01-基础配置命令参考
10-设备管理命令
本章节下载: 10-设备管理命令  (424.02 KB)
10-设备管理命令
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 display alarm
1.1.8 display asset-info
1.1.9 display clock
1.1.10 display copyright
1.1.11 display cpu-usage
1.1.12 display cpu-usage configuration
1.1.13 display cpu-usage history
1.1.14 display device
1.1.15 display device manuinfo
1.1.16 display device manuinfo chassis-only
1.1.17 display device manuinfo power
1.1.18 display diagnostic-information
1.1.19 display environment
1.1.20 display fan
1.1.21 display hardware-failure-detection
1.1.22 display hardware-failure-protection
1.1.23 display memory
1.1.24 display memory-threshold
1.1.25 display power
1.1.26 display scheduler job
1.1.27 display scheduler logfile
1.1.28 display scheduler reboot
1.1.29 display scheduler schedule
1.1.30 display system stable state
1.1.31 display system-working-mode
1.1.32 display transceiver alarm
1.1.33 display transceiver diagnosis
1.1.34 display transceiver interface
1.1.35 display transceiver manuinfo
1.1.36 display version
1.1.37 display version-update-record
1.1.38 display xbar
1.1.39 fabric load-sharing mode
1.1.40 forward-path-detection enable
1.1.41 hardware-failure-detection
1.1.42 hardware-failure-protection aggregation
1.1.43 hardware-failure-protection auto-down
1.1.44 header
1.1.45 job
1.1.46 memory-threshold
1.1.47 memory-threshold usage
1.1.48 monitor cpu-usage enable
1.1.49 monitor cpu-usage interval
1.1.50 monitor cpu-usage threshold
1.1.51 monitor handshake-timeout disable-port
1.1.52 password-recovery enable
1.1.53 reboot
1.1.54 reset asset-info
1.1.55 reset scheduler logfile
1.1.56 reset version-update-record
1.1.57 restore factory-default
1.1.58 scheduler job
1.1.59 scheduler logfile size
1.1.60 scheduler reboot at
1.1.61 scheduler reboot delay
1.1.62 scheduler schedule
1.1.63 set asset-info
1.1.64 shutdown-interval
1.1.65 sysname
1.1.66 system-working-mode
1.1.67 temperature-limit
1.1.68 time at
1.1.69 time once
1.1.70 time repeating
1.1.71 user-role
1.1.72 xbar
1 设备管理
1.1  设备管理配置命令
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的UTC时间为出厂时间。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
# 配置设备的系统时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 配置设备的系统时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp mdc mdc-id }
undo clock protocol
通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号,该取值只能为1。
系统时间的获取方式有:
·     配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
·     配置clock protocol ntp命令后,通过NTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用UTC时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
设配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口GigabitEthernet1/0/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface gigabitethernet 1/0/1
[Sysname-job-shutdownGE] command 3 shutdown
·     scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
1.1.7  display alarm
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number ]
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot CPU Level   Info
1    0   ERROR   faulty
表1-1 display alarm命令显示信息描述表
Slot
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上
CPU
告警CPU的编号
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息。取值为:
·     faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态)
·     Fan n is absent:风扇n当前不在位
·     Power n is absent:电源n当前不在位
·     Power n is faulty:电源n处于异常状态
·     The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限
·     The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限
display asset-info命令用来显示设备的用户资产信息。使用该命令,可以显示设备机箱、单板、风扇框或电源模块的资产信息。
(独立运行模式)
display asset-info { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
display asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } [ csn | custom | department | description | location | service-date | state ]
