  display system internal session relation-table ipv4
display system internal session relation-table ipv4命令用来显示IPv4关联表详细信息。
display system internal session relation-table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的IPv4关联表详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv4关联表详细信息。
source-ip source-ip:显示指定源IPv4地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的关联表表项。destination-ip表示发起方到响应方关联表的目的IPv4地址。
1.2.326  display system internal session relation-table ipv6
display system internal session relation-table ipv6命令用来显示IPv6关联表详细信息。
display system internal session relation-table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的IPv6关联表详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv6关联表详细信息。
source-ip source-ip:显示指定源IPv6地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的关联表表项。destination-ip表示发起方到响应方关联表的目的IPv6地址。
1.2.327  display system internal session statistics
display system internal session statistics命令用来显示会话的异常报文统计信息。
display system internal session statistics { ipv4 | ipv6 } [ slot slot-number ]
Probe视图
context-admin
ipv4:显示Pv4会话的异常报文统计信息。
ipv6:显示IPv6会话的异常报文统计信息。
slot slot-number:显示指定成员设备上的异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的异常报文统计信息。
1.2.328  display system internal session table ipv4
display system internal session table ipv4命令用来显示IPv4单播会话表项详细信息。
display system internal session table ipv4 [ slot slot-number ] [ [ responder ] { source-ip source-ip | destination-ip destination-ip | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-port source-port | destination-port destination-port } * ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的IPv4单播会话表项详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv4单播会话表项详细信息。
responder:表示以响应方的信息筛选显示IPv4单播会话表项。若不指定该参数时,则以发起方的信息筛选显示IPv4单播会话表项。
source-ip source-ip:显示指定源IP地址的单播会话表项。source-ip表示报文的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的单播会话表项详细信息。destination-ip表示报文的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项详细信息。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4单播会话表项详细信息。其中,source-port表示报文的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项详细信息。其中,destination-port表示报文的目的端口号,取值为0~65535。
1.2.329  display system internal session table ipv6
display system internal session table ipv6命令用来显示IPv6单播会话表项详细信息。
display system internal session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
context-admin
slot slot-number:显示指定成员设备上的IPv6会话表项详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv6会话表项详细信息。
source-ip source-ip:显示指定源IPv6地址的单播会话表项。source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的单播会话表项。destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPV6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
1.2.330  display system internal sslvpn statistics
display system internal sslvpn statistics命令用来显示SSL VPN的统计信息。
display system internal sslvpn statistics slot slot-number
Probe视图
context-admin
slot slot-number:显示指定成员设备上的SSL VPN的统计信息,slot-number表示设备在IRF中的成员编号。
1.2.331  display system internal startup cache
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
context-admin
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
·            字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
·            二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
1.2.332  display system internal stp bridge-info
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
display system internal stp bridge-info instance instance-id slot slot-number
Probe视图
context-admin
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
slot slot-number:显示指定成员设备的生成树桥配置信息和运行状态,slot-number表示设备在IRF中的成员编号。
1.2.333  display system internal stp port-info
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
context-admin
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
1.2.334  display system internal tunnel data
display system internal tunnel data命令用来显示Tunnel接口内核数据信息。
display system internal tunnel data interface tunnel number [ slot slot-number ]
Probe视图
context-admin
interface tunnel number:显示指定Tunnel接口的内核数据信息。number表示Tunnel接口编号,取值为已创建的Tunnel接口的编号。
