- 06 IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-PIM snooping commands
- 03-Multicast VLAN commands
- 04-Multicast routing and forwarding commands
- 05-IGMP commands
- 06-PIM commands
- 07-MSDP commands
- 08-Multicast VPN commands
- 09-MLD snooping commands
- 10-IPv6 PIM snooping commands
- 11-IPv6 multicast VLAN commands
- 12-IPv6 multicast routing and forwarding commands
- 13-MLD commands
- 14-IPv6 PIM commands
| 01-IGMP snooping commands | 226.63 KB |
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display l2-multicast ip forwarding
display l2-multicast mac forwarding
dot1p-priority (IGMP-snooping view)
entry-limit (IGMP-snooping view)
fast-leave (IGMP-snooping view)
group-policy (IGMP-snooping view)
host-aging-time (IGMP-snooping view)
igmp-snooping general-query source-ip
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping special-query source-ip
last-member-query-interval (IGMP-snooping view)
max-response-time (IGMP-snooping view)
overflow-replace (IGMP-snooping view)
report-aggregation (IGMP-snooping view)
reset igmp-snooping router-port
reset igmp-snooping statistics
router-aging-time (IGMP-snooping view)
source-deny (IGMP-snooping view)
Use display igmp-snooping to display IGMP snooping status.
display igmp-snooping [ global | vlan vlan-id ]
global: Displays the global IGMP snooping status.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094.
If you do not specify a parameter, this command displays the global IGMP snooping status and the IGMP snooping status in all VLANs.
# Display the global IGMP snooping status and the IGMP snooping status for all VLANs.
<Sysname> display igmp-snooping
IGMP snooping information: Global
IGMP snooping: Enabled
Drop-unknown: Disabled
Host-aging-time: 260s
Router-aging-time: 260s
Max-response-time: 10s
Last-member-query-interval: 1s
Report-aggregation: Enabled
Dot1p-priority: --
IGMP snooping information: VLAN 1
Version: 2
Querier: Disabled
Query-interval: 125s
General-query source IP: 1.1.1.1
Special-query source IP: 2.2.2.2
Report source IP: 3.0.0.3
Leave source IP: 1.0.0.1
Dot1p-priority: 2
IGMP snooping information: VLAN 10
Drop-unknown: Enabled
Version: 3
Querier: Disabled
Dot1p-priority: --
IGMP snooping |
IGMP snooping status: · Enabled. · Disabled. |
Drop-unknown |
Status of dropping unknown multicast data: · Enabled. · Disabled. |
Version |
IGMP snooping version. |
Host-aging-time |
Aging timer for the dynamic member port. |
Router-aging-time |
Aging timer for the dynamic router port. |
Max-response-time |
Maximum response time for IGMP general queries. |
Last-member-query-interval |
Interval for sending IGMP group-specific queries. |
Report-aggregation |
Status of IGMP report suppression: · Enabled. · Disabled. |
802.1p priority for IGMP messages. If the priority is not configured, this field displays two hyphens (--). |
Whether the IGMP snooping querier is enabled. |
Interval for sending IGMP general queries. |
Source IP address of IGMP general queries. |
Source IP address of IGMP group-specific queries. |
Source IP address of IGMP reports. |
Source IP address of IGMP leave messages. |
display igmp-snooping group
Use display igmp-snooping group to display dynamic IGMP snooping forwarding entries.
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, the command displays dynamic IGMP snooping forwarding entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command displays dynamic IGMP snooping forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays dynamic IGMP snooping forwarding entries for all VLANs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays dynamic IGMP snooping forwarding entries on the master device.
# Display detailed information about dynamic IGMP snooping forwarding entries for VLAN 2.
<Sysname> display igmp-snooping group vlan 2 verbose
Total 1 entries.
VLAN 2: Total 1 entries.
