01-基础配置命令参考
09-设备管理命令
本章节下载 09-设备管理命令  (376.96 KB)
09-设备管理命令
  录
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 display clock
1.1.8 display copyright
1.1.9 display cpu-usage
1.1.10 display cpu-usage configuration
1.1.11 display cpu-usage history
1.1.12 display device
1.1.13 display device manuinfo
1.1.14 display device manuinfo fan
1.1.15 display device manuinfo power
1.1.16 display diagnostic-information
1.1.17 display environment
1.1.18 display fan
1.1.19 display memory
1.1.20 display memory-threshold
1.1.21 display power
1.1.22 display scheduler job
1.1.23 display scheduler logfile
1.1.24 display scheduler reboot
1.1.25 display scheduler schedule
1.1.26 display system stable state
1.1.27 display system-working-mode
1.1.28 display switch-mode status
1.1.29 display transceiver alarm
1.1.30 display transceiver diagnosis
1.1.31 display transceiver interface
1.1.32 display transceiver manuinfo
1.1.33 display version
1.1.34 display version-update-record
1.1.35 fan prefer-direction
1.1.36 header
1.1.37 job
1.1.38 memory-threshold
1.1.39 memory-threshold usage
1.1.40 monitor cpu-usage enable
1.1.41 monitor cpu-usage interval
1.1.42 monitor cpu-usage threshold
1.1.43 parity-error monitor log enable
1.1.44 parity-error monitor period
1.1.45 parity-error monitor threshold
1.1.46 password-recovery enable
1.1.47 reboot
1.1.48 reset scheduler logfile
1.1.49 reset version-update-record
1.1.50 restore factory-default
1.1.51 scheduler job
1.1.52 scheduler logfile size
1.1.53 scheduler reboot at
1.1.54 scheduler reboot delay
1.1.55 scheduler schedule
1.1.56 shutdown-interval
1.1.57 switch-mode
1.1.58 sysname
1.1.59 system-working-mode
1.1.60 temperature-limit
1.1.61 time at
1.1.62 time once
1.1.63 time repeating
1.1.64 transceiver phony-alarm-disable
1.1.65 usb disable
1.1.66 user-role
1 设备管理
1.1  设备管理配置命令
clock datetime命令用来设置设备的UTC(Coordinated Universal Time,国际协调时间)时间。
clock datetime time date
设备的UTC时间为出厂时间。
time:设置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将time参数设置为0表示零点。
date:设置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。
为了保证与其它设备协调工作,为了更好的监控和维护设备,请将系统时间配置准确。用户可使用该命令来配置系统时间,或者通过NTP协议获取系统时间。
# 设置设备的UTC时间为2012年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2012
# 设置设备的UTC时间为2012年1月1日8时10分。
<Sysname> clock datetime 8:10 2012/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置获取系统时间的方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp }
undo clock protocol
通过NTP协议获取系统时间。
none:表示通过本地时钟源获取系统时间。配置该参数后,用户可通过clock datetimeclock timezoneclock summer-time命令修改系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取系统时间。配置该参数后,用户不能通过命令行修改系统时间,需要配置NTP的相关参数才能获取到时钟。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
多次使用该命令配置不同的系统时间获取方式时,新配置将覆盖旧配置。
# 配置通过本地时钟源获取系统时间。
[Sysname] clock protocol none
clock summer-time命令用来设置夏令时。
undo clock summer-time命令用来恢复缺省情况。
没有配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:JanuaryFebruaryMarchAprilMayJuneJulyAugustSeptemberOctoberNovemberDecember;然后输入开始的星期,用当月的第几个星期表示,取值如下:firstsecondthirdfourthfifthlast;最后输入起始日,取值为SundayMondayTuesdayWednesdayThursdayFridaySaturday
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的夏令时配置保持一致。
# 设置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone命令用来对本地时区进行设置。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
本地时区采用UTC时区。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的时区和当地地理时区保持一致。
# 设置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
需要注意的是,通过command指定的命令行必须是设备上可成功执行的命令行,不包括telnetftpssh2monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
# 为Job(假设名称为backupconfig)分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
·     scheduler job
copyright-info enable命令用来使能显示版权信息。
undo copyright-info enable命令用来禁止显示版权信息。
显示版权信息处于开启状态。
# 使能显示版权信息。
[Sysname] copyright-info enable
·     使用Telnet方式登录设备,会显示如下信息:
* Without the owner's prior written consent,                                 *
<Sysname>
·     如果当前已经使用Console口登录设备了,再退出用户视图,由于设备会自动尝试再次登录,会显示如下信息:
User interface aux0 is available.
