01-Probe命令
本章节下载: 01-Probe命令 (1.12 MB)
1.1.1 crypto-engine accelerator disable
1.2.2 debugging system internal adj4
1.2.3 debugging system internal adj6
1.2.4 debugging system internal arp event
1.2.5 debugging system internal arp features
1.2.6 debugging system internal arp mac-forced-forwarding
1.2.7 debugging system internal arp notify
1.2.8 debugging system internal arp sync
1.2.9 debugging system internal fib prefix
1.2.10 debugging system internal fib vn
1.2.11 debugging system internal flow-manager
1.2.12 debugging system internal ip vpn-instance
1.2.13 debugging system internal ipv6 fib prefix
1.2.14 debugging system internal nd
1.2.15 debugging system internal nd sub-features
1.2.16 debugging system internal sib flow
1.2.17 debugging system internal vlan
1.2.19 display fastforward session table
1.2.20 display hardware internal transceiver register interface
1.2.21 display system internal acl
1.2.22 display system internal adj4 entry
1.2.23 display system internal adj4 statistics
1.2.24 display system internal adj6 entry
1.2.25 display system internal adj6 statistics
1.2.26 display system internal adjacent-table
1.2.27 display system internal arp
1.2.28 display system internal arp ifcb
1.2.29 display system internal arp ip-address
1.2.30 display system internal arp mac-forced-forwarding
1.2.31 display system internal arp machash
1.2.32 display system internal arp probe
1.2.33 display system internal arp rbhash
1.2.34 display system internal arp reload
1.2.35 display system internal arp rule
1.2.36 display system internal arp source-suppression cache
1.2.37 display system internal arp statistics
1.2.38 display system internal arp vlan
1.2.39 display system internal aspf statistics
1.2.40 display system internal attack-defense scan stat-nodes ip
1.2.41 display system internal attack-defense scan stat-nodes ipv6
1.2.42 display system internal bfd packet statistics
1.2.43 display system internal blacklist ip
1.2.44 display system internal blacklist ipv6
1.2.45 display system internal bridge cache ip verbose
1.2.46 display system internal bridge cache ipv6 verbose
1.2.47 display system internal client-verify http redirect-node
1.2.48 display system internal context block-information
1.2.49 display system internal context configuration-status
1.2.50 display system internal context running-status
1.2.51 display system internal customlog host
1.2.52 display system internal customlog mbuf dump
1.2.53 display system internal customlog mbuf usage
1.2.54 display system internal customlog test
1.2.55 display system internal data-filter match
1.2.56 display system internal data-filter policy
1.2.57 display system internal data-filter rule
1.2.58 display system internal dbm
1.2.59 display system internal ethernet character
1.2.60 display system internal ethernet controlblock
1.2.61 display system internal fib prefix
1.2.62 display system internal fib prefix entry-status
1.2.63 display system internal fib prefix ip-address
1.2.64 display system internal fib running-status
1.2.65 display system internal fib statistics
1.2.66 display system internal fib vn
1.2.67 display system internal fib vn entry-status
1.2.68 display system internal flow-manager failover-group
1.2.69 display system internal ha service
1.2.70 display system internal ha service-group
1.2.71 display system internal ha statistics
1.2.72 display system internal hot-backup broadcast node
1.2.73 display system internal hot-backup peer
1.2.74 display system internal ifmgr brief
1.2.75 display system internal ifmgr down
1.2.76 display system internal ifmgr entry
1.2.77 display system internal ifmgr event
1.2.78 display system internal ifmgr hotplug
1.2.79 display system internal ifmgr index
1.2.80 display system internal ifmgr list
1.2.81 display system internal ifmgr name
1.2.82 display system internal ifmgr type
1.2.83 display system internal inspect dim-rule
1.2.84 display system internal inspect hit-statistics
1.2.85 display system internal inspect http
1.2.86 display system internal inspect memory engine ac
1.2.87 display system internal inspect memory engine mn
1.2.88 display system internal inspect memory rule
1.2.89 display system internal inspect statistic packet
1.2.90 display system internal ip address
1.2.91 display system internal ip fast-forwarding cache verbose
1.2.92 display system internal ip routing-table
1.2.93 display system internal ip routing-table acl
1.2.94 display system internal ip routing-table ip-address
1.2.95 display system internal ip routing-table prefix-list
1.2.96 display system internal ip routing-table protocol
1.2.97 display system internal ip routing-table statistics
1.2.98 display system internal ip source binding
1.2.99 display system internal ip vpn-binding
1.2.100 display system internal ip vpn-instance
1.2.101 display system internal ip vpn-instance inactive
1.2.102 display system internal ip vpn-instance statistics
1.2.103 display system internal ipv6 address
1.2.104 display system internal ipv6 adjacent-table
1.2.105 display system internal ipv6 fast-forwarding cache verbose
1.2.106 display system internal ipv6 fast-forwarding statistics
1.2.107 display system internal ipv6 fib prefix
1.2.108 display system internal ipv6 fib prefix entry-status
1.2.109 display system internal ipv6 fib prefix ipv6-address
1.2.110 display system internal ipv6 pathmtu
1.2.111 display system internal ipv6 pbr fib
1.2.112 display system internal ipv6 pbr kernel policy
1.2.113 display system internal ipv6 pbr policy
1.2.114 display system internal ipv6 rawip
1.2.115 display system internal ipv6 rib event attribute
1.2.116 display system internal ipv6 rib event policy
1.2.117 display system internal ipv6 rib event prefix
1.2.118 display system internal ipv6 rib event protocol
1.2.119 display system internal ipv6 rib event statistics
1.2.120 display system internal ipv6 rib instance
1.2.121 display system internal ipv6 rib log
1.2.122 display system internal ipv6 rib memory
1.2.123 display system internal ipv6 rib nib
1.2.124 display system internal ipv6 rib nib log
1.2.125 display system internal ipv6 rib prefix
1.2.126 display system internal ipv6 rib summary
1.2.127 display system internal ipv6 route-direct interface
1.2.128 display system internal ipv6 route-direct log
1.2.129 display system internal ipv6 route-static nib log
1.2.130 display system internal ipv6 routing-table
1.2.131 display system internal ipv6 routing-table acl
1.2.132 display system internal ipv6 routing-table ipv6-address
1.2.133 display system internal ipv6 routing-table prefix-list
1.2.134 display system internal ipv6 routing-table protocol
1.2.135 display system internal ipv6 routing-table statistics
1.2.136 display system internal ipv6 source binding
1.2.137 display system internal ipv6 tcp
1.2.138 display system internal ipv6 tcp port-info
1.2.139 display system internal ipv6 udp
1.2.140 display system internal ipv6 udp port-info
1.2.141 display system internal irf global
1.2.142 display system internal irf msg
1.2.143 display system internal irf roledb
1.2.144 display system internal irf topodb
1.2.145 display system internal kernel memory dump
1.2.146 display system internal kernel memory pool
1.2.147 display system internal license buffer-data
1.2.148 display system internal license feature-set
1.2.149 display system internal license fifo
1.2.150 display system internal license lipc
1.2.151 display system internal license lipc hash
1.2.152 display system internal license lmi-paa
1.2.153 display system internal link-aggregation global
1.2.154 display system internal link-aggregation interface
1.2.155 display system internal mac-address configuration
1.2.156 display system internal mac-address learned
1.2.157 display system internal mac-address statistics
1.2.158 display system internal mac-forwarding cache ip verbose
1.2.159 display system internal mac-forwarding cache ipv6 verbose
1.2.160 display system internal mac-forwarding controlblock
1.2.161 display system internal nd dad
1.2.162 display system internal nd entry
1.2.163 display system internal nd ifcb
1.2.164 display system internal nd machash
1.2.165 display system internal nd probe
1.2.166 display system internal nd rbhash
1.2.167 display system internal nd reload
1.2.168 display system internal nd rule
1.2.169 display system internal nd static
1.2.170 display system internal nd statistics
1.2.171 display system internal object-group
1.2.172 display system internal object-policy
1.2.173 display system internal ospf event-log
1.2.174 display system internal ospf flood-list
1.2.175 display system internal ospf interface
1.2.176 display system internal ospf interface standby
1.2.177 display system internal ospf keychain
1.2.178 display system internal ospf lsdb
1.2.179 display system internal ospf lsdb standby
1.2.180 display system internal ospf nib
1.2.181 display system internal ospf peer standby
1.2.182 display system internal ospf peer statistics standby
1.2.183 display system internal ospf prefix
1.2.184 display system internal ospf router
1.2.185 display system internal ospf sham-link standby
1.2.186 display system internal ospf statistics
1.2.187 display system internal ospf status
1.2.188 display system internal ospf vlink standby
1.2.189 display system internal ospfv3 event-log
1.2.190 display system internal ospfv3 flood-list
1.2.191 display system internal ospfv3 interface
1.2.192 display system internal ospfv3 interface standby
1.2.193 display system internal ospfv3 lsdb
1.2.194 display system internal ospfv3 lsdb standby
1.2.195 display system internal ospfv3 nib
1.2.196 display system internal ospfv3 peer standby
1.2.197 display system internal ospfv3 prefix
1.2.198 display system internal ospfv3 router
1.2.199 display system internal ospfv3 standby
1.2.200 display system internal ospfv3 statistics
1.2.201 display system internal ospfv3 status
1.2.202 display system internal ospfv3 vlink standby
1.2.203 display system internal pbr fib
1.2.204 display system internal pbr kernel policy
1.2.205 display system internal pbr policy
1.2.206 display system internal process state
1.2.207 display system internal rawip
1.2.208 display system internal rib event attribute
1.2.209 display system internal rib event policy
1.2.210 display system internal rib event prefix
1.2.211 display system internal rib event protocol
1.2.212 display system internal rib event statistics
1.2.213 display system internal rib ftn
1.2.214 display system internal rib ftn summary
1.2.215 display system internal rib instance
1.2.216 display system internal rib log
1.2.217 display system internal rib memory
1.2.218 display system internal rib nib
1.2.219 display system internal rib nib log
1.2.220 display system internal rib prefix
1.2.221 display system internal rib summary
1.2.222 display system internal rip database standby
1.2.223 display system internal rip graceful-restart event-log
1.2.224 display system internal rip interface
1.2.225 display system internal rip interface standby
1.2.226 display system internal rip neighbor standby
1.2.227 display system internal rip nib
1.2.228 display system internal rip nib log
1.2.229 display system internal rip non-stop-routing event-log
1.2.230 display system internal rip route standby
1.2.231 display system internal rip status
1.2.232 display system internal ripng database standby
1.2.233 display system internal ripng graceful-restart event-log
1.2.234 display system internal ripng interface
1.2.235 display system internal ripng interface standby
1.2.236 display system internal ripng neighbor standby
1.2.237 display system internal ripng nib
1.2.238 display system internal ripng nib log
1.2.239 display system internal ripng non-stop-routing event-log
1.2.240 display system internal ripng route standby
1.2.241 display system internal ripng status
1.2.242 display system internal route-direct interface
1.2.243 display system internal route-direct log
1.2.244 display system internal route-static nib log
1.2.245 display system internal session
1.2.246 display system internal session alg-exception
1.2.247 display system internal session fdb statistics
1.2.248 display system internal session hot-backup statistics
1.2.249 display system internal session relation hot-backup statistics
1.2.250 display system internal session relation-table ipv4
1.2.251 display system internal session relation-table ipv6
1.2.252 display system internal session statistics
1.2.253 display system internal session table ipv4
1.2.254 display system internal session table ipv6
1.2.255 display system internal startup cache
1.2.256 display system internal tcp
1.2.257 display system internal tcp port-info
1.2.258 display system internal udp
1.2.259 display system internal udp port-info
1.2.260 display system internal userlog mbuf dump
1.2.261 display system internal userlog statistic
1.2.262 display system internal userlog test
1.2.263 display system internal virtual-crypto-engine
1.2.264 display system internal virtual-crypto-engine statistics
1.2.265 display system internal vlan
1.2.266 display transceiver information interface
1.2.267 display transceiver moduleinfo
1.2.268 display transceiver register
1.5.1 memory boundary-check enable
1.5.2 memory boundary-check scan
1.7.1 reset system internal adj4 statistics
1.7.2 reset system internal adj6 statistics
1.7.3 reset system internal arp statistics
1.7.4 reset system internal aspf statistics
1.7.5 reset system internal data-filter match statistics
1.7.6 reset system internal data-filter rule statistics
1.7.7 reset system internal fib statistics
1.7.8 reset system internal inspect hit-statistics
1.7.9 reset system internal inspect http
1.7.10 reset system internal ip routing-table statistics protocol
1.7.11 reset system internal ipv6 fast-forwarding statistics
1.7.12 reset system internal ipv6 rib log
1.7.13 reset system internal ipv6 rib nib log
1.7.14 reset system internal ipv6 rib summary
1.7.15 reset system internal ipv6 route-direct log
1.7.16 reset system internal ipv6 route-static nib log
1.7.17 reset system internal ipv6 routing-table statistics protocol
1.7.18 reset system internal irf msg
1.7.19 reset system internal mac-address statistics
1.7.20 reset system internal nd statistics
1.7.21 reset system internal ospf event-log
1.7.22 reset system internal rib log
1.7.23 reset system internal rib nib log
1.7.24 reset system internal rib summary
1.7.25 reset system internal rip graceful-restart event-log
1.7.26 reset system internal rip non-stop-routing event-log
1.7.27 reset system internal ripng graceful-restart event-log
1.7.28 reset system internal ripng non-stop-routing event-log
1.7.29 reset system internal route-direct log
1.7.30 reset system internal route-static nib log
1.7.31 reset system internal session alg statistics
1.7.32 reset system internal session statistics
1.7.33 reset system internal virtual-crypto-engine statistics
1.8.1 system internal relation hot-backup force-delete enable
1.8.2 system internal relation hot-backup update enable
1.8.3 system internal relation synchronization enable
1.8.4 system internal session alg statistics
1.8.5 system internal session hot-backup aging-request enable
1.8.6 system internal session hot-backup aging-response enable
1.8.7 system internal session hot-backup broadcast enable
1.8.8 system internal session hot-backup force-delete enable
对于本节命令中的CPU参数,仅T9006/T9010/T9014产品支持。
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
crypto-engine accelerator disable命令用来关闭硬件加密引擎。
undo crypto-engine accelerator disable命令用来开启硬件加密引擎。
硬件加密引擎处于开启状态。
Probe视图
context-admin
无
开启硬件加密引擎加密功能,是指开启硬件加密引擎来加速加密过程。
硬件加密引擎的开启或关闭状态的改变对业务模块的影响由业务模块决定,例如,对于IPsec业务来说,硬件加密引擎状态的改变只对新建立的IPsec SA有影响,已建的IPsec SA仍旧使用之前选择的加密引擎来处理。因此,建议在开启或关闭硬件加密引擎之后,使用reset ipsec sa命令将当前已有的IPsec SA删除,使得所有新建立的IPsec SA都将使用新选择的加密引擎处理流程来处理。
硬件加密引擎加密功能仅允许在测试、调试或故障排除的环境下关闭,正常情况下不建议关闭该功能。
debugging ha命令用来打开HA各子模块的调试信息开关。
undo debugging ha命令用来关闭HA各子模块的调试信息开关。
debugging ha { all | config | fsm | policy | standby | sync }
undo debugging ha { all | config | fsm | policy | standby | sync }
HA各子模块的调试信息开关处于关闭状态。
context-admin
all:HA所有模块的信息。
config:config子模块的信息。
fsm:FSM子模块的信息。
policy:policy子模块的信息。
standby:备份HA模块的信息。
sync:sync子模块的信息。
# 打开HA FSM子模块的调试开关。
<Sysname> debugging ha fsm
debugging system internal adj4命令用来打开IPv4邻接表调试开关。
undo debugging system internal adj4命令用来关闭IPv4邻接表调试开关。
debugging system internal adj4 { hardware | bind | notify | entry }
undo debugging system internal adj4 { hardware | bind | notify | entry }
IPv4邻接表调试开关处于关闭状态。
Probe视图
hardware:打开IPv4邻接表下驱动调试功能。
bind:打开VN/NHLFE表项绑定IPv4邻接表调试功能。
notify:打开IPv4邻接表项变化时,反刷VN和NHLFE表项调试功能。
entry:打开IPv4邻接表项更新时调试功能。
debugging system internal adj6命令用来打开IPv6邻接表调试开关。
undo debugging system internal adj6命令用来关闭IPv6邻接表调试开关。
debugging system internal adj6 { hardware | bind | notify | entry }
undo debugging system internal adj6 { hardware | bind | notify | entry }
IPv6邻接表调试开关处于关闭状态。
Probe视图
hardware:打开IPv6邻接表下驱动调试功能。
bind:打开VN/NHLFE表项绑定IPv6邻接表调试功能。
notify:打开IPv6邻接表项变化时,反刷VN和NHLFE表项调试功能。
entry:打开IPv6邻接表项更新时调试功能。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp mac-forced-forwarding命令用来打开MAC强制转发调试信息开关。
undo debugging system internal arp mac-forced-forwarding命令用来关闭MAC强制转发调试信息开关。
debugging system internal arp mac-forced-forwarding { event | notify | hardware }
undo debugging system internal arp mac-forced-forwarding { event | notify | hardware }
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号 |
T9006/T9010/T9014 |
debugging system internal arp mac-forced-forwarding |
不支持 |
T5010/T5020 |
支持 |
T1020/T1030/T1050/T1060/T1080 |
支持 |
LSWM1IPSD0 |
支持 |
MAC强制转发调试信息开关处于关闭状态。
Probe视图
event:表示MAC强制转发特性事件调试开关。
notify:表示MAC强制转发特性外部通知调试开关。
hardware:表示MAC强制转发特性硬件调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal fib 命令用来打开FIB调试信息开关。
undo debugging system internal fib命令用来关闭FIB调试信息开关。
分布式设备-独立运行模式/集中式IRF设备:
debugging system internal fib prefix { all | message | hardware } slot slot-number [ cpu cpu-number ]
undo debugging system internal fib prefix { all | message | hardware } slot slot-number [ cpu cpu-number ]
分布式设备- IRF模式:
debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number [ cpu cpu-number ]
undo debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number [ cpu cpu-number ]
FIB 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关,打印路由下发和板间同步的IPv4 FIB前缀消息。
hardware:打开hardware调试开关,打印下发驱动信息以及驱动返回的消息。
slot slot-number:打开指定单板的调试开关。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:打开指定成员设备的调试开关。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:打开指定成员设备上指定单板的调试开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:打开指定CPU的调试开关。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
debugging system internal fib vn 命令用来打开VN调试信息开关。
undo debugging system internal fib vn命令用来关闭VN调试信息开关。
debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number [ cpu cpu-number ]
undo debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number [ cpu cpu-number ]
debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number [ cpu cpu-number ]
undo debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number [ cpu cpu-number ]
VN 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关,显示路由下发和板间同步的vn消息。
hardware:打开hardware调试开关,显示下发驱动的信息以及驱动返回的信息。
bind:打开bind调试开关,显示前缀绑定vn,vn绑定adj/nhlfe的相关信息。
notify:打开notify调试开关,显示adj/nhlfe通知vn,以及vn通知前缀的信息。
debugging system internal flow-manager命令用来打开软件引流的调试信息开关。
undo debugging system internal flow-manager命令用来关闭软件引流的调试信息开关。
分布式设备-独立运行模式:
debugging system internal flow-manager [ acl { ipv4-acl-number | ipv6 ipv6-acl-number } | remote-address { ipv4-address | ipv6 ipv6-address } ] [ slot slot-number cpu cpu-number ]
undo debugging system internal flow-manager [ slot slot-number cpu cpu-number ]
分布式设备-IRF模式:
debugging system internal flow-manager [ acl { ipv4-acl-number | ipv6 ipv6-acl-number } | remote-address { ipv4-address | ipv6 ipv6-address } ] [ chassis chassis-number slot slot-number cpu cpu-number ]
undo debugging system internal flow-manager [ chassis chassis-number slot slot-number cpu cpu-number ]
软件引流的调试信息开关处于关闭状态。
Probe视图
context-admin
acl:根据ACL过滤调试信息。
ipv4-acl-number:表示IPv4 ACL的编号,取值范围为3000~3999。
ipv6 ipv6-acl-number:表示IPv6 ACL。ipv6-acl-number表示IPv6 ACL的编号,取值范围为3000~3999。
remote-address:根据对端IP地址过滤调试信息。
ipv4-address:对端IPv4地址,为点分十进制格式。
ipv6 ipv6-address:对端IPv6地址。
slot slot-number:打开指定单板上的软件引流调试信息开关,slot-number表示单板所在的槽位号。若不指定该参数,则表示打开所有单板上的软件引流调试信息开关。(分布式设备-独立运行模式)
slot slot-number:打开指定成员设备上的软件引流调试信息开关,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示打开所有成员设备上的软件引流调试信息开关。(集中式IRF设备)
chassis chassis-number slot slot-number:打开指定成员设备的指定单板上的软件引流调试信息开关,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示打开所有成员设备的所有单板上的软件引流调试信息开关。(分布式设备-IRF模式)
cpu cpu-number:打开指定CPU上的软件引流调试开关,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
debugging system internal ip vpn-instance命令用来打开VPN实例调试信息开关。
undo debugging system internal ip vpn-instance命令用来关闭VPN实例调试信息开关。
debugging system internal ip vpn-instance slot slot-number [ cpu cpu-number ]