slot slot-number:显示指定成员设备的Tunnel接口内核数据信息。slot-number表示设备在IRF中的成员编号。如果不指定本参数,则显示命令所在主成员设备的信息。
1.2.335  display system internal userlog mbuf dump
display system internal userlog mbuf dump命令用来显示指定个数的USERLOG UDP报文内容。
display system internal userlog mbuf dump count number [ slot slot-number ]
Probe视图
context-admin
count number:指定显示报文的个数。number为需要显示内容的日志个数,取值范围为1~100。
slot slot-number:指定显示报文的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的报文内容。
1.2.336  display system internal userlog statistic
display system internal userlog statistic命令用来显示USERLOG模块的运行统计信息。
display system internal userlog statistic [ slot slot-number ]
Probe视图
context-admin
slot slot-number:指定查看统计信息的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的统计信息。
1.2.337  display system internal userlog test
display system internal userlog test命令用来发送指定个数的FLOW测试日志,并显示日志发送结果信息。
display system internal userlog test count number [ slot slot-number ]
Probe视图
context-admin
count number:指定发送测试日志个数。number为发送测试日志的个数,取值范围为1~3000。
slot slot-number:指定发送测试日志的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上发送的测试日志。
1.2.338  display system internal virtual-crypto-engine
display system internal virtual-crypto-engine命令用来显示虚拟加密引擎的基本信息,包括虚拟加密引擎的名称、支持的算法能力等信息。
Probe视图
context-admin
若设备没有虚拟加密引擎,则不会显示任何信息。
1.2.339  display system internal virtual-crypto-engine statistics
display system internal virtual-crypto-engine statistics命令用来显示虚拟加密引擎的统计信息,包括建立会话的个数,加密引擎处理的报文数等信息。
display system internal virtual-crypto-engine statistics [ engine-id engine-id slot slot-number ]
Probe视图
context-admin
engine-id engine-id:显示指定加密引擎的统计信息,engine-id为加密引擎ID编号,取值范围为0~4294967295。
slot slot-number:显示指定成员设备上的加密引擎统计信息,slot-number表示设备在IRF中的成员编号。
若不指定任何参数,则表示显示所有虚拟加密引擎的统计信息。
1.2.340  display system internal vlan
display system internal vlan命令用来查看VLAN模块相关的内部信息。
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number
Probe视图
context-admin
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
slot slot-number:查看指定成员设备的VLAN模块信息。其中,slot-number表示设备在IRF中的成员编号。
1.2.341  display system internal vrrp ipv6 kernel
display system internal vrrp ipv6 kernel命令用来显示IPv6 VRRP内核信息。
display system internal vrrp ipv6 kernel { virtual-ip | virtual-router } [ interface interface-type interface number [ vrid virtual-router-id ] ] slot slot-number
Probe视图
context-admin
virtual-ip:显示IPv6 VRRP内核的虚拟地址信息。
virtual-router:显示IPv6 VRRP内核的虚拟路由器信息。
interface interface-type interface-number:显示指定接口的IPv6 VRRP备份组内核信息。interface-type interface-number表示接口类型和接口编号。
vrid virtual-router-id:显示指定IPv6 VRRP备份组号的备份组内核信息。
slot slot-number:显示指定成员设备的IPv6 VRRP备份组内核信息。slot-number表示设备在IRF中的成员编号。
1.2.342  display system internal vrrp kernel
display system internal vrrp kernel命令用来显示IPv4 VRRP内核信息。
display system internal vrrp kernel { virtual-ip | virtual-router } [ interface interface-type interface number [ vrid virtual-router-id ] ] slot slot-number
Probe视图
context-admin
virtual-ip:显示IPv4 VRRP内核的虚拟地址信息。
virtual-router:显示IPv4 VRRP内核的虚拟路由器信息。
interface interface-type interface-number:显示指定接口的IPv4 VRRP备份组内核信息。interface-type interface-number表示接口类型和接口编号。
vrid virtual-router-id:显示指定VRRP备份组号的备份组内核信息。
slot slot-number:显示指定成员设备的IPv4 VRRP备份组内核信息。slot-number表示设备在IRF中的成员编号。
1.2.343  display transceiver information
display transceiver information命令用来显示光模块的详细信息。
display transceiver information interface [ interface-type interface-number ]
Probe视图
context-admin
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的详细信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
1.2.344  display transceiver moduleinfo
display transceiver moduleinfo命令用来显示可插拔光模块软件内部的核心数据结构的信息。
display transceiver moduleinfo interface [ interface-type interface-number ]
Probe视图
context-admin
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块软件内部的核心数据结构的信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数时,表示所有接口。
1.2.345  display transceiver register
display transceiver register命令用来显示可插拔光模块的寄存器信息。
display transceiver register interface [ interface-type interface-number ]
Probe视图
context-admin
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的寄存器信息。interface-type interface-number表示接口类型和接口编号,不指定该参数时,表示所有接口。
