08-安全命令参考
01-AAA命令
本章节下载 01-AAA命令  (530.86 KB)
01-AAA命令
1 AAA配置命令
1.1 AAA配置命令
1.1.1 aaa nas-id profile
1.1.2 access-limit enable
1.1.3 accounting command
1.1.4 accounting default
1.1.5 accounting lan-access
1.1.6 accounting login
1.1.7 accounting optional
1.1.8 accounting portal
1.1.9 authentication default
1.1.10 authentication lan-access
1.1.11 authentication login
1.1.12 authentication portal
1.1.13 authentication super
1.1.14 authorization command
1.1.15 authorization default
1.1.16 authorization lan-access
1.1.17 authorization login
1.1.18 authorization portal
1.1.19 authorization-attribute user-profile
1.1.20 cut connection
1.1.21 display connection
1.1.22 display domain
1.1.23 domain
1.1.24 domain default enable
1.1.25 dscp(ISP domain view)
1.1.26 idle-cut enable
1.1.27 nas-id bind vlan
1.1.28 nas device-id
1.1.29 self-service-url enable
1.1.30 state(ISP domain view)
1.2 本地用户配置命令
1.2.1 access-limit
1.2.2 authorization-attribute(Local user view/user group view)
1.2.3 bind-attribute
1.2.4 display local-user
1.2.5 display user-group
1.2.6 expiration-date(Local user view)
1.2.7 group
1.2.8 group-attribute allow-guest
1.2.9 local-user
1.2.10 password
1.2.11 service-type
1.2.12 state(Local user view)
1.2.13 user-group
1.2.14 validity-date(Local user view)
1.3 RADIUS配置命令
1.3.1 accounting-on enable
1.3.2 attribute 25 car
1.3.3 data-flow-format (RADIUS scheme view)
1.3.4 display radius scheme
1.3.5 display radius statistics
1.3.6 display stop-accounting-buffer (for RADIUS)
1.3.7 key (RADIUS scheme view)
1.3.8 nas-backup-ip
1.3.9 nas-ip (RADIUS scheme view)
1.3.10 primary accounting (RADIUS scheme view)
1.3.11 primary authentication (RADIUS scheme view)
1.3.12 radius client
1.3.13 radius dscp
1.3.14 radius ipv6 dscp
1.3.15 radius nas-backup-ip
1.3.16 radius nas-ip
1.3.17 radius scheme
1.3.18 radius trap
1.3.19 reset radius statistics
1.3.20 reset stop-accounting-buffer (for RADIUS)
1.3.21 retry
1.3.22 retry realtime-accounting
1.3.23 retry stop-accounting (RADIUS scheme view)
1.3.24 secondary accounting (RADIUS scheme view)
1.3.25 secondary authentication (RADIUS scheme view)
1.3.26 security-policy-server
1.3.27 server-type
1.3.28 state primary
1.3.29 state secondary
1.3.30 stop-accounting-buffer enable (RADIUS scheme view)
1.3.31 timer quiet (RADIUS scheme view)
1.3.32 timer realtime-accounting (RADIUS scheme view)
1.3.33 timer response-timeout (RADIUS scheme view)
1.3.34 user-name-format (RADIUS scheme view)
1.3.35 vpn-instance (RADIUS scheme view)
1.4 HWTACACS配置命令
1.4.1 data-flow-format (HWTACACS scheme view)
1.4.2 display hwtacacs
1.4.3 display stop-accounting-buffer (for HWTACACS)
1.4.4 hwtacacs nas-ip
1.4.5 hwtacacs scheme
1.4.6 key (HWTACACS scheme view)
1.4.7 nas-ip (HWTACACS scheme view)
1.4.8 primary accounting (HWTACACS scheme view)
1.4.9 primary authentication (HWTACACS scheme view)
1.4.10 primary authorization
1.4.11 reset hwtacacs statistics
1.4.12 reset stop-accounting-buffer (for HWTACACS)
1.4.13 retry stop-accounting (HWTACACS scheme view)
1.4.14 secondary accounting (HWTACACS scheme view)
1.4.15 secondary authentication (HWTACACS scheme view)
1.4.16 secondary authorization
1.4.17 stop-accounting-buffer enable (HWTACACS scheme view)
1.4.18 timer quiet (HWTACACS scheme view)
1.4.19 timer realtime-accounting (HWTACACS scheme view)
1.4.20 timer response-timeout (HWTACACS scheme view)
1.4.21 user-name-format (HWTACACS scheme view)
1.4.22 vpn-instance (HWTACACS scheme view)
1.5 RADIUS服务器配置命令
1.5.1 authorization-attribute(RADIUS-server user view)
1.5.2 description (RADIUS-server user view)
1.5.3 expiration-date (RADIUS-server user view)
1.5.4 password (RADIUS-server user view)
1.5.5 radius-server client-ip
1.5.6 radius-server user
1 AAA配置命令
设备运行于FIPS模式时,本特性的部分配置命令相对于非FIPS模式有所变化,具体差异请见本文相关描述。有关FIPS模式的详细介绍请参见“安全配置指导”中的“FIPS”。
1.1  AAA配置命令
undo aaa nas-id profile profile-name
【缺省级别】
2:系统级
profile-name:Profile名称,为1~16个字符的字符串,不区分大小写。该Profile用于保存NAS-ID与VLAN的绑定关系。
【描述】
aaa nas-id profile命令用来创建NAS-ID Profile并进入NAS-ID-Profile视图。undo aaa nas-id profile命令用来删除一个指定的NAS-ID Profile。
相关配置可参考命令nas-id bind vlan
# 创建一个名字为aaa的NAS-ID Profile。
[Sysname] aaa nas-id profile aaa
[Sysname-nas-id-prof-aaa]
access-limit enable max-user-number
undo access-limit enable
ISP域视图
【缺省级别】
2:系统级
max-user-number:表示当前ISP域可容纳接入用户数的最大值,取值范围为1~2147483646。
【描述】
access-limit enable命令用来限制当前ISP域可容纳接入用户数。当接入此域的用户数超过当前ISP域可容纳的最大用户数后,新接入的用户将被拒绝。undo access-limit enable命令用来恢复缺省情况。
缺省情况下,不限制当前ISP域可容纳的接入用户数。
需要注意的是,由于系统资源有限,如果当前ISP域下接入的用户过多,接入用户之间会发生资源的争用,因此适当地配置该值可以使属于当前ISP域的用户获得可靠的性能保障。
相关配置可参考命令display domain
# 指定ISP域test最多可容纳500个接入用户。
[Sysname] domain test
[Sysname-isp-test] access-limit enable 500
accounting command hwtacacs-scheme hwtacacs-scheme-name
undo accounting command
ISP域视图
【缺省级别】
2:系统级
hwtacacs-scheme hwtacacs-scheme-name:指定HWTACACS方案。其中,hwtacacs-scheme-name表示HWTACACS方案名,为1~32个字符的字符串,不区分大小写。
【描述】
accounting command命令用来配置命令行计费方法。undo accounting command命令用来恢复缺省情况。
缺省情况下,命令行计费采用当前ISP域的缺省计费方法。
·     当前ISP域所引用的HWTACACS方案必须是已配置的。
·     命令行计费支持的远程AAA方案目前仅为HWTACACS方案。
相关配置可参考命令accounting defaulthwtacacs scheme
# 在ISP域test下,配置使用HWTACACS计费方案hwtac进行命令行计费。
[Sysname-isp-test] accounting command hwtacacs-scheme hwtac
accounting default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting default
ISP域视图
【缺省级别】
2:系统级
local:本地计费。
none:不计费。
radius-scheme radius-scheme-name:指定RADIUS方案。其中,radius-scheme-name表示RADIUS方案名,为1~32个字符的字符串,不区分大小写。
【描述】
accounting default命令用来为当前ISP域配置缺省的计费方法。undo accounting default命令用来恢复缺省情况。
缺省情况下,当前ISP域的缺省计费方法为local
·     当前ISP域所引用的RADIUS或HWTACACS方案必须是已配置的。
·     当前ISP域的缺省计费方法对于该域中未指定具体计费方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的计费方法,则该计费方法对于这类用户不能生效。
·     本地计费只是为了支持本地用户的连接数管理,没有实际的计费相关的统计功能。
相关配置可参考命令local-userhwtacacs schemeradius scheme
# 在ISP域test下,配置缺省计费方法为使用RADIUS方案rd进行计费,并且使用local作为备份计费方法。
[Sysname-isp-test] accounting default radius-scheme rd local
accounting lan-access { local | none | radius-scheme radius-scheme-name [ local | none] }
undo accounting lan-access
ISP域视图
【缺省级别】
2:系统级
local:本地计费。
none:不计费。
【描述】
accounting lan-access命令用来为lan-access用户配置计费方法。undo accounting lan-access命令用来恢复缺省情况。
缺省情况下,lan-access用户采用当前ISP域的缺省计费方法。
需要注意的是,当前ISP域所引用的RADIUS方案必须是已配置的。
相关配置可参考命令local-useraccounting defaultradius scheme
# 在ISP域test下,为lan-access用户配置计费方法为local
[Sysname-isp-test] accounting lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行计费,并且使用local作为备份计费方法。
[Sysname-isp-test] accounting lan-access radius-scheme rd local
accounting login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting login
ISP域视图
【缺省级别】
2:系统级
local:本地计费。
none:不计费。
【描述】
accounting login命令用来为login用户配置计费方法。undo accounting login命令用来恢复缺省情况。
缺省情况下,login用户采用当前ISP域的缺省计费方法。
·     FTP类型的login用户不支持计费流程。
相关配置可参考命令local-useraccounting defaulthwtacacs schemeradius scheme
# 在ISP域test下,为login用户配置计费方法为local
[Sysname-isp-test] accounting login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行计费,并且使用local作为备份计费方法。
[Sysname-isp-test] accounting login radius-scheme rd local
accounting optional
undo accounting optional
ISP域视图
【缺省级别】
2:系统级
【描述】
accounting optional命令用来打开计费可选开关。undo accounting optional命令用来关闭计费可选开关。
缺省情况下,计费可选开关处于关闭状态。
·     对上线用户计费时,如果发现没有可用的计费服务器或与计费服务器通信失败时,若配置了本命令,则用户可以继续使用网络资源,且系统不再为其发送实时计费更新报文,否则用户连接将被切断。该命令适用于不是特别关心计费结果的情况下。
·     计费可选开关打开的情况下,本地用户视图下的access-limit命令配置的本地用户的连接数限制功能不生效。
# 打开ISP域test的计费可选开关。
[Sysname-isp-test] accounting optional
accounting portal { local | none | radius-scheme radius-scheme-name [ local ] }
undo accounting portal
ISP域视图
【缺省级别】
2:系统级
local:本地计费。
none:不计费。
【描述】
accounting portal命令用来为Portal用户配置计费方法。undo accounting portal命令用来恢复缺省情况。
缺省情况下,Portal用户采用当前ISP域的缺省计费方法。
# 在ISP域test下,为Portal用户配置计费方法为local
[Sysname-isp-test] accounting portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行计费,并且使用local作为备份计费方法。
[Sysname-isp-test] accounting portal radius-scheme rd local
authentication default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authentication default
ISP域视图
【缺省级别】
2:系统级
local:本地认证。
none:不进行认证。
【描述】
authentication default命令用来为当前ISP域配置缺省的认证方法。undo authentication default命令用来为恢复缺省情况。
缺省情况下,当前ISP域的缺省认证方法为local
·     当前ISP域所引用的RADIUS、HWTACACS方案必须是已配置的。
·     当前ISP域的缺省的认证方法对于该域中未指定具体认证方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的认证方法,则该认证方法对于这类用户不能生效。
# 在ISP域test下,配置缺省认证方法为使用RADIUS方案rd进行认证,并且使用local作为备份认证方法。
[Sysname-isp-test] authentication default radius-scheme rd local
authentication lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
undo authentication lan-access
ISP域视图
【缺省级别】
2:系统级
local:本地认证。
none:不进行认证。
【描述】
authentication lan-access命令用来为lan-access用户配置认证方法。undo authentication lan-access命令用来恢复缺省情况。
缺省情况下,lan-access用户采用当前ISP域的缺省认证方法。
相关配置可参考命令local-userauthentication defaultradius scheme
# 在ISP域test下,为lan-access用户配置认证方法为local
[Sysname-isp-test] authentication lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行认证,并且local作为备份认证方法。
[Sysname-isp-test] authentication lan-access radius-scheme rd local
authentication login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authentication login
ISP域视图
【缺省级别】
2:系统级
local:本地认证。
none:不进行认证。
【描述】
authentication login命令用来为login用户配置认证方法。undo authentication login命令用来恢复缺省情况。
缺省情况下,login用户采用当前ISP域的缺省认证方法。
需要注意的是,当前ISP域所引用的RADIUS、HWTACACS方案必须是已配置的。
相关配置可参考命令local-userauthentication defaulthwtacacs schemeradius scheme
# 在ISP域test下,为login用户配置认证方法为local
[Sysname-isp-test] authentication login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行认证,并且使用local作为备份认证方法。
[Sysname-isp-test] authentication login radius-scheme rd local
authentication portal { local | none | radius-scheme radius-scheme-name [ local ] }
undo authentication portal
ISP域视图
【缺省级别】
2:系统级
local:本地认证。
none:不进行认证。
【描述】
authentication portal命令用来为Portal用户配置认证方法。undo authentication portal命令用来恢复缺省情况。
缺省情况下,Portal用户采用当前ISP域的缺省认证方法。
# 在ISP域test下,为Portal用户配置认证方法为local
[Sysname-isp-test] authentication portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行认证,并且local作为备份认证方法。
[Sysname-isp-test] authentication portal radius-scheme rd local
authentication super { hwtacacs-scheme hwtacacs-scheme-name | radius-scheme radius-scheme-name }
undo authentication super
ISP域视图
【缺省级别】
2:系统级
【描述】
authentication super命令用来配置级别切换认证方法。undo authentication super命令用来恢复缺省情况。
缺省情况下,级别切换认证采用当前ISP域的缺省认证方法。
需要注意的是,当前ISP域所引用的RADIUS方案和HWTACACS方案必须是已配置的。
相关配置可参考命令hwtacacs schemeradius scheme和“基础命令参考/CLI”中的命令super authentication-mode
# 在ISP域test下,配置使用HWTACACS方案tac进行级别切换认证。
[Sysname] super authentication-mode scheme
[Sysname-domain-test] authentication super hwtacacs-scheme tac
authorization command { hwtacacs-scheme hwtacacs-scheme-name [ local | none ] | local | none }
undo authorization command
ISP域视图
【缺省级别】
2:系统级
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的用户只有系统所给予的0级别的命令行访问权限。
【描述】
authorization command命令用来配置命令行授权方法。undo authorization command命令用来恢复缺省情况。
缺省情况下,命令行授权采用当前ISP域的缺省授权方法。
·     对用户采用本地命令行授权时,成功登录设备的用户只能执行不大于本地用户级别的命令行。
相关配置可参考命令local-userauthorization defaulthwtacacs scheme
# 在ISP域test下,配置命令行授权方法为local
[Sysname-isp-test] authorization command local
# 在ISP域test下,配置使用HWTACACS方案hwtac进行命令行授权,并且使用local作为备份授权方法。
[Sysname-isp-test] authorization command hwtacacs-scheme hwtac local
authorization default { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization default
ISP域视图
【缺省级别】
2:系统级
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP访问设备的用户)只有系统所给予的0级别的命令行访问权限,其中FTP用户可访问设备的根目录;认证通过的非Login用户可直接访问网络。