(0.0.0.0, 224.1.1.1)
Attribute: local port
FSM information: normal
Host slots (0 in total):
Host ports (1 in total):
FGE1/1/2 (00:03:23)
Total 1 entries |
Total number of dynamic IGMP snooping forwarding entries. |
VLAN 2: Total 1 entries |
Total number of dynamic IGMP snooping forwarding entries in VLAN 2. |
(0.0.0.0, 224.1.1.1) |
(S, G) entry, where 0.0.0.0 in the S position means any multicast sources. |
Entry attribute: · global port—The entry has a global port. · local port—The entry has a port that resides on the specified device. · slot—The entry has a port that resides on a device other than the specified device. |
Finite state machine information of the entry: · delete—The entry attributes have been deleted. · dummy—The entry is a new and temporary entry. · no info—No entry exists. · normal—The entry is a correct entry. |
Member IDs of the member devices that have member ports and the total number of the member devices (excluding the specified member device). |
Host ports (1 in total) |
Member ports, and the total number of the member ports. |
(00:03:23) |
Remaining aging time for the dynamic member port. · For a global port, this field is always displayed. · For a non-global port, this field is displayed when on the following conditions exists: ¡ The port is on the specified member device. ¡ The port is on the master device and no member device is specified. |
reset igmp-snooping group
Use display igmp-snooping router-port to display dynamic router port information.
display igmp-snooping router-port [ vlan vlan-id ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays dynamic router port information on the master device in the IRF fabric.
# Display dynamic router port information for VLAN 2.
<Sysname> display igmp-snooping router-port vlan 2
VLAN 2:
Router slots (0 in total):
Router ports (2 in total):
FGE1/1/1 (00:01:30)
FGE1/1/2 (00:00:23)
VLAN 2 |
VLAN ID. |
Router slots (0 in total) |
Member IDs of the member devices that have router ports and the total number of the member devices (excluding the specified member device). |
Router ports (2 in total) |
Dynamic router ports, and the total number of the dynamic router ports. |
(00:01:30) |
Remaining aging time for the dynamic router port. · For a global port, this field is always displayed. · For a non-global port, this field is displayed when on the following conditions exists: ¡ The port is on the specified member device. ¡ The port is on the master device and no member device is specified. |
Use display igmp-snooping static-group to display static IGMP snooping forwarding entries.
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ] [ slot slot-number ]
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, the command displays static IGMP snooping forwarding entries for all multicast groups.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command displays static IGMP snooping forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays static IGMP snooping forwarding entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays static IGMP snooping forwarding entries on the master device in the IRF fabric.
# Display detailed information about static IGMP snooping forwarding entries for VLAN 2.
<Sysname> display igmp-snooping static-group vlan 2 verbose
Total 1 entries.
FGE1/1/2
Total 1 entries |
Total number of static IGMP snooping forwarding entries. |
Total number of static IGMP snooping forwarding entries in VLAN 2. |
Attribute |
FSM information |
Finite state machine information of the entry: · delete—The entry attributes have been deleted. · dummy—The entry is a new temporary entry. · no info—No entry exists. · normal—The entry is a correct entry. |
Host slots (0 in total) |
Use display igmp-snooping static-router-port to display static router port information.
display igmp-snooping static-router-port [ vlan vlan-id ] [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays static router port information on the master device in the IRF fabric.
# Display static router port information for VLAN 2.
<Sysname> display igmp-snooping static-router-port vlan 2
VLAN 2:
FGE1/1/1
FGE1/1/2
Table 5 Command output
VLAN 2 |
VLAN ID. |
Static router ports, and the total number of the static router ports. |
Use display igmp-snooping statistics to display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Display statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> display igmp-snooping statistics
Received IGMP general queries: 0
Received IGMPv1 reports: 0
Received IGMPv2 reports: 19
Received IGMP leaves: 0
Received IGMPv2 specific queries: 0
Sent IGMPv2 specific queries: 0
Received IGMPv3 reports: 1
Received IGMPv3 reports with right and wrong records: 0
Received IGMPv3 specific queries: 0
Received IGMPv3 specific sg queries: 0
Sent IGMPv3 specific queries: 0
Sent IGMPv3 specific sg queries: 0
Received PIMv2 hello: 0
Received error IGMP messages: 19
Table 6 Command output
general queries |
Number of IGMP general queries. |
specific queries |
Number of IGMP group-specific queries. |
reports |
Number of IGMP reports. |
leaves |
Number of IGMP leave messages. |
reports with right and wrong records |
Number of IGMP reports with correct and incorrect records. |
specific sg queries |
Number of IGMP group-and-source-specific queries. |
PIMv2 hello |
Number of PIMv2 hello messages. |
error IGMP messages |
Number of IGMP messages with errors. |
Use display l2-multicast ip to display information about Layer 2 IP multicast groups.