1.3  F
1.3.1  follow
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number ]
Probe视图
context-admin
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
1.4  L
1.4.1  license check-timer
license check-timer命令用来修改License的每天检查定时器的值。
license check-timer interval-value slot slot-number
License的每天检查定时器的值为864000秒(24小时)。
Probe视图
context-admin
interval-value:指定检查定时器的周期,单位为秒,范围为10~864000。时间过短可能造成系统繁忙,建议60秒以上。
slot slot-number:表示设备在IRF中的成员编号。
License的有效期以天为单位,设备以每天检查定时器时长为周期,检查License是否过期,如果已经过期,则标识为过期;如果没有过期,则将有效期减一。
本命令不会保存到配置文件,设备重启后会恢复到缺省情况。
本命令仅用于内部测试使用,用户不要使用此命令修改时间,否则会导致License快速过期。
1.4.2  license file-timer
license file-timer命令用来修改License文件检查定时器的周期。
license file-timer interval-value slot slot-number
License文件检查定时器的周期为1800秒(30分钟)。
Probe视图
context-admin
interval-value:指定文件丢失检查定时器的周期,单位为秒,范围为10~864000。时间过短可能造成系统繁忙,建议60秒以上。
slot slot-number:修改指定设备上的文件丢失检查定定时器时间周期。slot-number为设备在IRF中的成员编号。
设备启动后,会自动启动License进程,并检查License文件是否存在。如果License文件不存在,则启动License文件检查定时器,周期性检测License文件是否恢复。License文件恢复,License文件检查定时器会自动删除。
1.4.3  lipc connection detect
lipc connection detect命令用来检测本节点和所有相连节点的连通性。
Probe视图
context-admin
执行该命令后,本节点会向本节点所有相连节点连续发送5个ping报文,如果在200ms内收到目的节点的任何一个回复报文则认为该节点可达,否则不可达。
1.4.4  lipc dump
lipc dump命令用来配置LIPC各协议报文的抓包规则。
undo lipc dump命令用来清除抓包规则。
lipc dump lgmp [ port port ] [ recv | send ] [ lip lip ]
undo lipc dump [ lgmp [ port port ] [ recv | send ] ] [ lip lip ]
lipc dump { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] [ lip lip ]
undo lipc dump [ { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] ] [ lip lip ]
lipc dump { publish | topology } [ recv | send ] [ lip lip ]
undo lipc dump [ { publish | topology } [ recv | send ] ] [ lip lip ]
未配置协议报文的抓包规则。
Probe视图
context-admin
lgmp:配置组播管理协议报文的抓包规则。
mtcp:配置组播传输控制协议报文的抓包规则。
stcp:配置单播传输控制协议报文的抓包规则。
sudp:配置单播用户数据报协议报文的抓包规则。
publish:配置可靠发布协议报文的抓包规则。
topology:配置拓扑协议报文的抓包规则。
port port:匹配协议端口号,不指定本参数时,表示匹配该协议所有端口。
ack:匹配该协议的确认报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
ctrl:匹配该协议的控制报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
data:匹配该协议的数据报文。不指定ack、ctrl和data参数时,表示匹配确认、控制和数据报文。
recv:匹配该协议的接收报文。不指定recv和send参数时,表示匹配接收和发送报文。
send:匹配该协议的发送报文。不指定recv和send参数时,表示匹配接收和发送报文。
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示主设备所在节点。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条协议报文的抓包规则。
所有下发的规则会被记录到系统,使用display system internal lipc dump configuration命令可以查看。
同一个报文被多个协议规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。
报文匹配成功后记录到抓包缓存区,使用display system internal lipc dump命令可以查看。
1.4.5  lipc dump buffer
lipc dump buffer命令用来申请或释放指定节点的LIPC抓包缓存。
lipc dump buffer { alloc [ max-record num ] | free } [ lip lip ]
Probe视图
context-admin
alloc:申请缓存。
free:释放缓存。
max-record num:信息的最大记录缓存字节数,取值范围为1~10000,单位为KB,缺省值为10KB。
开启抓包功能后,系统会缺省申请10KB缓存来缓存捕获的报文。如果要捕获的报文较多,请先使用本命令提前申请内存,再开启抓包功能。
1.4.6  lipc dump enable
lipc dump enable命令用来开启本节点的LIPC抓包功能。
undo lipc dump enable命令用来关闭本节点的LIPC抓包功能。
lipc dump enable [ loop] [ lip lip ]
undo lipc dump enable [ lip lip ]
本节点的LIPC抓包功能处于关闭状态。
Probe视图
context-admin
loop:表示开启循环记录模式,即缓存区满后会删除旧记录来保存新记录。不指定本参数时,表示非循环模式,缓存区满后不再继续记录。
开启本节点的LIPC抓包功能时,如未申请抓包缓存,系统会在开启抓包功能的同时申请10KB的抓包缓存。
关闭本节点的LIPC抓包功能时,不会清除抓包规则和抓包缓存区。
1.4.7  lipc dump offset
lipc dump offset命令用来配置报文内容抓包规则。
lipc dump offset offset length length value value [ recv | send ] [ lip lip ]
undo lipc dump [ offset offset length length value value [ recv | send ] ] [ lip lip ]
未配置报文内容抓包规则。
Probe视图
context-admin
offset:信息的偏移量,取值范围为0~65535。报文偏移起始位置为LIP报文头位置。
length length:信息的长度。取值为1、2、4、8,单位为字节。
value value:信息的内容的十六进制字符串形式(字符串不带“0x”)。length取值为1时,value的取值范围为0~0xFF;length取值为2时,value的取值范围为0~0xFFFF;length取值为4时,value的取值范围为0~0xFFFFFFFF;length取值为8时,value的取值范围为0~0xFFFFFFFFFFFFFFFF。
recv:匹配接收报文。不指定recv和send参数时,表示匹配接收和发送报文。
send:匹配发送报文。不指定recv和send参数时,表示匹配接收和发送报文。
下发内容匹配规则并开启抓包功能后,系统从驱动层收到的报文,从报文的第offset个字节开始取length长的内容,内容的值为value时,记录这个报文的前48字节内容到抓包缓存区。协议抓包规则和内容抓包规则抓取到的报文存放在同一个缓冲区,使用display system internal lipc dump命令可以查看捕获到的报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条不同的报文内容抓包规则。
清除报文内容抓包规则时,需要offset、length、value三个字段完全匹配时才清除该规则,否则提示规则不存在。
