05-WLAN RRM命令
本章节下载: 05-WLAN RRM命令 (331.13 KB)
1.1.1 adjacent-channel interference trap
1.1.3 autochannel-set avoid-dot11h
1.1.5 co-channel interference trap
1.1.7 display wlan ap rrm-history
1.1.8 display wlan ap rrm-status
1.1.9 display wlan mesh calibrate-channel history(仅AC支持)
1.1.11 display wlan rrm-calibration-group
1.1.13 dot11a adjacency-factor
1.1.14 dot11a calibrate-channel
1.1.15 dot11a calibrate-channel pronto
1.1.16 dot11a calibrate-channel self-decisive
1.1.18 dot11a calibrate-power min
1.1.19 dot11a calibrate-power pronto
1.1.20 dot11a calibrate-power self-decisive
1.1.21 dot11a calibrate-power threshold
1.1.22 dot11a calibration-interval
1.1.23 dot11a crc-error-threshold
1.1.25 dot11a interference-threshold
1.1.30 dot11bg adjacency-factor
1.1.31 dot11bg calibrate-channel
1.1.32 dot11bg calibrate-channel pronto
1.1.33 dot11bg calibrate-channel self-decisive
1.1.34 dot11bg calibrate-power min
1.1.35 dot11bg calibrate-power
1.1.36 dot11bg calibrate-power pronto
1.1.37 dot11bg calibrate-power self-decisive
1.1.38 dot11bg calibrate-power threshold
1.1.39 dot11bg calibration-interval
1.1.40 dot11bg crc-error-threshold
1.1.41 dot11bg exclude-channel
1.1.42 dot11bg interference-threshold
1.1.43 dot11bg tolerance-level
1.1.46 dot11g protection enable
1.1.48 dot11n mandatory maximum-mcs
1.1.51 dot11n protection enable
1.1.54 mesh calibrate-channel pronto
1.1.55 mesh calibrate-channel self-decisive
1.1.56 dot11n support maximum-mcs
1.1.62 spectrum-management enable
1.1.64 wlan rrm-calibration-group
1.2.3 load-balance access-denial
1.2.4 load-balance rssi-threshold
1.2.5 display wlan load-balance-group
1.3.1 band-navigation aging-time
1.3.2 band-navigation balance access-denial
1.3.3 band-navigation balance session
1.3.4 band-navigation enable (WLAN RRM View)
1.3.5 band-navigation enable (AP Template View)
1.3.6 band-navigation rssi-threshold
adjacent-channel interference trap threshold value
undo adjacent-channel interference trap threshold
RRM视图
【缺省级别】
2:系统级
threshold value:邻频干扰告警门限值,取值范围为10~90,单位为dBm,代表功率范围为-90~-10。如果设备检测到的邻频干扰达到指定值,则向网络管理系统发送Trap消息。
【描述】
adjacent-channel interference trap threshold命令用来配置邻频干扰告警门限值。undo adjacent-channel interference trap threshold命令用来恢复缺省情况。
缺省情况下,邻频干扰告警门限值为60。
# 配置邻频干扰告警门限值为80。
[Sysname] wlan rrm
[Sysname-wlan rrm] adjacent-channel interference trap threshold 80
ap ap-name radio radio-number
undo ap { ap-name [ radio radio-number ] | all }
RRM保持调整组视图
【缺省级别】
2:系统级
ap-name:加入RRM保持调整组的AP名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写。加入RRM保持调整组的AP必须已经存在。
radio-number:将AP的第几个Radio加入RRM保持调整组。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:删除RRM保持调整组中的所有Radio。
【描述】
ap radio命令用来将AP的Radio加入到RRM保持调整组中。undo ap ap-name用来删除RRM保持调整组中的Radio。
缺省情况下,RRM保持调整组中不存在任何AP的Radio。
· 删除RRM保持调整组中的Raido时,如果使用undo ap ap-name命令(即不指定radio radio-number参数时)表示删除RRM保持调整组中指定AP的所有Radio。
· RRM保持调整组中的成员单位为Radio。
· 一个Radio只能加入一个RRM保持调整组。
# 将ap1的第2个Radio加入到ID为10的RRM保持调整组中。
[Sysname] wlan rrm-calibration-group 10
[Sysname-wlan-rc-group-10] ap ap1 radio 2
# 删除ID为10的RRM保持调整组中的所有Radio。
[Sysname-wlan-rc-group-10] undo ap all
# 删除RRM保持调整组10中ap1的所有Radio。
[Sysname-wlan-rc-group-10] undo ap ap1
# 删除RRM保持调整组10中ap1的第2个Radio。
[Sysname-wlan-rc-group-10] undo ap ap1 radio 2
undo autochannel-set avoid-dot11h
RRM视图
【缺省级别】
2:系统级
无
【描述】
autochannel-set avoid-dot11h命令用来配置扫描非dot11h信道。配置此功能后,设备在初始信道选择时,只扫描属于配置国家代码的非dot11h信道,此时如果也配置了自动信道选择功能,将在被扫描的信道中选择一个使用。undo autochannel-set avoid-dot11h命令用来恢复缺省情况。
缺省情况下,扫描国家码支持的所有信道。
autochannel-set avoid-dot11h命令的缺省情况和scan channel命令的设置情况有关。
相关命令可参考scan channel。
# 配置扫描非dot11h信道。
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
channel holddown-time minutes
undo channel holddown-time
RRM保持调整组视图
【缺省级别】
2:系统级
minutes:信道保持时长,表示信道在每次调整后(包括手动调整、自动调整和初始信道选择)的指定时间内将保持不变,取值范围为10~1440,单位为分钟。
【描述】
channel holddown-time命令用来配置信道保持时长。undo channel holddown-time命令用来恢复缺省情况。
缺省情况下,信道保持时长为720分钟。
需要注意的是,如果AC在信道保持时长内检测到信道内存在雷达信号,AC会立即重新选择信道,选定新的信道后,信道保持时长会重新开始计时。
# 为RRM保持调整组10配置信道保持时长为600分钟。
[Sysname-wlan-rc-group-10] channel holddown-time 600
co-channel interference trap threshold value
undo co-channel interference trap threshold
RRM视图
【缺省级别】
2:系统级
threshold value:同频干扰告警门限值,取值范围为10~90,单位为dBm,代表功率范围为-90~-10。如果设备检测到的同频干扰达到指定值,则向网络管理系统发送Trap消息。
【描述】
co-channel interference trap命令用来配置同频干扰告警门限值。undo co-channel interference trap命令用来恢复缺省情况。
缺省情况下,同频干扰告警门限值为60。
# 配置同频干扰告警门限值为80。
[Sysname] wlan rrm
[Sysname-wlan rrm] co-channel interference trap threshold 80
RRM保持调整组
【缺省级别】
2:系统级
text:RRM保持调整组的描述信息,为1~64个字符的字符串,可以包含字母、数字和下划线,区分大小写。
【描述】
description命令用来配置RRM保持调整组的描述信息。undo description命令用来恢复缺省情况。
缺省情况下,RRM保持调整组没有描述信息。
# 配置RRM保持调整组10的描述信息为office。
[Sysname-wlan-rc-group-10] description office
