06 IP Multicast Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10006 IP Multicast Command Reference
04-Multicast routing and forwarding commands
04-Multicast routing and forwarding commands 171.23 KB
The term "interface" in this chapter collectively refers to VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
delete ip rpf-route-static
Use delete ip rpf-route-static to delete static multicast routes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes static multicast routes on the public network.
This command deletes static multicast routes, but the undo ip rpf-route-static command deletes a specific static multicast route.
# Delete all static multicast routes on the public network.
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ip rpf-route-static
display mac-address multicast
Use display mac-address multicast to display static multicast MAC address entries.
mac-address: Specifies a multicast MAC address. The MAC address can be any legal multicast MAC address. (A multicast MAC address is the MAC address in which the least significant bit of the most significant octet is 1.)
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. If you do not specify a VLAN, the command displays the static multicast MAC address entries for all VLANs.
multicast: Specifies static multicast MAC address entries.
count: Specifies the number of static multicast MAC address entries. If you specify this keyword, the command displays the number of matching static multicast MAC address entries. If you do not specify this keyword, the command displays the contents of the matching entries rather than the entry count.
This command displays all MAC address table entries, including static multicast and unicast MAC address entries when one of the following conditions exists:
·     You do not specify parameters.
·     You specify either or both of the vlan and count keywords.
# Display the static multicast MAC address entries for VLAN 2.
<Sysname> display mac-address multicast vlan 2
MAC Address      VLAN ID    State            Port/NickName            Aging
0100-0001-0001   2          Multicast        FGE1/1/1                 N
                                             FGE1/1/2
# Display the number of static multicast MAC address entries.
<Sysname> display mac-address multicast count
1 mac address(es) found.
VLAN ID
ID of the VLAN to which the network device identified by the MAC address belongs.
Status of the MAC address. If the multicast MAC address entry is static, this field displays Multicast.
Port/NickName
Outgoing ports or nickname of the Egress RB in a TRILL network for the packet that is sent to the MAC address in this MAC address entry. For more information about the nickname, TRILL, and RB, see TRILL Configuration Guide.
The switch does not support the TRILL function.
Aging
Aging time state. If this entry never expires, this field displays N.
One static multicast MAC address entry is found.
display mrib interface
Use display mrib interface to display information about interfaces maintained by the MRIB.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about interfaces maintained by the MRIB on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays information about all interfaces maintained by the MRIB.
# Display information about all interfaces maintained by the MRIB on the public network.
<Sysname> display mrib interface
 Interface: Vlan-interface1
     Index: 0x00000001
     Current state: up
     MTU: 1500
     Type: BROADCAST
     Protocol: PIM-DM
     PIM protocol state: Enabled
     Address list:
          1. Local address : 8.12.0.2/16
             Remote address: 0.0.0.0
             Reference     : 1
             State         : NORMAL
Interface name.
Index
Index number of the interface.
Current state
Current status of the interface: up or down.
MTU
MTU value.
Interface type:
·     BROADCAST—Broadcast link interface.
·     LOOP—Loopback interface.
·     REGISTER—Register interface.
·     NBMA—NBMA interface.
·     MTUNNEL—Multicast tunnel interface.
For interface Null 0, this field does not display a value.
Protocol
Protocol running on the interface: PIM-DM, PIM-SM, IGMP, or MD.
PIM protocol state
Whether PIM is enabled:
·     Enabled.
·     Disabled.
Address list
Interface address list.
Local address
Local IP address.
Remote address
Remote end IP address. This field is displayed when the interface is vlink type.
Reference
Number of times that the address has been referenced.
Status of the interface address: NORMAL or DEL.
display multicast boundary
Use display multicast boundary to display multicast boundary information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays multicast boundary information on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, the command displays the multicast boundary information of all multicast groups.
mask-length: Specifies an address mask length in the range of 4 to 32. The default is 32.
mask: Specifies an address mask. The default is 255.255.255.255.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays the multicast boundary information on all interfaces.
# Display multicast boundary information for all multicast groups on all interfaces on the public network.
<Sysname> display multicast boundary
 Boundary            Interface
 224.1.1.0/24        Vlan1
 239.2.2.0/24        Vlan2
Boundary
Multicast group that corresponds to the multicast boundary.
Boundary interface that corresponds to the multicast boundary.
multicast boundary
display multicast forwarding df-info
Use display multicast forwarding df-info to display information about the DF for multicast forwarding.
display multicast [ vpn-instance vpn-instance-name ] forwarding df-info [ rp-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about the DF for multicast forwarding on the public network.
rp-address: Specifies an RP of BIDIR-PIM by its IP address.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information about the DF.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the DF for multicast forwarding on the master device.