Press ENTER to get started.
# 禁止显示版权信息。
[Sysname] undo copyright-info enable
<Sysname>
1.1.7  display clock
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 没有配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2012
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示系统软件和硬件的详细版权信息。
display copyright
【缺省级别】
通过查看版权信息,可以获知系统当前使用软件和硬件版本的版权信息、版权的参照标准、版权证书等相关信息。
# 显示详细的软件版权信息。
<Sysname> display copyright
display cpu-usage命令用来显示CPU利用率的统计信息。
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定成员设备的CPU利用率的统计信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的相应信息。
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number取值只能为0。
该命令用于显示最近5秒钟、最近1分钟、最近5分钟CPU利用率的平均值。
# 显示IRF中所有成员设备当前CPU利用率统计信息。
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       6% in last 5 seconds
      10% in last 1 minute
       5% in last 5 minutes
表1-1 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Slot x CPU y CPU usage
x号成员设备上y号CPU的CPU利用率信息
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能相关配置。
slot slot-number:显示指定成员设备上CPU利用率历史信息记录功能相关配置。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示主设备上的相应信息。
cpu cpu-number:表示CPU的编号。cpu-number取值只能为0。
# 显示CPU利用率历史信息记录功能相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
表1-2 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能已开启。
当前CPU利用率历史记录的采样周期为60秒。
当前CPU利用率阈值为99%
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
job job-id:显示指定进程的CPU利用率的历史信息,job-id表示进程的编号。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定成员设备的CPU利用率的历史信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示主设备的相应信息。
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number取值只能为0。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示整个系统的CPU利用率的历史记录。
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明整个系统(用“SYSTEM”表示)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
# 以图表方式显示编号为1的进程的CPU利用率的历史记录。
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (scmd)
以上显示信息表明编号为1的进程(进程名为scmd,如果进程名带有“[]”标识则表示它是内核线程)在最近60分钟内CPU的利用率情况:20分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash显示设备的Flash信息。
usb:显示USB接口连接设备的信息。
slot slot-number:显示指定成员设备的设备信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的相应信息。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
# 显示IRF中各成员设备的设备信息。
<Sysname> display device
Slot Type             State    Subslot  Soft Ver             Patch Ver
1    S6900-54QF-F     Master   0        S6900-2415           None
表1-3 display device命令显示信息描述表
Slot
成员编号为1的成员设备的信息
设备的类型
设备的状态
Subslot
子卡所在的槽位号。
Soft Ver
设备的软件版本
Patch Ver
设备的补丁包版本
display device manuinfo命令用来显示设备的电子标签信息。
slot slot-number:显示指定成员设备的电子标签信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的相应信息。
电子标签信息也可以称为永久配置数据或档案信息等,设备的调测(调试、测试)过程中被写入到设备的存储器件中,包括设备的名称、生产序列号、MAC地址、制造商等信息。本命令显示的是设备的部分电子标签信息。
# 显示设备的电子标签信息。
<Sysname>display device manuinfo
 Slot 1 CPU 0:
DEVICE_NAME          : S6900-54QF-F
DEVICE_SERIAL_NUMBER : 210235A1AE0000001234
MAC_ADDRESS          : 00E0-FC00-5800
MANUFACTURING_DATE   : 2008-05-08
VENDOR_NAME          : H3C
Fan 1
DEVICE_NAME          : LSWM1HFANSC
DEVICE_SERIAL_NUMBER : 210231A0WFH115000073
MANUFACTURING_DATE   : 2011-11-12
VENDOR_NAME          : H3C
Fan 2
DEVICE_SERIAL_NUMBER : 210231A0WFH115000070
MANUFACTURING_DATE   : 2011-11-13
VENDOR_NAME          : H3C
Power 2
DEVICE_NAME          : LSVM1AC650
MANU SERIAL NUMBER   : 210231A0QMX129000007
MANUFACTURING_DATE   : 2011-11-14
VENDOR_NAME          : H3C
表1-4 display device manuinfo命令信息显示描述表
Slot 1 CPU 0
1号成员设备上的0号CPU
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
Fan 1
风扇编号
Power 1
电源编号
display device manuinfo fan命令用来显示指定风扇的电子标签信息。
