06 IP Multicast Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10006 IP Multicast Command Reference
08-Multicast VPN commands
08-Multicast VPN commands 103.02 KB
address-family ipv4 mdt
Use address-family ipv4 mdt to create a BGP IPv4 MDT address family and enter BGP IPv4 MDT address family view.
Use undo address-family ipv4 mdt to delete the BGP IPv4 MDT address family and all configurations in BGP IPv4 MDT address family view.
No BGP IPv4 MDT address family exists.
BGP instance view
Execute this command before you use the peer enable command to enable BGP peers to exchange MDT information. The MDT information includes the IP address of a PE and default-group to which the PE belongs. On a public network running PIM-SSM, the multicast VPN establishes a default-MDT rooted at the PE (multicast source) based on the MDT information.
The configuration made in the BGP IPv4 MDT address family view takes effect only on BGP MDT messages, BGP MDT peers, and BGP MDT peer groups.
# In BGP instance view of the BGP instance default, create a BGP IPv4 MDT address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv4 mdt
[Sysname-bgp-default-mdt]
peer enable (see Layer 3IP Routing Configuration Guide)
data-delay
Use data-delay to set the data-delay period (delay period before the default-MDT switches to the data-MDT).
Use undo data-delay to restore the default.
data-delay delay
undo data-delay
The default setting is 3 seconds.
MD view
delay: Specifies a data-delay period in the range of 1 to 60 seconds.
# Set the data-delay period to 20 seconds in the VPN instance mvpn.
[Sysname] multicast-domain vpn-instance mvpn
[Sysname-md-mvpn] data-delay 20
data-group
Use data-group to configure the data-group address range and the switchover criteria.
Use undo data-group to restore the default.
data-group group-address { mask-length | mask } [ acl acl-number ]
undo data-group
The data-group address range is not configured, and multicast traffic never switches to a data-MDT.
MD view
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
mask-length: Specifies an address mask length in the range of 25 to 32.
mask: Specifies the address mask.
acl acl-number: Specifies an advanced ACL number in the range of 3000 to 3999. I f you specify an ACL, the configured MDT switchover criteria applies to the (S, G) entries that the ACL permits. If you do not specify an ACL, the configured MDT switchover criteria apply to all (S, G) entries. To make the ACL effective, specify the protocol type as IP, and include the source and destination keywords when creating an ACL rule. The source and destination keywords specify a multicast source address range and a multicast group address range, respectively.
On a PE device, the data-group address range must meet the following requirements:
·     It must not include the default-group address of the MD.
·     It must not overlap with the data-group address range of any other MDs.
On different devices, if the public network is not in PIM-SSM mode, the data-group address ranges for different MDs cannot overlap.
If you execute the command multiple times in an MD, the most recent configuration takes effect.
If you configure this command on the device, switchover from the default-MDT to data-MDT will take place when the following conditions are met:
·     The device receives the multicast traffic that has passed the ACL rule filtering.
·     The multicast traffic is maintained for the data-delay period.
# Configure the data-group address range in VPN instance mvpn as 239.1.2.128 to 239.1.2.255.
[Sysname-md-mvpn] data-group 239.1.2.128 25
default-group
Use default-group to specify a default-group address.
Use undo default-group to restore the default.
default-group group-address
undo default-group
The default-group address is not specified.
MD view
group-address: Specifies a default-group address in the range of 224.0.1.0 to 239.255.255.255.
The same default-group address must be used by the MD of the same VPN instance on different PE device. In addition, the default-group address must be different from the default-group address and the data-group address used by other MDs.
# Specify the default-group address as 239.1.1.1 for VPN instance mvpn.
[Sysname-md-mvpn] default-group 239.1.1.1
display bgp routing-table ipv4 mdt
Use display bgp routing-table ipv4 mdt to display BGP MDT routing information.
display bgp routing-table ipv4 mdt [ route-distinguisher route-distinguisher ] [ ip-address [ advertise-info ] ]
route-distinguisher route-distinguisher: Specifies a router distinguisher (RD), a string of 3 to 21 characters. If you do not specify an RD, this command displays BGP MDT routing for all RDs. An RD can be in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
ip-address: Specifies a multicast source address. The ip-address argument represents the IP address of the PE device in the default-MDT. If you do not specify a multicast source, this command displays brief information about BGP MDT routes for all multicast sources.
advertise-info: Displays advertisement information. If you do not specify this keyword, no advertisement information is displayed.
# Display brief information about BGP MDT routes for all multicast sources.
<Sysname> display bgp routing-table ipv4 mdt
 Route distinguisher: 100:1
 Total number of routes: 2
* >  1.1.1.1/32         0.0.0.0                               32768   ?
* >i 2.2.2.2/32         2.2.2.2                    100        0       ?
