07-Password Control命令
本章节下载: 07-Password Control命令 (157.81 KB)
1.1.1 display password-control
1.1.2 display password-control blacklist
1.1.5 password-control alert-before-expire
1.1.6 password-control authentication-timeout
1.1.7 password-control complexity
1.1.8 password-control composition
1.1.9 password-control { aging | composition | history | length } enable
1.1.10 password-control enable
1.1.11 password-control expired-user-login
1.1.12 password-control history
1.1.13 password-control length
1.1.14 password-control login idle-time
1.1.15 password-control login-attempt
1.1.16 password-control password update interval
1.1.17 password-control super aging
1.1.18 password-control super composition
1.1.19 password-control super length
1.1.20 reset password-control blacklist
1.1.21 reset password-control history-record
display password-control [ super ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
super:显示super密码的管理信息。如果不指定该参数,将显示全局密码管理的信息。
|:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display password-control命令用来显示密码管理的配置信息。
# 显示全局密码管理信息。
Password control: Disabled
Password aging: Enabled (90 days)
Password length: Enabled (10 characters)
Password composition: Enabled (1 types, 1 characters per type)
Password history: Enabled (max history records:4)
Early notice on password expiration: 7 days
User authentication timeout: 60 seconds
Maximum failed login attempts: 3 times
Login attempt-failed action: Lock for 1 minutes
Minimum password update time: 24 hours
User account idle-time: 90 days
Login with aged password: 3 times in 30 days
Password complexity: Disabled (username checking)
Disabled (repeated characters checking)
# 显示super密码管理信息。
Super password configurations:
表1-1 display password-control命令显示信息描述表
| 字段 | 描述 |
| Password control | 密码管理功能 |
| Password aging | 密码老化功能 |
| Password length | 最小密码长度功能 |
| Password composition | 组合密码功能 |
| Password history | 密码历史功能 |
| Early notice on password expiration | 密码老化提醒功能 |
| User authentication timeout | 认证超时功能 |
| Maximum failed login attempts | 登录失败尝试次数功能 |
| Login attempt-failed action | 登录失败尝试次数达到设定次数后的锁定行为功能 |
| Minimum password update time | 密码更新的最小时间间隔 |
| User account idle-time | 用户帐号闲置时间 |
| Login with aged password | 密码过期后允许用户登录功能 |
| Password complexity | 密码复杂度检查功能,可检查内容包括:是否包含用户名或者颠倒的用户名;是否包含三个或以上相同字符 |
display password-control blacklist [ user-name name | ip ipv4-address | ipv6 ipv6-address ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
2:系统级
user-name name:显示黑名单中指定用户名的用户信息。其中,name表示用户名,为1~80个字符的字符串。
ipv4-address:显示黑名单中指定IPv4地址的用户信息。
ipv6-address:显示黑名单中指定IPv6地址的用户信息。
【描述】
display password-control blacklist命令用来显示用户认证失败后,被加入黑名单中的用户信息。
如果不指定任何参数,则显示黑名单中的所有用户信息。
# 显示用户尝试失败后,被加入黑名单中的用户信息。
<Sysname> display password-control blacklist
Username: test
IP: 192.168.44.1 Login failed times: 1 Lock flag: unlock
Total 1 blacklist item(s) matched. 1 listed.
表1-2 display password-control blacklist命令显示信息描述表
| 字段 | 描述 |
| Username | 用户名 |
| IP | 登录IP地址 |
| Login failed times | 登录失败的次数 |
| Lock flag | 该用户是否被锁定 · unlock:表示未锁定,允许用户再次尝试登录 · lock:表示锁定,暂时或永久禁止用户尝试登录(具体由password-control login-attempt命令的配置情况决定) |
password
undo password
本地用户视图
【缺省级别】
2:系统级
无
【描述】
password命令用来以交互式方式设置本地用户密码,undo password命令用来删除本地用户密码。
· 密码可以包含的字符为:[A~Z]、[a~z]、[0~9]以及32个特殊字符(空格~`!@#$%^&*()_+-={}|[]\:”;’<>,./)。
· 以交互式方式设置本地用户密码时,密码必须符合密码管理的相关配置。例如,当密码的最小长度限制为8个字符时,输入的密码就必须大于或等于8个字符。
# 以交互式方式设置本地用户密码。
[Sysname] local-user test
[Sysname-luser-test] password
Password:**********
Confirm :**********
Updating user(s) information, please wait....
