- 06 IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
| 05-IGMP commands | 181.31 KB |
igmp last-member-query-interval
igmp other-querier-present-interval
last-member-query-count (IGMP view)
last-member-query-interval (IGMP view)
other-querier-present-interval (IGMP view)
startup-query-count (IGMP view)
startup-query-interval (IGMP view)
The term "interface" in this chapter collectively refers to VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
display igmp group
Use display igmp group to display information about IGMP groups (multicast groups that hosts have joined through IGMP).
display igmp [ vpn-instance vpn-instance-name ] group [ group-address | interface interface-type interface-number ] [ static | verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about IGMP groups on the public network.
group-address: Specifies a multicast group by its address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, the command displays information about all IGMP groups.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about IGMP groups for all interfaces.
static: Specifies IGMP groups that hosts have joined statically. If you do not specify this keyword, the command displays information about IGMP groups that hosts have joined dynamically.
verbose: Displays detailed information.
# Display information about IGMP groups that hosts have joined dynamically joined on the public network.
<Sysname> display igmp group
IGMP groups in total: 3
Vlan-interface1(10.10.1.20):
IGMP groups reported in total: 3
Group address Last reporter Uptime Expires
225.1.1.1 10.10.1.10 00:02:04 00:01:15
225.1.1.2 10.10.1.10 00:02:04 00:01:15
225.1.1.3 10.10.1.10 00:02:04 00:01:15
IGMP groups in total |
Total number of IGMP groups. |
IGMP groups reported in total |
Total number of IGMP groups that the interface joins dynamically. |
Group address |
Multicast group address. |
Last reporter |
Address of the last receiver host that reported its membership to the multicast group. |
Uptime |
Length of time since the multicast group was reported. |
Expire |
Remaining time for the multicast group. If the timer is disabled, this field displays Off. |
# Display detailed information about the IGMP group 225.1.1.1 that hosts have dynamically joined on the public network. In this example, IGMPv3 is running.
<Sysname> display igmp group 225.1.1.1 verbose
IGMP groups reported in total: 1
Group: 225.1.1.1
Uptime: 00:00:34
Expires: Off
Last reporter: 10.10.1.10
Last-member-query-counter: 0
Last-member-query-timer-expiry: Off
Group mode: Exclude
Version1-host-present-timer-expiry: Off
Version2-host-present-timer-expiry: Off
Source list (sources in total: 1):
Source: 10.1.1.1
Uptime: 00:00:03
Expires: 00:04:16
Total number of IGMP groups that hosts attached to the interface have joined dynamically. |
Group |
Uptime |
Expires |
Last reporter |
Address of the last receiver host that reported its membership to this multicast group. |
Last-member-query-counter |
Number of group-specific queries or source-and-group-specific queries sent for the multicast group. |
Remaining time for the last member query timer of the multicast group. If the timer is disabled, this field displays Off. |
Group mode |
Multicast source filtering mode: · Include. · Exclude. This field is displayed only when the switch runs IGMPv3. |
Version1-host-present-timer-expiry |
Remaining time for the IGMPv1 host present timer. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs IGMPv2 or IGMPv3. |
Version2-host-present-timer-expiry |
Remaining time for the IGMPv2 host present timer. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs IGMPv3. |
Source list (sources in total) |
List of multicast sources, and the total number of multicast sources. This field is displayed only when the switch runs IGMPv3. |
Source |
Multicast source address. This field is displayed only when the switch runs IGMPv3. |
Uptime |
Length of time since the multicast source was reported. This field is displayed only when the switch runs IGMPv3. |
Remaining time for the multicast source. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs IGMPv3. |
Number of group-specific queries or group-and-source-specific queries sent for the multicast source and group. This field is displayed only when the switch runs IGMPv3. |
Remaining time for the last member query timer for the multicast source and group. If the timer is disabled, this field displays Off. This field is displayed only when the switch runs IGMPv3. |
# Display information about IGMP groups that hosts have statically joined on the public network.
<Sysname> display igmp group static
Entries in total: 2
Group address Source address Interface Expires
225.1.1.1 0.0.0.0 Vlan1 Never
225.2.2.2 1.1.1.1 Vlan1 Never
Multicast source address. |
Interface name. |
reset igmp group
display igmp interface
Use display igmp interface to display IGMP information for interfaces.
