08-MPLS命令参考
04-MPLS TE命令
本章节下载 04-MPLS TE命令  (377.63 KB)
04-MPLS TE命令
  录
1 MPLS TE
1.1 MPLS TE配置命令
1.1.1 auto-tunnel backup
1.1.2 disable (explicit path view)
1.1.3 display explicit-path
1.1.4 display isis mpls te advertisement
1.1.5 display isis mpls te configured-sub-tlvs
1.1.6 display isis mpls te network
1.1.7 display isis mpls te tunnel
1.1.8 display mpls te ds-te
1.1.9 display mpls te link-management bandwidth-allocation
1.1.10 display mpls te tedb
1.1.11 display mpls te tunnel-interface
1.1.12 display ospf mpls te advertisement
1.1.13 display ospf mpls te network
1.1.14 display ospf mpls te tunnel
1.1.15 ds-te bc-model
1.1.16 ds-te mode
1.1.17 ds-te te-class
1.1.18 explicit-path
1.1.19 fast-reroute timer
1.1.20 link-management periodic-flooding timer
1.1.21 mpls te
1.1.22 mpls te affinity-attribute
1.1.23 mpls te auto-tunnel backup disable
1.1.24 mpls te backup
1.1.25 mpls te backup bandwidth
1.1.26 mpls te backup-path
1.1.27 mpls te bandwidth
1.1.28 mpls te bandwidth change thresholds
1.1.29 mpls te bidirectional
1.1.30 mpls te enable (interface view)
1.1.31 mpls te enable (IS-IS view)
1.1.32 mpls te enable (OSPF area view)
1.1.33 mpls te fast-reroute
1.1.34 mpls te fast-reroute bypass-tunnel
1.1.35 mpls te igp advertise
1.1.36 mpls te igp metric
1.1.37 mpls te igp shortcut
1.1.38 mpls te link-attribute
1.1.39 mpls te loop-detection
1.1.40 mpls te max-link-bandwidth
1.1.41 mpls te max-reservable-bandwidth
1.1.42 mpls te max-reservable-bandwidth mam
1.1.43 mpls te max-reservable-bandwidth rdm
1.1.44 mpls te metric
1.1.45 mpls te path
1.1.46 mpls te path-metric-type
1.1.47 mpls te priority
1.1.48 mpls te record-route
1.1.49 mpls te reoptimization (tunnel interface view)
1.1.50 mpls te reoptimization (user view)
1.1.51 mpls te resv-style
1.1.52 mpls te retry
1.1.53 mpls te route-pinning
1.1.54 mpls te signaling
1.1.55 mpls te static-cr-lsp
1.1.56 mpls te timer retry
1.1.57 nexthop
1.1.58 nhop-only
1.1.59 path-metric-type
1.1.60 snmp-agent trap enable te
1.1.61 te-subtlv
1.1.62 timers removal unused
1.1.63 tunnel-number
1 MPLS TE
1.1  MPLS TE配置命令
auto-tunnel backup命令用来全局开启自动隧道备份功能,并进入MPLS TE自动隧道备份视图。
undo auto-tunnel backup命令用来全局关闭自动隧道备份功能。
auto-tunnel backup
自动隧道备份功能处于全局关闭状态。
MPLS TE视图
通过本命令全局开启自动隧道备份功能,并通过tunnel-number命令配置自动创建的Bypass隧道的接口编号范围后,本地设备会自动为经过本设备、且开启了FRR功能的所有MPLS TE隧道建立两条Bypass隧道:一条链路保护的Bypass隧道和一条节点保护的Bypass隧道。
执行undo auto-tunnel backup命令后,MPLS TE会删除所有已经自动建立的Bypass隧道。
倒数第二跳节点作为PLR时,只自动创建链路保护类型的Bypass隧道,不会自动创建节点保护类型的Bypass隧道。
# 全局开启自动隧道备份功能,并进入MPLS TE自动隧道备份视图。
[Sysname] mpls te
[Sysname-te] auto-tunnel backup
[Sysname-te-auto-bk]
·     mpls te auto-backup disable
·     nhop-only
·     timers removal unused
·     tunnel-number
disable命令用来禁用显式路径。
undo disable命令用来恢复缺省情况。
disable
undo disable
显式路径可用。
显式路径视图
disable命令用来防止显式路径在配置过程中错误地被隧道引用,错误地建立隧道。
# 禁用名为path1的显式路径。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] disable
display explicit-path命令用来显示显式路径的信息。
display explicit-path [ path-name ]
path-name:显示指定显式路径的信息。path-name表示显式路径名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示所有显式路径的信息。
# 显示所有显式路径的信息。
<Sysname> display explicit-path
Path Name: path1      Hop Count: 3     Path Status: Enabled
Index     IP Address             Hop Type    Hop Attribute
1         1.1.1.1                Strict      Include
101       2.2.2.2                Loose       Include
201       3.3.3.3                  -         Exclude
表1-1 display explicit-path命令显示信息描述表
Path Name
显式路径名称
Hop Count
显式路径中配置的节点数
Path Status
显式路径状态,取值包括:
·     Enabled:表示显式路径可用
·     Disabled:表示显式路径不可用
Index
显式路径中节点的索引
IP Address
显式路径中节点的IP地址
Hop Type
节点的类型,取值包括:
·     Strict:表示严格下一跳,即上一跳与该节点必须直接相连
·     Loose:表示松散下一跳,即上一跳与该节点可以不是直接相连
Hop Attribute
节点的属性,取值包括:
·     Include:表示在显式路径中需要包含该节点
·     Exclude:表示在显式路径中不能包含该节点
display isis mpls te advertisement命令用来显示IS-IS TEDB中的链路和节点信息。
display isis mpls te advertisement [ [ level-1 | level-2 ] | [ originate-system system-id | local ] | verbose ] * [ process-id ]
level-1:显示Level-1路由器的链路和节点信息。
level-2:显示Level-2路由器的链路和节点信息。
originate-system system-id:显示指定系统发布的链路和节点信息。system-id为系统ID,形式为XXXX.XXXX.XXXX。
local:显示本地发布的链路和节点信息。
verbose:显示详细信息。如果不指定本参数,则显示简要信息。
process-id:显示指定IS-IS进程的信息。process-id为IS-IS进程号,取值范围为1~65535。如果不指定本参数,则显示所有IS-IS进程的信息。
如果未指定level-1level-2参数,则同时显示Level-1路由器和Level-2路由器的信息;如果未指定originate-system system-idlocal参数,则显示所有系统发布的信息。
# 显示IS-IS TEDB中Level-1路由器的链路和节点简要信息。
<Sysname> display isis mpls te advertisement level-1
                           TE information for IS-IS(1)
Level-1 TE node and link information
Node total count   : 2
Node index         : 0
  System ID        : 0000.0000.0004
  MPLS LSR ID      : 4.4.4.4
  Node flags       : -/-/R/-
  Link total count : 1
  Link information :
    Neighbour           Frag ID   Link Type   Local Address    Remote Address
    0000.0000.0004.04   0x00      Broadcast   1.1.1.3
Node index         : 1
  System ID        : 0000.0000.0001
  MPLS LSR ID      : 1.1.1.1
  Link information :
    0000.0000.0004.04   0x00      Broadcast   1.1.1.1          --
# 显示IS-IS TEDB中Level-1路由器的链路和节点详细信息。
<Sysname> display isis mpls te advertisement level-1 local verbose
Node index         : 0
  Link information :
  Link index   : 0
    Neighbor   : 0000.0000.0004.04       Frag ID     : 0x00
    Link type  : Broadcast               Admin group : 0x00000000
    IGP metric : 10                      TE metric   : 10
    Link flags : -/-/-
    Physical bandwidth: 12500000 bytes/sec
    Reservable bandwidth: 0 bytes/sec
    Unreserved bandwidth for each TE class:
      TE class  0: 0 bytes/sec           TE class  1: 0 bytes/sec
      TE class  2: 0 bytes/sec           TE class  3: 0 bytes/sec
      TE class  4: 0 bytes/sec           TE class  5: 0 bytes/sec
      TE class  6: 0 bytes/sec           TE class  7: 0 bytes/sec
      TE class  8: 0 bytes/sec           TE class  9: 0 bytes/sec
      TE class 10: 0 bytes/sec           TE class 11: 0 bytes/sec
      TE class 12: 0 bytes/sec           TE class 13: 0 bytes/sec
      TE class 14: 0 bytes/sec           TE class 15: 0 bytes/sec
    Bandwidth constraint model: Prestandard DS-TE RDM
    Bandwidth constraints:
      BC[00]: 0 bytes/sec                BC[01]: 0 bytes/sec
    Local address: 1.1.1.3
Node index         : 1
  Node flags       : -/-/-/-
  Link information :
  Link index  : 0
    IGP metric: 10                       TE metric   : 10
    Link flags: -/-/-
    Local address: 1.1.1.1
表1-2 display isis mpls te advertisement命令显示信息描述表
指定IS-IS进程的TE信息
Level-1路由器的TE信息
Level-2 TE node and link information
Level-2路由器的TE信息
Node total count
发布TE信息的节点个数
Node index
发布TE信息的节点索引
System ID
节点的系统ID
MPLS LSR ID
节点的MPLS LSR ID
Node flags
节点信息的状态标记,取值包括:
·     A:节点信息成功同步到CSPF
·     S:向CSPF同步节点信息失败后,准备再次向CSPF同步
·     R:表示到达该节点的路由可达
·     O:节点处于overload状态
Link total count
节点发布的链路数目
Link information
节点发布的链路信息
Link index
链路索引
Neighbor
邻居系统ID
Frag ID
LSP分片号
Link type
该条链路的链路类型,取值包括:
·     Broadcast:表示广播链路
·     P2P:表示点对点链路
Admin group
链路管理组属性
IGP metric
IGP开销值
TE metric
TE开销值
Link flags
链路信息的状态标记,取值包括:
·     A:链路信息成功同步到CSPF
·     U:向CSPF同步更新链路信息失败后,准备再次向CSPF同步
·     D:向CSPF同步删除链路信息失败后,准备再次向CSPF同步
Physical bandwidth
物理带宽
可预留带宽
每个TE class的未预留带宽
TE class 0-15
16个TE class各自的未预留带宽
带宽约束模型,取值包括:
·     Prestandard DS-TE RDM
·     IETF DS-TE RDM
·     IETF DS-TE MAM
带宽约束
BC
各个带宽约束值(Prestandard模式支持2个BC,IETF模式支持4个BC)
Local address
该条链路的本地IP地址
Remote address
该条链路的对端IP地址
display isis mpls te configured-sub-tlvs命令用来显示IS-IS TE配置的子TLV类型值信息。
display isis mpls te configured-sub-tlvs [ process-id ]
# 显示IS-IS TE配置的子TLV类型值信息。
<Sysname> display isis mpls te configured-sub-tlvs
TE sub-TLV information for IS-IS(1)
  Type value of the unreserved sub-pool bandwidth sub-TLV : 251
  Type value of the bandwidth constraint sub-TLV          : 252
表1-3 display isis mpls te configured-sub-tlvs命令显示信息描述表