display wlan ap { all | name ap-name } rrm-history [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
name ap-name:AP名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写,不可以包含空格。
|:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display wlan ap name ap-name rrm-history命令用来显示AP的RRM历史信息。display wlan ap all rrm-history命令用来显示所有AP的RRM历史信息。此命令用来显示所有或指定名称的AP上最近3个改变的信道或功率的详细信息。命令输出包括改变时间、触发原因、功率、冲突等参数。
# 显示ap1的RRM详细信息。
<Sysname> display wlan ap name ap1 rrm-history
AP RRM History
Flags : I - Interference, P - Packets discarded, F - Retransmission,
R - Radar, C - Coverage, O - Others
AP RRM History : ap1
Radio : 1 Basic BSSID : 000f-e2ff-7700
Chl Power Load Util Intf PER Retry Reason Date Time
(dBm) (%) (%) (%) (%) (%) (yyyy-mm-dd) (hh:mm:ss)
Before 6 20 24 2 21 11 18 -P---- 2008-01-07 17:31:50
After 1 20 9 0 8 0 27 - - -
Before 1 20 54 1 53 11 15 IP---- 2008-01-08 12:19:50
After 6 20 10 0 10 3 29 - - -
Before 6 20 29 1 28 21 20 -P---- 2008-01-08 12:59:50
After 1 20 30 0 29 2 24 - - -
表1-1 display wlan ap name rrm-history命令显示信息描述表
Radio |
AP的射频 |
Basic BSSID |
基本服务集标识,AP的Radio接口的MAC地址 |
Chl |
信道,channel number的缩写形式。射频或功率改变时,射频运行的信道 |
Power |
射频或功率改变时,射频运行的功率 |
Load |
射频或功率改变时,射频上观测到的负载,以百分比表示 |
Util |
射频利用率,utilization的缩写形式。射频或功率改变时,射频利用率,以百分比表示 |
Intf |
干扰,interference的缩写形式。射频或功率改变时,射频上观测到的冲突,以百分比表示 |
PER |
包错误率,packet error rate的缩写形式。信道中观测到的包错误率,以百分比显示。 |
Retry |
重传率,retransmission rate的缩写形式。射频或功率改变时,射频上发生的重传,以百分比表示 |
Reason |
射频或功率改变的原因,如冲突、噪声、包丢弃、重传、反射和覆盖 |
Date |
显示射频或功率改变发生的日期 |
Time |
显示射频或功率改变发生的时间 |
display wlan ap { all | name ap-name } rrm-status [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
all:所有AP。
name ap-name:AP名称,为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”不区分大小写,不可以包含空格。
【描述】
display wlan ap { all | name apname } rrm-status命令用来显示所有AP或指定名称的AP的每个射频的RRM详细信息。如:AP运行的信道、AP功率级别、观测到的冲突以及邻居的数量。
在AC设备上,如果RRM处于未使能状态,或射频采用了固定信道,则执行此命令时,只会显示
AP相应射频的运行信道和功率级别,其他信息如冲突、邻居的数量等不会显示。这里的RRM使能是指动态功率选择或信道自动优化功能处于开启状态。
# 显示ap1的RRM详细信息。
<Sysname> display wlan ap name ap1 rrm-status
AP RRM Profile : ap1
Channel : 6 (Good) Tx Power (dBm) : 20
Chl NbrCnt Load Util Intf PER Retry Radar
1 6 33 - 33 1 - -
6 6 25 0 25 8 0 -
11 4 48 - 48 5 - -
Nbr-BasicBSSID Chl Intf SignalStrength Type
(%) (dBm)
000f-e20c-4080 6 8 -69 Unmanaged
000f-e211-2220 6 0 -63 Unmanaged
000f-e232-5500 6 1 -79 Unmanaged
000f-e23e-e740 1 1 -71 Unmanaged
000f-e23e-e760 1 1 -63 Unmanaged
000f-e25d-f3c0 11 0 -59 Unmanaged
000f-e25d-f420 1 2 -89 Unmanaged
000f-e267-9990 1 8 -80 Unmanaged
000f-e267-9b10 11 0 -65 Unmanaged
000f-e26c-2980 6 0 -85 Unmanaged
000f-e26e-5f00 11 0 -63 Unmanaged
000f-e274-1020 6 5 -60 Unmanaged
000f-e299-5510 1 2 -78 Unmanaged
000f-e2c0-0120 1 4 -76 Unmanaged
000f-e2ff-ee10 6 1 -74 Unmanaged
5055-5555-5500 11 41 -67 Unmanaged
表1-2 display wlan ap name rrm-status命令显示信息描述表
Radio |
AP的射频id |
Basic BSSID |
Channel |
射频运行的信道 |
Tx Power |
当前射频运行的Tx功率 |
Chl |
信道,channel number的缩写形式 |
NbrCnt |
信道中找到的邻居数量,neighbor count的缩写形式 |
Load |
信道中观测到的负载,以百分比显示 |
Util |
信道利用率,utilization的缩写形式,以百分比显示 |
Intf |
信道中观测到的冲突,interference的缩写形式,以百分比显示 |
PER |
信道中观测到的包错误率,packet error rate的缩写形式,以百分比显示 |
Load |
信道中观测到的负载,以百分比显示 |
Retry |
重传率,retransmission rate的缩写形式,信道中发生重传的百分比 |
Radar |
雷达检测状态,radar detection status的缩写形式,信道中的反射状态 |
Nbr-BasicBSSID |
邻居AP的Radio接口的MAC地址 |
SignalStrengt |
AP信号强度,以dBm为单位 |
Type |
AP类型,如已管理的或未管理的 |
display wlan mesh calibrate-channel history [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display wlan mesh calibrate-channel history命令用来查看Mesh动态信道调整的历史信息。
# 查看Mesh动态信道调整的历史信息。
<Sysname> display wlan mesh calibrate-channel history
Mesh RRM History
Mesh-ID: outdoor Number of Radios: 2
AP Radio Chl(After/Before) Date/Time
mpp 1 149/auto 2009-10-10/13:16:19
mpp 1 153/149 2009-10-10/13:19:22
map 1 149/auto 2009-10-10/13:17:1
map 1 153/149 2009-10-10/13:19:24
表1-3 display wlan mesh calibrate-channel history命令显示信息描述表
Mesh-ID |
Mesh名称 |
Number of Radios |
所有AP启用的射频个数 |
AP |
AP名称 |
Radio |
射频ID |
Chl(After/Before) |
信道(调整后/调整前) |
Date/Time |
日期/时间 |
display wlan rrm [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display wlan rrm命令用来显示基本RRM配置参数。
# 显示RRM配置参数。
<Sysname> display wlan rrm
RRM Configuration
11a Configured Rates (Mbps)
Mandatory : 6, 12, 24
Supported : 9, 18, 36, 48, 54
Multicast : -NA-
Disabled : -NA-
11b Configured Rates (Mbps)
Mandatory : 1, 2
Supported : 5.5, 11
Multicast : -NA-
Disabled : -NA-
11g Configured Rates (Mbps)
Mandatory : 1, 2, 5.5, 11
Supported : 6, 9, 12, 18, 24, 36, 48, 54
Multicast : -NA-
Disabled : -NA-
Scan Configuration
Scan Type : Passive
Channel Mode : Auto
Report-Interval (s) : 10