undo password-control aging
系统视图/用户组/本地用户视图
【缺省级别】
2:系统级
aging-time:密码的老化时间,取值范围为1~365,单位为天。
【描述】
password-control aging命令用来配置密码的老化时间。undo password-control aging命令用来恢复缺省情况。
缺省情况下,全局的密码老化时间为90天;用户组的密码老化时间为全局配置的密码老化时间;本地用户的密码老化时间为所属用户组的密码老化时间,若用户组未配置该值,则采用全局配置值。
· 系统视图下配置具有全局性,对所有用户组有效,用户组视图下的配置对用户组内所有本地用户有效,本地用户视图下的配置只对当前本地用户有效。
· 本地用户密码老化时间生效的优先级顺序由高到底依次为本地用户视图、用户组视图、全局视图。即,系统优先采用本地用户视图下的配置,若本地用户视图下未配置,则采用用户组视图下的配置,若用户组视图下也未配置,则采用全局视图下的配置。
相关配置可参考命令display password-control和“安全命令参考/AAA配置命令”中的命令local-user、user-group。
# 配置全局的密码老化时间为80天。
[Sysname] password-control aging 80
# 配置用户组test的密码老化时间为90天。
[Sysname] user-group test
[Sysname-ugroup-test] password-control aging 90
[Sysname-ugroup-test] quit
# 配置本地用户abc的密码老化时间为100天。
[Sysname] local-user abc
[Sysname-luser-abc] password-control aging 100
undo password-control alert-before-expire
【缺省级别】
2:系统级
alert-time:密码过期前的提醒时间,取值范围为1~30,单位为天。
【描述】
password-control alert-before-expire命令用来配置密码过期前的提醒时间。undo password-control alert-before-expire命令用来恢复缺省情况。
缺省情况下,密码过期前的提醒时间为7天,表示在密码过期之前7天提醒用户密码即将老化。
# 设定密码过期前的提醒时间为10天。
[Sysname] password-control alert-before-expire 10
password-control authentication-timeout authentication-timeout
undo password-control authentication-timeout
【缺省级别】
2:系统级
authentication-timeout:用户认证的超时时间,取值范围为30~120,单位为秒。
【描述】
password-control authentication-timeout命令用来配置用户认证的超时时间。undo password-control authentication-timeout命令用来恢复缺省情况。
缺省情况下,用户认证的超时时间为60秒。
# 设定用户认证的超时时间为40秒。
[Sysname] password-control authentication-timeout 40
undo password-control complexity { same-character | user-name } check
【缺省级别】
2:系统级
same-character:指定检查密码中是否包含连续三个或以上相同的字符。
user-name:指定检查密码中是否包含用户名或者颠倒的用户名。
【描述】
password-control complexity命令用来配置用户密码的复杂度检查策略。undo password-control complexity check命令用来取消指定的密码复杂度检查策略。
缺省情况下,不对用户密码进行复杂度检查,允许密码中包含用户名或者颠倒的用户名,也允许包含连续三个或以上的相同字符。
相关配置可参考命令display password-control。
# 配置密码复杂度检测策略,具体要求为:检查配置的密码中是否包含用户名或者颠倒的用户名,若密码不符合复杂度策略,则密码设置不成功。
undo password-control composition
系统视图/用户组/本地用户视图
【缺省级别】
2:系统级
type-number type-number:密码元素的最少组合类型。其中,type-number表示组合类型的个数,取值范围为1~4。
type-length type-length:密码中至少要包含每种元素的个数。其中,type-length表示元素个数,取值范围为1~63。
【描述】
password-control composition命令用来配置用户密码的组合策略。undo password-control composition命令用来恢复缺省情况。
缺省情况下,全局的密码元素的最少组合类型为1种,至少要包含每种元素的个数为1个;用户组的密码组合策略为全局配置的密码组合策略;本地用户的密码组合策略为所属用户组的密码组合策略,若用户组未配置该值,则采用全局配置值。