display igmp [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ host ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IGMP information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays IGMP information for all interfaces.
host: Displays information about interfaces enabled with the IGMP host feature. If this keyword is not specified, this command displays IGMP information for interfaces enabled with IGMP and those enabled with the IGMP host feature. For more information about the IGMP host feature, see VXLAN Configuration Guide.
verbose: Displays detailed IGMP information.
# Display detailed IGMP information for VLAN-interface 1 on the public network.
<Sysname> display igmp interface vlan-interface 1 verbose
IGMP is enabled.
IGMP version: 2
Query interval for IGMP: 125s
Other querier present time for IGMP: 255s
Maximum query response time for IGMP: 10s
Last member query interval: 1s
Last member query count: 2
Startup query interval: 31s
Startup query count: 2
General query timer expiry (hh:mm:ss): 00:00:54
Querier for IGMP: 10.10.1.20 (This router)
IGMP activity: 1 join(s), 0 leave(s)
Multicast routing on this interface: Enabled
Robustness: 2
Require-router-alert: Disabled
Fast-leave: Disabled
SSM-mapping: Disabled
Startup-query: Off
Other-querier-present-timer-expiry (hh:mm:ss): --:--:--
# Display detailed IGMP information on the interfaces enabled with IGMP host feature on the public network.
<Sysname> display igmp interface host verbose
Vlan-interface2(20.10.1.20):
IGMP host is enabled.
IGMP version: 2
Version1-querier-present-timer-expiry (hh:mm:ss): --:--:--
Vlan-interface1(10.10.1.20) |
Interface and its IP address. |
Query interval for IGMP |
IGMP general query interval, in seconds. |
Other querier present time for IGMP |
Other querier present interval, in seconds. |
Maximum query response time for IGMP |
Maximum response time for IGMP general queries, in seconds. |
Last member query interval |
IGMP last member query interval, in seconds. |
Number of IGMP group-specific queries or IGMP group-and-source-specific queries sent for the multicast group. |
Startup query interval |
IGMP startup query interval, in seconds. |
Startup query count |
Number of IGMP general queries that the switch sends on startup. |
General query timer expiry |
Remaining time for the IGMP general query time. If the timer is disabled, this field displays Off. |
Querier for IGMP |
IP address of the IGMP querier. This field is not displayed when the switch runs IGMPv1 and the switch is not the IGMP querier. NOTE: In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information. |
No IGMP querier is elected. This field is displayed only when the switch runs IGMPv1 and the switch is not the IGMP querier. NOTE: In IGMPv1, the PIM DR acts as the IGMP querier. You can use the display pim interface command to display PIM information. |
IGMP activity: 1 join(s), 0 leave(s) |
Statistics of IGMP activities: · join(s)—Total number of multicast groups that this interface has joined. · leave(s)—Total number of multicast groups that this interface has left. |
Multicast routing on this interface |
Whether multicast routing and forwarding is enabled. |
Robustness |
Robustness variable of the IGMP querier. |
Require-router-alert |
Whether the feature of dropping IGMP messages without Router-Alert is enabled. |
Fast-leave |
Whether the fast-leave processing feature is enabled. |
SSM-mapping |
Whether the IGMP SSM mapping feature is enabled. |
Startup-query |
Whether the IGMP querier sends IGMP general queries at the startup query interval on startup: · On—The IGMP querier performs the above action. · Off—The IGMP querier does not perform the above action. |
Other-querier-present-timer-expiry |
Remaining time for the other querier present timer. If the timer is disabled, this field displays Off. |
Total number of multicast groups that the interface has joined dynamically. This field is not displayed if the interface does not join multicast groups. |
IGMP host is enabled. |
The IGMP host feature is enabled. |
Remaining time for the IGMPv1 querier present timer. |
Remaining time for the IGMPv2 querier present timer. |
display igmp ssm-mapping
Use display igmp ssm-mapping to display IGMP SSM mappings.
display igmp [ vpn-instance vpn-instance-name ] ssm-mapping group-address
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about the IGMP SSM mappings on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255.