undo debugging system internal ip vpn-instance slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
debugging system internal ip vpn-instance chassis chassis-number slot slot-number [ cpu cpu-number ]
undo debugging system internal ip vpn-instance chassis chassis-number slot slot-number [ cpu cpu-number ]
VPN实例的调试信息开关处于关闭状态。
Probe视图
context-admin
slot slot-number:表示指定单板上的VPN实例调试信息开关。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:表示指定成员设备上的VPN实例调试信息开关。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的VPN实例调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:表示指定CPU上的VPN实例调试信息开关。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number [ cpu cpu-number ]
undo debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number [ cpu cpu-number ]
undo debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number [ cpu cpu-number ]
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
slot slot-number:打开指定单板的IPv6 FIB调试信息开关,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:打开指定成员设备的IPv6 FIB调试信息开关,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:打开指定成员设备上指定单板的IPv6 FIB调试信息开关,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:打开指定CPU的IPv6 FIB调试信息开关。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
Probe视图
notify:表示邻居发现的通知调试开关。
sync: 表示邻居发现的同步调试开关。
【描述】
debugging system internal nd命令用来打开邻居发现的调试信息开关。undo debugging system internal nd命令用来关闭邻居发现的调试信息开关。
缺省情况下,邻居发现的调试信息开关处于关闭状态。
debugging system internal nd sub-features { all | event | packet }
undo debugging system internal nd sub-features
Probe视图
all:表示ND子特性的所有调试信息开关。
event:表示ND子特性的事件调试信息开关。
packet:表示ND子特性的报文调试信息开关。
【描述】
debugging system internal nd sub-features命令用来打开ND子特性的调试开关。undo debugging system internal nd sub-features命令用来关闭ND子特性的调试开关。
缺省情况下,ND子特性的调试开关处于关闭状态。
debugging system internal sib flow命令用来打开非缺省Context下引流规则的调试开关。
undo debugging system internal sib flow命令用来恢复缺省情况。
型号 |
T9006/T9010/T9014 |
debugging system internal sib flow |
支持 |
T5010/T5020 |
不支持 |
不支持 |
LSWM1IPSD0 |
不支持 |
非缺省Context下引流规则的调试开关处于关闭状态。
Probe视图
context-admin
请登录非缺省Context,在非缺省Context下配置该命令。缺省Context下不支持该命令。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
context-admin
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
debugging transceiver命令用来调试光模块的相关功能。
debugging transceiver { mibcache | moduleinfo | read_write_retry } { disable | enable } interface [ interface-type interface-number ]
光模块的调试开关处于关闭状态。
Probe视图
moduleinfo:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块在需要使用光模块的信息时,必须直接从光模块中获取。关闭调试开关后,设备第一次识别光模块时,会在软件内部保存光模块的信息,以便上层模块可直接从软件中获取光模块的信息。
mibcache:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块需要使用MIB节点的值时,必须通过硬件中的数据立即构建光模块MIB节点的值。关闭调试开关后,系统后台会定期从硬件获取数据来构建光模块MIB节点的值,并将该值保存在内存中供上层模块使用。
read_write_retry:该参数用来控制读写错误的光模块信息时采取的措施。打开调试开关后,即便系统读写的光模块基本信息存在校验和错误,软件也不会重新读写。关闭调试开关后,当系统读写的光模块基本信息存在校验和错误时,软件会重新读写。
disable:关闭调试开关。
enable:打开调试开关。
interface [ interface-type interface-number ]:表示接口类型和接口编号。不指定该参数时,表示所有接口。需要注意的,配置该参数后,会开启/关闭接口所在单板的光模块的相关功能。
display fastforward session table命令用来显示未经过安全业务处理的会话表项。
display fastforward session table { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ verbose ]
分布式设备-IRF模式:
display fastforward session table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ verbose ]
Probe视图
context-admin
ipv4:显示IPv4会话表项。
ipv6:显示IPv6会话表项。
slot slot-number:显示指定单板上的会话表项,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的会话表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的会话表项,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的会话表项。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的会话表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的会话表项。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的会话表项,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
source-ip source-ip:显示指定源IP地址的会话表项。其中,source-ip表示发起方到响应方会话的源IP地址。
destination-ip destination-ip:显示指定目的IP地址的会话表项。其中,destination-ip表示发起方到响应方会话的目的IP地址。
verbose:显示详细的会话表项。不指定该参数表示显示会话表项的概要信息。
如果除ipv4、ipv6外不指定任何参数,则显示所有未经过安全业务处理的IPv4或IPv6会话表项。
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe视图
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name } slot slot-number
分布式设备-IRF模式:
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name } chassis chassis-number slot slot-number
Probe视图
context-admin
ipv6:指定ACL类型为IPv6 ACL。
mac:指定ACL类型为二层ACL。
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
· 2000~2999:表示基本ACL。
· 3000~3999:表示高级ACL。
· 4000~4999:表示二层ACL。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
slot slot-number:显示指定单板上ACL的配置和运行情况,slot-number表示单板所在的槽位号。若未指定本参数,将显示主控板上ACL的配置和运行情况。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上ACL的配置和运行情况,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上ACL的配置和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal adj4 entry 命令用来显示指定IPv4邻接表项的详细信息。
display system internal adj4 entry ip-address interface interface-type interface-number slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal adj4 entry ip-address interface interface-type interface-number chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
ip-address:IPv4邻接表项中的IP地址。
interface interface-type interface-number:IPv4邻接表项所对应的三层接口类型和接口号。
slot slot-number:显示指定单板的IPv4邻接表项的信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv4邻接表项的信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表项的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4邻接表项的信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数
display system internal adj4 statistics命令用来显示IPv4邻接表项的统计信息。
display system internal adj4 statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal adj4 statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的IPv4邻接表项的统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv4邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4邻接表项的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal adj6 entry 命令用来显示指定IPv6邻接表项的详细信息。
display system internal adj6 entry ipv6-address interface interface-type interface-number slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal adj6 entry ipv6-address interface interface-type interface-number chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
ipv6-address:IPv6邻接表项中的IPv6地址。
interface interface-type interface-number:IPv6邻接表项所对应的三层接口类型和接口号。
slot slot-number:显示指定单板的IPv6邻接表项的信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6邻接表项的信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6邻接表项的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6邻接表项的信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal adj6 statistics 命令用来显示IPv6邻接表项的统计信息。
display system internal adj6 statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal adj6 statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的IPv6邻接表项的统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6邻接表项的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal adjacent-table命令用来显示IPv4邻接表的信息。
display system internal adjacent-table slot slot-number [ cpu cpu-number ] [ count | verbose ]
分布式设备-IRF模式:
display system internal adjacent-table chassis chassis-number slot slot-number [ cpu cpu-number ] [ count | verbose ]
Probe视图
slot slot-number:显示指定单板的IPv4邻接表信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv4邻接表信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4邻接表信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
count:显示IPv4邻接表项的数目。
verbose:显示IPv4邻接表项的详细信息。不指定该参数时显示IPv4邻接表项的摘要信息。
display system internal arp命令用来显示对应设备或单板上学习到的ARP表项信息或表项数目。
display system internal arp { all | static | dynamic } slot slot-number [ cpu cpu-number ] [ count ]
分布式设备—IRF模式:
display system internal arp { all | static | dynamic } chassis chassis-number slot slot-number [ cpu cpu-number ] [ count ]
Probe视图
all:命令用来显示所有ARP表项信息或表项数目。
static:用来显示静态ARP表项信息或表项数目。
dynamic:用来显示动态ARP表项信息或表项数目。
slot slot-number:显示指定单板的ARP表项信息或表项数目,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP表项信息或表项数目,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP表项信息或表项数目,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ARP表项信息或表项数目。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
count:用来显示ARP表项数目。
display system internal arp ifcb命令用来查看指定板上二层或三层接口ARP控制块信息
display system internal arp ifcb interface interface-type interface-number slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp ifcb interface interface-type interface-number chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ARP控制块信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP控制块信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ARP控制块信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp ip-address命令用来显示指定板上指定IP的ARP表项信息。
display system internal arp ip-address slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp ip-address chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
slot slot-number:显示指定单板指定IP的ARP表项信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备指定IP的ARP表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板指定IP的ARP表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU指定IP的ARP表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp mac-forced-forwarding命令用来显示指定板上MAC强制转发配置信息。
display system internal arp mac-forced-forwarding vlan vlan-id slot slot-number
型号 |
T9006/T9010/T9014 |
display system internal arp mac-forced-forwarding |
不支持 |
T5010/T5020 |
支持 |
支持 |
LSWM1IPSD0 |
支持 |
Probe视图
vlan vlan-id:显示指定VLAN上mac强制转发配置信息。vlan-id表示指定VLAN的编号。
slot slot-number:显示指定成员设备的MFF配置信息,slot-number表示设备在IRF中的成员编号。
display system internal arp machash命令用来显示指定板上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp machash vlan vlan-id ip ip-address chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vlan vlan-id:显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的ID。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址
slot slot-number:显示指定单板的machash表项信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的machash表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的machash表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的machash表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp probe命令用来显示指定板上ARP探测链表项。
display system internal arp probe slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp probe chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的ARP探测链表项,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP探测链表项,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP探测链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ARP探测链表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp rbhash命令用来显示指定板上rbhash表项信息。
display system internal arp rbhash vlan vlan-id ip ip-address slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp rbhash vlan vlan-id ip ip-address chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vlan vlan-id:显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ip ip-address:显示指定IP上rbhash表项信息。
slot slot-number:显示指定单板的rbhash表项信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的rbhash表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的rbhash表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的rbhash表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp reload命令用来显示指定板上ARP重刷链表项。
display system internal arp reload slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp reload chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的ARP重刷链表项,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP重刷链表项,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP重刷链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ARP重刷链表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp rule命令用来显示ARP规则信息。
分布式设备—独立运行模式/集中式IRF设备:
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] } slot slot-number [ cpu cpu-number ]
分布式设备—IRF模式:
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] } chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
all:显示所有ARP规则信息。
interface interface-type interface-number:显示指定接口的ARP规则信息,interface-type interface-number表示接口类型和接口编号。
ip-address:显示指定IP地址的ARP规则信息。
slot slot-number:显示指定单板的ARP规则信息。slot-number表示单板所在的槽位号。(分布式设备—独立运行模式)
slot slot-number:显示指定成员设备的ARP规则信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP规则信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备—IRF模式)
cpu cpu-number:显示指定CPU的ARP规则信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp source-suppression cache命令用来显示指定板源抑制表项。
display system internal arp source-suppression cache slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp source-suppression cache chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的源抑制表项,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的源抑制表项,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的源抑制表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的源抑制表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp statistics命令用来显示指定板ARP统计信息。
display system internal arp statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal arp statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ARP统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ARP统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项数目。
display system internal arp vlan vlan-id slot slot-number [ cpu cpu-number ] [ count ]
分布式设备—IRF模式:
display system internal arp vlan vlan-id chassis chassis-number slot slot-number [ cpu cpu-number ] [ count ]
Probe视图
vlan vlan-id:用来显示指定VLAN的ARP表项信息或表项数目。
slot slot-number:显示指定单板指定VLAN的ARP表项信息或表项数目,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备指定VLAN的ARP表项信息或表项数目,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板指定VLAN的ARP表项信息或表项数目,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU指定VLAN的ARP表项信息或表项数目。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
count:用来显示ARP表项数目。
display system internal aspf statistics命令用来查看ASPF、报文过滤以及对象策略模块的丢包统计信息。
display system internal aspf statistics zone-pair { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal aspf statistics zone-pair { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
zone-pair:查看域间实例上的ASPF丢包统计信息。
ipv4: 查看IPv4报文的丢包统计信息。
ipv6: 查看IPv6报文的丢包统计信息。
slot slot-number:显示指定单板上的丢包统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有单板上的丢包统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示显示所有成员设备上的丢包统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的丢包统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示显示所有成员设备的所有单板上的丢包统计表项信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的丢包统计信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal attack-defense scan stat-nodes ip命令用来显示扫描攻击防范的IPv4统计节点信息。
display system internal attack-defense scan stat-nodes ip [ { source | destination } [ ipv4-address [ vpn vpn-instance-name ] ] ] [ slot slot-number [ cpu cpu-number ] ] [ count ]
分布式设备-IRF模式:
display system internal attack-defense scan stat-nodes ip [ { source | destination } [ ipv4-address [ vpn vpn-instance-name ] ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ count ]
Probe视图
context-admin
source:显示基于源IP地址进行统计的扫描攻击统计节点。
destination:显示基于目的IP地址进行统计的扫描攻击统计节点。
ipv4-address:表示指定的源IPv4地址或目的IPv4地址,不能为广播地址、127.0.0.0/8网段地址、D类地址或E类地址。
vpn-instance vpn-instance-name:指定IPv4地址所属的VPN实例。其中,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示该IPv4地址属于公网。
slot slot-number:显示指定单板上的扫描攻击统计节点,slot-number表示单板所在槽位号。该参数仅在指定显示全局接口(例如VLAN接口)时可见。如果不指定该参数,则表示显示所有单板上的扫描攻击统计节点。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的扫描攻击统计节点,slot-number表示设备在IRF中的成员编号。该参数仅在指定显示全局接口(例如VLAN接口)时可见。如果不指定该参数,则表示显示所有成员设备上的扫描攻击统计节点。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板上的扫描攻击统计节点,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。该参数仅在指定显示全局接口(例如VLAN接口)时可见。如果不指定该参数,则表示显示所有单板上的扫描攻击统计节点。
cpu cpu-number:显示指定CPU上的扫描攻击统计节点,cpu-number表示单板上的CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
count:显示符合指定条件的统计节点的个数。
display system internal attack-defense scan stat-nodes ipv6命令用来显示扫描攻击防范的IPv6统计节点信息。
display system internal attack-defense scan stat-nodes ipv6 [ { source | destination } [ ipv6-address [ vpn vpn-instance-name ] ] ] [ slot slot-number [ cpu cpu-number ] ] [ count ]
分布式设备-IRF模式:
display system internal attack-defense scan stat-nodes ipv6 [ { source | destination } [ ipv6-address [ vpn vpn-instance-name ] ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ count ]
Probe视图
context-admin
source:显示基于源IPv6地址进行统计的扫描攻击统计节点。
destination:显示基于目的IPv6地址进行统计的扫描攻击统计节点。
ipv6-address:表示指定的源IPv6地址或目的IPv6地址。
vpn-instance vpn-instance-name:指定IPv6地址所属的VPN实例。其中,vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示该IPv6地址属于公网。
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的扫描攻击统计节点,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。该参数仅在指定显示全局接口(例如VLAN接口)时可见。如果不指定该参数,则表示显示所有单板上的扫描攻击统计节点。(分布式设备-IRF模式)
display system internal bfd packet statistics命令用来显示BFD报文的统计信息。
Probe视图
context-admin
display system internal blacklist ip命令用来显示IPv4黑名单表项。
display system internal blacklist ip [ source-ip-address [ vpn-instance vpn-instance-name ] ] [ slot slot-number [ cpu cpu-number ] ] [ count ]
分布式设备-IRF模式:
display system internal blacklist ip [ source-ip-address [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ count ]
Probe视图
context-admin
source-ip-address:显示指定IPv4地址的黑名单表项。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4黑名单表项。其中vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。
slot slot-number:显示指定单板上的IPv4黑名单表项,slot-number表示单板所在槽位号。如果不指定该参数,则表示显示所有单板上的IPv4黑名单表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4黑名单表项,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的IPv4黑名单表项。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4黑名单表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则表示显示所有单板上的IPv4黑名单表项。
cpu cpu-number:显示指定CPU上的IPv4黑名单表项,cpu-number表示单板上的CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
count:显示符合指定条件的IPv4黑名单个数。
display system internal blacklist ipv6命令用来显示IPv6黑名单表项。
display system internal blacklist ipv6 [ source-ipv6-address [ vpn-instance vpn-instance-name ] ] [ slot slot-number [ cpu cpu-number ] ] [ count ]
分布式设备-IRF模式:
display system internal blacklist ipv6 [ source-ipv6-address [ vpn-instance vpn-instance-name ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ count ]
Probe视图
context-admin
source-ipv6-address:显示指定IPv6地址的黑名单表项。
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6黑名单表项。其中vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。
slot slot-number:显示指定单板上的IPv6黑名单表项,slot-number表示单板所在槽位号。如果不指定该参数,则表示显示所有单板上的IPv6黑名单表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv6黑名单表项,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的IPv6黑名单表项。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6黑名单表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则表示显示所有成员设备上的IPv6黑名单表项。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv6黑名单表项,cpu-number表示单板上的CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
count:仅显示符合指定条件的IPv6黑名单个数。
display system internal bridge cache ip inline verbose命令用来显示Bridge转发创建的IP快速转发表的详细内容。
display system internal bridge cache ip inline [ ip-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal bridge cache ip inline [ ip-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
probe视图
context-admin
inline:显示Inline转发的快速转发表信息。
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
slot slot-number:显示指定单板的快速转发表信息。如果不指定slot slot-number,将显示所有单板的快速转发表信息。slot-number表示单板的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的快速转发表信息。slot-number表示设备在IRF中的成员编号。如果不指定slot slot-number,将显示所有成员设备的快速转发表信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的快速转发表信息。如果不指定chassis chassis-number slot slot-number,将显示所有单板的快速转发表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上快速转发表信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal bridge cache ipv6 inline verbose命令用来显示Bridge转发创建的IPv6快速转发表的详细内容。
display system internal bridge cache ipv6 inline [ ipv6-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal bridge cache ipv6 inline [ ipv6-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
probe视图
context-admin
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
slot slot-number:显示指定单板的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有单板的IPv6快速转发表信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有成员设备的IPv6快速转发表信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6快速转发表信息。如果不指定chassis chassis-number slot slot-number,将显示所有单板的IPv6快速转发表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上IPv6快速转发表信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal client-verify http redirect-node命令用来显示HTTP客户端验证重定向节点信息。
display system internal client-verify http redirect-node { ip [ ipv4-address [ vpn ipv4-vpn-instance-name ] ] | ipv6 [ ipv6-address [ vpn ipv6-vpn-instance-name ] ] } [ slot slot-number [ cpu cpu-number ] ] ] [ count ]
分布式设备-IRF模式:
display system internal client-verify http redirect-node { ip [ ipv4-address [ vpn ipv4-vpn-instance-name ] ] | ipv6 [ ipv6-address [ vpn ipv6-vpn-instance-name ] ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ count ]
Probe视图
context-admin
ip ipv4-address:显示指定IPv4地址的重定向节点。
ipv6 ipv6-address:显示指定IPv6地址的重定向节点。
vpn-instance ipv4-vpn-instance-name:显示指定VPN实例的重定向节点。其中ipv4-vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示信任IPv4地址位于公网。
vpn-instance ipv6-vpn-instance-name:显示指定VPN实例的重定向节点。其中ipv6-vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。若不指定该参数,则表示信任IPv6地址位于公网。
slot slot-number:显示指定单板上的重定向节点,slot-number表示单板所在槽位号。如果不指定该参数,则表示显示所有单板上的重定向节点。(分布式设备-独立运行模式)。