chassis:显示设备机箱的用户资产信息。设备不支持配置本参数。
fan fan-id:显示指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号。设备不支持配置本参数。
power power-id:显示指定电源模块的用户资产信息。power-id表示设备上电源模块的编号。设备不支持配置本参数。
slot slot-number:显示指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:显示资产编号信息。
custom:显示用户自定义的资产信息。
department:显示资产的归属部门信息。
description:显示资产的描述信息。
service-date:显示资产的启用时间信息。
state:显示资产的使用状态信息。
chassis chassis-number:显示指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
【描述】
当用户希望显示单板的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,显示的是该单板的所有用户资产信息。
使用该命令显示单板没有经过设置的具体信息项目时,该信息项目的内容显示为空。
# 显示设备上0号单板的资产编号信息(该显示信息与用户的当前配置有关)。(独立运行模式)
<Sysname> display asset-info slot 0 csn
Type        : Slot 0
csn         : 123456
# 显示设备上0号单板的资产信息(该显示信息与用户的当前配置有关)。(独立运行模式)
Type        : Slot 0
csn         : 123456
description : Slot 0
service-date:
department  :
state       : Normal
custom      : 1:789
表1-2 display asset-info命令显示信息描述表
资产类型,内容为指定的单板
csn
资产编号信息,内容为空表示用户没有进行设置
description
资产描述信息,内容为空表示用户没有进行设置
location
资产位置信息,内容为空表示用户没有进行设置
service-date
资产启用时间信息,内容为空表示用户没有进行设置
department
资产归属部门信息,内容为空表示用户没有进行设置
state
资产使用状态信息,内容为空表示用户没有进行设置
custom
用户自定义的资产信息,内容为空表示用户没有进行设置
·     reset asset-info
·     set asset-info
1.1.9  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2015
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
【缺省级别】
# 显示设备的版权信息。
<Sysname> display copyright
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number ] ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       1% in last 5 seconds
       1% in last 1 minute
       1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU        Last 5 sec        Last 1 min        Last 5 min
1    0          17%               29%               28%
表1-3 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
Last 5 sec
1% in last 1 minute
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
Last 1 min
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Last 5 min
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
# 显示CPU利用率历史信息记录功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 90%.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
(独立运行模式)
display device[ flash ]  [ slot slot-number | verbose ]
display device[ flash ]  [ chassis chassis-number [ slot slot-number ] | verbose ]
flash:显示Flash的信息。
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。(独立运行模式)
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板。不指定该参数时,表示所有单板。(IRF模式)
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不指定flash参数时,显示单板的信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
Slot No. Brd Type           Brd Status   Subslot Sft Ver                Patch Ver
 0       LSQM1CGT24TSSA8    Master       0       S7000E-7524            None
 1       NONE               Absent       0       NONE                   None
 2       LSQM2GP48SA8       Normal       0       S7000E-7524            None
表1-4 display device命令显示信息描述表(独立运行模式)
Slot No.
单板的槽位号
Brd Type
单板的硬件类型
Brd Status
单板状态:
·     Standby表示该板是备用主控板
·     Master表示该板是主用主控板
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板出错,不能正常启动
·     Normal表示该槽位单板是接口板并处于正常工作状态
Subslot
业务底板支持接口子卡的最大个数(暂不支持)
Sft Ver
当前单板上运行的软件版本
Patch Ver
当前单板上运行的热补丁版本
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。(独立运行模式)
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。(IRF模式)
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。
<Sysname> display device manuinfo
显示信息略……。
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
# 显示机框背板的电子标签信息。
<Sysname> display device manuinfo chassis-only
显示信息略……。
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。(IRF模式)
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。
<Sysname> display device manuinfo power 1
显示信息略……。
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1)     使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2)     使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3)     使用more命令查看文件XXXX的内容。