TE Sub-TLV Information for IS-IS(1)
指定进程配置的DS-TE子TLV类型值E
Type value of the unreserved subpool bandwidth sub-TLV
可用子池带宽子TLV的类型值
带宽约束子TLV的类型值
display isis mpls te network命令用来显示IS-IS TEDB中的网络信息。
display isis mpls te network [ [ level-1 | level-2 ] | local | lsp-id lsp-id ] * [ process-id ]
level-1:显示Level-1路由器的网络信息。
level-2:显示Level-2路由器的网络信息。
local:显示本地发布的网络信息。
lsp-id lsp-id:显示指定LSP的网络信息。lsp-id为LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的节点或伪节点的SystemID,Pseudonode ID是伪节点ID,fragment num是该LSP的分片号。
如果未指定level-1level-2参数,则同时显示Level-1路由器和Level-2路由器的信息;如果未指定locallsp-id lsp-id参数,则显示所有网络的信息。
# 显示IS-IS TEDB中Level-1路由器和Level-2路由器的网络信息。
<Sysname> display isis mpls te network
Level-1 network information
LAN ID             : 0000.0000.0004.04
Frag ID            : 0x00
Flags              : -/-/-
Attached routers   : 0000.0000.0001
                     0000.0000.0004
Level-2 Network Information
Frag ID            : 0x00
Flags              : -/-/-
                     0000.0000.0004
表1-4 display isis mpls te network命令显示信息描述表
指定IS-IS进程的TE信息
Level-1 TE Network Information
Level-1的TE网络信息
Level-2 TE Network Information
Level-2的TE网络信息
LAN ID
广播网络ID,形式为System-ID.Pseudonode-ID
Frag ID
LSP分片号
Flags
网络信息的状态标记:
·     A:网络信息已成功同步到CSPF
·     U:向CSPF同步更新网络信息失败后,准备再次向CSPF同步
·     D:向CSPF同步删除网络信息失败后,准备再次向CSPF同步
Attached routers
相连路由器列表
display isis mpls te tunnel命令用来显示IS-IS的Tunnel接口信息。
display isis mpls te tunnel [ level-1 | level-2 ] [ process-id ]
level-1:显示Level-1路由器的Tunnel接口信息。
level-2:显示Level-2路由器的Tunnel接口信息。
如果未指定level-1level-2参数,则同时显示Level-1路由器和Level-2路由器的信息。
# 显示IS-IS的Tunnel接口信息。
<Sysname> display isis mpls te tunnel
                    MPLS-TE tunnel information for IS-IS(1)
                           Level-1 Tunnel Statistics
   Tunnel Name      Auto Route       Destination      Metric
   Tun0             Advertise        2.2.2.2          Relative 0
                           Level-2 Tunnel Statistics
表1-5 display isis mpls te tunnel命令显示信息描述表
指定IS-IS进程的MPLS TE隧道接口信息
Level-1的MPLS TE隧道接口信息
Level-2的MPLS TE隧道接口信息
Tunnel Name
隧道接口名称
Auto Route
隧道接口上配置的自动路由发布类型,取值包括:
·     Advertise:转发邻接
·     Shortcut:IGP shortcut
Destination
隧道的目的端地址
Metric
隧道接口上配置的度量值,取值包括:
·     Relative:相对度量值
·     Absolute:绝对度量值
display mpls te ds-te命令用来显示DS-TE相关信息,包括DS-TE的模式、带宽约束模型及TE class与服务类型、优先级的对应关系等。
# 显示DS-TE相关信息。
<Sysname> display mpls te ds-te
MPLS LSR ID         : 0.0.0.0
MPLS DS-TE mode     : Prestandard
MPLS DS-TE BC model : RDM
TE Class       Class Type     Priority
0              0              0
1              0              1
2              0              2
3              0              3
4              0              4
5              0              5
6              0              6
7              0              7
8              1              0
9              1              1
10             1              2
11             1              3
12             1              4
13             1              5
14             1              6
15             1              7
表1-6 display mpls te ds-te命令显示信息描述表
MPLS LSR ID
设备的MPLS LSR ID
MPLS DS-TE mode
DS-TE模式,取值包括Prestandard和IETF
MPLS DS-TE BC model
DS-TE的带宽约束模型,取值包括
·     RDM:俄罗斯套娃模型
·     MAM:最大分配模型
TE Class
CT及优先级组合的编号
Class Type
服务类型
Priority
优先级
display mpls te link-management bandwidth-allocation命令用来显示开启了MPLS TE的接口上的带宽相关信息。
display mpls te link-management bandwidth-allocation [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口上的带宽相关信息。interface-type interface-number为接口类型和接口编号。如果不指定本参数,则显示所有开启了MPLS TE的接口上的带宽相关信息。
# 显示所有开启了MPLS TE的接口上的带宽相关信息。
<Sysname> display mpls te link-management bandwidth-allocation
Interface: Vlan-interface10
  Max Link Bandwidth                          : 3200000 kbps
  Max Reservable Bandwidth of Prestandard RDM : 2000000 kbps
  Max Reservable Bandwidth of IETF RDM        : 200000 kbps
  Max Reservable Bandwidth of IETF MAM        : 300000 kbps
  Allocated Bandwidth-Item Count :1
  Allocated Bandwidth            :1000 kbps
  Physical Link Status           : Up
  BC  Prestandard RDM(kbps)  IETF RDM(kbps)       IETF MAM(kbps)
  0   2000000                200000               2000
  1   1000000                150000               2000
  2   0                      100000               2000
  3   0                      50000                2000
  TE Class    Class Type    Priority   BW Reserved(kbps)  BW Available(kbps)
      0           0             0            0            2000000
      1           0             1            0            2000000
      2           0             2            0            2000000
      3           0             3            0            2000000
      4           0             4            0            2000000
      5           0             5            0            2000000
      6           0             6            0            2000000
      7           0             7            1000         1999000
      8           1             0            0            1000000
      9           1             1            0            1000000
     10           1             2            0            1000000
     11           1             3            0            1000000
     12           1             4            0            1000000
     13           1             5            0            1000000
     14           1             6            0            1000000
     15           1             7            0            1000000
表1-7 display mpls te link-management bandwidth-allocation命令显示信息描述表
开启了MPLS TE的接口
Max Link Bandwidth
用于转发MPLS TE流量的最大链路带宽
Prestandard RDM模型的最大可预留带宽
IETF RDM模型的最大可预留带宽
IETF MAM模型的最大可预留带宽
已分配带宽条目的数量
Allocated Bandwidth
已分配的带宽,单位为kbps
接口的物理层链路状态,取值包括Up和Down
BC
带宽约束
Prestandard RDM
Prestandard模式RDM模型的带宽约束,单位为kbps
IETF RDM
IETF模式RDM模型的带宽约束,单位为kbps
IETF MAM
IETF模式MAM模型的带宽约束,单位为kbps
TE Class
CT及优先级组合的编号
Class Type
服务类型
Priority
优先级
BW Reserved
已经为该TE class预留的带宽,单位为kbps
BW Available
目前该TE class可预留的带宽,单位为kbps
·     mpls te max-link-bandwidth
·     mpls te max-reservable-bandwidth
·     mpls te max-reservable-bandwidth mam
·     mpls te max-reservable-bandwidth rdm
display mpls te tedb命令用来显示MPLS TEDB(TE DataBase,流量工程数据库)信息。
display mpls te tedb { { isis { level-1 | level-2 } | ospf area area-id } | link ip-address | network | node [ local | mpls-lsr-id ] | summary }
isis:显示指定IS-IS级别的TEDB信息。
level-1:显示level-1级别的TEDB信息。
level-2:显示level-2级别的TEDB信息。
ospf area area-id:显示指定OSPF区域的TEDB信息。area-id为OSPF区域的标识,取值范围为0~4294967295。
link ip-address:显示指定IP地址对应链路的TEDB信息。ip-address为接口的IP地址。
network:显示所有广播和NBMA网络的TEDB信息。
node:显示节点相关的TEDB信息。如果未指定localmpls-lsr-id参数,则显示所有节点相关的TEDB信息。
local:显示本地节点相关的TEDB信息。
mpls-lsr-id:显示指定节点相关的TEDB信息。mpls-lsr-id为节点的MPLS LSR ID。
summary:显示TEDB的摘要信息。
# 显示所有广播和NBMA网络的TEDB信息。
<Sysname> display mpls te tedb network
DR MPLS LSR-ID  DR-address      IGP   Process-ID Area/Level  Neighbors
8.1.1.2         3.0.0.2         OSPF  100        0           1.1.1.1
                                                             2.1.1.1
                                                             8.1.1.2
2.1.1.1         3.0.0.3         OSPF  100        0           2.1.1.1
                                                             3.1.1.1
                                                             2.1.1.2
3.1.1.2         3.0.0.4          OSPF  100       0           3.1.1.1
                                                             4.1.1.1
                                                             3.1.1.2
4.1.1.2        3.0.0.5          OSPF  100         0          4.1.1.1
                                                             5.1.1.1
                                                             4.1.1.2
5.1.1.2        3.0.0.6          OSPF  100         0          5.1.1.1
                                                             6.1.1.1
                                                             5.1.1.2