display device manuinfo slot slot-number fan fan-id
slot slot-number:表示设备在IRF中的成员编号。
fan-id:表示设备上风扇的ID编号。
# 显示设备上风扇1的电子标签信息。
<Sysname> display device manuinfo slot 1 fan 1
Fan 1:
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MANUFACTURING_DATE   : 2010-01-20
VENDOR_NAME          : H3C
display device manuinfo power命令用来显示指定电源的电子标签信息。
display device manuinfo slot slot-number power power-id
power-id:表示设备上电源的ID编号。
# 显示设备上电源1的电子标签信息。
<Sysname> display device manuinfo slot 1 power 1
Power 1:
VENDOR_NAME          : H3C
display diagnostic-information命令用来显示系统当前多个功能模块运行的统计信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info ] [ filename ]
hardware:收集硬件相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个功能模块的运行信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,显示系统当前多个功能模块运行的统计信息。
未指定hardwareinfrastructurel2l3service参数时,将收集设备产生的所有诊断信息。
不指定filename参数执行display diagnostic-information命令,当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
该命令不支持使用“|”、“>”和“>>”参数过滤诊断信息。
执行该命令后,用户可以选择直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请使用tar extract命令解包后再使用more命令查看。关于more命令和tar extract命令的详细介绍请参见“基础配置命令”中的“文件系统管理”。
# 显示系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2012
……略……
display environment命令用来显示设备上温度传感器的温度信息,包括当前温度和设定的温度告警门限。
slot slot-number:显示IRF中指定成员设备上的温度传感器的温度信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是IRF中所有温度传感器的温度信息。
# 显示设备上所有温度传感器的温度信息。
<Sysname>display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 38           0      62       75     NA
 1     hotspot 2 36           0      62       75     NA
 1     hotspot 3 36           0      52       55     NA
 1     hotspot 4 42           0      77       87     NA
表1-5 display environment命令显示信息描述表
系统温度信息(单位为摄氏度)
sensor
温度传感器
hotspot:表示热点温度传感器
Slot
当显示数字时表示指定成员设备上温度传感器的温度信息
Temperature
当前温度
Lower
低温告警门限
Warning
一般级(Warning)高温告警门限
Alarm
严重级(Alarm)高温告警门限
Shutdown
关断级(Shutdown)高温告警门限
1.1.18  display fan
display fan命令用来显示设备风扇的工作状态。
display fan [ slot slot-number [ fan-id ] ]
slot slot-number:显示指定成员设备上风扇的状态信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示的是所有成员设备上风扇的状态信息。
fan-id:表示设备内置风扇的编号。不指定该参数时,显示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
 Slot 1:
 Fan 1:
 State    : Normal
 Airflow Direction: Port-to-power
 Prefer Airflow Direction: Port-to-power
 Fan 2:
 State    : Normal
表1-6 display fan命令显示信息描述表
Slot 1
设备的成员编号
Fan 1
设备上风扇的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
·     FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致
Airflow Direction
风扇模块的实际风道方向:
·     Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后
·     Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前
用户期望的风扇模块的风道方向:
display memory命令用来显示内存使用情况。
display memory [ slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定成员设备内存使用情况。slot-number表示设备在IRF中的成员编号,不指定该参数时,显示当前所有成员设备的内存使用情况。
# 显示设备的内存使用情况。
<Sysname>display memory
The statistics about memory is measured in KB:
Slot 10:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       3854876    651188   3203688         0       740    157844       83.3%
-/+ Buffers/Cache:    492604   3362272
Swap:            0         0         0
LowMem:     709152    303772    405380        --        --        --       57.2%
HighMem:   3145724    347416   2798308        --        --        --       89.0%
表1-7 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Slot
设备在IRF中的成员编号
Mem
内存使用信息
LowMem
低端内存使用信息。
HighMem
高端内存使用信息。
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销以及ISSU功能运行等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值
Buffers
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值
Cached
