10-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (532.64 KB)
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 packet-rate
1.2.6 primap color-map-dp
1.2.7 primap pre-defined color
1.2.8 redirect
1.2.9 redirect-default
1.2.10 remark dot1p
1.2.11 remark drop-precedence
1.2.12 remark dscp
1.2.13 remark ip-precedence
1.2.14 remark local-precedence
1.2.15 remark mpls-exp
1.2.16 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos vlan-policy
1.3.9 qos apply policy
1.3.10 qos apply policy global
1.3.11 qos policy
1.3.12 qos vlan-policy
1.3.13 reset qos policy control-plane
1.3.14 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 display qos map-table color
2.1.3 import
2.1.4 qos map-table
2.1.5 qos map-table color
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量监管/流量整形/接口限速
3.1 流量监管配置命令
3.1.1 display car resource
3.2 流量整形配置命令
3.2.1 display qos gts interface
3.2.2 qos gts any
3.2.3 qos gts queue
3.3 接口限速配置命令
3.3.1 display qos lr interface
3.3.2 qos lr
4 硬件实现拥塞管理
4.1 WFQ队列配置命令
4.1.1 display qos wfq interface
4.1.2 qos bandwidth queue
4.1.3 qos wfq weight
4.2 基于类的队列配置命令
4.2.1 queue af
4.2.2 queue ef
4.2.3 queue wfq
4.2.4 weight
4.3 队列调度策略配置命令
4.3.1 display qos qmprofile configuration
4.3.2 display qos qmprofile interface
4.3.3 qos apply qmprofile
4.3.4 qos qmprofile
4.3.5 queue
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.2 WRED表配置命令
5.2.1 display qos wred table
5.2.2 qos wred table
5.2.3 queue
5.2.4 queue weighting-constant
5.2.5 qos wred apply
6 全局CAR
6.1 全局CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car aggregative
6.1.4 reset qos car name
7 报文统计
7.1 报文统计配置命令
7.1.1 display qos traffic-counter
7.1.2 qos traffic-counter
7.1.3 reset qos traffic-counter
8 端口队列统计
8.1 端口队列统计配置命令
8.1.1 display qos queue-statistics interface
9 QoS调度精度增强模式
9.1 QoS调度精度增强模式配置命令
9.1.1 enhanced-qos
10 QPPB
10.1 QPPB配置命令
10.1.1 bgp-policy
11 QoS管道模式配置命令
11.1.1 qos pipe-mode
1 QoS策略
·     设备支持两种运行模式:独立运行模式和IRF模式,缺省情况为独立运行模式。有关IRF模式的介绍,请参见“IRF配置指导”中的“IRF”。
·     本文中的“业务处理板”指的是单板丝印为“CR-SPE-3020-E-I”的单板,“普通型接口板”指的是单板丝印为“CR-SPC-XP8LEF-I/CR-SPC-XP4LEF-I/CR-SPC-GP48LEF/ CR-SPC-GT48LEF”的单板,“增强型接口板”指的是单板丝印为“CR-SPC-PUP4L-E-I /CR-SPC-XP4L-E-I”的单板。
·     除特殊说明外,本文档中所有的接口视图均包含子接口视图。
·     如果主接口包含的所有子接口都没有配置qos lr outboundqos gts anyqueue efqueue afqueue wfqqos wfq weightqos wred applyremark local-precedence,则在其中一个子接口上首次配置qos lr outboundqos gts anyqueue ef bandwidthqueue af bandwidthqueue wfqqos wfq weightqos wred applyremark local-precedence命令时,需要保证对应的主接口上没有配置qos lr outboundqos gts any,否则子接口上将无法配置上述命令。您可以通过undo qos lr outboundundo qos gts any命令取消主接口上的配置。
1.1  定义类的命令
display traffic classifier user-defined [ classifier-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义类。
classifier-name:类名。长度为1~31个字符的字符串。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display traffic classifier命令用来显示配置的类信息。
如果未指定类名,本命令将显示所有用户定义类的信息。
# 显示配置的用户自定义的类信息。
User Defined Classifier Information:
 Classifier: USER1
  Operator: AND
  Rule(s) : If-match ip-precedence 5
 Classifier: database
  Operator: AND
  Rule(s) : If-match acl 3131
表1-1 display traffic classifier user-defined命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule
分类规则
1.1.2  if-match
if-match match-criteria
undo if-match match-criteria
类视图
【缺省级别】
2:系统级
match-criteria:类的匹配规则,取值范围如下表所示。
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~5999,IPv6 ACL序号的取值范围是2000~3999
acl-name是ACL的名称,为1~32个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
在普通型接口板上,QoS策略所引用的类匹配规则如果使用用户自定义ACL,此QoS策略仅能应用在端口的inbound方向,用户自定义ACL才生效
customer-dot1p 8021p-list
定义匹配用户网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配用户网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4094
destination-mac mac-address
定义匹配目的MAC地址的规则
dscp dscp-list
定义匹配DSCP的规则,dscp-list为DSCP取值的列表,最多可以输入8个DSCP取值,DSCP取值范围为0~63
forwarding-layer { bridge | route }
定义匹配转发报文的二、三层属性的规则:bridge表示只匹配二层转发报文,route表示只匹配三层转发报文
在业务处理板和增强型接口板上,不支持此关键字
inbound-interface interface-type interface-number
定义匹配入接口的规则,interface-type interface-number为接口类型和接口编号
·     包含该关键字的QoS策略,仅支持基于控制平面的应用
·     inbound-interface所指定的接口必须与qos apply policy所应用的控制平面所在的槽位一致,否则功能应用失败
·     支持接口类型:ATM、以太网接口、CPOS串口、POS接口
ip-precedence ip-precedence-list
定义匹配IP优先级的规则,ip-precedence-list为ip-precedence的列表,最多可以输入8个ip-precedence,ip-precedence取值范围为0~7
mpls-exp exp-list
定义匹配MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
mpls-label { { label-value-list | label-value1 to label-value2 } [ stack-bottom bottom-value ] | stack-bottom bottom-value }
定义匹配mpls-label和mpls-label栈底标志的规则,label-value-list为mpls-label值的列表,最多可以输入8个mpls-label值,label-value1 to label-value2表示一个mpls-label的范围,label-value1的值必须小于label-value2的值,mpls-label的取值范围为0~1048575;bottom-value为mpls-label栈底标志的值。1表示栈底标志被置位,0表示栈底标志未置位
packet-length { min min-value | max max-value } *
定义匹配报文长度的规则,min-value为匹配报文最小长度的字节数,max-value为匹配报文最大长度的字节数
protocol protocol-name
定义匹配协议的规则,protocol-name取值为IP或者IPv6
qos-local-id local-id-value
定义匹配qos-local-id的规则,local-id-value为QoS本地ID,取值范围为1~4095
second-mpls-exp exp-list
定义匹配内层MPLS EXP优先级的规则,exp-list为EXP的列表,最多可以输入8个EXP,EXP取值范围为0~7
second-mpls-label { { label-value-list | label-value1 to label-value2 } [ stack-bottom bottom-value ] | stack-bottom bottom-value }
定义匹配内层mpls-label和内层mpls-label栈底标志的规则,label-value-list为mpls-label值的列表,最多可以输入8个mpls-label值,label-value1 to label-value2表示一个mpls-label的范围,label-value1的值必须小于label-value2的值,mpls-label的取值范围为0~1048575;bottom-value为内层mpls-label栈底标志的值。1表示栈底标志被置位,0表示栈底标志未置位
service-dot1p 8021p-list
定义匹配运营商网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配运营商网络VLAN ID的规则,vlan-id-listVLAN ID的列表,最多可以输入8VLAN IDvlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为14094
在普通型接口板上,不支持此关键字
source-mac mac-address
定义匹配源MAC地址的规则
system-index index-value-list
定义规则来匹配预定义的上送控制平面报文类型,index-value-list为系统预定义匹配字段索引号(system-index)的列表,最多可以输入8system-index值,system-index值的取值范围为131,每个取值的具体含义可以通过display qos policy control-plane pre-defined命令来查看
需要注意的是,在业务处理板和增强型接口板上不支持取值为81618
需要注意的是,当在流分类中定义规则以匹配预定义的上送控制平面报文时,此流分类中不能再定义其它匹配规则,且此流分类对应的流行为下只能配置限速动作,即只能配置packet-rate
【描述】
if-match命令用来定义匹配指定匹配规则的所有报文的规则。undo if-match命令用来删除匹配指定匹配规则的所有报文的规则。
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     对同一个类,允许通过ACL名称和序号的方式分别引用一次同一个ACL。
(2)     定义匹配目的MAC地址规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
·     匹配目的MAC地址规则只对以太网类型的接口有意义。
(3)     定义匹配源MAC地址规则
·     匹配源MAC地址规则只对以太网类型的接口有意义。
(4)     定义匹配DSCP的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,dscp值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个DSCP值,最多可指定8个;如果指定了多个相同的DSCP值,系统默认为一个;多个不同的DSCP值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配二层转发或者三层转发报文的规则
·     if-match forwarding-layer bridgeif-match forwarding-layer route 不能同时配置。
·     类中的forwarding-layer参数必须和其他参数配合使用,不允许单独配置;且不论类操作符是andor,同时配置的其他参数都不允许和forwarding-layer参数冲突。
(6)     定义匹配用户网络的802.1p优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,8021p值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个802.1p优先级值,最多可指定8个;如果指定了多个相同的802.1p优先级值,系统默认为一个;多个不同的802.1p优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配入接口的规则
·     定义该匹配规则时,指定接口必须存在。
·     支持接口类型:ATM、以太网接口、CPOS串口、POS接口。
(8)     定义匹配IP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,IP优先级的值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个IP优先级值,最多可指定8个;如果指定了多个相同的IP优先级值,系统默认为一个;多个不同的IP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(9)     定义匹配用户网络和运营商网络VLAN ID的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,vlan-id值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(10)     定义匹配预定义的上送控制平面报文类型的规则
·     一条命令可以配置多个system-index值,如果指定了多个相同的system-index值,系统默认为一个;多个不同的system-index值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配system-index的规则时,指定的所有system-index值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     系统预定义的报文类型信息可以通过display qos policy control-plane pre-defined命令查看。