# Display IGMP SSM mappings for the multicast group 232.1.1.1 on the public network.
<Sysname> display igmp ssm-mapping 232.1.1.1
Group: 232.1.1.1
Source list:
1.2.3.4
5.5.5.5
10.1.1.1
100.1.1.10
Table 5 Command output
Group |
Source list |
List of multicast source addresses. |
igmp
Use igmp to enter IGMP view.
Use undo igmp to delete the configurations in IGMP view.
undo igmp [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command applies to the public network.
# Enter IGMP view for the public network.
[Sysname] igmp
[Sysname-igmp]
# Enter IGMP view for VPN instance mvpn.
[Sysname] igmp vpn-instance mvpn
[Sysname-igmp-mvpn]
igmp enable
Use igmp enable to enable IGMP on an interface.
Use undo igmp enable to disable IGMP on an interface.
undo igmp enable
IGMP is disabled on all interfaces.
Interface view
This command takes effect only when IP multicast routing is enabled. If the interface belongs to a VPN instance, make sure IP multicast routing is enabled on the VPN instance.
IGMP configurations on an interface take effect only when IGMP is enabled on the interface.
# Enable IP multicast routing, and enable IGMP on VLAN-interface 100 on the public network.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname-Vlan-interface100] igmp enable
multicast routing
igmp fast-leave
Use igmp fast-leave to enable fast-leave processing on an interface.
Use undo igmp fast-leave to disable fast-leave processing on an interface.
igmp fast-leave [ group-policy acl-number ]
Fast-leave processing is disabled. The IGMP querier sends IGMP group-specific or group-and-source-specific queries after receiving IGMP leave messages.
Interface view
acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the command takes effect only on the multicast groups that the ACL permits. The command takes effect on all multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not contain valid rules.
This feature enables an IGMP querier to send leave notifications to the upstream routers without sending group-specific or group-and-source-specific queries after receiving leave messages.
In an IPv4 basic ACL, the source keyword matches the multicast group address in IGMP leave messages.
If you specify the vpn-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
# Enable fast-leave processing on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp fast-leave
igmp group-policy
Use igmp group-policy to configure a multicast group policy on an interface to control multicast groups that hosts attached to the interface can join.
Use undo igmp group-policy to delete the configured multicast group policy.
igmp group-policy acl-number [ version-number ]
Multicast group policies are not configured on an interface, and hosts attached to the interface can join multicast groups.
Interface view
acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts attached to the interface can join only the multicast groups that the ACL permits. If the specified ACL does not exist or the specified ACL does not contain valid rules, receiver hosts cannot join multicast groups.
version-number: Specifies an IGMP version in the range of 1 to 3. By default, the configured group filter applies to IGMP reports of all versions.
In an IPv4 basic ACL, the source keyword matches the multicast group address in IGMP reports. In an IPv4 advanced ACL, the source and destination keywords match the multicast source address and multicast group address in IGMP reports, respectively. The multicast source address is regarded as 0.0.0.0 for the following IGMP reports:
· IGMPv1 and IGMPv2 reports.
· IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
If you configure the interface as a static member interface for a multicast group or a multicast source and group, this configuration has no effect on the multicast group or the multicast source and group.
# Configure a multicast group policy on VLAN-interface 100 so that hosts attached to VLAN-interface 100 can join only the multicast group 225.1.1.1.
[Sysname] acl number 2005
[Sysname-acl-basic-2005] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2005] quit
[Sysname-Vlan-interface100] igmp group-policy 2005
igmp last-member-query-count
Use igmp last-member-query-count to set the IGMP last member query count on an interface.
Use undo igmp last-member-query-count to restore the default.
igmp last-member-query-count count
The IGMP last member query count equals the IGMP querier's robustness variable.
Interface view
count: Sets an IGMP last member query count in the range of 1 to 255.
