08-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (387.09 KB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 redirect
1.2.7 remark customer-vlan-id
1.2.8 remark dot1p
1.2.9 remark drop-precedence
1.2.10 remark dscp
1.2.11 remark ip-precedence
1.2.12 remark local-precedence
1.2.13 remark qos-local-id
1.2.14 remark service-vlan-id
1.2.15 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos vlan-policy
1.3.9 qos apply policy (interface view, control plane view)
1.3.10 qos apply policy (user-profile view)
1.3.11 qos apply policy global
1.3.12 qos policy
1.3.13 qos vlan-policy
1.3.14 reset qos policy control-plane
1.3.15 reset qos policy global
1.3.16 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 qos map-table
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量整形和接口限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.2 接口限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr
4 拥塞管理
4.1 严格优先级队列配置命令
4.1.1 display qos queue sp
4.1.2 qos sp
4.2 加权轮询队列配置命令
4.2.1 display qos queue wrr interface
4.2.2 qos wrr
4.2.3 qos wrr { byte-count | weight }
4.2.4 qos wrr group sp
4.3 加权公平队列配置命令
4.3.1 display qos queue wfq interface
4.3.2 qos bandwidth queue
4.3.3 qos wfq
4.3.4 qos wfq { byte-count | weight }
4.3.5 qos wfq group sp
4.4 队列调度策略配置命令
4.4.1 bandwidth
4.4.2 display qos qmprofile configuration
4.4.3 display qos qmprofile interface
4.4.4 qos apply qmprofile
4.4.5 qos qmprofile
4.4.6 queue
4.5 队列老化时间配置命令
4.5.1 qos queue aging-time
4.6 端口队列统计配置命令
4.6.1 display qos queue-statistics interface outbound
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred table
5.1.5 queue
5.1.6 queue ecn
5.1.7 queue weighting-constant
6 聚合CAR
6.1 聚合CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car
6.1.4 reset qos car name
1 QoS策略
1.1  定义类的命令
display traffic classifier命令用来显示流分类的配置信息。
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定设备的流分类的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,在IRF环境下显示所有成员设备上流分类的配置信息。
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
没有定义匹配数据包的规则。
类视图
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999,用户自定义ACL序号的取值范围是5000~5999
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
any
定义匹配所有数据包的规则
control-plane protocol protocol-name&<1-8>
定义匹配控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示。&<1-8>表示前面的参数最多可以输入8次。
control-plane protocol-group protocol-group-name
定义匹配控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect
customer-dot1p dot1p-value&<1-8>
定义匹配内层VLAN Tag的802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag的VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address
定义匹配目的MAC地址的规则
dscp dscp-value&<1-8>
定义匹配DSCP的规则,dscp-value&<1-8>为DSCP取值的列表,DSCP的取值范围为0~63,&<1-8>表示前面的参数最多可以输入8次;也可以输入关键字,具体如表1-5所示
ip-precedence ip-precedence-value&<1-8>
定义匹配IP优先级的规则,ip-precedence-value&<1-8>为IP优先级的列表,IP优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
定义匹配协议的规则,protocol-name取值为ip、ipv6
qos-local-id local-id-value
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095
在本系列交换机上,能够支持的QoS本地ID值为1~3999
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag的802.1p优先级的规则,dot1p-value&<1-8>为802.1p优先级值的列表,802.1p优先级的取值范围为0~7,&<1-8>表示前面的参数最多可以输入8次
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag的VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>,vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
source-mac mac-address
定义匹配源MAC地址的规则
·     如果流分类的匹配规则中包括customer-vlan-id,则使用该流分类的QoS策略只能应用在接口上。
·     一个流分类中匹配control-plane protocolcontrol-plane protocol-group的规则不能和其它匹配规则同时存在,否则使用该类的QoS策略将不能正常应用。
·     当流分类匹配control-plane protocolcontrol-plane protocol-group时,使用该流分类的QoS策略只能应用在控制平面上。
·     对于同一匹配条件,若需匹配多个值,请先将流分类中各规则之间的逻辑关系配置为or
·     service-vlan-idcustomer-vlan-id外,对于其他匹配条件,只有通过重复执行多次匹配单一取值的if-match命令才能对同一匹配条件的多个值进行匹配。
·     当流分类中各规则之间的逻辑关系为and时,若在一个流分类下,匹配的一条ACL中包含多条规则,则多条匹配规则之间的逻辑关系为or
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
arp
ARP协议
arp-snooping
ARP Snooping协议
bfd
BFD协议
bgp
BGP协议
bgp4+
IPv6 BGP
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcp6
IPv6 DHCP协议
dldp
DLDP协议
dot1x
802.1X协议
mvrp
MVPR协议(包含GVRP协议)
hop limit expires
ICMPv6超时报文
http
HTTP协议
https
HTTPS协议
icmp
ICMP协议
icmp6
IPv6 ICMP协议
igmp
IGMP协议
ip-option
带选项字段的IPv4报文
ipv6-option
带选项字段的IPv6报文
isis
IS-IS协议
lacp
LACP协议
lldp
LLDP协议