· 本地用户密码组合策略生效的优先级顺序由高到底依次为本地用户视图、用户组视图、全局视图。即,系统优先采用本地用户视图下的配置,若本地用户视图下未配置,则采用用户组视图下的配置,若用户组视图下也未配置,则采用全局视图下的配置。
# 配置全局的密码元素的最少组合类型为3种,至少要包含每种元素的个数为5个。
[Sysname] password-control composition type-number 3 type-length 5
# 配置用户组test的密码元素的最少组合类型为3种,至少要包含每种元素的个数为5个。
[Sysname-ugroup-test] password-control composition type-number 3 type-length 5
# 配置本地用户abc的密码元素的最少组合类型为3种,至少要包含每种元素的个数为5个。
[Sysname-luser-abc] password-control composition type-number 3 type-length 5
undo password-control { aging | composition | history | length } enable
【缺省级别】
2:系统级
aging:使能密码老化管理功能。
composition:使能密码的组合检测管理功能。
history:使能密码历史记录管理功能。
length:使能密码最小长度管理功能。
【描述】
password-control { aging | composition | history | length } enable命令用来使能指定的密码管理的相关功能。undo password-control { aging | composition | history | length } enable命令用来关闭指定的密码管理的相关功能。
缺省情况下,各密码管理功能均处于使能状态。
· 要使相关的密码管理功能生效,必须保证全局密码管理功能处于使能状态。
· 如果没有使能指定的密码管理功能,则它对应的密码管理策略配置将不起作用。例如,若密码最小长度管理功能处于未使能状态,则password-control length命令配置的具体长度限制就不生效。
· 如果执行命令undo password-control history enable,在此之前的历史记录依然保存,命令执行之后将不再记录历史密码。
相关配置可参考命令password-control enable和 display password-control。
# 使能全局密码管理功能。
# 使能密码组合检测管理功能。
[Sysname] password-control composition enable
# 使能密码老化功能。
[Sysname] password-control aging enable
# 使能密码最小长度功能。
[Sysname] password-control length enable
# 使能密码历史记录功能。
[Sysname] password-control history enable
undo password-control enable
【缺省级别】
2:系统级
无
【描述】
password-control enable命令用来使能全局密码管理功能。undo password-control enable命令用来关闭全局密码管理功能。
缺省情况下,全局的密码管理能处于未使能状态。
只有在使能了全局密码管理功能的情况下,其它相关的密码管理功能才能生效。
# 使能全局密码管理功能。
undo password-control expired-user-login
【缺省级别】
2:系统级
delay:密码过期后允许用户登录的时长,取值范围为1~90,单位为天。
times:密码过期后允许用户登录的最大次数,取值范围为0~10。0表示密码过期后不允许用户登录。
【描述】
password-control expired-user-login命令用来配置密码过期后允许登录的时间和次数。undo password-control expired-user-login命令用来恢复缺省情况。
缺省情况下,密码过期后允许登录的时间为30天,允许登录的次数为3次,表示如果密码过期,那么系统还允许用户在30天内登录3次。
# 设定允许用户在密码过期之后的60天内登录5次。
password-control history max-record-num
【缺省级别】
2:系统级
max-record-num:每个用户密码历史记录的最大条数,取值范围为2~15。
【描述】
password-control history命令用来配置每个用户密码历史记录的最大条数。undo password-control history命令用来恢复缺省情况。
缺省情况下,每个用户密码历史记录的最大条数为4条。
# 设定每个用户密码历史记录的最大条数为10条。
[Sysname] password-control history 10
undo password-control length
系统视图/用户组/本地用户视图
【缺省级别】