(11)     定义匹配MPLS EXP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS EXP优先级的值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个MPLS EXP优先级值,最多可指定8个;如果指定了多个相同的MPLS EXP优先级值,系统默认为一个;多个不同的MPLS EXP优先级值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS EXP优先级的规则时,指定的所有MPLS EXP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     MPLS EXP为MPLS报文特有的参数,该匹配规则仅对MPLS报文生效。
(12)     定义匹配MPLS Label和MPLS Label栈底标志的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,MPLS Label值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个MPLS Label值,如果指定了多个相同的MPLS Label值,系统默认为一个;多个不同的MPLS Label值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配MPLS Label的规则时,指定的所有MPLS Label值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     删除某条匹配MPLS Label栈底标志的规则时,指定的栈底标志值必须与该规则中定义的完全相同才会删除。
(13)     定义匹配报文长度的规则
·     一个类下可配置多条这样的命令,各个配置之间相互不覆盖。
·     如果只配置min,则表示匹配大于min-value长度的报文;如果只配置max,表示匹配小于max-value长度的报文;同时配置min和max,表示匹配长度在min-valuemax-value之间的报文。其中max-value必须大于等于min-value
相关配置可参考命令traffic classifier
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname-classifier-class1] if-match dscp 1 6 9
# 定义类class1的匹配规则为:匹配用户网络VLAN ID值为1或6或9的报文。
【缺省级别】
2:系统级
classifier-name:类名,为1~31个字符的字符串。
operator:指定各规则之间的逻辑运算符。
【描述】
traffic classifier命令用来定义一个类并进入类视图。undo traffic classifier命令用来删除一个类。
缺省情况下为operator and,即类视图下各匹配规则之间的关系为逻辑与。
相关配置可参考命令qos policyqos apply policyclassifier behavior
# 定义一个名为class1的类。
1.2  定义流行为的命令
1.2.1  accounting
accounting [ byte | packet ]
undo accounting
流行为视图
【缺省级别】
2:系统级
byte:表示报文以字节为单位进行统计。
packet:表示报文以包数为单位进行统计。此参数的配置,同时会影响CAR的统计单位。
【描述】
accounting命令用来为流行为配置统计动作。undo accounting命令用来取消统计动作配置。
相关统计信息可以通过命令display qos policy interfacedisplay qos vlan-policydisplay qos policy global查看。
相关配置可参考命令qos policytraffic behaviorclassifier behavior
·     对于以太网接口,报文长度按照整个报文长度来计算。
·     对于广域网接口, accounting统计只计算报文IP首部和载荷的长度。计算方法如下(以128字节长度的报文为例):流量统计结果=报文个数*(128字节报文长度-4字节CRC长度-14字节二层首部长度)。
·     bytepacket为可选参数。若用户不指明统计单位,则采用默认的统计单位进行统计,默认的统计单位为byte
# 为流行为配置统计动作。
[Sysname-behavior-database] accounting
1.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ red { discard | pass } ]
undo car
流行为视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率。committed-information-rate的取值范围为64~10000000kbps。需要注意的是,如果此参数是基于控制平面的QoS策略应用且应用对象为业务处理板或增强型接口板时,那么最大可生效的值为10000kbps。
cbs committed-burst-size:承诺突发尺寸,缺省取值为大约500毫秒时间内以CIR速率通过的流量。committed-burst-size的取值范围为1875~1000000000字节。
ebs excess-burst-size:超出突发尺寸,缺省值为0。excess-burst-size的取值范围为0~1000000000字节。
pir peak-information-rate:峰值速率。peak-information-rate的取值范围为64~10000000kbps。需要注意的是,如果此参数是基于控制平面的QoS策略应用且应用对象为业务处理板或增强型接口板时,那么最大可生效的值为10000kbps。
red:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
·     discard:对数据包采取的动作,丢弃数据包。
·     pass:对数据包采取的动作,允许数据包通过。
【描述】
car命令用来为流行为配置流量监管动作。undo car命令用来取消流量监管动作配置。
接口上应用的策略中使用car时,可以应用到接口报文的接收或者发送方向。
如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
·     对于以太网接口,配置的速率值与理论输出速率值一致。
·     对于广域网接口(如POS接口、ATM接口等),car命令中的报文长度只计算报文IP首部和载荷的长度。car命令中配置的端口速率参数,配置的速率值与理论输出速率值对应的计算方式如下,以报文的长度为128字节,配置的速率值为10000 kbps为例,出接口速率的理论值计算为:(10000 kbps)*128字节/(128字节报文长度-4字节CRC长度-14字节二层首部长度)=11636 kbps。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为50000bytes,不符合承诺速率时对数据包采取丢弃动作。
[Sysname-behavior-database] car cir 200 cbs 50000 red discard
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义行为。
behavior-name:行为名,如果未指定行为名,则显示所有用户定义行为的信息。
【描述】
display traffic behavior命令用来显示配置的流行为信息。
# 显示配置的用户自定义的流行为信息。
  User Defined Behavior Information:
    Behavior: ben
      Mirror enable:
        Mirror type: vlan
        Mirror destination: 23
    Behavior: 23
      Mirror enable:
        Mirror type: vlan
        Mirror destination: 25
表1-3 display traffic behavior user-defined命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
1.2.4  filter
filter { deny | permit }
undo filter
流行为视图
【缺省级别】
2:系统级
deny:丢弃数据包。
permit:允许数据包通过。
【描述】
filter命令用来为流行为配置流量过滤动作。undo filter命令用来取消过滤动作配置。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  packet-rate
packet-rate value
undo packet-rate
流行为视图
【缺省级别】
2:系统级
value:协议报文速率,单位为包每秒(pps)。取值范围为1~1048575。
【描述】
packet-rate命令用来为流行为配置限速动作。undo packet-rate命令用来取消配置。
通过限速可以实现CPU的协议报文防攻击功能。
需要注意的是,当流行为下配置了packet-rate动作时,此流行为下不能再配置其它动作,且在对应的流分类下只能配置if-match system-index 命令。
# 为流行为copp配置CPU报文限速动作。
[Sysname] traffic behavior copp
[Sysname-behavior-copp] packet-rate 1600
primap color-map-dp
undo primap color-map-dp
流行为视图
【缺省级别】
2:系统级
【描述】
primap color-map-dp命令用来配置流行为中的动作为根据报文颜色标记报文的丢弃优先级。undo primap color-map-dp命令用来取消上述设置。
需要注意的是,本命令需要和car结合在一起使用。
映射关系为:红色对应丢弃优先级2,黄色对应丢弃优先级1,绿色对应丢弃优先级0。此映射关系固定,不能修改。
# 根据报文的颜色标记报文的丢弃优先级。
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap color-map-dp
primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
undo primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
流行为视图
【缺省级别】
2:系统级
dot1p-dot1p:802.1p优先级到802.1p优先级映射表。
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-dscp:802.1p优先级到DSCP映射表。
dot1p-exp:802.1p优先级到EXP映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP到802.1p优先级映射表。
dscp-dp:DSCP到丢弃优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
dscp-exp:DSCP到EXP映射表。
dscp-lp:DSCP到本地优先级映射表。
exp-dot1p:EXP到802.1p优先级映射表。
exp-dp:EXP到丢弃优先级映射表。
exp-dscp:EXP到DSCP映射表。
exp-exp:EXP到EXP映射表。
exp-lp:EXP到本地优先级映射表。
【描述】
primap pre-defined color命令用来配置流行为中的动作为使用相应的带颜色优先级映射表为报文获取其他的优先级参数。undo primap pre-defined color命令用来取消流行为中的使用相应的带颜色优先级映射表为报文映射优先级的动作。
需要注意的是,
·     本命令需要和car结合在一起使用。
·     当设备运行在IRF模式时,对于需要通过其它成员设备的业务处理板或增强型接口板转发,且出接口为VLAN接口的报文,在发送报文方向配置的DSCP优先级到其它优先级、EXP优先级到其它优先级的映射表不生效。
相关配置可参考命令display qos map-table color
# 使用带颜色的DSCP到丢弃优先级映射表为报文获取丢弃优先级参数。
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
1.2.8  redirect
redirect { cpu | interface interface-type interface-number [ vlan vlan-id ] | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ interface-type interface-number ] [ track track-entry-number ] [ ipv6-add2 [ interface-type interface-number ] [ track track-entry-number ] ] } [ fail-action { discard | forward } ] | vpn-instance vpn-instance-name }
undo redirect { cpu | interface interface-type interface-number | next-hop | vpn-instance }
流行为视图
【缺省级别】
2:系统级
cpu:重定向到CPU。
interface:重定向到指定的接口。目前支持的接口类型为POS接口(加入捆绑组或链路类型为FR的POS接口除外)、OAP单板内联接口(OAP单板中前插板和后插板之间进行数据通信的一个虚拟接口)。
vlan vlan-id:对重定向到接口的报文封装的VLAN。vlan-id为封装的VLAN ID,取值范围为1~4094。从业务处理板或增强型接口板重定向到OAP单板内联接口时,不支持本参数。
next-hop:重定向到指定的下一跳(在普通型接口板上,下一跳可以是网络上任意一个地址。在业务处理板或增强型接口板上,下一跳必须直连)。
ipv4-add:下一跳IPv4地址。ipv4-add2ipv4-add1的备份下一跳地址,如果重定向到ipv4-add1失败,则会选择重定向到ipv4-add2
ipv6-add:下一跳IPv6地址。不支持重定向到链路本地地址;当IPv6地址为非链路本地地址时,下一跳IPv6地址不需要配置接口。ipv6-add2ipv6-add1的备份下一跳地址,如果重定向到ipv6-add1失败,则会选择重定向到ipv6-add2
track track-entry-number:指定下一跳关联的Track项,对于不同的IP地址需要分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测模块(如NQA模块、BFD模块)的联动,具体请参见“可靠性配置指导”中的“Track”。
fail-action { discard | forward }:当下一跳的地址不存在时,对报文采取的处理动作。discard表示丢弃此报文。forward表示转发此报文。
vpn-instance vpn-instance-name:重定向到指定的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
【描述】
redirect命令用来为流行为配置流量重定向动作。undo redirect命令用来取消流量重定向动作配置。
·     在配置重定向动作时,同一个流行为中重定向类型只能为重定向到CPU、重定向到下一跳、重定向到接口或重定向到VPN实例中的一种,生效的为当前最新的配置。
·     当设备运行在IRF模式时,不支持重定向到跨成员设备的POS接口。
# 为流行为配置流量重定向动作,重定向到CPU。
[Sysname-behavior-database] redirect cpu
redirect-default next-hop ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ]
undo redirect-default next-hop
流行为视图
【缺省级别】
2:系统级
next-hop:缺省重定向到指定的下一跳。
【描述】
redirect-default命令用来为流行为配置流量缺省重定向动作。undo redirect-default命令用来取消流量缺省重定向动作配置。
需要注意的是,本命令仅在业务处理板和增强型接口板上支持。
# 为流行为配置流量缺省重定向动作,缺省重定向到下一条1.1.1.1。
[Sysname-behavior-database] redirect-default next-hop 1.1.1.1
1.2.10  remark dot1p
remark dot1p 8021p
undo remark dot1p
流行为视图
【缺省级别】
2:系统级
8021p:标记的802.1p优先级,取值范围为0~7。
【描述】
remark dot1p命令用来配置标记报文的802.1p优先级。undo remark dot1p命令用来取消标记报文的802.1p优先级。