# Display detailed information about BGP MDT routes for the multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1
 BGP local router ID: 1.1.1.1
 Local AS number: 100
 Total number of routes: 1
 Paths:   1 available, 1 best
 BGP MDT information of source 1.1.1.1:
 Default-group   : 224.1.1.1
 Original nexthop: 0.0.0.0
 AS-path         : (null)
 Origin          : incomplete
 Attribute value : pref-val 32768
 State           : valid, local, best
# Display advertisement information about BGP MDT routes for the multicast source 1.1.1.1.
<Sysname> display bgp routing-table ipv4 mdt 1.1.1.1 advertise-info
 Paths:   1 best
 Default-group: 224.1.1.1
     6.6.6.6
BGP local router ID
ID of the local router.
Status codes
Codes of route status:
·     * – valid—Valid route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the route information:
·     i – IGP—Originated in the AS. The origins of the routes advertised by the network command are IGP.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Learned by some other means. The origins of routes redistributed by IGP are incomplete.
Total number of BGP MDT routes.
Network
Source IP address of the default-MDT.
NextHop
IP address of the next hop.
MED
Attribute value of Multi-Exit-Discrimination (MED).
LocPrf
Local preference value.
PrefVal
Preferred value of a route.
Path/Ogn
AS PATH attribute and ORIGIN attribute:
·     AS_PATH—Records the ASs the packet has passed to avoid routing loops.
·     ORIGIN—Identifies the origin of the BGP MDT routes.
Paths
Number of the BGP MDT routes:
·     availableNumber of valid BGP MDT routes.
·     best—Number of the best BGP MDT routes.
Default-group
Default-group address to which the route belongs.
Peers to which the route has been advertised and total number of peers.
From
IP address of the BGP peer that advertises the route.
Original nexthop
IP address of the original next hop.
If the route is learned from the BGP update message, this field displays the IP address of the next hop that receives the message.
AS-path
AS PATH attribute of the path, recording the ASs that the BGP MDT route has passed to avoid routing loops.
Attribute value
Attributes of the BGP MDT routes:
·     MED—MED value related to destination network.
·     Localpref—Local preferred value.
·     pref-val—Preferred value of the route.
·     pre—Preferred value of the protocol.
Current states:
·     valid—Valid routes.
·     internal—Internal routes.
·     external—External routes.
·     local—Local routes.
·     synchronize—Synchronized routes.
·     best—Best routes.
display multicast-domain data-group receive
Use display multicast-domain data-group receive to display data-group information received by a VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name data-group receive [ brief | [ active | group group-address | sender source-address | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] * ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
brief: Specifies brief information. If you do not specify this keyword, the command displays detailed information.
active: Specifies the data-group that has joined the data-MDT.
group group-address: Specifies a public network multicast group address in the range of 224.0.1.0 to 239.255.255.255.
sender source-address: Specifies a public network multicast source address.
vpn-source-address: Specifies a VPN multicast source address.
mask-length: Specifies a mask length of the specified VPN multicast source/group address, in the range of 0 to 32. The default value is 32.
mask: Specifies a subnet mask of the specified VPN multicast source/group address, 255.255.255.255 by default.
vpn-group-address: Specifies a VPN multicast group address in the range of 224.0.0.0 to 239.255.255.255.
# Display data-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group receive
MD data-group information received by VPN instance: mvpn
Total 2 data-groups for 8 entries
Total 2 data-groups and 8 entries matched
Data-group: 226.1.1.0   Reference count: 4   Active count: 2
  Sender: 172.100.1.1   Active count: 1
    (192.6.1.5, 239.1.1.1)       expires: 00:03:10 active
    (192.6.1.5, 239.1.1.158)     expires: 00:03:10
  Sender:  181.100.1.1, active count: 1
    (195.6.1.2, 239.1.2.12)      expires: 00:03:10 active
    (195.6.1.2, 239.1.2.197)     expires: 00:03:10
Data-group: 229.1.1.0   Reference count: 4   Active count: 2
  Sender: 185.100.1.1   Active count: 1
    (198.6.1.5, 239.1.3.62)      expires: 00:03:10 active
    (198.6.1.5, 225.1.1.109)     expires: 00:03:10
  Sender: 190.100.1.1   Active count: 1
    (200.6.1.2, 225.1.4.80)      expires: 00:03:10 active
    (200.6.1.2, 225.1.4.173)     expires: 00:03:10
# Display brief data-group information received by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group receive brief
Data group: 226.1.1.0   Reference count: 4   Active count: 2
Data group: 229.1.1.0   Reference count: 4   Active count: 2
Data-group information received by VPN instance mvpn.
A total of two data-groups, associated with eight (S, G) entries.
A total of two data-groups are matched, associated with eight (S, G) entries.
Data-group
Data-group address received.
Sender
BGP peer address of the PE device that sent the data-group information.
Reference count
Number of VPN multicast groups referenced by the data-group.