6.1.1.2        3.0.0.9          OSPF  100         0          6.1.1.1
                                                             7.1.1.1
                                                             6.1.1.2
7.1.1.1        12.0.0.7         OSPF  100         0          3.1.1.1
                                                             7.1.1.1
                                                             7.1.1.2
表1-8 display mpls te tedb network命令显示信息描述表
DR MPLS LSR-ID
DR(Designated Router,指定路由器)的MPLS LSR ID,点分十进制形式
DR-address
DR的接口地址
IGP
内部网关协议,取值为OSPF或IS-IS
Process-ID
IGP进程ID
Area/Level
路由器属于的区域(OSPF)或Level(IS-IS)
Neighbors
与DR形成了完全邻接关系的路由器的Router ID,也包括DR自身的Router ID
# 显示TEDB的概要信息。
<Sysname> display mpls te tedb summary
MPLS LSR-ID     IGP     Process-ID    Area/Level    Links-Count
1.1.1.1         OSPF    100           1001          20
                                      1002          30
                                      1003          40
                                      1004          50
                                      1007          70
                                      1010          80
2.1.1.1         ISIS    100           Level-1       20
                                      Level-1       30
3.1.1.1         OSPF    100           0             4
表1-9 display mpls te tedb summary命令显示信息描述表
MPLS LSR-ID
MPLS LSR ID,点分十进制形式
IGP
Process-ID
IGP进程ID
Area/Level
Links-Count
Area或Level中的链路数
# 显示指定OSPF区域的TEDB信息。
<Sysname> display mpls te tedb ospf area 1
Node information for OSPF area 1:
MPLS LSR-ID    IGP     Process-ID     Area            Links-Count
2.2.2.2        OSPF    100            1               1
3.3.3.3        OSPF    100            1               1
Network information for OSPF area 1:
DR MPLS LSR-ID  DR-address    IGP  Process-ID Area    Neighbors
3.3.3.3         20.1.1.2      OSPF 100        1       2.2.2.2
                                                      3.3.3.3
表1-10 display mpls te tedb ospf area命令显示信息描述表
MPLS LSR-ID
MPLS LSR ID,点分十进制形式
IGP
Process-ID
IGP的进程号
Area
路由器所属的OSPF区域
Links-Count
Area或Level中的链路数
DR MPLS LSR-ID
DR的MPLS LSR ID
DR-address
DR的接口地址
Neighbors
# Prestandard模式下显示本地节点相关的TEDB信息。
<Sysname> display mpls te tedb node local
MPLS LSR-ID: 1.1.1.1
  IGP Type: OSPF          Process ID: 100         Area: 1
  Link[1]:
    Local IP Address: 2.0.1.33
          Neighbor IP Address: 2.0.1.2
    Neighbor MPLS LSR-ID: 1.1.1.2
    Link Type: P2P  Link Status: Inactive
    IGP Metric: 100             TE Metric: 100         Link Attribute: 0xff
    Maximum Link Bandwidth: 100 kbps
    Maximum Reservable Bandwidth: 20 kbps
    Bandwidth Constraint Model: Prestandard DS-TE RDM
    Bandwidth Constraints:
         BC[0]:  100        kbps
         BC[1]:  20         kbps
    Unreserved Bandwidth for each TE class:
         TE class  0:    10         kbps
         TE class  1:    10         kbps
         TE class  2:    10         kbps
         TE class  3:    10         kbps
         TE class  4:    10         kbps
         TE class  5:    10         kbps
         TE class  6:    10         kbps
         TE class  7:    10         kbps
         TE class  8:    10         kbps
         TE class  9:    10         kbps
         TE class 10:    10         kbps
         TE class 11:    10         kbps
         TE class 12:    10         kbps
         TE class 13:    10         kbps
         TE class 14:    10         kbps
         TE class 15:    10         kbps
  IGP Type: ISIS   Process ID: 100   Level: Level-1
  Link[1]:
    Link Type: P2P  Link Status: Active
    IGP Metric: 10              TE Metric: 10          Link Attribute: 0x11
    Maximum Bandwidth: 100 (kbps)
    Maximum Reservable Bandwidth: 100 (kbps)
         BC[0]:  100        kbps
         BC[1]:  20         kbps
    Unreserved Bandwidth for each TE Class:
         TE class  0:    10         kbps
         TE class  1:    10         kbps
         TE class  2:    10         kbps
         TE class  3:    10         kbps
         TE class  4:    10         kbps
         TE class  5:    10         kbps
         TE class  6:    10         kbps
         TE class  7:    10         kbps
         TE class  8:    10         kbps
         TE class  9:    10         kbps
表1-11 display mpls te tedb node命令显示信息描述表
MPLS LSR-ID
MPLS LSR ID,点分十进制形式
IGP Type
IGP类型,取值为OSPF或ISIS
Process ID
IGP进程号
Area
路由器所属的OSPF区域
Level
路由器所属的IS-IS级别,取值为Level-1、Level-2
Link[n]
第n条链路的信息
Local IP Address
本地接口地址
Neighbor IP Address
对于P2P、P2MP链路,表示对端接口地址
对于NBMA、Broadcast链路,本字段显示为“-”
对端的MPLS LSR ID
Link Type
链路类型,取值包括:
·     P2P:点到点链路
·     P2MP:点到多点链路
·     NBMA:非广播多路访问链路
·     Broadcast:广播链路
Link Status
链路状态,取值包括Active、Inactive
IGP Metric
IGP度量值
TE Metric
TE度量值
Link Attribute
链路的属性
Maximum Bandwidth
链路最大带宽
链路最大可预留带宽
带宽约束模型,取值包括:
·     IETF DS-TE RDM
·     IETF DS-TE MAM
带宽约束
每个TE class的可预留带宽
# IETF DS-TE模式RDM带宽约束模型下显示接口地址20.1.1.1对应链路的TEDB信息。
<Sysname> display mpls te tedb link 20.1.1.1
MPLS LSR-ID: 2.2.2.2
    Local IP Address: 20.1.1.1
Neighbor MPLS LSR-ID: 20.1.1.2
Link Type: Broadcast  Link Status: Active
    IGP Metric: 10          TE Metric: 0             Link Attribute: 0x0
    Maximum Bandwidth: 0 kbps
    Maximum Reservable Bandwidth: 0 kbps
    Bandwidth Constraint Model: IETF DS-TE RDM
         BC[0] :  0          kbps
         BC[1] :  0          kbps
         BC[2] :  0          kbps
         BC[3] :  0          kbps
         TE class  0:    0          kbps
         TE class  1:    0          kbps
         TE class  2:    0          kbps
         TE class  3:    0          kbps
         TE class  4:    0          kbps
         TE class  5:    0          kbps
         TE class  6:    0          kbps
         TE class  7:    0          kbps
表1-12 display mpls te tedb link命令显示信息描述表
MPLS LSR-ID
MPLS LSR ID,点分十进制形式
IGP Type
IGP类型,取值为OSPF或ISIS
Process ID
IGP进程号
Area
路由器所属的OSPF区域
Level
Local IP Address
本地接口地址
Neighbor IP Address
对于NBMA、Broadcast链路,不显示本字段
对端MPLS LSR ID
Link Type
链路类型,取值包括:
·     P2P:点到点链路
·     P2MP:点到多点链路
·     NBMA:非广播多路访问链路
·     Broadcast:广播链路
Link Status
IGP Metric
IGP度量值
TE Metric
TE度量值
Link Attribute
链路的属性
Maximum Bandwidth
链路最大带宽
链路最大可预留带宽
带宽约束模型,取值包括:
·     IETF DS-TE RDM
·     IETF DS-TE MAM
带宽约束
每个TE class的可预留带宽
display mpls te tunnel-interface命令用来显示MPLS TE隧道接口的信息。
display mpls te tunnel-interface [ tunnel number ]
tunnel number:显示指定Tunnel接口的信息。number为设备上已创建的Tunnel接口的编号。如果不指定本参数,则显示所有MPLS TE隧道接口的信息。
# 显示所有MPLS TE隧道接口的信息。
<Sysname> display mpls te tunnel-interface
Tunnel Name            : Tunnel 1
Tunnel State           : Up (Main CRLSP up)
Tunnel Attributes      :
  LSP ID               : 1               Tunnel ID            : 1
  Admin State          : Normal
  Ingress LSR ID       : 1.1.1.1         Egress LSR ID        : 3.3.3.3
  Signaling            : Static          Static CRLSP Name    : static-cr-lsp-1
  Resv Style           : -
  Tunnel mode          : -
  Reverse-LSP name     : -
  Reverse-LSP LSR ID   : -               Reverse-LSP Tunnel ID: -
  Class Type           : -               Tunnel Bandwidth     : -
  Reserved Bandwidth   : -
  Setup Priority       : 0               Holding Priority     : 0
  Affinity Attr/Mask   : -/-
  Explicit Path        : -
  Backup Explicit Path : -
  Metric Type          : TE
  Record Route         : -               Record Label         : -
  FRR Flag             : -               Bandwidth Protection : Disabled
  Backup Bandwidth Flag: Disabled        Backup Bandwidth Type: -
  Backup Bandwidth     : -
  Bypass Tunnel        : No              Auto Created         : No
  Route Pinning        : -
  Retry Limit          : 10              Retry Interval       : 2 sec
  Reoptimization       : -               Reoptimization Freq  : -
  Backup Type          : -               Backup LSP ID        : -
