10-LLDP命令
本章节下载: 10-LLDP命令 (266.87 KB)
1.1.1 display lldp local-information
1.1.2 display lldp neighbor-information
1.1.7 lldp check-change-interval
1.1.8 lldp compliance admin-status cdp
1.1.11 lldp encapsulation snap
1.1.15 lldp management-address-format string
1.1.18 lldp notification med-topology-change enable
1.1.19 lldp notification remote-change enable
1.1.20 lldp timer fast-interval
1.1.21 lldp timer notification-interval
1.1.22 lldp timer reinit-delay
三层以太网接口是指在以太网接口视图下通过port link-mode route命令切换为三层模式的以太网接口,有关以太网接口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网接口配置”。
display lldp local-information命令用来显示LLDP本地信息,这些信息将将根据端口TLV使能情况被组织成TLV发送给邻居设备。
global:显示全局LLDP本地信息。
interface interface-type interface-number:显示指定接口上的LLDP本地信息,interface-type interface-number表示接口类型和接口编号。
如果未指定任何参数,将显示所有LLDP本地信息,包括全局LLDP信息以及所有使能了LLDP功能且状态为up的接口上的LLDP信息。
<Sysname> display lldp local-information
Chassis ID : 0000-fc00-a208
System name : H3C
System description : H3C Comware Platform Software, Software Version 7.1.045,
Ess 1105
H3C S12510-X
Copyright (c) 2004-2013 Hangzhou H3C Tech. Co., Ltd. All
rights reserved.
System capabilities supported : Bridge, Router, Customer Bridge, Service Bridge
System capabilities enabled : Bridge, Router, Customer Bridge
MED information:
Device class : Connectivity device
MED inventory information of master board:
HardwareRev : VER.A
FirmwareRev : 119
SoftwareRev : S12510-X-CMW71045-1105
SerialNum : Unknown
Manufacturer name : H3C
Model name : H3C S12510-X
Asset tracking identifier : Unknown
LLDP local-information of port 52[FortyGigE1/0/3]:
Port ID type : Interface name
Port ID : FortyGigE1/0/3
Port description : FortyGigE1/0/3 Interface
LLDP agent nearest-bridge management address:
Management address type : IPv4
Management address : 192.168.80.60
Management address interface ID : Unknown
Management address OID : 0
LLDP agent nearest-nontpmr management address:
Management address : 192.168.80.61
LLDP agent nearest-customer management address:
Management address : 192.168.80.62
DCBX Control info:
Oper version : Standard
DCBX PFC info:
P0-0 P1-0 P2-0 P3-0 P4-0 P5-0 P6-0 P7-0
Number of traffic classes supported: 8
Value of MBC: 0
Port VLAN ID(PVID): 1
Port and protocol VLAN ID(PPVID) : 0
Port and protocol VLAN supported : No
Port and protocol VLAN enabled : No
VLAN name of VLAN 12: VLAN 0012
Management VLAN ID : 5
Link aggregation enabled : No
Aggregation port ID : 0
Auto-negotiation enabled : Yes
OperMau : Speed(40000)/Duplex(Full)
Power port class : PSE
PSE power supported : No
PSE power enabled : No
PSE pairs control ability : No
Power pairs : Signal
Port power classification : Class 0
Maximum frame size : 12288
表1-1 display lldp local-information命令显示信息描述表
Global LLDP local-information |
本设备的全局LLDP本地信息 |
Chassis ID |
Chassis ID值,为本设备的桥MAC地址 |
System name |
系统名称 |
System description |
系统描述 |
System capabilities supported |
系统所支持的功能: · Bridge:表示支持交换功能 · Router:表示支持路由功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
System capabilities enabled |
系统已使能的功能: · Bridge:表示交换功能已使能 · Router:表示路由功能已使能 · DocsisCableDevice:表示电缆设备功能已使能 · StationOnly:表示只作站点功能已使能 · Customer Bridge:表示客户桥功能已使能 · Service Bridge:表示服务桥功能已使能 · TPMR:表示双端口MAC中继功能已使能 · Other:表示不在上述列表的其它功能已使能 |
MED information |
MED设备相关信息 |
Device class |
MED设备类型: · Connectivity device:表示网络设备 · Class I:表示一般终端设备,即所有需要LLDP发现服务的终端设备 · Class II:表示媒体终端设备,即具备媒体能力的终端设备,其能力包含了一般终端设备的能力。该类设备支持媒体流 · Class III:表示通讯终端设备,即直接支持目标用户IP通讯系统的终端设备,其能力包含了一般终端设备和媒体终端设备的所有能力。该类设备直接被目标用户所使用 |
MED inventory information of master board |