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
radius
RADIUS协议
snmp
SNMP协议
ssh
SSH协议
stp
STP协议
tacacs
TACACS协议
telnet
TELNET协议
ttl expires
ICMP超时报文
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则使用该类的QoS策略将不能正常应用。
·     当一个类下配置多条这样的命令时,各个配置之间互相不覆盖。
·     对同一个类,允许通过ACL名称和序号的方式分别引用一次同一个ACL。
(2)     定义匹配目的MAC地址规则
(3)     定义匹配源MAC地址规则
(4)     定义匹配DSCP的规则
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配内层VLAN Tag和外层VLAN Tag的802.1p优先级的规则
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(6)     定义匹配IP优先级的规则
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配内层VLAN Tag和外层VLAN Tag的VLAN ID的规则
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID来匹配。
(8)     定义匹配预定义的上送控制平面报文类型的规则
·     一条命令可以配置多个protocol,如果指定了多个相同的protocol,系统默认为一个;多个不同的protocol是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配protocol的规则时,指定的所有protocol必须与该规则中定义的完全相同才会删除,顺序可不一样。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1
[Sysname-classifier-class1] if-match dscp 6
[Sysname-classifier-class1] if-match dscp 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1
[Sysname-classifier-class1] if-match ip-precedence 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配qos-local-id 3。
[Sysname-classifier-class1] if-match qos-local-id 3
# 在流分类class1中配置匹配上送控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
traffic classifier命令用来定义一个类,并进入类视图。
undo traffic classifier命令用来删除一个类。
没有定义类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来取消流量统计动作配置。
accounting [ byte | packet ] *
undo accounting
没有配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来取消流量监管动作配置。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
没有配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,缺省值为512,单位为byte。取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。peak-information-rate取值范围为8~160000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
·     接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
·     如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定设备的流行为的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,在IRF环境下显示所有成员设备上流行为的配置信息。
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 128 (kbps), CBS 8192 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 4
      Redirecting:
        Redirect to the CPU
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,即允许的流的平均速度,单位为kbps
CBS
承诺突发尺寸,即每次允许的最大突发流量,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超过承诺突发流量的部分,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
Accounting enable
流量统计动作
Filter enable
流量过滤动作
none
表示没有配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来取消流量过滤动作配置。
filter { deny | permit }
undo filter
没有配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来配置添加VLAN Tag的动作。
undo nest top-most命令用来取消添加VLAN Tag的动作。
nest top-most vlan vlan-id
undo nest top-most
没有配置添加VLAN Tag的动作。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
·     引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
·     在同一个流行为上多次配置本命令,新配置将覆盖旧配置。
# 在流行为b1上配置如下动作:添加VLAN ID为123的VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来取消流量重定向动作配置。
redirect { cpu | interface interface-type interface-number }
undo redirect { cpu | interface interface-type interface-number }
没有配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
在配置重定向动作时,同一个流行为中重定向类型只能为重定向到CPU、重定向到接口中的一种,以最后一次配置为准。
# 为流行为配置流量重定向动作,重定向到接口FortyGigE1/1/1。
[Sysname-behavior-database] redirect interface FortyGigE1/1/1
·     classifier behavior
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重标记报文的CVLAN。
undo remark customer-vlan-id命令用来取消重标记报文的CVLAN。
没有配置重新标记报文的动作。
流行为视图
vlan-id:表示重标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.8  remark dot1p
remark dot1p命令用来重新标记报文的802.1p优先级或配置内外层标签优先级复制功能。
undo remark dot1p命令用来取消标记报文的802.1p优先级或内外层标签优先级复制功能。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
没有配置重新标记报文的动作或没有配置内外层标签优先级复制功能。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dot1p-value:802.1p优先级,取值范围为0~7。
customer-dot1p-trust:QoS策略应用到端口后,将内层VLAN tag的802.1p优先级复制为外层VLAN tag的802.1p优先级。
命令remark dot1p dot1p-valueremark dot1p customer-dot1p-trust是覆盖关系。
如果报文只携带一层VLAN tag,则配置remark dot1p customer-dot1p-trust不会生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
没有配置重新标记报文的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