11a Configuration
Automatic Channel Selection : Enabled
Automatic Power Selection : Enabled
Calibration Mode-Channel : -NA-
Mesh Calibration Mode-Channel: -NA-
Calibration Mode-Power : -NA-
Exclude-channel : -NA-
Calibration Interval (min) : 10
Interference Threshold (%) : 50
Tolerance Level (%) : 20
Adjacency Factor : 3
CRC-Error Threshold (%) : 20
Power Threshold (dBm) : -65
Minimum Power (dBm) : 1
max-bandwidth (kbps) : 30000
11bg Configuration
Calibration Interval (min) : 8
CRC-Error Threshold (%) : 11
11b Configuration
max-bandwidth (kbps) : 7000
11g Configuration
11g Protection : Disabled
11g Protection Mode : CTS-to-Self
11n Configuration
Mandatory Maximum MCS : -NA-
Supported Maximum MCS : 76
Multicast MCS : -NA-
11n Protection : Disabled
11n Protection Mode : CTS-to-Self
max-bandwidth (kbps) : 180000
11h configuration
Spectrum Management : Enabled
Power Constraint (dBm) : 5
Channel Set : All
Load Balance Configuration
Load Balancing Mode : Disabled
表1-4 display wlan rrm命令显示信息描述表
11a Configured Rates (Mbps) |
802.11a模式下的射频速率。802.11b和802.11g具有的相同字段表示相同的意思 |
Mandatory |
强制速率,AP必须支持其中一种速率 |
Supported |
支持速率,AP或客户端支持的扩展速率 |
Multicast |
组播速率, AP向客户端发送组播报文的速率,组播速率必须在强制速率中选取 |
Disabled |
禁用速率,禁止AP传输的速率 |
Scan Type |
扫描类型 |
Channel Mode |
射频的工作信道。如果信道模式设置为auto模式时,只扫描规定的信道;模式设置为all,会在所有信道进行Rogue检测扫描 |
Report-Interval (s) |
报告间隔 |
11a Configuration |
802.11a的配置信息。802.11b、802.11g和802.11n具有的相同字段表示相同的意思。 |
Automatic Channel Selection |
动态信道选择功能自动信道调整功能: · Enabled:开启 Disabled:关闭 |
Automatic Power Selection |
自动功率调整功能 · Enabled:开启 Disabled:关闭 |
Calibration Mode-Channel |
接入服务的动态信道选择功能自动信道调整触发方式: · Self-decisive:定时触发 Pronto:手动触发 -NA-:未配置 |
Mesh Calibration Mode-Channel |
Mesh自动信道调整触发方式: · Self-decisive:定时触发 · Pronto:手动触发 · -NA-:未配置 |
Calibration Mode-Power |
自动功率调整触发方式: · Self-decisive:定时触发 Pronto:手动触发 -NA-:未配置 |
Exclude-channel |
信道排除列表 |
Calibration Interval (min) |
校准间隔 |
Interference Threshold (%) |
信道冲突门限值 |
Tolerance Level (%) |
容限系数 |
Adjacency Factor |
邻居系数 |
CRC-Error Threshold (%) |
CRC错误门限值 |
Power Threshold (dBm) |
功率调整门限值 |
Minimum Power (dBm) |
最小发射功率 |
max-bandwidth (kbps) |
最大带宽参考值 |
11g Protection |
802.11g保护功能 · Enabled:开启802.11g保护功能 · Disabled:关闭802.11g保护功能 |
11g Protection Mode |
802.11g保护方式 · CTS-to-Self方式 · RTS/CTS方式 |
Mandatory Maximum MCS |
802.11n基本MCS集的最大MCS索引 |
Supported Maximum MCS |
802.11n支持MCS集的最大MCS索引 |
Multicast MCS |
802.11n的组播MCS索引 |
11n Protection |
802.11n保护功能 · Enabled:开启802.11g保护功能 · Disabled:关闭802.11g保护功能 |
11n Protection Mode |
802.11n保护方式 · CTS-to-Self方式 · RTS/CTS方式 |
11h Configuration |
802.11h的配置情况 |
Spectrum Management |
802.11a频段的频谱管理功能: · Enabled:开启 · Disabled:关闭 |
Power Constraint (dBm) |
802.11a射频的功率限制值 |
Channel Set |
Non-dot11h:信道组设置为非dot11h信道。配置此功能后,设备在初始信道选择时,只扫描属于配置国家代码的非dot11h信道 all:不限制选择的信道 |
Load Balance Configuration |
负载均衡的配置情况 |
Load Balancing Mode |
负载均衡模式 如果没有使能负载均衡,此字段将显示Disabled,并不会显示下面两个字段 |
Session Threshold (users) |
会话门限。当配置负载均衡模式为流量模式(traffic)时,此字段将显示:Traffic Threshold (%),表示流量门限 |
Session Gap (users) |
会话差值门限。当配置负载均衡模式为流量模式(traffic)时,此字段将显示:Traffic Gap (%),表示流量差值门限 |
display wlan rrm-calibration-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-id:RRM保持调整组的ID。
all:所有RRM保持调整组的配置。
【描述】
display wlan rrm-calibration-group命令用来显示RRM保持调整组的相关配置。
# 显示RRM保持调整组10的相关配置。
<Sysname> display wlan rrm-calibration-group 10
RRM Calibration Group Information
Group ID : 10
Description : office
Channel holddown time : 720 (in minutes)
Power holddown time : 60 (in minutes)
Group members : ap4-radio2,
ap3-radio2,
表1-5 display wlan rrm-calibration-group命令显示信息描述表
Group ID |
RRM保持调整组的ID |
RRM保持调整组的描述信息 |
Channel holddown time |
信道保持时长 |
Power holddown time |
功率保持时长 |
Group members |
加入RRM保持调整组的Radio |
dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
mandatory-rate:强制速率。
multicast-rate:组播速率,即AP向客户端发送组播报文的速率。组播速率必须在强制速率中选取。supported-rate:支持速率。
rate-value:可设置的射频速率如下:
· 6 Mbps
· 9 Mbps
· 12 Mbps
· 18 Mbps
· 24 Mbps
· 36 Mbps
· 48 Mbps
· 54 Mbps
【描述】
dot11a命令用来配置“802.11a”模式下的射频速率。undo dot11a用来恢复缺省情况。
缺省情况下,
· 禁用速率:无。
· 强制速率:6,12,24。
· 组播速率:自动从强制速率集中选取,即在所有客户端都支持的强制速率中选取发送速率,作为组播报文的发送速率。
· 支持速率:9,18,36,48,54。
# 配置802.11a模式的射频速率(禁用速率:12;支持速率:6;组播速率:18)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a disabled-rate 12
[Sysname-wlan-rrm] dot11a supported-rate 6
[Sysname-wlan-rrm] dot11a multicast-rate 18
dot11a adjacency-factor neighbor
undo dot11a adjacency-factor
RRM视图
【缺省级别】
2:系统级
neighbor:最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP,取值范围为1~16。
【描述】
dot11a adjacency-factor用来配置工作在802.11a频段上的最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP。undo dot11a adjacency-factor命令用来恢复缺省情况。