This command and the last-member-query-count command have the same function but different effective ranges:
· The last-member-query-count command takes effect on all interfaces.
· The igmp last-member-query-count command takes effect on the current interface.
For an interface, the igmp last-member-query-count command takes priority over the last-member-query-count command.
# Set the IGMP last member query count to 6 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp last-member-query-count 6
Use igmp last-member-query-interval to set the IGMP last member query interval on an interface.
Use undo igmp last-member-query-interval to restore the default.
igmp last-member-query-interval interval
The IGMP last member query interval is 1 second.
Interface view
interval: Sets an IGMP last member query interval in the range of 1 to 25 seconds.
This command and the last-member-query-interval command in IGMP view have the same function but different effective ranges:
· The last-member-query-interval command in IGMP view takes effect on all interfaces.
· The igmp last-member-query-interval command takes effect on the current interface.
For an interface, the igmp last-member-query-interval command takes priority over the last-member-query-interval command in IGMP view.
# Set the IGMP last member query interval to 6 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp last-member-query-interval 6
igmp max-response-time
Use igmp max-response-time to set the maximum response time for IGMP general queries on an interface.
Use undo igmp max-response-time to restore the default.
The maximum response time for IGMP general queries is 10 seconds.
Interface view
time: Sets the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
This command and the max-response-time command in IGMP view have the same function but different effective ranges:
· The max-response-time command in IGMP view takes effect on all interfaces.
· The igmp max-response-time command takes effect on the current interface.
For an interface, the igmp max-response-time command takes priority over the max-response-time command in IGMP view.
# Set the maximum response time for IGMP general queries to 25 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp max-response-time 25
igmp non-stop-routing
Use igmp non-stop-routing to enable IGMP NSR.
Use undo igmp non-stop-routing to disable IGMP NSR.
IGMP NSR is disabled.
# Enable IGMP NSR.
[Sysname] igmp non-stop-routing
Use igmp other-querier-present-interval to set the IGMP other querier present timer on an interface.
Use undo igmp other-querier-present-interval to restore the default.
igmp other-querier-present-interval interval
The IGMP other querier present timer is calculated by using the following formula:
[ IGMP general query interval ] × [ IGMP querier's robustness variable ] + [ maximum response time for IGMP general queries ] / 2.
Interface view
interval: Sets an IGMP other querier present timer in the range of 1 to 31744 seconds.
This command and the other-querier-present-interval command have the same function but different effective ranges:
· The other-querier-present-interval command takes effect on all interfaces.
· The igmp other-querier-present-interval command takes effect on the current interface.
For an interface, the igmp other-querier-present-interval command takes priority over the other-querier-present-interval command.
# Set the IGMP other querier present timer to 125 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp other-querier-present-interval 125
igmp query-interval
Use igmp query-interval to set the IGMP general query interval on an interface.
Use undo igmp query-interval to restore the default.
igmp query-interval interval
The IGMP general query interval is 125 seconds.
Interface view
interval: Sets an IGMP general query interval in the range of 1 to 31744 seconds.
This command and the query-interval command in IGMP view have the same function but different effective ranges:
· The query-interval command in IGMP view takes effect on all interfaces.
· The igmp query-interval command takes effect on the current interface.
For an interface, the igmp query-interval command takes priority over the query-interval command in IGMP view.
# Set the IGMP general query interval to 60 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp query-interval 60
igmp robust-count
Use igmp robust-count to set the IGMP querier's robustness variable on an interface.
Use undo igmp robust-count to restore the default.
The IGMP querier's robustness variable is 2.
Interface view
count: Sets an IGMP querier's robustness variable in the range of 1 to 255.
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases timeout time for multicast groups.
This command and the robust-count command in IGMP view have the same function but different effective ranges:
· The robust-count command in IGMP view takes effect on all interfaces.
· The igmp robust-count command takes effect on the current interface.
For an interface, the igmp robust-count command takes priority over the robust-count command in IGMP view.
# Set the IGMP querier's robustness variable to 5 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp robust-count 5
igmp startup-query-count
Use igmp startup-query-count to set the IGMP startup query count on an interface.