本命令仅应用在入方向。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.10  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来取消标记报文的DSCP值。
undo remark [ green | red | yellow ] dscp
没有配置重新标记报文的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来取消标记报文的IP优先级。
remark ip-precedence ip-precedence-value
没有配置重新标记报文的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来取消标记报文的本地优先级。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
没有配置重新标记报文的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
local-precedence-value:本地优先级,取值范围为0~7。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id local-id-value
没有配置重新标记报文的动作。
流行为视图
local-id-value:QoS本地ID值,取值范围为1~4095。在本系列交换机上,能够支持QoS本地ID值为1~3999。
·     重标记QoS本地ID功能可以将匹配不同分类条件的多种报文划分到一个新的类(使用QoS本地ID进行标识),用户在对各类报文配置了原有分类对应的流行为之后,还可以针对这个新的分类实施另外的流行为,该流行为将对所有新类中的报文生效,从而实现对某一类报文的两层控制动作。
·     重标记QoS本地ID的动作仅能应用在入方向。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重标记报文的SVLAN。
undo remark service-vlan-id命令用来取消重标记报文的SVLAN。
没有配置重新标记报文的动作。
流行为视图
vlan-id:表示重标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior命令用来定义一个流行为,并进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
没有定义流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
·     display traffic behavior
1.3  定义策略和应用策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [ mode dcbx | insert-before before-classifier-name ] *
没有为类指定流行为。
策略视图
mode dcbx:表示该策略为DCBX(Data Center Bridging Exchange Protocol,数据中心桥能力交换协议)模式。有关DCBX的介绍,请参见“二层技术-以太网交换配置指导”中的“LLDP”。
insert-before before-classifier-name:表示将配置的类插入到策略中已存在的指定类之前。before-classifier-name表示策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到策略最后。
·     策略下每个类只能与一个流行为关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
·     不能对策略中已配置的类指定插入位置。
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
slot slot-number:指定设备。slot-number表示设备在IRF中的成员编号。
# 在IRF环境下,进入1号成员设备控制平面视图。
[Sysname] control-plane slot 1
[Sysname-cp-slot1]
display qos policy命令用来显示QoS策略的配置信息。
user-defined:用户定义策略。
policy-name:策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定设备的策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,在IRF环境下显示所有成员设备上QoS策略的配置信息。
# 显示用户定义策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
表1-6 display qos policy命令显示信息描述表
用户自定义策略的信息
Policy
策略名
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
slot slot-number:显示指定设备的控制平面应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。
# 显示应用到控制平面的QoS策略信息。
<Sysname> display qos policy control-plane slot 1
Control plane
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
表1-7 display qos policy control-plane命令显示信息描述表
Direction
对进入控制平面(Inbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-6
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
slot slot-number:显示指定设备的系统预定义的控制平面策略信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,在IRF环境下显示所有成员设备上系统预定义的控制平面应用QoS策略的信息。
# 在IRF环境中,显示1号成员设备系统预定义的控制平面应用QoS策略的信息。
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth (kbps)   Group
  IS-IS             37         512                critical
  VRRP              40         768                important
  OSPF Multicast    35         256                critical
  OSPF Unicast      35         256                critical
  IGMP              19         512                important
  OSPFv3 Unicast    34         256                critical
  OSPFv3 Multicast  34         256                critical
  VRRPv6            40         768                important
  ARP               8          256                normal
  DHCP Snooping     17         256                redirect
  DHCP              15         256                normal
  802.1x            9          128                important
  STP               44         256                critical
  LACP              38         64                 critical
  MVRP              11         256                critical
  BGP               27         256                critical
  ICMP              9          640                monitor
  TTL Expires       20         64                 normal
  IPOPTION          20         64                 normal
  BGPv6             26         256                critical
  Hop Limit Expires 13         64                 normal
  IPOPTIONv6        13         64                 normal
  LLDP              25         128                important
  DLDP              24         64                 critical