主控板MED资产信息 |
HardwareRev |
产品的硬件版本 |
FirmwareRev |
产品的固件版本 |
SoftwareRev |
产品的软件版本 |
SerialNum |
序列号 |
Manufacturer name |
制造厂商 |
Model name |
模块名称 |
Asset tracking identifier |
资产跟踪ID |
LLDP local-information of port 1 |
端口1上LLDP本地信息 |
Port ID type |
端口ID类型: · MAC address:表示MAC地址 · Interface name:表示接口名称 |
Port ID |
端口ID值,根据本设备的Port ID type取相应类型的值 |
Port description |
端口描述 |
LLDP agent nearest-bridge management address |
LLDP缺省代理,即最近桥代理的管理地址 |
LLDP agent nearest-customer management address |
LLDP最近客户桥代理的管理地址 |
LLDP agent nearest-nontpmr management address |
LLDP最近非TPMR桥代理的管理地址 |
Management address type |
管理地址类型 |
Management address |
管理地址 |
Management address interface type |
管理地址所在接口的编码方式 |
Management address interface ID |
管理地址接口索引 |
Management address OID |
管理地址对象标识符 |
DCBX control info |
显示DCBX控制TLV的信息,在标准DCBX中显示版本信息
本系列设备暂不支持DCBX功能。 |
Oper version |
DCBX版本号
本系列设备暂不支持DCBX功能。 |
Number of traffic classes supported |
PFC支持的能力集,只在1.01版本中显示该项
本系列设备暂不支持DCBX PFC功能。 |
DCBX PFC info |
显示PFC TLV信息
支持的MBC状态(MBC表示报文避开MACsec的能力,占1个bit,取值为0表示MACsec去使能时,报文可以避开MACsec,取值为1表示MACsec去使能时,报文不可以避开MACsec)
本系列设备暂不支持此功能。 |
Port VLAN ID(PVID) |
端口VLAN ID |
Port and protocol VLAN ID(PPVID) |
端口协议VLAN ID |
Port and protocol VLAN supported |
是否支持端口协议VLAN |
Port and protocol VLAN enabled |
是否已使能端口协议VLAN |
VLAN name of VLAN 12 |
VLAN 12的名称 |
Management VLAN ID |
管理VLAN ID |
Auto-negotiation supported |
端口是否支持自协商 |
Auto-negotiation enabled |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE(Power Sourcing Equipment,供电设备) · PD(Powered Device,受电设备) |
PSE power supported |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
PSE pairs control ability |
供电方式是否可控 |
Power pairs |
PoE端口的远程供电模式: · Signal:表示信号线供电模式 · Spare:表示空闲线供电模式 |
Port power classification |
PD的端口控制级别: · Class 0:表示级别0 · Class 1:表示级别1 · Class 2:表示级别2 · Class 3:表示级别3 · Class 4:表示级别4 |
Link aggregation supported |
端口是否支持链路聚合 |
Link aggregation enabled |
端口是否已使能链路聚合 |
Aggregation port ID |
聚合组中该成员端口的编号,未使能链路聚合功能时为0 |
Maximum frame size |
端口支持的最大帧长度 |
display lldp neighbor-information命令用来显示由邻居设备发来的LLDP信息,这些信息是由邻居设备组织成TLV并发送给本设备的。
interface interface-type interface-number:显示指定接口收到的由邻居设备发来的LLDP信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口收到的由邻居设备发来的LLDP信息。
agent:显示指定类型LLDP代理收到的由邻居设备发来的LLDP信息。如果未指定该参数,将显示所有类型LLDP代理收到的由邻居设备发来的LLDP信息。
nearest-bridge:表示最近桥代理。
nearest-customer:表示最近客户桥代理。
nearest-nontpmr:表示最近非TPMR桥代理。
verbose:显示由邻居设备发来的LLDP详细信息。如果未指定该参数,将显示由邻居设备发来的LLDP概要信息。
list:按列表显示由邻居设备发来的LLDP信息。
system-name system-name:按列表显示由指定邻居设备发来的LLDP信息。system-name表示邻居设备的系统名称,为1~255个字符的字符串。如果未指定该参数,将按列表显示由所有邻居设备发来的LLDP信息。
# 显示所有接口最近桥代理收到的由邻居设备发来的LLDP详细信息。
<Sysname> display lldp neighbor-information agent nearest-bridge verbose
LLDP neighbor-information of port 1[FortyGigE1/0/1]:
LLDP agent nearest-bridge:
LLDP Neighbor index : 1
Update time : 0 days, 0 hours, 1 minutes, 1 seconds
Chassis type : MAC address
Chassis ID : 000f-0055-0002
Port ID : FortyGigE1/0/1
Time to live : 120
Port description : FortyGigE1/0/1 Interface
System name : Sysname
Management address : 192.168.1.55
CDP neighbor-information of port 1[FortyGigE1/0/1]:
CDP neighbor index : 2
Chassis ID : Switch
Address : 2.0.0.2
Port ID : GigabitEthernet1/0/3
Software version : Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9
-M), Version 12.2(25)SED1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 22-Nov-05 23:37 by yenanh
Platform : cisco WS-C3750G-48TS
Duplex : Full
# 显示所有接口所有类型LLDP代理收到的由邻居设备发来的LLDP概要信息。
LLDP neighbor-information of port 52[FortyGigE1/0/3]:
LLDP neighbor index : 3
ChassisID/subtype : 0011-2233-4400/MAC address
PortID/subtype : 000c-29f5-c71f/MAC address
Capabilities : Bridge, Router, Customer Bridge
LLDP neighbor index : 6
PortID/subtype : 000c-29f5-c715/MAC address
Capabilities : None
CDP neighbor-information of port 52[FortyGigE1/0/3]:
CDP neighbor index : 4
Chassis ID : SEP00260B5C0548
Port ID : Port 1
CDP neighbor index : 5
Chassis ID : 0011-2233-4400
Port ID : FortyGigE1/0/4
LLDP agent nearest-nontpmr:
Capabilities : None
# 按列表显示类型LLDP代理所有邻居设备发来的LLDP信息。
Chassis ID : * -- --Nearest nontpmr bridge neighbor
# -- --Nearest customer bridge neighbor
Default -- -- Nearest bridge neighbor
System Name Local Interface Chassis ID Port ID
System1 FGE1/0/1 000f-e25d-ee91 FortyGigE1/0/5
System2 FGE1/0/2 000f-e25d-ee92* FortyGigE1/0/6
System3 FGE1/0/3 000f-e25d-ee93# FortyGigE1/0/7
表1-2 display lldp neighbor-information命令显示信息描述表
LLDP agent nearest-bridge |
LLDP缺省代理,即最近桥代理 |
LLDP agent nearest-customer |
LLDP最近客户桥代理 |
LLDP agent nearest-nontpmr |
LLDP最近非TPMR桥代理 |
LLDP neighbor-information of port 1 |
端口1上收到的LLDP邻居信息 |
LLDP Neighbor index |
邻居索引 |
Update time |
邻居信息最新更新时间 |
Chassis type |
Chassis ID类型: · Chassis component:表示底架组件 · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Locally assigned:表示邻居自定义 |
Chassis ID |
Chassis ID值,根据邻居设备的Chassis type取相应类型的值 |
Port ID type |
端口ID类型: · Interface alias:表示接口化名 · Port component:表示端口组件 · MAC address:表示MAC地址 · Network Address(ipv4):表示网络地址(括号里表示地址类型) · Interface name:表示接口名称 · Agent circuit ID:表示代理巡回标识 · Locally assigned:表示邻居自定义 |
Port ID |
端口ID值,根据邻居设备的Port ID type取相应类型的值 |
Time to live |
邻居信息在本地的存活时间 |
Port description |
端口描述 |
System name |
系统名称 |
系统描述 |
系统所支持的功能: · Repeater:表示支持信号中继功能 · Bridge:表示支持交换功能 · WlanAccessPoint:表示支持无线接入点功能 · Router:表示支持路由功能 · Telephone:表示支持电话功能 · DocsisCableDevice:表示支持电缆设备功能 · StationOnly:表示支持只作站点功能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示支持不在上述列表的其它功能 |
系统已使能的功能: · Repeater:表示信号中继功能已使能 · Bridge:表示交换功能已使能 · WlanAccessPoint:表示无线接入点功能已使能 · Router:表示路由功能已使能 · Telephone:表示电话功能已使能 · DocsisCableDevice:表示电缆设备功能已使能 · StationOnly:表示只作站点功能已使能 · Customer Bridge:表示支持客户桥功能 · Service Bridge:表示支持服务桥功能 · TPMR:表示支持双端口MAC中继功能 · Other:表示不在上述列表的其它功能已使能 |
管理地址类型 |
管理地址 |
管理地址接口类型 |
管理地址接口索引 |
管理地址对象标识符 |
Port VLAN ID |
端口VLAN ID |
VLAN 12的名称 |
管理VLAN ID |
端口是否支持自协商 |
端口是否已使能自协商 |
OperMau |
端口自适应的速率和双工状态 |
Power port class |
PoE类型: · PSE:表示供电设备 · PD:表示受电设备 |
是否支持PSE供电 |
PSE power enabled |
是否已使能PSE供电 |
供电方式是否可控 |
Power pairs |
端口是否支持链路聚合 |
端口是否已使能链路聚合 |
端口支持的最大帧长度 |
Local Interface |
接收LLDP信息的本端端口 |
Chassis ID : * -- -- Nearest nontpmr bridge neighbor #-- -- Nearest customer bridge neighbor |
· *符号:表示该邻居是最近非TPMR桥代理类型邻居 #符号:表示该邻居是最近客户桥代理类型邻居 |
display lldp statistics命令用来显示LLDP的统计信息。
global:显示全局LLDP统计信息。
interface interface-type interface-number:显示指定接口上的LLDP统计信息,interface-type interface-number表示接口类型和接口编号。
agent:显示指定类型LLDP代理的统计信息。如果未指定该参数,将显示所有类型LLDP代理的统计信息。
如果未指定任何参数,将同时显示全局和接口上的LLDP统计信息。
# 显示全局和接口上的LLDP统计信息。
LLDP statistics global information:
LLDP neighbor information last change time:0 days, 0 hours, 4 minutes, 40 seconds
The number of LLDP neighbor information deleted : 1
The number of LLDP neighbor information dropped : 0
LLDP statistics information of port 1 [FortyGigE1/0/1]:
The number of LLDP frames transmitted : 0
The number of LLDP frames received : 0
The number of LLDP frames discarded : 0
The number of LLDP error frames : 0
The number of LLDP TLVs discarded : 0
The number of LLDP TLVs unrecognized : 0
The number of CDP frames transmitted : 0
