H3C S9500 Series Routing Switches Installation Manual-(V2.03)
HomeSupportSwitchesH3C S9500 Series SwitchesInstall & UpgradeInstallation GuidesH3C S9500 Series Routing Switches Installation Manual-(V2.03)
00-1Cover
00-1Cover 61 KB
Installation Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08048H-20071025-C-2.03
Product Version: S9500-CMW520-R2127
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, Adobe Systems, Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
The related manuals are listed in the following table.
Manual
H3C S9500 Series Routing Switches  Operation Manual
It provides an operation guide. It consists of access volume, IP service volume, IP routing volume, IP multicast volume, MPLS/VPN volume, QoS/ACL volume, security volume, system volume, and acronyms.
H3C S9500 Series Routing Switches  Command Manual
It explains all commands available in the S9500 series and provides a list of commands the S9500 series do not support. It consists of the same modules as the operation manual.
Organization
H3C S9500 Series Routing Switches Installation Manual is organized as follows:
Chapter
1 Product Overview
Introduces the appearance, architecture and system features of the S9500 series.
2 Preparing for Installation
Lists the preparations and precautions for the installation.
3 Installing the Switch
Details the installation of the chassis, PSUs, boards and cable connection for the S9500 series.
4 Commissioning the Switch
Concentrates on the initial power-on and booting of the S9500 series.
5 Troubleshooting and Maintaining the Switch
Presents troubleshooting the switch ,the hardware and software upgrade.
6 Appendix A  Cable Management
Introduces how to bind cables.
7 Appendix B Engineering Labels for Cables
Introduces the use of engineering labels.
8 Appendix C Installation of Lightning Arrester for AC Power
Introduces the installation of lightning arrester for AC power of S9500 series routing switches.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
II. GUI conventions
Convention
Button names are inside angle brackets. For example, click <OK>.
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window.
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder].
III. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
Environmental Protection
This product has been designed to comply with the requirements on environmental protection. For the proper storage, use and disposal of this product, national laws and regulations must be observed.
