08-IP组播命令参考
01-IGMP Snooping命令
本章节下载: 01-IGMP Snooping命令  (238.75 KB)
01-IGMP Snooping命令
1 IGMP Snooping
1.1 IGMP Snooping配置命令
1.1.1 display igmp-snooping group
1.1.2 display igmp-snooping host
1.1.3 display igmp-snooping statistics
1.1.4 entry-limit (IGMP-Snooping view)
1.1.5 fast-leave (IGMP-Snooping view)
1.1.6 group-policy (IGMP-Snooping view)
1.1.7 host-aging-time (IGMP-Snooping view)
1.1.8 host-tracking (IGMP-Snooping view)
1.1.9 igmp-snooping
1.1.10 igmp-snooping drop-unknown
1.1.11 igmp-snooping enable
1.1.12 igmp-snooping fast-leave
1.1.13 igmp-snooping general-query source-ip
1.1.14 igmp-snooping group-limit
1.1.15 igmp-snooping group-policy
1.1.16 igmp-snooping host-aging-time
1.1.17 igmp-snooping host-join
1.1.18 igmp-snooping host-tracking
1.1.19 igmp-snooping last-member-query-interval
1.1.20 igmp-snooping leave source-ip
1.1.21 igmp-snooping max-response-time
1.1.22 igmp-snooping overflow-replace
1.1.23 igmp-snooping proxying enable
1.1.24 igmp-snooping querier
1.1.25 igmp-snooping query-interval
1.1.26 igmp-snooping report source-ip
1.1.27 igmp-snooping router-aging-time
1.1.28 igmp-snooping router-port-deny
1.1.29 igmp-snooping special-query source-ip
1.1.30 igmp-snooping static-group
1.1.31 igmp-snooping static-router-port
1.1.32 igmp-snooping version
1.1.33 last-member-query-interval (IGMP-Snooping view)
1.1.34 max-response-time (IGMP-Snooping view)
1.1.35 overflow-replace (IGMP-Snooping view)
1.1.36 report-aggregation (IGMP-Snooping view)
1.1.37 reset igmp-snooping group
1.1.38 reset igmp-snooping statistics
1.1.39 router-aging-time (IGMP-Snooping view)
1 IGMP Snooping
设备支持两种运行模式:独立运行模式和IRF模式,缺省情况下为独立运行模式。有关IRF模式的介绍,请参见“IRF配置指导”中的“IRF”。
独立运行模式:
display igmp-snooping group [ [ vlan vlan-id ] [ slot slot-number ] | vsi vsi-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display igmp-snooping group [ [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] | vsi vsi-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vlan vlan-id:查看指定VLAN内IGMP Snooping组的信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
vsi vsi-name:查看指定VPLS实例内IGMP Snooping组的信息。vsi-name为指定VPLS实例的名称,为1~31个字符的字符串。
slot slot-number:查看指定单板上IGMP Snooping组的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上IGMP Snooping组的信息。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的IGMP Snooping组信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device命令查看。如果未指定本参数,将显示IRF中所有主控板上IGMP Snooping组的信息。(IRF模式)
verbose:查看IGMP Snooping组的详细信息。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display igmp-snooping group命令用来查看IGMP Snooping组的信息,包括动态和静态加入的IGMP Snooping组。
需要注意的是,如果未指定VLAN和VPLS实例,将显示所有VLAN/VPLS实例内IGMP Snooping组的信息。
# 查看VLAN 2内IGMP Snooping组的详细信息。
<Sysname> display igmp-snooping group vlan 2 verbose
  Total 1 IP Group(s).
  Total 1 IP Source(s).
  Total 1 MAC Group(s).
  Port flags: D-Dynamic port, S-Static port, C-Copy port, P-PIM port
  Subvlan flags: R-Real VLAN, C-Copy VLAN
  Vlan(id):2.
    Router port unit board: Mask(0x000004)
    Router port(s):total 1 port(s).
            GE2/1/1                (D)
    IP group(s):the following ip group(s) match to one mac group.
      IP group address:224.1.1.1
        (0.0.0.0, 224.1.1.1):
          Attribute:    Host Port
          Host port unit board: Mask(0x000004)
          Host port(s):total 1 port(s).
            GE2/1/2                (D)
    MAC group(s):
      MAC group address:0100-5e01-0101
            GE2/1/2
# 查看VPLS实例aaa内IGMP Snooping组的详细信息。
<Sysname> display igmp-snooping group vsi aaa verbose
  VSI(name):aaa.