  Auto Bandwidth       : Disabled        Auto Bandwidth Freq  : -
  Min Bandwidth        : -               Max Bandwidth        : -
  Collected Bandwidth  : -
表1-13 display mpls te tunnel-interface命令显示信息描述表
Tunnel Name
隧道接口的名称
Tunnel State
隧道的运行状态,取值包括Down和Up
隧道状态描述信息的取值包括:
·     Main CRLSP down:配置不全,主CRLSP未建立
·     Main CRLSP up:主CRLSP已建立
·     Main CRLSP being set up:主CRLSP正在建立中
·     Shared-resource CRLSP down:存在Shared-resource CRLSP相关配置,但Shared-resource CRLSP未建立
·     Shared-resource CRLSP up:Shared-resource CRLSP已建立
·     Shared-resource CRLSP being set up:Shared-resource CRLSP正在建立中
·     Shared-resource CRLSP being activated:Shared-resource CRLSP激活中
·     Shared-resource CRLSP switching to Main CRLSP:Shared-resource CRLSP与主CRLSP切换中
·     Backup CRLSP down:存在备份CRLSP相关配置,但备份CRLSP未建立
·     Backup CRLSP up:备份CRLSP已建立
·     Backup CRLSP being set up:备份CRLSP正在建立中
·     Reverse CRLSP down:配置了双向隧道,反向CRLSP未建立
·     Reverse CRLSP up:双向隧道的反向CRLSP已建立
·     Reverse CRLSP being set up:双向隧道的反向CRLSP正在建立中
LSP ID
LSP ID
Tunnel ID
会话ID
Admin State
隧道接口的管理状态,取值包括:
·     Normal:未通过shutdown命令关闭隧道接口
·     Shutdown:通过shutdown命令关闭隧道接口
Ingress LSR ID
入口标签交换路由器ID
Egress LSR ID
出口标签交换路由器ID
Signaling
建立隧道使用的信令协议,取值包括RSVP-TE和Static
Static CRLSP Name
隧道引用的静态CRLSP
Resv Style
实际生效的资源预留风格,对于动态建立CRLSP的MPLS TE隧道,本字段有意义,取值为FF和SE;对于静态建立CRLSP的MPLS TE隧道,本字段显示为“-”
Tunnel Mode
双向隧道的模式,取值包括:
·     Co-routed, active:表示Co-routed方式双向隧道的Active端
·     Co-routed, passive:表示Co-routed方式双向隧道的Passive端
·     Associated:表示Associated方式的双向隧道
Reverse-LSP Name
Associated方式反向LSP的名称
Reverse-LSP LSR ID
反向LSP的LSR ID
显示Associated方式双向隧道信息或Co-routed方式双向隧道的Passive端信息时,本字段有意义;其他情况下,本字段显示为“-”
反向LSP的Tunnel ID
Class Type
隧道流量所属的服务类型,取值包括CT0、CT1、CT2和CT3
Tunnel Bandwidth
隧道所需的带宽,单位为kbps
Reserved Bandwidth
为隧道预留的带宽,单位为kbps
Setup Priority
隧道的建立优先级
Holding Priority
隧道的保持优先级
Affinity Attr/Mask
隧道的亲和属性及掩码
Explicit Path Name
隧道引用的显式路径名称
存在显示路径时,本字段有意义,其他情况下,本字段显示为“-”
备份隧道引用的显式路径名称
Metric Type
隧道选路时使用的链路度量值类型,取值包括:
·     TE:使用TE度量值
·     IGP:使用IGP度量值
Record Route
是否开启路由记录功能,取值包括:
·     Enabled:开启了路由记录功能
·     Disabled:未开启路由记录功能
Record Label
是否开启标签记录功能,取值包括:
·     Enabled:开启了标签记录功能
·     Disabled:未开启标签记录功能
FRR Flag
是否开启快速重路由功能,取值包括:
·     Enabled:开启了快速重路由功能
·     Disabled:未开启快速重路由功能
快速重路由功能是否要求带宽保护,取值包括:
·     Enabled:要求带宽保护
·     Disabled:不要求带宽保护
是否通过mpls te backup bandwidth命令指定了Bypass隧道可以保护的带宽和CRLSP类型,取值包括:
·     Enabled:指定了Bypass隧道可以保护的带宽和CRLSP类型
·     Disabled:未指定Bypass隧道可以保护的带宽和CRLSP类型
Bypass隧道可以保护的主CRLSP流量的服务类型,取值包括CT0、CT1、CT2和CT3
Backup Bandwidth
Bypass隧道可以保护的带宽,单位为kbps
Bypass Tunnel
是否是Bypass隧道,取值包括:
·     Yes:是Bypass隧道
·     No:不是Bypass隧道
Auto Created
是否为自动创建的Bypass隧道,取值包括:
·     Yes:是自动创建
·     No:不是自动创建
Route Pinning
是否开启路由固定功能,取值包括:
·     Enabled:开启了路由固定功能
·     Disabled:未开启路由固定功能
Retry Limit
隧道的最大重建次数
Retry Interval
隧道重建的时间间隔,单位为秒
Reoptimization
是否开启隧道重优化功能,取值包括:
·     Enabled:开启了隧道重优化功能
·     Disabled:未开启隧道重优化功能
Reoptimization Freq
隧道重优化频率,单位为秒
Backup Type
隧道使用的备份模式,取值包括:
·     None:未开启隧道备份功能
·     Hot Standby:热备份
·     Ordinary:普通备份
Backup LSP ID
备份隧道的LSP ID
Auto Bandwidth
(暂不支持)是否开启自动带宽调整功能,取值包括:
·     Enabled:开启了自动带宽调整功能
·     Disabled:未开启自动带宽调整功能
Auto Bandwidth Freq
(暂不支持)自动带宽调整的时间间隔,单位为秒
Min Bandwidth
(暂不支持)允许调整到的最小带宽值,单位为kbps
Max Bandwidth
(暂不支持)允许调整到的最大带宽值,单位为kbps
Collected Bandwidth
(暂不支持)当前收集到的出口速率,单位为kbps
display ospf mpls te advertisement命令用来显示OSPF TEDB中的链路和节点信息。
display ospf [ process-id ] [ area area-id ] mpls te advertisement [ originate-router advertising-router-id | self-originate ]
process-id:显示指定OSPF进程的信息。process-id为OSPF进程号,取值范围为1~65535。如果未指定本参数,则显示所有OSPF进程的信息。
area area-id:显示指定区域的信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,则显示所有区域的信息。
originate-router advertising-router-id:显示指定路由器发布的信息。advertising-router-id为路由器的Router ID。
self-originate:显示本地路由器自己产生的信息。
# 显示OSPF TEDB中的链路和节点信息。
<Sysname> display ospf mpls te advertisement
                 Traffic Engineering Database
                          Area: 0.0.0.1
    Adv Router ID              : 1.1.1.1
    Flags                      : A/S/R
    Router Address Count       : 1
      Router Address Index     : 0
      Instance ID              : 0.0.0.0
    Link Count                 : 1
      Link Index               : 0
      Link Type                : Broadcast
      Instance ID              : 0.0.0.1
      Link Flags               : -/U/-
      Link ID                  : 197.168.1.1
      TE Metric                : 1000
      IGP Metric               : 1000
      Maximum Bandwidth        : 12500000 bytes/sec
      Maximum Reservable BW    : 0 bytes/sec
      Administrative Group     : 0x0
        TE class  0 = 0 bytes/sec
        TE class  1 = 0 bytes/sec
        TE class  2 = 0 bytes/sec
        TE class  3 = 0 bytes/sec
        TE class  4 = 0 bytes/sec
        TE class  5 = 0 bytes/sec
        TE class  6 = 0 bytes/sec
        TE class  7 = 0 bytes/sec
        TE class  8 = 0 bytes/sec
        TE class  9 = 0 bytes/sec
        TE class 10 = 0 bytes/sec
        TE class 11 = 0 bytes/sec
        TE class 12 = 0 bytes/sec
        TE class 13 = 0 bytes/sec
        TE class 14 = 0 bytes/sec
        TE class 15 = 0 bytes/sec
        BC [ 0] = 0 bytes/sec
        BC [ 1] = 0 bytes/sec
      Local Interface Address  : 197.168.1.1
      Remote Interface Address : 197.168.1.11
表1-14  display ospf mpls te advertisement命令显示信息描述表
Adv Router ID
发布该信息的路由器的Router ID
MPLS LSR ID
发布该信息的路由器的MPLS LSR ID
Flags
TE信息相关标记,取值包括:
·     A:表示已向CSPF同步该信息
·     S:表示准备向CSPF同步该信息
·     R:表示到达发布该信息的路由器的路由可达
TEDB中RouterTLV信息的总数
当前RouterTLV信息的索引
Instance ID
LSA的实例号
Link Count
TEDB中LinkTLV信息的总数
Link Index
当前LinkTLV信息的索引
Link Type
链路类型,取值包括:
·     Point to Point:点到点链路
·     Point to Multi Point:点到多点链路
·     Broadcast:广播链路
·     NBMA:非广播多点可达链路
Link Flags
Link信息相关标记,取值包括:
·     A:已向CSPF同步该信息
·     U:向CSPF同步更新该信息失败后,准备再次向CSPF同步
·     D:向CSPF同步删除该信息失败后,准备再次向CSPF同步
Link ID
链路状态ID
TE Metric
TE度量值
IGP Metric
OSPF协议度量值
Maximum bandwidth
链路的最大带宽
Maximum reservable BW
链路的最大可预留带宽
链路的管理组,即链路的属性
每个TE class的可预留带宽
TE class
16个TE class各自的可预留带宽
带宽约束模型,取值包括:Prestandard DS-TE RDM、IETF DS-TE RDM、IETF DS-TE MAM
带宽约束(仅对于DS-TE有意义)
BC
本地接口的主IP地址
远端接口的地址
display ospf mpls te network命令用来显示OSPF TEDB中的Network信息。
display ospf [ process-id ] [ area area-id ] mpls te network [ originate-router advertising-router-id | self-originate ]
area area-id:显示指定区域的信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式如果未指定本参数,则显示所有区域的信息。
# 显示OSPF TEDB中的Network信息。
<Sysname> display ospf mpls te network
         OSPF Process 1 with Router ID 12.1.1.1
                 Traffic Engineering Network
                          Area: 0.0.0.0
      Designated Router         :  197.168.1.1
      Flags                     :  -/U/-
       Attached Router    2.2.2.2
       Attached Router    1.1.1.1
表1-15 display ospf mpls te network命令显示信息描述表
Adv Router ID
发布该信息的路由器的Router ID
Designated Router
DR的IP地址
Flag
Network信息相关标记,取值包括:
·     A:已向CSPF同步该信息
Attached Router
相连路由器的Router ID
display ospf mpls te tunnel命令用来显示OSPF的Tunnel接口信息。
display ospf [ process-id ] [ area area-id ] mpls te tunnel
area area-id:显示指定区域的信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,则显示所有区域的信息。
# 显示OSPF的Tunnel接口信息。
<Sysname> display ospf mpls te tunnel
                   Traffic Engineering Tunnel
                          Area: 0.0.0.1
Interface: Tunnel1 (12.1.1.2)
    State: Inactive
    Neighbor ID: 0.0.0.0         Cost: 0
    Destination: 125.1.1.1
    Auto Route: IGP Shortcut
    Metric: Relative  10
表1-16 display ospf mpls te tunnel命令显示信息描述表
隧道类型接口的接口名称和接口地址
隧道接口的状态,取值包括:
·     Inactive:表示该隧道接口对应的路由不是最优路由,不用于转发报文
·     Active:表示该隧道接口对应的路由为最优路由,用于转发报文
Neighbor ID
隧道目的端的Router ID
Cost
隧道接口的路由开销
Destination
隧道目的端的LSR ID
Auto Route
隧道采用的自动路由发布方式,取值包括IGP Shortcut、IGP Advertise
Metric
MPLS TE隧道的度量值,取值包括:
·     Absolute:以绝对值的方式指定MPLS TE隧道的度量值
·     Relative:以相对值的方式指定MPLS TE隧道的度量值