The router that acts as a DF is the only multicast data forwarder to the RP in a BIDIR-PIM domain.
# Display brief information about the DF for multicast routing on the public network.
<Sysname> display multicast forwarding df-info
Total 1 RP, 1 matched
00001. RP address: 7.11.0.2
     Flags: 0x0
     Uptime: 04:14:40
     RPF interface: Vlan-interface1
     List of 1 DF interface:
       1: Vlan-interface2
# Display detailed information about the DF for multicast routing on the public network.
<Sysname> display multicast forwarding df-info verbose
     MID: 2, Flags: 0x0
     Uptime: 03:37:22
       Product information: 0x7a2f762f, 0x718fee9f, 0x4b82f137, 0x71c32184
       Product information: 0xa567d6fc, 0xadeb03e3
       Tunnel  information: 0xdfb107d4, 0x7aa5d510
       1: Vlan-interface2
          Product information: 0xa986152b, 0xb74a9a2f
          Tunnel  information: 0x297ca208, 0x76985b89
Total number of RPs and total number of matching RPs.
00001
Sequence number of the entry to which the RP is designated.
MID
ID of the entry to which the RP is designated. Each entry to which the RP is designated has a unique MID.
Flags
Entry flag.
This field displays one flag or the sum of multiple flags. In this example, the value 0x0 means that the entry has only one flag 0x0.
The following flags are available for an entry:
·     0x0—The entry is in correct state.
·     0x4—The entry fails to update.
·     0x8—DF interface information fails to update for the entry.
·     0x40—The entry is to be deleted.
·     0x100—The entry is being deleted.
·     0x200—The entry is in GR state.
Uptime
Existence duration for the entry to which the RP is designated.
RPF interface
RPF interface to the RP.
DF interface list.
display multicast forwarding event
Use display multicast forwarding event to display statistics for multicast forwarding events.
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays statistics for the multicast forwarding events on the public network.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays statistics for the multicast forwarding events on the master device.
# Display statistics for the multicast forwarding events on the public network.
<Sysname> display multicast forwarding event
Total entry active event sent: 0
Total entry inactive event sent: 0
Total NoCache event sent: 2
Total NoCache event dropped: 0
Total WrongIF event sent: 0
Total WrongIF event dropped: 0
Total SPT switch event sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
Table 5 Command output
Number of times that the entry-active event has been sent.
Number of times that the entry-inactive event has been sent.
Number of times that the NoCache event has been sent.
Number of times that the NoCache event has been dropped.
Number of times that the WrongIF event has been sent.
Number of times that the WrongIF event has been dropped.
Number of times that the SPT-switch event has been sent.
NoCache rate limit
Rate limit for sending the NoCache event, in pps.
WrongIF rate limit
Rate limit for sending the WrongIF event, in packets per 10 seconds.
Number of times that the registration suppression has timed out in total.
reset multicast forwarding event
display multicast forwarding-table
Use display multicast forwarding-table to display multicast forwarding entries.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number| statistics ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays multicast forwarding entries on the public network.
source-address: Specifies a multicast source address.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255.
mask-length: Specifies an address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
incoming-interface: Specifies the multicast forwarding entries that contain the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the multicast forwarding entries that contain the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that contain the specified interface in the outgoing interface list.
match: Specifies the forwarding entries that contain only the specified interface in the outgoing interface list.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays multicast forwarding entries on the master device.
statistics: Displays statistics for the multicast forwarding entries.
# Display multicast forwarding entries on the public network.
<Sysname> display multicast forwarding-table
Total 1 entry, 1 matched
00001. (172.168.0.2, 227.0.0.1)
     Flags: 0x0
     Incoming interface: Vlan-interface10
          Incoming sub-VLAN: VLAN 11
          Outgoing sub-VLAN: VLAN 12
                             VLAN 13
     List of 1 outgoing interface:
       1: Vlan-interface20
          Sub-VLAN: VLAN 21
                    VLAN 22
     Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Table 6 Command output
Total number of (S, G) entries and total number of matching (S, G) entries.
00001
Sequence number of the (S, G) entry.
(172.168.0.2,227.0.0.1)
(S, G) entry.
Flags
Entry flag.
·     0x1—The entry is in inactive state.
·     0x2—The entry is null.