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值
FreeRatio
整个系统物理内存的空闲率
-/+ Buffers/Cache
-/+ Buffers/Cache:Used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+ Buffers/Cache:Free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
slot slot-number:显示指定成员设备的内存告警门限。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示主设备的相应信息。
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname>display memory-threshold
Memory usage threshold:  100%
Free memory threshold:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-8 display memory-threshold命令显示信息描述表
内存利用率阈值
         Minor:
         Severe:
         Critical:
         Normal:
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
Normal:恢复到正常状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Enter minor low-memory state:进入一级告警门限状态
·     Back to minor low-memory state:恢复到一级告警门限状态
·     Enter severe low-memory state:进入二级告警门限状态
·     Back to severe low-memory state:恢复到二级告警门限状态
·     Enter critical low-memory state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Total number of notification send
事件发生的总次数
·     memory-threshold
·     memory-threshold usage
display power命令用来显示设备电源的信息。
display power [ slot slot-number [ power-id ] ]
slot slot-number:显示指定成员设备上电源的信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备上电源的信息。
power-id:表示电源的编号。不指定该参数时,表示指定位置的所有电源。
# 显示设备电源的状况。
<Sysname> display power
 Slot 1:
 Input Power: 244(W)
 PowerID State    Mode   Current(A)  Voltage(V)  Power(W)
 1       Absent   --        --          --          --
 2       Normal   AC        --          --          -
表1-9 display power命令显示信息描述表
Slot 1
设备在IRF中的成员编号
Input Power
电源输入功率
PowerID
电源编号
电源模块的工作状态:
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
Mode
电源模块的工作模式:
·     AC:交流电源
·     DC:直流电源
Current(A)
输入电流,以安为单位
Voltage(V)
输入电压,以伏为单位
Power(W)
电源功率,以瓦为单位
表示不支持显示此项
display scheduler job命令用来查看Job的配置信息,包括Job的名称和分配的命令。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示已执行的Job的日志关信息,包括Job的名称、对应的Schedule的名称、执行时间以及执行结果。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface range fortygige 1/0/1 to fortygige 1/0/2
[Sysname-if-range]shutdown
表1-10 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来查看定时重启功能的相关配置。
# 查看定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来查看Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 查看所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2011
Last execution time  : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts     : 1
shutdown                                          Successful
表1-11 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system stable state命令用来显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
IRF启动需要一定的时间,才能达到Stable状态。如果IRF长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的成员设备,根据其具体状态,采取进一步措施。
IRF处于不稳定状态时,需要结合相关命令查看IRF的具体情况。例如:
·     通过display device命令查看设备是否处于故障状态。
·     通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。
<Sysname> display system stable state
System state    : Stable
Redundancy state: No redundance
  Slot   CPU   Role      State
  1      0     Active    Stable
表1-12 display system stable state命令显示信息描述表
System state
IRF的状态:
·     Stable:稳定运行
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以主备倒换
·     No Redundance:IRF中只有一台成员设备,不能主备倒换
·     Not Ready:未稳定,不能主备倒换
Role
成员设备在IRF中的身份:
·     Active:主设备
·     Standby:备设备
成员设备的状态:
·     Stable:成员设备稳定运行
·     Board Inserted:成员设备插入
·     Kernel Init:成员设备内核初始化
·     Service Starting:成员设备上的服务正在启动
·     Service Stopping:成员设备上的服务正在关闭
·     HA Batch Backup:HA批量备份中
·     Interface Data Batch Backup:接口管理批量备份未完成
当前成员设备处于未稳定状态
·     display ha service-group(可靠性命令参考/进程分布优化)