The number of CDP frames received : 0
The number of CDP frames discarded : 0
The number of CDP error frames : 0
LLDP agent nearest-customer:
# 显示接口FortyGigE1/0/1的最近客户桥代理上的LLDP统计信息。
<Sysname> display lldp statistics interface FortyGigE1/0/1 agent nearest-customer
表1-3 display lldp statistics命令显示信息描述表
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
LLDP statistics global information |
全局LLDP统计信息 |
LLDP neighbor information last change time |
邻居信息的最后更新时间 |
The number of LLDP neighbor information inserted |
邻居信息的增加次数 |
The number of LLDP neighbor information deleted |
邻居信息的删除次数 |
The number of LLDP neighbor information dropped |
由于空间不足而导致丢弃邻居信息的次数 |
The number of LLDP neighbor information aged out |
邻居信息的老化数量 |
LLDP statistics Information of port 1 |
端口1上的LLDP统计信息 |
The number of LLDP frames transmitted |
发送的LLDP帧总数 |
The number of LLDP frames received |
收到的LLDP帧总数 |
The number of LLDP frames discarded |
丢弃的LLDP帧总数 |
The number of LLDP error frames |
收到的错误LLDP帧总数 |
The number of LLDP TLVs discarded |
丢弃的LLDP TLV总数 |
The number of LLDP TLVs unrecognized |
不可识别的LLDP TLV总数 |
老化的LLDP邻居信息总数 |
The number of CDP frames transmitted |
发送的CDP帧总数 |
The number of CDP frames received |
收到的CDP帧总数 |
The number of CDP frames discarded |
丢弃的CDP帧总数 |
The number of CDP error frames |
收到的错误CDP帧总数 |
display lldp status命令用来显示LLDP的状态信息。
interface interface-type interface-number:显示指定接口上的LLDP状态信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有使能了LLDP功能的接口上的LLDP状态信息。
agent:显示指定类型LLDP代理的状态信息。如果未指定该参数,将显示所有类型LLDP代理的状态信息。
# 显示全局和所有接口上的LLDP状态信息。
<Sysname> display lldp status
Global status of LLDP: Enable
The current number of LLDP neighbors: 0
Transmit interval : 30s
Fast transmit interval : 1s
Transmit max credit : 5
Hold multiplier : 4
Reinit delay : 2s
Trap interval : 5s
Fast start times : 3
LLDP status information of port 1 [FortyGigE1/0/1]:
Port status of LLDP : Enable
Admin status : Tx_Rx
Trap flag : No
MED trap flag : No
Polling interval : 0s
Number of LLDP neighbors : 5
Number of MED neighbors : 2
Number of CDP neighbors : 0
Number of sent optional TLV : 12
Trap flag : No
Trap flag : No
表1-4 display lldp status命令显示信息描述表
Bridge mode of LLDP |
LLDP桥模式: · service-bridge:表示服务桥模式 · customer-bridge:表示客户桥模式 |
LLDP缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
Global status of LLDP |
LLDP功能是否已全局使能 |
The current number of LLDP neighbors |
当前设备的LLDP邻居总数 |
The current number of CDP neighbors |
当前设备的CDP邻居总数 |
LLDP neighbor information last changed time |
邻居信息的最后更新时间 |
Transmit interval |
LLDP报文的发送间隔 |
Hold multiplier |
TTL乘数 |
Reinit delay |
端口初始化延迟时间 |
Transmit max credit |
LLDP报文发包限速令牌桶的最大值 |
Trap interval |
Trap信息的发送间隔 |
Fast start times |
快速发送LLDP报文的个数 |
LLDP status infomation of port 1 |
端口1上的LLDP状态信息 |
Port status of LLDP |
LLDP功能是否已在端口上使能 |
Admin status |
端口LLDP工作模式: · Tx_Rx:表示既发送也接收LLDP报文 · Rx_Only:表示只接收不发送LLDP报文 · Tx_Only:表示只发送不接收LLDP报文 · Disable:表示既不发送也不接收LLDP报文 |
Trap Flag |
LLDP Trap功能是否已使能 |
MED trap flag |
LLDP-MED Trap功能是否已使能 |
Polling interval |
轮询间隔,0表示轮询功能处于关闭状态 |
Number of neighbors |
端口LLDP邻居数量 |
Number of MED neighbors |
端口MED邻居设备的数量 |
Number of CDP neighbors |
端口CDP邻居设备的数量 |
Number of sent optional TLV |
端口在一个LLDP报文中发送的可选TLV总数 |
Number of received unknown TLV |
端口在所有LLDP报文中收到的不能识别的TLV总数 |
display lldp tlv-config命令用来显示接口上可发送的可选TLV信息。
display lldp tlv-config [ interface interface-type interface-number ] [ agent { nearest-bridge | nearest-customer | nearest-nontpmr ] ]
interface interface-type interface-number:显示指定接口上可发送的可选TLV信息,interface-type interface-number表示接口类型和接口编号。如果未指定该参数,将显示所有接口上可发送的可选TLV信息。