·     0x8—Outgoing interface information fails to update for the entry.
·     0x10—Data-group information fails to update for the entry.
·     0x20—A register outgoing interface is available.
·     0x80—The entry is in registration suppression state.
·     0x400—The entry has the VLAN interface of the super VLAN.
·     0x800—The entry has the associated ARP entry for the multicast source address.
·     0x2000000—The entry is a BIDIR-PIM forwarding entry.
Uptime
Length of time for which the (S, G) entry has been up.
Timeout in
Length of time in which the (S, G) entry will expire.
Incoming interface
Incoming interface of the (S, G) entry.
Incoming sub-VLAN
Incoming sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Outgoing sub-VLAN
Outgoing sub-VLAN of the super VLAN when the incoming interface of the (S, G) entry is the VLAN interface of this super VLAN.
Outgoing interface list of the (S, G) entry.
Sub-VLAN
Outgoing sub-VLAN of the super VLAN when the outgoing interface of the (S, G) entry is the VLAN interface of this super VLAN.
Number of packets (bytes) that match the (S, G) entry, and number of packets with incoming interface errors.
Number of packets (bytes) that have been forwarded.
reset multicast forwarding-table
display multicast forwarding-table df-list
Use display multicast forwarding-table df-list to display information about the DF list in the multicast forwarding table.
display multicast [ vpn-instance vpn-instance-name ] forwarding-table df-list [ group-address ] [ verbose ] [ slot slot-number ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about the DF list in the multicast forwarding table on the public network.
verbose: Specifies detailed information about the DF list in the multicast forwarding table. If you do not specify this keyword, the command displays brief information about the DF list in the multicast forwarding table.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays information about the DF list in the multicast forwarding table on the master device.
# Display brief information about the DF list in the multicast forwarding table on the public network.
<Sysname> display multicast forwarding-table df-list
00001. (0.0.0.0, 225.0.0.1)
       1: Vlan-interface1
# Display detailed information about the DF list in the multicast forwarding table on the public network.
<Sysname> display multicast forwarding-table df-list verbose
         1: Vlan-interface1
            Product information: 0x347849f6, 0x14bd6837
            Tunnel  information: 0xc4857986, 0x128a9c8f
Table 7 Command output
Total number of entries, and the total number of matching entries.
00001
Sequence number of the entry.
(*, G) entry.
DF interface list.
display multicast routing-table
Use display multicast routing-table to display multicast routing entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays multicast routing entries on the public network.
incoming-interface: Specifies the multicast routing entries that contain the specified incoming interface.
outgoing-interface: Specifies the multicast routing entries that contain the specified outgoing interface.
exclude: Specifies the multicast routing entries that do not contain the specified interface in the outgoing interface list.
include: Specifies the multicast routing entries that contain the specified interface in the outgoing interface list.
match: Specifies the multicast routing entries that contain only the specified interface in the outgoing interface list.
Multicast routing tables are the basis of multicast forwarding. You can display the establishment state of an (S, G) entry by examining the multicast routing table.
# Display multicast routing entries on the public network.
<Sysname> display multicast routing-table
 Total 1 entry
       Uptime: 00:00:28
       Upstream Interface: Vlan-interface1
       List of 2 downstream interfaces
           1:  Vlan-interface2
           2:  Vlan-interface3
Table 8 Command output
Total 1 entry
Total number of (S, G) entries.
00001
(S, G) entry.
Uptime
Upstream Interface
Upstream interface of the (S, G) entry that multicast packets should arrive at.
List of downstream interfaces that need to forward multicast packets.
reset multicast routing-table
display multicast routing-table static
Use display multicast routing-table static to display static multicast routing entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays static multicast routes on the public network.
mask-length: Specifies an address mask length in the range of 0 to 32.
This command displays information about only valid static multicast routes.
# Display static multicast routing entries on the public network.
<Sysname> display multicast routing-table static
Destinations: 3        Routes: 4
Destination/Mask   Pre  RPF neighbor    Interface
1.1.0.0/16         10   7.12.0.1        Vlan12
                        7.11.0.1        Vlan11
2.2.2.0/24         20   7.11.0.1        Vlan11
3.3.3.3/32         50   7.12.0.1        Vlan12
Table 9 Command output
Destinations
Number of the multicast destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address and mask length.
Pre
Route preference.
RPF neighbor
IP address of the RPF neighbor to the reachable destination.