  TELNET            10         512                management
  SSH               10         512                management
  HTTP              10         64                 management
  HTTPS             10         64                 management
  TACACS            10         64                 management
  RADIUS            10         64                 management
  ARP Snooping      10         256                redirect
  ICMPv6            1          512                monitor
  DHCPv6            12         256                normal
  BFD               10         512                critical
表1-8 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined control plane policy
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
Priority
优先级
Bandwidth
带宽
Group
协议所属的协议组
display qos policy global命令用来显示基于全局应用QoS策略的信息。
inbound:显示对全局接收到的报文应用QoS策略的信息。
outbound:显示对全局发送的报文应用QoS策略的信息。
slot slot-number:显示指定设备的基于全局应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上基于全局应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dot1p 4
表1-9 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
inbound:显示对接口接收到的报文应用QoS策略的信息。
outbound:显示对接口发送的报文应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向接口上应用QoS策略的配置信息和运行情况。
# 显示对接口FortyGigE1/1/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface FortyGigE 1/1/1 inbound
Interface: FortyGigE1/1/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action: pass
        Yellow action: pass
        Red action: discard
        Green packets: 0 (Packets)
        Red packets: 0 (Packets)
   Classifier: 2
     Operator: AND
     Rule(s) : If-match protocol ipv6
     Behavior: 2
      Accounting Enable:
        0 (Packets)
      Filter Enable: Permit
      Marking:
        Remark dot1p 1
表1-10 display qos policy interface命令显示信息描述表
Direction
Policy应用在接口的方向
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的信息。
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:显示对VLAN接收到的报文应用的QoS策略信息。
outbound:显示对VLAN发送的报文应用的QoS策略信息。
slot slot-number:显示指定设备上基于VLAN应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备上的所有基于VLAN应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向基于VLAN应用QoS策略的信息。
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action: pass
        Yellow action: pass
        Red action: discard
        Green packets: 0(Packets)
        Red packets: 0(Packets)
   Classifier: 2
     Operator: AND
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dot1p 1
   Classifier: 3
     Operator: AND
     Rule(s) : -none-
     Behavior: 3
      -none-
表1-11 display qos vlan-policy命令显示信息描述表
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
qos apply policy命令用来在接口或控制平面上应用QoS策略。
undo qos apply policy命令用来取消接口或控制平面上应用的QoS策略。
undo qos apply policy policy-name { inbound | outbound }
没有在接口或控制平面上应用QoS策略。
二层以太网接口视图/三层以太网接口视图/控制平面视图/S通道接口视图/S通道聚合接口视图/VSI接口视图/VSI聚合接口视图
inbound:对接口或控制平面接收到的报文应用QoS策略。
outbound:对接口发送的报文应用QoS策略。
有关S通道接口、S通道聚合接口、VSI接口以及VSI聚合接口的详细介绍,请参见“EVB配置指导”。
# 将策略USER1应用到接口FortyGigE1/1/1的出方向上。
[Sysname] interface FortyGigE 1/1/1
[Sysname-FortyGigE1/1/1] qos apply policy USER1 outbound
# 对进入3号成员设备控制平面的报文应用策略aaa。
[Sysname] control-plane slot 3
[Sysname-cp-slot3] qos apply policy aaa inbound
# 将策略USER1应用到S通道接口S-Channel1/1/1:1的出方向上。
[Sysname] interface S-Channel 1/1/1:1
[Sysname-S-Channel1/1/1:1] qos apply policy USER1 outbound
# 将策略USER1应用到S通道聚合接口Schannel-Aggregation1:1的入方向上。
[Sysname] interface Schannel-Aggregation 1:1
[Sysname-Schannel-Aggregation1:1] qos apply policy USER1 inbound
qos apply policy命令用来在User Profile下应用策略。
undo qos apply policy命令用来取消User Profile下应用的策略。
没有在User Profile下应用QoS策略。
user-profile视图
inbound:入方向,对设备接收的上线用户流量(即上线用户发送的流量)应用策略。
outbound:出方向,对设备发送的上线用户流量(即上线用户接收的流量)应用策略。
policy-name:策略名,为1~31个字符的字符串。
·     User Profile被删除将导致其下的QoS策略被删除。
·     关联的策略只有在下发驱动成功后才能生效。
# 对设备发送的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test outbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
没有在全局应用QoS策略。
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
全局应用的QoS策略对全部流量生效。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.12  qos policy
qos policy命令用来定义一个策略,并进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
没有定义策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
