- 06 IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
| 09-MLD snooping commands | 228.77 KB |
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac forwarding
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
dot1p-priority (MLD-snooping view)
entry-limit (MLD-snooping view)
fast-leave (MLD-snooping view)
group-policy (MLD-snooping view)
host-aging-time (MLD-snooping view)
last-listener-query-interval (MLD-snooping view)
max-response-time (MLD-snooping view)
mld-snooping general-query source-ip
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping router-aging-time
mld-snooping special-query source-ip
overflow-replace (MLD-snooping view)
report-aggregation (MLD-snooping view)
reset mld-snooping router-port
router-aging-time (MLD-snooping view)
source-deny (MLD-snooping view)
Use display ipv6 l2-multicast ip to display information about Layer 2 IPv6 multicast groups.
display ipv6 l2-multicast ip [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, the command displays information about all Layer 2 IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command displays information about Layer 2 IPv6 multicast groups for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays information about Layer 2 IPv6 multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the Layer 2 IPv6 multicast groups on the master device.
# Display information about the Layer 2 IPv6 multicast groups for VLAN 2.
<Sysname> display ipv6 l2-multicast ip vlan 2
Total 1 entries.
VLAN 2: Total 1 IP entries.
(::, FF1E::101)
Attribute: static, success
Host slots (0 in total):
Host ports (1 in total):
FGE1/1/1 (S, SUC)
Total 1 entries |
Total number of Layer 2 IPv6 multicast groups. |
VLAN 2: Total 1 IP entries |
Total number of Layer 2 IPv6 multicast groups in VLAN 2. |
(::, FF1E::101) |
(S, G) entry, where a double colon (::) in the S position means any IPv6 multicast sources. |
Attribute |
Entry attribute: · dynamic—The entry is created by a dynamic protocol. · static—The entry is created by a static protocol. · pim—The entry is created by IPv6 PIM. · kernel—The entry is obtained from the kernel. · success—Processing succeeds. · fail—Processing fails. |
Host ports (1 in total) |
Member ports, and the total number of the member ports. |
(S, SUC) |
Port attribute: · D—Dynamic port. · S—Static port. · P—IPv6 PIM port. · K—Port obtained from the kernel. · R—Port learned from (*, *) entries. · W—Port learned from (*, G) entries. · SUC—Processing succeeds. · F—Processing fails. · BC—Broadcast port. The TRILL port floods the IPv6 multicast data after the topology changes. |
Use display ipv6 l2-multicast ip forwarding to display Layer 2 IPv6 multicast group entries.
display ipv6 l2-multicast ip forwarding [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. If you do not specify an IPv6 multicast group, the command displays Layer 2 IPv6 multicast group entries for all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command displays Layer 2 IPv6 multicast group entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays Layer 2 IPv6 multicast group entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays Layer 2 IPv6 multicast group entries on the master device.
# Display Layer 2 IPv6 multicast group entries for VLAN 2.
<Sysname> display ipv6 l2-multicast ip forwarding vlan 2
Total 1 entries.
(::, FF1E::101)
Host ports (3 in total):
FGE1/1/1
FGE1/1/2
FGE1/1/3
Total 1 entries |
Total number of Layer 2 IPv6 multicast group entries. |
Total number of Layer 2 IPv6 multicast group entries in VLAN 2. |
(::, FF1E::101) |
Host slots (0 in total) |
Member IDs of the member devices that have member ports and the total number of the member devices (excluding the specified member device). |
Host ports (3 in total) |
Use display ipv6 l2-multicast mac to display information about Layer 2 IPv6 MAC multicast groups.
display ipv6 l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies an IPv6 MAC multicast group by its IPv6 MAC address. If you do not specify an IPv6 MAC multicast group, the command displays information about all Layer 2 IPv6 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays information about Layer 2 IPv6 MAC multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the Layer 2 IPv6 MAC multicast groups on the master device.
# Display information about the Layer 2 IPv6 MAC multicast groups for VLAN 2.
<Sysname> display ipv6 l2-multicast mac vlan 2
Total 1 MAC entries.
VLAN 2: Total 1 MAC entries.