Use undo igmp startup-query-count to restore the default.
igmp startup-query-count count
The IGMP startup query count equals the IGMP querier's robustness variable.
Interface view
count: Sets an IGMP startup query count in the range of 1 to 255.
This command and the startup-query-count command in IGMP view have the same function but different effective ranges:
· The startup-query-count command in IGMP view takes effect on all interfaces.
· The igmp startup-query-count command takes effect on the current interface.
For an interface, the igmp startup-query-count command takes priority over the startup-query-count command in IGMP view.
# Set the IGMP startup query count to 5 on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-count 5
igmp startup-query-interval
Use igmp startup-query-interval to set the IGMP startup query interval on an interface.
Use undo igmp startup-query-interval to restore the default.
igmp startup-query-interval interval
The IGMP startup query interval equals one quarter of the IGMP general query interval.
Interface view
interval: Sets an IGMP startup query interval in the range of 1 to 31744 seconds.
This command and the startup-query-interval command in IGMP view have the same function but different effective ranges:
· The startup-query-interval command in IGMP view takes effect on all interfaces.
· The igmp startup-query-interval command takes effect on the current interface.
For an interface, the igmp startup-query-interval command takes priority over the startup-query-interval command in IGMP view.
# Set the IGMP startup query interval to 100 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] igmp startup-query-interval 100
igmp static-group
Use igmp static-group to configure an interface as a static group member of a multicast group.
Use undo igmp static-group to restore the default.
igmp static-group group-address [ source source-address ]
undo igmp static-group { all | group-address [ source source-address ] }
An interface is not a static group member of multicast groups.
Interface view
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command configures an interface as a static group member of the multicast groups with all multicast source addresses.
all: Specifies all multicast groups that the interface has statically joined.
If the specified multicast address is in the SSM multicast address range, you must specify a multicast source address at the same time. Otherwise, IGMP routing entries cannot be established. No such a restriction exists if the specified multicast group address is not in the SSM multicast address range.
# Configure VLAN-interface 100 as a static group member of the multicast group 224.1.1.1.
[Sysname-Vlan-interface100] igmp static-group 224.1.1.1
# Configure VLAN-interface 100 as a static group member of the multicast source and group (192.168.1.1, 232.1.1.1).
[Sysname-Vlan-interface100] igmp static-group 232.1.1.1 source 192.168.1.1
igmp version
Use igmp version to specify an IGMP version for an interface.
Use undo igmp version to restore the default.
igmp version version-number
undo igmp version
The default IGMP version is 2.
Interface view
# Specify IGMP version 1 for VLAN-interface 100.
[Sysname-Vlan-interface100] igmp version 1
Use last-member-query-count to set the global IGMP last member query count.
Use undo last-member-query-count to restore the default.
The global IGMP last member query count equals the IGMP querier's robustness variable.
IGMP view
This command and the igmp last-member-query-count command have the same function but different effective ranges:
· The last-member-query-count command in IGMP view takes effect on all interfaces.
For an interface, the igmp last-member-query-count command takes priority over the last-member-query-count command in IGMP view.
# Set the global IGMP last member query count to 6 on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-count 6
Use last-member-query-interval to set the global IGMP last member query interval.
Use undo last-member-query-interval to restore the default.
The global IGMP last member query interval is 1 second.
IGMP view
This command and the igmp last-member-query-interval command have the same function but different effective ranges:
# Set the global IGMP last member query interval to 6 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] last-member-query-interval 6
max-response-time (IGMP view)
Use max-response-time to set the global maximum response time for IGMP general queries.
Use undo max-response-time to restore the default.
The global maximum response time for IGMP general queries is 10 seconds.
IGMP view
time: Sets the maximum response time for IGMP general queries in the range of 1 to 3174 seconds.
This command and the igmp max-response-time command have the same function but different effective ranges:
#Set the global maximum response time for IGMP general queries to 25 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] max-response-time 25
Use other-querier-present-interval to set the global IGMP other querier present timer.
Use undo other-querier-present-interval to restore the default.