不指定filename参数执行display diagnostic-information命令时,系统会要求用户选择显示诊断信息还是将诊断信息保存到文件中。如果用户选择保存诊断信息,且当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
该命令不支持“|”、“>”和“>>”参数。
执行display diagnostic-information命令前,请使用display cpu-usage、display memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
显示信息略……。
# 将收集到的诊断信息保存到缺省文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysnme_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
·     gunzip(基础配置命令参考/文件系统管理)
·     more(基础配置命令参考/文件系统管理)
·     tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。(独立运行模式)
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。(IRF模式)
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 0     inflow  1 28           0      68       80     NA
 0     outflow 1 34           0      68       80     NA
 0     hotspot 1 44           0      88       100    NA
 2     hotspot 1 35           0      80       97     110
 2     hotspot 2 41           0      80       97     110
 4     hotspot 1 34           0      80       97     NA
表1-5 display environment命令显示信息描述表
System Temperature information (degree centigrade)
系统温度信息,单位为摄氏度
sensor
温度传感器
·     hotspot:表示热点温度传感器
·     inflow:表示入风口温度传感器
·     outflow:表示出风口温度传感器
Slot
当显示数字时表示指定slot上温度传感器的温度信息
Temperature
当前温度
Lower
低温告警门限。当显示为NA时,表示不支持该门限
Warning
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限
Alarm
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限
Shutdown
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限
1.1.20  display fan
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ fan-id ]
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number:显示指定成员设备上风扇的状态信息。chassis-number表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
 Fan Frame 0  State: Normal
表1-6 display fan命令显示信息描述表
Fan Frame
风扇框的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
·     FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致
Airflow Direction
风扇模块的实际风道方向:
·     Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后
·     Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前
Prefer Airflow Direction
用户期望的风扇模块的风道方向:
display hardware-failure-detection命令用来显示交换机的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示交换机的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
# 查看交换机的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
    chip       : isolate
    board      : isolate
    forwarding : warning
Recent record:
--------------------------Slot  0 executed records:-----------------------------
                 There is no record.
--------------------------Slot  0 trapped records:-----------------------------
                 There is no record.
表1-7 display hardware-failure-detection命令显示信息描述表
Current level
当前故障检测对应的修复操作级别
chip       :
器件类级别
board      :
单板类级别
forwarding :
转发类级别
Recent record:
最近记录
Slot  n executed records:
对应主控板n上记录的各个单板的历史操作记录(独立运行模式)
Chassis n, Slot m executed records:
对应成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式)
Slot  n trapped records:
对应主控板n上记录的各个单板的trap告警信息(独立运行模式)
Chassis n, Slot m trapped records:
对应成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式)
display hardware-failure-protection命令用来显示交换机上硬件故障保护的配置情况。
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation:显示聚合组的硬件故障保护配置情况。
port:显示端口硬件故障保护的配置情况。
auto-down:显示已配置端口硬件故障保护的端口列表。
interface-type interface-number:显示指定端口上硬件故障保护的配置情况。
如果不带参数,则显示交换机上所有硬件故障保护的配置情况,包括是否配置了针对聚合组的硬件故障保护和所有配置了端口硬件故障保护的端口列表。
# 查看交换机上所有硬件故障保护的配置情况。
<Sysname> display hardware-failure-protection
Aggregation: on
Port: GE2/0/1     GE3/0/1
# 查看配置了端口硬件故障保护的端口列表。
<Sysname> display hardware-failure-protection port auto-down
# 查看端口GE2/0/2是否配置了硬件故障保护。
<Sysname> display hardware-failure-protection port GigabitEthernet 2/0/2
Auto-down is NOT allowed while hardware-failure happened.