ds-te bc-model命令用来配置IETF DS-TE模式下使用的带宽约束模型。
undo ds-te bc-model命令用来恢复缺省情况。
ds-te bc-model mam
undo ds-te bc-model
IETF DS-TE模式的带宽约束模型为RDM(Russian Dolls Model,俄罗斯套娃模型)。
MPLS TE视图
mam:指定带宽约束模型为MAM(Maximum Allocation Model,最大分配模型)。
RDM比较适用于属于CT的流量不平稳、可能存在突发流量的情况。RDM模型可以限制多种服务类型流量(CT)的共用带宽,允许多种CT间共享使用带宽,而不是限制某一种CT的带宽。RDM与建立优先级/保持优先级配合,可以实现CT间的带宽隔离。
MAM比较适用于属于CT的流量较为平稳、不存在突发流量的情况。MAM模型可以限制某一CT在接口上占用的带宽总和,即隔离CT之间的带宽使用。MAM不需要与建立优先级/保持优先级配合,就可以实现CT间的带宽隔离。MAM的特点是比较直观,配置较为容易。
本命令仅对IETF DS-TE模式有效。Prestandard DS-TE模式下,只能使用RDM带宽约束模型。
在IETF DS-TE模式下修改带宽约束模型后,设备上所有预留带宽非零的CRLSP都将被拆除,并重新建立。
# 配置IETF模式下带宽约束模型为MAM。
[Sysname] mpls te
[Sysname-te] ds-te bc-model mam
·     display mpls te ds-te
·     ds-te mode
1.1.16  ds-te mode
ds-te mode命令用来配置DS-TE模式。
undo ds-te mode命令用来恢复缺省情况。
ds-te mode ietf
undo ds-te mode
DS-TE模式为Prestandard模式。
MPLS TE视图
ietf:指定DS-TE模式为IETF模式。
Prestandard模式和IETF模式具有如下区别,请根据服务类型的数量、所需带宽约束模型等选择合适的DS-TE模式。
·     Prestandard模式支持2个CT(CT 0和CT 1),8种优先级,最大支持16个TE class;IETF模式支持4个CT(CT 0、CT 1、CT 2和CT 3),8种优先级,最大支持8个TE class。
·     Prestandard模式下不可以通过配置改变TE class;IETF模式下可以通过配置改变TE class。
·     Prestandard模式只支持RDM模型;IETF模式支持RDM模型和MAM模型。
·     Prestandard模式为自定义模式,无法与所有厂商设备互通;IETF模式为根据RFC标准实现的模式,可以与其他厂商设备互通。
修改DS-TE模式后,设备上所有的CRLSP都将被拆除,并重新建立。
# 配置DS-TE模式为IETF模式。
[Sysname] mpls te
[Sysname-te] ds-te mode ietf
·     ds-te bc-model
ds-te te-class命令用来配置IETF DS-TE模式下TE class与服务类型、优先级的对应关系。
undo ds-te te-class命令用来恢复缺省的TE class。
ds-te te-class te-class-index class-type class-type-number priority priority
undo ds-te te-class te-class-index
IETF模式的TE class如表1-17所示。
表1-17 IETF模式的缺省TE class
TE Class
CT
Priority
0
0
7
1
1
7
2
2
7
3
3
7
4
0
0
5
1
0
6
2
0
7
3
0
MPLS TE视图
te-class-index:TE class编号,取值范围为0~7。
class-type class-type-number:指定TE class对应的CT。class-type-number为CT编号,取值范围为0~3,即系统支持四个CT(CT 0、CT 1、CT 2和CT 3)。
priority priority:指定TE class对应的优先级。priority为优先级,取值范围为0~7。
如果流量属于某个CT,则传输该流量的LSP隧道的建立优先级或保持优先级必须是TE class中该CT对应的优先级。
通过ds-te te-class命令配置TE class时,输入的CT和优先级不要与已有TE class的CT和优先级相同。
通过undo ds-te te-class命令恢复缺省TE class时,恢复的TE class的CT和优先级不要与已有TE class的CT和优先级相同。
修改任意的TE class后,设备都会通知IGP更新发布所有TE接口的带宽信息,拆除所有TE接口上此TE class对应的CRLSP,并重新建立。
# 配置IETF模式下TE class 7对应CT 2,优先级为3。
[Sysname] mpls te
[Sysname-mpls] ds-te te-class 7 class-type 2 priority 3
·     ds-te mode
explicit-path命令用来创建隧道的显式路径,并进入显式路径视图。如果指定的显式路径已经存在,则直接进入显式路径视图。
undo explicit-path命令用来删除指定的显式路径。
explicit-path path-name
undo explicit-path path-name
不存在显式路径。
path-name:显式路径名称,为1~31个字符的字符串,区分大小写。
在显式路径视图下通过nexthop命令可以显式地指定隧道必须经过哪些节点或链路、不能经过哪些节点或链路,以便根据网络实际情况人为地干预隧道的建立。
# 创建一条名为path1的显式路径,并进入显式路径视图。
·     display explicit-path
·     mpls te backup-path
·     mpls te path
·     nexthop
fast-reroute timer命令用来配置在多条Bypass隧道中进行优选的时间间隔。
undo fast-reroute timer命令用来恢复缺省情况。
fast-reroute timer interval
在多条Bypass隧道中进行优选的时间间隔为300秒。
MPLS TE视图
interval:在多条Bypass隧道中进行优选的时间间隔,取值范围为0~604800,单位为秒。取值为0表示不会定期进行Bypass隧道优选。
如果为一条主CRLSP指定了多条Bypass隧道,MPLS TE会从中选择一条最优的Bypass隧道,当主CRLSP出现故障时,将流量切换到该Bypass隧道转发。在某些情况下(如Bypass隧道的可预留带宽发生变化),当前的最优隧道可能不是之前选中的Bypass隧道。因此,MPLS TE需要周期性地选择最优的Bypass隧道。通过本命令可以调整Bypass隧道优选的周期。
如果流量已经从主CRLSP切换到了Bypass隧道,则不再进行Bypass隧道优选。
# 配置在多条Bypass隧道中进行优选的时间间隔为120秒。
[Sysname] mpls te
[Sysname-te] fast-reroute timer 120
link-management periodic-flooding timer命令用来设置通过IGP周期性泛洪TE信息的时间间隔。
undo link-management periodic-flooding timer命令用来恢复缺省情况。
link-management periodic-flooding timer interval
通过IGP周期性泛洪TE信息的时间间隔为180秒。
MPLS TE视图
interval:通过IGP周期性泛洪TE信息的时间间隔,取值范围为0~3600,单位为秒。
链路的可预留带宽发生变化时,需要通过IGP泛洪链路的TE相关信息,以便将变化后的链路情况通知给网络中的设备。通过mpls te bandwidth change thresholds命令可以配置带宽变化达到一定程度时才进行IGP泛洪,而不是只要带宽变化就进行IGP泛洪,以减轻网络负担。此时,没有及时泛洪的链路带宽变化,就可以按照本命令配置的时间间隔周期性地通告给网络中的设备。
如果配置时间间隔为0,则表示关闭周期性泛洪功能。本命令配置的最小生效时间间隔为30秒,如果配置的时间间隔为1~29秒,则设备自动将时间间隔设置为30秒。
执行本命令后,配置的时间间隔立即生效。
# 配置通过IGP周期性泛洪TE信息的时间间隔为100秒。
[Sysname] mpls te
[Sysname-te] link-management periodic-flooding timer 100
·     mpls te bandwidth change thresholds
1.1.21  mpls te
mpls te命令用来开启本节点的MPLS TE能力,并进入MPLS TE视图。
undo mpls te命令用来关闭本节点的MPLS TE能力。
mpls te
undo mpls te
MPLS TE能力处于关闭状态。
执行undo mpls te命令后,将关闭本节点的MPLS TE能力,并拆除设备上所有CRLSP、删除所有接口下的MPLS TE相关配置。
# 开启本节点的MPLS TE能力,并进入MPLS TE视图。
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls te
[Sysname-te]
·     mpls te enable
mpls te affinity-attribute命令用来配置隧道的亲和属性,即隧道使用的链路需要具有的链路属性。
undo mpls te affinity-attribute命令用来恢复缺省情况。
mpls te affinity-attribute attribute-value [ mask mask-value ]
隧道的亲和属性为0x00000000,掩码为0x00000000,即隧道可以使用任意属性的链路。
Tunnel接口视图
attribute-value:隧道的亲和属性,取值范围为十六进制数0~ffffffff,即为32位的二进制数。亲和属性中的每一位二进制数代表一种属性,属性值为0或1。
mask mask-value:指定亲和属性的掩码。mask-value为亲和属性掩码,取值范围为十六进制数0~ffffffff,即为32位的二进制数。掩码中的每一位二进制数都表示是否检查该位的链路属性。掩码为1,表示需要检查该位的链路属性,只有该位的链路属性满足一定条件时,才可以使用该链路;掩码为0,表示不检查该位的链路属性,不管该位的链路属性与隧道的亲和属性是否相同,都可以使用该链路。
MPLS TE隧道的亲和属性和链路的属性配合,决定了该隧道可以使用哪些链路。
链路属性、亲和属性、亲和属性的掩码都是32位的二进制数。如果希望某条链路能够被隧道所用,则需要满足如下要求:
·     对于掩码为1的位,亲和属性为1的位中链路属性至少有1位也为1,亲和属性为0的位对应的链路属性位不能为1。
·     对于掩码为0的位,不对链路属性的相应位进行检查。
例如,亲和属性为0xfffffff0,掩码为0x0000ffff,则可用链路的链路属性高16位可以任意取0或1,17~28位中至少有1位为1,且低4位不能为1。
# 配置隧道的亲和属性为0x101,掩码为0x303,即只有链路属性的左数第23位为0、31位为0、24位和32位中至少有一位为1时,才可以使用该链路。
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls te affinity-attribute 101 mask 303
·     display mpls te tunnel-interface
·     mpls te link-attribute
mpls te auto-tunnel backup disable命令用来关闭接口的自动隧道备份功能。
undo mpls te auto-tunnel backup disable命令用来开启接口的自动隧道备份功能。
全局开启了自动隧道备份功能后,所有使能RSVP能力的接口都会开启自动隧道备份功能,允许自动创建Bypass隧道。
缺省情况下,全局开启了自动隧道备份功能后,所有使能RSVP能力的接口都会开启自动隧道备份功能,允许为采用该接口作为出接口的主隧道建立两条Bypass隧道(一条链路保护和一条节点保护的Bypass隧道)。由于Bypass隧道需要预先建立,占用额外的带宽。因此,为了节省网络带宽资源,应该只对关键的接口进行快速重路由保护,在非关键的接口上可以通过本命令关闭该接口的自动隧道备份功能,避免为该接口建立Bypass隧道。
配置mpls te auto-tunnel backup disable命令后,已自动创建的保护该接口的Bypass隧道会被删除。
# 关闭接口Vlan-interface10的自动隧道备份功能。
[Sysname-Vlan-interface10] mpls te auto-tunnel backup disable
·     auto-tunnel backup
mpls te backup命令用来开启隧道的备份功能,并配置使用的备份模式。
undo mpls te backup命令用来关闭隧道的备份功能。
mpls te backup { hot-standby | ordinary }
undo mpls te backup
隧道的备份功能处于关闭状态。
Tunnel接口视图
hot-standby:热备份,即创建主CRLSP后随即创建备份CRLSP。主CRLSP失效时,通过MPLS TE直接将业务切换至备份CRLSP。
ordinary:普通备份,即主CRLSP失效后再创建备份CRLSP。
通过本命令开启了隧道的备份功能后,将自动启动该隧道的路由记录功能,而不管用户是否配置了mpls te record-route命令。
在同一个Tunnel接口视图下,本命令与mpls te reoptimization命令互斥。
如果同时配置了mpls te backupmpls te bidirectional,则仅mpls te bidirectional生效。
# 开启隧道Tunnel1的备份功能,并配置使用的备份模式为热备份。
[Sysname-Tunnel1] mpls te backup hot-standby
mpls te backup bandwidth命令用来配置Bypass隧道可以保护的带宽和CT类型。
undo mpls te backup bandwidth命令用来恢复缺省情况。
mpls te backup bandwidth [ ct0 | ct1 | ct2 | ct3 ] { bandwidth | un-limited }
未指定Bypass隧道可以保护的带宽和CT类型。
Tunnel接口视图
ct0:只有CT 0的CRLSP可以使用Bypass隧道。
ct1:只有CT 1的CRLSP可以使用Bypass隧道。
ct2:只有CT 2的CRLSP可以使用Bypass隧道。
ct3:只有CT 3的CRLSP可以使用Bypass隧道。
bandwidth:Bypass隧道所能保护的带宽总量,取值范围为1~4294967295,单位为kbps。
un-limited:不对所能保护的带宽总量进行限制,即不能提供带宽保护。
如果不指定ct0ct1ct2ct3,则表示所有服务类型均可以使用Bypass隧道。
如果配置的保护带宽为un-limited,则该Bypass隧道不能提供带宽保护功能,即FRR保护时不保证被保护隧道的带宽。如果被保护的隧道流量总和超过Bypass隧道实际的带宽,会导致被保护隧道所承载的流量丢失。不要求带宽保护的主CRLSP优选此类Bypass隧道进行绑定。
如果为Bypass隧道配置了具体的保护带宽值,则该Bypass隧道能够提供带宽保护功能。要求带宽保护的主CRLSP优选此类Bypass隧道进行绑定。由于带宽为零的隧道意味着尽力转发,占用的带宽不固定,因此,此类Bypass隧道不能保护带宽为零的主CRLSP。此类Bypass隧道也不能保护带宽超过保护带宽的主CRLSP。
配置Bypass隧道能够提供带宽保护功能时,需要注意的是:
·     配置的保护带宽数目要小于Bypass隧道实际的带宽。否则,FRR切换后,会导致被保护隧道所承载的流量丢失,并可能造成被保护隧道down。
·     发生FRR切换后,如果修改Bypass隧道的保护带宽,使得保护带宽类型不同、保护带宽不够或者引起FRR保护类型(是否为主CRLSP提供带宽保护)变化,都将导致主CRLSP Down。
通过本命令配置的保护带宽仅用于计算并确立带宽保护关系,在Bypass隧道上不会预留相应的带宽。
在Tunnel接口视图下执行mpls te backup bandwidth命令后,将自动启动该隧道的路由记录功能,而不管用户是否配置了mpls te record-route命令。
# 配置隧道Tunnel1只用来保护属于CT 0的CRLSP,并且不对所保护带宽总量进行限制。配置隧道Tunnel2只用来保护属于CT 1的CRLSP,保护的带宽总量是1000kbps。
[Sysname-Tunnel1] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel1] quit
[Sysname] interface tunnel 2
[Sysname-Tunnel2] mpls te backup bandwidth ct1 1000
·     mpls te fast-reroute
mpls te backup-path命令用来配置备份CRLSP应用的路径及路径的优先级。
undo mpls te backup-path命令用来删除指定的备份路径。