MAC group address: 3333-0000-0101
Attribute: success
FGE1/1/1
Total 1 MAC entries |
Total number of Layer 2 IPv6 MAC multicast groups. |
VLAN 2: Total 1 MAC entries |
Total number of Layer 2 IPv6 MAC multicast groups in VLAN 2. |
MAC group address |
IPv6 address of the Layer 2 Ipv6 MAC multicast group. |
Attribute |
Entry attribute: · success—Processing succeeds. · fail—Processing fails. |
Use display ipv6 l2-multicast mac forwarding to display IPv6 MAC multicast group entries.
display ipv6 l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies an IPv6 MAC multicast group by its IPv6 MAC address. If you do not specify an IPv6 MAC multicast group, the command displays IPv6 MAC multicast group entries for all IPv6 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays IPv6 MAC multicast group entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays IPv6 MAC multicast group entries on the master device.
# Display IPv6 MAC multicast group entries for VLAN 2.
<Sysname> display ipv6 l2-multicast mac forwarding vlan 2
FGE1/1/1
FGE1/1/2
FGE1/1/3
Total number of IPv6 MAC multicast group entries. |
Total number of IPv6 MAC multicast group entries in VLAN 2. |
MAC group address |
Address of the IPv6 MAC multicast group. |
Use display mld-snooping to display MLD snooping status.
display mld-snooping [ global | vlan vlan-id ]
global: Displays the global MLD snooping status.
If you do not specify a parameter, the command displays the global MLD snooping status and the MLD snooping status in all VLANs.
# Display the global MLD snooping status and the MLD snooping status for all VLANs.
<Sysname> display mld-snooping
MLD snooping information: Global
MLD snooping: Enabled
Drop-unknown: Disabled
Host-aging-time: 260s
Router-aging-time: 260s
Max-response-time: 10s
Last-listener-query-interval: 1s
Report-aggregation: Enabled
Dot1p-priority: --
MLD snooping information: VLAN 1
Version: 1
Querier: Disabled
Query-interval: 125s
General-query source IP: FE80::2FF:FFFF:FE00:1
Special-query source IP: FE80::2FF:FFFF:FE00:1
Report source IP: FE80::2FF:FFFF:FE00:2
Done source IP: FE80::2FF:FFFF:FE00:3
Dot1p-priority: 2
MLD snooping information: VLAN 10
Drop-unknown: Enabled
Version: 2
Dot1p-priority: --
Table 5 Command output
MLD snooping |
MLD snooping status: · Enabled. · Disabled. |
Drop-unknown |
Status of dropping unknown IPv6 multicast data: · Enabled. · Disabled. |
Version |
MLD snooping version. |
Host-aging-time |
Aging timer for the dynamic member port. |
Router-aging-time |
Aging timer for the dynamic router port. |
Max-response-time |
Maximum time for responding to MLD general queries. |
Last-listener-query-interval |
Interval for sending MLD multicast-address-specific queries. |
Report-aggregation |
Status of MLD report suppression: · Enabled. · Disabled. |
802.1p priority for MLD messages, where two hyphens (--) mean that it is not configured. |
Whether the MLD snooping querier is enabled. |
Interval for sending MLD general queries. |
Source IPv6 address of MLD general queries. |
Source IPv6 address of MLD multicast-address-specific queries. |
Source IPv6 address of MLD reports. |
Source IPv6 address of MLD done messages. |
display mld-snooping group
Use display mld-snooping group to display dynamic MLD snooping forwarding entries.
display mld-snooping group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast group, the command displays dynamic MLD snooping forwarding entries for all IPv6 multicast groups.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command displays dynamic MLD snooping forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays dynamic MLD snooping forwarding entries for all VLANs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays dynamic MLD snooping forwarding entries on the master device.
# Display detailed information about dynamic MLD snooping forwarding entries for VLAN 2.
<Sysname> display mld-snooping group vlan 2 verbose
Total 1 entries.
VLAN 2: Total 1 entries.
(::,FF1E::101)
Attribute: local port
FSM information: normal
FGE1/1/2 (00:03:23)
Table 6 Command output
Total 1 entries |
Total number of dynamic MLD snooping forwarding entries. |
VLAN 2: Total 1 entries |
Total number of dynamic MLD snooping forwarding entries in VLAN. |
(::, FF1E::101) |
Entry attribute: · global port—The entry has a global port. · local port—The entry has a port that resides on the specified device. · slot—The entry has a port that resides on a device other than the specified device. |
Finite state machine information of the entry: · delete—The entry attributes have been deleted. · dummy—The entry is a new temporary entry. · no info—No entry exists. · normal—The entry is a correct entry. |
(00:03:23) |
Remaining aging time for the dynamic member port. · For a global port (including Layer 2 aggregate interfaces), this field is always displayed. · For a non-global port, this field is displayed when on the following conditions exists: ¡ The port is on the specified member device. ¡ The port is on the master device and no member device is specified. |
reset mld-snooping group
Use display mld-snooping router-port to display dynamic router port information.
display mld-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays dynamic router port information on the master device.
