06 IP Multicast Command Reference
HomeSupportSwitchesH3C S7500E-XS Switch SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10006 IP Multicast Command Reference
06-PIM commands
06-PIM commands 257.41 KB
PIM commands 1
auto-rp enable· 1
bidir-pim enable (PIM view) 1
bidir-rp-limit (PIM view) 2
bsm-fragment enable (PIM view) 3
bsr-policy (PIM view) 3
c-bsr (PIM view) 4
c-rp (PIM view) 5
crp-policy (PIM view) 6
display interface register-tunnel 7
display pim bsr-info· 10
display pim claimed-route· 11
display pim c-rp· 12
display pim df-info· 14
display pim interface· 15
display pim neighbor 17
display pim routing-table· 19
display pim rp-info· 21
display pim statistics 23
hello-option dr-priority (PIM view) 24
hello-option holdtime (PIM view) 25
hello-option lan-delay (PIM view) 26
hello-option neighbor-tracking (PIM view) 27
hello-option override-interval (PIM view) 27
holdtime join-prune (PIM view) 28
jp-pkt-size (PIM view) 29
pim·· 29
pim bfd enable· 30
pim bsr-boundary· 31
pim dm·· 31
pim hello-option dr-priority· 32
pim hello-option holdtime· 33
pim hello-option lan-delay· 33
pim hello-option neighbor-tracking· 34
pim hello-option override-interval 35
pim holdtime join-prune· 36
pim neighbor-policy· 36
pim non-stop-routing· 37
pim passive· 38
pim require-genid· 38
pim sm·· 39
pim state-refresh-capable· 40
pim timer graft-retry· 40
pim timer hello· 41
pim timer join-prune· 41
pim triggered-hello-delay· 42
register-policy (PIM view) 43
register-whole-checksum (PIM view) 44
source-lifetime (PIM view) 44
source-policy (PIM view) 45
spt-switch-threshold (PIM view) 45
ssm-policy (PIM view) 46
state-refresh-interval (PIM view) 47
state-refresh-rate-limit (PIM view) 48
state-refresh-ttl (PIM view) 48
static-rp (PIM view) 49
timer hello (PIM view) 50
timer join-prune (PIM view) 51
PIM commands
The term "interface" in this chapter collectively refers to VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
auto-rp enable
Use auto-rp enable to enable Auto-RP listening.
Use undo auto-rp enable to disable Auto-RP listening.
auto-rp enable
undo auto-rp enable
Auto-RP listening is disabled.
PIM view
# Enable Auto-RP listening on the public network.
[Sysname] pim
[Sysname-pim] auto-rp enable
Use bidir-pim enable to enable BIDIR-PIM.
Use undo bidir-pim enable to disable BIDIR-PIM.
bidir-pim enable
BIDIR-PIM is disabled.
PIM view
This command takes effect only when IP multicast routing is enabled.
# Enable IP multicast routing on the public network, and enable BIDIR-PIM.
[Sysname] multicast routing
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim] bidir-pim enable
multicast routing
Use bidir-rp-limit to configure the maximum number of BIDIR-PIM RPs.
Use undo bidir-rp-limit to restore the default.
bidir-rp-limit limit
undo bidir-rp-limit
The maximum number of BIDIR-PIM RPs is 6.
PIM view
limit: Sets the maximum number of RPs in BIDIR-PIM, in the range of 1 to 32.
In a BIDIR-PIM domain, one DF election per RP is implemented on all PIM-enabled interfaces. To avoid unnecessary DF elections, H3C recommends not configuring multiple RPs for BIDIR-PIM.
This command sets a limit on the number of BIDIR-PIM RPs. If the number of RPs exceeds the limit, excess RPs do not take effect and can be used only for DF election rather than multicast data forwarding.
# Set the maximum number of BIDIR-PIM RPs to 3 on the public network.
[Sysname] pim
[Sysname-pim] bidir-rp-limit 3
Use bsm-fragment enable to enable bootstrap message (BSM) semantic fragmentation.
Use undo bsm-fragment enable to disable BSM semantic fragmentation.
bsm-fragment enable
BSM semantic fragmentation is enabled.
PIM view
Disable BSM semantic fragmentation if the PIM-SM domain contains a device that does not support this feature.
# Disable BSM semantic fragmentation on the public network.
[Sysname] pim
[Sysname-pim] undo bsm-fragment enable
Use bsr-policy to configure a BSR policy to define the legal bootstrap router (BSR) address range.
Use undo bsr-policy to remove the configuration.
bsr-policy acl-number
undo bsr-policy
BSR policies are not configured, and all bootstrap messages are regarded legal.
PIM view
acl-number: Specifies an IPv4 basic ACL by its number in the range of 2000 to 2999.
You can use this command to guard against BSR spoofing.
In an IPv4 basic ACL, the source keyword matches the source address in bootstrap messages.
If you specify the vpn-instance keyword in an ACL rule, the rule does not take effect. The other optional parameters except the time-range and the fragment keywords in the ACL rule are ignored.
# On the public network, configure a BSR policy so that only the devices on the subnet 10.1.1.0/24 can act as the BSR.
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.1.1.0 0.0.0.255
[Sysname-acl-basic-2000] quit
[Sysname] pim
[Sysname-pim] bsr-policy 2000
c-bsr (PIM view)
c-bsr (PIM view)
Use c-bsr to configure a candidate-BSR (C-BSR).
Use undo c-bsr to delete a C-BSR.
c-bsr ip-address [ scope group-address { mask-length | mask } ] [ hash-length hash-length | priority priority ] *
undo c-bsr ip-address [ scope group-address { mask-length | mask } ]
No C-BSR is configured.
PIM view
ip-address: Specifies the IP address of a C-BSR.
scope group-address: Specifies a multicast group address by its IP address in the range of 239.0.0.0 to 239.255.255.255. If you do not specify a multicast group, the command designates the C-BSR to the global-scoped zone.
mask-length: Specifies an address mask length in the range of 8 to 32.
mask: Specifies an address mask.
hash-length hash-length: Specifies a hash mask length in the range of 0 to 32. The default setting is 30.
priority priority: Sets a C-BSR priority in the range of 0 to 255. The default setting is 64. A larger value represents a higher priority.
The IP address of a C-BSR must be the IP address of a local PIM enabled interface on the C-BSR. Otherwise, the configuration does not take effect.
If you execute this command for a zone multiple times, the most recent configuration takes effect.
You can configure the same C-BSR for different zones.