mpls te backup-path preference value { dynamic | explicit-path path-name } [ no-cspf ]
undo mpls te backup-path preference value
使用自动计算的路径建立备份CRLSP。
Tunnel接口视图
preference value:指定路径的优先级。value的取值范围为1~10,数值越小,优先级越高。
dynamic:使用自动计算的路径建立备份CRLSP。
explicit-path path-name:引用已经存在的显式路径,根据该显式路径的要求建立备份CRLSP。path-name为显式路径名称,为1~31个字符的字符串,区分大小写。
no-cspf:不使用CSPF算法计算路径,通过查找路由来计算路径。
一个Tunnel接口下最多可以配置10条备份路径。不同备份路径的优先级不能相同。
建立备份CRLSP时,按照优先级从高到低的顺序,依次根据配置的路径进行CSPF计算,直到成功建立备份CRLSP。如果所有路径的CSPF计算都失败,则无法建立备份CRLSP。
只有通过mpls te backup命令开启隧道的备份功能后,本命令才会生效。
# 配置Tunnel1使用显式路径path1建立备份CRLSP。
[Sysname-Tunnel1] mpls te backup-path preference 2 explicit-path path1
·     mpls te backup
·     mpls te path
mpls te bandwidth命令用来配置MPLS TE隧道所需的带宽,并指定隧道流量所属的服务类型。
undo mpls te bandwidth命令用来恢复缺省配置。
mpls te bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth
未配置MPLS TE隧道所需的带宽,即带宽为0,隧道流量属于CT 0。
Tunnel接口视图
ct0:配置隧道流量属于CT 0。
ct1:配置隧道流量属于CT 1。
ct2:配置隧道流量属于CT 2。
ct3:配置隧道流量属于CT 3。
bandwidth:MPLS TE隧道所需的带宽,取值范围为1~4294967295,单位为kbps。
如果不指定ct0ct1ct2ct3,则隧道流量属于CT 0。
当配置MPLS TE隧道所需的带宽大于1024kbps时,建议配置为1024kbps的整数倍。
本命令只用于采用RSVP-TE协议建立的MPLS TE隧道。使用静态CRLSP建立MPLS TE隧道时,隧道所需的带宽及隧道流量所属的服务类型由static-cr-lsp ingress命令决定。
# 配置MPLS TE隧道所需带宽为1000kbps,隧道流量所属的服务类型为CT 1。
[Sysname-Tunnel1] mpls te bandwidth ct1 1000
mpls te bandwidth change thresholds命令用来配置通过IGP泛洪TE信息的带宽变化阈值。
undo mpls te bandwidth change thresholds命令用来恢复缺省情况。
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
通过IGP泛洪TE信息的带宽变化阈值为10%,即可预留带宽增加或减少10%时进行IGP泛洪。
down:配置可预留带宽减少时IGP进行泛洪的百分比阈值。当链路可预留带宽的减少值与链路原有可预留带宽的比值大于等于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
up:配置可预留带宽增加时IGP进行泛洪的百分比阈值。当链路可预留带宽的增加值与链路原有可预留带宽的比值大于等于此百分比阈值时,IGP将进行泛洪,并更新流量工程数据库。
percent:带宽变化的百分比阈值,取值范围为0~100。
链路的可预留带宽发生变化时,需要通过IGP泛洪链路的TE相关信息,以便将变化后的链路情况通知给网络中的设备。但是,频繁地IGP泛洪会增加网络中的流量,加大网络中设备的处理负担,并导致Ingress节点上频繁进行CSPF计算,占用过多的系统资源。通过本命令可以配置带宽变化达到一定程度时才进行IGP泛洪,以减轻网络负担。
# 在接口Vlan-interface10上配置链路带宽减少100%时进行IGP泛洪。
[Sysname-Vlan-interface10] mpls te bandwidth change thresholds down 100
·     link-management periodic-flooding timer
mpls te bidirectional命令用来在MPLS TE隧道接口上开启双向隧道功能。
undo mpls te bidirectional命令用来在MPLS TE隧道接口上关闭双向隧道功能。
mpls te bidirectional { associated reverse-lsp { lsp-name lsp-name | lsr-id ingress-lsr-id tunnel-id tunnel-id } | co-routed { active | passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id } }
MPLS TE隧道接口的双向隧道功能处于关闭状态,MPLS TE隧道接口上建立的隧道为MPLS TE单向隧道。
Tunnel接口视图
associated reverse-lsp lsp-name lsp-name:配置Associated方式的MPLS TE双向隧道,并指定关联的反向CRLSP。lsp-name为反向静态CRLSP的名称,为1~15个字符的字符串,区分大小写。
associated reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id:配置Associated方式的MPLS TE双向隧道,并指定关联的反向CRLSP。ingress-lsr-id为反向CRLSP的入节点LSR ID;tunnel-id为反向CRLSP的Tunnel ID,取值范围为0~65535。
co-routed:配置Co-routed方式的MPLS TE双向隧道。
active:指定本端作为Co-routed方式MPLS TE双向隧道的主动方。
passive reverse-lsp lsr-id ingress-lsr-id tunnel-id tunnel-id:指定本端作为Co-routed方式MPLS TE双向隧道的被动方,并指定关联的反向CRLSP。ingress-lsr-id为反向CRLSP的入节点LSR ID;tunnel-id为反向CRLSP的Tunnel ID,取值范围为0~65535。被动方上需要指定反向CRLSP,以便将正、反两个方向的单向CRLSP关联为MPLS TE双向隧道。
MPLS TE双向隧道的建立有如下几种方式:
·     Co-routed方式:通过RSVP-TE信令协议建立MPLS TE双向隧道。配置Co-routed方式MPLS TE双向隧道时,必须配置建立隧道使用的信令协议为RSVP-TE,且隧道的两端节点需要分别配置为主动方(Active)和被动方(Passive)。
·     Associated方式:通过配置手工将两条单向的CRLSP绑定,从而形成MPLS TE双向隧道。绑定在一起的两条单向CRLSP可以通过不同的方式建立,例如一个方向上的CRLSP使用静态方式建立,而另一个方向上的CRLSP使用RSVP-TE信令建立。绑定在一起的两条单向CRLSP使用的路径可以不同。
配置MPLS TE双向隧道时,在隧道两端都需要关闭PHP功能,为倒数第二跳分配非空标签。
如果mpls te bidirectionalmpls te backupmpls te reoptimizationmpls te fast-reroute同时配置,则仅mpls te bidirectional生效。
·     Co-routed方式
 # 在隧道本端Device A的接口Tunnel1上开启MPLS TE双向隧道功能,配置为Co-routed方式的主动方。
[DeviceA] interface tunnel 1 mode mpls-te
[DeviceA-Tunnel1] destination 10.0.0.2
[DeviceA-Tunnel1] mpls te bidirectional co-routed active
# 在隧道对端Device B的接口Tunnel1上开启MPLS TE双向隧道功能,并配置为Co-routed方式双向隧道的被动方,关联的反向CRLSP的入节点LSR ID为10.0.0.1,反向CRLSP的Tunnel ID为2。
[DeviceB] interface tunnel 1 mode mpls-te
[DeviceB-Tunnel1] destination 10.0.0.1
[DeviceB-Tunnel1] mpls te bidirectional co-routed passive reverse-lsp lsr-id 10.0.0.1 tunnel-id 2
·     Associated方式
# 在隧道本端Device A的接口Tunnel1上开启MPLS TE双向隧道功能,并配置双向隧道建立方式为Associated方式,关联的反向CRLSP的入节点LSR ID为10.0.0.2,反向CRLSP的Tunnel ID为2。
[DeviceA-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 10.0.0.2 tunnel-id 2
# 在隧道对端Device B的接口Tunnel1上开启MPLS TE双向隧道功能,并配置双向隧道建立方式为Associated方式,关联的反向CRLSP的入节点LSR ID为10.0.0.1,反向CRLSP的Tunnel ID为3。
[DeviceB-Tunnel1] mpls te bidirectional associated reverse-lsp lsr-id 10.0.0.1 tunnel-id 3
mpls te enable命令用来开启接口的MPLS TE能力。
undo mpls te enable命令用来关闭接口的MPLS TE能力。
mpls te enable
undo mpls te enable
接口上的MPLS TE能力处于关闭状态。
通过mpls te enable命令开启接口的MPLS TE能力后,该接口可以作为MPLS TE隧道的一部分。
在接口上执行undo mpls te enable命令后,将关闭接口的MPLS TE能力,并拆除接口上所有的CRLSP。
# 开启接口Vlan-interface10的MPLS TE能力。
[Sysname-Vlan-interface10] mpls te enable
·     display mpls te link-management bandwidth-allocation
·     mpls te
mpls te enable命令用来开启IS-IS进程的MPLS TE能力。
undo mpls te enable命令用来关闭IS-IS进程的MPLS TE能力。
mpls te enable [ level-1 | level-2 ]
undo mpls te enable [ level-1 | level-2 ]
IS-IS进程的MPLS TE能力处于关闭状态。
IS-IS视图
level-1:在IS-IS Level-1使能MPLS TE能力。
level-2:在IS-IS Level-2使能MPLS TE能力。
如果不指定级别,则同时使能Level-1和Level-2的MPLS TE能力。
IS-IS TE使用扩展IS可达性TLV(类型为22)的子TLV携带TE属性信息,扩展IS可达性TLV携带wide类型的开销值。因此,配置IS-IS TE时,必须配置IS-IS的开销值类型为widecompatiblewide-compatible。有关IS-IS的介绍请参见“三层技术-IP路由配置指导”中的“IS-IS”。
多次执行本命令,最后一次执行的命令生效。例如,执行mpls te enable命令后执行mpls te enable level-1命令,则使能Level-1的MPLS TE能力,关闭Level-2的MPLS TE能力。
通过mpls te enable命令同时使能Level-1和Level-2的MPLS TE能力后,如果配置undo mpls te enable level-1命令,则仅关闭Level-1的MPLS TE能力,Level-2的MPLS TE能力仍然使能。配置undo mpls te enable level-2命令,与此类似。
由于IS-IS 的TE信息不可分片,若接口mtulsp-length originate配置的值过小,会导致IS-IS 的LSP 携带TE信息失败,造成IS-IS功能不能正常运行。
# 开启IS-IS进程1的Level-2的MPLS TE能力。
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] mpls te enable level-2
·     cost-style(三层技术-IP路由命令参考/IS-IS)
mpls te enable命令用来开启OSPF区域的MPLS TE能力。
undo mpls te enable命令用来关闭OSPF区域的MPLS TE能力。
mpls te enable
undo mpls te enable
OSPF区域的MPLS TE能力处于关闭状态。
OSPF区域视图
OSPF TE使用Opaque Type 10 LSA携带链路的TE属性信息,因此,配置OSPF TE时必须先通过opaque-capability命令使能OSPF的Opaque能力。有关OSPF Opaque能力的介绍请参见“三层技术-IP路由配置指导”中的“OSPF”。
# 开启OSPF进程1区域1的MPLS TE能力。
[Sysname] ospf 1
[Sysname-ospf-1] area 1
[Sysname-ospf-1-area-0.0.0.1] mpls te enable
·     opaque-capability(三层技术-IP路由命令参考/OSPF)
mpls te fast-reroute命令用来开启快速重路由功能。
undo mpls te fast-reroute命令用来关闭快速重路由功能。
mpls te fast-reroute [ bandwidth ]
快速重路由功能处于关闭状态。
Tunnel接口视图
bandwidth:指定主CRLSP需要进行带宽保护。如果不指定本参数,则表示主CRLSP不需要进行带宽保护。
FRR(Fast Reroute,快速重路由)是MPLS TE中实现网络局部保护的技术。FRR的切换速度可以达到50ms,能够最大程度减少网络故障时数据的丢失。
开启隧道的FRR功能后,当主CRLSP上的某条链路或某个节点失效时,流量会被切换到Bypass隧道上。同时,隧道的Ingress节点尝试建立新的CRLSP。新的CRLSP建立成功后,流量将切换到新的CRLSP。
不需要进行带宽保护时,主CRLSP优选不提供保护带宽的Bypass隧道,表明FRR切换后不要求带宽保证;需要进行带宽保护时,主CRLSP优选具有足够保护带宽的Bypass隧道,以提供FRR切换后的带宽保证。
无论主CRLSP是否要求带宽保护,一旦主CRLSP和提供保护带宽的Bypass隧道绑定,就会占用保护带宽,在PLR节点的RRO信息中可以看到带宽保护标记。
通过本命令开启了隧道的快速重路由功能后,将自动启动该隧道的标签记录功能,而不管用户是否配置了mpls te record-route label命令。
如果同时配置了mpls te fast-reroutempls te bidirectional,则仅mpls te bidirectional生效。
# 开启接口Tunnel1的快速重路由功能。
[Sysname-Tunnel1] mpls te fast-reroute
·     mpls te backup bandwidth
mpls te fast-reroute bypass-tunnel命令用来为被保护的接口指定一条Bypass隧道。
undo mpls te fast-reroute bypass-tunnel命令用来删除指定的Bypass隧道。
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
接口上不存在任何Bypass隧道。
tunnel tunnel-number:指定Bypass隧道对应的隧道接口的编号。tunnel-number为Tunnel接口的编号,取值范围为1~4095。所指定的Bypass隧道必须使用RSVP信令协议建立且被保护的接口不能是Bypass隧道的出接口。
执行本命令后,如果主CRLSP的出接口Down、通过BFD或Hello机制检测到邻居故障,则会将主CRLSP的报文切换到Bypass隧道进行转发。
通过多次执行mpls te fast-reroute bypass-tunnel命令,可以为一个接口指定多条Bypass隧道。最多可以为一个被保护接口指定3条Bypass隧道。
一条隧道最多可以保护3个接口。
# 在接口Vlan-interface10上使用隧道接口Tunnel1作为Bypass隧道。
[Sysname-Vlan-interface10] mpls te fast-reroute bypass-tunnel tunnel 1
·     fast-reroute timer
mpls te igp advertise命令用来开启转发邻接功能,即将MPLS TE隧道作为一条链路发布到IGP路由中。
undo mpls te igp advertise命令用来关闭转发邻接功能。
