- 06 IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
| 13-MLD commands | 175.87 KB |
last-listener-query-count (MLD view)
last-listener-query-interval (MLD view)
mld last-listener-query-interval
mld other-querier-present-timeout
other-querier-present-timeout (MLD view)
startup-query-count (MLD view)
startup-query-interval (MLD view)
The term "interface" in this chapter collectively refers to VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
display mld group
Use display mld group to display information about MLD groups (IPv6 multicast groups that hosts have joined through MLD).
display mld [ vpn-instance vpn-instance-name ] group [ ipv6-group-address | interface interface-type interface-number ] [ static | verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about MLD groups on the public network.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast source, the command displays information about all MLD groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about MLD group for all interfaces.
static: Specifies MLD groups that hosts have joined statically. If you do not specify this keyword, the command displays information about MLD groups that hosts have joined dynamically.
verbose: Displays detailed MLD information.
# Display information about MLD groups that hosts have dynamically joined on the public network.
MLD groups in total: 1
Vlan-interface1(FE80::101):
MLD groups reported in total: 1
Group address: FF03::101
Last reporter: FE80::10
Uptime: 00:02:04
Expires: 00:01:15
Figure 1 Command output
Total number of MLD groups. |
Total number of MLD that hosts attached to the interface have joined dynamically. |
IPv6 multicast group address. |
IPv6 address of the receiver host that last reported membership for the group. |
Length of time since the IPv6 multicast group was joined. |
Remaining lifetime for the IPv6 multicast group. If the timer is disabled, this field displays Off. |
# Display detailed information about the MLD group FF03::101 that host have dynamically joined on the public network. In this example, MLDv2 is running.
<Sysname> display mld group ff03::101 verbose
Group: FF03::101
Uptime: 00:01:46
Expires: Off
Last-listener-query-counter: 0
Last-listener-query-timer-expiry: Off
Group mode: Exclude
Version1-host-present-timer-expiry: Off
Source list (sources in total: 1):
Source: 10::10
Uptime: 00:00:09
Expires: 00:04:11
MLD groups reported in total |
Total number of MLD groups that hosts attached to the interface have joined dynamically. |
Group |
Uptime |
Expires |
Remaining time for the IPv6 multicast group. If the timer is disabled, this field displays Off. |
Last reporter |
IPv6 address of the host that last reported membership for this group. |
Last-listener-query-counter |
Number of multicast-address-specific queries or multicast-address-and-source-specific queries sent for this group. |
Last-listener-query-timer-expiry |
Remaining time for the MLD last listener of the multicast group. If the timer is disabled, this field displays Off. |
Group mode |
Multicast source filtering mode: · Include—Include mode. · Exclude—Exclude mode. This field is displayed only when the switch runs MLDv2. |
Version1-host-present-timer-expiry |
Remaining time for the MLDv1 host present timer. If the timer is disabled, this field displays Off. |
Source list (sources in total ) |
List of IPv6 multicast sources and total number of IPv6 multicast sources. This field is displayed only when the switch runs MLDv2. |
IPv6 multicast source address. This field is displayed only when the switch runs MLDv2. |
Length of time since the IPv6 multicast source was reported. This field is displayed only when the switch runs MLDv2. |
Remaining time for the IPv6 multicast source. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs MLDv2. |
Number of multicast-address-specific queries or multicast-address-and-source-specific queries sent for this IPv6 multicast source and group. This field is displayed only when the switch runs MLDv2. |
Remaining time for the last listener query timer of the IPv6 multicast source and group. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs MLDv2. |
# Display detailed information about MLD group that hosts have statically joined on the public network.
<Sysname> display mld group static
Entries in total: 2
(*, FF03::101)
Interface: Vlan1
Expires: Never
(2001::101, FF3E::202)
Interface: Vlan1
Expires: Never
Figure 2 Command output
(*, G) entry. |
(S, G) entry. |
Interface name. |
Remaining time for the IPv6 multicast group. The timer is disabled, and this field displays Never. |
reset mld group
display mld interface
Use display mld interface to display MLD information for interfaces.
display mld [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays MLD information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays MLD information for all interfaces.