同一个报文被多个内容匹配规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。报文匹配成功后记录到抓包缓存区,可使用display system internal lipc dump命令查看。
1.4.8  lipc dump-port
lipc dump-port命令打开指定单播端口的dump开关。
lipc dump-port port &<1-5> [ lip lip ]
undo lipc dump-port [ lip lip ]
单播端口的dump开关是关闭的。
Probe视图
context-admin
port &<1-5>:表示单播端口号,取值范围为0~65535。&<1-5>表示前面的参数最多可以输入5次。
打开指定单播端口的dump开关后,系统会在/proc/lipc/dumpinfo文件中记录该端口的所有报文收发信息。
1.4.9  lipc performance
lipc performance命令用来配置单播或者组播的性能统计功能,用于评测LIPC的传输性能。
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
性能统计开关是关闭的。
Probe视图
context-admin
mtcp:MTCP子模块的信息。
stcp:STCP子模块的信息。
clear:清除单播或者组播的性能统计信息。
off:关闭单播或者组播的性能统计开关。
on:打开单播或者组播的性能统计开关。
1.4.10  lipc ping
lipc ping命令用来检查本节点与目的节点LIPC通信链路的连通性和稳定性。
lipc ping lip lip [ length length ] [ times times ] [ summary ]
Probe视图
context-admin
lip lip:指定目的端的LIP地址,取值范围0~65535。
length length:指定发送的LIPC回显请求报文的长度(不包括LIPC报文头),取值范围为0~32767,单位为字节,缺省值为100字节。
times times:指定LIPC回显请求报文的发送次数,取值范围为0~32767,缺省值为3。
summary:只显示统计信息。不指定该参数时,系统将显示包括统计信息在内的详细信息。
1.4.11  lipc timeout
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
context-admin
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的TOPOLOGY模块在超时时间内一直没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
1.5  M
1.5.1  memory boundary-check enable
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id [ slot slot-number ]
undo memory boundary-check enable job job-id [ slot slot-number ]
内存越界检查功能处于关闭状态。
Probe视图
context-admin
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
·            memory boundary-check scan
1.5.2  memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id [ slot slot-number ]
Probe视图
context-admin
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。(
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
·            memory boundary-check enable
1.5.3  monitor lipc
monitor lipc命令用来以交互模式显示各协议的实时统计信息。统计信息包括收发包信息、状态信息、缓存信息等。
monitor lipc { mtcp | stcp | sudp } { recv | send } [ lip lip ]
Probe视图
context-admin
mtcp:显示组播传输控制协议的实时统计信息。
stcp:显示单播传输控制协议的实时统计信息。
sudp:显示单播用户数据报的实时统计信息。
recv:显示该协议接收报文的实时统计信息。
send:显示该协议发送报文的实时统计信息。
信息的统计周期为5秒。统计结果以报文发送或接收量降序排列,最多同时显示10个数据,每隔5秒刷新一次。命令执行后前5秒内系统需统计信息,无统计信息输出。
用户可以通过输入q或Q来停止执行命令行,退回到命令行视图。
1.5.4  multicast record limit
multicast record limit命令用来配置组播表项操作记录的最大数目。
undo multicast record limit命令用来恢复缺省情况。
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
组播表项操作记录的最大数目为0,即不记录组播表项的操作信息。
Probe视图
fail:表示组播表项的失败操作记录。
limit-value:表示操作记录的最大数目,取值范围为0~500000。
1.6  R
1.6.1  reset hardware internal gm-engine statistics
reset hardware internal gm-engine statistics命令用来清除国密硬件加密引擎的加解密统计信息。
reset hardware internal gm-engine statistics slot-number subslot-number
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号
特性
F1000-E-G2/F1000-A-G2/F1000-S-G2/F1000-C-G2
支持
F100-E-G2/F100-A-G2/F100-M-G2/F100-S-G2/F100-C-G2
·         F100-E-G2/F100-A-G2:支持
·         F100-M-G2/F100-S-G2/F100-C-G2:不支持
F1000-C-EI/F100-E-EI/F100-A-EI/F100-C-EI/F100-A-SI
·         F1000-C-EI/F100-E-EI/F100-A-EI/F100-A-SI:支持
·         F100-C-EI:不支持
F100-C-HI/F100-S-HI/F100-A-HI/F1000-C-HI
·         F100-A-HI/F1000-C-HI:支持
·         F100-C-HI/F100-S-HI:不支持
F1000-C8180/F1000-C8170/F1000-C8160/F1000-C8150/F1000-C8130/F1000-C8120
·         F1000-C8180/F1000-C8170/F1000-C8160:支持
·         F1000-C8150/F1000-C8130/F1000-C8120:不支持
F100-C80-WiNet/F100-C60-WiNet
不支持
Probe视图
context-admin
slot-number:表示单板所在槽位号。
subslot-number:表示单板所在子槽位号。
1.6.2  reset hardware internal irf statistics
reset hardware internal irf statistics命令用来清除所有堆叠通道报文统计。
Probe视图
context-admin
1.6.3  reset system internal adj4 statistics
reset system internal adj4 statistics命令用来清除IPv4邻接表项的统计信息
reset system internal adj4 statistics slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的IPv4邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。
1.6.4  reset system internal adj6 statistics
reset system internal adj6 statistics命令用来清除IPv6邻接表项的统计信息
reset system internal adj6 statistics slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的IPv6邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。
1.6.5  reset system internal aspf statistics