    Router port unit board: Mask(0x0000)
            AC VSI index:0 Link ID:1  (D) ( 00:00:54 )
          Attribute:    Host AggPort
          Host port unit board: Mask(0x0000)
            PW VSI index:0 Link ID:65 (D) ( 00:03:31 )
    MAC group(s):
表1-1 display igmp-snooping group命令显示信息描述表
IP组播组的数量
IP组播源的数量
MAC组播组的数量
端口标志:D代表动态端口,S代表静态端口,C代表由(*,G)表项拷贝到(S,G)表项下的端口,P代表由PIM Snooping添加的端口
子VLAN标志:R代表本表项下的真实出口子VLAN,C代表由(*,G)表项拷贝到(S,G)表项下的出口子VLAN
路由器端口所在单板的编号(以掩码表示)。
Router port(s)
路由器端口的数量
( 00:01:30 )
动态路由器/成员端口的老化剩余时间,需要注意的是:如果某非聚合端口不属于主控板,则须指定其所在单板的槽位号(即slot slot-number参数)才能显示出该时间值;而对于聚合端口则无此限制
IP group address
IP组播组的地址
(S,G)表项,0.0.0.0表示所有组播源
MAC group address
MAC组播组的地址
Attribute
IP组播组的属性
成员端口所在单板的编号(以掩码表示)。
Host port(s)
成员端口的数量
独立运行模式:
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
IRF模式:
display igmp-snooping host vlan vlan-id group group-address [ source source-address ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
vlan vlan-id:查看指定VLAN内IGMP Snooping跟踪的主机信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
group group-address:查看IGMP Snooping跟踪的加入指定组播组的主机信息。group-address为组播组的地址,取值范围为224.0.1.0~239.255.255.255。
source source-address:查看IGMP Snooping跟踪的加入指定组播源的主机信息。source-address为组播源的地址,取值为有效的单播地址或0.0.0.0,0.0.0.0表示所有组播源。
slot slot-number:查看指定单板上IGMP Snooping跟踪的主机信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上IGMP Snooping跟踪的主机信息。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的IGMP Snooping跟踪的主机信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,可使用display device命令查看。如果未指定本参数,将显示IRF中所有主控板上IGMP Snooping跟踪的主机信息。(IRF模式)
【描述】
display igmp-snooping host命令用来查看IGMP Snooping跟踪的主机信息,以配合IGMP Snooping主机跟踪功能的使用。
# 查看VLAN 2内IGMP Snooping跟踪的加入组播组224.1.1.1的主机信息。
<Sysname> display igmp-snooping host vlan 2 group 224.1.1.1
VLAN(ID) : 2
    Port : GigabitEthernet3/1/1
      Host                                    Uptime          Expires
      1.1.1.1                                 00:02:20        00:00:40
      2.2.2.2                                 00:02:21        00:00:39
    Port : GigabitEthernet3/1/2
      Host                                    Uptime          Expires
      3.3.3.3                                 00:02:20        00:00:40
表1-2 display igmp-snooping host命令显示信息描述表
VLAN(ID)
VLAN的编号
Port
成员端口的名称
Host
主机的IP地址
Uptime
主机的运行时间
Expires
主机的超时时间,timeout表示已超时
display igmp-snooping statistics [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display igmp-snooping statistics命令用来查看IGMP Snooping监听到的IGMP报文的统计信息。
# 查看IGMP Snooping监听到的IGMP报文的统计信息。
<Sysname> display igmp-snooping statistics
  Received IGMP general queries:0.
  Received IGMPv1 reports:0.
  Received IGMPv2 reports:19.
  Received IGMP leaves:0.
  Received IGMPv2 specific queries:0.
  Sent     IGMPv2 specific queries:0.
  Received IGMPv3 reports:1.
  Received IGMPv3 reports with right and wrong records:0.
  Received IGMPv3 specific queries:0.
  Received IGMPv3 specific sg queries:0.
  Sent     IGMPv3 specific queries:0.
  Sent     IGMPv3 specific sg queries:0.
  Received error IGMP messages:19.