# 定义一个名为user1的策略。
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy命令用来在指定VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
没有在指定VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
slot slot-number:清除指定设备的基于控制平面应用QoS策略的统计信息,slot-number表示设备在IRF中的成员编号。
# 清除应用到3号成员设备控制平面的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 3
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除全局接收到的报文应用QoS策略的统计信息。
outbound:清除全局发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向全局应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示指定优先级映射表配置情况。
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | exp-dot1p | exp-dp ]
表2-1 优先级映射表
优先级映射
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-exp
802.1p优先级到EXP优先级映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dot1p
DSCP到802.1p优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
exp-dot1p
EXP优先级到802.1p优先级映射表
exp-dp
EXP优先级到丢弃优先级映射表
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.2  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 A
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
2.1.3  qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p | exp-dp }
相关参数请参见表2-1
# 进入802.1p优先级到本地优先级映射表视图。
·     import
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority命令用来配置当前端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority priority-value
undo qos priority
端口优先级为0
二层以太网接口视图/三层以太网接口视图
priority-value:端口优先级值,取值范围为0~7。
# 配置接口FortyGigE1/1/1的端口优先级为2。
[Sysname-FortyGigE1/1/1] qos priority 2
·     display qos trust interface
2.3  端口优先级信任模式配置命令
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口FortyGigE1/1/1的优先级信任模式信息。
<Sysname> display qos trust interface FortyGigE 1/1/1
 Port priority information
  Port priority: 0
  Port priority trust type: none
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority trust information
端口优先级信任信息
Port priority
端口优先级
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
·     none:不信任任何优先级
2.3.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备不信任报文携带的优先级。
二层以太网接口视图/三层以太网接口视图
# 在接口FortyGigE1/1/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-FortyGigE1/1/1] qos trust dot1p
3 流量整形和接口限速
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况。
# 显示所有接口的流量整形配置情况。
 Rule: If-match queue 1
 Rule: If-match queue 2
  CIR 256 (kbps), CBS 16384 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
CBS
承诺突发尺寸,即每次允许的最大突发流量,单位为Byte
3.1.2  qos gts
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
接口上没有配置流量整形。
二层以太网接口视图/三层以太网接口视图
queue queue-id对队列queue上的数据包进行流量整形,queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。万兆端口的取值范围为8~10485760,40GE端口的取值范围为8~41943040,用户配置的数值必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍。
·     如果指定cbs参数,取值范围为512~16777216,committed-burst-size必须为512的整数倍。
# 在接口FortyGigE1/1/1上对队列1中的报文进行流量整形。正常流速为6400kbps,突发流量为51200bytes。
[Sysname-FortyGigE1/1/1] qos gts queue 1 cir 6400 cbs 51200
3.2  接口限速配置命令
display qos lr interface命令用来显示接口的接口限速配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口限速配置情况。
# 显示所有接口的接口限速配置情况。
 Direction: Outbound
  CIR 12800 (kbps), CBS 800256 (Bytes)
Interface: FortyGigE1/1/2
 Direction: Outbound
  CIR 25600 (kbps), CBS 1600000 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction
方向,可以是Inbound、Outbound
CIR
CBS
3.2.2  qos lr
qos lr命令用来在接口上配置接口限速。
undo qos lr命令用来取消接口上配置接口限速的配置。
undo qos lr { inbound | outbound }
接口上没有配置接口限速。
二层以太网接口视图/三层以太网接口视图
inbound:对接口接收的数据流进行限速。
outbound:对接口发送的数据流进行限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
·     如果指定cbs参数,取值范围为512~134217728,committed-burst-size必须为512的整数倍。
# 在接口FortyGigE1/1/1上出方向的报文进行接口限速。正常流速为25600kbps,突发流量为512000bytes。
[Sysname-FortyGigE1/1/1] qos lr outbound cir 25600 cbs 512000
4 拥塞管理
4.1  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示FortyGigE1/1/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface FortyGigE 1/1/1
 Output queue: Strict Priority queuing
表4-1 display qos queue sp interface命令显示信息描述表
Output queue
当前出队列类型
4.1.2  qos sp
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复接口上缺省的队列算法。
qos sp
undo qos sp
端口采用WRR调度算法。
二层以太网接口视图/三层以太网接口视图
# 在接口FortyGigE1/1/1上应用SP模式的队列调度。
[Sysname-FortyGigE1/1/1] qos sp
·     display qos queue sp interface
4.2  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口FortyGigE1/1/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface FortyGigE 1/1/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Group           Byte-count