display system-working-mode命令用来显示系统的工作模式。
# 显示系统的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The next system working mode is advance.
display switch-mode status命令用来显示设备工作的表项模式。
# 显示设备工作的表项模式。
<Sysname> display switch-mode status
Switch-mode in use: 1--MAC table is 224K, L3 host table is 56K, LPM Table is 16K
Switch-mode at the next reboot: 0--MAC table is 288K, L3 host table is 16K, LPM
Table is 16K
表1-13 display switch-mode status命令显示信息描述表
Switch-mode in use
设备当前的表项模式
重启后设备的表项模式
MAC table is 288K
MAC地址表容量
ARP表或ND表容量
LPM Table is 16K
路由表容量
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见表1-14。如果没有故障,则显示为None。
表1-14 display transceiver alarm命令输出信息描述表
SFP/SFP+
RX loss of signal
接收信号丢失
RX power high
接收光功率高告警
RX power low
接收光功率低告警
TX fault
发送错误
TX bias high
偏置电流高告警
TX bias low
偏置电流低告警
TX power high
发送光功率高告警
TX power low
发送光功率低告警
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
QSFP+
RX signal loss in channel x
通道x接收信号丢失
TX fault in channel x
通道x发送错误
TX signal loss in channel x
通道x发送信号丢失
RX power high in channel x
通道x接收光功率高告警
RX power low in channel x
通道x接收光功率低告警
TX bias high in channel x
通道x偏置电流高告警
TX bias low in channel x
通道x偏置电流低告警
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface fortygige 1/0/1
FortyGigE1/0/1 transceiver current alarm information:
  Temp high
表1-15 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal
接收信号丢失
RX power low
接收光功率低告警
Temp high
温度高告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/2上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface fortygige 1/0/2
FortyGigE1/0/2 transceiver diagnostic information:
    Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    43         3.31        6.23      -6.50          -2.15
  Alarm thresholds:
          Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   75         -63        10.50       2.00           1.50
    Low    -5         2.97        2.00      -13.90         -11
表1-16 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/3上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface fortygige 1/0/3
FortyGigE1/0/3 transceiver information:
  Transceiver Type              : 40G_BASE_LR4_QSFP_PLUS
  Connector Type                : LC
  Wavelength(nm)                : 1301
  Transfer Distance(km)          : 10(SMF)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : QSFP-40G-LR4-WDM1300
表1-17 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,包括:
·     MPO(Multi-fiber Push On)连接器
·     LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)类型
·     RJ-45
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块,各个波长值之间用逗号分隔
·     电模块:显示为“N/A
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
·     CX4:表示CX4电缆
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
Ordering Name
可插拔接口模块的对外型号
display transceiver manuinfo命令用于显示可插拔接口模块的部分电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/4 上插入的可插拔接口模块的部分电子标签信息。
<Sysname> display transceiver manuinfo interface fortygige 1/0/4
FortyGigE1/0/4 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
表1-18 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在生产过程中生成的序列号
Manufacturing Date
写入电子标签的日期
Vendor Name
厂商名称
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
display version-update-record命令用来显示主设备启动软件包版本更新操作的记录。
【描述】
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
目前最多可以保存的更新记录的数目为10
# 显示设备启动软件包版本更新操作的记录。
<Sysname>display version-update-record
  Name                                   Version            Compile time
Record 1  (updated on Sep 17 2014 at 00:48:51):
* s6900-cmw710-boot-e2415.bin            7.1.045 ESS 2415   Sep 16 2014 13:44:42
* s6900-cmw710-system-e2415.bin          7.1.045 ESS 2415   Sep 16 2014 13:44:42
表1-19 display version-update-record命令显示信息描述表
Name
软件包的名称
Version
软件包的版本号
Compile time
版本编译时间
Record n
最近的第n次更新的时间,Record 1为最新的一次更新
表示软件包的版本和升级前的版本有变化,没有星号的表示版本没有变化
·     reset version-update-record
fan prefer-direction命令用来配置用户期望的风扇模块的风道方向。
undo fan prefer-direction命令用来恢复缺省情况。
fan prefer-direction slot slot-number { power-to-port | port-to-power }
undo fan prefer-direction slot slot-number
用户期望的风道方向为power-to-port,即电源侧进风、端口侧出风。
power-to-port:表示用户期望的风道方向是电源侧进风、端口侧出风。
port-to-power表示用户期望的风道方向是端口侧进风、电源侧出风。
# 配置IRF中成员设备1的用户期望的风扇模块的风道方向为port-to-power。
[Sysname] fan prefer-direction slot 1 port-to-power
·     display fan
1.1.36  header
header命令用来设置欢迎信息。
undo header命令用来关闭欢迎信息。
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
没有配置任何欢迎信息。
incoming:设置Modem登录用户登录进入用户视图时的欢迎信息。如果要求认证,则欢迎信息在通过认证后输出。
legal:设置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:设置登录验证时的欢迎信息。
motd:设置登录终端界面前的欢迎信息。
shell:设置非Modem登录用户登录进入用户视图时的欢迎信息。
text:输入欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 先后配置incominglegalloginmotdshell欢迎信息,并验证配置效果。
[Sysname] header incoming
Welcome to incoming(header incoming)%
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
本例中,“%”为text的起始/结束字符,在显示文本后输入“%”表示文本结束,退出header命令。作为起始与结束字符,“%”不会成为所设置欢迎信息的一部分。
采用Telnet方式远程登录设备,测试以上设置(只有设置了登录认证之后,才会显示login欢迎信息)。
 Press Y or ENTER to continue, N to exit.