# 配置标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
remark drop-precedence drop-precedence-value
undo remark drop-precedence
流行为视图
【缺省级别】
2:系统级
drop-precedence-value:标记的丢弃优先级,取值范围为0~2。
【描述】
remark drop-precedence命令用来配置标记报文的丢弃优先级。undo remark drop-precedence命令用来取消标记报文的丢弃优先级。
# 配置标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.12  remark dscp
remark dscp dscp-value
undo remark dscp
流行为视图
【缺省级别】
2:系统级
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-4所示。
表1-4 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
【描述】
remark dscp命令用来为类配置标记报文的DSCP值。undo remark dscp命令用来取消标记报文的DSCP值。
需要注意的是,当设备运行在IRF模式时,对于需要通过其它成员设备的业务处理板或增强型接口板转发,且出接口为VLAN接口的报文,配置标记报文的DSCP值不生效。
# 配置标记报文的DSCP值为6。
remark ip-precedence ip-precedence-value
undo remark ip-precedence
流行为视图
【缺省级别】
2:系统级
ip-precedence-value:标记的IP优先级,取值范围为0~7。
【描述】
remark ip-precedence命令用来配置标记报文的IP优先级。undo remark ip-precedence命令用来取消标记报文的IP优先级。
本命令执行后,同时会将报文中DSCP字段的低3位修改为0。
# 配置标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence local-precedence
undo remark local-precedence
流行为视图
【缺省级别】
2:系统级
local-precedence:标记的本地优先级,可以使用数字或关键字表示,两者对应关系:
表1-5 本地优先级参数描述表
关键字
本地优先级(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
【描述】
remark local-precedence命令用来配置标记报文的本地优先级。undo remark local-precedence命令用来取消标记报文的本地优先级。
需要注意的是,remark local-precedenceremark forwarding-classremark qos-local-id互斥。关于remark forwarding-classremark qos-local-id的介绍请参见“ACL和QoS命令参考”中的“HQoS”。
# 配置标记报文的本地优先级值为2。
remark mpls-exp exp-value
undo remark mpls-exp
流行为视图
【缺省级别】
2:系统级
exp-value:标记的MPLS报文的EXP域的值,取值范围为0~7。
【描述】
remark mpls-exp命令用来配置标记MPLS报文的EXP域的值。undo remark mpls-exp命令用来取消标记MPLS报文的EXP域的值。
需要注意的是,当设备运行在IRF模式时,对于需要通过其它成员设备的业务处理板或增强型接口板转发,且出接口为VLAN接口的报文,配置标记MPLS报文的EXP域的值不生效。
# 配置标记MPLS报文的EXP域的值为2。
[Sysname-behavior-database] remark mpls-exp 2
【缺省级别】
2:系统级
behavior-name:流行为名,为1~31个字符的字符串。
【描述】
traffic behavior命令用来定义一个流行为并进入流行为视图。undo traffic behavior命令用来删除一个流行为。
# 定义一个名为behavior1的流行为。
1.3  定义策略和应用策略的命令
classifier classifier-name behavior behavior-name [ mode { qppb-manipulation } ]
策略视图
【缺省级别】
2:系统级
mode qppb-manipulation设置类和流行为对应关系,用于匹配BGP路由策略中apply qos-local-idapply ip-precedence的信息。类中if-match qos-local-id对应路由策略命令中apply qos-local-id,类中if-match ip-precedence对应路由策略命令中apply ip-precedence命令,具体内容请参见“三层技术-IP路由配置指导”中的“路由策略”。
【描述】
classifier behavior命令用来在策略中为类指定采用的流行为。undo classifier命令用来取消指定类在策略中的使用。
·     策略下每个类只能与一个动作关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
·     对缺省类不能使用undo命令。
相关配置可参考命令qos policy
相关配置可参考命令qos policy,“三层技术-IP路由命令参考/路由策略”中的命令route-policyapply qos-local-id
·     当QoS策略应用在入方向时且此策略中包含带mode qppb-manipulation参数的classifier behavior命令和不带qppb-manipulation参数的classifier behavior命令时,多种classifier behavior命令同时生效。如果多个流行为中都配置car,则较小生效;如果多个流行为中都配置remark dscpremark ip-precedence,则带qppb-manipulation参数的Remark生效。
·     当QoS策略应用在出方向时且此策略中包含带qppb-manipulation参数的classifier behavior命令和不带qppb-manipulation参数的classifier behavior命令时,先配置的classifier behavior 命令生效。
·     当QoS策略中包含多个带qppb-manipulation参数的classifier behavior命令时,仅最先配置的classifier behavior命令生效。
·     当classifier behavior命令中指定了mode qppb-manipulation参数时,那么采用的流行为对Remark的支持情况为:仅支持remark dscpremark ip-precedence
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
[Sysname-qospolicy-user1] classifier database behavior test mode qppb-manipulation
1.3.2  control-plane
独立运行模式:
IRF模式:
control-plane chassis chassis-number slot slot-number
【缺省级别】
2:系统级
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
control-plane slot命令用来进入指定槽位的控制平面视图。
# 进入3号板控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
# 进入1号成员设备3号板控制平面视图。(IRF模式)
[Sysname] control-plane chassis 1 slot 3
[Sysname-cp-chassis1-slot3]
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义策略。
policy-name:策略名,如果未指定,则显示所有用户定义策略的配置信息。
classifier-name:策略中的类名。
【描述】
display qos policy命令用来显示用户定义策略的配置信息。
# 显示用户定义策略的配置信息。
  User Defined QoS Policy Information:
  Policy: user1
   Classifier: class1
     Behavior: test
      Accounting Enable
      Committed Access Rate:
        CIR 20000 (kbps), CBS 300000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
      Filter enable : permit
      Marking:
        Remark dot1p COS 2
表1-6 display qos policy user-defined命令显示信息描述表
Policy
策略名
Classifier
类名,一个策略中可以存在多个类,每个类有对应的行为,每个类的匹配规则又可以有多条,参见traffic classifier命令
Behavior
策略中一个类对应的行为,每个行为可以有多条规则,参见traffic behavior命令
Accounting
流行为配置统计
流量限速的相关信息
Red Action
对流量不符合承诺速率的报文所做的动作
Filter enable
流行为配置流量过滤动作
Marking
重标记的相关信息
独立运行模式:
display qos policy control-plane slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy control-plane chassis chassis-number slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
inbound:显示对进入控制平面的报文应用的QoS策略信息。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
# 显示应用到3号板控制平面入方向的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 3 inbound
Control-plane slot 3
  Direction: Inbound
  Policy: 1
    Classifier: 2
      Operator: AND
      Rule(s) : If-match acl 2000
      Behavior: 2
          CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
          Red Action: discard
          Green : 12928(Bytes)
          Yellow: 0(Bytes)
# 显示应用到1号成员设备3号板控制平面入方向的QoS策略信息。(IRF模式)
<Sysname> display qos policy control-plane chassis 1 slot 3 inbound
Control-plane chassis 1 slot 3
  Direction: Inbound
  Policy: 1
   Classifier: default-class
     Matched : 0(Packets)
     Rule(s) : If-match any
     Behavior: be
      -none-
表1-7 display qos policy control-plane命令显示信息描述表
Control-plane
控制平面
Direction
对进控制平面(Inbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Matched
符合分类规则的数据包数目
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
none
表示没有配置其他流行为
独立运行模式:
display qos policy control-plane pre-defined slot slot-number [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy control-plane pre-defined chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:显示指定成员设备上指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
# 显示2号板系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 2
  Slot: 2
  Pre-defined Control-plane Policy Slot: 2
  Index  |  PacketType  |  BandWidth(pps)  |  Priority
  1          STP             200               7
  2          ARP-BC          600               2
  3          IGMP            2048              3
  4          GVRP            100               7
  5          MLD             500               3
  6          PIM             2000              4
  7          DHCP            400               2
  8          802.3ah         100               7
  9          TTL(1)          20                3
  10         HopLimit(1)     20                3
  11         ARP-UC          600               3
  12         LACP            100               7
  13         CFD             20000             7
  14         802.1X          4096              1
  15         RRPP            300               3
  16         DLDP            100               7
  17         LLDP            200               7
  18         Loopback        100               7
  19         DHCP Snooping   600               0
  20         Portal          400               1
  21         VRRP/VRRP3      2000              5
  22         RSVP            2000              4
  23         UDP Helper      500               3
  24         DHCPv6          400               2
  25         ICMP ping       1000              6
  26         NTPv3           200               4
  27         SNMP            200               1
  28         ISIS            1500              5
  29         BGP             1200              5
  30         OSPF            1000              5
# 显示1号成员设备3号单板系统预定义的控制平面应用QoS策略的信息。(IRF模式)
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 2
 Pre-defined Control-plane Policy Slot 2
  1          STP             200               7
  2          ARP-BC          600               2