【描述】
authorization default命令用来为当前ISP域配置缺省的授权方法。undo authorization default命令用来恢复缺省情况。
缺省情况下,当前ISP域的缺省授权方法为local
·     当前ISP域的缺省的授权方法对于该域中未指定具体授权方法的所有接入用户都起作用,但是如果某类型的用户不支持指定的授权方法,则该授权方法对于这类用户不能生效。
·     在一个ISP域中,只有配置的认证和授权方法中引用了相同的RADIUS方案时,RADIUS授权过程才能生效。
# 在ISP域test下,配置缺省授权方法为使用RADIUS方案rd进行授权,并且使用local作为备份授权方法。
[Sysname-isp-test] authorization default radius-scheme rd local
authorization lan-access { local | none | radius-scheme radius-scheme-name [ local | none ] }
undo authorization lan-access
ISP域视图
【缺省级别】
2:系统级
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的lan-access用户可直接访问网络。
【描述】
authorization lan-access命令用来为lan-access用户配置授权方法。undo authorization lan-access命令用来为恢复缺省情况。
缺省情况下,lan-access用户采用当前ISP域的缺省授权方法。
·     当前ISP域所引用的RADIUS方案必须是已配置的。
相关配置可参考命令local-userauthorization defaultradius scheme
# 在ISP域test下,为lan-access用户配置授权方法为local
[Sysname-isp-test] authorization lan-access local
# 在ISP域test下,配置lan-access用户使用RADIUS方案rd进行授权,并且使用local作为备份授权方法。
[Sysname-isp-test] authorization lan-access radius-scheme rd local
authorization login { hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization login
ISP域视图
【缺省级别】
2:系统级
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权。此时,认证通过的Login用户(通过Console口或者Telnet、FTP访问设备的用户)只有系统所给予的0级别的命令行访问权限,其中FTP用户可访问设备的根目录。
【描述】
authorization login命令用来为login用户配置授权方法。undo authorization login命令用来恢复缺省情况。
缺省情况下,login用户采用当前ISP域的缺省授权方法。
相关配置可参考命令local-userauthorization defaulthwtacacs schemeradius scheme
# 在ISP域test下,为login用户配置授权方法为local
[Sysname-isp-test] authorization login local
# 在ISP域test下,配置login用户使用RADIUS方案rd进行授权,并且使用local作为备份授权方法。
[Sysname-isp-test] authorization login radius-scheme rd local
authorization portal { local | none | radius-scheme radius-scheme-name [ local ] }
undo authorization portal
ISP域视图
【缺省级别】
2:系统级
local:本地授权。
none:不授权。接入设备不请求授权信息,不对用户可以使用的操作以及用户允许使用的网络服务进行授权,认证通过的Portal用户可直接访问网络。
【描述】
authorization portal命令用来为Portal用户配置授权方法。undo authorization portal命令用来恢复缺省情况。
缺省情况下,Portal用户采用当前ISP域的缺省授权方法。
# 在ISP域test下,为Portal用户配置授权方法为local
[Sysname-isp-test] authorization portal local
# 在ISP域test下,配置Portal用户使用RADIUS方案rd进行授权,并且使用local作为备份授权方法。
[Sysname-isp-test] authorization portal radius-scheme rd local
authorization-attribute user-profile profile-name
undo authorization-attribute user-profile
ISP域视图
【缺省级别】
3:管理级
profile-name:指定的User Profile名称,为1~31个字符的字符串,区分大小写。User Profile的相关配置请参考“安全配置指导”中的“User Profile”。
【描述】
authorization-attribute user-profile命令用于配置当前ISP域的缺省授权User Porfile。undo authorization-attribute user-profile命令用于恢复缺省情况。
缺省情况下,当前ISP域无缺省授权User Porfile。
如果当前ISP域的用户认证成功,但认证服务器(包括本地认证下的接入设备)未对该ISP域下发授权User Porfile,则系统使用本配置指定的User Porfile作为当前ISP域的授权User Porfile。
需要注意的是,重复配置本命令,会覆盖原有的配置。
# 配置test域下的缺省授权User Profile为profile1。
[Sysname-isp-test] authorization-attribute user-profile profile1
cut connection { access-type { dot1x | mac-authentication | portal } | all | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id } [ slot slot-number ]
【缺省级别】
2:系统级
access-type:指定接入方式。
·     dot1x:表示802.1X认证接入方式;
·     mac-authentication:表示MAC地址认证接入方式;
·     portal:表示Portal认证接入方式。
all:指定所有用户连接。
domain isp-name:指定ISP域。其中,isp-name为ISP域名,为1~24个字符的字符串。
interface interface-type interface-number:指定接口。其中,interface-type interface-number为接口类型和接口编号。目前只支持二层以太网端口。
ip ip-address:指定IP地址。
mac mac-address:指定MAC地址。其中,mac-address为H-H-H格式。
ucibindex ucib-index:指定连接索引号,取值范围为0~4294967295。
user-name user-name:指定用户名。其中,user-name表示用户名,为1~80个字符的字符串,区分大小写。若用户输入的用户名未携带域名,则系统默认其带缺省域名或强制认证域名。
vlan vlan-id:指定用户所在VLAN。其中,vlan-id的取值范围为1~4094。
slot slot-number:指定成员设备,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
cut connection命令用来强制切断指定AAA用户的连接。
此命令目前只对lan-access、Portal服务类型的用户有效。
·     如果客户端配置的用户名携带版本号或者用户名中存在空格,则无法通过用户名来检索和切断用户连接,但是通过其他方式(如IP地址、连接索引号等)仍然可以检索和切断用户的连接。
·     如果接入用户的接口上配置了指定接入类型的强制认证域(例如802.1X强制认证域),则通过该接口上线的指定接入类型的用户将使用强制认证域进行认证、授权和计费,因此若要通过cut connection domain isp-name命令切断该类用户连接,则必须指定用户使用的强制认证域名。
·     对于使用域名分隔符\或者/的802.1X在线用户,不能通过cut connection user-name user-name命令切断其连接。例如,执行命令cut connection user-name aaa\bbb后,不能切断在线用户aaa\bbb的连接。
相关配置可参考命令display connectionservice-type
# 切断ISP域test下的所有用户连接。
[Sysname] cut connection domain test
display connection [ access-type { dot1x | mac-authentication | portal } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | ucibindex ucib-index | user-name user-name | vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
access-type:显示指定接入方式的用户连接。
domain isp-name:显示指定ISP域中的用户连接。其中,isp-name表示ISP域名,为1~24个字符的字符串,不区分大小写。
interface interface-type interface-number:显示指定接口的用户连接。其中,interface-type interface-number为接口类型和接口编号。目前只支持二层以太网端口。
ip ip-address:显示指定IP地址的用户连接。
mac mac-address:显示指定MAC地址的用户连接。其中,mac-address为H-H-H格式。
ucibindex ucib-index:显示指定连接索引的用户连接。其中,ucib-index表示连接索引号,取值范围为0~4294967295。
user-name user-name:显示指定用户名的用户连接。其中,user-name表示用户名,为1~80个字符的字符串,区分大小写。若用户输入的用户名未携带域名,则系统默认其带缺省域名或强制认证域名。
vlan vlan-id:显示指定VLAN的用户连接。其中,vlan-id的取值范围为1~4094。
slot slot-number:显示指定成员设备上的用户连接,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display connection命令用来显示所有或指定的AAA用户连接的相关信息。
·     不指定任何参数的情况下,系统显示所有AAA用户连接的概要信息。
·     指定参数ucibindex的情况下,显示详细的用户连接信息,指定其它参数则显示概要信息。
·     对于FTP类型用户,无法显示AAA用户连接的相关信息。
·     如果接入用户的接口上配置了强制认证域(例如802.1X强制认证域),则通过该接口上线的用户将使用强制认证域进行认证、授权和计费。通过本命令查看到的用户名形式与用户输入的用户名是否携带域名有关,如果用户输入的用户名未携带域名分隔符,则设备默认以“用户输入的用户名@强制认证域名”的形式显示用户名,因此若要通过display connection domain isp-name命令显示该类用户信息,则必须指定用户使用的强制认证域名;如果用户输入的用户名中已经包含了域名分隔符,则系统仅显示用户输入的用户名,而不携带强制认证域名。例如,用户输入的用户名为aaa@123,上线时使用的强制认证域为dom,则设备上显示出的用户名为aaa@123,而不是aaa@123@dom。
·     对于使用域名分隔符\或者/的802.1X在线用户,不能通过display connection user-name user-name命令查看到其相关信息。例如,执行命令display connection user-name aaa\bbb后,不能查询到在线用户aaa\bbb的相关信息。
相关配置可参考命令cut connection
# 显示所有AAA用户连接的相关信息。
<Sysname> display connection
Slot:  1
Index=0   , Username=telnet@system
IP=10.0.0.1
IPv6=N/A
 Total 1 connection(s) matched on slot 1.
 Total 1 connection(s) matched.
# 显示连接索引为0的AAA用户连接的详细信息。
<Sysname> display connection ucibindex 0
Slot:  1
IP=10.0.0.1
IPv6=N/A
Access=Admin   ,AuthMethod=PAP
Port Type=Virtual ,Port Name=N/A
Initial VLAN=999, Authorization VLAN=20
ACL Group=Disable
User Profile=N/A
CAR=Disable
Priority=Disable
Start=2011-01-16 10:53:03 ,Current=2011-01-16 10:57:06 ,Online=00h04m03s
 Total 1 connection matched.
Slot:  2
 Total 0 connection matched.
表1-1 display connection命令显示信息描述表
Slot
用户连接所在的成员设备编号
Index
用户连接的索引号
Username
当前连接的用户名,格式为username@domain
MAC
该用户的MAC地址
IP
该用户IPv4地址
IPv6
该用户IPv6地址
Access
用户接入类型
AuthMethod
认证方法
Port Type
用户接入的端口类型
Port Name
用户接入的端口名称
Initial VLAN
用户所在的初始VLAN
Authorization VLAN
授权untagged VLAN
Authorization Tagged VLAN list
授权tagged VLAN列表
ACL Group
授权ACL组
User Profile
授权User Profile
CAR(kbps)
授权CAR参数信息
UpPeakRate
上行峰值速率
DnPeakRate
下行峰值速率
UpAverageRate
上行平均速率
DnAverageRate
下行平均速率
Priority
用户报文的处理优先级
Start=xxx ,Current=xxx ,Online=xxx
用户上线的时间,当前的系统时间,用户在线时长
总计1个AAA用户连接
display domain [ isp-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
isp-name:指定ISP域名,为1~24个字符的字符串。
【描述】
display domain命令用来显示指定ISP域的配置信息。
如果不指定ISP域,则显示系统中所有ISP域的配置信息。
相关配置可参考命令access-limit enabledomainstate
# 显示系统中所有ISP域的配置信息。
<Sysname> display domain
0  Domain : system
   State :  Active
   Access-limit :  Disabled
   Accounting method : Required
   Default authentication scheme      : local
   Default authorization scheme       : local
   Default accounting scheme          : local
   DSCP :  63
   Domain User Template:
   Idle-cut : Disabled
   Self-service : Disabled
   Authorization attributes :
1  Domain : test
   State : Active
   DSCP :  63
   Lan-access authentication scheme   : radius:test, local
   Lan-access authorization scheme    : hwtacacs:hw, local
   Lan-access accounting scheme       : local
   Idle-cut : Disabled
    User-profile : profile1
Default Domain Name: system
Total 2 domain(s).
表1-2 display domain命令显示信息描述表
Domain
ISP域名
ISP域的当前状态
·     Active:激活状态,表示系统允许该域下的用户请求网络服务
·     Block:阻塞状态,表示系统不允许该域下的用户请求网络服务
Access-limit
ISP所能容纳的最大接入用户数(若显示为Disabled,则表示不限制当前ISP域可容纳接入用户数)
Accounting method
计费方法是否可选
·     Required:必选,表示如果发现没有可用的计费服务器或与计费服务器通信失败时,将切断用户连接
·     Optional:可选,表示如果发现没有可用的计费服务器或与计费服务器通信失败时,用户可以继续使用网络资源
缺省的认证方法
缺省的授权方法
缺省的计费方法
DSCP
该ISP域用户IP报文的DSCP优先级
lan-access用户的认证方法
lan-access用户的授权方法
lan-access用户的计费方法
ISP域的用户模板,定义了与域用户相关的一些功能
Idle-cut
ISP域的用户闲置切断功能
·     Disabled:未使能,表示不对用户进行限制切断控制
·     Enabled:使能,表示当域中的用户在指定的最大空闲时间内的产生的流量小于指定的最小数据流量时,会被强制下线
Self-service
自助服务定位功能
·     Disabled:自助服务定位功能处于未使能状态
·     Self-service URL:用户可以通过浏览器访问该URL指定的服务器页面,并进行相应的操作
ISP域的缺省授权属性
User-profile
缺省授权User Profile名称
Default Domain Name
缺省ISP域名
Total 2 domain(s).
总计2个ISP域
1.1.23  domain
domain isp-name
undo domain isp-name
【缺省级别】
3:管理级
isp-name:ISP域名,为1~24个字符的字符串,不区分大小写,不能包括“/”、“\”、“:”、“*”、“?”、“<”、“>”、“””、“|”以及“@”字符。
【描述】
domain命令用来创建ISP域并进入其视图。undo domain命令用来删除指定的ISP域。
缺省情况下,系统存在一个名称为system的ISP域。
·     所有的ISP域在创建后即处于active状态。
·     不能删除系统中预定义的ISP域system,只能修改该域的配置。
·     不能删除系统缺省的ISP域,除非先恢复要删除的域为非缺省域,系统缺省的ISP域的配置请参考domain default enable命令。
相关配置可参考命令statedisplay domain
# 创建一个新的ISP域test,并进入其视图。
[Sysname-isp-test]
domain default enable isp-name
undo domain default enable
【缺省级别】
3:管理级
isp-name:ISP域名,为1~24个字符的字符串,不区分大小写。
【描述】
domain default enable命令用来配置系统缺省的ISP域,所有在登录时没有提供ISP域名的用户都属于这个域。undo domain default enable命令用来恢复缺省情况。
缺省情况下,系统缺省的ISP域为system。
·     缺省的ISP域有且只有一个。
·     指定的缺省ISP域要必须存在,否则会导致用户名中未携带域名的用户无法进行认证。
·     配置为缺省的ISP域不能被删除,除非先恢复要删除的域为非缺省域。
相关配置可参考命令domainstatedisplay domain
# 创建一个新的ISP域test,并设置为系统缺省的ISP域。
[Sysname-isp-test] quit
[Sysname] domain default enable test
dscp dscp-value
undo dscp
ISP域视图
【缺省级别】
2:系统级
dscp-value:指定协议报文优先级,取值范围为0~63。
【描述】
dscp命令用来配置ISP域的DSCP优先级,该ISP域用户通过认证后,IP报文会设置为指定的DSCP优先级。undo dscp命令用来恢复缺省情况。
缺省情况下,未配置ISP域的DSCP优先级,认证通过后用户IP报文的DSCP优先级不改变。
# 配置ISP域aaa的DSCP优先级为6。
[Sysname] domain aaa
[Sysname -isp-aaa] dscp 6
idle-cut enable minute [ flow ]
undo idle-cut enable
ISP域视图
【缺省级别】
2:系统级
minute:指定闲置检测时间,取值范围为1~600,单位为分钟。
flow:指定用户在闲置检测时间内产生的数据流量,取值范围为1~10240000,单位为字节,缺省值为10240。
【描述】
idle-cut enable命令用来设置当前ISP域下的用户闲置切断功能。用户上线后,设备会周期性检测用户的流量,若域内某用户在指定的闲置检测时间内产生的流量小于本命令中指定的数据流量,则会被强制下线。undo idle-cut enable命令用来恢复缺省情况。
缺省情况下,用户闲置切断功能处于关闭状态。
需要注意的是,服务器上也可以配置最大空闲时间实现对用户的闲置切断功能,具体为当用户在指定的闲置检测时间内产生的流量小于10240个字节时,会被强制下线。但是,只有在设备上的闲置切断功能处于关闭状态时,服务器才会根据自身的配置来控制用户的闲置切断。
# 允许ISP域test中的用户启用闲置切断功能,闲置检测时间为50分钟,允许用户闲置时的最小数据流量为1024个字节。
[Sysname-isp-test] idle-cut enable 50 1024
nas-id nas-identifier bind vlan vlan-id
undo nas-id nas-identifier bind vlan vlan-id
NAS-ID Profile视图
【缺省级别】
2:系统级
nas-identifier:NAS-ID名称,为1~20个字符的字符串,区分大小写。
vlan-id:与NAS-ID绑定的VLAN ID,取值范围为1~4094。
【描述】
nas-id bind vlan命令用来设置NAS-ID与VLAN的绑定关系,即把一个NAS-ID指定给一个VLAN。undo nas-id bind vlan命令用来删除一个指定的NAS-ID和VLAN的绑定关系。
缺省情况下,未设置任何绑定关系。
·     一个NAS-ID Profile视图下,可以指定多个NAS-ID与VLAN的绑定关系。
·     一个NAS-ID可以与多个VLAN绑定,但是一个VLAN只能与一个NAS-ID绑定。若多次将一个VLAN与不同的NAS-ID进行绑定,则最后的绑定关系生效。
相关配置可参考命令aaa nas-id profile
# 把NAS-ID 222指定给VLAN 2。
[Sysname-nas-id-prof-aaa] nas-id 222 bind vlan 2
nas device-id device-id
undo nas device-id
【缺省级别】
2:系统级
device-id:表示设备ID,取值为1或2。
【描述】
nas device-id命令用于配置双机热备模式下的设备ID。双机热备组网环境下的两台设备的设备ID分别为1和2。undo nas device-id命令用于恢复缺省情况。
缺省情况下,设备工作在单机模式,无设备ID。
·     改变设备ID后,设备上所有在线用户均会被强制下线。
·     为保证双机模式下两台设备之间的业务备份正常工作,需要保证两台设备的设备ID分别为1和2。
·     由于设备ID是设备运行在双机模式下的标志,因此单机运行的环境下,不需要配置此命令。
# 在双机热备的组网环境中,配置本端设备运行在双机热备模式,设备ID为1。
[Sysname] nas device-id 1