表1-3 display igmp-snooping statistics命令显示信息描述表
general queries
普遍组查询报文
specific queries
特定组查询报文
reports
报告报文
leaves
离开报文
包含错误和正确纪录的报告报文
specific sg queries
特定源组查询报文
error IGMP messages
错误的IGMP报文
entry-limit limit
undo entry-limit
IGMP-Snooping视图
【缺省级别】
2:系统级
limit:全局IGMP Snooping转发表项的最大数量,取值范围为0~2000。
【描述】
entry-limit命令用来配置全局IGMP Snooping转发表项的最大数量。undo entry-limit命令用来恢复缺省情况。
缺省情况下,全局IGMP Snooping转发表项的最大数量为2000。
相关配置可参考“IP组播命令参考/组播VLAN”中的命令multicast-vlan entry-limit。
# 配置全局IGMP Snooping转发表项的最大数量为512个。
[Sysname] igmp-snooping
[Sysname-igmp-snooping] entry-limit 512
fast-leave [ vlan vlan-list ]
undo fast-leave [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内配置端口快速离开功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果指定了本参数,本配置只对指定VLAN有效;如果未指定本参数,则本配置将对所有VLAN/VPLS实例都有效。
【描述】
fast-leave命令用来全局使能端口快速离开功能。端口快速离开是指当设备从某端口收到主机发送的离开某组播组的IGMP离开组报文时,直接把该端口从对应转发表项的出端口列表中删除。undo fast-leave命令用来全局关闭端口快速离开功能。
缺省情况下,端口快速离开功能处于关闭状态。
需要注意的是,本命令对使能了IGMP Snooping的VLAN或相应VLAN接口上使能了IGMP的VLAN都有效。
相关配置可参考命令igmp-snooping fast-leave。
# 使能VLAN 2内的端口快速离开功能。
[Sysname-igmp-snooping] fast-leave vlan 2
group-policy acl-number [ vlan vlan-list ]
undo group-policy [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
acl-number:指定基本或高级ACL的编号,取值范围为2000~3999。主机只能加入与该ACL规则中permit语句匹配的组播组。其中,高级ACL规则中的源地址是指IGMP报告报文中指定要接收的组播源的地址(对于IGMPv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的IGMPv3报文,视其组播源地址为0.0.0.0),而不是IGMP报告报文的源地址。
vlan vlan-list:在指定VLAN内配置组播组过滤器。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果指定了本参数,本配置只对指定VLAN有效;如果未指定本参数,则本配置将对所有VLAN/VPLS实例都有效。
【描述】
group-policy命令用来配置全局组播组过滤器,以限定VLAN内的主机所能加入的组播组。undo group-policy命令用来删除全局组播组过滤器。
缺省情况下,没有配置全局组播组过滤器,即各VLAN/VPLS实例内主机可以加入任意合法的组播组。
·     本命令对VLAN接口上使能了IGMP的VLAN也有效。
·     当指定的ACL不存在或者其规则为空时,将过滤掉所有的组播组。
·     可以为端口在不同的VLAN内配置不同的ACL规则,但在相同VLAN内所配置的新规则会取代旧规则。
相关配置可参考命令igmp-snooping group-policy。
# 限定VLAN 2内的主机只能加入组播组225.1.1.1。
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 225.1.1.1 0
[Sysname-acl-basic-2000] quit
[Sysname-igmp-snooping] group-policy 2000 vlan 2
host-aging-time interval
undo host-aging-time
IGMP-Snooping视图
【缺省级别】
2:系统级
interval:动态成员端口的老化时间,取值范围为200~1000,单位为秒。
【描述】
host-aging-time命令用来全局配置动态成员端口的老化时间。undo host-aging-time命令用来恢复缺省情况。
缺省情况下,动态成员端口的老化时间为260秒。
相关配置可参考命令igmp-snooping host-aging-time。
# 全局配置动态成员端口的老化时间为300秒。
[Sysname-igmp-snooping] host-aging-time 300
host-tracking
undo host-tracking
IGMP-Snooping视图
【缺省级别】
2:系统级
无
【描述】
host-tracking命令用来全局使能IGMP Snooping主机跟踪功能。undo host-tracking命令用来全局关闭IGMP Snooping主机跟踪功能。
缺省情况下,IGMP Snooping主机跟踪功能处于关闭状态。
相关配置可参考命令display igmp-snooping host和igmp-snooping host-tracking。
# 全局使能IGMP Snooping主机跟踪功能。
[Sysname-igmp-snooping] host-tracking
1.1.9  igmp-snooping
igmp-snooping
undo igmp-snooping
【缺省级别】
2:系统级
无
【描述】
igmp-snooping命令用来全局使能IGMP Snooping,并进入IGMP-Snooping视图。undo igmp-snooping命令用来全局关闭IGMP Snooping。
缺省情况下,IGMP Snooping处于关闭状态。
相关配置可参考命令igmp-snooping enable。
# 全局使能IGMP Snooping,并进入IGMP-Snooping视图。
undo igmp-snooping drop-unknown
VLAN视图/VSI视图
【缺省级别】
2:系统级
无
【描述】
igmp-snooping drop-unknown命令用来在VLAN/VPLS实例内使能丢弃未知组播数据报文的功能。undo igmp-snooping drop-unknown命令用来在VLAN/VPLS实例内关闭丢弃未知组播数据报文的功能。
缺省情况下,丢弃未知组播数据报文的功能处于关闭状态,即对未知组播数据报文进行广播。
在配置本命令之前,必须先在VLAN/VPLS实例内使能IGMP Snooping。