reset system internal aspf statistics命令用来清除ASPF、报文过滤以及对象策略模块的丢包统计信息。
reset system internal aspf statistics { interface | zone-pair } { ipv4 | ipv6 } [ slot slot-number ]
Probe视图
context-admin
interface:清除接口上的ASPF丢包统计信息。
zone-pair:清除域间实例上的ASPF丢包统计信息。
ipv4:清除IPv4报文的丢包统计信息。
ipv6:清除IPv6报文的丢包统计信息。
slot slot-number:清除指定成员设备上的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示清除所有成员设备上的丢包统计信息。
1.6.6  reset system internal bgp link-state
reset system internal bgp link-state命令用来清除BGP和IGP进程间通信的日志信息、IGP发布到BGP的链路状态的统计信息。
reset system internal bgp [ instance instance-name ] link-state log { control | data }
reset system internal bgp [ instance instance-name ] link-state statistics
Probe视图
context-admin
instance instance-name:清除指定BGP实例的信息。instance-name为BGP实例的名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除default实例的信息。
log:清除BGP和IGP进程间通信的日志信息。
control:清除链路状态控制类日志信息。
data:清除链路状态数据类日志信息。
statistics:清除IGP发布到BGP的链路状态的统计信息。
1.6.7  reset system internal bgp log
reset system internal bgp log命令用来清除BGP进程的日志信息。
reset system internal bgp [ instance instance-name ] log [ standby slot slot-number ]
Probe视图
context-admin
standby:清除指定BGP备进程的信息。如果不指定本参数,则清除BGP主进程的信息。
slot slot-number:指定备进程所在的成员设备。slot-number为设备在IRF中的成员编号。
1.6.8  reset system internal bgpm log
reset system internal bgpm log命令用来清除BGP管理进程的日志信息。
reset system internal bgpm log [ standby slot slot-number ]
Probe视图
context-admin
1.6.9  reset system internal data-filter match statistics
reset system internal data-filter match statistics命令用来清除数据过滤匹配的统计信息。
reset system internal data-filter match statistics slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的数据过滤匹配的统计信息。slot-number表示设备在IRF中的成员编号。
·            display system internal data-filter match
1.6.10  reset system internal data-filter rule statistics
reset system internal data-filter rule statistics命令用来清除数据过滤规则的统计信息。
reset system internal data-filter rule statistics slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的数据过滤规则的统计信息。slot-number表示设备在IRF中的成员编号。
·            display system internal data-filter rule
1.6.11  reset system internal inspect hit-statistics
reset system internal inspect hit-statistics命令用来清除应用层检测引擎中检测规则被命中的统计信息。
reset system internal inspect hit-statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上的应用层检测引擎中检测规则被命中的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。
1.6.12  reset system internal inspect http
reset system internal inspect http命令用来清除应用层检测引擎处理HTTP报文解析结果的统计信息。
reset system internal inspect http [ slot slot-number ]
Probe视图
context-admin
该命令清除应用层检测引擎处理HTTP报文解析结果的统计信息。
slot slot-number:清除指定成员设备上的应用层检测引擎处理HTTP报文解析结果的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。
1.6.13  reset system internal ip packet-drop statistics
reset system internal ip packet-drop statistics命令用来清除IPv4转发的丢包统计信息。
reset system internal ip packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上IPv4转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示清除所有成员设备上IPv4转发的丢包统计信息。
1.6.14  reset system internal ip routing-table statistics protocol
reset system internal ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
reset system internal ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby slot slot-number
Probe视图
context-admin
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网的路由统计信息。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
standby slot slot-number:清除备份的指定成员设备的路由统计信息,slot-number表示设备在IRF中的成员编号。
1.6.15  reset system internal ipv6 fast-forwarding statistics
reset system internal ipv6 fast-forwarding statistics 命令用来清除IPv6快转的报文统计信息。
reset system internal ipv6 fast-forwarding statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备的IPv6快转的报文统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则清除Master设备上的快转的报文统计信息。
1.6.16  reset system internal ipv6 packet-drop statistics
reset system internal ipv6 packet-drop statistics命令用来清除IPv6转发的丢包统计信息。
reset system internal ipv6 packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上IPv6转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示清除所有成员设备上IPv6转发的丢包统计信息。
1.6.17  reset system internal ipv6 rib log