  3          IGMP            2048              3
  4          GVRP            100               7
  5          MLD             500               3
  6          PIM             2000              4
  7          DHCP            400               2
  8          802.3ah         100               7
  9          TTL(1)          20                3
  10         HopLimit(1)     20                3
  11         ARP-UC          600               3
  12         LACP            100               7
  13         CFD             20000             7
  14         802.1X          4096              1
  15         RRPP            300               3
  16         DLDP            100               7
  17         LLDP            200               7
  18         Loopback        100               7
  20         Portal          400               1
  22         RSVP            2000              4
  23         UDP Helper      500               3
  24         DHCPv6          400               2
  25         ICMP ping       1000              6
  26         NTPv3           200               4
  27         SNMP            200               1
  28         ISIS            1500              5
  29         BGP             1200              5
  30         OSPF            1000              5
表1-8 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Index
系统预定义匹配字段索引号
Packet-type
匹配字段内容
Priority
优先级
BandWidth
带宽
独立运行模式:
display qos policy global [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:显示入方向全局QoS策略的信息。
outbound:显示出方向全局QoS策略的信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示设备在IRF中的成员编号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
display qos policy global命令用来显示基于全局应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
·     如果不指定槽位号,则显示主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(独立运行模式)
·     如果不指定成员编号和槽位号,则显示全局主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(IRF模式)
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Behavior: 2
       Accounting Enable
         20864 (Bytes)
         CIR 128 (kbps), CBS 8000 (Bytes), EBS 0 (Bytes)
         Red Action: discard
         Yellow: 7936(Bytes)
         Red   : 43904(Bytes)
表1-9 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Mode
类和流行为的对应关系所支持的模式
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
Accounting
流行为统计
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
超出突发尺寸,在双令牌桶算法中超出承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type:接口类型。
interface-number:接口编号。
inbound:显示对接口接收到的报文应用的QoS策略信息。
outbound:显示对接口发送的报文应用的QoS策略信息。
【描述】
display qos policy interface命令用来显示指定接口或所有接口上QoS策略的配置信息和运行情况。
# 显示GigabitEthernet2/1/1接口上策略的配置信息和运行情况。
<Sysname> display qos policy interface GigabitEthernet 2/1/1
Interface: GigabitEthernet2/1/1
  Direction: Outbound
  Policy: user1
   Classifier: class1
     Operator: AND
     Rule(s) : If-match acl 2001
     Behavior: test
      Accounting Enable:
        0 (Packets)
        CIR 2000 (kbps), CBS 30000 (byte), EBS 100 (byte), PIR 25000 (kbps)
        Red Action: discard
        Green : 0(Packets)
        Yellow: 0(Packets)
        Red   : 0(Packets)
      Filter Enable: permit
      Marking:
        Remark dot1p COS 2
表1-10 display qos policy interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Direction
Policy应用在接口的方向
Policy
应用到接口上的策略的名字
Classifier
策略里分类规则以及对应的配置信息
Operator
同一个类中多条分类规则的逻辑关系
Rule(s)
类的分类规则
Behavior
策略里行为的名字及配置信息,参见behavior的相关命令
Accounting enable
流量统计相关信息。统计单位可以配置字节(byte)和报文个数(packet)两种方式
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
Filter enable
流量过滤相关信息。过滤功能可以配置允许(permit)和阻止(deny)两种方式
Marking
重标记的相关信息
Remark
重标记的类型。可支持的类型有DSCP、IP precedence、MPLS EXP等类型,相关类型描述请参考1.2  定义流行为的命令
独立运行模式:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
name policy-name:显示指定策略名称的VLAN策略信息。policy-name表示策略名称,取值为1~31个字符的字符串。
vlan vlan-id:显示指定VLAN上应用的基于VLAN应用QoS策略的信息。vlan-id表示应用策略的VLAN ID。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
inbound:显示对VLAN接收到的报文应用QoS策略信息。
outbound:显示对VLAN发送的报文应用QoS策略信息。
【描述】
display qos vlan-policy命令用来显示VLAN应用QoS策略的信息。
# 显示6号单板上名字为user1的QoS策略信息。
<Sysname> display qos vlan-policy name user1 slot 6
Policy user1
    Vlan 2: inbound
表1-11 display qos vlan-policy命令显示信息描述表
Policy
QoS策略名称
Vlan
引用QoS策略的VLAN ID
Inbound
对VLAN接收到的报文应用QoS策略
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: user1
   Classifier: class1
     Operator: AND
     Behavior: test
      Accounting Enable:
        0 (Packets)
        Red Action: discard
        Green : 0(Packets)
        Yellow: 0(Packets)
        Red   : 0(Packets)
      Marking:
        Remark dot1p COS 2
表1-12 display qos vlan-policy命令显示信息描述表
Vlan
引用QoS策略的VLAN ID
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
Accounting
流行为统计
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
EBS
PIR
峰值速率
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Yellow
黄色报文的流量统计
Red
红色报文的流量统计
undo qos apply policy { inbound | outbound }
接口视图/端口组视图/控制平面视图
【缺省级别】
2:系统级
policy policy-name:策略名,为1~31个字符的字符串。
inbound:入方向。
outbound:出方向。在控制平面视图下设备不支持此关键字。
【描述】
qos apply policy命令用来在应用关联的策略。undo qos apply policy命令用来删除关联的策略。
除链路层协议为X.25、LAPB协议的接口外,所有物理接口都可以应用QoS策略。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效;在子接口视图下执行该命令,则该配置只在当前子接口生效。
·     在普通型接口板上,QoS策略所引用的类匹配规则如果使用用户自定义ACL,此QoS策略仅能应用在inbound方向,用户自定义ACL才生效。
·     在将QoS策略应用在IRF端口所在槽位单板控制平面时,如果在此QoS策略对应的流分类包含的二层ACL中定义了匹配所有的报文的规则(即配置rule permit命令),那么请不要在对应的流行为下配置流量监管(即car cir命令)或配置丢弃数据包(即filter deny命令)功能,否则可能导致IRF分裂,影响设备正常使用。
# 将策略USER1应用到接口GigabitEthernet2/1/1的出方向上。
[Sysname] interface GigabitEthernet2/1/1
[Sysname-GigabitEthernet2/1/1] qos apply policy USER1 outbound
# 对进入3号槽位单板控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
undo qos apply policy [ policy-name ] global { inbound | outbound }
【缺省级别】
2:系统级
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
【描述】
qos apply policy global命令用来全局应用QoS策略,全局应用的QoS策略对全部流量生效。undo qos apply policy global命令用来取消全局应用的QoS策略。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.11  qos policy
qos policy policy-name
undo qos policy policy-name
【缺省级别】
2:系统级
policy policy-name:策略名。为1~31个字符的字符串。
【描述】
qos policy命令用来定义一个策略并进入策略视图。undo qos policy命令用来删除一个策略。
如果某接口应用了该策略,则不允许删除该策略,需要先在应用的接口上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
相关配置可参考命令classifier behaviorqos apply policy
# 定义一个名为user1的策略。
undo qos vlan-policy vlan vlan-id-list { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略名称。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
【描述】
qos vlan-policy命令用来在指定VLAN上应用QoS策略。undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
# 在VLAN 200、300、400、500、600、700、800、900的inbound方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 600 700 800 900 inbound
独立运行模式:
reset qos policy control-plane slot slot-number [ inbound ]
IRF模式:
reset qos policy control-plane chassis chassis-number slot slot-number[ inbound ]
【缺省级别】
1:监控级
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
inbound:清除进入控制平面的方向的基于控制平面应用QoS策略的统计信息。
chassis chassis-number:清除指定成员设备上指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
# 清除应用到3号板进入控制平面方向的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 3 inbound
# 清除应用到1号成员设备3号板控制平面的QoS策略统计信息。(IRF模式)
<Sysname> reset qos policy control-plane chassis 1 slot 3
【缺省级别】
1:监控级
vlan-id:VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除VLAN接收到的报文应用QoS策略的统计信息。
【描述】
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table [ inbound | outbound ] [dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | up-rpr ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:接收报文方向优先级映射表。
outbound:发送报文方向优先级映射表。
exp-exp:EXP到EXP映射表。
up-rpr:用户优先级到RPR优先级映射表。
【描述】
display qos map-table命令用来显示指定优先级映射表配置情况。
如不指定表的类型,本命令将显示所有映射表的配置情况。
相关配置可参考命令qos map-table
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-1 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
DIRECTION