# Configure the interface with the IP address of 1.1.1.1 as the C-BSR for the global-scoped zone on the public network.
[Sysname] pim
[Sysname-pim] c-bsr 1.1.1.1
c-rp (PIM view)
Use c-rp to configure a candidate-RP (C-RP).
Use undo c-rp to remove the configuration of a C-RP.
c-rp ip-address [ advertisement-interval adv-interval | group-policy acl-number | holdtime hold-time | priority priority ] * [ bidir ]
undo c-rp ip-address
No C-RPs are configured.
PIM view
ip-address: Specifies the IP address of a C-RP.
advertisement-interval adv-interval: Sets a C-RP advertisement interval in the range of 1 to 65535 seconds. The default value is 60 seconds.
group-policy acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. The C-RP is designated only to IPv4 multicast group ranges that the ACL permits. The C-RP is designated to all IPv4 multicast groups 224.0.0.0/4 when the one of the following conditions exists:
·     You do not specify an ACL.
·     The specified ACL does not exist.
·     The specified ACL does not have valid rules.
holdtime hold-time: Sets a C-RP lifetime in the range of 1 to 65535 seconds. The default value is 150 seconds.
priority priority: Sets a C-RP priority in the range of 0 to 255. The default setting is 192. A larger value represents a lower priority.
bidir: Specifies BIDIR-PIM. If you do not specify this keyword, the C-RP provides services for PIM-SM.
The IP address of a C-RP must be the IP address of a local PIM enabled interface on the C-RP. Otherwise, the configuration does not take effect.
In an IPv4 basic ACL, the source keyword matches the multicast group range in C-RP advertisement messages, and the other parameters are ignored. To designate a C-RP to multiple multicast ranges, you can configure multiple rules that specify multiple multicast group ranges in the ACL. If a specified range is not a multicast group range, the rule is not valid.
If you execute this command using the same C-RP IP address multiple times, the most recent configuration takes effect.
# On the public network, configure the interface with the IP address of 1.1.1.1 as the C-RP for multicast group ranges 225.1.0.0/16 and 226.2.0.0/16, and set its priority to 10.
[Sysname-acl-basic-2000] rule permit source 225.1.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule permit source 226.2.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] c-rp 1.1.1.1 group-policy 2000 priority 10
Use crp-policy to configure a C-RP policy to define the legal C-RP address range and the multicast group range to which the C-RP is designated.
Use undo crp-policy to remove the configuration.
crp-policy acl-number
undo crp-policy
C-RP policies are not configured, and all received C-RP messages are regarded legal.
PIM view
acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999.
You can use this command to guard against C-RP spoofing.
In an IPv4 advanced ACL, the source and destination keywords match the RP address and multicast group address in C-RP advertisement messages, respectively. If you do not specify the source keyword in rules, all C-RPs are considered to be legal. If you do not specify the destination keyword in rules, the C-RPs are designated to all multicast groups.
When the switch compares the advertisement message against the destination field in the ACL, it uses only the prefix of the multicast group range in the advertisement message. For example, the multicast group range specified in a C-RP advertisement message is 224.1.0.0/16. If the prefix 224.1.0.0 is in the multicast group range specified in the destination field of the ACL, the advertisement message passes the filtering. Otherwise, the advertisement message is discarded.
# On the public network, configure a C-RP policy so that only devices in the address range of 1.1.1.1/24 can be C-RPs for groups in the range of 225.1.1.0/24.
[Sysname] acl number 3000
[Sysname-acl-adv-3000] rule permit ip source 1.1.1.1 0.0.0.255 destination 225.1.1.0 0.0.0.255
[Sysname-acl-adv-3000] quit
[Sysname] pim
[Sysname-pim] crp-policy 3000
c-rp (PIM view)
Use display interface register-tunnel to display register-tunnel interface information.
display interface [ register-tunnel [ interface-number ] ] [ brief [ description | down ] ]
register-tunnel: Displays information about the register-tunnel interface. If you do not specify this keyword, the command displays information about all interfaces.
interface-number: Specifies a register-tunnel interface by its number. The switch has only one register-tunnel interface, and the value for this argument is fixed at 0. The command always displays information about Register-Tunnel 0 when you specify the register-tunnel keyword, regardless of whether you specify an interface number.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
description: Displays the full interface description. If you do not specify this keyword, the command displays only the first 27 characters of the interface description.
down: Displays information about the interfaces in down state and the reasons why the interfaces are down. If you do not specify this keyword, the command displays information about interfaces in all states.
The register-tunnel interface is a virtual interface that is automatically created by the system. You cannot configure it or delete it, but you can display the interface information by using this command.
In the initial stage of multicast source registration, the register-tunnel interface is used to establish a channel between the source-side DR and the RP to transmit multicast register messages. The process of initial source registration is as follows:
1.     After receiving the first multicast data from the source, the source-side DR encapsulates the multicast data into a register message. The register message is forwarded to the RP through the register-tunnel interface.
2.     The register message reaches RP on the register-tunnel interface on the RP. The RP decapsulates the register message and forwards the multicast data to the receiver hosts. At the same time, the RP learns the IP address of the multicast source.
3.     The RP sends a join message toward the multicast source to build an SPT.
4.     After the SPT is built, the multicast data travels to the RP along the SPT rather than through the register-tunnel interface.
# Display detailed information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0
Register-Tunnel0
Current state: UP
Line protocol state: DOWN
Description: Register-Tunnel0 Interface
Bandwidth: 0kbps
Maximum Transmit Unit: 1536
Internet protocol processing: disabled
Physical: Unknown
# Display brief information about Register-Tunnel 0.
<Sysname> display interface register-tunnel 0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
REG0                 UP   --       --
Current state
Physical state of the register-tunnel interface. This field always displays UP.
Line protocol state
Link state of the register-tunnel interface. This field always displays DOWN.
Description of the register-tunnel interface. It is not configurable.
Bandwidth
Expected bandwidth of the register-tunnel interface. It is not configurable.
MTU of the register-tunnel interface. It is not configurable.
IP protocol processing capability. This field always displays disabled.
Physical
Physical type of the register-tunnel interface. This field always displays Unknown.
Average incoming rate in the last 300 seconds. This field always displays 0.
Average outgoing rate in the last 300 seconds. This field always displays 0.
Input
Number of incoming packets, incoming bytes, and discarded packets. This field always displays 0.
Output
Number of outgoing packets, outgoing bytes, and discarded packets. This field always displays 0.
Brief information about Layer 3 interfaces.
Physical state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been administratively shut down. To recover its physical state, use the undo shutdown command.