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, the command displays information about all Layer 2 IP multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command displays information about Layer 2 IP multicast groups for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays information about Layer 2 IP multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the Layer 2 IP multicast groups on the master device in the IRF fabric.
# Display information about Layer 2 IP multicast groups for VLAN 2.
<Sysname> display l2-multicast ip vlan 2
Total 1 entries.
VLAN 2: Total 1 IP entries.
Attribute: static, success
FGE1/1/1 (S, SUC)
Table 7 Command output
Total 1 entries |
Total number of Layer 2 IP multicast groups. |
VLAN 2: Total 1 IP entries |
Total number of Layer 2 IP multicast groups in VLAN 2. |
Attribute |
Entry attribute: · dynamic—The entry is created by a dynamic protocol. · static—The entry is created by a static protocol. · pim—The entry is created by PIM. · kernel—The entry is obtained from the kernel. · success—Processing succeeds. · fail—Processing fails. |
(S, SUC) |
Port attribute: · D—Dynamic port. · S—Static port. · P—PIM port. · K—Port obtained from the kernel. · R—Port learned from (*, *) entries. · W—Port learned from (*, G) entries. · SUC—Processing succeeds. · F—Processing fails. · BC—Broadcast port. The TRILL port floods the multicast traffic after the topology changes. |
Use display l2-multicast ip forwarding to display Layer 2 IP multicast group entries.
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
group group-address: Specifies a multicast group by its IP address. If you do not specify a multicast group, the command displays Layer 2 IP multicast group entries for all multicast groups.
source source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command displays Layer 2 IP multicast group entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays Layer 2 IP multicast group entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays Layer 2 IP multicast group entries on the master device in the IRF fabric.
# Display Layer 2 IP multicast group entries for VLAN 2.
<Sysname> display l2-multicast ip forwarding vlan 2
Total 1 entries.
Host ports (3 in total):
FGE1/1/1
FGE1/1/2
FGE1/1/3
Table 8 Command output
Total 1 entries |
Total number of Layer 2 IP multicast group entries. |
Total number of Layer 2 IP multicast group entries in VLAN 2. |
Host ports (3 in total) |
Use display l2-multicast mac to display information about Layer 2 MAC multicast groups.
display l2-multicast mac [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its MAC address. If you do not specify a MAC multicast group, the command displays information about all Layer 2 MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays information about Layer 2 MAC multicast groups for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the Layer 2 MAC multicast groups on the master device in the IRF fabric.
# Display information about Layer 2 MAC multicast groups for VLAN 2.
<Sysname> display l2-multicast mac vlan 2
Total 1 MAC entries.
VLAN 2: Total 1 MAC entries.
MAC group address: 0100-5e01-0101
Attribute: success
FGE1/1/1
Table 9 Command output
Total 1 MAC entries |
Total number of Layer 2 MAC multicast groups. |
VLAN 2: Total 1 MAC entries |
Total number of Layer 2 MAC multicast groups in VLAN 2. |
Attribute |
Entry attribute: · success—Processing succeeds. · fail—Processing fails. |
Use display l2-multicast mac forwarding to display Layer 2 MAC multicast group entries.
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
mac-address: Specifies a MAC multicast group by its MAC address. If you do not specify a MAC multicast group, the command displays Layer 2 MAC multicast group entries for all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays Layer 2 MAC multicast group entries for all VLANs.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays Layer 2 MAC multicast group entries on the master device in the IRF fabric.
# Display Layer 2 MAC multicast group entries for VLAN 2.
<Sysname> display l2-multicast mac forwarding vlan 2
FGE1/1/1
FGE1/1/2
FGE1/1/3
Table 10 Command output
Total number of Layer 2 MAC multicast group entries. |
Total number of Layer 2 MAC multicast group entries in VLAN 2. |
MAC group address |
Address of the MAC multicast group. |
Use dot1p-priority to set the 802.1p priority for IGMP messages globally.
Use undo dot1p-priority to restore the default.
dot1p-priority priority-number
undo dot1p-priority
The 802.1p priority for IGMP messages is not configured.