Warning: This command will cut all user connections on this device. Continue? [Y/N]
此时,在对端设备上应该配置设备的设备ID为2,业务备份才能正常工作。
self-service-url enable url-string
undo self-service-url enable
ISP域视图
【缺省级别】
2:系统级
url-string:表示自助服务器的URL,为1~64个字符的字符串。字符串必须以“http://”开始,字符串中不能包括“?”字符。该URL在安装RADIUS服务器时由服务器管理员指定。
【描述】
self-service-url enable命令用来指定自助服务器的URL。undo self-service-url enable命令用来恢复缺省情况。
缺省情况下,自助服务器定位功能处于关闭状态。
自助服务即用户可以对自己的帐号和密码进行管理和控制。目前,仅CAMS/iMC类型的RADIUS服务器支持自助服务。
# 在ISP域test下,配置自助服务器修改用户密码页面的URL为http://10.153.89.94/selfservice。
[Sysname-isp-test] self-service-url enable http://10.153.89.94/selfservice
state { active | block }
undo state
ISP域视图
【缺省级别】
2:系统级
active:指定当前ISP域处于活动状态,即系统允许该域下的用户请求网络服务。
block:指定当前ISP域处于“阻塞”状态,即系统不允许该域下的用户请求网络服务。
【描述】
state命令用来设置当前ISP域的状态。undo state命令用来恢复缺省情况。
缺省情况下,当一个ISP域被创建以后,其状态为active(ISP域视图)。
当指定某个ISP域处于block状态时,不允许该域下的用户请求网络服务,但是不影响已经在线的用户。
# 设置当前ISP域test处于“阻塞”状态,域下的接入用户不能再请求网络服务。
[Sysname-isp-test] state block
1.2  本地用户配置命令
1.2.1  access-limit
access-limit max-user-number
undo access-limit
本地用户视图
【缺省级别】
3:管理级
max-user-number:表示使用当前用户名接入设备的最大用户数,取值范围为1~1024。
【描述】
access-limit命令用来设置当前用户名可容纳的最大接入用户数。undo access-limit命令用来取消对当前用户名的接入用户数限制。
缺省情况下,不限制当前本地用户名可容纳的接入用户数。
·     本地用户的access-limit命令只在该用户采用了本地计费方法的情况下生效。
·     由于FTP用户不支持计费,因此FTP用户不受此属性限制。
相关配置可参考命令display local-user
# 允许同时以用户名abc在线的用户数为5。
[Sysname] local-user abc
[Sysname-luser-abc] access-limit 5
authorization-attribute { acl acl-number | idle-cut minute | level level | user-profile profile-name | user-role { guest | guest-manager | security-audit } | vlan vlan-id | work-directory directory-name } *
undo authorization-attribute { acl | idle-cut | level | user-profile | user-role | vlan | work-directory } *
本地用户视图/用户组视图
【缺省级别】
3:管理级
acl acl-number:指定本地用户的授权ACL。其中,acl-number为授权ACL的编号,取值范围为2000~5999。本地用户认证成功后,将被授权仅可以访问符合指定ACL规则的网络资源。
idle-cut minute:设置本地用户的闲置切断时间。其中,minute为设定的闲置切断时间,取值范围为1~120,单位为分钟。如果用户在线后连续闲置的时长超过该值,设备会强制该用户下线。
level level:指定本地用户的级别,取值范围为0~3。其中0为访问级、1为监控级、2为系统级、3为管理级,数值越小,用户的级别越低。当登录设备用户界面的验证方式配置为scheme时,用户成功登录后所能访问的命令行的级别由本参数决定。缺省情况下,本地用户的级别为0,即用户成功登录后缺省可以访问级别为0的命令行。
user-profile profile-name:指定本地用户的授权User Profile。其中,profile-name表示用户配置文件的名称,为1~32个字符的字符串,只能包含英文字母、数字、下划线,且必须以英文字母开始,区分大小写。当用户通过认证上线后,其访问行为将受到User Profile中预设配置的限制。关于User Profile的详细介绍请参见“安全配置指导”中的“User Profile”。
user-role:指定授权本地用户的角色,不同角色的用户具有不同的命令行使用权限。该属性仅在本地用户视图下支持。未被授权为某特殊角色的本地用户,其认证成功后具有的访问权限受其它本地用户授权属性限制。目前,设备支持的本地用户角色包括以下几种:
·     guest:表示授权本地用户为来宾用户。通常,该角色的用户通过Web页面创建。
·     guest-manager:表示授权本地用户为来宾管理员,该类型的本地用户通过认证后,仅能通过Web访问来宾用户相关的页面,比如创建、修改和删除来宾用户。
·     security-audit表示授权本地用户为安全日志管理员,该类型的本地用户通过认证后,仅能执行与安全日志文件操作相关的命令,比如保存安全日志文件等,可执行命令的具体情况请参见“网络管理和监控命令参考”中的“信息中心”。
vlan vlan-id:指定本地用户的授权VLAN。本地用户认证成功后,将被授权仅可以访问指定VLAN内的网络资源。其中,vlan-id为VLAN编号,取值范围为1~4094。
work-directory directory-name:授权FTP/SFTP用户可以访问的目录。其中,directory-name表示FTP/SFTP用户可以访问的目录,为1~135个字符的字符串,不区分大小写,且该目录必须已经存在。缺省情况下,FTP/SFTP用户可访问设备的根目录,可通过本参数来修改用户可以访问的目录。
【描述】
authorization-attribute命令用来设置本地用户或用户组的授权属性,该属性在本地用户认证通过之后,由设备下发给用户。undo authorization-attribute命令用来删除配置的授权属性,恢复用户具有的缺省访问权限。
缺省情况下,未对本地用户或用户组设置任何授权属性。
·     可配置的授权属性都有其明确的使用环境和用途,请仅针对用户的服务类型配置对应的授权属性。
·     用户组的授权属性对于组内的所有本地用户生效,因此具有相同属性的用户可通过加入相同的用户组来统一配置和管理。
·     本地用户视图下未配置的授权属性继承所属用户组的授权属性配置,但是如果本地用户视图与所属的用户组视图下都配置了某授权属性,则本地用户视图下的授权属性生效。
·     系统中只剩一个角色为安全日志管理员的本地用户时,该本地用户就不能被删除,而且也不能修改或删除该本地用户的安全日志管理员角色,除非再指定一个新的用户为安全日志管理员。
·     一个本地用户只能被指定为一种角色,后设置的角色会覆盖前面设置的角色。
# 配置本地用户abc的授权VLAN为VLAN 2。
[Sysname-luser-abc] authorization-attribute vlan 2
# 配置用户组abc的授权VLAN为VLAN 3。
[Sysname] user-group abc
[Sysname-ugroup-abc] authorization-attribute vlan 3
bind-attribute { ip ip-address | location port slot-number subslot-number port-number | mac mac-address | vlan vlan-id } *
undo bind-attribute { ip | location | mac | vlan } *
本地用户视图
【缺省级别】
3:管理级
ip ip-address:指定用户的IP地址。
location port slot-number subslot-number port-number:指定用户绑定的端口。其中slot-number为槽位号,取值范围为0~255;subslot-number为子槽位号,取值范围为0~15;port-number为端口号,取值范围0~255。
mac mac-address:指定用户的MAC地址。其中,mac-address为H-H-H格式。
vlan vlan-id:指定用户所属于的VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。
【描述】
bind-attribute命令用来设置用户的绑定属性。undo bind-attribute命令用来删除配置的用户绑定属性。
缺省情况下,未设置用户的任何绑定属性。
需要注意的是,当对本地用户进行认证时,如果配置了绑定属性,则会检查用户的实际属性与配置的绑定属性是否一致,如果不一致则认证失败。而且,由于认证检测时不区分用户的接入服务类型,即会对所有类型的用户都进行已配置绑定属性的认证检测,因此在配置绑定属性时要考虑某类型的用户是否需要绑定某些属性。例如,只有支持IP地址上传功能的802.1X认证用户才可以配置绑定IP地址;对于不支持IP地址上传功能的MAC地址认证用户,如果配置了绑定IP地址,则会导致该用户的本地认证失败。
# 配置本地用户abc的绑定IP为3.3.3.3。
[Sysname-luser-abc] bind-attribute ip 3.3.3.3
display local-user [ idle-cut { disable | enable } | service-type { ftp | lan-access | portal | ssh | telnet | terminal | web } | state { active | block } | user-name user-name | vlan vlan-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
idle-cut { disable | enable }:显示使能或未使能闲置切断功能的本地用户信息。其中,disable表示未启用闲置切断功能的本地用户;enable表示启用了闲置切断功能并配置了闲置切断时间的本地用户。
service-type:显示指定用户类型的本地用户信息。
·     ftp:FTP用户。
·     lan-access:lan-access类型用户(主要指以太网接入用户,比如802.1X用户)。
·     portal:Portal用户。
·     ssh:SSH用户。
·     telnet:Telnet用户。
·     terminal:从Console口登录的终端用户。
·     web:Web用户。
state { active | block }:显示处于指定状态的本地用户信息。其中,active表示用户处于活动状态,即系统允许该用户请求网络服务;block表示用于处于阻塞状态,即系统不允许用户请求网络服务。
user-name user-name:显示指定用户名的本地用户信息。其中,user-name表示本地用户名,为1~55个字符的字符串,区分大小写,不能携带域名。
vlan vlan-id:显示指定VLAN内的所有本地用户信息。其中,vlan-id为VLAN编号,取值范围为1~4094。
slot slot-number:显示指定成员设备上的所有本地用户信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display local-user命令用来显示本地用户的配置信息和在线用户数的统计信息。
需要注意的是:如果不指定任何参数,则显示所有本地用户信息。
相关配置可参考命令local-user
# 显示所有本地用户的相关信息。
<Sysname> display local-user
The contents of local user abc:
 State:                    Active
 ServiceType:              lan-access
 Access-limit:             Enabled           Current AccessNum: 0
 Max AccessNum:            300
 User-group:               system
 Bind attributes:
  IP address:              1.2.3.4
  Bind location:           1/4/1 (SLOT/SUBSLOT/PORT)
  MAC address:             0001-0002-0003
  Vlan ID:                 100
 Authorization attributes:
  Idle TimeOut:            10(min)
  Work Directory:          flash:/
  User Privilege:          3
  Acl ID:                  2000
  Vlan ID:                 100
  User Profile:            prof1
 Expiration date:          12:12:12-2018/09/16
 Password aging:           Enabled (30 days)
 Password length:          Enabled (4 characters)
 Password composition:     Enabled (4 types,  2 characters per type)
Total 1 local user(s) matched.
表1-3 display local-user命令显示信息描述表
本地用户的状态(Active:激活、Block:阻塞)
ServiceType
本地用户的服务类型(ftp、lan-access、portal、ssh、telnet、terminal、web)
Access-limit
是否对使用该用户名的接入连接数进行限制(Enabled:使能连接限制功能、Disabled:未使能连接限制功能)
Current AccessNum
使用该用户名的当前接入用户数
Max AccessNum
最大接入用户数
User-group
本地用户所属用户组
Bind attributes
本地用户的绑定属性
IP address
本地用户绑定的IP地址
Bind location
本地用户绑定的端口
MAC address
本地用户绑定的MAC地址
VLAN ID
本地用户绑定的VLAN
Calling Number
ISDN用户绑定的主叫号码
本地用户的授权属性
Idle TimeOut
本地用户闲置切断时间(单位为分钟)
Work Directory
FTP/SFTP用户可以访问的目录
User Privilege
本地用户级别
VLAN ID
本地用户授权VLAN
User Profile
本地用户授权User Profile
Expiration date
本地用户的有效期
Password aging
本地用户密码的老化时间
Password length
本地用户密码的最小长度
本地用户密码的组合策略
总计有1个本地用户匹配
display user-group [ group-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
group-name:用户组名称,为1~32个字符的字符串,不区分大小写。
【描述】
display user-group命令用来显示用户组的相关配置。不指定用户组名称,则显示所有用户组的相关配置。
相关配置请参考命令user-group
# 显示用户组abc的相关配置。
<Sysname> display user-group abc
The contents of user group abc:
  Idle-cut:                120(min)
  Work Directory:          FLASH:
  Level:                   1
  Acl Number:              2000
  Vlan ID:                 1
  User-Profile:            1
Password aging:           Enabled (1 days)
 Password composition:     Enabled (1 types,  1 characters per type)
Total 1 user group(s) matched.
表1-4 display user-group命令显示信息描述表
Idle-cut
闲置切断时间(单位:分钟)
Work Directory
FTP/SFTP用户可以访问的目录
Level
本地用户的级别
Acl Number
授权ACL号
Vlan ID
授权VlAN ID
User-Profile
授权User Profile名称
Password aging
本地用户密码老化时间
Password length
本地用户密码最小长度
本地用户密码组合策略
总计有1个用户组匹配
expiration-date time
undo expiration-date
本地用户视图
【缺省级别】
3:管理级
time:本地用户的有效期,精确到秒,格式为HH:MM:SS-MM/DD/YYYY(时:分:秒-月/日/年)、HH:MM:SS-YYYY/MM/DD(时:分:秒-年/月/日)、MM/DD/YYYY-HH:MM:SS(月/日/年-时:分:秒)或YYYY/MM/DD-HH:MM:SS(年/月/日-时:分:秒)。其中,HH:MM:SS中的HH取值范围为0~23,MM和SS取值范围为0~59;MM/DD/YYYY或YYYY/MM/DD中的MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。除表示零点外,格式中的前导0可以省略不写,比如2:2:0-2011/2/2等效于02:02:00-2011/02/02。
【描述】
expiration-date命令用来设置本地用户的有效期。undo expiration-date用来取消本地用户的有效期配置。
缺省情况下,未设置用户的有效期,设备不进行用户有效期的检查。
在有用户临时需要接入网络的情况下,设备管理员可以为用户建立临时使用的来宾帐户,并通过本命令与vaildity-date命令一起完成对用户有效起止时间的控制。当用户进行本地认证时,接入设备检查当前系统时间是否在该用户的生效时间与有效期之间,若在则允许用户登录,否则拒绝用户登录。
# 配置用户abc的有效期为2011/01/31的12:10:20。
[Sysname-luser-abc] expiration-date 12:10:20-2011/01/31
1.2.7  group
group group-name
undo group
本地用户视图
【缺省级别】
3:管理级
【描述】
group命令用来设置本地用户所属的用户组。undo group命令用来恢复缺省配置。
缺省情况下,用户属于系统默认创建的用户组system。
# 设置本地用户111所属的用户组为abc。
[Sysname] local-user 111
[Sysname-luser-111] group abc
undo group-attribute allow-guest
用户组视图
【缺省级别】
3:管理级
【描述】
group-attribute allow-guest命令用来设置用户组的来宾可选属性,即允许来宾用户管理员在Web页面上创建的来宾用户加入该用户组。undo group-attribute allow-guest命令用来恢复缺省情况。
缺省情况下,用户组不具有来宾可选属性,来宾用户管理员在Web界面上创建的来宾用户不能加入该用户组。
需要注意的是,系统默认创建的用户组system缺省就具有来宾可选属性,并且该属性不能被删除。
# 设置用户组test允许来宾用户加入。
[Sysname] user-group test
[Sysname-ugroup-test] group-attribute allow-guest
1.2.9  local-user
local-user user-name
undo local-user { user-name | all [ service-type { ftp | lan-access | portal | ssh | telnet | terminal | web } ] }
【缺省级别】
3:管理级
user-name:表示本地用户名,为1~55个字符的字符串,区分大小写。用户名不能携带域名,不能包括符号“\”、“|”、“/”、“:”、“*”、“?”、“<”、“>”和“@”,且不能为“a”、“al”或“all”。
all:所有的用户。
service-type:指定用户的类型。具体用户类型如下:
·     ftp:表示FTP类型用户;
·     lan-access:表示lan-access类型用户(主要指以太网接入用户,比如802.1X用户);
·     portal:表示Portal用户;
·     ssh:表示SSH用户;
·     telnet:表示Telnet用户;
·     terminal:表示从Console口登录的终端用户;
·     web:表示Web用户。
【描述】
local-user命令用来添加本地用户并进入本地用户视图。undo local-user命令用来删除指定的本地用户。
缺省情况下,无本地用户。
相关配置可参考命令display local-userservice-type
# 添加名称为user1的本地用户。
[Sysname] local-user user1
[Sysname-luser-user1]
1.2.10  password
非FIPS模式下:
password [ [ hash ] { cipher | simple } password ]
undo password
FIPS模式下:
password
本地用户视图
【缺省级别】
2:系统级
hash: 以哈希加密算法方式保存密码并显示为密码的hash值。
cipher:表示以密文方式设置用户密码。
simple:表示以明文方式设置用户密码。
password:设置的明文密码或密文密码,区分大小写。
·     如果未指定哈希加密算法保存时,明文密码为1~63个字符的字符串;密文密码为1~117个字符的字符串;
·     如果指定哈希加密算法保存,明文密码为1~63个字符的字符串;密文密码为1~110个字符的字符串。
【描述】
password命令用来设置本地用户的密码。undo password命令用来取消本地用户的密码。
·     如果不指定任何参数,则表示以交互式方式设置本地用户密码,涵义与指定simple关键字相同。仅支持Password Control特性的设备上才支持本方式,Password Control相关命令的具体介绍请参见“安全命令参考”中的“Password Control”。
·     使能Password Control特性的全局密码管理功能(通过命令password-control enable)后,本地用户密码的设置将受到Password Control特性的约束,比如密码的长度、复杂度等将会受到限制,并且设备上将不显示配置的本地用户密码。另外,用户也不能再通过password hash cipher password命令配置用户密码。
·     以明文或密文方式设置的用户密码,均以密文的方式保存在配置文件中。
·     相关配置可参考命令display local-user
# 设置本地用户user1的密码为明文123456。
[Sysname-luser-user1] password simple 123456
# 以交互式方式设置本地用户user1的密码为AAbbcc1234%。
Password:***********
Confirm :***********
1.2.11  service-type
非FIPS模式下:
service-type { ftp | lan-access | { ssh | telnet | terminal } * | portal | web }
undo service-type { ftp | lan-access | { ssh | telnet | terminal } * | portal | web }
FIPS模式下:
service-type { lan-access | { ssh | terminal } * | portal | web }
undo service-type { lan-access | { ssh | terminal } * | portal | web }
本地用户视图
【缺省级别】