表1-8 display hardware-failure-protection命令显示信息描述表
Aggregation
显示是否配置了针对聚合组的硬件故障保护功能
Port:
显示配置了端口硬件故障保护的端口列表
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:        507980    154896    353084         0       488     54488       69.5%
-/+ Buffers/Cache:     99920    408060
Swap:           0         0         0
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU   Total      Used      Free      Buffers  Caches    FreeRatio
1    0     507980     154896    353084    488      54488     69.5%
表1-9 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额
Buffers
已使用的文件缓冲区的大小
Cached
高速缓冲寄存器已使用的内存大小
Caches
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ buffers/cache
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
     Minor: 64M
     Severe: 48M
     Critical: 32M
     Normal: 96M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 2015-5-15 09:21:35.546
    Latest notification: 2015-5-15 09:21:35.546
    Total number of notifications sent: 1
 [Enter minor low-memory state]
    First notification at: 2015-5-15 09:07:05.941
    Latest  notification at: 2015-5-15 09:07:05.941
 [Back to minor low-memory state]
    First notification at: 0.0
    Latest  notification at: 0.0
    Total number of notifications sent: 0
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-10 display memory-threshold命令显示信息描述表
内存利用率阈值
         Minor:
         Severe:
         Critical:
         Normal:
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Enter minor low-memory state:进入一级告警门限状态
·     Back to minor low-memory state:恢复到一级告警门限状态
·     Enter severe low-memory state:进入二级告警门限状态
·     Back to severe low-memory state:恢复到二级告警门限状态
·     Enter critical low-memory state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id ]
display power [ chassis chassis-number } [ power-id ] ]
chassis { chassis-number | virtual-chassis-number slot slot-number }:显示指定成员设备上电源的信息。chassis-number表示设备在IRF中的成员编号。不指定chassis参数时,表示所有电源。(IRF模式)
power-id:表示电源的编号。不指定该参数时,表示指定位置的所有电源。
# 显示设备电源的状况。
<Sysname> display power
 Power        1 State: Normal
 Power        2 State: Absent
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface rang gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[Sysname-if-range]shutdown
表1-11 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
表1-12 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system stable state命令用来显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/单板启动需要一定的时间,才能达到Stable状态。如果设备/单板长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
·     通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。(独立运行模式)
<Sysname> display system stable state
System state     : Stable
Redundancy state : Stable
  Slot    CPU    Role       State
  0       0      Active     Stable
  1       0      Standby    Stable
  3       0      Other      Stable
  15      0      Other      Stable
表1-13 display system stable state命令显示信息描述表
System state
系统状态:
·     Stable:稳定运行
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No redundance:系统无冗余,不能倒换
·     Not ready:未稳定,不可以倒换
Role
单板在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:业务板
单板状态:
·     Stable:单板稳定运行
·     Board inserted:单板插入
·     Kernel initiating:单板内核初始化
·     Service starting:单板上的服务正在启动
·     Service stopping:单板上的服务正在关闭
·     HA Batch backup:HA批量备份中
·     Interface data batch backup:接口管理批量备份未完成
当前对象处于未稳定状态
·     display device
·     display ha service-group(可靠性命令参考/进程分布优化)
display system-working-mode命令用来显示设备的工作模式。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-14 SFP/SFP+的display transceiver alarm命令输出信息描述表
RX loss of signal
接收信号丢失
RX power high
接收光功率高
RX power low
接收光功率低
TX fault
发送错误
TX bias high
偏置电流高
TX bias low
偏置电流低
TX power high
发送光功率高
TX power low
发送光功率低
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
表1-15 QSFP+的display transceiver alarm命令输出信息描述表
Temp high
温度高
Temp low
温度低
Voltage high
电压高
Voltage low
电压低
RX signal loss in channel x
通道x接收到的信号丢失
TX fault in channel x
通道x发送报文时出错
TX signal loss in channel x
通道x发送的信号丢失
RX power high in channel x
通道x接收到的光的功率太高
RX power low in channel x
通道x接收到的光的功率太低
TX bias high in channel x
通道x的偏置电流高
TX bias low in channel x
通道x的偏置电流低
模块读写错误
模块信息校验和错误
Transceiver type and port configuration mismatched
模块类型和端口配置不匹配
端口不支持该类型的模块
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver current alarm information:
  RX loss of signal
  RX power low
表1-16 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal
接收信号丢失
RX power low
接收光功率低告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface gigabitethernet 1/0/1
GigabitEthernet1/0/1 transceiver diagnostic information:
    Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    36        3.31        6.13      -35.64          -5.19
  Alarm thresholds:
           Temp(℃)   Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   50         3.55        1.44      -10.00         5.00
    Low    30         3.01        1.01      -30.00         0.00
表1-17 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet3/0/45上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface gigabitethernet 3/0/45
GigabitEthernet3/0/45 transceiver information:
  Transceiver Type              : 10G_BASE_SR_SFP
  Connector Type                : LC
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 80(OM2),20(OM1),300(OM3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : FINISAR CORP.