·     Stby—The interface is a backup interface. To display information about the primary interface, use the display interface-backup command.
If the Protocol field contains "(s)", it means one of the following conditions:
·     The data link protocol state of the interface is up, but no link is present on the interface.
·     The link is created on demand.
Typically, null interfaces or loopback interfaces have this attribute.
Protocol
Protocol connection state of the interface. This field always displays double hyphens (--).
Main IP
IP address of the interface. This field always displays double hyphens (--).
Cause
Causes why the physical state of the interface is down. This field always displays Not connected.
Use display pim bsr-info to display BSR information in the PIM-SM domain.
display pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays BSR information on the public network.
# Display BSR information in the PIM-SM domain on the public network.
<Sysname> display pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 12.12.12.1
       Priority: 64
       Hash mask length: 30
       Uptime: 00:21:56
 Scope: 239.4.0.0/16
     State: Accept Any
     Scope-zone expiry timer: 00:21:12
 Scope: 239.1.0.0/16
     State: Elected
     Bootstrap timer: 00:00:26
     Elected BSR address: 17.1.11.1
       Priority: 64
       Uptime: 02:53:37
     Candidate BSR address: 17.1.11.1
       Priority: 64
 Scope: 239.2.2.0/24
     State: Candidate
     Bootstrap timer: 00:01:56
     Elected BSR address: 61.2.37.1
       Priority: 64
       Uptime: 02:53:32
     Candidate BSR address: 17.1.12.1
       Priority: 64
 Scope: 239.3.3.0/24
     State: Pending
     Bootstrap timer: 00:00:07
     Candidate BSR address: 17.1.13.1
       Priority: 64
Scoped zone aging timer.
Elected BSR address
Address of the elected BSR.
Address of the candidate BSR.
Priority
BSR priority.
Uptime
Length of time the BSR has been up.
Use display pim claimed-route to display information about all routes that PIM uses.
display pim [ vpn-instance vpn-instance-name ] claimed-route [ source-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about all routes that PIM uses on the public network.
source-address: Specifies a multicast source by its IP address. If you do not specify a multicast source, the command displays information about all routes that PIM uses.
# Display information about all routes that PIM uses on the public network.
<Sysname> display pim claimed-route
 RPF-route selecting rule: longest-match
 Route/mask: 7.11.0.0/16 (unicast (direct))
     RPF interface: Vlan-interface2, RPF neighbor: 8.0.0.2
     Total number of (S,G) or (*,G) dependent on this route entry: 4
     (7.11.0.10, 225.1.1.1)
     (7.11.0.10, 226.1.1.1)
     (7.11.0.10, 227.1.1.1)
     (*, 228.1.1.1)
 Route/mask: 7.12.0.0/16 (multicast static)
     RPF interface: Vlan-interface2, RPF neighbor: 8.0.0.3,
     Config NextHop: 8.0.0.5
     Total number of (S,G) or (*,G) dependent on this route entry: 2
     (7.12.0.10, 226.1.1.1)
     (7.12.0.10, 225.1.1.1)
Route/mask
Route entry. Route types in parentheses include:
·     igp—IGP unicast route.
·     egp—EGP unicast route.
·     unicast (direct)—Direct unicast route.
·     unicast—Other unicast route, such as static unicast route.
·     multicast static—Static multicast route.
RPF interface
Name of the RPF interface.
RPF neighbor
IP address of the RPF neighbor.
Config NextHop
Address of the configured next hop. This field is displayed only when the static multicast route is configured with a next hop.
Total number of (S, G) or (*, G) entries dependent on the RPF route and their details.
display pim c-rp
Use display pim c-rp to display C-RP information in the PIM-SM domain.
display pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays information about learned C-RPs on the public network.
local: Specifies local C-RPs. If you do not specify this keyword, the command displays information about all C-RPs.
You can view information about learned C-RPs only on the BSR. On other devices, you can view information about the locally configured C-RPs.
# Display information about learnt C-RPs on the public network.
<Sysname> display pim c-rp
 Scope: non-scoped
     Group/MaskLen: 224.0.0.0/4
       C-RP address             Priority  HoldTime  Uptime    Expires
       1.1.1.1 (local)          192       150       03:01:36  00:02:29
       2.2.2.2                  192       150       1d:13h    00:02:02
     Group/MaskLen: 226.1.1.0/24 [B] Expires: 00:00:33
     Group/MaskLen: 225.1.0.0/16 [B]
       C-RP Address             Priority  HoldTime  Uptime    Expires
       3.3.3.3                  192       150       12w:5d    00:02:05
# Display information about the locally configured C-RPs.
<Sysname> display pim c-rp local
 Candidate RP: 12.12.12.9(Loop1)
     Priority: 192
     HoldTime: 150
     Advertisement interval: 60
     Next advertisement scheduled at: 00:00:48
Group/MaskLen
Multicast group to which the C-RP is designated.
[B]
The C-RP provides services for BIDIR-PIM. If this field is not displayed, the C-RP provides services for PIM-SM.
C-RP address
IP address of the C-RP. If the C-RP resides on the device where the command is executed, this field displays (local) after the address.
HoldTime
C-RP lifetime.
Uptime
Length of time the C-RP has been up:
·     wWeeks.
·     dDays.
·     hHours.
Expires
Remaining lifetime for the C-RP and the multicast group.
Candidate RP
IP address of the locally configured C-RP.
Interval between two advertisement messages sent by the locally configured C-RP.
Remaining time for the locally configured C-RP to send the next advertisement message.
display pim df-info
Use display pim df-info to display the DF information of BIDIR-PIM.
display pim [ vpn-instance vpn-instance-name ] df-info [ rp-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays the DF information of BIDIR-PIM on the public network.
rp-address: Specifies the RP address of BIDIR-PIM.
# Display the DF information of BIDIR-PIM on the public network.
<Sysname> display pim df-info
 RP address: 1.1.0.3
  Interface           State   DF-Pref    DF-Metric  DF-Uptime DF-Address
  Vlan1               Lose    0          0          00:20:13  8.13.0.3
  Vlan2               Win     10         1          00:20:12  7.11.0.1 (local)
Table 5 Command output
DF election state:
·     Win—The interface wins the DF election.
·     Lose—The interface loses the DF election.
·     Offer—The interface is in the initial state of the DF election.
·     Backoff—The interface is acting as the DF, but there are more appropriate devices running for the DF.
If the interface does not participate in the DF election, this field displays a hyphen (-).
DF-Pref
Advertised route preference for DF election.