slot slot-number:显示指定成员设备上的重定向节点,slot-number表示设备在IRF中的成员编号。如果不指定该参数,则表示显示所有成员设备上的重定向节点。(集中式IRF设备)。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的重定向节点,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定该参数,则表示显示所有成员设备上的重定向节点。
cpu cpu-number:显示指定CPU上的重定向节点,cpu-number表示单板上的CPU编号。
count:显示统计数据的个数。
display system internal context block-information命令用来显示Context的阻塞信息。
集中式设备:
display system internal context id context-id block-information
display system internal context id context-id block-information [ slot slot-number cpu cpu-number ]
分布式设备-IRF模式:
display system internal context id context-id block-information [ chassis chassis-number slot slot-number cpu cpu-number ]
Probe视图
context-admin
id context-id:Context的编号。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示所有单板。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。不指定该参数时,表示所有单板。(分布式设备-IRF模式)
cpu cpu-number:表示CPU的编号。
该命令用于确认Context阻塞的原因。可根据阻塞信息找到对应模块定位。
display system internal context configuration-status命令用来查询各单板上Context相关配置的执行情况。
Probe视图
context-admin
当设备重启或者单板插入时,设备或单板会运行Context进程,并运行Context的相关配置。使用本命令可以查看各单板Context相关配置的执行情况,如果执行过程中出现错误,可以定位到出错的单板。
display system internal context running-status命令用来显示Context在各单板上的运行状态。
display system internal context id context-id running-status
Probe视图
context-admin
该命令用于确定哪些单板上的Context存在问题,分别阻塞在哪个阶段。
display system internal customlog host命令用来显示指定日志主机当前运行状态下的内核数据信息。
display system internal customlog host index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal customlog host index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
index:表示指定日志主机的索引号。index取值范围为0~3。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的内核数据信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的内核数据信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的内核数据信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的内核数据信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的内核数据信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的内核数据信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的内核数据信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的内核数据信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的内核数据信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的内核数据信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在槽位号。如未指定该参数,则显示主用主控板运行状态下的内核数据信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的内核数据信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示在Master设备运行状态下的内核数据信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备和单板上的内核数据信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上的内核数据信息。(分布式设备-IRF模式)
cpu cpu-number:指定需要显示信息的成员设备所在的CPU。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal customlog mbuf dump命令用来显示指定个数的CUSTOMLOG报文的详细信息。
display system internal customlog mbuf dump count number [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal customlog mbuf dump count number [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
number:指定需要显示的日志个数。number取值范围为1~100。
slot slot-number:显示指定单板上CUSTOMLOG报文的详细信息,slot-number表示单板所在槽位号。如未指定该参数,则显示主用主控板上日志报文的详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上CUSTOMLOG报文的详细信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上日志报文的详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备和单板的CUSTOMLOG报文的详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上日志报文的详细信息。(分布式设备-IRF模式)
display system internal customlog mbuf usage命令用来显示指定日志主机上每个CPU内MBUF池的使用情况信息。
display system internal customlog mbuf usage index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal customlog mbuf usage index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
index:指定需要查看数据的日志主机索引号。index取值范围为0~3。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的MBUF池使用情况信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的MBUF池使用情况信息。
slot slot-number:显示指定单板上的CPU内MBUF池的使用情况信息,slot-number表示单板所在槽位号。如未指定该参数,则显示主用主控板上CPU内MBUF使用情况。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的CPU内MBUF池的使用情况信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的CPU内MBUF使用情况。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备和单板上的CPU内MBUF池的使用情况信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上的CPU内MBUF使用情况。(分布式设备-IRF模式)
display system internal customlog test命令用来发送指定数目CUSTOMLOG测试的报文,并显示日志发送结果信息。
display system internal customlog test count number { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal customlog test count number { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
number:指定需要参与测试的CUSTOMLOG数目。number取值范围为1~100。
cmccPortA:指定中国移动公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortF:指定中国移动公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortW:指定中国移动公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionA:指定中国移动公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionW:指定中国移动公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
portA:指定中国联通公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
portW:指定中国联通公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionA:指定中国联通公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionW:指定中国联通公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedA:指定中国电信公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedW :指定中国电信公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
userbasedA:指定中国电信公司的端口创建日志,并显示日志对应的测试日志发送结果信息。
userbasedF:指定中国电信公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
userbasedW:指定中国电信公司的端口删除日志,并显示日志对应的测试日志发送结果信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在槽位号。如未指定该参数,则显示主用主控板上日志报文的发送结果信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的日志发送结果信息,slot-number表示设备在IRF中的成员编号。如未指定该参数,则显示Master设备上日志报文的发送结果信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备和单板上的日志发送结果信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上日志报文的发送结果信息。(分布式设备-IRF模式)
display system internal data-filter match命令用来显示数据过滤匹配表项信息。
display system internal data-filter match [ match-id match-id ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal data-filter match [ match-id match-id ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
match-id match-id:显示指定数据匹配表项信息,match-id为match表项的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上所有的匹配信息信息。。
statistics:显示统计信息。
slot slot-number:显示指定单板上的数据过滤匹配表项信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的数据过滤匹配表项信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的数据过滤匹配表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的数据过滤匹配表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的数据过滤匹配表项信息,cpu-number表示CPU的编号。
display system internal data-filter policy命令用来显示数据过滤策略信息。
display system internal data-filter policy [ policy-id policy-id ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal data-filter policy [ policy-id policy-id ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
policy-id policy-id:显示指定数据过滤策略的信息。policy-id为数据过滤策略的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上的所有数据过滤策略信息
slot slot-number:显示指定单板上的数据过滤策略信息。slot-number表示单板所在槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的数据过滤策略信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的数据过滤策略信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的数据过滤策略信息。cpu-number表示CPU的编号。
display system internal data-filter rule命令用来显示数据过滤规则信息。
display system internal data-filter rule [ policy-id policy-id [ rule-id rule-id ] ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal data-filter rule [ policy-id policy-id [ rule-id rule-id ] ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
policy-id policy-id:显示指定数据过滤策略中的数据过滤规则的信息。policy-id为数据过滤策略的ID,取值范围为0~4294967294。若不指定该参数,则显示单板上的所有数据过滤策略中的规则信息。
rule-id rule-id:显示指定数据过滤规则的信息。rule-id为数据过滤规则的ID,取值范围为0~4294967294。若不指定该参数,则显示指定数据过滤策略中的所有规则信息。
slot slot-number:显示指定单板上的数据过滤规则信息。slot-number表示单板所在槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的数据过滤规则信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的数据过滤规则信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的数据过滤规则信息。cpu-number表示CPU的编号。
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] } [ slot slot-number ]
分布式设备-IRF模式:
display system internal dbm { all | name dbname [ key keyname ] } [ chassis chassis-number slot slot-number ]
Probe视图
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(分布式设备-IRF模式)
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number } slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ethernet character { global | interface interface-type interface-number } chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
slot slot-number:表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface { interface-type interface-number } slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ethernet controlblock interface { interface-type interface-number } chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
display system internal fib prefix命令用来显示IPv4 FIB前缀基本信息。
display system internal fib prefix vpn-instance vpn-instance-name slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib prefix vpn-instance vpn-instance-name chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀基本信息。
slot slot-number:显示指定单板上的IPv4 FIB前缀基本信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4 FIB前缀基本信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4 FIB前缀基本信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv4 FIB表项信息。
display system internal fib prefix [ vpn-instance vpn-instance-name ] entry-status status slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib prefix [ vpn-instance vpn-instance-name] entry-status status chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的下驱动失败或者待老化的IPv4 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB表项信息。
entry-status status:用于匹配FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv4 FIB表项信息,“F”表示下刷驱动失败的IPv4 FIB表项信息。
slot slot-number:显示指定单板上的下驱动失败或者待老化的IPv4 FIB表项信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备上的下驱动失败或者待老化的IPv4 FIB表项信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的下驱动失败或者待老化的IPv4 FIB表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的下驱动失败或者待老化的IPv4 FIB表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib prefix ip-address命令用来显示IPv4 FIB前缀详细信息。
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀详细信息。
ip-address:显示指定IP地址的IPv4 FIB前缀详细信息。
mask:IP地址掩码。
mask-length:IP地址掩码长度,即掩码中连续“1”的个数。
slot slot-number:显示指定单板上的IPv4 FIB前缀详细信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4 FIB前缀详细信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4 FIB前缀详细信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib running-status命令用来显示IPv4 FIB、IPv6 FIB、VN全局信息。
display system internal fib running-status slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib running-status chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN全局信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4 FIB、IPv6 FIB、VN全局信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN全局信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4 FIB、IPv6 FIB、VN全局信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib statistics命令用来显示IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。
display system internal fib statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib vn命令用来显示VN表项信息。
display system internal fib vn [ next-hop next-hop ] slot slot-number [ cpu cpu-number ]
display system internal fib vn [ id id | index index ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib vn [ next-hop next-hop ] chassis chassis-number slot slot-number [ cpu cpu-number ]
display system internal fib vn [ id id | index index ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
id id:按指定VN ID显示VN表项详细信息。
index index:按指定VN索引显示VN表项详细信息。
next-hop next-hop:显示指定下一跳的VN表项基本信息,可以输入IPv4、IPv6地址。
slot slot-number:显示指定单板上的VN表项信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备上的VN表项信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的VN表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的VN表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal fib vn entry-status命令用来显示指定状态的VN表项基本信息。
display system internal fib vn entry-status status slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal fib vn entry-status status chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
entry-status status:按指定状态显示VN信息。取值范围为<A,F,R>,“A”表示待老化表项,“F”表示下驱动失败表项,“R”表示由于被关联而未删除的表项。
slot slot-number:显示指定单板上的指定状态的VN表项基本信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备的指定状态的VN表项基本信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定状态的VN表项基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的指定状态的VN表项基本信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal flow-manager failover-group命令用来显示软件引流的备份组信息。
分布式设备-独立运行模式:
display system internal flow-manager failover-group [ slot slot-number cpu cpu-number ]
分布式设备-IRF模式:
display system internal flow-manager failover-group [ chassis chassis-number slot slot-number cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板上软件引流的备份组信息,slot-number表示单板所在的槽位号。若未指定本参数,将显示主用主控板上软件引流的备份组信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上软件引流的备份组信息,slot-number表示设备在IRF中的成员编号。若未指定本参数,将显示主用设备上软件引流的备份组信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上软件引流的备份组信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若未指定本参数,将显示全局主用主控板上软件引流的备份组信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上软件引流的备份组信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ha service命令用来显示某个业务进程的HA统计信息,包括业务注册的基本信息、各控制消息接收处理统计、各数据的发送统计和接收统计等。
display system internal ha service socket
Probe视图
context-admin
socket:所要查询的业务进程的socket ID,socket ID可通过display system internal ha service-group sg-name命令显示信息中Socket字段的值获取。
display system internal ha service-group命令用来显示当前到HA模块注册的所有SG信息,包括SG的名称、SG的状态、SU的个数等信息。
display system internal ha service-group [ name [ instance ] ]
Probe视图
context-admin
instance:SG实例的名称(如果有实例)。
display system internal ha statistics命令用来显示HA各子模块的统计信息。
display system internal ha statistics { submodule { fsm | service } | summary }
Probe视图
context-admin
submodule:HA子模块的信息。
fsm:FSM子模块的信息。
service:service子模块的信息。
summary:全局统计信息。
display system internal hot-backup broadcast node命令用来显示广播会话热备份的节点信息。
display system internal hot-backup broadcast node [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal hot-backup broadcast node [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
无
Probe视图
context-admin
slot slot-number:显示指定单板上广播会话热备份的节点信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上广播会话热备份的节点信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上广播会话热备份的节点信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备广播会话热备份的节点信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上广播会话热备份的节点信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上广播会话热备份的节点信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上广播会话热备份的节点信息,cpu-number表示CPU的编号。
display system internal hot-backup peer命令用来显示热备份的对端信息。
Probe视图
context-admin
display system internal ifmgr brief命令用来显示接口基本信息同步的信息。
display system internal ifmgr brief { para slot slot-number [ cpu cpu-number ] | help }
分布式设备-IRF模式:
display system internal ifmgr brief { para chassis chassis-number slot slot-number [ cpu cpu-number ] | help }
Probe视图
context-admin
para:指定显示时的参数,为接口索引值。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr down命令用来显示已注册的down类型。
display system internal ifmgr down [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ifmgr down [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。(分布式设备-IRF模式)
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para [ slot slot-number [ cpu cpu-number ] ] | help }
分布式设备-IRF模式:
display system internal ifmgr entry { para [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help }
Probe视图
context-admin
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para [ slot slot-number [ cpu cpu-number ] ] | help }
分布式设备-IRF模式:
display system internal ifmgr event { para [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help }
Probe视图
context-admin
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type。
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ [ para ] [ slot slot-number [ cpu cpu-number ] ] | help ]
分布式设备-IRF模式:
display system internal ifmgr hotplug [ [ para ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help ]
Probe视图
context-admin
para:指定显示时的参数。para为槽位号或者槽位号和子槽位号(格式为slot-number*subslot-number),用于显示该板或子卡的热插拔信息。不指定该参数以及help参数时,显示所有板的热插拔信息;
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。用于显示slot-number单板上记录的热插拔信息。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。用于显示slot-number成员设备上记录的热插拔信息。(集中式IRF设备)。
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。用于显示slot-number单板上记录的热插拔信息。(分布式设备-IRF模式)
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para [ slot slot-number [ cpu cpu-number ] ] | help }
分布式设备-IRF模式:
display system internal ifmgr index { para [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help }
Probe视图
context-admin
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ [ para ] [ slot slot-number [ cpu cpu-number ] ] | help ]
分布式设备-IRF模式:
display system internal ifmgr list [ [ para ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help ]
Probe视图
context-admin
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定para和help参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para [ slot slot-number [ cpu cpu-number ] ] | help }
分布式设备-IRF模式:
display system internal ifmgr name { para [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help }
Probe视图
context-admin
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para [ slot slot-number [ cpu cpu-number ] ] | help }
分布式设备-IRF模式:
display system internal ifmgr type { para [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] | help }
Probe视图
context-admin
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal inspect dim-rule命令用来显示各个DPI业务模块在各个Context内的检测规则的统计信息。
display system internal inspect dim-rule [ context-id ] [ rule-id ] [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect dim-rule [ context-id ] [ rule-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
context-id:显示指定Context上的各个DPI业务模块的检测规则的统计信息。若不指定该参数,则表示所有Context。
rule-id:显示各个DPI业务模块在各个Context内指定的检测规则的统计信息。若不指定该参数,则表示所有检测规则
slot slot-number:显示指定单板上的各个DPI业务模块在各个Context内的检测规则ID的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的各个DPI业务模块在各个Context内的检测规则ID的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的各个DPI业务模块在各个Context内的检测规则ID的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的各个DPI业务模块在各个Context内的检测规则ID的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
display system internal inspect hit-statistics命令用来显示应用层检测引擎中的检测规则被命中的统计信息。
display system internal inspect hit-statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect hit-statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎中的检测规则被命中的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上规则被命中的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎中的检测规则被命中的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上规则被命中的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎中的检测规则被命中的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上规则被命中的统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎中的检测规则被命中的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
# 显示应用层检测引擎中的检测规则被命中的统计信息。
<Sysname> display inspect hit-statistics
Slot 1:
Rule ID Module Rule hits AC hits PCRE try PCRE hits
0 DFILTER 1253 1616 0 0
268435456 UFLT 28 30 0 0
1 DFILTER 0 488 0 0
表1-1 display inspect statistic rule-hit命令显示信息描述表
RuleID |
检测规则ID |
Module |
检测规则所属的DPI业务的名称 |
Rulehits |
检测规则被命中次数 |
AC hits |
AC关键字被命中的次数 |
PCRE try |
正则表达式尝试匹配的次数 |
PCRE hits |
正则表达式被命中的次数 |
display system internal inspect http命令用来显示应用层检测引擎对HTTP协议解析的统计信息。
display system internal inspect http [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect http [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎对HTTP协议解析的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP协议解析的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎对HTTP协议解析的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上HTTP协议解析的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎对HTTP协议解析的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上HTTP协议解析的统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎对HTTP协议解析的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
该命令可以显示应用层检测引擎对HTTP协议解析的统计信息,一定程度上可以用来观察HTTP协议解析对设备的性能、内存等运行情况的影响。
display system internal inspect memory engine ac命令用来显示应用层检测引擎中AC关键字检测模块占用内存的统计信息。
display system internal inspect memory engine ac [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect memory engine ac [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎中AC关键字检测模块占用内存的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎中AC关键字检测模块占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎中AC关键字检测模块占用内存的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎中AC关键字检测模块占用内存的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
该命令可以显示应用层检测引擎中AC关键字检测模块占用的内存数值,一定程度上可以用来观察应用层检测引擎对设备运行情况的影响。
display system internal inspect memory engine mn命令用来显示应用层检测引擎锚定AC关键字检测模块占用内存的统计信息。
分布式设备-独立运行模式/集中式IRF设备:
display system internal inspect memory engine mn [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect memory engine mn [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎中锚定AC关键字检测模块占用内存的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎中锚定AC关键字检测模块占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎中锚定AC关键字检测模块占用内存的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎中锚定AC关键字检测模块占用内存的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