 be              1               1
 af1             1               2
 af2             1               3
 af3             1               4
 af4             1               5
 ef              1               9
 cs6             1               13
 cs7             1               15
表4-2 display qos queue wrr interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Group
分组号,说明队列属于哪一个分组,缺省情况下,队列所属的分组号为1
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为Weight, N/A表示该队列采用SP调度算法
4.2.2  qos wrr
qos wrr命令用于在接口上使能WRR队列,并指明当前WRR队列调度权重的计算方式。
undo qos wrr命令用于在接口上取消WRR队列,恢复缺省的队列算法。
undo qos wrr { byte-count | weight }
接口上的队列算法为WRR,队列0~7的调度权重分别为1、2、3、4、5、9、13、15。
二层以太网接口视图/三层以太网接口视图
byte-count:表示以字节数为调度单位,即按照每次轮询发送的字节数来体现调度权重。
weight:表示以报文个数为调度单位,即按照每次轮询发送的报文个数来体现调度权重。
必须先使用qos wrr命令在接口上使能WRR队列,然后才能进行WRR配置。
# 在接口FortyGigE1/1/1上使能WRR队列,并将报文个数作为调度单位。
[Sysname-FortyGigE1/1/1] qos wrr weight
# 在接口FortyGigE1/1/1上使能WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-FortyGigE1/1/1] qos wrr byte-count
·     display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来恢复缺省情况。
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
接口使用Byte-count方式的WRR队列调度算法,所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、9、13、15。
二层以太网接口视图/三层以太网接口视图
queue-id:队列序号,取值范围为0~7或表4-3中的关键字。
group { 1 | 2 }:表示该队列属于哪个WRR优先组,缺省为group 1。其中group 1表示该队列属于WRR优先组1,group 2表示该队列属于WRR优先组2。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
schedule-value:配置队列的调度权重,取值范围为1~15。
必须先使用qos wrr命令在接口上使能WRR队列,然后才能进行本配置。
queue-id除了支持数字外,还支持直接输入关键字,具体情况请参见表4-3
表4-3 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
# 在接口FortyGigE1/1/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0加入WRR调度组1,调度权重为10;配置队列1加入WRR调度组2,调度权重为5。
[Sysname-FortyGigE1/1/1] qos wrr 0 group 1 byte-count 10
[Sysname-FortyGigE1/1/1] qos wrr 1 group 2 byte-count 5
·     qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来恢复缺省情况。
qos wrr queue-id group sp
接口使用Byte-count方式的WRR队列调度算法,所有队列都处于WRR调度组1中。
二层以太网接口视图/三层以太网接口视图
sp:队列加入SP组,采用严格优先级调度算法。
此命令需要在端口队列为WRR调度模式下使用。
SP组与WRR组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后按用户配置的调度权重对每个WRR调度组中的队列进行调度,两个WRR调度组输出的流量之间按1:1的权重进行轮询调度。
# 在接口FortyGigE1/1/1上应用WRR队列,并按照每次轮询可发送的报文个数进行计算,配置队列0加入SP组进行严格优先级调度。
[Sysname-FortyGigE1/1/1] qos wrr 0 group sp
·     qos wrr
4.3  加权公平队列配置命令
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口FortyGigE1/1/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface FortyGigE 1/1/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Group           Byte-count      Min-Bandwidth
 be              1               1               64
 af1             1               1               64
 af2             1               1               64
 af3             1               1               64
 af4             1               1               64
 ef              1               1               64
 cs6             1               1               64
 cs7             1               1               64
表4-4 display qos queue wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Group
Byte-count
队列调度权重值
当前WFQ队列调度权重的计算方式为Byte-count
Min-Bandwidth
队列的最小保证带宽值
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,每个队列的最小带宽保证为64kbps。
二层以太网接口视图/三层以太网接口视图
min bandwidth-value:最小保证带宽值,万兆端口取值范围为8~10000000,40GE端口取值范围为8~40000000,单位为kbps,表示端口流量拥塞时能够保证的最小队列带宽。
必须先使用qos wfq命令在接口上使能WFQ队列,然后才能进行本配置。
# 在接口FortyGigE1/1/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-FortyGigE1/1/1] qos wfq weight
[Sysname-FortyGigE1/1/1] qos bandwidth queue 0 min 100
·     qos wfq
4.3.3  qos wfq
qos wfq命令用来在接口上使能WFQ队列,并指明当前WFQ队列调度权重的计算方式。
undo qos wfq命令用来在接口上取消WFQ队列,恢复缺省的队列算法。
undo qos wfq { byte-count | weight }
接口使用Byte-count方式的WRR队列调度算法,所有队列都处于WRR调度组中。
二层以太网接口视图/三层以太网接口视图
必须先使用qos wfq命令在接口上使能WFQ队列,然后才能进行WFQ配置。
# 在接口FortyGigE1/1/1上使能WFQ队列,并按照权重进行计算。
# 在接口FortyGigE1/1/1上使能WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-FortyGigE1/1/1] qos wfq byte-count
·     display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来恢复缺省情况。
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
二层以太网接口视图/三层以太网接口视图
group { 1 | 2 }:表示该队列属于哪个WFQ优先组,缺省为group 1。其中group 1表示该队列属于WFQ优先组1,group 2表示该队列属于WFQ优先组2。
# 在接口FortyGigE1/1/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0加入WFQ调度组1,调度权重为10;配置队列1加入WFQ调度组2,调度权重为5。
[Sysname-FortyGigE1/1/1] qos wfq 0 group 1 byte-count 10
[Sysname-FortyGigE1/1/1] qos wfq 1 group 2 byte-count 5
·     qos bandwidth queue
·     qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来恢复缺省情况。
qos wfq queue-id group sp
当使用WFQ队列时,所有队列都处于WFQ调度组中。
二层以太网接口视图/三层以太网接口视图
在使用SP+WFQ队列时,首先调度每个WFQ组的队列中满足最小保证带宽的流量,两个组的输出数据按1:1的权重进行轮询调度;然后按SP方式对SP组中的队列进行调度;最后再对两个WFQ组中各队列的数据按权重进行调度,两个组的输出数据按1:1的权重进行轮询调度。
# 在接口FortyGigE1/1/1上应用WFQ队列,并按照每次轮询可发送的报文个数进行计算,配置队列0加入SP组进行严格优先级调度。
[Sysname-FortyGigE1/1/1] qos wfq 0 group sp
·     qos wfq
4.4  队列调度策略配置命令
4.4.1  bandwidth
bandwidth命令用来配置队列调度策略中WFQ队列的最小带宽保证。
undo bandwidth命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,该队列的最小带宽保证为64kbps。
队列调度策略视图
min bandwidth-value:最小保证带宽值,取值范围为8~100000000,单位为kbps,表示端口流量拥塞时能够为该队列保证的最小带宽。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列0使用WFQ队列算法,使用报文个数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
·     display qos qmprofile interface
·     qos qmprofile
·     queue
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。若未指定本参数,将显示所有队列调度策略的配置情况。
slot slot-number:显示指定设备上队列调度策略的配置情况。slot-number表示设备在IRF中的成员编号。若未指定本参数,显示主设备上队列调度策略的配置信息。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID    Type    Group    Schedule-unit    Schedule-value    Bandwidth
 be          WFQ     1        weight           1                  64
 af1         WFQ     1        weight           1                  64
 af2         WFQ     1        weight           1                  1000
 af3         SP      N/A      N/A              N/A                N/A
 af4         SP      N/A      N/A              N/A                N/A
 ef          SP      N/A      N/A              N/A                N/A
 cs6         SP      N/A      N/A              N/A                N/A
 cs7         SP      N/A      N/A              N/A                N/A
表4-5 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列)
Group
队列分组,N/A表示无效
Schedule-unit
队列调度权重类型,对于SP队列始终显示为N/A,对于WRR和WFQ队列可以根据配置显示为weight或byte-count
Schedule-vlaue
队列调度权重值, N/A表示无效
Bnadwidth
队列最小带宽保证,仅当队列为WFQ队列时才能够配置
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface FortyGigE 1/1/1
表4-6 display qos qmprofile interface命令显示信息描述表
接口名称
队列调度策略名称
qos apply qmprofile命令用来在接口上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
二层以太网接口视图/三层以太网接口视图
每个接口只能应用一个队列调度策略。
# 在接口FortyGigE1/1/1上应用队列调度策略myprofile。
[Sysname-FortyGigE1/1/1] qos apply qmprofile myprofile
4.4.5  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
不能删除已经应用到接口的队列调度策略,必须先在应用的接口上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建自定义的队列调度策略myprofile,并进入队列调度策略视图。
·     queue
4.4.6  queue
queue命令用来配置队列调度参数。
undo queue命令用来恢复缺省情况。
queue queue-id { sp | wfq group group-id { byte-count | weight } schedule-value | wrr group group-id { byte-count | weight } schedule-value }
undo queue queue-id
队列调度策略的内容是所有队列均采用WRR方式调度。
队列调度策略视图
queue-id:队列序号,取值范围为0~7。
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
group group-id:队列所在组号,group-id取值范围为1~2。
byte-count:表示按照每次轮询发送的字节数作为调度权重进行计算。
weight:表示按照每次轮询可发送的报文个数作为调度权重进行计算。
schedule-value:调度权重,取值范围为1~15。
wrr:配置队列为加权轮询调度。
# 创建自定义的队列调度策略myprofile,并配置队列0为SP队列。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为WRR队列,权重为10,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
4.5  队列老化时间配置命令
qos queue aging-time命令用来配置队列老化时间。
undo qos queue aging-time命令用来恢复缺省值。
qos queue aging-time time-value
队列老化时间为0,即未开启队列老化功能。
time-value:表示队列的老化时间,取值范围为100~500,且取值必须是100的整数倍,单位为毫秒。
# 配置队列的老化时间为200毫秒。
[Sysname] qos queue aging-time 200
4.6  端口队列统计配置命令
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有端口的队列出方向统计信息。
outbound:显示端口队列出方向的统计信息。
# 显示接口FortyGigE1/1/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface FortyGigE 1/1/1 outbound
Interface: FortyGigE 1/1/1
 Direction: outbound
 Forwarded: 1087 packets, 98466 bytes
 Dropped: 0 packets, 0 bytes
 Aged: 0 packets
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
  Forwarded: 1087 packets, 98466 bytes, 0 pps, 0 bps
表4-7 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目和字节数
Dropped
丢弃的数据包数目和字节数
Aged
因队列老化时间到达而丢弃的数据包数目
需要注意的是:只有配置了队列老化时间才会显示此项
Queue 7
各个队列的统计信息,包括:
·     该队列转发的数据包数目、字节数、每秒转发包数目和每秒转发bit
·     该队列丢弃的数据包数目和字节数
·     该队列当前的长度
5 拥塞避免
5.1  WRED配置命令