# Display dynamic router port information for VLAN 2.
<Sysname> display mld-snooping router-port vlan 2
VLAN 2:
Router slots (0 in total):
Router ports (2 in total):
FGE1/1/1 (00:01:30)
FGE1/1/2 (00:00:23)
Table 7 Command output
Router slots (0 in total) |
Member IDs of the member devices that have router ports and the total number of the member devices (excluding the specified member device). |
Router ports (2 in total) |
Dynamic router ports, and the total number of the dynamic router ports. |
(00:01:30) |
Remaining aging time for the dynamic router port. · For a global port, this field is always displayed. · For a non-global port, this field is displayed when on the following conditions exists: ¡ The port is on the specified member device. ¡ The port is on the master device and no member device is specified. |
Use display mld-snooping static-group to display static MLD snooping forwarding entries.
display mld-snooping static-group [ ipv6-group-address | ipv6-source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F. If you do not specify an IPv6 multicast group, the command displays static MLD snooping forwarding entries for all IPv6 multicast groups.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command displays static MLD snooping forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays static MLD snooping forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays static MLD snooping forwarding entries on the master device.
# Display detailed information about static MLD snooping forwarding entries for VLAN 2.
<Sysname> display mld-snooping static-group vlan 2 verbose
Total 1 entries.
(::,FF1E::101)
FGE1/1/2
Table 8 Command output
Total 1 entries |
Total number of static MLD snooping forwarding entries. |
Total number of static MLD snooping forwarding entries in VLAN 2. |
(::, FF1E::101) |
Attribute |
FSM information |
Use display mld-snooping static-router-port to display static router port information.
display mld-snooping static-router-port [ vlan vlan-id ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays static router port information on the master device.
# Display static router port information for VLAN 2.
<Sysname> display mld-snooping static-router-port vlan 2
VLAN 2:
FGE1/1/1
FGE1/1/2
Table 9 Command output
Static router ports, and the total number of the static router ports. |
Use display mld-snooping statistics to display statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping.
# Display statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping.
<Sysname> display mld-snooping statistics
Received MLD general queries: 0
Received MLDv1 specific queries: 0
Received MLDv1 reports: 0
Received MLD dones: 0
Sent MLDv1 specific queries: 0
Received MLDv2 reports: 0
Received MLDv2 reports with right and wrong records: 0
Received MLDv2 specific queries: 0
Received MLDv2 specific sg queries: 0
Sent MLDv2 specific queries: 0
Sent MLDv2 specific sg queries: 0
Received IPv6 PIM hello: 0
Received error MLD messages: 0
Table 10 Command output
general queries |
Number of MLD general queries. |
specific queries |
Number of MLD multicast-address-specific queries. |
reports |
Number of MLD reports. |
dones |
Number of MLD done messages. |
reports with right and wrong records |
Number of MLD reports with correct and incorrect records. |
specific sg queries |
Number of MLD multicast-address-and-source-specific queries. |
IPv6 PIM hello |
Number of IPv6 PIM hello messages. |
error MLD messages |
Number of MLD messages with errors. |
reset mld-snooping statistics
Use dot1p-priority to set the 802.1p priority for MLD messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority-number
undo dot1p-priority
The 802.1p priority for MLD messages is not configured.
MLD-snooping view
priority-number: Sets an 802.1p priority for MLD messages, in the range of 0 to 7. A higher value means a higher priority.
You can set the 802.1p priority globally for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the 802.1p priority for MLD messages to 3 globally.
[Sysname] mld-snooping
[Sysname-mld-snooping] dot1p-priority 3
enable (MLD-snooping view)
Use enable to enable MLD snooping for VLANs.
Use undo enable to disable MLD snooping for VLANs.
enable vlan vlan-list
undo enable vlan vlan-list
MLD snooping is disabled in a VLAN.
MLD-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094.
You must globally enable MLD snooping before you execute this command.
You can enable MLD snooping for the specified VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable MLD snooping globally, and enable MLD snooping for VLAN 2 through VLAN 10.