该命令可以显示应用层检测引擎中锚定AC关键字检测模块占用的内存数值,一定程度上可以用来观察引擎对设备内存运行情况的影响。锚定的意思是要求目标关键字的第一个字符在报文中出现的位置是预先固定的。
display system internal inspect memory rule命令用来显示应用层检测引擎中的检测规则占用内存的统计信息。
display system internal inspect memory rule [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect memory rule [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎中的检测规则占用内存的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎中的检测规则占用内存的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备上占用内存的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎中的检测规则占用内存的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板上占用内存的统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎中的检测规则占用内存的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
该命令可以显示应用层检测引擎中的检测规则占用的内存数值,一定程度上可以用来观察引擎对设备内存运行情况的影响。
display system internal inspect statistic packet命令用来显示应用层检测引擎处理异常情况时的报文统计信息。
display system internal inspect statistic packet [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
display system internal inspect statistic packet [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的应用层检测引擎处理异常情况的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的应用层检测引擎处理异常情况的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的应用层检测引擎处理异常情况的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的应用层检测引擎处理异常情况的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。(分布式设备-独立运行模式/集中式IRF设备/分布式设备-IRF模式)
display system internal ip address命令用来显示地址详细信息
display system internal ip address [ vpn-instance vpn-instance-name ] [ ip-address | interface interface-type interface-number ] [ slot slot-number ]
分布式设备-IRF模式:
display system internal ip address [ vpn-instance vpn-instance-name ] [ ip-address | interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的IP地址。
ip-address:显示指定IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定单板上的IP地址,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的IP地址。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IP地址,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上的IP地址。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IP地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的IP地址。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IP地址。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ip fast-forwarding cache verbose命令用来显示IPv4快转表项的详细内容。
display system internal ip fast-forwarding cache [ ip-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ip fast-forwarding cache [ ip-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
ip-address:显示指定IP地址的 IPv4 快转表详细信息。
slot slot-number: 显示指定单板的快转表详细信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的快转表详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的快转表详细信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的快转表详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的快转表详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的快转表详细信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的快转表详细信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ip routing-table命令用来显示路由表的信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
verbose:显示全部路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的路由表信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的路由表信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的路由表信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的信息。cpu-number表示CPU编号。
display system internal ip routing-table acl命令用来显示通过指定ACL过滤的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] acl ipv4-acl-number [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
ipv4-acl-number:基本ACL的编号,取值范围为2000~2999。
verbose:显示通过指定ACL过滤的所有路由的详细信息。如果未指定本参数,将只显示通过指定ACL过滤的激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的通过指定ACL过滤的路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的通过指定ACL过滤的路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上通过指定ACL过滤的路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ip routing-table ip-address命令用来显示指定目的地址的路由信息。
display system internal ip routing-table ip-address1 to ip-address2命令用来显示指定目的地址范围内的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
display system internal ip routing-table [ vpn-instance vpn-instance-name ] ip-address1 to ip-address2 [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
ip-address:目的IP地址,点分十进制格式。
mask/mask-length:IP地址掩码,点分十进制格式或以整数形式表示的长度,当用整数时,取值范围为0~32。
longer-match:匹配掩码更长的路由。
ip-address1 to ip-address2:IP地址范围。ip-address1和ip-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
standby slot slot-number:显示备份的指定单板的指定目的地址的路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的指定目的地址的路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定目的地址的路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ip routing-table prefix-list命令用来显示通过指定前缀列表过滤的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
prefix-list-name:前缀列表名称,为1~63个字符的字符串,区分大小写。
verbose:当使用该参数时,显示通过过滤规则的所有路由的详细信息。如果未指定本参数,将只显示通过过滤规则的激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的指定前缀列表过滤的路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的指定前缀列表过滤的路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的指定前缀列表过滤的路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ip routing-table protocol命令用来显示指定协议生成或发现的路由信息。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
protocol:显示指定路由协议的信息。
inactive:显示未激活路由的信息。如果未指定本参数,则显示激活路由和未激活路由的信息。
verbose:当使用该参数时,显示路由的详细信息。如果未指定本参数,将显示路由的概要信息。
standby slot slot-number:显示备份的指定单板的指定路由协议的信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的路由表中的指定路由协议的信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的路由表中的指定路由协议的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ip routing-table statistics命令用来显示路由表中的综合路由统计信息。综合路由统计信息包括路由总数目、路由协议添加/删除路由数目、激活路由数目。
display system internal ip routing-table [ vpn-instance vpn-instance-name ] statistics standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip routing-table [ vpn-instance vpn-instance-name ] statistics standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定单板的路由表中的综合路由统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的路由表中的综合路由统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的路由表中的综合路由统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ip source binding命令用来显示详细的IPv4绑定表项信息。
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping | dot1x | wlan-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping | dot1x | wlan-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
static:显示配置的静态绑定表项。
vpn-instance vpn-instance-name:显示指定VPN的动态绑定表项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示公网的动态绑定表项。
dhcp-relay:显示DHCP中继模块生成的动态绑定表项。
dhcp-server:显示DHCP服务器模块生成的动态绑定表项。
dhcp-snooping:显示DHCP Snooping模块生成的动态绑定表项。
dot1x:显示802.1X模块生成的动态绑定表项。
wlan-snooping:显示WLAN Snooping模块生成的动态绑定表项。
ip-address ip-address:显示指定IPv4地址的绑定表项,ip-address表示绑定的IPv4地址。
mac-address mac-address:显示指定MAC地址的绑定表项,mac-address表示绑定的MAC地址,格式为H-H-H。
vlan vlan-id:显示指定VLAN的绑定表项,vlan-id表示绑定的VLAN ID,取值范围为1~4094。
interface interface-type interface-number:显示指定接口的绑定表项,interface-type interface-number表示绑定的接口类型和接口编号。
slot slot-number:显示存储在指定单板上的绑定表项,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的绑定表项。(分布式设备-独立运行模式)
slot slot-number:显示存储在指定成员设备上的绑定表项,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的绑定表项。(集中式IRF设备)
chassis chassis-number slot slot-number:显示存储在指定成员设备上指定单板的绑定表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的绑定表项。(分布式设备-IRF模式)
cpu cpu-number:显示存储在指定CPU的绑定表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。(分布式设备-独立运行模式/集中式IRF设备/分布式设备-IRF模式)
display system internal ip vpn-binding命令用来显示内核的VPN实例绑定信息。
display system internal ip vpn-binding slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip vpn-binding chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板上的内核VPN实例绑定信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的内核VPN实例绑定信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例绑定信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的内核VPN实例绑定信息。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ip vpn-instance命令用来显示内核的VPN实例信息。
display system internal ip vpn-instance [ instance-name vpn-instance-name ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
instance-name vpn-instance-name:显示指定VPN实例的内核信息。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
slot slot-number:显示指定单板上的内核VPN实例信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的内核VPN实例信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的内核VPN实例信息。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ip vpn-instance inactive命令用来显示正在删除中的VPN实例的信息。
Probe视图
context-admin
display system internal ip vpn-instance statistics命令用来显示内核VPN实例的统计信息。
display system internal ip vpn-instance statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ip vpn-instance statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板上的内核VPN实例统计信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的内核VPN实例统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式))
cpu cpu-number:显示指定CPU上的内核VPN实例统计信息。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 address命令用来显示IPv6地址详细信息
display system internal ipv6 address [ [ vpn-instance vpn-instance-name ] [ ipv6-address ] | [ interface interface-type interface-number ] ] [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 address [ [ vpn-instance vpn-instance-name ] [ ipv6-address ] | [ interface interface-type interface-number [ gateway | multicast | prefix | unicast ] ] ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
ipv6-address:显示的指定IPv6地址。
vpn-instance vpn-instance-name: 显示指定VPN的IPv6地址。
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
gateway:显示指定接口的网关地址信息。
multicast:显示指定接口的组播地址信息。
prefix:显示指定接口的ipv6前缀信息。
unicast:显示指定接口的单播地址信息。
slot slot-number:显示指定单板上的IPv6地址,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的IPv6地址。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv6地址,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的IPv6地址。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的IPv6地址。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6地址。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 adjacent-table命令用来显示IPv6邻接表的信息。
display system internal ipv6 adjacent-table slot slot-number [ cpu cpu-number ] [ count | verbose ]
分布式设备-IRF模式:
display system internal ipv6 adjacent-table chassis chassis-number slot slot-number [ cpu cpu-number ] [ count | verbose ]
Probe视图
slot slot-number:显示指定单板的IPv6邻接表信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6邻接表信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6邻接表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6邻接表信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
count:显示IPv6邻接表项的数目。
verbose:显示IPv6邻接表项的详细信息。不指定该参数时显示IPv6邻接表项的摘要信息。
display system internal ipv6 fast-forwarding cache verbose命令用来显示指定IPv6地址的IPv6快转表项的详细内容。
display system internal ipv6 fast-forwarding cache [ ipv6-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 fast-forwarding cache [ ipv6-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
ipv6-address:显示指定IPv6地址的IPv6快转表详细信息。
slot slot-number:显示指定成员设备的IPv6快转表详细信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的IPv6快转表详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6快转表详细信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的IPv6快转表详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6快转表详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的IPv6快转表详细信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6快转表详细信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 fast-forwarding statistics 命令用来显示IPv6快转的报文统计信息。
display system internal ipv6 fast-forwarding statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定成员设备的IPv6快转的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上的快转的报文统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6快转的报文统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示Master设备上的快转的报文统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6快转的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示全局主用主控板上的快转的报文统计信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6快转的报文统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 fib prefix [vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀基本信息。
slot slot-number:显示指定单板的IPv6 FIB前缀基本信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6 FIB前缀基本信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6 FIB前缀基本信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6 FIB前缀基本信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息信息。
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] entry-status status slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] entry-status status chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB表项信息。
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
slot slot-number:显示指定单板的下驱动失败或者待老化的IPv6 FIB表项信息,slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备的下驱动失败或者待老化的IPv6 FIB表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的下驱动失败或者待老化的IPv6 FIB表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的下驱动失败或者待老化的IPv6 FIB表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 fib prefix ipv6-address命令用来显示IPv6 FIB前缀详细信息。
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀详细信息。
ipv6-address:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
slot slot-number:显示指定单板的IPv6 FIB前缀详细信息,slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示指定成员设备的IPv6 FIB前缀详细信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6 FIB前缀详细信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的IPv6 FIB前缀详细信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 pathmtu命令用来显示IPv6的PMTU信息,信息全局同步。
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的IPv6 PMTU信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的IPv6 PMTU信息。
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有公网的PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
count:显示PMTU表项数目。
slot slot-number:显示指定单板上的所有PMTU表项。slot-number表示单板的槽位号。如果未指定本参数,则显示所有单板上所有PMTU表项。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的所有PMTU表项。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上所有PMTU表项。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的所有PMTU表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。如果未指定本参数,则显示所有单板上的所有PMTU表项。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的所有PMTU表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 pbr fib命令用来显示用户态下IPv6下一跳的配置信息。
display system internal ipv6 pbr slot slot-number [ cpu cpu-number ] fib [ vpn-instance vpn-instance-name ]
分布式设备-IRF模式:
display system internal ipv6 pbr chassis chassis-number slot slot-number [ cpu cpu-number ] fib [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示用户态下指定私网内IPv6下一跳的配置信息,如果未指定本参数,则显示用户态下公网内下一跳的配置信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定单板指定私网内IPv6下一跳的配置信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示用户态下指定成员设备的指定私网内IPv6下一跳的配置信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的指定私网内IPv6下一跳的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示用户态下指定CPU上指定私网内IPv6下一跳的配置信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 pbr kernel policy用于显示内核态下指定单板上的IPv6策略路由信息。
display system internal ipv6 pbr slot slot-number [ cpu cpu-number ] kernel policy [ policy-name [ setup ] ]
分布式设备-IRF模式:
display system internal ipv6 pbr chassis chassis-number slot slot-number [ cpu cpu-number ] kernel policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示内核态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息
slot slot-number:显示内核态下指定单板上的内核态下IPv6策略路由信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示内核态下指定成员设备的IPv6策略路由信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示内核态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示内核态下指定CPU上IPv6策略路由信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 pbr policy用于显示用户态下的IPv6策略路由信息。
display system internal ipv6 pbr slot slot-number [ cpu cpu-number ] policy [ policy-name [ setup ] ]
分布式设备-IRF模式:
display system internal ipv6 pbr chassis chassis-number slot slot-number [ cpu cpu-number ] policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示用户态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定单板上的IPv6策略路由信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示用户态下指定成员设备的IPv6策略路由信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示用户态下指定CPU上IPv6策略路由信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 rawip命令用来显示设备上所有IPv6 RawIP连接的摘要信息。
display system internal ipv6 rawip slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 rawip chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 RawIP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有IPv6 RawIP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有IPv6 RawIP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 rib event attribute 命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
context-admin
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
context-admin
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
context-admin
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
display system internal ipv6 rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
display system internal ipv6 rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
display system internal ipv6 rib instance命令用来显示IPv6 RIB的协议进程信息。
Probe视图
context-admin
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ] [ standby slot slot-number [ cpu cpu-number ] ]
display system internal ipv6 rib event log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 rib log [ reverse ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display system internal ipv6 rib event log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定单板RIB的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIB的日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB的日志信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上RIB的日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(分布式设备-IRF模式)
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
context-admin
display system internal ipv6 rib nib命令用来显示IPv6 RIB的下一跳信息。
display system internal ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
display system internal ipv6 rib nib protocol protocol [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
display system internal ipv6 rib nib protocol protocol [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
self-originated:路由管理自己生成的下一跳。
nib-id:路由下一跳ID值,取值范围1~FFFFFFFF。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议的下一跳信息。
standby slot slot-number:显示备份的指定单板的IPv6 RIB下一跳信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的IPv6 RIB下一跳信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IPv6 RIB下一跳信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ] [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 rib nib log [ reverse ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
nib:显示IPv6 NIB子模块的运行状态。
standby slot slot-number:显示备份的指定单板NIB子模块的运行状态日志,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的NIB子模块的运行状态日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示NIB子模块的运行状态日志。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上NIB子模块的运行状态日志,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(分布式设备-IRF模式)
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length [ vpn-instance vpn-instance-name ] [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 rib prefix ipv6-address prefix-length [ vpn-instance vpn-instance-name ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定单板IPv6路由表前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv6路由表前缀信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的IPv6路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv6路由表前缀信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上IPv6路由表前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv6路由表前缀信息。(分布式设备-IRF模式)
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
display system internal ipv6 rib summary [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 rib summary [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定单板的RIB统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIB统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB统计信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIB统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(分布式设备-IRF模式)
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
ipv6-address:IPv6地址。
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
context-admin
display system internal ipv6 routing-table命令用来显示IPv6路由表的信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
verbose:显示IPv6路由表的详细信息,包括激活路由和未激活路由。如果未指定本参数,将显示激活路由的概要信息。
slot slot-number:显示备份的指定单板的IPv6路由表信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示备份的指定成员设备的IPv6路由表信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IPv6路由表信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 routing-table acl命令用来显示通过指定IPv6 ACL过滤的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] acl ipv6-acl-number [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
ipv6-acl-number:基本IPv6 ACL编号,取值范围为2000~2999。
verbose:显示通过指定IPv6 ACL过滤的所有路由的详细信息。如果未指定本参数,只显示通过IPv6 ACL过滤的激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的通过指定ACL过滤的IPv6路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的通过指定ACL过滤的IPv6路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上通过指定ACL过滤的IPv6路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 routing-table ipv6-address命令用来显示指定目的地址的IPv6路由信息。