# 在VLAN 2内使能IGMP Snooping,并使能丢弃未知组播数据报文的功能。
[Sysname-igmp-snooping] quit
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping enable
[Sysname-vlan2] igmp-snooping drop-unknown
# 在VPLS实例aaa内使能IGMP Snooping,并使能丢弃未知组播数据报文的功能。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping enable
[Sysname-vsi-aaa] igmp-snooping drop-unknown
undo igmp-snooping enable
VLAN视图/VSI视图
【缺省级别】
2:系统级
无
【描述】
igmp-snooping enable命令用来在VLAN/VPLS实例内使能IGMP Snooping。undo igmp-snooping enable命令用来在VLAN/VPLS实例内关闭IGMP Snooping。
缺省情况下,VLAN/VPLS实例内的IGMP Snooping处于关闭状态。
需要注意的是,在VLAN/VPLS实例内使能IGMP Snooping之前,必须先全局使能IGMP Snooping,否则将无法在VLAN/VPLS实例内使能IGMP Snooping。
相关配置可参考命令igmp-snooping。
# 在VLAN 2内使能IGMP Snooping。
[Sysname] vlan 2
# 在VPLS实例aaa内使能IGMP Snooping。
[Sysname] vsi aaa
igmp-snooping fast-leave [ vlan vlan-list ]
undo igmp-snooping fast-leave [ vlan vlan-list ]
二层以太网接口视图/二层聚合接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
igmp-snooping fast-leave命令用来在端口上使能端口快速离开功能。端口快速离开是指当设备从某端口收到主机发送的离开某组播组的IGMP离开组报文时,直接把该端口从对应转发表项的出端口列表中删除。undo igmp-snooping fast-leave命令用来在端口上关闭端口快速离开功能。
·     在二层以太网接口或二层聚合口视图下配置时,如果未指定VLAN,则该配置将对该接口所属的每个VLAN分别生效;如果指定了VLAN,则只有当该接口属于指定VLAN时,该配置才生效。
·     在端口组视图下配置时,如果未指定VLAN,则该配置对该端口组内的所有端口都生效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口有效。
相关配置可参考命令fast-leave。
# 在VLAN 2内的端口GigabitEthernet2/1/1上使能端口快速离开功能。
[Sysname] interface GigabitEthernet 2/1/1
[Sysname-GigabitEthernet2/1/1] igmp-snooping fast-leave vlan 2
在VLAN视图下:
igmp-snooping general-query source-ip { ip-address | current-interface }
undo igmp-snooping general-query source-ip
在VSI视图下:
igmp-snooping general-query source-ip ip-address
VLAN视图/VSI视图
【缺省级别】
2:系统级
ip-address:指定任意合法IP地址作为发送IGMP普遍组查询报文时的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为IGMP普遍组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP普遍组查询报文的源IP地址。
【描述】
igmp-snooping general-query source-ip命令用来配置IGMP普遍组查询报文的源IP地址。undo igmp-snooping general-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询报文的源IP地址为0.0.0.0。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping general-query source-ip 10.1.1.1
# 在VPLS实例aaa内使能IGMP Snooping,并配置IGMP普遍组查询报文的源IP地址为10.1.1.1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping general-query source-ip 10.1.1.1
igmp-snooping group-limit limit [ vlan vlan-list ]
undo igmp-snooping group-limit [ vlan vlan-list ]
【缺省级别】
2:系统级
limit:表示端口加入的组播组最大数量,取值范围1~1024。
vlan vlan-list:表示端口在指定VLAN内加入的组播组最大数量。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping group-limit命令用来配置允许端口加入的组播组最大数量。undo igmp-snooping group-limit命令用来恢复缺省情况。
缺省情况下,允许端口在一个VLAN内加入的组播组最大数量为1024。
·     可以使用igmp group-limit命令限制接口上的组播组数量。而对于同一个VLAN,如果既对该VLAN内的端口进行限制,又对该VLAN接口进行限制,可能导致二、三层表项不一致,因此在这种情况下建议只限制VLAN接口上的组播组数量。
·     在二层以太网接口或二层聚合接口视图下配置时,如果未指定VLAN,则该配置将对该接口所属的每个VLAN分别生效;如果指定了VLAN,则只有当该接口属于指定VLAN时,该配置才生效。
·     端口组视图下配置时,如果未指定VLAN,则该配置将对该端口组内所有的端口都生效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口有效。
# 配置端口GigabitEthernet2/1/1在VLAN 2内加入的组播组最大数量为10个。
[Sysname-GigabitEthernet2/1/1] igmp-snooping group-limit 10 vlan 2
igmp-snooping group-policy acl-number [ vlan vlan-list ]
undo igmp-snooping group-policy [ vlan vlan-list ]
【缺省级别】
2:系统级