DF-Metric
Advertised route metric for DF election.
DF-Uptime
Length of time the DF has been up.
DF-Address
IP address of DF. If the DF resides on the device where the command is executed, this field displays (local) after the address.
Use display pim interface to display PIM information for interfaces.
display pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays PIM information on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays PIM information on all interfaces.
verbose: Displays detailed PIM information. If you do not specify this keyword, the command displays brief PIM information.
# Display brief PIM information for all interfaces on the public network.
<Sysname> display pim interface
 Interface         NbrCnt  HelloInt  DR-Pri     DR-Address
 Vlan1             1       30        1          10.1.1.2
 Vlan2             0       30        1          172.168.0.2    (local)
 Vlan3             1       30        1          20.1.1.2
Table 6 Command output
NbrCnt
Number of PIM neighbors.
HelloInt
Interval for sending hello messages.
DR-Pri
DR priority.
DR-Address
IP address of the DR. If the DR resides on the device where the command is executed, this field displays (local) after the address.
# Display detailed PIM information on VLAN-interface 1 on the public network.
<Sysname> display pim interface vlan-interface 1 verbose
 Interface: Vlan-interface1, 10.1.1.1
     PIM version: 2
     PIM mode: Sparse
     PIM DR: 10.1.1.2
     PIM DR Priority (configured): 1
     PIM neighbor count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     PIM BFD: disabled
     PIM passive: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
Table 7 Command output
PIM mode
PIM mode:
·     Dense.
·     Sparse.
PIM DR
Configured DR priority.
PIM neighbor count
Total number of PIM neighbors.
PIM hello interval
Interval between two hello messages.
Negotiated PIM message propagation delay.
Configured PIM message propagation delay.
Negotiated interval for overriding prune messages.
Configured interval for overriding prune messages.
Negotiated neighbor tracking status: enabled or disabled.
Configured neighbor tracking status: enabled or disabled.
Whether the feature of discarding hello messages without Generation_ID is enabled.
PIM neighbor lifetime.
Assert holdtime timer.
Maximum delay for sending hello messages.
PIM J/P interval
Interval between two join/prune messages.
Joined/pruned state holdtime timer.
Whether a PIM domain border is configured.
PIM BFD
Whether PIM is enabled to work with BFD.
PIM passive
Whether PIM passive mode is enabled.
Number of routers that do not use the DR priority field on the subnet where the interface resides.
Number of routers that do not use the LAN delay field on the subnet where the interface resides.
Number of routers that are not enabled with neighbor tracking on the subnet where the interface resides.
Use display pim neighbor to display PIM neighbor information.
display pim [ vpn-instance vpn-instance-name ] neighbor [ neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays PIM neighbor information on the public network.
neighbor-address: Specifies a PIM neighbor by its IP address. If you do not specify a PIM neighbor, the command displays information about all PIM neighbors.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays PIM neighbor information on all interfaces.
verbose: Displays detailed PIM neighbor information. If you do not specify this keyword, the command displays brief PIM neighbor information.
# Display brief information about all PIM neighbors on the public network.
<Sysname> display pim neighbor
 Total Number of Neighbors = 2
 Neighbor        Interface           Uptime   Expires  DR-Priority Mode
 10.1.1.2        Vlan1               02:50:49 00:01:31 1           B
 20.1.1.2        Vlan2               02:49:39 00:01:42 1
# Display detailed information about the PIM neighbor with the IP address 11.110.0.20 on the public network.
<Sysname> display pim neighbor 11.110.0.20 verbose
 Neighbor: 11.110.0.20
     Interface: Vlan-interface3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     Bidirectional PIM: Enabled
Table 8 Command output
Neighbor
IP address of the PIM neighbor.
Interface that connects to the PIM neighbor.
Uptime
Length of time the PIM neighbor has been up.
Expires/Expiry time
Remaining lifetime for the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays never.
DR-Priority/DR Priority
Priority of the PIM neighbor.
Mode
PIM mode. If the PIM mode is BIDIR-PIM, this field displays B. If a PIM mode other than BIDIR-PIM is used, this field is blank.
Generation ID
Generation ID of the PIM neighbor. (A random value represents a status change of the PIM neighbor.)
Holdtime
Lifetime of the PIM neighbor. If the PIM neighbor is always up and reachable, this field displays forever.
LAN delay
Override interval
Interval for overriding prune messages.
Interval for refreshing state. This field is displayed only when the PIM neighbor operates in PIM-DM mode and the state refresh capability is enabled.
Neighbor tracking
Neighbor tracking status: enabled or disabled.
Bidirectional PIM
Whether BIDIR-PIM is enabled.
Use display pim routing-table to display PIM routing entries.
display pim [ vpn-instance vpn-instance-name ] routing-table [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays PIM routing entries on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.0.0 to 239.255.255.255. If you do not specify a multicast group, the command displays PIM routing entries for all multicast groups.
mask-length: Specifies an address mask length in the range of 0 to 32. The default value is 32.
mask: Specifies an address mask. The default value is 255.255.255.255.
flags flag-value: Specifies a flag. If you do not specify a flag, the command displays PIM routing entries that contain all flags. The following lists the values for the flag-value argument and their meanings:
·     2msdp: Specifies PIM routing entries to be contained in the next SA message to notify an MSDP peer.
·     act: Specifies PIM routing entries that have been used for routing data.
·     del: Specifies PIM routing entries to be deleted.
·     exprune: Specifies PIM routing entries that contain outgoing interfaces pruned by other multicast routing protocols.
·     ext: Specifies PIM routing entries that contain outgoing interfaces provided by other multicast routing protocols.
·     loc: Specifies PIM routing entries on the devices that reside on the same subnet as the multicast source.
·     msdp: Specifies PIM routing entries learned from MSDP SA messages.
·     niif: Specifies PIM routing entries that contain unknown incoming interfaces.
·     nonbr: Specifies PIM routing entries with PIM neighbor lookup failure.
·     rpt: Specifies PIM routing entries on the RPT branches where (S, G) prunes have been sent to the RP.
·     spt: Specifies PIM routing entries on the SPT.
·     swt: Specifies PIM routing entries in the process of RPT-to-SPT switchover.
·     wc: Specifies PIM routing entries with wildcards.
fsm: Displays detailed information about the finite state machine.
incoming-interface interface-type interface-number: Specifies an incoming interface. If you do not specify an incoming interface, the command displays PIM routing entries that contain all incoming interfaces.
mode mode-type: Specifies a PIM mode. If you do not specify a PIM mode, the command displays PIM routing entries in all PIM modes. The available PIM modes include:
·     bidir: Specifies BIDIR-PIM.