3:管理级
ftp:指定用户可以使用FTP服务。若授权FTP服务,缺省授权FTP用户可访问设备的根目录。
lan-access:指定用户可以使用lan-access服务。主要指以太网接入,比如用户可以通过802.1X认证接入。
ssh:指定用户可以使用SSH服务。
telnet:指定用户可以使用Telnet服务。
terminal:指定用户可以使用terminal服务(即从Console口登录)。
portal:指定用户可以使用Portal服务。
web:指定用户可以使用Web服务。
【描述】
service-type命令用来设置用户可以使用的服务类型。undo service-type命令用来删除用户可以使用的服务类型。
缺省情况下,系统不对用户授权任何服务。
可以通过多次执行本命令,设置用户可以使用多种服务类型。
# 指定用户可以使用Telnet服务。
[Sysname-luser-user1] service-type telnet
undo state
本地用户视图
【缺省级别】
2:系统级
active:指定当前本地用户处于活动状态,即系统允许当前本地用户请求网络服务。
block:指定当前本地用户处于“阻塞”状态,即系统不允许当前本地用户请求网络服务。
【描述】
state命令用来设置当前本地用户的状态。undo state命令用来恢复缺省情况。
缺省情况下,当一个本地用户被创建以后,其状态为active(本地用户视图)。
当指示某个用户处于block状态时,不允许当前本地用户请求网络服务,但是不影响其它用户。
相关配置可参考命令local-user
# 设置本地用户user1处于“阻塞”状态。
[Sysname-luser-user1] state block
1.2.13  user-group
user-group group-name
undo user-group group-name
【缺省级别】
3:管理级
【描述】
user-group命令用来创建用户组并进入其视图。undo user-group命令用来删除指定的用户组。
用户组是一个本地用户策略及属性的集合,某些需要集中管理的策略或者属性可在在用户组中统一配置和管理。目前,用户组中可配置的内容包括本地用户密码的控制策略和用户的授权属性。
·     当用户组中有本地用户时,不允许使用undo user-group删除该用户组。
·     不能删除系统中存在的默认用户组system,但可以修改该用户组的配置。
相关配置可参考命令display user-group
# 创建名称为abc的用户组并进入其视图。
validity-date time
undo validity-date
本地用户视图
【缺省级别】
3:管理级
time:本地用户的生效时间,精确到秒,格式为HH:MM:SS-MM/DD/YYYY(时:分:秒-月/日/年)、MM/DD/YYYY-HH:MM:SS(月/日/年-时:分:秒)、YYYY/MM/DD-HH:MM:SS(年/月/日-时:分:秒)或HH:MM:SS-YYYY/MM/DD(时:分:秒-年/月/日)。其中,HH:MM:SS中的HH取值范围为0~23,MM和SS取值范围为0~59;MM/DD/YYYY中的MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。除表示零点外,格式中的前导0可以省略不写,比如2:2:0-2011/2/2等效于02:02:00-2011/02/02。
【描述】
validity-date命令用来设置本地用户的生效时间。undo validity-date用来取消本地用户的生效时间配置。
缺省情况下,未设置用户的生效时间,设备不进行用户生效时间的检查。
在有用户临时需要接入网络的情况下,设备管理员可以为用户建立临时使用的来宾帐户,并通过本命令与expiration-date命令一起完成对用户有效起止时间的控制。当用户进行本地认证时,接入设备检查当前系统时间是否在该用户的生效时间与有效期之间,若在则允许用户登录,否则拒绝用户登录。
# 配置用户abc的生效时间为2011/04/30的12:10:20,有效期截至2011/05/31的12:10:20。
[Sysname-luser-abc] validity-date 12:10:20-2011/04/30
[Sysname-luser-abc] expiration-date 12:10:20-2011/05/31
1.3  RADIUS配置命令
accounting-on enable [ interval seconds | send send-times ] *
undo accounting-on enable
RADIUS方案视图
【缺省级别】
2:系统级
seconds:accounting-on报文重发时间间隔,取值范围为1~15,单位为秒,缺省值为3。
send-times:accounting-on报文的最大发送次数,取值范围为1~255,缺省值为50。
【描述】
accounting-on enable命令用来配置accounting-on功能。在accounting-on功能处于使能的情况下,若设备重启,则设备会在重启之后发送accounting-on报文通知该方案所使用的计费RADIUS服务器,要求RADIUS服务器停止计费且强制该设备的用户下线。undo accounting-on enable命令用来恢复缺省情况。
缺省情况下,accounting-on功能处于关闭状态。
·     执行完该命令后,请执行save操作,以保证设备重启后accounting-on功能生效。
·     在执行accounting-on功能的过程中,使用该命令重新设置的报文重发间隔时间以及报文最大发送次数会立即生效。
# 使能RADIUS认证方案radius1的accounting-on功能,并配置accounting-on报文重发时间间隔为5秒、accounting-on报文的最大发送次数为15次。
[Sysname] radius scheme radius1
[Sysname-radius-radius1] accounting-on enable interval 5 send 15
attribute 25 car
undo attribute 25 car
RADIUS方案视图
【缺省级别】
2:系统级
【描述】
attribute 25 car命令用来开启RADIUS Attribute 25的CAR参数解析功能。undo attribute 25 car命令用来恢复缺省情况。
缺省情况下,RADIUS Attribute 25的CAR参数解析功能处于关闭状态。
相关配置可参考命令display radius schemedisplay connection
# 开启RADIUS Attribute 25的CAR参数解析功能。
[Sysname-radius-radius1] attribute 25 car
data-flow-format { data { byte | giga-byte | kilo-byte | mega-byte } | packet { giga-packet | kilo-packet | mega-packet | one-packet } } *
undo data-flow-format { data | packet }
RADIUS方案视图
【缺省级别】
2:系统级
data:设置数据流的单位。
·     byte:数据流的单位为字节。
·     giga-byte:数据流的单位千兆字节。
·     kilo-byte:数据流的单位为千字节。
·     mega-byte:数据流的单位为兆字节。
packet:设置数据包的单位。
·     giga-packet:数据包的单位为千兆包。
·     kilo-packet:数据包的单位为千包。
·     mega-packet:数据包的单位为兆包。
·     one-packet:数据包的单位为包。
【描述】
data-flow-format命令用来配置发送到RADIUS服务器的数据流及数据包的单位。undo data-flow-format命令用来恢复缺省情况。
缺省情况下,数据流的单位为byte,数据包的单位为one-packet
需要注意的是,设备上配置的发送给RADIUS服务器的数据流单位及数据包单位应与RADUIS服务器上的流量统计单位保持一致,否则无法正确计费。
# 在RADIUS方案radius1中,设置发往RADIUS服务器的数据流单位为千字节、数据包单位为千包。
[Sysname-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
display radius scheme [ radius-scheme-name ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
radius-scheme-name:指定RADIUS方案名。
slot slot-number:显示指定成员设备上的RADIUS方案配置信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display radius scheme命令用来显示所有或指定RADIUS方案的配置信息。
需要注意的是:如果不指定RADIUS方案名,则显示所有RADIUS方案的配置信息。
相关配置可参考命令radius scheme
# 显示所有RADIUS方案的配置信息。
<Sysname> display radius scheme
SchemeName  : radius1
  Index : 0                           Type : extended
  Primary Auth Server:
    IP: 1.1.1.1                                  Port: 1812   State: active
    Encryption Key : ******
    VPN instance   : 1
    Probe username :test
    Probe interval : 60 min
  Primary Acct Server:
    IP: 1.1.1.1                                  Port: 1813   State: active
    VPN instance   : 1
  Second Auth Server:
    IP: 1.1.2.1                                  Port: 1812   State: active
    Encryption Key : N/A
    VPN instance   : 1
    IP: 1.1.3.1                                  Port: 1812   State: active
    VPN instance   : 1
  Second Acct Server:
    IP: 1.1.2.1                                  Port: 1813   State: block
    VPN instance   : 1
  Auth Server Encryption Key : ******
  Acct Server Encryption Key : N/A
  VPN instance               : 1
  Accounting-On packet disable, send times : 50 , interval : 3s
  Interval for timeout(second)                            : 3
  Retransmission times for timeout                        : 3
  Interval for realtime accounting(minute)                : 12
  Retransmission times of realtime-accounting packet      : 5
  Retransmission times of stop-accounting packet          : 500
  Quiet-interval(min)                                     : 5
  Username format                                         : without-domain
  Data flow unit                                          : Byte
  Packet unit                                             : one
  NAS-IP address                                          : 1.1.1.1
  Attribute 25                                            : car
Total 1 RADIUS scheme(s).
表1-5 display radius scheme命令显示信息描述表
SchemeName
RADIUS方案的名称
Index
RADIUS方案的索引号
RADIUS服务器的类型
·     extended类型
·     standard类型
Primary Auth Server
主认证服务器相关信息
Primary Acct Server
主计费服务器相关信息
Second Auth Server
从认证服务器相关信息
Second Acct Server
从计费服务器相关信息
IP
认证/计费服务器的IP地址
Port
认证/计费服务器的接入端口号
未配置时,显示缺省值
认证/计费服务器的目前状态
·     active:激活
·     block:阻塞
Encryption Key
认证/计费报文的共享密钥
·     已配置时,显示为******
·     未配置时,显示为N/A
该密钥仅在配置RADIUS服务器同时未指定相应密钥的情况下时使用
VPN instance
服务器所属的MPLS L3VPN
未配置时,显示为N/A
Probe username
探测服务器状态使用的用户名
Probe interval
探测服务器状态的周期(分钟)
认证报文的共享密钥
·     已配置时,显示为******
·     未配置时,显示为N/A
计费报文的共享密钥
·     已配置时,显示为******
·     未配置时,显示为N/A
VPN instance
RADIUS方案所属的MPLS L3VPN
未配置时,不显示
accounting-on功能未使能
send times
accounting-on报文的重发次数
interval
accounting-on报文的重发间隔(秒)
RADIUS服务器的响应超时时间(秒)
发送RADIUS报文的最大尝试次数
实时计费的时间间隔(分钟)
允许实时计费请求无响应的最大次数
发起停止计费请求的最大尝试次数
Quiet-interval(min)
主服务器恢复激活状态的时间
Username format
发送给RADIUS服务器的用户名格式
Data flow unit
发送给RADIUS服务器的数据流的单位
Packet unit
发送给RADIUS服务器的数据包的单位
NAS-IP address
发送RADIUS报文的源IP地址
Backup-NAS-IP address
发送RADIUS报文的备份源IP地址
Attribute 25
将RADIUS Attribute 25解析为CAR参数
共计1个RADIUS方案
display radius statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
slot slot-number:显示指定成员设备上的RADIUS报文的统计信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display radius statistics命令用来显示RADIUS报文的统计信息。
# 显示RADIUS报文的统计信息。
<Sysname> display radius statistics
Slot  1:state statistic(total=2048):
     DEAD = 4096      AuthProc = 0        AuthSucc = 0
AcctStart = 0         RLTSend = 0         RLTWait = 0
 AcctStop = 0          OnLine = 0            Stop = 0
Received and Sent packets statistic:
Sent PKT total   = 1547     Received PKT total = 23
Resend Times     Resend total
1                508
2                508
Total            1016
RADIUS received packets statistic:
Code =  2   Num = 15       Err = 0
Code =  3   Num = 4        Err = 0
Code =  5   Num = 4        Err = 0
Code = 11   Num = 0        Err = 0
Running statistic:
RADIUS received messages statistic:
Normal auth request      Num = 24       Err = 0        Succ = 24
EAP auth request         Num = 0        Err = 0        Succ = 0
Account request          Num = 4        Err = 0        Succ = 4
Account off request      Num = 503      Err = 0        Succ = 503
PKT auth timeout         Num = 15       Err = 5        Succ = 10
PKT acct_timeout         Num = 1509     Err = 503      Succ = 1006
Realtime Account timer   Num = 0        Err = 0        Succ = 0
PKT response             Num = 23       Err = 0        Succ = 23
Accounting on response   Num = 0        Err = 0        Succ = 0
Session ctrl pkt         Num = 0        Err = 0        Succ = 0
Normal author request    Num = 0        Err = 0        Succ = 0
Set policy result        Num = 0        Err = 0        Succ = 0
RADIUS sent messages statistic:
Auth accept              Num = 10
Auth reject              Num = 14
EAP auth replying        Num = 0
Account success          Num = 4
Account failure          Num = 3
Server ctrl req          Num = 0
RecError_MSG_sum = 0
SndMSG_Fail_sum  = 0
Timer_Err        = 0
Alloc_Mem_Err    = 0
State Mismatch   = 0
Other_Error      = 0
No-response-acct-stop packet = 1
Discarded No-response-acct-stop packet for buffer overflow = 0
表1-6 display radius statistics命令显示信息描述表
state statistic
各状态的用户数统计信息
DEAD
处于空闲态的用户数
AuthProc
处于认证等待态的用户数
AuthSucc
处于认证成功态的用户数
AcctStart
处于计费开始态的用户数
RLTSend
处于实时计费发送态的用户数
RLTWait
处于实时计费等待态的用户数
AcctStop
处于计费等待停止态的用户数
OnLine
处于在线态的用户数
Stop
处于停止态的用户数
RADIUS模块收发报文的数目统计信息
Sent PKT total
发送报文总数
Received PKT total
接收报文总数
Resend Times
重传报文的次数
Resend total
单次重传报文数
Total
重传报文总数
RADIUS模块接收报文数目统计
Code
报文类型
Num
报文总数
Err
处理失败的报文数或消息数
Succ
成功处理的消息数
Running statistic
RADIUS模块收发报文的分类统计信息
RADIUS已接收消息数目统计
Normal auth request
普通认证请求报文数
EAP auth request
EAP认证请求报文数
Account request
计费请求报文数
Account off request
计费停止请求报文数
PKT auth timeout
认证超时报文数
PKT acct_timeout
计费超时报文数
实时计费请求报文数
PKT response
服务器的响应报文数
accounting on响应报文数
Session ctrl pkt
会话控制报文数
普通授权请求报文数
Set policy result
Set policy结果报文数
RADIUS模块已发送消息数目统计
Auth accept
认证接收报文数
Auth reject
认证拒绝报文数
EAP auth replying
EAP认证回应报文数
Account success
计费成功报文数
Account failure
计费失败报文数
Server ctrl req
服务器控制请求报文数
RecError_MSG_sum
接收错误消息总数
SndMSG_Fail_sum
发送消息失败总数
Timer_Err
启动定时器失败报文数
Alloc_Mem_Err
申请内存失败报文数
State Mismatch
状态不匹配报文数
Other_Error
其它错误报文数
停止计费报文无响应数
因缓存区满而丢弃的无响应停止计费报文总数
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
radius-scheme radius-scheme-name:显示缓存的、向指定RADIUS方案中的计费服务器发送的停止计费请求报文。其中,radius-scheme-name为RADIUS方案名,为1~32个字符的字符串。
session-id session-id:显示缓存的指定会话ID的停止计费请求报文。其中,session-id为1~50个字符的字符串。
time-range start-time stop-time:显示缓存的指定时间段内的停止计费请求报文,即只要是在指定时间段内的发起且被暂存的停止计费请求报文都会被显示。其中,start-time为请求时间段的起始时间;stop-time为请求时间段的结束时间,格式为hh:mm:ss- mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:显示缓存的指定用户名的停止计费请求报文。其中,user-name表示用户名,为1~80个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中的user-name-format配置保持一致。
slot slot-number:显示指定成员设备上缓存的RADIUS停止计费请求报文,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display stop-accounting-buffer命令用来显示缓存的没有得到响应的停止计费请求报文的相关信息,主要包括该计费请求报文所属的会话ID、用户名以及产生停止计费请求的时间。
在发送停止计费请求报文而RADIUS服务器没有响应时,设备会尝试重传该报文,如果发送该报文的最大尝试次数超过指定的值(由retry命令设置)后仍然没有得到响应,则设备会缓存该报文,然后再发起一次请求,若继续无响应,则重复上述过程,一定次数(由retry stop-accounting命令设置)之后,设备将其丢弃。
相关配置可参考命令reset stop-accounting-bufferstop-accounting-buffer enableuser-name-formatretryretry stop-accounting
# 显示系统缓存的用户名为abc的停止计费请求报文的相关信息。
<Sysname> display stop-accounting-buffer user-name abc
 Slot  1:
RDIdx Session-ID               user name                  Happened time
1    1000326232325010          abc                       23:27:16-03/31/2011
1    1000326232326010          abc                       23:33:01-03/31/2011
Total 2 record(s) Matched
key { accounting | authentication } [ cipher | simple ] key
undo key { accounting | authentication }
RADIUS方案视图
【缺省级别】
2:系统级
accounting:指定RADIUS计费报文的共享密钥。
authentication:指定RADIUS认证/授权报文的共享密钥。
cipher:表示以密文方式设置共享密钥。
simple:表示以明文方式设置共享密钥。
key:设置的明文密钥或密文密钥,区分大小写。非FIPS模式下,明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串;FIPS模式下,明文密钥为8~64个字符的字符串,且密钥元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符);密文密钥为8~117个字符的字符串。不指定simplecipher时,表示以明文方式设置共享密钥。
【描述】
key命令用来配置RADIUS认证/授权或计费报文的共享密钥。undo key命令用来删除配置。
缺省情况下,无共享密钥。
·     以明文或密文方式设置的共享密钥,均以密文的方式保存在配置文件中。
·     设备优先采用配置RADIUS认证/授权/计费服务器时指定的报文共享密钥,本配置中指定的报文共享密钥仅在配置RADIUS认证/授权/计费服务器时未指定相应密钥的情况下使用。
·     必须保证设备上设置的共享密钥与RADIUS服务器上的完全一致。
# 将RADIUS方案radius1的计费报文的共享密钥设置为明文ok。
[Sysname-radius-radius1] key accounting simple ok
[Sysname-radius-radius1] key accounting ok
1.3.8  nas-backup-ip
nas-backup-ip ip-address
undo nas-backup-ip
RADIUS方案视图
【缺省级别】
2:系统级
ip-address:指定的备份源IP地址,禁止配置全0地址、全1地址、D类地址、E类地址和环回地址,且必须指定为双机热备环境中对端设备上发送RADIUS报文的源IP地址。
【描述】
nas-backup-ip命令用来设置设备发送RADIUS报文使用的备份源IP地址。undo nas-backup-ip命令用来恢复缺省情况。
缺省情况下,未指定设备发送RADIUS报文使用的备份源IP地址。
·     该配置只在双机热备环境下需要配置,可以保证双机热备环境中主设备发生故障时,服务器发送的报文可以被备份设备收到并进行处理。
·     RADIUS方案视图下的命令nas-backup-ip只对本RADIUS方案有效,系统视图下的命令radius nas-backup-ip对所有RADIUS方案有效。RADIUS方案视图下的设置具有更高的优先级。
·     如果多次执行本命令,则新配置的备份源IP地址会覆盖原有的备份源IP地址。
相关配置可参考命令nas-ipradius nas-ip
# 在双机热备的组网环境中,设置本端设备发送RADIUS报文使用的源IP地址为2.2.2.2,备份源IP为3.3.3.3。
[Sysname-radius-radius1] nas-ip 2.2.2.2
[Sysname-radius-radius1] nas-backup-ip 3.3.3.3
此时,在对端设备上应该设置设备发送RADIUS报文使用的源IP地址为3.3.3.3,备份源IP为2.2.2.2,业务备份才能正常工作。
nas-ip { ipv4-address | ipv6 ipv6-address }
undo nas-ip
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:指定的源IPv4地址,应该为本机的地址,禁止配置全0地址、全1地址、D类地址、E类地址和环回地址。
ipv6 ipv6-address:指定的源IPv6地址,应该为本机的地址,必须是单播地址,不能为环回地址与本地链路地址。
【描述】
nas-ip命令用来设置设备发送RADIUS报文使用的源IP地址。undo nas-ip命令用来恢复缺省情况。
缺省情况下,使用系统视图下由命令radius nas-ip指定的源地址,若系统视图下未指定源地址,则使用发送RADIUS报文的接口的IP地址。
·     RADIUS服务器上通过IP地址来标识接入设备,并根据收到的RADIUS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证认证和计费报文可被服务器正常接收并处理,接入设备上发送RADIUS报文使用的源地址必须与RADIUS服务器上指定的接入设备的IP地址保持一致。
·     RADIUS方案视图下的命令nas-ip只对本RADIUS方案有效,系统视图下的命令radius nas-ip对所有RADIUS方案有效。RADIUS方案视图下的设置具有更高的优先级。
·     本命令配置的源IP地址与RADIUS方案中设置的服务器IP地址的协议版本必须保持一致,否则配置不生效。
·     如果重复执行此命令,新配置的源地址会覆盖原有的源地址。
相关配置可参考命令radius nas-ip
# 配置设备发送RADIUS报文使用的源IP地址为10.1.1.1。
[Sysname-radius-radius1] nas-ip 10.1.1.1
primary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo primary accounting
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:主RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS计费服务器的IPv6地址。
port-number:主RADIUS计费服务器的UDP端口号,缺省为1813,取值范围为1~65535。此端口号必须与服务器提供计费服务的端口号保持一致。
key [ cipher | simple ] key:与主RADIUS计费服务器交互的计费报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
·     cipher key:以密文方式设置共享密钥。非FIPS模式下,key为1~117个字符的字符串,区分大小写;FIPS模式下,key为8~117个字符的字符串,区分大小写。
·     simple key:以明文方式设置共享密钥。非FIPS模式下,key为1~64个字符的字符串,区分大小写;FIPS模式下,key为8~64个字符的字符串,区分大小写,且密钥元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符)。
·     在不指定ciphersimple时,表示以明文方式设置共享密钥。
vpn-instance vpn-instance-name:主RADIUS计费服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS计费服务器位于公网中。
【描述】
primary accounting命令用来配置主RADIUS计费服务器。undo primary accounting命令用来删除设置的主RADIUS计费服务器。
缺省情况下,未配置主计费服务器。
·     主计费服务器和从计费服务器的IP地址不能相同,且IP地址协议版本必须一致。
·     设备与主计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key accounting [ cipher | simple ] key命令设置的共享密钥。
·     若设备与MPLS VPN私网服务器通信,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例名称。本命令指定的服务器所属的VPN实例比RADIUS方案所属的VPN实例具有更高的优先级。
·     计费服务器与认证/授权服务器的IP地址协议版本必须一致。
·     如果在发送计费开始请求过程中修改了主计费服务器,则设备在与当前服务器通信超时后,将会重新从主服务器开始依次查找状态为active的服务器进行通信。
·     如果在线用户正在使用的计费服务器被删除,则设备将将无法发送用户的实时计费请求和停止计费请求,且停止计费报文不会被缓存到本地。
相关配置可参考命令keyvpn-instance (RADIUS scheme view)。
# 设置RADIUS方案radius1的主计费服务器的IP地址为10.110.1.2,使用UDP端口1813提供RADIUS计费服务,计费报文的共享密钥为明文hello。
[Sysname-radius-radius1] primary accounting 10.110.1.2 1813 key simple hello
primary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | probe username name [ interval interval ] | vpn-instance vpn-instance-name ] *
undo primary authentication
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:主RADIUS认证/授权服务器的IPv4地址。
ipv6 ipv6-address:主RADIUS认证/授权服务器的IPv6地址。
port-number:主RADIUS认证/授权服务器的UDP端口号,缺省为1812,取值范围为1~65535。此端口号必须与服务器提供认证/授权服务的端口号保持一致。
key [ cipher | simple ] key:与主RADIUS认证/授权服务器交互的认证/授权报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
probe:开启对主RADIUS认证/授权服务器状态的探测功能。
username name:设置探测主RADIUS认证/授权服务器状态时认证报文中使用的用户名。该用户名并不要求是认证/授权服务器上存在的用户名。
interval interval:设置探测主RADIUS认证/授权服务器是否可达的时间间隔,取值范围为1~3600,单位为分钟,缺省值为60。
vpn-instance vpn-instance-name:主RADIUS认证/授权服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主RADIUS认证/授权服务器位于公网中。
【描述】
primary authentication命令用来配置主RADIUS认证/授权服务器。undo primary authentication命令用来删除设置的主RADIUS认证/授权服务器。
缺省情况下,未配置主认证/授权服务器。
·     设备与主认证/授权服务器通信时优先使用本命令设置的共享密钥,如果本命令中未设置,则使用命令key authenticaiton [ cipher | simple ] key命令设置的共享密钥。
·     若设备与MPLS VPN私网服务器通信,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例名称。本命令指定的服务器所属的VPN比RADIUS方案所属的VPN具优先级高。
·     主认证/授权服务器和从认证/授权服务器的IP地址不能相同,且IP地址协议版本必须一致。
·     认证/授权服务器与计费服务器的IP地址协议版本必须一致。
·     如果在认证过程中使用本命令删除了主认证服务器,则设备在与当前服务器通信超时后,将会重新从主服务器开始依次查找状态为active的服务器进行通信。
开启了服务器的探测功能后,设备以指定的探测周期向当前的认证服务器发送认证请求报文,用户名为配置的探测用户名,如果服务器在指定的时间内(由timer response-timeout命令设置)没有回应,则设备重传该请求报文。若在累计的传送次数超过最大尝试次数(由retry命令设置)后,设备仍未收到服务器的回应报文,则认为服务器状态为block。对于802.1X认证而言,当所有服务器状态均为block时,设备会将认证用户的端口加入到指定的Critical VLAN中(有关802.1X Critical VLAN的相关介绍请参见“安全配置指导”中的“802.1X”);如果在最大尝试次数到达之前,收到服务器的回应报文,则认为该服务器状态为active。
·     对于状态为active的服务器,如果设备的探测结果为失败(即服务器不可达),则会将其置为block状态;对于状态为block的服务器,如果设备的探测结果为成功(即服务器可达),则会将其置为active状态。
·     使能了对服务器的探测功能后,建议将timer quiet定时器的时间配置得尽可能长一些,以保证设备将服务器的状态置为实际探测到的状态。若配置的timer quiet定时器的时间较短,端口上同时配置了Critical VLAN,则可能会出现设备频繁切换服务器状态的情况,并导致端口反复加入并离开Critical VLAN。
# 设置RADIUS方案radius1的主认证/授权服务器的IP地址为10.110.1.1,使用UDP端口1812提供RADIUS认证/授权服务,认证/授权报文的共享密钥为明文hello。
[Sysname-radius-radius1] primary authentication 10.110.1.1 1812 key hello
# 设置对RADIUS方案radius1中的主认证/授权服务器状态进行探测时使用的用户名为test,探测周期为120分钟。
[Sysname-radius-radius1] primary authentication 10.110.1.1 probe username test interval 120
radius client enable
undo radius client
【缺省级别】
2:系统级
【描述】
radius client enable命令用来使能RADIUS客户端的监听端口,使能后的端口可以接收和发送RADIUS报文。undo radius client命令用来关闭RADIUS客户端的监听端口。
缺省情况下,监听端口处于使能状态。
需要注意的是,关闭RADIUS客户端的监听端口后:
·     在线用户的计费结束报文无法发出,也不能被缓存下来尝试继续发送。RADIUS服务器因为收不到在线用户的下线报文,会出现有一段时间用户已经下线,但RADIUS服务器上还有此用户的情况。另外,已缓存的计费报文会发送失败,如果发送失败的次数达到配置的最大次数后,仍然没有收到响应,计费报文将从缓存中被删除。计费报文的发送失败,都会直接影响用户计费信息的准确性。
·     如果配置了本地认证/授权/计费作为备份方法,则RADIUS请求失败后会转由设备本地继续认证/授权/计费,其中本地计费只是为了支持本地用户的连接数管理,没有实际的计费相关的统计功能。
# 使能RADIUS客户端的监听端口。
[Sysname] radius client enable
1.3.13  radius dscp
radius dscp dscp-value
undo radius dscp
【缺省级别】
2:系统级
dscp-value:报文的DSCP优先级,取值范围为0~63。
【描述】
radius dscp命令用来配置IPv4 RADIUS报文的DSCP优先级。undo radius dscp命令用来恢复缺省情况。
缺省情况下,IPv4 RADIUS报文的DSCP优先级为0。
# 配置IPv4 RADIUS报文的DSCP优先级为6。
[Sysname] radius dscp 6
radius ipv6 dscp dscp-value
undo radius ipv6 dscp
【缺省级别】
2:系统级
【描述】
radius ipv6 dscp命令用来配置IPv6 RADIUS报文的DSCP优先级。undo radius ipv6 dscp命令用来恢复缺省情况。
缺省情况下,IPv6 RADIUS报文的DSCP优先级为0。
# 配置IPv6 RADIUS报文的DSCP优先级为6。
[Sysname] radius ipv6 dscp 6
radius nas-backup-ip ip-address [ vpn-instance vpn-instance-name ]
undo radius nas-backup-ip
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:指定私网备份源IP地址所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网备份源地址。
【描述】
radius nas-backup-ip命令用来设置设备发送RADIUS报文使用的备份源IP地址。undo radius nas-backup-ip命令用来恢复缺省情况。
·     设置发送RADIUS报文使用的备份源IP地址,可以保证双机热备环境中主设备发生故障时,服务器发送的报文可以被备份设备收到并进行处理。
·     系统最多允许指定1个公网备份源地址和15个私网备份源地址。新配置的公网备份源地址会覆盖原有的公网备份源地址。而且,每一个VPN只能指定一个私网备份源地址,新配置会覆盖原有配置。
相关配置可参考命令nas-backup-ip
[Sysname] radius nas-ip 2.2.2.2
[Sysname] radius nas-backup-ip 3.3.3.3
在对端设备上,应该设置设备发送RADIUS报文使用的源IP地址为3.3.3.3,备份源IP为2.2.2.2。
radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
undo radius nas-ip { ipv4-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ]
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:指定私网源IPv4地址所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网源地址。
【描述】
radius nas-ip命令用来指定设备发送RADIUS报文使用的源地址。undo radius nas-ip命令用来删除指定的源地址。
缺省情况下,不指定源地址,即以发送报文的接口地址作为源地址。
·     系统最多允许指定1个公网源地址和15个私网源地址。新配置的公网源地址会覆盖原有的公网源地址。而且,每一个VPN只能指定一个私网源地址,新配置会覆盖原有配置。
相关配置可参考命令nas-ip
# 配置设备发送RADIUS报文使用的源地址为129.10.10.1。
[Sysname] radius nas-ip 129.10.10.1
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
【缺省级别】
3:管理级
radius-scheme-name:RADIUS方案名,为1~32个字符的字符串,不区分大小写。
【描述】
radius scheme命令用来创建RADIUS方案并进入其视图。undo radius scheme命令用来删除指定的RADIUS方案。
缺省情况下,未定义RADIUS方案。
·     一个RADIUS方案可以同时被多个ISP域引用。
·     不允许使用undo radius scheme命令删除被ISP域引用的RADIUS方案。
# 创建名为radius1的RADIUS方案并进入其视图。
1.3.18  radius trap
radius trap { accounting-server-down | authentication-error-threshold | authentication-server-down }
undo radius trap { accounting-server-down | authentication-error-threshold | authentication-server-down }
【缺省级别】
2:系统级
accounting-server-down:表示RADIUS计费服务器可达状态改变时发送Trap信息。
authentication-error-threshold:表示认证失败次数超过阈值时发送Trap信息。该阈值为认证失败次数占认证请求总数的百分比数值,目前仅能通过MIB方式配置,取值范围为1~100,缺省为30。
authentication-server-down:表示RADIUS认证服务器可达状态改变时发送Trap信息。
【描述】
radius trap命令用来使能RADIUS Trap功能。undo radius trap命令用来关闭指定的RADIUS Trap功能。
缺省情况下,RADIUS Trap功能处于关闭状态。
使能RADIUS服务器可达状态改变时的Trap功能后,Trap信息的发送包括以下两种情况:
·     当NAS向RADIUS服务器发送计费或认证请求没有响应时,会重传请求,当重传次数达到最大传送次数时仍然没有响应时,NAS认为该服务器不可达,并发送Trap信息。
·     当NAS收到处于不可达状态的RADIUS服务器发送的报文时,则认为该服务器可达,并发送一次Trap报文。
使能认证失败次数超过阈值时的Trap功能后,当NAS发现认证失败次数与认证请求总数的百分比超过阈值时,系统会发送一次Trap报文。
# 使能RADIUS计费服务器可达状态改变时的 Trap功能。
[Sysname] radius trap accounting-server-down
reset radius statistics [ slot slot-number ]
【缺省级别】
2:系统级
slot slot-number:清除指定成员设备上的RADIUS协议的统计信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
reset radius statistics命令用来清除RADIUS协议的统计信息。
相关配置请参考命令display radius statistics
# 清除RADIUS协议的统计信息。
<Sysname> reset radius statistics
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name } [ slot slot-number ]
【缺省级别】
2:系统级
radius-scheme radius-scheme-name:根据指定RADIUS方案清除缓存的停止计费响应报文。其中,radius-scheme-name为RAIUDS方案名,为1~32个字符的字符串。
session-id session-id:根据指定会话ID清除缓存的停止计费响应报文。其中,session-id为会话ID,为1~50个字符的字符串。
time-range start-time stop-time:根据指定停止计费请求时刻的起始和结束时间清除缓存的停止计费响应报文。其中,start-time为请求时间段的起始时间;stop-time为请求时间段的结束时间,格式为hh:mm:ss-mm/dd/yyyy(时:分:秒-月/日/年)或hh:mm:ss-yyyy/mm/dd(时:分:秒-年/月/日)。
user-name user-name:根据指定用户名清除缓存的停止计费响应报文。其中,user-name表示用户名,为1~80个字符的字符串,区分大小写。输入的用户名是否携带ISP域名,必须与RADIUS方案中配置的发送给RADIUS服务器的用户名格式保持一致。
slot slot-number:清除指定成员设备上的停止计费响应报文,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
reset stop-accounting-buffer命令用来清除缓存中的没有得到响应的停止计费请求报文。
相关配置可参考命令stop-accounting-buffer enabledisplay stop-accounting-buffer
# 清除用户user0001@test缓存在系统中的停止计费请求报文。
<Sysname> reset stop-accounting-buffer user-name user0001@test
# 清除从2011年3月31日0点0分0秒到2011年3月31日23点59分59秒期间内系统缓存的停止计费请求报文。
<Sysname> reset stop-accounting-buffer time-range 0:0:0-03/31/2011 23:59:59-03/31/2011
1.3.21  retry
retry retry-times
undo retry
RADIUS方案视图
【缺省级别】
2:系统级
retry-times:发送RAIUDS报文的最大尝试次数,取值范围为1~20。
【描述】