[Sysname-mld-snooping] enable vlan 2 to 10
· mld-snooping
· mld-snooping enable
Use entry-limit to globally set the maximum number of MLD snooping forwarding entries, including dynamic entries and static entries.
Use undo entry-limit to restore the default.
entry-limit limit
undo entry-limit
The default setting is 4294967295.
MLD-snooping view
limit: Sets the maximum number of MLD snooping forwarding entries, in the range of 0 to 4294967295.
# Set the global maximum number of MLD snooping forwarding entries to 512.
[Sysname-mld-snooping] entry-limit 512
Use fast-leave to enable fast-leave processing globally.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
MLD-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094. If you do not specify a VLAN, the command applies to all VLANs.
The fast-leave processing feature enables the switch to immediately remove a port from the forwarding entry for an IPv6 multicast group when the port receives a done message.
You can enable fast-leave processing globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally enable fast-leave processing for VLAN 2.
[Sysname-mld-snooping] fast-leave vlan 2
mld-snooping fast-leave
Use group-policy to globally configure an IPv6 multicast group policy to control IPv6 multicast groups that hosts can join.
Use undo group-policy to delete the configured global IPv6 multicast group policy.
group-policy acl6-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
IPv6 multicast group policies are not configured, and hosts can join IPv6 multicast groups.
MLD-snooping view
acl6-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only IPv6 multicast groups that the ACL permits. If the ACL does not exist or the ACL does not contain valid rules, receiver hosts cannot join IPv6 multicast groups.
In an IPv6 basic ACL, the source keyword matches the multicast group address in MLD reports. In an IPv6 advanced ACL, the source and destination keywords match the multicast source address and multicast group address in MLD reports, respectively. The multicast source address is regarded as 0::0 for the following MLD reports:
· MLDv1 reports.
· MLDv2 IS_EX and MLDv2 TO_EX reports that do not carry IPv6 multicast source addresses.
If you specify the VPN-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
You can configure different ACL rules on a port in different VLANs. However, for a given VLAN, a newly configured ACL rule overrides the existing one.
This configuration takes effect only on the IPv6 multicast groups that the port joins dynamically.
You can configure an IPv6 multicast group policy globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally configure an IPv6 multicast group policy for VLAN 2 so that hosts in this VLAN can join only the IPv6 multicast group FF03::101.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source ff03::101 128
[Sysname-acl6-basic-2000] quit
[Sysname-mld-snooping] group-policy 2000 vlan 2
mld-snooping group-policy
Use host-aging-time to set the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time interval
The default setting is 260 seconds.
MLD-snooping view
interval: Sets an aging timer for dynamic member ports, in the range of 1 to 8097894 seconds.
To avoid mistakenly deleting IPv6 multicast group members, set the aging timer for dynamic member ports to be greater than the value calculated by using the following formula:
[ MLD general query interval ] + [ maximum response time for MLD general queries ]
H3C recommends that you set the aging timer of dynamic member ports to the value calculated by using the following formula:
[ MLD general query interval ] × 2 + [ maximum response time for MLD general queries ]
You can set the timer globally for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the global aging timer for dynamic member ports to 300 seconds.
[Sysname-mld-snooping] host-aging-time 300
mld-snooping host-aging-time
Use last-listener-query-interval to globally set the MLD last listener query interval (interval for sending MLD multicast-address-specific queries).
Use undo last-listener-query-interval to restore the default.
The MLD last listener query interval is 1 second.
MLD-snooping view
interval: Sets an MLD last listener query interval in the range of 1 to 25 seconds.
The MLD last listener query interval determines the maximum response time for MLD multicast-address-specific queries.
You can set the interval for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the global MLD last listener query interval to 3 seconds.
[Sysname-mld-snooping] last-listener-query-interval 3
Use max-response-time to globally set the maximum response time for MLD general queries.
Use undo max-response-time to restore the default.
max-response-time interval
The maximum response time for MLD general queries is 10 seconds.
MLD-snooping view
interval: Sets the maximum response time for MLD general queries, in the range of 1 to 3174 seconds.
To avoid mistakenly deleting IPv6 multicast group members, set the maximum response time for MLD general queries to be less than the MLD general query interval.
You can set the time globally for all VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the global maximum response time for MLD general queries to 5 seconds.
[Sysname-mld-snooping] max-response-time 5
mld-snooping
Use mld-snooping to enable MLD snooping globally and enter MLD-snooping view.
