06 IP Multicast Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10006 IP Multicast Command Reference
02-PIM snooping commands
02-PIM snooping commands 100.62 KB
display pim-snooping neighbor
Use display pim-snooping neighbor to display PIM snooping neighbor information.
display pim-snooping neighbor [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, the command displays PIM snooping neighbor information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping neighbor information for all member devices.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display detailed PIM snooping neighbor information for VLAN 2.
<Sysname> display pim-snooping neighbor vlan 2 verbose
Total 2 neighbors.
VLAN 2: Total 2 neighbors.
  10.1.1.2
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/1                  (02:02:23)    LAN Prune Delay(T)
  10.1.1.3
    Slots (0 in total):
    Ports (1 in total):
      FGE1/1/2                  (00:32:43)
Total 2 neighbors
Total number of PIM snooping neighbors.
Total number of PIM snooping neighbors in VLAN 2.
10.1.1.2
IP address of the PIM snooping neighbor.
Ports (1 in total)
Ports that have PIM snooping neighbors, and the total number of the ports.
(02:02:23)
Remaining aging timer for a PIM snooping neighbor on the port.
·     For a global port, this field is always displayed.
·     For a non-global port, this field is displayed when on the following conditions exists:
¡ The port is on the specified member device.
¡ The port is on the master device and no member device is specified.
LAN Prune Delay
The PIM hello message sent by the PIM snooping neighbor has the LAN_Prune_Delay option.
(T)
The join message suppression feature has been disabled for the PIM snooping neighbor.
display pim-snooping router-port
Use display pim-snooping router-port to display PIM snooping router port information.
display pim-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, the command displays PIM snooping router port information for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping router port information for all member devices.
# Display PIM snooping router port information for VLAN 2.
<Sysname> display pim-snooping router-port vlan 2
VLAN 2:
  Router slots (0 in total):
  Router ports (2 in total):
    FGE1/1/1                  (00:01:30)
    FGE1/1/2                  (00:01:32)
VLAN 2
VLAN ID.
Router ports, and the total number of the router ports.
(00:01:30)
Remaining aging time for the router port.
display pim-snooping routing-table
Use display pim-snooping routing-table to display PIM snooping routing entries.
display pim-snooping routing-table [ vlan vlan-id ] [ slot slot-number ] [ verbose ]
vlan vlan-id: Specifies a VLAN in the range of 1 to 4094. If you do not specify a VLAN, the command displays PIM snooping routing entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays PIM snooping routing entries for the master device.
# Display detailed information about PIM snooping routing entries for VLAN 2.
<Sysname> display pim-snooping routing-table vlan 2 verbose
Total 1 entries.
FSM Flag: NI-no info, J-join, PP-prune pending
VLAN 2: Total 1 entries.
  (172.10.10.1, 225.1.1.1)
    Upstream neighbor: 20.1.1.1
    FSM information: normal
      Upstream Slots (0 in total):
      Upstream Ports (1 in total):
        FGE1/1/1
      Downstream Slots (0 in total):
      Downstream Ports (2 in total):
        FGE1/1/2
          Expires: 00:03:01, FSM: J
          Downstream Neighbors (2 in total):
            7.1.1.1
              Expires: 00:59:19, FSM: J
            7.1.1.11
              Expires: 00:59:20, FSM: J
        FGE1/1/3
          Expires: 00:02:21, FSM: PP
Total 1 entries
Total number of (S, G) entries and (*, G) entries.
State machine flag of the downstream port:
·     NI—Initial state.
·     J—Join.
·     PP—Prune pending.
(S, G) entry.
FSM information
Finite state machine information of the entry:
·     deleteThe entry attributes have been deleted.
·     dummyThe entry is a new temporary entry.
·     no infoNo entry exists.
·     normalThe entry is a correct entry.
Upstream neighbor
Upstream neighbor of the (S, G) or (*, G) entry.
Upstream ports, and the total number of the upstream ports.
This field is displayed when on the following conditions exists:
·     The port is on the specified member device.
·     The port is on the master device and no member device is specified.
Downstream port of the upstream neighbor, and the total number of the downstream ports.
Downstream neighbors of the downstream port, and the total number of the downstream neighbors.
Remaining aging time for the downstream port or downstream neighbor, and the finite state machine information.
display pim-snooping statistics
Use display pim-snooping statistics to display statistics for the PIM messages learned through PIM snooping.
# Display statistics for the PIM messages learned through PIM snooping.
<Sysname> display pim-snooping statistics
Received PIMv2 hello:  100
Received PIMv2 join/prune:  100
Received PIMv2 error:  0
Received PIMv2 messages in total:  200
Received PIMv1 messages in total:  0
Number of received PIMv2 hello messages.
Number of received PIMv2 join/prune messages.
Number of received PIMv2 messages with errors.
Total number of received PIMv2 messages.
Total number of received PIMv1 messages.
reset pim-snooping statistics
pim-snooping enable
Use pim-snooping enable to enable PIM snooping for a VLAN.
Use undo pim-snooping enable to disable PIM snooping for a VLAN.
pim-snooping enable
PIM snooping is disabled in a VLAN.
VLAN view
You must enable IGMP snooping globally and for a VLAN before you execute this command the VLAN.
PIM snooping does not take effect on sub-VLANs of a multicast VLAN.
# Enable IGMP snooping globally, and enable IGMP snooping and PIM snooping for VLAN 2.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] pim-snooping enable
·     igmp-snooping
·     igmp-snooping enable
pim-snooping graceful-restart join-aging-time
Use pim-snooping graceful-restart join-aging-time to set the aging time for global downstream ports and global router ports on the new master device in IRF master election.
Use undo pim-snooping graceful-restart join-aging-time to restore the default.
pim-snooping graceful-restart join-aging-time interval
The default setting is 210 seconds.
VLAN view
interval: Sets an aging time in the range of 210 to 18000 seconds.
A global downstream port or a global router port is a Layer 2 aggregate interface that acts as a downstream port or router port.
You must enable PIM snooping for a VLAN before you execute this command for the VLAN.
# In VLAN 2, set the aging time for global downstream ports and global router ports to 600 seconds on the new master device in IRF master election.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart join-aging-time 600
pim-snooping enable
pim-snooping graceful-restart neighbor-aging-time
Use pim-snooping graceful-restart neighbor-aging-time to set the aging time for global neighbor ports on the new master device in IRF master election.
Use undo pim-snooping graceful-restart neighbor-aging-time to restore the default.
pim-snooping graceful-restart neighbor-aging-time interval
The default setting is 105 seconds.
VLAN view
interval: Sets an aging time in the range of 105 to 18000 seconds.
A global neighbor port is a Layer 2 aggregate interface that acts as a neighbor port.
# In VLAN 2, set the aging time for global neighbor ports to 300 seconds on the new master device in IRF master election.
[Sysname] vlan 2
[Sysname-vlan2] pim-snooping graceful-restart neighbor-aging-time 300
pim-snooping enable
Use reset pim-snooping statistics to clear statistics for the PIM messages learned through PIM snooping.
# Clear statistics for the PIM messages learned through PIM snooping.
<Sysname> reset pim-snooping statistics