缺省情况下,最大邻居数为3,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第3位的邻居AP。
相关命令可参考dot11a calibrate-power threshold。
# 配置802.11a频段上最大邻居数为7,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第7位的邻居AP。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a adjacency-factor 7
undo dot11a calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-channel命令用来配置信道监测,以开启自动信道调整功能。undo dot11a calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置信道监测。
开启自动信道调整功能后,获取到的最大功率是以最终信道为准的,最终信道不同,获取到的最大功率就不同。
# 配置802.11a的信道监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel
dot11a calibrate-channel pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
name apname:AP名称。
radio radio-num:射频号。
【描述】
dot11a calibrate-channel pronto ap命令用来配置手动触发自动信道调整,即指定AP或所有AP开始信道优化。从RRM中获得的校准信道将在下一次优化间隔后应用到AP上。该命令不能取消。
缺省情况下,没有配置手动触发自动信道调整。
# 配置802.11a下所有AP开始信道优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel pronto ap all
undo dot11a calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-channel self-decisive命令用来配置定时触发自动信道调整(同时配置了信道监测)。undo dot11a calibrate-channel self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发自动信道调整。
# 配置定时触发自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-channel self-decisive
undo dot11a calibrate-power
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-power命令用来配置功率监测,以开启自动功率调整功能。undo dot11a calibrate-power命令用来恢复缺省情况。
缺省情况下,没有配置功率监测。
# 配置802.11a的功率监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power
dot11a calibrate-power min tx-power
undo dot11a calibrate-power min
RRM视图
【缺省级别】
2:系统级
tx-power:AP的最小发射功率,取值范围为1~20,单位为dBm。
【描述】
dot11a calibrate-power min用来配置AP的最小发射功率。undo dot11a calibrate-power min用来恢复缺省情况。
缺省情况下,AP的最小发射功率为1dBm。
# 配置AP的最小发射功率为10。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power min 10
dot11a calibrate-power pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
all :所有AP。
name apname:AP名称。
【描述】
dot11a calibrate-power pronto ap命令用来配置手动触发自动功率调整,即指定AP或所有AP开始功率优化。从RRM中获得的校准功率将在下一次优化间隔后应用到AP上。该命令不能取消。
缺省情况下,没有配置手动触发自动功率调整。
# 配置802.11a下AP1和射频1开始功率优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power pronto ap name ap1 radio 1
undo dot11a calibrate-power self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11a calibrate-power self-decisive命令用来配置定时触发自动功率调整(同时配置了功率监测)。undo dot11a calibrate-power self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发自动功率调整。
# 配置定时触发自动功率调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power self-decisive
dot11a calibrate-power threshold value
undo dot11a calibrate-power threshold
RRM视图
【缺省级别】
2:系统级
value:功率调整门限值,取值范围为50~90,单位为dBm,代表功率范围为-90~-50。
【描述】
dot11a calibrate-power threshold用来配置功率调整门限值。undo dot11a calibrate-power threshold用来恢复缺省情况。
缺省情况下,功率调整门限值为65。
相关命令可参考dot11a adjacency-factor。
# 配置功率调整门限值为70。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibrate-power threshold 70
dot11a calibration-interval minutes
undo dot11a calibration-interval
RRM视图
【缺省级别】
2:系统级
minutes:校准间隔,取值范围为3~180,单位为分钟。
【描述】
dot11a calibration-interval命令用来配置校准间隔为指定值。undo dot11a calibration-interval命令用来恢复缺省情况。
缺省情况下,校准间隔是8分钟。RRM机制会在校准间隔后周期运行。
需要注意的是,校准间隔对Mesh网络信道优化和无线服务的信道以及功率优化都会起作用。
# 配置802.11a的校准间隔为10分钟。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a calibration-interval 10
dot11a crc-error-threshold percent
undo dot11a crc-error-threshold
RRM视图
【缺省级别】
2:系统级
percent:门限,以百分比表示,取值范围为10~100。
【描述】
dot11a crc-error-threshold命令用来配置CRC错误门限值。undo dot11a crc-error-threshold命令用来恢复缺省情况。
缺省情况下,CRC错误门限值为20。
# 配置802.11a的CRC错误门限为50%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a crc-error-threshold 50
dot11a exclude-channel channel-list
undo dot11a exclude-channel { channel-list | all }
RRM视图
【缺省级别】
2:系统级
channel-list:信道列表,表示方式为channel-list = { channel }& <1-10>,channel的取值范围为设备支持的所有5GHz信道,&<1-10>表示前面的参数最多可以重复输入10次。
all:所有信道。
【描述】
dot11a exclude-channel命令用来配置5GHz信道排除列表。undo dot11a exclude-channel用来删除5GHz信道列表中的信道。
缺省情况下,信道排除列表中不存在任何信道。
本命令的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况。
# 将信道149和153添加到5GHz信道排除列表。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a exclude-channel 149 153
dot11a interference-threshold percent
undo dot11a interference-threshold
RRM视图
【缺省级别】
2:系统级
percent:信道冲突门限,以百分比表示,取值范围为40~100。
【描述】
dot11a interference-threshold命令用来配置信道冲突门限值。undo dot11a interference-threshold命令用来恢复缺省情况。
缺省情况下,信道冲突门限值为50。
开启信道调整功能后,如果工作信道中的信道冲突高于设置的冲突门限值,设备会执行信道切换。
# 配置802.11a的信道冲突门限是60%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a interference-threshold 60
dot11a max-bandwidth 11a-bandwidth
undo dot11a max-bandwidth
RRM视图
【缺省级别】
2:系统级
11a-bandwidth:802.11a的带宽参考值,单位为kbps。取值范围为16~30000。
【描述】
dot11a max-bandwidth命令用来配置802.11a的最大带宽参考值。undo dot11a max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11a的最大带宽参考值为30000kbps。