IGMP-snooping view
priority-number: Sets an 802.1p priority for IGMP messages, in the range of 0 to 7. A higher value means a higher priority.
You can set the 802.1p priority globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the 802.1p priority for IGMP messages to 3 globally.
[Sysname] igmp-snooping
[Sysname-igmp-snooping] dot1p-priority 3
enable (IGMP-snooping view)
Use enable to enable IGMP snooping for VLANs.
Use undo enable to disable IGMP snooping for VLANs.
enable vlan vlan-list
undo enable vlan vlan-list
IGMP snooping is disabled in a VLAN.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094.
You must enable IGMP snooping globally before you enable IGMP snooping for VLANs.
You can enable IGMP snooping for the specified VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the configuration in IGMP-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
# Enable IGMP snooping globally, and enable IGMP snooping for VLAN 2 through VLAN 10.
[Sysname-igmp-snooping] enable vlan 2 to 10
· igmp-snooping
· igmp-snooping enable
Use entry-limit to set the global maximum number of IGMP snooping forwarding entries, including dynamic entries and static entries.
Use undo entry-limit to restore the default.
entry-limit limit
undo entry-limit
The setting is 4294967295.
IGMP-snooping view
limit: Sets the global maximum number of IGMP snooping forwarding entries, in the range of 0 to 4294967295.
# Set the global maximum number of IGMP snooping forwarding entries to 512.
[Sysname-igmp-snooping] entry-limit 512
Use fast-leave to enable fast-leave processing globally.
Use undo fast-leave to disable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled.
IGMP-snooping view
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The value range for the VLAN ID is 1 to 4094. If you do not specify a VLAN, the command takes effect on all VLANs.
The fast-leave processing feature enables the switch to immediately remove a port from the forwarding entry for a multicast group when the port receives a leave message.
You can enable fast-leave processing globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing globally for VLAN 2.
[Sysname-igmp-snooping] fast-leave vlan 2
igmp-snooping fast-leave
Use group-policy to configure a global multicast group policy to control multicast groups that hosts can join.
Use undo group-policy to delete the configured global multicast group policy.
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
Global multicast group policies are not configured, and receiver hosts can join multicast groups.
IGMP-snooping view
acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Receiver hosts can join only the multicast groups that the ACL permits. If the ACL does not exist or the ACL does not contain valid rules, receiver hosts cannot join multicast groups.
In an IPv4 basic ACL, the source keyword matches the multicast group address in IGMP reports. In an IPv4 advanced ACL, the source and destination keywords match the multicast source address and multicast group address in IGMP reports, respectively. The multicast source address is regarded as 0.0.0.0 for the following IGMP reports:
· IGMPv1 and IGMPv2 reports.
· IGMPv3 IS_EX and IGMPv3 TO_EX reports that do not carry multicast source addresses.
If you specify the vpn-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
You can configure different ACL rules on a port in different VLANs. However, for a given VLAN, a newly configured ACL rule overrides the existing one.
This command takes effect only on the multicast groups that a port joins dynamically.
You can configure a multicast group policy globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Globally configure a multicast group policy for VLAN 2 so that the hosts in this VLAN can join only the multicast group 225.1.1.1.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
igmp-snooping group-policy
Use host-aging-time to set the aging timer for dynamic member ports globally.
Use undo host-aging-time to restore the default.
host-aging-time interval
The default setting is 260 seconds.
IGMP-snooping view
interval: Sets an aging timer for dynamic member ports, in the range of 1 to 8097894 seconds.
To avoid mistakenly deleting multicast group members, set the aging timer for dynamic member ports to be greater than the value calculated by using the following formula:
[ IGMP general query interval ] + [ maximum response time for IGMP general queries ]
H3C recommends that you set the aging timer of dynamic member ports to the value calculated by using the following formula:
[ IGMP general query interval ] × 2 + [ maximum response time for IGMP general queries ]
You can set the timer globally for all VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# Set the aging timer for dynamic member ports to 300 seconds globally.
[Sysname-igmp-snooping] host-aging-time 300
igmp-snooping host-aging-time
igmp-snooping
Use igmp-snooping to enable IGMP snooping globally and enter IGMP-snooping view.