映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
display qos map-table color [ green | yellow | red ] [ inbound | outbound ] [dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
color:带颜色优先级映射表。
green:绿色报文。
yellow:黄色报文。
red:红色报文。
inbound:接收报文方向。
outbound:发送报文方向。
exp-exp:EXP到EXP映射表。
【描述】
display qos map-table color命令用来显示指定带颜色优先级映射表配置情况。
·     如不指定表的类型,本命令将显示所有带颜色映射表的配置情况。
·     如不指定颜色,本命令将显示所有颜色的带颜色映射表的配置情况。
·     如不指定方向,本命令将显示所有方向带颜色映射表的配置情况。
相关配置可参考命令qos map-table color
# 显示绿色报文的802.1p优先级到本地优先级映射表的配置信息。
<Sysname> display qos map-table color green dot1p-lp
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define   COLOR: green   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table color命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
COLOR
映射表的颜色
DIRECTION
映射表的方向
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.3  import
优先级映射表视图
【缺省级别】
2:系统级
import-value-list:映射输入参数列表。
export-value:映射输出参数。
all:删除该映射表所有参数。
【描述】
import命令用来配置指定优先级映射表参数,定义一条或一组映射规则。undo import命令用来删除指定映射索引所对应的映射项,被删除的映射条目恢复为系统缺省值。
# Inbound方向上,配置802.1p优先级到丢弃优先级映射表参数,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table inbound dot1p-dp
[Sysname-maptbl-in-dot1p-dp] import 4 5 export 1
2.1.4  qos map-table
qos map-table inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
qos map-table outbound up-rpr
【缺省级别】
2:系统级
【描述】
# 进入接收报文方向的802.1p优先级到丢弃优先级映射表视图。
qos map-table color { green | yellow | red } inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
qos map-table color { green | yellow | red } outbound { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp }
【缺省级别】
2:系统级
color:带颜色优先级映射表。
green:绿色报文。
yellow:黄色报文。
red:红色报文。
inbound:接收报文方向。
outbound:发送报文方向。
exp-exp:EXP到EXP映射表。
【描述】
qos map-table color命令用来进入指定的带颜色优先级映射表视图。
对于同一种颜色、同一种优先级映射一共存在无方向、接收报文方向、发送报文方向三张不同的映射表。如果不指定方向,则表示进入无方向的优先级映射表视图。
# 进入绿色报文的EXP到本地优先级映射表视图。
[Sysname] qos map-table color green exp-lp
[Sysname-maptbl-green-exp-lp]
# 进入红色报文的接收报文方向的DSCP到本地优先级映射表视图。
[Sysname] qos map-table color red inbound dscp-lp
[Sysname-maptbl-red-in-dscp-lp]
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority { dot1p | dp | dscp | exp | lp } priority-value
undo qos priority { dot1p | dp | dscp | exp | lp }
接口视图/端口组视图
【缺省级别】
2:系统级
dot1p:表示802.1p优先级,取值范围为0~7,缺省值为0。
dp:表示丢弃优先级,取值范围为0~2,缺省值为0。此关键字仅在普通型接口板上支持。
dscp:表示DSCP优先级,取值范围为0~63,缺省值为0。
exp:表示EXP优先级,取值范围为0~7,缺省值为0。
lp:表示本地优先级,取值范围为0~7,缺省值为2。此关键字仅在普通型接口板上支持。
priority-value:优先级值。
【描述】
qos priority命令用来配置当前端口的优先级。undo qos priority命令用来恢复优先级为缺省值。
端口优先级可以通过命令display qos trust interface来查看。
在接口视图下执行该命令,则该配置只在当前端口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效;在子接口视图下执行该命令,则该配置只在当前子接口生效。
需要注意的是,仅业务处理板和增强型接口板支持在子接口上配置qos priority命令。
# 配置以太网端口GigabitEthernet3/0/3的802.1p优先级为2。
[Sysname] interface GigabitEthernet 3/0/3
[Sysname-GigabitEthernet3/0/3] qos priority dot1p 2
2.3  端口优先级信任模式配置命令
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-number:接口号。
【描述】
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
如果不指定接口,本命令将显示所有接口的端口优先级信任模式信息。
# 显示GigabitEthernet3/0/3接口当前配置的端口优先级信任模式信息。
<Sysname> display qos trust interface gigabitethernet 3/0/3
Interface: GigabitEthernet3/0/3
Port priority information
  Port dot1p priority: -
  Port dp priority: 0
  Port dscp priority: -
  Port exp priority: -
  Port lp priority: 2
  Port priority trust type: untrust
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
端口优先级信息
Port dot1p priority
端口802.1p优先级
Port dscp priority
端口DSCP优先级
Port dp priority
端口丢弃优先级
Port exp priority
端口EXP优先级
Port lp priority
端口本地优先级
端口优先级信任类型
2.3.2  qos trust
qos trust auto
undo qos trust
接口视图/端口组视图
【缺省级别】
2:系统级
auto:表示根据报文的类型,自动提取报文中的优先级字段进行优先级映射。
·     在业务处理板和增强型接口板上,对于二层报文,采用802.1p优先级;对于三层报文,采用IP优先级;对于MPLS报文,采用EXP。
·     在普通型接口板上,对于只有非IP报文,采用802.1p优先级;对于IP报文,采用IP优先级;对于MPLS报文,采用EXP。
【描述】
qos trust auto命令用来配置端口优先级信任模式为auto模式。undo qos trust命令用来取消配置端口优先级信任模式为auto模式。
报文在进入设备以后,设备会根据自身支持的情况和相应的规则给报文分配包括802.1p优先级、DSCP、本地优先级、丢弃优先级等在内的一系列参数。
其中,本地优先级和丢弃优先级的概念如下:
·     本地优先级:设备为报文分配的一种具有本地意义的优先级,对应出端口队列序号;
·     丢弃优先级:在进行报文丢弃时参考的参数,2对应红色报文、1对应黄色报文、0对应绿色报文。
需要注意的是,仅业务处理板和增强型接口板支持在子接口上配置qos trust auto命令。
# 在以太网端口GigabitEthernet2/1/1上配置优先级信任模式为auto模式。
[Sysname] interface GigabitEthernet 2/1/1
[Sysname-GigabitEthernet2/1/1] qos trust auto
3 流量监管/流量整形/接口限速
3.1  流量监管配置命令
独立运行模式:
display car resource [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display car resource [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定单板的CAR资源使用情况,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CAR资源使用情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
display car resource命令用来显示设备的CAR资源使用情况。
·     本命令仅普通型接口板支持,业务处理板和增强型接口板不支持。
·     如果不指定槽位号,则显示所有在位普通型接口板的CAR资源使用情况。(独立运行模式)
·     如果不指定成员编号和槽位号,则显示所有在位普通型接口板的CAR资源使用情况。(IRF模式)
# 显示所有在位普通型接口板的CAR资源使用情况。
<Sysname> display car resource
Slot: 4
  Resource Type   Total   Reserved  Configured  Remaining  Start      End
                  Number  Number    Number      Number     Interface  Interface
  INBOUND-CAR     8192    0         0           8192       XGE4/0/1   XGE4/0/2
  INBOUND-CAR     8192    0         0           8192       XGE4/0/3   XGE4/0/4
  INBOUND-CAR     8192    0         0           8192       XGE4/0/5   XGE4/0/6
  INBOUND-CAR     8192    0         0           8192       XGE4/0/7   XGE4/0/8
  INBOUND-COUNT   8192    0         24          8168       XGE4/0/1   XGE4/0/2
  INBOUND-COUNT   8192    0         24          8168       XGE4/0/3   XGE4/0/4
  INBOUND-COUNT   8192    0         24          8168       XGE4/0/5   XGE4/0/6
  INBOUND-COUNT   8192    0         24          8168       XGE4/0/7   XGE4/0/8
  OUTBOUND-CAR    4096    0         0           4096       XGE4/0/1   XGE4/0/2
  OUTBOUND-CAR    4096    0         0           4096       XGE4/0/3   XGE4/0/4
  OUTBOUND-CAR    4096    0         0           4096       XGE4/0/5   XGE4/0/6
  OUTBOUND-CAR    4096    0         0           4096       XGE4/0/7   XGE4/0/8
  OUTBOUND-COUNT  8192    0         0           8168       XGE4/0/1   XGE4/0/2
  OUTBOUND-COUNT  8192    0         0           8168       XGE4/0/3   XGE4/0/4
  OUTBOUND-COUNT  8192    0         0           8168       XGE4/0/5   XGE4/0/6
  OUTBOUND-COUNT  8192    0         0           8168       XGE4/0/7   XGE4/0/8
表3-1 display car resource命令显示信息描述表
Resource Type
资源类型:
·     INBOUND-CAR表示上行方向流量监管资源
·     OUTBOUND-CAR表示下行方向流量监管资源
·     INBOUND-COUNT表示上行方向报文统计所占用的资源
·     OUTBOUND-COUNT表示下行方向报文统计所占用的资源
Total Number
支持的指定方向的流量监管或报文统计表项总数
Reserved Number
预留的指定方向的流量监管或报文统计表项总数
Configured Number
已经配置的指定方向的流量监管或报文统计表项总数
Remaining Number
剩余的指定方向的流量监管或报文统计表项总数
Start Interface
起始接口名称
End Interface
结束接口名称
3.2  流量整形配置命令
display qos gts interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定的接口类型和接口编号。
【描述】
display qos gts interface命令用来显示某个接口或所有接口的GTS配置情况。
如不指定接口,本命令将显示所有接口的GTS配置情况和运行统计信息。
需要注意的是:在接口上开启流量整形后,接口上是否显示GTS配置情况和统计信息与接口状态(开启还是关闭)没有关系。
# 显示指定接口的GTS配置情况和统计信息。
<Sysname> display qos gts interface GigabitEthernet2/1/5
Interface: GigabitEthernet2/1/5
 Rule(s): If-match any
 CIR 300 (kbps), CBS 18750 (byte)
表3-2 display qos gts interface命令显示信息描述表
Rule(s)
匹配规则
CIR
承诺信息速率,单位为kbps
CBS
3.2.2  qos gts any
qos gts any cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts any
接口视图/端口组视图
【缺省级别】
2:系统级
any:对所有的数据包进行流量整形。
cir committed-information-rate:承诺信息速率,单位为kbps。接口类型不同,committed-information-rate的取值范围有所不同,具体如下:
·     在千兆以太网接口(即GE接口)或对应的三层以太网子接口上,取值范围为300~1000000;
·     在万兆以太网接口(即10GE接口)或对应的三层以太网子接口上,取值范围为2500~10000000;
·     在链路类型非FR的POS接口上,取值范围为300~10000000;
·     在MP-group接口或链路类型非FR的串口上,取值范围为40~1000000。
cbs committed-burst-size:承诺突发尺寸,单位为byte,其生效值为1024的整数倍。接口类型不同,committed-burst-size的取值范围和缺省情况有所不同,具体如下:
·     在以太网接口或三层以太网子接口上,取值范围为4096~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在链路类型非FR的POS接口上,取值范围为1024~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在MP-group接口或链路类型非FR的串口上,取值范围为1024~15360,缺省值为1024