# 配置802.11a的最大带宽参考值为15000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a max-bandwidth 15000
dot11a tolerance-level percentage
undo dot11a tolerance-level
RRM视图
【缺省级别】
2:系统级
percentage:容限系数,以百分比表示,取值范围为15~45。
【描述】
dot11a tolerance-level命令用来配置频段的容限系数。undo dot11a tolerance-level命令用来恢复缺省情况。
当冲突门限超过门限值时,系统会选择新的信道,但只有在新的信道和旧信道的信道质量差超过容限系数时,新的信道才会真正被应用。
缺省情况下,容限系数的值为20。
# 配置802.11a的容限系数为25%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a tolerance-level 25
dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
· 1 Mbps
· 2 Mbps
· 5.5 Mbps
· 11 Mbps
【描述】
dot11b命令用来配置“802.11b”模式下的射频速率。undo dot11b用来恢复缺省情况。
缺省情况下,
· 禁用速率:无。
· 强制速率:1,2。
· 支持速率:5.5,11。
# 配置802.11b模式的射频速率(禁用速率:1;支持速率:11;组播速率:11)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1
[Sysname-wlan-rrm] dot11b supported-rate 11
[Sysname-wlan-rrm] dot11b multicast-rate 1
dot11b max-bandwidth 11b-bandwidth
undo dot11b max-bandwidth
RRM视图
【缺省级别】
2:系统级
11b-bandwidth:802.11b的带宽参考值,单位为kbps。取值范围为16~7000。
【描述】
dot11b max-bandwidth命令用来配置802.11b的最大带宽参考值。undo dot11b max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11b的最大带宽参考值为7000kbps。
# 配置802.11b的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b max-bandwidth 6000
dot11bg adjacency-factor neighbor
undo dot11bg adjacency-factor
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg adjacency-factor用来配置工作在802.11b/g频段上的最大邻居数,并指定需要和功率调整门限值进行比较的邻居AP。undo dot11bg adjacency-factor命令用来恢复缺省情况。
相关命令可参考dot11bg calibrate-power threshold。
# 配置802.11g频段上最大邻居数为7,需要和功率调整门限值进行比较的AP为在所有邻居AP中信号强度排在第7位的邻居AP。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg adjacency-factor 7
undo dot11bg calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-channel命令用来配置信道监测,以开启自动信道调整功能。undo dot11bg calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置信道监测。
#配置802.11bg的信道监测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel
dot11bg calibrate-channel pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
all :所有AP。
name apname:AP名称。
【描述】
dot11bg calibrate-channel pronto ap命令用来配置手动触发自动信道调整,即指定AP或所有AP开始信道优化。从RRM中获得的校准信道将在下一次优化间隔后应用到AP上。
# 配置AP1和射频1开始信道优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel pronto ap name ap1 radio 1
undo dot11bg calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-channel self-decisive命令用来配置定时触发自动信道调整(同时配置了信道监测)。undo dot11bg calibrate-channel self-decisive命令用来恢复缺省情况。
# 配置定时触发自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-channel self-decisive
dot11bg calibrate-power min tx-power
undo dot11bg calibrate-power min
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibrate-power min命令用来配置AP的最小发射功率。undo dot11bg calibrate-power min命令用来恢复缺省情况。
# 配置AP的最小发射功率为10。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power min 10
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-power命令用来配置功率监测,以开启自动功率调整功能。undo dot11bg calibrate-power命令用来恢复缺省情况。
缺省情况下,没有配置功率监测。
#配置802.11bg的功率监测。
[Sysname] wlan rrm
dot11bg calibrate-power pronto ap { all | name apname radio radio-num }
RRM视图
【缺省级别】
2:系统级
name apname:AP名称,为1~32个字符的字符串,不区分大小写。
【描述】
dot11bg calibrate-power pronto ap命令用来配置手动触发自动功率调整,即指定名称的AP或所有AP开始功率优化。从RRM中获得的校准功率将在下一次优化间隔后应用到AP上。
# 配置802.11bg下所有AP开始功率优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power pronto all
undo dot11bg calibrate-power self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11bg calibrate-power self-decisive命令用来配置定时触发自动功率调整(同时配置了功率监测)。undo dot11bg calibrate-power self-decisive命令用来恢复缺省情况。
# 配置定时触发自动功率调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power self-decisive
dot11bg calibrate-power threshold value
undo dot11bg calibrate-power threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibrate-power threshold命令用来配置功率调整门限值。undo dot11bg calibrate-power threshold命令用来恢复缺省情况。
缺省情况下,功率调整门限值为65。
相关命令可参考dot11bg adjacency-factor。
# 配置功率调整门限值为70。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibrate-power threshold 70
dot11bg calibration-interval minutes
undo dot11bg calibration-interval
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg calibration-interval命令用来配置校准间隔。undo dot11bg calibration-interval命令用来恢复缺省情况。
# 配置802.11bg的校准间隔为10分钟。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg calibration-interval 10
dot11bg crc-error-threshold percent
undo dot11bg crc-error-threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg crc-error-threshold命令用来配置CRC错误门限值。undo dot11bg crc-error-threshold命令用来恢复缺省情况。
缺省情况下,CRC错误门限值为20。
# 配置802.11bg的CRC错误门限为50%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg crc-error-threshold 50
dot11bg exclude-channel channel-list
undo dot11bg exclude-channel { channel-list | all }
RRM视图
【缺省级别】
2:系统级