Use undo igmp-snooping to disable IGMP snooping globally.
igmp-snooping
undo igmp-snooping
IGMP snooping is globally disabled.
# Enable IGMP snooping globally and enter IGMP-snooping view.
· enable (IGMP-snooping view)
igmp-snooping dot1p-priority
Use igmp-snooping dot1p-priority to set the 802.1p priority for IGMP messages in a VLAN.
Use undo igmp-snooping dot1p-priority to restore the default.
igmp-snooping dot1p-priority priority-number
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command.
You can set the 802.1p priority for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the 802.1p priority for IGMP messages to 3.
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping dot1p-priority 3
· dot1p-priority (IGMP-snooping view)
igmp-snooping drop-unknown
Use igmp-snooping drop-unknown to enable dropping unknown multicast data for a VLAN.
Use undo igmp-snooping drop-unknown to disable dropping unknown multicast data for a VLAN.
Dropping unknown multicast data in a VLAN is disabled, and unknown multicast data is flooded in the VLAN.
VLAN view
You must enable IGMP snooping for a VLAN before you execute this command for the VLAN.
# In VLAN 2, enable IGMP snooping, and enable dropping unknown multicast data.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping drop-unknown
Use igmp-snooping enable to enable IGMP snooping for a VLAN.
Use undo igmp-snooping enable to disable IGMP snooping for a VLAN.
VLAN view
You must enable IGMP snooping globally before you enable IGMP snooping for a VLAN.
You can enable IGMP snooping for a VLAN in VLAN view or for the specified VLANs in IGMP-snooping view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable IGMP snooping globally and for VLAN 2.
[Sysname] vlan 2
· igmp-snooping
Use igmp-snooping fast-leave to enable fast-leave processing on a port.
Use undo igmp-snooping fast-leave to disable fast-leave processing on a port.
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
Fast-leave processing is disabled on a port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
You can enable fast-leave processing for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable fast-leave processing for VLAN 2 on FortyGigE 1/1/1.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] igmp-snooping fast-leave vlan 2
Use igmp-snooping general-query source-ip to configure the source IP address for IGMP general queries.
Use undo igmp-snooping general-query source-ip to restore the default.
igmp-snooping general-query source-ip ip-address
The source IP address of IGMP general queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies an IP address for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and configure 10.1.1.1 as the source IP address of IGMP general queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit
Use igmp-snooping group-limit to set the maximum number of multicast groups that a port can join.
Use undo igmp-snooping group-limit to restore the default.
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
The default setting is 4294967295.
limit: Sets the maximum number of multicast groups that a port can join, in the range of 0 to 4294967295.
# Set the maximum number of multicast groups that FortyGigE 1/1/1 in VLAN 2 can join to 10.
[Sysname-FortyGigE1/1/1] igmp-snooping group-limit 10 vlan 2
Use igmp-snooping group-policy to configure a multicast group policy on a port to control multicast groups that hosts attached to the port can join.
Use undo igmp-snooping group-policy to delete the multicast group policy on a port.
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
Multicast group policies are not configured on a port, and hosts attached to the port can join multicast groups.
acl-number: Specifies an IPv4 basic or advanced ACL by its number in the range of 2000 to 3999. Hosts can join only multicast groups that the ACL permits. If the ACL does not exist or the ACL does not contain valid rules, receiver hosts cannot join multicast groups.
You can configure a multicast group policy for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Configure a multicast group policy for VLAN 2 on FortyGigE 1/1/1 so that hosts attached to the port in VLAN 2 can join only the multicast group 225.1.1.1.
[Sysname-FortyGigE1/1/1] igmp-snooping group-policy 2000 vlan 2
Use igmp-snooping host-aging-time to set the aging timer for dynamic member ports in a VLAN.
Use undo igmp-snooping host-aging-time to restore the default.
igmp-snooping host-aging-time interval
VLAN view
interval: Sets an aging timer for dynamic member ports in a VLAN, in the range of 1 to 8097894 seconds.
You can set the timer for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic member ports to 300 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
· host-aging-time (IGMP-snooping view)
igmp-snooping host-join
Use igmp-snooping host-join to configure a port as a simulated member host for a multicast group.