display system internal ipv6 routing-table ipv6-address1 to ipv6-address2命令用来显示指定目的地址范围内的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] ipv6-address1 to ipv6-address2 [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
ipv6-address:IPv6目的地址。
longer-match:匹配并显示前缀最长的路由条目。
ipv6-address1 to ipv6-address2:IPv6地址范围。ipv6-address1和ipv6-address2共同决定一个地址范围,只有地址在此范围内的路由才会被显示。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的指定目的地址的IPv6路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的指定目的地址的IPv6路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定目的地址的IPv6路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 routing-table prefix-list命令用来显示通过指定前缀列表过滤的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] prefix-list prefix-list-name [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
prefix-list-name:IPv6前缀列表的名称,为1~63个字符的字符串,区分大小写。
verbose:显示所有路由的详细信息。如果未指定本参数,只显示激活路由的概要信息。
standby slot slot-number:显示备份的指定单板的指定前缀列表过滤的IPv6路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的指定前缀列表过滤的IPv6路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的指定前缀列表过滤的IPv6路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 routing-table protocol命令用来显示指定协议生成或发现的IPv6路由信息。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] protocol protocol [ inactive | verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
inactive:如果配置了该参数,此命令只显示未激活路由信息。如果未指定本参数,将显示所有激活和未激活路由信息。
verbose:显示激活和未激活路由的详细信息。如果未指定本参数,将显示路由的概要信息。
standby slot slot-number:显示备份的指定单板的指定IPv6路由协议的信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的指定IPv6路由协议的信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的指定IPv6路由协议的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 routing-table statistics命令用来显示IPv6路由表中的综合路由统计信息。综合路由统计信息包括路由总数、增加的路由数、删除的路由数等。
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 routing-table [ vpn-instance vpn-instance-name ] statistics standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定单板的IPv6路由表中的综合路由统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的IPv6路由表中的综合路由统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IPv6路由表中的综合路由统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ipv6 source binding命令用来显示详细的IPv6绑定表项信息。
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping | nd-snooping | wlan-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping | nd-snooping | wlan-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
static:显示配置的静态绑定表项。
dhcpv6-snooping:显示DHCPv6 Snooping模块生成的动态绑定表项。
nd-snooping:显示ND Snooping模块生成的动态绑定表项。
wlan-snooping:显示WLAN Snooping模块生产的动态绑定表项。
ip-address ipv6-address:显示指定IPv6地址的绑定表项,ipv6-address表示绑定的IPv6地址。
display system internal ipv6 tcp命令用来显示设备上所有IPv6 TCP连接的摘要信息。
display system internal ipv6 tcp slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 tcp chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 TCP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有IPv6 TCP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有IPv6 TCP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 tcp port-info命令用来显示IPv6 TCP模块非保留端口的使用信息。
display system internal ipv6 tcp port-info [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 tcp port-info [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定单板上的IPv6 TCP模块非保留端口的使用信息,slot-number表示单板所在槽位号。如果未指定本参数,则显示所有单板上的IPv6 TCP模块非保留端口的使用信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上IPv6 TCP模块非保留端口的使用信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的IPv6 TCP模块非保留端口的使用信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6 TCP模块非保留端口的使用信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的IPv6 TCP模块非保留端口的使用信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv6 TCP模块非保留端口的使用信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 udp命令用来显示设备上所有IPv6 UDP连接的摘要信息。
display system internal ipv6 udp slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ipv6 udp chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 UDP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有IPv6 UDP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有IPv6 UDP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ipv6 udp port-info命令用来显示IPv6 UDP模块非保留端口的使用信息。
display system internal ipv6 udp port-info [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal ipv6 udp port-info [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定单板上的IPv6 UDP模块非保留端口的使用信息,slot-number表示单板所在槽位号。如果未指定本参数,则显示所有单板上的IPv6 UDP模块非保留端口的使用信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上IPv6 UDP模块非保留端口的使用信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的IPv6 UDP模块非保留端口的使用信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6 UDP模块非保留端口的使用信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的IPv6 UDP模块非保留端口的使用信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv6 UDP模块非保留端口的使用信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal irf global命令用来显示IRF的部分全局信息。
集中式IRF设备:
display system internal irf global [ slot slot-number ]
分布式设备-IRF模式:
display system internal irf global [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示主控板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。(分布式设备-IRF模式)
display system internal irf msg命令用来显示IRF的日志信息。
集中式IRF设备:
display system internal irf msg [ reverse ] [ slot slot-number ]
分布式设备-IRF模式:
display system internal irf msg [ reverse ] [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
reverse:表示反向显示信息,先显示时间新的日志,再显示时间旧的日志。不指定该参数时,表示按时间先后顺序显示信息。
display system internal irf roledb命令用来显示IRF的角色数据库信息。
集中式IRF设备:
display system internal irf roledb [ slot slot-number ]
分布式设备-IRF模式:
display system internal irf roledb [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
display system internal irf topodb命令用来显示IRF的拓扑数据库信息。
集中式IRF设备:
display system internal irf topodb [ slot slot-number ]
分布式设备-IRF模式:
display system internal irf topodb [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,则表示主设备。(集中式IRF设备)。
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal kernel memory dump address address-hex length memory-length [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
slot slot-number:表示单板所在的槽位号,不指定表示主控板。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,不指定表示全局主用主控板。(分布式设备-IRF模式)
cpu cpu-number:表示CPU编号。
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ] [ slot slot-number [cpu cpu-number ] ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number [cpu cpu-number ] ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number [cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal kernel memory pool [ name name-string ] [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
display system internal kernel memory pool tag [ tag-value ] [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
display system internal kernel memory pool name name-string tag tag-value [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
Probe视图
context-admin
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(分布式设备-独立运行模式)
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal license buffer-data命令用来显示内存中缓存的License数据。
display system internal license buffer-data slot slot-number
分布式设备-IRF模式:
display system internal license buffer-data chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的内存缓存的License数据。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的内存缓存的License数据。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的内存缓存的License数据。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal license feature-set命令用来显示设备支持的特性集的相关信息。
display system internal license feature-set slot slot-number
分布式设备-IRF模式:
display system internal license feature-set chassis chassis-number slot slot-number
Probe视图
feature-set:显示设备中的特性集相关信息。
slot slot-number:显示指定单板的设备中的特性集相关信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的设备中的特性集相关信息。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的特性集相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal license fifo命令用来显示License使用的FIFO管道信息。
display system internal license fifo slot slot-number
分布式设备-IRF模式:
display system internal license fifo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的FIFO管道信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的FIFO管道信息。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的FIFO管道信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal license lipc命令用来显示License LIPC通道信息。License LIPC用于特性模块和License模块的内部通信。
display system internal license lipc slot slot-number
分布式设备-IRF模式:
display system internal license lipc chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的License LIPC通道信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的License LIPC通道信息。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的License LIPC通道信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal license lipc hash命令用来显示hash链表中存储的License LIPC通道信息。
display system internal license lipc hash slot slot-number
分布式设备-IRF模式:
display system internal license lipc hash chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的hash链表中存储的LIPC信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的hash链表中存储的LIPC信息。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的hash链表中存储的LIPC信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal license lmi-paa命令用来显示LMI(License Manage Item,License管理项)信息和PAA(Product Ability Aggregate,产品能力集)信息。
display system internal license lmi-paa slot slot-number
分布式设备-IRF模式:
display system internal license lmi-paa chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的LMI信息和PAA能力信息。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的LMI信息和PAA能力信息。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定单板的LMI信息和PAA能力信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
display system internal link-aggregation slot slot-number global
分布式设备-IRF模式:
display system internal link-aggregation chassis chassis-number slot slot-number global
Probe视图
slot slot-number:表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:表示设备所在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:表示指定设备上指定单板的位置。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。(分布式设备-IRF模式)
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
display system internal link-aggregation slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
分布式设备-IRF模式:
display system internal link-aggregation chassis chassis-number slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation chassis chassis-number slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
route-aggregation:显示三层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
ipv4:IPv4报文统计值。
ipv6:IPv6报文统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
· 如果未指定kernel、lacp、lacppdu和statistics参数,则显示LAGG主线程中接口的基本数据。
· 如果未指定ipv4、ipv6参数,则显示所有报文统计值。
· 部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | static } [ count ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal mac-address configuration { blackhole | static } [ count ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
blackhole:显示黑洞MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
slot slot-number:显示指定单板的MAC地址信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的MAC地址信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的MAC地址信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal mac-address learned命令用来显示动态MAC地址表项。
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
slot slot-number:显示指定单板的动态MAC地址表项。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的动态MAC地址表项。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的动态MAC地址表项chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的动态MAC地址表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
display system internal mac-address statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal mac-address statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的MAC地址表统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的MAC地址表的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal mac-forwarding cache ip verbose命令用来显示IP快转表项的详细内容。
display system internal mac-forwarding cache ip [ ip-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal mac-forwarding cache ip [ ip-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
probe视图
context-admin
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
slot slot-number:显示指定单板的快速转发表信息。如果不指定slot slot-number,将显示所有单板的快速转发表信息。slot-number表示单板的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的快速转发表信息。slot-number表示设备在IRF中的成员编号。如果不指定slot slot-number,将显示所有成员设备的快速转发表信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的快速转发表信息。如果不指定chassis chassis-number slot slot-number,将显示所有单板的快速转发表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上快速转发表信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal mac-forwarding cache ipv6 verbose命令用来显示IPv6快转表项的详细内容。
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
probe视图
context-admin
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
slot slot-number:显示指定单板的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有单板的IPv6快速转发表信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的IPv6快速转发表信息。如果不指定slot slot-number,将显示所有成员设备的IPv6快速转发表信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6快速转发表信息。如果不指定chassis chassis-number slot slot-number,将显示所有单板的IPv6快速转发表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
chassis chassis-number slot slot-number:显示指定单板的IPv6快速转发表信息。如果不指定
cpu cpu-number:显示指定CPU上IPv6快速转发表信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal mac-forwarding controlblock interface interface-type interface-number chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
slot slot-number:显示指定单板的二层转发控制信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的二层转发控制信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的二层转发控制信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的二层转发控制信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd dad命令用来显示DAD链信息。
display system internal nd dad slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd dad chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的DAD链信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的DAD链信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的DAD链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的DAD链信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd entry命令用来显示各板上的ND表项信息。
display system internal nd entry slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd entry chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的ND表项信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ND表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ND表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该。
display system internal nd ifcb命令用来显示接口的ND控制块信息。
display system internal nd ifcb interface interface-type interface-number slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd ifcb interface interface-type interface-number chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ND控制块信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ND控制块信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ND控制块信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd machash命令用来显示各板上的machash表项。
display system internal nd machash vlan vlan-id ipv6-address slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd machash vlan vlan-id ipv6-address chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vlan vlan-id:显示指定VLAN的信息。vlan-id表示指定VLAN的编号。
ipv6-address:指定IPv6地址。
slot slot-number:显示指定单板的machash表项,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的machash表项,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的machash表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的machash表项。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd probe命令用来显示探测链信息。
display system internal nd probe slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd probe chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的探测链信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的探测链信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的探测链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的探测链信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd rbhash命令用来显示指定板上rbhash表项信息。
display system internal nd rbhash vlan vlan-id ipv6-address slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd rbhash vlan vlan-id ipv6-address chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
vlan vlan-id:显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ipv6-address:显示指定IPv6地址上rbhash表项信息。
slot slot-number:显示指定单板的rbhash表项信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的rbhash表项信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的rbhash表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的rbhash表项信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd reload命令用来显示重刷链信息。
分布式设备-独立运行模式/集中式IRF设备:
display system internal nd reload slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd reload chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的重刷链信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的重刷链信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的重刷链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的重刷链信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd rule命令用来显示ND规则信息。
display system internal nd rule { all | interface interface-type interface-number [ ipv6-address ] } slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd rule { all | interface interface-type interface-number [ ipv6-address ] } chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
all:显示所有ND规则信息。
interface interface-type interface-number:显示指定接口的ND规则信息,interface-type interface-number表示接口类型和接口编号。
ipv6-address:显示的指定IPv6地址的ND规则信息。
slot slot-number:显示指定单板ND规则信息,slot-number表示单板所在的槽位号。(分布式设备—独立运行模式)
slot slot-number:显示指定成员设备的ND规则信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND规则信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备—IRF模式)
cpu cpu-number:显示指定CPU的ND规则信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
display system internal nd statistics命令用来显示各板上的ND统计信息。
display system internal nd statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal nd statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示指定单板的ND统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的ND统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的ND统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal object-group命令用来显示对象组的配置和运行情况。
display system internal object-group [ { { ip | ipv6 } address | port | service } [ default ] [ name object-group-name ] | name object-group-name ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal object-group [ { { ip | ipv6 } address | port | service } [ default ] [ name object-group-name ] | name object-group-name ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
ip address:指定对象组类型为IP地址对象组。
ipv6 address:指定对象组类型为IPv6地址对象组。
port:指定对象组类型为端口对象组。
service:指定对象组类型为服务对象组。
default:指定默认对象组。
name object-group-name:指定对象组名称。object-group-name表示对象组的名称,为1~31个字符的字符串,不区分大小写。
slot slot-number:显示指定单板上对象组的配置和运行情况,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上对象组的配置和运行情况,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上对象组的配置和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的地址对象组。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal object-policy命令用来显示指定对象策略的配置信息。
display system internal object-policy { ip | ipv6 } object-policy-name slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal object-policy { ip | ipv6 } object-policy-name chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
context-operator
ip:表示IPv4对象策略。
ipv6:表示IPv6对象策略。
object-policy-name表示对象策略的名称,为1~63个字符的字符串,不区分大小写。
slot slot-number:显示指定单板上指定对象策略的配置信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上指定对象策略的配置信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上指定对象策略的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的对象策略。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal ospf event-log命令用来显示OSPF的日志信息。
display system internal ospf event-log { gr | interface | nib | notify | { ha | upgrade } [ standby slot slot-number [ cpu cpu-number ] ] }
分布式设备-IRF模式:
display system internal ospf event-log { gr | interface | nib | notify | { ha | upgrade } [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ] }
Probe视图
context-admin
gr:显示GR日志。
ha:显示HA事件处理日志信息。
interface:显示接口事件日志。
nib:显示NIB日志。
notify:显示接口通知日志。
upgrade:显示升级平滑日志信息。
standby slot slot-number:显示备份的指定单板的OSPF日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的日志信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的日志信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的日志信息。(分布式设备-IRF模式)
display system internal ospf flood-list命令用来显示OSPF的flooding信息。
display system internal ospf [ process-id ] flood-list [ interface-type interface-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的flooding信息。
interface-type interface-number:显示指定接口的flooding信息。如果未指定本参数,将显示所有接口的flooding信息。
display system internal ospf interface命令用来显示接口相关信息。
display system internal ospf interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN实例下接口相关信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的信息。
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
display system internal ospf interface standby命令用来显示备份的OSPF接口信息。