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口GigabitEthernet1/0/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface gigabitethernet 1/0/1
显示信息略……。
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
显示信息略……。
display version-update-record命令用来显示启动软件包版本更新操作的记录。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1  (updated on Apr 18 2015 at 06:23:54):
 *Name        : simware-cmw710-boot.bin
  Version     : 7.1.053 Test 0001
  Compile time: Mar 25 2015 15:52:43
 *Name        : simware-cmw710-system.bin
表1-18 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54)
最近的第n次更新的时间,Record 1为最新的一次更新
*Name
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化
Version
软件包的版本号
Compile time
版本编译时间
·     reset version-update-record
1.1.38  display xbar
display xbar命令用来显示主控板的负载模式。
(独立运行模式)
display xbar
display xbar [ chassis chassis-number ]
chassis chassis-number:用来显示指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
配置的负载模式和当前运行的负载模式不一定相同。只有主用主控板和备用主控板同时在位时,配置的负载分担模式才会生效;否则,即便配置了负载分担模式,主用主控板也会自动切换到独立负载模式。
S7003E设备不支持本命令。
# 显示设备主用主控板和备用主控板的负载模式。(独立运行模式)
<Sysname> display xbar
The configured system HA xbar load mode is BALANCE
The activated system HA xbar load mode is SINGLE
以上显示信息表明:当前系统配置的负载模式为负载分担模式,但实际生效的是独立负载模式。
·     xbar
fabric load-sharing mode命令用来配置业务板的负载分担类型。
undo fabric load-sharing mode命令用来恢复缺省情况。
(独立运行模式)
fabric load-sharing mode { { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible } slot slot-number
undo fabric load-sharing mode slot slot-number
fabric load-sharing mode { { destination-ip | destination-mac | ingress-port | source-ip | source-mac } * | flexible } chassis chassis-number slot slot-number
undo fabric load-sharing mode chassis chassis-number slot slot-number
本命令的缺省情况请参见“基础配置指导”中的“设备管理”。
destination-ip:表示按报文的目的IP地址进行负载分担。
destination-mac:表示按报文的目的MAC地址进行负载分担。
ingress-port:表示按报文的入端口进行负载分担。
source-ip:表示按报文的源IP地址进行负载分担。
source-mac:表示按报文的源MAC地址进行负载分担。
flexible:表示按报文类型(如二层、IPv4等)自动选择负载分担的类型。
slot slot-number:单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number为单板所在的槽位号。(IRF模式)
如果多次执行本命令,最后一次执行的命令生效。
# 配置指定slot按照报文目的MAC地址进行负载分担。(独立运行模式)
[Sysname] fabric load-sharing mode destination-mac slot 2
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { board | chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { board | chip | forwarding }
当系统检测到器件(chip)、单板(board)和转发(forwarding)的硬件故障时,修复操作均为warning。
board:对单板故障进行在线检测,包括控制通道检测。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动关闭端口、隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
配置该命令后,当系统检测到硬件故障时,会按顺序遵循如下原则处理:
·     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而且该端口不是聚合组中最后一个UP状态的端口,则该端口会被自动关闭;
·     如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而该端口是聚合组中最后一个UP状态的端口,则该端口不会被关闭;
·     如果聚合组成员端口配置了hardware-failure-protection auto-down命令,则不管该端口是不是聚合组中最后一个UP状态的端口,该端口都会被关闭。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
·     端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
·     端口下配置了以太网接口的强制开启功能,即port up-mode命令;
·     该端口配置为IRF物理端口。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
·     hardware-failure-detection
·     hardware-failure-protection auto-down
hardware-failure-protection auto-down命令用来开启针对端口的硬件故障保护功能。
undo hardware-failure-protection auto-down命令用来关闭针对端口的硬件故障保护功能。
端口的硬件故障保护功能处于开启状态。
以太网接口视图
配置了hardware-failure-detection forwarding isolate后,本命令才会生效。
在端口上配置该命令前,请确保该端口存在备份的链路,以免造成业务中断。
在端口上配置hardware-failure-protection auto-down命令后,当系统检测到硬件故障时,会自动关闭该端口。此时使用display interface命令可看到该端口状态为Protect DOWN。端口硬件故障解除后,请在接口下执行undo shutdown命令来恢复端口状态。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对该端口失效:
·     该端口配置为IRF物理端口。