Use undo igmp-snooping host-join to delete the simulated joining configuration.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not configured as a simulated member host for multicast groups.
group-address: Specifies a multicast group in the range of 224.0.1.0 to 239.255.255.255.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, the command configures the port as a simulated member host for a multicast source and group. If you do not specify a multicast source, the command configures the port as a simulated member host for a multicast group. This option takes effect on IGMPv3 snooping devices.
all: Specifies all multicast groups.
A port configured as a simulated member host ages out like a dynamic member port.
The IGMP version and IGMP snooping version that the simulated member host runs must be the same.
# Configure FortyGigE 1/1/1 as a simulated member host of the multicast source and group (1.1.1.1, 232.1.1.1) in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-FortyGigE1/1/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping last-member-query-interval to set the IGMP last member query interval for a VLAN.
Use undo igmp-snooping last-member-query-interval to restore the default.
igmp-snooping last-member-query-interval interval
The default setting is 1 second.
VLAN view
interval: Sets an IGMP last member query interval in the range of 1 to 25 seconds.
The IGMP last member query interval determines the interval for sending IGMP group-specific queries and the maximum response time for IGMP group-specific queries in a VLAN.
You can set the interval for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the IGMP last member query interval to 3 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
· last-member-query-interval (IGMP-snooping view)
igmp-snooping leave source-ip
Use igmp-snooping leave source-ip to configure a source IP address for IGMP leave messages.
Use undo igmp-snooping leave source-ip to restore the default.
igmp-snooping leave source-ip ip-address
The source IP address of IGMP leave messages is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies a source IP address for IGMP leave messages.
# In VLAN 2, enable IGMP snooping, and configure 10.1.1.1 as the source IP address of IGMP leave messages.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
Use igmp-snooping max-response-time to set the maximum response time for IGMP general queries in a VLAN.
Use undo igmp-snooping max-response-time to restore the default.
igmp-snooping max-response-time interval
The default setting is 10 seconds.
VLAN view
interval: Sets the maximum response time for IGMP general queries, in the range of 1 to 3174 seconds.
To avoid mistakenly deleting multicast group members, set the maximum response time for IGMP general queries to be less than the IGMP general query interval.
You can set the time for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. For a VLAN, the VLAN-specific configuration takes priority over the global configuration.
# In VLAN 2, enable IGMP snooping, and set the maximum response time for IGMP general queries to 5 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
· max-response-time (IGMP-snooping view)
Use igmp-snooping overflow-replace to enable the multicast group replacement feature on a port.
Use undo igmp-snooping overflow-replace to disable the multicast group replacement feature on a port.
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
The multicast group replacement feature is disabled on a port.
You can enable the multicast group replacement feature for a port in interface view or globally for all ports in IGMP-snooping view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable the multicast group replacement feature for VLAN 2 on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] igmp-snooping overflow-replace vlan 2
igmp-snooping querier
Use igmp-snooping querier to enable the IGMP snooping querier.
Use undo igmp-snooping querier to disable the IGMP snooping querier.
The IGMP snooping querier is disabled.
VLAN view
This command takes effect on a sub-VLAN only after you remove the sub-VLAN from the multicast VLAN.
# In VLAN 2, enable IGMP snooping, and enable the IGMP snooping querier.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
· subvlan (multicast VLAN view)
igmp-snooping query-interval
Use igmp-snooping query-interval to set the IGMP general query interval for a VLAN.
Use undo igmp-snooping query-interval to restore the default.
igmp-snooping query-interval interval
The IGMP general query interval in a VLAN is 125 seconds.
VLAN view
interval: Sets an IGMP general query interval in the range of 2 to 31744 seconds.
To avoid mistakenly deleting multicast group members, set the IGMP general query interval to be greater than the maximum response time for IGMP general queries.
# In VLAN 2, enable IGMP snooping, and set the IGMP general query interval to 20 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
· igmp-snooping max-response-time
· igmp-snooping querier
· max-response-time
Use igmp-snooping report source-ip to configure a source IP address for IGMP reports.
Use undo igmp-snooping report source-ip to restore the default.
igmp-snooping report source-ip ip-address
The source IP address of IGMP reports is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies a source IP address for IGMP reports.
# In VLAN 2, enable IGMP snooping, and configure 10.1.1.1 as the source IP address of IGMP reports.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
Use igmp-snooping router-aging-time to set the aging timer for dynamic router ports in a VLAN.