IGMP view
This command and the igmp other-query-present-interval command have the same function but different effective ranges:
· The igmp other-query-present-interval command takes effect on the current interface.
For an interface, the igmp other-query-present-interval command takes priority over the other-querier-present-interval command.
# Set the global IGMP other querier present timer to 125 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] other-querier-present-interval 125
Use query-interval to set the global IGMP general query interval.
Use undo query-interval to restore the default.
The global IGMP general query interval is 125 seconds.
IGMP view
This command and the igmp query-interval command have the same function but different effective ranges:
# Set the global IGMP general query interval to 60 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] query-interval 60
igmp query-interval
reset igmp group
Use reset igmp group to clear dynamic IGMP group entries.
reset igmp [ vpn-instance vpn-instance-name ] group { all | interface interface-type interface-number { all | group-address [ mask { mask | mask-length } ] [ source-address [ mask { mask | mask-length } ] ] } }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears dynamic IGMP group entries on the public network.
all: Specifies all interfaces (the first all), or all multicast groups (the second all).
group-address: Specifies a multicast group by its address in the range of 224.0.0.0 to 239.255.255.255.
source-address: Specifies a multicast source address. If this argument is not specified, the command deletes dynamic IGMP group entries of all multicast source addresses.
mask: Specifies an address mask. The default is 255.255.255.255.
mask-length: Specifies an address mask length. The default is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
This command might interrupt the multicast information transmission.
# Clear all dynamic IGMP group entries on the public network.
<Sysname> reset igmp group all
# Clear dynamic IGMP group entries for VLAN-interface 100 on the public network.
<Sysname> reset igmp group interface vlan-interface 100 all
# Clear dynamic IGMP group entries for the IGMP group 225.0.0.1 on VLAN-interface 100 on the public network.
<Sysname> reset igmp group interface vlan-interface 100 225.0.0.1
robust-count (IGMP view)
Use robust-count to set the global IGMP querier's robustness variable.
Use undo robust-count to restore the default.
The global IGMP querier's robustness variable is 2.
IGMP view
The IGMP querier's robustness variable defines the number of times to retransmit queries if packet loss occurs. A higher robustness variable makes the IGMP querier more robust, but it increases the timeout time for multicast groups.
This command and the igmp robust-count command have the same function but different effective ranges:
# Set the global IGMP querier's robustness variable to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] robust-count 5
ssm-mapping (IGMP view)
Use ssm-mapping to configure IGMP SSM mappings.
Use undo ssm-mapping to delete IGMP SSM mappings.
ssm-mapping source-address acl-number
undo ssm-mapping { source-address | all }
IGMP SSM mappings are not configured.
IGMP view
acl-number: Specifies a basic ACL number in the range of 2000 to 2999. The specified multicast source is mapped only to multicast groups that the ACL permits. If the ACL does not exist or the ACL does not have valid rules, the specified multicast source is not mapped to multicast groups.
all: Deletes all the IGMP SSM mappings.
# Map the multicast source 125.1.1.1 to the multicast groups in the range of 232.1.1.0/24 on the public network.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 232.1.1.1 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] igmp
[Sysname-igmp] ssm-mapping 125.1.1.1 2001
Use startup-query-count to set the global IGMP startup query count.
Use undo startup-query-count to restore the default.
The global IGMP startup query count equals the IGMP querier's robustness variable.
IGMP view
This command and the igmp startup-query count command have the same function but different effective ranges:
· The igmp startup-query count command takes effect on the current interface.
For an interface, the igmp startup-query count command takes priority over the startup-query-count command in IGMP view.
# Set the global IGMP startup query count to 5 on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-count 5
Use startup-query-interval to set the global IGMP startup query interval.
Use undo startup-query-interval to restore the default.
The global IGMP startup query interval equals one quarter of the IGMP general query interval.
IGMP view
This command and the igmp startup-query-interval command have the same function but different effective ranges:
# Set the global IGMP startup query interval to 100 seconds on the public network.
[Sysname] igmp
[Sysname-igmp] startup-query-interval 100