acl-number:指定基本或高级ACL的编号,取值范围为2000~3999。主机只能加入与该ACL规则中permit语句匹配的组播组。其中,高级ACL规则中的源地址是指IGMP报告报文中指定要接收的的组播源的地址(对于IGMPv1/v2报文和未携带组播源地址的IS_EX/TO_EX类型的IGMPv3报文,视其组播源地址为0.0.0.0),而不是IGMP报告报文的源地址。
【描述】
igmp-snooping group-policy命令用来在端口上配置组播组过滤器,以限定该端口下的主机所能加入的组播组。undo igmp-snooping group-policy命令用来在端口上删除组播组过滤器。
缺省情况下,端口上没有配置组播组过滤器,即该端口下的主机可以加入任意合法的组播组。
·     在端口组视图下配置时,如果未指定VLAN,则该配置将对该端口组内的所有端口都生效;如果指定了VLAN,则该配置只对该端口组内属于指定VLAN的那些端口生效。
相关配置可参考命令group-policy。
# 限定端口GigabitEthernet2/1/1下VLAN 2内的主机只能加入组播组225.1.1.1
[Sysname-GigabitEthernet2/1/1] igmp-snooping group-policy 2000 vlan 2
igmp-snooping host-aging-time interval
undo igmp-snooping host-aging-time
VLAN视图/VSI视图
【缺省级别】
2:系统级
【描述】
igmp-snooping host-aging-time命令用来在VLAN/VPLS实例内配置动态成员端口的老化时间。undo igmp-snooping host-aging-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping enable和host-aging-time。
# 在VLAN 2内使能IGMP Snooping,并配置动态成员端口的老化时间为300秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-aging-time 300
# 在VPLS实例aaa内使能IGMP Snooping,并配置动态成员端口的老化时间为300秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping host-aging-time 300
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
【缺省级别】
2:系统级
group-address:模拟主机要加入的组播组的地址,取值范围为224.0.1.0~239.255.255.255。
source-address:模拟主机要加入的组播源的地址,取值为有效的单播地址或0.0.0.0,0.0.0.0表示所有组播源。
vlan vlan-id:指定端口所属的VLAN。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping host-join命令用来配置模拟主机加入组播组或组播源组。模拟主机加入就是将设备的端口配置成为组播组的成员。undo igmp-snooping host-join命令用来恢复缺省情况。
缺省情况下,没有配置模拟主机加入组播组或组播源组。
·     模拟主机采用的IGMP版本与VLAN内的IGMP Snooping版本保持一致。
·     本命令对VLAN接口上使能了IGMP的VLAN也有效,且模拟主机采用的IGMP版本与VLAN接口上的IGMP版本保持一致。
·     只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但模拟主机在收到查询报文时并不会进行响应。
·     在二层以太网接口或二层聚合接口视图下配置时,只有当该接口属于指定VLAN时,该配置才生效;在端口组视图下配置时,该配置只对该端口组内属于指定VLAN的那些端口有效。
# 在VLAN 2内的端口GigabitEthernet2/1/1配置模拟主机加入组播源组(1.1.1.1, 232.1.1.1)。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping version 3
[Sysname-vlan2] quit
[Sysname-GigabitEthernet2/1/1] igmp-snooping host-join 232.1.1.1 source-ip 1.1.1.1 vlan 2
undo igmp-snooping host-tracking
VLAN视图
【缺省级别】
2:系统级
无
【描述】
igmp-snooping host-tracking命令用来在VLAN内使能IGMP Snooping主机跟踪功能。undo igmp-snooping host-tracking命令用来在VLAN内关闭IGMP Snooping主机跟踪功能。
在配置本命令之前,必须先在VLAN内使能IGMP Snooping。
相关配置可参考命令display igmp-snooping host、igmp-snooping enable和host-tracking。
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping主机跟踪功能。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping host-tracking
igmp-snooping last-member-query-interval interval
undo igmp-snooping last-member-query-interval
VLAN视图/VSI视图
【缺省级别】
2:系统级
interval:发送IGMP特定组查询报文的时间间隔,取值范围为1~5,单位为秒。
【描述】
igmp-snooping last-member-query-interval命令用来在VLAN/VPLS实例内配置发送IGMP特定组查询报文的时间间隔。undo igmp-snooping last-member-query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP特定组查询报文的时间间隔为1秒。
相关配置可参考命令igmp-snooping enable和last-member-query-interval。
# 在VLAN 2内使能IGMP Snooping,并配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping last-member-query-interval 3
# 在VPLS实例aaa内使能IGMP Snooping,并配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping last-member-query-interval 3
igmp-snooping leave source-ip { ip-address | current-interface }
undo igmp-snooping leave source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address:指定任意合法的IP地址作为代理发送IGMP离开报文的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为代理发送IGMP离开报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为代理发送IGMP离开报文的源IP地址。