mpls te igp advertise [ hold-time value ]
转发邻接功能处于关闭状态,即不会将MPLS TE隧道作为一条链路发布到IGP路由中。
Tunnel接口视图
hold-time value:MPLS TE隧道状态发生变化,即由up状态变更为down状态或由down状态变更为up状态后,通过IGP发布该信息的等待时间。value取值范围为0~4294967295,单位为毫秒,缺省值为0,即MPLS TE隧道状态变化后,立即通过IGP发布该信息。
使用转发邻接功能时,需要在隧道两端节点上都建立到达对方的MPLS TE隧道,并在两端节点上都开启转发邻接功能。
如果在同一接口下多次执行mpls te igp advertise命令和mpls te igp shortcut命令,则最后一次执行的命令生效。
# 开启转发邻接功能,并配置MPLS TE隧道状态变化后通过IGP发布该信息的等待时间为10000毫秒。
[Sysname-Tunnel1] mpls te igp advertise hold-time 10000
·     mpls te igp metric
·     mpls te igp shortcut
mpls te igp metric命令用来配置MPLS TE隧道的度量值。
undo mpls te igp metric命令用来恢复缺省情况。
mpls te igp metric { absolute value | relative value }
MPLS TE隧道的度量值等于其IGP度量值。
Tunnel接口视图
absolute value:以绝对值的方式指定度量值,即实际度量值为配置的值valuevalue为正整数,取值范围为1~65535。
relative value:以相对值的方式指定度量值,即实际度量值为配置的值value+该隧道的IGP度量值。value可以是正整数、负整数或0,取值范围为-10~10。
使用IGP Shortcut功能时,MPLS TE隧道作为一条链路参与IGP路由的计算。MPLS TE隧道这条链路在路由计算过程中的度量值可以通过本命令来配置。
# 配置在IGP Shortcut功能中计算IGP路由时,MPLS TE隧道Tunnel1的度量值为该隧道的IGP度量值-1。
[Sysname-Tunnel1] mpls te igp metric relative -1
mpls te igp shortcut命令用来开启IGP Shortcut功能,即在隧道的Ingress节点上将MPLS TE隧道当作一条链路参与IGP路由的计算。
undo mpls te igp shortcut命令用来关闭IGP Shortcut功能。
mpls te igp shortcut [ isis | ospf ]
IGP Shortcut功能处于关闭状态,即在隧道的Ingress节点上进行IGP路由计算时不考虑MPLS TE隧道。
Tunnel接口视图
isis:指定在IS-IS协议的路由计算中考虑MPLS TE隧道。
ospf:指定在OSPF协议的路由计算中考虑MPLS TE隧道。
如果不指定isisospf,则OSPF和IS-IS协议的路由计算中都考虑MPLS TE隧道。
# 开启IGP Shortcut功能,在MPLS TE隧道Tunnel1的Ingress节点上将该隧道当作一条链路参与OSPF和IS-IS路由的计算
[Sysname-Tunnel1] mpls te igp shortcut
·     mpls te igp advertise
mpls te link-attribute命令用来配置链路的属性。
undo mpls te link-attribute命令用来恢复缺省情况。
mpls te link-attribute attribute-value
链路的属性值为0x00000000。
attribute-value:链路的属性,取值范围为十六进制数0~ffffffff,即为32位的二进制数,每一位二进制数代表一个属性,属性值为0或1。
设备通过IGP发布的链路TE相关信息中包括本命令配置的链路属性。隧道的Ingress节点获取到该信息后,根据Ingress节点上配置的隧道亲和属性,判断建立MPLS TE隧道时是否可以使用该链路。如果希望某条链路能够被隧道所用,则需要满足如下要求:
# 在接口Vlan-interface10上配置该链路的属性为0x00000101。
[Sysname-Vlan-interface10] mpls te link-attribute 101
·     mpls te affinity-attribute
mpls te loop-detection命令用来配置隧道建立时进行环路检测。
undo mpls te loop-detection命令用来恢复缺省情况。
隧道建立时不进行环路检测。
Tunnel接口视图
通过本命令配置隧道建立时进行环路检测后,将自动启动该隧道的路由记录功能,而不管用户是否配置了mpls te record-route命令。隧道经过的节点根据记录的路由信息,判断是否出现环路。
# 配置建立MPLS TE隧道Tunnel1时进行环路检测。
[Sysname-Tunnel1] mpls te loop-detection
mpls te max-link-bandwidth命令用来配置用于转发MPLS TE流量的链路最大带宽。
undo mpls te max-link-bandwidth命令用来恢复缺省情况。
mpls te max-link-bandwidth bandwidth-value
用于转发MPLS TE流量的链路最大带宽为0。
bandwidth-value:链路的最大带宽,取值范围为1~4294967295,单位为kbps。
设备在发布的IGP路由中携带本命令配置的链路最大带宽值,以便隧道的Ingress节点获取到该信息,并根据该信息进行CSPF计算,选择符合隧道带宽要求的路径。
# 配置接口Vlan-interface10用于转发MPLS TE流量的链路最大带宽为1158kbps。
[Sysname-Vlan-interface10] mpls te max-link-bandwidth 1158
·     mpls te bandwidth
mpls te max-reservable-bandwidth命令用来配置Prestandard DS-TE模式下RDM带宽约束模型BC 0和BC 1的最大可预留带宽。
undo mpls te max-reservable-bandwidth命令用来恢复缺省情况。
mpls te max-reservable-bandwidth bandwidth-value [ bc1 bc1-bandwidth ]
最大可预留带宽为0。
bandwidth-value:链路的最大可预留带宽,即BC 0的最大可预留带宽,取值范围为1~4294967295,单位为kbps。
bc1 bc1-bandwidth:BC 1的最大可预留带宽,取值范围为1~4294967295,单位为kbps,缺省值为0。
设备在发布的IGP路由中携带本命令配置的最大可预留带宽值,以便隧道的Ingress节点获取到该信息,并根据该信息进行CSPF计算,选择符合隧道带宽要求的路径。
链路的最大可预留带宽bandwidth-value不能大于mpls te max-link-bandwidth命令配置的链路最大带宽,且BC 1的最大可预留带宽bc1-bandwidth不能大于链路的最大可预留带宽bandwidth-value
本命令配置的链路最大可预留带宽只能用于MPLS TE流量。
# Prestandard模式下配置链路上最多可以为MPLS TE流量预留1158kbps的带宽,BC 1的最大可预留带宽为200kbps。
[Sysname-Vlan-interface10] mpls te max-reservable-bandwidth 1158 bc1 200
·     mpls te bandwidth
mpls te max-reservable-bandwidth mam命令用来配置IETF DS-TE模式下MAM带宽约束模型的MPLS TE链路最大可预留带宽及各BC的最大可预留带宽。
undo mpls te max-reservable-bandwidth mam命令用来恢复缺省情况。
mpls te max-reservable-bandwidth mam bandwidth-value { bc0 bc0-bandwidth | bc1 bc1-bandwidth | bc2 bc2-bandwidth | bc3 bc3-bandwidth } *
最大可预留带宽均为0。
bandwidth-value:链路的最大可预留带宽,取值范围为1~4294967295,单位为kbps。
bc0 bc0-bandwidth:BC 0的最大可预留带宽,取值范围为1~4294967295,单位为kbps,缺省值为0。
bc2 bc2-bandwidth:BC 2的最大可预留带宽,取值范围为1~4294967295,单位为kbps,缺省值为0。
bc3 bc3-bandwidth:BC 3的最大可预留带宽,取值范围为1~4294967295,单位为kbps,缺省值为0。
链路的最大可预留带宽bandwidth-value不能大于mpls te max-link-bandwidth命令配置的链路最大带宽;所有BC的最大可预留带宽均不能大于链路的最大可预留带宽,即bc0-bandwidthbc1-bandwidthbc2-bandwidthbc3-bandwidth不能大于bandwidth-value
# 配置IETF模式MAM带宽约束模型下链路上最多可以为MPLS TE流量预留1158kbps的带宽,BC 0的最大可预留带宽为500kbps,BC 1的最大可预留带宽为300kbps,BC 2的最大可预留带宽为400kbps,BC 3的最大可预留带宽为100kbps。
[Sysname-Vlan-interface10] mpls te max-reservable-bandwidth mam 1158 bc0 500 bc1 300 bc2 400 bc3 100
·     mpls te bandwidth
mpls te max-reservable-bandwidth rdm命令用来配置IETF DS-TE模式RDM带宽约束模型各BC的最大可预留带宽。
undo mpls te max-reservable-bandwidth rdm命令用来恢复缺省情况。
mpls te max-reservable-bandwidth rdm bandwidth-value [ bc1 bc1-bandwidth ] [ bc2 bc2-bandwidth ] [ bc3 bc3-bandwidth ]
BC 0、BC 1、BC 2和BC 3的最大可预留带宽均为0。
BC 0的最大预留带宽bandwidth-value必须小于等于mpls te max-link-bandwidth命令配置的最大链路带宽;BC 0的最大预留带宽bandwidth-value必须大于等于BC 1的最大预留带宽bc1-bandwidth;BC 1的最大预留带宽bc1-bandwidth必须大于等于BC 2的最大预留带宽bc2-bandwidth;BC 2的最大预留带宽bc2-bandwidth必须大于等于BC 3的最大预留带宽bc3-bandwidth
# 配置IETF模式RDM带宽约束模型下BC 0的最大可预留带宽为500kbps,BC 1的最大可预留带宽为400kbps,BC 2的最大可预留带宽为300kbps,BC 3的最大可预留带宽为100kbps。
[Sysname-Vlan-interface1] mpls te max-reservable-bandwidth rdm 500 bc1 400 bc2 300 bc3 100
·     mpls te bandwidth
mpls te metric命令用来配置链路的TE度量值。
undo mpls te metric命令用来恢复缺省情况。
mpls te metric value
undo mpls te metric
链路使用其IGP度量作为TE的度量值。
value:链路的TE度量值,取值范围是1~4294967295。
设备在发布的IGP路由中携带链路的两种度量值:IGP度量值和TE度量值。其中,链路的TE度量值可以通过本命令来配置。隧道的Ingress节点获取到链路的度量值后,根据Ingress节点设备上mpls te path-metric-type命令或path-metric-type命令的配置,决定选择路径时采用IGP度量值还是TE度量值。
# 在接口Vlan-interface10上配置链路的TE度量值为20。
[Sysname-Vlan-interface10] mpls te metric 20
·     mpls te path metric-type
·     path metric-type
1.1.45  mpls te path
mpls te path命令用来配置CRLSP应用的路径及路径的优先级。
undo mpls te path命令用来删除指定的路径。
mpls te path preference value { dynamic | explicit-path path-name } [ no-cspf ]
undo mpls te path preference value
使用自动计算的路径建立CRLSP。
Tunnel接口视图
dynamic:使用自动计算的路径建立CRLSP。
explicit-path path-name:引用已经存在的显式路径,根据该显式路径的要求建立CRLSP。path-name为显式路径名称,为1~31个字符的字符串,区分大小写。
一个Tunnel接口下最多可以配置10条路径。不同路径的优先级不能相同。
建立CRLSP时,按照优先级从高到低的顺序,依次根据配置的路径进行CSPF计算,直到成功建立CRLSP。如果所有路径的CSPF计算都失败,则无法建立CRLSP。
# 配置Tunnel1使用显式路径path1建立CRLSP。
[Sysname-Tunnel1] mpls te path preference 2 explicit-path path1
mpls te path-metric-type命令用来配置隧道选路时使用的链路度量值类型。
undo mpls te path-metric-type命令用来恢复缺省情况。
mpls te path-metric-type { igp | te }
未指定隧道选路时使用的链路度量值类型。
Tunnel接口视图
igp:使用IGP度量。
te:使用TE度量。
在MPLS TE中每条链路都具有两种度量值:IGP度量值和TE度量值。通过合理地规划两种度量值,可以实现为不同种类的业务选择不同的隧道。例如,使用IGP度量值来表示链路延迟的大小(IGP度量值越小,链路的延迟越小),使用TE度量值来表示链路带宽的大小(TE度量值越小,链路的带宽越大)。建立两条MPLS TE隧道(Tunnel1和Tunnel2),分别用来承载语音业务和视频业务。Tunnel1选择路径时使用IGP度量值,可以实现为延迟要求较高的语音业务选择延迟小的路径;Tunnel2选择路径时使用TE度量值,可以实现为数据量较大的视频业务选择带宽大的路径。
如果在Tunnel接口视图下执行了本命令,则该隧道使用本接口下配置的度量值类型选择路径;否则,使用MPLS TE视图下path-metric-type命令配置的度量值类型选择路径。
# 配置为隧道Tunnel1选路时使用IGP度量。
[Sysname-Tunnel1] mpls te path-metric-type igp
·     mpls te metric
·     path-metric-type
mpls te priority命令用来配置MPLS TE隧道的建立优先级和保持优先级。
undo mpls te priority命令用来恢复缺省情况。
mpls te priority setup-priority [ hold-priority ]
建立优先级和保持优先级都为7。
Tunnel接口视图
setup-priority:建立优先级,取值范围为0~7,数值越小优先级越高。
hold-priority:保持优先级,取值范围为0~7,数值越小优先级越高。如果不指定本参数,则保持优先级与建立优先级相同。
建立优先级和保持优先级标识了MPLS TE隧道的重要程度。数值越小,优先级越高,MPLS TE隧道越重要。如果一条隧道的建立优先级数值小于另一条隧道的保持优先级,则该隧道可以抢占另一条隧道的资源。
建立优先级和保持优先级可以应用在以下场景:
·     多条MPLS TE隧道经过相同的路径,而该路径上的带宽不足以满足所有隧道的带宽要求时,通过为不同的隧道配置不同的建立优先级和保持优先级,可以确保重要的隧道能够优先建立。
·     在重要的隧道建立之前,网络中已经建立了多条MPLS TE隧道,占用了带宽资源,使得重要的隧道无法使用最优路径建立。此时,通过为重要的隧道配置更高的优先级,可以使得该隧道抢占已建立隧道的资源,采用最优路径建立重要隧道。
隧道的建立优先级不能高于该隧道的保持优先级,即其在数值上应大于或等于保持优先级。
# 配置隧道Tunnel1的建立优先级和保持优先级都为1。
[Sysname-Tunnel1] mpls te priority 1 1
mpls te record-route命令用来开启隧道的路由记录或标签记录功能。
undo mpls te record-route命令用来关闭隧道的路由记录和标签记录功能。
mpls te record-route [ label ]
隧道的路由记录和标签记录功能处于关闭状态。
Tunnel接口视图
label:同时开启路由记录和标签记录功能。如果不指定本参数,则仅开启路由记录功能,未开启标签记录功能。