display system internal ospf [ process-id ] interface [ interface-type interface-number | verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] interface [ interface-type interface-number | verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的接口信息。
interface-type interface-number:接口类型和编号。显示指定接口的OSPF详细信息。
verbose:显示所有接口的OSPF详细信息。
standby slot slot-number:显示备份的指定单板的OSPF接口信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的接口信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF接口信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的接口信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF接口信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的接口信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的信息。cpu-number表示CPU编号。
display system internal ospf keychain命令用来查看OSPF进程下的keychain信息。
display system internal ospf keychain [ name keychain-name [ key key-id ] ]
Probe视图
context-admin
keychain-name:keychain名称,为1~63个字符的字符串,区分大小写。如果不指定本参数,则显示OSPF进程下所有keychain的信息。
key-id:key的标识符,取值范围为0~281474976710655。如果不指定本参数,则显示指定keychain的所有key的信息。
display system internal ospf lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospf [ process-id ] lsdb { asbr | ase | nssa | summary }
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的LSA map信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的map信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的map信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的map信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的map信息。
display system internal ospf lsdb standby命令用来显示备份的OSPF链路状态数据库信息。
display system internal ospf [ process-id ] lsdb [ area area-id | brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] lsdb [ area area-id | brief | [ { asbr | ase | network | nssa | opaque-area | opaque-as | opaque-link | router | summary } [ link-state-id ] ] [ originate-router advertising-router-id | self-originate ] ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的链路状态数据库信息。
area area-id:显示数据库中指定区域的LSA信息。area-id表示区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其转换成IP地址格式)或者是IP地址格式。如果未指定本参数,将显示所有区域的信息。
brief:显示数据库的概要信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的信息。
network:显示数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的信息。
opaque-area:显示数据库中Type-10 LSA (Opaque-area LSA)的信息。
opaque-as:显示数据库中Type-11 LSA (Opaque-AS LSA)的信息。
opaque-link:显示数据库中Type-9 LSA(Opaque-link LSA)的信息。
router:显示数据库中Type-1 LSA(Router LSA)的信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的信息。
link-state-id:链路状态ID,IP地址格式。
originate-router advertising-router-id:发布LSA报文的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的数据库信息。
standby slot slot-number:显示备份的指定单板的OSPF链路状态数据库信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的链路状态数据库信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF链路状态数据库信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的链路状态数据库信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF链路状态数据库信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的链路状态数据库信息。(分布式设备-IRF模式)
display system internal ospf nib命令用来显示NIB分配的下一跳信息。
display system internal ospf nib [ nib-id ] [ verbose ]
Probe视图
context-admin
nib-id:路由下一跳信息的ID值,取值范围1~FFFFFFFF。
verbose:显示NIB详细信息。
display system internal ospf peer standby命令用来显示备份的OSPF邻居信息。
display system internal ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] peer [ verbose ] [ interface-type interface-number ] [ neighbor-id ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的各区域邻居的信息。
verbose:显示OSPF各区域邻居的详细信息。如果未指定本参数,将显示OSPF进程各区域邻居的概要信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的OSPF邻居的信息。
neighbor-id:邻居路由器的Router ID。如果未指定本参数,将显示所有邻居路由器的OSPF邻居的信息。
standby slot slot-number:显示备份的指定单板的OSPF各区域邻居的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF各区域邻居的信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF各区域邻居的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF各区域邻居的信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF各区域邻居的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF各区域邻居的信息。(分布式设备-IRF模式)
display system internal ospf peer statistics standby命令用来显示备份的本地路由器所有OSPF邻居的统计信息,即处于各种状态的邻居数目。
display system internal ospf [ process-id ] peer statistics standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] peer statistics standby chassis chassis-number slot slot-number [ cpu cpu-number ]
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的邻居统计信息。
standby slot slot-number:显示备份的指定单板的OSPF邻居统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的邻居统计信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF邻居统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的邻居统计信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF邻居统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的邻居统计信息。(分布式设备-IRF模式)
display system internal ospf prefix命令用来显示OSPF中前缀对应的LSA信息。
display system internal ospf [ process-id ] prefix [ ip-address { mask | mask-length } ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的前缀信息。
ip-address:路由的目的IP地址。如果未指定本参数,将显示所有前缀的信息。
mask:网络掩码,点分十进制格式。
display system internal ospf router命令用来显示OSPF中到路由器节点的路由信息。
display system internal ospf [ process-id ] router
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的信息。
display system internal ospf sham-link standby命令用来显示OSPF备进程上OSPF伪连接的信息。
display system internal ospf [ process-id ] sham-link [ area area-id ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] sham-link [ area area-id ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:显示指定OSPF进程内的伪连接信息。process-id为OSPF进程号,取值范围为1~65535。如果不指定本参数,则显示所有OSPF进程的伪连接信息。
area area-id:显示指定OSPF区域内的伪连接信息。area-id为OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。如果不指定本参数,则显示所有OSPF区域的伪连接信息。
slot slot-number:指定备进程所在的单板。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:指定备进程所在的成员设备。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:指定备进程所在的成员设备和单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:指定备进程所在的CPU。cpu-number表示CPU编号。
执行本命令时,如果不指定进程号和区域号,则显示所有的OSPF伪连接信息。
开启OSPF NSR功能后,OSPF主进程将OSPF邻居和路由等信息备份到备进程,通过本命令可以显示备份到备进程的信息。如果没有开启OSPF NSR功能,则不会显示任何信息。
display system internal ospf statistics命令用来显示OSPF的统计信息。
display system internal ospf [ process-id ] statistics { confusion-log | { request-queue | retrans-queue } [ interface-type interface-number ] [ neighbor-id ] }
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的统计信息。
confusion-log:显示Router ID冲突和IP地址冲突的统计信息。
request-queue:邻居请求链计数。
retrans-queue:邻居重传链计数。
interface-type interface-number:接口类型和编号,显示指定接口的统计信息。
neighbor-id:显示指定邻居的统计信息。
display system internal ospf status命令用来显示OSPF协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
context-admin
display system internal ospf vlink standby命令用来显示备份的OSPF虚连接信息。
display system internal ospf [ process-id ] vlink standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospf [ process-id ] vlink standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的虚连接信息。
standby slot slot-number:显示备份的指定单板的OSPF虚连接信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的虚连接信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPF虚连接信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPF的虚连接信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPF虚连接信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPF的虚连接信息。(分布式设备-IRF模式)
display system internal ospfv3 event-log命令用来显示OSPFv3的各种日志信息。
display system internal ospfv3 event-log { gr | nib | rib }
Probe视图
context-admin
gr:显示GR状态机变迁记录。
nib:显示路由管理上报给OSPFv3的NIB信息。
rib:显示路由管理上报给OSPFv3的RIB信息。
display system internal ospfv3 flood-list命令用来显示OSPFv3的flooding信息。
display system internal ospfv3 [ process-id ] flood-list [ interface-type interface-number ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的flooding信息。
display system internal ospfv3 interface命令用来显示OSPFv3的接口相关信息。
display system internal ospfv3 interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。
ipv6-address:IPv6地址前缀。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
display system internal ospfv3 interface standby命令用来显示备份的OSPFv3接口信息。
display system internal ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface-type interface-number:接口类型和接口编号。显示指定接口的详细信息。
verbose:显示所有接口的详细信息。
standby slot slot-number:显示备份的指定单板的OSPFv3接口信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的接口信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPFv3接口信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的接口信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPFv3接口信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的接口信息。(分布式设备-IRF模式)
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的接口信息。
如果未指定接口或参数verbose,将显示所有接口的概要信息。
display system internal ospfv3 lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospfv3 [ process-id ] lsdb { inter-prefix | inter-router | intra-prefix { reference type-1 | reference type-2 } | router }
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下的map信息。
inter-prefix:显示Inter-area-prefix LSA的map信息。
inter-router:显示Inter-area-router LSA的map信息。
intra-prefix:显示Intra-area-prefix LSA的map信息。
reference type-1:显示引用Router-LSA的Intra-area-prefix LSA map信息。
reference type-2:显示引用Network-LSA的Intra-area-prefix LSA map信息。
router:显示Router-LSA的map信息。
display system internal ospfv3 lsdb standby命令用来显示备份的LSA信息。
display system internal ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的链路状态数据库信息。
external:显示链路状态数据库中Type-5 LSA(AS External LSA)的信息。
grace:显示链路状态数据库中Type-11 LSA(Grace LSA)的信息。
inter-prefix:显示链路状态数据库中Type-3 LSA(Inter-Area-Prefix LSA)的信息。
inter-router:显示链路状态数据库中Type-4 LSA(Inter-Area-Router LSA)的信息。
intra-prefix:显示链路状态数据库中Type-9 LSA(Intra-Area-Prefix LSA)的信息。
link:显示链路状态数据库中Type-8 LSA(Link LSA)的信息。
network:显示链路状态数据库中Type-2 LSA(Network LSA)的信息。
nssa:显示链路状态数据库中Type-7 LSA(NSSA LSA)的信息。
router:显示链路状态数据库中Type-1 LSA(Router LSA)的信息。
unknown:显示链路状态数据库中未知类型LSA的信息。
type:LSA类型,取值范围十六进制0~FFFF。如果未指定本参数,将显示所有未知类型LSA的信息。
link-state-id:链路状态ID,IPv4地址形式。
originate-router router-id:发布该LSA的路由器的Router ID。
self-originate:显示本地路由器自己产生的LSA的链路状态数据库信息。
statistics:显示链路状态数据库中LSA的统计信息。
total:显示链路状态数据库中各种LSA的总数。
standby slot slot-number:显示备份的指定单板的OSPFv3链路状态数据库信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的链路状态数据库信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPFv3链路状态数据库信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的链路状态数据库信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPFv3链路状态数据库信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的链路状态数据库信息。(分布式设备-IRF模式)
display system internal ospfv3 nib命令用来显示OSPFv3的下一跳NIB信息。
display system internal ospfv3 nib [ nib-id ] [ verbose ]
Probe视图
context-admin
verbose:显示NIB详细信息。
display system internal ospfv3 peer standby命令用来显示备份的OSPFv3邻居信息。
display system internal ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
area area-id:显示位于指定区域的邻居信息。area-id为区域的标识,可以是十进制整数(取值范围为0~4294967295,系统会将其处理成IPv4地址格式)或IPv4地址格式。
verbose:显示邻居的详细信息。
peer-router-id:显示指定邻居的信息。
statistics:显示OSPFv3邻居的统计信息。
standby slot slot-number:显示备份的指定单板的OSPFv3邻居的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3邻居的信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPFv3邻居的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3邻居的信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPFv3邻居的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3邻居的信息。(分布式设备-IRF模式)
如果未指定OSPFv3进程号,将显示所有OSPFv3进程的邻居信息。
如果未指定区域,将显示所有区域的邻居信息。
如果接口参数、邻居Router ID参数都不输入,则显示所有接口的邻居信息。
display system internal ospfv3 prefix命令用来显示OSPFv3的前缀对应的LSA信息。
display system internal ospfv3 [ process-id ] prefix { inter | intra } [ ipv6-address prefix-length ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的前缀对应的LSA信息。
inter:显示InterAs前缀对应的LSA信息。
intra:显示IntraAs前缀对应的LSA信息。
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3前缀对应的LSA信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有的前缀对应的LSA信息。
display system internal ospfv3 router命令用来显示OSPFv3中到路由器节点的路由信息。
display system internal ospfv3 [ process-id ] router
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的信息。
display system internal ospfv3 standby命令用来显示备份的OSPFv3进程的信息。
display system internal ospfv3 [ process-id ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospfv3 [ process-id ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
verbose:显示OSPFv3进程的详细信息。如果未指定本参数,将显示OSPFv3进程的概要信息。
standby slot slot-number:显示备份的指定单板的OSPFv3进程信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的进程信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPFv3进程信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的进程信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPFv3进程信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的进程信息。(分布式设备-IRF模式)
display system internal ospfv3 statistics命令用来显示OSPFv3的统计信息。
display system internal ospfv3 [ process-id ] statistics { request-queue | retrans-queue } [ interface-type interface-number ] [ neighbor-id ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的统计信息。
interface-type interface-number:接口类型和编号,显示指定接口的统计信息。如果未指定本参数,将显示所有接口的统计信息。
neighbor-id:显示指定邻居的统计信息。如果未指定本参数,将显示所有邻居的统计信息。
display system internal ospfv3 status命令用来显示OSPFv3协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
context-admin
display system internal ospfv3 vlink standby命令用来显示备份的OSPFv3虚连接信息。
display system internal ospfv3 [ process-id ] vlink standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ospfv3 [ process-id ] vlink standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的虚连接信息。
standby slot slot-number:显示备份的指定单板的OSPFv3的虚连接信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的虚连接信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的OSPFv3的虚连接信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示OSPFv3的虚连接信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的OSPFv3的虚连接信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示OSPFv3的虚连接信息。(分布式设备-IRF模式)
display system internal pbr fib命令用来显示用户态下下一跳的配置信息。
display system internal pbr slot slot-number [ cpu cpu-number ] fib [ vpn-instance vpn-instance-name ]
分布式设备-IRF模式:
display system internal pbr chassis chassis-number slot slot-number [ cpu cpu-number ] fib [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示用户态下指定私网内下一跳的配置信息,如果未指定本参数,则显示用户态下公网内下一跳的配置信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定单板指定私网内下一跳的配置信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示用户态下指定成员设备的指定私网内下一跳的配置信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的指定私网内下一跳的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示用户态下指定CPU上指定私网内下一跳的配置信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal pbr kernel policy用于显示内核态下的策略路由信息。
display system internal pbr slot slot-number [ cpu cpu-number ] kernel policy [ policy-name [ setup ] ]
分布式设备-IRF模式:
display system internal pbr chassis chassis-number slot slot-number [ cpu cpu-number ] kernel policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示内核态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息。
slot slot-number:显示内核态下指定单板上的策略路由信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示内核态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示内核态下指定成员设备上指定单板的策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示内核态下指定CPU上策略路由信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal pbr policy用于显示用户态下的策略路由信息。
display system internal pbr slot slot-number [ cpu cpu-number ] policy [ policy-name [ setup ] ]
分布式设备-IRF模式:
display system internal pbr chassis chassis-number slot slot-number [ cpu cpu-number ] policy [ policy-name [ setup ] ]
Probe视图
context-admin
policy policy-name:显示用户态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定单板上的策略路由信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示用户态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示用户态下指定CPU上策略路由信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal process state命令用来显示服务的运行状态。
display system internal process state [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal process state [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定单板上服务的运行状态,slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上服务的运行状态,slot-number表示设备在IRF中的成员编号。不指定该参数时,表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上服务的运行状态,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上服务的运行状态,cpu-number表示CPU的编号。
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
display system internal rawip slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rawip chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有RawIP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有RawIP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有RawIP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
context-admin
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
context-admin
display system internal rib notificaion prefix命令用来显示IPv4 RIB的路由前缀事件信息。
display system internal rib event prefix
Probe视图
context-admin
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
display system internal rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
display system internal rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
context-admin
display system internal rib ftn命令用来显示FTN表项和统计计数信息。
display system internal rib ftn [ index ] [ statistics ]
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号 |
T9006/T9010/T9014 |
display system internal rib ftn |
支持 |
T5010/T5020 |
不支持 |
T1020/T1030/T1050/T1060/T1080 |
不支持 |
LSWM1IPSD0 |
不支持 |
Probe视图
context-admin
index:显示指定FTN索引的FTN信息。index为FTN索引值,为十六进制数,最高位统一设置为1。如果未指定本参数,将显示所有FTN索引的FTN信息。
statistics:显示FTN统计计数信息。
display system internal rib ftn summary命令用来显示FTN的运行信息。
型号 |
T9006/T9010/T9014 |
display system internal rib ftn summary |
支持 |
T5010/T5020 |
不支持 |
不支持 |
LSWM1IPSD0 |
不支持 |
Probe视图
context-admin
display system internal rib instance命令用来显示RIB的协议进程信息。
Probe视图
context-admin
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ] [ standby slot slot-number [ cpu cpu-number ] ]
display system internal rib event log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal rib log [ reverse ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display system internal rib event log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定单板RIB的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIB的日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB的日志信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上RIB的日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(分布式设备-IRF模式)
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
context-admin
display system internal rib nib命令用来显示RIB的下一跳信息。
display system internal rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number [ cpu cpu-number ]
display system internal rib nib protocol protocol [ verbose ] standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rib nib [ self-originated ] [ nib-id ] [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
display system internal rib nib protocol protocol [ verbose ] standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
self-originated:路由管理自己生成的下一跳信息。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol:显示指定路由协议生成的下一跳信息。
standby slot slot-number:显示备份的指定单板的RIB下一跳信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIB下一跳信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIB下一跳信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ] [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal rib nib log [ reverse ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
nib:显示NIB子模块的运行状态。
standby slot slot-number:显示备份的指定单板NIB子模块的运行状态日志,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的NIB子模块的运行状态日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示NIB子模块的运行状态日志。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上NIB子模块的运行状态日志,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(分布式设备-IRF模式)
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length [ vpn-instance vpn-instance-name ] [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal rib prefix ip-address mask-length [ vpn-instance vpn-instance-name ] [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
standby slot slot-number:显示备份的指定单板IPv4路由表前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4路由表前缀信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的IPv4路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv4路由表前缀信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上IPv4路由表前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4路由表前缀信息。(分布式设备-IRF模式)
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
display system internal rib summary [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal rib summary [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定单板的RIB统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIB统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB统计信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIB统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(分布式设备-IRF模式)
display system internal rip database standby命令用来显示备份的RIP数据库的激活路由。
display system internal rip process-id database standby [ ip-address { mask-length | mask } ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip process-id database standby [ ip-address { mask-length | mask } ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:RIP进程号,取值范围为1~65535。
ip-address:目的IP地址,点分十进制格式。
mask-length/mask:IP地址掩码,点分十进制格式或以整数形式表示的长度,当用整数时,取值范围为0~32。
standby slot slot-number:显示备份的指定单板的RIP数据库的激活路由,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIP数据库的激活路由,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIP数据库的激活路由,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip graceful-restart event-log命令用来显示RIP GR日志信息。