·     dm: Specifies PIM-DM.
·     sm: Specifies PIM-SM.
·     ssm: Specifies PIM-SSM.
outgoing-interface { exclude | include | match } interface-type interface-number: Specifies an outgoing interface. If you do not specify an outgoing interface, the command displays PIM routing entries that contain all outgoing interfaces. Whether an outgoing interface is contained in the PIM routing entries depends on the following conditions:
·     If you specify an excluded interface, the command displays PIM routing entries that do not contain the specified outgoing interface.
·     If you specify an included interface, the command displays PIM routing entries that contain the specified outgoing interface.
·     If you specify a matching interface, the command displays PIM routing entries that contain only the specified outgoing interface.
# Display PIM routing entries on the public network.
<Sysname> display pim routing-table
 (172.168.0.12, 227.0.0.1)
     RP: 2.2.2.2
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
         1: Vlan-interface2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
Table 9 Command output
Total number of (*, G) entries, and the total number of (S, G) entries.
(S, G) entry.
Protocol
PIM mode.
Flag
Flag of the (S, G) entry or (*, G) entry:
·     ACTThe entry has been used for routing data.
·     DELThe entry will be removed.
·     EXPRUNESome outgoing interfaces are pruned by other multicast routing protocols.
·     EXTThe entry contains outgoing interfaces provided by other multicast routing protocols.
·     LOCThe entry is on a router directly connected to the same subnet with the multicast source.
·     NIIFThe entry contains unknown incoming interfaces.
·     NONBRThe entry has a PIM neighbor lookup failure.
·     RPTThe entry is on an RPT branch where (S, G) prunes have been sent to the RP.
·     SPTThe entry is on the SPT.
·     SWTThe entry is in the process of RPT-to-SPT switchover.
·     WCThe entry contains a wildcard.
Uptime
Length of time since the (S, G) entry or (*, G) entry was installed.
Upstream interface
Upstream (incoming) interface of the (S, G) entry or (*, G) entry.
Upstream neighbor
Upstream neighbor of the (S, G) entry or (*, G) entry.
RPF prime neighbor
RPF neighbor of the (S, G) or (*, G) entry:
·     For a (*, G) entry, if the RPF neighbor is the RP, the field displays NULL.
·     For an (S, G) entry, if the RPF neighbor is a router that directly connects to the multicast source, this field displays NULL.
Information about the downstream interfaces:
·     Total number of downstream interfaces.
·     Names of the downstream interfaces.
·     Protocol type on the downstream interfaces.
·     Uptime of the downstream interfaces.
·     Expiration time of the downstream interfaces.
display pim rp-info
Use display pim rp-info to display RP information in the PIM-SM domain.
display pim [ vpn-instance vpn-instance-name ] rp-info [ group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays RP information on the public network.
group-address: Specifies a multicast group by its IP address in the range of 224.0.1.0 to 239.255.255.255. If you do not specify a multicast group, the command displays RP information for all multicast groups.
# Display RP information for the multicast group 224.0.1.1 on the public network.
<Sysname> display pim rp-info 224.0.1.1
Auto RP address is: 1.1.1.1
     HoldTime: 181
     Uptime: 00:20:19
     Expires: 00:02:42
 BSR RP address is: 2.2.2.2
     Priority: 192
     HoldTime: 150
     Uptime: 03:01:10
     Expires: 00:02:30
 Static RP address is: 3.3.3.5
     Preferred: Yes
     Configured ACL: 2003
 RP mapping for this group is: 3.3.3.5
# Display RP information for all multicast groups on the public network.
Auto RP information:
   RP agent address: 4.4.4.4
       RP address               HoldTime  Uptime    Expires
       1.1.1.1                  181       00:20:19  00:02:42
       1.1.1.2                  181       00:20:19  00:02:42
 BSR RP information:
   Scope: non-scoped
 Static RP information:
       RP address               ACL   Mode    Preferred
       3.3.3.1                  2000  pim-sm  No
       3.3.3.2                  2001  bidir   Yes
       3.3.3.3                  2002  pim-sm  No
       3.3.3.4                        pim-sm  No
       3.3.3.5                  2002  pim-sm  Yes
Table 10 Command output
Auto RP address is
IP address of the Auto-RP.
RP agent address
IP address of the Auto-RP agent.
Group/MaskLen
Multicast group to which the RP is designated.
[B]
The RP provides services for multicast groups in the BIDIR-PIM domain. If this field is not displayed, the RP provides services for groups in the PIM-SM domain.
RP address
IP address of the RP. If the RP resides on the device where the command is executed, this field displays (local) after the address.
Priority
Priority of the RP.
HoldTime
RP lifetime.
Uptime
Length of time the RP has been up.
Expires
Remaining lifetime for the RP.
Preferred
Whether the static RP is preferred.
Configured ACL/ACL
ACL defining the multicast groups to which the static RP is designated.
Mode
RP service mode: PIM-SM or BIDIR-PIM.
IP address of the RP that provides services for the multicast group.
Use display pim statistics to display statistics for PIM packets.
# Display statistics for PIM packets.
<Sysname> display pim statistics
 Received PIM packets: 3295
 Sent PIM packets    : 5975
                Valid       Invalid        Succeeded   Failed
     Hello    : 3128        0              4333        0
     Reg      : 14          0              0           0
     Reg-stop : 0           0              0           0
     JP       : 151         0              561         0
     BSM      : 0           0              1081        0
     Assert   : 0           0              0           0
     Graft    : 0           0              0           0
     Graft-ACK: 0           0              0           0
     C-RP     : 0           0              0           0
     SRM      : 0           0              0           0
     DF       : 0           0              0           0
Table 11 Command output
Total number of received PIM packets.
Sent PIM packets
Total number of sent PIM packets.
Valid
Number of received valid PIM packets.
Invalid
Number of received invalid PIM packets.
Succeeded
Number of valid PIM packets that were sent successfully.
Failed
Number of valid PIM packets that failed to be sent.
Hello
Hello message statistics.
Reg
Register message statistics.
Reg-stop
Register-stop message statistics.
JP
Join/prune message statistics.
BSM
BSM statistics.
Assert
Assert message statistics.
Graft
Graft message statistics.
Graft-ACK
Graft-ACK message statistics.
C-RP
C-RP message statistics.
SRM
State refresh message statistics.
DF
Designated forwarder message statistics.
Use hello-option dr-priority to set the global DR priority.