Use undo igmp-snooping router-aging-time to restore the default.
igmp-snooping router-aging-time interval
VLAN view
interval: Sets an aging timer for dynamic router ports in a VLAN, in the range of 1 to 8097894 seconds.
# In VLAN 2, enable IGMP snooping, and set the aging timer for dynamic router ports to 100 seconds.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
· router-aging-time (IGMP-snooping view)
Use igmp-snooping router-port-deny to disable a port from becoming a dynamic router port.
Use undo igmp-snooping router-port-deny to restore the default.
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
A port can become a dynamic router port.
vlan vlan-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN by its ID or a range of VLANs in the form of start-vlan-id to end-vlan-id. The VLAN ID is in the range of 1 to 4094. If you specify VLANs, the command takes effect only when the port belongs to the specified VLANs. If you do not specify a VLAN, the command takes effect on all VLANs to which the port belongs.
# Disable FortyGigE 1/1/1 from becoming a dynamic router port in VLAN 2.
[Sysname-FortyGigE1/1/1] igmp-snooping router-port-deny vlan 2
igmp-snooping source-deny
Use igmp-snooping source-deny to enable multicast source port filtering on a port to discard all multicast data packets.
Use undo igmp-snooping source-deny to disable multicast source port filtering on a port.
Multicast source port filtering is disabled.
You can enable this feature for a port in interface view or for the specified ports in IGMP-snooping view. For a port, the configuration in interface view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# Enable source port filtering for multicast data on FortyGigE 1/1/1.
[Sysname-FortyGigE1/1/1] igmp-snooping source-deny
Use igmp-snooping special-query source-ip to configure a source IP address for IGMP group-specific queries.
Use undo igmp-snooping special-query source-ip to restore the default.
igmp-snooping special-query source-ip ip-address
If the IGMP snooping querier has received IGMP general queries, the source IP address of IGMP group-specific queries is the source IP address of IGMP general queries. Otherwise, the source IP address of IGMP group-specific queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
VLAN view
ip-address: Specifies a source IP address for IGMP group-specific queries.
# In VLAN 2, enable IGMP snooping, and configure 10.1.1.1 as the source IP address of IGMP group-specific queries.
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
Use igmp-snooping static-group to configure a port as a static group member of a multicast group.
Use undo igmp-snooping static-group to delete a static group member.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group { group-address [ source-ip source-address ] vlan vlan-id | all }
A port is not a static group member of multicast groups.
source-ip source-address: Specifies a multicast source by its IP address. If you specify a multicast source, the command configures the port as a static group member for a multicast source and group. If you do not specify a multicast source, the command configures the port as a static group member for a multicast group. This option takes effect on IGMPv3 snooping devices.
all: Specifies all VLANs.
# Configure FortyGigE 1/1/1 as a static group member of the multicast source and group (1.1.1.1, 225.0.0.1) in VLAN 2.
[Sysname] vlan 2
[Sysname-FortyGigE1/1/1] igmp-snooping static-group 225.0.0.1 source-ip 1.1.1.1 vlan 2
Use igmp-snooping static-router-port to configure a port as a static router port.
Use undo igmp-snooping static-router-port to delete a static router port.
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port { all | vlan vlan-id }
A port is not a static router port.
# Configure FortyGigE 1/1/1 as a static router port in VLAN 2.
[Sysname-FortyGigE1/1/1] igmp-snooping static-router-port vlan 2
Use igmp-snooping version to specify an IGMP snooping version.
Use undo igmp-snooping version to restore the default.
igmp-snooping version version-number
The IGMP snooping version in a VLAN is 2.
VLAN view
version-number: Specifies an IGMP snooping version, 2 or 3.
You can specify the version for a VLAN in VLAN view or for the specified VLANs in IGMP-snooping view. For a VLAN, the configuration in VLAN view has the same priority as the configuration in IGMP-snooping view, and the most recent configuration takes effect.
# In VLAN 2, enable IGMP snooping, and specify IGMP snooping version 3.
[Sysname] vlan 2
· version (IGMP-snooping view)
Use last-member-query-interval to set the global IGMP last member query interval.
Use undo last-member-query-interval to restore the default.