2:系统级
length:密码的最小长度,取值范围为4~32。
【描述】
password-control length命令用来配置密码的最小长度。undo password-control length命令用来恢复缺省情况。
缺省情况下,全局的密码最小长度为10个字符,本地用户的密码最小长度为全局配置。用户组的密码最小长度为全局配置的密码最小长度;本地用户的密码最小长度为所属用户组的密码最小长度,若用户组未配置该值,则采用全局配置值。
· 本地用户密码最小长度生效的优先级顺序由高到底依次为本地用户视图、用户组视图、全局视图。即,系统优先采用本地用户视图下的配置,若本地用户视图下未配置,则采用用户组视图下的配置,若用户组视图下也未配置,则采用全局视图下的配置。
# 配置全局的密码最小长度为9个字符。
[Sysname] password-control length 9
# 配置用户组test的密码最小长度为9个字符。
[Sysname-ugroup-test] password-control length 9
# 配置本地用户abc的密码最小长度为9个字符。
[Sysname-luser-abc] password-control length 9
undo password-control login idle-time
【缺省级别】
2:系统级
idle-time:用户帐号的闲置时间,取值范围为0~365,单位为天。0表示对用户帐号闲置时间无限制。
【描述】
password-control login idle-time命令用来配置用户帐号的闲置时间。undo password-control login idle-time命令用来恢复缺省情况。
缺省情况下,用户帐号的闲置时间为90天,表示如果用户自最后一次成功登录后,在90天内再未成功登录过设备,那么该用户帐号将会失效。
# 设定用户帐号的闲置时间为30天,表示自最后一次成功登录后,若用户在30天内再未成功登录过设备,那么将该用户帐号将会失效。
undo password-control login-attempt
【缺省级别】
2:系统级
login-times:用户登录尝试次数,取值范围为2~10。
exceed:用户登录尝试失败后的行为。
lock:表示永久禁止该用户登录。
lock-time time:表示禁止该用户一段时间后,再允许该用户重新登录。其中,time为禁止该用户的时间,取值范围为1~360,单位为分钟。
unlock:表示不禁止该用户,允许其继续登录。
【描述】
password-control login-attempt命令用来配置用户登录尝试次数以及登录尝试失败后的行为。undo password-control login-attempt命令用来恢复缺省情况。
缺省情况下,用户登录尝试次数为3次;如果用户登录失败,则1分钟后再允许该用户重新登录。
· 对于被永久禁止登录的用户,只有管理员把该用户从黑名单中删除后,该用户才能重新登录。
· 对于被禁止一段时间内登录的用户,当配置的禁止时间超时或者管理员将其从黑名单中删除,该用户才可以重新登录。
· 对于不禁止登录的用户,只要用户登录成功或者黑名单的老化时间(系统规定为1分钟)超时后,该用户就会从黑名单中被删除。
相关配置可参考命令display password-control、display password-control blacklist和reset password-control blacklist。
# 管理员设定用户登录尝试次数为4次,并且永久禁止该用户登录。
[Sysname] password-control login-attempt 4 exceed lock
之后,若有用户连续尝试认证的失败累加次数达到4次,管理员可通过命令查看到被加入黑名单中的用户锁定状态由之前的unlock切换为lock,且该用户无法再次成功登录。
[Sysname] display password-control blacklist
Username: test
IP: 192.168.44.1 Login failed times: 4 Lock flag: lock
# 管理员设定用户登录尝试次数为2次,并且禁止该用户3分钟后,再允许该用户重新登录。
[Sysname] password-control login-attempt 2 exceed lock-time 3
之后,若有用户连续尝试认证的失败累加次数达到2次,管理员可通过命令查看到被加入黑名单中的用户锁定状态由之前的unlock切换为lock。
Username: test
IP: 192.168.44.1 Login failed times: 2 Lock flag: lock
用户被禁止登录3分钟后,将被从黑名单中删除,且可以重新登录。
password-control password update interval interval
undo password-control password update interval
【缺省级别】
2:系统级
interval:密码更新的最小时间间隔,取值范围为0~168,单位为小时。0表示对密码更新的时间间隔无限制。
【描述】