Password:
1.1.37  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
没有为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置剩余内存告警的门限值。
undo memory-threshold命令用来恢复剩余内存告警的门限值。
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
一级告警门限为96MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为128MB。
minor minor-value:一级告警门限,单位为兆字节(MB),取值范围0~1742。minor-value应小于等于normal-valueminor-value为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB),取值范围0~1742。severe-value必须小于等于minor-valuesevere-value为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB),取值范围0~1742。critical-value必须小于等于severe-valuecritical-value为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB),取值范围0~1742。normal-value必须小于等于实际内存大小。
slot slot-number:设置指定成员设备的空闲内存告警门限值。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示设置主设备的空闲内存告警门限值。
系统实时监控系统剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备支持一级、二级、三级告警门限,关于这些告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%
slot slot-number:设置指定成员设备的内存利用率阈值。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示设置主设备的内存利用率阈值。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
·     memory-threshold
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:开启指定成员设备上CPU利用率历史记录功能。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示开启主设备的CPU利用率历史记录功能。
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
monitor cpu-usage interval interval-value [ slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval-value:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min。输入该参数时,请完整输入,否则,系统会提示参数错误。
slot slot-number:设置指定成员设备上CPU利用率历史记录的采用周期。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示设置主设备的CPU利用率历史记录的采用周期。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
monitor cpu-usage threshold命令用来配置CPU利用率阈值。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
CPU利用率阈值为99%。
cpu-threshold:CPU利用率阈值百分比,取值范围为0~100。
slot slot-number:设置指定成员设备的CPU利用率阈值。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示设置主设备的CPU利用率阈值。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率阈值比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
# 配置CPU利用率阈值为80%。
[Sysname] monitor cpu-usage threshold 80
·     display cpu-usage
parity-error monitor log enable命令用来允许生成奇偶校验错误日志
undo parity-error monitor log enable命令用来禁止生成奇偶校验错误日志
不允许生成奇偶校验错误日志。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,当设备奇偶校验错误时,设备会自动生成日志记录奇偶校验错误的详细信息。
# 允许生成奇偶校验错误日志。
[Sysname] parity-error monitor log enable
parity-error monitor period命令用来配置奇偶校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period value
奇偶校验错误次数的采样周期为60秒。
value:表示奇偶校验错误次数的采样周期,取值范围为1~86400,单位为秒。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,设备会按周期收集奇偶校验错误发生的次数。
# 配置奇偶校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
相关命令】
·     parity-error monitor threshold
parity-error monitor threshold命令用来配置奇偶校验错误次数的告警门限。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
奇偶校验错误次数的告警门限为5000次。
value表示奇偶校验错误次数的告警门限,取值范围为1~1000000,单位为次数。
设备在运行过程中,会自动检测并记录转发芯片上表项发生奇偶校验错误的次数。配置本命令后,如果设备在采样周期内发生奇偶校验错误的次数大于配置的告警门限,则发送告警提示用户。
举例】
# 配置奇偶校验错误次数的告警门限为8000次。
[Sysname] parity-error monitor threshold 8000
相关命令】
·     parity-error monitor period
password-recovery enable命令用来使能密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于使能状态。
配置密码恢复功能后,当用户忘记Console口认证密码或者登录认证失败,导致无法使用命令行操作设备时,可通过Bootrom菜单清除该认证密码,再继续使用设备;关闭密码恢复功能后,设备将处于一个安全性更高的状态,即当出现上述情况时,若想继续使用Console口对设备进行命令行操作,只能通过Bootrom菜单选择将设备恢复为出厂配置之后方可继续操作,这样可以有效地防止非法用户获取启动配置文件。
Bootrom菜单中支持配置的选项与密码恢复功能的配置有关,详见产品的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.47  reboot
reboot命令用来重启指定成员设备或所有成员设备。
slot slot-number:表示设备在IRF中的成员编号。不指定slot参数,会导致所有成员设备重启。
force:强制重启:
·     不指定该参数时,重启设备,系统会进行保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
·     如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
·     如果设备在准备重启时,用户正在进行文件操作,为了安全起见,系统将不会执行此次重启操作。
# 当配置没有变化时,重启设备。
<Sysname> reboot
Now rebooting, please wait...