# Display detailed MLD information for VLAN-interface 1 on the public network.
<Sysname> display mld interface vlan-interface 1 verbose
Vlan-interface1(FE80::200:AFF:FE01:101):
MLD is enabled.
MLD version: 1
Query interval for MLD: 125s
Other querier present time for MLD: 255s
Maximum query response time for MLD: 10s
Last listener query interval: 1s
Last listener query count: 2
Startup query interval: 31s
Startup query count: 2
General query timer expiry (hh:mm:ss): 00:00:23
Querier for MLD: FE80::200:AFF:FE01:101 (This router)
MLD activity: 1 join(s), 0 done(s)
IPv6 multicast routing on this interface: Enabled
Robustness: 2
Require-router-alert: Disabled
Fast-leave: Disabled
SSM-mapping: Disabled
Startup-query: Off
Other-querier-present-timer-expiry (hh:mm:ss): --:--:--
Vlan-interface1(FE80::200:AFF:FE01:101) |
Interface and IPv6 link-local address. |
Query interval for MLD |
MLD query interval, in seconds. |
Other querier present time for MLD |
MLD other querier present interval, in seconds. |
Maximum query response time for MLD |
Maximum response time for general query messages, in seconds. |
Last listener query interval |
MLD last listener query interval, in seconds. |
Number of MLD multicast-address-specific queries or MLD multicast-address-and-source-specific queries sent for the group. |
Startup query interval |
MLD startup query interval, in seconds. |
Startup query count |
Number of MLD general queries sent on startup. |
General query timer expiry |
Remaining time for the MLD general query timer. If the timer is disabled, this field displays Off. |
Querier for MLD |
IPv6 link-local address of the MLD querier. |
MLD activity: 1 join(s), 0 done(s) |
MLD activity statistics: · join(s)—Total number of IPv6 multicast groups that the interface has joined. · done(s)—Total number of IPv6 multicast groups that the interface has left. |
IPv6 multicast routing on this interface |
Whether IPv6 multicast routing and forwarding is enabled. |
Robustness |
Robustness variable of the MLD querier. |
Require-router-alert |
Whether the function of dropping MLD messages without Router-Alert is enabled. |
Fast-leave |
Whether the MLD fast-leave processing feature is enabled. |
SSM-mapping |
Whether the MLD SSM mapping feature is enabled. |
Startup-query |
Whether the MLD querier sends MLD general queries at the startup query interval on startup: · On—The MLD querier performs the above action. · Off—The MLD querier does not perform the above action. |
Other-querier-present-timer-expiry |
Remaining time for MLD other querier present timer. If the timer is disabled, this field displays Off. |
Total number of IPv6 multicast groups the interface joined dynamically. This field is not displayed if the interface does not join IPv6 multicast groups. |
display mld ssm-mapping
Use display mld ssm-mapping to display MLD SSM mappings.
display mld [ vpn-instance vpn-instance-name ] ssm-mapping ipv6-group-address
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays MLD SSM mappings on the public network.
# Display MLD SSM mappings for the IPv6 multicast group FF3E::101 on the public network.
<Sysname> display mld ssm-mapping ff3e::101
Group: FF3E::101
Source list:
1::1
1::2
10::1
100::10
Fields |
Group |
Source list |
List of IPv6 multicast source addresses. |
Use last-listener-query-count to set the MLD global last listener query count.
Use undo last-listener-query-count to restore the default.
mld last-member-query-count count
undo mld last-member-query-count
The MLD last listener query count equals the MLD querier's robustness variable.
MLD view
count: Sets an MLD last listener query count in the range of 1 to 255.
This command and the mld last-listener-query-count command have the same function but different effective ranges:
· The last-listener-query-count command in MLD view takes effect on all interfaces.
· The mld last-listener-query-count command takes effect on the current interface.