Use undo mld-snooping to disable MLD snooping globally.
mld-snooping
undo mld-snooping
MLD snooping is globally disabled.
# Enable MLD snooping globally and enter MLD -snooping view.
· enable (MLD-snooping view)
mld-snooping done source-ip
Use mld-snooping done source-ip to configure a source IPv6 address for MLD done messages.
Use undo mld-snooping done source-ip to restore the default.
The source IPv6 address of the MLD done messages is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
ipv6-address: Specifies a source IPv6 address for MLD done messages.
You must enable MLD snooping for a VLAN before you execute this command.
# In VLAN 2, enable MLD snooping, and configure FE80:0:0:1::1 as the source IPv6 address of MLD done messages.
[Sysname-mld-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping enable
[Sysname-vlan2] mld-snooping done source-ip fe80:0:0:1::1
mld-snooping dot1p-priority
Use mld-snooping dot1p-priority to set the 802.1p priority for MLD messages in a VLAN.
Use undo mld-snooping dot1p-priority to restore the default.
mld-snooping dot1p-priority priority-number
VLAN view
You can set the 802.1p priority for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set the 802.1p priority for MLD messages to 3.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping dot1p-priority 3
· dot1p-priority (MLD-snooping view)
mld-snooping drop-unknown
Use mld-snooping drop-unknown to enable dropping unknown IPv6 multicast data for a VLAN.
Use undo mld-snooping drop-unknown to disable dropping unknown IPv6 multicast data for a VLAN.
Dropping unknown IPv6 multicast data is disabled for a VLAN, and unknown IPv6 multicast data is flooded in the VLAN.
VLAN view
# In VLAN 2, enable MLD snooping, and enable dropping unknown IPv6 multicast data.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping drop-unknown
mld-snooping enable
Use mld-snooping enable to enable MLD snooping for a VLAN.
Use undo mld-snooping enable to disable MLD snooping for a VLAN.
mld-snooping enable
VLAN view
You must enable MLD snooping globally before you enable MLD snooping for a VLAN.
You can enable MLD snooping for a VLAN in VLAN view or for the specified VLANs in MLD-snooping view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable MLD snooping globally and for VLAN 2.
[Sysname] vlan 2
· mld-snooping
Use mld-snooping fast-leave to enable fast-leave processing on a port.
Use undo mld-snooping fast-leave to disable fast-leave processing on a port.
undo mld-snooping fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled on a port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
The fast-leave processing feature enables the switch to immediately remove a port from the forwarding entry for a multicast group specified when the port receives a done message.
You can enable fast-leave processing for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing for VLAN 2 on FortyGigE 1/1/1.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] mld-snooping fast-leave vlan 2
Use mld-snooping general-query source-ip to configure a source IPv6 address for MLD general queries.
Use undo mld-snooping general-query source-ip to restore the default.
The source IPv6 address for MLD general queries is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
ipv6-address: Specifies a source IPv6 address for MLD general queries.
You must enable MLD snooping for a VLAN before you execute this command for the VLAN.
# In VLAN 2, enable MLD snooping, and configure FE80:0:0:1::1 as the source IPv6 address of MLD general queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping general-query source-ip fe80:0:0:1::1
mld-snooping group-limit
Use mld-snooping group-limit to set the maximum number of IPv6 multicast groups that a port can join.
Use undo mld-snooping group-limit to restore the default.
undo mld-snooping group-limit [ vlan vlan-list ]
limit: Sets the maximum number of multicast groups that a port can join, in the range of 0 to 4294967295.
This command takes effect only on the IPv6 multicast groups that a port joins dynamically.
# Set the maximum number of IPv6 multicast groups that FortyGigE 1/1/1 in VLAN 2 can join to 10.
[Sysname-FortyGigE1/1/1] mld-snooping group-limit 10 vlan 2
Use mld-snooping group-policy to configure an IPv6 multicast group policy on a port to control IPv6 multicast groups that hosts attached to the port can join.
Use undo mld-snooping group-policy to delete the IPv6 multicast group policy on a port.
mld-snooping group-policy acl6-number [ vlan vlan-list ]
undo mld-snooping group-policy [ vlan vlan-list ]
IPv6 multicast group policies are not configured on a port, and hosts attached to the port can join IPv6 multicast groups.
acl6-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts attached to the port can join only IPv6 multicast groups that the ACL permits. If the ACL does not exist or the ACL does not contain valid rules, receiver hosts cannot join IPv6 multicast groups.