retry命令用来设置发送RADIUS报文的最大尝试次数,即由于某RADIUS服务器未响应或未及时响应设备发送的RAIUDS报文,设备尝试向该服务器发送RADIUS报文的最大次数。undo retry命令用来恢复缺省情况。
缺省情况下,发送RADIUS报文的最大尝试次数为3次。
·     由于RADIUS协议采用UDP报文来承载数据,因此其通信过程是不可靠的。如果RADIUS服务器在应答超时定时器规定的时长内没有响应设备,则设备有必要向RADIUS服务器重传RADIUS请求报文。如果累计的传送次数超过最大传送次数而RADIUS服务器仍旧没有响应,则设备将认为本次请求失败。
·     发送RADIUS报文的最大尝试次数与RADIUS服务器应答超时时间的乘积不能超过75秒。
相关配置可参考命令radius schemetimer response-timeout
# 设置在RADIUS方案radius1下,发送RAIUDS报文的最大尝试次数为5次。
[Sysname-radius-radius1] retry 5
retry realtime-accounting retry-times
undo retry realtime-accounting
RADIUS方案视图
【缺省级别】
2:系统级
retry-times:允许实时计费请求无响应的最大次数,取值范围为1~255。
【描述】
retry realtime-accounting命令用来设置允许实时计费请求无响应的最大次数。undo retry realtime-accounting命令用来恢复缺省情况。
缺省情况下,设备最多允许5次实时计费请求无响应,之后将切断用户连接。
RADIUS服务器通常通过连接超时定时器来判断用户是否在线。如果RADIUS服务器在连接超时时间之内一直收不到设备传来的实时计费报文,它会认为线路或设备故障并停止对用户记帐。为了配合RADIUS服务器的这种特性,有必要在不可预见的故障条件下,尽量保持设备端与RADIUS服务器同步切断用户连接。设备提供对实时计费请求连续无响应次数限制的设置,保证在设备向RADIUS服务器发出的实时计费请求没有得到响应的次数超过所设定的限度时,设备才会切断用户连接。
假设RADIUS服务器的应答超时时长(timer response-timeout命令设置)为3秒,发送RADIUS报文的最大尝试次数(retry命令设置)为3,设备的实时计费间隔(timer realtime-accounting命令设置)为12分钟,设备允许实时计费无响应的最大次数为5次(retry realtime-accounting命令设置),则其含义为:设备每隔12分钟发起一次计费请求,如果3秒钟得不到回应就重新发起一次请求,如果3次发送都没有得到回应就认为该次实时计费失败,然后每隔12分钟再发送一次,5次均失败以后,设备将切断用户连接。
相关配置可参考命令retrytimer response-timeouttimer realtime-accounting
# 设置RADIUS方案radius1最多允许10次实时计费请求无响应。
[Sysname-radius-radius1] retry realtime-accounting 10
retry stop-accounting retry-times
undo retry stop-accounting
RADIUS方案视图
【缺省级别】
2:系统级
retry-times:允许停止计费请求无响应的最大次数,取值范围为10~65535。
【描述】
retry stop-accounting命令用来设置发起停止计费请求的最大尝试次数。undo retry stop-accounting命令用来恢复缺省情况。
缺省情况下,发起停止计费请求的最大尝试次数为500。
假设RADIUS服务器的应答超时时长(timer response-timeout命令设置)为3秒,发送RADIUS报文的最大尝试次数(retry命令设置)为5,设备允许的停止计费请求无响应的最大次数为20次(retry stop-accounting命令设置),则其含义为:设备发起停止计费请求,如果3秒钟内得不到回应就重新发起一次请求,如果尝试5次都没有得到回应就认为该次停止计费请求失败,设备会将其缓存在本机上,然后再发起一次请求,重复上述过程,20次尝试均失败以后,设备将其丢弃。
相关配置可参考命令retryretry stop-accountingtimer response-timeoutdisplay stop-accounting-buffer
# 在RADIUS方案radius1中,设置设备最多可以尝试向该方案中的服务器发起1000次停止计费请求。
[Sysname-radius-radius1] retry stop-accounting 1000
secondary accounting { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo secondary accounting [ ipv4-address | ipv6 ipv6-address ]
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:从RADIUS计费服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS计费服务器的IPv6地址。
port-number:从RADIUS计费服务器的UDP端口号,缺省为1813,取值范围为1~65535。此端口号必须与服务器提供计费服务的端口号保持一致。
key [ cipher | simple ] key:与从RADIUS计费服务器交互的计费报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
·     不指定ciphersimple时,表示以明文方式设置共享密钥。
vpn-instance vpn-instance-name:从RADIUS计费服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS计费服务器位于公网中。
【描述】
secondary accounting命令用来配置从RADIUS计费服务器。undo secondary accounting命令用来删除指定的从RADIUS计费服务器。
缺省情况下,未配置从计费服务器。
·     可通过多次执行本命令,配置多个从RADIUS计费服务器,当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。每个RADIUS方案中最多支持配置16个从RADIUS计费服务器。
·     从RADIUS计费服务器的IP地址协议版本与主RADIUS计费服务器必须一致,并且各从RADIUS计费服务器的IP地址协议版本也必须一致。
·     主计费服务器和从计费服务器的IP地址不能相同,并且各从计费服务器的IP地址也不能相同。
·     设备与从计费服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key accounting [ cipher | simple ] key命令设置的共享密钥。
·     若设备与MPLS VPN私网服务器通信,为保证RADIUS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例名称。本命令指定的服务器所属的VPN比RADIUS方案所属的VPN优先级高。
·     计费服务器与认证服务器的IP地址协议版本必须一致。
·     如果在发送计费开始请求过程中删除了从服务器,则设备在与当前服务器通信超时后,将会重新从主服务器开始依次查找状态为active的服务器进行通信。
相关配置可参考命令keystatevpn-instance (RADIUS scheme view)。
# 设置RADIUS方案radius2的从计费服务器:IP地址分别为10.110.1.1,10.110.1.2,均使用UDP端口1813提供RADIUS计费服务,计费报文的共享密钥为明文hello。
[Sysname] radius scheme radius2
[Sysname-radius-radius2] secondary accounting 10.110.1.1 1813 key hello
[Sysname-radius-radius2] secondary accounting 10.110.1.2 1813 key hello
secondary authentication { ipv4-address | ipv6 ipv6-address } [ port-number | key [ cipher | simple ] key  | probe username name [ interval interval ] | vpn-instance vpn-instance-name ] *
undo secondary authentication [ ipv4-address | ipv6 ipv6-address ]
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:从RADIUS认证/授权服务器的IPv4地址。
ipv6 ipv6-address:从RADIUS认证/授权服务器的IPv6地址。
port-number:从RADIUS认证/授权服务器的UDP端口号,缺省为1812,取值范围为1~65535。此端口号必须与服务器提供认证/授权服务的端口号保持一致。
key [ cipher | simple ] key:从RADIUS认证/授权服务器的认证/授权报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
probe:开启对从RADIUS认证/授权服务器状态的探测功能。
username name:设置探测从RADIUS认证/授权服务器状态时认证报文中使用的用户名。该用户名并不要求是认证/授权服务器上存在的用户名。
interval interval:设置探测从RADIUS认证/授权服务器是否可达的时间间隔,取值范围为1~3600,单位为分钟,缺省值为60。
vpn-instance vpn-instance-name:从RADIUS认证/授权服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从RADIUS认证/授权服务器位于公网中。
【描述】
secondary authentication命令用来配置从RADIUS认证/授权服务器。undo secondary authentication命令用来删除指定的从RADIUS认证/授权服务器。
缺省情况下,未配置从认证/授权服务器。
·     可通过多次执行本命令,配置多个从RADIUS认证/授权服务器,当主服务器不可达时,设备根据从服务器的配置顺序由先到后查找状态为active的从服务器并与之交互。每个RADIUS方案中最多支持配置16个从RADIUS计费服务器。
·     主认证/授权服务器和从认证/授权服务器的IP地址协议版本必须一致,并且各从RADIUS认证/授权服务器的IP地址协议版本也必须一致。
·     主认证/授权服务器和从认证/授权服务器的IP地址不能相同,并且各从认证服务器的IP地址不能相同。
·     设备与从认证/授权服务器通信时优先使用本命令设置的共享密钥,如果此处未设置,则使用命令key authentication [ cipher | simple ] key命令设置的共享密钥。
·     如果在认证过程中使用本命令删除了从认证服务器,则设备在与当前服务器通信超时后,将会重新从主服务器开始依次查找状态为active的服务器进行通信。
# 设置RADIUS方案radius2的从认证/授权服务器:IP地址分别为10.110.1.1,10.110.1.2,均使用UDP端口1812提供RADIUS认证/授权服务,认证/授权报文的共享密钥为明文hello。
[Sysname-radius-radius2] secondary authentication 10.110.1.1 1812 key simple hello
[Sysname-radius-radius2] secondary authentication 10.110.1.2 1812 key simple hello
# 设置对RADIUS方案radius1中的从认证/授权服务器状态进行探测时使用的用户名为test,探测周期为120分钟。
[Sysname-radius-radius1] secondary authentication 10.110.1.1 probe username test interval 120
1.3.26  security-policy-server
security-policy-server { ipv4-address | ipv6 ipv6-address }
undo security-policy-server { ipv4-address | all | ipv6 ipv6-address }
RADIUS方案视图
【缺省级别】
2:系统级
ipv4-address:安全策略服务器IPv4地址。
ipv6-address:安全策略服务器IPv6地址。
all:所有安全策略服务器。
【描述】
security-policy-server命令用来指定安全策略服务器。undo security-policy-server命令用来删除指定的安全策略服务器。
缺省情况下,未指定安全策略服务器。
需要注意的是:只有当该RADIUS方案没有被用户使用时,才能改变此配置。
# 指定RADIUS方案radius1的安全策略服务器IP地址为10.110.1.2。
[Sysname-radius-radius1] security-policy-server 10.110.1.2
1.3.27  server-type
server-type { extended [ vendor vendor-id ] | standard }
undo server-type
RADIUS方案视图
【缺省级别】
2:系统级
extended:指定extended类型的RADIUS服务器(一般为CAMS/iMC),即要求RADIUS客户端和RADIUS服务器按照私有RADIUS协议的规程和报文格式进行交互。
vendor vendor-id:厂商标识号码,取值范围为1~65535。目前设备支持的vendor-id包括:9、43、311、2011、25506。若未指定本参数,则表示设备可以向RADIUS服务器发送设备支持的所有厂商的Vendor-Specific属性。仅Release 2112及以上版本支持本参数。
standard:指定standard类型的RADIUS服务器,即要求RADIUS客户端和RADIUS服务器按照标准RADIUS协议(RFC 2865/2866或更新)的规程和报文格式进行交互。
【描述】
server-type命令用来配置设备支持的RADIUS服务器类型。undo server-type命令用来恢复缺省情况。
缺省情况下,设备支持的RADIUS服务器类型为standard
如果配置本命令时指定了vendor参数,则表示设备向RADIUS服务器发送的Vendor-Specific属性只能为指定厂商的Vendor-Specific属性。
# 将RADIUS方案radius1的RADIUS服务器类型设置为standard
[Sysname-radius-radius1] server-type standard
1.3.28  state primary
state primary { accounting | authentication } { active | block }
RADIUS方案视图
【缺省级别】
2:系统级
accounting:设置主RADIUS计费服务器的状态。
authentication:设置主RADIUS认证/授权服务器的状态。
active:设置主RADIUS服务器的状态为active,即处于正常工作状态。
block:设置主RADIUS服务器的状态为block,即处于通信中断状态。
【描述】
state primary命令用来设置主RADIUS服务器的状态。
缺省情况下,RADIUS方案中配置了IP地址的主RADIUS服务器状态为active
·     每次用户发起认证或计费,如果主服务器状态为active,则设备都会首先尝试与主服务器进行通信,如果主服务器不可达,则将主服务器的状态置为block,同时启动主服务器的timer quiet定时器,然后设备会严格按照从服务器的配置先后顺序依次查找状态为active的从服务器进行通信。在timer quiet定时器设定的时间到达之后,主服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将主服务器的状态手工设置为block,则定时器超时之后主服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active
·     如果主服务器与所有从服务器状态都是block,则默认使用主服务器进行认证或计费。
相关配置可参考命令display radius schemestate secondary
# 将RADIUS方案radius1的主认证服务器的状态设置为block
[Sysname-radius-radius1] state primary authentication block
1.3.29  state secondary
state secondary { accounting | authentication } [ ip ipv4-address | ipv6 ipv6-address ] { active | block }
RADIUS方案视图
【缺省级别】
2:系统级
accounting:设置从RADIUS计费服务器的状态。
authentication:设置从RADIUS认证/授权服务器的状态。
ip ipv4-address:指定从RADIUS服务器的IPv4地址。
ipv6 ipv6-address:指定从RADIUS服务器的IPv6地址。
active:设置从RADIUS服务器的状态为active,即处于正常工作状态。
block:设置从RADIUS服务器的状态为block,即处于通信中断状态。
【描述】
state secondary命令用来设置从RADIUS服务器的状态。
缺省情况下,RADIUS方案中配置了IP地址的各从RADIUS服务器状态为active
·     如果不指定从服务器IP地址,那么本命令将会修改所有已配置的从认证/授权服务器或从计费服务器的状态。
·     如果设备查找到的状态为active的从服务器不可达,则设备会将该从服务器的状态置为block,同时启动该服务器的timer quiet定时器,并继续查找下一个状态为active的从服务器。在timer quiet定时器设定的时间到达之后,从服务器状态将由block恢复为active。若该定时器超时之前,通过本命令将从服务器的状态手工设置为block,则定时器超时之后从服务器状态不会自动恢复为active,除非通过本命令手工将其设置为active。如果所有已配置的从服务器都不可达,则本次认证或计费失败。
相关配置可参考命令display radius schemestate primary
# 将RADIUS方案radius1的从认证服务器的状态设置为block
[Sysname-radius-radius1] state secondary authentication block
1.3.30  stop-accounting-buffer enable (RADIUS scheme view)
undo stop-accounting-buffer enable
RADIUS方案视图
【缺省级别】
2:系统级
【描述】
stop-accounting-buffer enable命令用来允许在设备上缓存没有得到响应的停止计费请求报文。undo stop-accounting-buffer enable命令用来禁止在设备上缓存没有得到响应的停止计费请求报文。
缺省情况下,允许设备缓存没有得到响应的停止计费请求报文。
由于停止计费请求报文涉及到话单结算、并最终影响收费多少,对用户和ISP都有比较重要的影响,因此设备应该尽最大努力把它发送给RADIUS计费服务器。所以,如果RADIUS计费服务器对设备发出的停止计费请求报文没有响应,设备应将其缓存在本机上,然后发送直到RADIUS计费服务器产生响应,或者在发送的次数达到指定的次数限制后将其丢弃。但在计费服务器已被删除的情况下,停止计费报文不会被缓存。
相关配置可参考命令reset stop-accounting-bufferdisplay stop-accounting-buffer
# 指示设备能够缓存没有得到响应的停止计费请求报文。
[Sysname-radius-radius1] stop-accounting-buffer enable
1.3.31  timer quiet (RADIUS scheme view)
timer quiet minutes
undo timer quiet
RADIUS方案视图
【缺省级别】
2:系统级
minutes:恢复激活状态的时间,取值范围为0~255,单位为分钟。当该参数取值为0时,若当前用户使用的认证或计费服务器不可达,则设备并不会切换它的状态,而是保持其为active,并且将使用该服务器的用户认证或计费的报文发送给下一个状态为active的服务器,而后续其它用户的认证请求报文仍然可以发送给该服务器进行处理。
【描述】
timer quiet命令用来设置服务器恢复激活状态的时间。undo timer quiet命令用来恢复缺省情况。
缺省情况下,服务器恢复激活状态的时间为5分钟。
本命令除了可以调节服务器恢复激活状态的时间之外,还可以控制是否对不可达服务器进行状态切换。例如,若判断主服务器不可达是网络端口短暂中断或者服务器忙碌造成的,则可以结合网络的实际运行状况,将服务器的恢复激活时间置为0,使得用户尽可能得集中在主服务器上进行认证和计费。
建议根据配置的从服务器数量合理设置服务器恢复激活状态的时间。如果服务器恢复激活状态时间设置的过短,就会出现设备反复尝试与状态active但实际不可达的服务器通信而导致的认证或计费频繁失败的问题。
# 设置服务器恢复激活状态的时间为10分钟。
[Sysname-radius-radius1] timer quiet 10
1.3.32  timer realtime-accounting (RADIUS scheme view)
timer realtime-accounting minutes
undo timer realtime-accounting
RADIUS方案视图
【缺省级别】
2:系统级
minutes:实时计费的时间间隔,取值范围为0~60,非零取值必须为3的倍数,单位为分钟。0表示设备不向RADIUS服务器发送在线用户的计费信息。
【描述】
timer realtime-accounting命令用来设置实时计费的时间间隔。undo timer realtime-accounting命令用来恢复缺省情况。
缺省情况下,实时计费的时间间隔为12分钟。
·     为了对用户实施实时计费,有必要设置实时计费的时间间隔。在设置了该属性以后,每隔设定的时间,设备会向RADIUS服务器发送一次在线用户的计费信息。
·     当实时计费间隔设置为0时,如果服务器上配置了实时计费间隔,则设备按照服务器上配置的实时计费间隔向RADIUS服务器发送在线用户的计费信息;如果服务器上没有配置该值,则设备不向RADIUS服务器发送在线用户的计费信息。
·     实时计费间隔的取值对设备和RADIUS服务器的性能有一定的相关性要求,取值小,会增加网络中的数据流量,对设备和RADIUS服务器的性能要求就高;取值大,会影响计费的准确性。因此要结合网络的实际情况合理设置计费间隔的大小,一般情况下,建议当用户量比较大(¦1000)时,尽量把该间隔的值设置得大一些。以下是实时计费间隔与用户量之间的推荐比例关系:
表1-7 实时计费间隔与用户量之间的推荐比例关系
用户数
实时计费间隔(分钟)
1~99
3
100~499
6
500~999
12
¦1000
¦15
相关配置可参考命令retry realtime-accounting
# 将RADIUS方案radius1的实时计费的时间间隔设置为51分钟。
[Sysname-radius-radius1] timer realtime-accounting 51
1.3.33  timer response-timeout (RADIUS scheme view)
timer response-timeout seconds
undo timer response-timeout
RADIUS方案视图
【缺省级别】
2:系统级
seconds:RADIUS服务器响应超时时间,取值范围为1~10,单位为秒。
【描述】
timer response-timeout命令用来设置RADIUS服务器响应超时时间。undo timer response-timeout命令用来恢复缺省情况。
缺省情况下,RADIUS服务器响应超时时间为3秒。
如果在RADIUS请求报文(认证/授权请求或计费请求)传送出去一段时间后,设备还没有得到RADIUS服务器的响应,则有必要重传RADIUS请求报文,以保证用户尽可能地获得RADIUS服务,这段时间被称为RADIUS服务器响应超时时长,本命令用于调整这个时长。
需要注意的是,发送RADIUS报文的最大尝试次数与RADIUS服务器响应超时时间的乘积不能超过75秒。
相关配置可参考命令retry
# 将RADIUS方案radius1的响应超时定时器设置为5秒。
[Sysname-radius-radius1] timer response-timeout 5