【描述】
igmp-snooping leave source-ip命令用来配置代理发送IGMP离开报文的源IP地址。undo igmp-snooping leave source-ip命令用来恢复缺省情况。
缺省情况下,代理发送IGMP离开报文的源IP地址为0.0.0.0。
·     在配置本命令之前,必须先在VLAN内使能IGMP Snooping。
·     模拟主机发送的IGMP离开报文的源IP地址也采用本命令所配置的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置代理发送IGMP离开报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping leave source-ip 10.1.1.1
igmp-snooping max-response-time interval
undo igmp-snooping max-response-time
VLAN视图/VSI视图
【缺省级别】
2:系统级
interval:IGMP普遍组查询的最大响应时间,取值范围为1~25,单位为秒。
【描述】
igmp-snooping max-response-time命令用来在VLAN/VPLS实例内配置IGMP普遍组查询的最大响应时间。undo igmp-snooping max-response-time命令用来恢复缺省情况。
缺省情况下,IGMP普遍组查询的最大响应时间为10秒。
相关配置可参考命令igmp-snooping enable、max-response-time和igmp-snooping query-interval。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping max-response-time 5
# 在VPLS实例aaa内使能IGMP Snooping,并配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping max-response-time 5
igmp-snooping overflow-replace [ vlan vlan-list ]
undo igmp-snooping overflow-replace [ vlan vlan-list ]
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内配置组播组替换功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping overflow-replace命令用来在端口上使能组播组替换功能。undo igmp-snooping overflow-replace命令用来关闭端口上的组播组替换功能。
缺省情况下,组播组替换功能处于关闭状态。
相关配置可参考命令overflow-replace。
# 在VLAN 2内的端口GigabitEthernet2/1/1上使能组播组替换功能。
[Sysname-GigabitEthernet2/1/1] igmp-snooping overflow-replace vlan 2
undo igmp-snooping proxying enable
VLAN视图
【缺省级别】
2:系统级
无
【描述】
igmp-snooping proxying enable命令用来在VLAN内使能IGMP Snooping代理功能。undo igmp-snooping proxying enable命令用来在VLAN内关闭IGMP Snooping代理功能。
缺省情况下,VLAN内的IGMP Snooping代理功能处于关闭状态。
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping代理功能。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping proxying enable
在VLAN视图下:
undo igmp-snooping querier
在VSI视图下:
igmp-snooping querier [ first-tag vlan-id [ second-tag vlan-id ] ]
VLAN视图/VSI视图
【缺省级别】
2:系统级
first-tag vlan-id:指定IGMP普遍组查询报文的外层VLAN Tag,vlan-id为外层VLAN的编号,取值范围为1~4094。
second-tag vlan-id:指定IGMP普遍组查询报文的内层VLAN Tag,vlan-id为内层VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping querier命令用来使能IGMP Snooping查询器。undo igmp-snooping querier命令用来关闭IGMP Snooping查询器。
缺省情况下,IGMP Snooping查询器处于关闭状态。
·     在配置本命令之前,必须先在VLAN/VPLS实例内使能IGMP Snooping。
·     本命令在组播VLAN的子VLAN内配置时将不会生效。
相关配置可参考命令igmp-snooping enable,以及“IP组播命令参考/组播VLAN”中的命令subvlan。
# 在VLAN 2内使能IGMP Snooping,并使能IGMP Snooping查询器。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping querier
# 在VPLS实例aaa内使能IGMP Snooping,并使能IGMP Snooping查询器。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping querier
igmp-snooping query-interval interval
undo igmp-snooping query-interval
VLAN视图/VSI视图
【缺省级别】
2:系统级
interval:发送IGMP普遍组查询报文的时间间隔,取值范围为2~300,单位为秒。
【描述】
igmp-snooping query-interval命令用来配置发送IGMP普遍组查询报文的时间间隔。undo igmp-snooping query-interval命令用来恢复缺省情况。
缺省情况下,发送IGMP普遍组查询报文的时间间隔为60秒。
相关配置可参考命令igmp-snooping enable、igmp-snooping querier、igmp-snooping max-response-time和max-response-time。
# 在VLAN 2内使能IGMP Snooping,并配置发送IGMP普遍组查询报文的时间间隔为20秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping query-interval 20
# 在VPLS实例aaa内使能IGMP Snooping,并配置发送IGMP普遍组查询报文的时间间隔为20秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping query-interval 20
igmp-snooping report source-ip { ip-address | current-interface }