· MLDv1 reports.
If you specify the vpn-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
You can configure different ACL rules on a port in different VLANs. If you configure different ACLs for a VLAN, the most recent configuration takes effect.
You can configure an IPv6 multicast group policy for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Configure an IPv6 multicast group policy for VLAN 2 on FortyGigE 1/1/1 so that hosts attached to the port can join only the multicast group FF03::101.
[Sysname-FortyGigE1/1/1] mld-snooping group-policy 2000 vlan 2
Use mld-snooping host-aging-time to set the aging timer for dynamic member ports in a VLAN.
Use undo mld-snooping host-aging-time to restore the default.
mld-snooping host-aging-time interval
VLAN view
interval: Sets an aging timer for dynamic member ports in a VLAN, in the range of 1 to 8097894 seconds.
You must enable MLD snooping for a VLAN before you configure this command for the VLAN.
You can set the timer for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set aging timer for the dynamic member ports to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping host-aging-time 300
· host-aging-time (MLD-snooping view)
mld-snooping host-join
Use mld-snooping host-join to configure a port as a simulated member host for an IPv6 multicast group.
Use undo mld-snooping host-join to restore the default.
undo mld-snooping host-join { ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id | all }
This function is disabled.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16 and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F.
source-ip ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you specify an IPv6 multicast source, the command configures the port as a simulated member host for an IPv6 multicast source and group. If you do not specify an IPv6 multicast source, the command configures the port as a simulated member host for an IPv6 multicast group. This option takes effect on MLDv2 snooping devices.
all: Specifies all IPv6 multicast groups.
Unlike a static member port, a port configured as a simulated member host ages out like a dynamic member port.
The MLD version and the MLD snooping version that the simulated member host runs must be the same.
# Configure FortyGigE 1/1/1 as a simulated member host for the IPv6 multicast source and group (2002::22, FF3E::101) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping version 2
[Sysname-vlan2] quit
[Sysname-FortyGigE1/1/1] mld-snooping host-join ff3e::101 source-ip 2002::22 vlan 2
Use mld-snooping last-listener-query-interval to set the MLD last listener query interval (interval for sending MLD multicast-address-specific queries) for a VLAN.
Use undo mld-snooping last-listener-query-interval to restore the default.
The MLD last listener query interval in a VLAN is 1 second.
VLAN view
The MLD last listener query interval determines the maximum response time for MLD multicast-address-specific queries in a VLAN.
# In VLAN 2, enable MLD snooping, and set the MLD last listener query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping last-listener-query-interval 3
· last-listener-query-interval (MLD-snooping view)
Use mld-snooping max-response-time to set the maximum response time for MLD general queries in a VLAN.
Use undo mld-snooping max-response-time to restore the default.
mld-snooping max-response-time interval
The maximum response time for MLD general queries in a VLAN is 10 seconds.
VLAN view
You can set the time for a VLAN in VLAN view or globally for all VLANs in MLD-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable MLD snooping, and set the maximum response time for MLD general queries to 5 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping max-response-time 5
· max-response-time (MLD-snooping view)
mld-snooping overflow-replace
Use mld-snooping overflow-replace to enable the IPv6 multicast group replacement feature on a port.
Use undo mld-snooping overflow-replace to disable the multicast group replacement feature on a port.
undo mld-snooping overflow-replace [ vlan vlan-list ]
The IPv6 multicast group replacement feature is disabled on a port.
This command takes effect only on the IPv6 multicast groups that a port dynamically joins.
You can enable the IPv6 multicast group replacement feature for a port in interface view or globally for all ports in MLD-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable the IPv6 multicast group replacement feature for VLAN 2 on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] mld-snooping overflow-replace vlan 2
mld-snooping querier
Use mld-snooping querier to enable the MLD snooping querier for a VLAN.
Use undo mld-snooping querier to disable the MLD snooping querier.
The MLD snooping querier for a VLAN is disabled.
VLAN view
This command takes effect on a sub-VLAN only after you remove the sub-VLAN from the IPv6 multicast VLAN.
# In VLAN 2, enable MLD snooping, and enable the MLD snooping querier.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping querier
· subvlan (IPv6 multicast VLAN view)
mld-snooping report source-ip
Use mld-snooping report source-ip to configure a source IPv6 address for MLD reports.
Use undo mld-snooping report source-ip to restore the default.