display system internal rip graceful-restart event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip graceful-restart event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板的RIP GR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的RIP GR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的RIP GR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip interface命令用来显示RIP的接口信息。
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal rip interface standby命令用来显示备份的RIP接口信息。
display system internal rip process-id interface standby [ interface-type interface-number ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip process-id interface standby [ interface-type interface-number ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有接口信息。
standby slot slot-number:显示备份的指定单板的RIP接口信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIP接口信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIP接口信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip neighbor standby命令用来显示备份的RIP邻居信息。
display system internal rip process-id neighbor standby [ interface-type interface-number ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip process-id neighbor standby [ interface-type interface-number ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有邻居信息。
standby slot slot-number:显示备份的指定单板的RIP邻居信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIP邻居信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIP邻居信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip nib命令用来显示RIP路由下一跳信息。
display system internal rip nib [ nib-id ] [ verbose ]
Probe视图
context-admin
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
display system internal rip nib log命令用来显示RIP路由下一跳日志信息。
Probe视图
context-admin
display system internal rip non-stop-routing event-log命令用来显示RIP NSR日志信息。
display system internal rip non-stop-routing event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip non-stop-routing event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:显示指定单板的RIP NSR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备的RIP NSR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的RIP NSR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip route standby命令用来显示备份的RIP路由信息。
display system internal rip process-id route standby [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal rip process-id route standby [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
verbose:显示当前RIP路由表中指定目的地址和掩码的所有路由信息。如果未指定本参数,则只显示指定目的地址和掩码的最优RIP路由。
peer ip-address:显示从指定邻居学到的所有路由信息。
statistics:显示路由的统计信息。路由的统计信息包括路由总数目,各个邻居的路由数目。
standby slot slot-number:显示备份的指定单板的RIP路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIP路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIP路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal rip status命令用来显示RIP协议全局状态信息。
Probe视图
context-admin
display system internal ripng database standby命令用来显示备份的RIPng数据库的激活路由。
display system internal ripng process-id database standby [ ipv6-address prefix-length ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng process-id database standby [ ipv6-address prefix-length ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
process-id:RIPng进程号,取值范围为1~65535。
ipv6-address prefix-length:显示指定IPv6地址的激活路由信息。ipv6-address表示IPv6地址;prefix-length表示IPv6地址前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定单板的RIPng数据库的激活路由,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIPng数据库的激活路由,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIPng数据库的激活路由,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng graceful-restart event-log命令用来显示RIPng GR日志信息。
display system internal ripng graceful-restart event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng graceful-restart event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:显示指定单板的RIPng GR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示指定成员设备的RIPng GR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示指定成员设备上指定单板的RIPng GR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng interface命令用来显示RIPng的接口信息。
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
context-admin
ipv6-address:IPv6地址。
prefix-length:前缀长度,取值范围为0~128。
display system internal ripng interface standby命令用来显示备份的RIPng接口信息。
display system internal ripng process-id interface standby [ interface-type interface-number ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng process-id interface standby [ interface-type interface-number ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng指定进程的所有接口信息。
standby slot slot-number:显示备份的指定单板的RIPng接口信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIPng接口信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIPng接口信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng neighbor standby命令用来显示备份的RIPng邻居信息。
display system internal ripng process-id neighbor standby [ interface-type interface-number ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng process-id neighbor standby [ interface-type interface-number ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng的所有接口信息。
standby slot slot-number:显示备份的指定单板的RIPng邻居信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIPng邻居信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIPng邻居信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng nib命令用来显示RIPng路由下一跳信息。
display system internal ripng nib [ nib-id ] [ verbose ]
Probe视图
context-admin
verbose:显示下一跳详细信息。
display system internal ripng nib log命令用来显示RIPng路由下一跳日志信息。
Probe视图
context-admin
display system internal ripng non-stop-routing event-log命令用来显示RIPng NSR日志信息。
display system internal ripng non-stop-routing event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng non-stop-routing event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:显示指定单板的RIPng NSR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示指定成员设备的RIPng NSR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示指定成员设备上指定单板的RIPng NSR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng route standby命令用来显示备份的RIPng路由信息。
display system internal ripng process-id route standby [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ] slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal ripng process-id route standby [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ] chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:显示备份的指定单板的RIPng路由信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:显示备份的指定成员设备的RIPng路由信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIPng路由信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
display system internal ripng status命令用来显示RIPng协议全局状态信息。
Probe视图
context-admin
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
context-admin
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
context-admin
display system internal session命令用来显示会话的配置信息。
display system internal session [ slot slot-number [ cpu cpu-number ] ] [ verbose | interface [ interface-type interface-number ] ]
分布式设备-IRF模式:
display system internal session [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ verbose | interface [ interface-type interface-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上的会话配置信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的会话内核配置信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的会话配置信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的会话配置信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的会话配置信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的会话配置信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的会话配置信息,cpu-number表示CPU的编号。
verbose:显示会话配置的详细信息。不指定该参数时,显示会话配置的概要信息。
interface interface-type interface-number:表示使用指定接口的会话配置信息。interface-type interface-number表示接口类型和接口编号。
display system internal session alg-exception命令用来显示ALG异常统计信息。
display system internal session alg-exception [ slot slot-number [ cpu cpu-number ] ] [ acl acl-number ] [ application { ftp | gtp | h225 | h245 | ils | mgcp | nbdgm | nbns | nbss | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } ]
分布式设备-IRF模式:
display system internal session alg-exception [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ acl acl-number ] [ application { ftp | gtp | h225 | h245 | ils | mgcp | nbdgm | nbns | nbss | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } ]
Probe视图
context-admin
slot slot-number:显示指定单板上的ALG异常报文统计信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的ALG异常报文统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的ALG异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的ALG异常报文统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的ALG异常报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的ALG异常报文统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的ALG异常报文统计信息,cpu-number表示CPU的编号。
acl acl-number:显示匹配指定ACL的ALG异常统计信息,取值范围为2000~3999。
ftp:表示FTP的ALG异常统计信息。
gtp:表示GTP的ALG异常统计信息。
h225:表示H.225的ALG异常统计信息。
h245:表示H.245的ALG异常统计信息。
ils:表示ILS的ALG异常统计信息。
mgcp:表示MGCP的ALG异常统计信息。
nbns:表示NBNS的ALG异常统计信息。
nbss:表示NBSS的ALG异常统计信息。
ngdgm:表示NGDGM的ALG异常统计信息。
pptp:表示PPTP的ALG异常统计信息。
rsh:表示RSH的ALG异常统计信息。
ras:表示RAS的ALG异常统计信息。
rtsp:表示RTSP的ALG异常统计信息。
sccp:表示SCCP的ALG异常统计信息。
sip:表示SIP的ALG异常统计信息。
sqlnet:表示SQLNET的ALG异常统计信息。
tftp:表示TFTP的ALG异常统计信息。
xdmcp:表示XDMCP的ALG异常统计信息。
本命令的支持情况与设备的型号有关,请以设备的实际情况为准。此命令只有支持四代卡的设备才支持。四代卡包括FW/NAT/IPS等。
display system internal session fdb statistics命令用来显示会话流表的统计信息。
分布式设备-独立运行模式:
display system internal session fdb statistics { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal session fdb statistics { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
设备各款型对于本节所描述的特性支持情况有所不同,详细差异信息如下:
型号 |
T9006/T9010/T9014 |
display system internal session fdb statistics |
支持 |
T5010/T5020 |
不支持 |
不支持 |
LSWM1IPSD0 |
不支持 |
Probe视图
context-admin
ipv4:显示IPv4的会话流表统计信息。
ipv6:显示IPv6的会话流表统计信息。
slot slot-num:显示指定单板上的会话流表统计信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的会话流表统计信息。(分布式设备-独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的会话流表统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的会话流表统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:清除指定CPU上的会话流表统计信息,cpu-number表示CPU的编号。
只有执行debugging session fdb statistics命令后,才可通过display system internal session fdb statistics命令查看到会话流表的统计信息。
display system internal session hot-backup statistics命令用来显示会话热备份的统计信息。
display system internal session hot-backup statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal session hot-backup statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上会话热备份的统计信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上会话热备份的统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上会话热备份的统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上会话热备份的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上会话热备份的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上会话热备份的统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上会话热备份的统计信息,cpu-number表示CPU的编号。
display system internal session relation hot-backup statistics命令用来显示会话关联表的热备统计信息。
display system internal session relation hot-backup statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal session relation hot-backup statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:显示指定单板上会话关联表的热备份统计信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上会话关联表的热备份统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上会话关联表的热备份统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上会话关联表的热备份统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上会话关联表的热备份统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上会话关联表的热备份统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上会话关联表的热备份统计信息,cpu-number表示CPU的编号。
display system internal session relation-table ipv4命令用来显示IPv4关联表详细信息
display system internal session relation-table ipv4 [ slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ]
分布式设备-IRF模式:
display system internal session relation-table ipv4 [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
context-admin
slot slot-number:显示指定单板上的IPv4关联表详细信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的IPv4关联表详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4关联表详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv4关联表详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv4关联表详细信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的IPv4关联表详细信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv4关联表详细信息,cpu-number表示CPU的编号。
source-ip source-ip:显示指定源IPv4地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的关联表表项。destination-ip表示发起方到响应方关联表的目的IPv4地址。
display system internal session relation-table ipv6命令用来显示IPv6关联表详细详细信息。
display system internal session relation-table ipv6 [ slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ]
分布式设备-IRF模式:
display system internal session relation-table ipv6 [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
context-admin
slot slot-number:显示指定单板上的IPv6关联表详细信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的IPv6关联表详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv6关联表详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv6关联表详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv6关联表详细信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的IPv6关联表详细信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv6关联表详细信息,cpu-number表示CPU的编号。
source-ip source-ip:显示指定源IPv6地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的关联表表项。 destination-ip表示发起方到响应方关联表的目的IPv6地址。
display system internal session statistics命令用来显示会话的异常报文统计信息。
display system internal session statistics { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal session statistics { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
ipv4:显示Pv4会话的异常报文统计信息。
ipv6:显示IPv6会话的异常报文统计信息。
slot slot-number:显示指定单板上的异常报文统计信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的异常报文统计信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的异常报文统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的异常报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的异常报文统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的异常报文统计信息,cpu-number表示CPU的编号。
display system internal session table ipv4命令用来显示IPv4单播会话表项详细信息。
display system internal session table ipv4 [ slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
分布式设备-IRF模式:
display system internal session table ipv4 [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
context-admin
slot slot-number:显示指定单板上的IPv4单播会话表项详细信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的IPv4单播会话表项详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv4单播会话表项详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv4单播会话表项详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv4单播会话表项详细信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的IPv4单播会话表项详细信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv4单播会话表项详细信息,cpu-number表示CPU的编号。
source-ip source-ip:显示指定源IP地址的单播会话表项。source-ip表示发起方到响应方会话的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的单播会话表项详细信息。destination-ip表示发起方到响应方会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项详细信息。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4单播会话表项详细信息。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项详细信息。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
display system internal session table ipv6命令用来显示IPv6单播会话表项详细信息。
display system internal session table ipv6 [ slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
分布式设备-IRF模式:
display system internal session table ipv6 [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
context-admin
slot slot-number:显示指定单板上的IPv6会话表项详细信息,slot-number表示单板所在槽位号。若不指定该参数,则显示所有单板上的IPv6会话表项详细信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的IPv6会话表项详细信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则显示所有成员设备上的IPv6会话表项详细信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上的IPv6会话表项详细信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则显示所有成员设备的所有单板上的IPv6会话表项详细信息。(分布式IRF设备-IRF模式)
cpu cpu-number:显示指定CPU上的IPv6会话表项详细信息,cpu-number表示CPU的编号。
source-ip source-ip:显示指定源IPv6地址的单播会话表项。 source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的单播会话表项。destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPV6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
context-admin
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
· 字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
· 二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal tcp命令用来显示设备上所有TCP连接的摘要信息。
display system internal tcp slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal tcp chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有TCP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有TCP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有TCP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal tcp port-info命令用来显示TCP模块非保留端口的使用信息。
display system internal tcp port-info [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal tcp port-info [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定单板上的TCP模块非保留端口的使用信息,slot-number表示单板所在槽位号。如果未指定本参数,则显示所有单板上的TCP模块非保留端口的使用信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上TCP模块非保留端口的使用信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的TCP模块非保留端口的使用信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的TCP模块非保留端口的使用信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的TCP模块非保留端口的使用信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的TCP模块非保留端口的使用信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal udp命令用来显示设备上所有UDP连接的摘要信息。
display system internal udp slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal udp chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:显示从指定单板上获取的所有UDP连接的摘要信息。slot-number表示单板所在的槽位号。(分布式-独立运行模式)
slot slot-number:显示从指定成员设备上获取的所有UDP连接的摘要信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示从指定CPU上获取的所有UDP连接的摘要信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal udp port-info命令用来显示UDP模块非保留端口的使用信息。
display system internal udp port-info [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal udp port-info [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:显示指定单板上的UDP模块非保留端口的使用信息,slot-number表示单板所在槽位号。如果未指定本参数,则显示所有单板上的UDP模块非保留端口的使用信息。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上UDP模块非保留端口的使用信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示所有成员设备上的UDP模块非保留端口的使用信息。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的UDP模块非保留端口的使用信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有单板上的UDP模块非保留端口的使用信息。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的UDP模块非保留端口的使用信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal userlog mbuf dump命令用来显示指定个数的USERLOG UDP报文内容。
display system internal userlog mbuf dump count number [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal userlog mbuf dump count number [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
count number:指定显示报文的个数。number为需要显示内容的日志个数,取值范围为1-100。
slot slot-number:指定显示报文所在的单板。slot-number为单板所在的槽位号。如未指定该参数,则显示主用主控板上的报文内容。(分布式设备-独立运行模式)
slot slot-number:指定显示报文的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的报文内容。(集中式IRF设备)
chassis chassis-number slot slot-number:指定显示报文的成员设备和单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上的报文内容。(分布式设备-IRF模式)
cpu cpu-number:指定显示报文设备的CPU。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal userlog statistic命令用来显示USERLOG模块的运行统计信息。
分布式设备-独立运行模式/集中式IRF设备:
display system internal userlog statistic [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal userlog statistic [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:指定查看统计信息的单板。slot-number为单板所在的槽位号。如未指定该参数,则显示主用主控板的统计信息。(分布式设备-独立运行模式)
slot slot-number:指定查看统计信息的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上的统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:指定查看统计信息的成员设备和单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上的统计信息。(分布式设备-IRF模式)
cpu cpu-number:指定查看统计信息的成员设备所在的CPU。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal userlog mbuf test命令用来发送指定个数的FLOW测试日志,并显示日志发送结果信息。
display system internal userlog test count number [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
display system internal userlog test count number [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
count number:指定发送测试日志个数。number为发送测试日志的个数,取值范围为1-3000。
slot slot-number:指定发送测试日志的单板。slot-number为单板所在的槽位号。如未指定该参数,则显示主用主控板上发送的测试日志。(分布式设备-独立运行模式)
slot slot-number:指定发送测试日志的成员设备。slot-number为设备在IRF中的成员编号。如未指定该参数,则显示Master设备上发送的测试日志。(集中式IRF设备)
chassis chassis-number slot slot-number:指定发送测试日志的成员设备和单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如未指定该参数,则显示全局主用主控板上发送的测试日志。(分布式设备-IRF模式)
cpu cpu-number:指定发送测试日志的CPU。cpu-number表示CPU编号。只有指定的slot支持多CPU时,才能配置该参数。
display system internal virtual-crypto-engine命令用来显示虚拟加密引擎的基本信息,包括虚拟加密引擎的名称、支持的算法能力等信息。
Probe视图
context-admin
若设备没有虚拟加密引擎,则不会显示任何信息。
display system internal virtual-crypto-engine statistics命令用来显示虚拟加密引擎的统计信息,包括建立会话的个数,加密引擎处理的报文数等信息。
分布式设备—独立运行模式/集中式IRF设备:
display system internal virtual-crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ]
分布式设备—IRF模式:
display system internal virtual-crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
engine-id engine-id:显示指定加密引擎的统计信息,engine-id为加密引擎ID编号,取值范围与为0~4294967295。
slot slot-number:显示指定单板上的加密引擎统计信息,slot-number表示单板所在槽位号。(分布式设备-独立运行模式)
slot slot-number:显示指定成员设备上的加密引擎统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的加密引擎统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU上的加密引擎统计信息,cpu-number表示单板上的CPU编号。