The global IGMP last member query is 1 second.
IGMP-snooping view
The IGMP last member query interval determines the interval for sending IGMP group-specific queries and the maximum response time for IGMP group-specific queries.
# Set the IGMP last member query interval to 3 seconds.
[Sysname-igmp-snooping] last-member-query-interval 3
Use max-response-time to set the global maximum response time for IGMP general queries.
Use undo max-response-time to restore the default.
The global maximum response time for IGMP general queries is 10 seconds.
IGMP-snooping view
# Set the global maximum response time for IGMP general queries to 5 seconds.
[Sysname-igmp-snooping] max-response-time 5
Use overflow-replace to enable the multicast group replacement feature globally.
Use undo overflow-replace to disable the multicast group replacement feature globally.
undo overflow-replace [ vlan vlan-list ]
The multicast group replacement feature is disabled globally.
IGMP-snooping view
You can enable the multicast group replacement feature globally for all ports in IGMP-snooping view or for a port in interface view. For a port, the port-specific configuration takes priority over the global configuration.
# Enable the multicast group replacement feature globally for VLAN 2.
[Sysname-igmp-snooping] overflow-replace vlan 2
Use report-aggregation to enable IGMP report suppression.
Use undo report-aggregation to disable IGMP report suppression.
report-aggregation
IGMP report suppression is enabled.
IGMP-snooping view
# Disable IGMP report suppression.
[Sysname-igmp-snooping] undo report-aggregation
Use reset igmp-snooping group to clear dynamic IGMP snooping forwarding entries.
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id ]
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command clears dynamic IGMP snooping forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command deletes dynamic IGMP snooping forwarding entries for all VLANs.
# Clear dynamic IGMP snooping forwarding entries for all multicast groups.
<Sysname> reset igmp-snooping group all
Use reset igmp-snooping router-port to clear dynamic router port information.
reset igmp-snooping router-port { all | vlan vlan-id ]
all: Specifies all dynamic router ports.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command clears dynamic router port information for all VLANs.
# Clear information about all dynamic router ports.
<Sysname> reset igmp-snooping router-port all
Use reset igmp-snooping statistics to clear statistics for the IGMP messages and PIMv2 hello messages learned through IGMP snooping.
# Clear the statistics for all IGMP messages and PIMv2 hello messages learned through IGMP snooping.
<Sysname> reset igmp-snooping statistics
Use router-aging-time to set the global aging timer for dynamic router ports.
Use undo router-aging-time to restore the default.
The global aging timer for dynamic router ports is 260 seconds.
IGMP-snooping view
interval: Sets an aging timer for dynamic router ports, in the range of 1 to 8097894 seconds.
# Set the global aging timer for dynamic router ports to 100 seconds.
[Sysname-igmp-snooping] router-aging-time 100
Use source-deny to enable multicast source port filtering on ports to discard all multicast data packets.
Use undo source-deny to disable multicast source port filtering on ports.
undo source-deny port interface-list
IGMP-snooping view
port interface-list: Specifies a space-separated list of port items. Each item specifies a port by its port type and number or a range of ports in the form of start-interface-type interface-number to end-interface-type interface-number.
You can enable this feature for the specified ports in IGMP-snooping view or for a port in interface view. For a port, the configuration in IGMP-snooping view has the same priority as the configuration in interface view, and the most recent configuration takes effect.
# Enable multicast source port filtering on ports FortyGigE 1/1/1 through FortyGigE 1/1/4.
[Sysname-igmp-snooping] source-deny port fortygige 1/1/1 to fortygige 1/1/4
Use version to specify an IGMP snooping version for VLANs.
Use undo version to restore the default.
undo version vlan vlan-list
The default setting in a VLAN is 2.
IGMP-snooping view
You must enable IGMP snooping for the specified VLANs before you execute this command.
You can specify the version for the specified VLANs in IGMP-snooping view or for a VLAN in VLAN view. For a VLAN, the configuration in IGMP-snooping view has the same priority as the configuration in VLAN view, and the most recent configuration takes effect.
# Enable IGMP snooping for VLAN 2 through VLAN 10, and specify IGMP snooping version 3 for these VLANs.
[Sysname-igmp-snooping] version 3 vlan 2 to 10