Use undo hello-option dr-priority to restore the default.
The global DR priority is 1.
PIM view
priority: Sets a DR priority in the range of 0 to 4294967295. A larger value represents a higher priority.
You can set the DR priority for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the global DR priority to 3 on the public network.
[Sysname] pim
[Sysname-pim] hello-option dr-priority 3
Use hello-option holdtime to set the global PIM neighbor lifetime.
Use undo hello-option holdtime to restore the default.
hello-option holdtime time
The global PIM neighbor lifetime is 105 seconds.
PIM view
time: Sets a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, PIM neighbors are always reachable.
You can set the PIM neighbor lifetime for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the global PIM neighbor lifetime to 120 seconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option holdtime 120
Use hello-option lan-delay to set the global PIM message propagation delay on a shared-media LAN.
Use undo hello-option lan-delay to restore the default.
hello-option lan-delay delay
The global PIM message propagation delay on a shared-media LAN is 500 milliseconds.
PIM view
delay: Sets a PIM message propagation delay on a shared-media LAN in the range of 1 to 32767 milliseconds.
You can set the global PIM message propagation delay on a shared-media LAN for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the global PIM message propagation delay on a shared-media LAN to 200 milliseconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option lan-delay 200
·     hello-option override-interval (PIM view)
·     pim hello-option lan-delay
·     pim hello-option override-interval
Use hello-option neighbor-tracking to enable neighbor tracking and disable join message suppression globally.
Use undo hello-option neighbor-tracking to restore the default.
Neighbor tracking is disabled, and join message suppression is enabled.
PIM view
You can enable neighbor tracking for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Enable neighbor tracking globally on the public network.
[Sysname] pim
[Sysname-pim] hello-option neighbor-tracking
Use hello-option override-interval to set the global override interval.
Use undo hello-option override-interval to restore the default.
The global override interval is 2500 milliseconds.
PIM view
interval: Sets an override interval in the range of 1 to 65535 milliseconds.
You can set the override interval for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the global override interval to 2000 milliseconds on the public network.
[Sysname] pim
[Sysname-pim] hello-option override-interval 2000
·     hello-option lan-delay (PIM view)
Use holdtime join-prune to set the global joined/pruned state holdtime timer.
Use undo holdtime join-prune to restore the default.
holdtime join-prune time
The global joined/pruned state holdtime timer is 210 seconds.
PIM view
time: Sets a joined/pruned state holdtime timer in the range of 1 to 65535 seconds.
You can set the joined/pruned state holdtime timer for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
To prevent the upstream neighbors from aging out, you must configure the interval for sending join/prune messages to be less than the joined/pruned state holdtime timer.
# Set the global joined/pruned state holdtime timer to 280 seconds on the public network.
[Sysname] pim
[Sysname-pim] holdtime join-prune 280
·     pim holdtime join-prune
·     timer join-prune (PIM view)
Use jp-pkt-size to set the maximum size of each join/prune message.
Use undo jp-pkt-size to restore the default.
jp-pkt-size size
undo jp-pkt-size
The maximum size of a join/prune message is 8100 bytes.
PIM view
size: Sets the maximum size of each join/prune message, in the range of 100 to 8100 bytes.
# Set the maximum size of each join/prune message to 1500 bytes on the public network.
[Sysname] pim
[Sysname-pim] jp-pkt-size 1500
pim
Use pim to enter PIM view.
Use undo pim to remove all configurations in PIM view.
undo pim [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, you enter public network PIM view.
# Enable IP multicast routing on the public network and enter public network PIM view.
[Sysname-mrib] quit
[Sysname] pim
[Sysname-pim]
# Enable IP multicast routing in VPN instance mvpn and enter PIM view of VPN instance mvpn.
[Sysname-mrib-mvpn] quit
[Sysname] pim vpn-instance mvpn
[Sysname-pim-mvpn]
multicast routing-enable
pim bfd enable
Use pim bfd enable to enable BFD for PIM.
Use undo pim bfd enable to disable BFD for PIM.
pim bfd enable
undo pim bfd enable
BFD is disabled for PIM.
Interface view
This command takes effect only when PIM-DM or PIM-SM is enabled on the interface.
# Enable IP multicast routing on the public network, enable PIM-DM on VLAN-interface 100, and enable BFD for PIM on the interface.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim dm
[Sysname-Vlan-interface100] pim bfd enable
·     pim dm
·     pim sm
pim bsr-boundary
Use pim bsr-boundary to configure a PIM-SM domain border (a bootstrap message boundary).
Use undo pim bsr-boundary to delete the configured PIM-SM domain border.
pim bsr-boundary
No PIM-SM domain border is configured.
Interface view
# Configure VLAN-interface 100 as a PIM-SM domain border.
[Sysname-Vlan-interface100] pim bsr-boundary
·     c-bsr (PIM view)
·     multicast boundary
pim dm
Use pim dm to enable PIM-DM.
Use undo pim dm to disable PIM-DM.
pim dm
undo pim dm
PIM-DM is disabled.
Interface view
This command takes effect only when IP multicast routing is enabled for the public network or the VPN instance to which the interface belongs.
# Enable IP multicast routing on the public network, and enable PIM-DM on VLAN-interface 100.
[Sysname-mrib] quit
multicast routing
Use pim hello-option dr-priority to set the DR priority on an interface.
Use undo pim hello-option dr-priority to restore the default.
pim hello-option dr-priority priority
The DR priority is 1.
Interface view
# Set the DR priority to 3 on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option dr-priority 3
Use pim hello-option holdtime to set the PIM neighbor lifetime on an interface.
Use undo pim hello-option holdtime to restore the default.
pim hello-option holdtime time
The PIM neighbor lifetime is 105 seconds.
Interface view
time: Sets a PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, the PIM neighbor is always reachable.
# Sets the PIM neighbor lifetime to 120 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option holdtime 120
Use pim hello-option lan-delay to set the PIM message propagation delay on a shared-media LAN for an interface.
Use undo pim hello-option lan-delay to restore the default.
pim hello-option lan-delay delay
The PIM message propagation delay is 500 milliseconds.
Interface view
You can set the PIM message propagation delay on a shared-media LAN for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the PIM message propagation delay on a shared-media LAN to 200 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option lan-delay 200
Use pim hello-option neighbor-tracking to enable neighbor tracking and disable join message suppression on an interface.
Use pim hello-option neighbor-tracking disable to disable neighbor tracking on an interface when neighbor tracking is enabled globally.