Active count
Number of active VPN multicast groups (multicast groups with active receivers) referenced by the data-group.
expires
Remaining time for the VPN (S, G) entry referenced by the data-group.
display multicast-domain data-group send
Use display multicast-domain data-group send to display data-group information sent by a VPN instance in the MD.
display multicast-domain vpn-instance vpn-instance-name data-group send [ group group-address | reuse interval | vpn-source-address [ mask { mask-length | mask } ] | vpn-group-address [ mask { mask-length | mask } ] ] *
group group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
reuse interval: Specifies an interval during which the data-group address reuses occur, in the range of 1 to 2147483647 seconds.
mask-length: Specifies a mask length of the specified multicast source/group address, in the range of 0 to 32. The default is 32.
# Display data-group information sent by VPN instance mvpn in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group send
MD data-group information sent by VPN instance: mvpn
Total 2 data-groups for 6 entries
Total 2 data-groups and 6 entries matched
  Reference count of 226.1.1.0: 3
    (192.6.1.5, 239.1.1.1)                  switch time: 00:00:21
    (192.6.1.5, 239.1.1.158)                switch time: 00:00:21
    (192.6.1.5, 239.1.2.50)                 switch time: 00:00:05
  Reference count of 226.1.1.1: 3
    (192.6.1.2, 225.1.1.1)                  switch time: 00:00:21
    (192.6.1.2, 225.1.2.50)                 switch time: 00:00:05
    (192.6.1.5, 239.1.1.159)                switch time: 00:00:21
# Display the data-group reuse information sent by VPN instance mvpn within 30 seconds in the MD.
<Sysname> display multicast-domain vpn-instance mvpn data-group send reuse 30
Total 2 data-groups for 3 entries
Total 2 data-groups and 3 entries matched
  Reuse count of 226.1.1.0: 1
  Reuse count of 226.1.1.1: 1
  Reuse count of 226.1.1.2: 1
Data-group information sent by VPN instance mvpn.
A total of two data-groups, associated with six (S, G) entries.
A total of two data-groups are matched, associated with six (S, G) entries.
Number of VPN multicast groups referenced by the sent data-group.
switch time
Switchover time of the VPN (S, G) entry referenced by the data-group.
Number of data-group reuses during the specified length of time.
display multicast-domain default-group
Use display multicast-domain default-group to display default-group information.
display multicast-domain [ vpn-instance vpn-instance-name ] default-group { local | remote }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays default-group information for all VPN instances.
local: Specifies local default-groups.
remote: Specifies remote default-groups.
# Display information about local default-groups for all VPN instances.
<Sysname> display multicast-domain default-group local
MD local default-group information:
 Group address    Source address   Interface     VPN instance
 239.1.1.1        1.1.1.1          MTunnel0      mvpna
 239.2.1.1        1.1.1.1          MTunnel1      mvpnb
 239.3.1.1        --               MTunnel2      mvpnc
# Display information about remote default-groups for all VPN instances.
<Sysname> display multicast-domain default-group remote
MD remote default-group information:
 Group address   Source address  Next hop         VPN instance
 239.1.1.1       1.2.0.1         1.2.0.1          a
 239.1.1.1       1.2.0.2         1.2.0.2          a
 239.1.1.1       1.2.0.3         1.2.0.3          a
 239.1.1.2       1.2.0.1         1.2.0.1          b
 239.1.1.2       1.2.0.2         1.2.0.2          b
 239.1.1.3       1.2.0.1         1.2.0.1          -
Group address
Address of the default-group.
Source address
IP address of the MD source interface, which is used by the MTI as the source address to encapsulate the VPN multicast packets.
MTI interface.
Next hop
VPN instance
VPN instance to which the default-group belongs.
log data-group-reuse
Use log data-group-reuse to enable data-group reuse logging.
Use undo log data-group-reuse to disable data-group reuse logging.
The data-group reuse logging function is disabled.
MD view
# Enable data-group reuse logging in VPN instance mvpn.
[Sysname-md-mvpn] log data-group-reuse
multicast-domain
Use multicast-domain to create the MD for a VPN instance and enter MD view.
Use undo multicast-domain to clear the configurations that are made in MD view for a VPN instance.
undo multicast-domain vpn-instance vpn-instance-name
No MD exists for a VPN instance.
# Create the MD for the VPN instance mvpn and enter MD view.
[Sysname-md-mvpn]
source
Use source to specify the MD source interface.
Use undo source to restore the default.
source interface-type interface-number
undo source
No MD source interface is specified.
MD view
The IP address of the MD source interface must be the same as the source address used for establishing BGP peer relationship. Otherwise, correct routing information cannot be obtained.
# The source interface used for establishing BGP peer relationship is Loopback 1. Specify this interface as the MD source interface for the VPN instance mvpn.
[Sysname-md-mvpn] source loopback 1