# 对端口配置硬件故障保护。
[Sysname-GigabitEthernet1/0/1] hardware-failure-protection auto-down
1.1.44  header
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
未配置欢迎信息。
incoming:配置Modem登录用户登录进入用户视图时的欢迎信息。如果要求认证,则欢迎信息在通过认证后输出。暂不支持通过Modem登录。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置非Modem登录用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
1.1.45  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
一级告警门限为96MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为128MB。
minor minor-value:一级告警门限,单位为兆字节(MB),取值范围为0~1924。minor-value应小于等于normal-value;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB),设备会根据用户输入的一级告警门限的值自动调整本参数的取值范围;severe-value必须小于等于minor-value;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB),设备会根据用户输入的二级告警门限的值自动调整本参数的取值范围;critical-value必须小于等于severe-value;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB),设备会根据用户输入的一级告警门限的值自动调整本参数的取值范围;normal-value必须小于等于实际内存大小。
系统实时监控系统剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
(独立运行模式)
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率阈值。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage threshold cpu-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率阈值为99%。
cpu-threshold:CPU利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率阈值比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
# 配置CPU利用率阈值为80%。
[Sysname] monitor cpu-usage threshold 80
monitor handshake-timeout disable-port命令用于全局开启Port Down功能。
undo monitor handshake-timeout disable-port命令用于全局关闭Port Down功能。
缺省情况下,Port Down功能处于开启状态。
【描述】
本功能常用于以主备方式提供网络可靠性的双机环境中(例如VRRP)。开启本功能后,当主设备的主控板被拔出或异常重启时,系统将立即关闭主设备上的所有业务口,使业务快速切换到备用设备上。
该功能配置成功后,只有当当前设备上已没有可用的主控板时才生效。
# 全局开启Port Down功能。
[Sysname] monitor handshake-timeout disable-port
Set successful!
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见“基础配置指导”中的“BootWare管理配置”。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.53  reboot
reboot命令用来重启设备。
(独立运行模式)
slot slot-number:表示单板所在的槽位号。(独立运行模式)
slot slot-number:表示单板所在的槽位号。(IRF模式)
force:强制重启:
·     不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
不指定slot参数,会重启整个设备。
指定slot参数,会重启指定单板。
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
不指定chassis和slot参数,则会重启所有成员设备。
只指定chassis不指定slot参数,则会重启IRF中指定的成员设备。
同时指定chassis和slot参数,则会重启IRF中指定的单板。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
·     display system stable state
reset asset-info命令用来清除设备的用户资产信息。使用该命令,用户可以清除设备机箱、单板、风扇框或电源模块的资产信息。
(独立运行模式)
reset asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn | custom | department | description | location | service-date | state }
reset asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn | custom | department | description | location | service-date | state }
chassis:清除设备机箱的用户资产信息。设备不支持配置本参数。
fan fan-id:清除指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号。设备不支持配置本参数。
power power-id:清除指定电源模块的用户资产信息。power-id表示设备上电源模块的编号。设备不支持配置本参数。
slot slot-number:清除指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn:清除资产编号信息。
custom:清除用户自定义的资产信息。
department:清除资产的归属部门信息。
description:清除资产的描述信息。
service-date:清除资产的启用时间信息。
state:清除资产的使用状态信息。
chassis chassis-number:清除指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
【描述】
reset asset-info命令用来清除设备的用户资产信息。使用该命令,用户可以清除单板的资产信息。
当用户希望清除单板的具体信息项目(比如资产编号、资产描述信息等)时,只需要选择该信息项目对应的命令行参数;不选择具体信息项目对应的参数时,清除的是该单板的所有用户资产信息。
# 清除设备上0号单板的资产编号信息。(独立运行模式)
[Sysname] reset asset-info slot 0 csn
·     display asset-info
·     set asset-info
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
restore factory-default命令用来将设备恢复到出厂状态。
请谨慎使用该命令。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
【缺省级别】
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
该命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