undo igmp-snooping report source-ip
VLAN视图
【缺省级别】
2:系统级
ip-address:指定任意合法的IP地址作为代理发送IGMP报告报文的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为代理发送IGMP报告报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为代理发送IGMP报告报文的源IP地址。
【描述】
igmp-snooping report source-ip命令用来配置代理发送IGMP报告报文的源IP地址。undo igmp-snooping report source-ip命令用来恢复缺省情况。
缺省情况下,代理发送IGMP报告报文的源IP地址为0.0.0.0。
·     模拟主机发送的IGMP报告报文的源IP地址也采用本命令所配置的源IP地址。
# 在VLAN 2内使能IGMP Snooping,并配置代理发送IGMP报告报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping report source-ip 10.1.1.1
igmp-snooping router-aging-time interval
undo igmp-snooping router-aging-time
VLAN视图/VSI视图
【缺省级别】
2:系统级
interval:动态路由器端口的老化时间,取值范围为1~1000,单位为秒。
【描述】
igmp-snooping router-aging-time命令用来在VLAN/VPLS实例内配置动态路由器端口的老化时间。undo igmp-snooping router-aging-time命令用来恢复缺省情况。
缺省情况下,动态路由器端口的老化时间为105秒。
相关配置可参考命令igmp-snooping enable和router-aging-time。
# 在VLAN 2内使能IGMP Snooping,并配置动态路由器端口的老化时间为100秒。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping router-aging-time 100
# 在VPLS实例aaa内使能IGMP Snooping,并配置动态路由器端口的老化时间为100秒。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping router-aging-time 100
igmp-snooping router-port-deny [ vlan vlan-list ]
undo igmp-snooping router-port-deny [ vlan vlan-list ]
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内禁止端口成为动态路由器端口。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。
【描述】
igmp-snooping router-port-deny命令用来禁止端口成为动态路由器端口。undo igmp-snooping router-port-deny命令用来恢复缺省情况。
缺省情况下,不禁止端口成为动态路由器端口。
# 在VLAN 2内禁止端口GigabitEthernet3/1/1成为动态路由器端口。
[Sysname] interface Gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] port link-mode bridge
[Sysname-GigabitEthernet3/1/1] igmp-snooping router-port-deny vlan 2
在VLAN视图下:
igmp-snooping special-query source-ip { ip-address | current-interface }
undo igmp-snooping special-query source-ip
在VSI视图下:
igmp-snooping special-query source-ip ip-address
VLAN视图/VSI视图
【缺省级别】
2:系统级
ip-address:指定IP地址作为发送IGMP特定组查询报文时的源IP地址。
current-interface:指定当前VLAN接口的IP地址作为IGMP特定组查询报文的源IP地址。如果当前VLAN的接口没有IP地址,则采用缺省的IP地址0.0.0.0作为IGMP特定组查询报文的源IP地址。
【描述】
igmp-snooping special-query source-ip命令用来配置IGMP特定组查询报文的源IP地址。undo igmp-snooping special-query source-ip命令用来恢复缺省情况。
缺省情况下,IGMP特定组查询报文的源IP地址为0.0.0.0。
# 在VLAN 2内使能IGMP Snooping,并配置IGMP特定组查询报文的源IP地址为10.1.1.1。
[Sysname] vlan 2
[Sysname-vlan2] igmp-snooping special-query source-ip 10.1.1.1
# 在VPLS实例aaa内使能IGMP Snooping,并配置IGMP特定组查询报文的源IP地址为10.1.1.1。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping special-query source-ip 10.1.1.1
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
undo igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
【缺省级别】
2:系统级
group-address:静态加入的组播组地址,取值范围为224.0.1.0~239.255.255.255。
source-address:静态加入的组播源地址,取值为有效的单播地址或0.0.0.0,0.0.0.0表示所有组播源。
【描述】
igmp-snooping static-group命令用来配置静态成员端口,即配置端口静态加入组播组或组播源组。undo igmp-snooping static-group命令用来恢复缺省情况。
缺省情况下,端口不是静态成员端口。
·     只有当IGMP Snooping的版本为3时,配置参数source-ip source-address才会有实际的意义;当IGMP Snooping的版本为2时,虽然也可以配置参数source-ip source-address,但该配置将不会生效。
# 在VLAN 2内的端口GigabitEthernet2/1/1上配置静态加入组播源组(1.1.1.1,232.1.1.1)。
[Sysname] vlan 2