For an interface, the mld last-listener-query-count command takes priority over the last-listener-query-count command in MLD view.
# Set the global MLD last listener query count to 6 on the public network.
[Sysname] mld
[Sysname-mld] last-listener-query-count 6
Use last-listener-query-interval to set the MLD last listener query interval globally.
Use undo last-listener-query-interval to restore the default.
The MLD last listener query interval is 1 second.
MLD view
interval: Sets an MLD last listener query interval in the range of 1 to 25 seconds.
This command and the mld last-listener-query-interval command have the same function but different effective ranges:
# Set the global MLD last listener query interval to 6 seconds on the public network.
[Sysname] mld
[Sysname-mld] last-listener-query-interval 6
max-response-time (MLD view)
Use max-response-time to set the maximum response time for MLD general queries globally.
Use undo max-response-time to restore the default.
The global maximum response time for MLD general queries is 10 seconds.
MLD view
time: Sets the maximum response time for MLD general queries in the range of 1 to 3174 seconds.
This command and the mld max-response-time command have the same function but different effective ranges:
· The max-response-time command in MLD view takes effect on all interfaces.
· The mld max-response-time command takes effect on the current interface.
For an interface, the mld max-response-time command takes priority over the max-response-time command in MLD view.
# Set the global maximum response time for MLD general queries to 25 seconds on the public network.
[Sysname] mld
[Sysname-mld] max-response-time 25
mld
Use mld to enter MLD view.
Use undo mld to remove the configurations made in MLD view.
undo mld [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command takes effect on the public network.
# Enter MLD view of the public network.
[Sysname] mld
[Sysname-mld]
# Enter MLD view of the VPN instance mvpn.
[Sysname] mld vpn-instance mvpn
[Sysname-mld-mvpn]
mld enable
Use mld enable to enable MLD on an interface.
Use undo mld enable to disable MLD on an interface.
undo mld enable
MLD is disabled on all interfaces.
Interface view
This command takes effect only when IPv6 multicast routing is enabled. If the interface belongs to a VPN instance, make sure IPv6 multicast routing is enabled on the VPN instance.
MLD configurations on an interface take effect only when MLD is enabled on the interface.
# Enable IPv6 multicast routing, and enable MLD for VLAN-interface 100 on the public network.
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname-Vlan-interface100] mld enable
mld fast-leave
Use mld fast-leave to enable fast-leave processing on an interface.
Use undo mld fast-leave to disable fast-leave processing on an interface.
mld fast-leave [ group-policy acl6-number ]
undo mld fast-leave
Fast-leave processing is disabled. The MLD querier sends MLD multicast-address-specific or multicast-address-and-source-specific queries after receiving MLD done messages.
Interface view
acl6-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the command takes effect only on the IPv6 multicast groups that the ACL permits. The command takes effect on all IPv6 multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not contain valid rules.
This feature enables an MLD querier to send leave notifications to the upstream routers without sending multicast-address-specific or multicast-address-and-source-specific queries after receiving done messages.
In an IPv6 basic ACL, the source keyword matches the IPv6 multicast group address in MLD done messages.
If you specify the vpn-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
# Enable MLD fast-leave processing on VLAN-interface 100.
[Sysname-Vlan-interface100] mld fast-leave
mld group-policy
Use mld group-policy to configure an IPv6 multicast group policy on an interface to control IPv6 multicast groups that hosts attached to the interface can join.
Use undo mld group-policy to delete the configured IPv6 multicast group policy.
mld group-policy acl6-number [ version-number ]
IPv6 multicast group polices are not configured on an interface, and hosts attached to the interface can join IPv6 multicast groups.
Interface view
acl6-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts attached to the interface can join only the IPv6 multicast groups that the ACL permits. If the specified ACL does not exists or the specified ACL does not contain valid rules, receiver hosts cannot join IPv6 multicast groups.
version-number: Specifies an MLD version number, 1 or 2. By default, the configured group filter is effective on both MLDv1 reports and MLDv2 reports.