·     配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2015年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule。
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
set asset-info命令用来设置设备的用户资产信息。使用该命令,用户可以根据自定义的规则为设备机箱、单板、风扇框及电源模块设置资产信息。
(独立运行模式)
set asset-info { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
set asset-info chassis chassis-number { chassis | fan fan-id | power power-id | slot slot-number } { csn csn-number | custom name value | department department | description description | location location | service-date date | state state }
chassis:设置设备机箱的用户资产信息。设备不支持配置本参数。
fan fan-id:设置指定风扇框的用户资产信息。fan-id表示设备上风扇框的编号。设备不支持配置本参数。
power power-id:设置指定电源模块的用户资产信息。power-id表示设备上电源模块的编号。设备不支持配置本参数。
slot slot-number:设置指定单板的用户资产信息。slot-number表示设备上单板所在的槽位号。
csn csn-number:设置资产编号信息。csn-number表示用户设置的资产编号信息,为1~64字节的字符串。
custom name value:设置用户自定义的资产信息。name表示用户自定义的资产信息名称,value表示用户设置的资产信息内容。
department department:设置资产的归属部门信息。department表示用户设置的资产归属部门,为1~64字节的字符串。
description description:设置资产的描述信息。description表示用户设置的资产描述信息,为1~64字节的字符串。
location location:设置资产的位置信息。location表示用户设置的资产位置信息,为1~64字节的字符串。
service-date date:设置资产的启用时间信息。date表示用户设置的资产启用时间,为1~25字节的字符串。
state state:设置资产的使用状态信息。state表示用户设置的资产使用状态,为1~64字节的字符串。
chassis chassis-number:设置指定成员设备的用户资产信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
# 设置设备上0号单板的资产编号为123456。(独立运行模式)
[Sysname] set asset-info slot 0 csn 123456
·     reset asset-info
·     display device manuinfo fan
·     display device manuinfo power
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
·     若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
·     若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
1.1.65  sysname
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | standard }
设备工作在标准模式。
advance:将设备的工作模式配置为高级模式。
standard:将设备的工作模式配置为标准模式。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,详细描述请参见“基础配置指导”中的“设备管理”。
要使修改的工作模式生效,必须重启设备。
# 将设备工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
System working mode changed. For the change to take effect, save the running configuration and reboot the device.
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number{ hotspot | inflow | outflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同单板的温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。(独立运行模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,每一个数字对应一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度,必须大于低温告警门限。设备会根据用户输入的低温告警门限值自动调整本参数的取值范围。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。设备会根据用户输入的一般级高温告警门限值自动调整本参数的取值范围。
·     不同单板支持的温度传感器类型不同,请通过display environment命令查看单板支持的温度传感器类型。
·     不同单板的温度传感器编号和温度告警门限取值范围不同,输入温度传感器编号或温度告警门限值时请通过<?>查看设备提示信息,以获取温度传感器编号或温度告警门限的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,Warning级高温门限为50摄氏度,Alarm级高温门限为60摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
·     display environment
1.1.68  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
1.1.69  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
·     display transceiver manuinfo
1.1.71  user-role
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
# 配置执行定时任务test时使用的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
·     command
1.1.72  xbar
xbar命令用来配置主控板的负载模式。
(独立运行模式)
xbar { load-balance | load-single }
xbar chassis chassis-number { load-balance | load-single }
主控板的负载模式为load-balance。
chassis chassis-number:用来配置指定成员设备上主用主控板和备用主控板的负载模式。chassis-number表示设备在IRF中的成员编号。(IRF模式)
load-balance:设备的主用主控板和备用主控板共同参与报文的处理和转发。
load-single:只有主用主控板能处理和转发报文,备用主控板仅备份主用主控板的数据、监控主用主控板的状态。
当设备上只有一块主控板时,只支持load-single模式,即便配置了load-balance模式,主控板也会自动切换到load-single模式。
S7003E设备不支持本命令。
# 配置主用主控板和备用主控板的负载模式为load-balance。(独立运行模式)
[Sysname] xbar load-balance
·     display xbar