reset system internal ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset system internal ipv6 rib [ event ] log [ standby slot slot-number ]
Probe视图
context-admin
event:IPv6 RIB路由变化相关的日志。
standby slot slot-number:清除备份的指定成员设备的RIB相关的日志内容,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB相关的日志内容。
1.6.18  reset system internal ipv6 rib nib log
reset system internal ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
reset system internal ipv6 rib nib log [ standby slot slot-number ]
Probe视图
context-admin
standby slot slot-number:清除备份的指定成员设备的NIB子模块日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除NIB子模块日志。
1.6.19  reset system internal ipv6 rib summary
reset system internal ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
reset system internal ipv6 rib summary [ standby slot slot-number ]
Probe视图
context-admin
standby slot slot-number:清除备份的指定成员设备RIB的统计摘要信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB的统计摘要信息。
1.6.20  reset system internal ipv6 route-direct log
reset system internal ipv6 route-direct log命令用来清除直连路由日志。
reset system internal ipv6 route-direct { event | notify | nib } log
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:ipv6直连路由NIB子模块相关日志。
1.6.21  reset system internal ipv6 route-static nib log
reset system internal ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
context-admin
1.6.22  reset system internal ipv6 routing-table statistics protocol
reset system internal ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset system internal ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby slot slot-number
Probe视图
context-admin
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
1.6.23  reset system internal irf msg
reset system internal irf msg命令用来清空IRF日志消息。
reset system internal irf msg [ slot slot-number ]
Probe视图
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。
1.6.24  reset system internal lipc dump buffer
reset system internal lipc dump buffer命令用来清空本节点的LIPC抓包缓存。
reset system internal lipc dump buffer [ lip lip ]
Probe视图
context-admin
1.6.25  reset system internal loadbalance local-dns-server statistics
reset system internal loadbalance local-dns-server statistics命令用来清除入方向链路负载均衡内核统计信息。
reset system internal loadbalance local-dns-server statistics [ error | selected-times | predictor-times ]
Probe视图
context-admin
error:清除入方向链路负载均衡的内核错误统计信息。
selected-times:清除入方向链路负载均衡虚服务选中次数的统计信息。
predictor-times:清除入方向链路负载均衡调度算法执行次数的统计信息。
1.6.26  reset system internal loadbalance statistics
reset system internal loadbalance statistics命令用来清除负载均衡转发流程的统计信息。
Probe视图
context-admin
1.6.27  reset system internal local-dns-server statistics
reset system internal local-dns-server statistics命令用来清空入方向链路负载均衡的KDNS内核统计信息。
reset system internal local-dns-server statistics [ error | packet ]
Probe视图
context-admin
packet:清除入方向链路负载均衡的报文统计信息。
1.6.28  reset system internal mac-address statistics
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
reset system internal mac-address statistics slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的MAC地址表统计信息。slot-number表示设备在IRF中的成员编号。
1.6.29  reset system internal mac-forwarding packet-drop statistics
reset system internal mac-forwarding packet-drop statistics命令用来清除二层转发的丢包统计信息。
reset system internal mac-forwarding packet-drop statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上二层转发的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示清除所有成员设备上二层转发的丢包统计信息。
1.6.30  reset system internal mbuf relay statistics
reset system internal mbuf relay statistics命令用来清除MBUF中继模块的统计信息。
reset system internal mbuf relay statistics slot slot-number [ vcpu vcpu-number ] [ rcv receiver-id ] ]
Probe视图
context-admin
slot slot-number:清除指定成员设备的MBUF中继模块的统计信息。slot-number表示设备在IRF中的成员编号。
vcpu vcpu-number:MBUF中继使用的VCPU的编号。不指定该参数时,表示当前单板上的所有VCPU。
rcv received-id:MBUF中继接收者的编号。不指定该参数时,表示当前VCPU上的所有接收者。
1.6.31  reset system internal multicast forwarding-table dummy
reset system internal multicast forwarding-table dummy命令用来清除组播临时转发表中的表项。
reset system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all } [ slot slot-number ]
Probe视图