channel-list:信道列表,表示方式为channel-list = { channel }& <1-10>,channel的取值范围为设备支持的所有2.4GHz信道,&<1-10>表示前面的参数最多可以重复输入10次。
all:所有信道。
【描述】
dot11 bg exclude-channel命令用来配置2.4GHz信道排除列表。undo dot11 bg exclude-channel用来删除2.4GHz信道列表中的信道。
# 将信道2和3添加到2.4GHz信道排除列表。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg exclude-channel 2 3
dot11bg interference-threshold percent
undo dot11bg interference-threshold
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg interference-threshold命令用来配置信道冲突门限值。undo dot11bg interference-threshold命令用来恢复缺省情况。
缺省情况下,信道冲突门限值为50。
# 配置802.11g的信道冲突门限为60%。
[Sysname] wlan rrm
dot11bg tolerance-level percentage
undo dot11bg tolerance-level
RRM视图
【缺省级别】
2:系统级
【描述】
dot11bg tolerance-level命令用来设置频段的容限系数。undo dot11bg tolerance-level命令用来恢复缺省情况。
缺省情况下,容限系数的值为20。
# 设置802.11g的容限系数设为25%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11bg tolerance-level 25
dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | multicast-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
· 1 Mbps
· 2 Mbps
· 5.5 Mbps
· 6 Mbps
· 9 Mbps
· 11 Mbps
· 12 Mbps
· 18 Mbps
· 24 Mbps
· 36 Mbps
· 48 Mbps
· 54 Mbps
【描述】
dot11g命令用来配置“802.11g”模式下的射频速率。undo dot11g用来恢复缺省情况。
缺省情况下,
· 禁用速率:无。
· 强制速率:1,2,5.5,11。
· 支持速率:6,9,12,18,24,36,48,54。
# 配置802.11g模式的射频速率(禁用速率:2,36;支持速率:54;组播速率:11)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g supported-rate 54
[Sysname-wlan-rrm] dot11g multicast-rate 11
dot11g max-bandwidth 11g-bandwidth
undo dot11g max-bandwidth
RRM视图
【缺省级别】
2:系统级
11g-bandwidth:802.11g的带宽参考值,单位为kbps。取值范围为16~30000。
【描述】
dot11g max-bandwidth命令用来配置802.11g的最大带宽参考值。undo dot11g max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11g的最大带宽参考值为30000kbps。
# 配置802.11g的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g max-bandwidth 6000
undo dot11g protection enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11g protection enable命令用来开启802.11g保护功能。undo dot11g protection enable命令用来恢复缺省情况。
缺省情况下,802.11g保护功能处于关闭状态。
# 开启802.11g保护功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11g protection-mode { cts-to-self | rts-cts }
undo dot11g protection-mode
RRM视图
【缺省级别】
2:系统级
cts-to-self:CTS-to-Self方式。
rts-cts:RTS/CTS方式。
【描述】
dot11g protection-mode命令用来配置802.11g保护方式。undo dot11g protection-mode命令用来恢复缺省情况。
缺省情况下,802.11g保护方式为CTS-to-Self。
# 配置802.11g保护方式为RTS/CTS。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection-mode rts-cts
dot11n mandatory maximum-mcs index
undo dot11n mandatory maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定802.11n基本MCS集的最大MCS索引,取值范围为0~最大MCS索引,目前MCS最大索引值为76。
【描述】
dot11n mandatory maximum-mcs命令用来配置802.11n基本MCS集的最大MCS索引。undo dot11n mandatory maximum-mcs命令用来取消已有配置。
缺省情况下,没有配置任何基本MCS集。
需要注意的是:如果用户在指定Radio接口下配置使能了client dot11n-only命令,则必须配置基本MCS集。
# 配置802.11n的基本MCS集的最大MCS索引为15。
<sysname> system-view
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 15
dot11n max-bandwidth 11n-bandwidth
undo dot11n max-bandwidth
RRM视图
【缺省级别】
2:系统级
11n-bandwidth:802.11n的带宽参考值,单位为kbps。取值范围为16~180000。
【描述】
dot11n max-bandwidth命令用来配置802.11n的最大带宽参考值。undo dot11n max-bandwidth命令用来恢复缺省情况。
缺省情况下,802.11n的最大带宽参考值为18000kbps。
# 配置802.11n的最大带宽参考值为6000。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n max-bandwidth 6000
dot11n multicast-rate index
undo dot11n multicast-rate
RRM视图
【缺省级别】
2:系统级
index:组播MCS索引,取值范围为0~76。
【描述】
dot11n multicast-rate命令用来配置802.11n的组播MCS索引。undo dot11n multicast-rate用来恢复缺省情况。
缺省情况下,没有配置802.11n的组播MCS索引。
· 对于802.11n模式,当所有的客户端都使用802.11n射频时,才使用组播MCS索引,如果存在非802.11n客户端,则使用基础模式的组播速率。
· 在配置组播MCS索引时,如果配置的值超过了射频支持的最大值,则实际采用的组播MCS索引值为射频支持的最大值。
· 组播MCS起作用时,无论是20M模式还是40M模式,统一采用20M模式对应的速率进行发送。
# 配置802.11n的组播MCS索引为76。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n multicast-rate 76
undo dot11n protection enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
dot11n protection enable命令用来开启802.11n保护功能,进行非802.11n的频谱重叠检测。undo dot11n protection enable 命令用来恢复缺省情况。
缺省情况下,802.11n保护功能处于关闭状态。
# 开启802.11n保护功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection enable
dot11n protection-mode { cts-to-self | rts-cts }
undo dot11n protection-mode
RRM视图
【缺省级别】
2:系统级
rts-cts:RTS/CTS方式。
【描述】
dot11n protection-mode命令用来配置802.11n保护方式。undo dot11n protection-mode命令用来恢复缺省情况。
缺省情况下,802.11n保护方式为CTS-to-Self。
# 配置802.11n保护方式为RTS/CTS。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11n protection-mode rts-cts
undo mesh calibrate-channel
RRM视图
【缺省级别】
2:系统级
无
【描述】
mesh calibrate-channel命令用来配置信道检测。undo mesh calibrate-channel命令用来恢复缺省情况。
缺省情况下,没有配置信道检测。
# 配置信道检测。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel
mesh calibrate-channel pronto mesh-profile { mesh-profile-number | all }
RRM视图
【缺省级别】
2:系统级
mesh-profile-number:Mesh Profile号,取值范围为1~32。
all:所有Mesh Profile。
【描述】