若不指定任何参数,则表示显示所有虚拟加密引擎的统计信息。
display system internal vlan命令用来查看VLAN模块相关的内部信息。
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
slot slot-number:查看指定单板的VLAN模块信息。其中,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:查看指定成员设备的VLAN模块信息。其中,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的VLAN模块信息。其中,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:查看指定CPU上的VLAN模块信息。cpu-number表示CPU的编号。不指定该参数时,表示默认CPU。
display transceiver information interface命令用来显示光模块的详细信息。
display transceiver information interface [ interface-type interface-number ]
Probe视图
interface-type interface-number:显示接口上插入的可插拔光模块的详细信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
display transceiver moduleinfo命令用来显示可插拔光模块软件内部的核心数据结构的信息。
display transceiver moduleinfo interface [ interface-type interface-number ]
Probe视图
interface [ interface-type interface-number ]:表示接口类型和接口编号。不指定该参数时,表示所有接口。
display transceiver register命令用来显示可插拔光模块的寄存器信息。
display transceiver register interface [ interface-type interface-number ]
Probe视图
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number [cpu cpu-number ] ]
分布式设备-IRF模式:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
Probe视图
context-admin
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号,不指定表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,不指定表示全局主用主控板。(分布式设备-IRF模式)
cpu cpu-number:表示CPU编号。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
license check-timer命令用来修改License的每天检查定时器的值。
license check-timer interval-value slot slot-number
分布式设备-IRF模式:
license check-timer interval-value chassis chassis-number slot slot-number
License的每天检查定时器的值为864000秒(24小时)。
Probe视图
interval-value:指定检查定时器的周期,单位为秒,范围为10~864000。时间过短可能造成系统繁忙,建议60秒以上。
slot slot-number:表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
License的有效期以天为单位,设备以每天检查定时器时长为周期,检查License是否过期,如果已经过期,则标识为过期;如果没有过期,则将有效期减一。
本命令不会保存到配置文件,设备重启后会恢复到缺省情况。
本命令仅用于内部测试使用,用户不要使用此命令修改时间,否则会导致License快速过期。
license file-timer命令用来修改License文件检查定时器的周期。
license file-timer interval-value slot slot-number
分布式设备-IRF模式:
license file-timer interval-value chassis chassis-number slot slot-number
License文件检查定时器的周期为1800秒(30分钟)。
Probe视图
interval-value:指定文件丢失检查定时器的周期,单位为秒,范围为10~864000。时间过短可能造成系统繁忙,建议60秒以上。
slot slot-number:修改指定单板上的文件丢失的检查周期。slot-number为单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:修改指定设备上的文件丢失检查定定时器时间周期。slot-number为设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:修改指定设备指定单板的文件丢失检查定时器周期。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
设备启动后,会自动启动License进程,并检查License文件是否存在。如果License文件不存在,则启动License文件检查定时器,周期性检测License文件是否恢复。License文件文件恢复,License文件检查定时器会自动删除。
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
list file-path [ slot slot-number ]
分布式设备-IRF模式:
list file-path [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
file-path:要查看的文件或目录的路径,区分大小写。
slot slot-number:查看指定单板系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:查看指定设备系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:查看指定设备上单板系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(分布式设备-IRF模式)
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id [ slot slot-number [cpu cpu-number ] ]
undo memory boundary-check enable job job-id [ slot slot-number [cpu cpu-number ] ]
分布式设备-IRF模式:
memory boundary-check enable job job-id [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
undo memory boundary-check enable job job-id [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
内存越界检查功能处于关闭状态。
Probe视图
context-admin
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
· memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id [ slot slot-number [cpu cpu-number ] ]
分布式设备-IRF模式:
memory boundary-check scan job job-id [ chassis chassis-number slot slot-number [cpu cpu-number ] ]
Probe视图
context-admin
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
· memory boundary-check enable
probe命令用来从系统视图进入Probe视图。
probe
context-admin
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
reset system internal adj4 statistics命令用来清除IPv4邻接表项的统计信息
reset system internal adj4 statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal adj4 statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:清除指定单板的IPv4邻接表项的统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的IPv4邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的IPv4邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的IPv4邻接表项的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal adj6 statistics命令用来清除IPv6邻接表项的统计信息
reset system internal adj6 statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal adj6 statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:清除指定单板的IPv6邻接表项的统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的IPv6邻接表项的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的IPv6邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的IPv6邻接表项的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal arp statistics命令用来清除指定板上的ARP统计信息。
reset system internal arp statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal arp statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:清除指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的ARP统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的ARP统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal aspf statistics命令用来清除ASPF、报文过滤以及对象策略模块的丢包统计信息。
reset system internal aspf statistics zone-pair { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal aspf statistics zone-pair { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
zone-pair:清除域间实例上的ASPF丢包统计信息。
ipv4:清除IPv4报文的丢包统计信息。
ipv6:清除IPv6报文的丢包统计信息。
slot slot-number:清除指定单板上的丢包统计信息,slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有单板上的丢包统计信息。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备上的丢包统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示清除所有成员设备上的丢包统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的丢包统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示清除所有成员设备的所有单板上的丢包统计表项信息。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU上的丢包统计信息,cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal data-filter match statistics命令用来清除数据过滤匹配的统计信息。
reset system internal data-filter match statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal data-filter match statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:清除指定单板的数据过滤匹配的统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的数据过滤匹配的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的数据过滤匹配的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的数据过滤匹配的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
· display system internal data-filter match
reset system internal data-filter rule statistics命令用来清除数据过滤规则的统计信息。
reset system internal data-filter rule statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal data-filter rule statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:清除指定单板的数据过滤规则的统计信息。slot-number表示单板所在的槽位号。不指定本参数时,将清除所有单板的数据过滤规则的统计信息。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的数据过滤规则的统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的数据过滤规则的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的数据过滤规则的统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
· display system internal data-filter rule
reset system internal fib statistics命令用来清除FIB统计信息。
reset system internal fib statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal fib statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
slot slot-number:清除指定单板的FIB统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的FIB统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的FIB统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的FIB统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal inspect hit-statistics命令用来清除应用层检测引擎中检测规则被命中的统计信息。
reset system internal inspect hit-statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
reset system internal inspect hit-statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
slot slot-number:清除指定单板上的应用层检测引擎中检测规则被命中的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备上的应用层检测引擎中检测规则被命中的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的应用层检测引擎中检测规则被命中的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的应用层检测引擎中检测规则被命中的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
reset system internal inspect http命令用来清除应用层检测引擎处理HTTP报文解析结果的统计信息。
reset system internal inspect http [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF设备:
reset system internal inspect http [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
该命令清除应用层检测引擎处理HTTP报文解析结果的统计信息。
slot slot-number:清除指定单板上的应用层检测引擎处理HTTP报文解析结果的统计信息。slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备上的应用层检测引擎处理HTTP报文解析结果的统计信息。slot-number表示设备在IRF中的成员编号。若不指定该参数,则表示所有成员设备。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的应用层检测引擎处理HTTP报文解析结果的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则表示所有单板。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的应用层检测引擎处理HTTP报文解析结果的统计信息。cpu-number表示CPU编号,只有指定的slot支持多CPU时,才能配置该参数。
reset system internal ip routing-table statistics protocol命令用来清除路由表中的路由统计信息。
分布式设备独立运行模式/集中式IRF设备:
reset system internal ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal ip routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。
protocol:清除IPv4路由表中指定路由协议的统计信息。
all:清除IPv4路由表中所有路由协议的统计信息。
standby slot slot-number:清除备份的指定单板的路由统计信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:清除备份的指定成员设备的路由统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备的路由统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:显示指定CPU的信息。cpu-number表示CPU编号。
reset system internal ipv6 fast-forwarding statistics 命令用来清除IPv6快转的报文统计信息。
reset system internal ipv6 fast-forwarding statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:清除指定成员设备的IPv6快转的报文统计信息。slot-number表示单板所在的槽位号。如果未指定本参数,则清除主用主控板上的快转的报文统计信息。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的IPv6快转的报文统计信息。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则清除Master设备上的快转的报文统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的IPv6快转的报文统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则清除全局主用主控板上的IPv6快转的报文统计信息。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的IPv6快转的报文统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset system internal ipv6 rib [ event ] log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal ipv6 rib [ event ] log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
event:IPv6 RIB路由变化相关的日志。
standby slot slot-number:清除备份的指定单板RIB相关的日志内容,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB相关的日志内容。(分布式设备-独立运行模式)
standby slot slot-number:清除备份的指定成员设备的RIB相关的日志内容,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB相关的日志内容。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上RIB相关的日志内容,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB相关的日志内容。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的信息。cpu-number表示CPU编号。
reset system internal ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
reset system internal ipv6 rib nib log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal ipv6 rib nib log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
standby slot slot-number:清除备份的指定单板NIB子模块日志,slot-number表示单板所在的槽位号。如果未指定本参数,将清除NIB子模块日志。(分布式设备-独立运行模式)
standby slot slot-number:清除备份的指定成员设备的NIB子模块日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除NIB子模块日志。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上NIB子模块日志,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除NIB子模块日志。(分布式设备-IRF模式)
reset system internal ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
reset system internal ipv6 rib summary [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal ipv6 rib summary [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
standby slot slot-number:清除备份的指定单板RIB的统计摘要信息,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB的统计摘要信息。(分布式设备-独立运行模式)
standby slot slot-number:清除备份的指定成员设备RIB的统计摘要信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB的统计摘要信息。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上RIB的统计摘要信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB的统计摘要信息。(分布式设备-IRF模式)
reset system internal ipv6 route-direct log命令用来清除直连路由日志。
reset system internal ipv6 route-direct { event | notify | nib } log
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:ipv6直连路由NIB子模块相关日志。
reset system internal ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
context-admin
reset system internal ipv6 routing-table statistics protocol命令用来清除IPv6路由表中的综合路由统计信息。
reset system internal ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal ipv6 routing-table statistics protocol [ vpn-instance vpn-instance-name ] { protocol | all } standby chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
vpn-instance vpn-instance-name:清除指定VPN的路由统计信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则清除公网的路由统计信息。
protocol:清除IPv6路由表中指定路由协议的统计信息。
all:清除IPv6路由表中所有路由协议的统计信息。
reset system internal irf msg命令用来清空IRF日志消息。
集中式IRF设备:
reset system internal irf msg [ slot slot-number ]
分布式设备-IRF模式:
reset system internal irf msg [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
slot slot-number:表示设备在IRF中的成员编号。不指定该参数时,表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示主控板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。(分布式设备-IRF模式)
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
reset system internal mac-address statistics slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal mac-address statistics chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:清除指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的MAC地址表统计信息。slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的MAC地址表统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal nd statistics命令用来清除各板上的ND统计信息。
reset system internal nd statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal nd statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
slot slot-number:清除指定单板的ND统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,则清除所有单板的ND统计信息。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的ND统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则清除所有单板的ND统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,则清除所有单板的ND统计信息。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU的ND统计信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
reset system internal ospf event-log命令用来清除OSPF的日志信息。
reset system internal ospf event-log { interface | nib | notify }
Probe视图
context-admin
interface:接口事件相关日志。
nib:NIB的相关日志。
notify:接口通知相关日志。
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal rib [ event ] log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
event:RIB路由变化相关的日志。
reset system internal rib nib log命令用来清除NIB子模块日志。
reset system internal rib nib log [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal rib nib log [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
reset system internal rib summary [ standby slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal rib summary [ standby chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
reset system internal rip graceful-restart event-log命令用来清除RIP GR日志信息。
reset system internal rip graceful-restart event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal rip graceful-restart event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:清除指定单板的RIP GR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的RIP GR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的RIP GR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
reset system internal rip non-stop-routing event-log命令用来清除RIP NSR日志信息。
reset system internal rip non-stop-routing event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal rip non-stop-routing event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
slot slot-number:清除指定单板的RIP NSR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备的RIP NSR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的RIP NSR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
reset system internal ripng graceful-restart event-log命令用来清除RIPng GR日志信息。
reset system internal ripng graceful-restart event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal ripng graceful-restart event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:清除指定单板的RIPng GR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:清除指定成员设备的RIPng GR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除指定成员设备上指定单板的RIPng GR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
reset system internal ripng non-stop-routing event-log命令用来清除RIPng NSR日志信息。
reset system internal ripng non-stop-routing event-log slot slot-number [ cpu cpu-number ]
分布式设备-IRF模式:
reset system internal ripng non-stop-routing event-log chassis chassis-number slot slot-number [ cpu cpu-number ]
Probe视图
context-admin
standby slot slot-number:清除指定单板的RIPng备进程的NSR日志信息,slot-number表示单板所在的槽位号。(分布式设备-独立运行模式)
standby slot slot-number:清除指定成员设备的RIPng备进程的NSR日志信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
standby chassis chassis-number slot slot-number:清除指定成员设备上指定单板的RIPng备进程的NSR日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
reset system internal route-direct log命令用来清除直连路由日志。
reset system internal route-direct { event | notify | nib } log
Probe视图
context-admin
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
context-admin
reset system internal session alg statistics命令用来清除ALG异常报文统计信息。
reset system internal session alg statistics [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal session alg statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
slot slot-number:清除指定单板上的ALG异常报文统计信息,slot-number表示单板所在槽位号。若不指定该参数,则清除所有单板上的ALG异常报文统计信息。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备上的ALG异常报文统计信息,slot-number表示设备在IRF中的成员编号。若不指定该参数,则清除所有成员设备上的ALG异常报文统计信息。(集中式IRF设备)
chassis chassis-number slot slot-number:清除指定成员设备的指定单板上的ALG异常报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若不指定该参数,则清除所有成员设备的所有单板上的ALG异常报文统计信息。(分布式IRF设备-IRF模式)
cpu cpu-number:清除指定CPU上的ALG异常报文统计信息,cpu-number表示CPU的编号。
reset system internal session statistics命令用来清除会话异常报文统计信息。
reset system internal session statistics { ipv4 | ipv6 } [ slot slot-number [ cpu cpu-number ] ]
分布式设备-IRF模式:
reset system internal session statistics { ipv4 | ipv6 } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
ipv4:清除IPv4会话的异常报文统计信息。
ipv6:清除IPv6会话的异常报文统计信息。
cpu cpu-number:清除指定CPU上的异常报文统计信息,cpu-number表示CPU的编号。
reset system internal virtual-crypto-engine statistics命令用来清除虚拟加密引擎的统计计数。
reset system internal virtual-crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ]
分布式设备—IRF模式:
reset system internal virtual-crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Probe视图
context-admin
engine-id engine-id:清除指定加密引擎的统计信息,engine-id为加密引擎ID编号,取值范围为0~4294967295。
slot slot-number:清除指定单板上的加密引擎统计信息,slot-number表示单板所在槽位号。(分布式设备-独立运行模式)
slot slot-number:清除指定成员设备上的加密引擎统计信息,slot-number表示设备在IRF中的成员编号。(集中式IRF设备)
chassis chassis-number slot slot-numbe:清除指定成员设备上指定单板的加密引擎统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
cpu cpu-number:清除指定CPU上的加密引擎统计信息,cpu-number表示单板上的CPU编号。
若不指定任何参数,则表示清除所有虚拟加密引擎的统计信息。
system internal relation hot-backup force-delete enable命令用来开启强制删除会话热备份的关联表功能。
undo system internal relation hot-backup force-delete enable命令用来关闭强制删除会话热备份的关联表功能。
强制删除会话热备份的关联表功能处于开启状态。
Probe视图
context-admin
system internal relation hot-backup update enable命令用来开启会话热备份的关联表更新功能。
undo system internal relation hot-backup update enable命令用来关闭会话热备份的关联表更新功能。
会话热备份的关联表更新功能处于开启状态。
Probe视图
context-admin
system internal relation synchronization enable命令用来开启会话热备份的关联表同步功能。
undo system internal relation synchronization enable命令用来关闭会话热备份的关联表同步功能。
会话热备份的关联表同步功能处于开启状态。
Probe视图
context-admin
system internal session alg statistics acl acl-number enable命令用来开启ALG异常报文统计功能。
undo system internal session alg statistics命令用来恢复缺省情况。
ALG异常报文统计功能处于关闭状态。
Probe视图
context-admin
acl acl-number:指定ACL的编号,acl-number取值范围为2000~3999。
开启ALG异常报文统计功能后,设备对匹配指定IPv4/IPv6 ACL的ALG异常报文进行统计。关闭ALG统计开关后,清除统计信息。
system internal session hot-backup aging-request enable命令用来开启热备份的会话老化请求发送功能。
undo system internal session hot-backup aging-request enable命令用来关闭热备份的会话老化请求发送功能。
热备份的会话老化请求发送功能处于开启状态。
Probe视图
context-admin
system internal session hot-backup aging-response enable命令用来开启热备份的会话老化应答功能。
undo system internal session hot-backup aging-response enable命令用来关闭热备份的会话老化应答功能。
热备份的会话老化应答功能处于开启状态。
Probe视图
context-admin
system internal session hot-backup broadcast enable命令用来开启广播会话热备份功能。
undo system internal session hot-backup broadcast enable命令用来关闭广播会话热备份功能。
广播会话热备份功能处于开启状态。
Probe视图
context-admin
system internal session hot-backup force-delete enable命令用来开启热备份的会话强制删除功能。
undo system internal session hot-backup force-delete enable命令用来关闭热备份的会话强制删除功能。
热备份的会话强制删除功能处于开启状态。
Probe视图
context-admin
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
view file-path [ slot slot-number ]
分布式设备-IRF模式:
view file-path [ chassis chassis-number slot slot-number ]
Probe视图
context-admin
file-path:要查看文件的路径,区分大小写。
slot slot-number:查看指定单板系统目录(/proc/、/sys/、/var/)下的文件的内容。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(分布式设备-独立运行模式)
slot slot-number:查看指定设备系统目录(/proc/、/sys/、/var/)下的文件的内容。slot-number表示设备在IRF中的成员编号。不指定该参数时,表示主设备。(集中式IRF设备)
chassis chassis-number slot slot-number:查看指定设备上单板系统目录(/proc/、/sys/、/var/)下的文件的内容。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示主用主用主控板。(分布式设备-IRF模式)
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