In an IPv6 basic ACL, the source keyword matches the IPv6 multicast group address in MLD reports. In an IPv6 advanced ACL, the source and destination keywords match the IPv6 multicast source address and IPv6 multicast group address in MLD report, respectively. The multicast source address is considered to be 0::0 for the following MLD reports:
· MLDv1 reports.
· MLDv2 IS_EX and MLDv2 TO-EX reports that do not carry IPv6 multicast source addresses.
This command controls the IPv6 multicast groups that the receiver hosts can join by filtering MLD messages. This command does not take effect on a static member interface, because the static member interface does not send MLD messages.
# Configure an IPv6 multicast group policy on VLAN-interface 100 so that hosts attached to the interface can join only the IPv6 multicast group FF03::101.
[Sysname] acl ipv6 number 2005
[Sysname-acl6-basic-2005] rule permit source ff03::101 128
[Sysname-acl6-basic-2005] quit
[Sysname-Vlan-interface100] mld group-policy 2005
Use mld last-listener-query-count to set the MLD last member query count on an interface.
Use undo mld last-listener-query-count to restore the default.
mld last-listener-query-count count
Interface view
This command and the last-listener-query-count command in MLD view have the same function but different effective ranges:
# Set the MLD last listener query count to 6 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld last-listener-query-count 6
Use mld last-listener-query-interval to set the MLD last listener query interval on an interface.
Use undo mld last-listener-query-interval to restore the default.
mld last-listener-query-interval interval
Interface view
This command and the last-listener-query-interval command in MLD view have the same function but different effective ranges:
· The last-listener-query-interval command in MLD view takes effect on all interfaces.
· The mld last-listener-query-interval command takes effect on the current interface.
For an interface, the mld last-listener-query-interval command takes priority over the last-listener-query-interval command in MLD view.
# Set the MLD last listener query interval to 6 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld last-listener-query-interval 6
Use mld max-response-time to set the maximum response time for MLD general queries on an interface.
Use undo mld max-response-time to restore the default.
The maximum response time for MLD general queries is 10 seconds.
Interface view
time: Sets the maximum response time for MLD general queries, in the range of 1 to 3174 seconds.
This command and the max-response-time command in MLD view have the same function but different effective ranges:
# Set the maximum response time for MLD general queries to 25 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld max-response-time 25
mld non-stop-routing
Use mld non-stop-routing to enable MLD NSR.
Use undo mld non-stop-routing to disable MLD NSR.
MLD NSR is disabled.
# Enable MLD NSR.
[Sysname] mld non-stop-routing
Use mld other-querier-present-timeout to set the MLD other querier present timer on an interface.
Use undo mld other-querier-present-timeout to restore the default.
mld other-querier-present-timeout time
The MLD other querier present timer is calculated by using the following formula:
[ MLD general query interval ] × [ MLD querier's robustness variable ] + [ maximum response time for MLD general queries ] / 2.
Interface view
time: Sets an MLD other querier present timer in the range of 1 to 31744 seconds.
This command and the other-querier-present-timer command have the same function but different effective ranges:
· The other-querier-present-timer command takes effect on all interfaces.
· The mld other-querier-present-timeout command takes effect on the current interface.
For an interface, the mld other-querier-present-timeout command takes priority over the other-querier-present-timer command.
# Set the MLD other querier present timer to 125 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld other-querier-present-timeout 125
mld query-interval
Use mld query-interval to set the MLD general query interval on an interface.
Use undo mld query-interval to restore the default.
mld query-interval interval
The MLD general query interval is 125 seconds.
Interface view
interval: Sets an MLD general interval in the range of 1 to 31744 seconds.
This command and the query-interval command in MLD view have the same function but different effective ranges:
· The query-interval command in MLD view takes effect on all interfaces.
· The mld query-interval command takes effect on the current interface.
For an interface, the mld query-interval command takes priority over the query-interval command in MLD view.