mesh calibrate-channel pronto命令用来配置手动触发Mesh自动信道调整,即在指定的Mesh Profile或所有的Mesh Profile上开始信道优化。从RRM中获得的校准信道将在下一次优化间隔后应用到Mesh Profile上。
缺省情况下,没有配置手动触发Mesh自动信道调整。
# 配置手动触发Mesh自动信道调整,在所有的Mesh Profile上开始信道优化。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel pronto mesh-profile all
undo mesh calibrate-channel self-decisive
RRM视图
【缺省级别】
2:系统级
无
【描述】
mesh calibrate-channel self-decisive命令用来配置定时触发Mesh自动信道调整。undo mesh calibrate-channel self-decisive命令用来恢复缺省情况。
缺省情况下,没有配置定时触发Mesh自动信道调整。
# 配置定时触发Mesh自动信道调整。
[Sysname] wlan rrm
[Sysname-wlan-rrm] mesh calibrate-channel self-decisive
dot11n support maximum-mcs index
undo dot11n support maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定802.11n支持MCS集的最大MCS索引,取值范围为0~最大MCS索引,目前MCS最大索引为76。
【描述】
dot11n support maximum-mcs命令用来配置802.11n支持MCS集的最大MCS索引。undo dot11n support maximum-mcs命令用来恢复缺省情况。
缺省情况下,支持MCS集的索引为76。
需要注意的是,用该命令指定的最大MCS索引不能小于dot11n mandatory maximum-mcs命令配置的基本MCS集最大索引。
# 配置802.11n的支持MCS集最大索引为25。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
power-constraint power-constraint
undo power-constraint
RRM视图
【缺省级别】
2:系统级
power-constraint:用于指定对无线客户端进行功率限制的功率值,取值范围为0~30,单位为dBm。
【描述】
power-constraint命令用于对802.11a无线客户端的发射功率进行限制。配置功率限制前需要先开启频谱管理功能。配置了功率限制功能后,无线客户端的发射功率等于无线客户端的当前发射功率减去power-constraint。undo power-constraint用来恢复缺省情况。
缺省情况下,对于802.11a的无线客户端的发射功率的限制为0dBm。
相关配置可参考命令spectrum-management enable。
# 配置802.11a无线客户端的发射功率的限制为5dBm。
[Sysname] wlan rrm
[Sysname-wlan-rrm] power-constraint 5
power holddown-time minutes
undo power holddown-time
RRM保持调整组视图
【缺省级别】
2:系统级
minutes:功率保持时长,表示功率在每次调整后(包括手动触发、定时触发)的指定时间内将保持不变,取值范围为10~1440,单位为分钟。
【描述】
power holddown-time命令用来配置功率保持时长。undo power holddown-time命令用来恢复缺省情况。
缺省情况下,功率保持时长为60分钟。
# 为RRM保持调整组10配置功率保持时长为600分钟。
[Sysname-wlan-rc-group-10] power holddown-time 600
scan channel { all | auto }
undo scan channel
RRM视图
【缺省级别】
2:系统级
all:配置为全部扫描模式,射频的所有信道都将被扫描。
auto:配置为自动扫描模式,属于国家码的所有的信道都将被扫描。
【描述】
scan channel命令用来配置扫描模式。undo scan channel命令用来恢复缺省情况。
缺省情况下,扫描模式为自动扫描。
# 配置扫描模式为全部扫描。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan channel all
scan type { active | passive }
undo scan type
RRM视图
【缺省级别】
2:系统级
active:配置为主动扫描类型。
passive:配置为被动扫描类型。
【描述】
scan type命令用来配置扫描类型。undo scan type命令用来恢复缺省情况。
缺省情况下,扫描类型为被动扫描。
# 配置扫描类型为主动扫描。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan type active
scan report-interval seconds
undo scan report-interval
RRM视图
【缺省级别】
2:系统级
seconds:报告间隔,取值范围为5~120,单位为秒。
【描述】
scan report-interval命令用来配置扫描报告间隔为指定值。undo scan report-interval命令用来恢复缺省情况。
缺省情况下,扫描报告间隔为10秒。
# 配置扫描报告间隔为20秒。
[Sysname] wlan rrm
[Sysname-wlan-rrm] scan report-interval 20
undo spectrum-management enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
spectrum-management enable命令用于开启802.11a频段的频谱管理功能。undo spectrum-management enable命令用来恢复缺省情况。缺省情况下,频谱管理功能处于关闭状态。
当WLAN子系统的频谱管理功能开启后,WLAN子系统会通告AP的功率能力和功率限制,该BSS下的所有设备都应根据所在地区的规定遵守AP通告的功率限制。
# 开启频谱管理功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
wlan rrm
无
【描述】
wlan rrm命令用来进入RRM(射频资源管理)视图。
在该视图下,用户可以进行WLAN射频资源管理的相关配置。
# 进入RRM视图。
[Sysname] wlan rrm
[Sysname-rrm]
wlan rrm-calibration-group group-id
undo wlan rrm-calibration-group { group-id | all }
【缺省级别】
2:系统级
group-id:RRM保持调整组的ID。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:所有的RRM保持调整组。
【描述】
wlan rrm-calibration-group命令用来创建RRM保持调整组,并进入RRM保持调整组视图。undo wlan rrm-calibration-group命令用来删除已创建的RRM保持调整组。
缺省情况下,不存在RRM保持调整组。
# 创建ID为10的RRM保持调整组。
负载均衡组视图
【缺省级别】
2:系统级
ap-name:加入负载均衡组的AP名称。为1~32个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”和连接符“-”,不区分大小写。加入负载均衡组的AP必须已经存在。
radio-number:将AP的第几个Radio加入负载均衡组。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:删除负载均衡组中所有的Radio。
【描述】
ap radio命令用来将AP的Radio加入到负载均衡组中。undo ap ap-name命令用来删除负载均衡组中的Radio。
缺省情况下,负载均衡组中不存在任何AP的Radio。
删除负载均衡组中的Raido时,如果使用undo ap ap-name命令(即不指定radio radio-number参数时),表示删除负载均衡组中指定AP的所有Radio。
# 将ap1的第2个Radio加入到ID为10的负载均衡组中。
[Sysname] wlan load-balance-group 10
[Sysname-wlan-lb-group-10] ap ap1 radio 2
# 删除ID为10的负载均衡组中的所有Radio。
[Sysname-wlan-lb-group-10] undo ap all
# 删除负载均衡组10中ap1的所有Radio。
[Sysname-wlan-lb-group-10] undo ap ap1
# 删除负载均衡组10中ap1的第2个Radio。
[Sysname-wlan-lb-group-10] undo ap ap1 radio 2
负载均衡组视图
【缺省级别】
2:系统级
text:负载均衡组的描述信息,为1~64个字符的字符串,可以包含字母、数字和下划线,区分大小写。
【描述】
description命令用来配置负载均衡组的描述信息。undo description命令用来删除描述信息。
缺省情况下,负载均衡组没有描述信息。
# 配置负载均衡组10的描述信息为marketing。
[Sysname-wlan-lb-group10] description marketing
load-balance access-denial access-denial
undo load-balance access-denial
RRM视图
【缺省级别】
2:系统级
access-denial:拒绝客户端关联请求的最大次数,取值范围为2~10。
【描述】
load-balance access-denial命令用来配置设备拒绝客户端关联请求的最大次数。undo load-balance access-denial命令用来恢复缺省情况。
缺省情况下,设备拒绝客户端关联请求的最大次数为10。
# 配置设备拒绝客户端关联请求的最大次数为4。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance access-denial 4
load-balance rssi-threshold rssi-threshold