【描述】
qos gts any命令用来为接口下所有流配置流量整形。undo qos gts any命令用来取消对接口下所有流的整形设置。
缺省情况下,接口上没有配置流量整形。
·     qos gts anyqos lr outbound命令不能在同一接口或端口组上同时配置。
·     支持qos gts any命令的子接口,目前仅包括以下子卡:PIC-XP1L、PIC-GP10L、PIC-GP20R和PIC-GT20R。
·     qos gts any命令在MFR接口、链路类型为FR的POS接口和链路类型为FR的串口上不生效。
·     在用qos gts any cir committed-information-rate命令为所有的数据包配置流量整形时,cir的取值建议不要小于所配置接口的所有队列最小队列带宽值之和(即cir的取值不要小于此接口上所有的qos bandwidth queue queue-number min bandwidth-value命令中min参数的取值之和)。
# 为通过GigabitEthernet2/1/1接口的所有流配置流量整形,流量整形的参数为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos gts any cir 640 cbs 1024000
3.2.3  qos gts queue
qos gts queue queue cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts queue queue
接口视图/端口组视图
【缺省级别】
2:系统级
queue queue-number:对队列上的数据包进行流量整形。queue用于指定队列,可以使用数字或关键字表示,两者对应关系:
表3-3 队列参数描述表
关键字
队列号(十进制)
af1
1
af2
2
af3
3
af4
4
be
0
cs6
6
cs7
7
ef
5
·     在千兆以太网接口(即GE接口)上,取值范围为300~1000000;
·     在万兆以太网接口(即10GE接口)上,取值范围为2500~10000000;
·     在E-CPOS通道化出的串口上,取值范围为40~1000000。
·     在以太网接口上,取值范围为4096~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在E-CPOS通道化出的串口上,取值范围为1024~15360,缺省值为1024。
【描述】
qos gts queue命令用来为某一队列的流流量整形。undo qos gts queue命令用来取消对某一队列的整形设置。
缺省情况下,接口上没有配置流量整形。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     目前不支持在子接口上配置qos gts queue命令。
·     qos gts queue命令在链路类型为FR的POS接口上不生效。
·     在用qos gts queue queue-number cir committed-information-rate命令为指定队列配置流量整形时,cir的取值建议不要小于所配置接口的指定队列的最小队列带宽值(即cir的取值不要小于qos bandwidth queue queue-number min bandwidth-value命令中min参数的取值)。
# 配置在GigabitEthernet2/1/1队列af1上的报文进行流量整形,流量整形的参数为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos gts queue af1 cir 640 cbs 1024000
3.3  接口限速配置命令
display qos lr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos lr interface命令用来显示某个接口或所有接口的接口限速配置情况。
如不指定接口,本命令将显示所有接口的接口限速配置情况。
需要注意的是:在接口上开启接口限速后,接口上是否显示接口限速配置情况与接口状态(开启还是关闭)没有关系。
# 显示指定接口的LR配置情况:
<Sysname>dis qos lr interface
Interface: GigabitEthernet5/2/2
Direction: Inbound
 CIR 3000 (kbps),  CBS 187500 (byte)
Direction: Outbound
Interface: GigabitEthernet5/2/2.1
Direction: Inbound
表3-4 display qos gts interface命令显示信息描述表
Direction
指明物理接口限速的方向是入接口还是出接口
CIR
承诺信息速率,单位为kbps
CBS
3.3.2  qos lr
undo qos lr { inbound | outbound }
接口视图/端口组视图
【缺省级别】
2:系统级
inbound:对接口接收的数据流进行限速。
·     如果在设备的某个接口配置了此参数,则不建议再配置可能会影响到该端口的ACL相关应用,如配置基于该端口应用QoS策略或基于全局应用QoS策略等。
·     如果在设备的某个接口配置了此参数,又配置了入方向HQoS,则仍然可以配置动作为remark qos-local-idremark forwarding-class的QoS策略。
outbound:对接口发送的数据流进行限速。
·     在POS接口上,取值范围为300~10000000;
·     在POS接口上,取值范围为1024~133169152,缺省值为500毫秒时间内以cir速率通过的流量;
·     在MP-group接口或链路类型非FR的串口上,取值范围为1024~15360,缺省值为1024。
【描述】
qos lr命令用来限制物理接口接收或发送数据的速率。undo qos lr命令用来取消限制。
缺省情况下,接口上没有限制物理接口发送数据的速率。
需要注意的是,
·     该命令仅在业务处理板和增强型接口板上支持。
·     qos lr outboundqos gts any命令不能在同一接口或端口组上同时配置。
·     inbound参数支持在以太网接口、以太网子接口和POS接口上配置。
·     outbound参数支持在以太网接口、以太网子接口、链路类型非FR的POS接口、链路类型非FR的串口和MP-group接口上配置。支持本参数的以太网子接口,目前仅包括以下子卡:PIC-XP1L、PIC-GP10L、PIC-GP20R和PIC-GT20R。
# 配置在GigabitEthernet2/1/1进行入方向和出方向接口限速,流量整形的参数均为:承诺信息速率为640kbps;承诺突发尺寸为1024000bytes。
[Sysname-GigabitEthernet2/1/1] qos lr inbound cir 640 cbs 1024000
[Sysname-GigabitEthernet2/1/1] qos lr outbound cir 640 cbs 1024000
4 硬件实现拥塞管理
4.1  WFQ队列配置命令
WFQ队列的相关命令,仅业务处理板和增强型接口板支持,普通型接口板不支持。
display qos wfq interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wfq interface命令用来显示接口的WFQ(Weighted Fair Queuing,加权公平队列)队列配置情况。
如不指定接口,本命令将显示所有接口的WFQ队列配置情况。
相关配置可参考命令qos wfq
# 显示接口GigabitEthernet2/1/1的WFQ队列配置情况。
<Sysname> display qos wfq interface GigabitEthernet 2/1/1
Output queue: Hardware weighted fair queue
Queue ID        Weight          Min-Bandwidth
be               1               NA
af1              1               200
af2              1               NA
af3              1               NA
af4              1               NA
ef               1               NA
cs6              1               NA
cs7              1               NA
表4-1 display qos wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Weight
调度时各个队列的权重
Min-Bandwidth
队列的最小保证带宽值,NA表示没有配置此内容
undo qos bandwidth queue queue-number [ min bandwidth-value ]
接口视图/端口组视图
【缺省级别】
2:系统级
queue-number :端口队列序号。可以使用数字或关键字表示,两者对应关系请参见表3-3。在业务处理板和增强型接口板上,队列0(be队列)不支持bandwidth的配置。
min bandwidth-value:端口流量拥塞时能够保证的最小队列带宽值。
·     在千兆以太网接口上(即GE接口),取值范围为40~1000000kbps;
·     在万兆以太网接口上(即10GE接口),取值范围为40~2500000kbps;
【描述】
qos bandwidth queue命令用来配置端口队列的最小带宽保证。undo qos bandwidth queue命令用来取消端口队列的最小带宽保证配置。
缺省情况下,接口上没有配置最小带宽保证值。
·     目前,本命令不支持在子接口上进行配置。
·     在ATM接口下配置本命令,会对该ATM接口下的所有PVC生效;
·     在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     在用qos bandwidth queue queue-number min bandwidth-value命令为指定队列配置最小带宽保证时,建议min的取值不要大于所配置接口上此队列的承诺信息速率(即min的取值不要大于qos gts queue queue-number cir committed-information-rate命令中cir参数的值)。
·     在同一接口用qos bandwidth queue queue-number min bandwidth-value命令为多个队列配置最小带宽保证时,建议这些队列min参数的取值之和不要大于所配置接口所有的数据包的承诺信息速率(即min的取值不要大于qos gts any cir committed-information-rate命令中cir参数的值)。
·     通过qos bandwidth queue queue-number min bandwidth-value命令配置WFQ队列的最小保证带宽值后,系统会自动根据所配置的最小保证带宽值为具有相同优先级的所有队列分别分配权重值。
·     qos wfq queue weight schedule-value命令和qos bandwidth queue queue-number min bandwidth-value命令在相同优先级的队列中配置时互斥。
# 在GigabitEthernet2/1/1上配置队列1的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet2/1/1] qos bandwidth queue 1 min 100
qos wfq queue-number weight schedule-value
undo qos wfq queue-number weight
接口视图/端口组视图
【缺省级别】
2:系统级
queue-number:指定的队列,可以使用数字或关键字表示,两者对应关系请参见表3-3
weight schedule-value:配置队列的调度权重。schedule-value的取值范围为1~63。
【描述】
qos wfq weight命令用来在接口上配置WFQ队列的队列调度权重值。undo qos wfq weight命令用来将队列调度权重值恢复为缺省情况。
相关配置可参考命令display qos wfq interface
·     支持本命令的子接口,目前仅包括以下子卡:PIC-XP1L、PIC-GP10L、PIC-GP20R和PIC-GT20R。
# 在GigabitEthernet2/1/1上配置队列3和队列4的调度权重分别为20、30。
[Sysname-GigabitEthernet2/1/1] qos wfq 3 weight 20
[Sysname-GigabitEthernet2/1/1] qos wfq 4 weight 30
4.2  基于类的队列配置命令
基于类的队列CBQ命令仅业务处理板和增强型接口板支持,普通型接口板不支持。
4.2.1  queue af
queue af bandwidth bandwidth [ pir peak-information-rate ]
undo queue af
流行为视图
【缺省级别】
2:系统级
bandwidth:可确保的最小带宽,取值范围为64~10000000,单位是kbps。
pir peak-information-rate:峰值速率,范围为64~10000000,单位为kbps。此参数仅在以太网主接口、E-CPOS接口、POS接口(且该POS接口的链路层封装协议不能为帧中继)上生效。
【描述】
queue af bandwidth命令用来配置类进行确保转发(Assured-Forwarding),并指定可确保的带宽。undo queue af命令用来取消配置。
·     当在策略下将类与queue af所属行为关联时,必须满足:同一个策略下为确保转发(queue af)和加速转发(queue ef)的类指定的带宽之和必须不大于该策略所应用接口的可用带宽。
·     该命令在流行为视图下不能与queue efqueue wfq同时使用。
# 配置af的流量保证带宽为200kbps。
[Sysname] traffic behavior af_behav
[Sysname-behavior-af_behav] queue af bandwidth 200
4.2.2  queue ef
queue ef bandwidth bandwidth [ cbs burst ] [ pir peak-information-rate ]
undo queue ef
流行为视图
【缺省级别】
2:系统级
bandwidth:用户定义的需要加速转发的流量保证带宽,范围为64~10000000,单位是kbps。
cbs burst承诺突发尺寸,即实际平均速率在用户定义带宽以内时的突发流量,取值范围为1600~1000000000,单位为byte,缺省值为bandwidth的25倍。用户配置的承诺突发尺寸不允许小于50ms承诺信息速率的流量,以避免令牌桶突发速率太小,影响网络流量的突发特征。
【描述】
queue ef bandwidth命令用来配置加速转发(Expedited-forwarding)的流量保证带宽。undo queue ef命令用来取消配置。
·     该命令在流行为视图下不能与queue afqueue wfq同时使用。
·     同一个策略下为确保转发(queue af)和加速转发(queue ef)的类指定的带宽之和必须不大于该策略所应用接口的可用带宽。
·     对于设置绝对值形式queue ef bandwidth bandwidth [ cbs burst ],CBS = burst,若不指定burst,CBS = bandwidth×25。
# 配置报文进入优先级队列,最大带宽为200kbps,burst为5000bytes。
[Sysname-behavior-database] queue ef bandwidth 200 cbs 5000
4.2.3  queue wfq
queue wfq
undo queue wfq
流行为视图
【缺省级别】
2:系统级
【描述】
queue wfq命令用来为缺省类配置采用公平队列。undo queue wfq命令用来取消配置。
需要注意的是,该命令在流行为视图下不能与queue afqueue ef同时使用。
# 为用户配置的进入BE队列的类配置WFQ。
[Sysname] traffic behavior be_behav
[Sysname-behavior-be_behav] queue wfq
4.2.4  weight
weight weight-value
undo weight
流行为视图
【缺省级别】
2:系统级
weight-value:权重的值。
【描述】
weight命令用来配置WFQ的权重。undo weight命令用来恢复缺省情况。
缺省情况下,对于AF和EF,WFQ的权重为1;对于BE,WFQ的权重为0。
在AF最小可保证带宽和峰值速率之间的流量采用WFQ调度;在EF最大带宽和峰值速率之间的流量采用WFQ调度。
相关配置可参考命令qos policytraffic behaviorclassifier behaviorqueue afqueue ef
·     设备提示的取值范围为1~255,但是实际能生效取值范围为1~63。
·     该命令在流行为视图下不能单独使用,必须与queue afqueue efqueue wfq三者中的一条配合使用。
·     该命令目前只在以太网主接口、E-CPOS接口和POS接口(且该POS接口的链路层封装协议不能为帧中继)上生效。
# 配置流行为database1采用AF,最小可保证带宽为200kbps,峰值速率为500kbps,200~500kbps之间的流量采用WFQ,其权重为62。
[Sysname] traffic behavior database1
[Sysname-behavior-database1] queue af bandwidth 200 pir 500
[Sysname-behavior-database1] weight 62
# 配置流行为database2采用EF,最大带宽为400kbps,峰值速率为800kbps,400~800kbps之间的流量采用WFQ,其权重为61。
[Sysname] traffic behavior database2
[Sysname-behavior-database2] queue ef bandwidth 400 pir 800
[Sysname-behavior-database2] weight 61
4.3  队列调度策略配置命令
对于本节的命令,支持的具体情况如下:
·     普通型接口板支持;
·     业务处理板和增强型接口板的千兆以太网接口、万兆以太网接口、POS接口及E-CPOS通道出的E3/T3串口(链路类型为帧中继的POS接口和E-CPOS通道出的E3/T3串口除外)支持。
display qos qmprofile configuration [ profile-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。
【描述】
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
如果不指定队列调度策略的名称,将显示所有队列调度策略的配置情况。
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile
 Queue ID    Type    Group    Weight
 0           SP      N/A      N/A
 1           SP      N/A      N/A
 2           SP      N/A      N/A
 3           SP      N/A      N/A
 4           SP      N/A      N/A
 5           SP      N/A      N/A
 6           WRR     1        62
 7           SP      N/A      N/A
表4-2 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)
Group
WRR优先组,N/A表示无效
Weight
调度权重,N/A表示无效
display qos qmprofile interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
如果不指定接口,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface gigabitethernet 3/0/1
Interface: GigabitEthernet3/0/1
表4-3 display qos qmprofile interface命令显示信息描述表
接口名称
队列调度策略名称
undo qos apply qmprofile
接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos apply qmprofile命令用来在接口上应用队列调度策略。undo qos apply qmprofile命令用来恢复接口缺省的队列调度策略。
缺省情况下,接口输出队列的调度方式如下:
·     普通型接口板的0、1、2、3、4、5、6、7队列使用严格优先级调度,队列号越大优先级越高;
·     业务处理板和增强型接口板的1、2、3、4队列加入WRR组优先组1,5、6队列加入WRR组优先组2,0、7队列使用严格优先级调度,调度优先级为队列7>WRR组2>WRR组1>队列0,各WRR组内的队列根据加权值(缺省加权值为1)进行轮询调度。
·     每个接口只能应用一个队列调度策略。
·     需要注意的是,该功能目前只应用在以太网主接口、E-CPOS通道化出的POS接口(且该POS接口的链路层封装协议不能为帧中继)、E-CPOS通道化出的E3/T3串口、POS接口(且该POS接口的链路层封装协议不能为帧中继)。
# 在GigabitEthernet3/0/1接口上应用队列调度策略myprofile。
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] qos apply qmprofile myprofile
4.3.4  qos qmprofile
qos qmprofile profile-name
undo qos qmprofile profile-name
【缺省级别】
2:系统级
【描述】
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入队列调度策略视图。undo qos qmprofile命令用来删除用户自定义的队列调度策略。
需要注意的是,不能删除已经应用到接口的队列调度策略,必须先在应用的接口上取消对该队列调度策略的应用,然后再删除该队列调度策略。
对于刚创建的队列调度策略,缺省情况是1、2、3、4队列使用加权轮询调度,0、5、6、7队列使用严格优先级调度。
# 创建自定义的队列调度策略myprofile,并进入队列调度策略视图。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile]
4.3.5  queue
queue queue-number { sp | wrr group group-id weight weight-value }
undo queue queue-number
队列调度策略视图
【缺省级别】
2:系统级
queue-number:队列号,取值范围0~7。
sp:配置队列为严格优先级调度。
wrr:配置队列为加权轮询调度。
group-id:WRR优先组号,取值范围1~4。
·     当在普通型接口板的接口上应用队列调度策略时,设备实际支持group-id的取值范围1~2。当在业务处理板和增强型接口板的接口上应用队列调度策略时,设备支持group-id的取值范围1~4。
·     当某个队列调度策略已经同时应用在普通型接口板、业务处理板和增强型接口板时,此时修改此队列调度策略中的group-id为3或4时,虽然业务处理板和增强型接口板支持的取值范围为1~4,但修改后的group-id并不会在业务处理板和增强型接口板上生效。必须先取消普通型接口板的队列调度策略,然后再修改group-id,此修改才会在业务处理板和增强型接口板上生效。
weight-value:调度权重,取值范围1~63,该参数仅普通型接口板支持。
【描述】
queue命令用来配置指定队列的调度策略。undo queue命令用来删除指定队列的调度策略。
# 创建自定义的队列调度策略myprofile,并配置队列1为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 1 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为20,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 20
5 拥塞避免
WRED的相关内容,仅业务处理板和增强型接口板支持,普通型接口板不支持。
5.1  WRED配置命令
display qos wred interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wred interface命令用来显示指定接口或所有接口的WRED配置情况和统计信息。
如果不指定接口,本命令将显示所有接口的WRED配置情况和统计信息。
# 显示指定接口的WRED配置情况。
<Sysname> display qos wred interface GigabitEthernet 2/1/1
 Current WRED configuration:
 Applied WRED table name: 123
表5-1 display qos wred interface命令显示信息描述表
当前WRED的配置情况
应用的WRED表名
5.2  WRED表配置命令
display qos wred table [ table-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
table-name:要显示的WRED表的名字。
【描述】
display qos wred table命令用来显示WRED表的配置情况。
如果不指定表名字,本命令将显示所有已配置的WRED表的配置情况。
# 显示WRED表的配置情况。
<Sysname> display qos wred table 1
Table Name: 1
Table Type: Queue based WRED
QID:  gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent
 0 10224  10240   100 10224  10240   100 10224  10240   100      8
 1 10224  10240   100 10224  10240   100 10224  10240   100      8
 2 10224  10240   100 10224  10240   100 10224  10240   100      8
 3 10224  10240   100 10224  10240   100 10224  10240   100      8
 4 10224  10240   100 10224  10240   100 10224  10240   100      8
 5 10224  10240   100 10224  10240   100 10224  10240   100      8
 6 10224  10240   100 10224  10240   100 10224  10240   100      8
 7 10224  10240   100 10224  10240   100 10224  10240   100      8
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列号
gmin
绿色报文下限阈值
gmax
绿色报文上限阈值
gprob
绿色报文最大丢弃概率
ymin
黄色报文下限阈值
ymax
黄色报文上限阈值
yprob
黄色报文最大丢弃概率
rmin
红色报文下限阈值
rmax
红色报文上限阈值
rprob
红色报文最大丢弃概率
exponent
计算平均队列长度指数
undo qos wred table table-name
【缺省级别】
2:系统级
queue:基于队列的表,拥塞时根据报文所在队列进行随机丢弃。
table table-name:指定表的名字,为1~32个字符的字符串。
【描述】
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。undo qos wred table命令用来删除全局WRED表。
缺省情况下,没有全局WRED表存在。
设备不允许删除正在使用的表。
相关配置可参考命令display qos wred tabledisplay qos wred interface
# 创建WRED表exp-table1。
[Sysname] qos wred queue table exp-table1
[Sysname-wred-table-exp-table1]
5.2.3  queue
queue queue-number [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-number | all }
WRED表视图
【缺省级别】
2:系统级
queue-number:队列编号。
drop-level drop-level:丢弃级别,如果没有指定,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:优先级的WRED下限,low-limit的缺省值为10224。
high-limit high-limit:优先级的WRED上限,high-limit的缺省值为10240。
discard-probability discard-prob:丢弃概率的分母,每一个丢弃级别都有自己独立的丢弃概率分母,discard-prob的缺省值为100。
【描述】
queue命令用来编辑基于queue的WRED表的内容。undo queue命令用来恢复WRED表的内容为缺省值。
缺省情况下,基于队列的WRED全局表有一套可用的缺省参数。
相关配置可参考命令qos wred table
# 修改基于queue的全局WRED表queue-table1的队列1的丢弃级别为1的数据包的丢弃参数。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
queue queue-number weighting-constant exponent
undo queue queue-number weighting-constant
WRED表视图
【缺省级别】
2:系统级
queue-number:队列编号。
weighting-constant exponent:计算平均队列长度的指数,取值范围为0~21。缺省情况下,该指数取值为8。
【描述】
queue weighting-constant命令用来配置基于queue的WRED表的平均队列长度的指数,undo queue weighting-constant命令用来恢复基于queue的WRED表平均队列长度指数为缺省值。
# 配置基于queue的WRED表的平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
qos wred apply table-name
undo qos wred apply
接口视图/端口组视图
【缺省级别】
2:系统级
table-name:WRED全局表的名字。
【描述】
qos wred apply命令用来在接口上应用WRED全局表。undo qos wred apply命令用来恢复端口缺省的尾丢弃模式,它同时取消WRED表的应用。
缺省情况下,端口采用尾丢弃。
·     不支持在普通型接口板上配置该命令。
相关配置可参考命令display qos wred interfacedisplay qos wred tableqos wred table
# 在接口GigabitEthernet2/1/1上应用基于队列的表queue-table1。
[Sysname-GigabitEthernet2/1/1] qos wred apply queue-table1
6 全局CAR
6.1  全局CAR配置命令
6.1.1  car name
car name car-name
undo car
流行为视图
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
car name命令用来配置流行为的聚合CAR动作。undo car用来删除流行为的流量监管动作。
# 配置流行为be1的聚合CAR动作为aggcar-1。
display qos car name [ car-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
car-name:聚合CAR的名称。
【描述】
display qos car name命令用来显示聚合CAR的配置和统计信息。
·     如果输入car-name参数,将显示指定聚合CAR的配置和统计信息。
·     如果不输入car-name参数,将显示所有聚合CAR的配置和统计信息。
# 显示聚合CAR aggcar-1的配置信息。
<Sysname> display qos car name aggcar-1
  Mode: aggregative
  CIR: 200(kbps)  CBS: 2000(byte)  EBS: 40000(byte)  PIR: 2000(kbps)
  Red Action: discard
  Green packet 172800(Bytes)
  Yellow packet 1555584(Bytes)
  Red packet 745665920(Bytes)
表6-1 display qos car name命令显示信息描述表
Name
流量监管的名称
Mode
流量监管的类型
CIR  CBS  EBS  PIR
流量监管流量的参数配置
Red Action
对红色报文的动作
Green packet
绿色报文的流量统计
Yellow packet
黄色报文的流量统计
Red packet
红色报文的流量统计