[Sysname-GigabitEthernet2/1/1] igmp-snooping static-group 232.1.1.1 source-ip 1.1.1.1 vlan 2
igmp-snooping static-router-port vlan vlan-id
undo igmp-snooping static-router-port vlan vlan-id
【缺省级别】
2:系统级
vlan vlan-id:在指定VLAN内配置静态路由器端口。vlan-id为指定VLAN的编号,取值范围为1~4094。
【描述】
igmp-snooping static-router-port命令用来配置静态路由器端口。undo igmp-snooping static-router-port命令用来恢复缺省情况。
缺省情况下,端口不是静态路由器端口。
相关配置可参考“IP组播命令参考/组播VLAN”中的命令subvlan。
# 在VLAN 2内的端口GigabitEthernet2/1/1上配置静态路由器端口。
[Sysname-GigabitEthernet2/1/1] igmp-snooping static-router-port vlan 2
igmp-snooping version version-number
undo igmp-snooping version
VLAN视图/VSI视图
【缺省级别】
2:系统级
version-number:表示IGMP Snooping的版本号,取值范围为2~3。
【描述】
igmp-snooping version命令用来配置IGMP Snooping的版本。undo igmp-snooping version命令用来恢复缺省情况。
缺省情况下,IGMP Snooping的版本为2。
相关配置可参考命令igmp-snooping enable以及“IP组播命令参考/组播VLAN”中的命令subvlan。
# 在VLAN 2内使能IGMP Snooping,并将其版本配置为3。
[Sysname] vlan 2
# 在VPLS实例aaa内使能IGMP Snooping,并将其版本配置为3。
[Sysname] vsi aaa
[Sysname-vsi-aaa] igmp-snooping version 3
undo last-member-query-interval
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
last-member-query-interval命令用来全局配置发送IGMP特定组查询报文的时间间隔。undo last-member-query-interval命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping last-member-query-interval。
# 全局配置发送IGMP特定组查询报文的时间间隔为3秒。
[Sysname-igmp-snooping] last-member-query-interval 3
undo max-response-time
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
max-response-time命令用来全局配置IGMP普遍组查询的最大响应时间。undo max-response-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping max-response-time和igmp-snooping query-interval。
# 全局配置IGMP普遍组查询的最大响应时间为5秒。
[Sysname-igmp-snooping] max-response-time 5
undo overflow-replace [ vlan vlan-list ]
IGMP-Snooping视图
【缺省级别】
2:系统级
vlan vlan-list:在指定VLAN内配置组播组替换功能。vlan-list为VLAN列表,表示多个VLAN。其表示方式为vlan-list = { vlan-id [ to vlan-id ] }&<1-10>,其中,vlan-id为指定VLAN的编号,取值范围为1~4094。&<1-10>表示前面的参数最多可以输入10次。如果指定了本参数,本配置只对指定VLAN有效;如果未指定本参数,则本配置将对所有VLAN/VPLS实例都有效。
【描述】
overflow-replace命令用来全局使能组播组替换功能。undo overflow-replace命令用来全局关闭组播组替换功能。
需要注意的是,本命令对VLAN接口上使能了IGMP的VLAN也有效。
相关配置可参考命令igmp-snooping overflow-replace。
# 在VLAN 2内全局使能组播组替换功能。
[Sysname-igmp-snooping] overflow-replace vlan 2
report-aggregation
undo report-aggregation
IGMP-Snooping视图
【缺省级别】
2:系统级
无
【描述】
report-aggregation命令用来使能IGMP成员关系报告报文抑制功能。undo report-aggregation命令用来关闭IGMP成员关系报告报文抑制功能。
缺省情况下,IGMP成员关系报告报文抑制功能处于使能状态。
# 关闭IGMP成员关系报告报文抑制功能。
[Sysname-igmp-snooping] undo report-aggregation
reset igmp-snooping group { group-address | all } [ vlan vlan-id | vsi vsi-name ]
【缺省级别】
2:系统级
group-address:指定组播组,取值范围为224.0.1.0~239.255.255.255。
all:表示所有组播组。
vlan vlan-id:指定VLAN的编号,取值范围为1~4094。
vsi vsi-name:指定VPLS实例的名称,为1~31个字符的字符串。
【描述】
reset igmp-snooping group命令用来清除IGMP Snooping组的动态加入记录。
需要注意的是,本命令只能清除动态加入记录,而无法清除静态加入记录。
# 清除所有IGMP Snooping组的动态加入记录。
<Sysname> reset igmp-snooping group all
【缺省级别】
2:系统级
无
【描述】
reset igmp-snooping statistics命令用来清除IGMP Snooping监听到的所有IGMP报文的统计信息。
# 清除IGMP Snooping监听到的所有IGMP报文的统计信息。
<Sysname> reset igmp-snooping statistics
undo router-aging-time
IGMP-Snooping视图
【缺省级别】
2:系统级
【描述】
router-aging-time命令用来全局配置动态路由器端口的老化时间。undo router-aging-time命令用来恢复缺省情况。
相关配置可参考命令igmp-snooping router-aging-time。
# 全局配置动态路由器端口的老化时间为100秒。
[Sysname-igmp-snooping] router-aging-time 100