agent:显示指定类型LLDP代理的可选TLV信息。如果未指定该参数,将显示所有类型LLDP代理的可选TLV信息。
# 显示接口FortyGigE1/0/1上可发送的可选TLV信息。
<Sysname> display lldp tlv-config interface fortygige 1/0/1
LLDP tlv-config of port 1[FortyGigE1/0/1]:
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES YES
System Name TLV YES YES
System Description TLV YES YES
System Capabilities TLV YES YES
Management Address TLV YES YES
IEEE 802.1 extend TLV:
Port VLAN ID TLV YES YES
Port And Protocol VLAN ID TLV YES YES
VLAN Name TLV YES YES
DCBX TLV NO NO
EVB TLV NO NO
Link Aggregation TLV YES YES
Management VID TLV YES YES
IEEE 802.3 extend TLV:
MAC-Physic TLV YES YES
Power via MDI TLV YES YES
Maximum Frame Size TLV YES YES
LLDP-MED extend TLV:
Network Policy TLV YES YES
Location Identification TLV NO NO
Extended Power via MDI TLV YES YES
Inventory TLV YES YES
NAME STATUS DEFAULT
Basic optional TLV:
Port Description TLV YES NO
System Name TLV YES NO
System Description TLV YES NO
System Capabilities TLV YES NO
Management Address TLV YES NO
Port VLAN ID TLV YES NO
Port And Protocol VLAN ID TLV YES NO
VLAN Name TLV YES NO
DCBX TLV NO NO
EVB TLV YES YES
Link Aggregation TLV YES NO
Management VID TLV NO NO
MAC-Physic TLV YES NO
Power via MDI TLV YES NO
Maximum Frame Size TLV YES NO
Network Policy TLV YES NO
Extended Power via MDI TLV YES NO
Inventory TLV YES NO
NAME STATUS DEFAULT
Basic optional TLV:
DCBX TLV NO NO
EVB TLV NO NO
表1-5 display lldp tlv-config命令显示信息描述表
LLDP 缺省代理,即最近桥代理 |
LLDP最近客户桥代理 |
LLDP最近非TPMR桥代理 |
LLDP tlv-config of port 1 |
端口1上可发送的可选TLV类型 |
NAME |
TLV类型 |
STATUS |
端口是否配置发布指定类型TLV |
DEFAULT |
端口发布指定类型TLV的缺省情况 |
Basic optional TLV |
端口可以发送的基本TLV类型 |
Port Description TLV |
端口描述TLV |
System Name TLV |
系统名称TLV |
System Description TLV |
系统描述TLV |
System Capabilities TLV |
系统能力集TLV |
Management Address TLV |
管理地址TLV |
IEEE 802.1 extended TLV |
端口可发送的IEEE 802.1组织定义的TLV类型 |
Port VLAN ID TLV |
端口VLAN ID TLV |
Port And Protocol VLAN ID TLV |
协议VLAN ID TLV |
VLAN Name TLV |
VLAN名称TLV |
DCBX TLV |
DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议) TLV。
本系列交换机暂不支持DCBX TLV。 |
EVB TLV |
EVB(Edge Virtual Bridging,边缘虚拟桥接)模块TLV。
本系列交换机暂不支持EVB TLV。 |
Management VID TLV |
管理VLAN TLV |
IEEE 802.3 extended TLV |
端口可发送的IEEE 802.3组织定义的TLV类型 |
MAC-Physic TLV |
端口物理属性TLV |
Power via MDI TLV |
供电能力TLV |
Link Aggregation TLV |
链路聚合TLV |
Maximum Frame Size TLV |
最大帧长度TLV |
LLDP-MED extend TLV |
LLDP-MED TLV |
Capabilities TLV |
MED能力集TLV |
Network Policy TLV |
网络策略TLV |
Location Identification TLV |
位置标识TLV |
Extended Power via MDI TLV |
扩展供电能力TLV |
Inventory TLV |
资产信息TLV,包括以下几种: · Hardware Revision TLV:终端设备硬件版本 · Firmware Revision TLV:终端设备固件版本 · Software Revision TLV:终端设备软件版本 · Serial Number TLV:终端设备序列号 · Manufacturer Name TLV:终端设备的制造厂商名称 · Model name TLV:终端设备的模块名称 · Asset ID TLV:终端设备的资产标识符,以便目录管理和资产跟踪 |
lldp admin-status命令用来配置LLDP的工作模式。
undo lldp admin-status命令用来恢复缺省情况。
在二层以太网接口视图/三层以太网接口视图下:
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] admin-status
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } admin-status
LLDP最近桥代理的工作模式为TxRx,既发送也接收LLDP报文。其他类型的LLDP代理的工作模式为Disable,即不发送也不接收LLDP报文。
二层以太网接口视图/二层聚合接口视图/三层以太网接口视图
agent:配置指定类型LLDP代理的工作模式。在以太网接口视图下,未指定时表示配置最近桥代理的工作模式。
disable:表示工作模式为Disable,既不发送也不接收LLDP报文。
rx:表示工作模式为Rx,只接收不发送LLDP报文。
tx:表示工作模式为Tx,只发送不接收LLDP报文。
txrx:表示工作模式为TxRx,既发送也接收LLDP报文。
# 配置接口FortyGigE1/0/1上最近客户桥代理LLDP的工作模式为Rx。
[Sysname] interface fortygige 1/0/1
[Sysname-FortyGigE1/0/1] lldp agent nearest-customer admin-status rx
lldp check-change-interval命令用来使能轮询功能并配置轮询间隔。
undo lldp check-change-interval命令用来关闭轮询功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] check-change-interval
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } check-change-interval
轮询功能处于关闭状态。
agent:配置指定类型LLDP代理的轮询功能。在以太网接口视图下,未指定时表示配置最近桥代理的轮询功能。
interval:表示轮询间隔,取值范围为1~30,单位为秒。
# 在接口FortyGigE1/0/1的最近客户桥代理上使能轮询功能,并配置轮询间隔为30秒。
[Sysname-FortyGigE1/0/1] lldp agent nearest-customer check-change-interval 30
lldp compliance admin-status cdp命令用来配置LLDP兼容CDP功能的工作模式。
undo lldp compliance admin-status cdp命令用来恢复缺省情况。
lldp compliance admin-status cdp { disable | txrx }
LLDP兼容CDP功能的工作模式为Disable,既不发送也不接收CDP报文。
二层以太网接口视图/三层以太网接口视图
disable:表示工作模式为Disable,既不发送也不接收CDP报文。
txrx:表示工作模式为TxRx,既发送也接收CDP报文。
欲使LLDP兼容CDP的功能生效,必须先使能LLDP兼容CDP功能,同时将LLDP兼容CDP功能的工作模式配置为TxRx。
# 使能LLDP兼容CDP功能,并在接口FortyGigE1/0/1上配置LLDP兼容CDP功能的工作模式为TxRx。
[Sysname] lldp compliance cdp
[Sysname-FortyGigE1/0/1] lldp compliance admin-status cdp txrx
· lldp compliance cdp
lldp compliance cdp命令用来使能LLDP兼容CDP功能。
undo lldp compliance cdp命令用来恢复缺省情况。
lldp compliance cdp
LLDP兼容CDP功能处于关闭状态。
由于CDP报文所携Time To Live TLV中TTL的最大值为255,而CDP报文的发送间隔由LLDP报文的发送间隔控制,因此为保证LLDP兼容CDP功能的正常运行,建议配置LLDP报文的发送间隔值不大于实际TTL的1/3。
# 使能LLDP兼容CDP功能。
· lldp hold-multiplier
· lldp timer tx-interval
lldp enable命令用来在接口上使能LLDP功能。
undo lldp enable命令用来在接口上关闭LLDP功能。
lldp enable
undo lldp enable
接口上的LLDP功能处于使能状态。
只有当全局和接口上都使能了LLDP功能后,该功能才会生效。
# 在接口FortyGigE1/0/1上关闭LLDP功能。
[Sysname-FortyGigE1/0/1] undo lldp enable
· lldp global enable
lldp encapsulation snap命令用来配置LLDP报文的封装格式为SNAP格式。
undo lldp encapsulation命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] encapsulation
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } encapsulation
LLDP报文的封装格式为Ethernet II格式。
agent:配置指定类型LLDP代理的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的封装格式。
LLDP CDP报文的封装格式只能为SNAP格式,不能为Ethernet II格式。
# 配置接口FortyGigE1/0/1上发送的LLDP报文的封装格式为SNAP格式。
[Sysname-FortyGigE1/0/1] lldp encapsulation snap
lldp fast-count命令用来配置快速发送LLDP报文的个数。
undo lldp fast-count命令用来恢复缺省情况。
lldp fast-count count
快速发送LLDP报文的个数为4个。
count:表示快速发送LLDP报文的个数,取值范围为1~8,单位为个。
# 配置快速发送LLDP报文的个数为5个。
[Sysname] lldp fast-count 5
lldp global enable命令用来全局使能LLDP功能。
undo lldp global enable命令用来全局关闭LLDP功能。
lldp global enable
LLDP功能处于全局关闭状态。
# 全局关闭LLDP功能。
[Sysname] undo lldp global enable
· lldp enable
lldp hold-multiplier命令用来配置TTL乘数。
undo lldp hold-multiplier命令用来恢复缺省情况。
lldp hold-multiplier value
TTL乘数为4。
value:表示TTL乘数,取值范围为2~10。
LLDP报文所携Time To Live TLV中TTL的值用来设置邻居信息在本地设备上的老化时间,由于TTL=Min(65535,(TTL乘数×LLDP报文的发送间隔)),即取65535与(TTL乘数×LLDP报文的发送间隔)中的最小值,因此通过调整TTL乘数可以控制本设备信息在邻居设备上的老化时间。
# 配置TTL乘数为6。
lldp management-address-format string命令用来配置管理地址在TLV中的封装格式为字符串格式。
undo lldp management-address-format命令用来恢复缺省情况。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] management-address-format
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } management-address-format
管理地址在TLV中的封装格式为数字格式。
agent:配置指定LLDP代理类型管理地址在TLV中的封装格式。在以太网接口视图下,未指定时表示配置最近桥代理的管理地址在TLV中的封装格式。
如果邻居将管理地址以字符串格式封装在TLV中,用户可在本地设备上也将封装格式改为字符串,以保证与邻居设备的正常通信。
# 在接口FortyGigE1/0/1的最近客户桥代理上配置管理地址在TLV中的封装格式为字符串格式。
[Sysname-FortyGigE1/0/1] lldp agent nearest-customer management-address-format string
lldp max-credit命令用来配置限制发送报文速率的令牌桶大小。
undo lldp max-credit命令用来恢复缺省情况。
lldp max-credit credit-value
限制发送报文速率的令牌桶大小为5。
credit-value:表示LLDP发包限速的令牌桶大小,取值范围1~100。
# 配置LLDP发包限速的令牌桶大小为10。
[Sysname] lldp max-credit 10
lldp mode命令用来配置当前设备的LLDP桥模式。
undo lldp mode命令用来恢复缺省情况。
lldp mode service-bridge
undo lldp mode
设备的LLDP桥模式为客户桥模式。
service-bridge:表示服务桥模式。
LLDP的桥模式命令用于控制设备支持不同的LLDP代理。
· 工作于服务桥模式时,设备可支持最近桥代理和最近非TPMR桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
· 工作于客户桥模式时,设备可支持最近桥代理、最近非TPMR桥代理及最近客户桥代理,即对上述类型代理MAC的报文进行处理,其他目的MAC的LLDP报文进行VLAN内透传。
桥模式配置只在LLDP全局使能后才能生效,LLDP全局未使能时,只能作为客户桥对三种类型代理MAC的报文进行拦截。
# 配置LLDP桥模式为服务桥模式。
[Sysname] lldp mode service-bridge
lldp notification med-topology-change enable命令用来使能LLDP-MED Trap功能。
undo lldp notification med-topology-change enable命令用来关闭LLDP-MED Trap功能。
LLDP-MED Trap功能处于关闭状态。
二层以太网接口视图/三层以太网接口视图
# 在接口FortyGigE1/0/1上使能LLDP-MED Trap功能。
[Sysname-FortyGigE1/0/1] lldp notification med-topology-change enable
lldp notification remote-change enable命令用来使能LLDP Trap功能。
undo lldp notification remote-change enable命令用来关闭LLDP Trap功能。
undo lldp [ agent { nearest-customer | nearest-nontpmr } ] notification remote-change enable
在二层聚合接口视图下:
undo lldp agent { nearest-customer | nearest-nontpmr } notification remote-change enable
LLDP Trap功能处于关闭状态。
agent:使能指定类型LLDP代理的LLDP Trap功能。在以太网接口视图下,未指定时表示使能最近桥代理类型LLDP代理的LLDP Trap功能。
# 在接口FortyGigE1/0/1最近客户桥代理上使能LLDP Trap功能。
[Sysname-FortyGigE1/0/1] lldp agent nearest-customer notification remote-change enable
lldp timer fast-interval命令用来配置LLDP快速发送报文的时间间隔。
undo lldp timer fast-interval命令用来恢复缺省情况。
LLDP快速发送报文的时间间隔为1秒。
interval:表示LLDP快速发送报文的时间间隔,取值范围为1~3600,单位为秒。
# 配置LLDP快速发送报文的时间间隔为2秒。
[Sysname] lldp timer fast-interval 2
lldp timer notification-interval命令用来配置LLDP Trap和LLDP-MED Trap信息的发送间隔。
undo lldp timer notification-interval命令用来恢复缺省情况。
LLDP Trap和LLDP-MED Trap信息的发送间隔均为30秒。
interval:表示LLDP Trap和LLDP-MED Trap信息的发送间隔,取值范围为5~3600,单位为秒。
# 配置LLDP Trap和LLDP-MED Trap信息的发送间隔为8秒。
lldp timer reinit-delay命令用来配置接口初始化的延迟时间。
undo lldp timer reinit-delay命令用来恢复缺省情况。
lldp timer reinit-delay delay
接口初始化的延迟时间为2秒。
delay:接口初始化的延迟时间,取值范围为1~10,单位为秒。
# 配置接口初始化的延迟时间为4秒。
lldp timer tx-interval命令用来配置LLDP报文的发送间隔。
undo lldp timer tx-interval命令用来恢复缺省情况。
LLDP报文的发送间隔为30秒。
interval:表示LLDP报文的发送间隔,取值范围为5~32768,单位为秒。
# 配置LLDP报文的发送间隔为20秒。
lldp tlv-enable命令用来配置接口上允许发布的TLV类型。
undo lldp tlv-enable命令用来配置接口上禁止发布的TLV类型。
在二层以太网接口视图下:
· 配置最近桥代理LLDP接口上允许发布的TLV类型
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id [ vlan-id ] | vlan-name [ vlan-id ] | management-vid [ mvlan-id ] } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | port-vlan-id | link-aggregation | protocol-vlan-id | vlan-name | management-vid } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | network-policy | power-over-ethernet | location-id } }
· 配置最近非TPMR代理LLDP接口上允许发布的TLV类型
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | port-vlan-id | link-aggregation } }
· 配置最近客户桥代理LLDP接口上允许发布的TLV类型
lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | port-vlan-id | link-aggregation } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | port-vlan-id | link-aggregation } }
在三层以太网接口视图下:
lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id { civic-address device-type country-code { ca-type ca-value }&<1-10> | elin-address tel-number } } }
lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv [ ip-address ] } | dot1-tlv { all | link-aggregation } }
undo lldp tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | link-aggregation } | dot3-tlv { all | mac-physic | max-frame-size | power } | med-tlv { all | capability | inventory | power-over-ethernet | location-id } }
undo lldp agent { nearest-nontpmr | nearest-customer } tlv-enable { basic-tlv { all | port-description | system-capability | system-description | system-name | management-address-tlv } | dot1-tlv { all | link-aggregation } }
在二层聚合接口视图下:
lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv [ ip-address ] | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-nontpmr tlv-enable { basic-tlv { all | management-address-tlv | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp agent nearest-customer tlv-enable { basic-tlv { all | management-address-tlv | port-description | system-capability | system-description | system-name } | dot1-tlv { all | port-vlan-id } }
undo lldp tlv-enable dot1-tlv { protocol-vlan-id | vlan-name | management-vid }
二层以太网接口上:
· 最近桥代理允许发布除Location-id TLV、Port And Protocol VLAN ID TLV、VLAN Name TLV和Management VLAN ID TLV之外所有类型的TLV;
· 最近非TPMR桥代理不允许发布任何TLV;
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV。
三层以太网接口上:
· 最近桥代理允许发布除Network Policy TLV之外所有类型的TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV;
· 最近非TPMR桥代理不发布任何TLV;
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Link Aggregation TLV。
二层聚合接口上:
· 不存在最近桥代理;
· 最近客户桥代理允许发布基本TLV和IEEE 802.1组织定义TLV,其中IEEE 802.1组织定义的TLV只支持Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV。
agent:配置指定类型LLDP代理允许发布的TLV类型。在以太网接口视图下,未指定时表示配置最近桥代理允许发布的TLV类型。
all:在二层以太网接口视图/二层聚合接口视图/三层以太网接口视图下指定basic-tlv、dot1-tlv或dot3-tlv时,本参数表示该类型下所有的可选TLV;在上述任何视图下指定med-tlv时,本参数都表示该类型下除location-id以外所有的可选TLV。
basic-tlv:表示基本类型TLV。
management-address-tlv [ ip-address ]:表示Management Address TLV。其中,ip-address表示在LLDP报文中所要发布的管理地址,其缺省值在二层以太网接口视图/二层聚合接口视图下配置时若未指定ip-address,则发布的管理地址为该端口允许通过的、对应VLAN接口上配置有IP地址且处于up状态的最小VLAN的主IP地址(如果该端口允许通过的所有VLAN所对应的VLAN接口上都未配置IP地址或均处于down状态,则发布该接口的MAC地址),在三层以太网接口视图下配置时若未指定ip-address,则发布的管理地址为该接口的IP地址(如果该接口未配置IP地址,则发布该接口的MAC地址)。
port-description:表示Port Description TLV。
system-capability:表示System Capabilities TLV。
system-description:表示System Description TLV。
system-name:表示System Name TLV。
dot1-tlv:表示IEEE 802.1组织定义的TLV。
port-vlan-id:表示Port VLAN ID TLV。
protocol-vlan-id [ vlan-id ]:表示Port And Protocol VLAN ID TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
vlan-name [ vlan-id ]:表示VLAN Name TLV,vlan-id为所要发布VLAN的VLAN ID,取值范围为1~4094,缺省值为该端口所属VLAN中最小的VLAN ID。
management-vid [ mvlan-id ]:表示Management VLAN ID TLV。mvlan-id指定要发布管理VLAN的VLAN ID,取值范围为1~4094。如果未指定该参数,则表示发布0,表示当前LLDP agent未配置管理VLAN。
link-aggregation:表示Link Aggregation TLV。
dot3-tlv:表示IEEE 802.3组织定义的TLV。
mac-physic:表示MAC/PHY Configuration/Status TLV。
max-frame-size:表示Maximum Frame Size TLV。
power:表示Power Via MDI TLV和Power Stateful Control TLV。
med-tlv:表示LLDP-MED TLV。
capability:表示LLDP-MED Capabilities TLV。
inventory:表示Hardware Revision TLV、Firmware Revision TLV、Software Revision TLV、Serial Number TLV、Manufacturer Name TLV、Model Name TLV和Asset ID TLV。
location-id:表示Location Identification TLV。
civic-address:表示Location Identification TLV封装网络设备的普通地址信息。
device-type:表示设备类型,取值范围为0~2。0表示设备类型为DHCP server,1表示设备类型为Switch,2表示设备类型为LLDP-MED Endpoint。
country-code:表示国家编码,取值范围请参考ISO 3166。
{ ca-type ca-value }&<1-10>:地址信息。ca-type表示地址信息类型,取值范围为0~255;ca-value表示地址信息,为1~250个字符的字符串。&<1-10>表示前面的参数最多可以输入10次。
elin-address:Location Identification TLV封装紧急电话号码。
tel-number:表示紧急电话号码,为10~25个字符的字符串,只能包含数字。
network-policy:表示Network Policy TLV。
power-over-ethernet:表示Extended Power-via-MDI TLV。
· 在使用本命令时若不指定all参数,每次只能配置某类型下的一种可选TLV,此时可通过多次使用该命令来配置各类型下的多种可选TLV。
· 如果禁止发布802.3的组织定义的MAC/PHY Configuration/Status TLV,则LLDP-MED TLV将不会被发布,不论其是否被允许发布;如果禁止发布LLDP-MED Capabilities TLV,则其它LLDP-MED TLV将不会被发布,不论其是否被允许发布。
· IEEE 802.1组织定义的TLV的Port And Protocol VLAN ID TLV、VLAN Name TLV及Management VLAN ID TLV只能基于最近桥代理配置,但是其配置会被最近非TPMR桥代理和最近客户桥代理继承。
# 配置接口FortyGigE1/0/1上最近客户桥代理允许发布IEEE 802.1组织定义的Link Aggregation可选TLV。
[Sysname-FortyGigE1/0/1] lldp agent nearest-customer tlv-enable dot1-tlv link-aggregation