# 当配置有变化时,重启设备,并选择保存配置文件。
<Sysname> reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
# 当配置有变化时,重启设备,但不保存配置文件
<Sysname> reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
reset version-update-record命令用来清除主设备启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
·     display version-update-record
restore factory-default命令用来将设备恢复到出厂状态。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。执行该命令后,设备将只保留“.bin”软件包、MAC地址、电子标签等维持设备正常工作必需的信息,其它文件和参数均恢复到出厂状态。例如:
·     设备存储介质根目录下的所有配置文件(即后缀为“.cfg”的文件)将被清除。
·     设备在使用过程中生成的日志信息(即/logfile下的“.log”文件以及logbuffer中的信息)、Trap信息、Debug信息将被清除。
·     Boot ROM菜单中各选项的值将恢复到缺省值。
·     License文件(即后缀为“.ak”的文件)将被删除。
·     可插拔存储介质(如U盘)中的所有文件将被删除。
提示
执行restore factory-default命令前,建议您将所有可插拔存储介质(如U盘)拔下。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
·     reboot
scheduler job命令用来创建Job并进入Job视图。如果Job已创建,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
没有创建Job
【缺省级别】
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
scheduler logfile size命令用来设置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户设置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 设置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来指定设备重启的具体时间和日期。
undo scheduler reboot命令用来取消重启时间的设置。
没有指定设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MMHH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
如果没有指定date参数,并且:
·     设置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     设置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot atscheduler reboot delay命令,最新配置生效。
需要注意的是,该命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
# 假设系统的当前时间为2011年6月6日11:43,设置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
undo scheduler reboot命令用来取消延时重启配置。
scheduler reboot delay time
没有配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2011年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule并进入相应的Schedule视图。如果Schedule已创建,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
没有创建Schedule
schedule-name:Schedule的名字,为1~47个字符的字符串,区分大小写。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time attime once或者time repeating命令来配置任务执行的时间。一个Schedule下只能设置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
shutdown-interval命令用来设定定时检测的时间间隔。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval time
定时检测的时间间隔为30秒。
time:定时检测的时间间隔:本参数的取值范围为0~300。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当使能了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
需要注意的是,如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。若T<T1,则被关闭的端口会再经过T1-T时间后被恢复;若T>=T1,则被关闭的端口会立即恢复。例如当前time设置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 设定定时检测时间间隔为100秒。
[Sysname] shutdown-interval 100
1.1.57  switch-mode
switch-mode命令用来配置设备MAC地址表、ARP表/ND表、路由表的容量。
switch-mode { 0 | 1 | 2 | 3 | 4 }
设备工作在0模式下。
0:设备的表项模式为0。
1:设备的表项模式为1。
2:设备的表项模式为2。
3:设备的表项模式为3。
4:设备的表项模式为4。
各表项模式下支持的MAC地址表、ARP表/ND表、路由表的容量与是否配置了switch-routing-mode ipv6-128命令相关,详细描述请参见“基础配置指导”中的“设备管理配置”。
·     如果已配置switch-routing-mode ipv6-128命令,则不能配置表项模式为4;如果已配置表项模式为4,则不能配置switch-routing-mode ipv6-128命令。关于switch-routing-mode ipv6-128命令的详细介绍,请参见“三层技术-IP路由命令参考”中的“IP路由基础命令”。
·     该配置在设备重启后才能生效,进行设备重启前请评估重启对网络造成的影响,做好相关准备工作。
# 设置设备的表项模式为2。
[Sysname] switch-mode 2
Reboot device to make the configuration take effect.