undo load-balance rssi-threshold
RRM视图
【缺省级别】
2:系统级
rssi-threshold:负载均衡RSSI门限值,取值范围为5~100。
【描述】
load-balance rssi-threshold命令用来配置负载均衡RSSI门限。undo load-balance rssi-threshold命令用来恢复缺省情况。
缺省情况下,负载均衡RSSI门限值为25。
# 配置负载均衡RSSI门限值为40。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance rssi-threshold 40
display wlan load-balance-group { group-id | all } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
group-id:负载均衡组的ID。不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
all:显示所有负载均衡组的配置。
【描述】
display wlan load-balance-group命令用来显示负载均衡组的相关配置。
# 显示负载均衡组10的相关配置。
<Sysname> display wlan load-balance-group 10
Load Balance Group Information
Group ID : 10
Description : AA
Group members : ap5-radio2,
ap4-radio2,
ap3-radio2,
ap2-radio2,
表1-6 display wlan load-balance-group命令显示信息描述表
Group ID |
负载均衡组的ID |
负载均衡组的描述信息 |
Group members |
加入负载均衡组的Radio |
load-balance session value [ gap gap-value ]
undo load-balance
RRM视图
【缺省级别】
2:系统级
value:会话门限,取值范围为2~40。
gap gap-value:会话差值门限,取值范围为1~8,缺省值为4。
【描述】
load-balance session命令用来配置负载均衡模式为会话模式,并配置会话门限值和会话差值门限。如果当前连接的用户数量同时达到会话门限和会话差值门限,则AP会启动负载均衡。undo load-balance命令用来禁用配置的负载均衡模式。
缺省情况下,没有开启负载均衡功能。
# 配置会话门限值为7。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7
# 配置会话门限值为7,会话差值门限为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance session 7 gap 5
load-balance traffic value [ gap gap-value ]
undo load-balance
RRM视图
【缺省级别】
2:系统级
value:流量门限,以百分比表示,取值范围为10~80。
gap gap-value:流量差值门限,以百分比表示,取值范围为10~40,缺省值为20。
【描述】
load-balance traffic命令用来配置负载均衡模式为流量模式,并配置流量门限值和流量差值门限。如果当前的流量同时达到流量门限和流量差值门限,则AP会启动负载均衡。undo load-balance命令用来禁用配置的负载均衡模式。
缺省情况下,没有开启负载均衡功能。
需要注意的是:开启802.11g保护功能后会占用一定的设备带宽,这在一定程度上降低了转发性能。若用户已开启了802.11g保护功能,那么再配置负载均衡时,应该考虑802.11g保护功能的影响,适当调低负载均衡设定的流量门限(带宽)值。
相关配置可参考命令dot11g protection enable。
# 配置流量门限值为50%。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 50
# 配置流量门限值为20%,流量差值门限为25。
[Sysname] wlan rrm
[Sysname-wlan-rrm] load-balance traffic 20 gap 25
wlan load-balance-group group-id
undo load-balance-group { group-id | all }
【缺省级别】
2:系统级
all:删除所有的负载均衡组。
【描述】
wlan load-balance-group命令用来创建负载均衡组,并进入负载均衡组视图。undo wlan load-balance-group命令用来删除已创建的负载均衡组。
缺省情况下,不存在负载均衡组。
# 创建ID为10的负载均衡组。
频谱导航配置命令的支持情况与设备的型号有关,请参见“命令参考导读”中的“命令行及参数差异情况。
band-navigation aging-time aging-time
undo band-navigation aging-time
RRM视图
【缺省级别】
2:系统级
aging-time:客户端信息的老化时间,取值范围为10~600,单位为秒。
【描述】
band-navigation aging-time命令用来配置客户端信息的老化时间。undo band-navigation aging-time命令用来恢复缺省情况。
缺省情况下,客户端信息的老化时间为180秒。
# 配置客户端信息的老化时间为50秒。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation aging-time 50
band-navigation balance access-denial access-denial
undo band-navigation balance access-denial
RRM视图
【缺省级别】
2:系统级
access-denial:设备拒绝5GHz客户端关联请求的最大次数,取值范围为1~10。
【描述】
band-navigation balance access-denial命令用来配置设备拒绝5GHz客户端关联请求的最大次数。undo band-navigation balance access-denial命令用来恢复缺省情况。
缺省情况下,不进行拒绝。
AP的5GHz射频上的客户端数目已经过载时,如果客户端仍反复向AP的5GHz射频发起关联请求,且AP拒绝客户端关联请求次数达到/超过设定的最大拒绝关联请求次数,那么该AP会认为此时该客户端不能连接到其它的AP,同时不能连接到该AP的2.4GHz射频上(即此客户端只支持5GHz频段),在这种情况下,AP上的5GHz射频也会接受该客户端的关联请求。
# 配置设备拒绝5GHz客户端关联请求的最大次数为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance access-denial 5
band-navigation balance session session [ gap gap ]
undo band-navigation balance session
RRM视图
【缺省级别】
2:系统级
session:5GHz射频上客户端连接数门限,取值范围为2~40。
gap:客户端连接数差值门限,即gap = 5GHz射频上客户端的数量-2.4GHz射频上客户端的数量,取值范围为1~8,缺省的差值门限为4。
【描述】
band-navigation balance session命令用来配置频谱导航负载均衡门限。undo band-navigation balance session命令用来恢复缺省情况。
缺省情况下,频谱导航的负载均衡功能关闭。
# 配置客户端连接数门限为10,差值门限为5。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation balance session 10 gap 5
undo band-navigation enable
RRM视图
【缺省级别】
2:系统级
无
【描述】
band-navigation enable命令用来开启全局频谱导航功能。undo band-navigation enable用来关闭全局频谱导航功能。
缺省情况下,全局频谱导航功能处于关闭状态。
只有同时开启全局和AP频谱导航功能,频谱导航功能才能在指定AP上生效。
# 开启全局频谱导航功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation enable
AP模板视图
【缺省级别】
2:系统级
无
【描述】
band-navigation enable命令用来开启指定AP的频谱导航功能。undo band-navigation enable用来关闭指定AP的频谱导航功能。只有同时支持2.4G和5G的AP才支持频谱导航功能。
缺省情况下,AP频谱导航功能处于开启状态。
· 只有同时开启全局和指定AP的频谱导航功能,频谱导航功能才能在指定AP上生效。
· 只有同时支持2.4G和5G的AP才支持频谱导航功能。
# 开启AP 1的频谱导航功能。
[Sysname] wlan ap ap1 model WA2620E-AGN
[Sysname-wlan-ap-ap1] band-navigation enable
band-navigation rssi-threshold rssi-threshold
undo band-navigation rssi-threshold
RRM视图
【缺省级别】
2:系统级
rssi-threshold:频谱导航RSSI门限值,取值范围为5~100。
【描述】
band-navigation rssi-threshold命令用来配置频谱导航RSSI门限值。undo band-navigation rssi-threshold命令用来恢复缺省情况。
缺省情况下,频谱导航RSSI门限值为15。
只有当AP的5GHz射频上检测到客户端的RSSI值达到/超过配置的门限值,AP才会引导其优先接入AP的5GHz射频。若检测到客户端的RSSI值低于配置的门限值,则不会将此客户端导航至5GHz射频。
# 配置频谱导航RSSI门限值为40。
[Sysname] wlan rrm
[Sysname-wlan-rrm] band-navigation rssi-threshold 40