vpn-instance vpn-instance-name:清除指定VPN实例的表项,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的表项。
source-address:清除指定组播源的表项。如果未指定本参数,将清除所有组播源的表项。
group-address:清除指定组播组的表项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将清除所有组播组的表项。
mask-length:指定组播源或组播组地址的掩码长度。对于组播源地址,其取值范围为0~32,缺省值为32;对于组播组地址,其取值范围为4~32,缺省值为32。
mask:指定组播源或组播组地址的掩码,缺省值为255.255.255.255。
all:清除所有表项。
slot slot-number:清除指定成员设备上的表项,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除主设备上的表项。
1.6.32  reset system internal multicast record
reset system internal multicast record命令用来清除组播表项的操作记录。
Probe视图
1.6.33  reset system internal nat statistics
reset system internal nat statistics命令用来清除NAT统计信息。
reset system internal nat statistics  [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上的NAT统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则清除所有成员设备上的NAT统计信息。
1.6.34  reset system internal ospf event-log
reset system internal ospf event-log命令用来清除OSPF的日志信息。
reset system internal ospf event-log { igp-ls { control | data } | interface | nib | notify }
Probe视图
context-admin
igp-ls:链路状态相关日志。
control:链路状态控制类日志信息。
data:链路状态数据类日志信息。
interface:接口事件相关日志。
nib:NIB的相关日志。
notify:接口通知相关日志。
1.6.35  reset system internal packet-capture statistics
reset system internal packet-capture statistics命令用来清除报文捕获的统计信息。
Probe视图
context-admin
1.6.36  reset system internal ppp statistics
reset system internal ppp statistics命令用来清除PPP的统计信息。
reset system internal ppp statistics { aggregation | all | interface-event } [ slot slot-number ]
Probe视图
context-admin
aggregation:清除PPP的聚合处理统计信息。
all:清除PPP的所有统计信息。
interface-event:清除PPP的接口处理统计信息。
slot slot-number:清除指定成员设备的PPP统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除所有成员设备上的PPP统计信息。
在主用设备和备用设备上都可以清除PPP的统计信息。
1.6.37  reset system internal rib log
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log [ standby slot slot-number ]
Probe视图
context-admin
event:RIB路由变化相关的日志。
1.6.38  reset system internal rib nib log
reset system internal rib nib log命令用来清除NIB子模块日志。
reset system internal rib nib log [ standby slot slot-number ]
Probe视图
context-admin
1.6.39  reset system internal rib summary
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
reset system internal rib summary [ standby slot slot-number ]
Probe视图
context-admin
1.6.40  reset system internal rip graceful-restart event-log
reset system internal rip graceful-restart event-log命令用来清除RIP GR日志信息。
reset system internal rip graceful-restart event-log slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的RIP GR日志信息,slot-number表示设备在IRF中的成员编号。
1.6.41  reset system internal rip non-stop-routing event-log
reset system internal rip non-stop-routing event-log命令用来清除RIP NSR日志信息。
reset system internal rip non-stop-routing event-log slot slot-number
Probe视图
context-admin
slot slot-number:清除指定成员设备的RIP NSR日志信息,slot-number表示设备在IRF中的成员编号。
1.6.42  reset system internal ripng graceful-restart event-log
reset system internal ripng graceful-restart event-log命令用来清除RIPng GR日志信息。
reset system internal ripng graceful-restart event-log slot slot-number
Probe视图
context-admin
standby slot slot-number:清除指定成员设备的RIPng GR日志信息,slot-number表示设备在IRF中的成员编号。
1.6.43  reset system internal ripng non-stop-routing event-log
reset system internal ripng non-stop-routing event-log命令用来清除RIPng NSR日志信息。
reset system internal ripng non-stop-routing event-log slot slot-number
Probe视图
context-admin
standby slot slot-number:清除指定成员设备的RIPng备进程的NSR日志信息,slot-number表示设备在IRF中的成员编号。
1.6.44  reset system internal route-direct log
reset system internal route-direct log命令用来清除直连路由日志。
reset system internal route-direct { event | notify | nib } log
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
1.6.45  reset system internal route-static nib log
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
context-admin
1.6.46  reset system internal session alg statistics
reset system internal session alg statistics命令用来清除ALG异常报文统计信息。
reset system internal session alg statistics [ slot slot-number ]
Probe视图
context-admin
slot slot-number:清除指定成员设备上的ALG异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则清除所有成员设备上的ALG异常报文统计信息。
1.6.47  reset system internal session statistics