The source IPv6 address for MLD reports is the IPv6 link-local address of current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
ipv6-address: Specifies a source IPv6 address for MLD reports.
# In VLAN 2, enable MLD snooping, and configure FE80:0:0:1::1 as the source IPv6 address of the MLD reports.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping report source-ip fe80:0:0:1::1
mld-snooping query-interval
Use mld-snooping query-interval to set the MLD general query interval in a VLAN.
Use undo mld-snooping query-interval to restore the default.
The MLD general query interval in a VLAN is 125 seconds.
VLAN view
interval: Set an MLD general query interval, in the range of 2 to 31744 seconds.
To avoid mistakenly deleting IPv6 multicast group members, set the MLD general query interval to be greater than the maximum response time for MLD general queries.
# In VLAN 2, enable MLD snooping, and set the MLD general query interval to 20 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping query-interval 20
· max-response-time
· mld-snooping max-response-time
· mld-snooping querier
Use mld-snooping router-aging-time to set the aging timer for dynamic router ports in a VLAN.
Use undo mld-snooping router-aging-time to restore the default.
mld-snooping router-aging-time interval
VLAN view
interval: Sets an aging timer for dynamic router ports in a VLAN, in the range of 1 to 8097894 seconds.
# In VLAN 2, enable MLD snooping, and set aging timer for the dynamic router ports to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping router-aging-time 100
· router-aging-time (MLD-snooping view)
mld-snooping router-port-deny
Use mld-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo mld-snooping router-port-deny to restore the default.
undo mld-snooping router-port-deny [ vlan vlan-list ]
A port can become a dynamic router port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you specify VLANs, the command takes effect only when the port belongs to the specified VLANs. If you do not specify a VLAN, the command takes effect on all VLANs.
# Disable FortyGigE 1/1/1 from becoming a dynamic router port in VLAN 2.
[Sysname-FortyGigE1/1/1] mld-snooping router-port-deny vlan 2
mld-snooping source-deny
Use mld-snooping source-deny to enable IPv6 multicast source port filtering on a port to discard all IPv6 multicast data packets.
Use undo mld-snooping source-deny to disable IPv6 multicast source port filtering on a port.
IPv6 multicast source port filtering is disabled.
You can enable this feature for a port in interface view or for the specified ports in MLD-snooping view. For a port, the configuration in interface view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# Enable source port filtering for IPv6 multicast data on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] mld-snooping source-deny
Use mld-snooping special-query source-ip to configure a source IPv6 address for MLD multicast-address-specific queries.
Use undo mld-snooping special-query source-ip to restore the default.
If the MLD snooping querier has received MLD general queries, the source IP address of MLD multicast-address-specific queries is the IPv6 address of the MLD general queries. Otherwise, the source IP address is the IPv6 link-local address of the current VLAN interface. If the current VLAN interface does not have an IPv6 link-local address, the source IPv6 address is FE80::02FF:FFFF:FE00:0001.
VLAN view
ipv6-address: Specifies a source IPv6 address for MLD multicast-address-specific queries.
# In VLAN 2, enable MLD snooping, and configure FE80:0:0:1::1 as the source IPv6 address of MLD multicast-address-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] mld-snooping special-query source-ip fe80:0:0:1::1
Use mld-snooping static-group to configure a port as a static member port of an IPv6 multicast group.
Use undo mld-snooping static-group to delete a static member port.
undo mld-snooping static-group { ipv6-group-address [ source-ip ipv6-source-address ] vlan vlan-id | all }
A port is not a static member port of IPv6 multicast groups.
ipv6-group-address: Specifies an IPv6 multicast group by its IPv6 address. The value can be 0::0 or in the range of FFxy::/16 (excluding FFx0::/16, FFx1::/16, FFx2::/16, and FF0y::), where "x" and "y" represent any hexadecimal numbers from 0 to F.
source-ip ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you specify an IPv6 multicast source, the command configures the port as a static member port of an IPv6 multicast source and group. If you do not specify an IPv6 multicast source, the command configures the port as a static member port of an IPv6 multicast group. This option takes effect on MLDv2 snooping devices.
all: Specifies all VLANs.
# Configure FortyGigE 1/1/1 as a static member port for the IPv6 multicast source and group (2002::22, FF3E::101) in VLAN 2.
[Sysname] vlan 2
[Sysname-FortyGigE1/1/1] mld-snooping static-group ff3e::101 source-ip 2002::22 vlan 2
Use mld-snooping static-router-port to configure a port as a static router port.