1.1.58  sysname
sysname命令用来设置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 设置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
system-working-mode命令用来配置系统的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | standard | expert }
设备工作在标准模式。
advance:将系统的工作模式设置为高级模式。
standard:将系统的工作模式设置为标准模式。
expert :将系统的工作模式设置为专家模式。
要使修改的工作模式生效,必须重启设备。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,请根据实际需要配置。关于各模式的详细描述请参见“基础配置指导”中的“设备管理”。
执行本命令后,若设备提示“Not enough hardware resources available.”,请通过display qos-acl resource命令查看设备ACL资源的使用情况,并通过undo acl命令释放ACL资源后,再进行工作模式的配置。有关display qos-acl resourceundo acl命令的详细介绍,请参见“ACL和QoS命令参考”中的“ACL命令”。
# 将系统工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective..
temperature-limit命令用于设置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number hotspot sensor-number
请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定成员设备上温度传感器的温度门限。slot-number表示设备在IRF中的成员编号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
sensor-number:温度传感器的编号,取值为从1开始的正整数,每一个数字对应设备上的一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度。一般级高温告警门限必须大于低温告警门限。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度。严重级高温告警门限必须大于一般级高温告警门限。
·     不同设备的温度传感器编号和温度告警门限取值范围不同,输入温度传感器编号或温度告警门限值时请通过<?>查看设备提示信息,以获取温度传感器编号或温度告警门限的取值范围。
·     如果温度低于低温告警门限,系统会生成日志信息和告警信息提示用户;如果温度高于Warning高温门限,系统会生成日志信息和告警信息提示用户;如果温度高于Alarm高温门限,系统一方面通过反复打印日志信息提示用户,另一方面还会通过设备面板上的指示灯来告警。
# 配置设备上1号热点温度传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为100摄氏度。
[sysname] temperature-limit slot 1 hotspot 1 -10 70 100
1.1.61  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
没有为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time attime oncetime repeating命令时,最新配置生效。
# 配置2011年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
1.1.62  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
没有为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval-time
undo time
没有配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval-time:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval-time表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver phony-alarm-disable命令用来关闭可插拔模块告警信息开关。
undo transceiver phony-alarm-disable命令用来恢复缺省情况。
可插拔模块告警信息开关处于开启状态。
设备根据光模块中记录的厂商信息来判断对应接口上插入的光模块的厂商是不是H3C。如果不是H3C,则会输出Trap和Log信息提醒用户,要求用户更换成H3C的光模块,以便管理和维护光模块。用户可使用display transceiver manuinfo命令查看光模块的厂商信息。
而H3C早期销售的光模块,可能没有记录厂商信息,为了保护用户投资,这样的光模块还能继续正常使用,但仍会输出Trap和Log信息。此时,可使用本命令,停止输出相关信息。
# 关闭可插拔模块告警信息开关。
[Sysname] transceiver phony-alarm-disable
1.1.65  usb disable
usb disable命令用来关闭设备上所有的USB接口。
undo usb disable命令用来打开设备上所有的USB接口。
usb disable
undo usb disable
设备上所有的USB接口处于开启状态。
在执行usb disable命令前,请先使用umount命令卸载所有USB分区,否则命令执行失败。有关umount命令的详细介绍,请参见“基础配置命令参考”中的“文件系统管理”。
用户可通过USB口进行文件的上传和下载。缺省状态下USB口处于开启状态,用户可根据需要关闭USB口。
# 关闭USB接口,请先umount所有USB分区。
<Sysname> umount slot1#usba0:
[Sysname] usb disable
# 打开USB接口。
[Sysname] undo usb disable
1.1.66  user-role
user-role命令用来配置执行定时任务时使用的用户角色。
undo user-role命令用来删除执行定时任务时的用户角色。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:执行定时任务时使用的用户角色,为1~63个字符,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator、level-0~level-15、security-audit,也可以是自定义的用户角色名称。
本命令用来指定执行定时任务时的用户角色。通过配置和删除执行定时任务时的用户角色可以控制定时任务下的各个命令的执行。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。当配置多个用户角色时:
·     如果没有配置安全日志管理员角色,系统会使用已配置的用户角色权限的并集去执行Schedule。
·     配置安全日志管理员角色后,系统会自动删除已配置的其它用户角色,安全日志管理员角色生效;配置其它用户角色后,系统会自动删除已配置的安全日志管理员角色,使用已配置的用户角色权限的并集去执行Schedule。
关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
# 配置执行定时任务test时的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
[Sysname-schedule-test] display this
 user-role network-admin
 user-role network-operator
 user-role rolename
return
·     command