路由记录和标签记录功能用来记录MPLS TE隧道经过的各个节点及各个节点分配的标签值,以便用户根据记录的信息了解MPLS TE隧道经过的路径和标签分配情况。在MPLS TE隧道出现故障时,用户也可以根据记录的信息对故障进行定位。
# 开启MPLS TE隧道Tunnel1的路由记录功能。
[Sysname-Tunnel1] mpls te record-route
mpls te reoptimization命令用来开启隧道重优化功能。
undo mpls te reoptimization命令用来关闭隧道重优化功能。
mpls te reoptimization [ frequency seconds ]
隧道重优化功能处于关闭状态。
Tunnel接口视图
frequency seconds:指定隧道重优化频率。seconds取值范围为1~604800,单位为秒,缺省值为3600。
隧道重优化功能是指周期性地或通过在用户视图下执行mpls te reoptimization命令手工触发隧道Ingress节点重新选择路径,以便将MPLS TE隧道切换到当前的最优路径。例如,如果在MPLS TE隧道建立时,最优路径上的链路没有足够的可预留带宽,则会导致MPLS TE隧道未使用最优路径建立。通过隧道重优化功能,可以实现链路上具有足够的带宽时将MPLS TE隧道自动切换到最优路径。
在同一个Tunnel接口下,隧道重优化功能与以下命令互斥:mpls te route-pinningmpls te backup
如果同时配置了mpls te reoptimizationmpls te bidirectional,则仅mpls te bidirectional生效。
# 开启隧道Tunnel1的重优化功能,并配置每隔43200秒(12小时)重新计算路由。
[Sysname-Tunnel1] mpls te reoptimization frequency 43200
·     mpls te reoptimization (user view)
mpls te reoptimization命令用来立即对所有开启了重优化功能的MPLS TE隧道进行重优化。
在Tunnel接口视图下通过mpls te reoptimization命令开启了该隧道的重优化功能后,在用户视图下执行本命令可以手工触发隧道Ingress节点重新为该隧道选择路径,以便将MPLS TE隧道切换到当前的最优路径。
# 立即对所有开启了重优化功能的MPLS TE隧道进行重优化。
<Sysname> mpls te reoptimization
·     mpls te reoptimization (tunnel interface view)
mpls te resv-style命令用来配置隧道的资源预留风格。
undo mpls te resv-style命令用来恢复缺省情况。
mpls te resv-style { ff | se }
隧道的资源预留风格为SE。
Tunnel接口视图
ff:使用FF(Fixed-Filter,固定过滤器)资源预留风格。FF资源预留风格是指为每个发送者单独预留资源,同一会话中的不同发送者不能共享资源。
se:使用SE(Shared-Explicit,共享显式)资源预留风格。SE资源预留风格是指为同一个会话中的不同发送者预留同一个资源,不同发送者之间可以共享资源。
只有采用RSVP-TE协议建立MPLS TE隧道时,本命令才会生效。
# 配置使用FF资源预留风格建立MPLS TE隧道Tunnel1。
[Sysname-Tunnel1] mpls te resv-style ff
·     mpls te signaling
mpls te retry命令用来配置尝试建立隧道的最大次数。
undo mpls te retry命令用来恢复缺省情况。
mpls te retry retries
undo mpls te retry
尝试建立隧道的最大次数为3次。
Tunnel接口视图
retries:尝试建立隧道的最大次数,取值范围为1~4294967295。
MPLS TE隧道建立失败后,隧道的Ingress节点等待mpls te timer retry命令配置的隧道重建时间间隔后,将尝试重新建立隧道,直到隧道建立成功或尝试建立隧道的次数达到本命令配置的值。如果尝试建立隧道的次数达到本命令配置的值时仍未成功建立隧道,则等待较长的一段时间后,重复上述过程。
# 配置尝试建立隧道Tunnel1的最大次数为20次。
[Sysname-Tunnel1] mpls te retry 20
·     mpls te timer retry
mpls te route-pinning命令用来开启路由固定功能。
undo mpls te route-pinning命令用来关闭路由固定功能。
路由固定功能处于关闭状态。
Tunnel接口视图
路由固定功能是指CRLSP创建成功后,该CRLSP不随路由变化而变化。
在路由变化频繁的网络中,如果不希望CRLSP随着路由频繁变化,则可以通过本功能确保只要已建立的CRLSP可用就不重新创建CRLSP。
在同一个Tunnel接口视图下,本命令与mpls te reoptimization互斥。
# 开启隧道Tunnel1的路由固定功能。
[Sysname-Tunnel1] mpls te route-pinning
mpls te signaling命令用来配置建立MPLS TE隧道使用的信令协议。
undo mpls te signaling命令用来恢复缺省情况。
mpls te signaling { rsvp-te | static }
MPLS TE使用RSVP-TE信令协议建立隧道。
Tunnel接口视图
rsvp-te:使用RSVP-TE信令协议建立隧道。
static:使用静态CRLSP建立隧道。
如果使用RSVP-TE信令协议建立MPLS TE隧道,则必须在隧道经过的路径上,开启接口的MPLS TE能力和RSVP-TE能力。
如果使用静态CRLSP建立隧道,则必须通过mpls te static-cr-lsp命令指定引用的静态CRLSP。
# 配置使用RSVP-TE信令协议建立MPLS TE隧道Tunnel1。
[Sysname-Tunnel1] mpls te signaling rsvp-te
·     mpls te static-cr-lsp
mpls te static-cr-lsp命令用来指定隧道引用的静态CRLSP。
undo mpls te static-cr-lsp命令用来取消引用指定的静态CRLSP。
mpls te static-cr-lsp lsp-name
undo mpls te static-cr-lsp lsp-name
隧道没有引用任何静态CRLSP。
Tunnel接口视图
lsp-name:引用的静态CRLSP的名称,为1~15个字符的字符串,区分大小写。
只有在Tunnel接口视图下配置了mpls te signaling static命令,本命令才会生效。
本命令需要在Ingress节点上执行,即本命令中引用的静态CRLSP,必须是通过static-cr-lsp ingress命令创建的。
# 配置隧道Tunnel1引用名称为static-te-3的静态CRLSP。
[Sysname-Tunnel1] mpls te static-cr-lsp static-te-3
·     mpls te signaling
·     static-cr-lsp egress(MPLS命令参考/静态CRLSP)
·     static-cr-lsp ingress(MPLS命令参考/静态CRLSP)
·     static-cr-lsp transit(MPLS命令参考/静态CRLSP)
mpls te timer retry命令用来配置隧道重建的时间间隔。
undo mpls te timer retry命令用来恢复缺省情况。
mpls te timer retry seconds
隧道重建的时间间隔为2秒。
Tunnel接口视图
seconds:隧道重建的时间间隔,取值范围为1~604800,单位为秒。
MPLS TE隧道建立失败后,隧道的Ingress节点等待本命令配置的隧道重建时间间隔后,将尝试重新建立隧道,直到隧道建立成功或尝试建立隧道的次数达到mpls te retry命令配置的值。如果尝试建立隧道的次数达到最大值时仍未成功建立隧道,则等待较长的一段时间后,重复上述过程。
# 配置每隔20秒重建隧道Tunnel1。
[Sysname-Tunnel1] mpls te timer retry 20
·     mpls te retry
1.1.57  nexthop
nexthop命令用来在显式路径中添加或修改节点及其属性(显式路径中是否包括添加的节点;添加的节点是松散下一跳,还是严格下一跳)。
undo nexthop命令用来删除显式路径中的指定节点。
nexthop [ index index-number ] ip-address [ exclude | include [ loose | strict ] ]
undo nexthop index index-number
显式路径中不存在任何节点。
显式路径视图
index-number:节点在显式路径中的索引,取值范围为1~65535。如果不指定本参数,则自动计算索引值,大小为当前最大索引值+100。
ip-address:显式路径中节点的IP地址,点分十进制格式。
exclude:在显式路径中不能包括此节点。
include:指定在显式路径中需要包含此节点。
loose:指定的节点为松散下一跳,即上一跳与本节点可以不是直接相连。
strict:指定的节点为严格下一跳,即上一跳与本节点必须直接相连。
本命令中指定的节点地址可以是:
·     链路的IP地址:即设备上接口的IP地址,代表该地址所属的设备。
·     设备的LSR ID:代表该设备。
严格下一跳的地址只能是链路的IP地址。松散下一跳的地址可以是链路的IP地址和设备的LSR ID。
对于exclude的节点,在CSPF计算时排除该地址对应的链路或设备;对于include的节点,CSPF计算时按照索引从小到大的顺序,依次查找符合节点地址要求的链路,以便建立CRLSP。
执行本命令时:
·     如果指定了索引,且该索引已经存在,则修改节点的地址或属性。
·     如果未指定includeexclude关键字,则缺省为include,即在显式路径中需要包含此节点。
·     如果未指定loosestrict关键字,则缺省为strict,即上一跳与本节点必须直接相连。
# 配置MPLS TE显式路径中不包括IP地址10.0.0.125。
[Sysname-explicit-path-path1] next-hop 10.0.0.125 exclude
1.1.58  nhop-only
nhop-only命令用来配置仅自动创建链路保护类型的Bypass隧道。
undo nhop-only命令用来恢复缺省情况。
nhop-only
undo nhop-only
链路保护和节点保护的Bypass隧道都会自动创建。
MPLS TE自动隧道备份视图
执行nhop-only命令后,如果设备已创建节点保护类型的Bypass隧道,则节点保护类型的Bypass隧道将被删除。
# 配置仅自动创建链路保护类型的Bypass隧道。
[Sysname] mpls te
[Sysname-te-auto-bk] nhop-only
·     tunnel-number
path-metric-type命令用来配置未配置度量类型的隧道选路时使用的链路度量值类型。
undo path-metric-type命令用来恢复缺省情况。
未配置度量类型的隧道选路时使用TE度量值。
MPLS TE视图
igp:使用IGP度量。
te:使用TE度量。
如果在Tunnel接口视图下执行了mpls te path-metric-type命令,则该隧道使用接口下配置的度量值类型选择路径;否则,使用本命令配置的度量值类型选择路径。
# 对所有未指定度量类型的MPLS TE隧道,配置其在进行路径计算时使用IGP度量值。
[Sysname] mpls te
[Sysname-te] path-metric-type igp
·     mpls te metric
·     mpls te path-metric-type
snmp-agent trap enable te命令用来开启MPLS TE模块的告警功能。
undo snmp-agent trap enable te命令用来关闭MPLS TE模块的告警功能。
MPLS TE模块的告警功能处于开启状态。
开启MPLS TE模块的告警功能后,当MPLS TE隧道状态发生变化时会产生RFC 3812中规定的告警信息。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。
# 开启MPLS TE模块的告警功能。
[Sysname] snmp-agent trap enable te
1.1.61  te-subtlv
te-subtlv命令用来配置携带DS-TE参数的各种子TLV的TLV类型值。
undo te-subtlv命令用来恢复缺省情况。
te-subtlv { bw-constraint value | unreserved-subpool-bw value } *
undo te-subtlv { bw-constraint | unreserved-subpool-bw } *
带宽约束bw-constraint的子TLV类型值为252;子池未预订带宽unreserved-subpool-bw的子TLV类型值为251。
IS-IS视图
bw-constraint value:指定带宽约束的子TLV类型值,value取值范围为23~254。
unreserved-subpool-bw value:指定子池未预订带宽的子TLV类型值,value取值范围为23~254。
在Prestandard模式下,携带DS-TE参数的子TLV类型值未形成标准,不同厂商可能使用不同的类型值。为了实现不同厂商设备的互通,需要通过本命令手工配置这些子TLV的类型值。
DS-TE模式为Prestandard时,本命令生效;模式为IETF时,本命令不生效。
# 配置IS-IS进程1携带DS-TE参数的各种子TLV的TLV类型值:
·     带宽约束bw-constraint的子TLV类型值为200;
·     子池未预订带宽unreserved-subpool-bw的子TLV类型值为202。
[Sysname] isis 1
[Sysname-isis-1] te-subtlv bw-constraint 200 unreserved-subpool-bw 202
·     display isis mpls te configured-sub-tlvs
timers removal unused命令用来配置空闲Bypass隧道的自动清除时间。
undo timers removal unused命令用来恢复缺省情况。
timers removal unused seconds
空闲Bypass隧道的自动清除时间为3600秒。
MPLS TE自动隧道备份视图
seconds:空闲Bypass隧道的自动清除时间,取值范围为0、300~604800,单位为秒。取值为0表示禁止清除空闲的Bypass隧道。
一条自动创建的Bypass隧道可以与多条主隧道绑定。当Bypass隧道没有与任何主隧道绑定时,该Bypass隧道称为空闲Bypass隧道。自动创建的Bypass隧道的空闲时间到达本命令配置的值时,自动清除该隧道,以释放该隧道占用的带宽资源和接口编号。
本命令配置的值如果过大,则会导致Bypass隧道长时间占用带宽资源和接口编号;本命令配置的值如果过小,则可能会导致Bypass隧道频繁建立和拆除。
# 配置空闲Bypass隧道的自动清除时间为100分钟。
[Sysname] mpls te
[Sysname-te-auto-bk] timers removal unused 60000
·     tunnel-number
tunnel-number命令用来配置自动创建的Bypass隧道的接口编号范围。
undo tunnel-number命令用来恢复缺省情况。
tunnel-number min min-number max max-number
undo tunnel-number
未指定自动创建Bypass隧道的接口编号范围,不能自动创建Bypass隧道。
MPLS TE自动隧道备份视图
min min-number max max-number:指定自动创建Bypass隧道的接口编号的最小值和最大值。min-numbermax-number的取值范围均为1~4095。配置的min-number必须小于等于max-number,且min-numbermax-number的差值必须小于1000。
通过auto-tunnel backup命令全局开启自动隧道备份功能后,还需执行本命令,才能自动建立Bypass隧道;否则,无法自动建立Bypass隧道。自动建立Bypass隧道时,设备按照由小到大的顺序从本命令指定的范围内依次为Bypass隧道选择接口编号。
多次执行本命令,最后一次执行的命令生效,且修改后的编号范围需要包含已经自动创建的Bypass隧道的接口编号,否则命令无法成功执行。即:如果在修改编号范围前已经自动创建了Bypass隧道,则min-number不能大于这些Bypass隧道中的接口编号的最小值;max-number不能小于这些Bypass隧道中的接口编号的最大值。
通过interface tunnel命令手工创建隧道接口时,指定的隧道接口编号可以在本命令配置的范围内,该编号不会再用于自动创建的Bypass隧道;通过undo interface tunnel命令删除该隧道接口后,该接口编号仍然可以用于自动创建的Bypass隧道。
# 配置自动创建的Bypass隧道的接口编号范围为100到120。
[Sysname] mpls te
[Sysname-te-auto-bk] tunnel-number min 100 max 120