1.3.34  user-name-format (RADIUS scheme view)
user-name-format { keep-original | with-domain | without-domain }
RADIUS方案视图
【缺省级别】
2:系统级
keep-original:发送给RADIUS服务器的用户名与用户输入的保持一致。
with-domain:发送给RADIUS服务器的用户名带ISP域名。
without-domain:发送给RADIUS服务器的用户名不带ISP域名。
【描述】
user-name-format命令用来设置发送给RADIUS服务器的用户名格式。
缺省情况下,RADIUS方案发送给RADIUS服务器的用户名携带有ISP域名。
·     接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些较早期的RADIUS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给RADIUS服务器。因此,设备提供此命令以指定发送给RADIUS服务器的用户名是否携带有ISP域名。
·     如果指定某个RADIUS方案不允许用户名中携带有ISP域名,那么请不要在两个乃至两个以上的ISP域中同时设置使用该RADIUS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但RADIUS服务器认为用户相同(因为传送到它的用户名相同)的错误。
·     在802.1X用户采用EAP认证方式的情况下,RADIUS方案中配置的user-name-format命令无效,客户端传送给RADIUS服务器的用户名不会有改动。
# 指定发送给RADIUS方案radius1中RADIUS服务器的用户名不得携带域名。
[Sysname-radius-radius1] user-name-format without-domain
1.3.35  vpn-instance (RADIUS scheme view)
undo vpn-instance
RADIUS方案视图
【缺省级别】
2:系统级
vpn-instance-name:MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
【描述】
vpn-instance命令用来配置RADIUS方案所属的VPN。undo vpn-instance命令用来取消RADIUS方案所属的VPN。
·     本命令配置的VPN对于该方案下的所有IPv4协议的RADIUS认证/授权/计费服务器生效,但设备优先使用配置RADIUS认证/授权/计费服务器时为各服务器单独指定的VPN。
·     目前,本命令指定的VPN对于IPv6协议的RADIUS认证/授权/计费服务器不生效。
# 配置RADIUS方案radius1所属的VPN为test。
[Sysname-radius-radius1] vpn-instance test
1.4  HWTACACS配置命令
1.4.1  data-flow-format (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
data:设置数据流的单位。
·     byte:数据流的单位为字节。
packet:设置数据包的单位。
【描述】
data-flow-format命令用来配置发送到HWTACACS服务器的数据流的单位。undo data-flow-format命令用来恢复缺省情况。
缺省情况下,数据的单位为byte,数据包的单位为one-packet
需要注意的是,设备上配置的发送给HWTACACS服务器的数据流单位及数据包单位应与HWTACACS服务器上的流量统计单位保持一致,否则无法正确计费。
相关配置可参考命令display hwtacacs
# 在HWTACACS方案hwt1中,设置发往HWTACACS服务器的数据流的数据单位为kilo-byte、数据包的单位为kilo-packet
[Sysname] hwtacacs scheme hwt1
[Sysname-hwtacacs-hwt1] data-flow-format data kilo-byte packet kilo-packet
1.4.2  display hwtacacs
display hwtacacs [ hwtacacs-scheme-name [ statistics ] ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
hwtacacs-scheme-name:指定HWTACACS方案名。
statistics:显示HWTACACS服务器的统计信息。不指定该参数,则显示HWTACACS方案的配置信息。
slot slot-number:显示指定成员设备上的HWTACACS方案的配置信息或统计信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display hwtacacs命令用来查看HWTACACS方案的配置信息或HWTACACS服务器的统计信息。
需要注意的是:如果不指定HWTACACS方案名,则显示所有HWTACACS方案的配置信息。
相关配置请参考命令hwtacacs scheme
# 查看HWTACACS方案gy的配置情况。
<Sysname> display hwtacacs gy
  HWTACACS-server template name     : gy
  Primary-authentication-server     : 172.31.1.11:49
  VPN instance                      : vpn1
  Primary-authorization-server      : 172.31.1.11:49
  VPN instance                      : vpn1
  Primary-accounting-server         : 172.31.1.11:49
  VPN instance                      : vpn1
  Secondary-authentication-server   : 0.0.0.0:0
  VPN instance                      : -
  Secondary-authorization-server    : 0.0.0.0:0
  VPN instance                      : -
  Secondary-accounting-server       : 0.0.0.0:0
  VPN instance                      : -
  Current-authentication-server     : 172.31.1.11:49
  Current-authorization-server      : 172.31.1.11:49
  Current-accounting-server         : 172.31.1.11:49
  NAS-IP-address                    : 0.0.0.0
  key authentication                : ******
  key authorization                 : ******
  key accounting                    : ******
  VPN instance                      : -
  Realtime-accounting-interval(min) : 12
  Response-timeout-interval(sec)    : 5
  Acct-stop-PKT retransmit times    : 100
  Username format                   : with-domain
  Data traffic-unit                 : B
  Packet traffic-unit               : one-packet
表1-8 display hwtacacs命令显示信息描述表
HWTACACS服务器方案名
主认证服务器IP地址/接入端口号
未配置主认证服务器时,IP地址/接入端口号显示为0.0.0.0:0。下面各服务器同理显示
主授权服务器IP地址/接入端口号
主计费服务器IP地址/接入端口号
从认证服务器IP地址/接入端口号
从授权服务器IP地址/接入端口号
从计费服务器IP地址/接入端口号
当前认证服务器IP地址/接入端口号
当前授权服务器IP地址/接入端口号
当前计费服务器IP地址/接入端口号
VPN instance
服务器所属的MPLS L3VPN
NAS-IP-address
NAS的IP地址
未指定NAS的IP地址时,此处显示为0.0.0.0
key authentication
认证密钥
·     已配置时,显示为******
·     未配置时,显示为-
key authorization
授权密钥
·     已配置时,显示为******
·     未配置时,显示为-
key accounting
计费密钥
·     已配置时,显示为******
·     未配置时,显示为-
Quiet-interval
主服务器恢复激活状态的时间
实时计费间隔
服务器响应超时间隔
停止计费报文的重传次数
Username format
发送给HWTACACS服务器的用户名格式
Data traffic-unit
数据流量单位
Packet traffic-unit
包流量单位
# 查看HWTACACS方案gy中各服务器的统计信息。
<Sysname> display hwtacacs gy statistics
Slot: 1
---[HWTACACS template gy primary authentication]---
HWTACACS server open number: 10
HWTACACS server close number: 10
HWTACACS authen client access request packet number: 10
HWTACACS authen client access response packet number: 6
HWTACACS authen client unknown type number: 0
HWTACACS authen client timeout number: 4
HWTACACS authen client packet dropped number: 4
HWTACACS authen client access request change password number: 0
HWTACACS authen client access request login number: 5
HWTACACS authen client access request send authentication number: 0
HWTACACS authen client access request send password number: 0
HWTACACS authen client access connect abort number: 0
HWTACACS authen client access connect packet number: 5
HWTACACS authen client access response error number: 0
HWTACACS authen client access response failure number: 0
HWTACACS authen client access response follow number: 0
HWTACACS authen client access response getdata number: 0
HWTACACS authen client access response getpassword number: 5
HWTACACS authen client access response getuser number: 0
HWTACACS authen client access response pass number: 1
HWTACACS authen client access response restart number: 0
HWTACACS authen client malformed access response number: 0
HWTACACS authen client round trip time(s): 5
---[HWTACACS template gy primary authorization]---
HWTACACS author client request packet number: 1
HWTACACS author client response packet number: 1
HWTACACS author client timeout number: 0
HWTACACS author client packet dropped number: 0
HWTACACS author client unknown type number: 0
HWTACACS author client request EXEC number: 1
HWTACACS author client response error number: 0
HWTACACS author client response EXEC number: 1
HWTACACS author client round trip time(s): 3
---[HWTACACS template gy primary accounting]---
HWTACACS server open number: 0
HWTACACS server close number: 0
HWTACACS account client request packet number: 0
HWTACACS account client response packet number: 0
HWTACACS account client unknown type number: 0
HWTACACS account client timeout number: 0
HWTACACS account client packet dropped number: 0
HWTACACS account client request command level number: 0
HWTACACS account client request connection number: 0
HWTACACS account client request EXEC number: 0
HWTACACS account client request network number: 0
HWTACACS account client request system event number: 0
HWTACACS account client request update number: 0
HWTACACS account client response error number: 0
HWTACACS account client round trip time(s): 0
1.4.3  display stop-accounting-buffer (for HWTACACS)
display stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
hwtacacs-scheme hwtacacs-scheme-name:根据指定HWTACACS方案显示缓存的停止计费请求报文。其中,hwtacacs-scheme-name为HWTACACS方案名,为1~32个字符的字符串。
slot slot-number:显示指定成员设备上缓存的停止计费请求报文,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display stop-accounting-buffer命令用来显示缓存的没有得到响应的停止计费请求报文。
相关配置可参考命令reset stop-accounting-bufferstop-accounting-buffer enableretry stop-accounting
# 显示HWTACACS方案hwt1缓存的停止计费请求报文。
<Sysname> display stop-accounting-buffer hwtacacs-scheme hwt1
  Slot  1:
Total 0 record(s) Matched
1.4.4  hwtacacs nas-ip
hwtacacs nas-ip ip-address [ vpn-instance vpn-instance-name ]
undo hwtacacs nas-ip ip-address [ vpn-instance vpn-instance-name ]
【缺省级别】
2:系统级
ip-address:指定的源IP地址,应该为本机的地址,禁止配置全0地址、全1地址、D类地址、E类地址和环回地址。
vpn-instance vpn-instance-name:指定私网源IP地址所属的VPN。MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示配置的是公网源地址。
【描述】
hwtacacs nas-ip命令用来指定设备发送HWTACACS报文使用的源地址。undo hwtacacs nas-ip命令用来删除指定的源地址。
·     HWTACACS服务器上通过IP地址来标识接入设备,并根据收到的HWTACACS报文的源IP地址是否与服务器所管理的接入设备的IP地址匹配,来决定是否处理来自该接入设备的认证或计费请求。因此,为保证认证和计费报文可被服务器正常接收并处理,接入设备上发送HWTACACS报文使用的源地址必须与HWTACACS服务器上指定的接入设备的IP地址保持一致。
·     HWTACACS方案视图下的命令nas-ip只对本HWTACACS方案有效,系统视图下的命令hwtacacs nas-ip对所有HWTACACS方案有效。HWTACACS方案视图下的设置具有更高的优先级。
相关配置可参考命令nas-ip
# 配置设备发送HWTACACS报文使用的源地址为129.10.10.1。
[Sysname] hwtacacs nas-ip 129.10.10.1
1.4.5  hwtacacs scheme
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
【缺省级别】
3:管理级
hwtacacs-scheme-name:HWTACACS方案名称,为1~32个字符的字符串,不区分大小写。
【描述】
hwtacacs scheme命令用来创建HWTACACS方案并进入其视图。undo hwtacacs scheme命令用来删除指定的HWTACACS方案。
缺省情况下,没有定义HWTACACS方案。
·     一个HWTACACS方案可以同时被多个ISP域引用。
·     不允许使用undo hwtacacs scheme命令删除被ISP域引用的HWTACACS方案。
# 创建名为hwt1的HWTACACS方案并进入相应的HWTACACS视图。
1.4.6  key (HWTACACS scheme view)
key { accounting | authentication | authorization } [ cipher | simple ] key
undo key { accounting | authentication | authorization }
HWTACACS方案视图
【缺省级别】
2:系统级
accounting:配置HWTACACS计费报文的共享密钥。
authentication:配置HWTACACS认证报文的共享密钥。
authorization:配置HWTACACS授权报文的共享密钥。
key:设置的明文密钥或密文密钥,区分大小写。非FIPS模式下,明文密钥为1~255个字符的字符串;密文密钥为1~373个字符的字符串;FIPS模式下,明文密钥为8~255个字符的字符串,且密钥元素的最少组合类型为4(必须包括数字、大写字母、小写字母以及特殊字符);密文密钥为8~373个字符的字符串。不指定simplecipher时,表示以明文方式设置共享密钥。
【描述】
key命令用来配置HWTACACS认证、授权、计费报文的共享密钥。undo key命令用来删除配置。
缺省情况下,无共享密钥。
必须保证设备上设置的共享密钥与HWTACACS服务器上的完全一致。
# 配置HWTACACS计费报文共享密钥为明文hello。
[Sysname-hwtacacs-hwt1] key accounting simple hello
[Sysname-hwtacacs-hwt1] key accounting hello
1.4.7  nas-ip (HWTACACS scheme view)
nas-ip ip-address
undo nas-ip
HWTACACS方案视图
【缺省级别】
2:系统级
【描述】
nas-ip命令用来指定设备发送HWTACACS报文使用的源地址。undo nas-ip命令用来恢复缺省情况。
缺省情况下,使用系统视图下由命令hwtacacs nas-ip指定的源地址,若系统视图下未指定源地址,则使用发送HWTACACS报文的接口的IP地址。
相关配置可参考命令hwtacacs nas-ip
# 配置设备发送HWTACACS报文使用的源IP地址为10.1.1.1。
[Sysname-hwtacacs-hwt1] nas-ip 10.1.1.1
1.4.8  primary accounting (HWTACACS scheme view)
primary accounting ip-address [ port-number  | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:主HWTACACS计费服务器的IP地址。
port-number:主HWTACACS计费服务器的TCP端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供计费服务的端口号保持一致。
key [ cipher | simple ] key:设置与主HWTACACS计费服务器交互的计费报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
·     cipher key:以密文方式设置共享密钥。key为1~373个字符的字符串,区分大小写。
·     simple key:以明文方式设置共享密钥。key为1~255个字符的字符串,区分大小写。
FIPS模式下:
·     cipher key:以密文方式设置共享密钥。key为8~373个字符的字符串,区分大小写。
·     simple key:以明文方式设置共享密钥。key为8~255个字符的字符串,区分大小写,且必须包括四种类型的密钥元素(大写字母、小写字母、数字、特殊字符)。
vpn-instance vpn-instance-name:主HWTACACS计费服务器所属的VPN。MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS计费服务器位于公网中。
【描述】
primary accounting命令用来配置主HWTACACS计费服务器。undo primary accounting命令用来删除配置的主HWTACACS计费服务器。
缺省情况下,未配置主计费服务器。
·     主计费服务器和从计费服务器的IP地址不能相同。
·     若设备与MPLS VPN私网服务器通信,为保证HWTACACS报文被发送到指定的私网服务器,必须指定服务器所属的VPN实例名称。本命令指定的服务器所属的VPN比HWTACACS方案所属的VPN优先级高。
·     只有在设备与计费服务器没有报文交互时,才允许删除该服务器。计费服务器删除后,只对之后的计费过程有影响。
相关配置可参考命令display hwtacacsvpn-instance (HWTACACS scheme view)。
# 配置主HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49提供HWTACACS计费服务。
[Sysname] hwtacacs scheme test1
[Sysname-hwtacacs-test1] primary accounting 10.163.155.12 49
1.4.9  primary authentication (HWTACACS scheme view)
primary authentication ip-address [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:主HWTACACS认证服务器的IP地址。
port-number:主HWTACACS认证服务器的TCP端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供认证服务的端口号保持一致。
key [ cipher | simple ] key:设置与主HWTACACS认证服务器交互的认证报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