reset system internal session statistics命令用来清除会话异常报文统计信息。
reset system internal session statistics { ipv4 | ipv6 } [ slot slot-number ]
Probe视图
context-admin
ipv4:清除IPv4会话的异常报文统计信息。
ipv6:清除IPv6会话的异常报文统计信息。
1.6.48  reset system internal sslvpn statistics
reset system internal sslvpn statistics命令用来清除SSL VPN的统计信息。
Probe视图
context-admin
1.6.49  reset system internal virtual-crypto-engine statistics
reset system internal virtual-crypto-engine statistics命令用来清除虚拟加密引擎的统计计数。
reset system internal virtual-crypto-engine statistics [ engine-id engine-id slot slot-number ]
Probe视图
context-admin
engine-id engine-id:清除指定加密引擎的统计信息,engine-id为加密引擎ID编号,取值范围为0~4294967295。
slot slot-number:清除指定成员设备上的加密引擎统计信息,slot-number表示设备在IRF中的成员编号。
若不指定任何参数,则表示清除所有虚拟加密引擎的统计信息。
1.7  S
1.7.1  set xlp txlane
set xlp txlane命令用来修改报文发送通道配置。
set xlp txlane { add | delete } { datapkt | hotbackuppkt | irfpkt } mailboxID slot slot-number subslot-number
型号
特性
支持
·         F100-C-EI:不支持
不支持
Probe视图
context-admin
add:为特定报文类型增加一个通道。
delete:为特定报文类型减少一个通道。
datapkt:普通数据报文类型。
hotbackuppkt:热备报文类型。
irfpkt:堆叠报文类型。
mailboxID:发送通道号。取值范围为0~1023。
subslot-number:子卡所在的子槽位号。取值范围为0~2,0表示主控板。
1.7.2  switch flow
本命令不支持buildrun,设备重启就会恢复默认配置。
switch flow命令用来配置交换芯片报文发送分流策略。
switch flow { both | dstip | srcip } slot slot-number subslot-number index-number
型号
特性
支持
·         F100-C-EI:不支持
不支持
同时通过源IP和目的IP地址进行hash分流。
Probe视图
both:配置交换芯片同时通过源IP和目的IP地址进行hash分流。
dstip:配置交换芯片通过目的IP地址进行hash分流。
srcip:配置交换芯片通过源IP地址进行hash分流。
subslot-number:子卡所在的子槽位号。0表示主控板。
index-number:交换芯片编号。固定取值为0。
1.7.3  switch show-flow
本命令是直接包装sdk的shell命令,输出信息为sdk自己的格式输出。
switch show-flow命令用来显示交换芯片报文发送分流策略。
switch show-flow slot slot-number subslot-number index-number
型号
特性
支持
·         F100-C-EI:不支持
不支持
Probe视图
1.7.4  system internal relation hot-backup force-delete enable
system internal relation hot-backup force-delete enable命令用来开启强制删除会话热备份的关联表功能。
undo system internal relation hot-backup force-delete enable命令用来关闭强制删除会话热备份的关联表功能。
强制删除会话热备份的关联表功能处于开启状态。
Probe视图
context-admin
1.7.5  system internal relation hot-backup update enable
system internal relation hot-backup update enable命令用来开启会话热备份的关联表更新功能。
undo system internal relation hot-backup update enable命令用来关闭会话热备份的关联表更新功能。
会话热备份的关联表更新功能处于开启状态。
Probe视图
context-admin
1.7.6  system internal relation synchronization enable
system internal relation synchronization enable命令用来开启会话热备份的关联表同步功能。
undo system internal relation synchronization enable命令用来关闭会话热备份的关联表同步功能。
会话热备份的关联表同步功能处于开启状态。
Probe视图
context-admin
1.7.7  system internal session alg statistics
system internal session alg statistics acl acl-number enable命令用来开启ALG异常报文统计功能。
undo system internal session alg statistics命令用来恢复缺省情况。
system internal session alg statistics acl acl-number enable [ slot slot-number ]
ALG异常报文统计功能处于关闭状态。
Probe视图
context-admin
acl acl-number:指定ACL的编号,acl-number取值范围为2000~3999。
slot slot-number:表示在指定成员设备上开启ALG异常报文统计功能,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示在所有成员设备上开启ALG异常报文统计功能。
开启ALG异常报文统计功能后,设备对匹配指定IPv4/IPv6 ACL的ALG异常报文进行统计。关闭ALG统计开关后,清除统计信息。
1.7.8  system internal session hot-backup aging-request enable
system internal session hot-backup aging-request enable命令用来开启热备份的会话老化请求发送功能。
undo system internal session hot-backup aging-request enable命令用来关闭热备份的会话老化请求发送功能。
热备份的会话老化请求发送功能处于开启状态。
Probe视图
context-admin
1.7.9  system internal session hot-backup aging-response enable
system internal session hot-backup aging-response enable命令用来开启热备份的会话老化应答功能。
undo system internal session hot-backup aging-response enable命令用来关闭热备份的会话老化应答功能。
热备份的会话老化应答功能处于开启状态。
Probe视图
context-admin
1.7.10  system internal session hot-backup broadcast enable
system internal session hot-backup broadcast enable命令用来开启广播会话热备份功能。
undo system internal session hot-backup broadcast enable命令用来关闭广播会话热备份功能。
广播会话热备份功能处于开启状态。
Probe视图
context-admin
1.7.11  system internal session hot-backup force-delete enable
system internal session hot-backup force-delete enable命令用来开启热备份的会话强制删除功能。
undo system internal session hot-backup force-delete enable命令用来关闭热备份的会话强制删除功能。
热备份的会话强制删除功能处于开启状态。
Probe视图
context-admin