# Set the MLD general query interval to 60 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld query-interval 60
mld robust-count
Use mld robust-count to set the MLD querier's robustness variable on an interface.
Use undo mld robust-count to restore the default.
The MLD querier's robustness variable is 2.
Interface view
count: Sets an MLD querier's robustness variable in the range of 1 to 255.
The MLD querier's robustness variable defines the number of times to retransmit MLD queries if packet loss occurs. A higher robustness variable makes the MLD querier more robust, but it increases the timeout time for IPv6 multicast groups.
This command and the robust-count command in MLD view have the same function but different effective ranges:
· The robust-count command in MLD view takes effect on all interfaces.
· The mld robust-count command takes effect on the current interface.
For an interface, the mld robust-count command takes priority over the robust-count command in MLD view.
# Set the MLD querier's robustness variable to 5 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld robust-count 5
mld startup-query-count
Use mld startup-query-count to set the MLD startup query count on an interface.
Use undo mld startup-query-count to restore the default.
The MLD startup query count equals the MLD querier's robustness variable.
Interface view
count: Sets an MLD startup query count in the range of 1 to 255.
This command and the startup-query-count command in MLD view have the same function but different effective ranges:
· The startup-query-count command in MLD view takes effect on all interfaces.
· The mld startup-query-count command takes effect on the current interface.
For an interface, the mld startup-query-count command takes priority over the startup-query-count command in MLD view.
# Set the MLD startup query count to 5 on VLAN-interface 100.
[Sysname-Vlan-interface100] mld startup-query-count 5
mld startup-query-interval
Use mld startup-query-interval to set the MLD startup query interval on an interface.
Use undo mld startup-query-interval to restore the default.
mld startup-query-interval interval
The MLD startup query interval equals one quarter of the MLD general query interval.
Interface view
interval: Sets an MLD startup query interval in the range of 1 to 31744 seconds.
This command and the startup-query-interval command in MLD view have the same function but different effective ranges:
· The startup-query-interval command in MLD view takes effect on all interfaces.
· The mld startup-query-interval command takes effect on the current interface.
For an interface, the mld startup-query-interval command takes priority over the startup-query-interval command in MLD view.
# Set the MLD startup query interval to 100 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] mld startup-query-interval 100
mld static-group
Use mld static-group to configure an interface as a static group member of an IPv6 multicast group.
Use undo mld static-group to restore the default.
mld static-group ipv6-group-address [ source ipv6-source-address ]
undo mld static-group { all | ipv6-group-address [ source ipv6-source-address ] }
An interface is not a static group member of IPv6 multicast groups.
Interface view
ipv6-source-address: Specifies an IPv6 multicast source. If you do not specify an IPv6 multicast source, the command configures an interface as a static group member of the multicast groups with all IPv6 multicast source addresses.
all: Specifies all IPv6 multicast groups that the interface has statically joined.
If the IPv6 multicast address is in the SSM multicast address range, you must specify an IPv6 multicast source address at the same time. Otherwise IPv6 multicast routing entries cannot be established. This restriction does not exist if the specified IPv6 multicast group address is not in the SSM multicast address range.
# Configure VLAN-interface 100 as a static group member of the IPv6 multicast group FF03::101.
[Sysname-Vlan-interface100] mld static-group ff03::101
# Configure VLAN-interface 100 as a static group member of the multicast source and group (2001::101, FF3E::202).
[Sysname-Vlan-interface100] mld static-group ff3e::202 source 2001::101
mld version
Use mld version to specify an MLD version for an interface.
Use undo mld version to restore the default.
mld version version-number
undo mld version
The MLD version is 1.
Interface view
version-number: Specifies an MLD version, 1 or 2.
# Specify MLD version 2 for VLAN-interface 100.
[Sysname-Vlan-interface100] mld version 2
Use other-querier-present-timeout to set the global MLD other querier present timer.
Use undo other-querier-present-timeout to restore the default.
MLD view
This command and the mld other-querier-present-timeout command have the same function but different effective ranges:
· The other-querier-present-timeout command takes effect on all interfaces.