Use undo mld-snooping static-router-port to delete a static router port.
undo mld-snooping static-router-port { all | vlan vlan-id }
A port is not a static router port.
# Configure FortyGigE 1/1/1 as a static router port in VLAN 2.
[Sysname-FortyGigE1/1/1] mld-snooping static-router-port vlan 2
Use mld-snooping version to specify an MLD snooping version in a VLAN.
Use undo mld-snooping version to restore the default.
The MLD snooping version in a VLAN is 1.
VLAN view
version-number: Specifies an MLD snooping version, 1 or 2.
You can specify the version for a VLAN in VLAN view or for the specified VLANs in MLD-snooping view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in MLD-snooping view, and the most recent configuration takes effect.
# In VLAN 2, enable MLD snooping, and specify MLD snooping version 2.
[Sysname] vlan 2
· version (MLD-snooping view)
Use overflow-replace to enable the IPv6 multicast group replacement feature globally.
Use undo overflow-replace to disable the IPv6 multicast group replacement feature globally.
undo overflow-replace [ vlan vlan-list ]
The IPv6 multicast group replacement feature is disabled globally.
MLD-snooping view
You can enable IPv6 multicast group replacement globally for all ports in MLD-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable the IPv6 multicast group replacement feature globally for VLAN 2.
[Sysname-mld-snooping] overflow-replace vlan 2
Use report-aggregation to enable MLD report suppression.
Use undo report-aggregation to disable MLD report suppression.
report-aggregation
MLD report suppression is enabled.
MLD-snooping view
# Disable MLD report suppression.
[Sysname-mld-snooping] undo report-aggregation
Use reset mld-snooping group to clear dynamic MLD snooping forwarding entries.
reset mld-snooping group { ipv6-group-address [ ipv6-source-address ] | all } [ vlan vlan-id ]
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, the command clears dynamic MLD snooping forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command clears dynamic MLD snooping forwarding entries for all VLANs.
# Clear dynamic MLD snooping forwarding entries for all IPv6 multicast groups.
<Sysname> reset mld-snooping group all
Use reset mld-snooping router-port to clear dynamic router port information.
reset mld-snooping router-port { all | vlan vlan-id }
all: Specifies all dynamic router ports.
# Clear all dynamic router ports.
<Sysname> reset mld-snooping router-port all
Use reset mld-snooping statistics to clear statistics for the MLD messages and IPv6 PIM hello messages learned through MLD snooping.
# Clear statistics for all MLD messages and IPv6 PIM hello messages learned through MLD snooping.
<Sysname> reset mld-snooping statistics
Use router-aging-time to set the aging timer for dynamic router ports globally.
Use undo router-aging-time to restore the default.
The aging timer for dynamic router ports is 260 seconds.
MLD-snooping view
interval: Sets an aging timer for dynamic router ports, in the range of 1 to 8097894 seconds.
# Set the global aging timer for dynamic router ports to 100 seconds.
[Sysname-mld-snooping] router-aging-time 100
Use source-deny to enable IPv6 multicast source port filtering on ports to discard all IPv6 multicast data packets.
Use undo source-deny to disable IPv6 multicast source port filtering on ports.
undo source-deny port interface-list
MLD-snooping view
port interface-list: Specifies a space-separated list of port items. Each item specifies a port by its port type and number or a range of ports in the form of start-interface-type interface-number to end-interface-type interface-number.
You can enable this feature for the specified ports in MLD-snooping view or for a port in interface view. For a port, the configuration in MLD-snooping view has the same priority as the configuration in interface view, and the most recent configuration takes effect.
# Enable source port filtering for IPv6 multicast data on ports FortyGigE 1/1/1 through FortyGigE 1/1/4.
[Sysname-mld-snooping] source-deny port fortygige 1/1/1 to fortygige 1/1/4
Use version to specify an MLD snooping version for VLANs.
Use undo version to restore the default.
undo version vlan vlan-list
The MLD snooping version is 1.
MLD-snooping view
You must enable MLD snooping for the specified VLANs before you execute this command.
You can specify the version for the specified VLANs in MLD-snooping view or for a VLAN in VLAN view. For a VLAN, the configuration in MLD-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
# Enable MLD snooping for VLAN 2 through VLAN 10, and specify MLD snooping version 2 for these VLANs.
[Sysname-mld-snooping] version 2 vlan 2 to 10