Outgoing interface to the reachable destination.
display multicast rpf-info
Use display multicast rpf-info to display RPF information for multicast sources.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays RPF information for multicast sources on the public network.
group-address: Specifies a multicast group address in the range of 224.0.1.0 to 239.255.255.255.
# Display the RPF information of multicast source 192.168.1.55 on the public network.
<Sysname> display multicast rpf-info 192.168.1.55
 RPF information about source 192.168.1.55:
     RPF interface: Vlan-interface1, RPF neighbor: 10.1.1.1
     Referenced route/mask: 192.168.1.0/24
     Referenced route type: igp
     Load splitting rule: disable
Table 10 Command output
RPF neighbor
IP address of the RPF neighbor.
Referenced route and its mask length.
Type of the referenced route:
·     igpIGP unicast route.
·     egpEGP unicast route.
·     unicast (direct)—Directly connected unicast route.
·     unicast—Other unicast routes, such as static unicast route.
·     multicast static—Static multicast route.
Rule for RPF route selection:
·     Route preference.
·     Longest prefix match.
Load splitting rule
Status of the load splitting rule: enabled or disabled.
·     display multicast forwarding-table
·     display multicast routing-table
ip rpf-route-static
Use ip rpf-route-static to configure a static multicast route.
Use undo ip rpf-route-static to delete a static multicast route.
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
No static multicast route exists.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command configures a static multicast route on the public network.
rpf-nbr-address: Specifies an RPF neighbor by its IP address.
interface-type interface-number: Specifies an interface by its type and number. The interface connects the RPF neighbor.
preference: Sets a route preference in the range of 1 to 255. The default value is 1.
In the same multicast source address range, you can configure up to 16 RPF neighbors.
When you specify an RPF neighbor on a Layer 3 interface, you must specify the rpf-nbr-address argument rather than the interface-type interface-number argument. Layer 3 interfaces include Layer 3 Ethernet, Layer 3 aggregate, Loopback, and VLAN interfaces.
The configured static multicast route might not take effect due to one of the following reasons:
·     The outgoing interface iteration fails.
·     The specified interface is not in the public network or the same VPN instance as the current interface.
·     The specified interface is not a point-to-point interface.
·     The specified interface is in down state.
If multiple static multicast routes within the same multicast source address range are available, only the one with the highest route preference can become active. Therefore, after you configure a static multicast route, use the display multicast routing-table static command to verify that the configured static multicast route has taken effect.
The undo ip rpf-route-static command deletes the specified static multicast route, but the delete ip rpf-route-static command deletes all static multicast routes.
# On the public network, configure a static multicast route to the multicast source groups 10.1.1.1/24, and specify a router with the IP address of 192.168.1.23 as its RPF neighbor.
[Sysname] ip rpf-route-static 10.1.1.1 24 192.168.1.23
·     delete ip rpf-route-static
·     display multicast routing-table static
load-splitting (MRIB view)
Use load-splitting to enable load splitting of multicast traffic.
Use undo load-splitting to restore the default.
undo load-splitting
Load splitting of multicast traffic is disabled.
MRIB view
source: Specifies load splitting on a per-source basis.
source-group: Specifies load splitting both on a per-source basis and on a per-group basis.
This command does not take effect on BIDIR-PIM.
# Enable load splitting of multicast traffic on a per-source basis on the public network.
[Sysname] multicast routing
[Sysname-mrib] load-splitting source
longest-match (MRIB view)
Use longest-match to specify the longest prefix match principle for RPF route selection.
Use undo longest-match to restore the default.
longest-match
undo longest-match
Route preference is used for RPF route selection
MRIB view
# Specify the longest prefix match principle for RPF route selection on the public network.
[Sysname-mrib] multicast longest-match
Use mac-address multicast to configure a static multicast MAC address entry.
Use undo mac-address multicast to delete a static multicast MAC address entry.
In system view:
undo mac-address [ multicast ] [ [ mac-address [ interface interface-list ] ] vlan vlan-id ]
In Ethernet interface view or Layer 2 aggregate interface view:
undo mac-address [ multicast ] mac-address vlan vlan-id
No static multicast MAC address entry is configured.
System view, Ethernet interface view, Layer 2 aggregate interface view
mac-address: Specifies a multicast MAC address, in the format H-H-H. The multicast MAC address that can be manually configured in the multicast MAC address entry must be unused. A multicast MAC address is the MAC address in which the least significant bit of the most significant octet is 1.
interface interface-list: Specifies a list of interfaces. You can specify up to four single interfaces, interface ranges, or combinations of both for the list. A single interface takes the form of interface-type interface-number. An interface range takes the form of interface-type interface-number to interface-type interface-number, where the end interface number must be greater than the start interface number.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094. The specified VLAN must exist, and the system gives a prompt if the specified interface does not belong to the VLAN.