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ red { discard | pass } ]
undo qos car car-name
【缺省级别】
2:系统级
car-name:聚合CAR的名称,取值为1~31个字符的字符串。
aggregative:标明该全局CAR为聚合模式,目前只支持聚合CAR。
cir committed-information-rate:承诺信息速率,committed-information-rate的取值范围为64~10000000,单位为kbps。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,committed-burst-size的取值范围为1875~1000000000字节。缺省值为大约500ms内承诺信息速率的流量。用户配置的承诺突发尺寸不允许小于50ms承诺信息速率的流量,以避免令牌桶突发速率太小,影响网络流量的突发特征。
ebs excess-burst-size:超出突发尺寸,excess-burst-size的取值范围为0~1000000000字节。
pir peak-information-rate:峰值速率,peak-information-rate的取值范围为64~10000000 kbps。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
【描述】
qos car aggregative命令用来配置聚合CAR。undo qos car命令用来取消聚合CAR的配置。
聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为200,cbs取值为2000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2000 red discard
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
【描述】
reset qos car name命令用来清除聚合CAR的统计信息。
·     如果输入car-name参数,将清除指定聚合CAR的统计信息。
·     如果不输入car-name参数,将清除所有聚合CAR的统计信息。
# 清除聚合CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 报文统计
报文统计的相关内容,仅普通型接口板且单板上的端口工作在二层模式时才支持,业务处理板和增强型接口板不支持。
7.1  报文统计配置命令
独立运行模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ | { begin | exclude | include } regular-expression ]
IRF模式:
display qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:入方向的报文统计计数器。
outbound:出方向的报文统计计数器。
counter0:计数器0。
counter1:计数器1。
slot slot-number:显示指定单板计数器统计的流量信息,slot-number表示单板槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的报文统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
【描述】
display qos tranffic-counter命令用来显示计数器统计的流量信息,同时显示该组计数器的配置信息。
# 显示4号槽位单板出方向上的报文统计信息。
<Sysname> display qos traffic-counter outbound counter0 slot 4
Slot 4 outbound counter0 mode:
 Interface: all
 VLAN: all
 Local precedence: all
 Drop priority: all
Traffic-counter summary:
 Unicast: 0 packets
 Multicast: 0 packets
 Broadcast: 0 packets
 Control packets: 2 packets
 Bridge egress filtered packets: 0 packets
 Tail drop packets: 0 packets
 Multicast Tail drop packets: 6 packets
 Forward restrictions packets: 0 packets
表7-1 display qos traffic-counter outbound命令显示信息描述表
4槽位单板上计数器0统计出方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
Local precedence
本计数器所统计的本地优先级
Drop priority
本计数器所统计的丢弃优先级
本计数器统计信息汇总
Unicast
单播报文数
Multicast
多播报文数
Broadcast
广播报文数
Control packets
控制报文和镜像报文统计
出方向桥(二层)过滤报文统计(包括VLAN过滤和STP Block报文)
Tail drop packets
单播报文拥塞尾丢弃统计
组播、广播报文拥塞尾丢弃统计
转发的限制报文数(目前,该项暂不支持)
# 显示1号槽位单板入方向上的报文统计信息。
<Sysname> display qos traffic-counter inbound counter0 slot 1
Slot 1 inbound counter0 mode:
 Interface: all
 VLAN: all
 Bridge in frames: 5490000 packets
 Bridge local discarded: 0 packets
 Bridge vlan ingress filter discarded: 0 packets
 Bridge security filter discarded: 0 packets
表7-2 display qos traffic-counter inbound命令显示信息描述表
1槽位单板上计数器0统计入方向流量的监控对象
本计数器所统计的接口
VLAN
本计数器所统计的VLAN
本计数器统计信息汇总
Bridge in frames
桥(二层)接收到的报文个数
桥(二层)丢弃报文个数(除了桥安全过滤和VLAN入方向过滤外的其他原因丢弃的报文数)
VLAN入方向过滤报文数
桥(二层)安全过滤报文数
7.1.2  qos traffic-counter
独立运行模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number [ interface interface-type interface-number ] [ vlan vlan-id ] [ local-precedence lp-value ] [ drop-priority dp-value ]
IRF模式:
qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number [ interface interface-type interface-number ] [ vlan vlan-id ] [ local-precedence lp-value ] [ drop-priority dp-value ]
undo qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
slot slot-number:单板槽位号。(独立运行模式)
chassis chassis-number slot slot-numberchassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
interface-type interface-number:指定绑定的接口类型和接口编号。
vlan-id:VLAN的编号,取值范围为1~4094。
local-precedence:本地优先级,取值范围为0~7。设备不支持配置此参数。
drop-priority:丢弃优先级,取值范围为0~2。
【描述】
qos traffic-counter命令用来使能报文统计功能。undo qos traffic-counter命令用来关闭报文统计功能。
缺省情况下,报文统计功能处于关闭状态。
一块单板提供两个计数器用于统计单板流量,监控的对象可以是指定端口、VLAN、本地优先级和丢弃优先级的报文。
·     当不指定端口时,则监控单板上所有端口的流量。
·     当不指定VLAN时,则监控单板上所有VLAN的流量。
·     当不指定本地优先级时,则监控单板上所有本地优先级的流量。
·     当不指定丢弃优先级时,则监控单板上所有丢弃优先级的流量。
使用qos traffic-counter命令重新设置某单板的监控对象后,计数器的值会自动清零。
# 使能4号槽位的计数器0的报文统计功能,统计GigabitEthernet4/0/1端口的出方向流量。
[Sysname] qos traffic-counter outbound counter0 slot 4 interface gigabitethernet 4/0/1
7.1.3  reset qos traffic-counter
独立运行模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } slot slot-number
IRF模式:
reset qos traffic-counter { inbound | outbound } { counter0 | counter1 } chassis chassis-number slot slot-number
【缺省级别】
2:系统级
counter0:计数器0。
counter1:计数器1。
【描述】
reset qos traffic-counter命令用来清除报文统计计数器的统计值。
# 清除4号槽位的出方向报文统计计数器的统计值。
<Sysname> reset qos traffic-counter outbound counter0 slot 4
8 端口队列统计
8.1  端口队列统计配置命令
8.1.1  display qos queue-statistics interface
display qos queue-statistics interface [ interface-type interface-number ] [ pvc { pvc-name [ vpi/vci ] | vpi/vci } ] [ dlci dlci-number ] [ outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定接口类型和编号。
pvc:只用于ATM接口,即显示ATM接口上的指定PVC的信息。
pvc-name:PVC名。
vpi/vci:VPI/VCI值。
dlci dlci-number:为帧中继接口分配的虚电路号。dlci-number取值范围为16~1007。当指定接口封装的链路层协议为帧中继时,才支持此参数。
outbound:显示出方向上的端口队列统计信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display qos queue-statistics interface命令用来显示端口队列统计信息。
·     如果不指定接口,将显示所有接口的队列统计信息。
·     统计信息可通过reset counters interface命令清除,关于此命令的介绍请参见“接口管理命令参考”中的“以太网接口”。
·     目前此命令仅在业务处理板和增强型接口板上可用。
·     如果接口上配置了HQoS,则本命令无法显示该接口上的队列统计信息。
# 显示接口GigabitEthernet2/1/3的出方向队列统计信息。
<Sysname>display qos queue-statistics interface GigabitEthernet 2/1/3
Interface: GigabitEthernet2/1/3
Direction: Outbound
    Pass: 0 packets, 0 bytes
    Drop: 0 packets, 0 bytes
  Data Flow:
    Queue 0:
      Total queue length  : 4096 packets
      Current queue length: 0 packets, 0% use ratio
    Queue 1:
      Total queue length  : 2048 packets
    Queue 2:
    Queue 3:
    Queue 4:
    Queue 5:
      Total queue length  : 512 packets
    Queue 6:
    Queue 7:
      Total queue length  : 8192 packets
表8-1 display qos queue-statistics interface命令显示信息描述表
统计的接口
Direction
端口队列统计的方向
Pass
转发的数据包数和字节数
Drop
丢弃的数据包数和字节数
Data Flow
数据流统计信息
Queue
队列编号
Total queue length
队列总长度
当前队列长度
use ratio
队列使用率
9 QoS调度精度增强模式
本功能仅在普通型接口板上支持。
9.1  QoS调度精度增强模式配置命令
9.1.1  enhanced-qos
enhanced-qos enable
undo enhanced-qos enable
【缺省级别】
2:系统级
【描述】
enhanced-qos enable命令用来设置QoS的调度精度增强模式。undo enhanced-qos enable 命令用来取消QoS调度精度增强模式。
缺省情况下,系统处于QoS调度精度增强模式。
在对转发时延性能要求较高的场景下,可取消系统的QoS调度精度增强模式,使得系统获得更高的转发时延性能。
# 取消系统的QoS调度精度增强模式。
[Sysname] undo enhanced-qos enable
10 QPPB
10.1  QPPB配置命令
10.1.1  bgp-policy
bgp-policy { destination | source } ip-prec-map ip-qos-map
undo bgp-policy { destination | source } [ ip-prec-map ip-qos-map ]
接口视图/端口组视图
【缺省级别】
2:系统级
destination:使用目的IP查找路由。
source:使用源IP查找路由。
ip-prec-map:设置IP优先级。
ip-qos-map:设置QoS本地ID。
【描述】
bgp-policy命令用来配置QPPB功能,即通过BGP传播路由策略中设置的apply ip-precedenceapply qos-local-id信息。undo bgp-policy命令用来取消配置。
缺省情况下,在业务处理板和增强型接口板上没有配置QPPB功能,在普通型接口板上已经配置QPPB功能。
l     bgp-policy只在接口入方向生效。
l     普通型接口板缺省已经配置了QPPB功能,如果您再次在此类接口上配置QPPB功能,设备会立即提示配置失败信息,但不影响QPPB功能的使用。
l     普通型接口板上只支持IP优先级设置并且只能使用目的IP查找路由。
l     MPLS L3VPN网络中,PE公网接口入方向QoS业务在bgp-policy之前进行;其他网络环境中QoS业务在bgp-policy之后进行。
l     如果指定source,则以源IP为目的进行反向查找。
l     仅业务处理板和增强型接口板上的子接口支持bgp-policy命令。
相关配置可参考“三层技术-IP路由命令参考/路由策略”中的命令route-policyapply ip-precedenceapply qos-local-id
# 在接口GigabitEthernet3/1/1上根据源IP查找路由获得IP优先级和QoS本地ID。
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] bgp-policy source ip-prec-map ip-qos-map
11 QoS管道模式配置命令
11.1.1  qos pipe-mode
qos pipe-mode
undo qos pipe-mode
【缺省级别】
2:系统级
【描述】
qos pipe-mode命令用来配置QoS管道模式。undo qos pipe-mode命令用来取消QoS管道模式。
缺省情况下,设备未配置QoS管道模式。
配置QoS管道模式后,可以确保报文在经过以下任意一种网络后:
·     在MPLS L2VPN网络;
·     在MPLS L3VPN网络;
·     在VPLS网络;
所携带的DSCP优先级字段不会被改变,从而不影响下游设备对该IP报文的转发调度。关于此功能的详细介绍请参见配置指导中的“QoS”。
需要注意的是,本命令仅在普通型接口板上支持。
# 配置QoS管道模式。
[Sysname] qos pipe-mode