FIPS模式下:
vpn-instance vpn-instance-name:主HWTACACS认证服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS认证服务器位于公网中。
【描述】
primary authentication命令用来配置主HWTACACS认证服务器。undo primary authentication命令用来删除配置的主HWTACACS认证服务器。
缺省情况下,未配置主认证服务器。
·     主认证服务器和从认证服务器的IP地址不能相同。
·     只有在设备与认证服务器没有报文交互时,才允许删除该服务器。认证服务器删除后,只对之后的认证过程有影响。
# 配置主HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49提供HWTACACS认证服务。
[Sysname-hwtacacs-hwt1] primary authentication 10.163.155.13 49
1.4.10  primary authorization
primary authorization ip-address [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo primary authorization
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:主HWTACACS授权服务器的IP地址。
port-number:主HWTACACS授权服务器的TCP端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供授权服务的端口号保持一致。
key [ cipher | simple ] key:设置与主HWTACACS授权服务器交互的授权报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
FIPS模式下:
vpn-instance vpn-instance-name:主HWTACACS授权服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示主HWTACACS授权服务器位于公网中。
【描述】
primary authorization命令用来配置主HWTACACS授权服务器。undo primary authorization命令用来删除配置的主HWTACACS授权服务器。
缺省情况下,未配置主授权服务器。
·     主授权服务器和从授权服务器的IP地址不能相同。
·     只有在设备与授权服务器没有报文交互时,才允许删除该服务器。授权服务器删除后,只对之后的授权过程有影响。
# 配置主HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49提供HWTACACS授权服务。
[Sysname-hwtacacs-hwt1] primary authorization 10.163.155.13 49
1.4.11  reset hwtacacs statistics
reset hwtacacs statistics { accounting | all | authentication | authorization } [ slot slot-number ]
【缺省级别】
1:监控级
accounting:清除HWTACACS协议关于计费的统计信息。
all:清除HWTACACS的所有统计信息。
authentication:清除HWTACACS协议关于认证的统计信息。
authorization:清除HWTACACS协议关于授权的统计信息。
slot slot-number:清除指定成员设备上的HWTACACS协议的统计信息,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
reset hwtacacs statistics命令用来清除HWTACACS协议的统计信息。
相关配置请参考命令display hwtacacs
# 清除HWTACACS协议的所有统计信息。
<Sysname> reset hwtacacs statistics all
1.4.12  reset stop-accounting-buffer (for HWTACACS)
reset stop-accounting-buffer hwtacacs-scheme hwtacacs-scheme-name [ slot slot-number ]
【缺省级别】
2:系统级
hwtacacs-scheme hwtacacs-scheme-name:根据指定HWTACACS方案清除缓存的停止计费请求报文。其中,hwtacacs-server-name为HWTACACS方案名,为1~32个字符的字符串。
slot slot-number:清除指定成员设备上缓存的停止计费请求报文,slot-number表示设备在IRF中的成员编号,取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
# 清除HWTACACS方案hwt1缓存在系统中的停止计费请求报文。
<Sysname> reset stop-accounting-buffer hwtacacs-scheme hwt1
1.4.13  retry stop-accounting (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
retry-times:停止计费请求报文的最大重试次数,取值范围为1~300。
【描述】
retry stop-accounting命令用来设置当出现没有得到响应的停止计费请求时,将该报文存入设备缓存后,发送停止计费请求报文的最大次数。undo retry stop-accounting命令用来恢复缺省情况。
缺省情况下,停止计费请求报文的最大发送次数为100。
# 在HWTACACS方案hwt1中,设置设备最多可以尝试向该方案中的服务器发送50次停止计费请求报文。
[Sysname-hwtacacs-hwt1] retry stop-accounting 50
1.4.14  secondary accounting (HWTACACS scheme view)
secondary accounting ip-address [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo secondary accounting [ ip-address ]
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:从HWTACACS计费服务器的IP地址。
port-number:从HWTACACS计费服务器的端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供计费服务的端口号保持一致。
key [ cipher | simple ] key:设置与从HWTACACS计费服务器交互的计费报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
FIPS模式下:
vpn-instance vpn-instance-name:从HWTACACS计费服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS计费服务器位于公网中。
【描述】
secondary accounting命令用来配置从HWTACACS计费服务器。undo secondary accounting命令用来删除配置的从HWTACACS计费服务器。
缺省情况下,未配置从计费服务器。
# 配置从HWTACACS计费服务器的IP地址为10.163.155.12,使用TCP端口49提供HWTACACS计费服务。
[Sysname-hwtacacs-hwt1] secondary accounting 10.163.155.12 49
1.4.15  secondary authentication (HWTACACS scheme view)
secondary authentication ip-address [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo secondary authentication [ ip-address ]
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:从HWTACACS认证服务器的IP地址。
port-number:从HWTACACS认证服务器的TCP端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供认证服务的端口号保持一致。
key [ cipher | simple ] key:设置与从HWTACACS认证服务器交互的认证报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
FIPS模式下:
vpn-instance vpn-instance-name:从HWTACACS认证服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS服务器位于公网中。
【描述】
secondary authentication命令用来配置从HWTACACS认证服务器。undo secondary authentication命令用来删除配置的从HWTACACS认证服务器。
缺省情况下,未配置从认证服务器。
# 配置从HWTACACS认证服务器的IP地址为10.163.155.13,使用TCP端口49提供HWTACACS认证服务。
[Sysname-hwtacacs-hwt1] secondary authentication 10.163.155.13 49
1.4.16  secondary authorization
secondary authorization ip-address [ port-number | key [ cipher | simple ] key | vpn-instance vpn-instance-name ] *
undo secondary authorization [ ip-address ]
HWTACACS方案视图
【缺省级别】
2:系统级
ip-address:从HWTACACS授权服务器的IP地址。
port-number:从HWTACACS授权服务器的TCP端口号,缺省为49,取值范围为1~65535。此端口号必须与服务器提供授权服务的端口号保持一致。
key [ cipher | simple ] key:设置与从HWTACACS授权服务器交互的授权报文的共享密钥。此共享密钥必须与服务器上配置的共享密钥保持一致。
非FIPS模式下:
FIPS模式下:
vpn-instance vpn-instance-name:从HWTACACS授权服务器所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示从HWTACACS授权服务器位于公网中。
【描述】
secondary authorization命令用来配置从HWTACACS授权服务器。undo secondary authorization命令用来删除配置的从HWTACACS授权服务器。
缺省情况下,未配置从授权服务器。
# 配置从HWTACACS授权服务器的IP地址为10.163.155.13,使用TCP端口49提供HWTACACS授权服务。
[Sysname-hwtacacs-hwt1] secondary authorization 10.163.155.13 49
1.4.17  stop-accounting-buffer enable (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
【描述】
由于停止计费请求报文涉及到话单结算、并最终影响收费多少,对用户和ISP都有比较重要的影响,因此设备应该尽最大努力把它发送给HWTACACS计费服务器。所以,如果HWTACACS计费服务器对设备发出的停止计费请求报文没有响应,设备应将其缓存在本机上,然后发送直到HWTACACS计费服务器产生响应,或者在发送的次数达到指定的次数限制后将其丢弃。
# 指示对于HWTACACS方案hwt1中的服务器,设备能够缓存没有得到响应的停止计费请求报文。
[Sysname-hwtacacs-hwt1] stop-accounting-buffer enable
1.4.18  timer quiet (HWTACACS scheme view)
timer quiet minutes
undo timer quiet
HWTACACS方案视图
【缺省级别】
2:系统级
minutes:恢复激活状态的时间,取值范围为1~255,单位为分钟。
【描述】
timer quiet命令用来设置主服务器恢复激活状态的时间。undo timer quiet命令用来恢复缺省情况。
缺省情况下,主服务器恢复激活状态的时间为5分钟。
# 设置主服务器恢复激活状态的时间为10分钟。
[Sysname-hwtacacs-hwt1] timer quiet 10
1.4.19  timer realtime-accounting (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
minutes:实时计费的时间间隔,取值范围为0~60,非零取值必须为3的倍数,单位为分钟。0表示设备不向HWTACACS服务器发送在线用户的计费信息。
【描述】
·     为了对用户实施实时计费,有必要设置实时计费的时间间隔。在设置了该属性以后,每隔设定的时间,设备会向HWTACACS服务器发送一次在线用户的计费信息。
·     实时计费间隔的取值对设备和HWTACACS服务器的性能有一定的相关性要求,取值越小,对设备和HWTACACS服务器的性能要求越高。建议当用户量比较大(¦1000)时,尽量把该间隔的值设置得大一些。以下是实时计费间隔与用户量之间的推荐比例关系:
表1-9 实时计费间隔与用户量之间的推荐比例关系
用户数
实时计费间隔(分钟)
1~99
3
100~499
6
500~999
12
¦1000
¦15
# 将HWTACACS方案hwt1的实时计费的时间间隔设置为51分钟。
[Sysname-hwtacacs-hwt1] timer realtime-accounting 51
1.4.20  timer response-timeout (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
seconds:HWTACACS服务器响应超时时间,取值范围为1~300,单位为秒。
【描述】
timer response-timeout命令用来设置HWTACACS服务器响应超时时间。undo timer response-timeout命令用来恢复缺省情况。
缺省情况下,HWTACACS服务器响应超时时间为5秒。
需要注意的是,由于HWTACACS是基于TCP实现的,因此,服务器响应超时或TCP超时都可能导致与HWTACACS服务器的连接断开。
# 配置TACACS服务器响应超时时间为30秒。
[Sysname-hwtacacs-hwt1] timer response-timeout 30
1.4.21  user-name-format (HWTACACS scheme view)
HWTACACS方案视图
【缺省级别】
2:系统级
keep-original:发送给HWTACACS服务器的用户名与用户输入的保持一致。
with-domain:发送给HWTACACS服务器的用户名带ISP域名。
without-domain:发送给HWTACACS服务器的用户名不带ISP域名。
【描述】
user-name-format命令用来设置发送给HWTACACS服务器的用户名格式。
缺省情况下,HWTACACS方案默认发送给HWTACACS服务器的用户名携带有ISP域名。
·     接入用户通常以“userid@isp-name”的格式命名,“@”后面的部分为ISP域名,设备就是通过该域名来决定将用户归于哪个ISP域的。但是,有些较早期的HWTACACS服务器不能接受携带有ISP域名的用户名,在这种情况下,有必要将用户名中携带的域名去除后再传送给HWTACACS服务器。因此,设备提供此命令以指定发送给HWTACACS服务器的用户名是否携带有ISP域名。
·     如果指定某个HWTACACS方案不允许用户名中携带有ISP域名,那么请不要在两个乃至两个以上的ISP域中同时设置使用该HWTACACS方案。否则,会出现虽然实际用户不同(在不同的ISP域中),但HWTACACS服务器认为用户相同(因为传送到它的用户名相同)的错误。
# 指定发送给HWTACACS方案hwt1的用户不带ISP域名。
[Sysname-hwtacacs-hwt1] user-name-format without-domain
1.4.22  vpn-instance (HWTACACS scheme view)
undo vpn-instance
HWTACACS方案视图
【缺省级别】
2:系统级
【描述】
vpn-instance命令用来配置HWTACACS方案所属的VPN。undo vpn-instance命令用来取消HWTACACS方案所属的VPN。
需要注意的是,本命令配置的VPN对于该方案下的所有HWTACACS认证/授权/计费服务器生效,但设备优先使用配置认证/授权/计费服务器时指定的各服务器所属的VPN。
# 配置HWTACACS方案hwt1所属的VPN为test。
[Sysname-hwtacacs-hwt1] vpn-instance test
1.5  RADIUS服务器配置命令
1.5.1  authorization-attribute(RADIUS-server user view)
authorization-attribute { acl acl-number | vlan vlan-id } *
undo authorization-attribute { acl | vlan } *
RADIUS服务器用户视图
【缺省级别】
2:系统级
acl acl-number:指定RADIUS用户的授权ACL。其中,acl-number为授权ACL的编号,取值范围为2000~5999。
vlan vlan-id:指定RADIUS用户的授权VLAN。其中,vlan-id为VLAN编号,取值范围为1~4094。
【描述】
authorization-attribute命令用来设置RADIUS用户的授权属性,该属性在用户认证通过之后,由作为RADIUS服务器的设备在认证回应报文中告知RADIUS客户端,RADIUS客户端将授权属性下发给用户,并对用户进行权限控制。undo authorization-attribute命令用来删除配置的授权属性。
缺省情况下,未设置任何授权属性。
相关配置可参考命令radius-server user
# 配置RADIUS用户user1的授权VLAN为VLAN 3。
[Sysname] radius-server user user1
[Sysname-rdsuser-user1] authorization-attribute vlan 3
1.5.2  description (RADIUS-server user view)
RADIUS服务器用户视图
【缺省级别】
2:系统级
text:RADIUS用户的描述信息,为1~255个字符的字符串,区分大小写。
【描述】
description命令用来配置RADIUS用户的描述信息。这些描述信息能够帮助管理员记忆并管理用户信息。undo description命令用来取消RADIUS用户的描述信息。
缺省情况下,未设置RADIUS用户的描述信息。
# 配置RADIUS用户user1的描述信息为VIP user。
[Sysname-rdsuser-user1] description VIP user
1.5.3  expiration-date (RADIUS-server user view)
RADIUS服务器用户视图
【缺省级别】
2:系统级
time:RADIUS用户的有效期,精确到秒,格式为HH:MM:SS-MM/DD/YYYY(时:分:秒-月/日/年)或HH:MM:SS-YYYY/MM/DD(时:分:秒-年/月/日)。其中,HH:MM:SS中的HH取值范围为0~23,MM和SS取值范围为0~59;MM/DD/YYYY中的MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。除表示零点外,格式中的前导0可以省略不写,比如2:2:0-2011/2/2等效于02:02:00-2011/02/02。
【描述】
expiration-date命令用来配置RADIUS用户的有效期。undo expiration-date用来取消RADIUS用户的有效期配置。
缺省情况下,未设置RADIUS用户的有效期,设备不进行用户有效期的检查。
在有用户需要临时接入网络的情况下,设备管理员可以为用户建立临时使用的来宾帐户,并通过该配置对来宾帐户进行有效期的控制。当该用户通过认证时,RADIUS服务器设备检查当前系统时间是否在用户的有效期内,若在有效期内则允许用户登录,否则拒绝用户登录。
需要注意的是,如果设备管理员手工修改系统时间,或其它原因导致系统时间发生变化,则在用户认证时使用修改后的系统时间与配置的用户有效期进行比较。
# 配置RADIUS用户user1的有效期为2012/05/31的12:10:20。
[Sysname-rdsuser-user1] expiration-date 12:10:20-2012/05/31
1.5.4  password (RADIUS-server user view)
password [ cipher | simple ] password
undo password
RADIUS服务器用户视图
【缺省级别】
2:系统级
password:设置的明文密码或密文密码,区分大小写。明文密码为1~128个字符的字符串;密文密码为1~201个字符的字符串。不指定ciphersimple时,表示以明文方式设置用户密码。
【描述】
password命令用来设置RADIUS用户的密码。undo password命令用来取消RADIUS用户的密码。
缺省情况下,未设置RADIUS用户的密码。
以明文或密文方式设置的密码,均以密文的方式保存在配置文件中。
# 设置RADIUS用户user1的密码为明文123456。
[Sysname-rdsuser-user1] password simple 123456
1.5.5  radius-server client-ip
radius-server client-ip ip-address [ key [ cipher | simple ] string ]
undo radius-server client-ip { ip-address | all }
【缺省级别】
2:系统级
ip-address:RADIUS客户端的IPv4地址。
key:指定与RADIUS客户端通信的共享密钥。
string:设置的明文密钥或密文密钥,区分大小写。明文密钥为1~64个字符的字符串;密文密钥为1~117个字符的字符串。不指定ciphersimple时,表示以明文方式设置共享密钥。
all:指定所有RADIUS客户端。
【描述】
radius-server client-ip命令用来指定RADIUS客户端。undo radius-server client-ip命令用来删除指定或所有的RADIUS客户端。
缺省情况下,未指定任何RADIUS客户端。
·     RADIUS服务器上指定的RADIUS客户端IP地址必须和RADIUS客户端上配置的发送RADIUS报文的源IP地址保持一致。
·     RADIUS服务器上指定的共享密钥必须和RADIUS客户端上配置的与RADIUS服务器通信的共享密钥保持一致。
·     可通过多次执行本命令,指定多个RADIUS客户端。
# 指定一个RADIUS客户端的IP地址为10.1.1.1,共享密钥为明文1234。
[Sysname] radius-server client-ip 10.1.1.1 key simple 1234
1.5.6  radius-server user
radius-server user user-name
undo radius-server user { user-name | all }
【缺省级别】
2:系统级
user-name:RADIUS用户名,为1~64个字符的字符串,区分大小写。用户名可以携带域名,不能包括符号“?”、“<”、“>”、“\”、“"”、“%”、“'”、“&”、“#”以及空格,且不能为“a”、“al”或“all”。
all:指定所有的RADIUS用户。
【描述】
radius-server user命令用来创建RADIUS用户并进入RADIUS服务器用户视图。undo radius-server user命令用来删除指定或所有的RADIUS用户。
缺省情况下,不存在任何RADIUS用户。
需要注意的是:RADIUS服务器上添加的用户名是否携带域名要与接入设备上设置的发送给RADIUS服务器的用户名格式保持一致。例如,若接入设备上设置的发送给RADIUS服务器的用户名携带域名(user-name-format with-domain),则RADIUS服务器上添加的RADIUS用户名也需要携带域名。
相关配置可参考命令user-name-format(RADIUS scheme view)。
# 创建名称为user1的RADIUS用户,并进入该用户视图。