You can configure static multicast MAC address entries on the specified interface in system view or on the current interface in interface view.
If you do not specify the multicast keyword, the undo mac-address command deletes all MAC address entries, including static unicast and multicast MAC address entries.
# Create a multicast entry for 0100-0001-0001 in VLAN 2, and configure FortyGigE 1/1/1 through FortyGigE 1/1/5 in VLAN 2 as outgoing ports.
[Sysname] mac-address multicast 0100-0001-0001 interface fortygige 1/1/1 to fortygige 1/1/5 vlan 2
# Configure a multicast entry for 0100-0001-0001 on FortyGigE 1/1/1 in VLAN 2.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] mac-address multicast 0100-0001-0001 vlan 2
multicast boundary
Use multicast boundary to configure a multicast forwarding boundary.
Use undo multicast boundary to remove a multicast forwarding boundary.
undo multicast boundary { group-address { mask-length | mask } | all }
No multicast forwarding boundary is configured.
Interface view
all: Specifies all forwarding boundaries configured on the interface.
A multicast forwarding boundary sets the boundary condition for the multicast groups in the specified address range. If the destination address of a multicast packet matches the set boundary condition, the packet is not forwarded.
You do not need to enable IP multicast routing before executing this command.
An interface can act as a forwarding boundary for multiple multicast groups in different address ranges. To achieve this, use this command on the interface for each multicast address range.
Assume that Set A and Set B are multicast forwarding boundary sets with different address ranges, and B is a subset of A. If B is configured after A, A still takes effect. If A is configured after B, B is removed.
# Configure VLAN-interface 100 as the forwarding boundary of multicast groups in the range of 239.2.0.0/16.
[Sysname-Vlan-interface100] multicast boundary 239.2.0.0 16
multicast forwarding supervlan community
Use multicast forwarding supervlan community to configure multicast forwarding among sub-VLANs of a super VLAN.
Use undo multicast forwarding supervlan community to restore the default.
Multicast data cannot be forwarded among sub-VLANs of the super VLAN.
VLAN interface view
After you execute the multicast forwarding supervlan community command, you must clear all multicast forwarding entries with the super VLAN interface as the incoming interface. Otherwise, this command cannot take effect. To clear the required multicast forwarding entries, use the reset multicast forwarding-table command.
# Configure multicast forwarding among sub-VLANs of the super VLAN 2.
[Sysname-Vlan-interface2] multicast forwarding supervlan community
multicast routing
Use multicast routing to enable IP multicast routing and enter MRIB view.
Use undo multicast routing to disable IP multicast routing.
undo multicast routing [ vpn-instance vpn-instance-name ]
IP multicast routing is disabled.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command enables IP multicast routing on the public network.
Other Layer 3 multicast commands take effect only when IP multicast routing is enabled.
The switch does not forward multicast packets before IP multicast routing is enabled.
# Enable IP multicast routing and enter MRIB view on the public network.
[Sysname-mrib]
# Enable IP multicast routing and enter MRIB view in the VPN instance mvpn.
[Sysname-mrib-mvpn]
Use reset multicast forwarding event to clear statistics for multicast forwarding events.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears statistics for multicast forwarding events on the public network.
# Clear statistics for multicast forwarding events on the public network.
<Sysname> reset multicast forwarding event
Use reset multicast forwarding-table to clear multicast forwarding entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears the multicast forwarding entries on the public network.
incoming-interface: Specifies multicast forwarding entries that contain the specified incoming interface.
all: Specifies all multicast forwarding entries.
When you clear a multicast forwarding entry, the associated multicast routing entry is also cleared.
# Clear multicast forwarding entries for the multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast forwarding-table 225.5.4.3
Use reset multicast routing-table to clear multicast routing entries.
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask | mask-length } ] | incoming-interface interface-type interface-number } * | all }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command clears multicast routing entries on the public network.
incoming-interface: Specifies multicast routing entries that contain the specified incoming interface.
all: Specifies all multicast routing entries.
When you clear a multicast routing entry, the associated multicast forwarding entry is also cleared.
# Clear multicast routing entries for the multicast group 225.5.4.3 on the public network.
<Sysname> reset multicast routing-table 225.5.4.3