Use undo pim hello-option neighbor-tracking to restore neighbor tracking on an interface to be consistent with the global setting.
Neighbor tracking is disabled and join message suppression is enabled.
Interface view
# Enable neighbor tracking on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking
# Disable neighbor tracking on VLAN-interface 100 when neighbor tracking is enabled globally on the public network.
[Sysname] pim
[Sysname-pim] quit
[Sysname-Vlan-interface100] pim hello-option neighbor-tracking disable
Use pim hello-option override-interval to set the override interval on an interface.
Use undo pim hello-option override-interval to restore the default.
pim hello-option override-interval interval
The override interval is 2500 milliseconds.
Interface view
# Set the override interval to 2000 milliseconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim hello-option override-interval 2000
Use pim holdtime join-prune to set the joined/pruned state holdtime timer on an interface.
Use undo pim holdtime join-prune to restore the default.
pim holdtime join-prune time
The joined/pruned state holdtime timer is 210 seconds.
Interface view
# Set the joined/pruned state holdtime timer to 280 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim holdtime join-prune 280
·     holdtime join-prune (PIM view)
·     pim timer join-prune
pim neighbor-policy
Use pim neighbor-policy to configure a PIM hello policy to define the legal source address range for hello messages.
Use undo pim neighbor-policy to restore the default.
pim neighbor-policy acl-number
PIM hello policies are not configured, and all hello messages are regarded legal.
Interface view
You can use this command to guard against hello message spoofing.
In an IPv4 basic ACL, the source keyword matches the source address in hello messages.
# Configure a PIM hello policy on VLAN-interface 100 so that only the devices on the 10.1.1.0/24 subnet can become PIM neighbors of this switch.
[Sysname-Vlan-interface100] pim neighbor-policy 2000
Use pim non-stop-routing to enable PIM NSR.
Use undo pim non-stop-routing to disable PIM NSR.
PIM NSR is disabled.
# Enable PIM NSR.
[Sysname] pim non-stop-routing
pim passive
Use pim passive to enable PIM passive mode on an interface.
Use undo pim passive to restore the default.
pim passive
undo pim passive
The PIM passive mode is disabled for an interface.
Interface view
# Enable IP multicast routing on the public network, and enable PIM-DM and PIM passive mode on VLAN-interface 100.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim passive
pim require-genid
Use pim require-genid to enable dropping hello messages without the generation ID options.
Use undo pim require-genid to restore the default.
pim require-genid
Hello messages without the generation ID options are accepted.
Interface view
# Enable VLAN-interface 100 to drop hello messages without the generation ID options.
[Sysname-Vlan-interface100] pim require-genid
pim sm
Use pim sm to enable PIM-SM.
Use undo pim sm to disable PIM-SM.
pim sm
undo pim sm
PIM-SM is disabled.
Interface view
# Enable IP multicast routing on the public network, and enable PIM-SM on VLAN-interface 100.
[Sysname-mrib] quit
[Sysname-Vlan-interface100] pim sm
multicast routing
Use pim state-refresh-capable to enable the state refresh feature on an interface.
Use undo pim state-refresh-capable to disable the state refresh feature.
The state refresh feature is enabled.
Interface view
# Disable state refresh on VLAN-interface 100.
[Sysname-Vlan-interface100] undo pim state-refresh-capable
·     state-refresh-interval (PIM view)
·     state-refresh-rate-limit (PIM view)
·     state-refresh-ttl (PIM view)
Use pim timer graft-retry to set a graft retry timer.
Use undo pim timer graft-retry to restore the default.
pim timer graft-retry interval
The graft retry timer is 3 seconds.
Interface view
interval: Sets a graft retry timer in the range of 1 to 65535 seconds.
# Set the graft retry timer to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer graft-retry 80
pim timer hello
Use pim timer hello to set the hello interval on an interface.
Use undo pim timer hello to restore the default.
pim timer hello interval
The hello interval on an interface is 30 seconds.
Interface view
interval: Sets a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send hello messages.
You can set the hello interval for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
# Set the hello interval to 40 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer hello 40
Use pim timer join-prune to set join/prune interval on an interface.
Use undo pim timer join-prune to restore the default.
pim timer join-prune interval
The join/prune interval on an interface is 60 seconds.
Interface view
interval: Sets a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send join or prune messages.
You can set the join/prune interval for all interfaces in PIM view or for the current interface in interface view. The configuration made in interface view takes priority over the configuration made in PIM view.
The configuration takes effect after the current interval ends.
To prevent the upstream neighbors from aging out, you must configure the join/prune interval to be less than the joined/pruned state holdtime timer.
# Set the join/prune interval to 80 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim timer join-prune 80
Use pim triggered-hello-delay to set the triggered hello delay.
Use undo pim triggered-hello-delay to restore the default.
pim triggered-hello-delay delay
The triggered hello delay is 5 seconds.
Interface view
delay: Sets a triggered hello delay in the range of 1 to 60 seconds.
The triggered hello delay defines the maximum delay for sending a hello message.
# Set the triggered hello delay to 3 seconds on VLAN-interface 100.
[Sysname-Vlan-interface100] pim triggered-hello-delay 3
Use register-policy to configure a PIM register policy.
Use undo register-policy to remove the configured PIM register policy.
register-policy acl-number
PIM register policies are not configured.
PIM view
acl-number: Specifies an IPv4 advanced ACL number in the range of 3000 to 3999. RPs accept register messages that the ACL permits.
In an IPv4 advanced ACL, the source and destination keywords match the multicast source address and multicast group address in register messages, respectively.
# On the public network, configure a PIM register policy to accept only register messages from sources on the subnet of 10.10.0.0/16 for groups on the subnet of 225.1.0.0/16.
[Sysname-acl-adv-3000] rule permit ip source 10.10.0.0 0.0.255.255 destination 225.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] register-policy 3000
Use register-whole-checksum to configure the switch to calculate the checksum based on an entire register message.
Use undo register-whole-checksum to restore the default.
The switch calculates the checksum based on the register message header.
PIM view
# Configure the switch to calculate the checksum based on an entire register message on the public network.
[Sysname] pim
[Sysname-pim] register-whole-checksum
Use source-lifetime to set the multicast source lifetime.
Use undo source-lifetime to restore the default.
source-lifetime time
The multicast source lifetime is 210 seconds.
PIM view
time: Sets a multicast source lifetime in the range of 0 to 31536000 seconds. If you set the value to 0 seconds, multicast sources are never aged out.
# Set the multicast source lifetime to 200 seconds on the public network.
[Sysname] pim
[Sysname-pim] source-lifetime 200
Use source-policy to configure a multicast source policy.