For an interface, the mld other-querier-present-timeout command takes priority over the other-querier-present-timeout command.
# Set the global MLD other querier present timer to 125 seconds on the public network.
[Sysname] mld
[Sysname-mld] other-querier-present-timeout 125
Use query-interval to set the global MLD general query interval.
Use undo query-interval to restore the default.
The global MLD general query interval is 125 seconds.
MLD view
interval: Sets an MLD general query interval in the range of 1 to 31744 seconds.
This command and the mld query-interval command have the same function but different effective ranges:
# Set the global MLD general query interval to 60 seconds on the public network.
[Sysname] mld
[Sysname-mld] query-interval 60
mld query-interval
reset mld group
Use reset mld group to clear dynamic MLD group entries.
reset mld [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | ipv6-group-address [ prefix-length ] [ ipv6-source-address [ prefix-length ] ] } }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears dynamic MLD group entries on the public network.
all: The first all specifies all interfaces, and the second all specifies all MLD groups.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address in the range of FFxy::/16, where "x and "y" represent any hexadecimal numbers from 0 to F.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command deletes dynamic MLD group entries of all IPv6 multicast source addresses.
prefix-length: Specifies an address prefix length. The default is 128. For a multicast source address, the value range for this argument is 0 to 128. For a multicast group address, the value range for this argument is 8 to 128.
This command might interrupt the IPv6 multicast information transmission.
# Clear all dynamic MLD group entries on the public network.
<Sysname> reset mld group all
# Clear dynamic MLD group entries for VLAN-interface 100 on the public network.
<Sysname> reset mld group interface vlan-interface 100 all
# Clear dynamic group entries for the MLD group FF03::101:10 on VLAN-interface 100 on the public network.
<Sysname> reset mld group interface vlan-interface 100 ff03::101:10
robust-count (MLD view)
Use robust-count to set the global MLD querier's robustness variable.
Use undo robust-count to restore the default.
The global MLD querier's robustness variable is 2.
MLD view
This command and the mld robust-count command have the same function but different effective ranges:
# Set the global MLD querier's robustness variable to 5 on the public network.
[Sysname] mld
[Sysname-mld] robust-count 5
ssm-mapping (MLD view)
Use ssm-mapping to configure MLD SSM mappings.
Use undo ssm-mapping to remove MLD SSM mappings.
ssm-mapping ipv6-source-address acl6-number
undo ssm-mapping { ipv6-source-address | all }
MLD SSM mappings are not configured.
MLD view
acl6-number: Specifies an IPv6 basic ACL number in the range of 2000 to 2999. The specified IPv6 multicast source is mapped only to IPv6 multicast groups that the ACL permits. If the ACL does not exist or the ACL does not have valid rules, the specified IPv6 multicast source is not mapped to IPv6 multicast groups.
all: Removes all the MLD SSM mappings.
In an IPv6 basic ACL, the source keyword matches IPv6 multicast group address in MLD reports.
# Map the IPv6 multicast source 1::1 to the IPv6 multicast groups in the range of FF3E::/64 on the public network.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source ff3e:: 64
[Sysname-acl6-basic-2001] quit
[Sysname] mld
[Sysname-mld] ssm-mapping 1::1 2001
Use startup-query-count to set the global MLD startup query count.
Use undo startup-query-count to restore the default.
The global MLD startup query count equals the MLD querier's robustness variable.
MLD view
This command and the mld startup-query-count command have the same function but different effective ranges:
# Set the global MLD startup query count to 5 on the public network.
[Sysname] mld
[Sysname-mld] startup-query-count 5
Use startup-query-interval to set the global MLD startup query interval.
Use undo startup-query-interval to restore the default.
The global MLD startup query interval equals one quarter of the MLD general query interval.
MLD view
This command and the mld startup-query-interval command have the same function but different effective ranges:
# Set the global MLD startup query interval to 100 seconds on the public network.
[Sysname] mld
[Sysname-mld] startup-query-interval 100