display qos wred interface命令用来显示接口的WRED配置情况。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况。
# 显示所有接口的WRED配置情况。
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: 1
表5-1 display qos wred interface命令显示信息描述表
当前WRED的配置情况
当前应用的WRED表的名称
display qos wred table命令用来显示WRED表的配置情况。
name table-name:要显示的WRED表的名字。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:指定设备。slot-number表示设备在IRF中的成员编号。如果未指定本参数,则显示主设备的WRED表配置情况。
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     100   1000  10     100   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gprob
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
yprob
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rprob
红色报文的丢弃概率
exponent
计算平均队列长度指数
ECN
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启
qos wred apply命令用来在接口上应用WRED全局表。
undo qos wred apply命令用来恢复接口缺省的尾丢弃模式,它同时取消WRED表的应用。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED全局表,即接口采用尾丢弃。
二层以太网接口视图/三层以太网接口视图
table-name:WRED表的名称。
如果不指定WRED表的名称,则在接口上应用缺省WRED表。
# 在接口FortyGigE1/1/1上应用WRED表。
[Sysname-FortyGigE1/1/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred table
qos wred table命令用来创建全局WRED表,同时进入该WRED表视图。
undo qos wred table命令用来删除全局WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
queue:基于队列的表,拥塞时根据报文所在队列进行随机丢弃。
table table-name:指定表的名称。
设备不允许删除正在使用的表。如果想删除正在使用的表,请先在接口上取消应用的WRED表。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue
queue命令用来配置基于队列的WRED表的内容。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
WRED表在创建之后,有缺省的一套参数,low-limit的取值为100,high-limit的取值为1000,discard-prob的取值为10。
WRED表视图
queue-id:队列编号,取值范围为0~7。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限,取值范围为0~38000。
high-limit high-limit:队列平均长度的上限,取值范围为0~38000且必须大于丢弃下限。
discard-probability discard-prob:以百分数形式表示的丢弃概率,取值范围为0~100。当报文队列平均长度在上限和下限之间时,设备采用这个概率来丢弃报文。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备按用户配置的丢弃概率随机丢弃报文。当队列平均长度超过上限时,丢弃所有到来的报文。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
·     qos wred table
5.1.6  queue ecn
queue ecn命令用来对指定队列开启拥塞通知功能。
undo queue ecn命令用来恢复缺省情况。
queue queue-id ecn
undo queue queue-id ecn
对任何队列都未开启拥塞通知功能。
WRED表视图
在报文的发送端和接收端都支持ECN功能时,设备可以通过对ECN域的识别和标记将拥塞状况告知终端,避免拥塞加剧。
# 在WRED表queue-table1中,对队列1开启拥塞通知功能。
[Sysname-wred-table-queue-table1] queue 1 ecn
·     qos wred table
queue weighting-constant命令用来配置计算平均队列长度的指数。
undo queue weighting-constant命令用来恢复缺省情况。
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
计算平均队列长度的指数为9
WRED表视图
queue-id:队列编号。
weighting-constant exponent:计算平均队列长度的指数,exponent的取值范围为0~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
·     qos wred table
6 聚合CAR
6.1  聚合CAR配置命令
6.1.1  car name
car name命令用来配置聚合CAR动作。
undo car用来删除聚合CAR动作。
car name car-name
undo car
没有配置聚合CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
# 配置流行为be1的聚合CAR动作为aggcar-1。
·     display qos car name
·     display traffic behavior user-defined
display qos car name命令用来显示聚合CAR的配置和统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定聚合CAR的配置和统计信息。如果未指定本参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR的配置和统计信息。
<Sysname> display qos car name
  Mode: aggregative
  CIR 12800 (kbps), CBS 800256 (Bytes), EBS 512 (Bytes)
  Green action: pass
  Yellow action: pass
  Red action: discard
   Slot 1:
    Green packets: 54641 (Packets)
    Red packets: 856 (Packets)
   Slot 2:
    Green packets: 12541 (Packets)
    Red packets: 1235 (Packets)
表6-1 display qos car name命令显示信息描述表
Name
聚合CAR的名称
Mode
聚合CAR的类型,即aggregative
CIR  CBS  EBS  PIR
流量监管流量的参数配置
Green action
对绿色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Yellow action
对黄色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Green packets
绿色报文的流量统计
Red packets
红色报文的流量统计
6.1.3  qos car
qos car命令用来配置聚合CAR。
undo qos car命令用来取消聚合CAR的配置。
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peek-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
没有配置聚合CAR
aggregative:表示创建聚合CAR。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
ebs excess-burst-size:过度突发尺寸,单位为byte,缺省值为512,取值范围为0~256000000且必须为512的整数倍。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
聚合CAR配置需要在接口上应用或在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
reset qos car name命令用来清除聚合CAR的统计信息。
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定聚合CAR的统计信息。如果未指定本参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的配置信息。
<Sysname> reset qos car name aggcar-1