Use undo source-policy to delete the configured multicast source policy.
source-policy acl-number
undo source-policy
Multicast source policies are not configured.
PIM view
acl-number: Specifies an IPv4 basic or advanced ACL number in the range of 2000 to 3999.
In an IPv4 basic ACL, the source keyword matches the source address in multicast data packets. In an IPv4 advanced ACL, the source and destination keywords match the source address and multicast group address in multicast data packets, respectively.
# On the public network, configure a multicast source policy to accept multicast data from the source 10.10.1.2 and to discard multicast data from the source 10.10.1.1.
[Sysname-acl-basic-2000] rule permit source 10.10.1.2 0
[Sysname-acl-basic-2000] rule deny source 10.10.1.1 0
[Sysname] pim
[Sysname-pim] source-policy 2000
Use spt-switch-threshold to configure the switchover to SPT.
Use undo spt-switch-threshold to restore the default.
spt-switch-threshold { immediacy | infinity } [ group-policy acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy acl-number ]
The switch immediately triggers the switchover to SPT after receiving the first multicast packet.
PIM view
immediacy: Triggers the switchover to SPT immediately.
infinity: Disables the switchover to SPT.
group-policy acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. If you specify an ACL, the configuration applies to only the multicast groups that the ACL permits. The configuration applies to all multicast groups when one of the following conditions exists:
CAUTION
CAUTION:
If the switch is an RP, disabling the switchover to SPT might cause multicast traffic forwarding failures on the source-side DR. When disabling the switchover to SPT, be sure you fully understand its impact on your network.
In an IPv4 basic ACL, the source keyword matches multicast group address in multicast packets.
# Disable the switchover to SPT on a receiver-side DR on the public network.
[Sysname] pim
[Sysname-pim] spt-switch-threshold infinity
Use ssm-policy to configure the SSM group range.
Use undo ssm-policy to restore the default.
ssm-policy acl-number
undo ssm-policy
The SSM group range is 232.0.0.0/8.
PIM view
In an IPv4 basic ACL, the source keyword matches the multicast group address in IGMP reports.
You can use this command to define a multicast group address range. If a packet to a multicast group is permitted by the used ACL, the multicast mode for the packet is PIM-SSM. Otherwise, the multicast mode is PIM-SM.
# Configure the SSM group range to be 232.1.0.0/16.
[Sysname-acl-basic-2000] rule permit source 232.1.0.0 0.0.255.255
[Sysname] pim
[Sysname-pim] ssm-policy 2000
Use state-refresh-interval to set the state refresh interval.
Use undo state-refresh-interval to restore the default.
The state refresh interval is 60 seconds.
PIM view
interval: Sets a state refresh interval in the range of 1 to 255 seconds.
# Set the state refresh interval to 70 seconds on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-interval 70
·     pim state-refresh-capable
Use state-refresh-rate-limit to configure the amount of time that the switch waits before receiving a new state refresh message.
Use undo state-refresh-rate-limit to restore the default.
state-refresh-rate-limit time
The switch waits 30 seconds before it receives a new state refresh message.
PIM view
time: Sets an amount of time that the switch waits before receiving a new refresh message, in the range of 1 to 65535 seconds.
# Configure the switch to wait 45 seconds before it receives a new state refresh message on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-rate-limit 45
Use state-refresh-ttl to set the TTL value for state refresh messages.
Use undo state-refresh-ttl to restore the default.
state-refresh-ttl ttl-value
The TTL value of state refresh messages is 255.
PIM view
ttl-value: Sets a TTL value for state refresh messages, in the range of 1 to 255.
# Set the TTL value for state refresh messages to be 45 on the public network.
[Sysname] pim
[Sysname-pim] state-refresh-ttl 45
·     pim state-refresh-capable (PIM view)
static-rp (PIM view)
Use static-rp to configure a static RP.
Use undo static-rp to remove a static RP.
static-rp rp-address [ acl-number | bidir | preferred ] *
undo static-rp rp-address
Static RPs are not configured.
PIM view
rp-address: Specifies the IP address of the static RP. This address must be a real, valid unicast IP address, rather than an address on the 127.0.0.0/8 subnet. For a static RP serving BIDIR-PIM, you can specify a virtual IP address.
acl-number: Specifies an IPv4 basic ACL number in the range of 2000 to 2999. The static RP is designated only to IPv4 multicast groups that the ACL permits. The static RP is designated to all multicast groups when one of the following conditions exists:
·     The specified ACL does not contain valid rules.
bidir: Specifies BIDIR-PIM to which the static RP is designated. If you do not specify this keyword, the PIM mode is PIM-SM.
preferred: Gives priority to the static RP if the static RP and the dynamic RP exist at the same time in the network. The dynamic RP takes effect only if no static RP exists in the network. If you do not specify this keyword, the dynamic RP has priority. The static RP takes effect only if no dynamic RP exists in the network or when the dynamic RP fails.
You do not need to enable PIM on an interface that acts as a static RP.
In an IPv4 basic ACL, the source keyword matches the multicast group address in multicast packets.
When the ACL rules used by a static RP change, new RPs must be elected for all multicast groups.
You can configure multiple static RPs by using this command multiple times. However, if you specify the same static RP address or reference the same ACL in the command, the most recent configuration takes effect. If you configure multiple static RPs for the same multicast group, the static RP with the highest IP address is used.
# On the public network, configure the interface with the IP address of 11.110.0.6 as a static RP for multicast group range 225.1.1.0/24, and give priority to this static RP.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 225.1.1.0 0.0.0.255
[Sysname-acl-basic-2001] quit
[Sysname] pim
[Sysname-pim] static-rp 11.110.0.6 2001 preferred
display pim rp-info
timer hello (PIM view)
Use timer hello to set the global hello interval.
Use undo timer hello to restore the default.
undo timer hello
The global hello interval is 30 seconds.
PIM view
interval: Sets a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the switch does not send hello messages.
# Set the global hello interval to 40 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer hello 40
pim timer hello
Use timer join-prune to set the global join/prune interval.
Use undo timer join-prune to restore the default.
The global join/prune interval is 60 seconds.
PIM view
interval: Sets a join/prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the switch does not send join or prune messages.
To prevent the upstream neighbors from expiring, you must configure the interval for sending join/prune messages to be less than the joined/pruned state holdtime timer.
# Set the global join/prune interval to 80 seconds on the public network.
[Sysname] pim
[Sysname-pim] timer join-prune 80