password-control password update interval命令用来配置密码更新的最小时间间隔。undo password-control password update interval命令用来恢复缺省情况。
缺省情况下,密码更新的最小时间间隔为24小时。
需要注意的是,有两种情况下的密码更新并不受该功能的约束:用户首次登录设备时系统要求用户修改密码;密码老化后系统要求用户修改密码。
# 设定密码更新的最小时间间隔为36小时。
[Sysname] password-control password update interval 36
undo password-control super aging
【缺省级别】
2:系统级
aging-time:super密码的老化时间,取值范围为1~365,单位为天。
【描述】
password-control super aging命令用来配置super密码的老化时间。undo password-control super aging命令用来恢复缺省情况。
缺省情况下,密码的老化时间为90天。
需要注意的是,对于super密码的各管理参数来说,系统优先采用为super密码的单独配置;当没有为super密码进行单独配置时,采用全局配置。
相关配置请参考命令password-control aging。
# 设定super密码的老化时间为10天。
[Sysname] password-control super aging 10
undo password-control super composition
【缺省级别】
2:系统级
type-number type-number:super密码的最少组合类型。其中,type-number表示组合类型,取值范围为1~4。
type-length type-length:super密码中每种类型的最少字符个数。其中,type-length表示字符个数,取值范围为1~16。
【描述】
password-control super composition命令用来配置super密码的组合策略。undo password-control super composition命令用来恢复缺省情况。
缺省情况下,组合密码的最少组合类型为1种,组合密码中每种类型的最少字符个数为1个。
相关配置请参考命令password-control composition。
# 配置super密码的最少组合类型为3种,每种类型的最少字符个数为5个。
[Sysname] password-control super composition type-number 3 type-length 5
undo password-control super length
【缺省级别】
2:系统级
length:super密码的最小字符长度,取值范围为4~16。
【描述】
password-control super length命令用来配置super密码的最小长度。undo password-control super length命令用来恢复缺省情况。
缺省情况下,密码的最小长度为10个字符。
相关配置请参考命令password-control length。
# 设定super密码的最小长度为10个字符。
[Sysname] password-control super length 10
reset password-control blacklist [ user-name name ]
【缺省级别】
3:管理级
user-name name:删除黑名单中指定的用户。其中,name表示用户名,为1~80个字符的字符串,区分大小写。
【描述】
reset password-control blacklist命令用来清除黑名单中的用户。
相关配置请参考命令display password-control blacklist。
# 清除黑名单中的用户test。
<Sysname> reset password-control blacklist user-name test
Are you sure to delete the specified user in blacklist? [Y/N]:
reset password-control history-record [ user-name name | super [ level level ] ]
【缺省级别】
3:管理级
user-name name:删除指定用户名的密码历史记录。其中,name表示用户名,为1~80个字符的字符串,区分大小写。
super:删除super密码的历史记录。
level level:指定用户级别。其中,level表示用户级别,取值范围为1~3。
【描述】
reset password-control history-record命令用来清除用户的密码历史记录。
· 如果不指定任何参数,将删除所有本地用户的密码历史记录。
· 如果不指定参数level,将删除所有super密码的历史记录。
# 清除所有本地用户的密码历史记录。当用户输入Y,系统删除所有本地用户的密码历史记录。
<Sysname> reset password-control history-record
Are you sure to delete all local user's history records? [Y/N]:
